2013-10-18Linux 3.11.6v3.11.6Greg Kroah-Hartman
2013-10-18x86: avoid remapping data in parse_setup_data()Linn Crosetto
commit 30e46b574a1db7d14404e52dca8e1aa5f5155fd2 upstream. Type SETUP_PCI, added by setup_efi_pci(), may advertise a ROM size larger than early_memremap() is able to handle, which is currently limited to 256kB. If this occurs it leads to a NULL dereference in parse_setup_data(). To avoid this, remap the setup_data header and allow parsing functions for individual types to handle their own data remapping. Signed-off-by: Linn Crosetto <linn@hp.com> Link: http://lkml.kernel.org/r/1376430401-67445-1-git-send-email-linn@hp.com Acked-by: Yinghai Lu <yinghai@kernel.org> Reviewed-by: Pekka Enberg <penberg@kernel.org> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc/sem.c: update sem_otime for all operationsManfred Spraul
commit 0e8c665699e953fa58dc1b0b0d09e5dce7343cc7 upstream. In commit 0a2b9d4c7967 ("ipc/sem.c: move wake_up_process out of the spinlock section"), the update of semaphore's sem_otime(last semop time) was moved to one central position (do_smart_update). But since do_smart_update() is only called for operations that modify the array, this means that wait-for-zero semops do not update sem_otime anymore. The fix is simple: Non-alter operations must update sem_otime. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Reported-by: Jia He <jiakernel@gmail.com> Tested-by: Jia He <jiakernel@gmail.com> Cc: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc/sem.c: synchronize the proc interfaceManfred Spraul
commit d8c633766ad88527f25d9f81a5c2f083d78a2b39 upstream. The proc interface is not aware of sem_lock(), it instead calls ipc_lock_object() directly. This means that simple semop() operations can run in parallel with the proc interface. Right now, this is uncritical, because the implementation doesn't do anything that requires a proper synchronization. But it is dangerous and therefore should be fixed. Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Cc: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc/sem.c: optimize sem_lock()Manfred Spraul
commit 6d07b68ce16ae9535955ba2059dedba5309c3ca1 upstream. Operations that need access to the whole array must guarantee that there are no simple operations ongoing. Right now this is achieved by spin_unlock_wait(sem->lock) on all semaphores. If complex_count is nonzero, then this spin_unlock_wait() is not necessary, because it was already performed in the past by the thread that increased complex_count and even though sem_perm.lock was dropped inbetween, no simple operation could have started, because simple operations cannot start when complex_count is non-zero. Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Cc: Mike Galbraith <bitbucket@online.de> Cc: Rik van Riel <riel@redhat.com> Reviewed-by: Davidlohr Bueso <davidlohr@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc: drop ipc_lock_checkDavidlohr Bueso
commit 20b8875abcf2daa1dda5cf70bd6369df5e85d4c1 upstream. No remaining users, we now use ipc_obtain_object_check(). Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc, shm: drop shm_lock_checkDavidlohr Bueso
commit 7a25dd9e042b2b94202a67e5551112f4ac87285a upstream. This function was replaced by a the lockless shm_obtain_object_check(), and no longer has any users. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc: drop ipc_lock_by_ptrDavidlohr Bueso
commit 32a2750010981216fb788c5190fb0e646abfab30 upstream. After previous cleanups and optimizations, this function is no longer heavily used and we don't have a good reason to keep it. Update the few remaining callers and get rid of it. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc, shm: guard against non-existant vma in shmdt(2)Davidlohr Bueso
commit 530fcd16d87cd2417c472a581ba5a1e501556c86 upstream. When !CONFIG_MMU there's a chance we can derefence a NULL pointer when the VM area isn't found - check the return value of find_vma(). Also, remove the redundant -EINVAL return: retval is set to the proper return code and *only* changed to 0, when we actually unmap the segments. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc: document general ipc locking schemeDavidlohr Bueso
