commit 8d7f6690cedb83456edd41c9bd583783f0703bf0 upstream.
The kernel currently crashes with a low-address-protection exception
if a user space process executes an instruction that tries to use the
linkage stack. Set the base-ASTE origin and the subspace-ASTE origin
of the dispatchable-unit-control-table to point to a dummy ASTE.
Set up control register 15 to point to an empty linkage stack with no
room left.
A user space process with a linkage stack instruction will still crash
but with a different exception which is correctly translated to a
segmentation fault instead of a kernel oops.
commit 5d81de8e8667da7135d3a32a964087c0faf5483f upstream.
It's possible for userland to pass down an iovec via writev() that has a
bogus user pointer in it. If that happens and we're doing an uncached
write, then we can end up getting less bytes than we expect from the
call to iov_iter_copy_from_user. This is CVE-2014-0069
cifs_iovec_write isn't set up to handle that situation however. It'll
blindly keep chugging through the page array and not filling those pages
with anything useful. Worse yet, we'll later end up with a negative
number in wdata->tailsz, which will confuse the sending routines and
cause an oops at the very least.
Fix this by having the copy phase of cifs_iovec_write stop copying data
in this situation and send the last write as a short one. At the same
time, we want to avoid sending a zero-length write to the server, so
break out of the loop and set rc to -EFAULT if that happens. This also
allows us to handle the case where no address in the iovec is valid.
[Note: Marking this for stable on v3.4+ kernels, but kernels as old as
v2.6.38 may have a similar problem and may need similar fix]
Reviewed-by: Pavel Shilovsky <piastry@etersoft.ru>
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Steve French <smfrench@gmail.com>
[bwh: Backported to 3.2:
- Adjust context
- s/nr_pages/npages/
- s/wdata->pages/pages/
- In case of an error with no data copied, we must kunmap() page 0,
but in neither case should we free anything else]
Thanks to Raphael Geissert for an independent backport that showed some
bugs in my first version.]
commit 26a865f4aa8e66a6d94958de7656f7f1b03c6c56 upstream.
After free_loaded_vmcs executes, the "loaded_vmcs" structure
is kfreed, and now vmx->loaded_vmcs points to a kfreed area.
Subsequent free_loaded_vmcs then attempts to manipulate
vmx->loaded_vmcs.
Switch the order to avoid the problem.
https://bugzilla.redhat.com/show_bug.cgi?id=1047892
Reviewed-by: Jan Kiszka <jan.kiszka@siemens.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
commit 989c6b34f6a9480e397b170cc62237e89bf4fdb9 upstream.
It is possible for __direct_map to be called on invalid root_hpa
(-1), two examples:
1) try_async_pf -> can_do_async_pf
-> vmx_interrupt_allowed -> nested_vmx_vmexit
2) vmx_handle_exit -> vmx_interrupt_allowed -> nested_vmx_vmexit
Then to load_vmcs12_host_state and kvm_mmu_reset_context.
Check for this possibility, let fault exception be regenerated.
BZ: https://bugzilla.redhat.com/show_bug.cgi?id=924916
commit d43ff4cd798911736fb39025ec8004284b1b0bc2 upstream.
The struct driver_info ax88178_info is assigned the function
asix_rx_fixup_common as it's rx_fixup callback. This means that
FLAG_MULTI_PACKET must be set as this function is cloning the
data and calling usbnet_skb_return. Not setting this flag leads
to usbnet_skb_return beeing called a second time from within
the rx_process function in the usbnet module.
Signed-off-by: Emil Goode <emilgoode@gmail.com>
Reported-by: Bjørn Mork <bjorn@mork.no>
commit 8b5b6f5413e97c3e8bafcdd67553d508f4f698cd upstream.
ASIX AX88772B started to pack data even more tightly. Packets and the ASIX packet
header may now cross URB boundaries. To handle this we have to introduce
some state between individual calls to asix_rx_fixup().
Signed-off-by: Lucas Stach <dev@lynxeye.de>
[ Emil: backported to 3.2:
- dropped changes to drivers/net/usb/ax88172a.c
- Introduced some static function declarations as the functions
are not used outside of asix.c (sparse is complaining about it) ]
commit a9e0aca4b37885b5599e52211f098bd7f565e749 upstream.
asix_rx_fixup() is complex, and does some unnecessary memory copies (at
least on x86 where NET_IP_ALIGN is 0)
Also, it tends to provide skbs with a big truesize (4096+256 with
MTU=1500) to upper stack, so incoming trafic consume a lot of memory and
I noticed early packet drops because we hit socket rcvbuf too fast.
Switch to a different strategy, using copybreak so that we provide nice
skbs to upper stack (including the NET_SKB_PAD to avoid future head
reallocations in some paths)
With this patch, I no longer see packets drops or tcp collapses on
various tcp workload with a AX88772 adapter.
