commit 0758f4f732b08b6ef07f2e5f735655cf69fea477 upstream.
When copy_from_user fails, return -EFAULT, not -ENOMEM
Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com>
Reported-by: Robert Elliott <elliott@hp.com>
Reviewed-by: Joe Handzik <joseph.t.handzik@hp.com>
Reviewed-by: Scott Teel <scott.teel@hp.com>
Reviewed by: Mike MIller <michael.miller@canonical.com>
commit 8d5999df35314607c38fbd6bdd709e25c3a4eeab upstream.
If the timer irqs are resumed during device resume it is possible in
certain circumstances for the resume to hang early on, before device
interrupts are resumed. For an Ubuntu 14.04 PVHVM guest this would
occur in ~0.5% of resume attempts.
It is not entirely clear what is occuring the point of the hang but I
think a task necessary for the resume calls schedule_timeout(),
waiting for a timer interrupt (which never arrives). This failure may
require specific tasks to be running on the other VCPUs to trigger
(processes are not frozen during a suspend/resume if PREEMPT is
disabled).
Add IRQF_EARLY_RESUME to the timer interrupts so they are resumed in
syscore_resume().
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
commit 7b2a583afb4ab894f78bc0f8bd136e96b6499a7e upstream.
Without CONFIG_RELOCATABLE the early boot code will decompress the
kernel to LOAD_PHYSICAL_ADDR. While this may have been fine in the BIOS
days, that isn't going to fly with UEFI since parts of the firmware
code/data may be located at LOAD_PHYSICAL_ADDR.
Straying outside of the bounds of the regions we've explicitly requested
from the firmware will cause all sorts of trouble. Bruno reports that
his machine resets while trying to decompress the kernel image.
We already go to great pains to ensure the kernel is loaded into a
suitably aligned buffer, it's just that the address isn't necessarily
LOAD_PHYSICAL_ADDR, because we can't guarantee that address isn't in-use
by the firmware.
Explicitly enforce CONFIG_RELOCATABLE for the EFI boot stub, so that we
can load the kernel at any address with the correct alignment.
Reported-by: Bruno Prémont <bonbons@linux-vserver.org>
Tested-by: Bruno Prémont <bonbons@linux-vserver.org>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
commit 53b884ac3745353de220d92ef792515c3ae692f0 upstream.
This commit in Linux 3.6:
commit c767a54ba0657e52e6edaa97cbe0b0a8bf1c1655
Author: Joe Perches <joe@perches.com>
Date: Mon May 21 19:50:07 2012 -0700
x86/debug: Add KERN_<LEVEL> to bare printks, convert printks to pr_<level>
caused warn_bad_vsyscall to output garbage in the middle of the
line. Revert the bad part of it.
The printk in question isn't actually bare; the level is "%s".
The bug this fixes is purely cosmetic; backports are optional.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Link: http://lkml.kernel.org/r/03eac1f24110bbe496ecc12a4df467e0d88466d4.1406330947.git.luto@amacapital.net
commit cbace46a9710a480cae51e4611697df5de41713e upstream.
Commit 30919b0bf356 ("x86: avoid low BIOS area when allocating address
space") moved the test for resource allocations that fall within the first
1MB of address space from the PCI-specific path to a generic path, such
that all resource allocations will avoid this area. However, this breaks
ISA cards which need to allocate a memory region within the first 1MB. An
example is the i82365 PCMCIA controller and derivatives like the Ricoh
RF5C296/396 which map part of the PCMCIA socket memory address space into
the first 1MB of system memory address space. They do not work anymore as
no usable memory region exists due to this change:
Intel ISA PCIC probe: Ricoh RF5C296/396 ISA-to-PCMCIA at port 0x3e0 ofs 0x00, 2 sockets
host opts [0]: none
host opts [1]: none
ISA irqs (scanned) = 3,4,5,9,10 status change on irq 10
pcmcia_socket pcmcia_socket1: pccard: PCMCIA card inserted into slot 1
pcmcia_socket pcmcia_socket0: cs: IO port probe 0xc00-0xcff: excluding 0xcf8-0xcff
pcmcia_socket pcmcia_socket0: cs: IO port probe 0xa00-0xaff: clean.
pcmcia_socket pcmcia_socket0: cs: IO port probe 0x100-0x3ff: excluding 0x170-0x177 0x1f0-0x1f7 0x2f8-0x2ff 0x370-0x37f 0x3c0-0x3e7 0x3f0-0x3ff
pcmcia_socket pcmcia_socket0: cs: memory probe 0x0a0000-0x0affff: excluding 0xa0000-0xaffff
pcmcia_socket pcmcia_socket0: cs: memory probe 0x0b0000-0x0bffff: excluding 0xb0000-0xbffff
pcmcia_socket pcmcia_socket0: cs: memory probe 0x0c0000-0x0cffff: excluding 0xc0000-0xcbfff
pcmcia_socket pcmcia_socket0: cs: memory probe 0x0d0000-0x0dffff: clean.
pcmcia_socket pcmcia_socket0: cs: memory probe 0x0e0000-0x0effff: clean.
pcmcia_socket pcmcia_socket0: cs: memory probe 0x60000000-0x60ffffff: clean.
