2014-10-26Linux 3.18-rc2v3.18-rc2Linus Torvalds
2014-10-26Merge tag 'armsoc-for-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "Another week, another small batch of fixes. Most of these make zynq, socfpga and sunxi platforms work a bit better: - due to new requirements for regulators, DWMMC on socfpga broke past v3.17 - SMP spinup fix for socfpga - a few DT fixes for zynq - another option (FIXED_REGULATOR) for sunxi is needed that used to be selected by other options but no longer is. - a couple of small DT fixes for at91 - ...and a couple for i.MX" * tag 'armsoc-for-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: dts: imx28-evk: Let i2c0 run at 100kHz ARM: i.MX6: Fix "emi" clock name typo ARM: multi_v7_defconfig: enable CONFIG_MMC_DW_ROCKCHIP ARM: sunxi_defconfig: enable CONFIG_REGULATOR_FIXED_VOLTAGE ARM: dts: socfpga: Add a 3.3V fixed regulator node ARM: dts: socfpga: Fix SD card detect ARM: dts: socfpga: rename gpio nodes ARM: at91/dt: sam9263: fix PLLB frequencies power: reset: at91-reset: fix power down register MAINTAINERS: add atmel ssc driver maintainer entry arm: socfpga: fix fetching cpu1start_addr for SMP ARM: zynq: DT: trivial: Fix mc node ARM: zynq: DT: Add cadence watchdog node ARM: zynq: DT: Add missing reference for memory-controller ARM: zynq: DT: Add missing reference for ADC ARM: zynq: DT: Add missing address for L2 pl310 ARM: zynq: DT: Remove 222 MHz OPP ARM: zynq: DT: Fix GEM register area size
2014-10-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "overlayfs merge + leak fix for d_splice_alias() failure exits" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: overlayfs: embed middle into overlay_readdir_data overlayfs: embed root into overlay_readdir_data overlayfs: make ovl_cache_entry->name an array instead of pointer overlayfs: don't hold ->i_mutex over opening the real directory fix inode leaks on d_splice_alias() failure exits fs: limit filesystem stacking depth overlay: overlay filesystem documentation overlayfs: implement show_options overlayfs: add statfs support overlay filesystem shmem: support RENAME_WHITEOUT ext4: support RENAME_WHITEOUT vfs: add RENAME_WHITEOUT vfs: add whiteout support vfs: export check_sticky() vfs: introduce clone_private_mount() vfs: export __inode_permission() to modules vfs: export do_splice_direct() to modules vfs: add i_op->dentry_open()
2014-10-25Merge tag 'imx-fixes-3.18' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into fixes Merge "ARM: imx: fixes for 3.18" from Shawn Guo: The i.MX fixes for 3.18: - Revert one patch which increases I2C bus frequency on imx28-evk - Fix a typo on imx6q EIM clock name * tag 'imx-fixes-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux: ARM: dts: imx28-evk: Let i2c0 run at 100kHz ARM: i.MX6: Fix "emi" clock name typo Signed-off-by: Olof Johansson <olof@lixom.net>
2014-10-25ARM: dts: imx28-evk: Let i2c0 run at 100kHzimx-fixes-3.18Fabio Estevam
Commit 78b81f4666fb ("ARM: dts: imx28-evk: Run I2C0 at 400kHz") caused issues when doing the following sequence in loop: - Boot the kernel - Perform audio playback - Reboot the system via 'reboot' command In many times the audio card cannot be probed, which causes playback to fail. After restoring to the original i2c0 frequency of 100kHz there is no such problem anymore. This reverts commit 78b81f4666fbb22a20b1e63e5baf197ad2e90e88. Cc: <stable@vger.kernel.org> # 3.16+ Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-10-25ARM: i.MX6: Fix "emi" clock name typoSteve Longerbeam
Fix a typo error, the "emi" names refer to the eim clocks. The change fixes typo in EIM and EIM_SLOW pre-output dividers and selectors clock names. Notably EIM_SLOW clock itself is named correctly. Signed-off-by: Steve Longerbeam <steve_longerbeam@mentor.com> [vladimir_zapolskiy@mentor.com: ported to v3.17] Signed-off-by: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com> Cc: Sascha Hauer <kernel@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-10-24overlayfs: embed middle into overlay_readdir_dataAl Viro
same story... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-10-24overlayfs: embed root into overlay_readdir_dataAl Viro
no sense having it a pointer - all instances have it pointing to local variable in the same stack frame Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-10-24overlayfs: make ovl_cache_entry->name an array instead of pointerAl Viro
2014-10-24overlayfs: don't hold ->i_mutex over opening the real directoryAl Viro
