2015-12-15Linux 3.18.25v3.18.25Sasha Levin
2015-12-14ipv6: sctp: implement sctp_v6_destroy_sock()Eric Dumazet
[ Upstream commit 602dd62dfbda3e63a2d6a3cbde953ebe82bf5087 ] Dmitry Vyukov reported a memory leak using IPV6 SCTP sockets. We need to call inet6_destroy_sock() to properly release inet6 specific fields. Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-14net/neighbour: fix crash at dumping device-agnostic proxy entriesKonstantin Khlebnikov
[ Upstream commit 6adc5fd6a142c6e2c80574c1db0c7c17dedaa42e ] Proxy entries could have null pointer to net-device. Signed-off-by: Konstantin Khlebnikov <koct9i@gmail.com> Fixes: 84920c1420e2 ("net: Allow ipv6 proxies and arp proxies be shown with iproute2") Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-14ipv6: add complete rcu protection around np->optEric Dumazet
[ Upstream commit 45f6fad84cc305103b28d73482b344d7f5b76f39 ] This patch addresses multiple problems : UDP/RAW sendmsg() need to get a stable struct ipv6_txoptions while socket is not locked : Other threads can change np->opt concurrently. Dmitry posted a syzkaller (http://github.com/google/syzkaller) program desmonstrating use-after-free. Starting with TCP/DCCP lockless listeners, tcp_v6_syn_recv_sock() and dccp_v6_request_recv_sock() also need to use RCU protection to dereference np->opt once (before calling ipv6_dup_options()) This patch adds full RCU protection to np->opt Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-14ipv6: distinguish frag queues by device for multicast and link-local packetsMichal Kubeček
[ Upstream commit 264640fc2c5f4f913db5c73fa3eb1ead2c45e9d7 ] If a fragmented multicast packet is received on an ethernet device which has an active macvlan on top of it, each fragment is duplicated and received both on the underlying device and the macvlan. If some fragments for macvlan are processed before the whole packet for the underlying device is reassembled, the "overlapping fragments" test in ip6_frag_queue() discards the whole fragment queue. To resolve this, add device ifindex to the search key and require it to match reassembling multicast packets and packets to link-local addresses. Note: similar patch has been already submitted by Yoshifuji Hideaki in http://patchwork.ozlabs.org/patch/220979/ but got lost and forgotten for some reason. Signed-off-by: Michal Kubecek <mkubecek@suse.cz> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-14broadcom: fix PHY_ID_BCM5481 entry in the id tableAaro Koskinen
[ Upstream commit 3c25a860d17b7378822f35d8c9141db9507e3beb ] Commit fcb26ec5b18d ("broadcom: move all PHY_ID's to header") updated broadcom_tbl to use PHY_IDs, but incorrectly replaced 0x0143bca0 with PHY_ID_BCM5482 (making a duplicate entry, and completely omitting the original). Fix that. Fixes: fcb26ec5b18d ("broadcom: move all PHY_ID's to header") Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-14net: ip6mr: fix static mfc/dev leaks on table destructionNikolay Aleksandrov
[ Upstream commit 4c6980462f32b4f282c5d8e5f7ea8070e2937725 ] Similar to ipv4, when destroying an mrt table the static mfc entries and the static devices are kept, which leads to devices that can never be destroyed (because of refcnt taken) and leaked memory. Make sure that everything is cleaned up on netns destruction. Fixes: 8229efdaef1e ("netns: ip6mr: enable namespace support in ipv6 multicast forwarding code") CC: Benjamin Thery <benjamin.thery@bull.net> Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com> Reviewed-by: Cong Wang <cwang@twopensource.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-14net: ipmr: fix static mfc/dev leaks on table destructionNikolay Aleksandrov
[ Upstream commit 0e615e9601a15efeeb8942cf7cd4dadba0c8c5a7 ] When destroying an mrt table the static mfc entries and the static devices are kept, which leads to devices that can never be destroyed (because of refcnt taken) and leaked memory, for example: unreferenced object 0xffff880034c144c0 (size 192): comm "mfc-broken", pid 4777, jiffies 4320349055 (age 46001.964s) hex dump (first 32 bytes): 98 53 f0 34 00 88 ff ff 98 53 f0 34 00 88 ff ff .S.4.....S.4.... ef 0a 0a 14 01 02 03 04 00 00 00 00 01 00 00 00 ................ backtrace: [<ffffffff815c1b9e>] kmemleak_alloc+0x4e/0xb0 [<ffffffff811ea6e0>] kmem_cache_alloc+0x190/0x300 [<ffffffff815931cb>] ip_mroute_setsockopt+0x5cb/0x910 [<ffffffff8153d575>] do_ip_setsockopt.isra.11+0x105/0xff0 [<ffffffff8153e490>] ip_setsockopt+0x30/0xa0 [<ffffffff81564e13>] raw_setsockopt+0x33/0x90 [<ffffffff814d1e14>] sock_common_setsockopt+0x14/0x20 [<ffffffff814d0b51>] SyS_setsockopt+0x71/0xc0 [<ffffffff815cdbf6>] entry_SYSCALL_64_fastpath+0x16/0x7a [<ffffffffffffffff>] 0xffffffffffffffff Make sure that everything is cleaned on netns destruction. Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com> Reviewed-by: Cong Wang <cwang@twopensource.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-14net, scm: fix PaX detected msg_controllen overflow in scm_detach_fdsDaniel Borkmann
[ Upstream commit 6900317f5eff0a7070c5936e5383f589e0de7a09 ] David and HacKurx reported a following/similar size overflow triggered in a grsecurity kernel, thanks to PaX's gcc size overflow plugin: (Already fixed in later grsecurity versions by Brad and PaX Team.) [ 1002.296137] PAX: size overflow detected in function scm_detach_fds net/core/scm.c:314 cicus.202_127 min, count: 4, decl: msg_controllen; num: 0; context: msghdr; [ 1002.296145] CPU: 0 PID: 3685 Comm: scm_rights_recv Not tainted 4.2.3-grsec+ #7 [ 1002.296149] Hardware name: Apple Inc. MacBookAir5,1/Mac-66F35F19FE2A0D05, [...] [ 1002.296153] ffffffff81c27366 0000000000000000 ffffffff81c27375 ffffc90007843aa8 [ 1002.296162] ffffffff818129ba 0000000000000000 ffffffff81c27366 ffffc90007843ad8 [ 1002.296169] ffffffff8121f838 fffffffffffffffc fffffffffffffffc ffffc90007843e60 [ 1002.296176] Call Trace: [ 1002.296190] [<ffffffff818129ba>] dump_stack+0x45/0x57 [ 1002.296200] [<ffffffff8121f838>] report_size_overflow+0x38/0x60 [ 1002.296209] [<ffffffff816a979e>] scm_detach_fds+0x2ce/0x300 [ 1002.296220] [<ffffffff81791899>] unix_stream_read_generic+0x609/0x930 [ 