2014-11-21Linux 3.10.61v3.10.61Greg Kroah-Hartman
2014-11-21mm: memcg: handle non-error OOM situations more gracefullyJohannes Weiner
commit 4942642080ea82d99ab5b653abb9a12b7ba31f4a upstream. Commit 3812c8c8f395 ("mm: memcg: do not trap chargers with full callstack on OOM") assumed that only a few places that can trigger a memcg OOM situation do not return VM_FAULT_OOM, like optional page cache readahead. But there are many more and it's impractical to annotate them all. First of all, we don't want to invoke the OOM killer when the failed allocation is gracefully handled, so defer the actual kill to the end of the fault handling as well. This simplifies the code quite a bit for added bonus. Second, since a failed allocation might not be the abrupt end of the fault, the memcg OOM handler needs to be re-entrant until the fault finishes for subsequent allocation attempts. If an allocation is attempted after the task already OOMed, allow it to bypass the limit so that it can quickly finish the fault and invoke the OOM killer. Reported-by: azurIt <azurit@pobox.sk> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21mm: memcg: do not trap chargers with full callstack on OOMJohannes Weiner
commit 3812c8c8f3953921ef18544110dafc3505c1ac62 upstream. The memcg OOM handling is incredibly fragile and can deadlock. When a task fails to charge memory, it invokes the OOM killer and loops right there in the charge code until it succeeds. Comparably, any other task that enters the charge path at this point will go to a waitqueue right then and there and sleep until the OOM situation is resolved. The problem is that these tasks may hold filesystem locks and the mmap_sem; locks that the selected OOM victim may need to exit. For example, in one reported case, the task invoking the OOM killer was about to charge a page cache page during a write(), which holds the i_mutex. The OOM killer selected a task that was just entering truncate() and trying to acquire the i_mutex: OOM invoking task: mem_cgroup_handle_oom+0x241/0x3b0 mem_cgroup_cache_charge+0xbe/0xe0 add_to_page_cache_locked+0x4c/0x140 add_to_page_cache_lru+0x22/0x50 grab_cache_page_write_begin+0x8b/0xe0 ext3_write_begin+0x88/0x270 generic_file_buffered_write+0x116/0x290 __generic_file_aio_write+0x27c/0x480 generic_file_aio_write+0x76/0xf0 # takes ->i_mutex do_sync_write+0xea/0x130 vfs_write+0xf3/0x1f0 sys_write+0x51/0x90 system_call_fastpath+0x18/0x1d OOM kill victim: do_truncate+0x58/0xa0 # takes i_mutex do_last+0x250/0xa30 path_openat+0xd7/0x440 do_filp_open+0x49/0xa0 do_sys_open+0x106/0x240 sys_open+0x20/0x30 system_call_fastpath+0x18/0x1d The OOM handling task will retry the charge indefinitely while the OOM killed task is not releasing any resources. A similar scenario can happen when the kernel OOM killer for a memcg is disabled and a userspace task is in charge of resolving OOM situations. In this case, ALL tasks that enter the OOM path will be made to sleep on the OOM waitqueue and wait for userspace to free resources or increase the group's limit. But a userspace OOM handler is prone to deadlock itself on the locks held by the waiting tasks. For example one of the sleeping tasks may be stuck in a brk() call with the mmap_sem held for writing but the userspace handler, in order to pick an optimal victim, may need to read files from /proc/<pid>, which tries to acquire the same mmap_sem for reading and deadlocks. This patch changes the way tasks behave after detecting a memcg OOM and makes sure nobody loops or sleeps with locks held: 1. When OOMing in a user fault, invoke the OOM killer and restart the fault instead of looping on the charge attempt. This way, the OOM victim can not get stuck on locks the looping task may hold. 2. When OOMing in a user fault but somebody else is handling it (either the kernel OOM killer or a userspace handler), don't go to sleep in the charge context. Instead, remember the OOMing memcg in the task struct and then fully unwind the page fault stack with -ENOMEM. pagefault_out_of_memory() will then call back into the memcg code to check if the -ENOMEM came from the memcg, and then either put the task to sleep on the memcg's OOM waitqueue or just restart the fault. The OOM victim can no longer get stuck on any lock a sleeping task may hold. Debugged by Michal Hocko. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reported-by: azurIt <azurit@pobox.sk> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21mm: memcg: rework and document OOM waiting and wakeupJohannes Weiner