commit 05603c44a7627793219b0bd9a7b236099dc9cd9d upstream. As suggested by Andrew, add a generic initial locking scheme used throughout all sysv ipc mechanisms. Documenting the ids rwsem, how rcu can be enough to do the initial checks and when to actually acquire the kern_ipc_perm.lock spinlock. I found that adding it to util.c was generic enough. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc,msg: drop msg_unlockDavidlohr Bueso
commit 4718787d1f626f45ddb239912bc07266b9880044 upstream. There is only one user left, drop this function and just call ipc_unlock_object() and rcu_read_unlock(). Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc: rename ids->rw_mutexDavidlohr Bueso
commit d9a605e40b1376eb02b067d7690580255a0df68f upstream. Since in some situations the lock can be shared for readers, we shouldn't be calling it a mutex, rename it to rwsem. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc,shm: shorten critical region for shmatDavidlohr Bueso
commit c2c737a0461e61a34676bd0bd1bc1a70a1b4e396 upstream. Similar to other system calls, acquire the kern_ipc_perm lock after doing the initial permission and security checks. [sasha.levin@oracle.com: dont leave do_shmat with rcu lock held] Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc,shm: cleanup do_shmat pastaDavidlohr Bueso
commit f42569b1388b1408b574a5e93a23a663647d4181 upstream. Clean up some of the messy do_shmat() spaghetti code, getting rid of out_free and out_put_dentry labels. This makes shortening the critical region of this function in the next patch a little easier to do and read. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc,shm: shorten critical region for shmctlDavidlohr Bueso
commit 2caacaa82a51b78fc0c800e206473874094287ed upstream. With the *_INFO, *_STAT, IPC_RMID and IPC_SET commands already optimized, deal with the remaining SHM_LOCK and SHM_UNLOCK commands. Take the shm_perm lock after doing the initial auditing and security checks. The rest of the logic remains unchanged. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc,shm: make shmctl_nolock locklessDavidlohr Bueso
commit c97cb9ccab8c85428ec21eff690642ad2ce1fa8a upstream. While the INFO cmd doesn't take the ipc lock, the STAT commands do acquire it unnecessarily. We can do the permissions and security checks only holding the rcu lock. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc,shm: introduce shmctl_nolockDavidlohr Bueso
commit 68eccc1dc345539d589ae78ee43b835c1a06a134 upstream. Similar to semctl and msgctl, when calling msgctl, the *_INFO and *_STAT commands can be performed without acquiring the ipc object. Add a shmctl_nolock() function and move the logic of *_INFO and *_STAT out of msgctl(). Since we are just moving functionality, this change still takes the lock and it will be properly lockless in the next patch. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc: drop ipcctl_pre_downDavidlohr Bueso
commit 3b1c4ad37741e53804ffe0a30dd01e08b2ab6241 upstream. Now that sem, msgque and shm, through *_down(), all use the lockless variant of ipcctl_pre_down(), go ahead and delete it. [akpm@linux-foundation.org: fix function name in kerneldoc, cleanups] Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc,shm: shorten critical region in shmctl_downDavidlohr Bueso
commit 79ccf0f8c8e04e8b9eda6645ba0f63b0915a3075 upstream. Instead of holding the ipc lock for the entire function, use the ipcctl_pre_down_nolock and only acquire the lock for specific commands: RMID and SET. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc,shm: introduce lockless functions to obtain the ipc objectDavidlohr Bueso
