commit e7d491a19d3e3aac544070293891a2542ae0c565 upstream.
This USB V.92/V.32bis Controllered Modem have the USB vendor ID 0x0572
and device ID 0x1340. It need the NO_UNION_NORMAL quirk to be recognized.
Reference:
http://www.conexant.com/servlets/DownloadServlet/DSH-201723-005.pdf?docid=1725&revid=5
See idVendor and idProduct in table 6-1. Device Descriptors
Signed-off-by: Jean-Christian de Rivaz <jc@eclis.ch>
commit 10f571d09106c3eb85951896522c9650596eff2e upstream.
Add chip details for E-mu 1010 PCIe card. It has the same
chip as found in E-mu 1010b but it uses different PCI id.
Signed-off-by: Maxim Kachur <mcdebugger@duganet.ru>
commit 733a48e5ae5bf28b046fad984d458c747cbb8c21 upstream.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=44721
commit abce9ac292e13da367bbd22c1f7669f988d931ac upstream.
tpm_write calls tpm_transmit without checking the return value and
assigns the return value unconditionally to chip->pending_data, even if
it's an error value.
This causes three bugs.
So if we write to /dev/tpm0 with a tpm_param_size bigger than
TPM_BUFSIZE=0x1000 (e.g. 0x100a)
and a bufsize also bigger than TPM_BUFSIZE (e.g. 0x100a)
tpm_transmit returns -E2BIG which is assigned to chip->pending_data as
-7, but tpm_write returns that TPM_BUFSIZE bytes have been successfully
been written to the TPM, altough this is not true (bug #1).
As we did write more than than TPM_BUFSIZE bytes but tpm_write reports
that only TPM_BUFSIZE bytes have been written the vfs tries to write
the remaining bytes (in this case 10 bytes) to the tpm device driver via
tpm_write which then blocks at
/* cannot perform a write until the read has cleared
either via tpm_read or a user_read_timer timeout */
while (atomic_read(&chip->data_pending) != 0)
msleep(TPM_TIMEOUT);
for 60 seconds, since data_pending is -7 and nobody is able to
read it (since tpm_read luckily checks if data_pending is greater than
0) (#bug 2).
After that the remaining bytes are written to the TPM which are
interpreted by the tpm as a normal command. (bug #3)
So if the last bytes of the command stream happen to be a e.g.
tpm_force_clear this gets accidentally sent to the TPM.
This patch fixes all three bugs, by propagating the error code of
tpm_write and returning -E2BIG if the input buffer is too big,
since the response from the tpm for a truncated value is bogus anyway.
Moreover it returns -EBUSY to userspace if there is a response ready to be
read.
Signed-off-by: Peter Huewe <peter.huewe@infineon.com>
Signed-off-by: Kent Yoder <key@linux.vnet.ibm.com>
commit 5b423f6a40a0327f9d40bc8b97ce9be266f74368 upstream.
Existing code assumes that del_timer returns true for alive conntrack
entries. However, this is not true if reliable events are enabled.
In that case, del_timer may return true for entries that were
just inserted in the dying list. Note that packets / ctnetlink may
hold references to conntrack entries that were just inserted to such
list.
This patch fixes the issue by adding an independent timer for
event delivery. This increases the size of the ecache extension.
Still we can revisit this later and use variable size extensions
to allocate this area on demand.
Tested-by: Oliver Smith <olipro@8.c.9.b.0.7.4.0.1.0.0.2.ip6.arpa>
Acked-by: David Miller <davem@davemloft.net>
This reverts 5ff39e971c87ea9f4c4c7b253898abafa960e32b which was commit
303a7ce92064c285a04c870f2dc0192fdb2968cb upstream.
It is not necessary for kernel versions without per-netns RPC clients.
commit 12176503366885edd542389eed3aaf94be163fdb upstream.
The compat ioctl for VIDEO_SET_SPU_PALETTE was missing an error check
while converting ioctl arguments. This could lead to leaking kernel
stack contents into userspace.
Patch extracted from existing fix in grsecurity.
Cc: Brad Spengler <spender@grsecurity.net>
Cc: PaX Team <pageexec@freemail.hu>
commit 20f1de659b77364d55d4e7fad2ef657e7730323f upstream.
Fix possible overflow of the buffer used for expanding environment
variables when building file list.
In the extremely unlikely case of an attacker having control over the
environment variables visible to gen_init_cpio, control over the
contents of the file gen_init_cpio parses, and gen_init_cpio was built
without compiler hardening, the attacker can gain arbitrary execution
control via a stack buffer overflow.
