2013-01-03Linux 3.2.36v3.2.36Ben Hutchings
2013-01-03ramoops: fix use of rounddown_pow_of_two()Marco Stornelli
commit fdb5950754eb3dedb9fea7c8828d3e51d9dbc3f7 upstream. The return value of rounddown_pow_of_two wasn't evaluated, so the operation was a no-op. Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com> Reported-by: Andrew Morton <akpm@linux-foundation.org> Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03staging: vt6656: 64bit fixes: vCommandTimerWait change calculation of timer.Malcolm Priestley
commit 70e227790d4ee4590023d8041a3485f8053593fc upstream. The timer appears to run too fast/race on 64 bit systems. Using msecs_to_jiffies seems to cause a deadlock on 64 bit. A calculation of (MSecond * HZ) / 1000 appears to run satisfactory. Change BSSIDInfoCount to u32. After this patch the driver can be successfully connect on little endian 64/32 bit systems. Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03staging: vt6656: 64bit fixes: key.c/h change unsigned long to u32Malcolm Priestley
commit c0d05b305b00c698b0a8c1b3d46c9380bce9db45 upstream. Fixes long issues. Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03staging: vt6656: 64 bit fixes: fix long warning messages.Malcolm Priestley
commit b4dc03af5513774277c9c36b12a25cd3f25f4404 upstream. Fixes long warning messages from patch [PATCH 08/14] staging: vt6656: 64 bit fixes : correct all type sizes Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03staging: vt6656: 64 bit fixes : correct all type sizesMalcolm Priestley
commit 7730492855a2f9c828599bcd8d62760f96d319e4 upstream. After this patch all BYTE/WORD/DWORD types can be replaced with the appropriate u sizes. Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03staging: vt6656: 64 bit fixes: use u32 for QWORD definition.Malcolm Priestley
commit a552397d5e4ef0cc0bd3e9595d6acc9a3b381171 upstream. Size of long issues replace with u32. Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03staging: vt6656: [BUG] out of bound array reference in RFbSetPower.Malcolm Priestley
commit ab1dd9963137a1e122004d5378a581bf16ae9bc8 upstream. Calling RFbSetPower with uCH zero value will cause out of bound array reference. This causes 64 bit kernels to oops on boot. Note: Driver does not function on 64 bit kernels and should be blacklisted on them. Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03udf: fix memory leak while allocating blocks during writeNamjae Jeon
commit 2fb7d99d0de3fd8ae869f35ab682581d8455887a upstream. Need to brelse the buffer_head stored in cur_epos and next_epos. Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Ashish Sangwan <a.sangwan@samsung.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03thp, memcg: split hugepage for memcg oom on cowDavid Rientjes
commit 1f1d06c34f7675026326cd9f39ff91e4555cf355 upstream. On COW, a new hugepage is allocated and charged to the memcg. If the system is oom or the charge to the memcg fails, however, the fault handler will return VM_FAULT_OOM which results in an oom kill. Instead, it's possible to fallback to splitting the hugepage so that the COW results only in an order-0 page being allocated and charged to the memcg which has a higher liklihood to succeed. This is expensive because the hugepage must be split in the page fault handler, but it is much better than unnecessarily oom killing a process. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Johannes Weiner <jweiner@redhat.com> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03Revert "mm: vmscan: fix endless loop in kswapd balancing"Ben Hutchings
This reverts commit 39d18dc4b8b0c000fa681cbae10ac3f8a132814b which was commit 60cefed485a02bd99b6299dad70666fe49245da7 upstream. This was not needed and is not suitable for 3.2.y. Reported-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03hpsa: gen8plus Smart Array IDsMike Miller
commit fe0c9610bb68dd0aad1017456f5e3c31264d70c2 upstream. Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03i82975x_edac: Fix dimm label initializationMauro Carvalho Chehab
