2014-03-24Linux 3.14-rc8v3.14-rc8Linus Torvalds
2014-03-24Merge branch 'parisc-3.14' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux Pull parisc updates from Helge Deller: - revert parts of the latest patch regarding font selection with STICON console - wire up the utimes() syscall for parisc - remove the unused parisc tmpalias code and unnecessary arch*relax defines * 'parisc-3.14' of git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux: parisc: locks: remove redundant arch_*_relax operations parisc: wire up sys_utimes parisc: Remove unused CONFIG_PARISC_TMPALIAS code partly revert commit 8a10bc9: parisc/sti_console: prefer Linux fonts over built-in ROM fonts
2014-03-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
Pull sparc fixes from David Miller: 1) Do serial locking in a way that makes things clear that these are IRQ spinlocks. 2) Conversion to generic idle loop broke first generation Niagara machines, need to have %pil interrupts enabled during cpu yield hypervisor call. 3) Do not use magic constants for iterations over tsb tables, from Doug Wilson. 4) Fix erroneous truncation of 64-bit system call return values to 32-bit. From Dave Kleikamp. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: sparc64: Make sure %pil interrupts are enabled during hypervisor yield. sparc64:tsb.c:use array size macro rather than number sparc64: don't treat 64-bit syscall return codes as 32-bit sparc: serial: Clean up the locking for -rt
2014-03-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) OpenVswitch's lookup_datapath() returns error pointers, so don't check against NULL. From Jiri Pirko. 2) pfkey_compile_policy() code path tries to do a GFP_KERNEL allocation under RCU locks, fix by using GFP_ATOMIC when necessary. From Nikolay Aleksandrov. 3) phy_suspend() indirectly passes uninitialized data into the ethtool get wake-on-land implementations. Fix from Sebastian Hesselbarth. 4) CPSW driver unregisters CPTS twice, fix from Benedikt Spranger. 5) If SKB allocation of reply packet fails, vxlan's arp_reduce() defers a NULL pointer. Fix from David Stevens. 6) IPV6 neigh handling in vxlan doesn't validate the destination address properly, and it builds a packet with the src and dst reversed. Fix also from David Stevens. 7) Fix spinlock recursion during subscription failures in TIPC stack, from Erik Hugne. 8) Revert buggy conversion of davinci_emac to devm_request_irq, from Chrstian Riesch. 9) Wrong flags passed into forwarding database netlink notifications, from Nicolas Dichtel. 10) The netpoll neighbour soliciation handler checks wrong ethertype, needs to be ETH_P_IPV6 rather than ETH_P_ARP. Fix from Li RongQing. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (34 commits) tipc: fix spinlock recursion bug for failed subscriptions vxlan: fix nonfunctional neigh_reduce() net: davinci_emac: Fix rollback of emac_dev_open() net: davinci_emac: Replace devm_request_irq with request_irq netpoll: fix the skb check in pkt_is_ns net: micrel : ks8851-ml: add vdd-supply support ip6mr: fix mfc notification flags ipmr: fix mfc notification flags rtnetlink: fix fdb notification flags tcp: syncookies: do not use getnstimeofday() netlink: fix setsockopt in mmap examples in documentation openvswitch: Correctly report flow used times for first 5 minutes after boot. via-rhine: Disable device in error path ATHEROS-ATL1E: Convert iounmap to pci_iounmap vxlan: fix potential NULL dereference in arp_reduce() cnic: Update version to 2.5.20 and copyright year. cnic,bnx2i,bnx2fc: Fix inconsistent use of page size cnic: Use proper ulp_ops for per device operations. net: cdc_ncm: fix control message ordering ipv6: ip6_append_data_mtu do not handle the mtu of the second fragment properly ...
