2013-07-27Linux 3.2.49v3.2.49Ben Hutchings
2013-07-27MAINTAINERS: add stable_kernel_rules.txt to stable maintainer informationGreg Kroah-Hartman
commit 7b175c46720f8e6b92801bb634c93d1016f80c62 upstream. This hopefully will help point developers to the proper way that patches should be submitted for inclusion in the stable kernel releases. Reported-by: David Howells <dhowells@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27MAINTAINERS: Greg's suse email address is deadGreg KH
commit 879a5a001b62a020e074d460b3a7c0fd993f9832 upstream. My email address has changed, the suse.de one is now dead, so update all of my MAINTAINER entries with the correct one so that patches don't get lost. Also change the status of some of my entries as I'm supposed to be doing this stuff now for real. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27ext4: fix data offset overflow in ext4_xattr_fiemap() on 32-bit archsJan Kara
commit a60697f411eb365fb09e639e6f183fe33d1eb796 upstream. On 32-bit architectures with 32-bit sector_t computation of data offset in ext4_xattr_fiemap() can overflow resulting in reporting bogus data location. Fix the problem by typing block number to proper type before shifting. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27ext4: fix overflow when counting used blocks on 32-bit architecturesJan Kara
commit 8af8eecc1331dbf5e8c662022272cf667e213da5 upstream. The arithmetics adding delalloc blocks to the number of used blocks in ext4_getattr() can easily overflow on 32-bit archs as we first multiply number of blocks by blocksize and then divide back by 512. Make the arithmetics more clever and also use proper type (unsigned long long instead of unsigned long). Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27drivers/cdrom/cdrom.c: use kzalloc() for failing hardwareJonathan Salwan
commit 542db01579fbb7ea7d1f7bb9ddcef1559df660b2 upstream. In drivers/cdrom/cdrom.c mmc_ioctl_cdrom_read_data() allocates a memory area with kmalloc in line 2885. 2885 cgc->buffer = kmalloc(blocksize, GFP_KERNEL); 2886 if (cgc->buffer == NULL) 2887 return -ENOMEM; In line 2908 we can find the copy_to_user function: 2908 if (!ret && copy_to_user(arg, cgc->buffer, blocksize)) The cgc->buffer is never cleaned and initialized before this function. If ret = 0 with the previous basic block, it's possible to display some memory bytes in kernel space from userspace. When we read a block from the disk it normally fills the ->buffer but if the drive is malfunctioning there is a chance that it would only be partially filled. The result is an leak information to userspace. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27pch_uart: fix a deadlock when pch_uart as consoleLiang Li
commit 384e301e3519599b000c1a2ecd938b533fc15d85 upstream. When we use pch_uart as system console like 'console=ttyPCH0,115200', then 'send break' to it. We'll encounter the deadlock on a cpu/core, with interrupts disabled on the core. When we happen to have all irqs affinity to cpu0 then the deadlock on cpu0 actually deadlock whole system. In pch_uart_interrupt, we have spin_lock_irqsave(&priv->lock, flags) then call pch_uart_err_ir when break is received. Then the call to dev_err would actually call to pch_console_write then we'll run into another spin_lock(&priv->lock), with interrupts disabled. So in the call sequence lead by pch_uart_interrupt, we should be carefully to call functions that will 'print message to console' only in case the uart port is not being used as serial console. Signed-off-by: Liang Li <liang.li@windriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27perf: Fix mmap() accounting holePeter Zijlstra
commit 9bb5d40cd93c9dd4be74834b1dcb1ba03629716b upstream. Vince's fuzzer once again found holes. This time it spotted a leak in the locked page accounting. When an event had redirected output and its close() was the last reference to the buffer we didn't have a vm context to undo accounting. Change the code to destroy the buffer on the last munmap() and detach all redirected events at that time. This provides us the right context to undo the vm accounting. [Backporting for 3.4-stable. VM_RESERVED flag was replaced with pair 'VM_DONTEXPAND | VM_DONTDUMP' in 314e51b9 since 3.7.0-rc1, and 314e51b9 comes from a big patchset, we didn't backport the patchset, so I restored 'VM_DNOTEXPAND | VM_DONTDUMP' as before: - vma->vm_flags |= VM_DONTCOPY | VM_DONTEXPAND | VM_DONTDUMP; + vma->vm_flags |= VM_DONTCOPY | VM_RESERVED; -- zliu] Reported-and-tested-by: Vince Weaver <vincent.weaver@maine.edu> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20130604084421.GI8923@twins.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Zhouping Liu <zliu@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> [bwh: Backported to 3.2: drop unrelated addition of braces in free_event()] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27perf: Fix perf mmap bugsPeter Zijlstra