commit 8b8d52ac382b17a19906b930cd69e2edb0aca8ba upstream. This is the third and final patchset that deals with reducing the amount of contention we impose on the ipc lock (kern_ipc_perm.lock). These changes mostly deal with shared memory, previous work has already been done for semaphores and message queues: http://lkml.org/lkml/2013/3/20/546 (sems) http://lkml.org/lkml/2013/5/15/584 (mqueues) With these patches applied, a custom shm microbenchmark stressing shmctl doing IPC_STAT with 4 threads a million times, reduces the execution time by 50%. A similar run, this time with IPC_SET, reduces the execution time from 3 mins and 35 secs to 27 seconds. Patches 1-8: replaces blindly taking the ipc lock for a smarter combination of rcu and ipc_obtain_object, only acquiring the spinlock when updating. Patch 9: renames the ids rw_mutex to rwsem, which is what it already was. Patch 10: is a trivial mqueue leftover cleanup Patch 11: adds a brief lock scheme description, requested by Andrew. This patch: Add shm_obtain_object() and shm_obtain_object_check(), which will allow us to get the ipc object without acquiring the lock. Just as with other forms of ipc, these functions are basically wrappers around ipc_obtain_object*(). Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18drm/radeon: fix hw contexts for SUMO2 asicswojciech kapuscinski
commit 50b8f5aec04ebec7dbdf2adb17220b9148c99e63 upstream. They have 4 rather than 8. Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=63599 Signed-off-by: wojciech kapuscinski <wojtask9@wp.pl> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18drm/radeon: fix typo in CP DMA register headersAlex Deucher
commit aa3e146d04b6ae37939daeebaec060562b3db559 upstream. Wrong bit offset for SRC endian swapping. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18drm/radeon: forever loop on error in radeon_do_test_moves()Dan Carpenter
commit 89cd67b326fa95872cc2b4524cd807128db6071d upstream. The error path does this: for (--i; i >= 0; --i) { which is a forever loop because "i" is unsigned. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18drm/radeon/dpm: off by one in si_set_mc_special_registers()Dan Carpenter
commit 5fd9c581862a4874c0bdaf16231d8873832bbb99 upstream. These checks should be ">=" instead of ">". j is used as an offset into the table->mc_reg_address[] array and that has SMC_SISLANDS_MC_REGISTER_ARRAY_SIZE (16) elements. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18drm/i915: fix rps.vlv_work initializationImre Deak
commit 671952a2a290a90017c64e75b7dd0343b0d005b4 upstream. During driver loading we are initializing rps.vlv_work in valleyview_enable_rps() via the rps.delayed_resume_work delayed work. This is too late since we are using vlv_work already via i915_driver_load()->intel_uncore_sanitize()-> intel_disable_gt_powersave(). This at least leads to the following kernel warning: INFO: trying to register non-static key. the code is fine but needs lockdep annotation. turning off the locking correctness validator. Fix this by initialzing vlv_work before we call intel_uncore_sanitize(). The regression was introduced in commit 7dcd2677ea912573d9ed4bcd629b0023b2d11505 Author: Konstantin Khlebnikov <khlebnikov@openvz.org> Date: Wed Jul 17 10:22:58 2013 +0400 drm/i915: fix long-standing SNB regression in power consumption after resume though there was no good reason to initialize the static vlv_work from another delayed work to begin with (especially since this will happen multiple times). Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=69397 Tested-by: shui yangwei <yangweix.shui@intel.com> Signed-off-by: Imre Deak <imre.deak@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18drm/i915: Only apply DPMS to the encoder if enabledChris Wilson
commit c9976dcf55c8aaa7037427b239f15e5acfc01a3a upstream. The current test for an attached enabled encoder fails if we have multiple connectors aliased to the same encoder - both connectors believe they own the enabled encoder and so we attempt to both enable and disable DPMS on the encoder, leading to hilarity and an OOPs: [ 354.803064] WARNING: CPU: 0 PID: 482 at /usr/src/linux/dist/3.11.2/drivers/gpu/drm/i915/intel_display.c:3869 intel_modeset_check_state+0x764/0x770 [i915]() [ 354.803064] wrong connector dpms state [ 354.803084] Modules linked in: nfsd auth_rpcgss oid_registry exportfs nfs lockd sunrpc xt_nat iptable_nat nf_nat_ipv4 nf_nat xt_limit xt_LOG xt_tcpudp nf_conntrack_ipv4 nf_defrag_ipv4 ipt_REJECT ipv6 xt_recent xt_conntrack nf_conntrack iptable_filter ip_tables x_tables snd_hda_codec_realtek snd_hda_codec_hdmi