2012-02-29Linux 3.2.9v3.2.9Greg Kroah-Hartman
2012-02-29cdrom: use copy_to_user() without the underscoresDan Carpenter
commit 822bfa51ce44f2c63c300fdb76dc99c4d5a5ca9f upstream. "nframes" comes from the user and "nframes * CD_FRAMESIZE_RAW" can wrap on 32 bit systems. That would have been ok if we used the same wrapped value for the copy, but we use a shifted value. We should just use the checked version of copy_to_user() because it's not going to make a difference to the speed. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29epoll: limit pathsJason Baron
commit 28d82dc1c4edbc352129f97f4ca22624d1fe61de upstream. The current epoll code can be tickled to run basically indefinitely in both loop detection path check (on ep_insert()), and in the wakeup paths. The programs that tickle this behavior set up deeply linked networks of epoll file descriptors that cause the epoll algorithms to traverse them indefinitely. A couple of these sample programs have been previously posted in this thread: https://lkml.org/lkml/2011/2/25/297. To fix the loop detection path check algorithms, I simply keep track of the epoll nodes that have been already visited. Thus, the loop detection becomes proportional to the number of epoll file descriptor and links. This dramatically decreases the run-time of the loop check algorithm. In one diabolical case I tried it reduced the run-time from 15 mintues (all in kernel time) to .3 seconds. Fixing the wakeup paths could be done at wakeup time in a similar manner by keeping track of nodes that have already been visited, but the complexity is harder, since there can be multiple wakeups on different cpus...Thus, I've opted to limit the number of possible wakeup paths when the paths are created. This is accomplished, by noting that the end file descriptor points that are found during the loop detection pass (from the newly added link), are actually the sources for wakeup events. I keep a list of these file descriptors and limit the number and length of these paths that emanate from these 'source file descriptors'. In the current implemetation I allow 1000 paths of length 1, 500 of length 2, 100 of length 3, 50 of length 4 and 10 of length 5. Note that it is sufficient to check the 'source file descriptors' reachable from the newly added link, since no other 'source file descriptors' will have newly added links. This allows us to check only the wakeup paths that may have gotten too long, and not re-check all possible wakeup paths on the system. In terms of the path limit selection, I think its first worth noting that the most common case for epoll, is probably the model where you have 1 epoll file descriptor that is monitoring n number of 'source file descriptors'. In this case, each 'source file descriptor' has a 1 path of length 1. Thus, I believe that the limits I'm proposing are quite reasonable and in fact may be too generous. Thus, I'm hoping that the proposed limits will not prevent any workloads that currently work to fail. In terms of locking, I have extended the use of the 'epmutex' to all epoll_ctl add and remove operations. Currently its only used in a subset of the add paths. I need to hold the epmutex, so that we can correctly traverse a coherent graph, to check the number of paths. I believe that this additional locking is probably ok, since its in the setup/teardown paths, and doesn't affect the running paths, but it certainly is going to add some extra overhead. Also, worth noting is that the epmuex was recently added to the ep_ctl add operations in the initial path loop detection code using the argument that it was not on a critical path. Another thing to note here, is the length of epoll chains that is allowed. Currently, eventpoll.c defines: /* Maximum number of nesting allowed inside epoll sets */ #define EP_MAX_NESTS 4 This basically means that I am limited to a graph depth of 5 (EP_MAX_NESTS + 1). However, this limit is currently only enforced during the loop check detection code, and only when the epoll file descriptors are added in a certain order. Thus, this limit is currently easily bypassed. The newly added check for wakeup paths, stricly limits the wakeup paths to a length of 5, regardless of the order in which ep's are linked together. Thus, a side-effect of the new code is a more consistent enforcement of the graph depth. Thus far, I've tested this, using the sample programs previously mentioned, which now either return quickly or return -EINVAL. I've also testing using the piptest.c epoll tester, which showed no difference in performance. I've also created a number of different epoll networks and tested that they behave as expectded. I believe this solves the original diabolical test cases, while still preserving the sane epoll nesting. Signed-off-by: Jason Baron <jbaron@redhat.com> Cc: Nelson Elhage <nelhage@ksplice.com> Cc: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29epoll: ep_unregister_pollwait() can use the freed pwq->wheadOleg Nesterov
commit 971316f0503a5c50633d07b83b6db2f15a3a5b00 upstream. signalfd_cleanup() ensures that ->signalfd_wqh is not used, but this is not enough. eppoll_entry->whead still points to the memory we are going to free, ep_unregister_pollwait()->remove_wait_queue() is obviously unsafe. Change ep_poll_callback(POLLFREE) to set eppoll_entry->whead = NULL, change ep_unregister_pollwait() to check pwq->whead != NULL under rcu_read_lock() before remove_wait_queue(). We add the new helper, ep_remove_wait_queue(), for this. This works because sighand_cachep is SLAB_DESTROY_BY_RCU and because ->signalfd_wqh is initialized in sighand_ctor(), not in copy_sighand. ep_unregister_pollwait()->remove_wait_queue() can play with already freed and potentially reused ->sighand, but this is fine. This memory must have the valid ->signalfd_wqh until rcu_read_unlock(). Reported-by: Maxime Bizon <mbizon@freebox.fr> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29epoll: introduce POLLFREE to flush ->signalfd_wqh before kfree()Oleg Nesterov
