commit 23795e580cad5d6b73d47d51b9074ce3e58bf334 upstream.
IVB Xeon currently shares the same parameters IVB client.
For 3.2, add model number to the switch in intel_idle_probe(), as
there is no device ID table.
commit 6edab08c24f9141d69cfa4683a0a027d86ab303e upstream.
From an OS point of view, IVB looks like SNB, but quicker.
Signed-off-by: Len Brown <len.brown@intel.com>
[bwh: Backported to 3.2: add model number to the switch in
intel_idle_probe(), as there is no device ID table]
commit 412d32e6c98527078779e5b515823b2810e40324 upstream.
A rescue thread exiting TASK_INTERRUPTIBLE can lead to a task scheduling
off, never to be seen again. In the case where this occurred, an exiting
thread hit reiserfs homebrew conditional resched while holding a mutex,
bringing the box to its knees.
PID: 18105 TASK: ffff8807fd412180 CPU: 5 COMMAND: "kdmflush"
#0 [ffff8808157e7670] schedule at ffffffff8143f489
#1 [ffff8808157e77b8] reiserfs_get_block at ffffffffa038ab2d [reiserfs]
#2 [ffff8808157e79a8] __block_write_begin at ffffffff8117fb14
#3 [ffff8808157e7a98] reiserfs_write_begin at ffffffffa0388695 [reiserfs]
#4 [ffff8808157e7ad8] generic_perform_write at ffffffff810ee9e2
#5 [ffff8808157e7b58] generic_file_buffered_write at ffffffff810eeb41
#6 [ffff8808157e7ba8] __generic_file_aio_write at ffffffff810f1a3a
#7 [ffff8808157e7c58] generic_file_aio_write at ffffffff810f1c88
#8 [ffff8808157e7cc8] do_sync_write at ffffffff8114f850
#9 [ffff8808157e7dd8] do_acct_process at ffffffff810a268f
[exception RIP: kernel_thread_helper]
RIP: ffffffff8144a5c0 RSP: ffff8808157e7f58 RFLAGS: 00000202
RAX: 0000000000000000 RBX: 0000000000000000 RCX: 0000000000000000
RDX: 0000000000000000 RSI: ffffffff8107af60 RDI: ffff8803ee491d18
RBP: 0000000000000000 R8: 0000000000000000 R9: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000000
R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
ORIG_RAX: ffffffffffffffff CS: 0010 SS: 0018
Signed-off-by: Mike Galbraith <mgalbraith@suse.de>
commit 783657a7dc20e5c0efbc9a09a9dd38e238a723da upstream.
When we try to soft-offline a thp tail page, put_page() is called on the
tail page unthinkingly and VM_BUG_ON is triggered in put_compound_page().
This patch splits thp before going into the main body of soft-offlining.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Andi Kleen <andi.kleen@intel.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
commit 60cefed485a02bd99b6299dad70666fe49245da7 upstream.
Kswapd does not in all places have the same criteria for a balanced
zone. Zones are only being reclaimed when their high watermark is
breached, but compaction checks loop over the zonelist again when the
zone does not meet the low watermark plus two times the size of the
allocation. This gets kswapd stuck in an endless loop over a small
zone, like the DMA zone, where the high watermark is smaller than the
compaction requirement.
Add a function, zone_balanced(), that checks the watermark, and, for
higher order allocations, if compaction has enough free memory. Then
use it uniformly to check for balanced zones.
This makes sure that when the compaction watermark is not met, at least
reclaim happens and progress is made - or the zone is declared
unreclaimable at some point and skipped entirely.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reported-by: George Spelvin <linux@horizon.com>
Reported-by: Johannes Hirte <johannes.hirte@fem.tu-ilmenau.de>
Reported-by: Tomas Racek <tracek@redhat.com>
Tested-by: Johannes Hirte <johannes.hirte@fem.tu-ilmenau.de>
[bwh: Backported to 3.2: adjust context]
commit ae64ffcac35de0db628ba9631edf8ff34c5cd7ac upstream.
I enable CONFIG_DEBUG_VIRTUAL and CONFIG_SPARSEMEM_VMEMMAP, when doing
memory hotremove, there is a kernel BUG at arch/x86/mm/physaddr.c:20.