commit 479696840239e0cc43efb3c917bdcad2174d2215 upstream. The driver has only 4 hardcoded labels, but allows much more memory. Fix it by removing the hardcoded logic, using snprintf() instead. [ 19.833972] general protection fault: 0000 [#1] SMP [ 19.837733] Modules linked in: i82975x_edac(+) edac_core firewire_ohci firewire_core crc_itu_t nouveau mxm_wmi wmi video i2c_algo_bit drm_kms_helper ttm drm i2c_core [ 19.837733] CPU 0 [ 19.837733] Pid: 390, comm: udevd Not tainted 3.6.1-1.fc17.x86_64.debug #1 Dell Inc. Precision WorkStation 390 /0MY510 [ 19.837733] RIP: 0010:[<ffffffff813463a8>] [<ffffffff813463a8>] strncpy+0x18/0x30 [ 19.837733] RSP: 0018:ffff880078535b68 EFLAGS: 00010202 [ 19.837733] RAX: ffff880069fa9708 RBX: ffff880078588000 RCX: ffff880069fa9708 [ 19.837733] RDX: 000000000000001f RSI: 5f706f5f63616465 RDI: ffff880069fa9708 [ 19.837733] RBP: ffff880078535b68 R08: ffff880069fa9727 R09: 000000000000fffe [ 19.837733] R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000003 [ 19.837733] R13: 0000000000000000 R14: ffff880069fa9290 R15: ffff880079624a80 [ 19.837733] FS: 00007f3de01ee840(0000) GS:ffff88007c400000(0000) knlGS:0000000000000000 [ 19.837733] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 19.837733] CR2: 00007f3de00b9000 CR3: 0000000078dbc000 CR4: 00000000000007f0 [ 19.837733] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 19.837733] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 19.837733] Process udevd (pid: 390, threadinfo ffff880078534000, task ffff880079642450) [ 19.837733] Stack: [ 19.837733] ffff880078535c18 ffffffffa017c6b8 00040000816d627f ffff880079624a88 [ 19.837733] ffffc90004cd6000 ffff880079624520 ffff88007ac21148 0000000000000000 [ 19.837733] 0000000000000000 0004000000000000 feda000078535bc8 ffffffff810d696d [ 19.837733] Call Trace: [ 19.837733] [<ffffffffa017c6b8>] i82975x_init_one+0x2e6/0x3e6 [i82975x_edac] ... Fix bug reported at: https://bugzilla.redhat.com/show_bug.cgi?id=848149 And, very likely: https://bbs.archlinux.org/viewtopic.php?id=148033 https://bugzilla.kernel.org/show_bug.cgi?id=47171 Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> [bwh: Backported to 3.2: - Adjust context - Use csrow->channels[chan].label not csrow->channels[chan]->dimm->label] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03telephony: ijx: buffer overflow in ixj_write_cid()Dan Carpenter
[Not needed in 3.8 or newer as this driver is removed there. - gregkh] We get this from user space and nothing has been done to ensure that these strings are NUL terminated. Reported-by: Chen Gang <gang.chen@asianux.com> Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03MISC: hpilo, remove pci_disable_deviceJiri Slaby
commit bcdee04ea7ae0406ae69094f6df1aacb66a69a0b upstream. pci_disable_device(pdev) used to be in pci remove function. But this PCI device has two functions with interrupt lines connected to a single pin. The other one is a USB host controller. So when we disable the PIN there e.g. by rmmod hpilo, the controller stops working. It is because the interrupt link is disabled in ACPI since it is not refcounted yet. See acpi_pci_link_free_irq called from acpi_pci_irq_disable. It is not the best solution whatsoever, but as a workaround until the ACPI irq link refcounting is sorted out this should fix the reported errors. References: https://lkml.org/lkml/2008/11/4/535 Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Nobin Mathew <nobin.mathew@gmail.com> Cc: Robert Hancock <hancockr@shaw.ca> Cc: Arnd Bergmann <arnd@arndb.de> Cc: David Altobelli <david.altobelli@hp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03iwlwifi: handle DMA mapping failuresJohannes Berg
commit 7c34158231b2eda8dcbd297be2bb1559e69cb433 upstream. The RX replenish code doesn't handle DMA mapping failures, which will cause issues if there actually is a failure. This was reported by Shuah Khan who found a DMA mapping framework warning ("device driver failed to check map error"). Reported-by: Shuah Khan <shuah.khan@hp.com> Reviewed-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> [bwh: Backported to 3.2: - Adjust filename, context, indentation - Use bus(trans) instead of trans where necessary - Use hw_params(trans).rx_page_order instead of trans_pcie->rx_page_order] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03usb/ipheth: Add iPhone 5 supportJay Purohit
[ Upstream commit af1b85e49089f945deb46258b0fc4bc9910afb22 ] I noticed that the iPhone ethernet driver did not support iPhone 5. I quickly added support to it in my kernel, here's a patch. Signed-off-by: Jay Purohit <jspurohit@velocitylimitless.com> Acked-by: Valdis Kletnieks <valdis.kletnieks@vt.edu> Signed-off-by: Jan Ceuleers <jan.ceuleers@computer.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03ipv4: ip_check_defrag must not modify skb before unsharingJohannes Berg
[ Upstream commit 1bf3751ec90cc3174e01f0d701e8449ce163d113 ] ip_check_defrag() might be called from af_packet within the RX path where shared SKBs are used, so it must not modify the input SKB before it has unshared it for defragmentation. Use skb_copy_bits() to get the IP header and only pull in everything later. The same is true for the other caller in macvlan as it is called from dev->rx_handler which can also get a shared SKB. Reported-by: Eric Leblond <eric@regit.org> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03irda: sir_dev: Fix copy/paste typoAlexander Shiyan