1002.296228] [<ffffffff81791c9f>] unix_stream_recvmsg+0x4f/0x60 [ 1002.296236] [<ffffffff8178dc00>] ? unix_set_peek_off+0x50/0x50 [ 1002.296243] [<ffffffff8168fac7>] sock_recvmsg+0x47/0x60 [ 1002.296248] [<ffffffff81691522>] ___sys_recvmsg+0xe2/0x1e0 [ 1002.296257] [<ffffffff81693496>] __sys_recvmsg+0x46/0x80 [ 1002.296263] [<ffffffff816934fc>] SyS_recvmsg+0x2c/0x40 [ 1002.296271] [<ffffffff8181a3ab>] entry_SYSCALL_64_fastpath+0x12/0x85 Further investigation showed that this can happen when an *odd* number of fds are being passed over AF_UNIX sockets. In these cases CMSG_LEN(i * sizeof(int)) and CMSG_SPACE(i * sizeof(int)), where i is the number of successfully passed fds, differ by 4 bytes due to the extra CMSG_ALIGN() padding in CMSG_SPACE() to an 8 byte boundary on 64 bit. The padding is used to align subsequent cmsg headers in the control buffer. When the control buffer passed in from the receiver side *lacks* these 4 bytes (e.g. due to buggy/wrong API usage), then msg->msg_controllen will overflow in scm_detach_fds(): int cmlen = CMSG_LEN(i * sizeof(int)); <--- cmlen w/o tail-padding err = put_user(SOL_SOCKET, &cm->cmsg_level); if (!err) err = put_user(SCM_RIGHTS, &cm->cmsg_type); if (!err) err = put_user(cmlen, &cm->cmsg_len); if (!err) { cmlen = CMSG_SPACE(i * sizeof(int)); <--- cmlen w/ 4 byte extra tail-padding msg->msg_control += cmlen; msg->msg_controllen -= cmlen; <--- iff no tail-padding space here ... } ... wrap-around F.e. it will wrap to a length of 18446744073709551612 bytes in case the receiver passed in msg->msg_controllen of 20 bytes, and the sender properly transferred 1 fd to the receiver, so that its CMSG_LEN results in 20 bytes and CMSG_SPACE in 24 bytes. In case of MSG_CMSG_COMPAT (scm_detach_fds_compat()), I haven't seen an issue in my tests as alignment seems always on 4 byte boundary. Same should be in case of native 32 bit, where we end up with 4 byte boundaries as well. In practice, passing msg->msg_controllen of 20 to recvmsg() while receiving a single fd would mean that on successful return, msg->msg_controllen is being set by the kernel to 24 bytes instead, thus more than the input buffer advertised. It could f.e. become an issue if such application later on zeroes or copies the control buffer based on the returned msg->msg_controllen elsewhere. Maximum number of fds we can send is a hard upper limit SCM_MAX_FD (253). Going over the code, it seems like msg->msg_controllen is not being read after scm_detach_fds() in scm_recv() anymore by the kernel, good! Relevant recvmsg() handler are unix_dgram_recvmsg() (unix_seqpacket_recvmsg()) and unix_stream_recvmsg(). Both return back to their recvmsg() caller, and ___sys_recvmsg() places the updated length, that is, new msg_control - old msg_control pointer into msg->msg_controllen (hence the 24 bytes seen in the example). Long time ago, Wei Yongjun fixed something related in commit 1ac70e7ad24a ("[NET]: Fix function put_cmsg() which may cause usr application memory overflow"). RFC3542, section 20.2. says: The fields shown as "XX" are possible padding, between the cmsghdr structure and the data, and between the data and the next cmsghdr structure, if required by the implementation. While sending an application may or may not include padding at the end of last ancillary data in msg_controllen and implementations must accept both as valid. On receiving a portable application must provide space for padding at the end of the last ancillary data as implementations may copy out the padding at the end of the control message buffer and include it in the received msg_controllen. When recvmsg() is called if msg_controllen is too small for all the ancillary data items including any trailing padding after the last item an implementation may set MSG_CTRUNC. Since we didn't place MSG_CTRUNC for already quite a long time, just do the same as in 1ac70e7ad24a to avoid an overflow. Btw, even man-page author got this wrong :/ See db939c9b26e9 ("cmsg.3: Fix error in SCM_RIGHTS code sample"). Some people must have copied this (?), thus it got triggered in the wild (reported several times during boot by David and HacKurx). No Fixes tag this time as pre 2002 (that is, pre history tree). Reported-by: David Sterba <dave@jikos.cz> Reported-by: HacKurx <hackurx@gmail.com> Cc: PaX Team <pageexec@freemail.hu> Cc: Emese Revfy <re.emese@gmail.com> Cc: Brad Spengler <spender@grsecurity.net> Cc: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Cc: Eric Dumazet <edumazet@google.com> Reviewed-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-14tcp: initialize tp->copied_seq in case of cross SYN connectionEric Dumazet
[ Upstream commit 142a2e7ece8d8ac0e818eb2c91f99ca894730e2a ] Dmitry provided a syzkaller (http://github.com/google/syzkaller) generated program that triggers the WARNING at net/ipv4/tcp.c:1729 in tcp_recvmsg() : WARN_ON(tp->copied_seq != tp->rcv_nxt && !(flags & (MSG_PEEK | MSG_TRUNC))); His program is specifically attempting a Cross SYN TCP exchange, that we support (for the pleasure of hackers ?), but it looks we lack proper tcp->copied_seq initialization. Thanks again Dmitry for your report and testings. Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Dmitry Vyukov <dvyukov@google.com> Tested-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-14tcp: fix potential huge kmalloc() calls in TCP_REPAIREric Dumazet
[ Upstream commit 5d4c9bfbabdb1d497f21afd81501e5c54b0c85d9 ] tcp_send_rcvq() is used for re-injecting data into tcp receive queue. Problems : - No check against size is performed, allowed user to fool kernel in attempting very large memory allocations, eventually triggering OOM when memory is fragmented. - In case of fault during the copy we do not return correct errno. Lets use alloc_skb_with_frags() to cook optimal skbs. Fixes: 292e8d8c8538 ("tcp: Move rcvq sending to tcp_input.c") Fixes: c0e88ff0f256 ("tcp: Repair socket queues") Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Pavel Emelyanov <xemul@parallels.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-14tcp: md5: fix lockdep annotationEric Dumazet