commit d80e731ecab420ddcb79ee9d0ac427acbc187b4b upstream. This patch is intentionally incomplete to simplify the review. It ignores ep_unregister_pollwait() which plays with the same wqh. See the next change. epoll assumes that the EPOLL_CTL_ADD'ed file controls everything f_op->poll() needs. In particular it assumes that the wait queue can't go away until eventpoll_release(). This is not true in case of signalfd, the task which does EPOLL_CTL_ADD uses its ->sighand which is not connected to the file. This patch adds the special event, POLLFREE, currently only for epoll. It expects that init_poll_funcptr()'ed hook should do the necessary cleanup. Perhaps it should be defined as EPOLLFREE in eventpoll. __cleanup_sighand() is changed to do wake_up_poll(POLLFREE) if ->signalfd_wqh is not empty, we add the new signalfd_cleanup() helper. ep_poll_callback(POLLFREE) simply does list_del_init(task_list). This make this poll entry inconsistent, but we don't care. If you share epoll fd which contains our sigfd with another process you should blame yourself. signalfd is "really special". I simply do not know how we can define the "right" semantics if it used with epoll. The main problem is, epoll calls signalfd_poll() once to establish the connection with the wait queue, after that signalfd_poll(NULL) returns the different/inconsistent results depending on who does EPOLL_CTL_MOD/signalfd_read/etc. IOW: apart from sigmask, signalfd has nothing to do with the file, it works with the current thread. In short: this patch is the hack which tries to fix the symptoms. It also assumes that nobody can take tasklist_lock under epoll locks, this seems to be true. Note: - we do not have wake_up_all_poll() but wake_up_poll() is fine, poll/epoll doesn't use WQ_FLAG_EXCLUSIVE. - signalfd_cleanup() uses POLLHUP along with POLLFREE, we need a couple of simple changes in eventpoll.c to make sure it can't be "lost". Reported-by: Maxime Bizon <mbizon@freebox.fr> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29hwmon: (f75375s) Fix register write order when setting fans to full speedNikolaus Schulz
commit c1c1a3d012fe5e82a9a025fb4b5a4f8ee67a53f6 upstream. By hwmon sysfs interface convention, setting pwm_enable to zero sets a fan to full speed. In the f75375s driver, this need be done by enabling manual fan control, plus duty mode for the F875387 chip, and then setting the maximum duty cycle. Fix a bug where the two necessary register writes were swapped, effectively discarding the setting to full-speed. Signed-off-by: Nikolaus Schulz <mail@microschulz.de> Cc: Riku Voipio <riku.voipio@iki.fi> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29imon: don't wedge hardware after early callbacksJarod Wilson
commit 8791d63af0cf113725ae4cb8cba9492814c59a93 upstream. This patch is just a minor update to one titled "imon: Input from ffdc device type ignored" from Corinna Vinschen. An earlier patch to prevent an oops when we got early callbacks also has the nasty side-effect of wedging imon hardware, as we don't acknowledge the urb. Rework the check slightly here to bypass processing the packet, as the driver isn't yet fully initialized, but still acknowlege the urb and submit a new rx_urb. Do this for both interfaces -- irrelevant for ffdc hardware, but relevant for newer hardware, though newer hardware doesn't spew the constant stream of data as soon as the hardware is initialized like the older ffdc devices, so they'd be less likely to trigger this anyway... Tested with both an ffdc device and an 0042 device. Reported-by: Corinna Vinschen <vinschen@redhat.com> Signed-off-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29hdpvr: fix race conditon during start of streamingJanne Grunau
commit afa159538af61f1a65d48927f4e949fe514fb4fc upstream. status has to be set to STREAMING before the streaming worker is queued. hdpvr_transmit_buffers() will exit immediately otherwise. Reported-by: Joerg Desch <vvd.joede@googlemail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29can: sja1000: fix isr hang when hw is unplugged under loadOliver Hartkopp
commit a7762b10c12a70c5dbf2253142764b728ac88c3a upstream. In the case of hotplug enabled devices (PCMCIA/PCIeC) the removal of the hardware can cause an infinite loop in the common sja1000 isr. Use the already retrieved status register to indicate a possible hardware removal and double check by reading the mode register in sja1000_is_absent. Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Acked-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29builddeb: Don't create files in /tmp with predictable namesBen Hutchings
commit 6c635224602d760c1208ada337562f40d8ae93a5 upstream. The current use of /tmp for file lists is insecure. Put them under $objtree/debian instead. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Acked-by: maximilian attems <max@stro.at> Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29davinci_emac: Do not free all rx dma descriptors during initChristian Riesch
commit 5d69703263d588dbb03f4e57091afd8942d96e6d upstream. This patch fixes a regression that was introduced by commit 0a5f38467765ee15478db90d81e40c269c8dda20 davinci_emac: Add Carrier Link OK check in Davinci RX Handler Said commit adds a check whether the carrier link is ok. If the link is not ok, the skb is freed and no new dma descriptor added to the rx dma channel. This causes trouble during initialization when the carrier status has not yet been updated. If a lot of packets are received while netif_carrier_ok returns false, all dma descriptors are freed and the rx dma transfer is stopped. The bug occurs when the board is connected to a network with lots of traffic and the ifconfig down/up is done, e.g., when reconfiguring the interface with DHCP. The bug can be reproduced by flood pinging the davinci board while doing ifconfig eth0 down ifconfig eth0 up on the board. After that, the rx path stops working and the overrun value reported by ifconfig is counting up. This patch reverts commit 0a5f38467765ee15478db90d81e40c269c8dda20 and instead issues warnings only if cpdma_chan_submit returns -ENOMEM. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Cyril Chemparathy <cyril@ti.com> Cc: Sascha Hauer <s.hauer@pengutronix.de> Tested-by: Rajashekhara, Sudhakar <sudhakar.raj@ti.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29jme: Fix FIFO flush issueGuo-Fu Tseng