$ cat usr/crash.list
file foo ${BIG}${BIG}${BIG}${BIG}${BIG}${BIG} 0755 0 0
$ BIG=$(perl -e 'print "A" x 4096;') ./usr/gen_init_cpio usr/crash.list
*** buffer overflow detected ***: ./usr/gen_init_cpio terminated
This also replaces the space-indenting with tabs.
Patch based on existing fix extracted from grsecurity.
Cc: Michal Marek <mmarek@suse.cz>
commit fee0de7791f967c2c5f0d43eb7b7261761b45e64 upstream.
Signed-off-by: Jan Luebbe <jlu@pengutronix.de>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: Roland Stigge <stigge@antcom.de>
Cc: Grant Likely <grant.likely@secretlab.ca>
Tested-by: Roland Stigge <stigge@antcom.de>
Cc: Sascha Hauer <kernel@pengutronix.de>
commit eedce141cd2dad8d0cefc5468ef41898949a7031 upstream.
The genalloc code uses the bitmap API from include/linux/bitmap.h and
lib/bitmap.c, which is based on long values. Both bitmap_set from
lib/bitmap.c and bitmap_set_ll, which is the lockless version from
genalloc.c, use BITMAP_LAST_WORD_MASK to set the first bits in a long in
the bitmap.
That one uses (1 << bits) - 1, 0b111, if you are setting the first three
bits. This means that the API counts from the least significant bits
(LSB from now on) to the MSB. The LSB in the first long is bit 0, then.
The same works for the lookup functions.
The genalloc code uses longs for the bitmap, as it should. In
include/linux/genalloc.h, struct gen_pool_chunk has unsigned long
bits[0] as its last member. When allocating the struct, genalloc should
reserve enough space for the bitmap. This should be a proper number of
longs that can fit the amount of bits in the bitmap.
However, genalloc allocates an integer number of bytes that fit the
amount of bits, but may not be an integer amount of longs. 9 bytes, for
example, could be allocated for 70 bits.
This is a problem in itself if the Least Significat Bit in a long is in
the byte with the largest address, which happens in Big Endian machines.
This means genalloc is not allocating the byte in which it will try to
set or check for a bit.
This may end up in memory corruption, where genalloc will try to set the
bits it has not allocated. In fact, genalloc may not set these bits
because it may find them already set, because they were not zeroed since
they were not allocated. And that's what causes a BUG when
gen_pool_destroy is called and check for any set bits.
What really happens is that genalloc uses kmalloc_node with __GFP_ZERO
on gen_pool_add_virt. With SLAB and SLUB, this means the whole slab
will be cleared, not only the requested bytes. Since struct
gen_pool_chunk has a size that is a multiple of 8, and slab sizes are
multiples of 8, we get lucky and allocate and clear the right amount of
bytes.
Hower, this is not the case with SLOB or with older code that did memset
after allocating instead of using __GFP_ZERO.
So, a simple module as this (running 3.6.0), will cause a crash when
rmmod'ed.
[root@phantom-lp2 foo]# cat foo.c
#include <linux/kernel.h>
#include <linux/module.h>
#include <linux/init.h>
#include <linux/genalloc.h>
MODULE_LICENSE("GPL");
MODULE_VERSION("0.1");
static struct gen_pool *foo_pool;
static __init int foo_init(void)
int ret;
foo_pool = gen_pool_create(10, -1);
if (!foo_pool)
return -ENOMEM;
ret = gen_pool_add(foo_pool, 0xa0000000, 32 << 10, -1);
if (ret) {
gen_pool_destroy(foo_pool);
return ret;
return 0;
static __exit void foo_exit(void)
module_init(foo_init);
module_exit(foo_exit);
[root@phantom-lp2 foo]# zcat /proc/config.gz | grep SLOB
CONFIG_SLOB=y
[root@phantom-lp2 foo]# insmod ./foo.ko
[root@phantom-lp2 foo]# rmmod foo
kernel BUG at lib/genalloc.c:243!
cpu 0x4: Vector: 700 (Program Check) at [c0000000bb0e7960]
pc: c0000000003cb50c: .gen_pool_destroy+0xac/0x110
lr: c0000000003cb4fc: .gen_pool_destroy+0x9c/0x110
sp: c0000000bb0e7be0
msr: 8000000000029032
current = 0xc0000000bb0e0000
paca = 0xc000000006d30e00 softe: 0 irq_happened: 0x01
pid = 13044, comm = rmmod
[c0000000bb0e7ca0] d000000004b00020 .foo_exit+0x20/0x38 [foo]
[c0000000bb0e7d20] c0000000000dff98 .SyS_delete_module+0x1a8/0x290
[c0000000bb0e7e30] c0000000000097d4 syscall_exit+0x0/0x94
--- Exception: c00 (System Call) at 000000800753d1a0
SP (fffd0b0e640) is in userspace
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@linux.vnet.ibm.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Benjamin Gaignard <benjamin.gaignard@stericsson.com>
commit ef5d437f71afdf4afdbab99213add99f4b1318fd upstream.