just use it to serialize the assignment Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-10-24Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS fixes from Ralf Baechle: "This is the first round of fixes and tying up loose ends for MIPS. - plenty of fixes for build errors in specific obscure configurations - remove redundant code on the Lantiq platform - removal of a useless SEAD I2C driver that was causing a build issue - fix an earlier TLB exeption handler fix to also work on Octeon. - fix ISA level dependencies in FPU emulator's instruction decoding. - don't hardcode kernel command line in Octeon software emulator. - fix an earlier fix for the Loondson 2 clock setting" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: MIPS: SEAD3: Fix I2C device registration. MIPS: SEAD3: Nuke PIC32 I2C driver. MIPS: ftrace: Fix a microMIPS build problem MIPS: MSP71xx: Fix build error MIPS: Malta: Do not build the malta-amon.c file if CMP is not enabled MIPS: Prevent compiler warning from cop2_{save,restore} MIPS: Kconfig: Add missing MIPS_CPS dependencies to PM and cpuidle MIPS: idle: Remove leftover __pastwait symbol and its references MIPS: Sibyte: Include the swarm subdir to the sb1250 LittleSur builds MIPS: ptrace.h: Add a missing include MIPS: ath79: Fix compilation error when CONFIG_PCI is disabled MIPS: MSP71xx: Remove compilation error when CONFIG_MIPS_MT is present MIPS: Octeon: Remove special case for simulator command line. MIPS: tlbex: Properly fix HUGE TLB Refill exception handler MIPS: loongson2_cpufreq: Fix CPU clock rate setting mismerge pci: pci-lantiq: remove duplicate check on resource MIPS: Lasat: Add missing CONFIG_PROC_FS dependency to PICVUE_PROC MIPS: cp1emu: Fix ISA restrictions for cop1x_op instructions
2014-10-24Merge tag 'arm64-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull arm64 fixes from Catalin Marinas: - enable 48-bit VA space now that KVM has been fixed, together with a couple of fixes for pgd allocation alignment and initial memblock current_limit. There is still a dependency on !ARM_SMMU which needs to be updated as it uses the page table manipulation macros of the host kernel - eBPF fixes following changes/conflicts during the merging window - Compat types affecting compat_elf_prpsinfo - Compilation error on UP builds - ASLR fix when /proc/sys/kernel/randomize_va_space == 0 - DT definitions for CLCD support on ARMv8 model platform * tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: arm64: Fix memblock current_limit with 64K pages and 48-bit VA arm64: ASLR: Don't randomise text when randomise_va_space == 0 arm64: vexpress: Add CLCD support to the ARMv8 model platform arm64: Fix compilation error on UP builds Documentation/arm64/memory.txt: fix typo net: bpf: arm64: minor fix of type in jited arm64: bpf: add 'load 64-bit immediate' instruction arm64: bpf: add 'shift by register' instructions net: bpf: arm64: address randomize and write protect JIT code arm64: mm: Correct fixmap pagetable types arm64: compat: fix compat types affecting struct compat_elf_prpsinfo arm64: Align less than PAGE_SIZE pgds naturally arm64: Allow 48-bits VA space without ARM_SMMU
2014-10-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
Pull two sparc fixes from David Miller: 1) Fix boots with gcc-4.9 compiled sparc64 kernels. 2) Add missing __get_user_pages_fast() on sparc64 to fix hangs on futexes used in transparent hugepage areas. It's really idiotic to have a weak symbolled fallback that just returns zero, and causes this kind of bug. There should be no backup implementation and the link should fail if the architecture fails to provide __get_user_pages_fast() and supports transparent hugepages. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: sparc64: Implement __get_user_pages_fast(). sparc64: Fix register corruption in top-most kernel stack frame during boot.
2014-10-24Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull kvm fixes from Paolo Bonzini: "This is a pretty large update. I think it is roughly as big as what I usually had for the _whole_ rc period. There are a few bad bugs where the guest can OOPS or crash the host. We have also started looking at attack models for nested virtualization; bugs that usually result in the guest ring 0 crashing itself become more worrisome if you have nested virtualization, because the nested guest might bring down the non-nested guest as well. For current uses of nested virtualization these do not really have a security impact, but you never know and bugs are bugs nevertheless. A lot of these bugs are in 3.17 too, resulting in a large number of stable@ Ccs. I checked that all the patches apply there with no conflicts" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: kvm: vfio: fix unregister kvm_device_ops of vfio KVM: x86: Wrong assertion on paging_tmpl.h kvm: fix excessive pages un-pinning in kvm_iommu_map error path. KVM: x86: PREFETCH and HINT_NOP should have SrcMem flag KVM: x86: Emulator does not decode clflush well KVM: emulate: avoid accessing NULL ctxt->memopp KVM: x86: Decoding guest instructions which cross page boundary may fail kvm: x86: don't kill guest on unknown exit reason kvm: vmx: handle invvpid vm exit gracefully KVM: x86: Handle errors when RIP is set during far jumps KVM: x86: Emulator fixes for eip canonical checks on near branches KVM: x86: Fix wrong masking on relative jump/call KVM: x86: Improve thread safety in pit KVM: x86: Prevent host from panicking on shared MSR writes. KVM: x86: Check non-canonical addresses upon WRMSR