commit ba9adbe67e288823ac1deb7f11576ab5653f833e upstream. Set the RX FIFO flush watermark lower. According to Federico and JMicron's reply, setting it to 16QW would be stable on most platforms. Otherwise, user might experience packet drop issue. Reported-by: Federico Quagliata <federico@quagliata.org> Fixed-by: Federico Quagliata <federico@quagliata.org> Signed-off-by: Guo-Fu Tseng <cooldavid@cooldavid.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29ipvs: fix matching of fwmark templates during schedulingSimon Horman
commit e0aac52e17a3db68fe2ceae281780a70fc69957f upstream. Commit f11017ec2d1859c661f4e2b12c4a8d250e1f47cf (2.6.37) moved the fwmark variable in subcontext that is invalidated before reaching the ip_vs_ct_in_get call. As vaddr is provided as pointer in the param structure make sure the fwmark variable is in same context. As the fwmark templates can not be matched, more and more template connections are created and the controlled connections can not go to single real server. Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29scsi_pm: Fix bug in the SCSI power management handlerAlan Stern
commit fea6d607e154cf96ab22254ccb48addfd43d4cb5 upstream. This patch (as1520) fixes a bug in the SCSI layer's power management implementation. LUN scanning can be carried out asynchronously in do_scan_async(), and sd uses an asynchronous thread for the time-consuming parts of disk probing in sd_probe_async(). Currently nothing coordinates these async threads with system sleep transitions; they can and do attempt to continue scanning/probing SCSI devices even after the host adapter has been suspended. As one might expect, the outcome is not ideal. This is what the "prepare" stage of system suspend was created for. After the prepare callback has been called for a host, target, or device, drivers are not allowed to register any children underneath them. Currently the SCSI prepare callback is not implemented; this patch rectifies that omission. For SCSI hosts, the prepare routine calls scsi_complete_async_scans() to wait until async scanning is finished. It might be slightly more efficient to wait only until the host in question has been scanned, but there's currently no way to do that. Besides, during a sleep transition we will ultimately have to wait until all the host scanning has finished anyway. For SCSI devices, the prepare routine calls async_synchronize_full() to wait until sd probing is finished. The routine does nothing for SCSI targets, because asynchronous target scanning is done only as part of host scanning. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29scsi_scan: Fix 'Poison overwritten' warning caused by using freed 'shost'Huajun Li
commit 267a6ad4aefaafbde607804c60945bcf97f91c1b upstream. In do_scan_async(), calling scsi_autopm_put_host(shost) may reference freed shost, and cause Posison overwitten warning. Yes, this case can happen, for example, an USB is disconnected just when do_scan_async() thread starts to run, then scsi_host_put() called in scsi_finish_async_scan() will lead to shost be freed(because the refcount of shost->shost_gendev decreases to 1 after USB disconnects), at this point, if references shost again, system will show following warning msg. To make scsi_autopm_put_host(shost) always reference a valid shost, put it just before scsi_host_put() in function scsi_finish_async_scan(). [ 299.281565] ============================================================================= [ 299.281634] BUG kmalloc-4096 (Tainted: G I ): Poison overwritten [ 299.281682] ----------------------------------------------------------------------------- [ 299.281684] [ 299.281752] INFO: 0xffff880056c305d0-0xffff880056c305d0. First byte 0x6a instead of 0x6b [ 299.281816] INFO: Allocated in scsi_host_alloc+0x4a/0x490 age=1688 cpu=1 pid=2004 [ 299.281870] __slab_alloc+0x617/0x6c1 [ 299.281901] __kmalloc+0x28c/0x2e0 [ 299.281931] scsi_host_alloc+0x4a/0x490 [ 299.281966] usb_stor_probe1+0x5b/0xc40 [usb_storage] [ 299.282010] storage_probe+0xa4/0xe0 [usb_storage] [ 299.282062] usb_probe_interface+0x172/0x330 [usbcore] [ 299.282105] driver_probe_device+0x257/0x3b0 [ 299.282138] __driver_attach+0x103/0x110 [ 299.282171] bus_for_each_dev+0x8e/0xe0 [ 299.282201] driver_attach+0x26/0x30 [ 299.282230] bus_add_driver+0x1c4/0x430 [ 299.282260] driver_register+0xb6/0x230 [ 299.282298] usb_register_driver+0xe5/0x270 [usbcore] [ 299.282337] 0xffffffffa04ab03d [ 299.282364] do_one_initcall+0x47/0x230 [ 299.282396] sys_init_module+0xa0f/0x1fe0 [ 299.282429] INFO: Freed in scsi_host_dev_release+0x18a/0x1d0 age=85 cpu=0 pid=2008 [ 299.282482] __slab_free+0x3c/0x2a1 [ 299.282510] kfree+0x296/0x310 [ 299.282536] scsi_host_dev_release+0x18a/0x1d0 [ 299.282574] device_release+0x74/0x100 [ 299.282606] kobject_release+0xc7/0x2a0 [ 299.282637] kobject_put+0x54/0xa0 [ 299.282668] put_device+0x27/0x40 [ 299.282694] scsi_host_put+0x1d/0x30 [ 299.282723] do_scan_async+0x1fc/0x2b0 [ 299.282753] kthread+0xdf/0xf0 [ 299.282782] kernel_thread_helper+0x4/0x10 [ 299.282817] INFO: Slab 0xffffea00015b0c00 objects=7 used=7 fp=0x (null) flags=0x100000000004080 [ 299.282882] INFO: Object 0xffff880056c30000 @offset=0 fp=0x (null) [ 299.282884] ... Signed-off-by: Huajun Li <huajun.li.lee@gmail.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29genirq: Handle pending irqs in irq_startup()Thomas Gleixner
