2012-04-13Linux 3.2.15v3.2.15Greg Kroah-Hartman
2012-04-13Bluetooth: Fix l2cap conn failures for ssp devicesPeter Hurley
commit 18daf1644e634bae951a6e3d4d19d89170209762 upstream Commit 330605423c fixed l2cap conn establishment for non-ssp remote devices by not setting HCI_CONN_ENCRYPT_PEND every time conn security is tested (which was always returning failure on any subsequent security checks). However, this broke l2cap conn establishment for ssp remote devices when an ACL link was already established at SDP-level security. This fix ensures that encryption must be pending whenever authentication is also pending. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Tested-by: Daniel Wagner <daniel.wagner@bmw-carit.de> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
2012-04-13iommu/amd: Make sure IOMMU interrupts are re-enabled on resumeJoerg Roedel
commit 9ddd592a191b32f2ee6c4b6ed2bd52665c3a49f5 upstream Unfortunatly the interrupts for the event log and the peripheral page-faults are only enabled at boot but not re-enabled at resume. Fix that for 3.2. Cc: stable@vger.kernel.org Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2012-04-13cred: copy_process() should clear child->replacement_session_keyringOleg Nesterov
commit 79549c6dfda0603dba9a70a53467ce62d9335c33 upstream. keyctl_session_to_parent(task) sets ->replacement_session_keyring, it should be processed and cleared by key_replace_session_keyring(). However, this task can fork before it notices TIF_NOTIFY_RESUME and the new child gets the bogus ->replacement_session_keyring copied by dup_task_struct(). This is obviously wrong and, if nothing else, this leads to put_cred(already_freed_cred). change copy_creds() to clear this member. If copy_process() fails before this point the wrong ->replacement_session_keyring doesn't matter, exit_creds() won't be called. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13ASoC: ak4642: fixup: mute needs +1 stepKuninori Morimoto
commit 1f99e44cf059d2ed43c5a0724fa738b83800f725 upstream. ak4642 out_tlv is +12.0dB to -115.0 dB, and it supports mute. But current settings didn't care +1 step for mute. This patch adds it Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13ioat: fix size of 'completion' for XenDan Williams
commit 275029353953c2117941ade84f02a2303912fad1 upstream. Starting with v3.2 Jonathan reports that Xen crashes loading the ioatdma driver. A debug run shows: ioatdma 0000:00:16.4: desc[0]: (0x300cc7000->0x300cc7040) cookie: 0 flags: 0x2 ctl: 0x29 (op: 0 int_en: 1 compl: 1) ... ioatdma 0000:00:16.4: ioat_get_current_completion: phys_complete: 0xcc7000 ...which shows that in this environment GFP_KERNEL memory may be backed by a 64-bit dma address. This breaks the driver's assumption that an unsigned long should be able to contain the physical address for descriptor memory. Switch to dma_addr_t which beyond being the right size, is the true type for the data i.e. an io-virtual address inidicating the engine's last processed descriptor. Reported-by: Jonathan Nieder <jrnieder@gmail.com> Reported-by: William Dauchy <wdauchy@gmail.com> Tested-by: William Dauchy <wdauchy@gmail.com> Tested-by: Dave Jiang <dave.jiang@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13USB: Add Motorola Rokr E6 Id to the USBNet driver "zaurus"Guan Xin
commit a2daf263107ba3eb6db33931881731fa51c95045 upstream. Added Vendor/Device Id of Motorola Rokr E6 (22b8:6027) so it can be recognized by the "zaurus" USBNet driver. Applies to Linux 3.2.13 and 2.6.39.4. Signed-off-by: Guan Xin <guanx.bac@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13mfd: Clear twl6030 IRQ status register only onceNishanth Menon
commit 3f8349e6e98ba0455437724589072523865eae5e upstream. TWL6030 family of PMIC use a shadow interrupt status register while kernel processes the current interrupt event. However, any write(0 or 1) to register INT_STS_A, INT_STS_B or INT_STS_C clears all 3 interrupt status registers. Since clear of the interrupt is done on 32k clk, depending on I2C bus speed, we could in-adverently clear the status of a interrupt status pending on shadow register in the current implementation. This is due to the fact that multi-byte i2c write operation into three seperate status register could result in multiple load and clear of status and result in lost interrupts. Instead, doing a single byte write to INT_STS_A register with 0x0 will clear all three interrupt status registers without the related risk. Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13sched/x86: Fix overflow in cyc2ns_offsetSalman Qazi
