commit 895162b1101b3ea5db08ca6822ae9672717efec0 upstream.
else we may fail to forward skb even if original fragments do fit
outgoing link mtu:
1. remote sends 2k packets in two 1000 byte frags, DF set
2. we want to forward but only see '2k > mtu and DF set'
3. we then send icmp error saying that outgoing link is 1500
But original sender never sent a packet that would not fit
the outgoing link.
Setting local_df makes outgoing path test size vs.
IPCB(skb)->frag_max_size, so we will still send the correct
error in case the largest original size did not fit
outgoing link mtu.
Reported-by: Maxime Bizon <mbizon@freebox.fr>
Suggested-by: Maxime Bizon <mbizon@freebox.fr>
Fixes: 5f2d04f1f9 (ipv4: fix path MTU discovery with connection tracking)
commit 54a217887a7b658e2650c3feff22756ab80c7339 upstream.
The current implementation of lookup_pi_state has ambigous handling of
the TID value 0 in the user space futex. We can get into the kernel
even if the TID value is 0, because either there is a stale waiters bit
or the owner died bit is set or we are called from the requeue_pi path
or from user space just for fun.
The current code avoids an explicit sanity check for pid = 0 in case
that kernel internal state (waiters) are found for the user space
address. This can lead to state leakage and worse under some
circumstances.
Handle the cases explicit:
Waiter | pi_state | pi->owner | uTID | uODIED | ?
[1] NULL | --- | --- | 0 | 0/1 | Valid
[2] NULL | --- | --- | >0 | 0/1 | Valid
[3] Found | NULL | -- | Any | 0/1 | Invalid
[4] Found | Found | NULL | 0 | 1 | Valid
[5] Found | Found | NULL | >0 | 1 | Invalid
[6] Found | Found | task | 0 | 1 | Valid
[7] Found | Found | NULL | Any | 0 | Invalid
[8] Found | Found | task | ==taskTID | 0/1 | Valid
[9] Found | Found | task | 0 | 0 | Invalid
[10] Found | Found | task | !=taskTID | 0/1 | Invalid
[1] Indicates that the kernel can acquire the futex atomically. We
came came here due to a stale FUTEX_WAITERS/FUTEX_OWNER_DIED bit.
[2] Valid, if TID does not belong to a kernel thread. If no matching
thread is found then it indicates that the owner TID has died.
[3] Invalid. The waiter is queued on a non PI futex
[4] Valid state after exit_robust_list(), which sets the user space
value to FUTEX_WAITERS | FUTEX_OWNER_DIED.
[5] The user space value got manipulated between exit_robust_list()
and exit_pi_state_list()
[6] Valid state after exit_pi_state_list() which sets the new owner in
the pi_state but cannot access the user space value.
[7] pi_state->owner can only be NULL when the OWNER_DIED bit is set.
[8] Owner and user space value match
[9] There is no transient state which sets the user space TID to 0
except exit_robust_list(), but this is indicated by the
FUTEX_OWNER_DIED bit. See [4]
[10] There is no transient state which leaves owner and user space
TID out of sync.
Cc: Will Drewry <wad@chromium.org>
Cc: Darren Hart <dvhart@linux.intel.com>
commit 13fbca4c6ecd96ec1a1cfa2e4f2ce191fe928a5e upstream.
If the owner died bit is set at futex_unlock_pi, we currently do not
cleanup the user space futex. So the owner TID of the current owner
(the unlocker) persists. That's observable inconsistant state,
especially when the ownership of the pi state got transferred.
Clean it up unconditionally.
commit b3eaa9fc5cd0a4d74b18f6b8dc617aeaf1873270 upstream.
We need to protect the atomic acquisition in the kernel against rogue
user space which sets the user space futex to 0, so the kernel side
acquisition succeeds while there is existing state in the kernel
associated to the real owner.
Verify whether the futex has waiters associated with kernel state. If
it has, return -EINVAL. The state is corrupted already, so no point in
cleaning it up. Subsequent calls will fail as well. Not our problem.
[ tglx: Use futex_top_waiter() and explain why we do not need to try
restoring the already corrupted user space state. ]
Signed-off-by: Darren Hart <dvhart@linux.intel.com>
in futex_requeue(..., requeue_pi=1)
commit e9c243a5a6de0be8e584c604d353412584b592f8 upstream.
If uaddr == uaddr2, then we have broken the rule of only requeueing from
a non-pi futex to a pi futex with this call. If we attempt this, then
dangling pointers may be left for rt_waiter resulting in an exploitable
condition.
This change brings futex_requeue() in line with futex_wait_requeue_pi()
which performs the same check as per commit 6f7b0a2a5c0f ("futex: Forbid
uaddr == uaddr2 in futex_wait_requeue_pi()")
[ tglx: Compare the resulting keys as well, as uaddrs might be
different depending on the mapping ]
Fixes CVE-2014-3153.
Reported-by: Pinkie Pie
Signed-off-by: Will Drewry <wad@chromium.org>
Reviewed-by: Darren Hart <dvhart@linux.intel.com>
commit 97d9d23dda6f37d90aefeec4ed619d52df525382 upstream.
If a struct contains 64-bit fields, it is aligned on 64-bit boundaries
within containing structs in 64-bit compilations. This is the case with
struct v4l2_window, which contains pointers and is embedded into struct
v4l2_format, and that one is embedded into struct v4l2_create_buffers.