On s390 any write to a page (even from kernel itself) sets architecture
specific page dirty bit. Thus when a page is written to via buffered
write, HW dirty bit gets set and when we later map and unmap the page,
page_remove_rmap() finds the dirty bit and calls set_page_dirty().
Dirtying of a page which shouldn't be dirty can cause all sorts of
problems to filesystems. The bug we observed in practice is that
buffers from the page get freed, so when the page gets later marked as
dirty and writeback writes it, XFS crashes due to an assertion
BUG_ON(!PagePrivate(page)) in page_buffers() called from
xfs_count_page_state().
Similar problem can also happen when zero_user_segment() call from
xfs_vm_writepage() (or block_write_full_page() for that matter) set the
hardware dirty bit during writeback, later buffers get freed, and then
page unmapped.
Fix the issue by ignoring s390 HW dirty bit for page cache pages of
mappings with mapping_cap_account_dirty(). This is safe because for
such mappings when a page gets marked as writeable in PTE it is also
marked dirty in do_wp_page() or do_page_fault(). When the dirty bit is
cleared by clear_page_dirty_for_io(), the page gets writeprotected in
page_mkclean(). So pagecache page is writeable if and only if it is
dirty.
Thanks to Hugh Dickins for pointing out mapping has to have
mapping_cap_account_dirty() for things to work and proposing a cleaned
up variant of the patch.
The patch has survived about two hours of running fsx-linux on tmpfs
while heavily swapping and several days of running on out build machines
where the original problem was triggered.
[bwh: Backported to 3.2: adjust context; in particular there is no local
'anon' in page_remove_rmap()]
commit b40a79591ca918e7b91b0d9b6abd5d00f2e88c19 upstream.
flush_old_exec() clears PF_KTHREAD but forgets about PF_NOFREEZE.
Acked-by: Tejun Heo <tj@kernel.org>
[bwh: Backported to 3.2: PF_FORKNOEXEC is cleared elsewhere]
commit 43a09f7fb01fa1e091416a2aa49b6c666458c1ee upstream.
The command cancellation code doesn't check whether find_trb_seg()
couldn't find the segment that contains the TRB to be canceled. This
could cause a NULL pointer deference later in the function when next_trb
is called. It's unlikely to happen unless something is wrong with the
command ring pointers, so add some debugging in case it happens.
This patch should be backported to stable kernels as old as 3.0, that
contain the commit b63f4053cc8aa22a98e3f9a97845afe6c15d0a0d "xHCI:
handle command after aborting the command ring".
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
commit 8daf8b6086f9d575200cd0aa3797e26137255609 upstream.
Board name changed on another shipping Lucid tablet.
Signed-off-by: Anisse Astier <anisse@astier.eu>
commit c323dc023b9501e5d09582ec7efd1d40a9001d99 upstream.
BIOS vendors keep changing the BIOS versions. Only match the beginning
of the string to match all Lucid tablets with board name M11JB.
commit e681b66f2e19fadbe8a7e2a17900978cb6bc921f upstream.
Remove private zombie flag used to signal disconnect and to prevent
control urb from being submitted from interrupt urb completion handler.
The control urb will not be re-submitted as both the control urb and the
interrupt urb is killed on disconnect.
Signed-off-by: Johan Hovold <jhovold@gmail.com>
commit 28c3ae9a8cf45f439c9a0779ebd0256e2ae72813 upstream.
The private int_urb is never allocated so the submission from the
control completion handler will always fail. Remove this odd piece of
broken code.
[bwh: Backported to 3.2: adjust context]
commit 3eb55cc4ed88eee3b5230f66abcdbd2a91639eda upstream.
The driver set the usb-serial port pointers to NULL on errors in attach,
effectively preventing usb-serial core from decrementing the port ref
counters and releasing the port devices and associated data.
commit 65a4cdbb170e4ec1a7fa0e94936d47e24a17b0e8 upstream.