commit 9993bc635d01a6ee7f6b833b4ee65ce7c06350b1 upstream. When a machine boots up, the TSC generally gets reset. However, when kexec is used to boot into a kernel, the TSC value would be carried over from the previous kernel. The computation of cycns_offset in set_cyc2ns_scale is prone to an overflow, if the machine has been up more than 208 days prior to the kexec. The overflow happens when we multiply *scale, even though there is enough room to store the final answer. We fix this issue by decomposing tsc_now into the quotient and remainder of division by CYC2NS_SCALE_FACTOR and then performing the multiplication separately on the two components. Refactor code to share the calculation with the previous fix in __cycles_2_ns(). Signed-off-by: Salman Qazi <sqazi@google.com> Acked-by: John Stultz <john.stultz@linaro.org> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Turner <pjt@google.com> Cc: john stultz <johnstul@us.ibm.com> Link: http://lkml.kernel.org/r/20120310004027.19291.88460.stgit@dungbeetle.mtv.corp.google.com Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13Fix length of buffer copied in __nfs4_get_acl_uncachedSachin Prabhu
commit 20e0fa98b751facf9a1101edaefbc19c82616a68 upstream. _copy_from_pages() used to copy data from the temporary buffer to the user passed buffer is passed the wrong size parameter when copying data. res.acl_len contains both the bitmap and acl lenghts while acl_len contains the acl length after adjusting for the bitmap size. Signed-off-by: Sachin Prabhu <sprabhu@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Josh Boyer <jwboyer@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13acer-wmi: No wifi rfkill on Sony machinesLee, Chun-Yi
commit 5719b81988f3c24ff694dc3a37e35b35630a3966 upstream. The wireless rfkill should charged by sony-laptop but not acer-wmi. So, add Sony's SNY5001 acpi device to blacklist in acer-wmi. Tested on Sony Vaio Cc: Carlos Corbacho <carlos@strangeworlds.co.uk> Cc: Matthew Garrett <mjg@redhat.com> Cc: Mattia Dongili <malattia@linux.it> Cc: Dimitris N <ddarlac@gmail.com> Tested-by: Dimitris N <ddarlac@gmail.com> Signed-off-by: Lee, Chun-Yi <jlee@suse.com> Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13Revert "x86/ioapic: Add register level checks to detect bogus io-apic entries"Greg Kroah-Hartman
This reverts commit 273fb194e86b795b08a724c7646d0f694949070b [73d63d038ee9f769f5e5b46792d227fe20e442c5 upstream] It causes problems, so needs to be reverted from 3.2-stable for now. Reported-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Jon Dufresne <jon@jondufresne.org> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: <yinghai@kernel.org> Cc: Josh Boyer <jwboyer@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Teck Choon Giam <giamteckchoon@gmail.com> Cc: Ben Guthro <ben@guthro.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13TOMOYO: Fix mount flags checking order.Tetsuo Handa
commit df91e49477a9be15921cb2854e1d12a3bdb5e425 upstream. Userspace can pass in arbitrary combinations of MS_* flags to mount(). If both MS_BIND and one of MS_SHARED/MS_PRIVATE/MS_SLAVE/MS_UNBINDABLE are passed, device name which should be checked for MS_BIND was not checked because MS_SHARED/MS_PRIVATE/MS_SLAVE/MS_UNBINDABLE had higher priority than MS_BIND. If both one of MS_BIND/MS_MOVE and MS_REMOUNT are passed, device name which should not be checked for MS_REMOUNT was checked because MS_BIND/MS_MOVE had higher priority than MS_REMOUNT. Fix these bugs by changing priority to MS_REMOUNT -> MS_BIND -> MS_SHARED/MS_PRIVATE/MS_SLAVE/MS_UNBINDABLE -> MS_MOVE as with do_mount() does. Also, unconditionally return -EINVAL if more than one of MS_SHARED/MS_PRIVATE/MS_SLAVE/MS_UNBINDABLE is passed so that TOMOYO will not generate inaccurate audit logs, for commit 7a2e8a8f "VFS: Sanity check mount flags passed to change_mnt_propagation()" clarified that these flags must be exclusively passed. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13x86/PCI: do not tie MSI MS-7253 use_crs quirk to BIOS versionJonathan Nieder
commit a97f4f5e524bcd09a85ef0b8821a14d35e69335f upstream. Carlos was getting WARNING: at drivers/pci/pci.c:118 pci_ioremap_bar+0x24/0x52() when probing his sound card, and sound did not work. After adding pci=use_crs to the kernel command line, no more trouble. Ok, we can add a quirk. dmidecode output reveals that this is an MSI MS-7253, for which we already have a quirk, but the short-sighted author tied the quirk to a single BIOS version, making it not kick in on Carlos's machine with BIOS V1.2. If a later BIOS update makes it no longer necessary to look at the _CRS info it will still be harmless, so let's stop trying to guess which versions have and don't have accurate _CRS tables. Addresses https://bugtrack.alsa-project.org/alsa-bug/view.php?id=5533 Also see <https://bugzilla.kernel.org/show_bug.cgi?id=42619>. Reported-by: Carlos Luna <caralu74@gmail.com> Reviewed-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Jonathan Nieder <jrnieder@gmail.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13x86/PCI: use host bridge _CRS info on MSI MS-7253Jonathan Nieder
