2014-12-07Linux 3.18v3.18Linus Torvalds
2014-12-07Merge branch 'for-3.18-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata Pull libata fixes from Tejun Heo: "Three libata fixes for v3.18. Nothing too interesting. PCI ID ID and quirk additions to ahci and an error handling path fix in sata_fsl" * 'for-3.18-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: ahci: disable MSI on SAMSUNG 0xa800 SSD sata_fsl: fix error handling of irq_of_parse_and_map AHCI: Add DeviceIDs for Sunrise Point-LP SATA controller
2014-12-06Merge git://www.linux-watchdog.org/linux-watchdogLinus Torvalds
Pull watchdog fix from Wim Van Sebroeck: "Fix the watchdog mask bit offset for Exynos7" * git://www.linux-watchdog.org/linux-watchdog: watchdog: s3c2410_wdt: Fix the mask bit offset for Exynos7
2014-12-06Merge branch 'i2c/for-current' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c fixes from Wolfram Sang: "Here are two more driver bugfixes for I2C which would be good to have" * 'i2c/for-current' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: i2c: cadence: Set the hardware time-out register to maximum value i2c: davinci: generate STP always when NACK is received
2014-12-05watchdog: s3c2410_wdt: Fix the mask bit offset for Exynos7Abhilash Kesavan
The watchdog mask bit offset listed for Exynos7 is incorrect. Fix this. Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com> Acked-by: Naveen Krishna Chatradhi <naveenkrishna.ch@gmail.com Reviewd-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2014-12-05Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Thomas Gleixner: "Two final fixlets for 3.18: - Prevent microcode reload wreckage on 32bit - Unbreak cross compilation" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, microcode: Limit the microcode reloading to 64-bit for now x86: Use $(OBJDUMP) instead of plain objdump
2014-12-05Merge tag 'sound-3.18' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixlet from Takashi Iwai: "Just one commit for adding a copule of HD-audio quirk entries" * tag 'sound-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda/realtek - Add headset Mic support for new Dell machine
2014-12-04Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm intel fixes from Dave Airlie: "Two intel stable fixes, that should be it from me for this round" * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: drm/i915: Unlock panel even when LVDS is disabled drm/i915: More cautious with pch fifo underruns
2014-12-04Merge tag 'pm+acpi-3.18-rc8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI backlight fix from Rafael Wysocki: "This is a simple fix for an ACPI backlight regression introduced by a recent commit that overlooked a corner case which should have been taken into account" * tag 'pm+acpi-3.18-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: ACPI / video: update condition to check if device is in _DOD list
2014-12-05Merge tag 'drm-intel-fixes-2014-12-04' of ↵Dave Airlie
git://anongit.freedesktop.org/drm-intel into drm-fixes Silence some pch fifo underrun reports and panel locking backtraces, both cc: stable. * tag 'drm-intel-fixes-2014-12-04' of git://anongit.freedesktop.org/drm-intel: drm/i915: Unlock panel even when LVDS is disabled drm/i915: More cautious with pch fifo underruns
2014-12-04Merge tag 'media/v3.18-rc8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media fixes from Mauro Carvalho Chehab: "A core fix and some driver fixes: - regression fix in Remote Controller core affecting RC6 protocol handling - fix video buffer handling in cx23885 - race fix in solo6x10 - fix image selection in smiapp - fix reported payload size on s2255drv - two updates for MAINTAINERS file" * tag 'media/v3.18-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: [media] rc-core: fix toggle handling in the rc6 decoder MAINTAINERS: Update mchehab's addresses [media] cx23885: use sg = sg_next(sg) instead of sg++ [media] s2255drv: fix payload size for JPG, MJPEG [media] Update MAINTAINERS for solo6x10 [media] solo6x10: fix a race in IRQ handler [media] smiapp: Only some selection targets are settable
2014-12-04uapi: fix to export linux/vm_sockets.hMasahiro Yamada