commit 26cb63ad11e04047a64309362674bcbbd6a6f246 upstream. Vince reported a problem found by his perf specific trinity fuzzer. Al noticed 2 problems with perf's mmap(): - it has issues against fork() since we use vma->vm_mm for accounting. - it has an rb refcount leak on double mmap(). We fix the issues against fork() by using VM_DONTCOPY; I don't think there's code out there that uses this; we didn't hear about weird accounting problems/crashes. If we do need this to work, the previously proposed VM_PINNED could make this work. Aside from the rb reference leak spotted by Al, Vince's example prog was indeed doing a double mmap() through the use of perf_event_set_output(). This exposes another problem, since we now have 2 events with one buffer, the accounting gets screwy because we account per event. Fix this by making the buffer responsible for its own accounting. [Backporting for 3.4-stable. VM_RESERVED flag was replaced with pair 'VM_DONTEXPAND | VM_DONTDUMP' in 314e51b9 since 3.7.0-rc1, and 314e51b9 comes from a big patchset, we didn't backport the patchset, so I restored 'VM_DNOTEXPAND | VM_DONTDUMP' as before: - vma->vm_flags |= VM_DONTCOPY | VM_DONTEXPAND | VM_DONTDUMP; + vma->vm_flags |= VM_DONTCOPY | VM_RESERVED; -- zliu] Reported-by: Vince Weaver <vincent.weaver@maine.edu> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Link: http://lkml.kernel.org/r/20130528085548.GA12193@twins.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Zhouping Liu <zliu@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27ceph: fix statvfs fr_sizeSage Weil
commit 92a49fb0f79f3300e6e50ddf56238e70678e4202 upstream. Different versions of glibc are broken in different ways, but the short of it is that for the time being, frsize should == bsize, and be used as the multiple for the blocks, free, and available fields. This mirrors what is done for NFS. The previous reporting of the page size for frsize meant that newer glibc and df would report a very small value for the fs size. Fixes http://tracker.ceph.com/issues/3793. Signed-off-by: Sage Weil <sage@inktank.com> Reviewed-by: Greg Farnum <greg@inktank.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27perf: Fix perf_lock_task_context() vs RCUPeter Zijlstra
commit 058ebd0eba3aff16b144eabf4510ed9510e1416e upstream. Jiri managed to trigger this warning: [] ====================================================== [] [ INFO: possible circular locking dependency detected ] [] 3.10.0+ #228 Tainted: G W [] ------------------------------------------------------- [] p/6613 is trying to acquire lock: [] (rcu_node_0){..-...}, at: [<ffffffff810ca797>] rcu_read_unlock_special+0xa7/0x250 [] [] but task is already holding lock: [] (&ctx->lock){-.-...}, at: [<ffffffff810f2879>] perf_lock_task_context+0xd9/0x2c0 [] [] which lock already depends on the new lock. [] [] the existing dependency chain (in reverse order) is: [] [] -> #4 (&ctx->lock){-.-...}: [] -> #3 (&rq->lock){-.-.-.}: [] -> #2 (&p->pi_lock){-.-.-.}: [] -> #1 (&rnp->nocb_gp_wq[1]){......}: [] -> #0 (rcu_node_0){..-...}: Paul was quick to explain that due to preemptible RCU we cannot call rcu_read_unlock() while holding scheduler (or nested) locks when part of the read side critical section was preemptible. Therefore solve it by making the entire RCU read side non-preemptible. Also pull out the retry from under the non-preempt to play nice with RT. Reported-by: Jiri Olsa <jolsa@redhat.com> Helped-out-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27perf: Remove WARN_ON_ONCE() check in __perf_event_enable() for valid scenarioJiri Olsa
commit 06f417968beac6e6b614e17b37d347aa6a6b1d30 upstream. The '!ctx->is_active' check has a valid scenario, so there's no need for the warning. The reason is that there's a time window between the 'ctx->is_active' check in the perf_event_enable() function and the __perf_event_enable() function having: - IRQs on - ctx->lock unlocked where the task could be killed and 'ctx' deactivated by perf_event_exit_task(), ending up with the warning below. So remove the WARN_ON_ONCE() check and add comments to explain it all. This addresses the following warning reported by Vince Weaver: [ 324.983534] ------------[ cut here ]------------ [ 324.984420] WARNING: at kernel/events/core.c:1953 __perf_event_enable+0x187/0x190() [ 324.984420] Modules linked in: [ 324.984420] CPU: 19 PID: 2715 Comm: nmi_bug_snb Not tainted 3.10.0+ #246 [ 324.984420] Hardware name: Supermicro X8DTN/X8DTN, BIOS 4.6.3 01/08/2010 [ 324.984420] 0000000000000009 ffff88043fce3ec8 ffffffff8160ea0b ffff88043fce3f00 [ 324.984420] ffffffff81080ff0 ffff8802314fdc00 ffff880231a8f800 ffff88043fcf7860 [ 324.984420] 0000000000000286 ffff880231a8f800 ffff88043fce3f10 ffffffff8108103a [ 324.984420] Call Trace: [ 324.984420] <IRQ> [<ffffffff8160ea0b>] dump_stack+0x19/0x1b [ 324.984420] [<ffffffff81080ff0>] warn_slowpath_common+0x70/0xa0 [ 324.984420] [<ffffffff8108103a>] warn_slowpath_null+0x1a/0x20 [ 324.984420] [<ffffffff81134437>] __perf_event_enable+0x187/0x190 [ 324.984420] [<ffffffff81130030>] remote_function+0x40/0x50 [ 324.984420] [<ffffffff810e51de>] generic_smp_call_function_single_interrupt+0xbe/0x130 [ 324.984420] [<ffffffff81066a47>] smp_call_function_single_interrupt+0x27/0x40 [ 324.984420] [<ffffffff8161fd2f>] call_function_single_interrupt+0x6f/0x80 [ 324.984420] <EOI> [<ffffffff816161a1>] ? _raw_spin_unlock_irqrestore+0x41/0x70 [ 324.984420] [<ffffffff8113799d>] perf_event_exit_task+0x14d/0x210 [ 324.984420] [<ffffffff810acd04>] ? switch_task_namespaces+0x24/0x60 [ 324.984420] [<ffffffff81086946>] do_exit+0x2b6/0xa40 [ 324.984420] [<ffffffff8161615c>] ? _raw_spin_unlock_irq+0x2c/0x30 [ 324.984420] [<ffffffff81087279>] do_group_exit+0x49/0xc0 [ 324.984420] [<ffffffff81096854>] get_signal_to_deliver+0x254/0x620 [ 324.984420] [<ffffffff81043057>] do_signal+0x57/0x5a0 [ 324.984420] [<ffffffff8161a164>] ? __do_page_fault+0x2a4/0x4e0 [ 324.984420] [<ffffffff8161665c>] ? retint_restore_args+0xe/0xe [ 324.984420] [<ffffffff816166cd>] ? retint_signal+0x11/0x84 [ 324.984420] [<ffffffff81043605>] do_notify_resume+0x65/0x80 [ 324.984420] [<ffffffff81616702>] retint_signal+0x46/0x84 [ 324.984420] ---[ end trace 442ec2f04db3771a ]--- Reported-by: Vince Weaver <vincent.weaver@maine.edu> Signed-off-by: Jiri Olsa <jolsa@redhat.com> Suggested-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1373384651-6109-2-git-send-email-jolsa@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27perf: Clone child context from parent context pmuJiri Olsa