commit 8411371709610c826bf65684f886bfdfb5780ca1 upstream. In the spirit of commit 29cf7a30f8a0 ("x86/PCI: use host bridge _CRS info on ASUS M2V-MX SE"), this DMI quirk turns on "pci_use_crs" by default on a board that needs it. This fixes boot failures and oopses introduced in 3e3da00c01d0 ("x86/pci: AMD one chain system to use pci read out res"). The quirk is quite targetted (to a specific board and BIOS version) for two reasons: (1) to emphasize that this method of tackling the problem one quirk at a time is a little insane (2) to give BIOS vendors an opportunity to use simpler tables and allow us to return to generic behavior (whatever that happens to be) with a later BIOS update In other words, I am not at all happy with having quirks like this. But it is even worse for the kernel not to work out of the box on these machines, so... Reference: https://bugzilla.kernel.org/show_bug.cgi?id=42619 Reported-by: Svante Signell <svante.signell@telia.com> Signed-off-by: Jonathan Nieder <jrnieder@gmail.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13modpost: Fix modpost license checking of vmlinux.oFrank Rowand
commit 258f742635360175564e9470eb060ff4d4b984e7 upstream. Commit f02e8a6596b7 ("module: Sort exported symbols") sorts symbols placing each of them in its own elf section. This sorting and merging into the canonical sections are done by the linker. Unfortunately modpost to generate Module.symvers file parses vmlinux.o (which is not linked yet) and all modules object files (which aren't linked yet). These aren't sanitized by the linker yet. That breaks modpost that can't detect license properly for modules. This patch makes modpost aware of the new exported symbols structure. [ This above is a slightly corrected version of the explanation of the problem, copied from commit 62a2635610db ("modpost: Fix modpost's license checking V3"). That commit fixed the problem for module object files, but not for vmlinux.o. This patch fixes modpost for vmlinux.o. ] Signed-off-by: Frank Rowand <frank.rowand@am.sony.com> Signed-off-by: Alessio Igor Bogani <abogani@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13sysctl: fix write access to dmesg_restrict/kptr_restrictKees Cook
commit 620f6e8e855d6d447688a5f67a4e176944a084e8 upstream. Commit bfdc0b4 adds code to restrict access to dmesg_restrict, however, it incorrectly alters kptr_restrict rather than dmesg_restrict. The original patch from Richard Weinberger (https://lkml.org/lkml/2011/3/14/362) alters dmesg_restrict as expected, and so the patch seems to have been misapplied. This adds the CAP_SYS_ADMIN check to both dmesg_restrict and kptr_restrict, since both are sensitive. Reported-by: Phillip Lougher <plougher@redhat.com> Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Acked-by: Richard Weinberger <richard@nod.at> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13tcm_fc: Do not free tpg structure during wq allocation failureMark Rustad
commit 06383f10c49f507220594a455c6491ca6f8c94ab upstream. Avoid freeing a registered tpg structure if an alloc_workqueue call fails. This fixes a bug where the failure was leaking memory associated with se_portal_group setup during the original core_tpg_register() call. Signed-off-by: Mark Rustad <mark.d.rustad@intel.com> Acked-by: Kiran Patil <Kiran.patil@intel.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13tcm_fc: Add abort flag for gracefully handling exchange timeoutMark Rustad
commit e1c4038282c7586c3544542b37872c434669d3ac upstream. Add abort flag and use it to terminate processing when an exchange is timed out or is reset. The abort flag is used in place of the transport_generic_free_cmd function call in the reset and timeout cases, because calling that function in that context would free memory that was in use. The aborted flag allows the lifetime to be managed in a more normal way, while truncating the processing. This change eliminates a source of memory corruption which manifested in a variety of ugly ways. (nab: Drop unused struct fc_exch *ep in ft_recv_seq) Signed-off-by: Mark Rustad <mark.d.rustad@intel.com> Acked-by: Kiran Patil <Kiran.patil@intel.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13mmc: atmel-mci: correct data timeout computationLudovic Desroches
commit 66292ad92c6d3f2f1c137a1c826b331ca8595dfd upstream. The HSMCI operates at a rate of up to Master Clock divided by two. Moreover previous calculation can cause overflows and so wrong timeouts. Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Chris Ball <cjb@laptop.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13mmc: sdhci-dove: Fix compile error by including module.hAlf Høgemark
commit 8c2fc8e413ecc2c96b696e28d4eb1bc6cee8dc84 upstream. This patch fixes a compile error in drivers/mmc/host/sdhci-dove.c by including the linux/module.h file. Signed-off-by: Alf Høgemark <alf@i100.no> Signed-off-by: Chris Ball <cjb@laptop.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13ARM: tegra: remove Tegra30 errata from MACH_TEGRA_DTStephen Warren
