commit c428b70c1e115c5649707a602742e34130d19428 upstream.
wdm_in_callback() will also touch this field, so we cannot change it without locking
Signed-off-by: Bjørn Mork <bjorn@mork.no>
Acked-by: Oliver Neukum <oneukum@suse.de>
commit 2353f806c97020d4c7709f15eebb49b591f7306d upstream.
0x04d8, 0x000a: Hornby Elite
Signed-off-by: Alan Cox <alan@linux.intel.com>
commit fc216ec363f4d174932df90bbf35c77d0540e561 upstream.
I tested this against 2.6.39 in the Ubuntu kernel, however I see the IDs
are not in latest 3.2 git.
This adds IDs for the FTDI controller in the Rainforest Automation
Zigbee dongle.
Signed-off-by: Peter Naulls <peter@chocky.org>
commit 55f13aeae0346f0c89bfface91ad9a97653dc433 upstream.
Port A for JTAG, port B for serial.
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
commit 108e02b12921078a59dcacd048079ece48a4a983 upstream.
Fix regression introduced by commit b1ffb4c851f1 ("USB: Fix Corruption
issue in USB ftdi driver ftdi_sio.c") which caused the termios settings
to no longer be initialised at open. Consequently it was no longer
possible to set the port to the default speed of 9600 baud without first
changing to another baud rate and back again.
Reported-by: Roland Ramthun <mail@roland-ramthun.de>
Signed-off-by: Johan Hovold <jhovold@gmail.com>
Tested-by: Roland Ramthun <mail@roland-ramthun.de>
commit eb833a9e0972f60beb4ab8104ad7ef6bf30f02fc upstream.
Return EINVAL if new baud_base does not match the current one.
The baud_base is device specific and can not be changed. This restores
the old (pre-2005) behaviour which was changed due to a
misunderstanding regarding this fact (see
https://lkml.org/lkml/2005/1/20/84).
Reported-by: Torbjörn Lofterud <torbjorn@pi.nxs.se>
commit e423d7401fd0717cb56a6cf51dd8341cc3e800d2 upstream.
Add vendor and product ID for USB 3G/LTE modem of docomo L-02C
Signed-off-by: Kentaro Matsuyama <kentaro.matsuyama@gmail.com>
commit 2cb6fc8c014b9b00c4487a79b8f6ed0da4121f45 upstream.
Removed redundant calling of _scsih_probe_devices() from _scsih_probe as
it is getting called from _scsih_scan_finished.
Also moved the function scsi_scan_host(shost) to get called after the
volumes on warp drive are reported to the OS. Otherwise by the time
the (ioc->hide_drives) flags is set, the volumes on warp drive
are reported to the OS already.
Also modified the initialization of reply queues only in case of driver load
time in the function _base_make_ioc_operational().
Signed-off-by: Nagalakshmi Nandigama <nagalakshmi.nandigama@lsi.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit 7a7546b377bdaa25ac77f33d9433c59f259b9688 upstream.
If NR_CPUS < 256 then arch_spinlock_t is only 16 bits wide but struct
xen_spinlock is 32 bits. When a spin lock is contended and
xl->spinners is modified the two bytes immediately after the spin lock
would be corrupted.
This is a regression caused by 84eb950db13ca40a0572ce9957e14723500943d6
(x86, ticketlock: Clean up types and accessors) which reduced the size
of arch_spinlock_t.
Fix this by making xl->spinners a u8 if NR_CPUS < 256. A
BUILD_BUG_ON() is also added to check the sizes of the two structures
are compatible.
In many cases this was not noticable as there would often be padding
bytes after the lock (e.g., if any of CONFIG_GENERIC_LOCKBREAK,
CONFIG_DEBUG_SPINLOCK, or CONFIG_DEBUG_LOCK_ALLOC were enabled).
The bnx2 driver is affected. In struct bnx2, phy_lock and
indirect_lock may have no padding after them. Contention on phy_lock
would corrupt indirect_lock making it appear locked and the driver
would deadlock.
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Signed-off-by: Jeremy Fitzhardinge <jeremy@goop.org>
Acked-by: Ian Campbell <ian.campbell@citrix.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
directories.
commit ce597919361dcec97341151690e780eade2a9cf4 upstream.
