2011-12-16Linux 3.2-rc6v3.2-rc6Linus Torvalds
2011-12-16Revert "drm/i915: fix infinite recursion on unbind due to ilk vt-d w/a"Linus Torvalds
This reverts commit eb1711bb94991e93669c5a1b5f84f11be2d51ea1. It blows up the i915 seqno tracking, resulting in the BUG_ON(seqno == 0); in i915_wait_request() triggering, which will cause lock-ups. See for example https://bugs.launchpad.net/ubuntu/+source/linux/+bug/903010 https://lkml.org/lkml/2011/12/14/395 Reported-requested-and-tested-by: Dirk Hohndel <dirk@hohndel.org> Reported-by: Richard Eames <Richard.Eames@flinders.edu.au> Reported-by: Rocko Requin <rockorequin@hotmail.com> Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: Dave Airlie <airlied@redhat.com> Cc: Chris Wilson <chris@chris-wilson.co.uk> Cc: Keith Packard <keithp@keithp.com> Cc: Eric Anholt <eric@anholt.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-12-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: sparc32: Be less strict in matching %lo part of relocation. sbus: convert drivers/sbus/char/* to use module_platform_driver() bbc_i2c: Remove unneeded err variable sparc: Use kmemdup rather than duplicating its implementation
2011-12-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: ipv6: Check dest prefix length on original route not copied one in rt6_alloc_cow(). sch_gred: should not use GFP_KERNEL while holding a spinlock ipip, sit: copy parms.name after register_netdevice ipv6: Fix for adding multicast route for loopback device automatically. ssb: fix init regression with SoCs rtl8192{ce,cu,de,se}: avoid problems because of possible ERFOFF -> ERFSLEEP transition mac80211: fix another race in aggregation start fsl_pq_mdio: Clean up tbi address configuration ppp: fix pptp double release_sock in pptp_bind() net/fec: fix the use of pdev->id ath9k: fix check for antenna diversity support batman-adv: delete global entry in case of roaming batman-adv: in case of roaming mark the client with TT_CLIENT_ROAM Bluetooth: Correct version check in hci_setup btusb: fix a memory leak in btusb_send_frame() Bluetooth: bnep: Fix module reference Bluetooth: cmtp: Fix module reference Bluetooth: btmrvl: support Marvell Bluetooth device SD8797
2011-12-16Merge branches 'for-linus' and 'for-linus-3.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: Btrfs: unplug every once and a while Btrfs: deal with NULL srv_rsv in the delalloc inode reservation code Btrfs: only set cache_generation if we setup the block group Btrfs: don't panic if orphan item already exists Btrfs: fix leaked space in truncate Btrfs: fix how we do delalloc reservations and how we free reservations on error Btrfs: deal with enospc from dirtying inodes properly Btrfs: fix num_workers_starting bug and other bugs in async thread BTRFS: Establish i_ops before calling d_instantiate Btrfs: add a cond_resched() into the worker loop Btrfs: fix ctime update of on-disk inode btrfs: keep orphans for subvolume deletion Btrfs: fix inaccurate available space on raid0 profile Btrfs: fix wrong disk space information of the files Btrfs: fix wrong i_size when truncating a file to a larger size Btrfs: fix btrfs_end_bio to deal with write errors to a single mirror * 'for-linus-3.2' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: btrfs: lower the dirty balance poll interval
2011-12-16Merge branch 'drm-intel-fixes' of git://people.freedesktop.org/~keithp/linuxLinus Torvalds
* 'drm-intel-fixes' of git://people.freedesktop.org/~keithp/linux: drm/i915/dp: Dither down to 6bpc if it makes the mode fit drm/i915: enable semaphores on per-device defaults drm/i915: don't set unpin_work if vblank_get fails drm/i915: By default, enable RC6 on IVB and SNB when reasonable iommu: Export intel_iommu_enabled to signal when iommu is in use drm/i915/sdvo: Include LVDS panels for the IS_DIGITAL check drm/i915: prevent division by zero when asking for chipset power drm/i915: add PCH info to i915_capabilities drm/i915: set the right SDVO transcoder for CPT drm/i915: no-lvds quirk for ASUS AT5NM10T-I drm/i915: Treat pre-gen4 backlight duty cycle value consistently drm/i915: Hook up Ivybridge eDP drm/i915: add multi-threaded forcewake support