Cc: Aurelien Jacobs <aurel@gnuage.org>
Cc: Trond Wuellner <trond@chromium.org>
Cc: Grant Grundler <grundler@chromium.org>
Cc: Paul Stewart <pstew@chromium.org>
Reviewed-by: Grant Grundler <grundler@chromium.org>
[ Emil: Backported to 3.2: fixed small conflict ]
commit f8ce239dfc7ba9add41d9ecdc5e7810738f839fa upstream.
builddeb generates a control file that says the linux-headers package
can only be built for the build system primary architecture. This
breaks cross-building configurations. We should use $debarch for this
instead.
Since $debarch is not yet set when generating the control file, set
Architecture: any and use control file variables to fill in the
description.
Fixes: cd8d60a20a45 ('kbuild: create linux-headers package in deb-pkg')
Reported-and-tested-by: "Niew, Sh." <shniew@gmail.com>
commit c5e318f67eebbad491615a752c51dbfde7dc3d78 upstream.
These commands will mysteriously fail:
$ make ARCH=arm versatile_defconfig
$ make ARCH=arm deb-pkg
make[1]: *** [deb-pkg] Error 1
make: *** [deb-pkg] Error 2
The Debian architecture selection for these kernel architectures does
'grep FOO=y $KCONFIG_CONFIG && echo bar', and after 'set -e' this
aborts the script if grep does not find the given config symbol.
Fixes: 10f26fa64200 ('build, deb-pkg: select userland architecture based on UTS_MACHINE')
commit d20917670ee1fd4b090555e551faea04b014ca97 upstream.
Signed-off-by: Anisse Astier <anisse@astier.eu>
Reviewed-by: Ben Hutchings <ben@decadent.org.uk>
[bwh: Backported to 3.2: adjust context]
commit fe6cc55f3a9a053482a76f5a6b2257cee51b4663 upstream.
[ use zero netdev_feature mask to avoid backport of
netif_skb_dev_features function ]
Marcelo Ricardo Leitner reported problems when the forwarding link path
has a lower mtu than the incoming one if the inbound interface supports GRO.
Given:
Host <mtu1500> R1 <mtu1200> R2
Host sends tcp stream which is routed via R1 and R2. R1 performs GRO.
In this case, the kernel will fail to send ICMP fragmentation needed
messages (or pkt too big for ipv6), as GSO packets currently bypass dstmtu
checks in forward path. Instead, Linux tries to send out packets exceeding
the mtu.
When locking route MTU on Host (i.e., no ipv4 DF bit set), R1 does
not fragment the packets when forwarding, and again tries to send out
packets exceeding R1-R2 link mtu.
This alters the forwarding dstmtu checks to take the individual gso
segment lengths into account.
For ipv6, we send out pkt too big error for gso if the individual
segments are too big.
For ipv4, we either send icmp fragmentation needed, or, if the DF bit
is not set, perform software segmentation and let the output path
create fragments when the packet is leaving the machine.
It is not 100% correct as the error message will contain the headers of
the GRO skb instead of the original/segmented one, but it seems to
work fine in my (limited) tests.
Eric Dumazet suggested to simply shrink mss via ->gso_size to avoid
sofware segmentation.
However it turns out that skb_segment() assumes skb nr_frags is related
to mss size so we would BUG there. I don't want to mess with it considering
Herbert and Eric disagree on what the correct behavior should be.
Hannes Frederic Sowa notes that when we would shrink gso_size
skb_segment would then also need to deal with the case where
SKB_MAX_FRAGS would be exceeded.
This uses sofware segmentation in the forward path when we hit ipv4
non-DF packets and the outgoing link mtu is too small. Its not perfect,
but given the lack of bug reports wrt. GRO fwd being broken this is a
rare case anyway. Also its not like this could not be improved later
once the dust settles.
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Reported-by: Marcelo Ricardo Leitner <mleitner@redhat.com>
commit de960aa9ab4decc3304959f69533eef64d05d8e8 upstream.
[ no skb_gso_seglen helper in 3.4, leave tbf alone ]
This moves part of Eric Dumazets skb_gso_seglen helper from tbf sched to
skbuff core so it may be reused by upcoming ip forwarding path patch.
In older kernels (before v3.10) ipc_rcu_hdr->refcount was non-atomic int.
There was possuble double-free bug: do_msgsnd() calls ipc_rcu_putref() under
msq->q_perm->lock and RCU, while freequeue() calls it while it holds only
'rw_mutex', so there is no sinchronization between them. Two function
decrements '2' non-atomically, they both can get '0' as result.
do_msgsnd() freequeue()
msq = msg_lock_check(ns, msqid);
ipc_rcu_getref(msq);
msg_unlock(msq);
schedule();
(caller locks spinlock)
expunge_all(msq, -EIDRM);
ss_wakeup(&msq->q_senders, 1);
msg_rmid(ns, msq);
msg_unlock(msq);
ipc_lock_by_ptr(&msq->q_perm);
ipc_rcu_putref(msq); ipc_rcu_putref(msq);
< both may get get --(...)->refcount == 0 >
This patch locks ipc_lock and RCU around ipc_rcu_putref in freequeue.
( RCU protects memory for spin_unlock() )
Similar bugs might be in other users of ipc_rcu_putref().