commit 734df5ab549ca44f40de0f07af1c8803856dfb18 upstream. Currently when the child context for inherited events is created, it's based on the pmu object of the first event of the parent context. This is wrong for the following scenario: - HW context having HW and SW event - HW event got removed (closed) - SW event stays in HW context as the only event and its pmu is used to clone the child context The issue starts when the cpu context object is touched based on the pmu context object (__get_cpu_context). In this case the HW context will work with SW cpu context ending up with following WARN below. Fixing this by using parent context pmu object to clone from child context. Addresses the following warning reported by Vince Weaver: [ 2716.472065] ------------[ cut here ]------------ [ 2716.476035] WARNING: at kernel/events/core.c:2122 task_ctx_sched_out+0x3c/0x) [ 2716.476035] Modules linked in: nfsd auth_rpcgss oid_registry nfs_acl nfs locn [ 2716.476035] CPU: 0 PID: 3164 Comm: perf_fuzzer Not tainted 3.10.0-rc4 #2 [ 2716.476035] Hardware name: AOpen DE7000/nMCP7ALPx-DE R1.06 Oct.19.2012, BI2 [ 2716.476035] 0000000000000000 ffffffff8102e215 0000000000000000 ffff88011fc18 [ 2716.476035] ffff8801175557f0 0000000000000000 ffff880119fda88c ffffffff810ad [ 2716.476035] ffff880119fda880 ffffffff810af02a 0000000000000009 ffff880117550 [ 2716.476035] Call Trace: [ 2716.476035] [<ffffffff8102e215>] ? warn_slowpath_common+0x5b/0x70 [ 2716.476035] [<ffffffff810ab2bd>] ? task_ctx_sched_out+0x3c/0x5f [ 2716.476035] [<ffffffff810af02a>] ? perf_event_exit_task+0xbf/0x194 [ 2716.476035] [<ffffffff81032a37>] ? do_exit+0x3e7/0x90c [ 2716.476035] [<ffffffff810cd5ab>] ? __do_fault+0x359/0x394 [ 2716.476035] [<ffffffff81032fe6>] ? do_group_exit+0x66/0x98 [ 2716.476035] [<ffffffff8103dbcd>] ? get_signal_to_deliver+0x479/0x4ad [ 2716.476035] [<ffffffff810ac05c>] ? __perf_event_task_sched_out+0x230/0x2d1 [ 2716.476035] [<ffffffff8100205d>] ? do_signal+0x3c/0x432 [ 2716.476035] [<ffffffff810abbf9>] ? ctx_sched_in+0x43/0x141 [ 2716.476035] [<ffffffff810ac2ca>] ? perf_event_context_sched_in+0x7a/0x90 [ 2716.476035] [<ffffffff810ac311>] ? __perf_event_task_sched_in+0x31/0x118 [ 2716.476035] [<ffffffff81050dd9>] ? mmdrop+0xd/0x1c [ 2716.476035] [<ffffffff81051a39>] ? finish_task_switch+0x7d/0xa6 [ 2716.476035] [<ffffffff81002473>] ? do_notify_resume+0x20/0x5d [ 2716.476035] [<ffffffff813654f5>] ? retint_signal+0x3d/0x78 [ 2716.476035] ---[ end trace 827178d8a5966c3d ]--- Reported-by: Vince Weaver <vincent.weaver@maine.edu> Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1373384651-6109-1-git-send-email-jolsa@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27iscsi-target: Fix tfc_tpg_nacl_auth_cit configfs length overflowJörn Engel
commit 0fbfc46fb0b2f543a8b539e94c6c293ebc0b05a6 upstream. This patch fixes a potential buffer overflow while processing iscsi_node_auth input for configfs attributes within NodeACL tfc_tpg_nacl_auth_cit context. Signed-off-by: Joern Engel <joern@logfs.org> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27megaraid_sas: fix memory leak if SGL has zero length entriesBjørn Mork
commit 7a6a731bd00ca90d0e250867c3b9c05b5ff0fa49 upstream. commit 98cb7e44 ([SCSI] megaraid_sas: Sanity check user supplied length before passing it to dma_alloc_coherent()) introduced a memory leak. Memory allocated for entries following zero length SGL entries will not be freed. Reference: http://bugs.debian.org/688198 Signed-off-by: Bjørn Mork <bjorn@mork.no> Acked-by: Adam Radford <aradford@gmail.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27hpfs: better test for errorsMikulas Patocka
commit 3ebacb05044f82c5f0bb456a894eb9dc57d0ed90 upstream. The test if bitmap access is out of bound could errorneously pass if the device size is divisible by 16384 sectors and we are asking for one bitmap after the end. Check for invalid size in the superblock. Invalid size could cause integer overflows in the rest of the code. Signed-off-by: Mikulas Patocka <mpatocka@artax.karlin.mff.cuni.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27nbd: correct disconnect behaviorPaul Clements
commit c378f70adbc1bbecd9e6db145019f14b2f688c7c upstream. Currently, when a disconnect is requested by the user (via NBD_DISCONNECT ioctl) the return from NBD_DO_IT is undefined (it is usually one of several error codes). This means that nbd-client does not know if a manual disconnect was performed or whether a network error occurred. Because of this, nbd-client's persist mode (which tries to reconnect after error, but not after manual disconnect) does not always work correctly. This change fixes this by causing NBD_DO_IT to always return 0 if a user requests a disconnect. This means that nbd-client can correctly either persist the connection (if an error occurred) or disconnect (if the user requested it). Signed-off-by: Paul Clements <paul.clements@steeleye.com> Acked-by: Rob Landley <rob@landley.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [bwh: Backported to 3.2: adjust device pointer name] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27drivers/rtc/rtc-rv3029c2.c: fix disabling AIE irqAxel Lin
commit 29ecd78c0fd6ee05f2c6b07b23823a6ae43c13ff upstream. In the disable AIE irq code path, current code passes "1" to enable parameter of rv3029c2_rtc_i2c_alarm_set_irq(). Thus it does not disable AIE irq. Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27crypto: sanitize argument for format stringKees Cook