Recently an OOPS was observed from the usb serial io_ti driver when it tried to remove
sysfs directories. Upon investigation it turns out this driver was always buggy
and that a recent sysfs change had stopped guarding itself against removing attributes
from sysfs directories that had already been removed. :(
Historically we have been silent about attempting to files from nonexistent sysfs
directories and have politely returned error codes. That has resulted in people writing
broken code that ignores the error codes.
Issue a kernel WARNING and a stack backtrace to make it clear in no uncertain
terms that abusing sysfs is not ok, and the callers need to fix their code.
This change transforms the io_ti OOPS into a more comprehensible error message
and stack backtrace.
Reported-by: Wolfgang Frisch <wfpub@roembden.net>
commit 612539e81f655f6ac73c7af1da8701c1ee618aee upstream.
On v7, we use the same cache maintenance instructions for data lines
as for unified lines. This was not the case for v6, where HARVARD_CACHE
was defined to indicate the L1 cache topology.
This patch removes the erroneous compile-time check for HARVARD_CACHE in
proc-v7.S, ensuring that we perform I-side invalidation at boot.
Reported-and-Acked-by: Shawn Guo <shawn.guo@linaro.org>
Acked-by: Catalin Marinas <Catalin.Marinas@arm.com>
commit d65015f7c5c5be9fd3f5e567889c844ba81bdc9c upstream.
This applies ARM errata 764369 for all ux500 platforms.
Signed-off-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
commit 3e90772f76010c315474bde59eaca7cc4c94d645 upstream.
Currently setting it to PQFP changes subtype to BGA as subtypes are
swapped in at91rm9200_set_type().
Wrong subtype causes GPIO bank D not to work at all.
After this fix, subtype is still set as unknown. But board code should
fill it in with proper value. Another information is thus printed.
Bug discovery and first implementation made by Veli-Pekka Peltola.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
commit 04115a9dee110b52a8eaa556c574022fa3bf4704 upstream.
Signed-off-by: Eric Anholt <eric@anholt.net>
Reviewed-by: Keith Packard <keithp@keithp.com>
Reviewed-by: Eugeni Dodonov <eugeni.dodonov@intel.com>
Reviewed-by: Kenneth Graunke <kenneth@whitecape.org>
Signed-off-by: Keith Packard <keithp@keithp.com>
commit ba68e086223a5f149f37bf8692c8cdbf1b0ba3ef upstream.
This is a revert of 81a14b46846fea0741902e8d8dfcc6c6c78154c8.
We already set the mode polarity using the SDVO commands with struct
intel_sdvo_dtd. We have at least 3 bugs that get fixed with this patch.
The documentation, despite not clear, can also be interpreted in a way
that suggests this patch is needed.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=15766
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=42174
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=43333
Reviewed-by: Eric Anholt <eric@anholt.net>
Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Signed-off-by: Paulo Zanoni <paulo.r.zanoni@intel.com>
commit 4cd53c0c8b01fc05c3ad5b2acdad02e37d3c2f55 upstream.
Two things seem to do the trick on my ivb machine here:
- prevent the gt from powering down while waiting for seqno
notification interrupts by grabbing the force_wake in get_irq (and
dropping it in put_irq again).
- ordering writes from the ring's CS by reading a CS register, ACTHD
seems to work.
Only the blt&bsd ring on ivb seem to be massively affected by this,
but for paranoia do this dance also on the render ring and on snb
(i.e. all gpus with forcewake).
Tested with Eric's glCopyPixels loop which without this patch scores a
missed irq every few seconds.
This patch needs my forcewake rework to use a spinlock instead of
dev->struct_mutex.
After crawling through docs a lot I've found the following nugget:
Internal doc "SNB GT PM Programming Guide", Section 4.3.1:
"GT does not generate interrupts while in RC6 (by design)"
So it looks like rc6 and irq generation are indeed related.
v2: Improve the comment per Eugeni Dodonov's suggestion.
v3: Add the documentation snipped. Also restrict the w/a to ivb only
for -fixes, as suggested by Keith Packard.
