2015-02-16Linux 3.12.38v3.12.38Jiri Slaby
2015-02-16iscsi_ibft: Fix finding Broadcom specific ibft signVikas Chaudhary
commit 629c27aa0c930b9c67188cfc625bf6cdd2af6764 upstream. Search for Broadcom specific ibft sign "BIFT" along with other possible values on UEFI This patch is fix for regression introduced in “935a9fee51c945b8942be2d7b4bae069167b4886”. https://lkml.org/lkml/2011/12/16/353 This impacts Broadcom CNA for iSCSI Boot on UEFI platform. Signed-off-by: Vikas Chaudhary <vikas.chaudhary@qlogic.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16ACPI: Fix bug when ACPI reset register is implemented in system memoryRandy Wright
commit a4714a898e85205e1118ec923cde43d88eb105f6 upstream. Use acpi_os_map_generic_address to pre-map the reset register if it is memory mapped, thereby preventing the BUG_ON() in line 1319 of mm/vmalloc.c from triggering during panic-triggered reboots. Link: https://bugzilla.kernel.org/show_bug.cgi?id=77131 Signed-off-by: Randy Wright <rwright@hp.com> Signed-off-by: David E. Box <david.e.box@linux.intel.com> [rjw: Changelog, simplified code] Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16x86: UV BAU: Avoid NULL pointer reference in ptc_seq_showJames Custer
commit fa2a79ce6aef5de35a4d50487da35deb6b634944 upstream. In init_per_cpu(), when get_cpu_topology() fails, init_per_cpu_tunables() is not called afterwards. This means that bau_control->statp is NULL. If a user then reads /proc/sgi_uv/ptc_statistics ptc_seq_show() references a NULL pointer. Therefore, since uv_bau_init calls set_bau_off when init_per_cpu() fails, we add code that detects when the bau is off in ptc_seq_show() to avoid referencing a NULL pointer. Signed-off-by: James Custer <jcuster@sgi.com> Cc: Russ Anderson <rja@sgi.com> Link: http://lkml.kernel.org/r/1414952199-185319-2-git-send-email-jcuster@sgi.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16SELinux: fix selinuxfs policy file on big endian systemsEric Paris
commit b138004ea0382bdc6d02599c39392651b4f63889 upstream. The /sys/fs/selinux/policy file is not valid on big endian systems like ppc64 or s390. Let's see why: static int hashtab_cnt(void *key, void *data, void *ptr) { int *cnt = ptr; *cnt = *cnt + 1; return 0; } static int range_write(struct policydb *p, void *fp) { size_t nel; [...] /* count the number of entries in the hashtab */ nel = 0; rc = hashtab_map(p->range_tr, hashtab_cnt, &nel); if (rc) return rc; buf[0] = cpu_to_le32(nel); rc = put_entry(buf, sizeof(u32), 1, fp); So size_t is 64 bits. But then we pass a pointer to it as we do to hashtab_cnt. hashtab_cnt thinks it is a 32 bit int and only deals with the first 4 bytes. On x86_64 which is little endian, those first 4 bytes and the least significant, so this works out fine. On ppc64/s390 those first 4 bytes of memory are the high order bits. So at the end of the call to hashtab_map nel has a HUGE number. But the least significant 32 bits are all 0's. We then pass that 64 bit number to cpu_to_le32() which happily truncates it to a 32 bit number and does endian swapping. But the low 32 bits are all 0's. So no matter how many entries are in the hashtab, big endian systems always say there are 0 entries because I screwed up the counting. The fix is easy. Use a 32 bit int, as the hashtab_cnt expects, for nel. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16dm: do not call dm_sync_table() when creating new devicesHannes Reinecke
commit 41abc4e1af369bb5438eaee398e3beee690cc8ca upstream. When creating new devices dm_sync_table() calls synchronize_rcu_expedited(), causing _all_ pending RCU pointers to be flushed. This causes a latency overhead that is especially noticeable when creating lots of devices. And all of this is pointless as there are no old maps to be disconnected, and hence no stale pointers which would need to be cleared up. Signed-off-by: Hannes Reinecke <hare@suse.de> Reviewed-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16parport: parport_pc, do not remove parent devices earlyJiri Slaby
commit 91905b6f4afe51e23a3f58df93e4cdc5e49cf40c upstream. When the parport_pc module is removed from the system, all parport devices are iterated in parport_pc_exit and removed by a call to parport_pc_unregister_port. Note that some parport devices have its 'struct device' parent, known as port->dev. And when port->dev is a platform device, it is destroyed in parport_pc_exit too. Now, when parport_pc_unregister_port is called for a going port, drv->detach(port) is called for every parport driver in the system. ppdev can be one of them. ppdev's detach() tears down its per-port sysfs directory, which established port->dev as a parent earlier. But since parport_pc_exit kills port->dev parents before unregisters ports proper, ppdev's sysfs directory has no living parent anymore. This results in the following warning: WARNING: CPU: 1 PID: 785 at fs/sysfs/group.c:219 sysfs_remove_group+0x9b/0xa0 sysfs group ffffffff81c69e20 not found for kobject 'parport1' Modules linked in: parport_pc(E-) ppdev(E) [last unloaded: ppdev] CPU: 1 PID: 785 Comm: rmmod Tainted: G W E 3.18.0-rc5-next-20141120+ #824 ... Call Trace: ... [<ffffffff810aff76>] warn_slowpath_fmt+0x46/0x50 [<ffffffff8123d81b>] sysfs_remove_group+0x9b/0xa0 [<ffffffff814c27e7>] dpm_sysfs_remove+0x57/0x60 [<ffffffff814b6ac9>] device_del+0x49/0x240 [<ffffffff814b6ce2>] device_unregister+0x22/0x70 [<ffffffff814b6dac>] device_destroy+0x3c/0x50 [<ffffffffc012209a>] pp_detach+0x4a/0x60 [ppdev] [<ffffffff814b32dd>] parport_remove_port+0x11d/0x150 [<ffffffffc0137328>] parport_pc_unregister_port+0x28/0xf0 [parport_pc] [<ffffffffc0138c0e>] parport_pc_exit+0x76/0x468 [parport_pc] [<ffffffff81128dbc>] SyS_delete_module+0x18c/0x230 It is also easily reproducible on qemu with two dummy ports '-parallel /dev/null -parallel /dev/null'. So switch the order of killing the two structures. But since port is freed by parport_pc_unregister_port, we have to remember port->dev in a local variable. Perhaps nothing worse than the warning happens thanks to the device refcounting. We *should* be on the safe side. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Reviewed-by: Takashi Iwai <tiwai@suse.de> Tested-by: Martin Pluskal <mpluskal@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16x86/early quirk: use gen6 stolen detection for VLVJesse Barnes
commit 7bd40c16ccb2cb6877dd00b0e66249c171e6fa43 upstream. We've always been able to use either method on VLV, but it appears more recent BIOSes only support the gen6 method, so switch over to that. References: https://bugs.freedesktop.org/show_bug.cgi?id=71370 Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16udf: Check component length before reading itJan Kara
commit e237ec37ec154564f8690c5bd1795339955eeef9 upstream. Check that length specified in a component of a symlink fits in the input buffer we are reading. Also properly ignore component length for component types that do not use it. Otherwise we read memory after end of buffer for corrupted udf image. Reported-by: Carl Henrik Lunde <chlunde@ping.uio.no> CC: stable@vger.kernel.org Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16udf: Check path length when reading symlinkJan Kara
commit 0e5cc9a40ada6046e6bc3bdfcd0c0d7e4b706b14 upstream. Symlink reading code does not check whether the resulting path fits into the page provided by the generic code. This isn't as easy as just checking the symlink size because of various encoding conversions we perform on path. So we have to check whether there is still enough space in the buffer on the fly. CC: stable@vger.kernel.org Reported-by: Carl Henrik Lunde <chlunde@ping.uio.no> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16udf: Verify i_size when loading inodeJan Kara
commit e159332b9af4b04d882dbcfe1bb0117f0a6d4b58 upstream. Verify that inode size is sane when loading inode with data stored in ICB. Otherwise we may get confused later when working with the inode and inode size is too big. CC: stable@vger.kernel.org Reported-by: Carl Henrik Lunde <chlunde@ping.uio.no> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16ocfs2: remove filesize checks for sync I/O journal commitGoldwyn Rodrigues
commit 86b9c6f3f891019b26f8e5bb11a6faa96bba54a8 upstream. Filesize is not a good indication that the file needs to be synced. An example where this breaks is: 1. Open the file in O_SYNC|O_RDWR 2. Read a small portion of the file (say 64 bytes) 3. Lseek to starting of the file 4. Write 64 bytes If the node crashes, it is not written out to disk because this was not committed in the journal and the other node which reads the file after recovery reads stale data (even if the write on the other node was successful) Signed-off-by: Goldwyn Rodrigues <rgoldwyn@suse.de> Reviewed-by: Mark Fasheh <mfasheh@suse.de> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16SUNRPC: Handle EPIPE in xprt_connect_statusTrond Myklebust
commit 2fc193cf924ea6eb74f6a0cf73b94b2e62938ae5 upstream. The callback handler xs_error_report() can end up propagating an EPIPE error by means of the call to xprt_wake_pending_tasks(). Ensure that xprt_connect_status() does not automatically convert this into an EIO error. Reported-by: Weston Andros Adamson <dros@primarydata.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16SUNRPC: Ensure that we handle ENOBUFS errors correctly.Trond Myklebust
commit 3601c4a91ebbbf1cf69f66a2abeffc6c64a4fe64 upstream. Currently, an ENOBUFS error will result in a fatal error for the RPC call. Normally, we will just want to wait and then retry. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16SUNRPC: Ensure call_connect_status() deals correctly with SOFTCONN tasksSteve Dickson
commit 1fa3e2eb9db07f30a605c66d1a2fdde4b24e74d5 upstream. Don't schedule an rpc_delay before checking to see if the task is a SOFTCONN because the tk_callback from the delay (__rpc_atrun) clears the task status before the rpc_exit_task can be run. Signed-off-by: Steve Dickson <steved@redhat.com> Fixes: 561ec1603171c (SUNRPC: call_connect_status should recheck...) Link: http://lkml.kernel.org/r/5329CF7C.7090308@RedHat.com Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16SUNRPC: Ensure that call_connect times out correctlyTrond Myklebust
commit 485f2251782f7c44299c491d4676a8a01428d191 upstream. When the server is unavailable due to a networking error, etc, we want the RPC client to respect the timeout delays when attempting to reconnect. Reported-by: Neil Brown <neilb@suse.de> Fixes: 561ec1603171 (SUNRPC: call_connect_status should recheck bind..) Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16SUNRPC: Handle connect errors ECONNABORTED and EHOSTUNREACHTrond Myklebust