In the mainline this has been fixed in v3.10 indirectly in commmit
6062a8dc0517bce23e3c2f7d2fea5e22411269a3
("ipc,sem: fine grained locking for semtimedop") by Rik van Riel.
That commit optimized locking and converted refcount into atomic.
I'm not sure that anybody should care about this bug: it's very-very unlikely
and no longer exists in actual mainline. I've found this just by looking into
the code, probably this never happens in real life.
Signed-off-by: Konstantin Khlebnikov <k.khlebnikov@samsung.com>
commit b22f5126a24b3b2f15448c3f2a254fc10cbc2b92 upstream.
Some occurences in the netfilter tree use skb_header_pointer() in
the following way ...
struct dccp_hdr _dh, *dh;
skb_header_pointer(skb, dataoff, sizeof(_dh), &dh);
... where dh itself is a pointer that is being passed as the copy
buffer. Instead, we need to use &_dh as the forth argument so that
we're copying the data into an actual buffer that sits on the stack.
Currently, we probably could overwrite memory on the stack (e.g.
with a possibly mal-formed DCCP packet), but unintentionally, as
we only want the buffer to be placed into _dh variable.
Fixes: 2bc780499aa3 ("[NETFILTER]: nf_conntrack: add DCCP protocol support")
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
commit 00a1a053ebe5febcfc2ec498bd894f035ad2aa06 upstream.
Use cmpxchg() to atomically set i_flags instead of clearing out the
S_IMMUTABLE, S_APPEND, etc. flags and then setting them from the
EXT4_IMMUTABLE_FL, EXT4_APPEND_FL flags, since this opens up a race
where an immutable file has the immutable flag cleared for a brief
window of time.
Reported-by: John Sullivan <jsrhbz@kanargh.force9.co.uk>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
This is part of commit ca2beaf84d96 ('staging: speakup: Prefix
externally-visible symbols') upstream. It is required as preparation
for commit 00a1a053ebe5 ('ext4: atomically set inode->i_flags in
ext4_set_inode_flags()').
commit 8a0435d958fb36d93b8df610124a0e91e5675c82 upstream.
This extends Benjamin Tissoires manual min/max quirk table with support for
the ThinkPad X240.
commit 421e08c41fda1f0c2ff6af81a67b491389b653a5 upstream.
The new Lenovo Haswell series (-40's) contains a new Synaptics touchpad.
However, these new Synaptics devices report bad axis ranges.
Under Windows, it is not a problem because the Windows driver uses RMI4
over SMBus to talk to the device. Under Linux, we are using the PS/2
fallback interface and it occurs the reported ranges are wrong.
Of course, it would be too easy to have only one range for the whole
series, each touchpad seems to be calibrated in a different way.
We can not use SMBus to get the actual range because I suspect the firmware
will switch into the SMBus mode and stop talking through PS/2 (this is the
case for hybrid HID over I2C / PS/2 Synaptics touchpads).
So as a temporary solution (until RMI4 land into upstream), start a new
list of quirks with the min/max manually set.
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
commit 3cdeb713dc66057b50682048c151eae07b186c42 upstream.
Andreas reported that after 1f42db786b14 ("PCI: Enable INTx if BIOS left
them disabled"), pciehp surprise removal stopped working.
This happens because pci_reenable_device() on the hotplug bridge (used in
the pciehp_configure_device() path) clears the Interrupt Disable bit, which
apparently breaks the bridge's MSI hotplug event reporting.
Previously we cleared the Interrupt Disable bit in do_pci_enable_device(),
which is used by both pci_enable_device() and pci_reenable_device(). But
we use pci_reenable_device() after the driver may have enabled MSI or
MSI-X, and we *set* Interrupt Disable as part of enabling MSI/MSI-X.
This patch clears Interrupt Disable only when MSI/MSI-X has not been
enabled.
Fixes: 1f42db786b14 PCI: Enable INTx if BIOS left them disabled
Link: https://bugzilla.kernel.org/show_bug.cgi?id=71691
Reported-and-tested-by: Andreas Noever <andreas.noever@gmail.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
CC: Sarah Sharp <sarah.a.sharp@linux.intel.com>
commit 3735d524da64b70b41c764359da36f88aded3610 upstream.
If the machine is booted without any cpu_idle driver set
(b/c disable_cpuidle() has been called) we should follow
other users of cpu_idle API and check the return value
for NULL before using it.