A typo "header=y" was introduced by commit 7071cf7fc435 ("uapi: add missing network related headers to kbuild"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Stephen Hemminger <stephen@networkplumber.org> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-04i2c: cadence: Set the hardware time-out register to maximum valueVishnu Motghare
Cadence I2C controller has bug wherein it generates invalid read transactions after timeout in master receiver mode. This driver does not use the HW timeout and this interrupt is disabled but the feature itself cannot be disabled. Hence, this patch writes the maximum value (0xFF) to this register. This is one of the workarounds to this bug and it will not avoid the issue completely but reduces the chances of error. Signed-off-by: Vishnu Motghare <vishnum@xilinx.com> Signed-off-by: Harini Katakam <harinik@xilinx.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Cc: stable@kernel.org
2014-12-04i2c: davinci: generate STP always when NACK is receivedGrygorii Strashko
According to I2C specification the NACK should be handled as follows: "When SDA remains HIGH during this ninth clock pulse, this is defined as the Not Acknowledge signal. The master can then generate either a STOP condition to abort the transfer, or a repeated START condition to start a new transfer." [I2C spec Rev. 6, 3.1.6: http://www.nxp.com/documents/user_manual/UM10204.pdf] Currently the Davinci i2c driver interrupts the transfer on receipt of a NACK but fails to send a STOP in some situations and so makes the bus stuck until next I2C IP reset (idle/enable). For example, the issue will happen during SMBus read transfer which consists from two i2c messages write command/address and read data: S Slave Address Wr A Command Code A Sr Slave Address Rd A D1..Dn A P <--- write -----------------------> <--- read ---------------------> The I2C client device will send NACK if it can't recognize "Command Code" and it's expected from I2C master to generate STP in this case. But now, Davinci i2C driver will just exit with -EREMOTEIO and STP will not be generated. Hence, fix it by generating Stop condition (STP) always when NACK is received. This patch fixes Davinci I2C in the same way it was done for OMAP I2C commit cda2109a26eb ("i2c: omap: query STP always when NACK is received"). Reviewed-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Reported-by: Hein Tibosch <hein_tibosch@yahoo.es> Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Cc: stable@kernel.org
2014-12-04ahci: disable MSI on SAMSUNG 0xa800 SSDTejun Heo
Just like 0x1600 which got blacklisted by 66a7cbc303f4 ("ahci: disable MSI instead of NCQ on Samsung pci-e SSDs on macbooks"), 0xa800 chokes on NCQ commands if MSI is enabled. Disable MSI. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Dominik Mierzejewski <dominik@greysector.net> Link: https://bugzilla.kernel.org/show_bug.cgi?id=89171 Cc: stable@vger.kernel.org
2014-12-03context_tracking: Restore previous state in schedule_userAndy Lutomirski
It appears that some SCHEDULE_USER (asm for schedule_user) callers in arch/x86/kernel/entry_64.S are called from RCU kernel context, and schedule_user will return in RCU user context. This causes RCU warnings and possible failures. This is intended to be a minimal fix suitable for 3.18. Reported-and-tested-by: Dave Jones <davej@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-03Merge branch 'i2c/for-current' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c bugfixes from Wolfram Sang: "A few driver bugfixes for 3.18" * 'i2c/for-current' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: i2c: omap: fix i207 errata handling i2c: designware: prevent early stop on TX FIFO empty i2c: omap: fix NACK and Arbitration Lost irq handling
2014-12-03Merge tag 'pci-v3.18-fixes-4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI fix from Bjorn Helgaas: "This fixes a Tegra20 regression that we introduced during the v3.18 merge window" * tag 'pci-v3.18-fixes-4' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: PCI: tegra: Use physical range for I/O mapping
