2014-03-30Linux 3.14v3.14Linus Torvalds
2014-03-30Merge branch 'for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs fixes from Al Viro: "Switch mnt_hash to hlist, turning the races between __lookup_mnt() and hash modifications into false negatives from __lookup_mnt() (instead of hangs)" On the false negatives from __lookup_mnt(): "The *only* thing we care about is not getting stuck in __lookup_mnt(). If it misses an entry because something in front of it just got moved around, etc, we are fine. We'll notice that mount_lock mismatch and that'll be it" * 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: switch mnt_hash to hlist don't bother with propagate_mnt() unless the target is shared keep shadowed vfsmounts together resizable namespace.c hashes
2014-03-30MAINTAINERS: resume as Documentation maintainerRandy Dunlap
I am the new kernel tree Documentation maintainer (except for parts that are handled by other people, of course). Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Acked-by: Rob Landley <rob@landley.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input updates from Dmitry Torokhov: "Some more updates for the input subsystem. You will get a fix for race in mousedev that has been causing quite a few oopses lately and a small fixup for force feedback support in evdev" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: mousedev - fix race when creating mixed device Input: don't modify the id of ioctl-provided ff effect on upload failure
2014-03-30AUDIT: Allow login in non-init namespacesEric Paris
It its possible to configure your PAM stack to refuse login if audit messages (about the login) were unable to be sent. This is common in many distros and thus normal configuration of many containers. The PAM modules determine if audit is enabled/disabled in the kernel based on the return value from sending an audit message on the netlink socket. If userspace gets back ECONNREFUSED it believes audit is disabled in the kernel. If it gets any other error else it refuses to let the login proceed. Just about ever since the introduction of namespaces the kernel audit subsystem has returned EPERM if the task sending a message was not in the init user or pid namespace. So many forms of containers have never worked if audit was enabled in the kernel. BUT if the container was not in net_init then the kernel network code would send ECONNREFUSED (instead of the audit code sending EPERM). Thus by pure accident/dumb luck/bug if an admin configured the PAM stack to reject all logins that didn't talk to audit, but then ran the login untility in the non-init_net namespace, it would work!! Clearly this was a bug, but it is a bug some people expected. With the introduction of network namespace support in 3.14-rc1 the two bugs stopped cancelling each other out. Now, containers in the non-init_net namespace refused to let users log in (just like PAM was configfured!) Obviously some people were not happy that what used to let users log in, now didn't! This fix is kinda hacky. We return ECONNREFUSED for all non-init relevant namespaces. That means that not only will the old broken non-init_net setups continue to work, now the broken non-init_pid or non-init_user setups will 'work'. They don't really work, since audit isn't logging things. But it's what most users want. In 3.15 we should have patches to support not only the non-init_net (3.14) namespace but also the non-init_pid and non-init_user namespace. So all will be right in the world. This just opens the doors wide open on 3.14 and hopefully makes users happy, if not the audit system... Reported-by: Andre Tomt <andre@tomt.net> Reported-by: Adam Richter <adam_richter2004@yahoo.com> Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-30ext4: atomically set inode->i_flags in ext4_set_inode_flags()Theodore Ts'o
Use cmpxchg() to atomically set i_flags instead of clearing out the S_IMMUTABLE, S_APPEND, etc. flags and then setting them from the EXT4_IMMUTABLE_FL, EXT4_APPEND_FL flags, since this opens up a race where an immutable file has the immutable flag cleared for a brief window of time. Reported-by: John Sullivan <jsrhbz@kanargh.force9.co.uk> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-30switch mnt_hash to hlistAl Viro
fixes RCU bug - walking through hlist is safe in face of element moves, since it's self-terminating. Cyclic lists are not - if we end up jumping to another hash chain, we'll loop infinitely without ever hitting the original list head. [fix for dumb braino folded] Spotted by: Max Kellermann <mk@cm4all.com> Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-03-30don't bother with propagate_mnt() unless the target is sharedAl Viro
If the dest_mnt is not shared, propagate_mnt() does nothing - there's no mounts to propagate to and thus no copies to create. Might as well don't bother calling it in that case. Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-03-30keep shadowed vfsmounts togetherAl Viro
preparation to switching mnt_hash to hlist Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-03-30resizable namespace.c hashesAl Viro
* switch allocation to alloc_large_system_hash() * make sizes overridable by boot parameters (mhash_entries=, mphash_entries=) * switch mountpoint_hashtable from list_head to hlist_head Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-03-29Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer fix from Ingo Molnar: "A late breaking fix from John. (The bug fixed has a hard lockup potential, but that was not observed, warnings were)" * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: time: Revert to calling clock_was_set_delayed() while in irq context