commit 1c8fca1d92e14859159a82b8a380d220139b7344 upstream. The template lookup interface does not provide a way to use format strings, so make sure that the interface cannot be abused accidentally. Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27block: do not pass disk names as format stringsKees Cook
commit ffc8b30866879ed9ba62bd0a86fecdbd51cd3d19 upstream. Disk names may contain arbitrary strings, so they must not be interpreted as format strings. It seems that only md allows arbitrary strings to be used for disk names, but this could allow for a local memory corruption from uid 0 into ring 0. CVE-2013-2851 Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [bwh: Backported to 3.2: adjust device pointer name in nbd.c] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27ocfs2: xattr: fix inlined xattr reflinkJunxiao Bi
commit ef962df057aaafd714f5c22ba3de1be459571fdf upstream. Inlined xattr shared free space of inode block with inlined data or data extent record, so the size of the later two should be adjusted when inlined xattr is enabled. See ocfs2_xattr_ibody_init(). But this isn't done well when reflink. For inode with inlined data, its max inlined data size is adjusted in ocfs2_duplicate_inline_data(), no problem. But for inode with data extent record, its record count isn't adjusted. Fix it, or data extent record and inlined xattr may overwrite each other, then cause data corruption or xattr failure. One panic caused by this bug in our test environment is the following: kernel BUG at fs/ocfs2/xattr.c:1435! invalid opcode: 0000 [#1] SMP Pid: 10871, comm: multi_reflink_t Not tainted 2.6.39-300.17.1.el5uek #1 RIP: ocfs2_xa_offset_pointer+0x17/0x20 [ocfs2] RSP: e02b:ffff88007a587948 EFLAGS: 00010283 RAX: 0000000000000000 RBX: 0000000000000010 RCX: 00000000000051e4 RDX: ffff880057092060 RSI: 0000000000000f80 RDI: ffff88007a587a68 RBP: ffff88007a587948 R08: 00000000000062f4 R09: 0000000000000000 R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000010 R13: ffff88007a587a68 R14: 0000000000000001 R15: ffff88007a587c68 FS: 00007fccff7f06e0(0000) GS:ffff88007fc00000(0000) knlGS:0000000000000000 CS: e033 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 00000000015cf000 CR3: 000000007aa76000 CR4: 0000000000000660 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process multi_reflink_t Call Trace: ocfs2_xa_reuse_entry+0x60/0x280 [ocfs2] ocfs2_xa_prepare_entry+0x17e/0x2a0 [ocfs2] ocfs2_xa_set+0xcc/0x250 [ocfs2] ocfs2_xattr_ibody_set+0x98/0x230 [ocfs2] __ocfs2_xattr_set_handle+0x4f/0x700 [ocfs2] ocfs2_xattr_set+0x6c6/0x890 [ocfs2] ocfs2_xattr_user_set+0x46/0x50 [ocfs2] generic_setxattr+0x70/0x90 __vfs_setxattr_noperm+0x80/0x1a0 vfs_setxattr+0xa9/0xb0 setxattr+0xc3/0x120 sys_fsetxattr+0xa8/0xd0 system_call_fastpath+0x16/0x1b Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com> Reviewed-by: Jie Liu <jeff.liu@oracle.com> Acked-by: Joel Becker <jlbec@evilplan.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Sunil Mushran <sunil.mushran@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27drivers/dma/pl330.c: fix locking in pl330_free_chan_resources()Bartlomiej Zolnierkiewicz
commit da331ba8e9c5de72a27e50f71105395bba6eebe0 upstream. tasklet_kill() may sleep so call it before taking pch->lock. Fixes following lockup: BUG: scheduling while atomic: cat/2383/0x00000002 Modules linked in: unwind_backtrace+0x0/0xfc __schedule_bug+0x4c/0x58 __schedule+0x690/0x6e0 sys_sched_yield+0x70/0x78 tasklet_kill+0x34/0x8c pl330_free_chan_resources+0x24/0x88 dma_chan_put+0x4c/0x50 [...] BUG: spinlock lockup suspected on CPU#0, swapper/0/0 lock: 0xe52aa04c, .magic: dead4ead, .owner: cat/2383, .owner_cpu: 1 unwind_backtrace+0x0/0xfc do_raw_spin_lock+0x194/0x204 _raw_spin_lock_irqsave+0x20/0x28 pl330_tasklet+0x2c/0x5a8 tasklet_action+0xfc/0x114 __do_softirq+0xe4/0x19c irq_exit+0x98/0x9c handle_IPI+0x124/0x16c gic_handle_irq+0x64/0x68 __irq_svc+0x40/0x70 cpuidle_wrap_enter+0x4c/0xa0 cpuidle_enter_state+0x18/0x68 cpuidle_idle_call+0xac/0xe0 cpu_idle+0xac/0xf0 Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Jassi Brar <jassisinghbrar@gmail.com> Cc: Vinod Koul <vinod.koul@linux.intel.com> Cc: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27libceph: Fix NULL pointer dereference in auth client codeTyler Hicks
commit 2cb33cac622afde897aa02d3dcd9fbba8bae839e upstream. A malicious monitor can craft an auth reply message that could cause a NULL function pointer dereference in the client's kernel. To prevent this, the auth_none protocol handler needs an empty ceph_auth_client_ops->build_request() function. CVE-2013-1059 Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Reported-by: Chanam Park <chanam.park@hkpco.kr> Reviewed-by: Seth Arnold <seth.arnold@canonical.com> Reviewed-by: Sage Weil <sage@inktank.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27tracing: Fix irqs-off tag display in syscall tracingzhangwei(Jovi)
