2014-10-19Linux 3.18-rc1v3.18-rc1Linus Torvalds
2014-10-19Merge tag 'arm-soc-fixes-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "A batch of fixes that have come in during the merge window. Some of them are defconfig updates for things that have now landed, some errata additions and a few general scattered fixes. There's also a qcom DT update that adds support for SATA on AP148, and basic support for Sony Xperia Z1 and CM-QS600 platforms that seemed isolated enough that we could merge it even if it's late" * tag 'arm-soc-fixes-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: MAINTAINERS: corrected bcm2835 search ARM: dts: Explicitly set dr_mode on exynos5420-arndale-octa ARM: dts: Explicitly set dr_mode on exynos Peach boards ARM: dts: qcom: add CM-QS600 board ARM: dts: qcom: Add initial DTS file for Sony Xperia Z1 phone ARM: dts: qcom: Add SATA support on IPQ8064/AP148 MAINTAINERS: Update Santosh Shilimkar's email id ARM: sunxi_defconfig: enable CONFIG_REGULATOR ARM: dts: Disable smc91x on n900 until bootloader dependency is removed ARM: omap2plus_defconfig: Enable ARM erratum 430973 for omap3 ARM: exynos_defconfig: enable USB gadget support ARM: exynos_defconfig: Enable Maxim 77693 and I2C GPIO drivers ARM: mm: Fix ifdef around cpu_*_do_[suspend, resume] ops ARM: EXYNOS: Fix build with PM_SLEEP=n and ARM_EXYNOS_CPUIDLE=n ARM: SAMSUNG: Restore Samsung PM Debug functionality ARM: dts: Fix pull setting in sd4_width8 pin group for exynos4x12 ARM: exynos_defconfig: Enable SBS battery support ARM: exynos_defconfig: Enable Control Groups support ARM: exynos_defconfig: Enable Atmel maXTouch support ARM: exynos_defconfig: Enable MAX77802
2014-10-19Merge git://git.infradead.org/users/eparis/auditLinus Torvalds
Pull audit updates from Eric Paris: "So this change across a whole bunch of arches really solves one basic problem. We want to audit when seccomp is killing a process. seccomp hooks in before the audit syscall entry code. audit_syscall_entry took as an argument the arch of the given syscall. Since the arch is part of what makes a syscall number meaningful it's an important part of the record, but it isn't available when seccomp shoots the syscall... For most arch's we have a better way to get the arch (syscall_get_arch) So the solution was two fold: Implement syscall_get_arch() everywhere there is audit which didn't have it. Use syscall_get_arch() in the seccomp audit code. Having syscall_get_arch() everywhere meant it was a useless flag on the stack and we could get rid of it for the typical syscall entry. The other changes inside the audit system aren't grand, fixed some records that had invalid spaces. Better locking around the task comm field. Removing some dead functions and structs. Make some things static. Really minor stuff" * git://git.infradead.org/users/eparis/audit: (31 commits) audit: rename audit_log_remove_rule to disambiguate for trees audit: cull redundancy in audit_rule_change audit: WARN if audit_rule_change called illegally audit: put rule existence check in canonical order next: openrisc: Fix build audit: get comm using lock to avoid race in string printing audit: remove open_arg() function that is never used audit: correct AUDIT_GET_FEATURE return message type audit: set nlmsg_len for multicast messages. audit: use union for audit_field values since they are mutually exclusive audit: invalid op= values for rules audit: use atomic_t to simplify audit_serial() kernel/audit.c: use ARRAY_SIZE instead of sizeof/sizeof[0] audit: reduce scope of audit_log_fcaps audit: reduce scope of audit_net_id audit: arm64: Remove the audit arch argument to audit_syscall_entry arm64: audit: Add audit hook in syscall_trace_enter/exit() audit: x86: drop arch from __audit_syscall_entry() interface sparc: implement is_32bit_task sparc: properly conditionalize use of TIF_32BIT ...
2014-10-19Merge tag 'qcom-dt-for-3.18-3' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/galak/linux-qcom into fixes Merge "qcom DT changes for v3.18-3" from Kumar Gala: Qualcomm ARM Based Device Tree Updates for v3.18-3 * Added Board support for CM-QS600 and Sony Xperia Z1 phone * Added SATA support on IPQ8064/AP148 * tag 'qcom-dt-for-3.18-3' of git://git.kernel.org/pub/scm/linux/kernel/git/galak/linux-qcom: ARM: dts: qcom: add CM-QS600 board ARM: dts: qcom: Add initial DTS file for Sony Xperia Z1 phone ARM: dts: qcom: Add SATA support on IPQ8064/AP148
2014-10-19Merge tag 'samsung-fixes-2' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into fixes Pull more fixes from Kukjin Kim: 2nd Samsung fixes for v3.18 - Explicitly set dr_mode on exynos5800-peach-pi, exynos5420-peach-pit and exynos5420-arndale-octa boards, because the USB dwc3 controller will not work properly without dr_mode as host on above boards if the USB host and gadget are enabled in kernel configuration both. * tag 'samsung-fixes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: ARM: dts: Explicitly set dr_mode on exynos5420-arndale-octa ARM: dts: Explicitly set dr_mode on exynos Peach boards Signed-off-by: Olof Johansson <olof@lixom.net>
2014-10-19MAINTAINERS: corrected bcm2835 searchScott Branden
Corrected bcm2835 maintainer info by using N: to specify any files with bcm2835 in are directed to the proper maintainer. Also corrected minor mispelling of ARCHITECTURE in 2 comment locations. Signed-off-by: Scott Branden <sbranden@broadcom.com> Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-10-19Merge tag 'ntb-3.18' of git://github.com/jonmason/ntbLinus Torvalds