It is caused by free_section_usemap()->virt_to_page(), virt_to_page() is
only used for kernel direct mapping address, but sparse-vmemmap uses
vmemmap address, so it is going wrong here.
kernel BUG at arch/x86/mm/physaddr.c:20!
invalid opcode: 0000 [#1] SMP
Modules linked in: acpihp_drv acpihp_slot edd cpufreq_conservative cpufreq_userspace cpufreq_powersave acpi_cpufreq mperf fuse vfat fat loop dm_mod coretemp kvm crc32c_intel ipv6 ixgbe igb iTCO_wdt i7core_edac edac_core pcspkr iTCO_vendor_support ioatdma microcode joydev sr_mod i2c_i801 dca lpc_ich mfd_core mdio tpm_tis i2c_core hid_generic tpm cdrom sg tpm_bios rtc_cmos button ext3 jbd mbcache usbhid hid uhci_hcd ehci_hcd usbcore usb_common sd_mod crc_t10dif processor thermal_sys hwmon scsi_dh_alua scsi_dh_hp_sw scsi_dh_rdac scsi_dh_emc scsi_dh ata_generic ata_piix libata megaraid_sas scsi_mod
CPU 39
Pid: 6454, comm: sh Not tainted 3.7.0-rc1-acpihp-final+ #45 QCI QSSC-S4R/QSSC-S4R
RIP: 0010:[<ffffffff8103c908>] [<ffffffff8103c908>] __phys_addr+0x88/0x90
RSP: 0018:ffff8804440d7c08 EFLAGS: 00010006
RAX: 0000000000000006 RBX: ffffea0012000000 RCX: 000000000000002c
Signed-off-by: Jianguo Wu <wujianguo@huawei.com>
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Reviewd-by: Wen Congyang <wency@cn.fujitsu.com>
Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
commit aa10990e028cac3d5e255711fb9fb47e00700e35 upstream.
Dave Jones reported a bug with futex_lock_pi() that his trinity test
exposed. Sometime between queue_me() and taking the q.lock_ptr, the
lock_ptr became NULL, resulting in a crash.
While futex_wake() is careful to not call wake_futex() on futex_q's with
a pi_state or an rt_waiter (which are either waiting for a
futex_unlock_pi() or a PI futex_requeue()), futex_wake_op() and
futex_requeue() do not perform the same test.
Update futex_wake_op() and futex_requeue() to test for q.pi_state and
q.rt_waiter and abort with -EINVAL if detected. To ensure any future
breakage is caught, add a WARN() to wake_futex() if the same condition
is true.
This fix has seen 3 hours of testing with "trinity -c futex" on an
x86_64 VM with 4 CPUS.
[akpm@linux-foundation.org: tidy up the WARN()]
Signed-off-by: Darren Hart <dvhart@linux.intel.com>
Reported-by: Dave Jones <davej@redat.com>
Cc: John Kacur <jkacur@redhat.com>
commit 81b401100c01d2357031e874689f89bd788d13cd upstream.
Set in the rx_ifindex to pass the correct interface index in the case of a
message timeout detection. Usually the rx_ifindex value is set at receive
time. But when no CAN frame has been received the RX_TIMEOUT notification
did not contain a valid value.
Reported-by: Andre Naujoks <nautsch2@googlemail.com>
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit 25389bb207987b5774182f763b9fb65ff08761c8 upstream.
Commit 09e05d48 introduced a wait for transaction commit into
journal_unmap_buffer() in the case we are truncating a buffer undergoing commit
in the page stradding i_size on a filesystem with blocksize < pagesize. Sadly
we forgot to drop buffer lock before waiting for transaction commit and thus
deadlock is possible when kjournald wants to lock the buffer.
Fix the problem by dropping the buffer lock before waiting for transaction
commit. Since we are still holding page lock (and that is OK), buffer cannot
disappear under us.
commit 893d290f1d7496db97c9471bc352ad4a11dc8a25 upstream.
After we've done __elv_add_request() and __blk_run_queue() in
blk_execute_rq_nowait(), the request might finish and be freed
immediately. Therefore checking if the type is REQ_TYPE_PM_RESUME
isn't safe afterwards, because if it isn't, rq might be gone.
Instead, check beforehand and stash the result in a temporary.
This fixes crashes in blk_execute_rq_nowait() I get occasionally when
running with lots of memory debugging options enabled -- I think this
race is usually harmless because the window for rq to be reallocated
is so small.
Signed-off-by: Roland Dreier <roland@purestorage.com>
commit a8c32a5c98943d370ea606a2e7dc04717eb92206 upstream.