commit b4bc724e82e80478cba5fe9825b62e71ddf78757 upstream. An interrupt might be pending when irq_startup() is called, but the startup code does not invoke the resend logic. In some cases this prevents the device from issuing another interrupt which renders the device non functional. Call the resend function in irq_startup() to keep things going. Reported-and-tested-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29genirq: Unmask oneshot irqs when thread was not wokenThomas Gleixner
commit ac5637611150281f398bb7a47e3fcb69a09e7803 upstream. When the primary handler of an interrupt which is marked IRQ_ONESHOT returns IRQ_HANDLED or IRQ_NONE, then the interrupt thread is not woken and the unmask logic of the interrupt line is never invoked. This keeps the interrupt masked forever. This was not noticed as most IRQ_ONESHOT users wake the thread unconditionally (usually because they cannot access the underlying device from hard interrupt context). Though this behaviour was nowhere documented and not necessarily intentional. Some drivers can avoid the thread wakeup in certain cases and run into the situation where the interrupt line s kept masked. Handle it gracefully. Reported-and-tested-by: Lothar Wassmann <lw@karo-electronics.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29ath9k: stop on rates with idx -1 in ath9k rate control's .tx_statusPavel Roskin
commit 2504a6423b9ab4c36df78227055995644de19edb upstream. Rate control algorithms are supposed to stop processing when they encounter a rate with the index -1. Checking for rate->count not being zero is not enough. Allowing a rate with negative index leads to memory corruption in ath_debug_stat_rc(). One consequence of the bug is discussed at https://bugzilla.redhat.com/show_bug.cgi?id=768639 Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29x86/amd: Fix L1i and L2 cache sharing information for AMD family 15h processorsAndreas Herrmann
commit 32c3233885eb10ac9cb9410f2f8cd64b8df2b2a1 upstream. For L1 instruction cache and L2 cache the shared CPU information is wrong. On current AMD family 15h CPUs those caches are shared between both cores of a compute unit. This fixes https://bugzilla.kernel.org/show_bug.cgi?id=42607 Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com> Cc: Petkov Borislav <Borislav.Petkov@amd.com> Cc: Dave Jones <davej@redhat.com> Link: http://lkml.kernel.org/r/20120208195229.GA17523@alberich.amd.com Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29ARM: omap: fix oops in arch/arm/mach-omap2/vp.c when pmic is not foundRussell King
commit d980e0f8d858c6963d676013e976ff00ab7acb2b upstream. When the PMIC is not found, voltdm->pmic will be NULL. vp.c's initialization function tries to dereferences this, which causes an oops: Unable to handle kernel NULL pointer dereference at virtual address 00000000 pgd = c0004000 [00000000] *pgd=00000000 Internal error: Oops: 5 [#1] PREEMPT Modules linked in: CPU: 0 Not tainted (3.3.0-rc2+ #204) PC is at omap_vp_init+0x5c/0x15c LR is at omap_vp_init+0x58/0x15c pc : [<c03db880>] lr : [<c03db87c>] psr: 60000013 sp : c181ff30 ip : c181ff68 fp : c181ff64 r10: c0407808 r9 : c040786c r8 : c0407814 r7 : c0026868 r6 : c00264fc r5 : c040ad6c r4 : 00000000 r3 : 00000040 r2 : 000032c8 r1 : 0000fa00 r0 : 000032c8 Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel Control: 10c5387d Table: 80004019 DAC: 00000015 Process swapper (pid: 1, stack limit = 0xc181e2e8) Stack: (0xc181ff30 to 0xc1820000) ff20: c0381d00 c02e9c6d c0383582 c040786c ff40: c040ad6c c00264fc c0026868 c0407814 00000000 c03d9de4 c181ff8c c181ff68 ff60: c03db448 c03db830 c02e982c c03fdfb8 c03fe004 c0039988 00000013 00000000 ff80: c181ff9c c181ff90 c03d9df8 c03db390 c181ffdc c181ffa0 c0008798 c03d9df0 ffa0: c181ffc4 c181ffb0 c0055a44 c0187050 c0039988 c03fdfb8 c03fe004 c0039988 ffc0: 00000013 00000000 00000000 00000000 c181fff4 c181ffe0 c03d1284 c0008708 ffe0: 00000000 c03d1208 00000000 c181fff8 c0039988 c03d1214 1077ce40 01f7ee08 Backtrace: [<c03db824>] (omap_vp_init+0x0/0x15c) from [<c03db448>] (omap_voltage_late_init+0xc4/0xfc) [<c03db384>] (omap_voltage_late_init+0x0/0xfc) from [<c03d9df8>] (omap2_common_pm_late_init+0x14/0x54) r8:00000000 r7:00000013 r6:c0039988 r5:c03fe004 r4:c03fdfb8 [<c03d9de4>] (omap2_common_pm_late_init+0x0/0x54) from [<c0008798>] (do_one_initcall+0x9c/0x164) [<c00086fc>] (do_one_initcall+0x0/0x164) from [<c03d1284>] (kernel_init+0x7c/0x120) [<c03d1208>] (kernel_init+0x0/0x120) from [<c0039988>] (do_exit+0x0/0x2cc) r5:c03d1208 r4:00000000 Code: e5ca300b e5900034 ebf69027 e5994024 (e5941000) ---[ end trace aed617dddaf32c3d ]--- Kernel panic - not syncing: Attempted to kill init! Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29ARM: omap: fix oops in drivers/video/omap2/dss/dpi.cRussell King
commit 40410715715178ec196314dd0c19150c06901f80 upstream. When a PMIC is not found, this driver is unable to obtain its 'vdds_dsi_reg' regulator. Even through its initialization function fails, other code still calls its enable function, which fails to check whether it has this regulator before asking for it to be enabled. This fixes the oops, however a better fix would be to sort out the upper layers to prevent them calling into a module which failed to initialize. Unable to handle kernel NULL pointer dereference at virtual address 00000038 pgd = c0004000 [00000038] *pgd=00000000 Internal error: Oops: 5 [#1] PREEMPT Modules linked in: CPU: 0 Not tainted (3.3.0-rc2+ #228) PC is at regulator_enable+0x10/0x70 LR is at omapdss_dpi_display_enable+0x54/0x15c pc : [<c01b9a08>] lr : [<c01af994>] psr: 60000013 sp : c181fd90 ip : c181fdb0 fp : c181fdac r10: c042eff0 r9 : 00000060 r8 : c044a164 r7 : c042c0e4 r6 : c042bd60 r5 : 00000000 r4 : c042bd60 r3 : c084de48 r2 : c181e000 r1 : c042bd60 r0 : 00000000 Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel Control: 10c5387d