commit df2772700c6ee706be7b2fd16c6bf2c1bf63cda0 upstream. Ensure that call_bind_status, call_connect_status, call_transmit_status and call_status all are capable of handling ECONNABORTED and EHOSTUNREACH. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16SUNRPC: Ensure xprt_connect_status handles all potential connection errorsTrond Myklebust
commit 0fe8d04e8c3a1eb49089793e38b60a17cee564e3 upstream. Currently, xprt_connect_status will convert connection error values such as ECONNREFUSED, ECONNRESET, ... into EIO, which means that they never get handled. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16SUNRPC: call_connect_status should recheck bind and connect status on errorTrond Myklebust
commit 561ec1603171cd9b38dcf6cac53e8710f437a48d upstream. Currently, we go directly to call_transmit which sends us to call_status on error. If we know that the connect attempt failed, we should rather just jump straight back to call_bind and call_connect. Ditto for EAGAIN, except do not delay. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16net, sunrpc: suppress allocation warning in rpc_malloc()David Rientjes
commit c6c8fe79a83e1a03e5dd83d0bac178d6ba5ef30a upstream. rpc_malloc() allocates with GFP_NOWAIT without making any attempt at reclaim so it easily fails when low on memory. This ends up spamming the kernel log: SLAB: Unable to allocate memory on node 0 (gfp=0x4000) cache: kmalloc-8192, object size: 8192, order: 1 node 0: slabs: 207/207, objs: 207/207, free: 0 rekonq: page allocation failure: order:1, mode:0x204000 CPU: 2 PID: 14321 Comm: rekonq Tainted: G O 3.15.0-rc3-12.gfc9498b-desktop+ #6 Hardware name: System manufacturer System Product Name/M4A785TD-V EVO, BIOS 2105 07/23/2010 0000000000000000 ffff880010ff17d0 ffffffff815e693c 0000000000204000 ffff880010ff1858 ffffffff81137bd2 0000000000000000 0000001000000000 ffff88011ffebc38 0000000000000001 0000000000204000 ffff88011ffea000 Call Trace: [<ffffffff815e693c>] dump_stack+0x4d/0x6f [<ffffffff81137bd2>] warn_alloc_failed+0xd2/0x140 [<ffffffff8113be19>] __alloc_pages_nodemask+0x7e9/0xa30 [<ffffffff811824a8>] kmem_getpages+0x58/0x140 [<ffffffff81183de6>] fallback_alloc+0x1d6/0x210 [<ffffffff81183be3>] ____cache_alloc_node+0x123/0x150 [<ffffffff81185953>] __kmalloc+0x203/0x490 [<ffffffffa06b0ee2>] rpc_malloc+0x32/0xa0 [sunrpc] [<ffffffffa06a6999>] call_allocate+0xb9/0x170 [sunrpc] [<ffffffffa06b19d8>] __rpc_execute+0x88/0x460 [sunrpc] [<ffffffffa06b2da9>] rpc_execute+0x59/0xc0 [sunrpc] [<ffffffffa06a932b>] rpc_run_task+0x6b/0x90 [sunrpc] [<ffffffffa077b5c1>] nfs4_call_sync_sequence+0x51/0x80 [nfsv4] [<ffffffffa077d45d>] _nfs4_do_setattr+0x1ed/0x280 [nfsv4] [<ffffffffa0782a72>] nfs4_do_setattr+0x72/0x180 [nfsv4] [<ffffffffa078334c>] nfs4_proc_setattr+0xbc/0x140 [nfsv4] [<ffffffffa074a7e8>] nfs_setattr+0xd8/0x240 [nfs] [<ffffffff811baa71>] notify_change+0x231/0x380 [<ffffffff8119cf5c>] chmod_common+0xfc/0x120 [<ffffffff8119df80>] SyS_chmod+0x40/0x90 [<ffffffff815f4cfd>] system_call_fastpath+0x1a/0x1f ... If the allocation fails, simply return NULL and avoid spamming the kernel log. Reported-by: Marc Dietrich <marvin24@gmx.de> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16ACPI idle: permit sparse C-state sub-state numbersLen Brown
commit 2194324d8bbbad1b179c08b6095649b06abd62d5 upstream. Linux uses CPUID.MWAIT.EDX to validate the C-states reported by ACPI, silently discarding states which are not supported by the HW. This test is too restrictive, as some HW now uses sparse sub-state numbering, so the sub-state number may be higher than the number of sub-states... Also, rather than silently ignoring an invalid state, we should complain about a firmware bug. In practice... Bay Trail systems originally supported C6-no-shrink as MWAIT sub-state 0x58, and in CPUID.MWAIT.EDX 0x03000000 indicated that there were 3 MWAIT-C6 sub-states. So acpi_idle would discard that C-state because 8 >= 3. Upon discovering this issue, the ucode was updated so that C6-no-shrink was also exported as 0x51, and the BIOS was updated to match. However, systems shipped with 0x58, will never get a BIOS update, and this patch allows Linux to see C6-no-shrink on early Bay Trail. Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16ipc/sem.c: change memory barrier in sem_lock() to smp_rmb()Manfred Spraul
commit 2e094abfd1f29a08a60523b42d4508281b8dee0e upstream. When I fixed bugs in the sem_lock() logic, I was more conservative than necessary. Therefore it is safe to replace the smp_mb() with smp_rmb(). And: With smp_rmb(), semop() syscalls are up to 10% faster. The race we must protect against is: sem->lock is free sma->complex_count = 0 sma->sem_perm.lock held by thread B thread A: A: spin_lock(&sem->lock) B: sma->complex_count++; (now 1) B: spin_unlock(&sma->sem_perm.lock); A: spin_is_locked(&sma->sem_perm.lock); A: XXXXX memory barrier A: if (sma->complex_count == 0) Thread A must read the increased complex_count value, i.e. the read must not be reordered with the read of sem_perm.lock done by spin_is_locked(). Since it's about ordering of reads, smp_rmb() is sufficient. [akpm@linux-foundation.org: update sem_lock() comment, from Davidlohr] Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Reviewed-by: Davidlohr Bueso <dave@stgolabs.net> Acked-by: Rafael Aquini <aquini@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16KVM: x86: Sysexit emulation does not mask RIP/RSPNadav Amit