Request based dm attempts to re-run the request queue off the
request completion path. If used with a driver that potentially does
end_io from its request_fn, we could deadlock trying to recurse
back into request dispatch. Fix this by punting the request queue
run to kblockd.
Tested to fix a quickly reproducible deadlock in such a scenario.
Acked-by: Alasdair G Kergon <agk@redhat.com>
commit 441a179dafc0f99fc8b3a8268eef66958621082e upstream.
int sys32_rt_sigprocmask(int how, compat_sigset_t __user *set, compat_sigset_t __user *oset,
unsigned int sigsetsize)
sigset_t old_set, new_set;
int ret;
if (set && get_sigset32(set, &new_set, sigsetsize))
static int
get_sigset32(compat_sigset_t __user *up, sigset_t *set, size_t sz)
compat_sigset_t s;
int r;
if (sz != sizeof *set) panic("put_sigset32()");
In other words, rt_sigprocmask(69, (void *)69, 69) done by 32bit process
will promptly panic the box.
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit 1dc831bf53fddcc6443f74a39e72db5bcea4f15d upstream.
- The code relies on rc_pci_fixup being called, which only happens
when CONFIG_PCI_QUIRKS is enabled, so add that to Kconfig. Omitting
this causes a booting failure with a non-obvious cause.
- Update rc_pci_fixup to set the class properly, copying the
more modern style from other places
- Correct the rc_pci_fixup comment
Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
commit d356cf5a74afa32b40decca3c9dd88bc3cd63eb5 upstream.
PMU interrupts start at IRQ_DOVE_PMU_START, not IRQ_DOVE_PMU_START + 1.
Fix the condition. (It may have been less likely to occur had the code
been written "if (irq >= IRQ_DOVE_PMU_START" which imho is the easier
to understand notation, and matches the normal way of thinking about
these things.)
commit 5d3df935426271016b895aecaa247101b4bfa35e upstream.
Fix the acknowledgement of PMU interrupts on Dove: some Dove hardware
has not been sensibly designed so that interrupts can be handled in a
race free manner. The PMU is one such instance.
The pending (aka 'cause') register is a bunch of RW bits, meaning that
these bits can be both cleared and set by software (confirmed on the
Armada-510 on the cubox.)
Hardware sets the appropriate bit when an interrupt is asserted, and
software is required to clear the bits which are to be processed. If
we write ~(1 << bit), then we end up asserting every other interrupt
except the one we're processing. So, we need to do a read-modify-write
cycle to clear the asserted bit.
However, any interrupts which occur in the middle of this cycle will
also be written back as zero, which will also clear the new interrupts.
The upshot of this is: there is _no_ way to safely clear down interrupts
in this register (and other similarly behaving interrupt pending
registers on this device.) The patch below at least stops us creating
new interrupts.
commit 88a693b5c1287be4da937699cb82068ce9db0135 upstream.
[ INFO: suspicious RCU usage. ]
3.5.0-rc1+ #63 Not tainted
security/selinux/netnode.c:178 suspicious rcu_dereference_check() usage!
rcu_scheduler_active = 1, debug_locks = 0
1 lock held by trinity-child1/8750:
#0: (sel_netnode_lock){+.....}, at: [<ffffffff812d8f8a>] sel_netnode_sid+0x16a/0x3e0
stack backtrace:
Pid: 8750, comm: trinity-child1 Not tainted 3.5.0-rc1+ #63
Call Trace:
[<ffffffff810cec2d>] lockdep_rcu_suspicious+0xfd/0x130
[<ffffffff812d91d1>] sel_netnode_sid+0x3b1/0x3e0
[<ffffffff812d8e20>] ? sel_netnode_find+0x1a0/0x1a0
[<ffffffff812d24a6>] selinux_socket_bind+0xf6/0x2c0
[<ffffffff810cd1dd>] ? trace_hardirqs_off+0xd/0x10
[<ffffffff810cdb55>] ? lock_release_holdtime.part.9+0x15/0x1a0
[<ffffffff81093841>] ? lock_hrtimer_base+0x31/0x60
[<ffffffff812c9536>] security_socket_bind+0x16/0x20
[<ffffffff815550ca>] sys_bind+0x7a/0x100
[<ffffffff816c03d5>] ? sysret_check+0x22/0x5d
[<ffffffff810d392d>] ? trace_hardirqs_on_caller+0x10d/0x1a0
[<ffffffff8133b09e>] ? trace_hardirqs_on_thunk+0x3a/0x3f
[<ffffffff816c03a9>] system_call_fastpath+0x16/0x1b
This patch below does what Paul McKenney suggested in the previous thread.
