2014-12-14Linux 3.2.65v3.2.65Ben Hutchings
2014-12-14mm: Remove false WARN_ON from pagecache_isize_extended()Jan Kara
commit f55fefd1a5a339b1bd08c120b93312d6eb64a9fb upstream. The WARN_ON checking whether i_mutex is held in pagecache_isize_extended() was wrong because some filesystems (e.g. XFS) use different locks for serialization of truncates / writes. So just remove the check. Signed-off-by: Jan Kara <jack@suse.cz> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14perf: Handle compat ioctlPawel Moll
commit b3f207855f57b9c8f43a547a801340bb5cbc59e5 upstream. When running a 32-bit userspace on a 64-bit kernel (eg. i386 application on x86_64 kernel or 32-bit arm userspace on arm64 kernel) some of the perf ioctls must be treated with special care, as they have a pointer size encoded in the command. For example, PERF_EVENT_IOC_ID in 32-bit world will be encoded as 0x80042407, but 64-bit kernel will expect 0x80082407. In result the ioctl will fail returning -ENOTTY. This patch solves the problem by adding code fixing up the size as compat_ioctl file operation. Reported-by: Drew Richardson <drew.richardson@arm.com> Signed-off-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1402671812-9078-1-git-send-email-pawel.moll@arm.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: David Ahern <dsahern@gmail.com> [lizf: Backported to 3.4 by David Ahern] Signed-off-by: Zefan Li <lizefan@huawei.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14crypto: algif - avoid excessive use of socket buffer in skcipherOndrej Kozina
commit e2cffb5f493a8b431dc87124388ea59b79f0bccb upstream. On archs with PAGE_SIZE >= 64 KiB the function skcipher_alloc_sgl() fails with -ENOMEM no matter what user space actually requested. This is caused by the fact sock_kmalloc call inside the function tried to allocate more memory than allowed by the default kernel socket buffer size (kernel param net.core.optmem_max). Signed-off-by: Ondrej Kozina <okozina@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14Patch for 3.2.x, 3.4.x IP identifier regressionJeffrey Knockel
With commits 73f156a6e8c1 ("inetpeer: get rid of ip_id_count") and 04ca6973f7c1 ("ip: make IP identifiers less predictable"), IP identifiers are generated from a counter chosen from an array of counters indexed by the hash of the outgoing packet header's source address, destination address, and protocol number. Thus, in __ip_make_skb(), we must now call ip_select_ident() only after setting these fields in the IP header to prevent IP identifiers from being generated from bogus counters. IP id sequence before fix: 18174, 5789, 5953, 59420, 59637, ... After fix: 5967, 6185, 6374, 6600, 6795, 6892, 7051, 7288, ... Signed-off-by: Jeffrey Knockel <jeffk@cs.unm.edu> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Cc: Eric Dumazet <edumazet@google.com>
2014-12-14hpsa: fix a race in cmd_free/scsi_doneTomas Henzl
commit 2cc5bfaf854463d9d1aa52091f60110fbf102a96 upstream. When the driver calls scsi_done and after that frees it's internal preallocated memory it can happen that a new job is enqueud before the memory is freed. The allocation fails and the message "cmd_alloc returned NULL" is shown. Patch below fixes it by moving cmd->scsi_done after cmd_free. Signed-off-by: Tomas Henzl <thenzl@redhat.com> Acked-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Cc: Masoud Sharbiani <msharbiani@twopensource.com>
2014-12-14tcp: be more strict before accepting ECN negociationEric Dumazet
commit bd14b1b2e29bd6812597f896dde06eaf7c6d2f24 upstream. It appears some networks play bad games with the two bits reserved for ECN. This can trigger false congestion notifications and very slow transferts. Since RFC 3168 (6.1.1) forbids SYN packets to carry CT bits, we can disable TCP ECN negociation if it happens we receive mangled CT bits in the SYN packet. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Perry Lorier <perryl@google.com> Cc: Matt Mathis <mattmathis@google.com> Cc: Yuchung Cheng <ycheng@google.com> Cc: Neal Cardwell <ncardwell@google.com> Cc: Wilmer van der Gaast <wilmer@google.com> Cc: Ankur Jain <jankur@google.com> Cc: Tom Herbert <therbert@google.com> Cc: Dave Täht <dave.taht@bufferbloat.net> Acked-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Cc: Florian Westphal <fw@strlen.de>
2014-12-14mei: limit the number of consecutive resetsTomas Winkler
commit 6adb8efb024a7e413b93b22848fc13395b1a438a upstream. give up reseting after 3 unsuccessful tries [Backported to 3.2: files were moved] Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Alexander Usyskin <alexander.usyskin@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14mei: add mei_quirk_probe functionTomas Winkler
commit 9a123f19832702753805afe0e93db26799b91b07 upstream. The main purpose of this function is to exclude ME devices without support for MEI/HECI interface from binding Currently affected systems are C600/X79 based servers that expose PCI device even though it doesn't supported ME Interface. MEI driver accessing such nonfunctional device can corrupt the system. [Backported to 3.2: files were moved] Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14Input: xpad - use proper endpoint typeGreg Kroah-Hartman