Pull ntb (non-transparent bridge) updates from Jon Mason: "Add support for Haswell NTB split BARs, a debugfs entry for basic debugging info, and some code clean-ups" * tag 'ntb-3.18' of git://github.com/jonmason/ntb: ntb: Adding split BAR support for Haswell platforms ntb: use errata flag set via DID to implement workaround ntb: conslidate reading of PPD to move platform detection earlier ntb: move platform detection to separate function NTB: debugfs device entry
2014-10-19Merge branch 'i2c/for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c updates from Wolfram Sang: "Highlights from the I2C subsystem for 3.18: - new drivers for Axxia AM55xx, and Hisilicon hix5hd2 SoC. - designware driver gained AMD support, exynos gained exynos7 support The rest is usual driver stuff. Hopefully no lowlights this time" * 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: i2c: i801: Add Device IDs for Intel Sunrise Point PCH i2c: hix5hd2: add i2c controller driver i2c-imx: Disable the clock on probe failure i2c: designware: Add support for AMD I2C controller i2c: designware: Rework probe() to get clock a bit later i2c: designware: Default to fast mode in case of ACPI i2c: axxia: Add I2C driver for AXM55xx i2c: exynos: add support for HSI2C module on Exynos7 i2c: mxs: detect No Slave Ack on SELECT in PIO mode i2c: cros_ec: Remove EC_I2C_FLAG_10BIT i2c: cros-ec-tunnel: Add of match table i2c: rcar: remove sign-compare flaw i2c: ismt: Use minimum descriptor size i2c: imx: Add arbitration lost check i2c: rk3x: Remove unlikely() annotations i2c: rcar: check for no IRQ in rcar_i2c_irq() i2c: rcar: make rcar_i2c_prepare_msg() *void* i2c: rcar: simplify check for last message i2c: designware: add support of platform data to set I2C mode i2c: designware: add support of I2C standard mode
2014-10-19Merge tag 'sound-fix-3.18-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "Here are a collection of small fixes after 3.18 merge. The urgent one is the fix for kernel panics with linked PCM substream triggered by the recent nonatomic PCM ops support. Other two fixes (emu10k1 and bebob) are stable fixes, and one easy PCI ID addition for a new Intel HD-audio controller" * tag 'sound-fix-3.18-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda_intel: Add Device IDs for Intel Sunrise Point PCH ALSA: emu10k1: Fix deadlock in synth voice lookup ALSA: pcm: Fix referred substream in snd_pcm_action_group() unlock loop ALSA: bebob: Fix failure to detect source of clock for Terratec Phase 88
2014-10-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull second round of input updates from Dmitry Torokhov: "Mostly simple bug fixes, although we do have one brand new driver for Microchip AR1021 i2c touchscreen. Also there is the change to stop trying to use i8042 active multiplexing by default (it is still possible to activate it via i8042.nomux=0 on boxes that implement it)" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: xpad - add Thrustmaster as Xbox 360 controller vendor Input: xpad - add USB ID for Thrustmaster Ferrari 458 Racing Wheel Input: max77693-haptic - fix state check in imax77693_haptic_disable() Input: xen-kbdfront - free grant table entry in xenkbd_disconnect_backend Input: alps - fix v4 button press recognition Input: i8042 - disable active multiplexing by default Input: i8042 - add noloop quirk for Asus X750LN Input: synaptics - gate forcepad support by DMI check Input: Add Microchip AR1021 i2c touchscreen Input: cros_ec_keyb - add of match table Input: serio - avoid negative serio device numbers Input: avoid negative input device numbers Input: automatically set EV_ABS bit in input_set_abs_params Input: adp5588-keys - cancel workqueue in failure path Input: opencores-kbd - switch to using managed resources Input: evdev - fix EVIOCG{type} ioctl
2014-10-19Merge tag 'rdma-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband Pull infiniband/RDMA updates from Roland Dreier: - large set of iSER initiator improvements - hardware driver fixes for cxgb4, mlx5 and ocrdma - small fixes to core midlayer * tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (47 commits) RDMA/cxgb4: Fix ntuple calculation for ipv6 and remove duplicate line RDMA/cxgb4: Add missing neigh_release in find_route RDMA/cxgb4: Take IPv6 into account for best_mtu and set_emss RDMA/cxgb4: Make c4iw_wr_log_size_order static IB/core: Fix XRC race condition in ib_uverbs_open_qp IB/core: Clear AH attr variable to prevent garbage data RDMA/ocrdma: Save the bit environment, spare unncessary parenthesis RDMA/ocrdma: The kernel has a perfectly good BIT() macro - use it RDMA/ocrdma: Don't memset() buffers we just allocated with kzalloc() RDMA/ocrdma: Remove a unused-label warning RDMA/ocrdma: Convert kernel VA to PA for mmap in user RDMA/ocrdma: Get vlan tag from ib_qp_attrs RDMA/ocrdma: Add default GID at index 0 IB/mlx5, iser, isert: Add Signature API additions Target/iser: Centralize ib_sig_domain setting IB/iser: Centralize ib_sig_domain settings IB/mlx5: Use extended internal signature layout IB/iser: Set IP_CSUM as default guard type IB/iser: Remove redundant assignment IB/mlx5: Use enumerations for PI copy mask ...