Signed-off-by: Dave Jones <davej@redhat.com>
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Acked-by: Paul Moore <paul@paul-moore.com>
Cc: Eric Paris <eparis@parisplace.org>
Signed-off-by: James Morris <james.l.morris@oracle.com>
commit af02dde8a609d8d071c4b31a82df811a55690a4a upstream.
We found a new codec ID 292, and that just a simple quirk would enable
sound output/input on this ALC292 chip.
BugLink: https://bugs.launchpad.net/bugs/1081466
Tested-by: Acelan Kao <acelan.kao@canonical.com>
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
commit 7ff34ad80b7080fafaac8efa9ef0061708eddd51 upstream.
These are compatible with standard ALC269 parser.
Signed-off-by: Kailang Yang <kailang@realtek.com>
commit 36c46ca4f322a7bf89aad5462a3a1f61713edce7 upstream.
Add valid patch size for family 16h processors.
[ hpa: promoting to urgent/stable since it is hw enabling and trivial ]
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@amd.com>
Acked-by: Andreas Herrmann <herrmann.der.user@googlemail.com>
Link: http://lkml.kernel.org/r/1353004910-2204-1-git-send-email-boris.ostrovsky@amd.com
commit cb57a2b4cff7edf2a4e32c0163200e9434807e0a upstream.
Modules, in particular oprofile (and possibly other similar tools)
need kernel_stack_pointer(), so export it using EXPORT_SYMBOL_GPL().
Cc: Yang Wei <wei.yang@windriver.com>
Cc: Robert Richter <robert.richter@amd.com>
Cc: Jun Zhang <jun.zhang@intel.com>
Link: http://lkml.kernel.org/r/20120912135059.GZ8285@erda.amd.com
commit 1022623842cb72ee4d0dbf02f6937f38c92c3f41 upstream.
In 32 bit the stack address provided by kernel_stack_pointer() may
point to an invalid range causing NULL pointer access or page faults
while in NMI (see trace below). This happens if called in softirq
context and if the stack is empty. The address at ®s->sp is then
out of range.
Fixing this by checking if regs and ®s->sp are in the same stack
context. Otherwise return the previous stack pointer stored in struct
thread_info. If that address is invalid too, return address of regs.
BUG: unable to handle kernel NULL pointer dereference at 0000000a
IP: [<c1004237>] print_context_stack+0x6e/0x8d
*pde = 00000000
Oops: 0000 [#1] SMP
Modules linked in:
Pid: 4434, comm: perl Not tainted 3.6.0-rc3-oprofile-i386-standard-g4411a05 #4 Hewlett-Packard HP xw9400 Workstation/0A1Ch
EIP: 0060:[<c1004237>] EFLAGS: 00010093 CPU: 0
EIP is at print_context_stack+0x6e/0x8d
EAX: ffffe000 EBX: 0000000a ECX: f4435f94 EDX: 0000000a
ESI: f4435f94 EDI: f4435f94 EBP: f5409ec0 ESP: f5409ea0
DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068
CR0: 8005003b CR2: 0000000a CR3: 34ac9000 CR4: 000007d0
DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000
DR6: ffff0ff0 DR7: 00000400
Process perl (pid: 4434, ti=f5408000 task=f5637850 task.ti=f4434000)
Stack:
000003e8 ffffe000 00001ffc f4e39b00 00000000 0000000a f4435f94 c155198c
f5409ef0 c1003723 c155198c f5409f04 00000000 f5409edc 00000000 00000000
f5409ee8 f4435f94 f5409fc4 00000001 f5409f1c c12dce1c 00000000 c155198c
Call Trace:
[<c1003723>] dump_trace+0x7b/0xa1
[<c12dce1c>] x86_backtrace+0x40/0x88
[<c12db712>] ? oprofile_add_sample+0x56/0x84
[<c12db731>] oprofile_add_sample+0x75/0x84
[<c12ddb5b>] op_amd_check_ctrs+0x46/0x260
[<c12dd40d>] profile_exceptions_notify+0x23/0x4c
[<c1395034>] nmi_handle+0x31/0x4a
[<c1029dc5>] ? ftrace_define_fields_irq_handler_entry+0x45/0x45
[<c13950ed>] do_nmi+0xa0/0x2ff
[<c13949e5>] nmi_stack_correct+0x28/0x2d
[<c1003603>] ? do_softirq+0x4b/0x7f
<IRQ>
[<c102a06f>] irq_exit+0x35/0x5b