commit 11034ae9c20f4057a6127fc965906417978e69b2 upstream. All syscall tracing irqs-off tags are wrong, the syscall enter entry doesn't disable irqs. [root@jovi tracing]#echo "syscalls:sys_enter_open" > set_event [root@jovi tracing]# cat trace # tracer: nop # # entries-in-buffer/entries-written: 13/13 #P:2 # # _-----=> irqs-off # / _----=> need-resched # | / _---=> hardirq/softirq # || / _--=> preempt-depth # ||| / delay # TASK-PID CPU# |||| TIMESTAMP FUNCTION # | | | |||| | | irqbalance-513 [000] d... 56115.496766: sys_open(filename: 804e1a6, flags: 0, mode: 1b6) irqbalance-513 [000] d... 56115.497008: sys_open(filename: 804e1bb, flags: 0, mode: 1b6) sendmail-771 [000] d... 56115.827982: sys_open(filename: b770e6d1, flags: 0, mode: 1b6) The reason is syscall tracing doesn't record irq_flags into buffer. The proper display is: [root@jovi tracing]#echo "syscalls:sys_enter_open" > set_event [root@jovi tracing]# cat trace # tracer: nop # # entries-in-buffer/entries-written: 14/14 #P:2 # # _-----=> irqs-off # / _----=> need-resched # | / _---=> hardirq/softirq # || / _--=> preempt-depth # ||| / delay # TASK-PID CPU# |||| TIMESTAMP FUNCTION # | | | |||| | | irqbalance-514 [001] .... 46.213921: sys_open(filename: 804e1a6, flags: 0, mode: 1b6) irqbalance-514 [001] .... 46.214160: sys_open(filename: 804e1bb, flags: 0, mode: 1b6) <...>-920 [001] .... 47.307260: sys_open(filename: 4e82a0c5, flags: 80000, mode: 0) Link: http://lkml.kernel.org/r/1365564393-10972-3-git-send-email-jovi.zhangwei@huawei.com Signed-off-by: zhangwei(Jovi) <jovi.zhangwei@huawei.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27nfsd4: fix decoding of compounds across page boundariesJ. Bruce Fields
commit 247500820ebd02ad87525db5d9b199e5b66f6636 upstream. A freebsd NFSv4.0 client was getting rare IO errors expanding a tarball. A network trace showed the server returning BAD_XDR on the final getattr of a getattr+write+getattr compound. The final getattr started on a page boundary. I believe the Linux client ignores errors on the post-write getattr, and that that's why we haven't seen this before. Reported-by: Rick Macklem <rmacklem@uoguelph.ca> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27jbd2: fix theoretical race in jbd2__journal_restartTheodore Ts'o
commit 39c04153fda8c32e85b51c96eb5511a326ad7609 upstream. Once we decrement transaction->t_updates, if this is the last handle holding the transaction from closing, and once we release the t_handle_lock spinlock, it's possible for the transaction to commit and be released. In practice with normal kernels, this probably won't happen, since the commit happens in a separate kernel thread and it's unlikely this could all happen within the space of a few CPU cycles. On the other hand, with a real-time kernel, this could potentially happen, so save the tid found in transaction->t_tid before we release t_handle_lock. It would require an insane configuration, such as one where the jbd2 thread was set to a very high real-time priority, perhaps because a high priority real-time thread is trying to read or write to a file system. But some people who use real-time kernels have been known to do insane things, including controlling laser-wielding industrial robots. :-) Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27ext3,ext4: don't mess with dir_file->f_pos in htree_dirblock_to_tree()Al Viro
commit 64cb927371cd2ec43758d8a094a003d27bc3d0dc upstream. Both ext3 and ext4 htree_dirblock_to_tree() is just filling the in-core rbtree for use by call_filldir(). All updates of ->f_pos are done by the latter; bumping it here (on error) is obviously wrong - we might very well have it nowhere near the block we'd found an error in. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27powerpc/smp: Section mismatch from smp_release_cpus to __initdata ↵Chen Gang
spinning_secondaries commit 8246aca7058f3f2c2ae503081777965cd8df7b90 upstream. the smp_release_cpus is a normal funciton and called in normal environments, but it calls the __initdata spinning_secondaries. need modify spinning_secondaries to match smp_release_cpus. the related warning: (the linker report boot_paca.33377, but it should be spinning_secondaries) ----------------------------------------------------------------------------- WARNING: arch/powerpc/kernel/built-in.o(.text+0x23176): Section mismatch in reference from the function .smp_release_cpus() to the variable .init.data:boot_paca.33377 The function .smp_release_cpus() references the variable __initdata boot_paca.33377. This is often because .smp_release_cpus lacks a __initdata annotation or the annotation of boot_paca.33377 is wrong. WARNING: arch/powerpc/kernel/built-in.o(.text+0x231fe): Section mismatch in reference from the function .smp_release_cpus() to the variable .init.data:boot_paca.33377 The function .smp_release_cpus() references the variable __initdata boot_paca.33377. This is often because .smp_release_cpus lacks a __initdata annotation or the annotation of boot_paca.33377 is wrong. ----------------------------------------------------------------------------- Signed-off-by: Chen Gang <gang.chen@asianux.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27Revert "serial: 8250_pci: add support for another kind of NetMos Technology ↵Greg Kroah-Hartman
PCI 9835 Multi-I/O Controller" commit 828c6a102b1f2b8583fadc0e779c46b31d448f0b upstream. This reverts commit 8d2f8cd424ca0b99001f3ff4f5db87c4e525f366. As reported by Stefan, this device already works with the parport_serial driver, so the 8250_pci driver should not also try to grab it as well. Reported-by: Stefan Seyfried <stefan.seyfried@googlemail.com> Cc: Wang YanQing <udknight@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> [bwh: Backported to 3.2: adjust filename] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27UBIFS: fix a horrid bugArtem Bityutskiy