x86_pkg_temp_thermal snd_hda_intel coretemp kvm_intel snd_hda_codec i915 kvm snd_hwdep snd_pcm_oss snd_mixer_oss crc32_pclmul snd_pcm crc32c_intel e1000e intel_agp igb ghash_clmulni_intel intel_gtt aesni_intel cfbfillrect aes_x86_64 cfbimgblt lrw cfbcopyarea drm_kms_helper ptp video thermal processor gf128mul snd_page_alloc drm snd_timer glue_helper 8250_pci snd pps_core ablk_helper agpgart cryptd sg soundcore fan i2c_algo_bit sr_mod thermal_sys 8250 i2c_i801 serial_core hwmon cdrom i2c_core evdev button [ 354.803086] CPU: 0 PID: 482 Comm: kworker/0:1 Not tainted 3.11.2 #1 [ 354.803087] Hardware name: Supermicro X10SAE/X10SAE, BIOS 1.00 05/03/2013 [ 354.803091] Workqueue: events console_callback [ 354.803092] 0000000000000009 ffff88023611db48 ffffffff814048ac ffff88023611db90 [ 354.803093] ffff88023611db80 ffffffff8103d4e3 ffff880230d82800 ffff880230f9b800 [ 354.803094] ffff880230f99000 ffff880230f99448 ffff8802351c0e00 ffff88023611dbe0 [ 354.803094] Call Trace: [ 354.803098] [<ffffffff814048ac>] dump_stack+0x54/0x8d [ 354.803101] [<ffffffff8103d4e3>] warn_slowpath_common+0x73/0x90 [ 354.803103] [<ffffffff8103d547>] warn_slowpath_fmt+0x47/0x50 [ 354.803109] [<ffffffffa089f1be>] ? intel_ddi_connector_get_hw_state+0x5e/0x110 [i915] [ 354.803114] [<ffffffffa0896974>] intel_modeset_check_state+0x764/0x770 [i915] [ 354.803117] [<ffffffffa08969bb>] intel_connector_dpms+0x3b/0x60 [i915] [ 354.803120] [<ffffffffa037e1d0>] drm_fb_helper_dpms.isra.11+0x120/0x160 [drm_kms_helper] [ 354.803122] [<ffffffffa037e24e>] drm_fb_helper_blank+0x3e/0x80 [drm_kms_helper] [ 354.803123] [<ffffffff812116c2>] fb_blank+0x52/0xc0 [ 354.803125] [<ffffffff8121e04b>] fbcon_blank+0x21b/0x2d0 [ 354.803127] [<ffffffff81062243>] ? update_rq_clock.part.74+0x13/0x30 [ 354.803129] [<ffffffff81047486>] ? lock_timer_base.isra.30+0x26/0x50 [ 354.803130] [<ffffffff810472b2>] ? internal_add_timer+0x12/0x40 [ 354.803131] [<ffffffff81047f48>] ? mod_timer+0xf8/0x1c0 [ 354.803133] [<ffffffff81266d61>] do_unblank_screen+0xa1/0x1c0 [ 354.803134] [<ffffffff81268087>] poke_blanked_console+0xc7/0xd0 [ 354.803136] [<ffffffff812681cf>] console_callback+0x13f/0x160 [ 354.803137] [<ffffffff81053258>] process_one_work+0x148/0x3d0 [ 354.803138] [<ffffffff81053f19>] worker_thread+0x119/0x3a0 [ 354.803140] [<ffffffff81053e00>] ? manage_workers.isra.30+0x2a0/0x2a0 [ 354.803141] [<ffffffff8105994b>] kthread+0xbb/0xc0 [ 354.803142] [<ffffffff81059890>] ? kthread_create_on_node+0x120/0x120 [ 354.803144] [<ffffffff8140b32c>] ret_from_fork+0x7c/0xb0 [ 354.803145] [<ffffffff81059890>] ? kthread_create_on_node+0x120/0x120 This regression goes back to the big modeset rework and the conversion to the new dpms helpers which started with: commit 5ab432ef4997ce32c9406721b37ef6e97e57dae1 Author: Daniel Vetter <daniel.vetter@ffwll.ch> Date: Sat Jun 30 08:59:56 2012 +0200 drm/i915/hdmi: convert to encoder->disable/enable Fixes: igt/kms_flip/dpms-off-confusion Reported-and-tested-by: Wakko Warner <wakko@animx.eu.org> Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=68030 Link: http://lkml.kernel.org/r/20130928185023.GA21672@animx.eu.org Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> [danvet: Add regression citation, mention the igt testcase this fixes and slap a cc: stable on the patch.] Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18drm/i915/hsw: Disable L3 caching of atomic memory operations.Francisco Jerez
commit f3fc4884ebe6ae649d3723be14b219230d3b7fd2 upstream. Otherwise using any atomic memory operation will lock up the GPU due to a Haswell hardware bug. v2: Use the _MASKED_BIT_ENABLE macro. Drop drm parameter definition. Signed-off-by: Francisco Jerez <currojerez@riseup.net> Reviewed-by: Ben Widawsky <ben@bwidawsk.net> Cc: Daniel Vetter <daniel@ffwll.ch> [danvet: Fix checkpatch fail.] Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ALSA: hda - Fix mono speakers and headset mic on Dell Vostro 5470David Henningsson