Reported-and-tested-by: Mark van Dijk <mark@internecto.net>
Suggested-by: Jan Beulich <JBeulich@suse.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
[ Upstream commit ec0223ec48a90cb605244b45f7c62de856403729 ]
RFC4895 introduced AUTH chunks for SCTP; during the SCTP
handshake RANDOM; CHUNKS; HMAC-ALGO are negotiated (CHUNKS
being optional though):
---------- INIT[RANDOM; CHUNKS; HMAC-ALGO] ---------->
<------- INIT-ACK[RANDOM; CHUNKS; HMAC-ALGO] ---------
-------------------- COOKIE-ECHO -------------------->
<-------------------- COOKIE-ACK ---------------------
A special case is when an endpoint requires COOKIE-ECHO
chunks to be authenticated:
------------------ AUTH; COOKIE-ECHO ---------------->
RFC4895, section 6.3. Receiving Authenticated Chunks says:
The receiver MUST use the HMAC algorithm indicated in
the HMAC Identifier field. If this algorithm was not
specified by the receiver in the HMAC-ALGO parameter in
the INIT or INIT-ACK chunk during association setup, the
AUTH chunk and all the chunks after it MUST be discarded
and an ERROR chunk SHOULD be sent with the error cause
defined in Section 4.1. [...] If no endpoint pair shared
key has been configured for that Shared Key Identifier,
all authenticated chunks MUST be silently discarded. [...]
When an endpoint requires COOKIE-ECHO chunks to be
authenticated, some special procedures have to be followed
because the reception of a COOKIE-ECHO chunk might result
in the creation of an SCTP association. If a packet arrives
containing an AUTH chunk as a first chunk, a COOKIE-ECHO
chunk as the second chunk, and possibly more chunks after
them, and the receiver does not have an STCB for that
packet, then authentication is based on the contents of
the COOKIE-ECHO chunk. In this situation, the receiver MUST
authenticate the chunks in the packet by using the RANDOM
parameters, CHUNKS parameters and HMAC_ALGO parameters
obtained from the COOKIE-ECHO chunk, and possibly a local
shared secret as inputs to the authentication procedure
specified in Section 6.3. If authentication fails, then
the packet is discarded. If the authentication is successful,
the COOKIE-ECHO and all the chunks after the COOKIE-ECHO
MUST be processed. If the receiver has an STCB, it MUST
process the AUTH chunk as described above using the STCB
from the existing association to authenticate the
COOKIE-ECHO chunk and all the chunks after it. [...]
Commit bbd0d59809f9 introduced the possibility to receive
and verification of AUTH chunk, including the edge case for
authenticated COOKIE-ECHO. On reception of COOKIE-ECHO,
the function sctp_sf_do_5_1D_ce() handles processing,
unpacks and creates a new association if it passed sanity
checks and also tests for authentication chunks being
present. After a new association has been processed, it
invokes sctp_process_init() on the new association and
walks through the parameter list it received from the INIT
chunk. It checks SCTP_PARAM_RANDOM, SCTP_PARAM_HMAC_ALGO
and SCTP_PARAM_CHUNKS, and copies them into asoc->peer
meta data (peer_random, peer_hmacs, peer_chunks) in case
sysctl -w net.sctp.auth_enable=1 is set. If in INIT's
SCTP_PARAM_SUPPORTED_EXT parameter SCTP_CID_AUTH is set,
peer_random != NULL and peer_hmacs != NULL the peer is to be
assumed asoc->peer.auth_capable=1, in any other case
asoc->peer.auth_capable=0.
Now, if in sctp_sf_do_5_1D_ce() chunk->auth_chunk is
available, we set up a fake auth chunk and pass that on to
sctp_sf_authenticate(), which at latest in
sctp_auth_calculate_hmac() reliably dereferences a NULL pointer
at position 0..0008 when setting up the crypto key in
crypto_hash_setkey() by using asoc->asoc_shared_key that is
NULL as condition key_id == asoc->active_key_id is true if
the AUTH chunk was injected correctly from remote. This
happens no matter what net.sctp.auth_enable sysctl says.
The fix is to check for net->sctp.auth_enable and for
asoc->peer.auth_capable before doing any operations like
sctp_sf_authenticate() as no key is activated in
sctp_auth_asoc_init_active_key() for each case.
Now as RFC4895 section 6.3 states that if the used HMAC-ALGO
passed from the INIT chunk was not used in the AUTH chunk, we
SHOULD send an error; however in this case it would be better
to just silently discard such a maliciously prepared handshake
as we didn't even receive a parameter at all. Also, as our
endpoint has no shared key configured, section 6.3 says that
MUST silently discard, which we are doing from now onwards.
Before calling sctp_sf_pdiscard(), we need not only to free
the association, but also the chunk->auth_chunk skb, as
commit bbd0d59809f9 created a skb clone in that case.
I have tested this locally by using netfilter's nfqueue and
re-injecting packets into the local stack after maliciously
modifying the INIT chunk (removing RANDOM; HMAC-ALGO param)
and the SCTP packet containing the COOKIE_ECHO (injecting
AUTH chunk before COOKIE_ECHO). Fixed with this patch applied.
Fixes: bbd0d59809f9 ("[SCTP]: Implement the receive and verification of AUTH chunk")
Cc: Vlad Yasevich <yasevich@gmail.com>
Cc: Neil Horman <nhorman@tuxdriver.com>
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
[ Upstream commit d7b95315cc7f441418845a165ee56df723941487 ]
Redefine the RXD_ERR_MASK to include only relevant error bits. This fixes
a customer reported issue of randomly dropping packets on the 5719.