commit 605c912bb843c024b1ed173dc427cd5c08e5d54d upstream. Al Viro pointed me to the fact that '->readdir()' and '->llseek()' have no mutual exclusion, which means the 'ubifs_dir_llseek()' can be run while we are in the middle of 'ubifs_readdir()'. This means that 'file->private_data' can be freed while 'ubifs_readdir()' uses it, and this is a very bad bug: not only 'ubifs_readdir()' can return garbage, but this may corrupt memory and lead to all kinds of problems like crashes an security holes. This patch fixes the problem by using the 'file->f_version' field, which '->llseek()' always unconditionally sets to zero. We set it to 1 in 'ubifs_readdir()' and whenever we detect that it became 0, we know there was a seek and it is time to clear the state saved in 'file->private_data'. I tested this patch by writing a user-space program which runds readdir and seek in parallell. I could easily crash the kernel without these patches, but could not crash it with these patches. Reported-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27UBIFS: prepare to fix a horrid bugArtem Bityutskiy
commit 33f1a63ae84dfd9ad298cf275b8f1887043ced36 upstream. Al Viro pointed me to the fact that '->readdir()' and '->llseek()' have no mutual exclusion, which means the 'ubifs_dir_llseek()' can be run while we are in the middle of 'ubifs_readdir()'. First of all, this means that 'file->private_data' can be freed while 'ubifs_readdir()' uses it. But this particular patch does not fix the problem. This patch is only a preparation, and the fix will follow next. In this patch we make 'ubifs_readdir()' stop using 'file->f_pos' directly, because 'file->f_pos' can be changed by '->llseek()' at any point. This may lead 'ubifs_readdir()' to returning inconsistent data: directory entry names may correspond to incorrect file positions. So here we introduce a local variable 'pos', read 'file->f_pose' once at very the beginning, and then stick to 'pos'. The result of this is that when 'ubifs_dir_llseek()' changes 'file->f_pos' while we are in the middle of 'ubifs_readdir()', the latter "wins". Reported-by: Al Viro <viro@zeniv.linux.org.uk> Tested-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27xen/time: remove blocked time accounting from xen "clockchip"Laszlo Ersek
commit 0b0c002c340e78173789f8afaa508070d838cf3d upstream. ... because the "clock_event_device framework" already accounts for idle time through the "event_handler" function pointer in xen_timer_interrupt(). The patch is intended as the completion of [1]. It should fix the double idle times seen in PV guests' /proc/stat [2]. It should be orthogonal to stolen time accounting (the removed code seems to be isolated). The approach may be completely misguided. [1] https://lkml.org/lkml/2011/10/6/10 [2] http://lists.xensource.com/archives/html/xen-devel/2010-08/msg01068.html John took the time to retest this patch on top of v3.10 and reported: "idle time is correctly incremented for pv and hvm for the normal case, nohz=off and nohz=idle." so lets put this patch in. Signed-off-by: Laszlo Ersek <lersek@redhat.com> Signed-off-by: John Haxby <john.haxby@oracle.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27timer: Fix jiffies wrap behavior of round_jiffies_common()Bart Van Assche
commit 9e04d3804d3ac97d8c03a41d78d0f0674b5d01e1 upstream. Direct compare of jiffies related values does not work in the wrap around case. Replace it with time_is_after_jiffies(). Signed-off-by: Bart Van Assche <bvanassche@acm.org> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Link: http://lkml.kernel.org/r/519BC066.5080600@acm.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27writeback: Fix periodic writeback after fs mountJan Kara
commit a5faeaf9109578e65e1a32e2a3e76c8b47e7dcb6 upstream. Code in blkdev.c moves a device inode to default_backing_dev_info when the last reference to the device is put and moves the device inode back to its bdi when the first reference is acquired. This includes moving to wb.b_dirty list if the device inode is dirty. The code however doesn't setup timer to wake corresponding flusher thread and while wb.b_dirty list is non-empty __mark_inode_dirty() will not set it up either. Thus periodic writeback is effectively disabled until a sync(2) call which can lead to unexpected data loss in case of crash or power failure. Fix the problem by setting up a timer for periodic writeback in case we add the first dirty inode to wb.b_dirty list in bdev_inode_switch_bdi(). Reported-by: Bert De Jonghe <Bert.DeJonghe@amplidata.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27genirq: Fix can_request_irq() for IRQs without an actionBen Hutchings
commit 2779db8d37d4b542d9ca2575f5f178dbeaca6c86 upstream. Commit 02725e7471b8 ('genirq: Use irq_get/put functions'), inadvertently changed can_request_irq() to return 0 for IRQs that have no action. This causes pcibios_lookup_irq() to select only IRQs that already have an action with IRQF_SHARED set, or to fail if there are none. Change can_request_irq() to return 1 for IRQs that have no action (if the first two conditions are met). Reported-by: Bjarni Ingi Gislason <bjarniig@rhi.hi.is> Tested-by: Bjarni Ingi Gislason <bjarniig@rhi.hi.is> (against 3.2) Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Cc: 709647@bugs.debian.org Link: http://bugs.debian.org/709647 Link: http://lkml.kernel.org/r/1372383630.23847.40.camel@deadeye.wl.decadent.org.uk Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-07-27dlci: validate the net device in dlci_del()Zefan Li
commit 578a1310f2592ba90c5674bca21c1dbd1adf3f0a upstream. We triggered an oops while running trinity with 3.4 kernel: BUG: unable to handle kernel paging request at 0000000100000d07 IP: [<ffffffffa0109738>] dlci_ioctl+0xd8/0x2d4 [dlci] PGD 640c0d067 PUD 0 Oops: 0000 [#1] PREEMPT SMP CPU 3 ... Pid: 7302, comm: trinity-child3 Not tainted 3.4.24.09+ 40 Huawei Technologies Co., Ltd. Tecal RH2285 /BC11BTSA RIP: 0010:[<ffffffffa0109738>] [<ffffffffa0109738>] dlci_ioctl+0xd8/0x2d4 [dlci] ... Call Trace: [<ffffffff8137c5c3>] sock_ioctl+0x153/0x280 [<ffffffff81195494>] do_vfs_ioctl+0xa4/0x5e0 [<ffffffff8118354a>] ? fget_light+0x3ea/0x490 [<ffffffff81195a1f>] sys_ioctl+0x4f/0x80 [<ffffffff81478b69>] system_call_fastpath+0x16/0x1b ... It's because the net device is not a dlci device. Reported-by: Li Jinyue <lijinyue@huawei.com> Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27dlci: acquire rtnl_lock before calling __dev_get_by_name()Zefan Li