commit fb2a6fc56be66c169f8b80e07ed999ba453a2db2 upstream. The memcg OOM handler open-codes a sleeping lock for OOM serialization (trylock, wait, repeat) because the required locking is so specific to memcg hierarchies. However, it would be nice if this construct would be clearly recognizable and not be as obfuscated as it is right now. Clean up as follows: 1. Remove the return value of mem_cgroup_oom_unlock() 2. Rename mem_cgroup_oom_lock() to mem_cgroup_oom_trylock(). 3. Pull the prepare_to_wait() out of the memcg_oom_lock scope. This makes it more obvious that the task has to be on the waitqueue before attempting to OOM-trylock the hierarchy, to not miss any wakeups before going to sleep. It just didn't matter until now because it was all lumped together into the global memcg_oom_lock spinlock section. 4. Pull the mem_cgroup_oom_notify() out of the memcg_oom_lock scope. It is proctected by the hierarchical OOM-lock. 5. The memcg_oom_lock spinlock is only required to propagate the OOM lock in any given hierarchy atomically. Restrict its scope to mem_cgroup_oom_(trylock|unlock). 6. Do not wake up the waitqueue unconditionally at the end of the function. Only the lockholder has to wake up the next in line after releasing the lock. Note that the lockholder kicks off the OOM-killer, which in turn leads to wakeups from the uncharges of the exiting task. But a contender is not guaranteed to see them if it enters the OOM path after the OOM kills but before the lockholder releases the lock. Thus there has to be an explicit wakeup after releasing the lock. 7. Put the OOM task on the waitqueue before marking the hierarchy as under OOM as that is the point where we start to receive wakeups. No point in listening before being on the waitqueue. 8. Likewise, unmark the hierarchy before finishing the sleep, for symmetry. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: azurIt <azurit@pobox.sk> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21mm: memcg: enable memcg OOM killer only for user faultsJohannes Weiner
commit 519e52473ebe9db5cdef44670d5a97f1fd53d721 upstream. System calls and kernel faults (uaccess, gup) can handle an out of memory situation gracefully and just return -ENOMEM. Enable the memcg OOM killer only for user faults, where it's really the only option available. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.cz> Cc: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: azurIt <azurit@pobox.sk> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21x86: finish user fault error path with fatal signalJohannes Weiner
commit 3a13c4d761b4b979ba8767f42345fed3274991b0 upstream. The x86 fault handler bails in the middle of error handling when the task has a fatal signal pending. For a subsequent patch this is a problem in OOM situations because it relies on pagefault_out_of_memory() being called even when the task has been killed, to perform proper per-task OOM state unwinding. Shortcutting the fault like this is a rather minor optimization that saves a few instructions in rare cases. Just remove it for user-triggered faults. Use the opportunity to split the fault retry handling from actual fault errors and add locking documentation that reads suprisingly similar to ARM's. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Michal Hocko <mhocko@suse.cz> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: azurIt <azurit@pobox.sk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21arch: mm: pass userspace fault flag to generic fault handlerJohannes Weiner
commit 759496ba6407c6994d6a5ce3a5e74937d7816208 upstream. Unlike global OOM handling, memory cgroup code will invoke the OOM killer in any OOM situation because it has no way of telling faults occuring in kernel context - which could be handled more gracefully - from user-triggered faults. Pass a flag that identifies faults originating in user space from the architecture-specific fault handlers to generic code so that memcg OOM handling can be improved. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: azurIt <azurit@pobox.sk> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21arch: mm: do not invoke OOM killer on kernel fault OOMJohannes Weiner