pcmcia_socket pcmcia_socket0: cs: memory probe 0xa0000000-0xa0ffffff: clean.
pcmcia_socket pcmcia_socket1: cs: IO port probe 0xc00-0xcff: excluding 0xcf8-0xcff
pcmcia_socket pcmcia_socket1: cs: IO port probe 0xa00-0xaff: clean.
pcmcia_socket pcmcia_socket1: cs: IO port probe 0x100-0x3ff: excluding 0x170-0x177 0x1f0-0x1f7 0x2f8-0x2ff 0x370-0x37f 0x3c0-0x3e7 0x3f0-0x3ff
pcmcia_socket pcmcia_socket1: cs: memory probe 0x0a0000-0x0affff: excluding 0xa0000-0xaffff
pcmcia_socket pcmcia_socket1: cs: memory probe 0x0b0000-0x0bffff: excluding 0xb0000-0xbffff
pcmcia_socket pcmcia_socket1: cs: memory probe 0x0c0000-0x0cffff: excluding 0xc0000-0xcbfff
pcmcia_socket pcmcia_socket1: cs: memory probe 0x0d0000-0x0dffff: clean.
pcmcia_socket pcmcia_socket1: cs: memory probe 0x0e0000-0x0effff: clean.
pcmcia_socket pcmcia_socket1: cs: memory probe 0x60000000-0x60ffffff: clean.
pcmcia_socket pcmcia_socket1: cs: memory probe 0xa0000000-0xa0ffffff: clean.
pcmcia_socket pcmcia_socket1: cs: memory probe 0x0cc000-0x0effff: excluding 0xe0000-0xeffff
pcmcia_socket pcmcia_socket1: cs: unable to map card memory!
If filtering out the first 1MB is reverted, everything works as expected.
Tested-by: Robert Resch <fli4l@robert.reschpara.de>
Signed-off-by: Christoph Schulz <develop@kristov.de>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
commit 1f6ae47ecff7f23da73417e068018b311f3b5583 upstream.
We can't do ASPM configuration at enumeration-time because enabling it
makes some defective hardware unresponsive, even if ASPM is disabled later
(see 41cd766b0659 ("PCI: Don't enable aspm before drivers have had a chance
to veto it"). Therefore, we have to do it after a driver claims the
device.
We previously configured ASPM in pci_set_power_state(), but that's not a
very good place because it's not really related to setting the PCI device
power state, and doing it there means:
- We incorrectly skipped ASPM config when setting a device that's
already in D0 to D0.
- We unnecessarily configured ASPM when setting a device to a low-power
state (the ASPM feature only applies when the device is in D0).
- We unnecessarily configured ASPM when called from a .resume() method
(ASPM configuration needs to be restored during resume, but
pci_restore_pcie_state() should already do this).
Move ASPM configuration from pci_set_power_state() to
do_pci_enable_device() so we do it when a driver enables a device.
[bhelgaas: changelog]
Link: https://bugzilla.kernel.org/show_bug.cgi?id=79621
Fixes: db288c9c5f9d ("PCI / PM: restore the original behavior of pci_set_power_state()")
Suggested-by: Bjorn Helgaas <bhelgaas@google.com>
Signed-off-by: Vidya Sagar <sagar.tv@gmail.com>
commit 37dbeab788a8f23fd946c0be083e5484d6f929a1 upstream.
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 5fc540edc8ea1297c76685f74bc82a2107fe6731 upstream.
commit 6dc14baf4ced769017c7a7045019c7a19f373865 upstream.
bug:
https://bugs.freedesktop.org/show_bug.cgi?id=82912
commit 350b8bdd689cd2ab2c67c8a86a0be86cfa0751a7 upstream.
The third parameter of kvm_iommu_put_pages is wrong,
It should be 'gfn - slot->base_gfn'.
By making gfn very large, malicious guest or userspace can cause kvm to
go to this error path, and subsequently to pass a huge value as size.
Alternatively if gfn is small, then pages would be pinned but never
unpinned, causing host memory leak and local DOS.
Passing a reasonable but large value could be the most dangerous case,
because it would unpin a page that should have stayed pinned, and thus
allow the device to DMA into arbitrary memory. However, this cannot
happen because of the condition that can trigger the error:
- out of memory (where you can't allocate even a single page)
should not be possible for the attacker to trigger
- when exceeding the iommu's address space, guest pages after gfn
will also exceed the iommu's address space, and inside
kvm_iommu_put_pages() the iommu_iova_to_phys() will fail. The
page thus would not be unpinned at all.
Reported-by: Jack Morgenstein <jackm@mellanox.com>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
commit 0d234daf7e0a3290a3a20c8087eefbd6335a5bd4 upstream.
This reverts commit 682367c494869008eb89ef733f196e99415ae862,
which causes 32-bit SMP Windows 7 guests to panic.
SeaBIOS has a limit on the number of MTRRs that it can handle,
and this patch exceeded the limit. Better revert it.
Thanks to Nadav Amit for debugging the cause.
Reported-by: Wanpeng Li <wanpeng.li@linux.intel.com>
commit 0f6c0a740b7d3e1f3697395922d674000f83d060 upstream.
