commit ecf5fc6e9654cd7a268c782a523f072b2f1959f9 upstream.
Nikolay has reported a hang when a memcg reclaim got stuck with the
following backtrace:
PID: 18308 TASK: ffff883d7c9b0a30 CPU: 1 COMMAND: "rsync"
#0 __schedule at ffffffff815ab152
#1 schedule at ffffffff815ab76e
#2 schedule_timeout at ffffffff815ae5e5
#3 io_schedule_timeout at ffffffff815aad6a
#4 bit_wait_io at ffffffff815abfc6
#5 __wait_on_bit at ffffffff815abda5
#6 wait_on_page_bit at ffffffff8111fd4f
#7 shrink_page_list at ffffffff81135445
#8 shrink_inactive_list at ffffffff81135845
#9 shrink_lruvec at ffffffff81135ead
#10 shrink_zone at ffffffff811360c3
#11 shrink_zones at ffffffff81136eff
#12 do_try_to_free_pages at ffffffff8113712f
#13 try_to_free_mem_cgroup_pages at ffffffff811372be
#14 try_charge at ffffffff81189423
#15 mem_cgroup_try_charge at ffffffff8118c6f5
#16 __add_to_page_cache_locked at ffffffff8112137d
#17 add_to_page_cache_lru at ffffffff81121618
#18 pagecache_get_page at ffffffff8112170b
#19 grow_dev_page at ffffffff811c8297
#20 __getblk_slow at ffffffff811c91d6
#21 __getblk_gfp at ffffffff811c92c1
#22 ext4_ext_grow_indepth at ffffffff8124565c
#23 ext4_ext_create_new_leaf at ffffffff81246ca8
#24 ext4_ext_insert_extent at ffffffff81246f09
#25 ext4_ext_map_blocks at ffffffff8124a848
#26 ext4_map_blocks at ffffffff8121a5b7
#27 mpage_map_one_extent at ffffffff8121b1fa
#28 mpage_map_and_submit_extent at ffffffff8121f07b
#29 ext4_writepages at ffffffff8121f6d5
#30 do_writepages at ffffffff8112c490
#31 __filemap_fdatawrite_range at ffffffff81120199
#32 filemap_flush at ffffffff8112041c
#33 ext4_alloc_da_blocks at ffffffff81219da1
#34 ext4_rename at ffffffff81229b91
#35 ext4_rename2 at ffffffff81229e32
#36 vfs_rename at ffffffff811a08a5
#37 SYSC_renameat2 at ffffffff811a3ffc
#38 sys_renameat2 at ffffffff811a408e
#39 sys_rename at ffffffff8119e51e
#40 system_call_fastpath at ffffffff815afa89
Dave Chinner has properly pointed out that this is a deadlock in the
reclaim code because ext4 doesn't submit pages which are marked by
PG_writeback right away.
The heuristic was introduced by commit e62e384e9da8 ("memcg: prevent OOM
with too many dirty pages") and it was applied only when may_enter_fs
was specified. The code has been changed by c3b94f44fcb0 ("memcg:
further prevent OOM with too many dirty pages") which has removed the
__GFP_FS restriction with a reasoning that we do not get into the fs
code. But this is not sufficient apparently because the fs doesn't
necessarily submit pages marked PG_writeback for IO right away.
ext4_bio_write_page calls io_submit_add_bh but that doesn't necessarily
submit the bio. Instead it tries to map more pages into the bio and
mpage_map_one_extent might trigger memcg charge which might end up
waiting on a page which is marked PG_writeback but hasn't been submitted
yet so we would end up waiting for something that never finishes.
Fix this issue by replacing __GFP_IO by may_enter_fs check (for case 2)
before we go to wait on the writeback. The page fault path, which is
the only path that triggers memcg oom killer since 3.12, shouldn't
require GFP_NOFS and so we shouldn't reintroduce the premature OOM
killer issue which was originally addressed by the heuristic.
As per David Chinner the xfs is doing similar thing since 2.6.15 already
so ext4 is not the only affected filesystem. Moreover he notes:
: For example: IO completion might require unwritten extent conversion
: which executes filesystem transactions and GFP_NOFS allocations. The
: writeback flag on the pages can not be cleared until unwritten
: extent conversion completes. Hence memory reclaim cannot wait on
: page writeback to complete in GFP_NOFS context because it is not
: safe to do so, memcg reclaim or otherwise.
[tytso@mit.edu: corrected the control flow]
Fixes: c3b94f44fcb0 ("memcg: further prevent OOM with too many dirty pages")
Reported-by: Nikolay Borisov <kernel@kyup.com>
commit b97e92574c0bf335db1cd2ec491d8ff5cd5d0b49 upstream
Use separate bitmaps for each nodes in the cluster
bitmap_read_sb() validates the bitmap superblock that it reads in.
If it finds an inconsistency like a bad magic number or out-of-range
version number, it prints an error and returns, but it incorrectly
returns zero, so the array is still assembled with the (invalid) bitmap.
This means it could try to use a bitmap with a new version number which
it therefore does not understand.
This bug was introduced in 3.5 and fix as part of a larger patch in 4.1.
So the patch is suitable for any -stable kernel in that range.
Fixes: 27581e5ae01f ("md/bitmap: centralise allocation of bitmap file pages.")
Signed-off-by: NeilBrown <neilb@suse.com>
Reported-by: GuoQing Jiang <gqjiang@suse.com>
commit f15133df088ecadd141ea1907f2c96df67c729f0 upstream.
path_openat() jumps to the wrong place after do_tmpfile() - it has
already done path_cleanup() (as part of path_lookupat() called by
do_tmpfile()), so doing that again can lead to double fput().
commit ce40cd3fc7fa40a6119e5fe6c0f2bc0eb4541009 upstream.
Malicious (or egregiously buggy) userspace can trigger it, but it
should never happen in normal operation.