commit bf0b682c9b6a6d6d54adf439bfe953feef7be2e8 upstream. If the operand size is not 64-bit, then the sysexit instruction should assign ECX to RSP and EDX to RIP. The current code assigns the full 64-bits. Fix it by masking. Signed-off-by: Nadav Amit <namit@cs.technion.ac.il> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16KVM: vmx: Inject #GP on invalid PAT CRNadav Amit
commit 4566654bb9be9e8864df417bb72ceee5136b6a6a upstream. Guest which sets the PAT CR to invalid value should get a #GP. Currently, if vmx supports loading PAT CR during entry, then the value is not checked. This patch makes the required check in that case. Signed-off-by: Nadav Amit <namit@cs.technion.ac.il> Signed-off-by: Bruce Rogers <brogers@suse.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16KVM: x86: emulating descriptor load misses long-mode caseNadav Amit
commit 040c8dc8a5afa7364bb8bb5b1b76c30007d6be14 upstream. In 64-bit mode a #GP should be delivered to the guest "if the code segment descriptor pointed to by the selector in the 64-bit gate doesn't have the L-bit set and the D-bit clear." - Intel SDM "Interrupt 13—General Protection Exception (#GP)". This patch fixes the behavior of CS loading emulation code. Although the comment says that segment loading is not supported in long mode, this function is executed in long mode, so the fix is necassary. Signed-off-by: Nadav Amit <namit@cs.technion.ac.il> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16KVM: x86: Distinguish between stack operation and near branchesNadav Amit
commit 58b7075d059f7d37ca86c76fb1446fa3447b9f4f upstream. In 64-bit, stack operations default to 64-bits, but can be overriden (to 16-bit) using opsize override prefix. In contrast, near-branches are always 64-bit. This patch distinguish between the different behaviors. Signed-off-by: Nadav Amit <namit@cs.technion.ac.il> Signed-off-by: Bruce Rogers <brogers@suse.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16KVM: x86: Getting rid of grp45 in emulatorNadav Amit
commit f7784046ab7cfc1645f4110b6ed14fbdffc2abee upstream. Breaking grp45 to the relevant functions to speed up the emulation and simplify the code. In addition, it is necassary the next patch will distinguish between far and near branches according to the flags. Signed-off-by: Nadav Amit <namit@cs.technion.ac.il> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16KVM: x86: Handle errors when RIP is set during far jumpsNadav Amit
commit d1442d85cc30ea75f7d399474ca738e0bc96f715 upstream. Far jmp/call/ret may fault while loading a new RIP. Currently KVM does not handle this case, and may result in failed vm-entry once the assignment is done. The tricky part of doing so is that loading the new CS affects the VMCS/VMCB state, so if we fail during loading the new RIP, we are left in unconsistent state. Therefore, this patch saves on 64-bit the old CS descriptor and restores it if loading RIP failed. Signed-off-by: Nadav Amit <namit@cs.technion.ac.il> Signed-off-by: Bruce Rogers <brogers@suse.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16KVM: x86: Warn if guest virtual address space is not 48-bitsNadav Amit
commit dd598091de4aabbc8bd7290a04f364e443c03455 upstream. The KVM emulator code assumes that the guest virtual address space (in 64-bit) is 48-bits wide. Since we are about to add more code that makes the same assumption, this patch adds an assertion to make sure guest virtual address space is indeed 48-bits wide. Signed-off-by: Nadav Amit <namit@cs.technion.ac.il> Signed-off-by: Bruce Rogers <brogers@suse.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-16Bluetooth: ath3k: workaround the compatibility issue with xHCI controllerAdam Lee
commit c561a5753dd631920c4459a067d22679b3d110d6 upstream. BugLink: https://bugs.launchpad.net/bugs/1400215 ath3k devices fail to load firmwares on xHCI buses, but work well on EHCI, this might be a compatibility issue between xHCI and ath3k chips. As my testing result, those chips will work on xHCI buses again with this patch. This workaround is from Qualcomm, they also did some workarounds in Windows driver. Signed-off-by: Adam Lee <adam.lee@canonical.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-13[media] media/rc: Send sync space information on the lirc deviceAustin Lund
commit a8f29e89f2b54fbf2c52be341f149bc195b63a8b upstream. Userspace expects to see a long space before the first pulse is sent on the lirc device. Currently, if a long time has passed and a new packet is started, the lirc codec just returns and doesn't send anything. This makes lircd ignore many perfectly valid signals unless they are sent in quick sucession. When a reset event is delivered, we cannot know anything about the duration of the space. But it should be safe to assume it has been a long time and we just set the duration to maximum. Signed-off-by: Austin Lund <austin.lund@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-13rbd: drop an unsafe assertionAlex Elder