[ Upstream commit 2355a62bcbdcc4b567425bab036bfab6ade87eed ] Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03ne2000: add the right platform deviceAlan Cox
[ Upstream commit da9da01d9199b5bb15289d0859053c9aa3a34ac0 ] Without this udev doesn't have a way to key the ne device to the platform device. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03sctp: fix -ENOMEM result with invalid user space pointer in sendto() syscallTommi Rantala
[ Upstream commit 6e51fe7572590d8d86e93b547fab6693d305fd0d ] Consider the following program, that sets the second argument to the sendto() syscall incorrectly: #include <string.h> #include <arpa/inet.h> #include <sys/socket.h> int main(void) { int fd; struct sockaddr_in sa; fd = socket(AF_INET, SOCK_STREAM, 132 /*IPPROTO_SCTP*/); if (fd < 0) return 1; memset(&sa, 0, sizeof(sa)); sa.sin_family = AF_INET; sa.sin_addr.s_addr = inet_addr("127.0.0.1"); sa.sin_port = htons(11111); sendto(fd, NULL, 1, 0, (struct sockaddr *)&sa, sizeof(sa)); return 0; } We get -ENOMEM: $ strace -e sendto ./demo sendto(3, NULL, 1, 0, {sa_family=AF_INET, sin_port=htons(11111), sin_addr=inet_addr("127.0.0.1")}, 16) = -1 ENOMEM (Cannot allocate memory) Propagate the error code from sctp_user_addto_chunk(), so that we will tell user space what actually went wrong: $ strace -e sendto ./demo sendto(3, NULL, 1, 0, {sa_family=AF_INET, sin_port=htons(11111), sin_addr=inet_addr("127.0.0.1")}, 16) = -1 EFAULT (Bad address) Noticed while running Trinity (the syscall fuzzer). Signed-off-by: Tommi Rantala <tt.rantala@gmail.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03sctp: fix memory leak in sctp_datamsg_from_user() when copy from user space ↵Tommi Rantala
fails [ Upstream commit be364c8c0f17a3dd42707b5a090b318028538eb9 ] Trinity (the syscall fuzzer) discovered a memory leak in SCTP, reproducible e.g. with the sendto() syscall by passing invalid user space pointer in the second argument: #include <string.h> #include <arpa/inet.h> #include <sys/socket.h> int main(void) { int fd; struct sockaddr_in sa; fd = socket(AF_INET, SOCK_STREAM, 132 /*IPPROTO_SCTP*/); if (fd < 0) return 1; memset(&sa, 0, sizeof(sa)); sa.sin_family = AF_INET; sa.sin_addr.s_addr = inet_addr("127.0.0.1"); sa.sin_port = htons(11111); sendto(fd, NULL, 1, 0, (struct sockaddr *)&sa, sizeof(sa)); return 0; } As far as I can tell, the leak has been around since ~2003. Signed-off-by: Tommi Rantala <tt.rantala@gmail.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03bonding: fix race condition in bonding_store_slaves_activenikolay@redhat.com
[ Upstream commit e196c0e579902f42cf72414461fb034e5a1ffbf7 ] Race between bonding_store_slaves_active() and slave manipulation functions. The bond_for_each_slave use in bonding_store_slaves_active() is not protected by any synchronization mechanism. NULL pointer dereference is easy to reach. Fixed by acquiring the bond->lock for the slave walk. v2: Make description text < 75 columns Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03bonding: Bonding driver does not consider the gso_max_size/gso_max_segs ↵Sarveshwar Bandi
setting of slave devices. [ Upstream commit 0e376bd0b791ac6ac6bdb051492df0769c840848 ] Patch sets the lowest gso_max_size and gso_max_segs values of the slave devices during enslave and detach. Signed-off-by: Sarveshwar Bandi <sarveshwar.bandi@emulex.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03USB: cdc-wdm: fix regression on buffer deallocationHerton Ronaldo Krzesinski
[ no commit upstream, since usb_alloc_coherent usage was removed from the driver before this was fixed ] Commit cafbe85 ("USB: cdc-wdm: better allocate a buffer that is at least as big as we tell the USB core") introduced a regression: it changed the size used in usb_alloc_coherent, but failed to do the same for the usb_free_coherent calls. It also was marked for stable and got backported to older kernels. But in the upstream kernel, the usage of usb_alloc_coherent was right after removed from the driver, so upstream doesn't have this problem, while the stable kernels still have, and thus need this fix. BugLink: https://bugs.launchpad.net/bugs/1074157 Signed-off-by: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03drm/i915: do not default to 18 bpp for eDP if missing from VBTJani Nikula