Unlike some other structs, used as a part of the kernel ABI as ioctl()
arguments, that are packed, these structs aren't packed. This isn't a
problem per se, but the ioctl-compat code for VIDIOC_CREATE_BUFS contains
a bug, that triggers in such 64-bit builds. That code wrongly assumes,
that in struct v4l2_create_buffers, struct v4l2_format immediately follows
the __u32 memory field, which in fact isn't the case. This bug wasn't
visible until now, because until recently hardly any applications used
this ioctl() and mostly embedded 32-bit only drivers implemented it. This
is changing now with addition of this ioctl() to some USB drivers, e.g.
UVC. This patch fixes the bug by copying parts of struct
v4l2_create_buffers separately.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
user-space
commit cfece5857ca51d1dcdb157017aba226f594e9dcf upstream.
Commit 75e2bdad8901a0b599e01a96229be922eef1e488 "ov7670: allow
configuration of image size, clock speed, and I/O method" uses a wrong
index to iterate an array. Apart from being wrong, it also uses an
unchecked value from user-space, which can cause access to unmapped
memory in the kernel, triggered by a normal desktop user with rights to
use V4L2 devices.
Acked-by: Jonathan Corbet <corbet@lwn.net>
commit 8845cc6415ec28ef8d57b3fb81c75ef9bce69c5f upstream.
There was some frequency calculation overflows which caused tuning
failure on 32-bit architecture. Use 64-bit numbers where needed in
order to avoid calculation overflows.
Thanks for the Finnish person, who asked remain anonymous, reporting,
testing and suggesting the fix.
Signed-off-by: Antti Palosaari <crope@iki.fi>
commit e028a9e6b8a637af09ac4114083280df4a7045f1 upstream.
An apparent cut and paste error prevents the correct flags from being
set on the alias device resulting in MSI on conventional PCI devices
failing to work. This also produces error events from the IOMMU like:
AMD-Vi: Event logged [INVALID_DEVICE_REQUEST device=00:14.4 address=0x000000fdf8000000 flags=0x0a00]
Where 14.4 is a PCIe-to-PCI bridge with a device behind it trying to
use MSI interrupts.
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
Signed-off-by: Joerg Roedel <joro@8bytes.org>
commit 178eda29ca721842f2146378e73d43e0044c4166 upstream.
It has been reported that using ZFSonLinux on rbd will result in memory
corruption. The bug report can be found here:
https://github.com/zfsonlinux/spl/issues/241
http://tracker.ceph.com/issues/7790
The reason is that ZFS will send pages with page_count 0 into rbd, which in
turns send them to tcp_sendpage. However, tcp_sendpage cannot deal with
page_count 0, as it will do get_page and put_page, and erroneously free the
page.
This type of issue has been noted before, and handled in iscsi, drbd,
etc. So, rbd should also handle this. This fix address this issue by fall back
to slower sendmsg when page_count 0 detected.
Cc: Sage Weil <sage@inktank.com>
Cc: Yehuda Sadeh <yehuda@inktank.com>
Signed-off-by: Chunwei Chen <tuxoko@gmail.com>
Reviewed-by: Ilya Dryomov <ilya.dryomov@inktank.com>
commit 83596fbeb5d28e8cb8878786133945d4dc7c0090 upstream.
The availability of SPI Dual or Quad Transfer Mode as indicated by the
"spi-tx-bus-width" and "spi-rx-bus-width" properties in the device tree is
a hardware property of the SPI master, SPI slave, and board wiring. Hence
the SPI core should not reject an SPI slave because an SPI master driver
doesn't (yet) support Dual or Quad Transfer Mode.
Change the lack of Dual or Quad Transfer Mode support in the SPI master
driver from an error condition to a warning condition, and ignore the
unsupported mode bits, falling back to Single Transfer Mode, to avoid
breakages when running old kernels with new device trees.
Fixes: f477b7fb13df (spi: DUAL and QUAD support)
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Signed-off-by: Mark Brown <broonie@linaro.org>
commit 011e4b02f1da156ac7fea28a9da878f3c23af739 upstream.
If we try to perform a kexec when the machine is in ST (Single-Threaded) mode
(ppc64_cpu --smt=off), the kexec operation doesn't succeed properly, and we
get the following messages during boot:
[ 0.089866] POWER8 performance monitor hardware support registered
[ 0.089985] power8-pmu: PMAO restore workaround active.
[ 5.095419] Processor 1 is stuck.
[ 10.097933] Processor 2 is stuck.
[ 15.100480] Processor 3 is stuck.
[ 20.102982] Processor 4 is stuck.
[ 25.105489] Processor 5 is stuck.
[ 30.108005] Processor 6 is stuck.
[ 35.110518] Processor 7 is stuck.
[ 40.113369] Processor 9 is stuck.
[ 45.115879] Processor 10 is stuck.
[ 50.118389] Processor 11 is stuck.
[ 55.120904] Processor 12 is stuck.
[ 60.123425] Processor 13 is stuck.
[ 65.125970] Processor 14 is stuck.
[ 70.128495] Processor 15 is stuck.
[ 75.131316] Processor 17 is stuck.
Note that only the sibling threads are stuck, while the primary threads (0, 8,
16 etc) boot just fine. Looking closer at the previous step of kexec, we observe
that kexec tries to wakeup (bring online) the sibling threads of all the cores,
before performing kexec:
[ 9464.131231] Starting new kernel
[ 9464.148507] kexec: Waking offline cpu 1.
[ 9464.148552] kexec: Waking offline cpu 2.
[ 9464.148600] kexec: Waking offline cpu 3.
[ 9464.148636] kexec: Waking offline cpu 4.
[ 9464.148671] kexec: Waking offline cpu 5.
[ 9464.148708] kexec: Waking offline cpu 6.
[ 9464.148743] kexec: Waking offline cpu 7.
[ 9464.148779] kexec: Waking offline cpu 9.
[ 9464.148815] kexec: Waking offline cpu 10.