Table: 80004019 DAC: 00000015 Process swapper (pid: 1, stack limit = 0xc181e2e8) Stack: (0xc181fd90 to 0xc1820000) fd80: c001754c c042bd60 00000000 c042bd60 fda0: c181fdcc c181fdb0 c01af994 c01b9a04 c0016104 c042bd60 c042bd60 c044a338 fdc0: c181fdec c181fdd0 c01b5ed0 c01af94c c042bd60 c042bd60 c1aa8000 c1aa8a0c fde0: c181fe04 c181fdf0 c01b5f54 c01b5ea8 c02fc18c c042bd60 c181fe3c c181fe08 fe00: c01b2a18 c01b5f48 c01aed14 c02fc160 c01df8ec 00000002 c042bd60 00000003 fe20: c042bd60 c1aa8000 c1aa8a0c c042eff8 c181fe84 c181fe40 c01b3874 c01b29fc fe40: c042eff8 00000000 c042f000 c0449db8 c044ed78 00000000 c181fe74 c042eff8 fe60: c042eff8 c0449db8 c0449db8 c044ed78 00000000 00000000 c181fe94 c181fe88 fe80: c01e452c c01b35e8 c181feb4 c181fe98 c01e2fdc c01e4518 c042eff8 c0449db8 fea0: c0449db8 c181fef0 c181fecc c181feb8 c01e3104 c01e2f48 c042eff8 c042f02c fec0: c181feec c181fed0 c01e3190 c01e30c0 c01e311c 00000000 c01e311c c0449db8 fee0: c181ff14 c181fef0 c01e1998 c01e3128 c18330a8 c1892290 c04165e8 c0449db8 ff00: c0449db8 c1ab60c0 c181ff24 c181ff18 c01e2e28 c01e194c c181ff54 c181ff28 ff20: c01e2218 c01e2e14 c039afed c181ff38 c04165e8 c041660c c0449db8 00000013 ff40: 00000000 c03ffdb8 c181ff7c c181ff58 c01e384c c01e217c c181ff7c c04165e8 ff60: c041660c c003a37c 00000013 00000000 c181ff8c c181ff80 c01e488c c01e3790 ff80: c181ff9c c181ff90 c03ffdcc c01e484c c181ffdc c181ffa0 c0008798 c03ffdc4 ffa0: c181ffc4 c181ffb0 c0056440 c0187810 c003a37c c04165e8 c041660c c003a37c ffc0: 00000013 00000000 00000000 00000000 c181fff4 c181ffe0 c03ea284 c0008708 ffe0: 00000000 c03ea208 00000000 c181fff8 c003a37c c03ea214 1073cec0 01f7ee08 Backtrace: [<c01b99f8>] (regulator_enable+0x0/0x70) from [<c01af994>] (omapdss_dpi_display_enable+0x54/0x15c) r6:c042bd60 r5:00000000 r4:c042bd60 [<c01af940>] (omapdss_dpi_display_enable+0x0/0x15c) from [<c01b5ed0>] (generic_dpi_panel_power_on+0x34/0x78) r6:c044a338 r5:c042bd60 r4:c042bd60 [<c01b5e9c>] (generic_dpi_panel_power_on+0x0/0x78) from [<c01b5f54>] (generic_dpi_panel_enable+0x18/0x28) r7:c1aa8a0c r6:c1aa8000 r5:c042bd60 r4:c042bd60 [<c01b5f3c>] (generic_dpi_panel_enable+0x0/0x28) from [<c01b2a18>] (omapfb_init_display+0x28/0x150) r4:c042bd60 [<c01b29f0>] (omapfb_init_display+0x0/0x150) from [<c01b3874>] (omapfb_probe+0x298/0x318) r8:c042eff8 r7:c1aa8a0c r6:c1aa8000 r5:c042bd60 r4:00000003 [<c01b35dc>] (omapfb_probe+0x0/0x318) from [<c01e452c>] (platform_drv_probe+0x20/0x24) [<c01e450c>] (platform_drv_probe+0x0/0x24) from [<c01e2fdc>] (really_probe+0xa0/0x178) [<c01e2f3c>] (really_probe+0x0/0x178) from [<c01e3104>] (driver_probe_device+0x50/0x68) r7:c181fef0 r6:c0449db8 r5:c0449db8 r4:c042eff8 [<c01e30b4>] (driver_probe_device+0x0/0x68) from [<c01e3190>] (__driver_attach+0x74/0x98) r5:c042f02c r4:c042eff8 [<c01e311c>] (__driver_attach+0x0/0x98) from [<c01e1998>] (bus_for_each_dev+0x58/0x98) r6:c0449db8 r5:c01e311c r4:00000000 [<c01e1940>] (bus_for_each_dev+0x0/0x98) from [<c01e2e28>] (driver_attach+0x20/0x28) r7:c1ab60c0 r6:c0449db8 r5:c0449db8 r4:c04165e8 [<c01e2e08>] (driver_attach+0x0/0x28) from [<c01e2218>] (bus_add_driver+0xa8/0x22c) [<c01e2170>] (bus_add_driver+0x0/0x22c) from [<c01e384c>] (driver_register+0xc8/0x154) [<c01e3784>] (driver_register+0x0/0x154) from [<c01e488c>] (platform_driver_register+0x4c/0x60) r8:00000000 r7:00000013 r6:c003a37c r5:c041660c r4:c04165e8 [<c01e4840>] (platform_driver_register+0x0/0x60) from [<c03ffdcc>] (omapfb_init+0x14/0x34) [<c03ffdb8>] (omapfb_init+0x0/0x34) from [<c0008798>] (do_one_initcall+0x9c/0x164) [<c00086fc>] (do_one_initcall+0x0/0x164) from [<c03ea284>] (kernel_init+0x7c/0x120) [<c03ea208>] (kernel_init+0x0/0x120) from [<c003a37c>] (do_exit+0x0/0x2d8) r5:c03ea208 r4:00000000 Code: e1a0c00d e92dd870 e24cb004 e24dd004 (e5906038) ---[ end trace 9e2474c2e193b223 ]--- Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29hwmon: (ads1015) Fix file leak in probe functionGuenter Roeck
commit 363434b5dc352464ac7601547891e5fc9105f124 upstream. An error while creating sysfs attribute files in the driver's probe function results in an error abort, but already created files are not removed. This patch fixes the problem. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Cc: Dirk Eibach <eibach@gdsys.de> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29hwmon: (max6639) Fix PPR register initialization to set both channelsChris D Schimp
commit 2f2da1ac0ba5b6cc6e1957c4da5ff20e67d8442b upstream. Initialize PPR register for both channels, and set correct PPR register bits. Also remove unnecessary variable initializations. Signed-off-by: Chris D Schimp <silverchris@gmail.com> [guenter.roeck@ericsson.com: Merged two patches into one] Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Roland Stigge <stigge@antcom.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29hwmon: (max6639) Fix FAN_FROM_REG calculationChris D Schimp
commit b63d97a36edb1aecf8c13e5f5783feff4d64c24b upstream. RPM calculation from tachometer value does not depend on PPR. Also, do not report negative RPM values. Signed-off-by: Chris D Schimp <silverchris@gmail.com> [guenter.roeck@ericsson.com: do not report negative RPM values] Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Roland Stigge <stigge@antcom.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29NOMMU: Lock i_mmap_mutex for access to the VMA prio listDavid Howells
commit 918e556ec214ed2f584e4cac56d7b29e4bb6bf27 upstream. Lock i_mmap_mutex for access to the VMA prio list to prevent concurrent access. Currently, certain parts of the mmap handling are protected by the region mutex, but not all. Reported-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29ALSA: hda/realtek - Fix surround output regression on Acer Aspire 5935Takashi Iwai