2014-03-29Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client Pull Ceph fix from Sage Weil: "This drops a bad assert that a few users have been hitting but we've only recently been able to track down" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: rbd: drop an unsafe assertion
2014-03-29Input: mousedev - fix race when creating mixed deviceDmitry Torokhov
We should not be using static variable mousedev_mix in methods that can be called before that singleton gets assigned. While at it let's add open and close methods to mousedev structure so that we do not need to test if we are dealing with multiplexor or normal device and simply call appropriate method directly. This fixes: https://bugzilla.kernel.org/show_bug.cgi?id=71551 Reported-by: GiulioDP <depasquale.giulio@gmail.com> Tested-by: GiulioDP <depasquale.giulio@gmail.com> Cc: stable@vger.kernel.org Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-03-29Input: don't modify the id of ioctl-provided ff effect on upload failureElias Vanderstuyft
If a new (id == -1) ff effect was uploaded from userspace, ff-core.c::input_ff_upload() will have assigned a positive number to the new effect id. Currently, evdev.c::evdev_do_ioctl() will save this new id to userspace, regardless of whether the upload succeeded or not. On upload failure, this can be confusing because the dev->ff->effects[] array will not contain an element at the index of that new effect id. This patch fixes this by leaving the id unchanged after upload fails. Note: Unfortunately applications should still expect changed effect id for quite some time. This has been discussed on: http://www.mail-archive.com/linux-input@vger.kernel.org/msg08513.html ("ff-core effect id handling in case of a failed effect upload") Suggested-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Elias Vanderstuyft <elias.vds@gmail.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-03-29rbd: drop an unsafe assertionAlex Elder
Olivier Bonvalet reported having repeated crashes due to a failed assertion he was hitting in rbd_img_obj_callback(): Assertion failure in rbd_img_obj_callback() at line 2165: rbd_assert(which >= img_request->next_completion); With a lot of help from Olivier with reproducing the problem we were able to determine the object and image requests had already been completed (and often freed) at the point the assertion failed. There was a great deal of discussion on the ceph-devel mailing list about this. The problem only arose when there were two (or more) object requests in an image request, and the problem was always seen when the second request was being completed. The problem is due to a race in the window between setting the "done" flag on an object request and checking the image request's next completion value. When the first object request completes, it checks to see if its successor request is marked "done", and if so, that request is also completed. In the process, the image request's next_completion value is updated to reflect that both the first and second requests are completed. By the time the second request is able to check the next_completion value, it has been set to a value *greater* than its own "which" value, which caused an assertion to fail. Fix this problem by skipping over any completion processing unless the completing object request is the next one expected. Test only for inequality (not >=), and eliminate the bad assertion. Tested-by: Olivier Bonvalet <ob@daevel.fr> Signed-off-by: Alex Elder <elder@linaro.org> Reviewed-by: Sage Weil <sage@inktank.com> Reviewed-by: Ilya Dryomov <ilya.dryomov@inktank.com>
2014-03-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) We've discovered a common error in several networking drivers, they put VLAN offload features into ->vlan_features, which would suggest that they support offloading 2 or more levels of VLAN encapsulation. Not only do these devices not do that, but we don't have the infrastructure yet to handle that at all. Fixes from Vlad Yasevich. 2) Fix tcpdump crash with bridging and vlans, also from Vlad. 3) Some MAINTAINERS updates for random32 and bonding. 4) Fix late reseeds of prandom generator, from Sasha Levin. 5) Bridge doesn't handle stacked vlans properly, fix from Toshiaki Makita. 6) Fix deadlock in openvswitch, from Flavio Leitner. 7) get_timewait4_sock() doesn't report delay times correctly, fix from Eric Dumazet. 8) Duplicate address detection and addrconf verification need to run in contexts where RTNL can be obtained. Move them to run from a workqueue. From Hannes Frederic Sowa. 9) Fix route refcount leaking in ip tunnels, from Pravin B Shelar. 10) Don't return -EINTR from non-blocking recvmsg() on AF_UNIX sockets, from Eric Dumazet. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (28 commits) vlan: Warn the user if lowerdev has bad vlan features. veth: Turn off vlan rx acceleration in vlan_features ifb: Remove vlan acceleration from vlan_features qlge: Do not propaged vlan tag offloads to vlans bridge: Fix crash with vlan filtering and tcpdump net: Account for all vlan headers in skb_mac_gso_segment MAINTAINERS: bonding: change email address MAINTAINERS: bonding: change email address ipv6: move DAD and addrconf_verify processing to workqueue tcp: fix get_timewait4_sock() delay computation on 64bit openvswitch: fix a possible deadlock and lockdep warning bridge: Fix handling stacked vlan tags bridge: Fix inabillity to retrieve vlan tags when tx offload is disabled vhost: validate vhost_get_vq_desc return value vhost: fix total length when packets are too short random32: avoid attempt to late reseed if in the middle of seeding random32: assign to network folks in MAINTAINERS net/mlx4_core: pass pci_device_id.driver_data to __mlx4_init_one during reset core, nfqueue, openvswitch: Orphan frags in skb_zerocopy and handle errors vlan: Set hard_header_len according to available acceleration ...