2014-12-03Merge tag 'devicetree-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/glikely/linux Pull devicetree bugfix from Grant Likely: "One more bug fix for v3.18. I debated whether or not to send you this merge request because we're at such a late rc. The bug isn't critical in that there is only one system known to be affected and the patch is easy to backport. The codepath is used by pretty much every DT based system, so there is risk a of regression (it /should/ be safe, but I've been bitten by stuff that should be safe before). I've had it in linux-next for a week and haven't received any complaints. I think it probably should just be merged right away rather than waiting for the merge window and backporting. It does fix a real bug and the code is theoretically safer after the change. I can't think of any situation where it would be dangerous to reserve the DT memory an extra time. Summary from tag: Single bugfix for boot failure seen in the wild. The memory reserve code tries to be clever about reserving the FDT, but it should just go ahead and reserve it unconditionally to avoid the problem of partial overlap described in the patch" * tag 'devicetree-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/glikely/linux: of/fdt: memblock_reserve /memreserve/ regions in the case of partial overlap
2014-12-03Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block core regression fix from Jens Axboe: "Single fix for a regression introduced in this development cycle, where dm on top of dif/dix is broken. From Darrick Wong" * 'for-linus' of git://git.kernel.dk/linux-block: block: fix regression where bio_integrity_process uses wrong bio_vec iterator
2014-12-03Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes from Dave Airlie: "Radeon and Nouveau fixes: So nouveau had a few regression introduced, Ben and Maarten finally tracked down the one that was causing problems on my MacBookPro, also nvidia gave some info on the an engine we were using incorrectly, so disable our use of it, and one regresion with pci hotplug affecting optimus users. Radeon has an oops fixs, sync fix, and one workaround to avoid broken functionality on 32-bit x86, this needs better root causing and a better fix, but the bandaid is a lot safer at this point" * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: drm/radeon: kernel panic in drm_calc_vbltimestamp_from_scanoutpos with 3.18.0-rc6 drm/radeon: Ignore RADEON_GEM_GTT_WC on 32-bit x86 drm/radeon: sync all BOs involved in a CS v2 nouveau: move the hotplug ignore to correct place. drm/nouveau/gf116: remove copy1 engine drm/nouveau: prevent stale fence->channel pointers, and protect with rcu drm/nouveau/fifo/g84-: ack non-stall interrupt before handling it
2014-12-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fill in ethtool link parameters for all link types in cxgb4, from Hariprasad Shenai. 2) Fix probe regressions in stmmac driver, from Huacai Chen. 3) Network namespace leaks on errirs in rtnetlink, from Nicolas Dichtel. 4) Remove erroneous BUG check which can actually trigger legitimately, in xen-netfront. From Seth Forshee. 5) Validate length of IFLA_BOND_ARP_IP_TARGET netlink attributes, from Thomas Grag. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: cxgb4: Fill in supported link mode for SFP modules xen-netfront: Remove BUGs on paged skb data which crosses a page boundary sh_eth: Fix sleeping function called from invalid context stmmac: platform: Move plat_dat checking earlier sh_eth: Fix skb alloc size and alignment adjust rule. rtnetlink: release net refcnt on error in do_setlink() bond: Check length of IFLA_BOND_ARP_IP_TARGET attributes
2014-12-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull keyring/nfs fixes from James Morris: "From David Howells: The first one fixes the handling of maximum buffer size for key descriptions, fixing the size at 4095 + NUL char rather than whatever PAGE_SIZE happens to be and permits you to read back the full description without it getting clipped because some extra information got prepended. The second and third fix a bug in NFS idmapper handling whereby a key representing a mapping between an id and a name expires and causing EKEYEXPIRED to be seen internally in NFS (which prevents the mapping from happening) rather than re-looking up the mapping" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: KEYS: request_key() should reget expired keys rather than give EKEYEXPIRED KEYS: Simplify KEYRING_SEARCH_{NO,DO}_STATE_CHECK flags KEYS: Fix the size of the key description passed to/from userspace