Signed-off-by: Wang Kai <morgan.wang@huawei.com>
commit 60942f2f235ce7b817166cdf355eed729094834d upstream.
Since now the shrink list is private and nobody can free the dentry while
it is on the shrink list, we can remove RCU protection from this.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Cc: "Nicholas A. Bellinger" <nab@linux-iscsi.org>
commit 9c8c10e262e0f62cb2530f1b076de979123183dd upstream.
Start with shrink_dcache_parent(), then scan what remains.
First of all, BUG() is very much an overkill here; we are holding
->s_umount, and hitting BUG() means that a lot of interesting stuff
will be hanging after that point (sync(2), for example). Moreover,
in cases when there had been more than one leak, we'll be better
off reporting all of them. And more than just the last component
of pathname - %pd is there for just such uses...
That was the last user of dentry_lru_del(), so kill it off...
commit fe91522a7ba82ca1a51b07e19954b3825e4aaa22 upstream.
If we find something already on a shrink list, just increment
data->found and do nothing else. Loops in shrink_dcache_parent() and
check_submounts_and_drop() will do the right thing - everything we
did put into our list will be evicted and if there had been nothing,
but data->found got non-zero, well, we have somebody else shrinking
those guys; just try again.
commit 41edf278fc2f042f4e22a12ed87d19c5201210e1 upstream.
If the victim in on the shrink list, don't remove it from there.
If shrink_dentry_list() manages to remove it from the list before
we are done - fine, we'll just free it as usual. If not - mark
it with new flag (DCACHE_MAY_FREE) and leave it there.
Eventually, shrink_dentry_list() will get to it, remove the sucker
from shrink list and call dentry_kill(dentry, 0). Which is where
we'll deal with freeing.
Since now dentry_kill(dentry, 0) may happen after or during
dentry_kill(dentry, 1), we need to recognize that (by seeing
DCACHE_DENTRY_KILLED already set), unlock everything
and either free the sucker (in case DCACHE_MAY_FREE has been
set) or leave it for ongoing dentry_kill(dentry, 1) to deal with.
commit 01b6035190b024240a43ac1d8e9c6f964f5f1c63 upstream.
commit b4f0354e968f5fabd39bc85b99fedae4a97589fe upstream.
The part of old d_free() that dealt with actual freeing of dentry.
Taken out of dentry_kill() into a separate function.
commit 5c47e6d0ad608987b91affbcf7d1fc12dfbe8fb4 upstream.
commit 03b3b889e79cdb6b806fc0ba9be0d71c186bbfaa upstream.
commit 3c00cb5e68dc719f2fc73a33b1b230aadfcb1309 upstream.
This function can leak kernel stack data when the user siginfo_t has a
positive si_code value. The top 16 bits of si_code descibe which fields
in the siginfo_t union are active, but they are treated inconsistently
between copy_siginfo_from_user32, copy_siginfo_to_user32 and
copy_siginfo_to_user.
copy_siginfo_from_user32 is called from rt_sigqueueinfo and
rt_tgsigqueueinfo in which the user has full control overthe top 16 bits
of si_code.
This fixes the following information leaks:
x86: 8 bytes leaked when sending a signal from a 32-bit process to
itself. This leak grows to 16 bytes if the process uses x32.
(si_code = __SI_CHLD)
x86: 100 bytes leaked when sending a signal from a 32-bit process to
a 64-bit process. (si_code = -1)
sparc: 4 bytes leaked when sending a signal from a 32-bit process to a
64-bit process. (si_code = any)
parsic and s390 have similar bugs, but they are not vulnerable because
rt_[tg]sigqueueinfo have checks that prevent sending a positive si_code
to a different process. These bugs are also fixed for consistency.
Signed-off-by: Amanieu d'Antras <amanieu@gmail.com>
Cc: Chris Metcalf <cmetcalf@ezchip.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
commit 26135022f85105ad725cda103fa069e29e83bd16 upstream.
This function may copy the si_addr_lsb, si_lower and si_upper fields to
user mode when they haven't been initialized, which can leak kernel
stack data to user mode.
Just checking the value of si_code is insufficient because the same
si_code value is shared between multiple signals. This is solved by
checking the value of si_signo in addition to si_code.
commit 3ead7c52bdb0ab44f4bb1feed505a8323cc12ba7 upstream.
This function may copy the si_addr_lsb field to user mode when it hasn't
been initialized, which can leak kernel stack data to user mode.
commit 451a2886b6bf90e2fb378f7c46c655450fb96e81 upstream.
unfortunately, allowing an arbitrary 16bit value means a possibility of
overflow in the calculation of total number of pages in bio_map_user_iov() -
we rely on there being no more than PAGE_SIZE members of sum in the
first loop there. If that sum wraps around, we end up allocating
too small array of pointers to pages and it's easy to overflow it in
the second loop.
X-Coverup: TINC (and there's no lumber cartel either)
[bwh: s/MAX_UIOVEC/UIO_MAXIOV/. This was fixed upstream by commit
fdc81f45e9f5 ("sg_start_req(): use import_iovec()"), but we don't have
that function.]
inconsistencies
commit 423f04d63cf421ea436bcc5be02543d549ce4b28 upstream.
raid1_end_read_request() assumes that the In_sync bits are consistent
with the ->degaded count.
raid1_spare_active updates the In_sync bit before the ->degraded count
and so exposes an inconsistency, as does error()
So extend the spinlock in raid1_spare_active() and error() to hide those
inconsistencies.
This should probably be part of
Commit: 34cab6f42003 ("md/raid1: fix test for 'was read error from
last working device'.")
as it addresses the same issue. It fixes the same bug and should go
to -stable for same reasons.
Fixes: 76073054c95b ("md/raid1: clean up read_balance.")
commit c9ddbac9c89110f77cb0fa07e634aaf1194899aa upstream.