[no upstream commit match, as this is a fix for a mis-applied patch in the previous 3.2-stable release. - gregkh] Commit 83e4194 "ARM: tegra: select required CPU and L2 errata options" contained two chunks; one was errata for Tegra20 (correctly applied) and the second errata for Tegra30. The latter was accidentally applied to the wrong config option; Tegra30 support wasn't added until v3.3, and so the second chunk should have just been dropped. This patch does so. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13CIFS: Fix VFS lock usage for oplocked filesPavel Shilovsky
commit 66189be74ff5f9f3fd6444315b85be210d07cef2 upstream. We can deadlock if we have a write oplock and two processes use the same file handle. In this case the first process can't unlock its lock if the second process blocked on the lock in the same time. Fix it by using posix_lock_file rather than posix_lock_file_wait under cinode->lock_mutex. If we request a blocking lock and posix_lock_file indicates that there is another lock that prevents us, wait untill that lock is released and restart our call. Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru> Signed-off-by: Steve French <sfrench@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13x86,kgdb: Fix DEBUG_RODATA limitation using text_poke()Jason Wessel
commit 3751d3e85cf693e10e2c47c03c8caa65e171099b upstream. There has long been a limitation using software breakpoints with a kernel compiled with CONFIG_DEBUG_RODATA going back to 2.6.26. For this particular patch, it will apply cleanly and has been tested all the way back to 2.6.36. The kprobes code uses the text_poke() function which accommodates writing a breakpoint into a read-only page. The x86 kgdb code can solve the problem similarly by overriding the default breakpoint set/remove routines and using text_poke() directly. The x86 kgdb code will first attempt to use the traditional probe_kernel_write(), and next try using a the text_poke() function. The break point install method is tracked such that the correct break point removal routine will get called later on. Cc: x86@kernel.org Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Inspried-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13kgdbts: (2 of 2) fix single step awareness to work correctly with SMPJason Wessel
commit 23bbd8e346f1ef3fc1219c79cea53d8d52b207d8 upstream. The do_fork and sys_open tests have never worked properly on anything other than a UP configuration with the kgdb test suite. This is because the test suite did not fully implement the behavior of a real debugger. A real debugger tracks the state of what thread it asked to single step and can correctly continue other threads of execution or conditionally stop while waiting for the original thread single step request to return. Below is a simple method to cause a fatal kernel oops with the kgdb test suite on a 2 processor ARM system: while [ 1 ] ; do ls > /dev/null 2> /dev/null; done& while [ 1 ] ; do ls > /dev/null 2> /dev/null; done& echo V1I1F100 > /sys/module/kgdbts/parameters/kgdbts Very soon after starting the test the kernel will start warning with messages like: kgdbts: BP mismatch c002487c expected c0024878 ------------[ cut here ]------------ WARNING: at drivers/misc/kgdbts.c:317 check_and_rewind_pc+0x9c/0xc4() [<c01f6520>] (check_and_rewind_pc+0x9c/0xc4) [<c01f595c>] (validate_simple_test+0x3c/0xc4) [<c01f60d4>] (run_simple_test+0x1e8/0x274) The kernel will eventually recovers, but the test suite has completely failed to test anything useful. This patch implements behavior similar to a real debugger that does not rely on hardware single stepping by using only software planted breakpoints. In order to mimic a real debugger, the kgdb test suite now tracks the most recent thread that was continued (cont_thread_id), with the intent to single step just this thread. When the response to the single step request stops in a different thread that hit the original break point that thread will now get continued, while the debugger waits for the thread with the single step pending. Here is a high level description of the sequence of events. cont_instead_of_sstep = 0; 1) set breakpoint at do_fork 2) continue 3) Save the thread id where we stop to cont_thread_id 4) Remove breakpoint at do_fork 5) Reset the PC if needed depending on kernel exception type 6) soft single step 7) Check where we stopped if current thread != cont_thread_id { if (here for more than 2 times for the same thead) { ### must be a really busy system, start test again ### goto step 1 } goto step 5 } else { cont_instead_of_sstep = 0; } 8) clean up and run test again if needed 9) Clear out any threads that were waiting on a break point at the point in time the test is ended with get_cont_catch(). This happens sometimes because breakpoints are used in place of single stepping and some threads could have been in the debugger exception handling queue because breakpoints were hit concurrently on different CPUs. This also means we wait at least one second before unplumbing the debugger connection at the very end, so as respond to any debug threads waiting to be serviced. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13kgdbts: (1 of 2) fix single step awareness to work correctly with SMPJason Wessel