2014-03-24tipc: fix spinlock recursion bug for failed subscriptionsErik Hugne
If a topology event subscription fails for any reason, such as out of memory, max number reached or because we received an invalid request the correct behavior is to terminate the subscribers connection to the topology server. This is currently broken and produces the following oops: [27.953662] tipc: Subscription rejected, illegal request [27.955329] BUG: spinlock recursion on CPU#1, kworker/u4:0/6 [27.957066] lock: 0xffff88003c67f408, .magic: dead4ead, .owner: kworker/u4:0/6, .owner_cpu: 1 [27.958054] CPU: 1 PID: 6 Comm: kworker/u4:0 Not tainted 3.14.0-rc6+ #5 [27.960230] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011 [27.960874] Workqueue: tipc_rcv tipc_recv_work [tipc] [27.961430] ffff88003c67f408 ffff88003de27c18 ffffffff815c0207 ffff88003de1c050 [27.962292] ffff88003de27c38 ffffffff815beec5 ffff88003c67f408 ffffffff817f0a8a [27.963152] ffff88003de27c58 ffffffff815beeeb ffff88003c67f408 ffffffffa0013520 [27.964023] Call Trace: [27.964292] [<ffffffff815c0207>] dump_stack+0x45/0x56 [27.964874] [<ffffffff815beec5>] spin_dump+0x8c/0x91 [27.965420] [<ffffffff815beeeb>] spin_bug+0x21/0x26 [27.965995] [<ffffffff81083df6>] do_raw_spin_lock+0x116/0x140 [27.966631] [<ffffffff815c6215>] _raw_spin_lock_bh+0x15/0x20 [27.967256] [<ffffffffa0008540>] subscr_conn_shutdown_event+0x20/0xa0 [tipc] [27.968051] [<ffffffffa000fde4>] tipc_close_conn+0xa4/0xb0 [tipc] [27.968722] [<ffffffffa00101ba>] tipc_conn_terminate+0x1a/0x30 [tipc] [27.969436] [<ffffffffa00089a2>] subscr_conn_msg_event+0x1f2/0x2f0 [tipc] [27.970209] [<ffffffffa0010000>] tipc_receive_from_sock+0x90/0xf0 [tipc] [27.970972] [<ffffffffa000fa79>] tipc_recv_work+0x29/0x50 [tipc] [27.971633] [<ffffffff8105dbf5>] process_one_work+0x165/0x3e0 [27.972267] [<ffffffff8105e869>] worker_thread+0x119/0x3a0 [27.972896] [<ffffffff8105e750>] ? manage_workers.isra.25+0x2a0/0x2a0 [27.973622] [<ffffffff810648af>] kthread+0xdf/0x100 [27.974168] [<ffffffff810647d0>] ? kthread_create_on_node+0x1a0/0x1a0 [27.974893] [<ffffffff815ce13c>] ret_from_fork+0x7c/0xb0 [27.975466] [<ffffffff810647d0>] ? kthread_create_on_node+0x1a0/0x1a0 The recursion occurs when subscr_terminate tries to grab the subscriber lock, which is already taken by subscr_conn_msg_event. We fix this by checking if the request to establish a new subscription was successful, and if not we initiate termination of the subscriber after we have released the subscriber lock. Signed-off-by: Erik Hugne <erik.hugne@ericsson.com> Reviewed-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-24vxlan: fix nonfunctional neigh_reduce()David Stevens
The VXLAN neigh_reduce() code is completely non-functional since check-in. Specific errors: 1) The original code drops all packets with a multicast destination address, even though neighbor solicitations are sent to the solicited-node address, a multicast address. The code after this check was never run. 2) The neighbor table lookup used the IPv6 header destination, which is the solicited node address, rather than the target address from the neighbor solicitation. So neighbor lookups would always fail if it got this far. Also for L3MISSes. 3) The code calls ndisc_send_na(), which does a send on the tunnel device. The context for neigh_reduce() is the transmit path, vxlan_xmit(), where the host or a bridge-attached neighbor is trying to transmit a neighbor solicitation. To respond to it, the tunnel endpoint needs to do a *receive* of the appropriate neighbor advertisement. Doing a send, would only try to send the advertisement, encapsulated, to the remote destinations in the fdb -- hosts that definitely did not do the corresponding solicitation. 4) The code uses the tunnel endpoint IPv6 forwarding flag to determine the isrouter flag in the advertisement. This has nothing to do with whether or not the target is a router, and generally won't be set since the tunnel endpoint is bridging, not routing, traffic. The patch below creates a proxy neighbor advertisement to respond to neighbor solicitions as intended, providing proper IPv6 support for neighbor reduction. Signed-off-by: David L Stevens <dlstevens@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-24Merge branch 'davinci_emac'David S. Miller
Christian Riesch says: ==================== net: davinci_emac: Fix interrupt requests and error handling since commit 6892b41d9701283085b655c6086fb57a5d63fa47 (Linux 3.11) the davinci_emac driver is broken. After doing ifconfig down, ifconfig up, requesting the interrupts for the driver fails. The interface remains dead until the board is rebooted. The first patch in this patchset reverts commit 6892b41d9701283085b655c6086fb57a5d63fa47 partially and makes the driver useable again. During the work on the first patch, a number of bugs in the error handling of the driver's ndo_open code were found. The second patch fixes these bugs. I believe the first patch meets the rules for stable kernels, I therefore added the stable tag to this patch. The second patch is just cleanup, the code that is fixed by this patch is only executed in case of an error. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-24net: davinci_emac: Fix rollback of emac_dev_open()Christian Riesch