[ 9464.148851] kexec: Waking offline cpu 11.
[ 9464.148887] kexec: Waking offline cpu 12.
[ 9464.148922] kexec: Waking offline cpu 13.
[ 9464.148958] kexec: Waking offline cpu 14.
[ 9464.148994] kexec: Waking offline cpu 15.
[ 9464.149030] kexec: Waking offline cpu 17.
Instrumenting this piece of code revealed that the cpu_up() operation actually
fails with -EBUSY. Thus, only the primary threads of all the cores are online
during kexec, and hence this is a sure-shot receipe for disaster, as explained
in commit e8e5c2155b (powerpc/kexec: Fix orphaned offline CPUs across kexec),
as well as in the comment above wake_offline_cpus().
It turns out that cpu_up() was returning -EBUSY because the variable
'cpu_hotplug_disabled' was set to 1; and this disabling of CPU hotplug was done
by migrate_to_reboot_cpu() inside kernel_kexec().
Now, migrate_to_reboot_cpu() was originally written with the assumption that
any further code will not need to perform CPU hotplug, since we are anyway in
the reboot path. However, kexec is clearly not such a case, since we depend on
onlining CPUs, atleast on powerpc.
So re-enable cpu-hotplug after returning from migrate_to_reboot_cpu() in the
kexec path, to fix this regression in kexec on powerpc.
Also, wrap the cpu_up() in powerpc kexec code within a WARN_ON(), so that we
can catch such issues more easily in the future.
Fixes: c97102ba963 (kexec: migrate to reboot cpu)
Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
commit 7998eb3dc700aaf499f93f50b3d77da834ef9e1d upstream.
With binutils 2.24, various 64 bit builds fail with relocation errors
such as
arch/powerpc/kernel/built-in.o: In function `exc_debug_crit_book3e':
(.text+0x165ee): relocation truncated to fit: R_PPC64_ADDR16_HI
against symbol `interrupt_base_book3e' defined in .text section
in arch/powerpc/kernel/built-in.o
(.text+0x16602): relocation truncated to fit: R_PPC64_ADDR16_HI
against symbol `interrupt_end_book3e' defined in .text section
The assembler maintainer says:
I changed the ABI, something that had to be done but unfortunately
happens to break the booke kernel code. When building up a 64-bit
value with lis, ori, shl, oris, ori or similar sequences, you now
should use @high and @higha in place of @h and @ha. @h and @ha
(and their associated relocs R_PPC64_ADDR16_HI and R_PPC64_ADDR16_HA)
now report overflow if the value is out of 32-bit signed range.
ie. @h and @ha assume you're building a 32-bit value. This is needed
to report out-of-range -mcmodel=medium toc pointer offsets in @toc@h
and @toc@ha expressions, and for consistency I did the same for all
other @h and @ha relocs.
Replacing @h with @high in one strategic location fixes the relocation
errors. This has to be done conditionally since the assembler either
supports @h or @high but not both.
commit 372cf1244d7c271806b83b32b09a1c8b1b31b353 upstream.
Resetting root port has more stuff to do than that for PCIe switch
ports and we should have resetting root port done in firmware instead
of the kernel itself. The problem was introduced by commit 5b2e198e
("powerpc/powernv: Rework EEH reset").
Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com>
commit 27c5fb7a84242b66bf1e0b2fe6bf40d19bcc5c04 upstream.
GFP_ATOMIC memory allocation could fail.
In this case, avoid NULL pointer dereference and notify user.
Cc: Kim Phillips <kim.phillips@freescale.com>
Signed-off-by: Horia Geanta <horia.geanta@freescale.com>
commit ce78cc071f5f541480e381cc0241d37590041a9d upstream.
Don't unmark the device as suspended until after it's been re-setup.
The main race would be w.r.t. an i2c driver that gets resumed at the same
time (asyncronously), that is allowed to do a transfer since suspended
is set to 0 before reinit, but really should have seen the -EIO return
instead.
Signed-off-by: Doug Anderson <dianders@chromium.org>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
commit 47bb27e78867997040a228328f2a631c3c7f2c82 upstream.
There have been "i2c_designware 80860F41:00: controller timed out" errors
on a number of Baytrail platforms. The issue is caused by incorrect value in
Interrupt Mask Register (DW_IC_INTR_MASK) when i2c core is being enabled.
This causes call to __i2c_dw_enable() to immediately start the transfer which
leads to timeout. There are 3 failure modes observed:
1. Failure in S0 to S3 resume path
The default value after reset for DW_IC_INTR_MASK is 0x8ff. When we start
the first transaction after resuming from system sleep, TX_EMPTY interrupt
is already unmasked because of the hardware default.
2. Failure in normal operational path
This failure happens rarely and is hard to reproduce. Debug trace showed that
DW_IC_INTR_MASK had value of 0x254 when failure occurred, which meant
TX_EMPTY was unmasked.
3. Failure in S3 to S0 suspend path
This failure also happens rarely and is hard to reproduce. Adding debug trace
that read DW_IC_INTR_MASK made this failure not reproducible. But from ISR
call trace we could conclude TX_EMPTY was unmasked when problem occurred.
The patch masks all interrupts before the controller is enabled to resolve the
faulty DW_IC_INTR_MASK conditions.
Signed-off-by: Wenkai Du <wenkai.du@intel.com>
Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com>
[wsa: improved the comment and removed typo in commit msg]
commit d7653964c590ba846aa11a8f6edf409773cbc492 upstream.
This hardware does not support zero length transfers. Instead, the
driver does one (random) byte transfers currently with undefined results
for the slaves. We now bail out.
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
commit b753631b3576bf343151a82513c5d56fcda1e24f upstream.