This is a backport for stable. The original commit SHA is 338cae565c53755de9f87d6a801517940d2d56f7. On this machine, DAC on node 0x03 seems to give mono output. Also, it needs additional patches for headset mic support. It supports CTIA style headsets only. Alsa-info available at the bug link below. BugLink: https://bugs.launchpad.net/bugs/1236228 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18compiler/gcc4: Add quirk for 'asm goto' miscompilation bugIngo Molnar
commit 3f0116c3238a96bc18ad4b4acefe4e7be32fa861 upstream. Fengguang Wu, Oleg Nesterov and Peter Zijlstra tracked down a kernel crash to a GCC bug: GCC miscompiles certain 'asm goto' constructs, as outlined here: http://gcc.gnu.org/bugzilla/show_bug.cgi?id=58670 Implement a workaround suggested by Jakub Jelinek. Reported-and-tested-by: Fengguang Wu <fengguang.wu@intel.com> Reported-by: Oleg Nesterov <oleg@redhat.com> Reported-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Suggested-by: Jakub Jelinek <jakub@redhat.com> Reviewed-by: Richard Henderson <rth@twiddle.net> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/20131015062351.GA4666@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18drm/radeon/dpm/btc: off by one in btc_set_mc_special_registers()Dan Carpenter
commit 96d8df846f52a720c8ae1fadadfad7c9e733e336 upstream. It should be ">=" instead of ">" here. The table->mc_reg_address[] array has SMC_EVERGREEN_MC_REGISTER_ARRAY_SIZE (16) elements. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18MIPS: stack protector: Fix per-task canary switchJames Hogan
commit 8b3c569a3999a8fd5a819f892525ab5520777c92 upstream. Commit 1400eb6 (MIPS: r4k,octeon,r2300: stack protector: change canary per task) was merged in v3.11 and introduced assembly in the MIPS resume functions to update the value of the current canary in __stack_chk_guard. However it used PTR_L resulting in a load of the canary value, instead of PTR_LA to construct its address. The value is intended to be random but is then treated as an address in the subsequent LONG_S (store). This was observed to cause a fault and panic: CPU 0 Unable to handle kernel paging request at virtual address 139fea20, epc == 8000cc0c, ra == 8034f2a4 Oops[#1]: ... $24 : 139fea20 1e1f7cb6 ... Call Trace: [<8000cc0c>] resume+0xac/0x118 [<8034f2a4>] __schedule+0x5f8/0x78c [<8034f4e0>] schedule_preempt_disabled+0x20/0x2c [<80348eec>] rest_init+0x74/0x84 [<804dc990>] start_kernel+0x43c/0x454 Code: 3c18804b 8f184030 8cb901f8 <af190000> 00c0e021 8cb002f0 8cb102f4 8cb202f8 8cb302fc This can also be forced by modifying arch/mips/include/asm/stackprotector.h so that the default __stack_chk_guard value is more likely to be a bad (or unaligned) pointer. Fix it to use PTR_LA instead, to load the address of the canary value, which the LONG_S can then use to write into it. Reported-by: bobjones (via #mipslinux on IRC) Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Gregory Fong <gregory.0xf0@gmail.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/6026/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18watchdog: kempld_wdt: Fix bit mask definitionJingoo Han
commit 4c4e45669de475573b15d968a6dca8d00124c9ad upstream. STAGE_CFG bits are defined as [5:4] bits. However, '(((x) & 0x30) << 4)' handles [9:8] bits. Thus, it should be fixed in order to handle [5:4] bits. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Cc: Jonghwan Choi <jhbird.choi@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18watchdog: ts72xx_wdt: locking bug in ioctlDan Carpenter
commit 8612ed0d97abcf1c016d34755b7cf2060de71963 upstream. Calling the WDIOC_GETSTATUS & WDIOC_GETBOOTSTATUS and twice will cause a interruptible deadlock. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Cc: Jonghwan Choi <jhbird.choi@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ARC: Ignore ptrace SETREGSET request for synthetic register "stop_pc"Vineet Gupta