commit 486c5987a00a89d56c2c04c506417ef8f823ca2e upstream. The do_fork and sys_open tests have never worked properly on anything other than a UP configuration with the kgdb test suite. This is because the test suite did not fully implement the behavior of a real debugger. A real debugger tracks the state of what thread it asked to single step and can correctly continue other threads of execution or conditionally stop while waiting for the original thread single step request to return. Below is a simple method to cause a fatal kernel oops with the kgdb test suite on a 4 processor x86 system: while [ 1 ] ; do ls > /dev/null 2> /dev/null; done& while [ 1 ] ; do ls > /dev/null 2> /dev/null; done& while [ 1 ] ; do ls > /dev/null 2> /dev/null; done& while [ 1 ] ; do ls > /dev/null 2> /dev/null; done& echo V1I1F1000 > /sys/module/kgdbts/parameters/kgdbts Very soon after starting the test the kernel will oops with a message like: kgdbts: BP mismatch 3b7da66480 expected ffffffff8106a590 WARNING: at drivers/misc/kgdbts.c:303 check_and_rewind_pc+0xe0/0x100() Call Trace: [<ffffffff812994a0>] check_and_rewind_pc+0xe0/0x100 [<ffffffff81298945>] validate_simple_test+0x25/0xc0 [<ffffffff81298f77>] run_simple_test+0x107/0x2c0 [<ffffffff81298a18>] kgdbts_put_char+0x18/0x20 The warn will turn to a hard kernel crash shortly after that because the pc will not get properly rewound to the right value after hitting a breakpoint leading to a hard lockup. This change is broken up into 2 pieces because archs that have hw single stepping (2.6.26 and up) need different changes than archs that do not have hw single stepping (3.0 and up). This change implements the correct behavior for an arch that supports hw single stepping. A minor defect was fixed where sys_open should be do_sys_open for the sys_open break point test. This solves the problem of running a 64 bit with a 32 bit user space. The sys_open() never gets called when using the 32 bit file system for the kgdb testsuite because the 32 bit binaries invoke the compat_sys_open() call leading to the test never completing. In order to mimic a real debugger, the kgdb test suite now tracks the most recent thread that was continued (cont_thread_id), with the intent to single step just this thread. When the response to the single step request stops in a different thread that hit the original break point that thread will now get continued, while the debugger waits for the thread with the single step pending. Here is a high level description of the sequence of events. cont_instead_of_sstep = 0; 1) set breakpoint at do_fork 2) continue 3) Save the thread id where we stop to cont_thread_id 4) Remove breakpoint at do_fork 5) Reset the PC if needed depending on kernel exception type 6) if (cont_instead_of_sstep) { continue } else { single step } 7) Check where we stopped if current thread != cont_thread_id { cont_instead_of_sstep = 1; goto step 5 } else { cont_instead_of_sstep = 0; } 8) clean up and run test again if needed Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13kgdbts: Fix kernel oops with CONFIG_DEBUG_RODATAJason Wessel
commit 456ca7ff24841bf2d2a2dfd690fe7d42ef70d932 upstream. On x86 the kgdb test suite will oops when the kernel is compiled with CONFIG_DEBUG_RODATA and you run the tests after boot time. This is regression has existed since 2.6.26 by commit: b33cb815 (kgdbts: Use HW breakpoints with CONFIG_DEBUG_RODATA). The test suite can use hw breakpoints for all the tests, but it has to execute the hardware breakpoint specific tests first in order to determine that the hw breakpoints actually work. Specifically the very first test causes an oops: # echo V1I1 > /sys/module/kgdbts/parameters/kgdbts kgdb: Registered I/O driver kgdbts. kgdbts:RUN plant and detach test Entering kdb (current=0xffff880017aa9320, pid 1078) on processor 0 due to Keyboard Entry [0]kdb> kgdbts: ERROR PUT: end of test buffer on 'plant_and_detach_test' line 1 expected OK got $E14#aa WARNING: at drivers/misc/kgdbts.c:730 run_simple_test+0x151/0x2c0() [...oops clipped...] This commit re-orders the running of the tests and puts the RODATA check into its own function so as to correctly avoid the kernel oops by detecting and using the hw breakpoints. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13kgdb,debug_core: pass the breakpoint struct instead of address and memoryJason Wessel