[<c1018f56>] smp_apic_timer_interrupt+0x6c/0x7a
[<c1394746>] apic_timer_interrupt+0x2a/0x30
Code: 89 fe eb 08 31 c9 8b 45 0c ff 55 ec 83 c3 04 83 7d 10 00 74 0c 3b 5d 10 73 26 3b 5d e4 73 0c eb 1f 3b 5d f0 76 1a 3b 5d e8 73 15 <8b> 13 89 d0 89 55 e0 e8 ad 42 03 00 85 c0 8b 55 e0 75 a6 eb cc
EIP: [<c1004237>] print_context_stack+0x6e/0x8d SS:ESP 0068:f5409ea0
CR2: 000000000000000a
---[ end trace 62afee3481b00012 ]---
Kernel panic - not syncing: Fatal exception in interrupt
V2:
* add comments to kernel_stack_pointer()
* always return a valid stack address by falling back to the address
of regs
Reported-by: Yang Wei <wei.yang@windriver.com>
Signed-off-by: Robert Richter <robert.richter@amd.com>
commit 45171002b01b2e2ec4f991eca81ffd8430fd0aec upstream.
The Intel 82855PM host bridge / Mobility FireGL 9000 RV250 combination
in an (outdated) ThinkPad T41 needs AGPMode 1 for suspend/resume (under
KMS, that is). So add a quirk for it.
(Change R250 to RV250 in comment for preceding quirk too.)
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 804cc4a0ad3a896ca295f771a28c6eb36ced7903 upstream.
The save struct is not initialized previously so explicitly
mark the crtcs as not used when they are not in use.
commit 35f9ac2dcec8f79d7059ce174fd7b7ee3290d620 upstream.
If read_seqretry returned true and bbp was changed, it will write
invalid address which can cause some serious problem.
This bug was introduced by commit v3.0-rc7-130-g2699b67.
So fix is suitable for 3.0.y thru 3.6.y.
Reported-by: zhuwenfeng@kedacom.com
Tested-by: zhuwenfeng@kedacom.com
Signed-off-by: Jianpeng Ma <majianpeng@gmail.com>
Signed-off-by: NeilBrown <neilb@suse.de>
md_is_badblock.
commit ab05613a0646dcc11049692d54bae76ca9ffa910 upstream.
This bug was introduced by commit(v3.0-rc7-126-g2230dfe).
commit 7af11686933726e99af22901d622f9e161404e6b upstream.
Calls into highlevel quota code cannot happen under the write lock. These
calls take dqio_mutex which ranks above write lock. So drop write lock
before calling back into quota code.
commit 361d94a338a3fd0cee6a4ea32bbc427ba228e628 upstream.
Calls into reiserfs journalling code and reiserfs_get_block() need to
be protected with write lock. We remove write lock around calls to high
level quota code in the next patch so these paths would suddently become
unprotected.
commit b9e06ef2e8706fe669b51f4364e3aeed58639eb2 upstream.
In reiserfs_quota_on() we do quite some work - for example unpacking
tail of a quota file. Thus we have to hold write lock until a moment
we call back into the quota code.
[bwh: Backported to 3.2: there is no distinction between USRQUOTA and
GRPQUOTA mount options here]
commit 3bb3e1fc47aca554e7e2cc4deeddc24750987ac2 upstream.
When remounting reiserfs dquot_suspend() or dquot_resume() can be called.
These functions take dqonoff_mutex which ranks above write lock so we have
to drop it before calling into quota code.
commit fae2ae2a900a5c7bb385fe4075f343e7e2d5daa2 upstream.
If a signal handler is executed on altstack and another signal comes,
we will end up with rt_sigreturn() on return from the second handler
getting -EPERM from do_sigaltstack(). It's perfectly OK, since we
are not asking to change the settings; in fact, they couldn't have been
changed during the second handler execution exactly because we'd been
on altstack all along. 64bit sigreturn on sparc treats any error from
do_sigaltstack() as "SIGSEGV now"; we need to switch to the same semantics
we are using on other architectures.
commit e99ddfde6ae0dd2662bb40435696002b590e4057 upstream.