commit 638c323c4d1f8eaf25224946e21ce8818f1bcee1 upstream. Olivier Bonvalet reported having repeated crashes due to a failed assertion he was hitting in rbd_img_obj_callback(): Assertion failure in rbd_img_obj_callback() at line 2165: rbd_assert(which >= img_request->next_completion); With a lot of help from Olivier with reproducing the problem we were able to determine the object and image requests had already been completed (and often freed) at the point the assertion failed. There was a great deal of discussion on the ceph-devel mailing list about this. The problem only arose when there were two (or more) object requests in an image request, and the problem was always seen when the second request was being completed. The problem is due to a race in the window between setting the "done" flag on an object request and checking the image request's next completion value. When the first object request completes, it checks to see if its successor request is marked "done", and if so, that request is also completed. In the process, the image request's next_completion value is updated to reflect that both the first and second requests are completed. By the time the second request is able to check the next_completion value, it has been set to a value *greater* than its own "which" value, which caused an assertion to fail. Fix this problem by skipping over any completion processing unless the completing object request is the next one expected. Test only for inequality (not >=), and eliminate the bad assertion. Tested-by: Olivier Bonvalet <ob@daevel.fr> Signed-off-by: Alex Elder <elder@linaro.org> Reviewed-by: Sage Weil <sage@inktank.com> Reviewed-by: Ilya Dryomov <ilya.dryomov@inktank.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-10net: sctp: fix passing wrong parameter header to param_type2af in ↵Saran Maruti Ramanara
sctp_process_param [ Upstream commit cfbf654efc6d78dc9812e030673b86f235bf677d ] When making use of RFC5061, section 4.2.4. for setting the primary IP address, we're passing a wrong parameter header to param_type2af(), resulting always in NULL being returned. At this point, param.p points to a sctp_addip_param struct, containing a sctp_paramhdr (type = 0xc004, length = var), and crr_id as a correlation id. Followed by that, as also presented in RFC5061 section 4.2.4., comes the actual sctp_addr_param, which also contains a sctp_paramhdr, but this time with the correct type SCTP_PARAM_IPV{4,6}_ADDRESS that param_type2af() can make use of. Since we already hold a pointer to addr_param from previous line, just reuse it for param_type2af(). Fixes: d6de3097592b ("[SCTP]: Add the handling of "Set Primary IP Address" parameter to INIT") Signed-off-by: Saran Maruti Ramanara <saran.neti@telus.com> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-10ppp: deflate: never return len larger than output bufferFlorian Westphal
[ Upstream commit e2a4800e75780ccf4e6c2487f82b688ba736eb18 ] When we've run out of space in the output buffer to store more data, we will call zlib_deflate with a NULL output buffer until we've consumed remaining input. When this happens, olen contains the size the output buffer would have consumed iff we'd have had enough room. This can later cause skb_over_panic when ppp_generic skb_put()s the returned length. Reported-by: Iain Douglas <centos@1n6.org.uk> Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-10ipv4: tcp: get rid of ugly unicast_sockEric Dumazet
[ Upstream commit bdbbb8527b6f6a358dbcb70dac247034d665b8e4 ] In commit be9f4a44e7d41 ("ipv4: tcp: remove per net tcp_sock") I tried to address contention on a socket lock, but the solution I chose was horrible : commit 3a7c384ffd57e ("ipv4: tcp: unicast_sock should not land outside of TCP stack") addressed a selinux regression. commit 0980e56e506b ("ipv4: tcp: set unicast_sock uc_ttl to -1") took care of another regression. commit b5ec8eeac46 ("ipv4: fix ip_send_skb()") fixed another regression. commit 811230cd85 ("tcp: ipv4: initialize unicast_sock sk_pacing_rate") was another shot in the dark. Really, just use a proper socket per cpu, and remove the skb_orphan() call, to re-enable flow control. This solves a serious problem with FQ packet scheduler when used in hostile environments, as we do not want to allocate a flow structure for every RST packet sent in response to a spoofed packet. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-10tcp: ipv4: initialize unicast_sock sk_pacing_rateEric Dumazet
[ Upstream commit 811230cd853d62f09ed0addd0ce9a1b9b0e13fb5 ] When I added sk_pacing_rate field, I forgot to initialize its value in the per cpu unicast_sock used in ip_send_unicast_reply() This means that for sch_fq users, RST packets, or ACK packets sent on behalf of TIME_WAIT sockets might be sent to slowly or even dropped once we reach the per flow limit. Signed-off-by: Eric Dumazet <edumazet@google.com> Fixes: 95bd09eb2750 ("tcp: TSO packets automatic sizing") Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-10bridge: dont send notification when skb->len == 0 in rtnl_bridge_notifyRoopa Prabhu