09a2c73ddfc7 ("PCI: Remove unused PCI_MSIX_FLAGS_BIRMASK definition")
removed PCI_MSIX_FLAGS_BIRMASK from an exported header because it was
unused in the kernel. But that breaks user programs that were using it
(QEMU in particular).
Restore the PCI_MSIX_FLAGS_BIRMASK definition.
[bhelgaas: changelog]
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
commit 209f7512d007980fd111a74a064d70a3656079cf upstream.
The "BUG_ON(list_empty(&osb->blocked_lock_list))" in
ocfs2_downconvert_thread_do_work can be triggered in the following case:
ocfs2dc has firstly saved osb->blocked_lock_count to local varibale
processed, and then processes the dentry lockres. During the dentry
put, it calls iput and then deletes rw, inode and open lockres from
blocked list in ocfs2_mark_lockres_freeing. And this causes the
variable `processed' to not reflect the number of blocked lockres to be
processed, which triggers the BUG.
Signed-off-by: Joseph Qi <joseph.qi@huawei.com>
Cc: Mark Fasheh <mfasheh@suse.com>
account
commit de54b9ac253787c366bbfb28d901a31954eb3511 upstream.
A while back, the message queue implementation in the kernel was
improved to use btrees to speed up retrieval of messages, in commit
d6629859b36d ("ipc/mqueue: improve performance of send/recv").
That patch introducing the improved kernel handling of message queues
(using btrees) has, as a by-product, changed the meaning of the QSIZE
field in the pseudo-file created for the queue. Before, this field
reflected the size of the user-data in the queue. Since, it also takes
kernel data structures into account. For example, if 13 bytes of user
data are in the queue, on my machine the file reports a size of 61
bytes.
There was some discussion on this topic before (for example
https://lkml.org/lkml/2014/10/1/115). Commenting on a th lkml, Michael
Kerrisk gave the following background
(https://lkml.org/lkml/2015/6/16/74):
The pseudofiles in the mqueue filesystem (usually mounted at
/dev/mqueue) expose fields with metadata describing a message
queue. One of these fields, QSIZE, as originally implemented,
showed the total number of bytes of user data in all messages in
the message queue, and this feature was documented from the
beginning in the mq_overview(7) page. In 3.5, some other (useful)
work happened to break the user-space API in a couple of places,
including the value exposed via QSIZE, which now includes a measure
of kernel overhead bytes for the queue, a figure that renders QSIZE
useless for its original purpose, since there's no way to deduce
the number of overhead bytes consumed by the implementation.
(The other user-space breakage was subsequently fixed.)
This patch removes the accounting of kernel data structures in the
queue. Reporting the size of these data-structures in the QSIZE field
was a breaking change (see Michael's comment above). Without the QSIZE
field reporting the total size of user-data in the queue, there is no
way to deduce this number.
It should be noted that the resource limit RLIMIT_MSGQUEUE is counted
against the worst-case size of the queue (in both the old and the new
implementation). Therefore, the kernel overhead accounting in QSIZE is
not necessary to help the user understand the limitations RLIMIT imposes
on the processes.
Signed-off-by: Marcus Gelderie <redmnic@gmail.com>
Acked-by: Doug Ledford <dledford@redhat.com>
Acked-by: Michael Kerrisk <mtk.manpages@gmail.com>
Acked-by: Davidlohr Bueso <dbueso@suse.de>
Cc: John Duffy <jb_duffy@btinternet.com>
Cc: Arto Bendiken <arto@bendiken.net>
Cc: Manfred Spraul <manfred@colorfullife.com>
commit 44008f0896ae205b02b0882dbf807f0de149efc4 upstream.
Smatch complains that we have nested checks for "spdif_present". It
turns out the current behavior isn't correct, we should remove the first
check and keep the second.
Fixes: 1077a024812d ('ALSA: hda - Use generic parser for Cirrus codec driver')
commit e54198657b65625085834847ab6271087323ffea upstream.
This patch fixes a regression introduced with the following commit
in v4.0-rc1 code, where a iscsit_start_kthreads() failure triggers
a NULL pointer dereference OOPs:
commit 88dcd2dab5c23b1c9cfc396246d8f476c872f0ca
Author: Nicholas Bellinger <nab@linux-iscsi.org>
Date: Thu Feb 26 22:19:15 2015 -0800
iscsi-target: Convert iscsi_thread_set usage to kthread.h
To address this bug, move iscsit_start_kthreads() immediately
preceeding the transmit of last login response, before signaling
a successful transition into full-feature-phase within existing
iscsi_target_do_tx_login_io() logic.
This ensures that no target-side resource allocation failures can
occur after the final login response has been successfully sent.
Also, it adds a iscsi_conn->rx_login_comp to allow the RX thread
to sleep to prevent other socket related failures until the final
iscsi_post_login_handler() call is able to complete.
Cc: Sagi Grimberg <sagig@mellanox.com>
Signed-off-by: Nicholas Bellinger <nab@daterainc.com>
commit 9a258afa928b45e6dd2efcac46ccf7eea705d35a upstream.
For hwmods without sysc, _init_mpu_rt_base(oh) won't be called and so
_find_mpu_rt_port(oh) will return NULL thus preventing ready state check
on those modules after the module is enabled.
This can potentially cause a bus access error if the module is accessed
before the module is ready.
Fix this by unconditionally calling _init_mpu_rt_base() during hwmod
_init(). Do ioremap only if we need SYSC access.
Eventhough _wait_target_ready() check doesn't really need MPU RT port but
just the PRCM registers, we still mandate that the hwmod must have an
MPU RT port if ready state check needs to be done. Else it would mean that
the module is not accessible by MPU so there is no point in waiting
for target to be ready.
e.g. this fixes the below DCAN bus access error on AM437x-gp-evm.