Commit 88a8516a2128 (ALSA: usbaudio: implement USB autosuspend) added
autosuspend code to all files making up the snd-usb-audio driver.
However, midi.c is part of snd-usb-lib and is also used by other
drivers, not all of which support autosuspend. Thus, calls to
usb_autopm_get_interface() could fail, and this unexpected error would
result in the MIDI output being completely unusable.
Make it work by ignoring the error that is expected with drivers that do
not support autosuspend.
Reported-by: Colin Fletcher <colin.m.fletcher@googlemail.com>
Reported-by: Devin Venable <venable.devin@gmail.com>
Reported-by: Dr Nick Bailey <nicholas.bailey@glasgow.ac.uk>
Reported-by: Jannis Achstetter <jannis_achstetter@web.de>
Reported-by: Rui Nuno Capela <rncbc@rncbc.org>
Cc: Oliver Neukum <oliver@neukum.org>
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
commit d69043c42d8c6414fa28ad18d99973aa6c1c2e24 upstream.
Error handling in xfs_buf_ioapply_map() does not handle IO reference
counts correctly. We increment the b_io_remaining count before
building the bio, but then fail to decrement it in the failure case.
This leads to the buffer never running IO completion and releasing
the reference that the IO holds, so at unmount we can leak the
buffer. This leak is captured by this assert failure during unmount:
XFS: Assertion failed: atomic_read(&pag->pag_ref) == 0, file: fs/xfs/xfs_mount.c, line: 273
This is not a new bug - the b_io_remaining accounting has had this
problem for a long, long time - it's just very hard to get a
zero length bio being built by this code...
Further, the buffer IO error can be overwritten on a multi-segment
buffer by subsequent bio completions for partial sections of the
buffer. Hence we should only set the buffer error status if the
buffer is not already carrying an error status. This ensures that a
partial IO error on a multi-segment buffer will not be lost. This
part of the problem is a regression, however.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Reviewed-by: Mark Tinguely <tinguely@sgi.com>
Signed-off-by: Ben Myers <bpm@sgi.com>
commit dd321acddc3be1371263b8c9e6c6f2af89f63d57 upstream.
When host_sleep_config command fails we should return error to
MMC core to indicate the failure for our device.
The misspelled variable is also removed as it's redundant.
Signed-off-by: Bing Zhao <bzhao@marvell.com>
commit b1a47aa5e1e159e2cb06d7dfcc17ef5149b09299 upstream.
Reported by Tim Shepard:
I was seeing sporadic failures (wedgeups), and the majority of those
failures I saw printed the printouts in mwifiex_cmd_timeout_func with
cmd = 0xe5 which is CMD_802_11_HS_CFG_ENH. When this happens, two
minutes later I get notified that the rtcwake thread is blocked, like
this:
INFO: task rtcwake:3495 blocked for more than 120 seconds.
To get the hung thread unblocked we wake up the cmd wait queue and
cancel the ioctl.
Reported-by: Tim Shepard <shep@laptop.org>
commit a485e827f07bfdd0762059386e6e787bed6e81ee upstream.
This is an ISY IWL 2000. Probably a clone of Belkin F7D1102 050d:1102.
Its FCC ID is the same.
Signed-off-by: Albert Pool <albertpool@solcon.nl>
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
commit 949a05d03490e39e773e8652ccab9157e6f595b4 upstream.
On Thu, 2012-11-01 at 16:45 -0700, Michel Lespinasse wrote:
> Looking at the arch/parisc/kernel/sys_parisc.c implementation of
> get_shared_area(), I do have a concern though. The function basically
> ignores the pgoff argument, so that if one creates a shared mapping of
> pages 0-N of a file, and then a separate shared mapping of pages 1-N
> of that same file, both will have the same cache offset for their
> starting address.
> This looks like this would create obvious aliasing issues. Am I
> misreading this ? I can't understand how this could work good enough
> to be undetected, so there must be something I'm missing here ???
This turns out to be correct and we need to pay attention to the pgoff as
well as the address when creating the virtual address for the area.
Fortunately, the bug is rarely triggered as most applications which use pgoff
tend to use large values (git being the primary one, and it uses pgoff in
multiples of 16MB) which are larger than our cache coherency modulus, so the
problem isn't often seen in practise.