2014-10-19Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull more perf updates from Ingo Molnar: "A second (and last) round of late coming fixes and changes, almost all of them in perf tooling: User visible tooling changes: - Add period data column and make it default in 'perf script' (Jiri Olsa) - Add a visual cue for toggle zeroing of samples in 'perf top' (Taeung Song) - Improve callchains when using libunwind (Namhyung Kim) Tooling fixes and infrastructure changes: - Fix for double free in 'perf stat' when using some specific invalid command line combo (Yasser Shalabi) - Fix off-by-one bugs in map->end handling (Stephane Eranian) - Fix off-by-one bug in maps__find(), also related to map->end handling (Namhyung Kim) - Make struct symbol->end be the first addr after the symbol range, to make it match the convention used for struct map->end. (Arnaldo Carvalho de Melo) - Fix perf_evlist__add_pollfd() error handling in 'perf kvm stat live' (Jiri Olsa) - Fix python test build by moving callchain_param to an object linked into the python binding (Jiri Olsa) - Document sysfs events/ interfaces (Cody P Schafer) - Fix typos in perf/Documentation (Masanari Iida) - Add missing 'struct option' forward declaration (Arnaldo Carvalho de Melo) - Add option to copy events when queuing for sorting across cpu buffers and enable it for 'perf kvm stat live', to avoid having events left in the queue pointing to the ring buffer be rewritten in high volume sessions. (Alexander Yarygin, improving work done by David Ahern): - Do not include a struct hists per perf_evsel, untangling the histogram code from perf_evsel, to pave the way for exporting a minimalistic tools/lib/api/perf/ library usable by tools/perf and initially by the rasd daemon being developed by Borislav Petkov, Robert Richter and Jean Pihet. (Arnaldo Carvalho de Melo) - Make perf_evlist__open(evlist, NULL, NULL), i.e. without cpu and thread maps mean syswide monitoring, reducing the boilerplate for tools that only want system wide mode. (Arnaldo Carvalho de Melo) - Move exit stuff from perf_evsel__delete to perf_evsel__exit, delete should be just a front end for exit + free (Arnaldo Carvalho de Melo) - Add support to new style format of kernel PMU event. (Kan Liang) and other misc fixes" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (45 commits) perf script: Add period as a default output column perf script: Add period data column perf evsel: No need to drag util/cgroup.h perf evlist: Add missing 'struct option' forward declaration perf evsel: Move exit stuff from __delete to __exit kprobes/x86: Remove stale ARCH_SUPPORTS_KPROBES_ON_FTRACE define perf kvm stat live: Enable events copying perf session: Add option to copy events when queueing perf Documentation: Fix typos in perf/Documentation perf trace: Use thread_{,_set}_priv helpers perf kvm: Use thread_{,_set}_priv helpers perf callchain: Create an address space per thread perf report: Set callchain_param.record_mode for future use perf evlist: Fix for double free in tools/perf stat perf test: Add test case for pmu event new style format perf tools: Add support to new style format of kernel PMU event perf tools: Parse the pmu event prefix and suffix Revert "perf tools: Default to cpu// for events v5" perf Documentation: Remove Ruplicated docs for powerpc cpu specific events perf Documentation: sysfs events/ interfaces ...
2014-10-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
Pull sparc fixes from David Miller: "Here we have two bug fixes: 1) The current thread's fault_code is not setup properly upon entry to do_sparc64_fault() in some paths, leading to spurious SIGBUS. 2) Don't use a zero length array at the end of thread_info on sparc64, otherwise end_of_stack() isn't right" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: sparc64: Do not define thread fpregs save area as zero-length array. sparc64: Fix corrupted thread fault code.
2014-10-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "A quick batch of bug fixes: 1) Fix build with IPV6 disabled, from Eric Dumazet. 2) Several more cases of caching SKB data pointers across calls to pskb_may_pull(), thus referencing potentially free'd memory. From Li RongQing. 3) DSA phy code tests operation presence improperly, instead of going: if (x->ops->foo) r = x->ops->foo(args); it was going: if (x->ops->foo(args)) r = x->ops->foo(args); Fix from Andew Lunn" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: Net: DSA: Fix checking for get_phy_flags function ipv6: fix a potential use after free in sit.c ipv6: fix a potential use after free in ip6_offload.c ipv4: fix a potential use after free in gre_offload.c tcp: fix build error if IPv6 is not enabled
2014-10-19Net: DSA: Fix checking for get_phy_flags functionAndrew Lunn
The check for the presence or not of the optional switch function get_phy_flags() called the function, rather than checked to see if it is a NULL pointer. This causes a derefernce of a NULL pointer on all switch chips except the sf2, the only switch to implement this call. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Fixes: 6819563e646a ("net: dsa: allow switch drivers to specify phy_device::dev_flags") Cc: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-18sparc64: Do not define thread fpregs save area as zero-length array.David S. Miller
This breaks the stack end corruption detection facility. What that facility does it write a magic value to "end_of_stack()" and checking to see if it gets overwritten. "end_of_stack()" is "task_thread_info(p) + 1", which for sparc64 is the beginning of the FPU register save area. So once the user uses the FPU, the magic value is overwritten and the debug checks trigger. Fix this by making the size explicit. Due to the size we use for the fpsaved[], gsr[], and xfsr[] arrays we are limited to 7 levels of FPU state saves. So each FPU register set is 256 bytes, allocate 256 * 7 for the fpregs area. Reported-by: Meelis Roos <mroos@linux.ee> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-18sparc64: Fix corrupted thread fault code.David S. Miller