If an error occurs during the initialization in emac_dev_open() (the driver's ndo_open function), interrupts, DMA descriptors etc. must be freed. The current rollback code is buggy in several ways. 1) Freeing the interrupts. The current code will not free all interrupts that were requested by the driver. Furthermore, the code tries to do a platform_get_resource(priv->pdev, IORESOURCE_IRQ, -1) in its last iteration. This patch fixes these bugs. 2) Wrong order of err: and rollback: labels. If the setup of the PHY in the code fails, the interrupts that have been requested before are not freed: request irq if requesting irqs fails, goto rollback setup phy if phy setup fails, goto err return 0 rollback: free irqs err: This patch brings the code into the correct order. 3) The code calls napi_enable() and emac_int_enable(), but does not undo both in case of an error. This patch adds calls of emac_int_disable() and napi_disable() to the rollback code. 4) RX DMA descriptors are not freed in case of an error: Right before requesting the irqs, the function creates DMA descriptors for the RX channel. These RX descriptors are never freed when we jump to either rollback or err. This patch adds code for freeing the DMA descriptors in the case of an initialization error. This required a modification of cpdma_ctrl_stop() in davinci_cpdma.c: We must be able to call this function to free the DMA descriptors while the DMA channels are in IDLE state (before cpdma_ctlr_start() was called). Tested on a custom board with the Texas Instruments AM1808. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-24net: davinci_emac: Replace devm_request_irq with request_irqChristian Riesch
In commit 6892b41d9701283085b655c6086fb57a5d63fa47 Author: Lad, Prabhakar <prabhakar.csengg@gmail.com> Date: Tue Jun 25 21:24:51 2013 +0530 net: davinci: emac: Convert to devm_* api the call of request_irq is replaced by devm_request_irq and the call of free_irq is removed. But since interrupts are requested in emac_dev_open, doing ifconfig up/down on the board requests the interrupts again each time, causing devm_request_irq to fail. The interface is dead until the device is rebooted. This patch reverts said commit partially: It changes the driver back to use request_irq instead of devm_request_irq, puts free_irq back in place, but keeps the remaining changes of the original patch. Reported-by: Jon Ringle <jon@ringle.org> Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Lad, Prabhakar <prabhakar.csengg@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-24netpoll: fix the skb check in pkt_is_nsLi RongQing
Neighbor Solicitation is ipv6 protocol, so we should check skb->protocol with ETH_P_IPV6 Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Cc: WANG Cong <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-24sparc64: Make sure %pil interrupts are enabled during hypervisor yield.David S. Miller
In arch_cpu_idle() we must enable %pil based interrupts before potentially invoking the hypervisor cpu yield call. As per the Hypervisor API documentation for cpu_yield: Interrupts which are blocked by some mechanism other that pstate.ie (for example %pil) are not guaranteed to cause a return from this service. It seems that only first generation Niagara chips are hit by this bug. My best guess is that later chips implement this in hardware and wake up anyways from %pil events, whereas in first generation chips the yield is implemented completely in hypervisor code and requires %pil to be enabled in order to wake properly from this call. Fixes: 87fa05aeb3a5 ("sparc: Use generic idle loop") Reported-by: Fabio M. Di Nitto <fabbione@fabbione.net> Reported-by: Jan Engelhardt <jengelh@inai.de> Tested-by: Jan Engelhardt <jengelh@inai.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-24net: micrel : ks8851-ml: add vdd-supply supportNishanth Menon
Few platforms use external regulator to keep the ethernet MAC supplied. So, request and enable the regulator for driver functionality. Fixes: 66fda75f47dc (regulator: core: Replace direct ops->disable usage) Reported-by: Russell King <rmk+kernel@arm.linux.org.uk> Suggested-by: Markus Pargmann <mpa@pengutronix.de> Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-23parisc: locks: remove redundant arch_*_relax operationsWill Deacon
Now that the arch_{spin,read,write}_relax macros default to cpu_relax(), remove the redundant definitions for parisc. Cc: Helge Deller <deller@gmx.de> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Helge Deller <deller@gmx.de>
2014-03-23parisc: wire up sys_utimesHelge Deller