With win8 capabiltiy, the machine will boot itself immediately after
shutdown command has executed.
Work around this issue by disabling win8 capcability. This workaround
also makes wireless hotkey work.
Signed-off-by: Edward Lin <yidi.lin@canonical.com>
commit 0b9d46dd7debf8e6dc8614106f1c1909fa8de64d upstream.
acpi_processor_add() assumes that present at boot CPUs
are always onlined, it is not so if a CPU failed to become
onlined. As result acpi_processor_add() will mark such CPU
device as onlined in sysfs and following attempts to
online/offline it using /sys/device/system/cpu/cpuX/online
attribute will fail.
Do not poke into device internals in acpi_processor_add()
and touch "struct device { .offline }" attribute, since
for CPUs onlined at boot it's set by:
topology_init() -> arch_register_cpu() -> register_cpu()
before ACPI device tree is parsed, and for hotplugged
CPUs it's set when userspace onlines CPU via sysfs.
Signed-off-by: Igor Mammedov <imammedo@redhat.com>
Acked-by: Toshi Kani <toshi.kani@hp.com>
commit f6e6e1b9fee88c90586787b71dc49bb3ce62bb89 upstream.
Without this this EEE PC exports a non working WMI interface, with this it
exports a working "good old" eeepc_laptop interface, fixing brightness control
not working as well as rfkill being stuck in a permanent wireless blocked
state.
This is not an ideal way to fix this, but various attempts to fix this
otherwise have failed, see:
References: https://bugzilla.redhat.com/show_bug.cgi?id=1067181
Reported-and-tested-by: lou.cardone@gmail.com
commit a6f9bf4d2f965b862b95213303d154e02957eed8 upstream.
When a ZPODD device is unbound via sysfs, the ACPI notify handler
is not removed. This causes panics as observed in Bug #74601. The
panic only happens when the wake happens from outside the kernel
(i.e. inserting a media or pressing a button). Add a loop to
ata_port_detach which loops through the port's devices and checks
if zpodd is enabled, if so call zpodd_exit.
Reviewed-by: Aaron Lu <aaron.lu@intel.com>
Signed-off-by: Levente Kurusa <levex@linux.com>
commit 97977f7576a89cb9436c000ae703c0d515e748ac upstream.
The commit dbde5c29 "dw_dmac: use devm_* functions to simplify code" turns
probe function to use devm_* helpers and simultaneously brings a regression. We
need to ensure irq is disabled, followed by ensuring that don't schedule any
more tasklets and then its safe to use tasklet_kill().
The free_irq() will ensure that the irq is disabled and also wait till all
scheduled interrupts are executed by invoking synchronize_irq(). So we need to
only do tasklet_kill() after invoking free_irq().
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
commit 5a9a55bf9157d3490b0c8c4c81d4708602c26e07 upstream.
We need to use writel() instead of writel_relaxed() when starting
a channel, to ensure all the descriptors have been flushed before
the activation.
While at it, remove the unneeded read-modify-write and make the
code simpler.
Signed-off-by: Lior Amsalem <alior@marvell.com>
Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
commit 610f2de3559c383caf8fbbf91e9968102dff7ca0 upstream.
The DM crypt target used per-cpu structures to hold pointers to a
ablkcipher_request structure. The code assumed that the work item keeps
executing on a single CPU, so it didn't use synchronization when
accessing this structure.
If a CPU is disabled by writing 0 to /sys/devices/system/cpu/cpu*/online,
the work item could be moved to another CPU. This causes dm-crypt
crashes, like the following, because the code starts using an incorrect
ablkcipher_request:
smpboot: CPU 7 is now offline
BUG: unable to handle kernel NULL pointer dereference at 0000000000000130
IP: [<ffffffffa1862b3d>] crypt_convert+0x12d/0x3c0 [dm_crypt]
Call Trace:
[<ffffffffa1864415>] ? kcryptd_crypt+0x305/0x470 [dm_crypt]
[<ffffffff81062060>] ? finish_task_switch+0x40/0xc0
[<ffffffff81052a28>] ? process_one_work+0x168/0x470
[<ffffffff8105366b>] ? worker_thread+0x10b/0x390
[<ffffffff81053560>] ? manage_workers.isra.26+0x290/0x290
[<ffffffff81058d9f>] ? kthread+0xaf/0xc0
[<ffffffff81058cf0>] ? kthread_create_on_node+0x120/0x120
[<ffffffff813464ac>] ? ret_from_fork+0x7c/0xb0
Fix this bug by removing the per-cpu definition. The structure
ablkcipher_request is accessed via a pointer from convert_context.
Consequently, if the work item is rescheduled to a different CPU, the
thread still uses the same ablkcipher_request.
This change may undermine performance improvements intended by commit
c0297721 ("dm crypt: scale to multiple cpus") on select hardware. In
practice no performance difference was observed on recent hardware. But
regardless, correctness is more important than performance.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
This is commit 0f540c3a7cfb91c9d7a19eb0c95c24 upstream.
Since
commit ee1452d7458451a7508e0663553ce88d63958157
Author: Jani Nikula <jani.nikula@intel.com>
Date: Fri Sep 20 15:05:30 2013 +0300
drm/i915: assume all GM45 Acer laptops use inverted backlight PWM
failed and was later reverted in
commit be505f643925e257087247b996cd8ece787c12af
Author: Alexander van Heukelum <heukelum@fastmail.fm>
Date: Sat Dec 28 21:00:39 2013 +0100
Revert "drm/i915: assume all GM45 Acer laptops use inverted backlight PWM"
fix the individual broken machine instead.