2011-12-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: HDA: Use LPIB Position fix for Intel SCH Poulsbo ALSA: hda: fix mute led polarity for HP laptops with buggy BIOS ALSA: HDA: Set position fix to LPIB for an Atom/Poulsbo based device ASoC: Fix hx4700 error handling to free gpios if snd_soc_register_card fails ASoC: WM8958: correctly show firmware magic on mismatch ASoC: mxs: Add appropriate MODULE_ALIAS() ASoC: mxs: Add missing MODULE_LICENSE("GPL") ASoC: Fix WM8996 24.576MHz clock operation ASoC: Include linux/module.h for smdk2443_wm9710 ASoC: Fix a typo in jive_wm8750 ASoC: Fix build dependency for SND_SOC_JZ4740_CODEC ASoC: Include linux/io.h for jz4740 codec
2011-12-16Merge branch 'gpio/merge' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'gpio/merge' of git://git.secretlab.ca/git/linux-2.6: gpio: Fix DA9052 GPIO build errors. gpio: mpc8xxx: don't allow input-only pins to be output for MPC5121 gpio-ml-ioh: Add the irq_disable/irq_enable hooks for ml-ioh irq chip gpio-ml-ioh: fix a bug in the interrupt handler gpio: pl061: drop extra check for NULL platform_data
2011-12-16Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: OMAP: rx51: fix USB ARM: OMAP: mcbsp: Fix possible memory corruption arm/imx: fix power button on imx51 babbage board ARM: imx: fix cpufreq build errors ARM: mx5: add __initconst for fec pdata MXC PWM: should active during DOZE/WAIT/DBG mode ARM: EXYNOS: Fix build error without CONFIG_LOCAL_TIMERS ARM: EXYNOS: Fix for stall in case of cpu hotplug or sleep ARM: S5PV210: Set 1000ns as PWM backlight period on SMDKV210 ARM: SAMSUNG: remove duplicated header include
2011-12-16Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-block: block: don't kick empty queue in blk_drain_queue() block/swim3: Locking fixes loop: Fix discard_alignment default setting cfq-iosched: fix cfq_cic_link() race confition cfq-iosched: free cic_index if blkio_alloc_blkg_stats fails cciss: fix flush cache transfer length cciss: Add IRQF_SHARED back in for the non-MSI(X) interrupt handler loop: fix loop block driver discard and encryption comment block: initialize request_queue's numa node during
2011-12-16btrfs: lower the dirty balance poll intervalWu Fengguang
Tests show that the original large intervals can easily make the dirty limit exceeded on 100 concurrent dd's. So adapt to as large as the next check point selected by the dirty throttling algorithm. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-12-16drm/i915/dp: Dither down to 6bpc if it makes the mode fitAdam Jackson
Some active adaptors (VGA usually) only have two lanes at 2.7GHz. That's a maximum pixel clock of 144MHz at 8bpc, but 192MHz at 6bpc. Fixes Asus UX31 panel being black at startup due to no valid modes since dc22ee6fc18ce0f15424e753e8473c306ece95c1. v2: Rebased to current code, resulting in the fix applying to EDP panels as well. Also changed from spatio-temporal to just spatial dithering on pre-ironlake, to be conssitent (and less visual flicker) Signed-off-by: Adam Jackson <ajax@redhat.com> Signed-off-by: Eric Anholt <eric@anholt.net> Tested-by: Eric Anholt <eric@anholt.net> Tested-by: Dirk Hohndel <hohndel@infradead.org> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-12-16drm/i915: enable semaphores on per-device defaultsEugeni Dodonov
This adds a default setting for semaphores parameter, and enables semaphores by default on IVB. For now, as semaphores interaction with VTd causes random issues on SNB, we do not enable them by default. But they can still be enabled via the semaphores=1 kernel parameter. v2: enables semaphores on SNB when IO remapping is disabled, with base on Keith Packard patch. CC: Daniel Vetter <daniel.vetter@ffwll.ch> CC: Ben Widawsky <ben@bwidawsk.net> CC: Keith Packard <keithp@keithp.com> CC: Jesse Barnes <jbarnes@virtuousgeek.org> CC: Chris Wilson <chris@chris-wilson.co.uk> Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=42696 Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=40564 Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=41353 Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=38862 Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-12-16drm/i915: don't set unpin_work if vblank_get failsJesse Barnes
This fixes a race where we may try to finish a page flip and decrement the refcount even if our vblank_get failed and we ended up with a spurious flip pending interrupt. Fixes https://bugs.freedesktop.org/show_bug.cgi?id=34211. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-12-16drm/i915: By default, enable RC6 on IVB and SNB when reasonableKeith Packard