Signed-off-by: Michael Chan <mchan@broadcom.com>
[ Upstream commit 0e7ede80d929ff0f830c44a543daa1acd590c749 ]
We should alloc big buffers also when guest can receive UFO
packets to let the big packets fit into guest rx buffer.
Fixes 5c5167515d80f78f6bb538492c423adcae31ad65
(virtio-net: Allow UFO feature to be set and advertised.)
Cc: Michael S. Tsirkin <mst@redhat.com>
Cc: Sridhar Samudrala <sri@us.ibm.com>
Signed-off-by: Jason Wang <jasowang@redhat.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
commit 5a581b367b5df0531265311fc681c2abd377e5e6 upstream.
According to the C standard 3.4.3p3, overflow of a signed integer results
in undefined behavior. This commit therefore changes the definitions
of time_after(), time_after_eq(), time_after64(), and time_after_eq64()
to avoid this undefined behavior. The trick is that the subtraction
is done using unsigned arithmetic, which according to 6.2.5p9 cannot
overflow because it is defined as modulo arithmetic. This has the added
(though admittedly quite small) benefit of shortening four lines of code
by four characters each.
Note that the C standard considers the cast from unsigned to
signed to be implementation-defined, see 6.3.1.3p3. However, on a
two's-complement system, an implementation that defines anything other
than a reinterpretation of the bits is free to come to me, and I will be
happy to act as a witness for its being committed to an insane asylum.
(Although I have nothing against saturating arithmetic or signals in some
cases, these things really should not be the default when compiling an
operating-system kernel.)
Cc: John Stultz <john.stultz@linaro.org>
Cc: Kevin Easton <kevin@guarana.org>
[ paulmck: Included time_after64() and time_after_eq64(), as suggested
by Eric Dumazet, also fixed commit message.]
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
commit 1f91ecc14deea9461aca93273d78871ec4d98fcd upstream.
When selecting the audio output destinations (headphones, FP headphones,
multichannel output), unnecessary I2S channels are digitally muted to
avoid invalid signal levels on the other outputs.
Signed-off-by: Roman Volkov <v1ron@mail.ru>
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
commit 3dd77654fb1d7f68b9739f3039bad8dbbc0739f8 upstream.
Actually CS4245 connected to the I2S channel 1 for
capture, not channel 2. Otherwise capturing and
playback does not work for CS4245.
commit e6355ad7b1c6f70e2f48ae159f5658b441ccff95 upstream.
snd_pcm_stop() must be called in the PCM substream lock context.
[wml: Backported to 3.4: Adjust filename]
Signed-off-by: Weng Meiling <wengmeiling.weng@huawei.com>
commit 0b7bc84000d71f3647ca33ab1bf5bd928535c846 upstream.
Setting this secFlg allows usage of dfs where some servers require
signing and others don't.
Signed-off-by: Martijn de Gouw <martijn.de.gouw@prodrive.nl>
Signed-off-by: Steve French <sfrench@us.ibm.com>
[Joseph Salisbury: This backport was done so including mainline commit
8830d7e07a5e38bc47650a7554b7c1cfd49902bf is not needed.]
BugLink: http://bugs.launchpad.net/bugs/1285723
Signed-off-by: Joseph Salisbury <joseph.salisbury@canonical.com>
[ Upstream commit ffd5939381c609056b33b7585fb05a77b4c695f3 ]
SCTP's sctp_connectx() abi breaks for 64bit kernels compiled with 32bit
emulation (e.g. ia32 emulation or x86_x32). Due to internal usage of
'struct sctp_getaddrs_old' which includes a struct sockaddr pointer,
sizeof(param) check will always fail in kernel as the structure in
64bit kernel space is 4bytes larger than for user binaries compiled
in 32bit mode. Thus, applications making use of sctp_connectx() won't
be able to run under such circumstances.
Introduce a compat interface in the kernel to deal with such
situations by using a 'struct compat_sctp_getaddrs_old' structure
where user data is copied into it, and then sucessively transformed
into a 'struct sctp_getaddrs_old' structure with the help of
compat_ptr(). That fixes sctp_connectx() abi without any changes
needed in user space, and lets the SCTP test suite pass when compiled
in 32bit and run on 64bit kernels.
Fixes: f9c67811ebc0 ("sctp: Fix regression introduced by new sctp_connectx api")
[ Upstream commit 163c8ff30dbe473abfbb24a7eac5536c87f3baa9 ]
aggregator_identifier is used to assign unique aggregator identifiers
to aggregators of a bond during device enslaving.
aggregator_identifier is currently a global variable that is zeroed in
bond_3ad_initialize().
This sequence will lead to duplicate aggregator identifiers for eth1 and eth3:
create bond0
change bond0 mode to 802.3ad
enslave eth0 to bond0 //eth0 gets agg id 1
enslave eth1 to bond0 //eth1 gets agg id 2
create bond1
change bond1 mode to 802.3ad
enslave eth2 to bond1 //aggregator_identifier is reset to 0
//eth2 gets agg id 1
enslave eth3 to bond0 //eth3 gets agg id 2
Fix this by making aggregator_identifier private to the bond.