[ 16.672978] ------------[ cut here ]------------
[ 16.677885] WARNING: CPU: 0 PID: 1580 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x234/0x35c()
[ 16.687946] 44000000.ocp:L3 Custom Error: MASTER M2 (64-bit) TARGET L4_PER_0 (Read): Data Access in User mode during Functional access
[ 16.700654] Modules linked in: xhci_hcd btwilink ti_vpfe dwc3 videobuf2_core ov2659 bluetooth v4l2_common videodev ti_am335x_adc kfifo_buf industrialio c_can_platform videobuf2_dma_contig media snd_soc_tlv320aic3x pixcir_i2c_ts c_can dc
[ 16.731144] CPU: 0 PID: 1580 Comm: rpc.statd Not tainted 3.14.26-02561-gf733aa036398 #180
[ 16.739747] Backtrace:
[ 16.742336] [<c0011108>] (dump_backtrace) from [<c00112a4>] (show_stack+0x18/0x1c)
[ 16.750285] r6:00000093 r5:00000009 r4:eab5b8a8 r3:00000000
[ 16.756252] [<c001128c>] (show_stack) from [<c05a4418>] (dump_stack+0x20/0x28)
[ 16.763870] [<c05a43f8>] (dump_stack) from [<c0037120>] (warn_slowpath_common+0x6c/0x8c)
[ 16.772408] [<c00370b4>] (warn_slowpath_common) from [<c00371e4>] (warn_slowpath_fmt+0x38/0x40)
[ 16.781550] r8:c05d1f90 r7:c0730844 r6:c0730448 r5:80080003 r4:ed0cd210
[ 16.788626] [<c00371b0>] (warn_slowpath_fmt) from [<c027fa94>] (l3_interrupt_handler+0x234/0x35c)
[ 16.797968] r3:ed0cd480 r2:c0730508
[ 16.801747] [<c027f860>] (l3_interrupt_handler) from [<c0063758>] (handle_irq_event_percpu+0x54/0x1bc)
[ 16.811533] r10:ed005600 r9:c084855b r8:0000002a r7:00000000 r6:00000000 r5:0000002a
[ 16.819780] r4:ed0e6d80
[ 16.822453] [<c0063704>] (handle_irq_event_percpu) from [<c00638f0>] (handle_irq_event+0x30/0x40)
[ 16.831789] r10:eb2b6938 r9:eb2b6960 r8:bf011420 r7:fa240100 r6:00000000 r5:0000002a
[ 16.840052] r4:ed005600
[ 16.842744] [<c00638c0>] (handle_irq_event) from [<c00661d8>] (handle_fasteoi_irq+0x74/0x128)
[ 16.851702] r4:ed005600 r3:00000000
[ 16.855479] [<c0066164>] (handle_fasteoi_irq) from [<c0063068>] (generic_handle_irq+0x28/0x38)
[ 16.864523] r4:0000002a r3:c0066164
[ 16.868294] [<c0063040>] (generic_handle_irq) from [<c000ef60>] (handle_IRQ+0x38/0x8c)
[ 16.876612] r4:c081c640 r3:00000202
[ 16.880380] [<c000ef28>] (handle_IRQ) from [<c00084f0>] (gic_handle_irq+0x30/0x5c)
[ 16.888328] r6:eab5ba38 r5:c0804460 r4:fa24010c r3:00000100
[ 16.894303] [<c00084c0>] (gic_handle_irq) from [<c05a8d80>] (__irq_svc+0x40/0x50)
[ 16.902193] Exception stack(0xeab5ba38 to 0xeab5ba80)
[ 16.907499] ba20: 00000000 00000006
[ 16.916108] ba40: fa1d0000 fa1d0008 ed3d3000 eab5bab4 ed3d3460 c0842af4 bf011420 eb2b6960
[ 16.924716] ba60: eb2b6938 eab5ba8c eab5ba90 eab5ba80 bf035220 bf07702c 600f0013 ffffffff
[ 16.933317] r7:eab5ba6c r6:ffffffff r5:600f0013 r4:bf07702c
[ 16.939317] [<bf077000>] (c_can_plat_read_reg_aligned_to_16bit [c_can_platform]) from [<bf035220>] (c_can_get_berr_counter+0x38/0x64 [c_can])
[ 16.952696] [<bf0351e8>] (c_can_get_berr_counter [c_can]) from [<bf010294>] (can_fill_info+0x124/0x15c [can_dev])
[ 16.963480] r5:ec8c9740 r4:ed3d3000
[ 16.967253] [<bf010170>] (can_fill_info [can_dev]) from [<c0502fa8>] (rtnl_fill_ifinfo+0x58c/0x8fc)
[ 16.976749] r6:ec8c9740 r5:ed3d3000 r4:eb2b6780
[ 16.981613] [<c0502a1c>] (rtnl_fill_ifinfo) from [<c0503408>] (rtnl_dump_ifinfo+0xf0/0x1dc)
[ 16.990401] r10:ec8c9740 r9:00000000 r8:00000000 r7:00000000 r6:ebd4d1b4 r5:ed3d3000
[ 16.998671] r4:00000000
[ 17.001342] [<c0503318>] (rtnl_dump_ifinfo) from [<c050e6e4>] (netlink_dump+0xa8/0x1e0)
[ 17.009772] r10:00000000 r9:00000000 r8:c0503318 r7:ebf3e6c0 r6:ebd4d1b4 r5:ec8c9740
[ 17.018050] r4:ebd4d000
[ 17.020714] [<c050e63c>] (netlink_dump) from [<c050ec10>] (__netlink_dump_start+0x104/0x154)
[ 17.029591] r6:eab5bd34 r5:ec8c9980 r4:ebd4d000
[ 17.034454] [<c050eb0c>] (__netlink_dump_start) from [<c0505604>] (rtnetlink_rcv_msg+0x110/0x1f4)
[ 17.043778] r7:00000000 r6:ec8c9980 r5:00000f40 r4:ebf3e6c0
[ 17.049743] [<c05054f4>] (rtnetlink_rcv_msg) from [<c05108e8>] (netlink_rcv_skb+0xb4/0xc8)
[ 17.058449] r8:eab5bdac r7:ec8c9980 r6:c05054f4 r5:ec8c9980 r4:ebf3e6c0
[ 17.065534] [<c0510834>] (netlink_rcv_skb) from [<c0504134>] (rtnetlink_rcv+0x24/0x2c)
[ 17.073854] r6:ebd4d000 r5:00000014 r4:ec8c9980 r3:c0504110
[ 17.079846] [<c0504110>] (rtnetlink_rcv) from [<c05102ac>] (netlink_unicast+0x180/0x1ec)
[ 17.088363] r4:ed0c6800 r3:c0504110
