2011-12-23Linux 3.2-rc7v3.2-rc7Linus Torvalds
2011-12-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: VFS: Fix race between CPU hotplug and lglocks
2011-12-23Merge tag 'writeback' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linuxLinus Torvalds
for linus: writeback reason binary tracing format fix * tag 'writeback' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux: writeback: show writeback reason with __print_symbolic
2011-12-23Merge branch 'rc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild * 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: kconfig: adapt update-po-config to new UML layout
2011-12-23Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: [media] omap3isp: Fix crash caused by subdevs now having a pointer to devnodes
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: Btrfs: call d_instantiate after all ops are setup Btrfs: fix worker lock misuse in find_worker
2011-12-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: sparc64: Fix MSIQ HV call ordering in pci_sun4v_msiq_build_irq().
2011-12-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: netfilter: xt_connbytes: handle negation correctly net: relax rcvbuf limits rps: fix insufficient bounds checking in store_rps_dev_flow_table_cnt() net: introduce DST_NOPEER dst flag mqprio: Avoid panic if no options are provided bridge: provide a mtu() method for fake_dst_ops
2011-12-23Merge branch 'nf' of git://1984.lsi.us.es/netDavid S. Miller
2011-12-23netfilter: xt_connbytes: handle negation correctlyFlorian Westphal
"! --connbytes 23:42" should match if the packet/byte count is not in range. As there is no explict "invert match" toggle in the match structure, userspace swaps the from and to arguments (i.e., as if "--connbytes 42:23" were given). However, "what <= 23 && what >= 42" will always be false. Change things so we use "||" in case "from" is larger than "to". This change may look like it breaks backwards compatibility when "to" is 0. However, older iptables binaries will refuse "connbytes 42:0", and current releases treat it to mean "! --connbytes 0:42", so we should be fine. Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2011-12-23Btrfs: call d_instantiate after all ops are setupAl Viro
This closes races where btrfs is calling d_instantiate too soon during inode creation. All of the callers of btrfs_add_nondir are updated to instantiate after the inode is fully setup in memory. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-12-23Btrfs: fix worker lock misuse in find_workerChris Mason
Dan Carpenter noticed that we were doing a double unlock on the worker lock, and sometimes picking a worker thread without the lock held. This fixes both errors. Signed-off-by: Chris Mason <chris.mason@oracle.com> Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
2011-12-23net: relax rcvbuf limitsEric Dumazet
skb->truesize might be big even for a small packet. Its even bigger after commit 87fb4b7b533 (net: more accurate skb truesize) and big MTU. We should allow queueing at least one packet per receiver, even with a low RCVBUF setting. Reported-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-22rps: fix insufficient bounds checking in store_rps_dev_flow_table_cnt()Xi Wang
Setting a large rps_flow_cnt like (1 << 30) on 32-bit platform will cause a kernel oops due to insufficient bounds checking. if (count > 1<<30) { /* Enforce a limit to prevent overflow */ return -EINVAL; } count = roundup_pow_of_two(count); table = vmalloc(RPS_DEV_FLOW_TABLE_SIZE(count)); Note that the macro RPS_DEV_FLOW_TABLE_SIZE(count) is defined as: ... + (count * sizeof(struct rps_dev_flow)) where sizeof(struct rps_dev_flow) is 8. (1 << 30) * 8 will overflow 32 bits. This patch replaces the magic number (1 << 30) with a symbolic bound. Suggested-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Xi Wang <xi.wang@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-22net: introduce DST_NOPEER dst flagEric Dumazet