Signed-off-by: Jiri Bohac <jbohac@suse.cz>
Acked-by: Veaceslav Falico <vfalico@redhat.com>
[ Upstream commit eb85569fe2d06c2fbf4de7b66c263ca095b397aa ]
This patch removes a generic hard_header_len check from the usbnet
module that is causing dropped packages under certain circumstances
for devices that send rx packets that cross urb boundaries.
One example is the AX88772B which occasionally send rx packets that
cross urb boundaries where the remaining partial packet is sent with
no hardware header. When the buffer with a partial packet is of less
number of octets than the value of hard_header_len the buffer is
discarded by the usbnet module.
With AX88772B this can be reproduced by using ping with a packet
size between 1965-1976.
The bug has been reported here:
https://bugzilla.kernel.org/show_bug.cgi?id=29082
This patch introduces the following changes:
- Removes the generic hard_header_len check in the rx_complete
- Introduces a ETH_HLEN check for skbs that are not cloned from
within a rx_fixup callback.
- For safety a hard_header_len check is added to each rx_fixup
callback function that could be affected by this change.
These extra checks could possibly be removed by someone
who has the hardware to test.
- Removes a call to dev_kfree_skb_any() and instead utilizes the
dev->done list to queue skbs for cleanup.
The changes place full responsibility on the rx_fixup callback
functions that clone skbs to only pass valid skbs to the
usbnet_skb_return function.
Reported-by: Igor Gnatenko <i.gnatenko.brain@gmail.com>
[ Upstream commit c6993dfd7db9b0c6b7ca7503a56fda9236a4710f ]
Quoting David Vrabel -
"5780 cards cannot have jumbo frames and TSO enabled together. When
jumbo frames are enabled by setting the MTU, the TSO feature must be
cleared. This is done indirectly by calling netdev_update_features()
which will call tg3_fix_features() to actually clear the flags.
netdev_update_features() will also trigger a new netlink message for the
feature change event which will result in a call to tg3_get_stats64()
which deadlocks on the tg3 lock."
tg3_set_mtu() does not need to be under the tg3 lock since converting
the flags to use set_bit(). Move it out to after tg3_netif_stop().
Reported-by: David Vrabel <david.vrabel@citrix.com>
Tested-by: David Vrabel <david.vrabel@citrix.com>
Signed-off-by: Nithin Nayak Sujir <nsujir@broadcom.com>
[ Upstream commit 946c032e5a53992ea45e062ecb08670ba39b99e3 ]
ip rules with iif/oif references do not update:
(detach/attach) across interface renames.
Signed-off-by: Maciej Żenczykowski <maze@google.com>
CC: Willem de Bruijn <willemb@google.com>
CC: Eric Dumazet <edumazet@google.com>
CC: Chris Davis <chrismd@google.com>
CC: Carlo Contavalli <ccontavalli@google.com>
Google-Bug-Id: 12936021
commit 85eae82a0855d49852b87deac8653e4ebc8b291f upstream.
The console_cpu_notify() function runs with interrupts disabled in the
CPU_DYING case. It therefore cannot block, for example, as will happen
when it calls console_lock(). Therefore, remove the CPU_DYING leg of
the switch statement to avoid this problem.
Reviewed-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
fixed upstream in v3.6 by ec145babe754f9ea1079034a108104b6001e001c
get_monotonic_boottime adds three nanonsecond values stored
in longs, followed by an s64. If the long values are all
close to 1e9 the first three additions can overflow and
become negative when added to the s64. Cast the first
value to s64 so that all additions are 64 bit.
Signed-off-by: Colin Cross <ccross@android.com>
[jstultz: Fished this out of the AOSP commong.git tree. This was
fixed upstream in v3.6 by ec145babe754f9ea1079034a108104b6001e001c]
Signed-off-by: John Stultz <john.stultz@linaro.org>
commit 23a8e8441a0a74dd612edf81dc89d1600bc0a3d1 upstream.
Doing some different tests, I discovered that function graph tracing, when
filtered via the set_ftrace_filter and set_ftrace_notrace files, does
not always keep with them if another function ftrace_ops is registered
to trace functions.
The reason is that function graph just happens to trace all functions
that the function tracer enables. When there was only one user of
function tracing, the function graph tracer did not need to worry about
being called by functions that it did not want to trace. But now that there
are other users, this becomes a problem.