commit 871341023c771ad233620b7a1fb3d9c7031c4e5c upstream. Kernel faults are expected to handle OOM conditions gracefully (gup, uaccess etc.), so they should never invoke the OOM killer. Reserve this for faults triggered in user context when it is the only option. Most architectures already do this, fix up the remaining few. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Michal Hocko <mhocko@suse.cz> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: azurIt <azurit@pobox.sk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21arch: mm: remove obsolete init OOM protectionJohannes Weiner
commit 94bce453c78996cc4373d5da6cfabe07fcc6d9f9 upstream. The memcg code can trap tasks in the context of the failing allocation until an OOM situation is resolved. They can hold all kinds of locks (fs, mm) at this point, which makes it prone to deadlocking. This series converts memcg OOM handling into a two step process that is started in the charge context, but any waiting is done after the fault stack is fully unwound. Patches 1-4 prepare architecture handlers to support the new memcg requirements, but in doing so they also remove old cruft and unify out-of-memory behavior across architectures. Patch 5 disables the memcg OOM handling for syscalls, readahead, kernel faults, because they can gracefully unwind the stack with -ENOMEM. OOM handling is restricted to user triggered faults that have no other option. Patch 6 reworks memcg's hierarchical OOM locking to make it a little more obvious wth is going on in there: reduce locked regions, rename locking functions, reorder and document. Patch 7 implements the two-part OOM handling such that tasks are never trapped with the full charge stack in an OOM situation. This patch: Back before smart OOM killing, when faulting tasks were killed directly on allocation failures, the arch-specific fault handlers needed special protection for the init process. Now that all fault handlers call into the generic OOM killer (see commit 609838cfed97: "mm: invoke oom-killer from remaining unconverted page fault handlers"), which already provides init protection, the arch-specific leftovers can be removed. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Michal Hocko <mhocko@suse.cz> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: azurIt <azurit@pobox.sk> Acked-by: Vineet Gupta <vgupta@synopsys.com> [arch/arc bits] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21mm: invoke oom-killer from remaining unconverted page fault handlersJohannes Weiner
commit 609838cfed972d49a65aac7923a9ff5cbe482e30 upstream. A few remaining architectures directly kill the page faulting task in an out of memory situation. This is usually not a good idea since that task might not even use a significant amount of memory and so may not be the optimal victim to resolve the situation. Since 2.6.29's 1c0fe6e ("mm: invoke oom-killer from page fault") there is a hook that architecture page fault handlers are supposed to call to invoke the OOM killer and let it pick the right task to kill. Convert the remaining architectures over to this hook. To have the previous behavior of simply taking out the faulting task the vm.oom_kill_allocating_task sysctl can be set to 1. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: David Rientjes <rientjes@google.com> Acked-by: Vineet Gupta <vgupta@synopsys.com> [arch/arc bits] Cc: James Hogan <james.hogan@imgtec.com> Cc: David Howells <dhowells@redhat.com> Cc: Jonas Bonn <jonas@southpole.se> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21net: sctp: fix skb_over_panic when receiving malformed ASCONF chunksDaniel Borkmann
commit 9de7922bc709eee2f609cd01d98aaedc4cf5ea74 upstream. Commit 6f4c618ddb0 ("SCTP : Add paramters validity check for ASCONF chunk") added basic verification of ASCONF chunks, however, it is still possible to remotely crash a server by sending a special crafted ASCONF chunk, even up to pre 2.6.12 kernels: skb_over_panic: text:ffffffffa01ea1c3 len:31056 put:30768 head:ffff88011bd81800 data:ffff88011bd81800 tail:0x7950 end:0x440 dev:<NULL> ------------[ cut here ]------------ kernel BUG at net/core/skbuff.c:129! [...] Call Trace: <IRQ> [<ffffffff8144fb1c>] skb_put+0x5c/0x70 [<ffffffffa01ea1c3>] sctp_addto_chunk+0x63/0xd0 [sctp] [<ffffffffa01eadaf>] sctp_process_asconf+0x1af/0x540 [sctp] [<ffffffff8152d025>] ? _read_unlock_bh+0x15/0x20 [<ffffffffa01e0038>] sctp_sf_do_asconf+0x168/0x240 [sctp] [<ffffffffa01e3751>] sctp_do_sm+0x71/0x1210 [sctp] [<ffffffff8147645d>] ? fib_rules_lookup+0xad/0xf0 [<ffffffffa01e6b22>] ? sctp_cmp_addr_exact+0x32/0x40 [sctp] [<ffffffffa01e8393>] sctp_assoc_bh_rcv+0xd3/0x180 [sctp] [<ffffffffa01ee986>] sctp_inq_push+0x56/0x80 [sctp] [<ffffffffa01fcc42>] sctp_rcv+0x982/0xa10 [sctp] [<ffffffffa01d5123>] ? ipt_local_in_hook+0x23/0x28 [iptable_filter] [<ffffffff8148bdc9>] ? nf_iterate+0x69/0xb0 [<ffffffff81496d10>] ? ip_local_deliver_finish+0x0/0x2d0 [<ffffffff8148bf86>] ? nf_hook_slow+0x76/0x120 [<ffffffff81496d10>] ? ip_local_deliver_finish+0x0/0x2d0 [<ffffffff81496ded>] ip_local_deliver_finish+0xdd/0x2d0 [<ffffffff81497078>] ip_local_deliver+0x98/0xa0 [<ffffffff8149653d>] ip_rcv_finish+0x12d/0x440 [<ffffffff81496ac5>] ip_rcv+0x275/0x350 [<ffffffff8145c88b>] __netif_receive_skb+0x4ab/0x750 [<ffffffff81460588>] netif_receive_skb+0x58/0x60 This can be triggered e.g., through a simple scripted nmap connection scan injecting the chunk after the handshake, for example, ... -------------- INIT[ASCONF; ASCONF_ACK] -------------> <----------- INIT-ACK[ASCONF; ASCONF_ACK] ------------ -------------------- COOKIE-ECHO --------------------> <-------------------- COOKIE-ACK --------------------- ------------------ ASCONF; UNKNOWN ------------------> ... where ASCONF chunk of length 280 contains 2 parameters ... 1) Add IP address parameter (param length: 16) 2) Add/del IP address parameter (param length: 255) ... followed by an UNKNOWN chunk of e.g. 4 bytes. Here, the Address Parameter in the ASCONF chunk is even missing, too. This is just an example and similarly-crafted ASCONF chunks could be used just as well. The ASCONF chunk passes through sctp_verify_asconf() as all parameters passed sanity checks, and after walking, we ended up successfully at the chunk end boundary, and thus may invoke sctp_process_asconf(). Parameter walking is done with WORD_ROUND() to take padding into account. In sctp_process_asconf()'s TLV processing, we may fail in sctp_process_asconf_param() e.g., due to removal of the IP address that is also the source address of the packet containing the ASCONF chunk, and thus we need to add all TLVs after the failure to our ASCONF response to remote via helper function sctp_add_asconf_response(), which basically invokes a sctp_addto_chunk() adding the error parameters to the given skb. When walking to the next parameter this time, we proceed with ... length = ntohs(asconf_param->param_hdr.length); asconf_param = (void *)asconf_param + length; ... instead of the WORD_ROUND()'ed length, thus resulting here in an off-by-one that leads to reading the follow-up garbage parameter length of 12336, and thus throwing an skb_over_panic for the reply when trying to sctp_addto_chunk() next time, which implicitly calls the skb_put() with that length. Fix it by using sctp_walk_params() [ which is also used in INIT parameter processing ] macro in the verification *and* in ASCONF processing: it will make sure we don't spill over, that we walk parameters WORD_ROUND()'ed. Moreover, we're being more defensive and guard against unknown parameter types and missized addresses. Joint work with Vlad Yasevich. Fixes: b896b82be4ae ("[SCTP] ADDIP: Support for processing incoming ASCONF_ACK chunks.") Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: Vlad Yasevich <vyasevich@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Josh Boyer <jwboyer@fedoraproject.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21net: sctp: fix panic on duplicate ASCONF chunksDaniel Borkmann
commit b69040d8e39f20d5215a03502a8e8b4c6ab78395 upstream. When receiving a e.g. semi-good formed connection scan in the form of ... -------------- INIT[ASCONF; ASCONF_ACK] -------------> <----------- INIT-ACK[ASCONF; ASCONF_ACK] ------------ -------------------- COOKIE-ECHO --------------------> <-------------------- COOKIE-ACK --------------------- ---------------- ASCONF_a; ASCONF_b -----------------> ... where ASCONF_a equals ASCONF_b chunk (at least both serials need to be equal), we panic an SCTP server! The problem is that good-formed ASCONF chunks that we reply with ASCONF_ACK chunks are cached per serial. Thus, when we receive a same ASCONF chunk twice (e.g. through a lost ASCONF_ACK), we do not need to process them again on the server side (that was the idea, also proposed in the RFC). Instead, we know it was cached and we just resend the cached chunk instead. So far, so good. Where things get nasty is in SCTP's side effect