We seem to be nearly the only platform which does not provide the sys_utimes syscall. Adding it now makes our life much easier with userspace applications (like dietlibc and e2fsprogs) since we then behave like all other platforms too and don't need extra patches which are hard to get upstream anyway because we are not a mainstream architecture. Signed-off-by: Helge Deller <deller@gmx.de> Cc: stable@vger.kernel.org # v3.13
2014-03-23parisc: Remove unused CONFIG_PARISC_TMPALIAS codeJohn David Anglin
The attached change removes the unused and experimental CONFIG_PARISC_TMPALIAS code. It doesn't work and I don't believe it will ever be used. Signed-off-by: John David Anglin <dave.anglin@bell.net> Signed-off-by: Helge Deller <deller@gmx.de>
2014-03-23partly revert commit 8a10bc9: parisc/sti_console: prefer Linux fonts over ↵Helge Deller
built-in ROM fonts STI console is used on parisc and m68k HP machines. This patch partly reverts my previous commit and as such restores the fonts for the m68k machines. Signed-off-by: Helge Deller <deller@gmx.de> Cc: stable@vger.kernel.org # v3.13
2014-03-22Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Two oneliner 'perf bench' tooling fixes" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf bench: Fix NULL pointer dereference in "perf bench all" perf bench numa: Make no args mean 'run all tests'
2014-03-22Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "Only two patches this time, one to fix ethernet probe order on at91 (better fix with proper device aliasing will be done for 3.15, this is stop-gap), and one update to MAINTAINERS due to Freescale moving their repo to kernel.org" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: at91: fix network interface ordering for sama5d36 MAINTAINERS: update IMX kernel git tree
2014-03-20Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes from Dave Airlie: "Some final few intel fixes, all regressions, all stable cc, and one exynos oops fixer. The biggest is probably the intel display error irqs one, but it seems to fix a few crashes on startup, and one use after free in drm core" * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: drm/exynos: Fix (more) freeing issues in exynos_drm_drv.c drm/i915: Disable stolen memory when DMAR is active Revert "drm/i915: don't touch the VDD when disabling the panel" drm: Fix use-after-free in the shadow-attache exit code drm/i915: Don't enable display error interrupts from the start drm/i915: Fix scanline counter fixup on BDW drm/i915: Add a workaround for HSW scanline counter weirdness drm/i915: Fix PSR programming
2014-03-20block: free q->flush_rq in blk_init_allocated_queue error pathsDave Jones
Commit 7982e90c3a57 ("block: fix q->flush_rq NULL pointer crash on dm-mpath flush") moved an allocation to blk_init_allocated_queue(), but neglected to free that allocation on the error paths that follow. Signed-off-by: Dave Jones <davej@fedoraproject.org> Acked-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Jens Axboe <axboe@fb.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-20futex: revert back to the explicit waiter counting codeLinus Torvalds
Srikar Dronamraju reports that commit b0c29f79ecea ("futexes: Avoid taking the hb->lock if there's nothing to wake up") causes java threads getting stuck on futexes when runing specjbb on a power7 numa box. The cause appears to be that the powerpc spinlocks aren't using the same ticket lock model that we use on x86 (and other) architectures, which in turn result in the "spin_is_locked()" test in hb_waiters_pending() occasionally reporting an unlocked spinlock even when there are pending waiters. So this reinstates Davidlohr Bueso's original explicit waiter counting code, which I had convinced Davidlohr to drop in favor of figuring out the pending waiters by just using the existing state of the spinlock and the wait queue. Reported-and-tested-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Original-code-by: Davidlohr Bueso <davidlohr@hp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-20Merge tag 'trace-fixes-v3.14-rc7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull trace fix from Steven Rostedt: "Vaibhav Nagarnaik discovered that since 3.10 a clean-up patch made the array index in the trace event format bogus. He supplied an elegant solution that uses __stringify() and also removes the need for the event_storage and event_storage_mutex and also cuts off a few K of overhead from the trace events" * tag 'trace-fixes-v3.14-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: tracing: Fix array size mismatch in format string
2014-03-20mm: fix swapops.h:131 bug if remap_file_pages raced migrationHugh Dickins