Reported-by: Michel Lespinasse <walken@google.com>
commit b78a4932f5fb11fadf41e69c606a33fa6787574c upstream.
The check whether the IBSS is active and can be removed should be
performed before deinitializing the fields used for the check/search.
Otherwise, the configured BSS will not be found and removed properly.
To make it more clear for the future, rename sdata->u.ibss to the
local pointer ifibss which is used within the checks.
This behaviour was introduced by
f3209bea110cade12e2b133da8b8499689cb0e2e
("mac80211: fix IBSS teardown race")
Cc: Ignacy Gawedzki <i@lri.fr>
Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de>
commit 49bd665c5407a453736d3232ee58f2906b42e83c upstream.
SATA MICROCODE DOWNALOAD fails on isci driver. After receiving Register
Device to Host (FIS 0x34) frame Initiator resets phy.
In the frame handler routine response (FIS 0x34) was copied into wrong
buffer and upper layer did not receive any answer which resulted in
timeout and reset.
This patch corrects this bug.
Signed-off-by: Maciej Patelczyk <maciej.patelczyk@intel.com>
Signed-off-by: Lukasz Dorau <lukasz.dorau@intel.com>
commit 5ffd3412ae5536a4c57469cb8ea31887121dcb2e upstream.
jffs2_write_begin() first acquires the page lock, then f->sem. This
causes an AB-BA deadlock with jffs2_garbage_collect_live(), which first
acquires f->sem, then the page lock:
mutex_lock(&f->sem) (A)
jffs2_garbage_collect_dnode
jffs2_gc_fetch_page
read_cache_page_async
do_read_cache_page
lock_page(page) (B)
jffs2_write_begin
grab_cache_page_write_begin
find_lock_page
lock_page(page) (B)
We fix this by restructuring jffs2_write_begin() to take f->sem before
the page lock. However, we make sure that f->sem is not held when
calling jffs2_reserve_space(), as this is not permitted by the locking
rules.
The deadlock above was observed multiple times on an SoC with a dual
ARMv7 (Cortex-A9), running the long-term 3.4.11 kernel; it occurred
when using scp to copy files from a host system to the ARM target
system. The fix was heavily tested on the same target system.
Signed-off-by: Thomas Betker <thomas.betker@rohde-schwarz.com>
Acked-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
- Adjust context
- Use D1(printk(KERN_DEBUG ...)) instead of jffs2_dbg(1, ...)]
commit c36a7ff4578ab6294885aef5ef241aeec4cdb1f0 upstream.
Fixed parsing end absolute address.
Signed-off-by: Jiri Engelthaler <engycz@gmail.com>
commit 5a6ea4af0907f995dc06df21a9c9ef764c7cd3bc upstream.
The pointer returned by kzalloc should be tested for NULL
to avoid potential NULL pointer dereference later. Incorrect
pointer was being tested for NULL. Bug introduced by commit fbcf62a3
(mtd: physmap_of: move parse_obsolete_partitions to become separate
parser).
This patch fixes this bug.
Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Cc: Artem Bityutskiy <artem.bityutskiy@intel.com>
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
commit 2bbf0a1427c377350f001fbc6260995334739ad7 upstream.
The Way Access Filter in recent AMD CPUs may hurt the performance of
some workloads, caused by aliasing issues in the L1 cache.
This patch disables it on the affected CPUs.
The issue is similar to that one of last year:
http://lkml.indiana.edu/hypermail/linux/kernel/1107.3/00041.html
This new patch does not replace the old one, we just need another
quirk for newer CPUs.
The performance penalty without the patch depends on the
circumstances, but is a bit less than the last year's 3%.
The workloads affected would be those that access code from the same
physical page under different virtual addresses, so different
processes using the same libraries with ASLR or multiple instances of
PIE-binaries. The code needs to be accessed simultaneously from both
cores of the same compute unit.
More details can be found here:
http://developer.amd.com/Assets/SharedL1InstructionCacheonAMD15hCPU.pdf
CPUs affected are anything with the core known as Piledriver.
That includes the new parts of the AMD A-Series (aka Trinity) and the
just released new CPUs of the FX-Series (aka Vishera).
The model numbering is a bit odd here: FX CPUs have model 2,
A-Series has model 10h, with possible extensions to 1Fh. Hence the
range of model ids.
