2014-11-16Linux 3.18-rc5v3.18-rc5Linus Torvalds
2014-11-16Merge tag 'armsoc-for-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "Another small set of fixes: - some DT compatible typo fixes - irq setup fix dealing with irq storms on orion - i2c quirk generalization for mvebu - a handful of smaller fixes for OMAP - a couple of added file patterns for OMAP entries in MAINTAINERS" * tag 'armsoc-for-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: at91/dt: Fix sama5d3x typos pinctrl: dra: dt-bindings: Fix output pull up/down MAINTAINERS: Update entry for omap related .dts files to cover new SoCs MAINTAINERS: add more files under OMAP SUPPORT ARM: dts: AM437x-SK-EVM: Fix DCDC3 voltage ARM: dts: AM437x-GP-EVM: Fix DCDC3 voltage ARM: dts: AM43x-EPOS-EVM: Fix DCDC3 voltage ARM: dts: am335x-evm: Fix 5th NAND partition's name ARM: orion: Fix for certain sequence of request_irq can cause irq storm ARM: mvebu: armada xp: Generalize use of i2c quirk
2014-11-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
Pull sparc fixes from David Miller: 1) Fix NULL oops in Schizo PCI controller error handler. 2) Fix race between xchg and other operations on 32-bit sparc, from Andreas Larsson. 3) swab*() helpers need a dummy memory input operand to show data flow on 64-bit sparc. 4) Fix RCU warnings due to missing irq_{enter,exit}() around generic_smp_call_function*() calls. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: sparc64: Fix constraints on swab helpers. sparc32: Implement xchg and atomic_xchg using ATOMIC_HASH locks sparc64: Do irq_{enter,exit}() around generic_smp_call_function*(). sparc64: Fix crashes in schizo_pcierr_intr_other().
2014-11-16Merge tag 'md/3.18-fix' of git://neil.brown.name/mdLinus Torvalds
Pull md bugfix from Neil Brown: "One fix for md for 3.18. This fixes a regression introduced in 3.13" * tag 'md/3.18-fix' of git://neil.brown.name/md: md: Always set RECOVERY_NEEDED when clearing RECOVERY_FROZEN
2014-11-16ARM: at91/dt: Fix sama5d3x typosPeter Rosin
Some DT files had a typo with a missing "5" in sama5d3x first compatible string. Signed-off-by: Peter Rosin <peda@axentia.se> [nicolas.ferre@atmel.com: modify commit log] Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-11-16Merge tag 'omap-fixes-against-v3.18-rc4' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes Merge "omap fixes against v3.18-rc4" from Tony Lindgren: Few omap fixes for hangs and wrong pinctrl defines, and update MAINTAINERS file to avoid missing PMIC and SoC related patches: - Fix random hangs on am437x because of incorrect default value for the DDR regulator - Fix wrong partition name for NAND on am335x-evm - Fix wrong pinctrl defines for dra7xx - Update maintainers entries for PMICs and SoCs * tag 'omap-fixes-against-v3.18-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: pinctrl: dra: dt-bindings: Fix output pull up/down MAINTAINERS: Update entry for omap related .dts files to cover new SoCs MAINTAINERS: add more files under OMAP SUPPORT ARM: dts: AM437x-SK-EVM: Fix DCDC3 voltage ARM: dts: AM437x-GP-EVM: Fix DCDC3 voltage ARM: dts: AM43x-EPOS-EVM: Fix DCDC3 voltage ARM: dts: am335x-evm: Fix 5th NAND partition's name Signed-off-by: Olof Johansson <olof@lixom.net>
2014-11-16Merge tag 'mvebu-fixes-3.18' of git://git.infradead.org/linux-mvebu into fixesOlof Johansson
Merge "mvebu fixes for v3.18" from Jason Cooper: - Armada XP - Generalize i2c quirk - orion - Fix irq storm caused by specific sequence of request_irq * tag 'mvebu-fixes-3.18' of git://git.infradead.org/linux-mvebu: ARM: orion: Fix for certain sequence of request_irq can cause irq storm ARM: mvebu: armada xp: Generalize use of i2c quirk
2014-11-17md: Always set RECOVERY_NEEDED when clearing RECOVERY_FROZENNeilBrown
md_check_recovery will skip any recovery and also clear MD_RECOVERY_NEEDED if MD_RECOVERY_FROZEN is set. So when we clear _FROZEN, we must set _NEEDED and ensure that md_check_recovery gets run. Otherwise we could miss out on something that is needed. In particular, this can make it impossible to remove a failed device from an array is the 'recovery-needed' processing didn't happen. Suitable for stable kernels since 3.13. Cc: stable@vger.kernel.org (3.13+) Reported-and-tested-by: Joe Lawrence <joe.lawrence@stratus.com> Fixes: 30b8feb730f9b9b3c5de02580897da03f59b6b16 Signed-off-by: NeilBrown <neilb@suse.de>
2014-11-16sparc64: Fix constraints on swab helpers.David S. Miller
We are reading the memory location, so we have to have a memory constraint in there purely for the sake of showing the data flow to the compiler. Reported-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-16Merge tag 'scsi-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi Pull SCSI fixes from James Bottomley: "This is a set of six fixes and a MAINTAINER update. The fixes are two multipath (one in Test Unit Ready handling for the path checkers and one in the section of code that sends a start unit after failover; both of these were perturbed by the scsi-mq update), a CD-ROM door locking fix that was likewise introduced by scsi-mq and three driver fixes for a previous code update in cxgb4i, megaraid_sas and bnx2fc" * tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: bnx2fc: fix tgt spinlock locking megaraid_sas: fix bug in handling return value of pci_enable_msix_range() cxgb4i: send abort_rpl correctly cxgbi: add maintainer for cxgb3i/cxgb4i scsi: TUR path is down after adapter gets reset with multipath scsi: call device handler for failed TUR command scsi: only re-lock door after EH on devices that were reset