Every path that ends up at do_sparc64_fault() must install a valid FAULT_CODE_* bitmask in the per-thread fault code byte. Two paths leading to the label winfix_trampoline (which expects the FAULT_CODE_* mask in register %g4) were not doing so: 1) For pre-hypervisor TLB protection violation traps, if we took the 'winfix_trampoline' path we wouldn't have %g4 initialized with the FAULT_CODE_* value yet. Resulting in using the TLB_TAG_ACCESS register address value instead. 2) In the TSB miss path, when we notice that we are going to use a hugepage mapping, but we haven't allocated the hugepage TSB yet, we still have to take the window fixup case into consideration and in that particular path we leave %g4 not setup properly. Errors on this sort were largely invisible previously, but after commit 4ccb9272892c33ef1c19a783cfa87103b30c2784 ("sparc64: sun4v TLB error power off events") we now have a fault_code mask bit (FAULT_CODE_BAD_RA) that triggers due to this bug. FAULT_CODE_BAD_RA triggers because this bit is set in TLB_TAG_ACCESS (see #1 above) and thus we get seemingly random bus errors triggered for user processes. Fixes: 4ccb9272892c ("sparc64: sun4v TLB error power off events") Reported-by: Meelis Roos <mroos@linux.ee> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-18Merge branch 'for-linus' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine updates from Vinod Koul: "For dmaengine contributions we have: - designware cleanup by Andy - my series moving device_control users to dmanegine_xxx APIs for later removal of device_control API - minor fixes spread over drivers mainly mv_xor, pl330, mmp, imx-sdma etc" * 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (60 commits) serial: atmel: add missing dmaengine header dmaengine: remove FSLDMA_EXTERNAL_START dmaengine: freescale: remove FSLDMA_EXTERNAL_START control method carma-fpga: move to fsl_dma_external_start() carma-fpga: use dmaengine_xxx() API dmaengine: freescale: add and export fsl_dma_external_start() dmaengine: add dmaengine_prep_dma_sg() helper video: mx3fb: use dmaengine_terminate_all() API serial: sh-sci: use dmaengine_terminate_all() API net: ks8842: use dmaengine_terminate_all() API mtd: sh_flctl: use dmaengine_terminate_all() API mtd: fsmc_nand: use dmaengine_terminate_all() API V4L2: mx3_camer: use dmaengine_pause() API dmaengine: coh901318: use dmaengine_terminate_all() API pata_arasan_cf: use dmaengine_terminate_all() API dmaengine: edma: check for echan->edesc => NULL in edma_dma_pause() dmaengine: dw: export probe()/remove() and Co to users dmaengine: dw: enable and disable controller when needed dmaengine: dw: always export dw_dma_{en,dis}able dmaengine: dw: introduce dw_dma_on() helper ...
2014-10-18Merge tag 'fbdev-3.18' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux Pull fbdev updates from Tomi Valkeinen: - new 6x10 font - various small fixes and cleanups * tag 'fbdev-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux: (30 commits) fonts: Add 6x10 font videomode: provide dummy inline functions for !CONFIG_OF video/atmel_lcdfb: Introduce regulator support fbdev: sh_mobile_hdmi: Re-init regs before irq re-enable on resume framebuffer: fix screen corruption when copying framebuffer: fix border color arm, fbdev, omap2, LLVMLinux: Remove nested function from omapfb arm, fbdev, omap2, LLVMLinux: Remove nested function from omap2 dss video: fbdev: valkyriefb.c: use container_of to resolve fb_info_valkyrie from fb_info video: fbdev: pxafb.c: use container_of to resolve pxafb_info/layer from fb_info video: fbdev: cyber2000fb.c: use container_of to resolve cfb_info from fb_info video: fbdev: controlfb.c: use container_of to resolve fb_info_control from fb_info video: fbdev: sa1100fb.c: use container_of to resolve sa1100fb_info from fb_info video: fbdev: stifb.c: use container_of to resolve stifb_info from fb_info video: fbdev: sis: sis_main.c: Cleaning up missing null-terminate in conjunction with strncpy video: valkyriefb: Fix unused variable warning in set_valkyrie_clock() video: fbdev: use %*ph specifier to dump small buffers video: mx3fb: always enable BACKLIGHT_LCD_SUPPORT video: fbdev: au1200fb: delete double assignment video: fbdev: sis: delete double assignment ...
2014-10-18Merge tag 'kvm-arm-for-3.18-take-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm Pull second batch of changes for KVM/{arm,arm64} from Marc Zyngier: "The most obvious thing is the sizeable MMU changes to support 48bit VAs on arm64. Summary: - support for 48bit IPA and VA (EL2) - a number of fixes for devices mapped into guests - yet another VGIC fix for BE - a fix for CPU hotplug - a few compile fixes (disabled VGIC, strict mm checks)" [ I'm pulling directly from Marc at the request of Paolo Bonzini, whose backpack was stolen at Düsseldorf airport and will do new keys and rebuild his web of trust. - Linus ] * tag 'kvm-arm-for-3.18-take-2' of git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm: arm/arm64: KVM: Fix BE accesses to GICv2 EISR and ELRSR regs arm: kvm: STRICT_MM_TYPECHECKS fix for user_mem_abort arm/arm64: KVM: Ensure memslots are within KVM_PHYS_SIZE arm64: KVM: Implement 48 VA support for KVM EL2 and Stage-2 arm/arm64: KVM: map MMIO regions at creation time arm64: kvm: define PAGE_S2_DEVICE as read-only by default ARM: kvm: define PAGE_S2_DEVICE as read-only by default arm/arm64: KVM: add 'writable' parameter to kvm_phys_addr_ioremap arm/arm64: KVM: fix potential NULL dereference in user_mem_abort() arm/arm64: KVM: use __GFP_ZERO not memset() to get zeroed pages ARM: KVM: fix vgic-disabled build arm: kvm: fix CPU hotplug
2014-10-18Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "This is the MIPS pull request for the next kernel: - Zubair's patch series adds CMA support for MIPS. Doing so it also touches ARM64 and x86. - remove the last instance of IRQF_DISABLED from arch/mips - updates to two of the MIPS defconfig files. - cleanup of how cache coherency bits are handled on MIPS and implement support for write-combining. - platform upgrades for Alchemy - move MIPS DTS files to arch/mips/boot/dts/" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (24 commits) MIPS: ralink: remove deprecated IRQF_DISABLED MIPS: pgtable.h: Implement the pgprot_writecombine function for MIPS MIPS: cpu-probe: Set the write-combine CCA value on per core basis MIPS: pgtable-bits: Define the CCA bit for WC writes on Ingenic cores MIPS: pgtable-bits: Move the CCA bits out of the core's ifdef blocks MIPS: DMA: Add cma support x86: use generic dma-contiguous.h arm64: use generic dma-contiguous.h asm-generic: Add dma-contiguous.h MIPS: BPF: Add new emit_long_instr macro MIPS: ralink: Move device-trees to arch/mips/boot/dts/ MIPS: Netlogic: Move device-trees to arch/mips/boot/dts/ MIPS: sead3: Move device-trees to arch/mips/boot/dts/ MIPS: Lantiq: Move device-trees to arch/mips/boot/dts/ MIPS: Octeon: Move device-trees to arch/mips/boot/dts/ MIPS: Add support for building device-tree binaries MIPS: Create common infrastructure for building built-in device-trees MIPS: SEAD3: Enable DEVTMPFS MIPS: SEAD3: Regenerate defconfigs MIPS: Alchemy: DB1300: Add touch penirq support ...