Chris Boot reported crashes occurring in ipv6_select_ident(). [ 461.457562] RIP: 0010:[<ffffffff812dde61>] [<ffffffff812dde61>] ipv6_select_ident+0x31/0xa7 [ 461.578229] Call Trace: [ 461.580742] <IRQ> [ 461.582870] [<ffffffff812efa7f>] ? udp6_ufo_fragment+0x124/0x1a2 [ 461.589054] [<ffffffff812dbfe0>] ? ipv6_gso_segment+0xc0/0x155 [ 461.595140] [<ffffffff812700c6>] ? skb_gso_segment+0x208/0x28b [ 461.601198] [<ffffffffa03f236b>] ? ipv6_confirm+0x146/0x15e [nf_conntrack_ipv6] [ 461.608786] [<ffffffff81291c4d>] ? nf_iterate+0x41/0x77 [ 461.614227] [<ffffffff81271d64>] ? dev_hard_start_xmit+0x357/0x543 [ 461.620659] [<ffffffff81291cf6>] ? nf_hook_slow+0x73/0x111 [ 461.626440] [<ffffffffa0379745>] ? br_parse_ip_options+0x19a/0x19a [bridge] [ 461.633581] [<ffffffff812722ff>] ? dev_queue_xmit+0x3af/0x459 [ 461.639577] [<ffffffffa03747d2>] ? br_dev_queue_push_xmit+0x72/0x76 [bridge] [ 461.646887] [<ffffffffa03791e3>] ? br_nf_post_routing+0x17d/0x18f [bridge] [ 461.653997] [<ffffffff81291c4d>] ? nf_iterate+0x41/0x77 [ 461.659473] [<ffffffffa0374760>] ? br_flood+0xfa/0xfa [bridge] [ 461.665485] [<ffffffff81291cf6>] ? nf_hook_slow+0x73/0x111 [ 461.671234] [<ffffffffa0374760>] ? br_flood+0xfa/0xfa [bridge] [ 461.677299] [<ffffffffa0379215>] ? nf_bridge_update_protocol+0x20/0x20 [bridge] [ 461.684891] [<ffffffffa03bb0e5>] ? nf_ct_zone+0xa/0x17 [nf_conntrack] [ 461.691520] [<ffffffffa0374760>] ? br_flood+0xfa/0xfa [bridge] [ 461.697572] [<ffffffffa0374812>] ? NF_HOOK.constprop.8+0x3c/0x56 [bridge] [ 461.704616] [<ffffffffa0379031>] ? nf_bridge_push_encap_header+0x1c/0x26 [bridge] [ 461.712329] [<ffffffffa037929f>] ? br_nf_forward_finish+0x8a/0x95 [bridge] [ 461.719490] [<ffffffffa037900a>] ? nf_bridge_pull_encap_header+0x1c/0x27 [bridge] [ 461.727223] [<ffffffffa0379974>] ? br_nf_forward_ip+0x1c0/0x1d4 [bridge] [ 461.734292] [<ffffffff81291c4d>] ? nf_iterate+0x41/0x77 [ 461.739758] [<ffffffffa03748cc>] ? __br_deliver+0xa0/0xa0 [bridge] [ 461.746203] [<ffffffff81291cf6>] ? nf_hook_slow+0x73/0x111 [ 461.751950] [<ffffffffa03748cc>] ? __br_deliver+0xa0/0xa0 [bridge] [ 461.758378] [<ffffffffa037533a>] ? NF_HOOK.constprop.4+0x56/0x56 [bridge] This is caused by bridge netfilter special dst_entry (fake_rtable), a special shared entry, where attaching an inetpeer makes no sense. Problem is present since commit 87c48fa3b46 (ipv6: make fragment identifications less predictable) Introduce DST_NOPEER dst flag and make sure ipv6_select_ident() and __ip_select_ident() fallback to the 'no peer attached' handling. Reported-by: Chris Boot <bootc@bootc.net> Tested-by: Chris Boot <bootc@bootc.net> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-22mqprio: Avoid panic if no options are providedThomas Graf
Userspace may not provide TCA_OPTIONS, in fact tc currently does so not do so if no arguments are specified on the command line. Return EINVAL instead of panicing. Signed-off-by: Thomas Graf <tgraf@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-22bridge: provide a mtu() method for fake_dst_opsEric Dumazet
Commit 618f9bc74a039da76 (net: Move mtu handling down to the protocol depended handlers) forgot the bridge netfilter case, adding a NULL dereference in ip_fragment(). Reported-by: Chris Boot <bootc@bootc.net> CC: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-22Merge branch 'for-linus' of git://neil.brown.name/mdLinus Torvalds
* 'for-linus' of git://neil.brown.name/md: md/bitmap: It is OK to clear bits during recovery. md: don't give up looking for spares on first failure-to-add md/raid5: ensure correct assessment of drives during degraded reshape. md/linear: fix hot-add of devices to linear arrays.