commit ef8d60fb79614a86a82720dc2402631dbcafb315 upstream. The previous fix for the speaker on Acer Aspire 59135 introduced another problem for surround outputs. It changed the connections on the line-in/mic pins for limiting the routes, but it left the modified connections. Thus wrong connection indices were written when set to 4ch or 6ch mode. This patch fixes it by restoring the right connections just after parsing the tree but before the initialization. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=42740 Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29ALSA: hda/realtek - Fix overflow of vol/sw check bitmapTakashi Iwai
commit c14c95f62ecb8710af14ae0d48e01991b70bb6f4 upstream. The bitmap introduced in the commit [527e4d73: ALSA: hda/realtek - Fix missing volume controls with ALC260] is too narrow for some codecs, which may have more NIDs than 0x20, thus it may overflow the bitmap array on them. Just double the number to cover all and also add a sanity-check code to be safer. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29ASoC: wm8962: Fix sidetone enumeration textsMark Brown
commit 31794bc37bf2db84f085da52b72bfba65739b2d2 upstream. The sidetone enumeration texts have left and right swapped. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29target: Allow control CDBs with data > 1 pageAndy Grover
commit 4949314c7283ea4f9ade182ca599583b89f7edd6 upstream. We need to handle >1 page control cdbs, so extend the code to do a vmap if bigger than 1 page. It seems like kmap() is still preferable if just a page, fewer TLB shootdowns(?), so keep using that when possible. Rename function pair for their new scope. Signed-off-by: Andy Grover <agrover@redhat.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29usb-storage: fix freezing of the scanning threadAlan Stern
commit bb94a406682770a35305daaa241ccdb7cab399de upstream. This patch (as1521b) fixes the interaction between usb-storage's scanning thread and the freezer. The current implementation has a race: If the device is unplugged shortly after being plugged in and just as a system sleep begins, the scanning thread may get frozen before the khubd task. Khubd won't be able to freeze until the disconnect processing is complete, and the disconnect processing can't proceed until the scanning thread finishes, so the sleep transition will fail. The implementation in the 3.2 kernel suffers from an additional problem. There the scanning thread calls set_freezable_with_signal(), and the signals sent by the freezer will mess up the thread's I/O delays, which are all interruptible. The solution to both problems is the same: Replace the kernel thread used for scanning with a delayed-work routine on the system freezable work queue. Freezable work queues have the nice property that you can cancel a work item even while the work queue is frozen, and no signals are needed. The 3.2 version of this patch solves the problem in Bugzilla #42730. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Seth Forshee <seth.forshee@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29USB: Set hub depth after USB3 hub resetElric Fu
commit a45aa3b30583e7d54e7cf4fbcd0aa699348a6e5c upstream. The superspeed device attached to a USB 3.0 hub(such as VIA's) doesn't respond the address device command after resume. The root cause is the superspeed hub will miss the Hub Depth value that is used as an offset into the route string to locate the bits it uses to determine the downstream port number after reset, and all packets can't be routed to the device attached to the superspeed hub. Hub driver sends a Set Hub Depth request to the superspeed hub except for USB 3.0 root hub when the hub is initialized and doesn't send the request again after reset due to the resume process. So moving the code that sends the Set Hub Depth request to the superspeed hub from hub_configure() to hub_activate() is to cover those situations include initialization and reset. The patch should be backported to kernels as old as 2.6.39. Signed-off-by: Elric Fu <elricfu1@gmail.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29USB: Don't fail USB3 probe on missing legacy PCI IRQ.Sarah Sharp
commit 68d07f64b8a11a852d48d1b05b724c3e20c0d94b upstream. Intel has a PCI USB xhci host controller on a new platform. It doesn't have a line IRQ definition in BIOS. The Linux driver refuses to initialize this controller, but Windows works well because it only depends on MSI. Actually, Linux also can work for MSI. This patch avoids the line IRQ checking for USB3 HCDs in usb core PCI probe. It allows the xHCI driver to try to enable MSI or MSI-X first. It will fail the probe if MSI enabling failed and there's no legacy PCI IRQ. This patch should be backported to kernels as old as 2.6.32. Signed-off-by: Alex Shi <alex.shi@intel.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29xhci: Fix encoding for HS bulk/control NAK rate.Sarah Sharp
commit 340a3504fd39dad753ba908fb6f894ee81fc3ae2 upstream. The xHCI 0.96 spec says that HS bulk and control endpoint NAK rate must be encoded as an exponent of two number of microframes. The endpoint descriptor has the NAK rate encoded in number of microframes. We were just copying the value from the endpoint descriptor into the endpoint context interval field, which was not correct. This lead to the VIA host rejecting the add of a bulk OUT endpoint from any USB 2.0 mass storage device. The fix is to use the correct encoding. Refactor the code to convert number of frames to an exponential number of microframes, and make sure we convert the number of microframes in HS bulk and control endpoints to an exponent. This should be back ported to kernels as old as 2.6.31, that contain the commit dfa49c4ad120a784ef1ff0717168aa79f55a483a "USB: xhci - fix math in xhci_get_endpoint_interval" Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Tested-by: Felipe Contreras <felipe.contreras@gmail.com> Suggested-by: Andiry Xu <andiry.xu@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29xhci: Fix oops caused by more USB2 ports than USB3 ports.Sarah Sharp