Cc: Eric Anholt <eric@anholt.net>
Cc: Kenneth Graunke <kenneth@whitecape.org>
Cc: Eugeni Dodonov <eugeni.dodonov@intel.com>
Tested-by: Eugeni Dodonov <eugeni.dodonov@intel.com>
Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit b3a81520bd37a28f77cb0f7002086fb14061824d upstream.
The very same problem is seen on Haier W18 laptop with ALC861 as seen
on ASUS A6Rp, which was fixed by the commit 3b25eb69.
Now we just need to add a new SSID entry pointing to the same fixup.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=42656
commit 3b25eb690e8c7424eecffe1458c02b87b32aa001 upstream.
The refactoring of Realtek codec driver in 3.2 kernel caused a
regression for ASUS A6Rp laptop; it doesn't give any output.
The reason was that this machine has a secret master mute (or EAPD)
control via NID 0x0f VREF. Setting VREF50 on this node makes the
sound working again.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=42588
commit a6a600d10aaddf1da38053c4c6b64f50f56176e6 upstream.
HP laptop models with buggy BIOS are apparently frequent, including
machines with different codecs. Set the polarity of the mute led based
on the SSID and include an entry for the HP Mini 110-3100.
Signed-off-by: Gustavo Maciel Dias Vieira <gustavo@sagui.org>
Tested-by: Predrag Ivanovic <predivan@open.telekom.rs>
commit 2a3535069e33d8b416f406c159ce924427315303 upstream.
Passing the address of a variable as an operand to an asm statement
doesn't mark the value of this variable as used, so gcc may optimize its
initialisation away. Fix this by using the "m" constraint instead.
Signed-off-by: Andreas Schwab <schwab@linux-m68k.org>
commit 5b68edc91cdc972c46f76f85eded7ffddc3ff5c2 upstream.
We've decided to provide CPU family specific container files
(starting with CPU family 15h). E.g. for family 15h we have to
load microcode_amd_fam15h.bin instead of microcode_amd.bin
Rationale is that starting with family 15h patch size is larger
than 2KB which was hard coded as maximum patch size in various
microcode loaders (not just Linux).
Container files which include patches larger than 2KB cause
different kinds of trouble with such old patch loaders. Thus we
have to ensure that the default container file provides only
patches with size less than 2KB.
Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com>
Cc: Borislav Petkov <borislav.petkov@amd.com>
Cc: <stable@kernel.org>
Link: http://lkml.kernel.org/r/20120120164412.GD24508@alberich.amd.com
[ documented the naming convention and tidied the code a bit. ]
commit 5a51467b146ab7948d2f6812892eac120a30529c upstream.
uv_gpa_to_soc_phys_ram() was inadvertently ignoring the
shift values. This fix takes the shift into account.
Signed-off-by: Russ Anderson <rja@sgi.com>
Link: http://lkml.kernel.org/r/20120119020753.GA7228@sgi.com
commit d2ebc71d472020bc30e29afe8c4d2a85a5b41f56 upstream.
Initialize two spinlocks in tlb_uv.c and also properly define/initialize
the uv_irq_lock.
The lack of explicit initialization seems to be functionally
harmless, but it is diagnosed when these are turned on:
CONFIG_DEBUG_SPINLOCK=y
CONFIG_DEBUG_MUTEXES=y
CONFIG_DEBUG_LOCK_ALLOC=y
CONFIG_LOCKDEP=y
Signed-off-by: Cliff Wickman <cpw@sgi.com>
Cc: Dimitri Sivanich <sivanich@sgi.com>
Link: http://lkml.kernel.org/r/E1RnXd1-0003wU-PM@eag09.americas.sgi.com
[ Added the uv_irq_lock initialization fix by Dimitri Sivanich ]
commit a927b8131794ee449b7f6666e7ab61301949b20f upstream.
This patch adds a delay after aborting a command. Some TPMs need
this and will not process the subsequent command correctly otherwise.
It's worth noting that a TPM randomly failing to process a command,
maps to randomly failing suspend/resume operations.
Signed-off-by: Stefan Berger <stefanb@linux.vnet.ibm.com>
Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
commit 51fc6dc8f948047364f7d42a4ed89b416c6cc0a3 upstream.