2014-12-03Merge branch 'akpm' (patches from Andrew Morton)Linus Torvalds
Merge misc fixes from Andrew Morton: "10 fixes" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: slab: fix nodeid bounds check for non-contiguous node IDs lib/genalloc.c: export devm_gen_pool_create() for modules mm: fix anon_vma_clone() error treatment mm: fix swapoff hang after page migration and fork fat: fix oops on corrupted vfat fs ipc/sem.c: fully initialize sem_array before making it visible drivers/input/evdev.c: don't kfree() a vmalloc address mm/vmpressure.c: fix race in vmpressure_work_fn() mm: frontswap: invalidate expired data on a dup-store failure mm: do not overwrite reserved pages counter at show_mem()
2014-12-03slab: fix nodeid bounds check for non-contiguous node IDsPaul Mackerras
The bounds check for nodeid in ____cache_alloc_node gives false positives on machines where the node IDs are not contiguous, leading to a panic at boot time. For example, on a POWER8 machine the node IDs are typically 0, 1, 16 and 17. This means that num_online_nodes() returns 4, so when ____cache_alloc_node is called with nodeid = 16 the VM_BUG_ON triggers, like this: kernel BUG at /home/paulus/kernel/kvm/mm/slab.c:3079! Call Trace: .____cache_alloc_node+0x5c/0x270 (unreliable) .kmem_cache_alloc_node_trace+0xdc/0x360 .init_list+0x3c/0x128 .kmem_cache_init+0x1dc/0x258 .start_kernel+0x2a0/0x568 start_here_common+0x20/0xa8 To fix this, we instead compare the nodeid with MAX_NUMNODES, and additionally make sure it isn't negative (since nodeid is an int). The check is there mainly to protect the array dereference in the get_node() call in the next line, and the array being dereferenced is of size MAX_NUMNODES. If the nodeid is in range but invalid (for example if the node is off-line), the BUG_ON in the next line will catch that. Fixes: 14e50c6a9bc2 ("mm: slab: Verify the nodeid passed to ____cache_alloc_node") Signed-off-by: Paul Mackerras <paulus@samba.org> Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Reviewed-by: Pekka Enberg <penberg@kernel.org> Acked-by: David Rientjes <rientjes@google.com> Cc: Christoph Lameter <cl@linux.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-03lib/genalloc.c: export devm_gen_pool_create() for modulesMichal Simek
Modules can use this function for creating pool. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Cc: Laura Abbott <lauraa@codeaurora.org> Cc: Olof Johansson <olof@lixom.net> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com> Cc: Philipp Zabel <p.zabel@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-03mm: fix anon_vma_clone() error treatmentDaniel Forrest
Andrew Morton noticed that the error return from anon_vma_clone() was being dropped and replaced with -ENOMEM (which is not itself a bug because the only error return value from anon_vma_clone() is -ENOMEM). I did an audit of callers of anon_vma_clone() and discovered an actual bug where the error return was being lost. In __split_vma(), between Linux 3.11 and 3.12 the code was changed so the err variable is used before the call to anon_vma_clone() and the default initial value of -ENOMEM is overwritten. So a failure of anon_vma_clone() will return success since err at this point is now zero. Below is a patch which fixes this bug and also propagates the error return value from anon_vma_clone() in all cases. Fixes: ef0855d334e1 ("mm: mempolicy: turn vma_set_policy() into vma_dup_policy()") Signed-off-by: Daniel Forrest <dan.forrest@ssec.wisc.edu> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Tim Hartrick <tim@edgecast.com> Cc: Hugh Dickins <hughd@google.com> Cc: Michel Lespinasse <walken@google.com> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: <stable@vger.kernel.org> [3.12+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-03mm: fix swapoff hang after page migration and forkHugh Dickins