commit 5b24282846c064ee90d40fcb3a8f63b8e754fd28 upstream. ARCompact TRAP_S insn used for breakpoints, commits before exception is taken (updating architectural PC). So ptregs->ret contains next-PC and not the breakpoint PC itself. This is different from other restartable exceptions such as TLB Miss where ptregs->ret has exact faulting PC. gdb needs to know exact-PC hence ARC ptrace GETREGSET provides for @stop_pc which returns ptregs->ret vs. EFA depending on the situation. However, writing stop_pc (SETREGSET request), which updates ptregs->ret doesn't makes sense stop_pc doesn't always correspond to that reg as described above. This was not an issue so far since user_regs->ret / user_regs->stop_pc had same value and both writing to ptregs->ret was OK, needless, but NOT broken, hence not observed. With gdb "jump", they diverge, and user_regs->ret updating ptregs is overwritten immediately with stop_pc, which this patch fixes. Reported-by: Anton Kolesov <akolesov@synopsys.com> Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ARC: Fix signal frame management for SA_SIGINFOChristian Ruppert
commit 10469350e345599dfef3fa78a7c19fb230e674c1 upstream. Previously, when a signal was registered with SA_SIGINFO, parameters 2 and 3 of the signal handler were written to registers r1 and r2 before the register set was saved. This led to corruption of these two registers after returning from the signal handler (the wrong values were restored). With this patch, registers are now saved before any parameters are passed, thus maintaining the processor state from before signal entry. Signed-off-by: Christian Ruppert <christian.ruppert@abilis.com> Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ARC: Workaround spinlock livelock in SMP SystemC simulationVineet Gupta
commit 6c00350b573c0bd3635436e43e8696951dd6e1b6 upstream. Some ARC SMP systems lack native atomic R-M-W (LLOCK/SCOND) insns and can only use atomic EX insn (reg with mem) to build higher level R-M-W primitives. This includes a SystemC based SMP simulation model. So rwlocks need to use a protecting spinlock for atomic cmp-n-exchange operation to update reader(s)/writer count. The spinlock operation itself looks as follows: mov reg, 1 ; 1=locked, 0=unlocked retry: EX reg, [lock] ; load existing, store 1, atomically BREQ reg, 1, rety ; if already locked, retry In single-threaded simulation, SystemC alternates between the 2 cores with "N" insn each based scheduling. Additionally for insn with global side effect, such as EX writing to shared mem, a core switch is enforced too. Given that, 2 cores doing a repeated EX on same location, Linux often got into a livelock e.g. when both cores were fiddling with tasklist lock (gdbserver / hackbench) for read/write respectively as the sequence diagram below shows: core1 core2 -------- -------- 1. spin lock [EX r=0, w=1] - LOCKED 2. rwlock(Read) - LOCKED 3. spin unlock [ST 0] - UNLOCKED spin lock [EX r=0,w=1] - LOCKED -- resched core 1---- 5. spin lock [EX r=1] - ALREADY-LOCKED -- resched core 2---- 6. rwlock(Write) - READER-LOCKED 7. spin unlock [ST 0] 8. rwlock failed, retry again 9. spin lock [EX r=0, w=1] -- resched core 1---- 10 spinlock locked in #9, retry #5 11. spin lock [EX gets 1] -- resched core 2---- ... ... The fix was to unlock using the EX insn too (step 7), to trigger another SystemC scheduling pass which would let core1 proceed, eliding the livelock. Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ARC: Fix 32-bit wrap around in access_ok()Vineet Gupta
commit 0752adfda15f0eca9859a76da3db1800e129ad43 upstream. Anton reported | LTP tests syscalls/process_vm_readv01 and process_vm_writev01 fail | similarly in one testcase test_iov_invalid -> lvec->iov_base. | Testcase expects errno EFAULT and return code -1, | but it gets return code 1 and ERRNO is 0 what means success. Essentially test case was passing a pointer of -1 which access_ok() was not catching. It was doing [@addr + @sz <= TASK_SIZE] which would pass for @addr == -1 Fixed that by rewriting as [@addr <= TASK_SIZE - @sz] Reported-by: Anton Kolesov <Anton.Kolesov@synopsys.com> Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ARC: Handle zero-overhead-loop in unaligned access handlerMischa Jonker
commit c11eb222fd7d4db91196121dbf854178505d2751 upstream. If a load or store is the last instruction in a zero-overhead-loop, and it's misaligned, the loop would execute only once. This fixes that problem. Signed-off-by: Mischa Jonker <mjonker@synopsys.com> Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ARC: Fix __udelay calculationMischa Jonker