2014-11-16Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Ingo Molnar: "Microcode fixes, a Xen fix and a KASLR boot loading fix with certain memory layouts" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, microcode, AMD: Fix ucode patch stashing on 32-bit x86/core, x86/xen/smp: Use 'die_complete' completion when taking CPU down x86, microcode: Fix accessing dis_ucode_ldr on 32-bit x86, kaslr: Prevent .bss from overlaping initrd x86, microcode, AMD: Fix early ucode loading on 32-bit
2014-11-16x86-64: make csum_partial_copy_from_user() error handling consistentLinus Torvalds
Al Viro pointed out that the x86-64 csum_partial_copy_from_user() is somewhat confused about what it should do on errors, notably it mostly clears the uncopied end result buffer, but misses that for the initial alignment case. All users should check for errors, so it's dubious whether the clearing is even necessary, and Al also points out that we should probably clean up the calling conventions, but regardless of any future changes to this function, the fact that it is inconsistent is just annoying. So make the __get_user() failure path use the same error exit as all the other errors do. Reported-by: Al Viro <viro@zeniv.linux.org.uk> Cc: David Miller <davem@davemloft.net> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-15Merge branch 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King: "Two fixes this time, one to ensure that the kuser helper option depends on MMU as they aren't available for noMMU targets (and if the option is selected, we end up oopsing.) The second fix plugs a corner case with the decompressor, ensuring that the instruction stream can see the relocated code in every case on ARMv7 CPUs" * 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: ARM: 8198/1: make kuser helpers depend on MMU ARM: 8191/1: decompressor: ensure I-side picks up relocated code
2014-11-15Merge branch 'parisc-3.18-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux Pull parisc updates from Helge Deller: "Changes include: - wire up the bpf syscall - remove CONFIG_64BIT usage from some userspace-exported header files - use compat functions for msgctl, shmat, shmctl and semtimedop syscalls" * 'parisc-3.18-2' of git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux: parisc: Avoid using CONFIG_64BIT in userspace exported headers parisc: Use compat layer for msgctl, shmat, shmctl and semtimedop syscalls parisc: Use BUILD_BUG() instead of undefined functions parisc: Wire up bpf syscall
2014-11-15Merge tag 'for-v3.18-rc' of git://git.infradead.org/battery-2.6Linus Torvalds
Pull power supply updates from Sebastian Reichel: "Power supply and reset changes for the v3.18-rc: - misc. charger-manager fixes - year 2038 fix in ab8500_fg - fix error handling of bq2415x_charger" * tag 'for-v3.18-rc' of git://git.infradead.org/battery-2.6: power: charger-manager: Fix accessing invalidated power supply after charger unbind power: charger-manager: Fix accessing invalidated power supply after fuel gauge unbind power: charger-manager: Avoid recursive thermal get_temp call power_supply: Add no_thermal property to prevent recursive get_temp calls power: bq2415x_charger: Fix memory leak on DTS parsing error power: bq2415x_charger: Properly handle ENODEV from power_supply_get_by_phandle power: ab8500_fg.c: use 64-bit time types
2014-11-15Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm gixes from Dave Airlie: - exynos: infinite loop regressions fixed - i915: one regression - radeon: one race condition on monitor probing - noveau: two regressions - tegra: one vblank regression fix * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: drm/tegra: dc: Add missing call to drm_vblank_on() drm/nouveau/nv50/disp: Fix modeset on G94 drm/gk20a/fb: fix setting of large page size bit drm/radeon: add locking around atombios scratch space usage drm/i915: Fix obj->map_and_fenceable across tiling changes drm/exynos: fix possible infinite loop issue drm/exynos: g2d: fix null pointer dereference drm/exynos: resolve infinite loop issue on non multi-platform drm/exynos: resolve infinite loop issue on multi-platform
2014-11-15kernel: use the gnu89 standard explicitlyKirill A. Shutemov
Sasha Levin reports: "gcc5 changes the default standard to c11, which makes kernel build unhappy Explicitly define the kernel standard to be gnu89 which should keep everything working exactly like it was before gcc5" There are multiple small issues with the new default, but the biggest issue seems to be that the old - and very useful - GNU extension to allow a cast in front of an initializer has gone away. Patch updated by Kirill: "I'm pretty sure all gcc versions you can build kernel with supports -std=gnu89. cc-option is redunrant. We also need to adjust HOSTCFLAGS otherwise allmodconfig fails for me" Note by Andrew Pinski: "Yes it was reported and both problems relating to this extension has been added to gnu99 and gnu11. Though there are other issues with the kernel dealing with extern inline have different semantics between gnu89 and gnu99/11" End result: we may be able to move up to a newer stdc model eventually, but right now the newer models have some annoying deficiencies, so the traditional "gnu89" model ends up being the preferred one. Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Singed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-15Merge tag 'nfs-for-3.18-3' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client bugfixes from Trond Myklebust: "Highlights include: - stable patches to fix NFSv4.x delegation reclaim error paths - fix a bug whereby we were advertising NFSv4.1 but using NFSv4.2 features - fix a use-after-free problem with pNFS block layouts - fix a memory leak in the pNFS files O_DIRECT code - replace an intrusive and Oops-prone performance fix in the NFSv4 atomic open code with a safer one-line version and revert the two original patches" * tag 'nfs-for-3.18-3' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: sunrpc: fix sleeping under rcu_read_lock in gss_stringify_acceptor NFS: Don't try to reclaim delegation open state if recovery failed NFSv4: Ensure that we call FREE_STATEID when NFSv4.x stateids are revoked NFSv4: Fix races between nfs_remove_bad_delegation() and delegation return NFSv4.1: nfs41_clear_delegation_stateid shouldn't trust NFS_DELEGATED_STATE NFSv4: Ensure that we remove NFSv4.0 delegations when state has expired NFS: SEEK is an NFS v4.2 feature nfs: Fix use of uninitialized variable in nfs_getattr() nfs: Remove bogus assignment nfs: remove spurious WARN_ON_ONCE in write path pnfs/blocklayout: serialize GETDEVICEINFO calls nfs: fix pnfs direct write memory leak Revert "NFS: nfs4_do_open should add negative results to the dcache." Revert "NFS: remove BUG possibility in nfs4_open_and_get_state" NFSv4: Ensure nfs_atomic_open set the dentry verifier on ENOENT
2014-11-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input subsystem updates from Dmitry Torokhov: "Mostly small fixups to PS/2 tochpad drivers (ALPS, Elantech, Synaptics) to better deal with specific hardware" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: elantech - update the documentation Input: elantech - provide a sysfs knob for crc_enabled Input: elantech - report the middle button of the touchpad Input: alps - ignore bad data on Dell Latitudes E6440 and E7440 Input: alps - allow up to 2 invalid packets without resetting device Input: alps - ignore potential bare packets when device is out of sync Input: elantech - fix crc_enabled for Fujitsu H730 Input: elantech - use elantech_report_trackpoint for hardware v4 too Input: twl4030-pwrbutton - ensure a wakeup event is recorded. Input: synaptics - add min/max quirk for Lenovo T440s
2014-11-14Merge tag 'arm64-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull arm64 fixes from Catalin Marinas: - fix EFI stub cache maintenance causing aborts during boot on certain platforms - handle byte stores in __clear_user without panicking - fix race condition in aarch64_insn_patch_text_sync() (instruction patching) - Couple of type fixes * tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: arm64: ARCH_PFN_OFFSET should be unsigned long Correct the race condition in aarch64_insn_patch_text_sync() arm64: __clear_user: handle exceptions on strb arm64: Fix data type for physical address arm64: efi: Fix stub cache maintenance
2014-11-14Merge tag 'platform-drivers-x86-v3.18-3' of ↵Linus Torvalds
git://git.infradead.org/users/dvhart/linux-platform-drivers-x86 Pull x86 platform drivers fixlets from Darren Hart: "Just two patches to remove hp_accel events from the keyboard bus stream via an i8042 filter" * tag 'platform-drivers-x86-v3.18-3' of git://git.infradead.org/users/dvhart/linux-platform-drivers-x86: platform: hp_accel: Add SERIO_I8042 as a dependency since it now includes i8042.h/serio.h platform: hp_accel: add a i8042 filter to remove HPQ6000 data from kb bus stream
2014-11-14Merge branch 'for-3.18-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata Pull libata fixes from Tejun Heo: "The most notable is the revert of lock splitting optimization in ahci. This also made the IRQ handling threaded even when there's only one IRQ in use. The conversion missed IRFQ_SHARED leading to screaming IRQs problem in some cases and the threaded IRQ handling showed performance regression in some LKP test cases. The changes are reverted for now. It'll probably be retried once threaded IRQ handling is removed from ahci. Other than that, there's one fix for ahci and several patches adding device IDs" * 'for-3.18-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: ahci: fix AHCI parameters not taken into account ata: sata_rcar: Add r8a7793 device support ahci: Add Device IDs for Intel Sunrise Point PCH ahci: disable MSI instead of NCQ on Samsung pci-e SSDs on macbooks Revert "AHCI: Optimize single IRQ interrupt processing" Revert "AHCI: Do not acquire ata_host::lock from single IRQ handler" ata: sata_rcar: Disable DIPM mode for r8a7790 ES1
2014-11-14Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block layer fixes from Jens Axboe: "Four small fixes that should be merged for the current 3.18-rc series. This pull request contains: - a minor bugfix for computation of best IO priority given two merging requests. From Jan Kara. - the final (final) merge count issue that has been plaguing virtio-blk. From Ming Lei. - enable parallel reinit notify for blk-mq queues, to combine the cost of an RCU grace period across lots of devices. From Tejun Heo. - an error handling fix for the SCSI_IOCTL_SEND_COMMAND ioctl. From Tony Battersby" * 'for-linus' of git://git.kernel.dk/linux-block: block: blk-merge: fix blk_recount_segments() scsi: Fix more error handling in SCSI_IOCTL_SEND_COMMAND blk-mq: make mq_queue_reinit_notify() freeze queues in parallel block: Fix computation of merged request priority