Add remove_linear_migration_ptes_from_nonlinear(), to fix an interesting little include/linux/swapops.h:131 BUG_ON(!PageLocked) found by trinity: indicating that remove_migration_ptes() failed to find one of the migration entries that was temporarily inserted. The problem comes from remap_file_pages()'s switch from vma_interval_tree (good for inserting the migration entry) to i_mmap_nonlinear list (no good for locating it again); but can only be a problem if the remap_file_pages() range does not cover the whole of the vma (zap_pte() clears the range). remove_migration_ptes() needs a file_nonlinear method to go down the i_mmap_nonlinear list, applying linear location to look for migration entries in those vmas too, just in case there was this race. The file_nonlinear method does need rmap_walk_control.arg to do this; but it never needed vma passed in - vma comes from its own iteration. Reported-and-tested-by: Dave Jones <davej@redhat.com> Reported-and-tested-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-20Merge branch 'fixes' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/jesse/openvswitch Jesse Gross says: ==================== Open vSwitch Four small fixes for net/3.14. I realize that these are late in the cycle - just got back from vacation. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-20ip6mr: fix mfc notification flagsNicolas Dichtel
Commit 812e44dd1829 ("ip6mr: advertise new mfc entries via rtnl") reuses the function ip6mr_fill_mroute() to notify mfc events. But this function was used only for dump and thus was always setting the flag NLM_F_MULTI, which is wrong in case of a single notification. Libraries like libnl will wait forever for NLMSG_DONE. CC: Thomas Graf <tgraf@suug.ch> Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Acked-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-20ipmr: fix mfc notification flagsNicolas Dichtel
Commit 8cd3ac9f9b7b ("ipmr: advertise new mfc entries via rtnl") reuses the function ipmr_fill_mroute() to notify mfc events. But this function was used only for dump and thus was always setting the flag NLM_F_MULTI, which is wrong in case of a single notification. Libraries like libnl will wait forever for NLMSG_DONE. CC: Thomas Graf <tgraf@suug.ch> Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Acked-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-20rtnetlink: fix fdb notification flagsNicolas Dichtel
Commit 3ff661c38c84 ("net: rtnetlink notify events for FDB NTF_SELF adds and deletes") reuses the function nlmsg_populate_fdb_fill() to notify fdb events. But this function was used only for dump and thus was always setting the flag NLM_F_MULTI, which is wrong in case of a single notification. Libraries like libnl will wait forever for NLMSG_DONE. CC: Thomas Graf <tgraf@suug.ch> Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Acked-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-20tcp: syncookies: do not use getnstimeofday()Eric Dumazet
While it is true that getnstimeofday() uses about 40 cycles if TSC is available, it can use 1600 cycles if hpet is the clocksource. Switch to get_jiffies_64(), as this is more than enough, and go back to 60 seconds periods. Fixes: 8c27bd75f04f ("tcp: syncookies: reduce cookie lifetime to 128 seconds") Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Florian Westphal <fw@strlen.de> Acked-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-20netlink: fix setsockopt in mmap examples in documentationstephen hemminger
The documentation for how to use netlink mmap interface is incorrect. The calls to setsockopt() require an additional argument. Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-20Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS fixes from Ralf Baechle: "Another set of five fixes. The most interesting one is a fix for race condition in the local_irq_disable() implementation used by .S code for pre-MIPS R2 processors only. It leaves a race that's hard but not impossible to hit; the others fairly obvious" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: MIPS: Make local_irq_disable macro safe for non-Mipsr2 MIPS: Octeon: Fix warning in of_device_alloc on cn3xxx MIPS: ftrace: Tweak safe_load()/safe_store() macros MIPS: BCM47XX: Check all (32) GPIOs when looking for a pin MIPS: Fix possible build error with transparent hugepages enabled
2014-03-20Merge tag 'sound-3.14' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "Just two minor bug fixes: a fix for a regression in oxygen driver that was introduced in 3.14-rc1, and a stable fix for the return value of compress offload open callback" * tag 'sound-3.14' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: compress: Pass through return value of open ops callback ALSA: oxygen: Xonar DG(X): fix Stereo Upmixing regression
2014-03-20openvswitch: Correctly report flow used times for first 5 minutes after boot.Ben Pfaff
The kernel starts out its "jiffies" timer as 5 minutes below zero, as shown in include/linux/jiffies.h: /* * Have the 32 bit jiffies value wrap 5 minutes after boot * so jiffies wrap bugs show up earlier. */ #define INITIAL_JIFFIES ((unsigned long)(unsigned int) (-300*HZ)) The loop in ovs_flow_stats_get() starts out with 'used' set to 0, then takes any "later" time. This means that for the first five minutes after boot, flows will always be reported as never used, since 0 is greater than any time already seen. Signed-off-by: Ben Pfaff <blp@nicira.com> Acked-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: Jesse Gross <jesse@nicira.com>