RC6 should always work on IVB, and should work on SNB whenever IO remapping is disabled. RC6 never works on Ironlake. Make the default value for the parameter follow these guidelines. Setting the value to either 0 or 1 will force the specified behavior. Signed-off-by: Keith Packard <keithp@keithp.com> Reviewed-by: Kenneth Graunke <kenneth@whitecape.org> Reviewed-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=38567 Cc: Ted Phelps <phelps@gnusto.com> Cc: Peter <pab1612@gmail.com> Cc: Lukas Hejtmanek <xhejtman@fi.muni.cz> Cc: Andrew Lutomirski <luto@mit.edu>
2011-12-16iommu: Export intel_iommu_enabled to signal when iommu is in useEugeni Dodonov
In i915 driver, we do not enable either rc6 or semaphores on SNB when dmar is enabled. The new 'intel_iommu_enabled' variable signals when the iommu code is in operation. Cc: Ted Phelps <phelps@gnusto.com> Cc: Peter <pab1612@gmail.com> Cc: Lukas Hejtmanek <xhejtman@fi.muni.cz> Cc: Andrew Lutomirski <luto@mit.edu> CC: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-12-16drm/i915/sdvo: Include LVDS panels for the IS_DIGITAL checkChris Wilson
We were checking whether the supplied edid matched the connector it was read from. We do this in case a DDC read returns an EDID for another device on a multifunction or otherwise interesting card. However, we failed to include LVDS as a digital device and so rejecting an otherwise valid EDID. Fixes the detection of the secondary SDVO LVDS panel on the Libretto W105. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Reviewed-by: Adam Jackson <ajax@redhat.com> Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=39216 Signed-off-by: Keith Packard <keithp@keithp.com>
2011-12-16drm/i915: prevent division by zero when asking for chipset powerEugeni Dodonov
This prevents an in-kernel division by zero which happens when we are asking for i915_chipset_val too quickly, or within a race condition between the power monitoring thread and userspace accesses via debugfs. The issue can be reproduced easily via the following command: while ``; do cat /sys/kernel/debug/dri/0/i915_emon_status; done This is particularly dangerous because it can be triggered by a non-privileged user by just reading the debugfs entry. This issue was also found independently by Konstantin Belousov <kostikbel@gmail.com>, who proposed a similar patch. Reported-by: Konstantin Belousov <kostikbel@gmail.com> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Acked-by: Keith Packard <keithp@keithp.com> Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: <stable@vger.kernel.org> Signed-off-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-12-16drm/i915: add PCH info to i915_capabilitiesPaulo Zanoni
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Paulo Zanoni <paulo.r.zanoni@intel.com> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-12-16drm/i915: set the right SDVO transcoder for CPTPaulo Zanoni
v2: add a CPT-specific macro, make code cleaner v3: fix commit message Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=41272 Cc: stable@kernel.org Signed-off-by: Paulo Zanoni <paulo.r.zanoni@intel.com> Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-12-16drm/i915: no-lvds quirk for ASUS AT5NM10T-IAdam Jackson
https://bugzilla.redhat.com/show_bug.cgi?id=750006 Signed-off-by: Adam Jackson <ajax@redhat.com> Signed-off-by: Keith Packard <keithp@keithp.com>
2011-12-15Merge branch 'samsung-fixes-3' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into fixes
2011-12-15Merge branch 'fixes' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes
2011-12-15Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/ibft * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/ibft: ibft: Fix finding IBFT ACPI table on UEFI
2011-12-15Merge branch 'staging-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging * 'staging-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: staging: r8712u: Add new USB ID staging: tidspbridge: request dmtimer clocks on init staging: tidspbridge: include module.h by default
2011-12-15Merge branch 'usb-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb * 'usb-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: USB: option: Removing one bogus and adding some new Huawei combinations USB: cdc-acm: add IDs for Motorola H24 HSPA USB module. usb: option: Add Huawei E398 controlling interfaces usb: renesas_usbhs: add hcd->has_tt for low/full speed usb: renesas_usbhs: typofix: irq_dtch control DTCHE usb: gadget: storage: release superspeed descriptors.