Note to backporters:
http://patchwork.freedesktop.org/patch/17837/
is the patch you want for 3.13 and older.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=54171
Reference: http://mid.gmane.org/DUB115-W7628C7C710EA51AA110CD4A5000@phx.gbl
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
[danvet: Patch mangling for 3.14 plus adding the link to the original
for 3.13.]
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
This is commit df6f783a4ef6790780a67c491897ac upstream.
On non-LLC platforms, when changing the cache level of an object, we may
need to unbind it so that prefetching across page boundaries does not
cross into a different memory domain. This requires us to unbind
conflicting vma, but we did so iterating over the objects vma in an
unsafe manner (as the list was being modified as we iterated).
The regression was introduced in
commit 3089c6f239d7d2c4cb2dd5c353e8984cf79af1d7
Author: Ben Widawsky <ben@bwidawsk.net>
Date: Wed Jul 31 17:00:03 2013 -0700
drm/i915: make caching operate on all address spaces
apparently as far back as v3.12-rc1, but it has only just begun to
trigger real world bug reports.
Reported-and-tested-by: Nikolay Martynov <mar.kolya@gmail.com>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=76384
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Ben Widawsky <ben@bwidawsk.net>
This is commit 2ab1bc9df01dbc19b55b2271100db7 upstream.
Apparently it doesn't work. X-tiled self-refresh works flawlessly
otoh. Apparently X still works correctly with linear framebuffers, so
might just be an issue with the initial modeset. It's unclear whether
this just borked wm setup from our side or a hw restriction, but just
disabling gets things going.
Note that this regression was only brought to light with
commit 3f2dc5ac05714711fc14f2bf0ee5e42d5c08c581
Author: Ville Syrjälä <ville.syrjala@linux.intel.com>
Date: Fri Jan 10 14:06:47 2014 +0200
drm/i915: Fix 915GM self-refresh enable/disable
before that self-refresh for i915GM didn't work at all.
Kudos to Ville for spotting a little bug in the original patch I've
attached to the bug.
Cc: Ville Syrjälä <ville.syrjala@linux.intel.com>
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=76103
Tested-by: Krzysztof Mazur <krzysiek@podlesie.net>
Cc: Krzysztof Mazur <krzysiek@podlesie.net>
[Jani: rebase on top of drm-next with primary plane support.]
commit 1e1110c43b1cda9fe77fc4a04835e460550e6b3c upstream.
On each processed XCOPY command, two "kmalloc-512" memory objects are
leaked. These represent two allocations of struct xcopy_pt_cmd in
target_core_xcopy.c.
The reason for the memory leak is that the cmd_kref field is not
initialized (thus, it is zero because the allocations were done with
kzalloc). When we decrement zero kref in target_put_sess_cmd, the result
is not zero, thus target_release_cmd_kref is not called.
This patch fixes the bug by moving kref initialization from
target_get_sess_cmd to transport_init_se_cmd (this function is called from
target_core_xcopy.c, so it will correctly initialize cmd_kref). It can be
easily verified that all code that calls target_get_sess_cmd also calls
transport_init_se_cmd earlier, thus moving kref_init shouldn't introduce
any new problems.
commit 07b8dae38b09bcfede7e726f172e39b5ce8390d9 upstream.
Just like for pSCSI, if the transport sets get_write_cache, then it is
not valid to enable write cache emulation for it. Return an error.
see https://bugzilla.redhat.com/show_bug.cgi?id=1082675
Reviewed-by: Chris Leech <cleech@redhat.com>
Signed-off-by: Andy Grover <agrover@redhat.com>
commit 7cbfcc953789ff864c2bf8365a82a3fba4869649 upstream.
This patch changes an incorrect use of BUG_ON to instead generate a
REJECT + PROTOCOL_ERROR in iscsit_process_nop_out() code. This case
can occur with traditional TCP where a flood of zeros in the data
stream can reach this block for what is presumed to be a NOP-OUT with
a solicited reply, but without a valid iscsi_cmd pointer.
This incorrect BUG_ON was introduced during the v3.11-rc timeframe
with the following commit:
commit 778de368964c5b7e8100cde9f549992d521e9c89
Author: Nicholas Bellinger <nab@linux-iscsi.org>
Date: Fri Jun 14 16:07:47 2013 -0700
iscsi/isert-target: Refactor ISCSI_OP_NOOP RX handling
Reported-by: Arshad Hussain <arshad.hussain@calsoftinc.com>
commit 531b7bf4bd795d9a09eac92504322a472c010bc8 upstream.
RDMA CM and iSCSI target flows are asynchronous and completely
uncorrelated. Relying on the fact that iscsi_accept_np will be called
after CM connection request event and will wait for it is a mistake.
When attempting to login to a few targets this flow is racy and
unpredictable, but for parallel login to dozens of targets will
race and hang every time.
The correct synchronizing mechanism in this case is pending on
a semaphore rather than a wait_for_event. We keep the pending
interruptible for iscsi_np cleanup stage.
(Squash patch to remove dead code into parent - nab)
Reported-by: Slava Shwartsman <valyushash@gmail.com>
Signed-off-by: Sagi Grimberg <sagig@mellanox.com>
commit 9fe63c88b1d59f1ce054d6948ccd3096496ecedb upstream.
Should be adding list_add_tail($new, $head) and not
the other way around.
commit 93fa9d32670f5592c8e56abc9928fc194e1e72fc upstream.
When a new device is added below a hotplug bridge, the bridge's secondary
bus speed and the device's bus speed must match. The shpchp driver
previously checked the bridge's *primary* bus speed, not the secondary bus
speed.
This caused hot-add errors like:
shpchp 0000:00:03.0: Speed of bus ff and adapter 0 mismatch
Check the secondary bus speed instead.