[ 17.092113] [<c051012c>] (netlink_unicast) from [<c0510670>] (netlink_sendmsg+0x2ac/0x380)
[ 17.100813] r10:00000000 r8:00000008 r7:ec8c9980 r6:ebd4d000 r5:eab5be70 r4:eab5bee4
[ 17.109083] [<c05103c4>] (netlink_sendmsg) from [<c04dfdb4>] (sock_sendmsg+0x90/0xb0)
[ 17.117305] r10:00000000 r9:eab5a000 r8:becdda3c r7:0000000c r6:ea978400 r5:eab5be70
[ 17.125563] r4:c05103c4
[ 17.128225] [<c04dfd24>] (sock_sendmsg) from [<c04e1c28>] (SyS_sendto+0xb8/0xdc)
[ 17.136001] r6:becdda5c r5:00000014 r4:ecd37040
[ 17.140876] [<c04e1b70>] (SyS_sendto) from [<c000e680>] (ret_fast_syscall+0x0/0x30)
[ 17.148923] r10:00000000 r8:c000e804 r7:00000122 r6:becdda5c r5:0000000c r4:becdda5c
[ 17.157169] ---[ end trace 2b71e15b38f58bad ]---
Fixes: 6423d6df1440 ("ARM: OMAP2+: hwmod: check for module address space during init")
Signed-off-by: Roger Quadros <rogerq@ti.com>
Signed-off-by: Paul Walmsley <paul@pwsan.com>
commit 2761713d35e370fd640b5781109f753066b746c4 upstream.
For write/discard obj_requests that involved a copyup method call, the
opcode of the first op is CEPH_OSD_OP_CALL and the ->callback is
rbd_img_obj_copyup_callback(). The latter frees copyup pages, sets
->xferred and delegates to rbd_img_obj_callback(), the "normal" image
object callback, for reporting to block layer and putting refs.
rbd_osd_req_callback() however treats CEPH_OSD_OP_CALL as a trivial op,
which means obj_request is marked done in rbd_osd_trivial_callback(),
*before* ->callback is invoked and rbd_img_obj_copyup_callback() has
a chance to run. Marking obj_request done essentially means giving
rbd_img_obj_callback() a license to end it at any moment, so if another
obj_request from the same img_request is being completed concurrently,
rbd_img_obj_end_request() may very well be called on such prematurally
marked done request:
<obj_request-1/2 reply>
handle_reply()
rbd_obj_request_complete()
<obj_request-2/2 reply>
handle_reply()
for_each_obj_request(obj_request->img_request) {
rbd_img_obj_end_request(obj_request-1/2)
rbd_img_obj_end_request(obj_request-2/2) <--
Calling rbd_img_obj_end_request() on such a request leads to trouble,
in particular because its ->xfferred is 0. We report 0 to the block
layer with blk_update_request(), get back 1 for "this request has more
data in flight" and then trip on
rbd_assert(more ^ (which == img_request->obj_request_count));
with rhs (which == ...) being 1 because rbd_img_obj_end_request() has
been called for both requests and lhs (more) being 1 because we haven't
got a chance to set ->xfferred in rbd_img_obj_copyup_callback() yet.
To fix this, leverage that rbd wants to call class methods in only two
cases: one is a generic method call wrapper (obj_request is standalone)
and the other is a copyup (obj_request is part of an img_request). So
make a dedicated handler for CEPH_OSD_OP_CALL and directly invoke
rbd_img_obj_copyup_callback() from it if obj_request is part of an
img_request, similar to how CEPH_OSD_OP_READ handler invokes
rbd_img_obj_request_read_callback().
Since rbd_img_obj_copyup_callback() is now being called from the OSD
request callback (only), it is renamed to rbd_osd_copyup_callback().
Cc: Alex Elder <elder@linaro.org>
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
Reviewed-by: Alex Elder <elder@linaro.org>
commit f898c522f0e9ac9f3177d0762b76e2ab2d2cf9c0 upstream.
This patch removes a bogus BUG_ON in the ablkcipher path that
triggers when the destination buffer is different from the source
buffer and is scattered.
commit 30b03d05e07467b8c6ec683ea96b5bffcbcd3931 upstream.
While gntdev_release() is called the MMU notifier is still registered
and can traverse priv->maps list even if no pages are mapped (which is
the case -- gntdev_release() is called after all). But
gntdev_release() will clear that list, so make sure that only one of
those things happens at the same time.
Signed-off-by: Marek Marczykowski-Górecki <marmarek@invisiblethingslab.com>
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
commit aa1acff356bbedfd03b544051f5b371746735d89 upstream.
The update_va_mapping hypercall can fail if the VA isn't present
in the guest's page tables. Under certain loads, this can
result in an OOPS when the target address is in unpopulated vmap
space.
While we're at it, add comments to help explain what's going on.