For rounds 16--79, W[i] only depends on W[i - 2], W[i - 7], W[i - 15] and W[i - 16].
Consequently, keeping all W[80] array on stack is unnecessary,
only 16 values are really needed.
Using W[16] instead of W[80] greatly reduces stack usage
(~750 bytes to ~340 bytes on x86_64).
Line by line explanation:
* BLEND_OP
array is "circular" now, all indexes have to be modulo 16.
Round number is positive, so remainder operation should be
without surprises.
* initial full message scheduling is trimmed to first 16 values which
come from data block, the rest is calculated before it's needed.
* original loop body is unrolled version of new SHA512_0_15 and
SHA512_16_79 macros, unrolling was done to not do explicit variable
renaming. Otherwise it's the very same code after preprocessing.
See sha1_transform() code which does the same trick.
Patch survives in-tree crypto test and original bugreport test
(ping flood with hmac(sha512).
See FIPS 180-2 for SHA-512 definition
http://csrc.nist.gov/publications/fips/fips180-2/fips180-2withchangenotice.pdf
commit 84e31fdb7c797a7303e0cc295cb9bc8b73fb872d upstream.
commit f9e2bca6c22d75a289a349f869701214d63b5060
aka "crypto: sha512 - Move message schedule W[80] to static percpu area"
created global message schedule area.
If sha512_update will ever be entered twice, hash will be silently
calculated incorrectly.
Probably the easiest way to notice incorrect hashes being calculated is
to run 2 ping floods over AH with hmac(sha512):
#!/usr/sbin/setkey -f
flush;
spdflush;
add IP1 IP2 ah 25 -A hmac-sha512 0x00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000025;
add IP2 IP1 ah 52 -A hmac-sha512 0x00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000052;
spdadd IP1 IP2 any -P out ipsec ah/transport//require;
spdadd IP2 IP1 any -P in ipsec ah/transport//require;
XfrmInStateProtoError will start ticking with -EBADMSG being returned
from ah_input(). This never happens with, say, hmac(sha1).
With patch applied (on BOTH sides), XfrmInStateProtoError does not tick
with multiple bidirectional ping flood streams like it doesn't tick
with SHA-1.
After this patch sha512_transform() will start using ~750 bytes of stack on x86_64.
This is OK for simple loads, for something more heavy, stack reduction will be done
separatedly.
commit 353b67d8ced4dc53281c88150ad295e24bc4b4c5 upstream.
When we reach cleanup_journal_tail(), there is no guarantee that
checkpointed buffers are on a stable storage - especially if buffers were
written out by log_do_checkpoint(), they are likely to be only in disk's
caches. Thus when we update journal superblock, effectively removing old
transaction from journal, this write of superblock can get to stable storage
before those checkpointed buffers which can result in filesystem corruption
after a crash.
A similar problem can happen if we replay the journal and wipe it before
flushing disk's caches.
Thus we must unconditionally issue a cache flush before we update journal
superblock in these cases. The fix is slightly complicated by the fact that we
have to get log tail before we issue cache flush but we can store it in the
journal superblock only after the cache flush. Otherwise we risk races where
new tail is written before appropriate cache flush is finished.
I managed to reproduce the corruption using somewhat tweaked Chris Mason's
barrier-test scheduler. Also this should fix occasional reports of 'Bit already
freed' filesystem errors which are totally unreproducible but inspection of
several fs images I've gathered over time points to a problem like this.
commit bc4934bc61d0a11fd62c5187ff83645628f8be8b upstream.
When deauth is requested while an auth or assoc
work item is in progress, we currently delete it
without regard for any state it might need to
clean up. Fix it by cleaning up for those items.
In the case Pontus found, the problem manifested
itself as such:
authenticate with 00:23:69:aa:dd:7b (try 1)
authenticated
failed to insert Dummy STA entry for the AP (error -17)
deauthenticating from 00:23:69:aa:dd:7b by local choice (reason=2)
It could also happen differently if the driver
uses the tx_sync callback.
We can't just call the ->done() method of the work
items because that will lock up due to the locking
in cfg80211. This fix isn't very clean, but that
seems acceptable since I have patches pending to
remove this code completely.