2014-10-24Merge tag 'stable/for-linus-3.18-b-rc1-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull xen bug fixes from David Vrabel: - Fix regression in xen_clocksource_read() which caused all Xen guests to crash early in boot. - Several fixes for super rare race conditions in the p2m. - Assorted other minor fixes. * tag 'stable/for-linus-3.18-b-rc1-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: xen/pci: Allocate memory for physdev_pci_device_add's optarr x86/xen: panic on bad Xen-provided memory map x86/xen: Fix incorrect per_cpu accessor in xen_clocksource_read() x86/xen: avoid race in p2m handling x86/xen: delay construction of mfn_list_list x86/xen: avoid writing to freed memory after race in p2m handling xen/balloon: Don't continue ballooning when BP_ECANCELED is encountered
2014-10-24Merge tag 'sound-3.18-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "Here are a chunk of small fixes since rc1: two PCM core fixes, one is a long-standing annoyance about lockdep and another is an ARM64 mmap fix. The rest are a HD-audio HDMI hotplug notification fix, a fix for missing NULL termination in Realtek codec quirks and a few new device/codec-specific quirks as usual" * tag 'sound-3.18-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda - Add missing terminating entry to SND_HDA_PIN_QUIRK macro ALSA: pcm: Fix false lockdep warnings ALSA: hda - Fix inverted LED gpio setup for Lenovo Ideapad ALSA: hda - hdmi: Fix missing ELD change event on plug/unplug ALSA: usb-audio: Add support for Steinberg UR22 USB interface ALSA: ALC283 codec - Avoid pop noise on headphones during suspend/resume ALSA: pcm: use the same dma mmap codepath both for arm and arm64
2014-10-24Merge tag 'random_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random Pull /dev/random updates from Ted Ts'o: "This adds a memzero_explicit() call which is guaranteed not to be optimized away by GCC. This is important when we are wiping cryptographically sensitive material" * tag 'random_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random: crypto: memzero_explicit - make sure to clear out sensitive data random: add and use memzero_explicit() for clearing data
2014-10-24Merge tag 'pm+acpi-3.18-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management updates from Rafael Wysocki: "This is material that didn't make it to my 3.18-rc1 pull request for various reasons, mostly related to timing and travel (LinuxCon EU / LPC) plus a couple of fixes for recent bugs. The only really new thing here is the PM QoS class for memory bandwidth, but it is simple enough and users of it will be added in the next cycle. One major change in behavior is that platform devices enumerated by ACPI will use 32-bit DMA mask by default. Also included is an ACPICA update to a new upstream release, but that's mostly cleanups, changes in tools and similar. The rest is fixes and cleanups mostly. Specifics: - Fix for a recent PCI power management change that overlooked the fact that some IRQ chips might not be able to configure PCIe PME for system wakeup from Lucas Stach. - Fix for a bug introduced in 3.17 where acpi_device_wakeup() is called with a wrong ordering of arguments from Zhang Rui. - A bunch of intel_pstate driver fixes (all -stable candidates) from Dirk Brandewie, Gabriele Mazzotta and Pali Rohár. - Fixes for a rather long-standing problem with the OOM killer and the freezer that frozen processes killed by the OOM do not actually release any memory until they are thawed, so OOM-killing them is rather pointless, with a couple of cleanups on top (Michal Hocko, Cong Wang, Rafael J Wysocki). - ACPICA update to upstream release 20140926, inlcuding mostly cleanups reducing differences between the upstream ACPICA and the kernel code, tools changes (acpidump, acpiexec) and support for the _DDN object (Bob Moore, Lv Zheng). - New PM QoS class for memory bandwidth from Tomeu Vizoso. - Default 32-bit DMA mask for platform devices enumerated by ACPI (this change is mostly needed for some drivers development in progress targeted at 3.19) from Heikki Krogerus. - ACPI EC driver cleanups, mostly related to debugging, from Lv Zheng. - cpufreq-dt driver updates from Thomas Petazzoni. - powernv cpuidle driver update from Preeti U Murthy" * tag 'pm+acpi-3.18-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (34 commits) intel_pstate: Correct BYT VID values. intel_pstate: Fix BYT frequency reporting intel_pstate: Don't lose sysfs settings during cpu offline cpufreq: intel_pstate: Reflect current no_turbo state correctly cpufreq: expose scaling_cur_freq sysfs file for set_policy() drivers cpufreq: intel_pstate: Fix setting max_perf_pct in performance policy PCI / PM: handle failure to enable wakeup on PCIe PME ACPI: invoke acpi_device_wakeup() with correct parameters PM / freezer: Clean up code after recent fixes PM: convert do_each_thread to for_each_process_thread OOM, PM: OOM killed task shouldn't escape PM suspend freezer: remove obsolete comments in __thaw_task() freezer: Do not freeze tasks killed by OOM killer ACPI / platform: provide default DMA mask cpuidle: powernv: Populate cpuidle state details by querying the device-tree cpufreq: cpufreq-dt: adjust message related to regulators cpufreq: cpufreq-dt: extend with platform_data cpufreq: allow driver-specific data ACPI / EC: Cleanup coding style. ACPI / EC: Refine event/query debugging messages. ...