[ Upstream commit 1b8e6a01e19f001e9f93b39c32387961c91ed3cc ] When a passive TCP is created, we eventually call tcp_md5_do_add() with sk pointing to the child. It is not owner by the user yet (we will add this socket into listener accept queue a bit later anyway) But we do own the spinlock, so amend the lockdep annotation to avoid following splat : [ 8451.090932] net/ipv4/tcp_ipv4.c:923 suspicious rcu_dereference_protected() usage! [ 8451.090932] [ 8451.090932] other info that might help us debug this: [ 8451.090932] [ 8451.090934] [ 8451.090934] rcu_scheduler_active = 1, debug_locks = 1 [ 8451.090936] 3 locks held by socket_sockopt_/214795: [ 8451.090936] #0: (rcu_read_lock){.+.+..}, at: [<ffffffff855c6ac1>] __netif_receive_skb_core+0x151/0xe90 [ 8451.090947] #1: (rcu_read_lock){.+.+..}, at: [<ffffffff85618143>] ip_local_deliver_finish+0x43/0x2b0 [ 8451.090952] #2: (slock-AF_INET){+.-...}, at: [<ffffffff855acda5>] sk_clone_lock+0x1c5/0x500 [ 8451.090958] [ 8451.090958] stack backtrace: [ 8451.090960] CPU: 7 PID: 214795 Comm: socket_sockopt_ [ 8451.091215] Call Trace: [ 8451.091216] <IRQ> [<ffffffff856fb29c>] dump_stack+0x55/0x76 [ 8451.091229] [<ffffffff85123b5b>] lockdep_rcu_suspicious+0xeb/0x110 [ 8451.091235] [<ffffffff8564544f>] tcp_md5_do_add+0x1bf/0x1e0 [ 8451.091239] [<ffffffff85645751>] tcp_v4_syn_recv_sock+0x1f1/0x4c0 [ 8451.091242] [<ffffffff85642b27>] ? tcp_v4_md5_hash_skb+0x167/0x190 [ 8451.091246] [<ffffffff85647c78>] tcp_check_req+0x3c8/0x500 [ 8451.091249] [<ffffffff856451ae>] ? tcp_v4_inbound_md5_hash+0x11e/0x190 [ 8451.091253] [<ffffffff85647170>] tcp_v4_rcv+0x3c0/0x9f0 [ 8451.091256] [<ffffffff85618143>] ? ip_local_deliver_finish+0x43/0x2b0 [ 8451.091260] [<ffffffff856181b6>] ip_local_deliver_finish+0xb6/0x2b0 [ 8451.091263] [<ffffffff85618143>] ? ip_local_deliver_finish+0x43/0x2b0 [ 8451.091267] [<ffffffff85618d38>] ip_local_deliver+0x48/0x80 [ 8451.091270] [<ffffffff85618510>] ip_rcv_finish+0x160/0x700 [ 8451.091273] [<ffffffff8561900e>] ip_rcv+0x29e/0x3d0 [ 8451.091277] [<ffffffff855c74b7>] __netif_receive_skb_core+0xb47/0xe90 Fixes: a8afca0329988 ("tcp: md5: protects md5sig_info with RCU") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-14net: qmi_wwan: add XS Stick W100-2 from 4G SystemsBjørn Mork
[ Upstream commit 68242a5a1e2edce39b069385cbafb82304eac0f1 ] Thomas reports " 4gsystems sells two total different LTE-surfsticks under the same name. .. The newer version of XS Stick W100 is from "omega" .. Under windows the driver switches to the same ID, and uses MI03\6 for network and MI01\6 for modem. .. echo "1c9e 9b01" > /sys/bus/usb/drivers/qmi_wwan/new_id echo "1c9e 9b01" > /sys/bus/usb-serial/drivers/option1/new_id T: Bus=01 Lev=01 Prnt=01 Port=03 Cnt=01 Dev#= 4 Spd=480 MxCh= 0 D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1 P: Vendor=1c9e ProdID=9b01 Rev=02.32 S: Manufacturer=USB Modem S: Product=USB Modem S: SerialNumber= C: #Ifs= 5 Cfg#= 1 Atr=80 MxPwr=500mA I: If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=option I: If#= 1 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=option I: If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=option I: If#= 3 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=qmi_wwan I: If#= 4 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage Now all important things are there: wwp0s29f7u2i3 (net), ttyUSB2 (at), cdc-wdm0 (qmi), ttyUSB1 (at) There is also ttyUSB0, but it is not usable, at least not for at. The device works well with qmi and ModemManager-NetworkManager. " Reported-by: Thomas Schäfer <tschaefer@t-online.de> Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-14snmp: Remove duplicate OUTMCAST stat incrementNeil Horman
[ Upstream commit 41033f029e393a64e81966cbe34d66c6cf8a2e7e ] the OUTMCAST stat is double incremented, getting bumped once in the mcast code itself, and again in the common ip output path. Remove the mcast bump, as its not needed Validated by the reporter, with good results Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Reported-by: Claus Jensen <claus.jensen@microsemi.com> CC: Claus Jensen <claus.jensen@microsemi.com> CC: David Miller <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-14ip_tunnel: disable preemption when updating per-cpu tstatsJason A. Donenfeld
[ Upstream commit b4fe85f9c9146f60457e9512fb6055e69e6a7a65 ] Drivers like vxlan use the recently introduced udp_tunnel_xmit_skb/udp_tunnel6_xmit_skb APIs. udp_tunnel6_xmit_skb makes use of ip6tunnel_xmit, and ip6tunnel_xmit, after sending the packet, updates the struct stats using the usual u64_stats_update_begin/end calls on this_cpu_ptr(dev->tstats). udp_tunnel_xmit_skb makes use of iptunnel_xmit, which doesn't touch tstats, so drivers like vxlan, immediately after, call iptunnel_xmit_stats, which does the same thing - calls u64_stats_update_begin/end on this_cpu_ptr(dev->tstats). While vxlan is probably fine (I don't know?), calling a similar function from, say, an unbound workqueue, on a fully preemptable kernel causes real issues: [ 188.434537] BUG: using smp_processor_id() in preemptible [00000000] code: kworker/u8:0/6 [ 188.435579] caller is debug_smp_processor_id+0x17/0x20 [ 188.435583] CPU: 0 PID: 6 Comm: kworker/u8:0 Not tainted 4.2.6 #2 [ 188.435607] Call Trace: [ 188.435611] [<ffffffff8234e936>] dump_stack+0x4f/0x7b [ 188.435615] [<ffffffff81915f3d>] check_preemption_disabled+0x19d/0x1c0 [ 188.435619] [<ffffffff81915f77>] debug_smp_processor_id+0x17/0x20 The solution would be to protect the whole this_cpu_ptr(dev->tstats)/u64_stats_update_begin/end blocks with disabling preemption and then reenabling it. Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-14sctp: translate host order to network order when setting a hmacidlucien
[ Upstream commit ed5a377d87dc4c87fb3e1f7f698cba38cd893103 ] now sctp auth cannot work well when setting a hmacid manually, which is caused by that we didn't use the network order for hmacid, so fix it by adding the transformation in sctp_auth_ep_set_hmacs. even we set hmacid with the network order in userspace, it still can't work, because of this condition in sctp_auth_ep_set_hmacs(): if (id > SCTP_AUTH_HMAC_ID_MAX) return -EOPNOTSUPP; so this wasn't working before and thus it won't break compatibility. Fixes: 65b07e5d0d09 ("[SCTP]: API updates to suport SCTP-AUTH extensions.") Signed-off-by: Xin Long <lucien.xin@gmail.com> Signed-off-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-14packet: fix tpacket_snd max frame lenDaniel Borkmann