2014-03-28Merge branch 'vlan_offloads'David S. Miller
Vlad Yasevich says: ==================== Audit all drivers for correct vlan_features. Some drivers set vlan acceleration features in vlan_features. This causes issues with Q-in-Q/802.1ad configurations. Audit all the drivers for correct vlan_features. Fix broken ones. Add a warning to vlan code to help catch future offenders. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-28vlan: Warn the user if lowerdev has bad vlan features.Vlad Yasevich
Some drivers incorrectly assign vlan acceleration features to vlan_features thus causing issues for Q-in-Q vlan configurations. Warn the user of such cases. Signed-off-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-28veth: Turn off vlan rx acceleration in vlan_featuresVlad Yasevich
For completeness, turn off vlan rx acceleration in vlan_features so that it doesn't show up on q-in-q setups. Signed-off-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-28ifb: Remove vlan acceleration from vlan_featuresVlad Yasevich
Do not include vlan acceleration features in vlan_features as that precludes correct Q-in-Q operation. Signed-off-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-28qlge: Do not propaged vlan tag offloads to vlansVlad Yasevich
qlge driver turns off NETIF_F_HW_CTAG_FILTER, but forgets to turn off HW_CTAG_TX and HW_CTAG_RX on vlan devices. With the current settings, q-in-q will only generate a single vlan header. Remember to mask off CTAG_TX and CTAG_RX features in vlan_features. CC: Shahed Shaikh <shahed.shaikh@qlogic.com> CC: Jitendra Kalsaria <jitendra.kalsaria@qlogic.com> CC: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: Vlad Yasevich <vyasevic@redhat.com> Acked-by: Jitendra Kalsaria <jitendra.kalsaria@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-28bridge: Fix crash with vlan filtering and tcpdumpVlad Yasevich
When the vlan filtering is enabled on the bridge, but the filter is not configured on the bridge device itself, running tcpdump on the bridge device will result in a an Oops with NULL pointer dereference. The reason is that br_pass_frame_up() will bypass the vlan check because promisc flag is set. It will then try to get the table pointer and process the packet based on the table. Since the table pointer is NULL, we oops. Catch this special condition in br_handle_vlan(). Reported-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> CC: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Signed-off-by: Vlad Yasevich <vyasevic@redhat.com> Acked-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-28net: Account for all vlan headers in skb_mac_gso_segmentVlad Yasevich
skb_network_protocol() already accounts for multiple vlan headers that may be present in the skb. However, skb_mac_gso_segment() doesn't know anything about it and assumes that skb->mac_len is set correctly to skip all mac headers. That may not always be the case. If we are simply forwarding the packet (via bridge or macvtap), all vlan headers may not be accounted for. A simple solution is to allow skb_network_protocol to return the vlan depth it has calculated. This way skb_mac_gso_segment will correctly skip all mac headers. Signed-off-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-28MAINTAINERS: bonding: change email addressVeaceslav Falico
Signed-off-by: Veaceslav Falico <vfalico@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-28MAINTAINERS: bonding: change email addressJay Vosburgh
Update my email address. Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-28Merge branch 'akpm' (patches from Andrew Morton)Linus Torvalds
Merge two fixes from Andrew Morton: "The x86 fix should come from x86 guys but they appear to be conferencing or otherwise distracted. The ocfs2 fix is a bit of a mess - the code runs into an immediate NULL deref and we're trying to work out how this got through test and review, but we haven't heard from Goldwyn in the past few days. Sasha's patch fixes the oops, but the feature as a whole is probably broken. So this is a stopgap for 3.14 - I'll aim to get the real fixes into 3.14.x" * emailed patches from Andrew Morton akpm@linux-foundation.org>: x86: fix boot on uniprocessor systems ocfs2: check if cluster name exists before deref
2014-03-28x86: fix boot on uniprocessor systemsArtem Fetishev