2014-10-24Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux Pull thermal management updates from Zhang Rui: "Sorry that I missed the merge window as there is a bug found in the last minute, and I have to fix it and wait for the code to be tested in linux-next tree for a few days. Now the buggy patch has been dropped entirely from my next branch. Thus I hope those changes can still be merged in 3.18-rc2 as most of them are platform thermal driver changes. Specifics: - introduce ACPI INT340X thermal drivers. Newer laptops and tablets may have thermal sensors and other devices with thermal control capabilities that are exposed for the OS to use via the ACPI INT340x device objects. Several drivers are introduced to expose the temperature information and cooling ability from these objects to user-space via the normal thermal framework. From: Lu Aaron, Lan Tianyu, Jacob Pan and Zhang Rui. - introduce a new thermal governor, which just uses a hysteresis to switch abruptly on/off a cooling device. This governor can be used to control certain fan devices that can not be throttled but just switched on or off. From: Peter Feuerer. - introduce support for some new thermal interrupt functions on i.MX6SX, in IMX thermal driver. From: Anson, Huang. - introduce tracing support on thermal framework. From: Punit Agrawal. - small fixes in OF thermal and thermal step_wise governor" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: (25 commits) Thermal: int340x thermal: select ACPI fan driver Thermal: int3400_thermal: use acpi_thermal_rel parsing APIs Thermal: int340x_thermal: expose acpi thermal relationship tables Thermal: introduce int3403 thermal driver Thermal: introduce INT3402 thermal driver Thermal: move the KELVIN_TO_MILLICELSIUS macro to thermal.h ACPI / Fan: support INT3404 thermal device ACPI / Fan: add ACPI 4.0 style fan support ACPI / fan: convert to platform driver ACPI / fan: use acpi_device_xxx_power instead of acpi_bus equivelant ACPI / fan: remove no need check for device pointer ACPI / fan: remove unused macro Thermal: int3400 thermal: register to thermal framework Thermal: int3400 thermal: add capability to detect supporting UUIDs Thermal: introduce int3400 thermal driver ACPI: add ACPI_TYPE_LOCAL_REFERENCE support to acpi_extract_package() ACPI: make acpi_create_platform_device() an external API thermal: step_wise: fix: Prevent from binary overflow when trend is dropping ACPI: introduce ACPI int340x thermal scan handler thermal: Added Bang-bang thermal governor ...
2014-10-24arm64: Fix memblock current_limit with 64K pages and 48-bit VACatalin Marinas
With 48-bit VA space, the 64K page configuration uses 3 levels instead of 2 and PUD_SIZE != PMD_SIZE. Since with 64K pages we only cover PMD_SIZE with the initial swapper_pg_dir populated in head.S, the memblock current_limit needs to be set accordingly in map_mem() to avoid allocating unmapped memory. The memblock current_limit is progressively increased as more blocks are mapped. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2014-10-24sparc64: Implement __get_user_pages_fast().David S. Miller
It is not sufficient to only implement get_user_pages_fast(), you must also implement the atomic version __get_user_pages_fast() otherwise you end up using the weak symbol fallback implementation which simply returns zero. This is dangerous, because it causes the futex code to loop forever if transparent hugepages are supported (see get_futex_key()). Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-24sparc64: Fix register corruption in top-most kernel stack frame during boot.David S. Miller
Meelis Roos reported that kernels built with gcc-4.9 do not boot, we eventually narrowed this down to only impacting machines using UltraSPARC-III and derivitive cpus. The crash happens right when the first user process is spawned: [ 54.451346] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000004 [ 54.451346] [ 54.571516] CPU: 1 PID: 1 Comm: init Not tainted 3.16.0-rc2-00211-gd7933ab #96 [ 54.666431] Call Trace: [ 54.698453] [0000000000762f8c] panic+0xb0/0x224 [ 54.759071] [000000000045cf68] do_exit+0x948/0x960 [ 54.823123] [000000000042cbc0] fault_in_user_windows+0xe0/0x100 [ 54.902036] [0000000000404ad0] __handle_user_windows+0x0/0x10 [ 54.978662] Press Stop-A (L1-A) to return to the boot prom [ 55.050713] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000004 Further investigation showed that compiling only per_cpu_patch() with an older compiler fixes the boot. Detailed analysis showed that the function is not being miscompiled by gcc-4.9, but it is using a different register allocation ordering. With the gcc-4.9 compiled function, something during the code patching causes some of the %i* input registers to get corrupted. Perhaps we have a TLB miss path into the firmware that is deep enough to cause a register window spill and subsequent restore when we get back from the TLB miss trap. Let's plug this up by doing two things: 1) Stop using the firmware stack for client interface calls into the firmware. Just use the kernel's stack. 2) As soon as we can, call into a new function "start_early_boot()" to put a one-register-window buffer between the firmware's deepest stack frame and the top-most initial kernel one. Reported-by: Meelis Roos <mroos@linux.ee> Tested-by: Meelis Roos <mroos@linux.ee> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-24arm64: ASLR: Don't randomise text when randomise_va_space == 0Arun Chandran