interpreter, that is, sctp_cmd_interpreter(): While incoming ASCONF_a (chunk = event_arg) is being marked !end_of_packet and !singleton, and we have an association context, we do not flush the outqueue the first time after processing the ASCONF_ACK singleton chunk via SCTP_CMD_REPLY. Instead, we keep it queued up, although we set local_cork to 1. Commit 2e3216cd54b1 changed the precedence, so that as long as we get bundled, incoming chunks we try possible bundling on outgoing queue as well. Before this commit, we would just flush the output queue. Now, while ASCONF_a's ASCONF_ACK sits in the corked outq, we continue to process the same ASCONF_b chunk from the packet. As we have cached the previous ASCONF_ACK, we find it, grab it and do another SCTP_CMD_REPLY command on it. So, effectively, we rip the chunk->list pointers and requeue the same ASCONF_ACK chunk another time. Since we process ASCONF_b, it's correctly marked with end_of_packet and we enforce an uncork, and thus flush, thus crashing the kernel. Fix it by testing if the ASCONF_ACK is currently pending and if that is the case, do not requeue it. When flushing the output queue we may relink the chunk for preparing an outgoing packet, but eventually unlink it when it's copied into the skb right before transmission. Joint work with Vlad Yasevich. Fixes: 2e3216cd54b1 ("sctp: Follow security requirement of responding with 1 packet") Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Josh Boyer <jwboyer@fedoraproject.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21net: sctp: fix remote memory pressure from excessive queueingDaniel Borkmann
commit 26b87c7881006311828bb0ab271a551a62dcceb4 upstream. This scenario is not limited to ASCONF, just taken as one example triggering the issue. When receiving ASCONF probes in the form of ... -------------- INIT[ASCONF; ASCONF_ACK] -------------> <----------- INIT-ACK[ASCONF; ASCONF_ACK] ------------ -------------------- COOKIE-ECHO --------------------> <-------------------- COOKIE-ACK --------------------- ---- ASCONF_a; [ASCONF_b; ...; ASCONF_n;] JUNK ------> [...] ---- ASCONF_m; [ASCONF_o; ...; ASCONF_z;] JUNK ------> ... where ASCONF_a, ASCONF_b, ..., ASCONF_z are good-formed ASCONFs and have increasing serial numbers, we process such ASCONF chunk(s) marked with !end_of_packet and !singleton, since we have not yet reached the SCTP packet end. SCTP does only do verification on a chunk by chunk basis, as an SCTP packet is nothing more than just a container of a stream of chunks which it eats up one by one. We could run into the case that we receive a packet with a malformed tail, above marked as trailing JUNK. All previous chunks are here goodformed, so the stack will eat up all previous chunks up to this point. In case JUNK does not fit into a chunk header and there are no more other chunks in the input queue, or in case JUNK contains a garbage chunk header, but the encoded chunk length would exceed the skb tail, or we came here from an entirely different scenario and the chunk has pdiscard=1 mark (without having had a flush point), it will happen, that we will excessively queue up the association's output queue (a correct final chunk may then turn it into a response flood when flushing the queue ;)): I ran a simple script with incremental ASCONF serial numbers and could see the server side consuming excessive amount of RAM [before/after: up to 2GB and more]. The issue at heart is that the chunk train basically ends with !end_of_packet and !singleton markers and since commit 2e3216cd54b1 ("sctp: Follow security requirement of responding with 1 packet") therefore preventing an output queue flush point in sctp_do_sm() -> sctp_cmd_interpreter() on the input chunk (chunk = event_arg) even though local_cork is set, but its precedence has changed since then. In the normal case, the last chunk with end_of_packet=1 would trigger the queue flush to accommodate possible outgoing bundling. In the input queue, sctp_inq_pop() seems to do the right thing in terms of discarding invalid chunks. So, above JUNK will not enter the state machine and instead be released and exit the sctp_assoc_bh_rcv() chunk processing loop. It's simply the flush point being missing at loop exit. Adding a try-flush approach on the output queue might not work as the underlying infrastructure might be long gone at this point due to the side-effect interpreter run. One possibility, albeit a bit of a kludge, would be to defer invalid chunk freeing into the state machine in order to possibly trigger packet discards and thus indirectly a queue flush on error. It would surely be better to discard chunks as in the current, perhaps better controlled environment, but going back and forth, it's simply architecturally not possible. I tried various trailing JUNK attack cases and it seems to look good now. Joint work with Vlad Yasevich. Fixes: 2e3216cd54b1 ("sctp: Follow security requirement of responding with 1 packet") Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Josh Boyer <jwboyer@fedoraproject.