[ Upstream commit 59ccaaaa49b5b096cdc1f16706a9f931416b2332 ] Reported in: https://bugzilla.kernel.org/show_bug.cgi?id=92081 This patch avoids calling rtnl_notify if the device ndo_bridge_getlink handler does not return any bytes in the skb. Alternately, the skb->len check can be moved inside rtnl_notify. For the bridge vlan case described in 92081, there is also a fix needed in bridge driver to generate a proper notification. Will fix that in subsequent patch. v2: rebase patch on net tree Signed-off-by: Roopa Prabhu <roopa@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-10net: don't OOPS on socket aioChristoph Hellwig
[ Upstream commit 06539d3071067ff146a9bffd1c801fa56d290909 ] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-10bnx2x: fix napi poll return value for repollGovindarajulu Varadarajan
[ Upstream commit 24e579c8898aa641ede3149234906982290934e5 ] With the commit d75b1ade567ffab ("net: less interrupt masking in NAPI") napi repoll is done only when work_done == budget. When in busy_poll is we return 0 in napi_poll. We should return budget. Signed-off-by: Govindarajulu Varadarajan <_govind@gmx.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-10ipv6: replacing a rt6_info needs to purge possible propagated rt6_infos tooHannes Frederic Sowa
[ Upstream commit 6e9e16e6143b725662e47026a1d0f270721cdd24 ] Lubomir Rintel reported that during replacing a route the interface reference counter isn't correctly decremented. To quote bug <https://bugzilla.kernel.org/show_bug.cgi?id=91941>: | [root@rhel7-5 lkundrak]# sh -x lal | + ip link add dev0 type dummy | + ip link set dev0 up | + ip link add dev1 type dummy | + ip link set dev1 up | + ip addr add 2001:db8:8086::2/64 dev dev0 | + ip route add 2001:db8:8086::/48 dev dev0 proto static metric 20 | + ip route add 2001:db8:8088::/48 dev dev1 proto static metric 10 | + ip route replace 2001:db8:8086::/48 dev dev1 proto static metric 20 | + ip link del dev0 type dummy | Message from syslogd@rhel7-5 at Jan 23 10:54:41 ... | kernel:unregister_netdevice: waiting for dev0 to become free. Usage count = 2 | | Message from syslogd@rhel7-5 at Jan 23 10:54:51 ... | kernel:unregister_netdevice: waiting for dev0 to become free. Usage count = 2 During replacement of a rt6_info we must walk all parent nodes and check if the to be replaced rt6_info got propagated. If so, replace it with an alive one. Fixes: 4a287eba2de3957 ("IPv6 routing, NLM_F_* flag support: REPLACE and EXCL flags support, warn about missing CREATE flag") Reported-by: Lubomir Rintel <lkundrak@v3.sk> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Tested-by: Lubomir Rintel <lkundrak@v3.sk> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-10ping: Fix race in free in receive pathsubashab@codeaurora.org
[ Upstream commit fc752f1f43c1c038a2c6ae58cc739ebb5953ccb0 ] An exception is seen in ICMP ping receive path where the skb destructor sock_rfree() tries to access a freed socket. This happens because ping_rcv() releases socket reference with sock_put() and this internally frees up the socket. Later icmp_rcv() will try to free the skb and as part of this, skb destructor is called and which leads to a kernel panic as the socket is freed already in ping_rcv(). -->|exception -007|sk_mem_uncharge -007|sock_rfree -008|skb_release_head_state -009|skb_release_all -009|__kfree_skb -010|kfree_skb -011|icmp_rcv -012|ip_local_deliver_finish Fix this incorrect free by cloning this skb and processing this cloned skb instead. This patch was suggested by Eric Dumazet Signed-off-by: Subash Abhinov Kasiviswanathan <subashab@codeaurora.org> Cc: Eric Dumazet <edumazet@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-10udp_diag: Fix socket skipping within chainHerbert Xu
[ Upstream commit 86f3cddbc3037882414c7308973530167906b7e9 ] While working on rhashtable walking I noticed that the UDP diag dumping code is buggy. In particular, the socket skipping within a chain never happens, even though we record the number of sockets that should be skipped. As this code was supposedly copied from TCP, this patch does what TCP does and resets num before we walk a chain. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-10ipv4: try to cache dst_entries which would cause a redirectHannes Frederic Sowa
[ Upstream commit df4d92549f23e1c037e83323aff58a21b3de7fe0 ] Not caching dst_entries which cause redirects could be exploited by hosts on the same subnet, causing a severe DoS attack. This effect aggravated since commit f88649721268999 ("ipv4: fix dst race in sk_dst_get()"). Lookups causing redirects will be allocated with DST_NOCACHE set which will force dst_release to free them via RCU. Unfortunately waiting for RCU grace period just takes too long, we can end up with >1M dst_entries waiting to be released and the system will run OOM. rcuos threads cannot catch up under high softirq load. Attaching the flag to emit a redirect later on to the specific skb allows us to cache those dst_entries thus reducing the pressure on allocation and deallocation. This issue was discovered by Marcelo Leitner. Cc: Julian Anastasov <ja@ssi.bg> Signed-off-by: Marcelo Leitner <mleitner@redhat.com> Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-10net: sctp: fix slab corruption from use after free on INIT collisionsDaniel Borkmann