When user asks to turn off ASLR by writing "0" to /proc/sys/kernel/randomize_va_space there should not be any randomization to mmap base, stack, VDSO, libs, text and heap Currently arm64 violates this behavior by randomising text. Fix this by defining a constant ELF_ET_DYN_BASE. The randomisation of mm->mmap_base is done by setup_new_exec -> arch_pick_mmap_layout -> mmap_base -> mmap_rnd. Signed-off-by: Arun Chandran <achandran@mvista.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2014-10-24MIPS: SEAD3: Fix I2C device registration.Ralf Baechle
This isn't a module and shouldn't be one. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-10-24kvm: vfio: fix unregister kvm_device_ops of vfioWanpeng Li
After commit 80ce163 (KVM: VFIO: register kvm_device_ops dynamically), kvm_device_ops of vfio can be registered dynamically. Commit 3c3c29fd (kvm-vfio: do not use module_init) move the dynamic register invoked by kvm_init in order to fix broke unloading of the kvm module. However, kvm_device_ops of vfio is unregistered after rmmod kvm-intel module which lead to device type collision detection warning after kvm-intel module reinsmod. WARNING: CPU: 1 PID: 10358 at /root/cathy/kvm/arch/x86/kvm/../../../virt/kvm/kvm_main.c:3289 kvm_init+0x234/0x282 [kvm]() Modules linked in: kvm_intel(O+) kvm(O) nfsv3 nfs_acl auth_rpcgss oid_registry nfsv4 dns_resolver nfs fscache lockd sunrpc pci_stub bridge stp llc autofs4 8021q cpufreq_ondemand ipv6 joydev microcode pcspkr igb i2c_algo_bit ehci_pci ehci_hcd e1000e i2c_i801 ixgbe ptp pps_core hwmon mdio tpm_tis tpm ipmi_si ipmi_msghandler acpi_cpufreq isci libsas scsi_transport_sas button dm_mirror dm_region_hash dm_log dm_mod [last unloaded: kvm_intel] CPU: 1 PID: 10358 Comm: insmod Tainted: G W O 3.17.0-rc1 #2 Hardware name: Intel Corporation S2600CP/S2600CP, BIOS RMLSDP.86I.00.29.D696.1311111329 11/11/2013 0000000000000cd9 ffff880ff08cfd18 ffffffff814a61d9 0000000000000cd9 0000000000000000 ffff880ff08cfd58 ffffffff810417b7 ffff880ff08cfd48 ffffffffa045bcac ffffffffa049c420 0000000000000040 00000000000000ff Call Trace: [<ffffffff814a61d9>] dump_stack+0x49/0x60 [<ffffffff810417b7>] warn_slowpath_common+0x7c/0x96 [<ffffffffa045bcac>] ? kvm_init+0x234/0x282 [kvm] [<ffffffff810417e6>] warn_slowpath_null+0x15/0x17 [<ffffffffa045bcac>] kvm_init+0x234/0x282 [kvm] [<ffffffffa016e995>] vmx_init+0x1bf/0x42a [kvm_intel] [<ffffffffa016e7d6>] ? vmx_check_processor_compat+0x64/0x64 [kvm_intel] [<ffffffff810002ab>] do_one_initcall+0xe3/0x170 [<ffffffff811168a9>] ? __vunmap+0xad/0xb8 [<ffffffff8109c58f>] do_init_module+0x2b/0x174 [<ffffffff8109d414>] load_module+0x43e/0x569 [<ffffffff8109c6d8>] ? do_init_module+0x174/0x174 [<ffffffff8109c75a>] ? copy_module_from_user+0x39/0x82 [<ffffffff8109b7dd>] ? module_sect_show+0x20/0x20 [<ffffffff8109d65f>] SyS_init_module+0x54/0x81 [<ffffffff814a9a12>] system_call_fastpath+0x16/0x1b ---[ end trace 0626f4a3ddea56f3 ]--- The bug can be reproduced by: rmmod kvm_intel.ko insmod kvm_intel.ko without rmmod/insmod kvm.ko This patch fixes the bug by unregistering kvm_device_ops of vfio when the kvm-intel module is removed. Reported-by: Liu Rongrong <rongrongx.liu@intel.com> Fixes: 3c3c29fd0d7cddc32862c350d0700ce69953e3bd Signed-off-by: Wanpeng Li <wanpeng.li@linux.intel.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-10-24KVM: x86: Wrong assertion on paging_tmpl.hNadav Amit
Even after the recent fix, the assertion on paging_tmpl.h is triggered. Apparently, the assertion wants to check that the PAE is always set on long-mode, but does it in incorrect way. Note that the assertion is not enabled unless the code is debugged by defining MMU_DEBUG. Signed-off-by: Nadav Amit <namit@cs.technion.ac.il> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-10-24kvm: fix excessive pages un-pinning in kvm_iommu_map error path.Quentin Casasnovas