2014-10-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux Pull powerpc fix from Michael Ellerman: "There was a bit of a misunderstanding between us and the ARM guys in the device tree PCI code, which is breaking virtio on powerpc. This is the minimal fix until we can sort it out properly" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux: powerpc/pci: Fix IO space breakage after of_pci_range_to_resource() change
2014-10-18Merge branch 'for-linus' of git://git.samba.org/sfrench/cifs-2.6Linus Torvalds
Pull cifs/smb3 updates from Steve French: "Improved SMB3 support (symlink and device emulation, and remapping by default the 7 reserved posix characters) and a workaround for cifs mounts to Mac (working around a commonly encountered Mac server bug)" * 'for-linus' of git://git.samba.org/sfrench/cifs-2.6: [CIFS] Remove obsolete comment Check minimum response length on query_network_interface Workaround Mac server problem Remap reserved posix characters by default (part 3/3) Allow conversion of characters in Mac remap range (part 2) Allow conversion of characters in Mac remap range. Part 1 mfsymlinks support for SMB2.1/SMB3. Part 2 query symlink Add mfsymlinks support for SMB2.1/SMB3. Part 1 create symlink Allow mknod and mkfifo on SMB2/SMB3 mounts add defines for two new file attributes
2014-10-18Merge tag 'dlm-3.18' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/teigland/linux-dlm Pull dlm fix from David Teigland: "This includes a single commit fixing a missing endian conversion" * tag 'dlm-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/teigland/linux-dlm: dlm: fix missing endian conversion of rcom_status flags
2014-10-18Merge branch 'for-linus-update' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs data corruption fix from Chris Mason: "I'm testing a pull with more fixes, but wanted to get this one out so Greg can pick it up. The corruption isn't easy to hit, you have to do a readonly snapshot and have orphans in the snapshot. But my review and testing missed the bug. Filipe has added a better xfstest to cover it" * 'for-linus-update' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: Revert "Btrfs: race free update of commit root for ro snapshots"
2014-10-18Merge tag 'please-pull-pstore' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux Pull pstore fix from Tony Luck: "Ensure unique filenames in pstore" * tag 'please-pull-pstore' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux: pstore: Fix duplicate {console,ftrace}-efi entries
2014-10-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/aia21/ntfsLinus Torvalds
Pull NTFS update from Anton Altaparmakov: "Here is a small NTFS update notably implementing FIBMAP ioctl for NTFS by adding the bmap address space operation. People seem to still want FIBMAP" * git://git.kernel.org/pub/scm/linux/kernel/git/aia21/ntfs: NTFS: Bump version to 2.1.31. NTFS: Add bmap address space operation needed for FIBMAP ioctl. NTFS: Remove changelog from Documentation/filesystems/ntfs.txt. NTFS: Split ntfs_aops into ntfs_normal_aops and ntfs_compressed_aops in preparation for them diverging.
2014-10-18Merge tag 'nfs-for-3.18-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client updates from Trond Myklebust: "Highlights include: Stable fixes: - fix an uninitialised pointer Oops in the writeback error path - fix a bogus warning (and early exit from the loop) in nfs_generic_pgio() Features: - Add NFSv4.2 SEEK feature and client support for lseek(SEEK_HOLE/SEEK_DATA) Other fixes: - pnfs: replace broken pnfs_put_lseg_async - Remove dead prototype for nfs4_insert_deviceid_node" * tag 'nfs-for-3.18-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: NFS: Fix a bogus warning in nfs_generic_pgio NFS: Fix an uninitialised pointer Oops in the writeback error path NFSv4.1/pnfs: replace broken pnfs_put_lseg_async NFSv4: Remove dead prototype for nfs4_insert_deviceid_node() NFS: Implement SEEK
2014-10-18Merge tag 'dm-3.18' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm Pull device-mapper updates from Mike Snitzer: "I rebased the DM tree ontop of linux-block.git's 'for-3.18/core' at the beginning of October because DM core now depends on the newly introduced bioset_create_nobvec() interface. Summary: - fix DM's long-standing excessive use of memory by leveraging the new bioset_create_nobvec() interface when creating the DM's bioset - fix a few bugs in dm-bufio and dm-log-userspace - add DM core support for a DM multipath use-case that requires loading DM tables that contain devices that have failed (by allowing active and inactive DM tables to share dm_devs) - add discard support to the DM raid target; like MD raid456 the user must opt-in to raid456 discard support be specifying the devices_handle_discard_safely=Y module param" * tag 'dm-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm: dm log userspace: fix memory leak in dm_ulog_tfr_init failure path dm bufio: when done scanning return from __scan immediately dm bufio: update last_accessed when relinking a buffer dm raid: add discard support for RAID levels 4, 5 and 6 dm raid: add discard support for RAID levels 1 and 10 dm: allow active and inactive tables to share dm_devs dm mpath: stop queueing IO when no valid paths exist dm: use bioset_create_nobvec() dm: remove nr_iovecs parameter from alloc_tio()