[bhelgaas: changelog]
Link: https://bugzilla.kernel.org/show_bug.cgi?id=75251
Fixes: 3749c51ac6c1 ("PCI: Make current and maximum bus speeds part of the PCI core")
Signed-off-by: Marcel Apfelbaum <marcel.a@redhat.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
commit 4c88d7f9b0d5fb0588c3386be62115cc2eaa8f9f upstream.
Patch 01f8fa4f01d "genirq: Allow forcing cpu affinity of interrupts" added
an irq_force_affinity() function, and 30ccf03b4a6 "clocksource: Exynos_mct:
Use irq_force_affinity() in cpu bringup" subsequently uses it. However, the
driver can be used with CONFIG_SMP disabled, but the function declaration
is only available for CONFIG_SMP, leading to this build error:
drivers/clocksource/exynos_mct.c:431:3: error: implicit declaration of function 'irq_force_affinity' [-Werror=implicit-function-declaration]
irq_force_affinity(mct_irqs[MCT_L0_IRQ + cpu], cpumask_of(cpu));
This patch introduces a dummy helper function for the non-SMP case
that always returns success, to get rid of the build error.
Since the patches causing the problem are marked for stable backports,
this one should be as well.
Cc: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Link: http://lkml.kernel.org/r/5619084.0zmrrIUZLV@wuerfel
commit fa81511bb0bbb2b1aace3695ce869da9762624ff upstream.
Checkin:
b3b42ac2cbae x86-64, modify_ldt: Ban 16-bit segments on 64-bit kernels
disabled 16-bit segments on 64-bit kernels due to an information
leak. However, it does seem that people are genuinely using Wine to
run old 16-bit Windows programs on Linux.
A proper fix for this ("espfix64") is coming in the upcoming merge
window, but as a temporary fix, create a sysctl to allow the
administrator to re-enable support for 16-bit segments.
It adds a "/proc/sys/abi/ldt16" sysctl that defaults to zero (off). If
you hit this issue and care about your old Windows program more than
you care about a kernel stack address information leak, you can do
echo 1 > /proc/sys/abi/ldt16
as root (add it to your startup scripts), and you should be ok.
The sysctl table is only added if you have COMPAT support enabled on
x86-64, but I assume anybody who runs old windows binaries very much
does that ;)
Link: http://lkml.kernel.org/r/CA%2B55aFw9BPoD10U1LfHbOMpHWZkvJTkMcfCs9s3urPr1YyWBxw@mail.gmail.com
commit d71f290b4e98a39f49f2595a13be3b4d5ce8e1f1 upstream.
Specify the maximum stack size for arches where the stack grows upward
(parisc and metag) in asm/processor.h rather than hard coding in
fs/exec.c so that metag can specify a smaller value of 256MB rather than
1GB.
This fixes a BUG on metag if the RLIMIT_STACK hard limit is increased
beyond a safe value by root. E.g. when starting a process after running
"ulimit -H -s unlimited" it will then attempt to use a stack size of the
maximum 1GB which is far too big for metag's limited user virtual
address space (stack_top is usually 0x3ffff000):
BUG: failure at fs/exec.c:589/shift_arg_pages()!
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Cc: Helge Deller <deller@gmx.de>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: linux-parisc@vger.kernel.org
Cc: linux-metag@vger.kernel.org
Cc: John David Anglin <dave.anglin@bell.net>
commit 2425ce84026c385b73ae72039f90d042d49e0394 upstream.
Volatile access doesn't really imply the compiler barrier. Volatile access
is only ordered with respect to other volatile accesses, it isn't ordered
with respect to general memory accesses. Gcc may reorder memory accesses
around volatile access, as we can see in this simple example (if we
compile it with optimization, both increments of *b will be collapsed to
just one):
void fn(volatile int *a, long *b)
(*b)++;
*a = 10;
(*b)++;
Consequently, we need the compiler barrier after a write to the volatile
variable, to make sure that the compiler doesn't reorder the volatile
write with something else.
Acked-by: Peter Zijlstra <peterz@infradead.org>
commit 44330ab516c15dda8a1e660eeaf0003f84e43e3f upstream.
The register CLASS_D_CONTROL_1 is marked as volatile because it contains
a bit, DAC_MUTE, which is also mirrored in the ADC_DAC_CONTROL_1
register. This causes problems for the "Speaker Switch" control, which
will report an error if the CODEC is suspended because it relies on a
volatile register.
To resolve this issue mark CLASS_D_CONTROL_1 as non-volatile and
manually keep the register cache in sync by updating both bits when
changing the mute status.
Reported-by: Shawn Guo <shawn.guo@linaro.org>
Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
Tested-by: Shawn Guo <shawn.guo@linaro.org>
commit 5a838c3b60e3a36ade764cf7751b8f17d7c9c2da upstream.
pcpu_chunk_struct_size = sizeof(struct pcpu_chunk) +
BITS_TO_LONGS(pcpu_unit_pages) * sizeof(unsigned long)
It hardly could be ever bigger than PAGE_SIZE even for large-scale machine,
but for consistency with its couterpart pcpu_mem_zalloc(),
use pcpu_mem_free() instead.
Commit b4916cb17c26 ("percpu: make pcpu_free_chunk() use
pcpu_mem_free() instead of kfree()") addressed this problem, but
missed this one.
tj: commit message updated
Signed-off-by: Jianyu Zhan <nasa4836@gmail.com>
Fixes: 099a19d91ca4 ("percpu: allow limited allocation before slab is online)
commit b566e782be32145664d96ada3e389f17d32742e5 upstream.
Having multiple windows with the same target and attribute is actually
legal, and can be useful for PCIe windows, when PCIe BARs have a size
that isn't a power of two, and we therefore need to create several
MBus windows to cover the PCIe BAR for a given PCIe interface.