Currently, the EOI exit bitmap (used for APICv) does not include
interrupts that are masked. However, this can cause a bug that manifests
as an interrupt storm inside the guest. Alex Williamson reported the
bug and is the one who really debugged this; I only wrote the patch. :)
The scenario involves a multi-function PCI device with OHCI and EHCI
USB functions and an audio function, all assigned to the guest, where
both USB functions use legacy INTx interrupts.
As soon as the guest boots, interrupts for these devices turn into an
interrupt storm in the guest; the host does not see the interrupt storm.
Basically the EOI path does not work, and the guest continues to see the
interrupt over and over, even after it attempts to mask it at the APIC.
The bug is only visible with older kernels (RHEL6.5, based on 2.6.32
with not many changes in the area of APIC/IOAPIC handling).
Alex then tried forcing bit 59 (corresponding to the USB functions' IRQ)
on in the eoi_exit_bitmap and TMR, and things then work. What happens
is that VFIO asserts IRQ11, then KVM recomputes the EOI exit bitmap.
It does not have set bit 59 because the RTE was masked, so the IOAPIC
never sees the EOI and the interrupt continues to fire in the guest.
My guess was that the guest is masking the interrupt in the redirection
table in the interrupt routine, i.e. while the interrupt is set in a
LAPIC's ISR, The simplest fix is to ignore the masking state, we would
rather have an unnecessary exit rather than a missed IRQ ACK and anyway
IOAPIC interrupts are not as performance-sensitive as for example MSIs.
Alex tested this patch and it fixed his bug.
[Thanks to Alex for his precise description of the problem
and initial debugging effort. A lot of the text above is
based on emails exchanged with him.]
Reported-by: Alex Williamson <alex.williamson@redhat.com>
Tested-by: Alex Williamson <alex.williamson@redhat.com>
commit 9e8919ae793f4edfaa29694a70f71a515ae9942a upstream.
Return unhandlable error on inter-privilege level ret instruction. This is
since the current emulation does not check the privilege level correctly when
loading the CS, and does not pop RSP/SS as needed.
Signed-off-by: Nadav Amit <namit@cs.technion.ac.il>
commit 485d44022a152c0254dd63445fdb81c4194cbf0e upstream.
[ I'm currently running my tests on it now, and so far, after a few
hours it has yet to blow up. I'll run it for 24 hours which it never
succeeded in the past. ]
The tracing code has a way to make directories within the debugfs file
system as well as deleting them using mkdir/rmdir in the instance
directory. This is very limited in functionality, such as there is
no renames, and the parent directory "instance" can not be modified.
The tracing code creates the instance directory from the debugfs code
and then replaces the dentry->d_inode->i_op with its own to allow
for mkdir/rmdir to work.
When these are called, the d_entry and inode locks need to be released
to call the instance creation and deletion code. That code has its own
accounting and locking to serialize everything to prevent multiple
users from causing harm. As the parent "instance" directory can not
be modified this simplifies things.
I created a stress test that creates several threads that randomly
creates and deletes directories thousands of times a second. The code
stood up to this test and I submitted it a while ago.
Recently I added a new test that adds readers to the mix. While the
instance directories were being added and deleted, readers would read
from these directories and even enable tracing within them. This test
was able to trigger a bug:
general protection fault: 0000 [#1] PREEMPT SMP
Modules linked in: ...
CPU: 3 PID: 17789 Comm: rmdir Tainted: G W 3.15.0-rc2-test+ #41
Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./To be filled by O.E.M., BIOS SDBLI944.86P 05/08/2007
task: ffff88003786ca60 ti: ffff880077018000 task.ti: ffff880077018000
RIP: 0010:[<ffffffff811ed5eb>] [<ffffffff811ed5eb>] debugfs_remove_recursive+0x1bd/0x367
RSP: 0018:ffff880077019df8 EFLAGS: 00010246
RAX: 0000000000000002 RBX: ffff88006f0fe490 RCX: 0000000000000000
RDX: dead000000100058 RSI: 0000000000000246 RDI: ffff88003786d454
RBP: ffff88006f0fe640 R08: 0000000000000628 R09: 0000000000000000
R10: 0000000000000628 R11: ffff8800795110a0 R12: ffff88006f0fe640
R13: ffff88006f0fe640 R14: ffffffff81817d0b R15: ffffffff818188b7
FS: 00007ff13ae24700(0000) GS:ffff88007d580000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000003054ec7be0 CR3: 0000000076d51000 CR4: 00000000000007e0
Stack:
ffff88007a41ebe0 dead000000100058 00000000fffffffe ffff88006f0fe640
0000000000000000 ffff88006f0fe678 ffff88007a41ebe0 ffff88003793a000
00000000fffffffe ffffffff810bde82 ffff88006f0fe640 ffff88007a41eb28
Call Trace:
[<ffffffff810bde82>] ? instance_rmdir+0x15b/0x1de
[<ffffffff81132e2d>] ? vfs_rmdir+0x80/0xd3
[<ffffffff81132f51>] ? do_rmdir+0xd1/0x139
[<ffffffff8124ad9e>] ? trace_hardirqs_on_thunk+0x3a/0x3c
[<ffffffff814fea62>] ? system_call_fastpath+0x16/0x1b
Code: fe ff ff 48 8d 75 30 48 89 df e8 c9 fd ff ff 85 c0 75 13 48 c7 c6 b8 cc d2 81 48 c7 c7 b0 cc d2 81 e8 8c 7a f5 ff 48 8b 54 24 08 <48> 8b 82 a8 00 00 00 48 89 d3 48 2d a8 00 00 00 48 89 44 24 08
RIP [<ffffffff811ed5eb>] debugfs_remove_recursive+0x1bd/0x367
RSP <ffff880077019df8>
It took a while, but every time it triggered, it was always in the
same place:
list_for_each_entry_safe(child, next, &parent->d_subdirs, d_u.d_child) {
Where the child->d_u.d_child seemed to be corrupted. I added lots of
trace_printk()s to see what was wrong, and sure enough, it was always
the child's d_u.d_child field. I looked around to see what touches
it and noticed that in __dentry_kill() which calls dentry_free():
static void dentry_free(struct dentry *dentry)
/* if dentry was never visible to RCU, immediate free is OK */
if (!(dentry->d_flags & DCACHE_RCUACCESS))
__d_free(&dentry->d_u.d_rcu);
else
call_rcu(&dentry->d_u.d_rcu, __d_free);
I also noticed that __dentry_kill() unlinks the child->d_u.child
under the parent->d_lock spin_lock.