commit 9a30a61f3516871c5c638fd7c025fbaa11ddf7fe upstream. commit 500a8cc466a24e2fbc4c86ef9c6467ae2ffdeb0c Author: Zhenyu Wang <zhenyuw@linux.intel.com> Date: Wed Jan 13 11:19:52 2010 +0800 drm/i915: parse eDP panel color depth from VBT block originally introduced parsing bpp for eDP from VBT, with a default of 18 bpp if the eDP BIOS data block is not present. Turns out that default seems to break the Macbook Pro with retina display, as noted in commit 4344b813f105a19f793f1fd93ad775b784648b95 Author: Daniel Vetter <daniel.vetter@ffwll.ch> Date: Fri Aug 10 11:10:20 2012 +0200 drm/i915: ignore eDP bpc settings from vbt Since we can't ignore bpc settings from VBT completely after all, get rid of the default. Do not clamp eDP to 18 bpp by default if the eDP BDB is missing from VBT. Signed-off-by: Jani Nikula <jani.nikula@intel.com> Tested-by: Henrik Rydberg <rydberg@euromail.se> [danvet: paste in the updated commit message from irc.] Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03drm/i915: do not ignore eDP bpc settings from vbtJani Nikula
commit 2f4f649a69a9eb51f6e98130e19dd90a260a4145 upstream. There are laptops out there that need the eDP bpc from VBT. This is effectively a revert of commit 4344b813f105a19f793f1fd93ad775b784648b95 Author: Daniel Vetter <daniel.vetter@ffwll.ch> Date: Fri Aug 10 11:10:20 2012 +0200 drm/i915: ignore eDP bpc settings from vbt but putting the VBT check after the EDID check to see them both in dmesg if this clamps more than the EDID. We have enough history with bpc clamping to warrant the extra debug info. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=47641 Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=56401 Signed-off-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03dm ioctl: prevent unsafe change to dm_ioctl data_sizeAlasdair G Kergon
commit e910d7ebecd1aac43125944a8641b6cb1a0dfabe upstream. Abort dm ioctl processing if userspace changes the data_size parameter after we validated it but before we finished copying the data buffer from userspace. The dm ioctl parameters are processed in the following sequence: 1. ctl_ioctl() calls copy_params(); 2. copy_params() makes a first copy of the fixed-sized portion of the userspace parameters into the local variable "tmp"; 3. copy_params() then validates tmp.data_size and allocates a new structure big enough to hold the complete data and copies the whole userspace buffer there; 4. ctl_ioctl() reads userspace data the second time and copies the whole buffer into the pointer "param"; 5. ctl_ioctl() reads param->data_size without any validation and stores it in the variable "input_param_size"; 6. "input_param_size" is further used as the authoritative size of the kernel buffer. The problem is that userspace code could change the contents of user memory between steps 2 and 4. In particular, the data_size parameter can be changed to an invalid value after the kernel has validated it. This lets userspace force the kernel to access invalid kernel memory. The fix is to ensure that the size has not changed at step 4. This patch shouldn't have a security impact because CAP_SYS_ADMIN is required to run this code, but it should be fixed anyway. Reported-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03dm persistent data: rename node to btree_nodeMikulas Patocka
commit 550929faf89e2e2cdb3e9945ea87d383989274cf upstream. This patch fixes a compilation failure on sparc32 by renaming struct node. struct node is already defined in include/linux/node.h. On sparc32, it happens to be included through other dependencies and persistent-data doesn't compile because of conflicting declarations. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03SGI-XP: handle non-fatal trapsRobin Holt
commit 891348ca0f66206f1dc0e30d63757e3df1ae2d15 upstream. We found a user code which was raising a divide-by-zero trap. That trap would lead to XPC connections between system-partitions being torn down due to the die_chain notifier callouts it received. This also revealed a different issue where multiple callers into xpc_die_deactivate() would all attempt to do the disconnect in parallel which would sometimes lock up but often overwhelm the console on very large machines as each would print at least one line of output at the end of the deactivate. I reviewed all the users of the die_chain notifier and changed the code to ignore the notifier callouts for reasons which will not actually lead to a system to continue on to call die(). [akpm@linux-foundation.org: fix ia64] Signed-off-by: Robin Holt <holt@sgi.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03exec: do not leave bprm->interp on stackKees Cook