Make sure control urb is freed at release.
commit 084817d79399ab5ccab2f90a148b0369912a8369 upstream.
Move interface data allocation to attach so that it is deallocated on
errors in usb-serial probe.
commit 7e41f9bcdd2e813ea2a3c40db291d87ea06b559f upstream.
Make sure port private data is deallocated on errors in attach.
commit 5260e458f5eff269a43e4f1e9c47186c57b88ddb upstream.
Make sure generic close is called at close.
The driver relies on the generic write implementation but did not call
generic close.
Note that the call to kill the read urb is not redundant, as mct_u232
uses an interrupt urb from the second port as the read urb and that
generic close therefore fails to kill it.
Compile-only tested.
commit acbf0e5263de563e25f7c104868e4490b9e72b13 upstream.
Fix memory leak in write error path.
commit ea0dbebffe118724cd4df7d9b071ea8ee48d48f0 upstream.
Make sure to allocate the control-message buffer dynamically as some
platforms cannot do DMA from stack.
Note that only the first byte of the old buffer was used.
commit c129197c99550d356cf5f69b046994dd53cd1b9d upstream.
Make sure command buffer is deallocated in case of errors during attach.
Cc: <support@connecttech.com>
commit 910a578f7e9400a78a3b13aba0b4d2df16a2cb05 upstream.
We copy head count to a 16 bit field, this works by chance on LE but on
BE guest gets 0. Fix it up.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Tested-by: Alexander Graf <agraf@suse.de>
commit 66081a72517a131430dcf986775f3268aafcb546 upstream.
The warning check for duplicate sysfs entries can cause a buffer overflow
when printing the warning, as strcat() doesn't check buffer sizes.
Use strlcat() instead.
Since strlcat() doesn't return a pointer to the passed buffer, unlike
strcat(), I had to convert the nested concatenation in sysfs_add_one() to
an admittedly more obscure comma operator construct, to avoid emitting code
for the concatenation if CONFIG_BUG is disabled.
commit 1392550240aaa72ce3a094a38bd23525cd67ce60 upstream.
Fix a memory leak in the error handling path in the function vmbus_open().
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com>
Reported-by: Jason Wang <jasowang@redhat.com>
Acked-by: Jason Wang <jasowang@redhat.com>
commit d7870af7e2e3a91b462075ec1ca669b482215187 upstream.
This commit sets removable subclass for Casio EX-N1 digital camera.
The patch has been tested within an ALT Linux kernel:
http://git.altlinux.org/people/led/packages/?p=kernel-image-3.0.git;a=commitdiff;h=c0fd891836e89fe0c93a4d536a59216d90e4e3e7
See also https://bugzilla.kernel.org/show_bug.cgi?id=49221
Signed-off-by: Oleksandr Chumachenko <ledest@gmail.com>
Signed-off-by: Michael Shigorin <mike@osdn.org.ua>
commit f7bc5051667b74c3861f79eed98c60d5c3b883f7 upstream.
I found a memory leak in sierra_release() (well sierra_probe() I guess)
that looses 8 bytes each time the driver releases a device.
Signed-off-by: Len Sorensen <lsorense@csclub.uwaterloo.ca>
Acked-by: Johan Hovold <jhovold@gmail.com>
commit 73b26df5fa1a6245d6fc982362518b620bc7c2fe upstream.
This reverts commit a240dc7b3c7463bd60cf0a9b2a90f52f78aae0fd.
This commit is reducing tx power by at least 10 db on some devices,
e.g. the Buffalo WZR-HP-G450H.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Cc: rmanohar@qca.qualcomm.com
commit f878b657ce8e7d3673afe48110ec208a29e38c4a upstream.
Chris Perl reports that we're seeing races between the wakeup call in
xs_error_report and the connect attempts. Basically, Chris has shown
that in certain circumstances, the call to xs_error_report causes the
rpc_task that is responsible for reconnecting to wake up early, thus
triggering a disconnect and retry.
Since the sk->sk_error_report() calls in the socket layer are always
followed by a tcp_done() in the cases where we care about waking up
the rpc_tasks, just let the state_change callbacks take responsibility
for those wake ups.
Reported-by: Chris Perl <chris.perl@gmail.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Tested-by: Chris Perl <chris.perl@gmail.com>
commit 4bc1e68ed6a8b59be8a79eb719be515a55c7bc68 upstream.
The call to xprt_disconnect_done() that is triggered by a successful
connection reset will trigger another automatic wakeup of all tasks
on the xprt->pending rpc_wait_queue. In particular it will cause an
early wake up of the task that called xprt_connect().