commit 3278a55a1aebe2bbd47fbb5196209e5326a88b56 upstream. The code to set the device removable bits in the USB 2.0 roothub descriptor was accidentally looking at the USB 3.0 port registers instead of the USB 2.0 registers. This can cause an oops if there are more USB 2.0 registers than USB 3.0 registers. This should be backported to kernels as old as 2.6.39, that contain the commit 4bbb0ace9a3de8392527e3c87926309d541d3b00 "xhci: Return a USB 3.0 hub descriptor for USB3 roothub." Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29USB: Fix handoff when BIOS disables host PCI device.Sarah Sharp
commit cab928ee1f221c9cc48d6615070fefe2e444384a upstream. On some systems with an Intel Panther Point xHCI host controller, the BIOS disables the xHCI PCI device during boot, and switches the xHCI ports over to EHCI. This allows the BIOS to access USB devices without having xHCI support. The downside is that the xHCI BIOS handoff mechanism will fail because memory mapped I/O is not enabled for the disabled PCI device. Jesse Barnes says this is expected behavior. The PCI core will enable BARs before quirks run, but it will leave it in an undefined state, and it may not have memory mapped I/O enabled. Make the generic USB quirk handler call pci_enable_device() to re-enable MMIO, and call pci_disable_device() once the host-specific BIOS handoff is finished. This will balance the ref counts in the PCI core. When the PCI probe function is called, usb_hcd_pci_probe() will call pci_enable_device() again. This should be back ported to kernels as old as 2.6.31. That was the first kernel with xHCI support, and no one has complained about BIOS handoffs failing due to memory mapped I/O being disabled on other hosts (EHCI, UHCI, or OHCI). Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Acked-by: Oliver Neukum <oneukum@suse.de> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29USB: Remove duplicate USB 3.0 hub feature #defines.Sarah Sharp
commit d9f5343e35d9138432657202afa8e3ddb2ade360 upstream. Somehow we ended up with duplicate hub feature #defines in ch11.h. Tatyana Brokhman first created the USB 3.0 hub feature macros in 2.6.38 with commit 0eadcc09203349b11ca477ec367079b23d32ab91 "usb: USB3.0 ch11 definitions". In 2.6.39, I modified a patch from John Youn that added similar macros in a different place in the same file, and committed dbe79bbe9dcb22cb3651c46f18943477141ca452 "USB 3.0 Hub Changes". Some of the #defines used different names for the same values. Others used exactly the same names with the same values, like these gems: #define USB_PORT_FEAT_BH_PORT_RESET 28 ... #define USB_PORT_FEAT_BH_PORT_RESET 28 According to my very geeky husband (who looked it up in the C99 spec), it is allowed to have object-like macros with duplicate names as long as the replacement list is exactly the same. However, he recalled that some compilers will give warnings when they find duplicate macros. It's probably best to remove the duplicates in the stable tree, so that the code compiles for everyone. The macros are now fixed to move the feature requests that are specific to USB 3.0 hubs into a new section (out of the USB 2.0 hub feature section), and use the most common macro name. This patch should be backported to 2.6.39. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Cc: Tatyana Brokhman <tlinder@codeaurora.org> Cc: John Youn <johnyoun@synopsys.com> Cc: Jamey Sharp <jamey@minilop.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29USB: Serial: ti_usb_3410_5052: Add Abbot Diabetes Care cable idAndrew Lunn
commit 7fd25702ba616d9ba56e2a625472f29e5aff25ee upstream. This USB-serial cable with mini stereo jack enumerates as: Bus 001 Device 004: ID 1a61:3410 Abbott Diabetes Care It is a TI3410 inside. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29USB: option: cleanup zte 3g-dongle's pid in option.cRui li
commit b9e44fe5ecda4158c22bc1ea4bffa378a4f83f65 upstream. 1. Remove all old mass-storage ids's pid: 0x0026,0x0053,0x0098,0x0099,0x0149,0x0150,0x0160; 2. As the pid from 0x1401 to 0x1510 which have not surely assigned to use for serial-port or mass-storage port,so i think it should be removed now, and will re-add after it have assigned in future; 3. sort the pid to WCDMA and CDMA. Signed-off-by: Rui li <li.rui27@zte.com.cn> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29USB: Added Kamstrup VID/PIDs to cp210x serial driver.Bruno Thomsen
commit c6c1e4491dc8d1ed2509fa6aacffa7f34614fc38 upstream. Signed-off-by: Bruno Thomsen <bruno.thomsen@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29tcp: fix tcp_shifted_skb() adjustment of lost_cnt_hint for FACKNeal Cardwell
[ Upstream commit 0af2a0d0576205dda778d25c6c344fc6508fc81d ] This commit ensures that lost_cnt_hint is correctly updated in tcp_shifted_skb() for FACK TCP senders. The lost_cnt_hint adjustment in tcp_sacktag_one() only applies to non-FACK senders, so FACK senders need their own adjustment. This applies the spirit of 1e5289e121372a3494402b1b131b41bfe1cf9b7f - except now that the sequence range passed into tcp_sacktag_one() is correct we need only have a special case adjustment for FACK. Signed-off-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29tcp: fix range tcp_shifted_skb() passes to tcp_sacktag_one()Neal Cardwell
[ Upstream commit daef52bab1fd26e24e8e9578f8fb33ba1d0cb412 ] Fix the newly-SACKed range to be the range of newly-shifted bytes. Previously - since 832d11c5cd076abc0aa1eaf7be96c81d1a59ce41 - tcp_shifted_skb() incorrectly called tcp_sacktag_one() with the start and end sequence numbers of the skb it passes in set to the range just beyond the range that is newly-SACKed. This commit also removes a special-case adjustment to lost_cnt_hint in tcp_shifted_skb() since the pre-existing adjustment of lost_cnt_hint in tcp_sacktag_one() now properly handles this things now that the correct start sequence number is passed in. Signed-off-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29tcp: allow tcp_sacktag_one() to tag ranges not aligned with skbsNeal Cardwell