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21KVM: x86: Don't report guest userspace emulation error to userspaceNadav Amit
commit a2b9e6c1a35afcc0973acb72e591c714e78885ff upstream. Commit fc3a9157d314 ("KVM: X86: Don't report L2 emulation failures to user-space") disabled the reporting of L2 (nested guest) emulation failures to userspace due to race-condition between a vmexit and the instruction emulator. The same rational applies also to userspace applications that are permitted by the guest OS to access MMIO area or perform PIO. This patch extends the current behavior - of injecting a #UD instead of reporting it to userspace - also for guest userspace code. Signed-off-by: Nadav Amit <namit@cs.technion.ac.il> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21SCSI: hpsa: fix a race in cmd_free/scsi_doneTomas Henzl
commit 2cc5bfaf854463d9d1aa52091f60110fbf102a96 upstream. When the driver calls scsi_done and after that frees it's internal preallocated memory it can happen that a new job is enqueud before the memory is freed. The allocation fails and the message "cmd_alloc returned NULL" is shown. Patch below fixes it by moving cmd->scsi_done after cmd_free. Signed-off-by: Tomas Henzl <thenzl@redhat.com> Acked-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Cc: Masoud Sharbiani <msharbiani@twitter.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21net/mlx4_en: Fix BlueFlame raceEugenia Emantayev
commit 2d4b646613d6b12175b017aca18113945af1faf3 upstream. Fix a race between BlueFlame flow and stamping in post send flow. Example: SW: Build WQE 0 on the TX buffer, except the ownership bit SW: Set ownership for WQE 0 on the TX buffer SW: Ring doorbell for WQE 0 SW: Build WQE 1 on the TX buffer, except the ownership bit SW: Set ownership for WQE 1 on the TX buffer HW: Read WQE 0 and then WQE 1, before doorbell was rung/BF was done for WQE 1 HW: Produce CQEs for WQE 0 and WQE 1 SW: Process the CQEs, and stamp WQE 0 and WQE 1 accordingly (on the TX buffer) SW: Copy WQE 1 from the TX buffer to the BF register - ALREADY STAMPED! HW: CQE error with index 0xFFFF - the BF WQE's control segment is STAMPED, so the BF index is 0xFFFF. Error: Invalid Opcode. As a result QP enters the error state and no traffic can be sent. Solution: When stamping - do not stamp last completed wqe. Signed-off-by: Eugenia Emantayev <eugenia@mellanox.com> Signed-off-by: Amir Vadai <amirv@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Vinson Lee <vlee@twopensource.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21ARM: Correct BUG() assembly to ensure it is endian-agnosticBen Dooks
commit 63328070eff2f4fd730c86966a0dbc976147c39f upstream. Currently BUG() uses .word or .hword to create the necessary illegal instructions. However if we are building BE8 then these get swapped by the linker into different illegal instructions in the text. This means that the BUG() macro does not get trapped properly. Change to using <asm/opcodes.h> to provide the necessary ARM instruction building as we cannot rely on gcc/gas having the `.inst` instructions which where added to try and resolve this issue (reported by Dave Martin <Dave.Martin@arm.com>). Signed-off-by: Ben Dooks <ben.dooks@codethink.co.uk> Reviewed-by: Dave Martin <Dave.Martin@arm.com> Cc: Wang Nan <wangnan0@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21perf/x86/intel: Use proper dTLB-load-misses event on IvyBridgeVince Weaver