[ Upstream commit 5cfb4c8d05b4409c4044cb9c05b19705c1d9818b ] Since it's introduction in commit 69e3c75f4d54 ("net: TX_RING and packet mmap"), TX_RING could be used from SOCK_DGRAM and SOCK_RAW side. When used with SOCK_DGRAM only, the size_max > dev->mtu + reserve check should have reserve as 0, but currently, this is unconditionally set (in it's original form as dev->hard_header_len). I think this is not correct since tpacket_fill_skb() would then take dev->mtu and dev->hard_header_len into account for SOCK_DGRAM, the extra VLAN_HLEN could be possible in both cases. Presumably, the reserve code was copied from packet_snd(), but later on missed the check. Make it similar as we have it in packet_snd(). Fixes: 69e3c75f4d54 ("net: TX_RING and packet mmap") Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-14packet: infer protocol from ethernet header if unsetDaniel Borkmann
[ Upstream commit c72219b75fde768efccf7666342282fab7f9e4e7 ] In case no struct sockaddr_ll has been passed to packet socket's sendmsg() when doing a TX_RING flush run, then skb->protocol is set to po->num instead, which is the protocol passed via socket(2)/bind(2). Applications only xmitting can go the path of allocating the socket as socket(PF_PACKET, <mode>, 0) and do a bind(2) on the TX_RING with sll_protocol of 0. That way, register_prot_hook() is neither called on creation nor on bind time, which saves cycles when there's no interest in capturing anyway. That leaves us however with po->num 0 instead and therefore the TX_RING flush run sets skb->protocol to 0 as well. Eric reported that this leads to problems when using tools like trafgen over bonding device. I.e. the bonding's hash function could invoke the kernel's flow dissector, which depends on skb->protocol being properly set. In the current situation, all the traffic is then directed to a single slave. Fix it up by inferring skb->protocol from the Ethernet header when not set and we have ARPHRD_ETHER device type. This is only done in case of SOCK_RAW and where we have a dev->hard_header_len length. In case of ARPHRD_ETHER devices, this is guaranteed to cover ETH_HLEN, and therefore being accessed on the skb after the skb_store_bits(). Reported-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-14packet: only allow extra vlan len on ethernet devicesDaniel Borkmann
[ Upstream commit 3c70c132488794e2489ab045559b0ce0afcf17de ] Packet sockets can be used by various net devices and are not really restricted to ARPHRD_ETHER device types. However, when currently checking for the extra 4 bytes that can be transmitted in VLAN case, our assumption is that we generally probe on ARPHRD_ETHER devices. Therefore, before looking into Ethernet header, check the device type first. This also fixes the issue where non-ARPHRD_ETHER devices could have no dev->hard_header_len in TX_RING SOCK_RAW case, and thus the check would test unfilled linear part of the skb (instead of non-linear). Fixes: 57f89bfa2140 ("network: Allow af_packet to transmit +4 bytes for VLAN packets.") Fixes: 52f1454f629f ("packet: allow to transmit +4 byte in TX_RING slot for VLAN case") Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-14packet: tpacket_snd(): fix signed/unsigned comparisonAlexander Drozdov
[ Upstream commit dbd46ab412b8fb395f2b0ff6f6a7eec9df311550 ] tpacket_fill_skb() can return a negative value (-errno) which is stored in tp_len variable. In that case the following condition will be (but shouldn't be) true: tp_len > dev->mtu + dev->hard_header_len as dev->mtu and dev->hard_header_len are both unsigned. That may lead to just returning an incorrect EMSGSIZE errno to the user. Fixes: 52f1454f629fa ("packet: allow to transmit +4 byte in TX_RING slot for VLAN case") Signed-off-by: Alexander Drozdov <al.drozdov@gmail.com> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-14packet: always probe for transport headerDaniel Borkmann
[ Upstream commit 8fd6c80d9dd938ca338c70698533a7e304752846 ] We concluded that the skb_probe_transport_header() should better be called unconditionally. Avoiding the call into the flow dissector has also not really much to do with the direct xmit mode. While it seems that only virtio_net code makes use of GSO from non RX/TX ring packet socket paths, we should probe for a transport header nevertheless before they hit devices. Reference: http://thread.gmane.org/gmane.linux.network/386173/ Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Jason Wang <jasowang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-14packet: do skb_probe_transport_header when we actually have dataDaniel Borkmann
[ Upstream commit efdfa2f7848f64517008136fb41f53c4a1faf93a ] In tpacket_fill_skb() commit c1aad275b029 ("packet: set transport header before doing xmit") and later on 40893fd0fd4e ("net: switch to use skb_probe_transport_header()") was probing for a transport header on the skb from a ring buffer slot, but at a time, where the skb has _not even_ been filled with data yet. So that call into the flow dissector is pretty useless. Lets do it after we've set up the skb frags. Fixes: c1aad275b029 ("packet: set transport header before doing xmit") Reported-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Jason Wang <jasowang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-14tools/net: Use include/uapi with __EXPORTED_HEADERS__Kamal Mostafa
[ Upstream commit d7475de58575c904818efa369c82e88c6648ce2e ] Use the local uapi headers to keep in sync with "recently" added #define's (e.g. SKF_AD_VLAN_TPID). Refactored CFLAGS, and bpf_asm doesn't need -I. Fixes: 3f356385e8a4 ("filter: bpf_asm: add minimal bpf asm tool") Signed-off-by: Kamal Mostafa <kamal@canonical.com> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-14Revert "net: Fix skb_set_peeked use-after-free bug"Sasha Levin
This reverts commit d9a1133495b487154ac351cd33b26b416e966d2d.