2011-12-15ARM: unwinder: fix bisection to find origin in .idx sectionUwe Kleine-König
The bisection implemented in unwind_find_origin() stopped to early. If there is only a single entry left to check the original code just took the end point as origin which might be wrong. This was introduced in commit de66a979012d ("ARM: 7187/1: fix unwinding for XIP kernels"). Reported-and-tested-by: Nick Bowler <nbowler@elliptictech.com> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-12-15Btrfs: unplug every once and a whileChris Mason
The btrfs io submission threads can build up massive plug lists. This keeps things more reasonable so we don't hand over huge dumps of IO at once. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-12-15block: don't kick empty queue in blk_drain_queue()Tejun Heo
While probing, fd sets up queue, probes hardware and tears down the queue if probing fails. In the process, blk_drain_queue() kicks the queue which failed to finish initialization and fd is unhappy about that. floppy0: no floppy controllers found ------------[ cut here ]------------ WARNING: at drivers/block/floppy.c:2929 do_fd_request+0xbf/0xd0() Hardware name: To Be Filled By O.E.M. VFS: do_fd_request called on non-open device Modules linked in: Pid: 1, comm: swapper Not tainted 3.2.0-rc4-00077-g5983fe2 #2 Call Trace: [<ffffffff81039a6a>] warn_slowpath_common+0x7a/0xb0 [<ffffffff81039b41>] warn_slowpath_fmt+0x41/0x50 [<ffffffff813d657f>] do_fd_request+0xbf/0xd0 [<ffffffff81322b95>] blk_drain_queue+0x65/0x80 [<ffffffff81322c93>] blk_cleanup_queue+0xe3/0x1a0 [<ffffffff818a809d>] floppy_init+0xdeb/0xe28 [<ffffffff818a72b2>] ? daring+0x6b/0x6b [<ffffffff810002af>] do_one_initcall+0x3f/0x170 [<ffffffff81884b34>] kernel_init+0x9d/0x11e [<ffffffff810317c2>] ? schedule_tail+0x22/0xa0 [<ffffffff815dbb14>] kernel_thread_helper+0x4/0x10 [<ffffffff81884a97>] ? start_kernel+0x2be/0x2be [<ffffffff815dbb10>] ? gs_change+0xb/0xb Avoid it by making blk_drain_queue() kick queue iff dispatch queue has something on it. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Ralf Hildebrandt <Ralf.Hildebrandt@charite.de> Reported-by: Wu Fengguang <fengguang.wu@intel.com> Tested-by: Sergei Trofimovich <slyich@gmail.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-12-15Merge branch 'stable/for-linus-fixes-3.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/for-linus-fixes-3.2' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/swiotlb: Use page alignment for early buffer allocation. xen: only limit memory map to maximum reservation for domain 0.