commit 11eb2645cbf38a08ae491bf6c602eea900ec0bb5 upstream. Otherwise the net device returned can be freed at anytime. Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27Handle big endianness in NTLM (ntlmv2) authenticationSteve French
commit fdf96a907c1fbb93c633e2b7ede3b8df26d6a4c0 upstream. This is RH bug 970891 Uppercasing of username during calculation of ntlmv2 hash fails because UniStrupr function does not handle big endian wchars. Also fix a comment in the same code to reflect its correct usage. [To make it easier for stable (rather than require 2nd patch) fixed this patch of Shirish's to remove endian warning generated by sparse -- steve f.] Reported-by: steve <sanpatr1@in.ibm.com> Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com> [bwh: Backported to 3.2: adjust context, indentation] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27cgroup: fix RCU accesses to task->cgroupsTejun Heo
commit 14611e51a57df10240817d8ada510842faf0ec51 upstream. task->cgroups is a RCU pointer pointing to struct css_set. A task switches to a different css_set on cgroup migration but a css_set doesn't change once created and its pointers to cgroup_subsys_states aren't RCU protected. task_subsys_state[_check]() is the macro to acquire css given a task and subsys_id pair. It RCU-dereferences task->cgroups->subsys[] not task->cgroups, so the RCU pointer task->cgroups ends up being dereferenced without read_barrier_depends() after it. It's broken. Fix it by introducing task_css_set[_check]() which does RCU-dereference on task->cgroups. task_subsys_state[_check]() is reimplemented to directly dereference ->subsys[] of the css_set returned from task_css_set[_check](). This removes some of sparse RCU warnings in cgroup. v2: Fixed unbalanced parenthsis and there's no need to use rcu_dereference_raw() when !CONFIG_PROVE_RCU. Both spotted by Li. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Fengguang Wu <fengguang.wu@intel.com> Acked-by: Li Zefan <lizefan@huawei.com> [bwh: Backported to 3.2: - Adjust context - Remove CONFIG_PROVE_RCU condition - s/lockdep_is_held(&cgroup_mutex)/cgroup_lock_is_held()/] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27sd: Fix parsing of 'temporary ' cache mode prefixBen Hutchings
commit 2ee3e26c673e75c05ef8b914f54fadee3d7b9c88 upstream. Commit 39c60a0948cc '[SCSI] sd: fix array cache flushing bug causing performance problems' added temp as a pointer to "temporary " and used sizeof(temp) - 1 as its length. But sizeof(temp) is the size of the pointer, not the size of the string constant. Change temp to a static array so that sizeof() does what was intended. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-07-27sd: fix array cache flushing bug causing performance problemsJames Bottomley
commit 39c60a0948cc06139e2fbfe084f83cb7e7deae3b upstream. Some arrays synchronize their full non volatile cache when the sd driver sends a SYNCHRONIZE CACHE command. Unfortunately, they can have Terrabytes of this and we send a SYNCHRONIZE CACHE for every barrier if an array reports it has a writeback cache. This leads to massive slowdowns on journalled filesystems. The fix is to allow userspace to turn off the writeback cache setting as a temporary measure (i.e. without doing the MODE SELECT to write it back to the device), so even though the device reported it has a writeback cache, the user, knowing that the cache is non volatile and all they care about is filesystem correctness, can turn that bit off in the kernel and avoid the performance ruinous (and safety irrelevant) SYNCHRONIZE CACHE commands. The way you do this is add a 'temporary' prefix when performing the usual cache setting operations, so echo temporary write through > /sys/class/scsi_disk/<disk>/cache_type Reported-by: Ric Wheeler <rwheeler@redhat.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27perf: Disable monitoring on setuid processes for regular usersStephane Eranian
commit 2976b10f05bd7f6dab9f9e7524451ddfed656a89 upstream. There was a a bug in setup_new_exec(), whereby the test to disabled perf monitoring was not correct because the new credentials for the process were not yet committed and therefore the get_dumpable() test was never firing. The patch fixes the problem by moving the perf_event test until after the credentials are committed. Signed-off-by: Stephane Eranian <eranian@google.com> Tested-by: Jiri Olsa <jolsa@redhat.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27vgacon.c: add cond reschedule points in vgacon_do_font_opMarcelo Tosatti
commit 7e6d72c15ff4cc0c27573901bb05f9eddbd71ed4 upstream. Booting a 64-vcpu KVM guest, with CONFIG_PREEMPT_VOLUNTARY, can result in a soft lockup: BUG: soft lockup - CPU#41 stuck for 67s! [setfont:1505] RIP: 0010:[<ffffffff812c48da>] [<ffffffff812c48da>] vgacon_do_font_op.clone.0+0x1ba/0x550 This is due to the 8192 (cmapsz) IO operations taking longer than expected due to lock contention in QEMU. Add conditional resched points in between writes allowing other tasks to execute. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com> [bwh: Backported to 3.2: add #include <linux/sched.h>, already present upstream] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27futex: Take hugepages into account when generating futex_keyZhang Yi