commit 98b54aa1a2241b59372468bd1e9c2d207bdba54b upstream. There is extra state information that needs to be exposed in the kgdb_bpt structure for tracking how a breakpoint was installed. The debug_core only uses the the probe_kernel_write() to install breakpoints, but this is not enough for all the archs. Some arch such as x86 need to use text_poke() in order to install a breakpoint into a read only page. Passing the kgdb_bpt structure to kgdb_arch_set_breakpoint() and kgdb_arch_remove_breakpoint() allows other archs to set the type variable which indicates how the breakpoint was installed. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13target: Fix unsupported WRITE_SAME sense payloadMartin Svec
commit 67236c44741e250199ccd77f1115568e68cf8848 upstream. This patch fixes a bug in target-core where unsupported WRITE_SAME ops from a target_check_write_same_discard() failure was incorrectly returning CHECK_CONDITION w/ TCM_INVALID_CDB_FIELD sense data. This was causing some clients to not properly fall back, so go ahead and use the correct TCM_UNSUPPORTED_SCSI_OPCODE sense for this case. Reported-by: Martin Svec <martin.svec@zoner.cz> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13r8169: runtime resume before shutdown.françois romieu
commit 2a15cd2ff488a9fdb55e5e34060f499853b27c77 upstream. With runtime PM, if the ethernet cable is disconnected, the device is transitioned to D3 state to conserve energy. If the system is shutdown in this state, any register accesses in rtl_shutdown are dropped on the floor. As the device was programmed by .runtime_suspend() to wake on link changes, it is thus brought back up as soon as the link recovers. Resuming every suspended device through the driver core would slow things down and it is not clear how many devices really need it now. Original report and D0 transition patch by Sameer Nanda. Patch has been changed to comply with advices by Rafael J. Wysocki and the PM folks. Reported-by: Sameer Nanda <snanda@chromium.org> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Cc: Rafael J. Wysocki <rjw@sisk.pl> Cc: Hayes Wang <hayeswang@realtek.com> Cc: Alan Stern <stern@rowland.harvard.edu> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13drm/i915: quirk away broken OpRegion VBTDaniel Vetter
commit 25e341cfc33d94435472983825163e97fe370a6c upstream. Somehow the BIOS manages to screw things up when copying the VBT around, because the one we scrap from the VBIOS rom actually works. Tested-by: Markus Heinz <markus.heinz@uni-dortmund.de> Acked-by: Chris Wilson <chris@chris-wilson.co.uk> Reviewed-by: Rodrigo Vivi <rodrigo.vivi@gmail.com> Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=28812 Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13drm/i915: Add lock on drm_helper_resume_force_modeSean Paul
commit 927a2f119e8235238a2fc64871051b16c9bdae75 upstream. i915_drm_thaw was not locking the mode_config lock when calling drm_helper_resume_force_mode. When there were multiple wake sources, this caused FDI training failure on SNB which in turn corrupted the display. Signed-off-by: Sean Paul <seanpaul@chromium.org> Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13drm/i915: Sanitize BIOS debugging bits from PIPECONFChris Wilson
commit f47166d2b0001fcb752b40c5a2d4db986dfbea68 upstream. Quoting the BSpec from time immemorial: PIPEACONF, bits 28:27: Frame Start Delay (Debug) Used to delay the frame start signal that is sent to the display planes. Care must be taken to insure that there are enough lines during VBLANK to support this setting. An instance of the BIOS leaving these bits set was found in the wild, where it caused our modesetting to go all squiffy and skewiff. Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=47271 Reported-and-tested-by: Eva Wang <evawang@linpus.com> Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=43012 Reported-and-tested-by: Carl Richell <carl@system76.com> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13drm/i915: no-lvds quirk on MSI DC500Anisse Astier
commit 97effadb65ed08809e1720c8d3ee80b73a93665c upstream. This hardware doesn't have an LVDS, it's a desktop box. Fix incorrect LVDS detection. Signed-off-by: Anisse Astier <anisse@astier.eu> Acked-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13drm/radeon/kms: fix fans after resumeAlex Deucher
commit 402976fe51b2d1a58a29ba06fa1ca5ace3a4cdcd upstream. On pre-R600 asics, the SpeedFanControl table is not executed as part of ASIC_Init as it is on newer asics. Fixes: https://bugzilla.kernel.org/show_bug.cgi?id=29412 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Reviewed-by: Michel Dänzer <michel.daenzer@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13drm: Validate requested virtual size against allocated fb sizeChris Wilson
commit 62fb376e214d3c1bfdf6fbb77dac162f6da04d7e upstream. mplayer -vo fbdev tries to create a screen that is twice as tall as the allocated framebuffer for "doublebuffering". By default, and all in-tree users, only sufficient memory is allocated and mapped to satisfy the smallest framebuffer and the virtual size is no larger than the actual. For these users, we should therefore reject any userspace request to create a screen that requires a buffer larger than the framebuffer originally allocated. References: https://bugs.freedesktop.org/show_bug.cgi?id=38138 Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13rtlwifi: rtl8192ce: rtl8192cu: rtl8192de: Fix low-gain setting when scanningLarry Finger