Looking back at the loop in debugfs_remove_recursive() it never takes the
parent->d_lock to do the list walk. Adding more tracing, I was able to
prove this was the issue:
ftrace-t-15385 1.... 246662024us : dentry_kill <ffffffff81138b91>: free ffff88006d573600
rmdir-15409 2.... 246662024us : debugfs_remove_recursive <ffffffff811ec7e5>: child=ffff88006d573600 next=dead000000100058
The dentry_kill freed ffff88006d573600 just as the remove recursive was walking
it.
In order to fix this, the list walk needs to be modified a bit to take
the parent->d_lock. The safe version is no longer necessary, as every
time we remove a child, the parent->d_lock must be released and the
list walk must start over. Each time a child is removed, even though it
may still be on the list, it should be skipped by the first check
in the loop:
if (!debugfs_positive(child))
continue;
commit e1f8859ee265fc89bd21b4dca79e8e983a044892 upstream.
The interrupt handler in the ux500 crypto driver has an obviously
incorrect way to access the data buffer, which for a while has
caused this build warning:
../ux500/cryp/cryp_core.c: In function 'cryp_interrupt_handler':
../ux500/cryp/cryp_core.c:234:5: warning: passing argument 1 of '__fswab32' makes integer from pointer without a cast [enabled by default]
writel_relaxed(ctx->indata,
In file included from ../include/linux/swab.h:4:0,
from ../include/uapi/linux/byteorder/big_endian.h:12,
from ../include/linux/byteorder/big_endian.h:4,
from ../arch/arm/include/uapi/asm/byteorder.h:19,
from ../include/asm-generic/bitops/le.h:5,
from ../arch/arm/include/asm/bitops.h:340,
from ../include/linux/bitops.h:33,
from ../include/linux/kernel.h:10,
from ../include/linux/clk.h:16,
from ../drivers/crypto/ux500/cryp/cryp_core.c:12:
../include/uapi/linux/swab.h:57:119: note: expected '__u32' but argument is of type 'const u8 *'
static inline __attribute_const__ __u32 __fswab32(__u32 val)
There are at least two, possibly three problems here:
a) when writing into the FIFO, we copy the pointer rather than the
actual data we want to give to the hardware
b) the data pointer is an array of 8-bit values, while the FIFO
is 32-bit wide, so both the read and write access fail to do
a proper type conversion
c) This seems incorrect for big-endian kernels, on which we need to
byte-swap any register access, but not normally FIFO accesses,
at least the DMA case doesn't do it either.
This converts the bogus loop to use the same readsl/writesl pair
that we use for the two other modes (DMA and polling). This is
more efficient and consistent, and probably correct for endianess.
The bug has existed since the driver was first merged, and was
probably never detected because nobody tried to use interrupt mode.
It might make sense to backport this fix to stable kernels, depending
on how the crypto maintainers feel about that.
Cc: linux-crypto@vger.kernel.org
Cc: Fabio Baltieri <fabio.baltieri@linaro.org>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
commit ae84db9661cafc63d179e1d985a2c5b841ff0ac4 upstream.
When a tty is opened for the serial console, the termios c_cflag
settings are inherited from the console line settings.
However, if the tty is subsequently closed, the termios settings
are lost. This results in a garbled console if the console is later
suspended and resumed.
Preserve the termios c_cflag for the serial console when the tty
is shutdown; this reflects the most recent line settings.
Fixes: Bugzilla #69751, 'serial console does not wake from S3'
Reported-by: Valerio Vanni <valerio.vanni@inwind.it>
Acked-by: Alan Cox <alan@linux.intel.com>
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
commit 86f0afd463215fc3e58020493482faa4ac3a4d69 upstream.
If there is a failure while allocating the preallocation structure, a
number of blocks can end up getting marked in the in-memory buddy
bitmap, and then not getting released. This can result in the
following corruption getting reported by the kernel:
EXT4-fs error (device sda3): ext4_mb_generate_buddy:758: group 1126,
12793 clusters in bitmap, 12729 in gd
In that case, we need to release the blocks using mb_free_blocks().