All we really want to do here is clear all the socket-specific state
flags, so we split that functionality out of xs_sock_mark_closed()
into a helper that can be called by xs_abort_connection()
commit b9d2bb2ee537424a7f855e1f93eed44eb9ee0854 upstream.
This reverts commit 55420c24a0d4d1fce70ca713f84aa00b6b74a70e.
Now that we clear the connected flag when entering TCP_CLOSE_WAIT,
the deadlock described in this commit is no longer possible.
Instead, the resulting call to xs_tcp_shutdown() can interfere
with pending reconnection attempts.
commit d0bea455dd48da1ecbd04fedf00eb89437455fdc upstream.
This is needed to ensure that we call xprt_connect() upon the next
call to call_connect().
commit 168bfeef7bba3f9784f7540b053e4ac72b769ce9 upstream.
If none of the elements in scrubrates[] matches, this loop will cause
__amd64_set_scrub_rate() to incorrectly use the n+1th element.
As the function is designed to use the final scrubrates[] element in the
case of no match, we can fix this bug by simply terminating the array
search at the n-1th element.
Boris: this code is fragile anyway, see here why:
http://marc.info/?l=linux-kernel&m=135102834131236&w=2
It will be rewritten more robustly soonish.
Reported-by: Denis Kirjanov <kirjanov@gmail.com>
Cc: Doug Thompson <dougthompson@xmission.com>
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
commit 627072b06c362bbe7dc256f618aaa63351f0cfe6 upstream.
The tile tool chain uses the .eh_frame information for backtracing.
The vmlinux build drops any .eh_frame sections at link time, but when
present in kernel modules, it causes a module load failure due to the
presence of unsupported pc-relative relocations. When compiling to
use compiler feedback support, the compiler by default omits .eh_frame
information, so we don't see this problem. But when not using feedback,
we need to explicitly suppress the .eh_frame.
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
commit e4df1cbcc1f329e53a1fff7450b2229e0addff20 upstream.
Commit 6889125b8b4e09c5e53e6ecab3433bed1ce198c9
(cpufreq/powernow-k8: workqueue user shouldn't migrate the kworker to another CPU)
causes powernow-k8 to trigger a preempt warning, e.g.:
BUG: using smp_processor_id() in preemptible [00000000] code: cpufreq/3776
caller is powernowk8_target+0x20/0x49
Pid: 3776, comm: cpufreq Not tainted 3.6.0 #9
Call Trace:
[<ffffffff8125b447>] debug_smp_processor_id+0xc7/0xe0
[<ffffffff814877e7>] powernowk8_target+0x20/0x49
[<ffffffff81482b02>] __cpufreq_driver_target+0x82/0x8a
[<ffffffff81484fc6>] cpufreq_governor_performance+0x4e/0x54
[<ffffffff81482c50>] __cpufreq_governor+0x8c/0xc9
[<ffffffff81482e6f>] __cpufreq_set_policy+0x1a9/0x21e
[<ffffffff814839af>] store_scaling_governor+0x16f/0x19b
[<ffffffff81484f16>] ? cpufreq_update_policy+0x124/0x124
[<ffffffff8162b4a5>] ? _raw_spin_unlock_irqrestore+0x2c/0x49
[<ffffffff81483640>] store+0x60/0x88
[<ffffffff811708c0>] sysfs_write_file+0xf4/0x130
[<ffffffff8111243b>] vfs_write+0xb5/0x151
[<ffffffff811126e0>] sys_write+0x4a/0x71
[<ffffffff816319a9>] system_call_fastpath+0x16/0x1b
Fix this by by always using work_on_cpu().
Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com>
commit 3b6054da68f9b0d5ed6a7ed0f42a79e61904352c upstream.