commit b66c5984017533316fd1951770302649baf1aa33 upstream. If a series of scripts are executed, each triggering module loading via unprintable bytes in the script header, kernel stack contents can leak into the command line. Normally execution of binfmt_script and binfmt_misc happens recursively. However, when modules are enabled, and unprintable bytes exist in the bprm->buf, execution will restart after attempting to load matching binfmt modules. Unfortunately, the logic in binfmt_script and binfmt_misc does not expect to get restarted. They leave bprm->interp pointing to their local stack. This means on restart bprm->interp is left pointing into unused stack memory which can then be copied into the userspace argv areas. After additional study, it seems that both recursion and restart remains the desirable way to handle exec with scripts, misc, and modules. As such, we need to protect the changes to interp. This changes the logic to require allocation for any changes to the bprm->interp. To avoid adding a new kmalloc to every exec, the default value is left as-is. Only when passing through binfmt_script or binfmt_misc does an allocation take place. For a proof of concept, see DoTest.sh from: http://www.halfdog.net/Security/2012/LinuxKernelBinfmtScriptStackDataDisclosure/ Signed-off-by: Kees Cook <keescook@chromium.org> Cc: halfdog <me@halfdog.net> Cc: P J P <ppandit@redhat.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03vfs: d_obtain_alias() needs to use "/" as default name.NeilBrown
commit b911a6bdeef5848c468597d040e3407e0aee04ce upstream. NFS appears to use d_obtain_alias() to create the root dentry rather than d_make_root. This can cause 'prepend_path()' to complain that the root has a weird name if an NFS filesystem is lazily unmounted. e.g. if "/mnt" is an NFS mount then { cd /mnt; umount -l /mnt ; ls -l /proc/self/cwd; } will cause a WARN message like WARNING: at /home/git/linux/fs/dcache.c:2624 prepend_path+0x1d7/0x1e0() ... Root dentry has weird name <> to appear in kernel logs. So change d_obtain_alias() to use "/" rather than "" as the anonymous name. Signed-off-by: NeilBrown <neilb@suse.de> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> [bwh: Backported to 3.2: use named initialisers instead of QSTR_INIT()] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03intel-iommu: Free old page tables before creating superpageWoodhouse, David
commit 6491d4d02893d9787ba67279595990217177b351 upstream. The dma_pte_free_pagetable() function will only free a page table page if it is asked to free the *entire* 2MiB range that it covers. So if a page table page was used for one or more small mappings, it's likely to end up still present in the page tables... but with no valid PTEs. This was fine when we'd only be repopulating it with 4KiB PTEs anyway but the same virtual address range can end up being reused for a *large-page* mapping. And in that case were were trying to insert the large page into the second-level page table, and getting a complaint from the sanity check in __domain_mapping() because there was already a corresponding entry. This was *relatively* harmless; it led to a memory leak of the old page table page, but no other ill-effects. Fix it by calling dma_pte_clear_range (hopefully redundant) and dma_pte_free_pagetable() before setting up the new large page. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Tested-by: Ravi Murty <Ravi.Murty@intel.com> Tested-by: Sudeep Dutt <sudeep.dutt@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03ARM: missing ->mmap_sem around find_vma() in swp_emulate.cAl Viro
commit 7bf9b7bef881aac820bf1f2e9951a17b09bd7e04 upstream. find_vma() is *not* safe when somebody else is removing vmas. Not just the return value might get bogus just as you are getting it (this instance doesn't try to dereference the resulting vma), the search itself can get buggered in rather spectacular ways. IOW, ->mmap_sem really, really is not optional here. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03CRIS: fix I/O macrosCorey Minyard
commit c24bf9b4cc6a0f330ea355d73bfdf1dae7e63a05 upstream. The inb/outb macros for CRIS are broken from a number of points of view, missing () around parameters and they have an unprotected if statement in them. This was breaking the compile of IPMI on CRIS and thus I was being annoyed by build regressions, so I fixed them. Plus I don't think they would have worked at all, since the data values were missing "&" and the outsl had a "3" instead of a "4" for the size. From what I can tell, this stuff is not used at all, so this can't be any more broken than it was before, anyway. Signed-off-by: Corey Minyard <cminyard@mvista.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Mikael Starvik <starvik@axis.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03nfsd4: fix oops on unusual readlike compoundJ. Bruce Fields
commit d5f50b0c290431c65377c4afa1c764e2c3fe5305 upstream. If the argument and reply together exceed the maximum payload size, then a reply with a read-like operation can overlow the rq_pages array. Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03proc: pid/status: show all supplementary groupsArtem Bityutskiy