On x86 uniprocessor systems topology_physical_package_id() returns -1 which causes rapl_cpu_prepare() to leave rapl_pmu variable uninitialized which leads to GPF in rapl_pmu_init(). See arch/x86/kernel/cpu/perf_event_intel_rapl.c. It turns out that physical_package_id and core_id can actually be retreived for uniprocessor systems too. Enabling them also fixes rapl_pmu code. Signed-off-by: Artem Fetishev <artem_fetishev@epam.com> Cc: Stephane Eranian <eranian@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-28ocfs2: check if cluster name exists before derefSasha Levin
Commit c74a3bdd9b52 ("ocfs2: add clustername to cluster connection") is trying to strlcpy a string which was explicitly passed as NULL in the very same patch, triggering a NULL ptr deref. BUG: unable to handle kernel NULL pointer dereference at (null) IP: strlcpy (lib/string.c:388 lib/string.c:151) CPU: 19 PID: 19426 Comm: trinity-c19 Tainted: G W 3.14.0-rc7-next-20140325-sasha-00014-g9476368-dirty #274 RIP: strlcpy (lib/string.c:388 lib/string.c:151) Call Trace: ocfs2_cluster_connect (fs/ocfs2/stackglue.c:350) ocfs2_cluster_connect_agnostic (fs/ocfs2/stackglue.c:396) user_dlm_register (fs/ocfs2/dlmfs/userdlm.c:679) dlmfs_mkdir (fs/ocfs2/dlmfs/dlmfs.c:503) vfs_mkdir (fs/namei.c:3467) SyS_mkdirat (fs/namei.c:3488 fs/namei.c:3472) tracesys (arch/x86/kernel/entry_64.S:749) akpm: this patch probably disables the feature. A temporary thing to avoid triviel oopses. Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Goldwyn Rodrigues <rgoldwyn@suse.com> Cc: Mark Fasheh <mfasheh@suse.de> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-28ipv6: move DAD and addrconf_verify processing to workqueueHannes Frederic Sowa
addrconf_join_solict and addrconf_join_anycast may cause actions which need rtnl locked, especially on first address creation. A new DAD state is introduced which defers processing of the initial DAD processing into a workqueue. To get rtnl lock we need to push the code paths which depend on those calls up to workqueues, specifically addrconf_verify and the DAD processing. (v2) addrconf_dad_failure needs to be queued up to the workqueue, too. This patch introduces a new DAD state and stop the DAD processing in the workqueue (this is because of the possible ipv6_del_addr processing which removes the solicited multicast address from the device). addrconf_verify_lock is removed, too. After the transition it is not needed any more. As we are not processing in bottom half anymore we need to be a bit more careful about disabling bottom half out when we lock spin_locks which are also used in bh. Relevant backtrace: [ 541.030090] RTNL: assertion failed at net/core/dev.c (4496) [ 541.031143] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G O 3.10.33-1-amd64-vyatta #1 [ 541.031145] Hardware name: Bochs Bochs, BIOS Bochs 01/01/2007 [ 541.031146] ffffffff8148a9f0 000000000000002f ffffffff813c98c1 ffff88007c4451f8 [ 541.031148] 0000000000000000 0000000000000000 ffffffff813d3540 ffff88007fc03d18 [ 541.031150] 0000880000000006 ffff88007c445000 ffffffffa0194160 0000000000000000 [ 541.031152] Call Trace: [ 541.031153] <IRQ> [<ffffffff8148a9f0>] ? dump_stack+0xd/0x17 [ 541.031180] [<ffffffff813c98c1>] ? __dev_set_promiscuity+0x101/0x180 [ 541.031183] [<ffffffff813d3540>] ? __hw_addr_create_ex+0x60/0xc0 [ 541.031185] [<ffffffff813cfe1a>] ? __dev_set_rx_mode+0xaa/0xc0 [ 541.031189] [<ffffffff813d3a81>] ? __dev_mc_add+0x61/0x90 [ 541.031198] [<ffffffffa01dcf9c>] ? igmp6_group_added+0xfc/0x1a0 [ipv6] [ 541.031208] [<ffffffff8111237b>] ? kmem_cache_alloc+0xcb/0xd0 [ 541.031212] [<ffffffffa01ddcd7>] ? ipv6_dev_mc_inc+0x267/0x300 [ipv6] [ 541.031216] [<ffffffffa01c2fae>] ? addrconf_join_solict+0x2e/0x40 [ipv6] [ 541.031219] [<ffffffffa01ba2e9>] ? ipv6_dev_ac_inc+0x159/0x1f0 [ipv6] [ 541.031223] [<ffffffffa01c0772>] ? addrconf_join_anycast+0x92/0xa0 [ipv6] [ 541.031226] [<ffffffffa01c311e>] ? __ipv6_ifa_notify+0x11e/0x1e0 [ipv6] [ 541.031229] [<ffffffffa01c3213>] ? ipv6_ifa_notify+0x33/0x50 [ipv6] [ 541.031233] [<ffffffffa01c36c8>] ? addrconf_dad_completed+0x28/0x100 [ipv6] [ 541.031241] [<ffffffff81075c1d>] ? task_cputime+0x2d/0x50 [ 541.031244] [<ffffffffa01c38d6>] ? addrconf_dad_timer+0x136/0x150 [ipv6] [ 541.031247] [<ffffffffa01c37a0>] ? addrconf_dad_completed+0x100/0x100 [ipv6] [ 541.031255] [<ffffffff8105313a>] ? call_timer_fn.isra.22+0x2a/0x90 [ 541.031258] [<ffffffffa01c37a0>] ? addrconf_dad_completed+0x100/0x100 [ipv6] Hunks and backtrace stolen from a patch by Stephen Hemminger. Reported-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-28tcp: fix get_timewait4_sock() delay computation on 64bitEric Dumazet