2014-11-14Merge tag 'pm+acpi-3.18-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management fixes from Rafael Wysocki: "These are three regression fixes, two recent (generic power domains, suspend-to-idle) and one older (cpufreq), an ACPI blacklist entry for one more machine having problems with Windows 8 compatibility, a minor cpufreq driver fix (cpufreq-dt) and a fixup for new callback definitions (generic power domains). Specifics: - Fix a crash in the suspend-to-idle code path introduced by a recent commit that forgot to check a pointer against NULL before dereferencing it (Dmitry Eremin-Solenikov). - Fix a boot crash on Exynos5 introduced by a recent commit making that platform use generic Device Tree bindings for power domains which exposed a weakness in the generic power domains framework leading to that crash (Ulf Hansson). - Fix a crash during system resume on systems where cpufreq depends on Operation Performance Points (OPP) for functionality, but CONFIG_OPP is not set. This leads the cpufreq driver registration to fail, but the resume code attempts to restore the pre-suspend cpufreq configuration (which does not exist) nevertheless and crashes. From Geert Uytterhoeven. - Add a new ACPI blacklist entry for Dell Vostro 3546 that has problems if it is reported as Windows 8 compatible to the BIOS (Adam Lee). - Fix swapped arguments in an error message in the cpufreq-dt driver (Abhilash Kesavan). - Fix up the prototypes of new callbacks in struct generic_pm_domain to make them more useful. Users of those callbacks will be added in 3.19 and it's better for them to be based on the correct struct definition in mainline from the start. From Ulf Hansson and Kevin Hilman" * tag 'pm+acpi-3.18-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: PM / Domains: Fix initial default state of the need_restore flag PM / sleep: Fix entering suspend-to-IDLE if no freeze_oops is set PM / Domains: Change prototype for the attach and detach callbacks cpufreq: Avoid crash in resume on SMP without OPP cpufreq: cpufreq-dt: Fix arguments in clock failure error message ACPI / blacklist: blacklist Win8 OSI for Dell Vostro 3546
2014-11-14Merge tag 'firewire-fix' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394 Pull firewire fix from Stefan Richter: "IEEE 1394 (FireWire) subsystem fix: The character device file interface for raw 1394 I/O took uninitialized kernel stack as substitute for missing ioctl() argument data. This could partially show up in subsequent read() output" * tag 'firewire-fix' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394: firewire: cdev: prevent kernel stack leaking into ioctl arguments
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs fix from Al Viro: "Fix for a really embarrassing braino in iov_iter. Kudos to paulus..." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: Fix thinko in iov_iter_single_seg_count
2014-11-14Merge branches 'pm-domains', 'pm-sleep' and 'pm-cpufreq'Rafael J. Wysocki
* pm-domains: PM / Domains: Fix initial default state of the need_restore flag PM / Domains: Change prototype for the attach and detach callbacks * pm-sleep: PM / sleep: Fix entering suspend-to-IDLE if no freeze_oops is set * pm-cpufreq: cpufreq: Avoid crash in resume on SMP without OPP cpufreq: cpufreq-dt: Fix arguments in clock failure error message
2014-11-14Merge branch 'acpi-blacklist'Rafael J. Wysocki
* acpi-blacklist: ACPI / blacklist: blacklist Win8 OSI for Dell Vostro 3546
2014-11-14firewire: cdev: prevent kernel stack leaking into ioctl argumentsStefan Richter
Found by the UC-KLEE tool: A user could supply less input to firewire-cdev ioctls than write- or write/read-type ioctl handlers expect. The handlers used data from uninitialized kernel stack then. This could partially leak back to the user if the kernel subsequently generated fw_cdev_event_'s (to be read from the firewire-cdev fd) which notably would contain the _u64 closure field which many of the ioctl argument structures contain. The fact that the handlers would act on random garbage input is a lesser issue since all handlers must check their input anyway. The fix simply always null-initializes the entire ioctl argument buffer regardless of the actual length of expected user input. That is, a runtime overhead of memset(..., 40) is added to each firewirew-cdev ioctl() call. [Comment from Clemens Ladisch: This part of the stack is most likely to be already in the cache.] Remarks: - There was never any leak from kernel stack to the ioctl output buffer itself. IOW, it was not possible to read kernel stack by a read-type or write/read-type ioctl alone; the leak could at most happen in combination with read()ing subsequent event data. - The actual expected minimum user input of each ioctl from include/uapi/linux/firewire-cdev.h is, in bytes: [0x00] = 32, [0x05] = 4, [0x0a] = 16, [0x0f] = 20, [0x14] = 16, [0x01] = 36, [0x06] = 20, [0x0b] = 4, [0x10] = 20, [0x15] = 20, [0x02] = 20, [0x07] = 4, [0x0c] = 0, [0x11] = 0, [0x16] = 8, [0x03] = 4, [0x08] = 24, [0x0d] = 20, [0x12] = 36, [0x17] = 12, [0x04] = 20, [0x09] = 24, [0x0e] = 4, [0x13] = 40, [0x18] = 4. Reported-by: David Ramos <daramos@stanford.edu> Cc: <stable@vger.kernel.org> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2014-11-13Merge tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhostLinus Torvalds
Pull virtio bugfix from Michael S Tsirkin: "This fixes a crash in virtio console multi-channel mode that got introduced in -rc1" * tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost: virtio_console: move early VQ enablement