2014-10-18Merge branch 'for-3.18/drivers' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block layer driver update from Jens Axboe: "This is the block driver pull request for 3.18. Not a lot in there this round, and nothing earth shattering. - A round of drbd fixes from the linbit team, and an improvement in asender performance. - Removal of deprecated (and unused) IRQF_DISABLED flag in rsxx and hd from Michael Opdenacker. - Disable entropy collection from flash devices by default, from Mike Snitzer. - A small collection of xen blkfront/back fixes from Roger Pau Monné and Vitaly Kuznetsov" * 'for-3.18/drivers' of git://git.kernel.dk/linux-block: block: disable entropy contributions for nonrot devices xen, blkfront: factor out flush-related checks from do_blkif_request() xen-blkback: fix leak on grant map error path xen/blkback: unmap all persistent grants when frontend gets disconnected rsxx: Remove deprecated IRQF_DISABLED block: hd: remove deprecated IRQF_DISABLED drbd: use RB_DECLARE_CALLBACKS() to define augment callbacks drbd: compute the end before rb_insert_augmented() drbd: Add missing newline in resync progress display in /proc/drbd drbd: reduce lock contention in drbd_worker drbd: Improve asender performance drbd: Get rid of the WORK_PENDING macro drbd: Get rid of the __no_warn and __cond_lock macros drbd: Avoid inconsistent locking warning drbd: Remove superfluous newline from "resync_extents" debugfs entry. drbd: Use consistent names for all the bi_end_io callbacks drbd: Use better variable names
2014-10-18Merge branch 'for-3.18/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull core block layer changes from Jens Axboe: "This is the core block IO pull request for 3.18. Apart from the new and improved flush machinery for blk-mq, this is all mostly bug fixes and cleanups. - blk-mq timeout updates and fixes from Christoph. - Removal of REQ_END, also from Christoph. We pass it through the ->queue_rq() hook for blk-mq instead, freeing up one of the request bits. The space was overly tight on 32-bit, so Martin also killed REQ_KERNEL since it's no longer used. - blk integrity updates and fixes from Martin and Gu Zheng. - Update to the flush machinery for blk-mq from Ming Lei. Now we have a per hardware context flush request, which both cleans up the code should scale better for flush intensive workloads on blk-mq. - Improve the error printing, from Rob Elliott. - Backing device improvements and cleanups from Tejun. - Fixup of a misplaced rq_complete() tracepoint from Hannes. - Make blk_get_request() return error pointers, fixing up issues where we NULL deref when a device goes bad or missing. From Joe Lawrence. - Prep work for drastically reducing the memory consumption of dm devices from Junichi Nomura. This allows creating clone bio sets without preallocating a lot of memory. - Fix a blk-mq hang on certain combinations of queue depths and hardware queues from me. - Limit memory consumption for blk-mq devices for crash dump scenarios and drivers that use crazy high depths (certain SCSI shared tag setups). We now just use a single queue and limited depth for that" * 'for-3.18/core' of git://git.kernel.dk/linux-block: (58 commits) block: Remove REQ_KERNEL blk-mq: allocate cpumask on the home node bio-integrity: remove the needless fail handle of bip_slab creating block: include func name in __get_request prints block: make blk_update_request print prefix match ratelimited prefix blk-merge: don't compute bi_phys_segments from bi_vcnt for cloned bio block: fix alignment_offset math that assumes io_min is a power-of-2 blk-mq: Make bt_clear_tag() easier to read blk-mq: fix potential hang if rolling wakeup depth is too high block: add bioset_create_nobvec() block: use bio_clone_fast() in blk_rq_prep_clone() block: misplaced rq_complete tracepoint sd: Honor block layer integrity handling flags block: Replace strnicmp with strncasecmp block: Add T10 Protection Information functions block: Don't merge requests if integrity flags differ block: Integrity checksum flag block: Relocate bio integrity flags block: Add a disk flag to block integrity profile block: Add prefix to block integrity profile flags ...
2014-10-18Merge tag 'for-linus-20141015' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull MTD update from Brian Norris: "Sorry for delaying this a bit later than usual. There's one mild regression from 3.16 that was noticed during the 3.17 cycle, and I meant to send a fix for it along with this pull request. I'll probably try to queue it up for a later pull request once I've had a better look at it, hopefully by -rc2 at the latest. Summary for this pull: NAND - Cleanup for Denali driver - Atmel: add support for new page sizes - Atmel: fix up 'raw' mode support - Atmel: miscellaneous cleanups - New timing mode helpers for non-ONFI NAND - OMAP: allow driver to be (properly) built as a module - bcm47xx: RESET support and other cleanups SPI NOR - Miscellaneous cleanups, to prepare framework for wider use (some further work still pending) - Compile-time configuration to select 4K vs. 64K support for flash that support both (necessary for using UBIFS on some SPI NOR) A few scattered code quality fixes, detected by Coverity See the changesets for more" * tag 'for-linus-20141015' of git://git.infradead.org/linux-mtd: (59 commits) mtd: nand: omap: Correct CONFIG_MTD_NAND_OMAP_BCH help message mtd: nand: Force omap_elm to be built as a module if omap2_nand is a module mtd: move support for struct flash_platform_data into m25p80 mtd: spi-nor: add Kconfig option to disable 4K sectors mtd: nand: Move ELM driver and rename as omap_elm nand: omap2: Replace pr_err with dev_err nand: omap2: Remove horrible ifdefs to fix module probe mtd: nand: add Hynix's H27UCG8T2ATR-BC to nand_ids table mtd: nand: support ONFI timing mode retrieval for non-ONFI NANDs mtd: physmap_of: Add non-obsolete map_rom probe mtd: physmap_of: Fix ROM support via OF MAINTAINERS: add l2-mtd.git, 'next' tree for MTD mtd: denali: fix indents and other trivial things mtd: denali: remove unnecessary parentheses mtd: denali: remove another set-but-unused variable mtd: denali: fix include guard and license block of denali.h mtd: nand: don't break long print messages mtd: bcm47xxnflash: replace some magic numbers mtd: bcm47xxnflash: NAND_CMD_RESET support mtd: bcm47xxnflash: add cmd_ctrl handler ...