2011-12-23md/bitmap: It is OK to clear bits during recovery.NeilBrown
commit d0a4bb492772ce5c4bdfba3744a99ed6f6fb238f introduced a regression which is annoying but fairly harmless. When writing to an array that is undergoing recovery (a spare in being integrated into the array), writing to the array will set bits in the bitmap, but they will not be cleared when the write completes. For bits covering areas that have not been recovered yet this is not a problem as the recovery will clear the bits. However bits set in already-recovered region will stay set and never be cleared. This doesn't risk data integrity. The only negatives are: - next time there is a crash, more resyncing than necessary will be done. - the bitmap doesn't look clean, which is confusing. While an array is recovering we don't want to update the 'events_cleared' setting in the bitmap but we do still want to clear bits that have very recently been set - providing they were written to the recovering device. So split those two needs - which previously both depended on 'success' and always clear the bit of the write went to all devices. Signed-off-by: NeilBrown <neilb@suse.de>
2011-12-23md: don't give up looking for spares on first failure-to-addNeilBrown
Before performing a recovery we try to remove any spares that might not be working, then add any that might have become relevant. Currently we abort on the first spare that cannot be added. This is a false optimisation. It is conceivable that - depending on rules in the personality - a subsequent spare might be accepted. Also the loop does other things like count the available spares and reset the 'recovery_offset' value. If we abort early these might not happen properly. So remove the early abort. In particular if you have an array what is undergoing recovery and which has extra spares, then the recovery may not restart after as reboot as the could of 'spares' might end up as zero. Reported-by: Anssi Hannula <anssi.hannula@iki.fi> Signed-off-by: NeilBrown <neilb@suse.de>
2011-12-23md/raid5: ensure correct assessment of drives during degraded reshape.NeilBrown
While reshaping a degraded array (as when reshaping a RAID0 by first converting it to a degraded RAID4) we currently get confused about which devices are in_sync. In most cases we get it right, but in the region that is being reshaped we need to treat non-failed devices as in-sync when we have the data but haven't actually written it out yet. Reported-by: Adam Kwolek <adam.kwolek@intel.com> Signed-off-by: NeilBrown <neilb@suse.de>
2011-12-23md/linear: fix hot-add of devices to linear arrays.NeilBrown
commit d70ed2e4fafdbef0800e73942482bb075c21578b broke hot-add to a linear array. After that commit, metadata if not written to devices until they have been fully integrated into the array as determined by saved_raid_disk. That patch arranged to clear that field after a recovery completed. However for linear arrays, there is no recovery - the integration is instantaneous. So we need to explicitly clear the saved_raid_disk field. Signed-off-by: NeilBrown <neilb@suse.de>
2011-12-22sparc64: Fix MSIQ HV call ordering in pci_sun4v_msiq_build_irq().David S. Miller
This silently was working for many years and stopped working on Niagara-T3 machines. We need to set the MSIQ to VALID before we can set it's state to IDLE. On Niagara-T3, setting the state to IDLE first was causing HV_EINVAL errors. The hypervisor documentation says, rather ambiguously, that the MSIQ must be "initialized" before one can set the state. I previously understood this to mean merely that a successful setconf() operation has been performed on the MSIQ, which we have done at this point. But it seems to also mean that it has been set VALID too. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-22Merge branch 'usb-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb * 'usb-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: USB: Fix usb/isp1760 build on sparc usb: gadget: epautoconf: do not change number of streams usb: dwc3: core: fix cached revision on our structure usb: musb: fix reset issue with full speed device
2011-12-22Merge branch 'upstream-linus' of git://github.com/jgarzik/libata-devLinus Torvalds
* 'upstream-linus' of git://github.com/jgarzik/libata-dev: pata_of_platform: Add missing CONFIG_OF_IRQ dependency.