I've been seeing swapoff hangs in recent testing: it's cycling around trying unsuccessfully to find an mm for some remaining pages of swap. I have been exercising swap and page migration more heavily recently, and now notice a long-standing error in copy_one_pte(): it's trying to add dst_mm to swapoff's mmlist when it finds a swap entry, but is doing so even when it's a migration entry or an hwpoison entry. Which wouldn't matter much, except it adds dst_mm next to src_mm, assuming src_mm is already on the mmlist: which may not be so. Then if pages are later swapped out from dst_mm, swapoff won't be able to find where to replace them. There's already a !non_swap_entry() test for stats: move that up before the swap_duplicate() and the addition to mmlist. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Kelley Nielsen <kelleynnn@gmail.com> Cc: <stable@vger.kernel.org> [2.6.18+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-03fat: fix oops on corrupted vfat fsAl Viro
a) don't bother with ->d_time for positives - we only check it for negatives anyway. b) make sure to set it at unlink and rmdir time - at *that* point soon-to-be negative dentry matches then-current directory contents c) don't go into renaming of old alias in vfat_lookup() unless it has the same parent (which it will, unless we are seeing corrupted image) [hirofumi@mail.parknet.co.jp: make change minimum, don't call d_move() for dir] Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: <stable@vger.kernel.org> [3.17.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-03ipc/sem.c: fully initialize sem_array before making it visibleManfred Spraul
ipc_addid() makes a new ipc identifier visible to everyone. New objects start as locked, so that the caller can complete the initialization after the call. Within struct sem_array, at least sma->sem_base and sma->sem_nsems are accessed without any locks, therefore this approach doesn't work. Thus: Move the ipc_addid() to the end of the initialization. Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Reported-by: Rik van Riel <riel@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Davidlohr Bueso <dave@stgolabs.net> Acked-by: Rafael Aquini <aquini@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-03drivers/input/evdev.c: don't kfree() a vmalloc addressAndrew Morton
If kzalloc() failed and then evdev_open_device() fails, evdev_open() will pass a vmalloc'ed pointer to kfree. This might fix https://bugzilla.kernel.org/show_bug.cgi?id=88401, where there was a crash in kfree(). Reported-by: Christian Casteyde <casteyde.christian@free.fr> Belatedly-Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Henrik Rydberg <rydberg@euromail.se> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-02cxgb4: Fill in supported link mode for SFP modulesHariprasad Shenai
Signed-off-by: Hariprasad Shenai <hariprasad@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-02xen-netfront: Remove BUGs on paged skb data which crosses a page boundarySeth Forshee
These BUGs can be erroneously triggered by frags which refer to tail pages within a compound page. The data in these pages may overrun the hardware page while still being contained within the compound page, but since compound_order() evaluates to 0 for tail pages the assertion fails. The code already iterates through subsequent pages correctly in this scenario, so the BUGs are unnecessary and can be removed. Fixes: f36c374782e4 ("xen/netfront: handle compound page fragments on transmit") Cc: <stable@vger.kernel.org> # 3.7+ Signed-off-by: Seth Forshee <seth.forshee@canonical.com> Reviewed-by: David Vrabel <david.vrabel@citrix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-02mm/vmpressure.c: fix race in vmpressure_work_fn()Andrew Morton
In some android devices, there will be a "divide by zero" exception. vmpr->scanned could be zero before spin_lock(&vmpr->sr_lock). Addresses https://bugzilla.kernel.org/show_bug.cgi?id=88051 [akpm@linux-foundation.org: neaten] Reported-by: ji_ang <ji_ang@163.com> Cc: Anton Vorontsov <anton.vorontsov@linaro.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-02mm: frontswap: invalidate expired data on a dup-store failureWeijie Yang
If a frontswap dup-store failed, it should invalidate the expired page in the backend, or it could trigger some data corruption issue. Such as: 1. use zswap as the frontswap backend with writeback feature 2. store a swap page(version_1) to entry A, success 3. dup-store a newer page(version_2) to the same entry A, fail 4. use __swap_writepage() write version_2 page to swapfile, success 5. zswap do shrink, writeback version_1 page to swapfile 6. version_2 page is overwrited by version_1, data corrupt. This patch fixes this issue by invalidating expired data immediately when meet a dup-store failure. Signed-off-by: Weijie Yang <weijie.yang@samsung.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Seth Jennings <sjennings@variantweb.net> Cc: Dan Streetman <ddstreet@ieee.org> Cc: Minchan Kim <minchan@kernel.org> Cc: Bob Liu <bob.liu@oracle.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-02mm: do not overwrite reserved pages counter at show_mem()Rafael Aquini