2014-03-20tracing: Fix array size mismatch in format stringVaibhav Nagarnaik
In event format strings, the array size is reported in two locations. One in array subscript and then via the "size:" attribute. The values reported there have a mismatch. For e.g., in sched:sched_switch the prev_comm and next_comm character arrays have subscript values as [32] where as the actual field size is 16. name: sched_switch ID: 301 format: field:unsigned short common_type; offset:0; size:2; signed:0; field:unsigned char common_flags; offset:2; size:1; signed:0; field:unsigned char common_preempt_count; offset:3; size:1;signed:0; field:int common_pid; offset:4; size:4; signed:1; field:char prev_comm[32]; offset:8; size:16; signed:1; field:pid_t prev_pid; offset:24; size:4; signed:1; field:int prev_prio; offset:28; size:4; signed:1; field:long prev_state; offset:32; size:8; signed:1; field:char next_comm[32]; offset:40; size:16; signed:1; field:pid_t next_pid; offset:56; size:4; signed:1; field:int next_prio; offset:60; size:4; signed:1; After bisection, the following commit was blamed: 92edca0 tracing: Use direct field, type and system names This commit removes the duplication of strings for field->name and field->type assuming that all the strings passed in __trace_define_field() are immutable. This is not true for arrays, where the type string is created in event_storage variable and field->type for all array fields points to event_storage. Use __stringify() to create a string constant for the type string. Also, get rid of event_storage and event_storage_mutex that are not needed anymore. also, an added benefit is that this reduces the overhead of events a bit more: text data bss dec hex filename 8424787 2036472 1302528 11763787 b3804b vmlinux 8420814 2036408 1302528 11759750 b37086 vmlinux.patched Link: http://lkml.kernel.org/r/1392349908-29685-1-git-send-email-vnagarnaik@google.com Cc: Laurent Chavey <chavey@google.com> Cc: stable@vger.kernel.org # 3.10+ Signed-off-by: Vaibhav Nagarnaik <vnagarnaik@google.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2014-03-20MIPS: Make local_irq_disable macro safe for non-Mipsr2Jim Quinlan
For non-mipsr2 processors, the local_irq_disable contains an mfc0-mtc0 pair with instructions inbetween. With preemption enabled, this sequence may get preempted and effect a stale value of CP0_STATUS when executing the mtc0 instruction. This commit avoids this scenario by incrementing the preempt count before the mfc0 and decrementing it after the mtc9. [ralf@linux-mips.org: This patch is sorting out the part that were missed by e97c5b6098 [MIPS: Make irqflags.h functions preempt-safe for non-mipsr2 cpus.] I also re-enabled the inclusion of <asm/asm-offsets.h> at the top of <asm/asmmacro.h>]. Signed-off-by: Jim Quinlan <jim2101024@gmail.com> Cc: linux-mips@linux-mips.org Cc: cernekee@gmail.com Patchwork: https://patchwork.linux-mips.org/patch/6164/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-03-20Merge branch 'exynos-drm-fixes' of ↵Dave Airlie
git://git.kernel.org/pub/scm/linux/kernel/git/daeinki/drm-exynos into drm-fixes Just fixed resource release issue at open fail. * 'exynos-drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/daeinki/drm-exynos: drm/exynos: Fix (more) freeing issues in exynos_drm_drv.c
2014-03-20drm/exynos: Fix (more) freeing issues in exynos_drm_drv.cDaniel Kurtz
The following commit [0] fixed a use-after-free, but left the subdrv open in the error path. [0] commit 6ca605f7c70895a35737435f17ae9cc5e36f1466 drm/exynos: Fix freeing issues in exynos_drm_drv.c Signed-off-by: Daniel Kurtz <djkurtz@chromium.org> Acked-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Inki Dae <inki.dae@samsung.com>
2014-03-19mm: fix bad rss-counter if remap_file_pages raced migrationHugh Dickins
Fix some "Bad rss-counter state" reports on exit, arising from the interaction between page migration and remap_file_pages(): zap_pte() must count a migration entry when zapping it. And yes, it is possible (though very unusual) to find an anon page or swap entry in a VM_SHARED nonlinear mapping: coming from that horrid get_user_pages(write, force) case which COWs even in a shared mapping. Signed-off-by: Hugh Dickins <hughd@google.com> Tested-by: Sasha Levin sasha.levin@oracle.com> Tested-by: Dave Jones davej@redhat.com> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-19Merge tag 'pci-v3.14-fixes-3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI resource management fix from Bjorn Helgaas: "This is a fix for an AGP regression exposed by e501b3d87f00 ("agp: Support 64-bit APBASE"), which we merged in v3.14-rc1. We've warned about the conflict between the GART and PCI resources and cleared out the PCI resource for a long time, but after e501b3d87f00, we still *use* that cleared-out PCI resource. I think the GART resource is incorrect, so this patch removes it" * tag 'pci-v3.14-fixes-3' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: Revert "[PATCH] Insert GART region into resource map"