Tested: fs smoke test; also demonstrated that with injected errors,
the file system is no longer getting corrupted
Google-Bug-Id: 16657874
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit 28772ac8711e4d7268c06e765887dd8cb6924f98 upstream.
dma_{un}map_* uses 'enum dma_data_direction' not 'enum dma_transfer_direction'.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Acked-by: Ludovic Desroches <ludovic.desroches@atmel.com>
commit f07a5e9a331045e976a3d317ba43d14859d9407c upstream.
Most device drivers do call 'tpm_do_selftest' which executes a
TPM_ContinueSelfTest. tpm_i2c_stm_st33 is just pointlessly different,
I think it is bug.
These days we have the general assumption that the TPM is usable by
the kernel immediately after the driver is finished, so we can no
longer defer the mandatory self test to userspace.
Reported-by: Richard Marciel <rmaciel@linux.vnet.ibm.com>
Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
commit d58e47d787c09fe5c61af3c6ce7d784762f29c3d upstream.
On platforms with sizeof(int) < sizeof(long), writing a temperature
limit larger than MAXINT will result in unpredictable limit values
written to the chip. Avoid auto-conversion from long to int to fix
the problem.
Voltage limits, fan minimum speed, pwm frequency, pwm ramp rate, and
other attributes have the same problem, fix them as well.
Zone temperature limits are signed, but were cached as u8, causing
unepected values to be reported for negative temperatures. Cache as
s8 to fix the problem.
vrm is an u8, so the written value needs to be limited to [0, 255].
Signed-off-by: Axel Lin <axel.lin@ingics.com>
[Guenter Roeck: Fix zone temperature cache]
commit e981429557cbe10c780fab1c1a237cb832757652 upstream.
Current code uses data_rate as array index in ads1015_read_adc() and uses pga
as array index in ads1015_reg_to_mv, so we must make sure both data_rate and
pga settings are in valid value range.
Return -EINVAL if the setting is out-of-range.
commit 3248c3b771ddd9d31695da17ba350eb6e1b80a53 upstream.
Temperature limit register writes did not account for negative numbers.
As a result, writing -127000 resulted in -126000 written into the
temperature limit register. This problem affected temp[1-3]_min,
temp[1-3]_max, temp[1-3]_auto_temp_crit, and temp[1-3]_auto_temp_min.
When writing pwm[1-3]_freq, a long variable was auto-converted into an int
without range check. Wiring values larger than MAXINT resulted in unexpected
register values.
When writing temp[1-3]_auto_temp_max, an unsigned long variable was
auto-converted into an int without range check. Writing values larger than
MAXINT resulted in unexpected register values.
Cc: Axel Lin <axel.lin@ingics.com>
Reviewed-by: Axel Lin <axel.lin@ingics.com>
commit 56de1377ad92f72ee4e5cb0faf7a9b6048fdf0bf upstream.
Current code uses channel as array index, so the valid channel value is
0 .. ADS1015_CHANNELS - 1.
commit 2565fb05d1e9fc0831f7b1c083bcfcb1cba1f020 upstream.
On platforms with sizeof(int) < sizeof(unsigned long), writing a rpm value
larger than MAXINT will result in unpredictable limit values written to the
chip. Avoid auto-conversion from unsigned long to int to fix the problem.
commit 1074d683a51f1aded3562add9ef313e75d557327 upstream.
the problem.
commit cf44819c98db11163f58f08b822d626c7a8f5188 upstream.
Ensure mutex lock protects the read-modify-write period to prevent possible
race condition bug.
In additional, update data->valid should also be protected by the mutex lock.
commit cc336546ddca8c22de83720632431c16a5f9fe9a upstream.
the problem.
commit 2d31ca3ad7d5d44c8adc7f253c96ce33f3a2e931 upstream.
Regular randconfig nightly testing has detected problems with omapdrm.
omapdrm fails to build when the kernel is built to support 64-bit DMA
addresses and/or 64-bit physical addresses due to an assumption about
the width of these types.
Use %pad to print DMA addresses, rather than %x or %Zx (which is even
more wrong than %x). Avoid passing a uint32_t pointer into a function
which expects dma_addr_t pointer.
drivers/gpu/drm/omapdrm/omap_plane.c: In function 'omap_plane_pre_apply':
drivers/gpu/drm/omapdrm/omap_plane.c:145:2: error: format '%x' expects argument of type 'unsigned int', but argument 5 has type 'dma_addr_t' [-Werror=format]
drivers/gpu/drm/omapdrm/omap_plane.c:145:2: error: format '%x' expects argument of type 'unsigned int', but argument 6 has type 'dma_addr_t' [-Werror=format]
make[5]: *** [drivers/gpu/drm/omapdrm/omap_plane.o] Error 1
drivers/gpu/drm/omapdrm/omap_gem.c: In function 'omap_gem_get_paddr':
drivers/gpu/drm/omapdrm/omap_gem.c:794:4: error: format '%x' expects argument of type 'unsigned int', but argument 3 has type 'dma_addr_t' [-Werror=format]
drivers/gpu/drm/omapdrm/omap_gem.c: In function 'omap_gem_describe':
drivers/gpu/drm/omapdrm/omap_gem.c:991:4: error: format '%Zx' expects argument of type 'size_t', but argument 7 has type 'dma_addr_t' [-Werror=format]
drivers/gpu/drm/omapdrm/omap_gem.c: In function 'omap_gem_init':
drivers/gpu/drm/omapdrm/omap_gem.c:1470:4: error: format '%x' expects argument of type 'unsigned int', but argument 7 has type 'dma_addr_t' [-Werror=format]
make[5]: *** [drivers/gpu/drm/omapdrm/omap_gem.o] Error 1
drivers/gpu/drm/omapdrm/omap_dmm_tiler.c: In function 'dmm_txn_append':
drivers/gpu/drm/omapdrm/omap_dmm_tiler.c:226:2: error: passing argument 3 of 'alloc_dma' from incompatible pointer type [-Werror]
make[5]: *** [drivers/gpu/drm/omapdrm/omap_dmm_tiler.o] Error 1
make[5]: Target `__build' not remade because of errors.