There is a race condition in the USB hub code with regard to handling
TT clear requests that can get the HCD driver in a deadlock. Usually
when an TT clear request is scheduled it will be executed immediately:
<7>[ 6.077583] usb 2-1.3: unlink qh1-0e01/f4d4db00 start 0 [1/2 us]
<3>[ 6.078041] usb 2-1: clear tt buffer port 3, a3 ep2 t04048d82
<7>[ 6.078299] hub_tt_work:731
<7>[ 9.309089] usb 2-1.5: link qh1-0e01/f4d506c0 start 0 [1/2 us]
<7>[ 9.324526] ehci_hcd 0000:00:1d.0: reused qh f4d4db00 schedule
<7>[ 9.324539] usb 2-1.3: link qh1-0e01/f4d4db00 start 0 [1/2 us]
<7>[ 9.341530] usb 1-1.1: link qh4-0e01/f397aec0 start 2 [1/2 us]
<7>[ 10.116159] usb 2-1.3: unlink qh1-0e01/f4d4db00 start 0 [1/2 us]
<3>[ 10.116459] usb 2-1: clear tt buffer port 3, a3 ep2 t04048d82
<7>[ 10.116537] hub_tt_work:731
However, if a suspend operation is triggered before hub_tt_work is
scheduled, hub_quiesce will cancel the work without notifying the HCD
driver:
<3>[ 35.033941] usb 2-1: clear tt buffer port 3, a3 ep2 t04048d80
<5>[ 35.034022] sd 0:0:0:0: [sda] Stopping disk
<7>[ 35.034039] hub 2-1:1.0: hub_suspend
<7>[ 35.034067] usb 2-1: unlink qh256-0001/f3b1ab00 start 1 [1/0 us]
<7>[ 35.035085] hub 1-0:1.0: hub_suspend
<7>[ 35.035102] usb usb1: bus suspend, wakeup 0
<7>[ 35.035106] ehci_hcd 0000:00:1a.0: suspend root hub
<7>[ 35.035298] hub 2-0:1.0: hub_suspend
<7>[ 35.035313] usb usb2: bus suspend, wakeup 0
<7>[ 35.035315] ehci_hcd 0000:00:1d.0: suspend root hub
<6>[ 35.250017] PM: suspend of devices complete after 216.979 msecs
<6>[ 35.250822] PM: late suspend of devices complete after 0.799 msecs
<7>[ 35.252343] ehci_hcd 0000:00:1d.0: wakeup: 1
<7>[ 35.262923] ehci_hcd 0000:00:1d.0: --> PCI D3hot
<7>[ 35.263302] ehci_hcd 0000:00:1a.0: wakeup: 1
<7>[ 35.273912] ehci_hcd 0000:00:1a.0: --> PCI D3hot
<6>[ 35.274254] PM: noirq suspend of devices complete after 23.442 msecs
<6>[ 35.274975] ACPI: Preparing to enter system sleep state S3
<6>[ 35.292666] PM: Saving platform NVS memory
<7>[ 35.295030] Disabling non-boot CPUs ...
<6>[ 35.297351] CPU 1 is now offline
<6>[ 35.300345] CPU 2 is now offline
<6>[ 35.303929] CPU 3 is now offline
<7>[ 35.303931] lockdep: fixing up alternatives.
<6>[ 35.304825] Extended CMOS year: 2000
When the device will resume the EHCI driver will get stuck in
ehci_endpoint_disable waiting for the tt_clearing flag to reset:
<0>[ 47.610967] usb 2-1.3: **** DPM device timeout ****
<7>[ 47.610972] f2f11c60 00000092 f2f11c0c c10624a5 00000003 f4c6e880 c1c8a4c0 c1c8a4c0
<7>[ 47.610983] 15c55698 0000000b f56b34c0 f2a45b70 f4c6e880 00000082 f2a4602c f2f11c30
<7>[ 47.610993] c10787f8 f4cac000 f2a45b70 00000000 f4cac010 f2f11c58 00000046 00000001
<7>[ 47.611004] Call Trace:
<7>[ 47.611006] [<c10624a5>] ? sched_clock_cpu+0xf5/0x160
<7>[ 47.611019] [<c10787f8>] ? lock_release_holdtime.part.22+0x88/0xf0
<7>[ 47.611026] [<c103ed46>] ? lock_timer_base.isra.35+0x26/0x50
<7>[ 47.611034] [<c17592d3>] ? schedule_timeout+0x133/0x290
<7>[ 47.611044] [<c175b43e>] schedule+0x1e/0x50
<7>[ 47.611051] [<c17592d8>] schedule_timeout+0x138/0x290
<7>[ 47.611057] [<c10624a5>] ? sched_clock_cpu+0xf5/0x160
<7>[ 47.611063] [<c103e560>] ? usleep_range+0x40/0x40
<7>[ 47.611070] [<c1759445>] schedule_timeout_uninterruptible+0x15/0x20
<7>[ 47.611077] [<c14935f4>] ehci_endpoint_disable+0x64/0x160
<7>[ 47.611084] [<c147d1ee>] ? usb_hcd_flush_endpoint+0x10e/0x1d0
<7>[ 47.611092] [<c1165663>] ? sysfs_add_file+0x13/0x20