2014-03-19Merge branch 'for-3.14-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup fix from Tejun Heo: "One really late cgroup patch to fix error path in create_css(). Hitting this bug would be pretty rare but still possible and it gets delayed we'd need to backport it through -stable anyway. It only updates error path in create_css() and has low chance of new breakages" * 'for-3.14-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: cgroup: fix a failure path in create_css()
2014-03-19MIPS: Octeon: Fix warning in of_device_alloc on cn3xxxAndreas Herrmann
Starting with commit 3da5278727a895d49a601f67fd49dffa0b80f9a5 (of/irq: Rework of_irq_count()) the following warning is triggered on octeon cn3xxx: [ 0.887281] WARNING: CPU: 0 PID: 1 at drivers/of/platform.c:171 of_device_alloc+0x228/0x230() [ 0.895642] Modules linked in: [ 0.898689] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.14.0-rc7-00012-g9ae51f2-dirty #41 [ 0.906860] Stack : c8b439581166d96e ffffffff816b0000 0000000040808000 ffffffff81185ddc [ 0.906860] 0000000000000000 0000000000000000 0000000000000000 000000000000000b [ 0.906860] 000000000000000a 000000000000000a 0000000000000000 0000000000000000 [ 0.906860] ffffffff81740000 ffffffff81720000 ffffffff81615900 ffffffff816b0177 [ 0.906860] ffffffff81727d10 800000041f868fb0 0000000000000001 0000000000000000 [ 0.906860] 0000000000000000 0000000000000038 0000000000000001 ffffffff81568484 [ 0.906860] 800000041f86faa8 ffffffff81145ddc 0000000000000000 ffffffff811873f4 [ 0.906860] 800000041f868b88 800000041f86f9c0 0000000000000000 ffffffff81569c9c [ 0.906860] 0000000000000000 0000000000000000 0000000000000000 0000000000000000 [ 0.906860] 0000000000000000 ffffffff811205e0 0000000000000000 0000000000000000 [ 0.906860] ... [ 0.971695] Call Trace: [ 0.974139] [<ffffffff811205e0>] show_stack+0x68/0x80 [ 0.979183] [<ffffffff81569c9c>] dump_stack+0x8c/0xe0 [ 0.984196] [<ffffffff81145efc>] warn_slowpath_common+0x84/0xb8 [ 0.990110] [<ffffffff81436888>] of_device_alloc+0x228/0x230 [ 0.995726] [<ffffffff814368d8>] of_platform_device_create_pdata+0x48/0xd0 [ 1.002593] [<ffffffff81436a94>] of_platform_bus_create+0x134/0x1e8 [ 1.008837] [<ffffffff81436af8>] of_platform_bus_create+0x198/0x1e8 [ 1.015064] [<ffffffff81436cc4>] of_platform_bus_probe+0xa4/0x100 [ 1.021149] [<ffffffff81100570>] do_one_initcall+0xd8/0x128 [ 1.026701] [<ffffffff816e2a10>] kernel_init_freeable+0x144/0x210 [ 1.032753] [<ffffffff81564bc4>] kernel_init+0x14/0x110 [ 1.037973] [<ffffffff8111bb44>] ret_from_kernel_thread+0x14/0x1c With this commit the kernel starts mapping the interrupts listed for gpio-controller node. irq_domain_ops for CIU (octeon_irq_ciu_map and octeon_irq_ciu_xlat) refuse to handle the GPIO lines (returning -EINVAL) and this is causing above warning in of_device_alloc(). Modify irq_domain_ops for CIU and CIU2 to "gracefully handle" GPIO lines (neither return error code nor call octeon_irq_set_ciu_mapping for it). This should avoid the warning. (As before the real setup for GPIO lines will happen using irq_domain_ops of gpio-controller.) This patch is based on Wei's patch v2 (see http://marc.info/?l=linux-mips&m=139511814813247). Signed-off-by: Andreas Herrmann <andreas.herrmann@caviumnetworks.com> Reported-by: Yang Wei <wei.yang@windriver.com> Acked-by: David Daney <david.daney@cavium.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/6624/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-03-19MIPS: ftrace: Tweak safe_load()/safe_store() macrosViller Hsiao
Due to name collision in ftrace safe_load and safe_store macros, these macros cannot take expressions as operands. For example, compiler will complain for a macro call like the following: safe_store_code(new_code2, ip + 4, faulted); arch/mips/include/asm/ftrace.h:61:6: note: in definition of macro 'safe_store' : [dst] "r" (dst), [src] "r" (src)\ ^ arch/mips/kernel/ftrace.c:118:2: note: in expansion of macro 'safe_store_code' safe_store_code(new_code2, ip + 4, faulted); ^ arch/mips/kernel/ftrace.c:118:32: error: undefined named operand 'ip + 4' safe_store_code(new_code2, ip + 4, faulted); ^ arch/mips/include/asm/ftrace.h:61:6: note: in definition of macro 'safe_store' : [dst] "r" (dst), [src] "r" (src)\ ^ arch/mips/kernel/ftrace.c:118:2: note: in expansion of macro 'safe_store_code' safe_store_code(new_code2, ip + 4, faulted); ^ This build error is triggered by a4671094 [MIPS: ftrace: Fix icache flush range error]. Tweak variable naming in those macros to allow flexible operands. Signed-off-by: Viller Hsiao <villerhsiao@gmail.com> Cc: linux-mips@linux-mips.org Cc: rostedt@goodmis.org Cc: fweisbec@gmail.com Cc: mingo@redhat.com Cc: Qais.Yousef@imgtec.com Patchwork: https://patchwork.linux-mips.org/patch/6622/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-03-20Merge tag 'drm-intel-fixes-2014-03-19' of ↵Dave Airlie