2011-12-15Merge branch 'for-chris' of ↵Chris Mason
http://git.kernel.org/pub/scm/linux/kernel/git/josef/btrfs-work into integration Conflicts: fs/btrfs/inode.c Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-12-15Btrfs: deal with NULL srv_rsv in the delalloc inode reservation codeChris Mason
btrfs_update_inode is sometimes called with a null reservation. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-12-15gpio: Fix DA9052 GPIO build errors.Ashish Jangam
This patch is functionally tested on Samsung SMDKV6410. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David Dajun Chen <dchen@diasemi.com> Signed-off-by: Ashish Jangam <ashish.jangam@kpitcummins.com> [grant.likely: don't create an unnecessary header file] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-12-15xen/swiotlb: Use page alignment for early buffer allocation.Konrad Rzeszutek Wilk
This fixes an odd bug found on a Dell PowerEdge 1850/0RC130 (BIOS A05 01/09/2006) where all of the modules doing pci_set_dma_mask would fail with: ata_piix 0000:00:1f.1: enabling device (0005 -> 0007) ata_piix 0000:00:1f.1: can't derive routing for PCI INT A ata_piix 0000:00:1f.1: BMDMA: failed to set dma mask, falling back to PIO The issue was the Xen-SWIOTLB was allocated such as that the end of buffer was stradling a page (and also above 4GB). The fix was spotted by Kalev Leonid which was to piggyback on git commit e79f86b2ef9c0a8c47225217c1018b7d3d90101c "swiotlb: Use page alignment for early buffer allocation" which: We could call free_bootmem_late() if swiotlb is not used, and it will shrink to page alignment. So alloc them with page alignment at first, to avoid lose two pages And doing that fixes the outstanding issue. CC: stable@kernel.org Suggested-by: "Kalev, Leonid" <Leonid.Kalev@ca.com> Reported-and-Tested-by: "Taylor, Neal E" <Neal.Taylor@ca.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-12-15xen: only limit memory map to maximum reservation for domain 0.Ian Campbell
d312ae878b6a "xen: use maximum reservation to limit amount of usable RAM" clamped the total amount of RAM to the current maximum reservation. This is correct for dom0 but is not correct for guest domains. In order to boot a guest "pre-ballooned" (e.g. with memory=1G but maxmem=2G) in order to allow for future memory expansion the guest must derive max_pfn from the e820 provided by the toolstack and not the current maximum reservation (which can reflect only the current maximum, not the guest lifetime max). The existing algorithm already behaves this correctly if we do not artificially limit the maximum number of pages for the guest case. For a guest booted with maxmem=512, memory=128 this results in: [ 0.000000] BIOS-provided physical RAM map: [ 0.000000] Xen: 0000000000000000 - 00000000000a0000 (usable) [ 0.000000] Xen: 00000000000a0000 - 0000000000100000 (reserved) -[ 0.000000] Xen: 0000000000100000 - 0000000008100000 (usable) -[ 0.000000] Xen: 0000000008100000 - 0000000020800000 (unusable) +[ 0.000000] Xen: 0000000000100000 - 0000000020800000 (usable) ... [ 0.000000] NX (Execute Disable) protection: active [ 0.000000] DMI not present or invalid. [ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved) [ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable) -[ 0.000000] last_pfn = 0x8100 max_arch_pfn = 0x1000000 +[ 0.000000] last_pfn = 0x20800 max_arch_pfn = 0x1000000 [ 0.000000] initial memory mapped : 0 - 027ff000 [ 0.000000] Base memory trampoline at [c009f000] 9f000 size 4096 -[ 0.000000] init_memory_mapping: 0000000000000000-0000000008100000 -[ 0.000000] 0000000000 - 0008100000 page 4k -[ 0.000000] kernel direct mapping tables up to 8100000 @ 27bb000-27ff000 +[ 0.000000] init_memory_mapping: 0000000000000000-0000000020800000 +[ 0.000000] 0000000000 - 0020800000 page 4k +[ 0.000000] kernel direct mapping tables up to 20800000 @ 26f8000-27ff000 [ 0.000000] xen: setting RW the range 27e8000 - 27ff000 [ 0.000000] 0MB HIGHMEM available. -[ 0.000000] 129MB LOWMEM available. -[ 0.000000] mapped low ram: 0 - 08100000 -[ 0.000000] low ram: 0 - 08100000 +[ 0.000000] 520MB LOWMEM available. +[ 0.000000] mapped low ram: 0 - 20800000 +[ 0.000000] low ram: 0 - 20800000 With this change "xl mem-set <domain> 512M" will successfully increase the guest RAM (by reducing the balloon). There is no change for dom0. Reported-and-Tested-by: George Shuklin <george.shuklin@gmail.com> Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Cc: stable@kernel.org Reviewed-by: David Vrabel <david.vrabel@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-12-15Btrfs: only set cache_generation if we setup the block groupJosef Bacik
A user reported a problem booting into a new kernel with the old format inodes. He was panicing in cow_file_range while writing out the inode cache. This is because if the block group is not cached we'll just skip writing out the cache, however if it gets dirtied again in the same transaction and it finished caching we'd go ahead and write it out, but since we set cache_generation to the transid we think we've already truncated it and will just carry on, running into cow_file_range and blowing up. We need to make sure we only set cache_generation if we've done the truncate. The user tested this patch and verified that the panic no longer occured. Thanks, Reported-and-Tested-by: Klaus Bitto <klaus.bitto@gmail.com> Signed-off-by: Josef Bacik <josef@redhat.com>