<7>[ 47.611100] [<c147d5a9>] usb_hcd_disable_endpoint+0x29/0x40
<7>[ 47.611107] [<c147fafc>] usb_disable_endpoint+0x5c/0x80
<7>[ 47.611111] [<c147fb57>] usb_disable_interface+0x37/0x50
<7>[ 47.611116] [<c1477650>] usb_reset_and_verify_device+0x4b0/0x640
<7>[ 47.611122] [<c1474665>] ? hub_port_status+0xb5/0x100
<7>[ 47.611129] [<c147a975>] usb_port_resume+0xd5/0x220
<7>[ 47.611136] [<c148877f>] generic_resume+0xf/0x30
<7>[ 47.611142] [<c14821a3>] usb_resume+0x133/0x180
<7>[ 47.611147] [<c1473b10>] ? usb_dev_thaw+0x10/0x10
<7>[ 47.611152] [<c1473b1d>] usb_dev_resume+0xd/0x10
<7>[ 47.611157] [<c13baa60>] dpm_run_callback+0x40/0xb0
<7>[ 47.611164] [<c13bdb03>] ? pm_runtime_enable+0x43/0x70
<7>[ 47.611171] [<c13bafc6>] device_resume+0x1a6/0x2c0
<7>[ 47.611177] [<c13ba940>] ? dpm_show_time+0xe0/0xe0
<7>[ 47.611183] [<c13bb0f9>] async_resume+0x19/0x40
<7>[ 47.611189] [<c10580c4>] async_run_entry_fn+0x64/0x160
<7>[ 47.611196] [<c104a244>] ? process_one_work+0x104/0x480
<7>[ 47.611203] [<c104a24c>] ? process_one_work+0x10c/0x480
<7>[ 47.611209] [<c104a2c0>] process_one_work+0x180/0x480
<7>[ 47.611215] [<c104a244>] ? process_one_work+0x104/0x480
<7>[ 47.611220] [<c1058060>] ? async_schedule+0x10/0x10
<7>[ 47.611226] [<c104c15c>] worker_thread+0x11c/0x2f0
<7>[ 47.611233] [<c104c040>] ? manage_workers.isra.27+0x1f0/0x1f0
<7>[ 47.611239] [<c10507f8>] kthread+0x78/0x80
<7>[ 47.611244] [<c1750000>] ? timer_cpu_notify+0xd6/0x20d
<7>[ 47.611253] [<c1050780>] ? __init_kthread_worker+0x60/0x60
<7>[ 47.611258] [<c176357e>] kernel_thread_helper+0x6/0xd
<7>[ 47.611283] ------------[ cut here ]------------
This patch changes hub_quiesce behavior to flush the TT clear work
instead of canceling it, to make sure that no TT clear request remains
uncompleted before suspend.
Signed-off-by: Octavian Purdila <octavian.purdila@intel.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 5f40b909728ad784eb43aa309d3c4e9bdf050781 upstream.
When booting a secondary CPU, the primary CPU hands two sets of page
tables via the secondary_data struct:
(1) swapper_pg_dir: a normal, cacheable, shared (if SMP) mapping
of the kernel image (i.e. the tables used by init_mm).
(2) idmap_pgd: an uncached mapping of the .idmap.text ELF
section.
The idmap is generally used when enabling and disabling the MMU, which
includes early CPU boot. In this case, the secondary CPU switches to
swapper as soon as it enters C code:
struct mm_struct *mm = &init_mm;
unsigned int cpu = smp_processor_id();
* All kernel threads share the same mm context; grab a
* reference and switch to it.
atomic_inc(&mm->mm_count);
current->active_mm = mm;
cpumask_set_cpu(cpu, mm_cpumask(mm));
cpu_switch_mm(mm->pgd, mm);
This causes a problem on ARMv7, where the identity mapping is treated as
strongly-ordered leading to architecturally UNPREDICTABLE behaviour of
exclusive accesses, such as those used by atomic_inc.
This patch re-orders the secondary_start_kernel function so that we
switch to swapper before performing any exclusive accesses.
Cc: David McKay <david.mckay@st.com>
Reported-by: Gilles Chanteperdrix <gilles.chanteperdrix@xenomai.org>
commit 2702b1526c7278c4d65d78de209a465d4de2885e upstream.
Calling uname() with the UNAME26 personality set allows a leak of kernel
stack contents. This fixes it by defensively calculating the length of
copy_to_user() call, making the len argument unsigned, and initializing
the stack buffer to zero (now technically unneeded, but hey, overkill).