This isn't a great long-term fix. This code should probably be
changed to use something like set_memory_ro.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Cc: Andrew Cooper <andrew.cooper3@citrix.com>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: David Vrabel <dvrabel@cantab.net>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Jan Beulich <jbeulich@suse.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Sasha Levin <sasha.levin@oracle.com>
Cc: security@kernel.org <security@kernel.org>
Cc: xen-devel <xen-devel@lists.xen.org>
Link: http://lkml.kernel.org/r/0b0e55b995cda11e7829f140b833ef932fcabe3a.1438291540.git.luto@kernel.org
commit fa8173a3ef0570affde7da352de202190b3786c2 upstream.
The de-emphasis sampling rate selection is controlled by BIT[3:4] of
PCM1681_DEEMPH_CONTROL register. Do proper left shift to set it.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Acked-by: Marek Belisko <marek.belisko@streamunlimited.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
[ Upstream commit 44922150d87cef616fd183220d43d8fde4d41390 ]
If we have a series of events from userpsace, with %fprs=FPRS_FEF,
like follows:
ETRAP
ETRAP
VIS_ENTRY(fprs=0x4)
VIS_EXIT
RTRAP (kernel FPU restore with fpu_saved=0x4)
RTRAP
We will not restore the user registers that were clobbered by the FPU
using kernel code in the inner-most trap.
Traps allocate FPU save slots in the thread struct, and FPU using
sequences save the "dirty" FPU registers only.
This works at the initial trap level because all of the registers
get recorded into the top-level FPU save area, and we'll return
to userspace with the FPU disabled so that any FPU use by the user
will take an FPU disabled trap wherein we'll load the registers
back up properly.
But this is not how trap returns from kernel to kernel operate.
The simplest fix for this bug is to always save all FPU register state
for anything other than the top-most FPU save area.
Getting rid of the optimized inner-slot FPU saving code ends up
making VISEntryHalf degenerate into plain VISEntry.
Longer term we need to do something smarter to reinstate the partial
save optimizations. Perhaps the fundament error is having trap entry
and exit allocate FPU save slots and restore register state. Instead,
the VISEntry et al. calls should be doing that work.
This bug is about two decades old.
Reported-by: James Y Knight <jyknight@google.com>
commit 1146b600044de64af0ef775025731eeef1fa2189 upstream.
Building an SMP kernel for the sunxi platform with THUMB2 instructions
fails with this error at the moment:
headsmp.S:7: Error: Thumb encoding does not support an immediate here -- `msr cpsr_fsxc,#0xd3'
Since the generic secondary_startup function already does
the same thing in a safe way, we can just drop the private
sunxi implementation and jump straight to secondary_startup.
Cc: Maxime Ripard <maxime.ripard@free-electrons.com>
Signed-off-by: Kevin Hilman <khilman@linaro.org>
commit b6878d9e03043695dbf3fa1caa6dfc09db225b16 upstream.
In drivers/md/md.c get_bitmap_file() uses kmalloc() for creating a
mdu_bitmap_file_t called "file".
5769 file = kmalloc(sizeof(*file), GFP_NOIO);
5770 if (!file)
5771 return -ENOMEM;
This structure is copied to user space at the end of the function.
5786 if (err == 0 &&
5787 copy_to_user(arg, file, sizeof(*file)))
5788 err = -EFAULT
But if bitmap is disabled only the first byte of "file" is initialized
with zero, so it's possible to read some bytes (up to 4095) of kernel
space memory from user space. This is an information leak.
5775 /* bitmap disabled, zero the first byte and copy out */
5776 if (!mddev->bitmap_info.file)
5777 file->pathname[0] = '\0';
Signed-off-by: Benjamin Randazzo <benjamin@randazzo.fr>
commit 4351c294b8c1028077280f761e158d167b592974 upstream.
The current "mask" policy option matches files opened as MAY_READ,
MAY_WRITE, MAY_APPEND or MAY_EXEC. This patch extends the "mask"
option to match files opened containing one of these modes. For
example, "mask=^MAY_READ" would match files opened read-write.
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
Signed-off-by: Dr. Greg Wettstein <gw@idfusion.org>
commit 139069eff7388407f19794384c42a534d618ccd7 upstream.
The new "euid" policy condition measures files with the specified
effective uid (euid). In addition, for CAP_SETUID files it measures
files with the specified uid or suid.
Changelog:
- fixed checkpatch.pl warnings
- fixed avc denied {setuid} messages - based on Roberto's feedback
commit 74472233233f577eaa0ca6d6e17d9017b6e53150 upstream.
Add support for the Sierra Wireless AR8550 device with
USB descriptor 0x1199, 0x68AB.
It is common with MC879x modules 1199:683c/683d which
also are composite devices with 7 interfaces (0..6)
and also MDM62xx based as the AR8550.
The major difference are only the interface attributes
02/02/01 on interfaces 3 and 4 on the AR8550. They are
vendor specific ff/ff/ff on MC879x modules.
lsusb reports:
Bus 001 Device 004: ID 1199:68ab Sierra Wireless, Inc.