Reported-by: Pontus Fuchs <pontus.fuchs@gmail.com>
Tested-by: Pontus Fuchs <pontus.fuchs@gmail.com>
commit f96b08a7e6f69c0f0a576554df3df5b1b519c479 upstream.
This patch workaround live deadlock problem caused by infinite loop
in brcms_c_wait_for_tx_completion(). I do not consider the patch as
the proper fix, which should fix the real reason of tx queue flush
failure, but patch helps with system lockup.
Reference:
https://bugzilla.kernel.org/show_bug.cgi?id=42576
Reported-and-tested-by: Patrick <ragamuffin@datacomm.ch>
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
commit a14304edcd5e8323205db34b08f709feb5357e64 upstream.
We should be allowing a 5ms delay after the charge pump is started in
order to ensure it has finished ramping.
commit 495174a8ffbaa0d15153d855cf206cdc46d51cf4 upstream.
These are all to either uncached registers or fixes to register defaults,
in the former case the cache won't do anything and in the latter case
we're fixing things so the cache sync will do the right thing.
commit fed22007113cb857e917913ce016d9b539dc3a80 upstream.
With a low frequency SYSCLK and a fast I2C clock register synchronisation
may occasionally take too long to take effect, causing I/O issues. Disable
synchronisation in order to avoid any issues.
commit e53e417331c57b9b97e3f8be870214a02c99265c upstream.
Writing to the registers won't work if we do actually manage to hit a fully
powered off state.
commit 9b025eb3a89e041bab6698e3858706be2385d692 upstream.
Commit b52a360b forgot to call xfs_iunlock() when it detected corrupted
symplink and bailed out. Fix it by jumping to 'out' instead of doing return.
CC: Carlos Maiolino <cmaiolino@redhat.com>
Reviewed-by: Alex Elder <elder@kernel.org>
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Ben Myers <bpm@sgi.com>
commit 598781d71119827b454fd75d46f84755bca6f0c6 upstream.
If the master tries to authenticate a client using drm_authmagic and
that client has already closed its drm file descriptor,
either wilfully or because it was terminated, the
call to drm_authmagic will dereference a stale pointer into kmalloc'ed memory
and corrupt it.
Typically this results in a hard system hang.
This patch fixes that problem by removing any authentication tokens
(struct drm_magic_entry) open for a file descriptor when that file
descriptor is closed.
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit 3a47824d85eeca122895646f027dc63480994199 upstream.
dig transmitter control table only has ENABLE/DISABLE actions
on DCE4.1/DCE5.
Fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=44955
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 386d4d751e8e0b4b693bb724f09aae064ee5297d upstream.
Needs to happen earlier in the mode set.
commit 44517c44496062180a6376cc704b33129441ce60 upstream.
Interrupts only work with MSIs.
https://bugs.freedesktop.org/show_bug.cgi?id=37679
Reported-by: Dmitry Podgorny <pasis.uax@gmail.com>
commit 58ded24f0fcb85bddb665baba75892f6ad0f4b8a upstream.
If pages passed to the eCryptfs extent-based crypto functions are not
mapped and the module parameter ecryptfs_verbosity=1 was specified at
loading time, a NULL pointer dereference will occur.
Note that this wouldn't happen on a production system, as you wouldn't
pass ecryptfs_verbosity=1 on a production system. It leaks private
information to the system logs and is for debugging only.
The debugging info printed in these messages is no longer very useful
and rather than doing a kmap() in these debugging paths, it will be
better to simply remove the debugging paths completely.
https://launchpad.net/bugs/913651
Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
commit a261a03904849c3df50bd0300efb7fb3f865137d upstream.
Most filesystems call inode_change_ok() very early in ->setattr(), but
eCryptfs didn't call it at all. It allowed the lower filesystem to make
the call in its ->setattr() function. Then, eCryptfs would copy the
appropriate inode attributes from the lower inode to the eCryptfs inode.
This patch changes that and actually calls inode_change_ok() on the
eCryptfs inode, fairly early in ecryptfs_setattr(). Ideally, the call
would happen earlier in ecryptfs_setattr(), but there are some possible
inode initialization steps that must happen first.