make[4]: *** [drivers/gpu/drm/omapdrm] Error 2
commit 9b5f7428f8b16bd8980213f2b70baf1dd0b9e36c upstream.
According to the comment “restore_es3: applies to 34xx >= ES3.0" in
"arch/arm/mach-omap2/sleep34xx.S”, omap3_restore_es3 should be used
if the revision of an OMAP34xx is ES3.1.2.
Signed-off-by: Jeremy Vial <jvial@adeneo-embedded.com>
commit 22b987a325701223f9a37db700c6eb20b9924c6f upstream.
Link must be reset in case the fw doesn't
respond to client disconnect request.
We did charge the timer only in irq path
from mei_cl_irq_close and not in mei_cl_disconnect
Signed-off-by: Alexander Usyskin <alexander.usyskin@intel.com>
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
commit f3ee07d8b6e061bf34a7167c3f564e8da4360a99 upstream.
ALC269 & co have many vendor-specific setups with COEF verbs.
However, some verbs seem specific to some codec versions and they
result in the codec stalling. Typically, such a case can be avoided
by checking the return value from reading a COEF. If the return value
is -1, it implies that the COEF is invalid, thus it shouldn't be
written.
This patch adds the invalid COEF checks in appropriate places
accessing ALC269 and its variants. The patch actually fixes the
resume problem on Acer AO725 laptop.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=52181
Tested-by: Francesco Muzio <muziofg@gmail.com>
commit f475371aa65de84fa483a998ab7594531026b9d9 upstream.
On some HP laptops, the mute led is controlled by codec gpio.
When some machine resume from s3/s4, the codec gpio data will be
cleared to 0 by BIOS:
Before suspend:
IO[3]: enable=1, dir=1, wake=0, sticky=0, data=1, unsol=0
After resume:
IO[3]: enable=1, dir=1, wake=0, sticky=0, data=0, unsol=0
To skip the AFG node to enter D3 can't fix this problem.
A workaround is to restore the gpio data when the system resume
back from s3/s4. It is safe even on the machines without this
problem.
BugLink: https://bugs.launchpad.net/bugs/1358116
Tested-by: Franz Hsieh <franz.hsieh@canonical.com>
Signed-off-by: Hui Wang <hui.wang@canonical.com>
commit 53da5ebfef66ea6e478ad9c6add3781472b79475 upstream.
The BOSS ME-25 turns out not to have any useful descriptors in its MIDI
interface, so its needs a quirk entry after all.
Reported-and-tested-by: Kees van Veen <kees.vanveen@gmail.com>
Fixes: 8e5ced83dd1c ("ALSA: usb-audio: remove superfluous Roland quirks")
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
commit e24aa0a4c5ac92a171d9dd74a8d3dbf652990d36 upstream.
CA0132 driver tries to reload the firmware at resume. Usually this
works since the firmware loader core caches the firmware contents by
itself. However, if the driver failed to load the firmwares
(e.g. missing files), reloading the firmware at resume goes through
the actual file loading code path, and triggers a kernel WARNING like:
WARNING: CPU: 10 PID:11371 at drivers/base/firmware_class.c:1105 _request_firmware+0x9ab/0x9d0()
For avoiding this situation, this patch makes CA0132 skipping the f/w
loading at resume when it failed at probe time.
Reported-and-tested-by: Janek Kozicki <cosurgi@gmail.com>
commit f42bb22243d2ae264d721b055f836059fe35321f upstream.
Just add the PCI ID for the STX II. It appears to work the same as the
STX, except for the addition of the not-yet-supported daughterboard.
Tested-by: Mario <fugazzi99@gmail.com>
Tested-by: corubba <corubba@gmx.de>
commit 7440850c20b69658f322119d20a94dc914127cc7 upstream.
ON the machine, two pin complex (0xb and 0xe) are both routed to
the same external right-side mic jack, this makes the jack can't work.
To fix this problem, set the 0xe to "not connected".
BugLink: https://bugs.launchpad.net/bugs/1350148
commit a40178b2fa6ad87670fb1e5fa4024db00c149629 upstream.
Problem Summary: Problem has been observed generally with PM states
where VBUS goes off during suspend. There are some SS USB devices which
take longer time for link training compared to many others. Such
devices fail to reconnect with same old address which was associated
with it before suspend.