commit 8d238027b87e654be552eabdf492042a34c5c300 upstream. We display a list of supplementary group for each process in /proc/<pid>/status. However, we show only the first 32 groups, not all of them. Although this is rare, but sometimes processes do have more than 32 supplementary groups, and this kernel limitation breaks user-space apps that rely on the group list in /proc/<pid>/status. Number 32 comes from the internal NGROUPS_SMALL macro which defines the length for the internal kernel "small" groups buffer. There is no apparent reason to limit to this value. This patch removes the 32 groups printing limit. The Linux kernel limits the amount of supplementary groups by NGROUPS_MAX, which is currently set to 65536. And this is the maximum count of groups we may possibly print. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com> Acked-by: Kees Cook <keescook@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03ALSA: hda - Fix the wrong pincaps set in ALC861VD dallas/hp fixupTakashi Iwai
commit b78562b10fa66175e30b76073e32a0ad8d92aa83 upstream. The workaround to force VREF50 for dallas/hp model with ALC861VD was introduced in commit 8fdcb6fe4204bdb4c6991652717ab5063751414e, but it contained wrong pincap override bits. This patch fixes to exclude VREF80 pincap bit correctly. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03Input: walkera0701 - fix crash on startupPeter Popovec
commit a455e2985f57e2a71566bb8850094af38b2c932d upstream. The driver's timer must be set up before enabling IRQ handler, otherwise bad things may happen. Reported-and-tested-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Peter Popovec <popovec@fei.tuke.sk> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03i2400m: add Intel 6150 device IDsDan Williams
commit 999a7c5776a0ed2133645fa7e008bec05bda9254 upstream. Add device IDs for WiMAX function of Intel 6150 cards. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03fix Null pointer dereference on disk errorXiaotian Feng
commit 26cd4d65deba587f3cf2329b6869ce02bcbe68ec upstream. Following oops were observed when disk error happened: [ 4272.896937] sd 0:0:0:0: [sda] Unhandled error code [ 4272.896939] sd 0:0:0:0: [sda] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK [ 4272.896942] sd 0:0:0:0: [sda] CDB: Read(10): 28 00 00 5a de a7 00 00 08 00 [ 4272.896951] end_request: I/O error, dev sda, sector 5955239 [ 4291.574947] BUG: unable to handle kernel NULL pointer dereference at (null) [ 4291.658305] IP: [] ahci_activity_show+0x1/0x40 [ 4291.730090] PGD 76dbbc067 PUD 6c4fba067 PMD 0 [ 4291.783408] Oops: 0000 [#1] SMP [ 4291.822100] last sysfs file: /sys/devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/sw_activity [ 4291.934235] CPU 9 [ 4291.958301] Pid: 27942, comm: hwinfo ...... ata_scsi_find_dev could return NULL, so ata_scsi_activity_{show,store} should check if atadev is NULL. Signed-off-by: Xiaotian Feng <dannyfeng@tencent.com> Cc: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03ALSA: hda - Always turn on pins for HDMI/DPTakashi Iwai
commit 6169b673618bf0b2518ce413b54925782a603f06 upstream. We've seen the broken HDMI *video* output on some machines with GM965, and the debugging session pointed that the culprit is the disabled audio output pins. Toggling these pins dynamically on demand caused flickering of HDMI TV. This patch changes the behavior to keep the pin ON constantly. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=51421 Signed-off-by: Takashi Iwai <tiwai@suse.de> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03MIPS: Fix poweroff failure when HOTPLUG_CPU configured.Huacai Chen
commit 8add1ecb81f541ef2fcb0b85a5470ad9ecfb4a84 upstream. When poweroff machine, kernel_power_off() call disable_nonboot_cpus(). And if we have HOTPLUG_CPU configured, disable_nonboot_cpus() is not an empty function but attempt to actually disable the nonboot cpus. Since system state is SYSTEM_POWER_OFF, play_dead() won't be called and thus disable_nonboot_cpus() hangs. Therefore, we make this patch to avoid poweroff failure. Signed-off-by: Huacai Chen <chenhc@lemote.com> Signed-off-by: Hongliang Tao <taohl@lemote.com> Signed-off-by: Hua Yan <yanh@lemote.com> Cc: Yong Zhang <yong.zhang@windriver.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Cc: Fuxin Zhang <zhangfx@lemote.com> Cc: Zhangjin Wu <wuzhangjin@gmail.com> Patchwork: https://patchwork.linux-mips.org/patch/4211/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03ALSA: hda - Fix pin configuration of HP Pavilion dv7Takashi Iwai
commit 8ae5865ec77c22462c736846a0679947a6953548 upstream. Fix the quirk entry for HP Pavilion dv7 in order to make the bass speaker working. Reported-and-tested-by: Tomas Pospisek <tpo2@sourcepole.ch> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03mtd: nand: gpmi: reset BCH earlier, too, to avoid NAND startup problemsWolfram Sang