2015-12-14ipv6: addrconf: validate new MTU before applying itMarcelo Leitner
[ Upstream commit 77751427a1ff25b27d47a4c36b12c3c8667855ac ] Currently we don't check if the new MTU is valid or not and this allows one to configure a smaller than minimum allowed by RFCs or even bigger than interface own MTU, which is a problem as it may lead to packet drops. If you have a daemon like NetworkManager running, this may be exploited by remote attackers by forging RA packets with an invalid MTU, possibly leading to a DoS. (NetworkManager currently only validates for values too small, but not for too big ones.) The fix is just to make sure the new value is valid. That is, between IPV6_MIN_MTU and interface's MTU. Note that similar check is already performed at ndisc_router_discovery(), for when kernel itself parses the RA. Signed-off-by: Marcelo Ricardo Leitner <mleitner@redhat.com> Signed-off-by: Sabrina Dubroca <sd@queasysnail.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-14KVM: x86: Use new is_noncanonical_address in _linearizeNadav Amit
[ Upstream commit 4be4de7ef9fd3a4d77320d4713970299ffecd286 ] Replace the current canonical address check with the new function which is identical. Signed-off-by: Nadav Amit <namit@cs.technion.ac.il> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-14KVM: x86: work around infinite loop in microcode when #AC is deliveredEric Northup
[ Upstream commit 54a20552e1eae07aa240fa370a0293e006b5faed ] It was found that a guest can DoS a host by triggering an infinite stream of "alignment check" (#AC) exceptions. This causes the microcode to enter an infinite loop where the core never receives another interrupt. The host kernel panics pretty quickly due to the effects (CVE-2015-5307). Signed-off-by: Eric Northup <digitaleric@google.com> Cc: stable@vger.kernel.org Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-14ARM: orion: Fix DSA platform device after mvmdio conversionFlorian Fainelli
[ Upstream commit d836ace65ee98d7079bc3c5afdbcc0e27dca20a3 ] DSA expects the host_dev pointer to be the device structure associated with the MDIO bus controller driver. First commit breaking that was c3a07134e6aa ("mv643xx_eth: convert to use the Marvell Orion MDIO driver"), and then, it got completely under the radar for a while. Reported-by: Frans van de Wiel <fvdw@fvdw.eu> Fixes: c3a07134e6aa ("mv643xx_eth: convert to use the Marvell Orion MDIO driver") CC: stable@vger.kernel.org Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-14RDS: verify the underlying transport exists before creating a connectionSasha Levin
[ Upstream commit 74e98eb085889b0d2d4908f59f6e00026063014f ] There was no verification that an underlying transport exists when creating a connection, this would cause dereferencing a NULL ptr. It might happen on sockets that weren't properly bound before attempting to send a message, which will cause a NULL ptr deref: [135546.047719] kasan: GPF could be caused by NULL-ptr deref or user memory accessgeneral protection fault: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC KASAN [135546.051270] Modules linked in: [135546.051781] CPU: 4 PID: 15650 Comm: trinity-c4 Not tainted 4.2.0-next-20150902-sasha-00041-gbaa1222-dirty #2527 [135546.053217] task: ffff8800835bc000 ti: ffff8800bc708000 task.ti: ffff8800bc708000 [135546.054291] RIP: __rds_conn_create (net/rds/connection.c:194) [135546.055666] RSP: 0018:ffff8800bc70fab0 EFLAGS: 00010202 [135546.056457] RAX: dffffc0000000000 RBX: 0000000000000f2c RCX: ffff8800835bc000 [135546.057494] RDX: 0000000000000007 RSI: ffff8800835bccd8 RDI: 0000000000000038 [135546.058530] RBP: ffff8800bc70fb18 R08: 0000000000000001 R09: 0000000000000000 [135546.059556] R10: ffffed014d7a3a23 R11: ffffed014d7a3a21 R12: 0000000000000000 [135546.060614] R13: 0000000000000001 R14: ffff8801ec3d0000 R15: 0000000000000000 [135546.061668] FS: 00007faad4ffb700(0000) GS:ffff880252000000(0000) knlGS:0000000000000000 [135546.062836] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [135546.063682] CR2: 000000000000846a CR3: 000000009d137000 CR4: 00000000000006a0 [135546.064723] Stack: [135546.065048] ffffffffafe2055c ffffffffafe23fc1 ffffed00493097bf ffff8801ec3d0008 [135546.066247] 0000000000000000 00000000000000d0 0000000000000000 ac194a24c0586342 [135546.067438] 1ffff100178e1f78 ffff880320581b00 ffff8800bc70fdd0 ffff880320581b00 [135546.068629] Call Trace: [135546.069028] ? __rds_conn_create (include/linux/rcupdate.h:856 net/rds/connection.c:134) [135546.069989] ? rds_message_copy_from_user (net/rds/message.c:298) [135546.071021] rds_conn_create_outgoing (net/rds/connection.c:278) [135546.071981] rds_sendmsg (net/rds/send.c:1058) [135546.072858] ? perf_trace_lock (include/trace/events/lock.h:38) [135546.073744] ? lockdep_init (kernel/locking/lockdep.c:3298) [135546.074577] ? rds_send_drop_to (net/rds/send.c:976) [135546.075508] ? __might_fault (./arch/x86/include/asm/current.h:14 mm/memory.c:3795) [135546.076349] ? __might_fault (mm/memory.c:3795) [135546.077179] ? rds_send_drop_to (net/rds/send.c:976) [135546.078114] sock_sendmsg (net/socket.c:611 net/socket.c:620) [135546.078856] SYSC_sendto (net/socket.c:1657) [135546.079596] ? SYSC_connect (net/socket.c:1628) [135546.080510] ? trace_dump_stack (kernel/trace/trace.c:1926) [135546.081397] ? ring_buffer_unlock_commit (kernel/trace/ring_buffer.c:2479 kernel/trace/ring_buffer.c:2558 kernel/trace/ring_buffer.c:2674) [135546.082390] ? trace_buffer_unlock_commit (kernel/trace/trace.c:1749) [135546.083410] ? trace_event_raw_event_sys_enter (include/trace/events/syscalls.h:16) [135546.084481] ? do_audit_syscall_entry (include/trace/events/syscalls.h:16) [135546.085438] ? trace_buffer_unlock_commit (kernel/trace/trace.c:1749) [135546.085515] rds_ib_laddr_check(): addr 36.74.25.172 ret -99 node type -1 Acked-by: Santosh Shilimkar <santosh.shilimkar@oracle.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-14packet: race condition in packet_bindFrancesco Ruggeri