commit 1996388e9f4e3444db8273bc08d25164d2967c21 upstream. This was discussed back in February: https://lkml.org/lkml/2014/2/18/956 But I never saw a patch come out of it. On IvyBridge we share the SandyBridge cache event tables, but the dTLB-load-miss event is not compatible. Patch it up after the fact to the proper DTLB_LOAD_MISSES.DEMAND_LD_MISS_CAUSES_A_WALK Signed-off-by: Vince Weaver <vincent.weaver@maine.edu> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/alpine.DEB.2.11.1407141528200.17214@vincent-weaver-1.umelst.maine.edu Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: Hou Pengyang <houpengyang@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21mei: bus: fix possible boundaries violationAlexander Usyskin
commit cfda2794b5afe7ce64ee9605c64bef0e56a48125 upstream. function 'strncpy' will fill whole buffer 'id.name' of fixed size (32) with string value and will not leave place for NULL-terminator. Possible buffer boundaries violation in following string operations. Replace strncpy with strlcpy. Signed-off-by: Alexander Usyskin <alexander.usyskin@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21perf: Handle compat ioctlPawel Moll
commit b3f207855f57b9c8f43a547a801340bb5cbc59e5 upstream. When running a 32-bit userspace on a 64-bit kernel (eg. i386 application on x86_64 kernel or 32-bit arm userspace on arm64 kernel) some of the perf ioctls must be treated with special care, as they have a pointer size encoded in the command. For example, PERF_EVENT_IOC_ID in 32-bit world will be encoded as 0x80042407, but 64-bit kernel will expect 0x80082407. In result the ioctl will fail returning -ENOTTY. This patch solves the problem by adding code fixing up the size as compat_ioctl file operation. Reported-by: Drew Richardson <drew.richardson@arm.com> Signed-off-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1402671812-9078-1-git-send-email-pawel.moll@arm.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: David Ahern <daahern@cisco.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21MIPS: Fix forgotten preempt_enable() when CPU has inclusive pcachesYoichi Yuasa
commit 5596b0b245fb9d2cefb5023b11061050351c1398 upstream. [ 1.904000] BUG: scheduling while atomic: swapper/1/0x00000002 [ 1.908000] Modules linked in: [ 1.916000] CPU: 0 PID: 1 Comm: swapper Not tainted 3.12.0-rc2-lemote-los.git-5318619-dirty #1 [ 1.920000] Stack : 0000000031aac000 ffffffff810d0000 0000000000000052 ffffffff802730a4 0000000000000000 0000000000000001 ffffffff810cdf90 ffffffff810d0000 ffffffff8068b968 ffffffff806f5537 ffffffff810cdf90 980000009f0782e8 0000000000000001 ffffffff80720000 ffffffff806b0000 980000009f078000 980000009f290000 ffffffff805f312c 980000009f05b5d8 ffffffff80233518 980000009f05b5e8 ffffffff80274b7c 980000009f078000 ffffffff8068b968 0000000000000000 0000000000000000 0000000000000000 0000000000000000 0000000000000000 980000009f05b520 0000000000000000 ffffffff805f2f6c 0000000000000000 ffffffff80700000 ffffffff80700000 ffffffff806fc758 ffffffff80700000 ffffffff8020be98 ffffffff806fceb0 ffffffff805f2f6c ... [ 2.028000] Call Trace: [ 2.032000] [<ffffffff8020be98>] show_stack+0x80/0x98 [ 2.036000] [<ffffffff805f2f6c>] __schedule_bug+0x44/0x6c [ 2.040000] [<ffffffff805fac58>] __schedule+0x518/0x5b0 [ 2.044000] [<ffffffff805f8a58>] schedule_timeout+0x128/0x1f0 [ 2.048000] [<ffffffff80240314>] msleep+0x3c/0x60 [ 2.052000] [<ffffffff80495400>] do_probe+0x238/0x3a8 [ 2.056000] [<ffffffff804958b0>] ide_probe_port+0x340/0x7e8 [ 2.060000] [<ffffffff80496028>] ide_host_register+0x2d0/0x7a8 [ 2.064000] [<ffffffff8049c65c>] ide_pci_init_two+0x4e4/0x790 [ 2.068000] [<ffffffff8049f9b8>] amd74xx_probe+0x148/0x2c8 [ 2.072000] [<ffffffff803f571c>] pci_device_probe+0xc4/0x130 [ 2.076000] [<ffffffff80478f60>] driver_probe_device+0x98/0x270 [ 2.080000] [<ffffffff80479298>] __driver_attach+0xe0/0xe8 [ 2.084000] [<ffffffff80476ab0>] bus_for_each_dev+0x78/0xe0 [ 2.088000] [<ffffffff80478468>] bus_add_driver+0x230/0x310 [ 2.092000] [<ffffffff80479b44>] driver_register+0x84/0x158 [ 2.096000] [<ffffffff80200504>] do_one_initcall+0x104/0x160 Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org> Reported-by: Aaro Koskinen <aaro.koskinen@iki.fi> Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi> Cc: linux-mips@linux-mips.org Cc: Linux Kernel Mailing List <linux-kernel@vger.kernel.org> Patchwork: https://patchwork.linux-mips.org/patch/5941/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Alexandre Oliva <lxoliva@fsfla.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21dell-wmi: Fix access out of memoryPali Rohár