For example, one just needs to do the following:
# cd /sys/kernel/debug/tracing
# echo schedule > set_ftrace_filter
# echo function_graph > current_tracer
# cat trace
0) | schedule() {
0) <idle>-0 => rcu_pre-7
0) ! 2980.314 us | }
0) | schedule() {
0) rcu_pre-7 => <idle>-0
0) + 20.701 us | }
# echo 1 > /proc/sys/kernel/stack_tracer_enabled
# cat trace
1) + 20.825 us | }
1) + 21.651 us | }
1) + 30.924 us | } /* SyS_ioctl */
1) | do_page_fault() {
1) | __do_page_fault() {
1) 0.274 us | down_read_trylock();
1) 0.098 us | find_vma();
1) | handle_mm_fault() {
1) | _raw_spin_lock() {
1) 0.102 us | preempt_count_add();
1) 0.097 us | do_raw_spin_lock();
1) 2.173 us | }
1) | do_wp_page() {
1) 0.079 us | vm_normal_page();
1) 0.086 us | reuse_swap_page();
1) 0.076 us | page_move_anon_rmap();
1) | unlock_page() {
1) 0.082 us | page_waitqueue();
1) 0.086 us | __wake_up_bit();
1) 1.801 us | }
1) 0.075 us | ptep_set_access_flags();
1) | _raw_spin_unlock() {
1) 0.098 us | do_raw_spin_unlock();
1) 0.105 us | preempt_count_sub();
1) 1.884 us | }
1) 9.149 us | }
1) + 13.083 us | }
1) 0.146 us | up_read();
When the stack tracer was enabled, it enabled all functions to be traced, which
now the function graph tracer also traces. This is a side effect that should
not occur.
To fix this a test is added when the function tracing is changed, as well as when
the graph tracer is enabled, to see if anything other than the ftrace global_ops
function tracer is enabled. If so, then the graph tracer calls a test trampoline
that will look at the function that is being traced and compare it with the
filters defined by the global_ops.
As an optimization, if there's no other function tracers registered, or if
the only registered function tracers also use the global ops, the function
graph infrastructure will call the registered function graph callback directly
and not go through the test trampoline.
Fixes: d2d45c7a03a2 "tracing: Have stack_tracer use a separate list of functions"
commit 31abdab9c11bb1694ecd1476a7edbe8e964d94ac upstream.
For one thing, there's an ABBA deadlock on hpfs fs-wide lock and i_mutex
in hpfs_dir_lseek() - there's a lot of methods that grab the former with
the caller already holding the latter, so it must take i_mutex first.
For another, locking the damn thing, carefully validating the offset,
then dropping locks and assigning the offset is obviously racy.
Moreover, we _must_ do hpfs_add_pos(), or the machinery in dnode.c
won't modify the sucker on B-tree surgeries.
commit 2cbe5c76fc5e38e9af4b709593146e4b8272b69e upstream.
Previously, hpfs scanned all bitmaps each time the user asked for free
space using statfs. This patch changes it so that hpfs scans the
bitmaps only once, remembes the free space and on next invocation of
statfs it returns the value instantly.
New versions of wine are hammering on the statfs syscall very heavily,
making some games unplayable when they're stored on hpfs, with load
times in minutes.
This should be backported to the stable kernels because it fixes
user-visible problem (excessive level load times in wine).
Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz>
[ kamal: backport to 3.8 (no hpfs_prefetch_bitmap) ]
Signed-off-by: Kamal Mostafa <kamal@canonical.com>
commit dc1dc2f8a5dd863bf2e79f338fc3ae29e99c683a upstream.
When booting a multi-platform m68k kernel on a non-Mac with "console=ttyS0"
on the kernel command line, it crashes with:
Unable to handle kernel NULL pointer dereference at virtual address (null)
Oops: 00000000
PC: [<0013ad28>] __pmz_startup+0x32/0x2a0
Call Trace: [<002c5d3e>] pmz_console_setup+0x64/0xe4
The normal tty driver doesn't crash, because init_pmz() checks
pmz_ports_count again after calling pmz_probe().
In the serial console initialization path, pmz_console_init() doesn't do
this, causing the driver to crash later.
Add a check for pmz_ports_count to fix this.
Cc: Finn Thain <fthain@telegraphics.com.au>
commit 98398c32f6687ee1e1f3ae084effb4b75adb0747 upstream.
In __page_check_address(), if address's pud is not present,
huge_pte_offset() will return NULL, we should check the return value.
Signed-off-by: Jianguo Wu <wujianguo@huawei.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: qiuxishi <qiuxishi@huawei.com>
Cc: Hanjun Guo <guohanjun@huawei.com>
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
commit 3873d064b8538686bbbd4b858dc8a07db1f7f43a upstream.
When compiling a 32bit kernel with CONFIG_LBDAF=n the compiler complains like
shown below. Fix this warning by instead using sector_div() which is provided
by the kernel.h header file.
fs/nfs/blocklayout/extents.c: In function ‘normalize’:
include/asm-generic/div64.h:43:28: warning: comparison of distinct pointer types lacks a cast [enabled by default]
fs/nfs/blocklayout/extents.c:47:13: note: in expansion of macro ‘do_div’
nfs/blocklayout/extents.c:47:2: warning: right shift count >= width of type [enabled by default]
fs/nfs/blocklayout/extents.c:47:2: warning: passing argument 1 of ‘__div64_32’ from incompatible pointer type [enabled by default]
include/asm-generic/div64.h:35:17: note: expected ‘uint64_t *’ but argument is of type ‘sector_t *’
extern uint32_t __div64_32(uint64_t *dividend, uint32_t divisor);
Signed-off-by: Helge Deller <deller@gmx.de>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit 2fd2bdfccae61efe18f6b92b6a45fbf936d75b48 upstream.
pcmuio_detach() is called by the comedi core even if pcmuio_attach()
returned an error, so `dev->private` might be `NULL`. Check for that
before dereferencing it.