Since the call was already being made on the lower inode, the change in
functionality should be minimal, except for the case of a file extending
truncate call. In that case, inode_newsize_ok() was never being
called on the eCryptfs inode. Rather than inode_newsize_ok() catching
maximum file size errors early on, eCryptfs would encrypt zeroed pages
and write them to the lower filesystem until the lower filesystem's
write path caught the error in generic_write_checks(). This patch
introduces a new function, called ecryptfs_inode_newsize_ok(), which
checks if the new lower file size is within the appropriate limits when
the truncate operation will be growing the lower file.
In summary this change prevents eCryptfs truncate operations (and the
resulting page encryptions), which would exceed the lower filesystem
limits or FSIZE rlimits, from ever starting.
Reviewed-by: Li Wang <liwang@nudt.edu.cn>
commit 5e6f0d769017cc49207ef56996e42363ec26c1f0 upstream.
ecryptfs_write() handles the truncation of eCryptfs inodes. It grabs a
page, zeroes out the appropriate portions, and then encrypts the page
before writing it to the lower filesystem. It was unkillable and due to
the lack of sparse file support could result in tying up a large portion
of system resources, while encrypting pages of zeros, with no way for
the truncate operation to be stopped from userspace.
This patch adds the ability for ecryptfs_write() to detect a pending
fatal signal and return as gracefully as possible. The intent is to
leave the lower file in a useable state, while still allowing a user to
break out of the encryption loop. If a pending fatal signal is detected,
the eCryptfs inode size is updated to reflect the modified inode size
and then -EINTR is returned.
commit 30373dc0c87ffef68d5628e77d56ffb1fa22e1ee upstream.
Print inode on metadata read failure. The only real
way of dealing with metadata read failures is to delete
the underlying file system file. Having the inode
allows one to 'find . -inum INODE`.
[tyhicks@canonical.com: Removed some minor not-for-stable parts]
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
commit db10e556518eb9d21ee92ff944530d84349684f4 upstream.
A malicious count value specified when writing to /dev/ecryptfs may
result in a a very large kernel memory allocation.
This patch peeks at the specified packet payload size, adds that to the
size of the packet headers and compares the result with the write count
value. The resulting maximum memory allocation size is approximately 532
bytes.
Reported-by: Sasha Levin <levinsasha928@gmail.com>
commit b4ead019afc201f71c39cd0dfcaafed4a97b3dd2 upstream.
The recent change of the power-widget handling for IDT codecs caused
the silent output from the docking-station line-out jack. This was
partially fixed by the commit f2cbba7602383cd9cdd21f0a5d0b8bd1aad47b33
"ALSA: hda - Fix the lost power-setup of seconary pins after PM resume".
But the line-out on the docking-station is still silent when booted
with the jack plugged even by this fix.
The remainig bug is that the power-widget is set off in stac92xx_init()
because the pins in cfg->line_out_pins[] aren't checked there properly
but only hp_pins[] are checked in is_nid_hp_pin().
This patch fixes the problem by checking both HP and line-out pins
and leaving the power-map correctly.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=42637
commit 52409aa6a0e96337da137c069856298f4dd825a0 upstream.
The commit 2ae66c26550cd94b0e2606a9275eb0ab7070ad0e
ALSA: hda: option to enable arbitrary buffer/period sizes
introduced a regression on machines with Intel controller and Nvidia
HDMI. The reason is that the driver modifies the global variable
align_buffer_size when an Intel controller is found, and the Nvidia
HDMI controller is probed after Intel although Nvidia chips require
the aligned buffers.
This patch fixes the problem by moving the flag into the local struct
so that it's not affected by other controllers.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=42567
I found the problem:
The bug comes from a timed out condition.
TASK 1 TASK 2
futex_wait_requeue_pi()
futex_wait_queue_me()
<timed out>
double_lock_hb();
raw_spin_lock(pi_lock);
if (current->pi_blocked_on) {
} else {
current->pi_blocked_on = PI_WAKE_INPROGRESS;
run_spin_unlock(pi_lock);
spin_lock(hb->lock); <-- blocked!
plist_for_each_entry_safe(this) {
rt_mutex_start_proxy_lock();
task_blocks_on_rt_mutex();
BUG_ON(task->pi_blocked_on)!!!!