When system resumes, at some point of time (dpm_run_callback->
usb_dev_resume->usb_resume->usb_resume_both->usb_resume_device->
usb_port_resume) SW reads hub status. If device is present,
then it finishes port resume and re-enumerates device with same
address. If device is not present then, SW thinks that device was
removed during suspend and therefore does logical disconnection
and removes all the resource allocated for this device.
Now, if I put sufficient delay just before root hub status read in
usb_resume_device then, SW sees always that device is present. In normal
course(without any delay) SW sees that no device is present and then SW
removes all resource associated with the device at this port. In the
latter case, after sometime, device says that hey I am here, now host
enumerates it, but with new address.
Problem had been reproduced when I connect verbatim USB3.0 hard disc
with my STiH407 XHCI host running with 3.10 kernel.
I see that similar problem has been reported here.
https://bugzilla.kernel.org/show_bug.cgi?id=53211
Reading above it seems that bug was not in 3.6.6 and was present in 3.8
and again it was not present for some in 3.12.6, while it was present
for few others. I tested with 3.13-FC19 running at i686 desktop, problem
was still there. However, I was failed to reproduce it with 3.16-RC4
running at same i686 machine. I would say it is just a random
observation. Problem for few devices is always there, as I am unable to
find a proper fix for the issue.
So, now question is what should be the amount of delay so that host is
always able to recognize suspended device after resume.
XHCI specs 4.19.4 says that when Link training is successful, port sets
CSC bit to 1. So if SW reads port status before successful link
training, then it will not find device to be present. USB Analyzer log
with such buggy devices show that in some cases device switch on the
RX termination after long delay of host enabling the VBUS. In few other
cases it has been seen that device fails to negotiate link training in
first attempt. It has been reported till now that few devices take as
long as 2000 ms to train the link after host enabling its VBUS and
RX termination. This patch implements a 2000 ms timeout for CSC bit to set
ie for link training. If in a case link trains before timeout, loop will
exit earlier.
This patch implements above delay, but only for SS device and when
persist is enabled.
So, for the good device overhead is almost none. While for the bad
devices penalty could be the time which it take for link training.
But, If a device was connected before suspend, and was removed
while system was asleep, then the penalty would be the timeout ie
2000 ms.
Results:
Verbatim USB SS hard disk connected with STiH407 USB host running 3.10
Kernel resumes in 461 msecs without this patch, but hard disk is
assigned a new device address. Same system resumes in 790 msecs with
this patch, but with old device address.
Signed-off-by: Pratyush Anand <pratyush.anand@st.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 6e693739e9b603b3ca9ce0d4f4178f0633458465 upstream.
The EHCI packet buffer in/out threshold is programmable for Intel Quark X1000
USB host controller, and the default value is 0x20 dwords. The in/out threshold
can be programmed to 0x80 dwords (512 Bytes) to maximize the perfomrance,
but only when isochronous/interrupt transactions are not initiated by the USB
host controller. This patch is to reconfigure the packet buffer in/out
threshold as maximal as possible to maximize the performance, and 0x7F dwords
(508 Bytes) should be used because the USB host controller initiates
isochronous/interrupt transactions.
Signed-off-by: Bryan O'Donoghue <bryan.odonoghue@intel.com>
Signed-off-by: Alvin (Weike) Chen <alvin.chen@intel.com>
Reviewed-by: Jingoo Han <jg1.han@samsung.com>
commit 4bdcde358b4bda74e356841d351945ca3f2245dd upstream.
This adds support for new Xsens devices, using Xsens' own Vendor ID.
Signed-off-by: Patrick Riphagen <patrick.riphagen@xsens.com>
Signed-off-by: Frans Klaver <frans.klaver@xsens.com>
Cc: Johan Hovold <johan@kernel.org>
commit 9273b8a270878906540349422ab24558b9d65716 upstream.
The converters are used in specific products. It can be useful to know
which they are exactly.
commit d310d05f1225d1f6f2bf505255fdf593bfbb3051 upstream.
usbfs allows user space to pass down an URB which sets URB_SHORT_NOT_OK
for output URBs. That causes usbcore to log messages without limit
for a nonsensical disallowed combination. The fix is to silently drop
the attribute in usbfs.
The problem is reported to exist since 3.14
https://www.virtualbox.org/ticket/13085
Signed-off-by: Oliver Neukum <oneukum@suse.de>
commit 977dcfdc60311e7aa571cabf6f39c36dde13339e upstream.
This patch fixes a bug in ohci-hcd. When an URB is unlinked, the
corresponding Endpoint Descriptor is added to the ed_rm_list and taken
off the hardware schedule. Once the ED is no longer visible to the
hardware, finish_unlinks() handles the URBs that were unlinked or have
completed. If any URBs remain attached to the ED, the ED is added
back to the hardware schedule -- but only if the controller is
running.
This fails when a controller dies. A non-empty ED does not get added
back to the hardware schedule and does not remain on the ed_rm_list;
ohci-hcd loses track of it. The remaining URBs cannot be unlinked,
which causes the USB stack to hang.
The patch changes finish_unlinks() so that non-empty EDs remain on
the ed_rm_list if the controller isn't running. This requires moving
some of the existing code around, to avoid modifying the ED's hardware
fields more than once.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
commit 256dbcd80f1ccf8abf421c1d72ba79a4e29941dd upstream.