The third parameter of kvm_unpin_pages() when called from kvm_iommu_map_pages() is wrong, it should be the number of pages to un-pin and not the page size. This error was facilitated with an inconsistent API: kvm_pin_pages() takes a size, but kvn_unpin_pages() takes a number of pages, so fix the problem by matching the two. This was introduced by commit 350b8bd ("kvm: iommu: fix the third parameter of kvm_iommu_put_pages (CVE-2014-3601)"), which fixes the lack of un-pinning for pages intended to be un-pinned (i.e. memory leak) but unfortunately potentially aggravated the number of pages we un-pin that should have stayed pinned. As far as I understand though, the same practical mitigations apply. This issue was found during review of Red Hat 6.6 patches to prepare Ksplice rebootless updates. Thanks to Vegard for his time on a late Friday evening to help me in understanding this code. Fixes: 350b8bd ("kvm: iommu: fix the third parameter of... (CVE-2014-3601)") Cc: stable@vger.kernel.org Signed-off-by: Quentin Casasnovas <quentin.casasnovas@oracle.com> Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com> Signed-off-by: Jamie Iles <jamie.iles@oracle.com> Reviewed-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-10-24KVM: x86: PREFETCH and HINT_NOP should have SrcMem flagNadav Amit
The decode phase of the x86 emulator assumes that every instruction with the ModRM flag, and which can be used with RIP-relative addressing, has either SrcMem or DstMem. This is not the case for several instructions - prefetch, hint-nop and clflush. Adding SrcMem|NoAccess for prefetch and hint-nop and SrcMem for clflush. This fixes CVE-2014-8480. Fixes: 41061cdb98a0bec464278b4db8e894a3121671f5 Cc: stable@vger.kernel.org Signed-off-by: Nadav Amit <namit@cs.technion.ac.il> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-10-24KVM: x86: Emulator does not decode clflush wellNadav Amit
Currently, all group15 instructions are decoded as clflush (e.g., mfence, xsave). In addition, the clflush instruction requires no prefix (66/f2/f3) would exist. If prefix exists it may encode a different instruction (e.g., clflushopt). Creating a group for clflush, and different group for each prefix. This has been the case forever, but the next patch needs the cflush group in order to fix a bug introduced in 3.17. Fixes: 41061cdb98a0bec464278b4db8e894a3121671f5 Cc: stable@vger.kernel.org Signed-off-by: Nadav Amit <namit@cs.technion.ac.il> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-10-24KVM: emulate: avoid accessing NULL ctxt->memoppPaolo Bonzini
A failure to decode the instruction can cause a NULL pointer access. This is fixed simply by moving the "done" label as close as possible to the return. This fixes CVE-2014-8481. Reported-by: Andy Lutomirski <luto@amacapital.net> Cc: stable@vger.kernel.org Fixes: 41061cdb98a0bec464278b4db8e894a3121671f5 Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-10-24MIPS: SEAD3: Nuke PIC32 I2C driver.Ralf Baechle
A platform driver for which nothing ever registers the corresponding platform device. Also it was driving the same hardware as sead3-i2c-drv.c so redundant anyway and couldn't co-exist with that driver because each of them was using a private spinlock to protect access to the same hardware resources. This also fixes a randconfig problem: arch/mips/mti-sead3/sead3-pic32-i2c-drv.c: In function 'i2c_platform_probe': arch/mips/mti-sead3/sead3-pic32-i2c-drv.c:345:2: error: implicit declaration of function 'i2c_add_numbered_adapter' [-Werror=implicit-function-declaration] ret = i2c_add_numbered_adapter(&priv->adap); ^ arch/mips/mti-sead3/sead3-pic32-i2c-drv.c: In function 'i2c_platform_remove': arch/mips/mti-sead3/sead3-pic32-i2c-drv.c:361:2: error: implicit declaration of function 'i2c_del_adapter' [-Werror=implicit-function-declaration] i2c_del_adapter(&priv->adap); Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-10-24KVM: x86: Decoding guest instructions which cross page boundary may failNadav Amit
Once an instruction crosses a page boundary, the size read from the second page disregards the common case that part of the operand resides on the first page. As a result, fetch of long insturctions may fail, and thereby cause the decoding to fail as well. Cc: stable@vger.kernel.org Fixes: 5cfc7e0f5e5e1adf998df94f8e36edaf5d30d38e Signed-off-by: Nadav Amit <namit@cs.technion.ac.il> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-10-24kvm: x86: don't kill guest on unknown exit reasonMichael S. Tsirkin
KVM_EXIT_UNKNOWN is a kvm bug, we don't really know whether it was triggered by a priveledged application. Let's not kill the guest: WARN and inject #UD instead. Cc: stable@vger.kernel.org Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-10-24kvm: vmx: handle invvpid vm exit gracefullyPetr Matousek
On systems with invvpid instruction support (corresponding bit in IA32_VMX_EPT_VPID_CAP MSR is set) guest invocation of invvpid causes vm exit, which is currently not handled and results in propagation of unknown exit to userspace. Fix this by installing an invvpid vm exit handler. This is CVE-2014-3646. Cc: stable@vger.kernel.org Signed-off-by: Petr Matousek <pmatouse@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-10-24KVM: x86: Handle errors when RIP is set during far jumpsNadav Amit