[ Upstream commit 600ddd6825543962fb807884169e57b580dba208 ] When hitting an INIT collision case during the 4WHS with AUTH enabled, as already described in detail in commit 1be9a950c646 ("net: sctp: inherit auth_capable on INIT collisions"), it can happen that we occasionally still remotely trigger the following panic on server side which seems to have been uncovered after the fix from commit 1be9a950c646 ... [ 533.876389] BUG: unable to handle kernel paging request at 00000000ffffffff [ 533.913657] IP: [<ffffffff811ac385>] __kmalloc+0x95/0x230 [ 533.940559] PGD 5030f2067 PUD 0 [ 533.957104] Oops: 0000 [#1] SMP [ 533.974283] Modules linked in: sctp mlx4_en [...] [ 534.939704] Call Trace: [ 534.951833] [<ffffffff81294e30>] ? crypto_init_shash_ops+0x60/0xf0 [ 534.984213] [<ffffffff81294e30>] crypto_init_shash_ops+0x60/0xf0 [ 535.015025] [<ffffffff8128c8ed>] __crypto_alloc_tfm+0x6d/0x170 [ 535.045661] [<ffffffff8128d12c>] crypto_alloc_base+0x4c/0xb0 [ 535.074593] [<ffffffff8160bd42>] ? _raw_spin_lock_bh+0x12/0x50 [ 535.105239] [<ffffffffa0418c11>] sctp_inet_listen+0x161/0x1e0 [sctp] [ 535.138606] [<ffffffff814e43bd>] SyS_listen+0x9d/0xb0 [ 535.166848] [<ffffffff816149a9>] system_call_fastpath+0x16/0x1b ... or depending on the the application, for example this one: [ 1370.026490] BUG: unable to handle kernel paging request at 00000000ffffffff [ 1370.026506] IP: [<ffffffff811ab455>] kmem_cache_alloc+0x75/0x1d0 [ 1370.054568] PGD 633c94067 PUD 0 [ 1370.070446] Oops: 0000 [#1] SMP [ 1370.085010] Modules linked in: sctp kvm_amd kvm [...] [ 1370.963431] Call Trace: [ 1370.974632] [<ffffffff8120f7cf>] ? SyS_epoll_ctl+0x53f/0x960 [ 1371.000863] [<ffffffff8120f7cf>] SyS_epoll_ctl+0x53f/0x960 [ 1371.027154] [<ffffffff812100d3>] ? anon_inode_getfile+0xd3/0x170 [ 1371.054679] [<ffffffff811e3d67>] ? __alloc_fd+0xa7/0x130 [ 1371.080183] [<ffffffff816149a9>] system_call_fastpath+0x16/0x1b With slab debugging enabled, we can see that the poison has been overwritten: [ 669.826368] BUG kmalloc-128 (Tainted: G W ): Poison overwritten [ 669.826385] INFO: 0xffff880228b32e50-0xffff880228b32e50. First byte 0x6a instead of 0x6b [ 669.826414] INFO: Allocated in sctp_auth_create_key+0x23/0x50 [sctp] age=3 cpu=0 pid=18494 [ 669.826424] __slab_alloc+0x4bf/0x566 [ 669.826433] __kmalloc+0x280/0x310 [ 669.826453] sctp_auth_create_key+0x23/0x50 [sctp] [ 669.826471] sctp_auth_asoc_create_secret+0xcb/0x1e0 [sctp] [ 669.826488] sctp_auth_asoc_init_active_key+0x68/0xa0 [sctp] [ 669.826505] sctp_do_sm+0x29d/0x17c0 [sctp] [...] [ 669.826629] INFO: Freed in kzfree+0x31/0x40 age=1 cpu=0 pid=18494 [ 669.826635] __slab_free+0x39/0x2a8 [ 669.826643] kfree+0x1d6/0x230 [ 669.826650] kzfree+0x31/0x40 [ 669.826666] sctp_auth_key_put+0x19/0x20 [sctp] [ 669.826681] sctp_assoc_update+0x1ee/0x2d0 [sctp] [ 669.826695] sctp_do_sm+0x674/0x17c0 [sctp] Since this only triggers in some collision-cases with AUTH, the problem at heart is that sctp_auth_key_put() on asoc->asoc_shared_key is called twice when having refcnt 1, once directly in sctp_assoc_update() and yet again from within sctp_auth_asoc_init_active_key() via sctp_assoc_update() on the already kzfree'd memory, which is also consistent with the observation of the poison decrease from 0x6b to 0x6a (note: the overwrite is detected at a later point in time when poison is checked on new allocation). Reference counting of auth keys revisited: Shared keys for AUTH chunks are being stored in endpoints and associations in endpoint_shared_keys list. On endpoint creation, a null key is being added; on association creation, all endpoint shared keys are being cached and thus cloned over to the association. struct sctp_shared_key only holds a pointer to the actual key bytes, that is, struct sctp_auth_bytes which keeps track of users internally through refcounting. Naturally, on assoc or enpoint destruction, sctp_shared_key are being destroyed directly and the reference on sctp_auth_bytes dropped. User space can add keys to either list via setsockopt(2) through struct sctp_authkey and by passing that to sctp_auth_set_key() which replaces or adds a new auth key. There, sctp_auth_create_key() creates a new sctp_auth_bytes with refcount 1 and in case of replacement drops the reference on the old sctp_auth_bytes. A key can be set active from user space through setsockopt() on the id via sctp_auth_set_active_key(), which iterates through either endpoint_shared_keys and in case of an assoc, invokes (one of various places) sctp_auth_asoc_init_active_key(). sctp_auth_asoc_init_active_key() computes the actual secret from local's and peer's random, hmac and shared key parameters and returns a new key directly as sctp_auth_bytes, that is asoc->asoc_shared_key, plus drops the reference if there was a previous one. The secret, which where we eventually double drop the ref comes from sctp_auth_asoc_set_secret() with intitial refcount of 1, which also stays unchanged eventually in sctp_assoc_update(). This key is later being used for crypto layer to set the key for the hash in crypto_hash_setkey() from sctp_auth_calculate_hmac(). To close the loop: asoc->asoc_shared_key is freshly allocated secret material and independant of the sctp_shared_key management keeping track of only shared keys in endpoints and assocs. Hence, also commit 4184b2a79a76 ("net: sctp: fix memory leak in auth key management") is independant of this bug here since it concerns a different layer (though same structures being used eventually). asoc->asoc_shared_key is reference dropped correctly on assoc destruction in sctp_association_free() and when active keys are being replaced in sctp_auth_asoc_init_active_key(), it always has a refcount of 1. Hence, it's freed prematurely in sctp_assoc_update(). Simple fix is to remove that sctp_auth_key_put() from there which fixes these panics. Fixes: 730fc3d05cd4 ("[SCTP]: Implete SCTP-AUTH parameter processing") Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-10netxen: fix netxen_nic_poll() logicEric Dumazet