2014-11-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) sunhme driver lacks DMA mapping error checks, based upon a report by Meelis Roos. 2) Fix memory leak in mvpp2 driver, from Sudip Mukherjee. 3) DMA memory allocation sizes are wrong in systemport ethernet driver, fix from Florian Fainelli. 4) Fix use after free in mac80211 defragmentation code, from Johannes Berg. 5) Some networking uapi headers missing from Kbuild file, from Stephen Hemminger. 6) TUN driver gets csum_start offset wrong when VLAN accel is enabled, and macvtap has a similar bug, from Herbert Xu. 7) Adjust several tunneling drivers to set dev->iflink after registry, because registry sets that to -1 overwriting whatever we did. From Steffen Klassert. 8) Geneve forgets to set inner tunneling type, causing GSO segmentation to fail on some NICs. From Jesse Gross. 9) Fix several locking bugs in stmmac driver, from Fabrice Gasnier and Giuseppe CAVALLARO. 10) Fix spurious timeouts with NewReno on low traffic connections, from Marcelo Leitner. 11) Fix descriptor updates in enic driver, from Govindarajulu Varadarajan. 12) PPP calls bpf_prog_create() with locks held, which isn't kosher. Fix from Takashi Iwai. 13) Fix NULL deref in SCTP with malformed INIT packets, from Daniel Borkmann. 14) psock_fanout selftest accesses past the end of the mmap ring, fix from Shuah Khan. 15) Fix PTP timestamping for VLAN packets, from Richard Cochran. 16) netlink_unbind() calls in netlink pass wrong initial argument, from Hiroaki SHIMODA. 17) vxlan socket reuse accidently reuses a socket when the address family is different, so we have to explicitly check this, from Marcelo Lietner. 18) Fix missing include in nft_reject_bridge.c breaking the build on ppc and other architectures, from Guenter Roeck. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (75 commits) vxlan: Do not reuse sockets for a different address family smsc911x: power-up phydev before doing a software reset. lib: rhashtable - Remove weird non-ASCII characters from comments net/smsc911x: Fix delays in the PHY enable/disable routines net/smsc911x: Fix rare soft reset timeout issue due to PHY power-down mode netlink: Properly unbind in error conditions. net: ptp: fix time stamp matching logic for VLAN packets. cxgb4 : dcb open-lldp interop fixes selftests/net: psock_fanout seg faults in sock_fanout_read_ring() net: bcmgenet: apply MII configuration in bcmgenet_open() net: bcmgenet: connect and disconnect from the PHY state machine net: qualcomm: Fix dependency ixgbe: phy: fix uninitialized status in ixgbe_setup_phy_link_tnx net: phy: Correctly handle MII ioctl which changes autonegotiation. ipv6: fix IPV6_PKTINFO with v4 mapped net: sctp: fix memory leak in auth key management net: sctp: fix NULL pointer dereference in af->from_addr_param on malformed packet net: ppp: Don't call bpf_prog_create() in ppp_lock net/mlx4_en: Advertize encapsulation offloads features only when VXLAN tunnel is set cxgb4 : Fix bug in DCB app deletion ...
2014-11-13Input: elantech - update the documentationUlrik De Bie
A chapter is added to describe the trackpoint packets. A section is added to describe the behaviour of the knob crc_enabled in sysfs. The introduction of the documentation only mentioned v1/v2, but in the last part it already contains explanation of v3 and v4. The introduction is updated. Signed-off-by: Ulrik De Bie <ulrik.debie-os@e2big.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-11-13Input: elantech - provide a sysfs knob for crc_enabledUlrik De Bie
The detection of crc_enabled is known to fail for Fujitsu H730. A DMI blacklist is added for that, but it can be expected that other laptops will pop up with this. Here a sysfs knob is provided to alter the behaviour of crc_enabled. Writing 0 or 1 to it sets the variable to 0 or 1. Reading it will show the crc_enabled variable (0 or 1). Reported-by: Stefan Valouch <stefan@valouch.com> Signed-off-by: Ulrik De Bie <ulrik.debie-os@e2big.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-11-13Input: elantech - report the middle button of the touchpadUlrik De Bie
In the past, no elantech was known with 3 touchpad mouse buttons. Fujitsu H730 is the first known elantech with a middle button. This commit enables this middle button. For backwards compatibility, the Fujitsu is detected via DMI, and only for this one 3 buttons will be announced. Reported-by: Stefan Valouch <stefan@valouch.com> Signed-off-by: Ulrik De Bie <ulrik.debie-os@e2big.org> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-11-13Input: alps - ignore bad data on Dell Latitudes E6440 and E7440Pali Rohár
Sometimes on Dell Latitude laptops psmouse/alps driver receive invalid ALPS protocol V3 packets with bit7 set in last byte. More often it can be reproduced on Dell Latitude E6440 or E7440 with closed lid and pushing cover above touchpad. If bit7 in last packet byte is set then it is not valid ALPS packet. I was told that ALPS devices never send these packets. It is not know yet who send those packets, it could be Dell EC, bug in BIOS and also bug in touchpad firmware... With this patch alps driver does not process those invalid packets, but instead of reporting PSMOUSE_BAD_DATA, getting into out of sync state, getting back in sync with the next byte and spam dmesg we return PSMOUSE_FULL_PACKET. If driver is truly out of sync we'll fail the checks on the next byte and report PSMOUSE_BAD_DATA then. Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Tested-by: Pali Rohár <pali.rohar@gmail.com> Cc: stable@vger.kernel.org Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-11-13Merge branch 'akpm' (fixes from Andrew Morton)Linus Torvalds