[ Upstream commit cc9a672ee522d4805495b98680f4a3db5d0a0af9 ] This commit allows callers of tcp_sacktag_one() to pass in sequence ranges that do not align with skb boundaries, as tcp_shifted_skb() needs to do in an upcoming fix in this patch series. In fact, now tcp_sacktag_one() does not need to depend on an input skb at all, which makes its semantics and dependencies more clear. Signed-off-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29gro: more generic L2 header checkEric Dumazet
[ Upstream commit 5ca3b72c5da47d95b83857b768def6172fbc080a ] Shlomo Pongratz reported GRO L2 header check was suited for Ethernet only, and failed on IB/ipoib traffic. He provided a patch faking a zeroed header to let GRO aggregates frames. Roland Dreier, Herbert Xu, and others suggested we change GRO L2 header check to be more generic, ie not assuming L2 header is 14 bytes, but taking into account hard_header_len. __napi_gro_receive() has special handling for the common case (Ethernet) to avoid a memcmp() call and use an inline optimized function instead. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Reported-by: Shlomo Pongratz <shlomop@mellanox.com> Cc: Roland Dreier <roland@kernel.org> Cc: Or Gerlitz <ogerlitz@mellanox.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29IPoIB: Stop lying about hard_header_len and use skb->cb to stash LL addressesRoland Dreier
[ Upstream commit 936d7de3d736e0737542641269436f4b5968e9ef ] Commit a0417fa3a18a ("net: Make qdisc_skb_cb upper size bound explicit.") made it possible for a netdev driver to use skb->cb between its header_ops.create method and its .ndo_start_xmit method. Use this in ipoib_hard_header() to stash away the LL address (GID + QPN), instead of the "ipoib_pseudoheader" hack. This allows IPoIB to stop lying about its hard_header_len, which will let us fix the L2 check for GRO. Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29net: Make qdisc_skb_cb upper size bound explicit.David S. Miller
[ Upstream commit 16bda13d90c8d5da243e2cfa1677e62ecce26860 ] Just like skb->cb[], so that qdisc_skb_cb can be encapsulated inside of other data structures. This is intended to be used by IPoIB so that it can remember addressing information stored at hard_header_ops->create() time that it can fetch when the packet gets to the transmit routine. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29ipv4: Fix wrong order of ip_rt_get_source() and update iph->daddr.Li Wei
[ Upstream commit 5dc7883f2a7c25f8df40d7479687153558cd531b ] This patch fix a bug which introduced by commit ac8a4810 (ipv4: Save nexthop address of LSRR/SSRR option to IPCB.).In that patch, we saved the nexthop of SRR in ip_option->nexthop and update iph->daddr until we get to ip_forward_options(), but we need to update it before ip_rt_get_source(), otherwise we may get a wrong src. Signed-off-by: Li Wei <lw@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29tcp_v4_send_reset: binding oif to iif in no sock caseShawn Lu
[ Upstream commit e2446eaab5585555a38ea0df4e01ff313dbb4ac9 ] Binding RST packet outgoing interface to incoming interface for tcp v4 when there is no socket associate with it. when sk is not NULL, using sk->sk_bound_dev_if instead. (suggested by Eric Dumazet). This has few benefits: 1. tcp_v6_send_reset already did that. 2. This helps tcp connect with SO_BINDTODEVICE set. When connection is lost, we still able to sending out RST using same interface. 3. we are sending reply, it is most likely to be succeed if iif is used Signed-off-by: Shawn Lu <shawn.lu@ericsson.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29ipv4: reset flowi parameters on route connectJulian Anastasov
[ Upstream commit e6b45241c57a83197e5de9166b3b0d32ac562609 ] Eric Dumazet found that commit 813b3b5db83 (ipv4: Use caller's on-stack flowi as-is in output route lookups.) that comes in 3.0 added a regression. The problem appears to be that resulting flowi4_oif is used incorrectly as input parameter to some routing lookups. The result is that when connecting to local port without listener if the IP address that is used is not on a loopback interface we incorrectly assign RTN_UNICAST to the output route because no route is matched by oif=lo. The RST packet can not be sent immediately by tcp_v4_send_reset because it expects RTN_LOCAL. So, change ip_route_connect and ip_route_newports to update the flowi4 fields that are input parameters because we do not want unnecessary binding to oif. To make it clear what are the input parameters that can be modified during lookup and to show which fields of floiw4 are reused add a new function to update the flowi4 structure: flowi4_update_output. Thanks to Yurij M. Plotnikov for providing a bug report including a program to reproduce the problem. Thanks to Eric Dumazet for tracking the problem down to tcp_v4_send_reset and providing initial fix. Reported-by: Yurij M. Plotnikov <Yurij.Plotnikov@oktetlabs.ru> Signed-off-by: Julian Anastasov <ja@ssi.bg> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29via-velocity: S3 resume fix.David Lv
[ Upstream commit b530b1930bbd9d005345133f0ff0c556d2a52b19 ] Initially diagnosed on Ubuntu 11.04 with kernel 2.6.38. velocity_close is not called during a suspend / resume cycle in this driver and it has no business playing directly with power states. Signed-off-by: David Lv <DavidLv@viatech.com.cn> Acked-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29veth: Enforce minimum size of VETH_INFO_PEERHagen Paul Pfeifer
[ Upstream commit 237114384ab22c174ec4641e809f8e6cbcfce774 ] VETH_INFO_PEER carries struct ifinfomsg plus optional IFLA attributes. A minimal size of sizeof(struct ifinfomsg) must be enforced or we may risk accessing that struct beyond the limits of the netlink message. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