commit 13d60f4b6ab5b702dc8d2ee20999f98a93728aec upstream. The futex_keys of process shared futexes are generated from the page offset, the mapping host and the mapping index of the futex user space address. This should result in an unique identifier for each futex. Though this is not true when futexes are located in different subpages of an hugepage. The reason is, that the mapping index for all those futexes evaluates to the index of the base page of the hugetlbfs mapping. So a futex at offset 0 of the hugepage mapping and another one at offset PAGE_SIZE of the same hugepage mapping have identical futex_keys. This happens because the futex code blindly uses page->index. Steps to reproduce the bug: 1. Map a file from hugetlbfs. Initialize pthread_mutex1 at offset 0 and pthread_mutex2 at offset PAGE_SIZE of the hugetlbfs mapping. The mutexes must be initialized as PTHREAD_PROCESS_SHARED because PTHREAD_PROCESS_PRIVATE mutexes are not affected by this issue as their keys solely depend on the user space address. 2. Lock mutex1 and mutex2 3. Create thread1 and in the thread function lock mutex1, which results in thread1 blocking on the locked mutex1. 4. Create thread2 and in the thread function lock mutex2, which results in thread2 blocking on the locked mutex2. 5. Unlock mutex2. Despite the fact that mutex2 got unlocked, thread2 still blocks on mutex2 because the futex_key points to mutex1. To solve this issue we need to take the normal page index of the page which contains the futex into account, if the futex is in an hugetlbfs mapping. In other words, we calculate the normal page mapping index of the subpage in the hugetlbfs mapping. Mappings which are not based on hugetlbfs are not affected and still use page->index. Thanks to Mel Gorman who provided a patch for adding proper evaluation functions to the hugetlbfs code to avoid exposing hugetlbfs specific details to the futex code. [ tglx: Massaged changelog ] Signed-off-by: Zhang Yi <zhang.yi20@zte.com.cn> Reviewed-by: Jiang Biao <jiang.biao2@zte.com.cn> Tested-by: Ma Chenggong <ma.chenggong@zte.com.cn> Reviewed-by: 'Mel Gorman' <mgorman@suse.de> Acked-by: 'Darren Hart' <dvhart@linux.intel.com> Cc: 'Peter Zijlstra' <peterz@infradead.org> Link: http://lkml.kernel.org/r/000101ce71a6%24a83c5880%24f8b50980%24@com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27USB: option,qcserial: move Novatel Gobi1K IDs to qcserialDan Williams
commit a254810a86aaaac4ac6ba44fa934558b042a17a7 upstream. These devices are all Gobi1K devices (according to the Windows INF files) and should be handled by qcserial instead of option. Their network port is handled by qmi_wwan. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27mpt2sas: fix firmware failure with wrong task attributeSreekanth Reddy
commit 48ba2efc382f94fae16ca8ca011e5961a81ad1ea upstream. When SCSI command is received with task attribute not set, set it to SIMPLE. Previously it is set to untagged. This causes the firmware to fail the commands. Signed-off-by: Sreekanth Reddy <Sreekanth.Reddy@lsi.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27mpt2sas: Fix for device scan following host reset could get stuck in a ↵Sreekanth Reddy
infinite loop commit 6241f22ca12a26ee149cbe31b27bac97dbdc8bc4 upstream. Modified device scan routine so each configuration page read breaks from the while loop when the ioc_status is not equal to MPI2_IOCSTATUS_SUCCESS. [jejb: checkpatch fixes] Signed-off-by: Sreekanth Reddy <Sreekanth.Reddy@lsi.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> [bwh: Backported to 3.2; adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27mpt2sas: Fix for issue Missing delay not getting set during system bootupReddy, Sreekanth
commit b0df96a0068daee4f9c2189c29b9053eb6e46b17 upstream. Missing delay is not getting set properly. The reason is that it is not defined in the same file from where it is being invoked. The fix is to move the missing delay module parameter from mpt2sas_base.c to mpt2sas_scsh.c. Signed-off-by: Sreekanth Reddy <Sreekanth.Reddy@lsi.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27ARM: 7765/1: perf: Record the user-mode PC in the call chain.Jed Davis
commit c5f927a6f62196226915f12194c9d0df4e2210d7 upstream. With this change, we no longer lose the innermost entry in the user-mode part of the call chain. See also the x86 port, which includes the ip. It's possible to partially work around this problem by post-processing the data to use the PERF_SAMPLE_IP value, but this works only if the CPU wasn't in the kernel when the sample was taken. Signed-off-by: Jed Davis <jld@mozilla.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-07-27iommu/amd: Only unmap large pages from the first pteAlex Williamson
commit 60d0ca3cfd199b6612bbbbf4999a3470dad38bb1 upstream. If we use a large mapping, the expectation is that only unmaps from the first pte in the superpage are supported. Unmaps from offsets into the superpage should fail (ie. return zero sized unmap). In the current code, unmapping from an offset clears the size of the full mapping starting from an offset. For instance, if we map a 16k physically contiguous range at IOVA 0x0 with a large page, then attempt to unmap 4k at offset 12k, 4 ptes are cleared (12k - 28k) and the unmap returns 16k unmapped. This potentially incorrectly clears valid mappings and confuses drivers like VFIO that use the unmap size to release pinned pages. Fix by refusing to unmap from offsets into the page. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Joerg Roedel <joro@8bytes.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