The debug routine fill_async_buffer() in ohci-hcd is buggy: It never
produces any output because it forgets to initialize the output buffer
size. Also, the debug routine ohci_dump() has an unused argument.
This patch adds the correct initialization and removes the unused
argument.
commit 410dd3cf4c9b36f27ed4542ee18b1af5e68645a4 upstream.
We did not check relocated directory in any way when processing Rock
Ridge 'CL' tag. Thus a corrupted isofs image can possibly have a CL
entry pointing to another CL entry leading to possibly unbounded
recursion in kernel code and thus stack overflow or deadlocks (if there
is a loop created from CL entries).
Fix the problem by not allowing CL entry to point to a directory entry
with CL entry (such use makes no good sense anyway) and by checking
whether CL entry doesn't point to itself.
Reported-by: Chris Evans <cevans@google.com>
commit 4ab25786c87eb20857bbb715c3ae34ec8fd6a214 upstream.
There are a few very theoretical off-by-one bugs in report descriptor size
checking when performing a pre-parsing fixup. Fix those.
Reported-by: Ben Hawkes <hawkes@google.com>
Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
commit ad3e14d7c5268c2e24477c6ef54bbdf88add5d36 upstream.
device_index is a char type and the size of paired_dj_deivces is 7
elements, therefore proper bounds checking has to be applied to
device_index before it is used.
We are currently performing the bounds checking in
logi_dj_recv_add_djhid_device(), which is too late, as malicious device
could send REPORT_TYPE_NOTIF_DEVICE_UNPAIRED early enough and trigger the
problem in one of the report forwarding functions called from
logi_dj_raw_event().
Fix this by performing the check at the earliest possible ocasion in
commit c6bde215acfd637708142ae671843b6f0eadbc6d upstream.
This adds a pci_upstream_bridge() interface to find the PCI-to-PCI bridge
upstream from a device. This is typically just "dev->bus->self", but in
the case of a VF on a virtual bus, we have to start from the corresponding
PF. Returns NULL if there is no upstream PCI bridge, i.e., if the device
is on a root bus.
Acked-by: Yinghai Lu <yinghai@kernel.org>
commit cbcd1054a1fd2aa980fc11ff28e436fc4aaa2d54 upstream.
Commit 08778795 ("block: Fix nr_vecs for inline integrity vectors") from
Martin introduces the function bip_integrity_vecs(get the useful vectors)
to fix the issue about nr_vecs for inline integrity vectors that reported
by David Milburn.
But it seems that bip_integrity_vecs() will return the wrong number if the
bio is not based on any bio_set for some reason(bio->bi_pool == NULL),
because in that case, the bip_inline_vecs[0] is malloced directly. So
here we add the bip_max_vcnt to record the count of vector slots, and
cleanup the function bip_integrity_vecs().
Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com>
Cc: Martin K. Petersen <martin.petersen@oracle.com>
Cc: Kent Overstreet <kmo@daterainc.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
commit 84c91b7ae07c62cf6dee7fde3277f4be21331f85 upstream.
When the machine doesn't well handle the e820 persistent when hibernate
resuming, then it may cause page fault when writing image to snapshot
buffer:
[ 17.929495] BUG: unable to handle kernel paging request at ffff880069d4f000
[ 17.933469] IP: [<ffffffff810a1cf0>] load_image_lzo+0x810/0xe40
[ 17.933469] PGD 2194067 PUD 77ffff067 PMD 2197067 PTE 0
[ 17.933469] Oops: 0002 [#1] SMP
The ffff880069d4f000 page is in e820 reserved region of resume boot
kernel:
[ 0.000000] BIOS-e820: [mem 0x0000000069d4f000-0x0000000069e12fff] reserved
[ 0.000000] PM: Registered nosave memory: [mem 0x69d4f000-0x69e12fff]
So snapshot.c mark the pfn to forbidden pages map. But, this
page is also in the memory bitmap in snapshot image because it's an
original page used by image kernel, so it will also mark as an
unsafe(free) page in prepare_image().
That means the page in e820 when resuming mark as "forbidden" and
"free", it causes get_buffer() treat it as an allocated unsafe page.
Then snapshot_write_next() return this page to load_image, load_image
writing content to this address, but this page didn't really allocated
. So, we got page fault.
Although the root cause is from BIOS, I think aggressive check and
significant message in kernel will better then a page fault for
issue tracking, especially when serial console unavailable.
This patch adds code in mark_unsafe_pages() for check does free pages in
nosave region. If so, then it print message and return fault to stop whole
S4 resume process:
[ 8.166004] PM: Image loading progress: 0%
[ 8.658717] PM: 0x6796c000 in e820 nosave region: [mem 0x6796c000-0x6796cfff]
[ 8.918737] PM: Read 2511940 kbytes in 1.04 seconds (2415.32 MB/s)
[ 8.926633] PM: Error -14 resuming
[ 8.933534] PM: Failed to load hibernation image, recovering.
Reviewed-by: Takashi Iwai <tiwai@suse.de>
Acked-by: Pavel Machek <pavel@ucw.cz>
Signed-off-by: Lee, Chun-Yi <jlee@suse.com>
[rjw: Subject]