2011-12-22pata_of_platform: Add missing CONFIG_OF_IRQ dependency.David Miller
Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2011-12-22ipv4: using prefetch requires including prefetch.hStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: David Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-12-22VFS: Fix race between CPU hotplug and lglocksSrivatsa S. Bhat
Currently, the *_global_[un]lock_online() routines are not at all synchronized with CPU hotplug. Soft-lockups detected as a consequence of this race was reported earlier at https://lkml.org/lkml/2011/8/24/185. (Thanks to Cong Meng for finding out that the root-cause of this issue is the race condition between br_write_[un]lock() and CPU hotplug, which results in the lock states getting messed up). Fixing this race by just adding {get,put}_online_cpus() at appropriate places in *_global_[un]lock_online() is not a good option, because, then suddenly br_write_[un]lock() would become blocking, whereas they have been kept as non-blocking all this time, and we would want to keep them that way. So, overall, we want to ensure 3 things: 1. br_write_lock() and br_write_unlock() must remain as non-blocking. 2. The corresponding lock and unlock of the per-cpu spinlocks must not happen for different sets of CPUs. 3. Either prevent any new CPU online operation in between this lock-unlock, or ensure that the newly onlined CPU does not proceed with its corresponding per-cpu spinlock unlocked. To achieve all this: (a) We introduce a new spinlock that is taken by the *_global_lock_online() routine and released by the *_global_unlock_online() routine. (b) We register a callback for CPU hotplug notifications, and this callback takes the same spinlock as above. (c) We maintain a bitmap which is close to the cpu_online_mask, and once it is initialized in the lock_init() code, all future updates to it are done in the callback, under the above spinlock. (d) The above bitmap is used (instead of cpu_online_mask) while locking and unlocking the per-cpu locks. The callback takes the spinlock upon the CPU_UP_PREPARE event. So, if the br_write_lock-unlock sequence is in progress, the callback keeps spinning, thus preventing the CPU online operation till the lock-unlock sequence is complete. This takes care of requirement (3). The bitmap that we maintain remains unmodified throughout the lock-unlock sequence, since all updates to it are managed by the callback, which takes the same spinlock as the one taken by the lock code and released only by the unlock routine. Combining this with (d) above, satisfies requirement (2). Overall, since we use a spinlock (mentioned in (a)) to prevent CPU hotplug operations from racing with br_write_lock-unlock, requirement (1) is also taken care of. By the way, it is to be noted that a CPU offline operation can actually run in parallel with our lock-unlock sequence, because our callback doesn't react to notifications earlier than CPU_DEAD (in order to maintain our bitmap properly). And this means, since we use our own bitmap (which is stale, on purpose) during the lock-unlock sequence, we could end up unlocking the per-cpu lock of an offline CPU (because we had locked it earlier, when the CPU was online), in order to satisfy requirement (2). But this is harmless, though it looks a bit awkward. Debugged-by: Cong Meng <mc@linux.vnet.ibm.com> Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Cc: stable@vger.kernel.org
2011-12-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: net: Add a flow_cache_flush_deferred function ipv4: reintroduce route cache garbage collector net: have ipconfig not wait if no dev is available sctp: Do not account for sizeof(struct sk_buff) in estimated rwnd asix: new device id davinci-cpdma: fix locking issue in cpdma_chan_stop sctp: fix incorrect overflow check on autoclose r8169: fix Config2 MSIEnable bit setting. llc: llc_cmsg_rcv was getting called after sk_eat_skb. net: bpf_jit: fix an off-one bug in x86_64 cond jump target iwlwifi: update SCD BC table for all SCD queues Revert "Bluetooth: Revert: Fix L2CAP connection establishment" Bluetooth: Clear RFCOMM session timer when disconnecting last channel Bluetooth: Prevent uninitialized data access in L2CAP configuration iwlwifi: allow to switch to HT40 if not associated iwlwifi: tx_sync only on PAN context mwifiex: avoid double list_del in command cancel path ath9k: fix max phy rate at rate control init nfc: signedness bug in __nci_request() iwlwifi: do not set the sequence control bit is not needed