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x1199 Sierra Wireless, Inc.
idProduct 0x68ab
bcdDevice 0.06
iManufacturer 3 Sierra Wireless, Incorporated
iProduct 2 AR8550
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 198
bNumInterfaces 7
bConfigurationValue 1
iConfiguration 1 Sierra Configuration
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 255 Vendor Specific Subclass
bInterfaceProtocol 255 Vendor Specific Protocol
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 32
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 32
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 32
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 32
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 32
bLength 7
bDescriptorType 5
bEndpointAddress 0x03 EP 3 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 32
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 0
bNumEndpoints 3
bInterfaceClass 2 Communications
bInterfaceSubClass 2 Abstract (modem)
bInterfaceProtocol 1 AT-commands (v.25ter)
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x84 EP 4 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 5
bLength 7
bDescriptorType 5
bEndpointAddress 0x85 EP 5 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 32
bLength 7
bDescriptorType 5
bEndpointAddress 0x04 EP 4 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 32
bLength 9
bDescriptorType 4
bInterfaceNumber 4
bAlternateSetting 0
bNumEndpoints 3
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x86 EP 6 IN
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 5
bLength 7
bDescriptorType 5
bEndpointAddress 0x87 EP 7 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 32
bLength 7
bDescriptorType 5
bEndpointAddress 0x05 EP 5 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 32
bLength 9
bDescriptorType 4
bInterfaceNumber 5
bAlternateSetting 0
bNumEndpoints 3
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x88 EP 8 IN
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 5
bLength 7
bDescriptorType 5
bEndpointAddress 0x89 EP 9 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 32
bLength 7
bDescriptorType 5
bEndpointAddress 0x06 EP 6 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 32
bLength 9
bDescriptorType 4
bInterfaceNumber 6
bAlternateSetting 0
bNumEndpoints 3
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x8a EP 10 IN
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 5
bLength 7
bDescriptorType 5
bEndpointAddress 0x8b EP 11 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 32
bLength 7
bDescriptorType 5
bEndpointAddress 0x07 EP 7 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 32
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
Device Status: 0x0001
Self Powered
Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com>
Cc: Lars Melin <larsm17@gmail.com>
Signed-off-by: Johan Hovold <johan@kernel.org>
commit 7895086afde2a05fa24a0e410d8e6b75ca7c8fdd upstream.
We need to check that a TRB is part of the current segment
before calculating its DMA address.
Previously a ring segment didn't use a full memory page, and every
new ring segment got a new memory page, so the off by one
error in checking the upper bound was never seen.
Now that we use a full memory page, 256 TRBs (4096 bytes), the off by one
didn't catch the case when a TRB was the first element of the next segment.
This is triggered if the virtual memory pages for a ring segment are
next to each in increasing order where the ring buffer wraps around and
causes errors like:
[ 106.398223] xhci_hcd 0000:00:14.0: ERROR Transfer event TRB DMA ptr not part of current TD ep_index 0 comp_code 1
[ 106.398230] xhci_hcd 0000:00:14.0: Looking for event-dma fffd3000 trb-start fffd4fd0 trb-end fffd5000 seg-start fffd4000 seg-end fffd4ff0
The trb-end address is one outside the end-seg address.
Tested-by: Arkadiusz Miśkiewicz <arekm@maven.pl>
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
commit 3f1c0581310d5d94bd72740231507e763a6252a4 upstream.
Fixes another signed / unsigned array indexing bug in the ipr driver.
Currently, when hrrq_index wraps, it becomes a negative number. We
do the modulo, but still have a negative number, so we end up indexing
backwards in the array. Given where the hrrq array is located in memory,
we probably won't actually reference memory we don't own, but nonetheless
ipr is still looking at data within struct ipr_ioa_cfg and interpreting it as
struct ipr_hrr_queue data, so bad things could certainly happen.
Each ipr adapter has anywhere from 1 to 16 HRRQs. By default, we use 2 on new
adapters. Let's take an example:
Assume ioa_cfg->hrrq_index=0x7fffffffe and ioa_cfg->hrrq_num=4:
The atomic_add_return will then return -1. We mod this with 3 and get -2, add
one and get -1 for an array index.
On adapters which support more than a single HRRQ, we dedicate HRRQ to adapter
initialization and error interrupts so that we can optimize the other queues
for fast path I/O. So all normal I/O uses HRRQ 1-15. So we want to spread the
I/O requests across those HRRQs.
With the default module parameter settings, this bug won't hit, only when
someone sets the ipr.number_of_msix parameter to a value larger than 3 is when
bad things start to happen.
Tested-by: Wen Xiong <wenxiong@linux.vnet.ibm.com>
Reviewed-by: Wen Xiong <wenxiong@linux.vnet.ibm.com>
Reviewed-by: Gabriel Krisman Bertazi <krisman@linux.vnet.ibm.com>
Signed-off-by: Brian King <brking@linux.vnet.ibm.com>
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
Signed-off-by: James Bottomley <JBottomley@Odin.com>
commit bb7c54339e6a10ecce5c4961adf5e75b3cf0af30 upstream.
When ipr's internal driver trace was changed to an atomic, a signed/unsigned
bug slipped in which results in us indexing backwards in our memory buffer
writing on memory that does not belong to us. This patch fixes this by removing
the modulo and instead just mask off the low bits.
commit 36b8e180e1e929e00b351c3b72aab3147fc14116 upstream.
Make sure we have the host lock held when calling scsi_report_bus_reset. Fixes
a crash seen as the __devices list in the scsi host was changing as we were
iterating through it.
commit 0a90a0cff9f429f886f423967ae053150dce9259 upstream.
Fixes a broken hsync start value uncovered by:
abc0b1447d4974963548777a5ba4a4457c82c426
(drm: Perform basic sanity checks on probed modes)
The driver handled the bad hsync start elsewhere, but
the above commit prevented it from getting added.
bug:
https://bugs.freedesktop.org/show_bug.cgi?id=91401
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 8f2f3eb59dff4ec538de55f2e0592fec85966aab upstream.
fsnotify_clear_marks_by_group_flags() can race with
fsnotify_destroy_marks() so that when fsnotify_destroy_mark_locked()
drops mark_mutex, a mark from the list iterated by
fsnotify_clear_marks_by_group_flags() can be freed and thus the next
entry pointer we have cached may become stale and we dereference free
memory.
Fix the problem by first moving marks to free to a special private list
and then always free the first entry in the special list. This method
is safe even when entries from the list can disappear once we drop the
lock.