Far jmp/call/ret may fault while loading a new RIP. Currently KVM does not handle this case, and may result in failed vm-entry once the assignment is done. The tricky part of doing so is that loading the new CS affects the VMCS/VMCB state, so if we fail during loading the new RIP, we are left in unconsistent state. Therefore, this patch saves on 64-bit the old CS descriptor and restores it if loading RIP failed. This fixes CVE-2014-3647. Cc: stable@vger.kernel.org Signed-off-by: Nadav Amit <namit@cs.technion.ac.il> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-10-24KVM: x86: Emulator fixes for eip canonical checks on near branchesNadav Amit
Before changing rip (during jmp, call, ret, etc.) the target should be asserted to be canonical one, as real CPUs do. During sysret, both target rsp and rip should be canonical. If any of these values is noncanonical, a #GP exception should occur. The exception to this rule are syscall and sysenter instructions in which the assigned rip is checked during the assignment to the relevant MSRs. This patch fixes the emulator to behave as real CPUs do for near branches. Far branches are handled by the next patch. This fixes CVE-2014-3647. Cc: stable@vger.kernel.org Signed-off-by: Nadav Amit <namit@cs.technion.ac.il> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-10-24KVM: x86: Fix wrong masking on relative jump/callNadav Amit
Relative jumps and calls do the masking according to the operand size, and not according to the address size as the KVM emulator does today. This patch fixes KVM behavior. Cc: stable@vger.kernel.org Signed-off-by: Nadav Amit <namit@cs.technion.ac.il> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-10-24KVM: x86: Improve thread safety in pitAndy Honig
There's a race condition in the PIT emulation code in KVM. In __kvm_migrate_pit_timer the pit_timer object is accessed without synchronization. If the race condition occurs at the wrong time this can crash the host kernel. This fixes CVE-2014-3611. Cc: stable@vger.kernel.org Signed-off-by: Andrew Honig <ahonig@google.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-10-24KVM: x86: Prevent host from panicking on shared MSR writes.Andy Honig
The previous patch blocked invalid writes directly when the MSR is written. As a precaution, prevent future similar mistakes by gracefulling handle GPs caused by writes to shared MSRs. Cc: stable@vger.kernel.org Signed-off-by: Andrew Honig <ahonig@google.com> [Remove parts obsoleted by Nadav's patch. - Paolo] Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-10-24KVM: x86: Check non-canonical addresses upon WRMSRNadav Amit
Upon WRMSR, the CPU should inject #GP if a non-canonical value (address) is written to certain MSRs. The behavior is "almost" identical for AMD and Intel (ignoring MSRs that are not implemented in either architecture since they would anyhow #GP). However, IA32_SYSENTER_ESP and IA32_SYSENTER_EIP cause #GP if non-canonical address is written on Intel but not on AMD (which ignores the top 32-bits). Accordingly, this patch injects a #GP on the MSRs which behave identically on Intel and AMD. To eliminate the differences between the architecutres, the value which is written to IA32_SYSENTER_ESP and IA32_SYSENTER_EIP is turned to canonical value before writing instead of injecting a #GP. Some references from Intel and AMD manuals: According to Intel SDM description of WRMSR instruction #GP is expected on WRMSR "If the source register contains a non-canonical address and ECX specifies one of the following MSRs: IA32_DS_AREA, IA32_FS_BASE, IA32_GS_BASE, IA32_KERNEL_GS_BASE, IA32_LSTAR, IA32_SYSENTER_EIP, IA32_SYSENTER_ESP." According to AMD manual instruction manual: LSTAR/CSTAR (SYSCALL): "The WRMSR instruction loads the target RIP into the LSTAR and CSTAR registers. If an RIP written by WRMSR is not in canonical form, a general-protection exception (#GP) occurs." IA32_GS_BASE and IA32_FS_BASE (WRFSBASE/WRGSBASE): "The address written to the base field must be in canonical form or a #GP fault will occur." IA32_KERNEL_GS_BASE (SWAPGS): "The address stored in the KernelGSbase MSR must be in canonical form." This patch fixes CVE-2014-3610. Cc: stable@vger.kernel.org Signed-off-by: Nadav Amit <namit@cs.technion.ac.il> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-10-24ALSA: hda - Add missing terminating entry to SND_HDA_PIN_QUIRK macroDavid Henningsson
Without this terminating entry, the pin matching would continue across random memory until a zero or a non-matching entry was found. The result being that in some cases, the pin quirk would not be applied correctly. Cc: stable@vger.kernel.org Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-10-23Merge tag 'socfpga_fixes_for_3.18' of ↵Olof Johansson