[ Upstream commit 30f7ea1c2b5f5fb7462c5ae44fe2e40cb2d6a474 ] There is a race conditions between packet_notifier and packet_bind{_spkt}. It happens if packet_notifier(NETDEV_UNREGISTER) executes between the time packet_bind{_spkt} takes a reference on the new netdevice and the time packet_do_bind sets po->ifindex. In this case the notification can be missed. If this happens during a dev_change_net_namespace this can result in the netdevice to be moved to the new namespace while the packet_sock in the old namespace still holds a reference on it. When the netdevice is later deleted in the new namespace the deletion hangs since the packet_sock is not found in the new namespace' &net->packet.sklist. It can be reproduced with the script below. This patch makes packet_do_bind check again for the presence of the netdevice in the packet_sock's namespace after the synchronize_net in unregister_prot_hook. More in general it also uses the rcu lock for the duration of the bind to stop dev_change_net_namespace/rollback_registered_many from going past the synchronize_net following unlist_netdevice, so that no NETDEV_UNREGISTER notifications can happen on the new netdevice while the bind is executing. In order to do this some code from packet_bind{_spkt} is consolidated into packet_do_dev. import socket, os, time, sys proto=7 realDev='em1' vlanId=400 if len(sys.argv) > 1: vlanId=int(sys.argv[1]) dev='vlan%d' % vlanId os.system('taskset -p 0x10 %d' % os.getpid()) s = socket.socket(socket.PF_PACKET, socket.SOCK_RAW, proto) os.system('ip link add link %s name %s type vlan id %d' % (realDev, dev, vlanId)) os.system('ip netns add dummy') pid=os.fork() if pid == 0: # dev should be moved while packet_do_bind is in synchronize net os.system('taskset -p 0x20000 %d' % os.getpid()) os.system('ip link set %s netns dummy' % dev) os.system('ip netns exec dummy ip link del %s' % dev) s.close() sys.exit(0) time.sleep(.004) try: s.bind(('%s' % dev, proto+1)) except: print 'Could not bind socket' s.close() os.system('ip netns del dummy') sys.exit(0) os.waitpid(pid, 0) s.close() os.system('ip netns del dummy') sys.exit(0) Signed-off-by: Francesco Ruggeri <fruggeri@arista.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-14ipv4: disable BH when changing ip local port rangeWANG Cong
[ Upstream commit 4ee3bd4a8c7463cdef0b82ebc33fc94a9170a7e0 ] This fixes the following lockdep warning: [ INFO: inconsistent lock state ] 4.3.0-rc7+ #1197 Not tainted --------------------------------- inconsistent {IN-SOFTIRQ-R} -> {SOFTIRQ-ON-W} usage. sysctl/1019 [HC0[0]:SC0[0]:HE1:SE1] takes: (&(&net->ipv4.ip_local_ports.lock)->seqcount){+.+-..}, at: [<ffffffff81921de7>] ipv4_local_port_range+0xb4/0x12a {IN-SOFTIRQ-R} state was registered at: [<ffffffff810bd682>] __lock_acquire+0x2f6/0xdf0 [<ffffffff810be6d5>] lock_acquire+0x11c/0x1a4 [<ffffffff818e599c>] inet_get_local_port_range+0x4e/0xae [<ffffffff8166e8e3>] udp_flow_src_port.constprop.40+0x23/0x116 [<ffffffff81671cb9>] vxlan_xmit_one+0x219/0xa6a [<ffffffff81672f75>] vxlan_xmit+0xa6b/0xaa5 [<ffffffff817f2deb>] dev_hard_start_xmit+0x2ae/0x465 [<ffffffff817f35ed>] __dev_queue_xmit+0x531/0x633 [<ffffffff817f3702>] dev_queue_xmit_sk+0x13/0x15 [<ffffffff818004a5>] neigh_resolve_output+0x12f/0x14d [<ffffffff81959cfa>] ip6_finish_output2+0x344/0x39f [<ffffffff8195bf58>] ip6_finish_output+0x88/0x8e [<ffffffff8195bfef>] ip6_output+0x91/0xe5 [<ffffffff819792ae>] dst_output_sk+0x47/0x4c [<ffffffff81979392>] NF_HOOK_THRESH.constprop.30+0x38/0x82 [<ffffffff8197981e>] mld_sendpack+0x189/0x266 [<ffffffff8197b28b>] mld_ifc_timer_expire+0x1ef/0x223 [<ffffffff810de581>] call_timer_fn+0xfb/0x28c [<ffffffff810ded1e>] run_timer_softirq+0x1c7/0x1f1 Fixes: b8f1a55639e6 ("udp: Add function to make source port for UDP tunnels") Cc: Tom Herbert <tom@herbertland.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-14ipv6: clean up dev_snmp6 proc entry when we fail to initialize inet6_devSabrina Dubroca
[ Upstream commit 2a189f9e57650e9f310ddf4aad75d66c1233a064 ] In ipv6_add_dev, when addrconf_sysctl_register fails, we do not clean up the dev_snmp6 entry that we have already registered for this device. Call snmp6_unregister_dev in this case. Fixes: a317a2f19da7d ("ipv6: fail early when creating netdev named all or default") Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Sabrina Dubroca <sd@queasysnail.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-14sfc: push partner queue for skb->xmit_moreMartin Habets
[ Upstream commit b2663a4f30e85ec606b806f5135413e6d5c78d1e ] When the IP stack passes SKBs the sfc driver puts them in 2 different TX queues (called partners), one for checksummed and one for not checksummed. If the SKB has xmit_more set the driver will delay pushing the work to the NIC. When later it does decide to push the buffers this patch ensures it also pushes the partner queue, if that also has any delayed work. Before this fix the work in the partner queue would be left for a long time and cause a netdev watchdog. Fixes: 70b33fb ("sfc: add support for skb->xmit_more") Reported-by: Jianlin Shi <jishi@redhat.com> Signed-off-by: Martin Habets <mhabets@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-14sit: fix sit0 percpu double allocationsEric Dumazet
[ Upstream commit 4ece9009774596ee3df0acba65a324b7ea79387c ] sit0 device allocates its percpu storage twice : - One time in ipip6_tunnel_init() - One time in ipip6_fb_tunnel_init() Thus we leak 48 bytes per possible cpu per network namespace dismantle. ipip6_fb_tunnel_init() can be much simpler and does not return an error, and should be called after register_netdev() Note that ipip6_tunnel_clone_6rd() also needs to be called after register_netdev() (calling ipip6_tunnel_init()) Fixes: ebe084aafb7e ("sit: Use ipip6_tunnel_init as the ndo_init function.") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Dmitry Vyukov <dvyukov@google.com> Cc: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-03ipv6: gre: support SIT encapsulationEric Dumazet
[ Upstream commit 7e3b6e7423d5f994257c1de88e06b509673fdbcf ] gre_gso_segment() chokes if SIT frames were aggregated by GRO engine. Fixes: 61c1db7fae21e ("ipv6: sit: add GSO/TSO support") Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-03qmi_wwan: add Sierra Wireless MC74xx/EM74xxBjørn Mork
[ Upstream commit 0db65fcfcded76fe4f74e3ca9f4e2baf67b683ef ] New device IDs shamelessly lifted from the vendor driver. Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-03virtio-net: drop NETIF_F_FRAGLISTJason Wang