commit 6f2a6a52560ad8d85710aabd92b7a3239b3a6b07 upstream. It could happen (1 out of 100 times) that NAND did not start up correctly after warm rebooting, so the kernel could not find the UBI or DMA timed out due to a stalled BCH. When resetting BCH together with GPMI, the issue could not be observed anymore (after 10000+ reboots). We probably need the consistent state already before sending any command to NAND, even when no ECC is needed. I chose to keep the extra reset for BCH when changing the flash layout to be on the safe side. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Huang Shijie <b32955@freescale.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03target/tcm_fc: fix the lockdep warning due to inconsistent lock stateYi Zou
commit 9f4ad44b264f8bb61ffdd607148215566568430d upstream. The lockdep warning below is in theory correct but it will be in really weird rare situation that ends up that deadlock since the tcm fc session is hashed based the rport id. Nonetheless, the complaining below is about rcu callback that does the transport_deregister_session() is happening in softirq, where transport_register_session() that happens earlier is not. This triggers the lockdep warning below. So, just fix this to make lockdep happy by disabling the soft irq before calling transport_register_session() in ft_prli. BTW, this was found in FCoE VN2VN over two VMs, couple of create and destroy would get this triggered. v1: was enforcing register to be in softirq context which was not righ. See, http://www.spinics.net/lists/target-devel/msg03614.html v2: following comments from Roland&Nick (thanks), it seems we don't have to do transport_deregister_session() in rcu callback, so move it into ft_sess_free() but still do kfree() of the corresponding ft_sess struct in rcu callback to make sure the ft_sess is not freed till the rcu callback. ... [ 1328.370592] scsi2 : FCoE Driver [ 1328.383429] fcoe: No FDMI support. [ 1328.384509] host2: libfc: Link up on port (000000) [ 1328.934229] host2: Assigned Port ID 00a292 [ 1357.232132] host2: rport 00a393: Remove port [ 1357.232568] host2: rport 00a393: Port sending LOGO from Ready state [ 1357.233692] host2: rport 00a393: Delete port [ 1357.234472] host2: rport 00a393: work event 3 [ 1357.234969] host2: rport 00a393: callback ev 3 [ 1357.235979] host2: rport 00a393: Received a LOGO response closed [ 1357.236706] host2: rport 00a393: work delete [ 1357.237481] [ 1357.237631] ================================= [ 1357.238064] [ INFO: inconsistent lock state ] [ 1357.238450] 3.7.0-rc7-yikvm+ #3 Tainted: G O [ 1357.238450] --------------------------------- [ 1357.238450] inconsistent {SOFTIRQ-ON-W} -> {IN-SOFTIRQ-W} usage. [ 1357.238450] ksoftirqd/0/3 [HC0[0]:SC1[1]:HE0:SE0] takes: [ 1357.238450] (&(&se_tpg->session_lock)->rlock){+.?...}, at: [<ffffffffa01eacd4>] transport_deregister_session+0x41/0x148 [target_core_mod] [ 1357.238450] {SOFTIRQ-ON-W} state was registered at: [ 1357.238450] [<ffffffff810834f5>] mark_held_locks+0x6d/0x95 [ 1357.238450] [<ffffffff8108364a>] trace_hardirqs_on_caller+0x12d/0x197 [ 1357.238450] [<ffffffff810836c1>] trace_hardirqs_on+0xd/0xf [ 1357.238450] [<ffffffff8149caba>] _raw_spin_unlock_irq+0x2d/0x45 [ 1357.238450] [<ffffffffa01e8d10>] __transport_register_session+0xb8/0x122 [target_core_mod] [ 1357.238450] [<ffffffffa01e8dbe>] transport_register_session+0x44/0x5a [target_core_mod] [ 1357.238450] [<ffffffffa018e32c>] ft_prli+0x1e3/0x275 [tcm_fc] [ 1357.238450] [<ffffffffa0160e8d>] fc_rport_recv_req+0x95e/0xdc5 [libfc] [ 1357.238450] [<ffffffffa015be88>] fc_lport_recv_els_req+0xc4/0xd5 [libfc] [ 1357.238450] [<ffffffffa015c778>] fc_lport_recv_req+0x12f/0x18f [libfc] [ 1357.238450] [<ffffffffa015a6d7>] fc_exch_recv+0x8ba/0x981 [libfc] [ 1357.238450] [<ffffffffa0176d7a>] fcoe_percpu_receive_thread+0x47a/0x4e2 [fcoe] [ 1357.238450] [<ffffffff810549f1>] kthread+0xb1/0xb9 [ 1357.238450] [<ffffffff814a40ec>] ret_from_fork+0x7c/0xb0 [ 1357.238450] irq event stamp: 275411 [ 1357.238450] hardirqs last enabled at (275410): [<ffffffff810bb6a0>] rcu_process_callbacks+0x229/0x42a [ 1357.238450] hardirqs last disabled at (275411): [<ffffffff8149c2f7>] _raw_spin_lock_irqsave+0x22/0x8e [ 1357.238450] softirqs last enabled at (275394): [<ffffffff8103d669>] __do_softirq+0x246/0x26f [ 1357.238450] softirqs last disabled at (275399): [<ffffffff8103d6bb>] run_ksoftirqd+0x29/0x62 [ 1357.238450] [ 1357.238450] other info that might help us debug this: [ 1357.238450] Possible unsafe locking scenario: [ 1357.238450] [ 1357.238450] CPU0 [ 1357.238450] ---- [ 