commit a1f9a4072655843fc03186acbad65990cc05dd2d upstream. The xpad wireless endpoint is not a bulk endpoint on my devices, but rather an interrupt one, so the USB core complains when it is submitted. I'm guessing that the author really did mean that this should be an interrupt urb, but as there are a zillion different xpad devices out there, let's cover out bases and handle both bulk and interrupt endpoints just as easily. Signed-off-by: "Pierre-Loup A. Griffais" <pgriffais@valvesoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14usb-quirks: Add reset-resume quirk for MS Wireless Laser Mouse 6000Hans de Goede
commit 263e80b43559a6103e178a9176938ce171b23872 upstream. This wireless mouse receiver needs a reset-resume quirk to properly come out of reset. BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1165206 Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14MIPS: Loongson: Make platform serial setup always built-in.Aaro Koskinen
commit 26927f76499849e095714452b8a4e09350f6a3b9 upstream. If SERIAL_8250 is compiled as a module, the platform specific setup for Loongson will be a module too, and it will not work very well. At least on Loongson 3 it will trigger a build failure, since loongson_sysconf is not exported to modules. Fix by making the platform specific serial code always built-in. Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Reported-by: Ralf Baechle <ralf@linux-mips.org> Cc: linux-mips@linux-mips.org Cc: Huacai Chen <chenhc@lemote.com> Cc: Markos Chandras <Markos.Chandras@imgtec.com> Patchwork: https://patchwork.linux-mips.org/patch/8533/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14ALSA: hda - Limit 40bit DMA for AMD HDMI controllersTakashi Iwai
commit 413cbf469a19e7662ba5025695bf5a573927105a upstream. AMD/ATI HDMI controller chip models, we already have a filter to lower to 32bit DMA, but the rest are supposed to be working with 64bit although the hardware doesn't really work with 63bit but only with 40 or 48bit DMA. In this patch, we take 40bit DMA for safety for the AMD/ATI controllers as the graphics drivers does. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> [bwh: Backported to 3.2: - Adjust context - s/AZX_GCAP_64OK/ICH6_GCAP_64OK/] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14x86/asm/traps: Disable tracing and kprobes in fixup_bad_iret and sync_regsAndy Lutomirski
commit 7ddc6a2199f1da405a2fb68c40db8899b1a8cd87 upstream. These functions can be executed on the int3 stack, so kprobes are dangerous. Tracing is probably a bad idea, too. Fixes: b645af2d5905 ("x86_64, traps: Rework bad_iret") Signed-off-by: Andy Lutomirski <luto@amacapital.net> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/50e33d26adca60816f3ba968875801652507d0c4.1416870125.git.luto@amacapital.net Signed-off-by: Ingo Molnar <mingo@kernel.org> [bwh: Backported to 3.2: - Use __kprobes instead of NOKPROBE_SYMBOL() - Don't use __visible] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14x86_64, traps: Rework bad_iretAndy Lutomirski
commit b645af2d5905c4e32399005b867987919cbfc3ae upstream. It's possible for iretq to userspace to fail. This can happen because of a bad CS, SS, or RIP. Historically, we've handled it by fixing up an exception from iretq to land at bad_iret, which pretends that the failed iret frame was really the hardware part of #GP(0) from userspace. To make this work, there's an extra fixup to fudge the gs base into a usable state. This is suboptimal because it loses the original exception. It's also buggy because there's no guarantee that we were on the kernel stack to begin with. For example, if the failing iret happened on return from an NMI, then we'll end up executing general_protection on the NMI stack. This is bad for several reasons, the most immediate of which is that general_protection, as a non-paranoid idtentry, will try to deliver signals and/or schedule from the wrong stack. This patch throws out bad_iret entirely. As a replacement, it augments the existing swapgs fudge into a full-blown iret fixup, mostly written in C. It's should be clearer and more correct. Signed-off-by: Andy Lutomirski <luto@amacapital.net> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [bwh: Backported to 3.2: - We didn't use the _ASM_EXTABLE macro - Don't use __visible] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14x86_64, traps: Fix the espfix64 #DF fixup and rewrite it in CAndy Lutomirski
commit af726f21ed8af2cdaa4e93098dc211521218ae65 upstream. There's nothing special enough about the espfix64 double fault fixup to justify writing it in assembly. Move it to C. This also fixes a bug: if the double fault came from an IST stack, the old asm code would return to a partially uninitialized stack frame. Fixes: 3891a04aafd668686239349ea58f3314ea2af86b Signed-off-by: Andy Lutomirski <luto@amacapital.net> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [bwh: Backported to 3.2: - Keep using the paranoiderrorentry macro to generate the asm code - Adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14x86_64, traps: Stop using IST for #SSAndy Lutomirski
commit 6f442be2fb22be02cafa606f1769fa1e6f894441 upstream. On a 32-bit kernel, this has no effect, since there are no IST stacks. On a 64-bit kernel, #SS can only happen in user code, on a failed iret to user space, a canonical violation on access via RSP or RBP, or a genuine stack segment violation in 32-bit kernel code. The first two cases don't need IST, and the latter two cases are unlikely fatal bugs, and promoting them to double faults would be fine. This fixes a bug in which the espfix64 code mishandles a stack segment violation. This saves 4k of memory per CPU and a tiny bit of code. Signed-off-by: Andy Lutomirski <luto@amacapital.net> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [bwh: Backported to 3.2: - No need to define trace_stack_segment - Use the errorentry macro to generate #SS asm code - Adjust context - Checked that this matches Luis's backport for Ubuntu] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14usb: xhci: rework root port wake bits if controller isn't allowed to wakeupLu Baolu