git://anongit.freedesktop.org/drm-intel into drm-fixes two more fixes, both regressions. * tag 'drm-intel-fixes-2014-03-19' of git://anongit.freedesktop.org/drm-intel: drm/i915: Disable stolen memory when DMAR is active Revert "drm/i915: don't touch the VDD when disabling the panel"
2014-03-19via-rhine: Disable device in error pathRoger Luethi
Currently, via-rhine fails to call pci_disable_device() for errors in rhine_init_one(). Reported-by: Huqiu Liu <liuhq11@mails.tsinghua.edu.cn> Signed-off-by: Roger Luethi <rl@hellgate.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-19Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer fix from Thomas Gleixner: "A single bugfix: make the scheduler clock on Vybrid SoCs count forward" * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: clocksource: vf_pit_timer: use complement for sched_clock reading
2014-03-19ALSA: compress: Pass through return value of open ops callbackCharles Keepax
The snd_compr_open function would always return 0 even if the compressed ops open function failed, obviously this is incorrect. Looks like this was introduced by a small typo in: commit a0830dbd4e42b38aefdf3fb61ba5019a1a99ea85 ALSA: Add a reference counter to card instance This patch returns the value from the compressed op as it should. Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Acked-by: Vinod Koul <vinod.koul@intel.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-03-19MIPS: BCM47XX: Check all (32) GPIOs when looking for a pinRafał Miłecki
Broadcom boards support 32 GPIOs and NVRAM may have entires for higher ones too. Example: gpio23=wombo_reset Signed-off-by: Rafa? Mi?ecki <zajec5@gmail.com> Acked-by: Hauke Mehrtens <hauke@hauke-m.de> Cc: linux-mips@linux-mips.org Cc: Rafał Miłecki <zajec5@gmail.com> Patchwork: https://patchwork.linux-mips.org/patch/6547/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-03-19drm/i915: Disable stolen memory when DMAR is activeChris Wilson
We have reports of heavy screen corruption if we try to use the stolen memory reserved by the BIOS whilst the DMA-Remapper is active. This quirk may be only specific to a few machines or BIOSes, but first lets apply the big hammer and always disable use of stolen memory when DMAR is active. v2 by Jani: Rebase on -fixes, only look at intel_iommu_gfx_mapped. Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=68535 Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: stable@vger.kernel.org Signed-off-by: Jani Nikula <jani.nikula@intel.com>
2014-03-19Revert "drm/i915: don't touch the VDD when disabling the panel"Jani Nikula
This reverts commit dff392dbd258381a6c3164f38420593f2d291e3b Author: Paulo Zanoni <paulo.r.zanoni@intel.com> Date: Fri Dec 6 17:32:41 2013 -0200 drm/i915: don't touch the VDD when disabling the panel which didn't take into account commit 6cb49835da0426f69a2931bc2a0a8156344b0e41 Author: Daniel Vetter <daniel.vetter@ffwll.ch> Date: Sun May 20 17:14:50 2012 +0200 drm/i915: enable vdd when switching off the eDP panel and commit 35a38556d900b9cb5dfa2529c93944b847f8a8a4 Author: Daniel Vetter <daniel.vetter@ffwll.ch> Date: Sun Aug 12 22:17:14 2012 +0200 drm/i915: reorder edp disabling to fix ivb MacBook Air Unsurprisingly, various MacBooks failed. Effectively the same has already been done in drm-intel-next-queued. Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=74628 Tested-by: Patrik Jakobsson <patrik.r.jakobsson@gmail.com> Cc: Paulo Zanoni <paulo.r.zanoni@intel.com> Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Jani Nikula <jani.nikula@intel.com>
2014-03-18cgroup: fix a failure path in create_css()Li Zefan
If online_css() fails, we should remove cgroup files belonging to css->ss. Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-03-18Revert "[PATCH] Insert GART region into resource map"Bjorn Helgaas
This reverts commit 56dd669a138c, which makes the GART visible in /proc/iomem. This fixes a regression: e501b3d87f00 ("agp: Support 64-bit APBASE") exposed an existing problem with a conflict between the GART region and a PCI BAR region. The GART addresses are bus addresses, not CPU addresses, and therefore should not be inserted in iomem_resource. On many machines, the GART region is addressable by the CPU as well as by an AGP master, but CPU addressability is not required by the spec. On some of these machines, the GART is mapped by a PCI BAR, and in that case, the PCI core automatically inserts it into iomem_resource, just as it does for all BARs. Inserting it here means we'll have a conflict if the PCI core later tries to claim the GART region, so let's drop the insertion here. The conflict indirectly causes X failures, as reported by Jouni in the bugzilla below. We detected the conflict even before e501b3d87f00, but after it the AGP code (fix_northbridge()) uses the PCI resource (which is zeroed because of the conflict) instead of reading the BAR again. Conflicts: arch/x86_64/kernel/aperture.c Fixes: e501b3d87f00 agp: Support 64-bit APBASE Link: https://bugzilla.kernel.org/show_bug.cgi?id=72201 Reported-and-tested-by: Jouni Mettälä <jtmettala@gmail.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