1357.238450] lock(&(&se_tpg->session_lock)->rlock); [ 1357.238450] <Interrupt> [ 1357.238450] lock(&(&se_tpg->session_lock)->rlock); [ 1357.238450] [ 1357.238450] *** DEADLOCK *** [ 1357.238450] [ 1357.238450] no locks held by ksoftirqd/0/3. [ 1357.238450] [ 1357.238450] stack backtrace: [ 1357.238450] Pid: 3, comm: ksoftirqd/0 Tainted: G O 3.7.0-rc7-yikvm+ #3 [ 1357.238450] Call Trace: [ 1357.238450] [<ffffffff8149399a>] print_usage_bug+0x1f5/0x206 [ 1357.238450] [<ffffffff8100da59>] ? save_stack_trace+0x2c/0x49 [ 1357.238450] [<ffffffff81082aae>] ? print_irq_inversion_bug.part.14+0x1ae/0x1ae [ 1357.238450] [<ffffffff81083336>] mark_lock+0x106/0x258 [ 1357.238450] [<ffffffff81084e34>] __lock_acquire+0x2e7/0xe53 [ 1357.238450] [<ffffffff8102903d>] ? pvclock_clocksource_read+0x48/0xb4 [ 1357.238450] [<ffffffff810ba6a3>] ? rcu_process_gp_end+0xc0/0xc9 [ 1357.238450] [<ffffffffa01eacd4>] ? transport_deregister_session+0x41/0x148 [target_core_mod] [ 1357.238450] [<ffffffff81085ef1>] lock_acquire+0x119/0x143 [ 1357.238450] [<ffffffffa01eacd4>] ? transport_deregister_session+0x41/0x148 [target_core_mod] [ 1357.238450] [<ffffffff8149c329>] _raw_spin_lock_irqsave+0x54/0x8e [ 1357.238450] [<ffffffffa01eacd4>] ? transport_deregister_session+0x41/0x148 [target_core_mod] [ 1357.238450] [<ffffffffa01eacd4>] transport_deregister_session+0x41/0x148 [target_core_mod] [ 1357.238450] [<ffffffff810bb6a0>] ? rcu_process_callbacks+0x229/0x42a [ 1357.238450] [<ffffffffa018ddc5>] ft_sess_rcu_free+0x17/0x24 [tcm_fc] [ 1357.238450] [<ffffffffa018ddae>] ? ft_sess_free+0x1b/0x1b [tcm_fc] [ 1357.238450] [<ffffffff810bb6d7>] rcu_process_callbacks+0x260/0x42a [ 1357.238450] [<ffffffff8103d55d>] __do_softirq+0x13a/0x26f [ 1357.238450] [<ffffffff8149b34e>] ? __schedule+0x65f/0x68e [ 1357.238450] [<ffffffff8103d6bb>] run_ksoftirqd+0x29/0x62 [ 1357.238450] [<ffffffff8105c83c>] smpboot_thread_fn+0x1a5/0x1aa [ 1357.238450] [<ffffffff8105c697>] ? smpboot_unregister_percpu_thread+0x47/0x47 [ 1357.238450] [<ffffffff810549f1>] kthread+0xb1/0xb9 [ 1357.238450] [<ffffffff8149b49d>] ? wait_for_common+0xbb/0x10a [ 1357.238450] [<ffffffff81054940>] ? __init_kthread_worker+0x59/0x59 [ 1357.238450] [<ffffffff814a40ec>] ret_from_fork+0x7c/0xb0 [ 1357.238450] [<ffffffff81054940>] ? __init_kthread_worker+0x59/0x59 [ 1417.440099] rport-2:0-0: blocked FC remote port time out: removing rport Signed-off-by: Yi Zou <yi.zou@intel.com> Cc: Open-FCoE <devel@open-fcoe.org> Cc: Nicholas A. Bellinger <nab@risingtidesystems.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03NFS: avoid NULL dereference in nfs_destroy_serverNeilBrown
commit f259613a1e4b44a0cf85a5dafd931be96ee7c9e5 upstream. In rare circumstances, nfs_clone_server() of a v2 or v3 server can get an error between setting server->destory (to nfs_destroy_server), and calling nfs_start_lockd (which will set server->nlm_host). If this happens, nfs_clone_server will call nfs_free_server which will call nfs_destroy_server and thence nlmclnt_done(NULL). This causes the NULL to be dereferenced. So add a guard to only call nlmclnt_done() if ->nlm_host is not NULL. The other guards there are irrelevant as nlm_host can only be non-NULL if one of these flags are set - so remove those tests. (Thanks to Trond for this suggestion). This is suitable for any stable kernel since 2.6.25. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03drm/radeon: fix amd afusion gpu setup aka sumo v2Jerome Glisse
commit bd25f0783dc3fb72e1e2779c2b99b2d34b67fa8a upstream. Set the proper number of tile pipe that should be a multiple of pipe depending on the number of se engine. Fix: https://bugs.freedesktop.org/show_bug.cgi?id=56405 https://bugs.freedesktop.org/show_bug.cgi?id=56720 v2: Don't change sumo2 Signed-off-by: Jerome Glisse <jglisse@redhat.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> [bwh: Backported to 3.2: don't define/use *_GB_ADDR_CONFIG_GOLDEN] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03ALSA: hda - Add stereo-dmic fixup for Acer Aspire One 522Takashi Iwai
commit 63a077e27648b4043b1ca1b4e29f0c42d99616b6 upstream. Acer Aspire One 522 has the infamous digital mic unit that needs the phase inversion fixup for stereo. Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=715737 Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-01-03solos-pci: fix double-free of TX skb in DMA modeDavid Woodhouse
commit cae49ede00ec3d0cda290b03fee55b72b49efc11 upstream. We weren't clearing card->tx_skb[port] when processing the TX done interrupt. If there wasn't another skb ready to transmit immediately, this led to a double-free because we'd free it *again* next time we did have a packet to send. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