Minor fixlet to perform the reserved pages counter aggregation for each node, at show_mem() Signed-off-by: Rafael Aquini <aquini@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Johannes Weiner <jweiner@redhat.com> Acked-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-03Merge branch 'drm-fixes-3.18' of git://people.freedesktop.org/~agd5f/linux ↵Dave Airlie
into drm-fixes A few more small fixes for 3.18. * 'drm-fixes-3.18' of git://people.freedesktop.org/~agd5f/linux: drm/radeon: kernel panic in drm_calc_vbltimestamp_from_scanoutpos with 3.18.0-rc6 drm/radeon: Ignore RADEON_GEM_GTT_WC on 32-bit x86 drm/radeon: sync all BOs involved in a CS v2
2014-12-02drm/radeon: kernel panic in drm_calc_vbltimestamp_from_scanoutpos with ↵Petr Mladek
3.18.0-rc6 I was unable too boot 3.18.0-rc6 because of the following kernel panic in drm_calc_vbltimestamp_from_scanoutpos(): [drm] Initialized drm 1.1.0 20060810 [drm] radeon kernel modesetting enabled. [drm] initializing kernel modesetting (RV100 0x1002:0x515E 0x15D9:0x8080). [drm] register mmio base: 0xC8400000 [drm] register mmio size: 65536 radeon 0000:0b:01.0: VRAM: 128M 0x00000000D0000000 - 0x00000000D7FFFFFF (16M used) radeon 0000:0b:01.0: GTT: 512M 0x00000000B0000000 - 0x00000000CFFFFFFF [drm] Detected VRAM RAM=128M, BAR=128M [drm] RAM width 16bits DDR [TTM] Zone kernel: Available graphics memory: 3829346 kiB [TTM] Zone dma32: Available graphics memory: 2097152 kiB [TTM] Initializing pool allocator [TTM] Initializing DMA pool allocator [drm] radeon: 16M of VRAM memory ready [drm] radeon: 512M of GTT memory ready. [drm] GART: num cpu pages 131072, num gpu pages 131072 [drm] PCI GART of 512M enabled (table at 0x0000000037880000). radeon 0000:0b:01.0: WB disabled radeon 0000:0b:01.0: fence driver on ring 0 use gpu addr 0x00000000b0000000 and cpu addr 0xffff8800bbbfa000 [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [drm] Driver supports precise vblank timestamp query. [drm] radeon: irq initialized. [drm] Loading R100 Microcode radeon 0000:0b:01.0: Direct firmware load for radeon/R100_cp.bin failed with error -2 radeon_cp: Failed to load firmware "radeon/R100_cp.bin" [drm:r100_cp_init] *ERROR* Failed to load firmware! radeon 0000:0b:01.0: failed initializing CP (-2). radeon 0000:0b:01.0: Disabling GPU acceleration [drm] radeon: cp finalized BUG: unable to handle kernel NULL pointer dereference at 000000000000025c IP: [<ffffffff8150423b>] drm_calc_vbltimestamp_from_scanoutpos+0x4b/0x320 PGD 0 Oops: 0000 [#1] SMP Modules linked in: CPU: 1 PID: 1 Comm: swapper/0 Not tainted 3.18.0-rc6-4-default #2649 Hardware name: Supermicro X7DB8/X7DB8, BIOS 6.00 07/26/2006 task: ffff880234da2010 ti: ffff880234da4000 task.ti: ffff880234da4000 RIP: 0010:[<ffffffff8150423b>] [<ffffffff8150423b>] drm_calc_vbltimestamp_from_scanoutpos+0x4b/0x320 RSP: 0000:ffff880234da7918 EFLAGS: 00010086 RAX: ffffffff81557890 RBX: 0000000000000000 RCX: ffff880234da7a48 RDX: ffff880234da79f4 RSI: 0000000000000000 RDI: ffff880232e15000 RBP: ffff880234da79b8 R08: 0000000000000000 R09: 0000000000000000 R10: 000000000000000a R11: 0000000000000001 R12: ffff880232dda1c0 R13: ffff880232e1518c R14: 0000000000000292 R15: ffff880232e15000 FS: 0000000000000000(0000) GS:ffff88023fc40000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 000000000000025c CR3: 0000000002014000 CR4: 00000000000007e0 Stack: ffff880234da79d8 0000000000000286 ffff880232dcbc00 0000000000002480 ffff880234da7958 0000000000000296 ffff880234da7998 ffffffff8151b51d ffff880234da7a48 0000000032dcbeb0 ffff880232dcbc00 ffff880232dcbc58 Call Trace: [<ffffffff8151b51d>] ? drm_vma_offset_remove+0x1d/0x110 [<ffffffff8152dc98>] radeon_get_vblank_timestamp_kms+0x38/0x60 [<ffffffff8152076a>] ? ttm_bo_release_list+0xba/0x180 [<ffffffff81503751>] drm_get_last_vbltimestamp+0x41/0x70 [<ffffffff81503933>] vblank_disable_and_save+0x73/0x1d0 [<ffffffff81106b2f>] ? try_to_del_timer_sync+0x4f/0x70 [<ffffffff81505245>] drm_vblank_cleanup+0x65/0xa0 [<ffffffff815604fa>] radeon_irq_kms_fini+0x1a/0x70 [<ffffffff8156c07e>] r100_init+0x26e/0x410 [<ffffffff8152ae3e>] radeon_device_init+0x7ae/0xb50 [<ffffffff8152d57f>] radeon_driver_load_kms+0x8f/0x210 [<ffffffff81506965>] drm_dev_register+0xb5/0x110 [<ffffffff8150998f>] drm_get_pci_dev+0x8f/0x200 [<ffffffff815291cd>] radeon_pci_probe+0xad/0xe0 [<ffffffff8141a365>] local_pci_probe+0x45/0xa0 [<ffffffff8141b741>] pci_device_probe+0xd1/0x130 [<ffffffff81633dad>] driver_probe_device+0x12d/0x3e0 [<ffffffff8163413b>] __driver_attach+0x9b/0xa0 [<ffffffff816340a0>] ? __device_attach+0x40/0x40 [<ffffffff81631cd3>] bus_for_each_dev+0x63/0xa0 [<ffffffff8163378e>] driver_attach+0x1e/0x20 [<ffffffff81633390>] bus_add_driver+0x180/0x240 [<ffffffff81634914>] driver_register+0x64/0xf0 [<ffffffff81419cac>] __pci_register_driver+0x4c/0x50 [<ffffffff81509bf5>] drm_pci_init+0xf5/0x120 [<ffffffff821dc871>] ? ttm_init+0x6a/0x6a [<ffffffff821dc908>] radeon_init+0x97/0xb5 [<ffffffff810002fc>] do_one_initcall+0xbc/0x1f0 [<ffffffff810e3278>] ? __wake_up+0x48/0x60 [<ffffffff8218e256>] kernel_init_freeable+0x18a/0x215 [<ffffffff8218d983>] ? initcall_blacklist+0xc0/0xc0 [<ffffffff818a78f0>] ? rest_init+0x80/0x80 [<ffffffff818a78fe>] kernel_init+0xe/0xf0 [<ffffffff818c0c3c>] ret_from_fork+0x7c/0xb0 [<ffffffff818a78f0>] ? rest_init+0x80/0x80 Code: 45 ac 0f 88 a8 01 00 00 3b b7 d0 01 00 00 49 89 ff 0f 83 99 01 00 00 48 8b 47 20 48 8b 80 88 00 00 00 48 85 c0 0f 84 cd 01 00 00 <41> 8b b1 5c 02 00 00 41 8b 89 58 02 00 00 89 75 98 41 8b b1 60 RIP [<ffffffff8150423b>] drm_calc_vbltimestamp_from_scanoutpos+0x4b/0x320 RSP <ffff880234da7918> CR2: 000000000000025c ---[ end trace ad2c0aadf48e2032 ]--- Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000009 It has helped me to add a NULL pointer check that was suggested at http://lists.freedesktop.org/archives/dri-devel/2014-October/070663.html I am not familiar with the code. But the change looks sane and we need something fast at this stage of 3.18 development. Suggested-by: Helge Deller <deller@gmx.de> Signed-off-by: Petr Mladek <pmladek@suse.cz> Tested-by: Petr Mladek <pmladek@suse.cz> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org
2014-12-02drm/radeon: Ignore RADEON_GEM_GTT_WC on 32-bit x86Michel Dänzer
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=84627 Signed-off-by: Michel Dänzer <michel.daenzer@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org
2014-12-02drm/radeon: sync all BOs involved in a CS v2Christian König
Not just the userspace relocs, otherwise we won't wait for a swapped out page tables to be swapped in again. v2: rebased on Alex current drm-fixes-3.18 Signed-off-by: Christian König <christian.koenig@amd.com> Cc: stable@vger.kernel.org Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2014-12-02sata_fsl: fix error handling of irq_of_parse_and_mapDmitry Torokhov
irq_of_parse_and_map() returns 0 on error (the result is unsigned int), so testing for negative result never works. Signed-off-by: Dmitry Torokhov <dtor@chromium.org> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org
2014-12-02AHCI: Add DeviceIDs for Sunrise Point-LP SATA controllerDevin Ryles
This patch adds DeviceIDs for Sunrise Point-LP. Signed-off-by: Devin Ryles <devin.ryles@intel.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org
2014-12-02block: fix regression where bio_integrity_process uses wrong bio_vec iteratorDarrick J. Wong
bio integrity handling is broken on a system with LVM layered atop a DIF/DIX SCSI drive because device mapper clones the bio, modifies the clone, and sends the clone to the lower layers for processing. However, the clone bio has bi_vcnt == 0, which means that when the sd driver calls bio_integrity_process to attach DIX data, the for_each_segment_all() call (which uses bi_vcnt) returns immediately and random garbage is sent to the disk on a disk write. The disk of course returns an error. Therefore, teach bio_integrity_process() to use bio_for_each_segment() to iterate the bio_vecs, since the per-bio iterator tracks which bio_vecs are associated with that particular bio. The integrity handling code is effectively part of the "driver" (it's not the bio owner), so it must use the correct iterator function. v2: Fix a compiler warning about abandoned local variables. This patch supersedes "block: bio_integrity_process uses wrong bio_vec iterator". Patch applies against 3.18-rc6. Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Acked-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-12-02drm/i915: Unlock panel even when LVDS is disabledDaniel Vetter