2014-10-18Merge tag 'md/3.18' of git://neil.brown.name/mdLinus Torvalds
Pull md updates from Neil Brown: - a few minor bug fixes - quite a lot of code tidy-up and simplification - remove PRINT_RAID_DEBUG ioctl. I'm fairly sure it is unused, and it isn't particularly useful. * tag 'md/3.18' of git://neil.brown.name/md: (21 commits) lib/raid6: Add log level to printks md: move EXPORT_SYMBOL to after function in md.c md: discard PRINT_RAID_DEBUG ioctl md: remove MD_BUG() md: clean up 'exit' labels in md_ioctl(). md: remove unnecessary test for MD_MAJOR in md_ioctl() md: don't allow "-sync" to be set for device in an active array. md: remove unwanted white space from md.c md: don't start resync thread directly from md thread. md: Just use RCU when checking for overlap between arrays. md: avoid potential long delay under pers_lock md: simplify export_array() md: discard find_rdev_nr in favour of find_rdev_nr_rcu md: use wait_event() to simplify md_super_wait() md: be more relaxed about stopping an array which isn't started. md/raid1: process_checks doesn't use its return value. md/raid5: fix init_stripe() inconsistencies md/raid10: another memory leak due to reshape. md: use set_bit/clear_bit instead of shift/mask for bi_flags changes. md/raid1: minor typos and reformatting. ...
2014-10-18Merge branch 'for-linus2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull selinux fix from James Morris: "Fix for a list corruption bug in the SELinux code" * 'for-linus2' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: selinux: fix inode security list corruption
2014-10-18Merge tag 'virtio-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull virtio updates from Rusty Russell: "One cc: stable commit, the rest are a series of minor cleanups which have been sitting in MST's tree during my vacation. I changed a function name and made one trivial change, then they spent two days in linux-next" * tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (25 commits) virtio-rng: refactor probe error handling virtio_scsi: drop scan callback virtio_balloon: enable VQs early on restore virtio_scsi: fix race on device removal virito_scsi: use freezable WQ for events virtio_net: enable VQs early on restore virtio_console: enable VQs early on restore virtio_scsi: enable VQs early on restore virtio_blk: enable VQs early on restore virtio_scsi: move kick event out from virtscsi_init virtio_net: fix use after free on allocation failure 9p/trans_virtio: enable VQs early virtio_console: enable VQs early virtio_blk: enable VQs early virtio_net: enable VQs early virtio: add API to enable VQs early virtio_net: minor cleanup virtio-net: drop config_mutex virtio_net: drop config_enable virtio-blk: drop config_mutex ...
2014-10-18Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module fix from Rusty Russell: "A single panic fix for a rare race, stable CC'd" * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: modules, lock around setting of MODULE_STATE_UNFORMED
2014-10-18MAINTAINERS: Become the docs maintainerJonathan Corbet
It seems it's my turn to be the documentation maintainer for a bit. My plan is to work to ensure that docs patches don't fall through the cracks; I assume most changes will continue to flow through subsystem-specific trees. Acked-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-18x86,kvm,vmx: Preserve CR4 across VM entryAndy Lutomirski
CR4 isn't constant; at least the TSD and PCE bits can vary. TBH, treating CR0 and CR3 as constant scares me a bit, too, but it looks like it's correct. This adds a branch and a read from cr4 to each vm entry. Because it is extremely likely that consecutive entries into the same vcpu will have the same host cr4 value, this fixes up the vmcs instead of restoring cr4 after the fact. A subsequent patch will add a kernel-wide cr4 shadow, reducing the overhead in the common case to just two memory reads and a branch. Signed-off-by: Andy Lutomirski <luto@amacapital.net> Acked-by: Paolo Bonzini <pbonzini@redhat.com> Cc: stable@vger.kernel.org Cc: Petr Matousek <pmatouse@redhat.com> Cc: Gleb Natapov <gleb@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-18ipv6: fix a potential use after free in sit.cLi RongQing
pskb_may_pull() maybe change skb->data and make iph pointer oboslete, fix it by geting ip header length directly. Fixes: ca15a078 (sit: generate icmpv6 error when receiving icmpv4 error) Cc: Oussama Ghorbel <ghorbel@pivasoftware.com> Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-18ipv6: fix a potential use after free in ip6_offload.cLi RongQing
pskb_may_pull() maybe change skb->data and make opth pointer oboslete, so set the opth again Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-18ipv4: fix a potential use after free in gre_offload.cLi RongQing
pskb_may_pull() may change skb->data and make greh pointer oboslete; so need to reassign greh; but since first calling pskb_may_pull already ensured that skb->data has enough space for greh, so move the reference of greh before second calling pskb_may_pull(), to avoid reassign greh. Fixes: 7a7ffbabf9("ipv4: fix tunneled VM traffic over hw VXLAN/GRE GSO NIC") Cc: Wei-Chun Chao <weichunc@plumgrid.com> Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-18tcp: fix build error if IPv6 is not enabledEric Dumazet