commit 643c61e119459e9d750087b7b34be94491efebf9 upstream. In https://bugzilla.redhat.com/show_bug.cgi?id=770207, slowdowns of driver rtl8192ce are reported. One fix (commit a9b89e2) has already been applied, and it helped, but the maximum RX speed would still drop to 1 Mbps. As in the previous fix, the initial gain was determined to be the problem; however, the problem arises from a setting of the gain when scans are started. Driver rtl8192de also has the same code structure - this one is fixed as well. Reported-and-Tested-by: Ivan Pesin <ivan.pesin@gmail.com> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13mac80211: fix possible tid_rx->reorder_timer use after freeStanislaw Gruszka
commit d72308bff5c2fa207949a5925b020bce74495e33 upstream. Is possible that we will arm the tid_rx->reorder_timer after del_timer_sync() in ___ieee80211_stop_rx_ba_session(). We need to stop timer after RCU grace period finish, so move it to ieee80211_free_tid_rx(). Timer will not be armed again, as rcu_dereference(sta->ampdu_mlme.tid_rx[tid]) will return NULL. Debug object detected problem with the following warning: ODEBUG: free active (active state 0) object type: timer_list hint: sta_rx_agg_reorder_timer_expired+0x0/0xf0 [mac80211] Bug report (with all warning messages): https://bugzilla.redhat.com/show_bug.cgi?id=804007 Reported-by: "jan p. springer" <jsd@igroup.org> Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13m68k/mac: Add missing platform check before registering platform devicesGeert Uytterhoeven
commit 6cfeba53911d6d2f17ebbd1246893557d5ff5aeb upstream. On multi-platform kernels, the Mac platform devices should be registered when running on Mac only. Else it may crash later. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13tracing: Fix ent_size in trace outputSteven Rostedt
commit 12b5da349a8b94c9dbc3430a6bc42eabd9eaf50b upstream. When reading the trace file, the records of each of the per_cpu buffers are examined to find the next event to print out. At the point of looking at the event, the size of the event is recorded. But if the first event is chosen, the other events in the other CPU buffers will reset the event size that is stored in the iterator descriptor, causing the event size passed to the output functions to be incorrect. In most cases this is not a problem, but for the case of stack traces, it is. With the change to the stack tracing to record a dynamic number of back traces, the output depends on the size of the entry instead of the fixed 8 back traces. When the entry size is not correct, the back traces would not be fully printed. Note, reading from the per-cpu trace files were not affected. Reported-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13tracing: Fix ftrace stack trace entriesWolfgang Mauerer
commit 01de982abf8c9e10fc3089e10585cd2cc914bdab upstream. 8 hex characters tell only half the tale for 64 bit CPUs, so use the appropriate length. Link: http://lkml.kernel.org/r/1332411501-8059-2-git-send-email-wolfgang.mauerer@siemens.com Signed-off-by: Wolfgang Mauerer <wolfgang.mauerer@siemens.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13genirq: Adjust irq thread affinity on IRQ_SET_MASK_OK_NOCOPY return valueJiang Liu
commit f5cb92ac82d06cb583c1f66666314c5c0a4d7913 upstream. irq_move_masked_irq() checks the return code of chip->irq_set_affinity() only for 0, but IRQ_SET_MASK_OK_NOCOPY is also a valid return code, which is there to avoid a redundant copy of the cpumask. But in case of IRQ_SET_MASK_OK_NOCOPY we not only avoid the redundant copy, we also fail to adjust the thread affinity of an eventually threaded interrupt handler. Handle IRQ_SET_MASK_OK (==0) and IRQ_SET_MASK_OK_NOCOPY(==1) return values correctly by checking the valid return values seperately. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Cc: Jiang Liu <liuj97@gmail.com> Cc: Keping Chen <chenkeping@huawei.com> Link: http://lkml.kernel.org/r/1333120296-13563-2-git-send-email-jiang.liu@huawei.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13modpost: fix ALL_INIT_DATA_SECTIONSJan Beulich
commit 9aaf440f8fabcebf9ea79a62ccf4c212e6544b49 upstream. This was lacking a comma between two supposed to be separate strings. Signed-off-by: Jan Beulich <jbeulich@suse.com> Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13ACPICA: Fix regression in FADT revision checksJulian Anastasov