Otherwise we'll have backtraces in assert_panel_unlocked because the BIOS locks the register. In the reporter's case this regression was introduced in commit c31407a3672aaebb4acddf90944a114fa5c8af7b Author: Chris Wilson <chris@chris-wilson.co.uk> Date: Thu Oct 18 21:07:01 2012 +0100 drm/i915: Add no-lvds quirk for Supermicro X7SPA-H Reported-by: Alexey Orishko <alexey.orishko@gmail.com> Cc: Alexey Orishko <alexey.orishko@gmail.com> Cc: stable@vger.kernel.org Cc: Chris Wilson <chris@chris-wilson.co.uk> Cc: Francois Tigeot <ftigeot@wolfpond.org> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Tested-by: Alexey Orishko <alexey.orishko@gmail.com> Signed-off-by: Jani Nikula <jani.nikula@intel.com>
2014-12-02drm/i915: More cautious with pch fifo underrunsDaniel Vetter
Apparently PCH fifo underruns are tricky, we have plenty reports that we see the occasional underrun (especially at boot-up). So for a change let's see what happens when we don't re-enable pch fifo underrun reporting when the pipe is disabled. This means that the kernel can't catch pch fifo underruns when they happen (except when all pipes are on on the pch). But we'll still catch underruns when disabling the pipe again. So not a terrible reduction in test coverage. Since the DRM_ERROR is new and hence a regression plan B would be to revert it back to a debug output. Which would be a lot worse than this hack for underrun test coverage in the wild. See the referenced discussions for more. References: http://mid.gmane.org/CA+gsUGRfGe3t4NcjdeA=qXysrhLY3r4CEu7z4bjTwxi1uOfy+g@mail.gmail.com Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=85898 References: https://bugs.freedesktop.org/show_bug.cgi?id=85898 References: https://bugs.freedesktop.org/show_bug.cgi?id=86233 References: https://bugs.freedesktop.org/show_bug.cgi?id=86478 Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Tested-by: lu hua <huax.lu@intel.com> Reviewed-by: Paulo Zanoni <paulo.r.zanoni@intel.com> Cc: stable@vger.kernel.org Signed-off-by: Jani Nikula <jani.nikula@intel.com>
2014-12-02ALSA: hda/realtek - Add headset Mic support for new Dell machineKailang Yang
Dell has new machines. It supports headset Mic and Headphone Mic. Signed-off-by: Kailang Yang <kailang@realtek.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-12-02Merge tag 'keys-fixes-20141201' of ↵James Morris
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs into for-linus
2014-12-02nouveau: move the hotplug ignore to correct place.Dave Airlie
Introduced in b440bde74f, however it was added to the wrong function in nouveau. https://bugzilla.kernel.org/show_bug.cgi?id=86011 Cc: Bjorn Helgaas <bhelgaas@google.com> CC: stable@vger.kernel.org # v3.15+ Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-12-02Merge branch 'linux-3.18' of ↵Dave Airlie
git://anongit.freedesktop.org/git/nouveau/linux-2.6 into drm-fixes Just a couple of fixes for the fallout from the fence rework. * 'linux-3.18' of git://anongit.freedesktop.org/git/nouveau/linux-2.6: drm/nouveau/gf116: remove copy1 engine drm/nouveau: prevent stale fence->channel pointers, and protect with rcu drm/nouveau/fifo/g84-: ack non-stall interrupt before handling it
2014-12-02drm/nouveau/gf116: remove copy1 engineIlia Mirkin
Indications are that no GF116's actually have a copy engine there, but actually have the decompression engine. This engine can be made to do copies, but that should be done separately. Unclear why this didn't turn up on all GF116's, but perhaps the non-mobile ones came with enough VRAM to not trigger ttm migrations in test scenarios. Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=85465 Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=59168 Cc: stable@vger.kernel.org Signed-off-by: Ilia Mirkin <imirkin@alum.mit.edu> Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