The BUG_ON() actually has a check for PI_WAKE_INPROGRESS, but the
problem is that, after TASK 1 sets PI_WAKE_INPROGRESS, it then tries to
grab the hb->lock, which it fails to do so. As the hb->lock is a mutex,
it will block and set the "pi_blocked_on" to the hb->lock.
When TASK 2 goes to requeue it, the check for PI_WAKE_INPROGESS fails
because the task1's pi_blocked_on is no longer set to that, but instead,
set to the hb->lock.
We need a way in rt_mutex_start_proxy_lock() to prevent this.
I just added the below patch, which makes the bug go away. It's a little
ugly (but no more ugly than the pi futex_requeue already is ;-)
-- Steve
commit 245132643e1cfcd145bbc86a716c1818371fcb93 upstream.
Commit cc39c6a9bbde ("mm: account skipped entries to avoid looping in
find_get_pages") correctly fixed an infinite loop; but left a problem
that find_get_pages() on shmem would return 0 (appearing to callers to
mean end of tree) when it meets a run of nr_pages swap entries.
The only uses of find_get_pages() on shmem are via pagevec_lookup(),
called from invalidate_mapping_pages(), and from shmctl SHM_UNLOCK's
scan_mapping_unevictable_pages(). The first is already commented, and
not worth worrying about; but the second can leave pages on the
Unevictable list after an unusual sequence of swapping and locking.
Fix that by using shmem_find_get_pages_and_swap() (then ignoring the
swap) instead of pagevec_lookup().
But I don't want to contaminate vmscan.c with shmem internals, nor
shmem.c with LRU locking. So move scan_mapping_unevictable_pages() into
shmem.c, renaming it shmem_unlock_mapping(); and rename
check_move_unevictable_page() to check_move_unevictable_pages(), looping
down an array of pages, oftentimes under the same lock.
Leave out the "rotate unevictable list" block: that's a leftover from
when this was used for /proc/sys/vm/scan_unevictable_pages, whose flawed
handling involved looking at pages at tail of LRU.
Was there significance to the sequence first ClearPageUnevictable, then
test page_evictable, then SetPageUnevictable here? I think not, we're
under LRU lock, and have no barriers between those.
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Cc: Minchan Kim <minchan.kim@gmail.com>
Cc: Shaohua Li <shaohua.li@intel.com>
Cc: Michel Lespinasse <walken@google.com>
commit 85046579bde15e532983438f86b36856e358f417 upstream.
scan_mapping_unevictable_pages() is used to make SysV SHM_LOCKed pages
evictable again once the shared memory is unlocked. It does this with
pagevec_lookup()s across the whole object (which might occupy most of
memory), and takes 300ms to unlock 7GB here. A cond_resched() every
PAGEVEC_SIZE pages would be good.
However, KOSAKI-san points out that this is called under shmem.c's
info->lock, and it's also under shm.c's shm_lock(), both spinlocks.
There is no strong reason for that: we need to take these pages off the
unevictable list soonish, but those locks are not required for it.
So move the call to scan_mapping_unevictable_pages() from shmem.c's
unlock handling up to shm.c's unlock handling. Remove the recently
added barrier, not needed now we have spin_unlock() before the scan.
Use get_file(), with subsequent fput(), to make sure we have a reference
to mapping throughout scan_mapping_unevictable_pages(): that's something
that was previously guaranteed by the shm_lock().
Remove shmctl's lru_add_drain_all(): we don't fault in pages at SHM_LOCK
time, and we lazily discover them to be Unevictable later, so it serves
no purpose for SHM_LOCK; and serves no purpose for SHM_UNLOCK, since
pages still on pagevec are not marked Unevictable.
The original code avoided redundant rescans by checking VM_LOCKED flag
at its level: now avoid them by checking shp's SHM_LOCKED.
The original code called scan_mapping_unevictable_pages() on a locked
area at shm_destroy() time: perhaps we once had accounting cross-checks
which required that, but not now, so skip the overhead and just let
inode eviction deal with them.
Put check_move_unevictable_page() and scan_mapping_unevictable_pages()
under CONFIG_SHMEM (with stub for the TINY case when ramfs is used),
more as comment than to save space; comment them used for SHM_UNLOCK.