Merge misc fixes from Andrew Morton: "15 fixes" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: MAINTAINERS: add IIO include files kernel/panic.c: update comments for print_tainted mem-hotplug: reset node present pages when hot-adding a new pgdat mem-hotplug: reset node managed pages when hot-adding a new pgdat mm/debug-pagealloc: correct freepage accounting and order resetting fanotify: fix notification of groups with inode & mount marks mm, compaction: prevent infinite loop in compact_zone mm: alloc_contig_range: demote pages busy message from warn to info mm/slab: fix unalignment problem on Malta with EVA due to slab merge mm/page_alloc: restrict max order of merging on isolated pageblock mm/page_alloc: move freepage counting logic to __free_one_page() mm/page_alloc: add freepage on isolate pageblock to correct buddy list mm/page_alloc: fix incorrect isolation behavior by rechecking migratetype mm/compaction: skip the range until proper target pageblock is met zram: avoid kunmap_atomic() of a NULL pointer
2014-11-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client Pull Ceph fixes from Sage Weil: "There is an overflow bug fix for cephfs from Zheng, a fix for handling large authentication ticket buffers in libceph from Ilya, and a few fixes for the request handling code from Ilya that affect RBD volumes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: libceph: change from BUG to WARN for __remove_osd() asserts libceph: clear r_req_lru_item in __unregister_linger_request() libceph: unlink from o_linger_requests when clearing r_osd libceph: do not crash on large auth tickets ceph: fix flush tid comparision
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid Pull HID fixes from Jiri Kosina: - fix for an oops in HID core upon repeated subdriver insertion/removal under certain circumstances, by Benjamin Tissoires - quirk for another Elan Touchscreen device, by Adel Gadllah * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: HID: core: cleanup .claimed field on disconnect HID: usbhid: enable always-poll quirk for Elan Touchscreen 0103
2014-11-13MAINTAINERS: add IIO include filesDaniel Baluta
Files under include/linux/iio were not reported as part of the IIO subsystem. Signed-off-by: Daniel Baluta <daniel.baluta@intel.com> Reported-by: Cristina Ciocan <cristina.ciocan@intel.com> Reviewed-by: Jingoo Han <jg1.han@samsung.com> Cc: Hartmut Knaack <knaack.h@gmx.de> Cc: Lars-Peter Clausen <lars@metafoo.de> Cc: Peter Meerwald <pmeerw@pmeerw.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-13kernel/panic.c: update comments for print_taintedXie XiuQi
Commit 69361eef9056 ("panic: add TAINT_SOFTLOCKUP") added the 'L' flag, but failed to update the comments for print_tainted(). So, update the comments. Signed-off-by: Xie XiuQi <xiexiuqi@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-13mem-hotplug: reset node present pages when hot-adding a new pgdatTang Chen
When memory is hot-added, all the memory is in offline state. So clear all zones' present_pages because they will be updated in online_pages() and offline_pages(). Otherwise, /proc/zoneinfo will corrupt: When the memory of node2 is offline: # cat /proc/zoneinfo ...... Node 2, zone Movable ...... spanned 8388608 present 8388608 managed 0 When we online memory on node2: # cat /proc/zoneinfo ...... Node 2, zone Movable ...... spanned 8388608 present 16777216 managed 8388608 Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com> Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: <stable@vger.kernel.org> [3.16+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-13mem-hotplug: reset node managed pages when hot-adding a new pgdatTang Chen
In free_area_init_core(), zone->managed_pages is set to an approximate value for lowmem, and will be adjusted when the bootmem allocator frees pages into the buddy system. But free_area_init_core() is also called by hotadd_new_pgdat() when hot-adding memory. As a result, zone->managed_pages of the newly added node's pgdat is set to an approximate value in the very beginning. Even if the memory on that node has node been onlined, /sys/device/system/node/nodeXXX/meminfo has wrong value: hot-add node2 (memory not onlined) cat /sys/device/system/node/node2/meminfo Node 2 MemTotal: 33554432 kB Node 2 MemFree: 0 kB Node 2 MemUsed: 33554432 kB Node 2 Active: 0 kB This patch fixes this problem by reset node managed pages to 0 after hot-adding a new node. 1. Move reset_managed_pages_done from reset_node_managed_pages() to reset_all_zones_managed_pages() 2. Make reset_node_managed_pages() non-static 3. Call reset_node_managed_pages() in hotadd_new_pgdat() after pgdat is initialized Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com> Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: <stable@vger.kernel.org> [3.16+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-13mm/debug-pagealloc: correct freepage accounting and order resettingJoonsoo Kim
One thing I did in this patch is fixing freepage accounting. If we clear guard page and link it onto isolate buddy list, we should not increase freepage count. This patch adds conditional branch to skip counting in this case. Without this patch, this overcounting happens frequently if guard order is set and CMA is used. Another thing fixed in this patch is the target to reset order. In __free_one_page(), we check the buddy page whether it is a guard page or not. And, if so, we should clear guard attribute on the buddy page and reset order of it to 0. But, current code resets original page's order rather than buddy one's. Maybe, this doesn't have any problem, because whole merged page's order will be re-assigned soon. But, it is better to correct code. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Gioh Kim <gioh.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-13fanotify: fix notification of groups with inode & mount marksJan Kara