commit a1377e5397ab321e21b793ec8cd2b6f12bd3c718 upstream. When system is being suspended, if host device is not allowed to do wakeup, xhci_suspend() needs to clear all root port wake on bits. Otherwise, some platforms may generate spurious wakeup, even if PCI PME# is disabled. The initial commit ff8cbf250b44 ("xhci: clear root port wake on bits"), which also got into stable, turned out to not work correctly and had to be reverted, and is now rewritten. Signed-off-by: Lu Baolu <baolu.lu@linux.intel.com> Suggested-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Alan Stern <stern@rowland.harvard.edu> [Mathias Nyman: reword commit message] Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> [bwh: Backported to 3.2: adjust context; drop xhci-plat changes] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14USB: xhci: Reset a halted endpoint immediately when we encounter a stall.Mathias Nyman
commit 8e71a322fdb127814bcba423a512914ca5bc6cf5 upstream. If a device is halted and reuturns a STALL, then the halted endpoint needs to be cleared both on the host and device side. The host side halt is cleared by issueing a xhci reset endpoint command. The device side is cleared with a ClearFeature(ENDPOINT_HALT) request, which should be issued by the device driver if a URB reruen -EPIPE. Previously we cleared the host side halt after the device side was cleared. To make sure the host side halt is cleared in time we want to issue the reset endpoint command immedialtely when a STALL status is encountered. Otherwise we end up not following the specs and not returning -EPIPE several times in a row when trying to transfer data to a halted endpoint. Fixes: bcef3fd (USB: xhci: Handle errors that cause endpoint halts.) Tested-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> [bwh: Backported to 3.2: xhci_endpoint_reset() looked a little different] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14Revert "xhci: clear root port wake on bits if controller isn't wake-up capable"Lu Baolu
commit 9b41ebd3cf0f68d8cad779d3eeba336f78262e43 upstream. commit ff8cbf250b44 ("xhci: clear root port wake on bits if controller isn't") can cause device detection error if runtime PM is enabled, and S3 wake is disabled. Revert it. https://bugzilla.kernel.org/show_bug.cgi?id=85701 This commit got into stable and should be reverted from there as well. Signed-off-by: Lu Baolu <baolu.lu@linux.intel.com> Reported-by: Dmitry Nezhevenko <dion@inhex.net> [Mathias Nyman: reword commit message] Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14USB: xhci: don't start a halted endpoint before its new dequeue is setMathias Nyman
commit c3492dbfa1050debf23a5b5cd2bc7514c5b37896 upstream. A halted endpoint ring must first be reset, then move the ring dequeue pointer past the problematic TRB. If we start the ring too early after reset, but before moving the dequeue pointer we will end up executing the same problematic TRB again. As we always issue a set transfer dequeue command after a reset endpoint command we can skip starting endpoint rings at reset endpoint command completion. Without this fix we end up trying to handle the same faulty TD for contol endpoints. causing timeout, and failing testusb ctrl_out write tests. Fixes: e9df17e (USB: xhci: Correct assumptions about number of rings per endpoint.) Tested-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14ARM: 8216/1: xscale: correct auxiliary register in suspend/resumeDmitry Eremin-Solenikov
commit ef59a20ba375aeb97b3150a118318884743452a8 upstream. According to the manuals I have, XScale auxiliary register should be reached with opc_2 = 1 instead of crn = 1. cpu_xscale_proc_init correctly uses c1, c0, 1 arguments, but cpu_xscale_do_suspend and cpu_xscale_do_resume use c1, c1, 0. Correct suspend/resume functions to also use c1, c0, 1. The issue was primarily noticed thanks to qemu reporing "unsupported instruction" on the pxa suspend path. Confirmed in PXA210/250 and PXA255 XScale Core manuals and in PXA270 and PXA320 Developers Guides. Harware tested by me on tosa (pxa255). Robert confirmed on pxa270 board. Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14bnx2fc: do not add shared skbs to the fcoe_rx_listMaurizio Lombardi
commit 01a4cc4d0cd6a836c7b923760e8eb1cbb6a47258 upstream. In some cases, the fcoe_rx_list may contains multiple instances of the same skb (the so called "shared skbs"). the bnx2fc_l2_rcv thread is a loop that extracts a skb from the list, modifies (and destroys) its content and then proceed to the next one. The problem is that if the skb is shared, the remaining instances will be corrupted. The solution is to use skb_share_check() before adding the skb to the fcoe_rx_list. [ 6286.808725] ------------[ cut here ]------------ [ 6286.808729] WARNING: at include/scsi/fc_frame.h:173 bnx2fc_l2_rcv_thread+0x425/0x450 [bnx2fc]() [ 6286.808748] Modules linked in: bnx2x(-) mdio dm_service_time bnx2fc cnic uio fcoe libfcoe 8021q garp stp mrp libfc llc scsi_transport_fc scsi_tgt sg iTCO_wdt iTCO_vendor_support coretemp kvm_intel kvm crct10dif_pclmul crc32_pclmul crc32c_intel e1000e ghash_clmulni_intel aesni_intel lrw gf128mul glue_helper ablk_helper