CVE-2012-0957
Reported-by: PaX Team <pageexec@freemail.hu>
commit 84f98fdf7865fbd35b312eb39ea91e5618c514c7 upstream.
I have a Lenovo ThinkPad T430 and an UltraBase Series 3 docking
station.
Without this patch, if I plug my headphones into the jack on the
computer, everything works fine. The computer speakers mute and the
audio is played in the headphones. However, if I plug into the docking
station headphone jack the computer speakers are muted but there is no
audio in the headphones.
Addresses https://bugs.launchpad.net/bugs/1060372
Signed-off-by: Joseph Salisbury <joseph.salisbury@canonical.com>
commit a349e23d1cf746f8bdc603dcc61fae9ee4a695f6 upstream.
In 32 bit guests, if a userspace process has %eax == -ERESTARTSYS
(-512) or -ERESTARTNOINTR (-513) when it is interrupted by an event
/and/ the process has a pending signal then %eip (and %eax) are
corrupted when returning to the main process after handling the
signal. The application may then crash with SIGSEGV or a SIGILL or it
may have subtly incorrect behaviour (depending on what instruction it
returned to).
The occurs because handle_signal() is incorrectly thinking that there
is a system call that needs to restarted so it adjusts %eip and %eax
to re-execute the system call instruction (even though user space had
not done a system call).
If %eax == -514 (-ERESTARTNOHAND (-514) or -ERESTART_RESTARTBLOCK
(-516) then handle_signal() only corrupted %eax (by setting it to
-EINTR). This may cause the application to crash or have incorrect
behaviour.
handle_signal() assumes that regs->orig_ax >= 0 means a system call so
any kernel entry point that is not for a system call must push a
negative value for orig_ax. For example, for physical interrupts on
bare metal the inverse of the vector is pushed and page_fault() sets
regs->orig_ax to -1, overwriting the hardware provided error code.
xen_hypervisor_callback() was incorrectly pushing 0 for orig_ax
instead of -1.
Classic Xen kernels pushed %eax which works as %eax cannot be both
non-negative and -RESTARTSYS (etc.), but using -1 is consistent with
other non-system call entry points and avoids some of the tests in
handle_signal().
There were similar bugs in xen_failsafe_callback() of both 32 and
64-bit guests. If the fault was corrected and the normal return path
was used then 0 was incorrectly pushed as the value for orig_ax.
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Acked-by: Jan Beulich <JBeulich@suse.com>
Acked-by: Ian Campbell <ian.campbell@citrix.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit c985cb37f1b39c2c8035af741a2a0b79f1fbaca7 upstream.
Because of a change in the s390 arch backend of binutils (commit 23ecd77
"Pick the default arch depending on the target size" in binutils repo)
31 bit builds will fail since the linker would now try to create 64 bit
binary output.
Fix this by setting OUTPUT_ARCH to s390:31-bit instead of s390.
Thanks to Andreas Krebbel for figuring out the issue.
Fixes this build error:
LD init/built-in.o
s390x-4.7.2-ld: s390:31-bit architecture of input file
`arch/s390/kernel/head.o' is incompatible with s390:64-bit output
Cc: Andreas Krebbel <Andreas.Krebbel@de.ibm.com>
commit 4b35f1c52943851b310afb09047bfe991ac8f5ae upstream.
Signed-off-by: Bjørn Mork <bjorn@mork.no>
commit 1452df6f1b7e396d89c2a1fdbdc0e0e839f97671 upstream.
Based on information from the ZTE Windows drivers.
commit 470809741a28c3092279f4e1f3f432e534d46068 upstream.
This minor change adds a new system to which the "Fix Compliance Mode
on SN65LVPE502CP Hardware" patch has to be applied also.
System added:
Vendor: Hewlett-Packard. System Model: Z1
Signed-off-by: Alexis R. Cortes <alexis.cortes@ti.com>
Acked-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
commit 301a29da6e891e7eb95c843af0ecdbe86d01f723 upstream.
The current code assumes that CSIZE is 0000060, which appears to be
wrong on some arches (such as powerpc).
Signed-off-by: Nicolas Boullis <nboullis@debian.org>
Acked-by: Oliver Neukum <oneukum@suse.de>
commit c5211187f7ff8e8dbff4ebf7c011ac4c0ffe319c upstream.
If the write endpoint is interrupt type, usb_sndintpipe() should
be passed to usb_fill_int_urb() instead of usb_sndbulkpipe().
Cc: Oliver Neukum <oneukum@suse.de>
Signed-off-by: Ming Lei <ming.lei@canonical.com>