fsnotify() needs to merge inode and mount marks lists when notifying groups about events so that ignore masks from inode marks are reflected in mount mark notifications and groups are notified in proper order (according to priorities). Currently the sorting of the lists done by fsnotify_add_inode_mark() / fsnotify_add_vfsmount_mark() and fsnotify() differed which resulted ignore masks not being used in some cases. Fix the problem by always using the same comparison function when sorting / merging the mark lists. Thanks to Heinrich Schuchardt for improvements of my patch. Link: https://bugzilla.kernel.org/show_bug.cgi?id=87721 Signed-off-by: Jan Kara <jack@suse.cz> Reported-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Tested-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-13mm, compaction: prevent infinite loop in compact_zoneVlastimil Babka
Several people have reported occasionally seeing processes stuck in compact_zone(), even triggering soft lockups, in 3.18-rc2+. Testing a revert of commit e14c720efdd7 ("mm, compaction: remember position within pageblock in free pages scanner") fixed the issue, although the stuck processes do not appear to involve the free scanner. Finally, by code inspection, the bug was found in isolate_migratepages() which uses a slightly different condition to detect if the migration and free scanners have met, than compact_finished(). That has not been a problem until commit e14c720efdd7 allowed the free scanner position between individual invocations to be in the middle of a pageblock. In a relatively rare case, the migration scanner position can end up at the beginning of a pageblock, with the free scanner position in the middle of the same pageblock. If it's the migration scanner's turn, isolate_migratepages() exits immediately (without updating the position), while compact_finished() decides to continue compaction, resulting in a potentially infinite loop. The system can recover only if another process creates enough high-order pages to make the watermark checks in compact_finished() pass. This patch fixes the immediate problem by bumping the migration scanner's position to meet the free scanner in isolate_migratepages(), when both are within the same pageblock. This causes compact_finished() to terminate properly. A more robust check in compact_finished() is planned as a cleanup for better future maintainability. Fixes: e14c720efdd73 ("mm, compaction: remember position within pageblock in free pages scanner) Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Reported-by: P. Christeas <xrg@linux.gr> Tested-by: P. Christeas <xrg@linux.gr> Link: http://marc.info/?l=linux-mm&m=141508604232522&w=2 Reported-by: Norbert Preining <preining@logic.at> Tested-by: Norbert Preining <preining@logic.at> Link: https://lkml.org/lkml/2014/11/4/904 Reported-by: Pavel Machek <pavel@ucw.cz> Link: https://lkml.org/lkml/2014/11/7/164 Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: David Rientjes <rientjes@google.com> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-13mm: alloc_contig_range: demote pages busy message from warn to infoMichal Nazarewicz
Having test_pages_isolated failure message as a warning confuses users into thinking that it is more serious than it really is. In reality, if called via CMA, allocation will be retried so a single test_pages_isolated failure does not prevent allocation from succeeding. Demote the warning message to an info message and reformat it such that the text "failed" does not appear and instead a less worrying "PFNS busy" is used. This message is trivially reproducible on a 10GB x86 machine on 3.16.y kernels configured with CONFIG_DMA_CMA. Signed-off-by: Michal Nazarewicz <mina86@mina86.com> Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Cc: Peter Hurley <peter@hurleysoftware.com> Cc: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-13mm/slab: fix unalignment problem on Malta with EVA due to slab mergeJoonsoo Kim
Unlike SLUB, sometimes, object isn't started at the beginning of the slab in SLAB. This causes the unalignment problem after slab merging is supported by commit 12220dea07f1 ("mm/slab: support slab merge"). Following is the report from Markos that fail to boot on Malta with EVA. Calibrating delay loop... 19.86 BogoMIPS (lpj=99328) pid_max: default: 32768 minimum: 301 Mount-cache hash table entries: 4096 (order: 0, 16384 bytes) Mountpoint-cache hash table entries: 4096 (order: 0, 16384 bytes) Kernel bug detected[#1]: CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.17.0-05639-g12220dea07f1 #1631 task: 1f04f5d8 ti: 1f050000 task.ti: 1f050000 epc : 80141190 alloc_unbound_pwq+0x234/0x304 Not tainted ra : 80141184 alloc_unbound_pwq+0x228/0x304 Process swapper/0 (pid: 1, threadinfo=1f050000, task=1f04f5d8, tls=00000000) Call Trace: alloc_unbound_pwq+0x234/0x304 apply_workqueue_attrs+0x11c/0x294 __alloc_workqueue_key+0x23c/0x470 init_workqueues+0x320/0x400 do_one_initcall+0xe8/0x23c kernel_init_freeable+0x9c/0x224 kernel_init+0x10/0x100 ret_from_kernel_thread+0x14/0x1c [ end trace cb88537fdc8fa200 ] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b alloc_unbound_pwq() allocates slab object from pool_workqueue. This kmem_cache requires 256 bytes alignment, but, current merging code doesn't honor that, and merge it with kmalloc-256. kmalloc-256 requires only cacheline size alignment so that above failure occurs. However, in x86, kmalloc-256 is luckily aligned in 256 bytes, so the problem didn't happen on it. To fix this problem, this patch introduces alignment mismatch check in find_mergeable(). This will fix the problem. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Reported-by: Markos Chandras <Markos.Chandras@imgtec.com> Tested-by: Markos Chandras <Markos.Chandras@imgtec.com> Acked-by: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-13mm/page_alloc: restrict max order of merging on isolated pageblockJoonsoo Kim