ptp cryptd hpilo serio_raw hpwdt lpc_ich pps_core ipmi_si pcspkr mfd_core ipmi_msghandler shpchp pcc_cpufreq mperf nfsd auth_rpcgss nfs_acl lockd sunrpc dm_multipath xfs libcrc32c ata_generic pata_acpi sd_mod crc_t10dif crct10dif_common mgag200 syscopyarea sysfillrect sysimgblt i2c_algo_bit ata_piix drm_kms_helper ttm drm libata i2c_core hpsa dm_mirror dm_region_hash dm_log dm_mod [last unloaded: mdio] [ 6286.808750] CPU: 3 PID: 1304 Comm: bnx2fc_l2_threa Not tainted 3.10.0-121.el7.x86_64 #1 [ 6286.808750] Hardware name: HP ProLiant DL120 G7, BIOS J01 07/01/2013 [ 6286.808752] 0000000000000000 000000000b36e715 ffff8800deba1e00 ffffffff815ec0ba [ 6286.808753] ffff8800deba1e38 ffffffff8105dee1 ffffffffa05618c0 ffff8801e4c81888 [ 6286.808754] ffffe8ffff663868 ffff8801f402b180 ffff8801f56bc000 ffff8800deba1e48 [ 6286.808754] Call Trace: [ 6286.808759] [<ffffffff815ec0ba>] dump_stack+0x19/0x1b [ 6286.808762] [<ffffffff8105dee1>] warn_slowpath_common+0x61/0x80 [ 6286.808763] [<ffffffff8105e00a>] warn_slowpath_null+0x1a/0x20 [ 6286.808765] [<ffffffffa054f415>] bnx2fc_l2_rcv_thread+0x425/0x450 [bnx2fc] [ 6286.808767] [<ffffffffa054eff0>] ? bnx2fc_disable+0x90/0x90 [bnx2fc] [ 6286.808769] [<ffffffff81085aef>] kthread+0xcf/0xe0 [ 6286.808770] [<ffffffff81085a20>] ? kthread_create_on_node+0x140/0x140 [ 6286.808772] [<ffffffff815fc76c>] ret_from_fork+0x7c/0xb0 [ 6286.808773] [<ffffffff81085a20>] ? kthread_create_on_node+0x140/0x140 [ 6286.808774] ---[ end trace c6cdb939184ccb4e ]--- Signed-off-by: Maurizio Lombardi <mlombard@redhat.com> Acked-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14nfsd: Fix slot wake up race in the nfsv4.1 callback codeTrond Myklebust
commit c6c15e1ed303ffc47e696ea1c9a9df1761c1f603 upstream. The currect code for nfsd41_cb_get_slot() and nfsd4_cb_done() has no locking in order to guarantee atomicity, and so allows for races of the form. Task 1 Task 2 ====== ====== if (test_and_set_bit(0) != 0) { clear_bit(0) rpc_wake_up_next(queue) rpc_sleep_on(queue) return false; } This patch breaks the race condition by adding a retest of the bit after the call to rpc_sleep_on(). Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14MIPS: oprofile: Fix backtrace on 64-bit kernelAaro Koskinen
commit bbaf113a481b6ce32444c125807ad3618643ce57 upstream. Fix incorrect cast that always results in wrong address for the new frame on 64-bit kernels. Signed-off-by: Aaro Koskinen <aaro.koskinen@nsn.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/8110/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14SUNRPC: Fix locking around callback channel reply receiveTrond Myklebust
commit 093a1468b6edb0e568be7311b8d2228d205702db upstream. Both xprt_lookup_rqst() and xprt_complete_rqst() require that you take the transport lock in order to avoid races with xprt_transmit(). Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Reviewed-by: Jeff Layton <jlayton@primarydata.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14sunrpc: fix byte-swapping of displayed XIDChuck Lever
commit 71efecb3f58c8c7a15f6135e3f9b39d1e3d3fae3 upstream. xprt_lookup_rqst() and bc_send_request() display a byte-swapped XID, but receive_cb_reply() does not. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14USB: ssu100: fix overrun-error reportingJohan Hovold
commit 75bcbf29c284dd0154c3e895a0bd1ef0e796160e upstream. Fix reporting of overrun errors, which should only be reported once using the inserted null character. Fixes: 6b8f1ca5581b ("USB: ssu100: set tty_flags in ssu100_process_packet") Signed-off-by: Johan Hovold <johan@kernel.org> [bwh: Backported to 3.2: - Use tty_port_tty_get() to look up tty_struct - Adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14USB: keyspan: fix overrun-error reportingJohan Hovold
commit 855515a6d3731242d85850a206f2ec084c917338 upstream. Fix reporting of overrun errors, which are not associated with a character. Instead insert a null character and report only once. Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2") Signed-off-by: Johan Hovold <johan@kernel.org> [bwh: Backported to 3.2: - s/\&port->port/tty/ - Adjust context, indentation] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14USB: keyspan: fix tty line-status reportingJohan Hovold
commit 5d1678a33c731b56e245e888fdae5e88efce0997 upstream. Fix handling of TTY error flags, which are not bitmasks and must specifically not be ORed together as this prevents the line discipline from recognising them. Also insert null characters when reporting overrun errors as these are not associated with the received character. Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2") Signed-off-by: Johan Hovold <johan@kernel.org> [bwh: Backported to 3.2: - s/\&port->port/tty/ - Adjust context, indentation] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14usb: serial: ftdi_sio: add PIDs for Matrix Orbital productsTroy Clark
commit 204ec6e07ea7aff863df0f7c53301f9cbbfbb9d3 upstream. Add PIDs for new Matrix Orbital GTT series products. Signed-off-by: Troy Clark <tclark@matrixorbital.ca> [johan: shorten commit message ] Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14of/base: Fix PowerPC address parsing hackBenjamin Herrenschmidt