2011-12-15Btrfs: don't panic if orphan item already existsJosef Bacik
I've been hitting this BUG_ON() in btrfs_orphan_add when running xfstest 269 in a loop. This is because we will add an orphan item, do the truncate, the truncate will fail for whatever reason (*cough*ENOSPC*cough*) and then we're left with an orphan item still in the fs. Then we come back later to do another truncate and it blows up because we already have an orphan item. This is ok so just fix the BUG_ON() to only BUG() if ret is not EEXIST. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com>
2011-12-15Btrfs: fix leaked space in truncateJosef Bacik
We were occasionaly leaking space when running xfstest 269. This is because if we failed to start the transaction in the truncate loop we'd just goto out, but we need to break so that the inode is removed from the orphan list and the space is properly freed. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com>
2011-12-15Btrfs: fix how we do delalloc reservations and how we free reservations on errorJosef Bacik
Running xfstests 269 with some tracing my scripts kept spitting out errors about releasing bytes that we didn't actually have reserved. This took me down a huge rabbit hole and it turns out the way we deal with reserved_extents is wrong, we need to only be setting it if the reservation succeeds, otherwise the free() method will come in and unreserve space that isn't actually reserved yet, which can lead to other warnings and such. The math was all working out right in the end, but it caused all sorts of other issues in addition to making my scripts yell and scream and generally make it impossible for me to track down the original issue I was looking for. The other problem is with our error handling in the reservation code. There are two cases that we need to deal with 1) We raced with free. In this case free won't free anything because csum_bytes is modified before we dro the lock in our reservation path, so free rightly doesn't release any space because the reservation code may be depending on that reservation. However if we fail, we need the reservation side to do the free at that point since that space is no longer in use. So as it stands the code was doing this fine and it worked out, except in case #2 2) We don't race with free. Nobody comes in and changes anything, and our reservation fails. In this case we didn't reserve anything anyway and we just need to clean up csum_bytes but not free anything. So we keep track of csum_bytes before we drop the lock and if it hasn't changed we know we can just decrement csum_bytes and carry on. Because of the case where we can race with free()'s since we have to drop our spin_lock to do the reservation, I'm going to serialize all reservations with the i_mutex. We already get this for free in the heavy use paths, truncate and file write all hold the i_mutex, just needed to add it to page_mkwrite and various ioctl/balance things. With this patch my space leak scripts no longer scream bloody murder. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com>
2011-12-15Btrfs: deal with enospc from dirtying inodes properlyJosef Bacik
Now that we're properly keeping track of delayed inode space we've been getting a lot of warnings out of btrfs_dirty_inode() when running xfstest 83. This is because a bunch of people call mark_inode_dirty, which is void so we can't return ENOSPC. This needs to be fixed in a few areas 1) file_update_time - this updates the mtime and such when writing to a file, which will call mark_inode_dirty. So copy file_update_time into btrfs so we can call btrfs_dirty_inode directly and return an error if we get one appropriately. 2) fix symlinks to use btrfs_setattr for ->setattr. For some reason we weren't setting ->setattr for symlinks, even though we should have been. This catches one of the cases where we were getting errors in mark_inode_dirty. 3) Fix btrfs_setattr and btrfs_setsize to call btrfs_dirty_inode directly instead of mark_inode_dirty. This lets us return errors properly for truncate and chown/anything related to setattr. 4) Add a new btrfs_fs_dirty_inode which will just call btrfs_dirty_inode and print an error if we have one. The only remaining user we can't control for this is touch_atime(), but we don't really want to keep people from walking down the tree if we don't have space to save the atime update, so just complain but don't worry about it. With this patch xfstests 83 complains a handful of times instead of hundreds of times. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com>
2011-12-15Btrfs: fix num_workers_starting bug and other bugs in async threadJosef Bacik