commit 3e80acd1af40fcd91a200b0416a7616b20c5d647 upstream. commit 64b3db22c04586997ab4be46dd5a5b99f8a2d390 (2.6.39), "Remove use of unreliable FADT revision field" causes regression for old P4 systems because now cst_control and other fields are not reset to 0. The effect is that acpi_processor_power_init will notice cst_control != 0 and a write to CST_CNT register is performed that should not happen. As result, the system oopses after the "No _CST, giving up" message, sometimes in acpi_ns_internalize_name, sometimes in acpi_ns_get_type, usually at random places. May be during migration to CPU 1 in acpi_processor_get_throttling. Every one of these settings help to avoid this problem: - acpi=off - processor.nocst=1 - maxcpus=1 The fix is to update acpi_gbl_FADT.header.length after the original value is used to check for old revisions. https://bugzilla.kernel.org/show_bug.cgi?id=42700 https://bugzilla.redhat.com/show_bug.cgi?id=727865 Signed-off-by: Julian Anastasov <ja@ssi.bg> Acked-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Cc: Jonathan Nieder <jrnieder@gmail.com> Cc: Josh Boyer <jwboyer@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13PNPACPI: Fix device ref leaking in acpi_pnp_matchYinghai Lu
commit 89e96ada572fb216e582dbe3f64e1a6939a37f74 upstream. During testing pci root bus removal, found some root bus bridge is not freed. If booting with pnpacpi=off, those hostbridge could be freed without problem. It turns out that some devices reference are not released during acpi_pnp_match. that match should not hold one device ref during every calling. Add pu_device calling before returning. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13ACPI: Do cpufreq clamping for throttling per package v2Andi Kleen
commit 2815ab92ba3ab27556212cc306288dc95692824b upstream. On Intel CPUs the processor typically uses the highest frequency set by any logical CPU. When the system overheats Linux first forces the frequency to the lowest available one to lower the temperature. However this was done only per logical CPU, which means all logical CPUs in a package would need to go through this before the frequency is actually lowered. Worse this delay actually prevents real throttling, because the real throttle code only proceeds when the lowest frequency is already reached. So when a throttle event happens force the lowest frequency for all CPUs in the package where it happened. The per CPU state is now kept per package, not per logical CPU. An alternative would be to do it per cpufreq unit, but since we want to bring down the temperature of the complete chip it's better to do it for all. In principle it may even make sense to do it for all CPUs, but I kept it on the package for now. With this change the frequency is actually lowered, which in terms also allows real throttling to proceed. I also removed an unnecessary per cpu variable initialization. v2: Fix package mapping Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13mtd: m25p80: set writebufsizeBrian Norris
commit b54f47c8bcfc5f766bf13ec31bd7dd1d4726d33b upstream. Using UBI on m25p80 can give messages like: UBI error: io_init: bad write buffer size 0 for 1 min. I/O unit We need to initialize writebufsize; I think "page_size" is the correct "bufsize", although I'm not sure. Comments? Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13mtd: lart: initialize writebufsizeArtem Bityutskiy
commit fcc44a07dae0af16e84e93425fc8afe642ddc603 upstream. The writebufsize concept was introduce by commit "0e4ca7e mtd: add writebufsize field to mtd_info struct" and it represents the maximum amount of data the device writes to the media at a time. This is an important parameter for UBIFS which is used during recovery and which basically defines how big a corruption caused by a power cut can be. Set writebufsize to 4 because this drivers writes at max 4 bytes at a time. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13mtd: block2mtd: initialize writebufsizeArtem Bityutskiy
commit b604387411ec6a072e95910099262616edd2bd2f upstream. The writebufsize concept was introduce by commit "0e4ca7e mtd: add writebufsize field to mtd_info struct" and it represents the maximum amount of data the device writes to the media at a time. This is an important parameter for UBIFS which is used during recovery and which basically defines how big a corruption caused by a power cut can be. However, we forgot to set this parameter for block2mtd. Set it to PAGE_SIZE because this is actually the amount of data we write at a time. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Acked-by: Joern Engel <joern@lazybastard.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-13mtd: sst25l: initialize writebufsizeArtem Bityutskiy
commit c4cc625ea5958d065c21cc0fcea29e9ed8f3d2bc upstream. The writebufsize concept was introduce by commit "0e4ca7e mtd: add writebufsize field to mtd_info struct" and it represents the maximum amount of data the device writes to the media at a time. This is an important parameter for UBIFS which is used during recovery and which basically defines how big a corruption caused by a power cut can be. Set writebufsize to the flash page size because it is the maximum amount of data it writes at a time. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