It seems I missed one change in get_timewait4_sock() to compute the remaining time before deletion of IPV4 timewait socket. This could result in wrong output in /proc/net/tcp for tm->when field. Fixes: 96f817fedec4 ("tcp: shrink tcp6_timewait_sock by one cache line") Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-28openvswitch: fix a possible deadlock and lockdep warningFlavio Leitner
There are two problematic situations. A deadlock can happen when is_percpu is false because it can get interrupted while holding the spinlock. Then it executes ovs_flow_stats_update() in softirq context which tries to get the same lock. The second sitation is that when is_percpu is true, the code correctly disables BH but only for the local CPU, so the following can happen when locking the remote CPU without disabling BH: CPU#0 CPU#1 ovs_flow_stats_get() stats_read() +->spin_lock remote CPU#1 ovs_flow_stats_get() | <interrupted> stats_read() | ... +--> spin_lock remote CPU#0 | | <interrupted> | ovs_flow_stats_update() | ... | spin_lock local CPU#0 <--+ ovs_flow_stats_update() +---------------------------------- spin_lock local CPU#1 This patch disables BH for both cases fixing the deadlocks. Acked-by: Jesse Gross <jesse@nicira.com> ================================= [ INFO: inconsistent lock state ] 3.14.0-rc8-00007-g632b06a #1 Tainted: G I --------------------------------- inconsistent {SOFTIRQ-ON-W} -> {IN-SOFTIRQ-W} usage. swapper/0/0 [HC0[0]:SC1[5]:HE1:SE0] takes: (&(&cpu_stats->lock)->rlock){+.?...}, at: [<ffffffffa05dd8a1>] ovs_flow_stats_update+0x51/0xd0 [openvswitch] {SOFTIRQ-ON-W} state was registered at: [<ffffffff810f973f>] __lock_acquire+0x68f/0x1c40 [<ffffffff810fb4e2>] lock_acquire+0xa2/0x1d0 [<ffffffff817d8d9e>] _raw_spin_lock+0x3e/0x80 [<ffffffffa05dd9e4>] ovs_flow_stats_get+0xc4/0x1e0 [openvswitch] [<ffffffffa05da855>] ovs_flow_cmd_fill_info+0x185/0x360 [openvswitch] [<ffffffffa05daf05>] ovs_flow_cmd_build_info.constprop.27+0x55/0x90 [openvswitch] [<ffffffffa05db41d>] ovs_flow_cmd_new_or_set+0x4dd/0x570 [openvswitch] [<ffffffff816c245d>] genl_family_rcv_msg+0x1cd/0x3f0 [<ffffffff816c270e>] genl_rcv_msg+0x8e/0xd0 [<ffffffff816c0239>] netlink_rcv_skb+0xa9/0xc0 [<ffffffff816c0798>] genl_rcv+0x28/0x40 [<ffffffff816bf830>] netlink_unicast+0x100/0x1e0 [<ffffffff816bfc57>] netlink_sendmsg+0x347/0x770 [<ffffffff81668e9c>] sock_sendmsg+0x9c/0xe0 [<ffffffff816692d9>] ___sys_sendmsg+0x3a9/0x3c0 [<ffffffff8166a911>] __sys_sendmsg+0x51/0x90 [<ffffffff8166a962>] SyS_sendmsg+0x12/0x20 [<ffffffff817e3ce9>] system_call_fastpath+0x16/0x1b irq event stamp: 1740726 hardirqs last enabled at (1740726): [<ffffffff8175d5e0>] ip6_finish_output2+0x4f0/0x840 hardirqs last disabled at (1740725): [<ffffffff8175d59b>] ip6_finish_output2+0x4ab/0x840 softirqs last enabled at (1740674): [<ffffffff8109be12>] _local_bh_enable+0x22/0x50 softirqs last disabled at (1740675): [<ffffffff8109db05>] irq_exit+0xc5/0xd0 other info that might help us debug this: Possible unsafe locking scenario: CPU0 ---- lock(&(&cpu_stats->lock)->rlock); <Interrupt> lock(&(&cpu_stats->lock)->rlock); *** DEADLOCK *** 5 locks held by swapper/0/0: #0: (((&ifa->dad_timer))){+.-...}, at: [<ffffffff810a7155>] call_timer_fn+0x5/0x320 #1: (rcu_read_lock){.+.+..}, at: [<ffffffff81788a55>] mld_sendpack+0x5/0x4a0 #2: (rcu_read_lock_bh){.+....}, at: [<ffffffff8175d149>] ip6_finish_output2+0x59/0x840 #3: (rcu_read_lock_bh){.+....}, at: [<ffffffff8168ba75>] __dev_queue_xmit+0x5/0x9b0 #4: (rcu_read_lock){.+.+..}, at: [<ffffffffa05e41b5>] internal_dev_xmit+0x5/0x110 [openvswitch] stack backtrace: CPU: 0 PID: 0 Comm: swapper/0 Tainted: G I 3.14.0-rc8-00007-g632b06a #1 Hardware name: /DX58SO, BIOS SOX5810J.86A.5599.2012.0529.2218 05/29/2012 0000000000000000 0fcf20709903df0c ffff88042d603808 ffffffff817cfe3c ffffffff81c134c0 ffff88042d603858 ffffffff817cb6da 0000000000000005 ffffffff00000001 ffff880400000000 0000000000000006 ffffffff81c134c0 Call Trace: <IRQ> [<ffffffff817cfe3c>] dump_stack+0x4d/0x66 [<ffffffff817cb6da>] print_usage_bug+0x1f4/0x205 [<ffffffff810f7f10>] ? check_usage_backwards+0x180/0x180 [<ffffffff810f8963>] mark_lock+0x223/0x2b0 [<ffffffff810f96d3>] __lock_acquire+0x623/0x1c40 [<ffffffff810f5707>] ? __lock_is_held+0x57/0x80 [<ffffffffa05e26c6>] ? masked_flow_lookup+0x236/0x250 [openvswitch] [<ffffffff810fb4e2>] lock_acquire+0xa2/0x1d0 [<ffffffffa05dd8a1>] ? ovs_flow_stats_update+0x51/0xd0 [openvswitch] [<ffffffff817d8d9e>] _raw_spin_lock+0x3e/0x80 [<ffffffffa05dd8a1>] ? ovs_flow_stats_update+0x51/0xd0 [openvswitch] [<ffffffffa05dd8a1>] ovs_flow_stats_update+0x51/0xd0 [openvswitch] [<ffffffffa05dcc64>] ovs_dp_process_received_packet+0x84/0x120 [openvswitch] [<ffffffff810f93f7>] ? __lock_acquire+0x347/0x1c40 [<ffffffffa05e3bea>] ovs_vport_receive+0x2a/0x30 [openvswitch] [<ffffffffa05e4218>] internal_dev_xmit+0x68/0x110 [openvswitch] [<ffffffffa05e41b5>] ? internal_dev_xmit+0x5/0x110 [openvswitch] [<ffffffff8168b4a6>] dev_hard_start_xmit+0x2e6/0x8b0 [<ffffffff8168be87>] __dev_queue_xmit+0x417/0x9b0 [<ffffffff8168ba75>] ? __dev_queue_xmit+0x5/0x9b0 [<ffffffff8175d5e0>] ? ip6_finish_output2+0x4f0/0x840 [<ffffffff8168c430>] dev_queue_xmit+0x10/0x20 [<ffffffff8175d641>] ip6_finish_output2+0x551/0x840 [<ffffffff8176128a>] ? ip6_finish_output+0x9a/0x220 [<ffffffff8176128a>] ip6_finish_output+0x9a/0x220 [<ffffffff8176145f>] ip6_output+0x4f/0x1f0 [<ffffffff81788c29>] mld_sendpack+0x1d9/0x4a0 [<ffffffff817895b8>] mld_send_initial_cr.part.32+0x88/0xa0 [<ffffffff817691b0>] ? addrconf_dad_completed+0x220/0x220 [<ffffffff8178e301>] ipv6_mc_dad_complete+0x31/0x50 [<ffffffff817690d7>] addrconf_dad_completed+0x147/0x220 [<ffffffff817691b0>] ? addrconf_dad_completed+0x220/0x220 [<ffffffff8176934f>] addrconf_dad_timer+0x19f/0x1c0 [<ffffffff810a71e9>] call_timer_fn+0x99/0x320 [<ffffffff810a7155>] ? call_timer_fn+0x5/0x320 [<ffffffff817691b0>] ? addrconf_dad_completed+0x220/0x220 [<ffffffff810a76c4>] run_timer_softirq+0x254/0x3b0 [<ffffffff8109d47d>] __do_softirq+0x12d/0x480 Signed-off-by: Flavio Leitner <fbl@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-28bridge: Fix handling stacked vlan tagsToshiaki Makita
If a bridge with vlan_filtering enabled receives frames with stacked vlan tags, i.e., they have two vlan tags, br_vlan_untag() strips not only the outer tag but also the inner tag. br_vlan_untag() is called only from br_handle_vlan(), and in this case, it is enough to set skb->vlan_tci to 0 here, because vlan_tci has already been set before calling br_handle_vlan(). Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Acked-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-28bridge: Fix inabillity to retrieve vlan tags when tx offload is disabledToshiaki Makita
Bridge vlan code (br_vlan_get_tag()) assumes that all frames have vlan_tci if they are tagged, but if vlan tx offload is manually disabled on bridge device and frames are sent from vlan device on the bridge device, the tags are embedded in skb->data and they break this assumption. Extract embedded vlan tags and move them to vlan_tci at ingress. Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp> Acked-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-28vhost: validate vhost_get_vq_desc return valueMichael S. Tsirkin
vhost fails to validate negative error code from vhost_get_vq_desc causing a crash: we are using -EFAULT which is 0xfffffff2 as vector size, which exceeds the allocated size. The code in question was introduced in commit 8dd014adfea6f173c1ef6378f7e5e7924866c923 vhost-net: mergeable buffers support CVE-2014-0055 Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-28vhost: fix total length when packets are too shortMichael S. Tsirkin
When mergeable buffers are disabled, and the incoming packet is too large for the rx buffer, get_rx_bufs returns success. This was intentional in order for make recvmsg truncate the packet and then handle_rx would detect err != sock_len and drop it. Unfortunately we pass the original sock_len to recvmsg - which means we use parts of iov not fully validated. Fix this up by detecting this overrun and doing packet drop immediately. CVE-2014-0077 Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-28random32: avoid attempt to late reseed if in the middle of seedingSasha Levin