Fixes: fddddb52a6c4 ('bus: introduce an Marvell EBU MBus driver')
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Link: https://lkml.kernel.org/r/1397823593-1932-7-git-send-email-thomas.petazzoni@free-electrons.com
Tested-by: Neil Greatorex <neil@fatboyfat.co.uk>
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
commit b6d07e0273d3296cfbdc88145b8a00ddbefb310a upstream.
mvebu_pcie_handle_membase_change() and
mvebu_pcie_handle_iobase_change() do not correctly compute the window
size. PCI uses an inclusive start/end address pair, which requires a
+1 when converting to size.
This only worked because a bug in the mbus driver allowed it to
silently accept and round up bogus sizes.
Fix this by adding one to the computed size.
Fixes: 45361a4fe446 ('PCIe driver for Marvell Armada 370/XP systems')
Signed-off-by: Willy Tarreau <w@1wt.eu>
Reviewed-By: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Link: https://lkml.kernel.org/r/1397823593-1932-5-git-send-email-thomas.petazzoni@free-electrons.com
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
commit ce965c3d2e68c5325dd5624eb101d70423022fef upstream.
According to the Armada 370 and Armada XP datasheets, the part of the
Device Bus register that configure the bus width should contain 0 for
a 8 bits bus width, and 1 for a 16 bits bus width (other values are
unsupported/reserved).
However, the current conversion done in the driver to convert from a
bus width in bits to the value expected by the register leads to
setting the register to 1 for a 8 bits bus, and 2 for a 16 bits bus.
This mistake was compensated by a mistake in the existing Device Tree
files for Armada 370/XP platforms: they were declaring a 8 bits bus
width, while the hardware in fact uses a 16 bits bus width.
This commit fixes that by adjusting the conversion logic.
This patch fixes a bug that was introduced in
3edad321b1bd2e6c8b5f38146c115c8982438f06 ('drivers: memory: Introduce
Marvell EBU Device Bus driver'), which was merged in v3.11.
Link: https://lkml.kernel.org/r/1397489361-5833-2-git-send-email-thomas.petazzoni@free-electrons.com
Fixes: 3edad321b1bd ('drivers: memory: Introduce Marvell EBU Device Bus driver')
Acked-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
commit 4d595b866d2c653dc90a492b9973a834eabfa354 upstream.
After a @pwq is scheduled for emergency execution, other workers may
consume the affectd work items before the rescuer gets to them. This
means that a workqueue many have pwqs queued on @wq->maydays list
while not having any work item pending or in-flight. If
destroy_workqueue() executes in such condition, the rescuer may exit
without emptying @wq->maydays.
This currently doesn't cause any actual harm. destroy_workqueue() can
safely destroy all the involved data structures whether @wq->maydays
is populated or not as nobody access the list once the rescuer exits.
However, this is nasty and makes future development difficult. Let's
update rescuer_thread() so that it empties @wq->maydays after seeing
should_stop to guarantee that the list is empty on rescuer exit.
tj: Updated comment and patch description.
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
commit 77668c8b559e4fe2acf2a0749c7c83cde49a5025 upstream.
There is a race condition between rescuer_thread() and
pwq_unbound_release_workfn().
Even after a pwq is scheduled for rescue, the associated work items
may be consumed by any worker. If all of them are consumed before the
rescuer gets to them and the pwq's base ref was put due to attribute
change, the pwq may be released while still being linked on
@wq->maydays list making the rescuer dereference already freed pwq
later.
Make send_mayday() pin the target pwq until the rescuer is done with
it.
commit 77f300b198f93328c26191b52655ce1b62e202cf upstream.
wq_update_unbound_numa() failure path has the following two bugs.
- alloc_unbound_pwq() is called without holding wq->mutex; however, if
the allocation fails, it jumps to out_unlock which tries to unlock
wq->mutex.
- The function should switch to dfl_pwq on failure but didn't do so
after alloc_unbound_pwq() failure.
Fix it by regrabbing wq->mutex and jumping to use_dfl_pwq on
Signed-off-by: Daeseok Youn <daeseok.youn@gmail.com>
Acked-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Fixes: 4c16bd327c74 ("workqueue: implement NUMA affinity for unbound workqueues")
commit a1b8ff4c97b4375d21b6d6c45d75877303f61b3b upstream.
The nfsv4 state code has always assumed a one-to-one correspondance
between lock stateid's and lockowners even if it appears not to in some
places.
We may actually change that, but for now when FREE_STATEID releases a
lock stateid it also needs to release the parent lockowner.
Symptoms were a subsequent LOCK crashing in find_lockowner_str when it
calls same_lockowner_ino on a lockowner that unexpectedly has an empty
so_stateids list.
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 27b11428b7de097c42f205beabb1764f4365443b upstream.
The current code assumes a one-to-one lockowner<->lock stateid
correspondance.
commit aa07c713ecfc0522916f3cd57ac628ea6127c0ec upstream.
After setting ACL for directory, I got two problems that caused
by the cached zero-length default posix acl.
This patch make sure nfsd4_set_nfs4_acl calls ->set_acl
with a NULL ACL structure if there are no entries.
Thanks for Christoph Hellwig's advice.
First problem:
............ hang ...........
Second problem:
[ 1610.167668] ------------[ cut here ]------------
[ 1610.168320] kernel BUG at /root/nfs/linux/fs/nfsd/nfs4acl.c:239!