commit 746c9e9f92dde2789908e51a354ba90a1962a2eb upstream. We have a historical hack that treats missing ranges properties as the equivalent of an empty one. This is needed for ancient PowerMac "bad" device-trees, and shouldn't be enabled for any other PowerPC platform, otherwise we get some nasty layout of devices in sysfs or even duplication when a set of otherwise identically named devices is created multiple times under a different parent node with no ranges property. This fix is needed for the PowerNV i2c busses to be exposed properly and will fix a number of other embedded cases. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Grant Likely <grant.likely@linaro.org> Signed-off-by: Rob Herring <robh@kernel.org> [bwh: Backported to 3.2: use #ifdef because IS_ENABLED() only works for config symbols that are defined on the current architecture] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14x86, mm: Set NX across entire PMD at bootKees Cook
commit 45e2a9d4701d8c624d4a4bcdd1084eae31e92f58 upstream. When setting up permissions on kernel memory at boot, the end of the PMD that was split from bss remained executable. It should be NX like the rest. This performs a PMD alignment instead of a PAGE alignment to get the correct span of memory. Before: ---[ High Kernel Mapping ]--- ... 0xffffffff8202d000-0xffffffff82200000 1868K RW GLB NX pte 0xffffffff82200000-0xffffffff82c00000 10M RW PSE GLB NX pmd 0xffffffff82c00000-0xffffffff82df5000 2004K RW GLB NX pte 0xffffffff82df5000-0xffffffff82e00000 44K RW GLB x pte 0xffffffff82e00000-0xffffffffc0000000 978M pmd After: ---[ High Kernel Mapping ]--- ... 0xffffffff8202d000-0xffffffff82200000 1868K RW GLB NX pte 0xffffffff82200000-0xffffffff82e00000 12M RW PSE GLB NX pmd 0xffffffff82e00000-0xffffffffc0000000 978M pmd [ tglx: Changed it to roundup(_brk_end, PMD_SIZE) and added a comment. We really should unmap the reminder along with the holes caused by init,initdata etc. but thats a different issue ] Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Toshi Kani <toshi.kani@hp.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: David Vrabel <david.vrabel@citrix.com> Cc: Wang Nan <wangnan0@huawei.com> Cc: Yinghai Lu <yinghai@kernel.org> Link: http://lkml.kernel.org/r/20141114194737.GA3091@www.outflux.net Signed-off-by: Thomas Gleixner <tglx@linutronix.de> [bwh: BAckported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14x86, 64bit, mm: Mark data/bss/brk to nxYinghai Lu
commit 72212675d1c96f5db8ec6fb35701879911193158 upstream. HPA said, we should not have RW and +x set at the time. for kernel layout: [ 0.000000] Kernel Layout: [ 0.000000] .text: [0x01000000-0x021434f8] [ 0.000000] .rodata: [0x02200000-0x02a13fff] [ 0.000000] .data: [0x02c00000-0x02dc763f] [ 0.000000] .init: [0x02dc9000-0x0312cfff] [ 0.000000] .bss: [0x0313b000-0x03dd6fff] [ 0.000000] .brk: [0x03dd7000-0x03dfffff] before the patch, we have ---[ High Kernel Mapping ]--- 0xffffffff80000000-0xffffffff81000000 16M pmd 0xffffffff81000000-0xffffffff82200000 18M ro PSE GLB x pmd 0xffffffff82200000-0xffffffff82c00000 10M ro PSE GLB NX pmd 0xffffffff82c00000-0xffffffff82dc9000 1828K RW GLB x pte 0xffffffff82dc9000-0xffffffff82e00000 220K RW GLB NX pte 0xffffffff82e00000-0xffffffff83000000 2M RW PSE GLB NX pmd 0xffffffff83000000-0xffffffff8313a000 1256K RW GLB NX pte 0xffffffff8313a000-0xffffffff83200000 792K RW GLB x pte 0xffffffff83200000-0xffffffff83e00000 12M RW PSE GLB x pmd 0xffffffff83e00000-0xffffffffa0000000 450M pmd after patch,, we get ---[ High Kernel Mapping ]--- 0xffffffff80000000-0xffffffff81000000 16M pmd 0xffffffff81000000-0xffffffff82200000 18M ro PSE GLB x pmd 0xffffffff82200000-0xffffffff82c00000 10M ro PSE GLB NX pmd 0xffffffff82c00000-0xffffffff82e00000 2M RW GLB NX pte 0xffffffff82e00000-0xffffffff83000000 2M RW PSE GLB NX pmd 0xffffffff83000000-0xffffffff83200000 2M RW GLB NX pte 0xffffffff83200000-0xffffffff83e00000 12M RW PSE GLB NX pmd 0xffffffff83e00000-0xffffffffa0000000 450M pmd so data, bss, brk get NX ... Signed-off-by: Yinghai Lu <yinghai@kernel.org> Link: http://lkml.kernel.org/r/1359058816-7615-33-git-send-email-yinghai@kernel.org Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14can: esd_usb2: fix memory leak on disconnectAlexey Khoroshilov
commit efbd50d2f62fc1f69a3dcd153e63ba28cc8eb27f upstream. It seems struct esd_usb2 dev is not deallocated on disconnect. The patch adds the missing deallocation. Found by Linux Driver Verification project (linuxtesting.org). Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru> Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14can: dev: avoid calling kfree_skb() from interrupt contextThomas Körper
commit 5247a589c24022ab34e780039cc8000c48f2035e upstream. ikfree_skb() is Called in can_free_echo_skb(), which might be called from (TX Error) interrupt, which triggers the folloing warning: [ 1153.360705] ------------[ cut here ]------------ [ 1153.360715] WARNING: CPU: 0 PID: 31 at net/core/skbuff.c:563 skb_release_head_state+0xb9/0xd0() [ 1153.360772] Call Trace: [ 1153.360778] [<c167906f>] dump_stack+0x41/0x52 [ 1153.360782] [<c105bb7e>] warn_slowpath_common+0x7e/0xa0 [ 1153.360784] [<c158b909>] ? skb_release_head_state+0xb9/0xd0 [ 1153.360786] [<c158b909>] ? skb_release_head_state+0xb9/0xd0 [ 1153.360788] [<c105bc42>] warn_slowpath_null+0x22/0x30 [ 1153.360791] [<c158b909>] skb_release_head_state+0xb9/0xd0 [ 1153.360793] [<c158be90>] skb_release_all+0x10/0x30 [ 1153.360795] [<c158bf06>] kfree_skb+0x36/0x80 [ 1153.360799] [<f8486938>] ? can_free_echo_skb+0x28/0x40 [can_dev] [ 1153.360802] [<f8486938>] can_free_echo_skb+0x28/0x40 [can_dev] [ 1153.360805] [<f849a12c>] esd_pci402_interrupt+0x34c/0x57a [esd402] [ 1153.360809] [<c10a75b5>] handle_irq_event_percpu+0x35/0x180 [ 1153.360811] [<c10a7623>] ? handle_irq_event_percpu+0xa3/0x180 [ 1153.360813] [<c10a7731>] handle_irq_event+0x31/0x50 [ 1153.360816] [<c10a9c7f>] handle_fasteoi_irq+0x6f/0x120 [ 1153.360818] [<c10a9c10>] ? handle_edge_irq+0x110/0x110 [ 1153.360822] [<c1011b61>] handle_irq+0x71/0x90 [ 1153.360823] <IRQ> [<c168152c>] do_IRQ+0x3c/0xd0 [ 1153.360829] [<c1680b6c>] common_interrupt+0x2c/0x34 [ 1153.360834] [<c107d277>] ? finish_task_switch+0x47/0xf0 [ 1153.360836] [<c167c27b>] __schedule+0x35b/0x7e0 [ 1153.360839] [<c10a5334>] ? console_unlock+0x2c4/0x4d0 [ 1153.360842] [<c13df500>] ? n_tty_receive_buf_common+0x890/0x890 [ 1153.360845] [<c10707b6>] ? process_one_work+0x196/0x370 [ 1153.360847] [<c167c723>] schedule+0x23/0x60 [ 1153.360849] [<c1070de1>] worker_thread+0x161/0x460 [ 1153.360852] [<c1090fcf>] ? __wake_up_locked+0x1f/0x30 [ 1153.360854] [<c1070c80>] ? rescuer_thread+0x2f0/0x2f0 [ 1153.360856] [<c1074f01>] kthread+0xa1/0xc0 [ 1153.360859] [<c1680401>] ret_from_kernel_thread+0x21/0x30 [ 1153.360861] [<c1074e60>] ? kthread_create_on_node+0x110/0x110 [ 1153.360863] ---[ end trace 5ff83639cbb74b35 ]--- This patch replaces the kfree_skb() by dev_kfree_skb_any(). Signed-off-by: Thomas Körper <thomas.koerper@esd.eu> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14x86: Require exact match for 'noxsave' command line optionDave Hansen
commit 2cd3949f702692cf4c5d05b463f19cd706a92dd3 upstream. We have some very similarly named command-line options: arch/x86/kernel/cpu/common.c:__setup("noxsave", x86_xsave_setup); arch/x86/kernel/cpu/common.c:__setup("noxsaveopt", x86_xsaveopt_setup); arch/x86/kernel/cpu/common.c:__setup("noxsaves", x86_xsaves_setup); __setup() is designed to match options that take arguments, like "foo=bar" where you would have: __setup("foo", x86_foo_func...); The problem is that "noxsave" actually _matches_ "noxsaves" in the same way that "foo" matches "foo=bar". If you boot an old kernel that does not know about "noxsaves" with "noxsaves" on the command line, it will interpret the argument as "noxsave", which is not what you want at all. This makes the "noxsave" handler only return success when it finds an *exact* match. [ tglx: We really need to make __setup() more robust. ] Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Cc: Dave Hansen <dave@sr71.net> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: x86@kernel.org Link: http://lkml.kernel.org/r/20141111220133.FE053984@viggo.jf.intel.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14iio: Fix IIO_EVENT_CODE_EXTRACT_DIR bit maskCristina Ciocan
commit ccf54555da9a5e91e454b909ca6a5303c7d6b910 upstream. The direction field is set on 7 bits, thus we need to AND it with 0111 111 mask in order to retrieve it, that is 0x7F, not 0xCF as it is now. Fixes: ade7ef7ba (staging:iio: Differential channel handling) Signed-off-by: Cristina Ciocan <cristina.ciocan@intel.com> Signed-off-by: Jonathan Cameron <jic23@kernel.org> [bwh: Backported to 3.2: adjust filename] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14firewire: cdev: prevent kernel stack leaking into ioctl argumentsStefan Richter
commit eaca2d8e75e90a70a63a6695c9f61932609db212 upstream. Found by the UC-KLEE tool: A user could supply less input to firewire-cdev ioctls than write- or write/read-type ioctl handlers expect. The handlers used data from uninitialized kernel stack then. This could partially leak back to the user if the kernel subsequently generated fw_cdev_event_'s (to be read from the firewire-cdev fd) which notably would contain the _u64 closure field which many of the ioctl argument structures contain. The fact that the handlers would act on random garbage input is a lesser issue since all handlers must check their input anyway. The fix simply always null-initializes the entire ioctl argument buffer regardless of the actual length of expected user input. That is, a runtime overhead of memset(..., 40) is added to each firewirew-cdev ioctl() call. [Comment from Clemens Ladisch: This part of the stack is most likely to be already in the cache.] Remarks: - There was never any leak from kernel stack to the ioctl output buffer itself. IOW, it was not possible to read kernel stack by a read-type or write/read-type ioctl alone; the leak could at most happen in combination with read()ing subsequent event data. - The actual expected minimum user input of each ioctl from include/uapi/linux/firewire-cdev.h is, in bytes: [0x00] = 32, [0x05] = 4, [0x0a] = 16, [0x0f] = 20, [0x14] = 16, [0x01] = 36, [0x06] = 20, [0x0b] = 4, [0x10] = 20, [0x15] = 20, [0x02] = 20, [0x07] = 4, [0x0c] = 0, [0x11] = 0, [0x16] = 8, [0x03] = 4, [0x08] = 24, [0x0d] = 20, [0x12] = 36, [0x17] = 12, [0x04] = 20, [0x09] = 24, [0x0e] = 4, [0x13] = 40, [0x18] = 4. Reported-by: David Ramos <daramos@stanford.edu> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14ASoC: sgtl5000: Fix SMALL_POP bit definitionFabio Estevam
commit c251ea7bd7a04f1f2575467e0de76e803cf59149 upstream. On a mx28evk with a sgtl5000 codec we notice a loud 'click' sound to happen 5 seconds after the end of a playback. The SMALL_POP bit should fix this, but its definition is incorrect: according to the sgtl5000 manual it is bit 0 of CHIP_REF_CTRL register, not bit 1. Fix the definition accordingly and enable the bit as intended per the code comment. After applying this change, no loud 'click' sound is heard after playback Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14libceph: do not crash on large auth ticketsIlya Dryomov