Signed-off-by: Jan Kara <jack@suse.com>
Reported-by: Ashish Sangwan <a.sangwan@samsung.com>
Reviewed-by: Ashish Sangwan <a.sangwan@samsung.com>
Cc: Lino Sanfilippo <LinoSanfilippo@gmx.de>
commit 46011e6ea39235e4aca656673c500eac81a07a17 upstream.
On MIPS the GLOBAL bit of the PTE must have the same value in any
aligned pair of PTEs. These pairs of PTEs are referred to as
"buddies". In a SMP system is is possible for two CPUs to be calling
set_pte() on adjacent PTEs at the same time. There is a race between
setting the PTE and a different CPU setting the GLOBAL bit in its
buddy PTE.
This race can be observed when multiple CPUs are executing
vmap()/vfree() at the same time.
Make setting the buddy PTE's GLOBAL bit an atomic operation to close
the race condition.
The case of CONFIG_64BIT_PHYS_ADDR && CONFIG_CPU_MIPS32 is *not*
handled.
Signed-off-by: David Daney <david.daney@cavium.com>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/10835/
commit 1d62d737555e1378eb62a8bba26644f7d97139d2 upstream.
p->thread.user_cpus_allowed is zero-initialized and is only filled on
the first sched_setaffinity call.
To avoid adding overhead in the task initialization codepath, simply OR
the returned mask in sched_getaffinity with p->cpus_allowed.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Patchwork: https://patchwork.linux-mips.org/patch/10740/
commit 106eccb4d20f35ebc58ff2286c170d9e79c5ff68 upstream.
On Malta, since commit a87ea88d8f6c ("MIPS: Malta: initialise the RTC at
boot"), the RTC is reinitialised and forced into binary coded decimal
(BCD) mode during init, even if the bootloader has already initialised
it, and may even have already put it into binary mode (as YAMON does).
This corrupts the current time, can result in the RTC seconds being an
invalid BCD (e.g. 0x1a..0x1f) for up to 6 seconds, as well as confusing
YAMON for a while after reset, enough for it to report timeouts when
attempting to load from TFTP (it actually uses the RTC in that code).
Therefore only initialise the RTC to the extent that is necessary so
that Linux avoids interfering with the bootloader setup, while also
allowing it to estimate the CPU frequency without hanging, without a
bootloader necessarily having done anything with the RTC (for example
when the kernel is loaded via EJTAG).
The divider control is configured for a 32KHZ reference clock if
necessary, and the SET bit of the RTC_CONTROL register is cleared if
necessary without changing any other bits (this bit will be set when
coming out of reset if the battery has been disconnected).
Fixes: a87ea88d8f6c ("MIPS: Malta: initialise the RTC at boot")
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Reviewed-by: Paul Burton <paul.burton@imgtec.com>
Cc: Maciej W. Rozycki <macro@linux-mips.org>
Patchwork: https://patchwork.linux-mips.org/patch/10739/
commit dd94d3558947756b102b1487911acd925224a38c upstream.
Commit b713aa0b15 "ARM: fix asm/memory.h build error" broke some
configurations on mach-realview with sparsemem enabled, which
is missing a definition of PHYS_OFFSET:
arch/arm/include/asm/memory.h:268:42: error: 'PHYS_OFFSET' undeclared (first use in this function)
#define PHYS_PFN_OFFSET ((unsigned long)(PHYS_OFFSET >> PAGE_SHIFT))
arch/arm/include/asm/dma-mapping.h:104:9: note: in expansion of macro 'PHYS_PFN_OFFSET'
return PHYS_PFN_OFFSET + dma_to_pfn(dev, *dev->dma_mask);
An easy workaround is for realview to define PHYS_OFFSET itself,
in the same way we define it for platforms that don't have a private
__virt_to_phys function.
Cc: Linus Walleij <linus.walleij@linaro.org>
Commit 35d5134b7d5a
("x86/efi: Correct EFI boot stub use of code32_start")
imported a bug, which will cause 32bit kernel boot failed
using efi method. It should use the label's address instead
of the value stored in the label to caculate the address of
code32_start.
Signed-off-by: Fupan Li <fupan.li@windriver.com>
Reviewed-by: Matt Fleming <matt.fleming@intel.com>
commit 007d038bdf95ccfe2491d0078be54040d110fd06 upstream.
in v4.0-rc1 code, where an explicit iser-target logout would result
in ->tx_thread_active being incorrectly cleared by the logout post
handler, and subsequent TX kthread leak:
To address this bug, change iscsit_logout_post_handler_closesession()
and iscsit_logout_post_handler_samecid() to only cmpxchg() on
->tx_thread_active for traditional iscsi/tcp connections.
This is required because iscsi/tcp connections are invoking logout
post handler logic directly from TX kthread context, while iser
connections are invoking logout post handler logic from a seperate
workqueue context.
commit 417c20a9bdd1e876384127cf096d8ae8b559066c upstream.
This patch fixes a use-after-free bug in iscsit_release_sessions_for_tpg()
where se_portal_group->session_lock was incorrectly released/re-acquired
while walking the active se_portal_group->tpg_sess_list.
The can result in a NULL pointer dereference when iscsit_close_session()
shutdown happens in the normal path asynchronously to this code, causing
a bogus dereference of an already freed list entry to occur.
To address this bug, walk the session list checking for the same state
as before, but move entries to a local list to avoid dropping the lock
while walking the active list.
As before, signal using iscsi_session->session_restatement=1 for those
list entries to be released locally by iscsit_free_session() code.
Reported-by: Sunilkumar Nadumuttlu <sjn@datera.io>
Cc: Sunilkumar Nadumuttlu <sjn@datera.io>
commit 5c02a4206538da12c040b51778d310df84c6bf6c upstream.
Since NULL is used as valid clock object on optional clocks we have to handle
this case in avr32 implementation as well.
Fixes: e1824dfe0d8e (net: macb: Adjust tx_clk when link speed changes)
Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