[ Upstream commit 48900cb6af4282fa0fb6ff4d72a81aa3dadb5c39 ] virtio declares support for NETIF_F_FRAGLIST, but assumes that there are at most MAX_SKB_FRAGS + 2 fragments which isn't always true with a fraglist. A longer fraglist in the skb will make the call to skb_to_sgvec overflow the sg array, leading to memory corruption. Drop NETIF_F_FRAGLIST so we only get what we can handle. Cc: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Jason Wang <jasowang@redhat.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-03net: fix a race in dst_release()Eric Dumazet
[ Upstream commit d69bbf88c8d0b367cf3e3a052f6daadf630ee566 ] Only cpu seeing dst refcount going to 0 can safely dereference dst->flags. Otherwise an other cpu might already have freed the dst. Fixes: 27b75c95f10d ("net: avoid RCU for NOCACHE dst") Reported-by: Greg Thelen <gthelen@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-03net: avoid NULL deref in inet_ctl_sock_destroy()Eric Dumazet
[ Upstream commit 8fa677d2706d325d71dab91bf6e6512c05214e37 ] Under low memory conditions, tcp_sk_init() and icmp_sk_init() can both iterate on all possible cpus and call inet_ctl_sock_destroy(), with eventual NULL pointer. Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-03qmi_wwan: fix entry for HP lt4112 LTE/HSPA+ Gobi 4G ModuleBjørn Mork
[ Upstream commit 70910791731b5956171e1bfcad707766b8e18fee ] The lt4112 is a HP branded Huawei me906e modem. Like other Huawei modems, it does not have a fixed interface to function mapping. Instead it uses a Huawei specific scheme: functions are mapped by subclass and protocol. However, the HP vendor ID is used for modems from many different manufacturers using different schemes, so we cannot apply a generic vendor rule like we do for the Huawei vendor ID. Replace the previous lt4112 entry pointing to an arbitrary interface number with a device specific subclass + protocol match. Reported-and-tested-by: Muri Nicanor <muri+libqmi@immerda.ch> Tested-by: Martin Hauke <mardnh@gmx.de> Fixes: bb2bdeb83fb1 ("qmi_wwan: Add support for HP lt4112 LTE/HSPA+ Gobi 4G Modem") Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-03ipmr: fix possible race resulting from improper usage of IP_INC_STATS_BH() ↵Ani Sinha
in preemptible context. [ Upstream commit 44f49dd8b5a606870a1f21101522a0f9c4414784 ] Fixes the following kernel BUG : BUG: using __this_cpu_add() in preemptible [00000000] code: bash/2758 caller is __this_cpu_preempt_check+0x13/0x15 CPU: 0 PID: 2758 Comm: bash Tainted: P O 3.18.19 #2 ffffffff8170eaca ffff880110d1b788 ffffffff81482b2a 0000000000000000 0000000000000000 ffff880110d1b7b8 ffffffff812010ae ffff880007cab800 ffff88001a060800 ffff88013a899108 ffff880108b84240 ffff880110d1b7c8 Call Trace: [<ffffffff81482b2a>] dump_stack+0x52/0x80 [<ffffffff812010ae>] check_preemption_disabled+0xce/0xe1 [<ffffffff812010d4>] __this_cpu_preempt_check+0x13/0x15 [<ffffffff81419d60>] ipmr_queue_xmit+0x647/0x70c [<ffffffff8141a154>] ip_mr_forward+0x32f/0x34e [<ffffffff8141af76>] ip_mroute_setsockopt+0xe03/0x108c [<ffffffff810553fc>] ? get_parent_ip+0x11/0x42 [<ffffffff810e6974>] ? pollwake+0x4d/0x51 [<ffffffff81058ac0>] ? default_wake_function+0x0/0xf [<ffffffff810553fc>] ? get_parent_ip+0x11/0x42 [<ffffffff810613d9>] ? __wake_up_common+0x45/0x77 [<ffffffff81486ea9>] ? _raw_spin_unlock_irqrestore+0x1d/0x32 [<ffffffff810618bc>] ? __wake_up_sync_key+0x4a/0x53 [<ffffffff8139a519>] ? sock_def_readable+0x71/0x75 [<ffffffff813dd226>] do_ip_setsockopt+0x9d/0xb55 [<ffffffff81429818>] ? unix_seqpacket_sendmsg+0x3f/0x41 [<ffffffff813963fe>] ? sock_sendmsg+0x6d/0x86 [<ffffffff813959d4>] ? sockfd_lookup_light+0x12/0x5d [<ffffffff8139650a>] ? SyS_sendto+0xf3/0x11b [<ffffffff810d5738>] ? new_sync_read+0x82/0xaa [<ffffffff813ddd19>] compat_ip_setsockopt+0x3b/0x99 [<ffffffff813fb24a>] compat_raw_setsockopt+0x11/0x32 [<ffffffff81399052>] compat_sock_common_setsockopt+0x18/0x1f [<ffffffff813c4d05>] compat_SyS_setsockopt+0x1a9/0x1cf [<ffffffff813c4149>] compat_SyS_socketcall+0x180/0x1e3 [<ffffffff81488ea1>] cstar_dispatch+0x7/0x1e Signed-off-by: Ani Sinha <ani@arista.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-03stmmac: Correctly report PTP capabilities.Phil Reid
[ Upstream commit e6dbe1eb2db0d7a14991c06278dd3030c45fb825 ] priv->hwts_*_en indicate if timestamping is enabled/disabled at run time. But priv->dma_cap.time_stamp and priv->dma_cap.atime_stamp indicates HW is support for PTPv1/PTPv2. Signed-off-by: Phil Reid <preid@electromag.com.au> Acked-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-03net/mlx4: Copy/set only sizeof struct mlx4_eqe bytesCarol L Soto
[ Upstream commit c02b05011fadf8e409e41910217ca689f2fc9d91 ] When doing memcpy/memset of EQEs, we should use sizeof struct mlx4_eqe as the base size and not caps.eqe_size which could be bigger. If caps.eqe_size is bigger than the struct mlx4_eqe then we corrupt data in the master context. When using a 64 byte stride, the memcpy copied over 63 bytes to the slave_eq structure. This resulted in copying over the entire eqe of interest, including its ownership bit -- and also 31 bytes of garbage into the next WQE in the slave EQ -- which did NOT include the ownership bit (and therefore had no impact). However, once the stride is increased to 128, we are overwriting the ownership bits of *three* eqes in the slave_eq struct. This results in an incorrect ownership bit for those eqes, which causes the eq to seem to be full. The issue therefore surfaced only once 128-byte EQEs started being used in SRIOV and (overarchitectures that have 128/256 byte cache-lines such as PPC) - e.g after commit 77507aa249ae "net/mlx4_core: Enable CQE/EQE stride support". Fixes: 08ff32352d6f ('mlx4: 64-byte CQE/EQE support') Signed-off-by: Carol L Soto <clsoto@linux.vnet.ibm.com> Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il> Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-03RDS-TCP: Recover correctly from pskb_pull()/pksb_trim() failure in ↵Sowmini Varadhan