commit aaef31703a0cf6a733e651885bfb49edc3ac6774 upstream. Large (greater than 32k, the value of PAGE_ALLOC_COSTLY_ORDER) auth tickets will have their buffers vmalloc'ed, which leads to the following crash in crypto: [ 28.685082] BUG: unable to handle kernel paging request at ffffeb04000032c0 [ 28.686032] IP: [<ffffffff81392b42>] scatterwalk_pagedone+0x22/0x80 [ 28.686032] PGD 0 [ 28.688088] Oops: 0000 [#1] PREEMPT SMP [ 28.688088] Modules linked in: [ 28.688088] CPU: 0 PID: 878 Comm: kworker/0:2 Not tainted 3.17.0-vm+ #305 [ 28.688088] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2007 [ 28.688088] Workqueue: ceph-msgr con_work [ 28.688088] task: ffff88011a7f9030 ti: ffff8800d903c000 task.ti: ffff8800d903c000 [ 28.688088] RIP: 0010:[<ffffffff81392b42>] [<ffffffff81392b42>] scatterwalk_pagedone+0x22/0x80 [ 28.688088] RSP: 0018:ffff8800d903f688 EFLAGS: 00010286 [ 28.688088] RAX: ffffeb04000032c0 RBX: ffff8800d903f718 RCX: ffffeb04000032c0 [ 28.688088] RDX: 0000000000000000 RSI: 0000000000000001 RDI: ffff8800d903f750 [ 28.688088] RBP: ffff8800d903f688 R08: 00000000000007de R09: ffff8800d903f880 [ 28.688088] R10: 18df467c72d6257b R11: 0000000000000000 R12: 0000000000000010 [ 28.688088] R13: ffff8800d903f750 R14: ffff8800d903f8a0 R15: 0000000000000000 [ 28.688088] FS: 00007f50a41c7700(0000) GS:ffff88011fc00000(0000) knlGS:0000000000000000 [ 28.688088] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [ 28.688088] CR2: ffffeb04000032c0 CR3: 00000000da3f3000 CR4: 00000000000006b0 [ 28.688088] Stack: [ 28.688088] ffff8800d903f698 ffffffff81392ca8 ffff8800d903f6e8 ffffffff81395d32 [ 28.688088] ffff8800dac96000 ffff880000000000 ffff8800d903f980 ffff880119b7e020 [ 28.688088] ffff880119b7e010 0000000000000000 0000000000000010 0000000000000010 [ 28.688088] Call Trace: [ 28.688088] [<ffffffff81392ca8>] scatterwalk_done+0x38/0x40 [ 28.688088] [<ffffffff81392ca8>] scatterwalk_done+0x38/0x40 [ 28.688088] [<ffffffff81395d32>] blkcipher_walk_done+0x182/0x220 [ 28.688088] [<ffffffff813990bf>] crypto_cbc_encrypt+0x15f/0x180 [ 28.688088] [<ffffffff81399780>] ? crypto_aes_set_key+0x30/0x30 [ 28.688088] [<ffffffff8156c40c>] ceph_aes_encrypt2+0x29c/0x2e0 [ 28.688088] [<ffffffff8156d2a3>] ceph_encrypt2+0x93/0xb0 [ 28.688088] [<ffffffff8156d7da>] ceph_x_encrypt+0x4a/0x60 [ 28.688088] [<ffffffff8155b39d>] ? ceph_buffer_new+0x5d/0xf0 [ 28.688088] [<ffffffff8156e837>] ceph_x_build_authorizer.isra.6+0x297/0x360 [ 28.688088] [<ffffffff8112089b>] ? kmem_cache_alloc_trace+0x11b/0x1c0 [ 28.688088] [<ffffffff8156b496>] ? ceph_auth_create_authorizer+0x36/0x80 [ 28.688088] [<ffffffff8156ed83>] ceph_x_create_authorizer+0x63/0xd0 [ 28.688088] [<ffffffff8156b4b4>] ceph_auth_create_authorizer+0x54/0x80 [ 28.688088] [<ffffffff8155f7c0>] get_authorizer+0x80/0xd0 [ 28.688088] [<ffffffff81555a8b>] prepare_write_connect+0x18b/0x2b0 [ 28.688088] [<ffffffff81559289>] try_read+0x1e59/0x1f10 This is because we set up crypto scatterlists as if all buffers were kmalloc'ed. Fix it. Signed-off-by: Ilya Dryomov <idryomov@redhat.com> Reviewed-by: Sage Weil <sage@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14rt2x00: do not align payload on modern H/WStanislaw Gruszka
commit cfd9167af14eb4ec21517a32911d460083ee3d59 upstream. RT2800 and newer hardware require padding between header and payload if header length is not multiple of 4. For historical reasons we also align payload to to 4 bytes boundary, but such alignment is not needed on modern H/W. Patch fixes skb_under_panic problems reported from time to time: https://bugzilla.kernel.org/show_bug.cgi?id=84911 https://bugzilla.kernel.org/show_bug.cgi?id=72471 http://marc.info/?l=linux-wireless&m=139108549530402&w=2 https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1087591 Panic happened because we eat 4 bytes of skb headroom on each (re)transmission when sending frame without the payload and the header length not being multiple of 4 (i.e. QoS header has 26 bytes). On such case because paylad_aling=2 is bigger than header_align=0 we increase header_align by 4 bytes. To prevent that we could change the check to: if (payload_length && payload_align > header_align) header_align += 4; but not aligning payload at all is more effective and alignment is not really needed by H/W (that has been tested on OpenWrt project for few years now). Reported-and-tested-by: Antti S. Lankila <alankila@bel.fi> Debugged-by: Antti S. Lankila <alankila@bel.fi> Reported-by: Henrik Asp <solenskiner@gmail.com> Originally-From: Helmut Schaa <helmut.schaa@googlemail.com> Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14audit: keep inode pinnedMiklos Szeredi
commit 799b601451b21ebe7af0e6e8f6e2ccd4683c5064 upstream. Audit rules disappear when an inode they watch is evicted from the cache. This is likely not what we want. The guilty commit is "fsnotify: allow marks to not pin inodes in core", which didn't take into account that audit_tree adds watches with a zero mask. Adding any mask should fix this. Fixes: 90b1e7a57880 ("fsnotify: allow marks to not pin inodes in core") Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14scsi: only re-lock door after EH on devices that were resetChristoph Hellwig
commit 48379270fe6808cf4612ee094adc8da2b7a83baa upstream. Setups that use the blk-mq I/O path can lock up if a host with a single device that has its door locked enters EH. Make sure to only send the command to re-lock the door to devices that actually were reset and thus might have lost their state. Otherwise the EH code might be get blocked on blk_get_request as all requests for non-reset devices might be in use. Signed-off-by: Christoph Hellwig <hch@lst.de> Reported-by: Meelis Roos <meelis.roos@ut.ee> Tested-by: Meelis Roos <meelis.roos@ut.ee> Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14USB: serial: cp210x: add IDs for CEL MeshConnect USB StickPreston Fick