commit 7efd0da2d17360e1cef91507dbe619db0ee2c691 upstream. Cast usecs to u64, to ensure that the (usecs * 4295 * HZ) multiplication is 64 bit. Initially, the (usecs * 4295 * HZ) part was done as a 32 bit multiplication, with the result casted to 64 bit. This led to some bits falling off, causing a "DMA initialization error" in the stmmac Ethernet driver, due to a premature timeout. Signed-off-by: Mischa Jonker <mjonker@synopsys.com> Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18parisc: fix interruption handler to respect pagefault_disable()Helge Deller
commit 59b33f148cc08fb33cbe823fca1e34f7f023765e upstream. Running an "echo t > /proc/sysrq-trigger" crashes the parisc kernel. The problem is, that in print_worker_info() we try to read the workqueue info via the probe_kernel_read() functions which use pagefault_disable() to avoid crashes like this: probe_kernel_read(&pwq, &worker->current_pwq, sizeof(pwq)); probe_kernel_read(&wq, &pwq->wq, sizeof(wq)); probe_kernel_read(name, wq->name, sizeof(name) - 1); The problem here is, that the first probe_kernel_read(&pwq) might return zero in pwq and as such the following probe_kernel_reads() try to access contents of the page zero which is read protected and generate a kernel segfault. With this patch we fix the interruption handler to call parisc_terminate() directly only if pagefault_disable() was not called (in which case preempt_count()==0). Otherwise we hand over to the pagefault handler which will try to look up the faulting address in the fixup tables. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: John David Anglin <dave.anglin@bell.net> Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18KVM: PPC: Book3S HV: Fix typo in saving DSCRPaul Mackerras
commit cfc860253abd73e1681696c08ea268d33285a2c4 upstream. This fixes a typo in the code that saves the guest DSCR (Data Stream Control Register) into the kvm_vcpu_arch struct on guest exit. The effect of the typo was that the DSCR value was saved in the wrong place, so changes to the DSCR by the guest didn't persist across guest exit and entry, and some host kernel memory got corrupted. Signed-off-by: Paul Mackerras <paulus@samba.org> Acked-by: Alexander Graf <agraf@suse.de> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ext4: fix memory leak in xattrDave Jones
commit 6e4ea8e33b2057b85d75175dd89b93f5e26de3bc upstream. If we take the 2nd retry path in ext4_expand_extra_isize_ea, we potentionally return from the function without having freed these allocations. If we don't do the return, we over-write the previous allocation pointers, so we leak either way. Spotted with Coverity. [ Fixed by tytso to set is and bs to NULL after freeing these pointers, in case in the retry loop we later end up triggering an error causing a jump to cleanup, at which point we could have a double free bug. -- Ted ] Signed-off-by: Dave Jones <davej@fedoraproject.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Reviewed-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18Btrfs: use right root when checking for hash collisionJosef Bacik
commit 4871c1588f92c6c13f4713a7009f25f217055807 upstream. btrfs_rename was using the root of the old dir instead of the root of the new dir when checking for a hash collision, so if you tried to move a file into a subvol it would freak out because it would see the file you are trying to move in its current root. This fixes the bug where this would fail btrfs subvol create test1 btrfs subvol create test2 mv test1 test2. Thanks to Chris Murphy for catching this, Reported-by: Chris Murphy <lists@colorremedies.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18hwmon: (applesmc) Always read until end of dataHenrik Rydberg