[ Upstream commit 6088beef3f7517717bd21d90b379714dd0837079 ] NAPI poll logic now enforces that a poller returns exactly the budget when it wants to be called again. If a driver limits TX completion, it has to return budget as well when the limit is hit, not the number of received packets. Reported-and-tested-by: Mike Galbraith <umgwanakikbuti@gmail.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Fixes: d75b1ade567f ("net: less interrupt masking in NAPI") Cc: Manish Chopra <manish.chopra@qlogic.com> Acked-by: Manish Chopra <manish.chopra@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-10ipv6: stop sending PTB packets for MTU < 1280Hagen Paul Pfeifer
[ Upstream commit 9d289715eb5c252ae15bd547cb252ca547a3c4f2 ] Reduce the attack vector and stop generating IPv6 Fragment Header for paths with an MTU smaller than the minimum required IPv6 MTU size (1280 byte) - called atomic fragments. See IETF I-D "Deprecating the Generation of IPv6 Atomic Fragments" [1] for more information and how this "feature" can be misused. [1] https://tools.ietf.org/html/draft-ietf-6man-deprecate-atomfrag-generation-00 Signed-off-by: Fernando Gont <fgont@si6networks.com> Signed-off-by: Hagen Paul Pfeifer <hagen@jauu.net> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-10net: rps: fix cpu unplugEric Dumazet
[ Upstream commit ac64da0b83d82abe62f78b3d0e21cca31aea24fa ] softnet_data.input_pkt_queue is protected by a spinlock that we must hold when transferring packets from victim queue to an active one. This is because other cpus could still be trying to enqueue packets into victim queue. A second problem is that when we transfert the NAPI poll_list from victim to current cpu, we absolutely need to special case the percpu backlog, because we do not want to add complex locking to protect process_queue : Only owner cpu is allowed to manipulate it, unless cpu is offline. Based on initial patch from Prasad Sodagudi & Subash Abhinov Kasiviswanathan. This version is better because we do not slow down packet processing, only make migration safer. Reported-by: Prasad Sodagudi <psodagud@codeaurora.org> Reported-by: Subash Abhinov Kasiviswanathan <subashab@codeaurora.org> Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-10ip: zero sockaddr returned on error queueWillem de Bruijn
[ Upstream commit f812116b174e59a350acc8e4856213a166a91222 ] The sockaddr is returned in IP(V6)_RECVERR as part of errhdr. That structure is defined and allocated on the stack as struct { struct sock_extended_err ee; struct sockaddr_in(6) offender; } errhdr; The second part is only initialized for certain SO_EE_ORIGIN values. Always initialize it completely. An MTU exceeded error on a SOCK_RAW/IPPROTO_RAW is one example that would return uninitialized bytes. Signed-off-by: Willem de Bruijn <willemb@google.com> ---- Also verified that there is no padding between errhdr.ee and errhdr.offender that could leak additional kernel data. Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-10crypto: crc32c - add missing crypto module aliasMathias Krause
The backport of commit 5d26a105b5a7 ("crypto: prefix module autoloading with "crypto-"") lost the MODULE_ALIAS_CRYPTO() annotation of crc32c.c. Add it to fix the reported filesystem related regressions. Signed-off-by: Mathias Krause <minipli@googlemail.com> Reported-by: Philip Müller <philm@manjaro.org> Cc: Kees Cook <keescook@chromium.org> Cc: Rob McCathie <rob@manjaro.org> Cc: Luis Henriques <luis.henriques@canonical.com> Cc: Kamal Mostafa <kamal@canonical.com> Cc: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2015-02-09x86,kvm,vmx: Preserve CR4 across VM entryAndy Lutomirski
commit d974baa398f34393db76be45f7d4d04fbdbb4a0a upstream. CR4 isn't constant; at least the TSD and PCE bits can vary. TBH, treating CR0 and CR3 as constant scares me a bit, too, but it looks like it's correct. This adds a branch and a read from cr4 to each vm entry. Because it is extremely likely that consecutive entries into the same vcpu will have the same host cr4 value, this fixes up the vmcs instead of restoring cr4 after the fact. A subsequent patch will add a kernel-wide cr4 shadow, reducing the overhead in the common case to just two memory reads and a branch. Signed-off-by: Andy Lutomirski <luto@amacapital.net> Acked-by: Paolo Bonzini <pbonzini@redhat.com> Cc: Petr Matousek <pmatouse@redhat.com> Cc: Gleb Natapov <gleb@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [wangkai: Backport to 3.10: adjust context] Signed-off-by: Wang Kai <morgan.wang@huawei.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