Signed-off-by: Andre Przywara <osp@andrep.de>
Link: http://lkml.kernel.org/r/1351700450-9277-1-git-send-email-osp@andrep.de
[bwh: Backported to 3.2: wrmsrl_safe() is called checking_wrmsrl()]
commit 8ffeb9b0e6369135bf03a073514f571ef10606b9 upstream.
In get_sample_period(), unsigned long is not enough:
watchdog_thresh * 2 * (NSEC_PER_SEC / 5)
case1:
watchdog_thresh is 10 by default, the sample value will be: 0xEE6B2800
case2:
set watchdog_thresh is 20, the sample value will be: 0x1 DCD6 5000
In case2, we need use u64 to express the sample period. Otherwise,
changing the threshold thru proc often can not be successful.
Signed-off-by: liu chuansheng <chuansheng.liu@intel.com>
Acked-by: Don Zickus <dzickus@redhat.com>
commit 52965cc012f7a3cf35f06485ec275ebf3b3fddae upstream.
Some bcm5974 trackpads have a physical button beneath the physical surface.
This patch sets the property bit so user space applications can detect the
trackpad type and act accordingly.
Signed-off-by: Jussi Pakkanen <jussi.pakkanen@canonical.com>
Reviewed-by: Henrik Rydberg <rydberg@euromail.se>
throttle events in mcelog
commit 29e9bf1841e4f9df13b4992a716fece7087dd237 upstream.
Thermal throttle and power limit events are not defined as MCE errors in x86
architecture and should not generate MCE errors in mcelog.
Current kernel generates fake software defined MCE errors for these events.
This may confuse users because they may think the machine has real MCE errors
while actually only thermal throttle or power limit events happen.
To make it worse, buggy firmware on some platforms may falsely generate
the events. Therefore, kernel reports MCE errors which users think as real
hardware errors. Although the firmware bugs should be fixed, on the other hand,
kernel should not report MCE errors either.
So mcelog is not a good mechanism to report these events. To report the events, we count them in respective counters (core_power_limit_count,
package_power_limit_count, core_throttle_count, and package_throttle_count) in
/sys/devices/system/cpu/cpu#/thermal_throttle/. Users can check the counters
for each event on each CPU. Please note that all CPU's on one package report
duplicate counters. It's user application's responsibity to retrieve a package
level counter for one package.
This patch doesn't report package level power limit, core level power limit, and
package level thermal throttle events in mcelog. When the events happen, only
report them in respective counters in sysfs.
Since core level thermal throttle has been legacy code in kernel for a while and
users accepted it as MCE error in mcelog, core level thermal throttle is still
reported in mcelog. In the mean time, the event is counted in a counter in sysfs
as well.
Signed-off-by: Fenghua Yu <fenghua.yu@intel.com>
Acked-by: Borislav Petkov <bp@amd64.org>
Acked-by: Tony Luck <tony.luck@intel.com>
Link: http://lkml.kernel.org/r/20111215001945.GA21009@linux-os.sc.intel.com
commit 2a9227a5eeaeb3f91e3a72ceea4fa59016ca5d20 upstream.
Getting a short packet or a babble error is usually a recoverable error,
so stop scaring users with warnings in dmesg when xHCI debugging is turned
off.
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
commit 3b9783b277e66731891ab42eeaacebbdcdd6e629 upstream.
xHCI host controllers may not be capable of MSI, but they should be able
to be used in legacy PCI interrupt mode. Similarly, some xHCI host
controllers will have MSI support but not MSI-X support. Lower the
dmesg log level from an error to debug. The message won't appear unless
CONFIG_USB_XHCI_HCD_DEBUGGING is turned on.
If we need to find out whether the device can support MSI or MSI-X and
it's not being enabled by the driver, it's easy to ask the user to run
lspci.
commit 67e1d34cd54cbf33f093f1dd53e7bda1124eb972 upstream.
BugLink: http://launchpad.net/bugs/865807
There is no entry for P key on TM8372, so when P key is pressed, only
"acer_wmi: Unknown key number - 0x29" in dmesg.
Signed-off-by: Merlin Schumacher <merlin.schumacher@gmail.com>
Signed-off-by: Ike Panhc <ike.pan@canonical.com>
commit 84e83c2846ffb42772056a0f825d8578dc92d586 upstream.
This patch adds the TCO Watchdog DeviceIDs for the Intel Lynx Point PCH.
Signed-off-by: Seth Heasley <seth.heasley@intel.com>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