commit 25f2bd7f5add608c1d1405938f39c96927b275ca upstream. The crash reported and investigated in commit 5f4513 turned out to be caused by a change to the read interface on newer (2012) SMCs. Tests by Chris show that simply reading the data valid line is enough for the problem to go away. Additional tests show that the newer SMCs no longer wait for the number of requested bytes, but start sending data right away. Apparently the number of bytes to read is no longer specified as before, but instead found out by reading until end of data. Failure to read until end of data confuses the state machine, which eventually causes the crash. As a remedy, assuming bit0 is the read valid line, make sure there is nothing more to read before leaving the read function. Tested to resolve the original problem, and runtested on MBA3,1, MBP4,1, MBP8,2, MBP10,1, MBP10,2. The patch seems to have no effect on machines before 2012. Tested-by: Chris Murphy <chris@cmurf.com> Signed-off-by: Henrik Rydberg <rydberg@euromail.se> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18i2c: omap: Clear ARDY bit twiceTaras Kondratiuk
commit 4cdbf7d346e7461c3b93a26707c852e2c9db3753 upstream. Initially commit cb527ede1bf6ff2008a025606f25344b8ed7b4ac "i2c-omap: Double clear of ARDY status in IRQ handler" added a workaround for undocumented errata ProDB0017052. But then commit 1d7afc95946487945cc7f5019b41255b72224b70 "i2c: omap: ack IRQ in parts" refactored code and missed one of ARDY clearings. So current code violates errata. It causes often i2c bus timeouts on my Pandaboard. This patch adds a second clearing in place. Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Signed-off-by: Taras Kondratiuk <taras.kondratiuk@linaro.org> Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18vfs: allow O_PATH file descriptors for fstatfs()Linus Torvalds
commit 9d05746e7b16d8565dddbe3200faa1e669d23bbf upstream. Olga reported that file descriptors opened with O_PATH do not work with fstatfs(), found during further development of ksh93's thread support. There is no reason to not allow O_PATH file descriptors here (fstatfs is very much a path operation), so use "fdget_raw()". See commit 55815f70147d ("vfs: make O_PATH file descriptors usable for 'fstat()'") for a very similar issue reported for fstat() by the same team. Reported-and-tested-by: ольга крыжановская <olga.kryzhanovska@gmail.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18random: run random_int_secret_init() run after all late_initcallsTheodore Ts'o
commit 47d06e532e95b71c0db3839ebdef3fe8812fca2c upstream. The some platforms (e.g., ARM) initializes their clocks as late_initcalls for some unknown reason. So make sure random_int_secret_init() is run after all of the late_initcalls are run. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ALSA: hda - Fix microphone for Sony VAIO Pro 13 (Haswell model)David Henningsson
commit 88cfcf86aa3ada84d97195bcad74f4dadb4ae23b upstream. The external mic showed up with a precense detect of "always present", essentially disabling the internal mic. Therefore turn off presence detection for this pin. Note: The external mic seems not yet working, but an internal mic is certainly better than no mic at all. BugLink: https://bugs.launchpad.net/bugs/1227093 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ALSA: hda - Add fixup for ASUS N56VZTakashi Iwai
commit c6cc3d58b4042f5cadae653ff8d3df26af1a0169 upstream. ASUS N56VZ needs a fixup for the bass speaker pin, which was already provided via model=asus-mode4. Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=841645 Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ALSA: hda - hdmi: Fix channel map switch not taking effectAnssi Hannula
commit 39edac70e9aedf451fccaa851b273ace9fcca0bd upstream. Currently hdmi_setup_audio_infoframe() reprograms the HDA channel mapping only when the infoframe is not up-to-date or the non-PCM flag has changed. However, when just the channel map has been changed, the infoframe may still be up-to-date and non-PCM flag may not have changed, so the new channel map is not actually programmed into the HDA codec. Notably, this failing case is also always triggered when the device is already in a prepared state and a new channel map is configured while changing only the channel positions (for example, plain "speaker-test -c2 -m FR,FL"). Fix that by always programming the channel map in hdmi_setup_audio_infoframe(). Tested on Intel HDMI. Signed-off-by: Anssi Hannula <anssi.hannula@iki.fi> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