rds_tcp_data_recv [ Upstream commit 8ce675ff39b9958d1c10f86cf58e357efaafc856 ] Either of pskb_pull() or pskb_trim() may fail under low memory conditions. If rds_tcp_data_recv() ignores such failures, the application will receive corrupted data because the skb has not been correctly carved to the RDS datagram size. Avoid this by handling pskb_pull/pskb_trim failure in the same manner as the skb_clone failure: bail out of rds_tcp_data_recv(), and retry via the deferred call to rds_send_worker() that gets set up on ENOMEM from rds_tcp_read_sock() Signed-off-by: Sowmini Varadhan <sowmini.varadhan@oracle.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-03ppp: fix pppoe_dev deletion condition in pppoe_release()Guillaume Nault
[ Upstream commit 1acea4f6ce1b1c0941438aca75dd2e5c6b09db60 ] We can't rely on PPPOX_ZOMBIE to decide whether to clear po->pppoe_dev. PPPOX_ZOMBIE can be set by pppoe_disc_rcv() even when po->pppoe_dev is NULL. So we have no guarantee that (sk->sk_state & PPPOX_ZOMBIE) implies (po->pppoe_dev != NULL). Since we're releasing a PPPoE socket, we want to release the pppoe_dev if it exists and reset sk_state to PPPOX_DEAD, no matter the previous value of sk_state. So we can just check for po->pppoe_dev and avoid any assumption on sk->sk_state. Fixes: 2b018d57ff18 ("pppoe: drop PPPOX_ZOMBIEs in pppoe_release") Signed-off-by: Guillaume Nault <g.nault@alphalink.fr> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-03macvtap: unbreak receiving of gro skb with frag listJason Wang
[ Upstream commit f23d538bc24a83c16127c2eb82c9cf1adc2b5149 ] We don't have fraglist support in TAP_FEATURES. This will lead software segmentation of gro skb with frag list. Fixes by having frag list support in TAP_FEATURES. With this patch single session of netperf receiving were restored from about 5Gb/s to about 12Gb/s on mlx4. Fixes a567dd6252 ("macvtap: simplify usage of tap_features") Cc: Vlad Yasevich <vyasevic@redhat.com> Cc: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Jason Wang <jasowang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-03irda: precedence bug in irlmp_seq_hb_idx()Dan Carpenter
[ Upstream commit 50010c20597d14667eff0fdb628309986f195230 ] This is decrementing the pointer, instead of the value stored in the pointer. KASan detects it as an out of bounds reference. Reported-by: "Berry Cheng 程君(成淼)" <chengmiao.cj@alibaba-inc.com> Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-03audit: create private file name copies when auditing inodesPaul Moore
[ Upstream commit fcf22d8267ad2601fe9b6c549d1be96401c23e0b ] Unfortunately, while commit 4a928436 ("audit: correctly record file names with different path name types") fixed a problem where we were not recording filenames, it created a new problem by attempting to use these file names after they had been freed. This patch resolves the issue by creating a copy of the filename which the audit subsystem frees after it is done with the string. At some point it would be nice to resolve this issue with refcounts, or something similar, instead of having to allocate/copy strings, but that is almost surely beyond the scope of a -rcX patch so we'll defer that for later. On the plus side, only audit users should be impacted by the string copying. Reported-by: Toralf Foerster <toralf.foerster@gmx.de> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-03audit: correctly record file names with different path name typesPaul Moore
[ Upstream commit 4a92843601ad0f5067f441d2f0dca55bbe18c076 ] There is a problem with the audit system when multiple audit records are created for the same path, each with a different path name type. The root cause of the problem is in __audit_inode() when an exact match (both the path name and path name type) is not found for a path name record; the existing code creates a new path name record, but it never sets the path name in this record, leaving it NULL. This patch corrects this problem by assigning the path name to these newly created records. There are many ways to reproduce this problem, but one of the easiest is the following (assuming auditd is running): # mkdir /root/tmp/test # touch /root/tmp/test/567 # auditctl -a always,exit -F dir=/root/tmp/test # touch /root/tmp/test/567 Afterwards, or while the commands above are running, check the audit log and pay special attention to the PATH records. A faulty kernel will display something like the following for the file creation: type=SYSCALL msg=audit(1416957442.025:93): arch=c000003e syscall=2 success=yes exit=3 ... comm="touch" exe="/usr/bin/touch" type=CWD msg=audit(1416957442.025:93): cwd="/root/tmp" type=PATH msg=audit(1416957442.025:93): item=0 name="test/" inode=401409 ... nametype=PARENT type=PATH msg=audit(1416957442.025:93): item=1 name=(null) inode=393804 ... nametype=NORMAL type=PATH msg=audit(1416957442.025:93): item=2 name=(null) inode=393804 ... nametype=NORMAL While a patched kernel will show the following: type=SYSCALL msg=audit(1416955786.566:89): arch=c000003e syscall=2 success=yes exit=3 ... comm="touch" exe="/usr/bin/touch" type=CWD msg=audit(1416955786.566:89): cwd="/root/tmp" type=PATH msg=audit(1416955786.566:89): item=0 name="test/" inode=401409 ... nametype=PARENT type=PATH msg=audit(1416955786.566:89): item=1 name="test/567" inode=393804 ... nametype=NORMAL This issue was brought up by a number of people, but special credit should go to hujianyang@huawei.com for reporting the problem along with an explanation of the problem and a patch. While the original patch did have some problems (see the archive link below), it did demonstrate the problem and helped kickstart the fix presented here. * https://lkml.org/lkml/2014/9/5/66 Reported-by: hujianyang <hujianyang@huawei.com> Signed-off-by: Paul Moore <pmoore@redhat.com> Acked-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-03mptfusion: prevent some memory corruptionDan Carpenter
[ Upstream commit e819cdb198319cccf4af4fc12ac4d796109d8c23 ] These are signed values the come from the user, we put a cap on the upper bounds but not on the lower bounds. We use "karg.dataSgeOffset" to calculate "sz". We verify "sz" and proceed as if that means that "karg.dataSgeOffset" is correct but this fails to consider that the "sz" calculations can have integer overflows. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Signed-off-by: James Bottomley <JBottomley@Odin.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