2011-12-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: atmel/ac97c: using software reset instead hardware reset if not available
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: mfd: Include linux/io.h to jz4740-adc mfd: Use request_threaded_irq for twl4030-irq instead of irq_set_chained_handler mfd: Base interrupt for twl4030-irq must be one-shot mfd: Handle tps65910 clear-mask correctly mfd: add #ifdef CONFIG_DEBUG_FS guard for ab8500_debug_resources mfd: Fix twl-core oops while calling twl_i2c_* for unbound driver mfd: include linux/module.h for ab5500-debugfs mfd: Update wm8994 active device checks for WM1811 mfd: Set tps6586x bits if new value is different from the old one mfd: Set da903x bits if new value is different from the old one mfd: Set adp5520 bits if new value is different from the old one mfd: Add missed free_irq in da903x_remove
2011-12-21vfs: __read_cache_page should use gfp argument rather than GFP_KERNELDave Kleikamp
lockdep reports a deadlock in jfs because a special inode's rw semaphore is taken recursively. The mapping's gfp mask is GFP_NOFS, but is not used when __read_cache_page() calls add_to_page_cache_lru(). Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com> Acked-by: Hugh Dickins <hughd@google.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-12-21Merge branch 'for-greg' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb into usb-linus * 'for-greg' of git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb: usb: gadget: epautoconf: do not change number of streams usb: dwc3: core: fix cached revision on our structure usb: musb: fix reset issue with full speed device
2011-12-21USB: Fix usb/isp1760 build on sparcDavid Miller
This commit: commit 8f5d621543cb064d2989fc223d3c2bc61a43981e Author: Joachim Foerster <joachim.foerster@missinglinkelectronics.com> Date: Mon Oct 10 18:06:54 2011 +0200 usb/isp1760: Let OF bindings depend on general CONFIG_OF instead of PPC_OF . To be able to use the driver on other OF-aware architectures, too. And add necessary OF related #includes to fix compilation error. Signed-off-by: Joachim Foerster <joachim.foerster@missinglinkelectronics.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> enabled the build on all CONFIG_OF architectures, but it cannot do this. This driver depends upon CONFIG_OF_IRQ but not all CONFIG_OF platforms support that infrastructure, in particular Sparc does not so the build fails. Please push a patch like the following to Linus so that this code only gets built where it actually should. -------------------- usb/isp1760: Add missing CONFIG_OF_IRQ dependency on OF code. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-21net: Add a flow_cache_flush_deferred functionSteffen Klassert
flow_cach_flush() might sleep but can be called from atomic context via the xfrm garbage collector. So add a flow_cache_flush_deferred() function and use this if the xfrm garbage colector is invoked from within the packet path. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Acked-by: Timo Teräs <timo.teras@iki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-21ipv4: reintroduce route cache garbage collectorEric Dumazet
Commit 2c8cec5c10b (ipv4: Cache learned PMTU information in inetpeer) removed IP route cache garbage collector a bit too soon, as this gc was responsible for expired routes cleanup, releasing their neighbour reference. As pointed out by Robert Gladewitz, recent kernels can fill and exhaust their neighbour cache. Reintroduce the garbage collection, since we'll have to wait our neighbour lookups become refcount-less to not depend on this stuff. Reported-by: Robert Gladewitz <gladewitz@gmx.de> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-21Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
2011-12-20firmware: Refer to the co-maintained linux-firmware.git repositoryBen Hutchings