Commit 4af712e8df ("random32: add prandom_reseed_late() and call when nonblocking pool becomes initialized") has added a late reseed stage that happens as soon as the nonblocking pool is marked as initialized. This fails in the case that the nonblocking pool gets initialized during __prandom_reseed()'s call to get_random_bytes(). In that case we'd double back into __prandom_reseed() in an attempt to do a late reseed - deadlocking on 'lock' early on in the boot process. Instead, just avoid even waiting to do a reseed if a reseed is already occuring. Fixes: 4af712e8df99 ("random32: add prandom_reseed_late() and call when nonblocking pool becomes initialized") Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input subsystem fixes from Dmitry Torokhov: "Updates to Synaptics touchpad to better cope with devices in Lenovo laptops, and a couple more fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: synaptics - add manual min/max quirk for ThinkPad X240 Input: synaptics - add manual min/max quirk Input: cypress_ps2 - don't report as a button pads Input: da9052_onkey - use correct register bit for key status Input: adp5588-keys - get value from data out when dir is out
2014-03-28random32: assign to network folks in MAINTAINERSSasha Levin
lib/random32.c was split out of the network code and is de-facto still maintained by the almighty net/ gods. Make it a bit more official so that people who aren't aware of that know where to send their patches. Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-28Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes from Dave Airlie: "I didn't want these to wait for stable cycle. The nouveau and radeon ones are the same problem, where the runtime pm stuff broke non-runtime pm managed secondary GPUs. The udl fix is for an oops on unplug, and the i915 fix is for a regression on Sandybridge even though it may break haswell (regression wins)" Daniel Vetter comments: "My apologies for the i915 regression fumble, that thing somehow fell through the cracks here for almost half a year :( Imo that's more than enough flailing to just go ahead with the revert, and the re-broken hsw should get peoples attention ..." * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: drm/i915: Undo gtt scratch pte unmapping again drm/radeon: fix runtime suspend breaking secondary GPUs drm/nouveau: fail runtime pm properly. drm/udl: take reference to device struct for dma-bufs
2014-03-28Merge branch 'i2c/for-current' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c build fix from Wolfram Sang: "The build fix from my last request unveiled another build problem which is fixed with this patch" * 'i2c/for-current' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: i2c: cpm: Fix build by adding of_address.h and of_irq.h
2014-03-28Merge tag 'stable/for-linus-3.14-rc8-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull Xen bugfixes from David Vrabel: "Fix two bugs that cause x86 PV guest crashes. 1. Ballooning a 32-bit guest would eventually crash it. 2. Revert a broken fix for a regression with NUMA_BALACING. The bad fix caused PV guests to crash after migration. This is not ideal but unpicking the madness that is _PAGE_NUMA == _PAGE_PROTNONE will take a while longer" * tag 'stable/for-linus-3.14-rc8-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: Revert "xen: properly account for _PAGE_NUMA during xen pte translations" xen/balloon: flush persistent kmaps in correct position
2014-03-28Input: synaptics - add manual min/max quirk for ThinkPad X240Hans de Goede
This extends Benjamin Tissoires manual min/max quirk table with support for the ThinkPad X240. Cc: stable@vger.kernel.org Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-03-28Input: synaptics - add manual min/max quirkBenjamin Tissoires
The new Lenovo Haswell series (-40's) contains a new Synaptics touchpad. However, these new Synaptics devices report bad axis ranges. Under Windows, it is not a problem because the Windows driver uses RMI4 over SMBus to talk to the device. Under Linux, we are using the PS/2 fallback interface and it occurs the reported ranges are wrong. Of course, it would be too easy to have only one range for the whole series, each touchpad seems to be calibrated in a different way. We can not use SMBus to get the actual range because I suspect the firmware will switch into the SMBus mode and stop talking through PS/2 (this is the case for hybrid HID over I2C / PS/2 Synaptics touchpads). So as a temporary solution (until RMI4 land into upstream), start a new list of quirks with the min/max manually set. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> CC: stable@vger.kernel.org Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2014-03-28time: Revert to calling clock_was_set_delayed() while in irq contextJohn Stultz