[ 1610.168320] invalid opcode: 0000 [#1] SMP DEBUG_PAGEALLOC
[ 1610.168320] Modules linked in: nfsv4(OE) nfs(OE) nfsd(OE)
rpcsec_gss_krb5 fscache ip6t_rpfilter ip6t_REJECT cfg80211 xt_conntrack
rfkill ebtable_nat ebtable_broute bridge stp llc ebtable_filter ebtables
ip6table_nat nf_conntrack_ipv6 nf_defrag_ipv6 nf_nat_ipv6
ip6table_mangle ip6table_security ip6table_raw ip6table_filter
ip6_tables iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4
nf_nat nf_conntrack iptable_mangle iptable_security iptable_raw
auth_rpcgss nfs_acl snd_intel8x0 ppdev lockd snd_ac97_codec ac97_bus
snd_pcm snd_timer e1000 pcspkr parport_pc snd parport serio_raw joydev
i2c_piix4 sunrpc(OE) microcode soundcore i2c_core ata_generic pata_acpi
[last unloaded: nfsd]
[ 1610.168320] CPU: 0 PID: 27397 Comm: nfsd Tainted: G OE
3.15.0-rc1+ #15
[ 1610.168320] Hardware name: innotek GmbH VirtualBox/VirtualBox, BIOS
VirtualBox 12/01/2006
[ 1610.168320] task: ffff88005ab653d0 ti: ffff88005a944000 task.ti:
ffff88005a944000
[ 1610.168320] RIP: 0010:[<ffffffffa034d5ed>] [<ffffffffa034d5ed>]
_posix_to_nfsv4_one+0x3cd/0x3d0 [nfsd]
[ 1610.168320] RSP: 0018:ffff88005a945b00 EFLAGS: 00010293
[ 1610.168320] RAX: 0000000000000001 RBX: ffff88006700bac0 RCX:
0000000000000000
[ 1610.168320] RDX: 0000000000000000 RSI: ffff880067c83f00 RDI:
ffff880068233300
[ 1610.168320] RBP: ffff88005a945b48 R08: ffffffff81c64830 R09:
0000000000000000
[ 1610.168320] R10: ffff88004ea85be0 R11: 000000000000f475 R12:
ffff880068233300
[ 1610.168320] R13: 0000000000000003 R14: 0000000000000002 R15:
ffff880068233300
[ 1610.168320] FS: 0000000000000000(0000) GS:ffff880077800000(0000)
knlGS:0000000000000000
[ 1610.168320] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 1610.168320] CR2: 00007f5bcbd3b0b9 CR3: 0000000001c0f000 CR4:
00000000000006f0
[ 1610.168320] DR0: 0000000000000000 DR1: 0000000000000000 DR2:
0000000000000000
[ 1610.168320] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7:
0000000000000400
[ 1610.168320] Stack:
[ 1610.168320] ffffffff00000000 0000000b67c83500 000000076700bac0
0000000000000000
[ 1610.168320] ffff88006700bac0 ffff880068233300 ffff88005a945c08
0000000000000002
[ 1610.168320] 0000000000000000 ffff88005a945b88 ffffffffa034e2d5
000000065a945b68
[ 1610.168320] Call Trace:
[ 1610.168320] [<ffffffffa034e2d5>] nfsd4_get_nfs4_acl+0x95/0x150 [nfsd]
[ 1610.168320] [<ffffffffa03400d6>] nfsd4_encode_fattr+0x646/0x1e70 [nfsd]
[ 1610.168320] [<ffffffff816a6e6e>] ? kmemleak_alloc+0x4e/0xb0
[ 1610.168320] [<ffffffffa0327962>] ?
nfsd_setuser_and_check_port+0x52/0x80 [nfsd]
[ 1610.168320] [<ffffffff812cd4bb>] ? selinux_cred_prepare+0x1b/0x30
[ 1610.168320] [<ffffffffa0341caa>] nfsd4_encode_getattr+0x5a/0x60 [nfsd]
[ 1610.168320] [<ffffffffa0341e07>] nfsd4_encode_operation+0x67/0x110
[nfsd]
[ 1610.168320] [<ffffffffa033844d>] nfsd4_proc_compound+0x21d/0x810 [nfsd]
[ 1610.168320] [<ffffffffa0324d9b>] nfsd_dispatch+0xbb/0x200 [nfsd]
[ 1610.168320] [<ffffffffa00850cd>] svc_process_common+0x46d/0x6d0 [sunrpc]
[ 1610.168320] [<ffffffffa0085433>] svc_process+0x103/0x170 [sunrpc]
[ 1610.168320] [<ffffffffa032472f>] nfsd+0xbf/0x130 [nfsd]
[ 1610.168320] [<ffffffffa0324670>] ? nfsd_destroy+0x80/0x80 [nfsd]
[ 1610.168320] [<ffffffff810a5202>] kthread+0xd2/0xf0
[ 1610.168320] [<ffffffff810a5130>] ? insert_kthread_work+0x40/0x40
[ 1610.168320] [<ffffffff816c1ebc>] ret_from_fork+0x7c/0xb0
[ 1610.168320] Code: 78 02 e9 e7 fc ff ff 31 c0 31 d2 31 c9 66 89 45 ce
41 8b 04 24 66 89 55 d0 66 89 4d d2 48 8d 04 80 49 8d 5c 84 04 e9 37 fd
ff ff <0f> 0b 90 0f 1f 44 00 00 55 8b 56 08 c7 07 00 00 00 00 8b 46 0c
[ 1610.168320] RIP [<ffffffffa034d5ed>] _posix_to_nfsv4_one+0x3cd/0x3d0
[nfsd]
[ 1610.168320] RSP <ffff88005a945b00>
[ 1610.257313] ---[ end trace 838254e3e352285b ]---
Signed-off-by: Kinglong Mee <kinglongmee@gmail.com>