commit ffcfe30ebd8dd703d0fc4324ffe56ea21f5479f4 upstream. Signed-off-by: Preston Fick <pffick@gmail.com> Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14Input: alps - allow up to 2 invalid packets without resetting devicePali Rohár
commit 9d720b34c0a432639252f63012e18b0507f5b432 upstream. On some Dell Latitude laptops ALPS device or Dell EC send one invalid byte in 6 bytes ALPS packet. In this case psmouse driver enter out of sync state. It looks like that all other bytes in packets are valid and also device working properly. So there is no need to do full device reset, just need to wait for byte which match condition for first byte (start of packet). Because ALPS packets are bigger (6 or 8 bytes) default limit is small. This patch increase number of invalid bytes to size of 2 ALPS packets which psmouse driver can drop before do full reset. Resetting ALPS devices take some time and when doing reset on some Dell laptops touchpad, trackstick and also keyboard do not respond. So it is better to do it only if really necessary. Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Tested-by: Pali Rohár <pali.rohar@gmail.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14Input: alps - ignore potential bare packets when device is out of syncPali Rohár
commit 4ab8f7f320f91f279c3f06a9795cfea5c972888a upstream. 5th and 6th byte of ALPS trackstick V3 protocol match condition for first byte of PS/2 3 bytes packet. When driver enters out of sync state and ALPS trackstick is sending data then driver match 5th, 6th and next 1st bytes as PS/2. It basically means if user is using trackstick when driver is in out of sync state driver will never resync. Processing these bytes as 3 bytes PS/2 data cause total mess (random cursor movements, random clicks) and make trackstick unusable until psmouse driver decide to do full device reset. Lot of users reported problems with ALPS devices on Dell Latitude E6440, E6540 and E7440 laptops. ALPS device or Dell EC for unknown reason send some invalid ALPS PS/2 bytes which cause driver out of sync. It looks like that i8042 and psmouse/alps driver always receive group of 6 bytes packets so there are no missing bytes and no bytes were inserted between valid ones. This patch does not fix root of problem with ALPS devices found in Dell Latitude laptops but it does not allow to process some (invalid) subsequence of 6 bytes ALPS packets as 3 bytes PS/2 when driver is out of sync. So with this patch trackstick input device does not report bogus data when also driver is out of sync, so trackstick should be usable on those machines. Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Tested-by: Pali Rohár <pali.rohar@gmail.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14spi: dw: Fix dynamic speed change.Thor Thayer
commit 0a8727e69778683495058852f783eeda141a754e upstream. An IOCTL call that calls spi_setup() and then dw_spi_setup() will overwrite the persisted last transfer speed. On each transfer, the SPI speed is compared to the last transfer speed to determine if the clock divider registers need to be updated (did the speed change?). This bug was observed with the spidev driver using spi-config to update the max transfer speed. This fix: Don't overwrite the persisted last transaction clock speed when updating the SPI parameters in dw_spi_setup(). On the next transaction, the new speed won't match the persisted last speed and the hardware registers will be updated. On initialization, the persisted last transaction clock speed will be 0 but will be updated after the first SPI transaction. Move zeroed clock divider check into clock change test because chip->clk_div is zero on startup and would cause a divide-by-zero error. The calculation was wrong as well (can't support odd #). Reported-by: Vlastimil Setka <setka@vsis.cz> Signed-off-by: Vlastimil Setka <setka@vsis.cz> Signed-off-by: Thor Thayer <tthayer@opensource.altera.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14tty/vt: don't set font mappings on vc not supporting thisImre Deak
commit 9e326f78713a4421fe11afc2ddeac07698fac131 upstream. We can call this function for a dummy console that doesn't support setting the font mapping, which will result in a null ptr BUG. So check for this case and return error for consoles w/o font mapping support. Reference: https://bugzilla.kernel.org/show_bug.cgi?id=59321 Signed-off-by: Imre Deak <imre.deak@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> [bwh: Backported to 3.2: this function doesn't take a lock, so doesn't need to unlock on error] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-12-14tty: Fix high cpu load if tty is unreleaseablePeter Hurley
commit 37b164578826406a173ca7c20d9ba7430134d23e upstream. Kernel oops can cause the tty to be unreleaseable (for example, if n_tty_read() crashes while on the read_wait queue). This will cause tty_release() to endlessly loop without sleeping. Use a killable sleep timeout which grows by 2n+1 jiffies over the interval [0, 120 secs.) and then jumps to forever (but still killable). NB: killable just allows for the task to be rewoken manually, not to be terminated. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