Also, as pointed out by Dan Carpenter, there is no need to check the
pointer passed to `kfree()` is non-NULL, so remove that check.
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
Cc: Dan Carpenter <dan.carpenter@oracle.com>
[Part of commit f6b316bcd8c421acd6fa5a6e18b4c846ecb9d965 upstream.
Split from original patch subject: "staging: comedi: ssv_dnp: use
comedi_dio_update_state()"]
Also, fix a bug where the state of the channels is returned in data[0].
The comedi core expects it to be returned in data[1].
commit 847d7970defb45540735b3fb4e88471c27cacd85 upstream.
For systems with multiple servers and routed fabric, all
northbridges get assigned to the first server. Fix this by also
using the node reported from the PCI bus. For single-fabric
systems, the northbriges are on PCI bus 0 by definition, which
are on NUMA node 0 by definition, so this is invarient on most
systems.
Tested on fam10h and fam15h single and multi-fabric systems and
candidate for stable.
Signed-off-by: Daniel J Blueman <daniel@numascale.com>
Acked-by: Steffen Persvold <sp@numascale.com>
Acked-by: Borislav Petkov <bp@suse.de>
Link: http://lkml.kernel.org/r/1394710981-3596-1-git-send-email-daniel@numascale.com
commit 0a8d8c446b5429d15ff2d48f46e00d8a08552303 upstream.
Since commit d25f06ea466e "vmxnet3: fix netpoll race condition",
the vmxnet3 driver fails to build when CONFIG_PCI_MSI is disabled,
because it unconditionally references the vmxnet3_msix_rx()
function.
To fix this, use the same #ifdef in the caller that exists around
the function definition.
Cc: Shreyas Bhatewara <sbhatewara@vmware.com>
Cc: "VMware, Inc." <pv-drivers@vmware.com>
commit 596f3142d2b7be307a1652d59e7b93adab918437 upstream.
We always disable cr8 intercept in its handler, but only re-enable it
if handling KVM_REQ_EVENT, so there can be a window where we do not
intercept cr8 writes, which allows an interrupt to disrupt a higher
priority task.
Fix this by disabling intercepts in the same function that re-enables
them when needed. This fixes BSOD in Windows 2008.
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com>
commit d25f06ea466ea521b563b76661180b4e44714ae6 upstream.
vmxnet3's netpoll driver is incorrectly coded. It directly calls
vmxnet3_do_poll, which is the driver internal napi poll routine. As the netpoll
controller method doesn't block real napi polls in any way, there is a potential
for race conditions in which the netpoll controller method and the napi poll
method run concurrently. The result is data corruption causing panics such as this
one recently observed:
PID: 1371 TASK: ffff88023762caa0 CPU: 1 COMMAND: "rs:main Q:Reg"
#0 [ffff88023abd5780] machine_kexec at ffffffff81038f3b
#1 [ffff88023abd57e0] crash_kexec at ffffffff810c5d92
#2 [ffff88023abd58b0] oops_end at ffffffff8152b570
#3 [ffff88023abd58e0] die at ffffffff81010e0b
#4 [ffff88023abd5910] do_trap at ffffffff8152add4
#5 [ffff88023abd5970] do_invalid_op at ffffffff8100cf95
#6 [ffff88023abd5a10] invalid_op at ffffffff8100bf9b
[exception RIP: vmxnet3_rq_rx_complete+1968]
RIP: ffffffffa00f1e80 RSP: ffff88023abd5ac8 RFLAGS: 00010086
RAX: 0000000000000000 RBX: ffff88023b5dcee0 RCX: 00000000000000c0
RDX: 0000000000000000 RSI: 00000000000005f2 RDI: ffff88023b5dcee0
RBP: ffff88023abd5b48 R8: 0000000000000000 R9: ffff88023a3b6048
R10: 0000000000000000 R11: 0000000000000002 R12: ffff8802398d4cd8
R13: ffff88023af35140 R14: ffff88023b60c890 R15: 0000000000000000
ORIG_RAX: ffffffffffffffff CS: 0010 SS: 0018
#7 [ffff88023abd5b50] vmxnet3_do_poll at ffffffffa00f204a [vmxnet3]
#8 [ffff88023abd5b80] vmxnet3_netpoll at ffffffffa00f209c [vmxnet3]
#9 [ffff88023abd5ba0] netpoll_poll_dev at ffffffff81472bb7
The fix is to do as other drivers do, and have the poll controller call the top
half interrupt handler, which schedules a napi poll properly to recieve frames
Tested by myself, successfully.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
CC: Shreyas Bhatewara <sbhatewara@vmware.com>
CC: "VMware, Inc." <pv-drivers@vmware.com>
CC: "David S. Miller" <davem@davemloft.net>
Reviewed-by: Shreyas N Bhatewara <sbhatewara@vmware.com>
commit 1b56e98990bcdbb20b9fab163654b9315bf158e8 upstream.