David and I are sharing maintenance of this repository. Patches should be sent to both of us. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-12-20Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: mtd: plat_ram: call mtd_device_register only if partition data exists mtd: pxa2xx-flash.c: It used to fall back to provided table. mtd: gpmi: add missing include 'module.h' mtd: ndfc: fix typo in structure dereference
2011-12-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: mmc: vub300: fix type of firmware_rom_wait_states module parameter Revert "mmc: enable runtime PM by default" mmc: sdhci: remove "state" argument from sdhci_suspend_host
2011-12-21SELinux: Fix RCU deref check warning in sel_netport_insert()David Howells
Fix the following bug in sel_netport_insert() where rcu_dereference() should be rcu_dereference_protected() as sel_netport_lock is held. =================================================== [ INFO: suspicious rcu_dereference_check() usage. ] --------------------------------------------------- security/selinux/netport.c:127 invoked rcu_dereference_check() without protection! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 0 1 lock held by ossec-rootcheck/3323: #0: (sel_netport_lock){+.....}, at: [<ffffffff8117d775>] sel_netport_sid+0xbb/0x226 stack backtrace: Pid: 3323, comm: ossec-rootcheck Not tainted 3.1.0-rc8-fsdevel+ #1095 Call Trace: [<ffffffff8105cfb7>] lockdep_rcu_dereference+0xa7/0xb0 [<ffffffff8117d871>] sel_netport_sid+0x1b7/0x226 [<ffffffff8117d6ba>] ? sel_netport_avc_callback+0xbc/0xbc [<ffffffff8117556c>] selinux_socket_bind+0x115/0x230 [<ffffffff810a5388>] ? might_fault+0x4e/0x9e [<ffffffff810a53d1>] ? might_fault+0x97/0x9e [<ffffffff81171cf4>] security_socket_bind+0x11/0x13 [<ffffffff812ba967>] sys_bind+0x56/0x95 [<ffffffff81380dac>] ? sysret_check+0x27/0x62 [<ffffffff8105b767>] ? trace_hardirqs_on_caller+0x11e/0x155 [<ffffffff81076fcd>] ? audit_syscall_entry+0x17b/0x1ae [<ffffffff811b5eae>] ? trace_hardirqs_on_thunk+0x3a/0x3f [<ffffffff81380d7b>] system_call_fastpath+0x16/0x1b Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Paul Moore <paul@paul-moore.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: stable@kernel.org Signed-off-by: James Morris <jmorris@namei.org>
2011-12-21Merge branch 'evm-fixes' of ↵James Morris
git://git.kernel.org/pub/scm/linux/kernel/git/kasatkin/linux-digsig into for-linus
2011-12-20Merge branch 'for-3.2-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup * 'for-3.2-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: cgroups: fix a css_set not found bug in cgroup_attach_proc
2011-12-20Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, dumpstack: Fix code bytes breakage due to missing KERN_CONT
2011-12-20Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: time/clocksource: Fix kernel-doc warnings rtc: m41t80: Workaround broken alarm functionality rtc: Expire alarms after the time is set.
2011-12-20Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: oprofile: Fix uninitialized memory access when writing to writing to oprofilefs
2011-12-20Merge branch 'stable/for-linus-fixes-3.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/for-linus-fixes-3.2' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: Revert "xen/pv-on-hvm kexec: add xs_reset_watches to shutdown watches from old kernel"
2011-12-20Merge branch 'sh-fixes-for-linus' of git://github.com/pmundt/linux-shLinus Torvalds
* 'sh-fixes-for-linus' of git://github.com/pmundt/linux-sh: sh: fix build warning in board-sh7757lcr
2011-12-20Merge branch 'rmobile-fixes-for-linus' of git://github.com/pmundt/linux-shLinus Torvalds
* 'rmobile-fixes-for-linus' of git://github.com/pmundt/linux-sh: ARM: mach-shmobile: SH73A0 external Ethernet fix ARM: mach-shmobile: AG5EVM GIC Sparse IRQ fix ARM: mach-shmobile: Kota2 TPU LED platform data ARM: mach-shmobile: Kota2 GIC Sparse IRQ fix ARM: mach-shmobile: Kota2 PINT fix
2011-12-20Merge branch 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: NFS: Fix a regression in nfs_file_llseek() NFSv4: Do not accept delegated opens when a delegation recall is in effect NFSv4: Ensure correct locking when accessing the 'lock_states' list NFSv4.1: Ensure that we handle _all_ SEQUENCE status bits. NFSv4: Don't error if we handled it in nfs4_recovery_handle_error SUNRPC: Ensure we always bump the backlog queue in xprt_free_slot SUNRPC: Fix the execution time statistics in the face of RPC restarts