git://git.rocketboards.org/linux-socfpga-next into fixes Merge "SOCFPGA fixes for 3.18" from Dinh Nguyen: These patches fixes an SMP and SDMMC driver hang during boot up on the SOCFPGA platform. Patch "arm: socfpga: fix fetching cpu1start_addr for SMP" fixes the SMP trampoline code in order for CPU1 to correctly fetch it's cpu1start_addr. Patch "ARM: dts: socfpga: rename gpio nodes" renames that GPIO node in order to allow a standard way of specifying status="okay" in the board DTS file. Patch "ARM: dts: socfpga: Fix SD card detect" fixes a SDMMC driver hang during boot. The reason for the hang was the deferred probe of the SDMMC driver was waiting for the GPIO resource that would never come. Patch "ARM: dts: socfpga: Add a 3.3V fixed regulator node" adds a fixed regulator node for the SDMMC driver to use. * tag 'socfpga_fixes_for_3.18' of git://git.rocketboards.org/linux-socfpga-next: ARM: dts: socfpga: Add a 3.3V fixed regulator node ARM: dts: socfpga: Fix SD card detect ARM: dts: socfpga: rename gpio nodes arm: socfpga: fix fetching cpu1start_addr for SMP Signed-off-by: Olof Johansson <olof@lixom.net>
2014-10-23Merge tag 'at91-fixes' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/nferre/linux-at91 into fixes Merge "at91: fixes for v3.18 #1" from Nicholas Ferre: First AT91 fixes for 3.18: - one more MAINTAINERS entry for the SSC driver - a fix for the newly introduced power/reset driver - a fix on at91sam9263 USB due to PLLB misconfiguration * tag 'at91-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/nferre/linux-at91: ARM: at91/dt: sam9263: fix PLLB frequencies power: reset: at91-reset: fix power down register MAINTAINERS: add atmel ssc driver maintainer entry Signed-off-by: Olof Johansson <olof@lixom.net>
2014-10-23Merge tag 'zynq-dt-fixes-for-3.18' of https://github.com/Xilinx/linux-xlnx ↵Olof Johansson
into fixes Merge "Xilinx Zynq dt fixes for v3.18" from Michal Simek: arm: Xilinx Zynq DT fixes for v3.18 - Fix gem register size - Fix OPP - Add missing references - Trivial cleanup * tag 'zynq-dt-fixes-for-3.18' of https://github.com/Xilinx/linux-xlnx: ARM: zynq: DT: trivial: Fix mc node ARM: zynq: DT: Add cadence watchdog node ARM: zynq: DT: Add missing reference for memory-controller ARM: zynq: DT: Add missing reference for ADC ARM: zynq: DT: Add missing address for L2 pl310 ARM: zynq: DT: Remove 222 MHz OPP ARM: zynq: DT: Fix GEM register area size Signed-off-by: Olof Johansson <olof@lixom.net>
2014-10-23ARM: multi_v7_defconfig: enable CONFIG_MMC_DW_ROCKCHIPOlof Johansson
Allows booting from SD/MMC on RK3288 and other platforms. Added here so I can enable the board in the boot farm. Signed-off-by: Olof Johansson <olof@lixom.net>
2014-10-23ARM: sunxi_defconfig: enable CONFIG_REGULATOR_FIXED_VOLTAGEOlof Johansson
I missed in 9a2ad529ed26 that REGULATOR_FIXED_VOLTAGE had also gotten deselected, so it needs to be added back as an explicit option. Signed-off-by: Olof Johansson <olof@lixom.net>
2014-10-23Merge branch 'overlayfs.v25' of ↵Al Viro
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs into for-linus
2014-10-23fix inode leaks on d_splice_alias() failure exitsAl Viro
d_splice_alias() callers expect it to either stash the inode reference into a new alias, or drop the inode reference. That makes it possible to just return d_splice_alias() result from ->lookup() instance, without any extra housekeeping required. Unfortunately, that should include the failure exits. If d_splice_alias() returns an error, it leaves the dentry it has been given negative and thus it *must* drop the inode reference. Easily fixed, but it goes way back and will need backporting. Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-10-24MIPS: ftrace: Fix a microMIPS build problemMarkos Chandras
Code before the .fixup section needs to have the .insn directive. This has no side effects on MIPS32/64 but it affects the way microMIPS loads the address for the return label. Fixes the following build problem: mips-linux-gnu-ld: arch/mips/built-in.o: .fixup+0x4a0: Unsupported jump between ISA modes; consider recompiling with interlinking enabled. mips-linux-gnu-ld: final link failed: Bad value Makefile:819: recipe for target 'vmlinux' failed The fix is similar to 1658f914ff91c3bf ("MIPS: microMIPS: Disable LL/SC and fix linker bug.") Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: stable@vger.kernel.org Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/8117/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-10-24MIPS: MSP71xx: Fix build errorStefan Hengelein
When CONFIG_MIPS_MT_SMP is enabled, the following compilation error occurs: arch/mips/pmcs-msp71xx/msp_irq_cic.c:134: error: ‘irq’ undeclared This code clearly never saw a compiler. The surrounding code suggests, that 'd->irq' was intended, not 'irq'. This error was found with vampyr. Signed-off-by: Stefan Hengelein <stefan.hengelein@fau.de> Fixes: d7881fbdf866d7d0 ("MIPS: msp71xx: Convert to new irq_chip functions") Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/8116/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