Current pageblock isolation logic could isolate each pageblock individually. This causes freepage accounting problem if freepage with pageblock order on isolate pageblock is merged with other freepage on normal pageblock. We can prevent merging by restricting max order of merging to pageblock order if freepage is on isolate pageblock. A side-effect of this change is that there could be non-merged buddy freepage even if finishing pageblock isolation, because undoing pageblock isolation is just to move freepage from isolate buddy list to normal buddy list rather than to consider merging. So, the patch also makes undoing pageblock isolation consider freepage merge. When un-isolation, freepage with more than pageblock order and it's buddy are checked. If they are on normal pageblock, instead of just moving, we isolate the freepage and free it in order to get merged. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Cc: Mel Gorman <mgorman@suse.de> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Minchan Kim <minchan@kernel.org> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Michal Nazarewicz <mina86@mina86.com> Cc: Laura Abbott <lauraa@codeaurora.org> Cc: Heesub Shin <heesub.shin@samsung.com> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Cc: Ritesh Harjani <ritesh.list@gmail.com> Cc: Gioh Kim <gioh.kim@lge.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-13mm/page_alloc: move freepage counting logic to __free_one_page()Joonsoo Kim
All the caller of __free_one_page() has similar freepage counting logic, so we can move it to __free_one_page(). This reduce line of code and help future maintenance. This is also preparation step for "mm/page_alloc: restrict max order of merging on isolated pageblock" which fix the freepage counting problem on freepage with more than pageblock order. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Cc: Mel Gorman <mgorman@suse.de> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Minchan Kim <minchan@kernel.org> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Michal Nazarewicz <mina86@mina86.com> Cc: Laura Abbott <lauraa@codeaurora.org> Cc: Heesub Shin <heesub.shin@samsung.com> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Cc: Ritesh Harjani <ritesh.list@gmail.com> Cc: Gioh Kim <gioh.kim@lge.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-13mm/page_alloc: add freepage on isolate pageblock to correct buddy listJoonsoo Kim
In free_pcppages_bulk(), we use cached migratetype of freepage to determine type of buddy list where freepage will be added. This information is stored when freepage is added to pcp list, so if isolation of pageblock of this freepage begins after storing, this cached information could be stale. In other words, it has original migratetype rather than MIGRATE_ISOLATE. There are two problems caused by this stale information. One is that we can't keep these freepages from being allocated. Although this pageblock is isolated, freepage will be added to normal buddy list so that it could be allocated without any restriction. And the other problem is incorrect freepage accounting. Freepages on isolate pageblock should not be counted for number of freepage. Following is the code snippet in free_pcppages_bulk(). /* MIGRATE_MOVABLE list may include MIGRATE_RESERVEs */ __free_one_page(page, page_to_pfn(page), zone, 0, mt); trace_mm_page_pcpu_drain(page, 0, mt); if (likely(!is_migrate_isolate_page(page))) { __mod_zone_page_state(zone, NR_FREE_PAGES, 1); if (is_migrate_cma(mt)) __mod_zone_page_state(zone, NR_FREE_CMA_PAGES, 1); } As you can see above snippet, current code already handle second problem, incorrect freepage accounting, by re-fetching pageblock migratetype through is_migrate_isolate_page(page). But, because this re-fetched information isn't used for __free_one_page(), first problem would not be solved. This patch try to solve this situation to re-fetch pageblock migratetype before __free_one_page() and to use it for __free_one_page(). In addition to move up position of this re-fetch, this patch use optimization technique, re-fetching migratetype only if there is isolate pageblock. Pageblock isolation is rare event, so we can avoid re-fetching in common case with this optimization. This patch also correct migratetype of the tracepoint output. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Minchan Kim <minchan@kernel.org> Acked-by: Michal Nazarewicz <mina86@mina86.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Cc: Mel Gorman <mgorman@suse.de> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Laura Abbott <lauraa@codeaurora.org> Cc: Heesub Shin <heesub.shin@samsung.com> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Cc: Ritesh Harjani <ritesh.list@gmail.com> Cc: Gioh Kim <gioh.kim@lge.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