$ make M=net/ipv4 CC net/ipv4/route.o In file included from net/ipv4/route.c:102:0: include/net/tcp.h: In function ‘tcp_v6_iif’: include/net/tcp.h:738:32: error: ‘union <anonymous>’ has no member named ‘h6’ return TCP_SKB_CB(skb)->header.h6.iif; Signed-off-by: Eric Dumazet <edumazet@google.com> Fixes: 870c3151382c ("ipv6: introduce tcp_v6_iif()") Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Include fixes for netrom and dsa (Fabian Frederick and Florian Fainelli) 2) Fix FIXED_PHY support in stmmac, from Giuseppe CAVALLARO. 3) Several SKB use after free fixes (vxlan, openvswitch, vxlan, ip_tunnel, fou), from Li ROngQing. 4) fec driver PTP support fixes from Luwei Zhou and Nimrod Andy. 5) Use after free in virtio_net, from Michael S Tsirkin. 6) Fix flow mask handling for megaflows in openvswitch, from Pravin B Shelar. 7) ISDN gigaset and capi bug fixes from Tilman Schmidt. 8) Fix route leak in ip_send_unicast_reply(), from Vasily Averin. 9) Fix two eBPF JIT bugs on x86, from Alexei Starovoitov. 10) TCP_SKB_CB() reorganization caused a few regressions, fixed by Cong Wang and Eric Dumazet. 11) Don't overwrite end of SKB when parsing malformed sctp ASCONF chunks, from Daniel Borkmann. 12) Don't call sock_kfree_s() with NULL pointers, this function also has the side effect of adjusting the socket memory usage. From Cong Wang. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (90 commits) bna: fix skb->truesize underestimation net: dsa: add includes for ethtool and phy_fixed definitions openvswitch: Set flow-key members. netrom: use linux/uaccess.h dsa: Fix conversion from host device to mii bus tipc: fix bug in bundled buffer reception ipv6: introduce tcp_v6_iif() sfc: add support for skb->xmit_more r8152: return -EBUSY for runtime suspend ipv4: fix a potential use after free in fou.c ipv4: fix a potential use after free in ip_tunnel_core.c hyperv: Add handling of IP header with option field in netvsc_set_hash() openvswitch: Create right mask with disabled megaflows vxlan: fix a free after use openvswitch: fix a use after free ipv4: dst_entry leak in ip_send_unicast_reply() ipv4: clean up cookie_v4_check() ipv4: share tcp_v4_save_options() with cookie_v4_check() ipv4: call __ip_options_echo() in cookie_v4_check() atm: simplify lanai.c by using module_pci_driver ...
2014-10-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
Pull Sparc bugfix from David Miller: "Sparc64 AES ctr mode bug fix" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: sparc64: Fix FPU register corruption with AES crypto offload.
2014-10-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/ideLinus Torvalds
Pull IDE cleanup from David Miller: "One IDE driver cleanup" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/ide: Drivers: ide: Remove typedef atiixp_ide_timing
2014-10-18futex: Ensure get_futex_key_refs() always implies a barrierCatalin Marinas
Commit b0c29f79ecea (futexes: Avoid taking the hb->lock if there's nothing to wake up) changes the futex code to avoid taking a lock when there are no waiters. This code has been subsequently fixed in commit 11d4616bd07f (futex: revert back to the explicit waiter counting code). Both the original commit and the fix-up rely on get_futex_key_refs() to always imply a barrier. However, for private futexes, none of the cases in the switch statement of get_futex_key_refs() would be hit and the function completes without a memory barrier as required before checking the "waiters" in futex_wake() -> hb_waiters_pending(). The consequence is a race with a thread waiting on a futex on another CPU, allowing the waker thread to read "waiters == 0" while the waiter thread to have read "futex_val == locked" (in kernel). Without this fix, the problem (user space deadlocks) can be seen with Android bionic's mutex implementation on an arm64 multi-cluster system. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Reported-by: Matteo Franchin <Matteo.Franchin@arm.com> Fixes: b0c29f79ecea (futexes: Avoid taking the hb->lock if there's nothing to wake up) Acked-by: Davidlohr Bueso <dave@stgolabs.net> Tested-by: Mike Galbraith <umgwanakikbuti@gmail.com> Cc: <stable@vger.kernel.org> Cc: Darren Hart <dvhart@linux.intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-18Merge tag 'perf-core-for-mingo' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent Pull perf/core improvements and fixes from Arnaldo Carvalho de Melo: User visible changes: * Add period data column and make it default in 'perf script' (Jiri Olsa) Infrastructure changes: * Move exit stuff from perf_evsel__delete to perf_evsel__exit, delete should be just a front end for exit + free (Arnaldo Carvalho de Melo) * Add missing 'struct option' forward declaration (Arnaldo Carvalho de Melo) * No need to drag util/cgroup.h into evsel.h (Arnaldo Carvalho de Melo) Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-10-17bna: fix skb->truesize underestimationEric Dumazet
skb->truesize is not meant to be tracking amount of used bytes in an skb, but amount of reserved/consumed bytes in memory. For instance, if we use a single byte in last page fragment, we have to account the full size of the fragment. skb->truesize can be very different from skb->len, that has a very specific safety purpose. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Rasesh Mody <rasesh.mody@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-17net: dsa: add includes for ethtool and phy_fixed definitionsFlorian Fainelli
net/dsa/slave.c uses functions and structures declared in phy_fixed.h but does not explicitely include it, while dsa.h needs structure declarations for 'struct ethtool_wolinfo' and 'struct ethtool_eee', fix those by including the correct header files. Fixes: ec9436baedb6 ("net: dsa: allow drivers to do link adjustment") Fixes: ce31b31c68e7 ("net: dsa: allow updating fixed PHY link information") Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-17openvswitch: Set flow-key members.Pravin B Shelar
This patch adds missing memset which are required to initialize flow key member. For example for IP flow we need to initialize ip.frag for all cases. Found by inspection. This bug is introduced by commit 0714812134d7dcadeb7ecfbfeb18788aa7e1eaac ("openvswitch: Eliminate memset() from flow_extract"). Signed-off-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