Al pointed out we have some random problems with the way we account for num_workers_starting in the async thread stuff. First of all we need to make sure to decrement num_workers_starting if we fail to start the worker, so make __btrfs_start_workers do this. Also fix __btrfs_start_workers so that it doesn't call btrfs_stop_workers(), there is no point in stopping everybody if we failed to create a worker. Also check_pending_worker_creates needs to call __btrfs_start_work in it's work function since it already increments num_workers_starting. People only start one worker at a time, so get rid of the num_workers argument everywhere, and make btrfs_queue_worker a void since it will always succeed. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com>
2011-12-15BTRFS: Establish i_ops before calling d_instantiateCasey Schaufler
The Smack LSM hook for security_d_instantiate checks the inode's i_op->getxattr value to determine if the containing filesystem supports extended attributes. The BTRFS filesystem sets the inode's i_op value only after it has instantiated the inode. This results in Smack incorrectly giving new BTRFS inodes attributes from the filesystem defaults on the assumption that values can't be stored on the filesystem. This patch moves the assignment of inode operation vectors ahead of the calls to d_instantiate, letting Smack know that the filesystem supports extended attributes. There should be no impact on the performance or behavior of BTRFS. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-12-15Btrfs: add a cond_resched() into the worker loopChris Mason
If we have a constant stream of end_io completions or crc work, we can hit softlockup messages from the async helper threads. This adds a cond_resched() into the loop to avoid them. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-12-15Btrfs: fix ctime update of on-disk inodeLi Zefan
To reproduce the bug: # touch /mnt/tmp # stat /mnt/tmp | grep Change Change: 2011-12-09 09:32:23.412105981 +0800 # chattr +i /mnt/tmp # stat /mnt/tmp | grep Change Change: 2011-12-09 09:32:43.198105295 +0800 # umount /mnt # mount /dev/loop1 /mnt # stat /mnt/tmp | grep Change Change: 2011-12-09 09:32:23.412105981 +0800 We should update ctime of in-memory inode before calling btrfs_update_inode(). Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-12-15btrfs: keep orphans for subvolume deletionArne Jansen
Since we have the free space caches, btrfs_orphan_cleanup also runs for the tree_root. Unfortunately this also cleans up the orphans used to mark subvol deletions in progress. Currently if a subvol deletion gets interrupted twice by umount/mount, the deletion will not be continued and the space permanently lost, though it would be possible to write a tool to recover those lost subvol deletions. This patch checks if the orphan belongs to a subvol (dead root) and skips the deletion. Signed-off-by: Arne Jansen <sensille@gmx.net> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-12-15Btrfs: fix inaccurate available space on raid0 profileMiao Xie
When we use raid0 as the data profile, df command may show us a very inaccurate value of the available space, which may be much less than the real one. It may make the users puzzled. Fix it by changing the calculation of the available space, and making it be more similar to a fake chunk allocation. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-12-15Btrfs: fix wrong disk space information of the filesMiao Xie
Btrfsck report errors after the 83th case of xfstests was run, The error number is 400, it means the used disk space of the file is wrong. The reason of this bug is that: The file truncation may fail when the space of the file system is not enough, and leave some file extents, whose offset are beyond the end of the files. When we want to expand those files, we will drop those file extents, and put in dummy file extents, and then we should update the i-node. But btrfs forgets to do it. This patch adds the forgotten i-node update. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-12-15Btrfs: fix wrong i_size when truncating a file to a larger sizeMiao Xie
Btrfsck report error 100 after the 83th case of xfstests was run, it means the i_size of the file is wrong. The reason of this bug is that: Btrfs increased i_size of the file at the beginning, but it failed to expand the file, and failed to update the i_size to the old size because there is no enough space in the file system, so we found a wrong i_size. This patch fixes this bug by updating the i_size just when we pass the file expanding and get enough space to update i-node. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-12-15Merge branch 'fix/asoc' into for-linusTakashi Iwai
2011-12-15ALSA: HDA: Use LPIB Position fix for Intel SCH PoulsboDavid Henningsson
Several people with this chipset have reported inconsistent/sloppy values for position reporting when the DMA position buffer is used, and that setting position_fix=1 have fixed their problems. BugLink: https://bugs.launchpad.net/bugs/825709 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