In commit 47a1b796306356f35 ("tick/timekeeping: Call update_wall_time outside the jiffies lock"), we moved to calling clock_was_set() due to the fact that we were no longer holding the timekeeping or jiffies lock. However, there is still the problem that clock_was_set() triggers an IPI, which cannot be done from the timer's hard irq context, and will generate WARN_ON warnings. Apparently in my earlier testing, I'm guessing I didn't bump the dmesg log level, so I somehow missed the WARN_ONs. Thus we need to revert back to calling clock_was_set_delayed(). Signed-off-by: John Stultz <john.stultz@linaro.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/1395963049-11923-1-git-send-email-john.stultz@linaro.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-03-28drm/i915: Undo gtt scratch pte unmapping againDaniel Vetter
It apparently blows up on some machines. This functionally reverts commit 828c79087cec61eaf4c76bb32c222fbe35ac3930 Author: Ben Widawsky <benjamin.widawsky@intel.com> Date: Wed Oct 16 09:21:30 2013 -0700 drm/i915: Disable GGTT PTEs on GEN6+ suspend Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=64841 Reported-and-Tested-by: Brad Jackson <bjackson0971@gmail.com> Cc: stable@vger.kernel.org Cc: Takashi Iwai <tiwai@suse.de> Cc: Paulo Zanoni <paulo.r.zanoni@intel.com> Cc: Todd Previte <tprevite@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-03-28drm/radeon: fix runtime suspend breaking secondary GPUsDave Airlie
Same fix as for nouveau, when we fail with EINVAL, subsequent gets fail hard, causing the device not to open. Signed-off-by: Dave Airlie <airlied@redhat.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
2014-03-27net/mlx4_core: pass pci_device_id.driver_data to __mlx4_init_one during resetWei Yang
The second parameter of __mlx4_init_one() is used to identify whether the pci_dev is a PF or VF. Currently, when it is invoked in mlx4_pci_slot_reset() this information is missed. This patch match the pci_dev with mlx4_pci_table and passes the pci_device_id.driver_data to __mlx4_init_one() in mlx4_pci_slot_reset(). Signed-off-by: Wei Yang <weiyang@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-27core, nfqueue, openvswitch: Orphan frags in skb_zerocopy and handle errorsZoltan Kiss
skb_zerocopy can copy elements of the frags array between skbs, but it doesn't orphan them. Also, it doesn't handle errors, so this patch takes care of that as well, and modify the callers accordingly. skb_tx_error() is also added to the callers so they will signal the failed delivery towards the creator of the skb. Signed-off-by: Zoltan Kiss <zoltan.kiss@citrix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-27vlan: Set hard_header_len according to available accelerationVlad Yasevich
Currently, if the card supports CTAG acceleration we do not account for the vlan header even if we are configuring an 8021AD vlan. This may not be best since we'll do software tagging for 8021AD which will cause data copy on skb head expansion Configure the length based on available hw offload capabilities and vlan protocol. CC: Patrick McHardy <kaber@trash.net> Signed-off-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-27usbnet: include wait queue head in device structureOliver Neukum
This fixes a race which happens by freeing an object on the stack. Quoting Julius: > The issue is > that it calls usbnet_terminate_urbs() before that, which temporarily > installs a waitqueue in dev->wait in order to be able to wait on the > tasklet to run and finish up some queues. The waiting itself looks > okay, but the access to 'dev->wait' is totally unprotected and can > race arbitrarily. I think in this case usbnet_bh() managed to succeed > it's dev->wait check just before usbnet_terminate_urbs() sets it back > to NULL. The latter then finishes and the waitqueue_t structure on its > stack gets overwritten by other functions halfway through the > wake_up() call in usbnet_bh(). The fix is to just not allocate the data structure on the stack. As dev->wait is abused as a flag it also takes a runtime PM change to fix this bug. Signed-off-by: Oliver Neukum <oneukum@suse.de> Reported-by: Grant Grundler <grundler@google.com> Tested-by: Grant Grundler <grundler@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