commit a666b6ffbc9b6705a3ced704f52c3fe9ea8bf959 upstream. Without this patch, dell-wmi is trying to access elements of dynamically allocated array without checking the array size. This can lead to memory corruption or a kernel panic. This patch adds the missing checks for array size. Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Darren Hart <dvhart@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21ARM: probes: fix instruction fetch order with <asm/opcodes.h>Ben Dooks
commit 888be25402021a425da3e85e2d5a954d7509286e upstream. If we are running BE8, the data and instruction endianness do not match, so use <asm/opcodes.h> to correctly translate memory accesses into ARM instructions. Acked-by: Jon Medhurst <tixy@linaro.org> Signed-off-by: Ben Dooks <ben.dooks@codethink.co.uk> [taras.kondratiuk@linaro.org: fixed Thumb instruction fetch order] Signed-off-by: Taras Kondratiuk <taras.kondratiuk@linaro.org> [wangnan: backport to 3.10 and 3.14: - adjust context - backport all changes on arch/arm/kernel/probes.c to arch/arm/kernel/kprobes-common.c since we don't have commit c18377c303787ded44b7decd7dee694db0f205e9. - After the above adjustments, becomes same to Taras Kondratiuk's original patch: http://lists.linaro.org/pipermail/linaro-kernel/2014-January/010346.html ] Signed-off-by: Wang Nan <wangnan0@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21br: fix use of ->rx_handler_data in code executed on non-rx_handler pathJiri Pirko
commit 859828c0ea476b42f3a93d69d117aaba90994b6f upstream. br_stp_rcv() is reached by non-rx_handler path. That means there is no guarantee that dev is bridge port and therefore simple NULL check of ->rx_handler_data is not enough. There is need to check if dev is really bridge port and since only rcu read lock is held here, do it by checking ->rx_handler pointer. Note that synchronize_net() in netdev_rx_handler_unregister() ensures this approach as valid. Introduced originally by: commit f350a0a87374418635689471606454abc7beaa3a "bridge: use rx_handler_data pointer to store net_bridge_port pointer" Fixed but not in the best way by: commit b5ed54e94d324f17c97852296d61a143f01b227a "bridge: fix RCU races with bridge port" Reintroduced by: commit 716ec052d2280d511e10e90ad54a86f5b5d4dcc2 "bridge: fix NULL pointer deref of br_port_get_rcu" Please apply to stable trees as well. Thanks. RH bugzilla reference: https://bugzilla.redhat.com/show_bug.cgi?id=1025770 Reported-by: Laine Stump <laine@redhat.com> Debugged-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Jiri Pirko <jiri@resnulli.us> Acked-by: Michael S. Tsirkin <mst@redhat.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Andrew Collins <bsderandrew@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21netfilter: nf_nat: fix oops on netns removalFlorian Westphal
commit 945b2b2d259d1a4364a2799e80e8ff32f8c6ee6f upstream. Quoting Samu Kallio: Basically what's happening is, during netns cleanup, nf_nat_net_exit gets called before ipv4_net_exit. As I understand it, nf_nat_net_exit is supposed to kill any conntrack entries which have NAT context (through nf_ct_iterate_cleanup), but for some reason this doesn't happen (perhaps something else is still holding refs to those entries?). When ipv4_net_exit is called, conntrack entries (including those with NAT context) are cleaned up, but the nat_bysource hashtable is long gone - freed in nf_nat_net_exit. The bug happens when attempting to free a conntrack entry whose NAT hash 'prev' field points to a slot in the freed hash table (head for that bin). We ignore conntracks with null nat bindings. But this is wrong, as these are in bysource hash table as well. Restore nat-cleaning for the netns-is-being-removed case. bug: https://bugzilla.kernel.org/show_bug.cgi?id=65191 Fixes: c2d421e1718 ('netfilter: nf_nat: fix race when unloading protocol modules') Reported-by: Samu Kallio <samu.kallio@aberdeencloud.com> Debugged-by: Samu Kallio <samu.kallio@aberdeencloud.com> Signed-off-by: Florian Westphal <fw@strlen.de> Tested-by: Samu Kallio <samu.kallio@aberdeencloud.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> [samu.kallio@aberdeencloud.com: backport to 3.10-stable] Signed-off-by: Samu Kallio <samu.kallio@aberdeencloud.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21netfilter: xt_bpf: add mising opaque struct sk_filter definitionPablo Neira
commit e10038a8ec06ac819b7552bb67aaa6d2d6f850c1 upstream. This structure is not exposed to userspace, so fix this by defining struct sk_filter; so we skip the casting in kernelspace. This is safe since userspace has no way to lurk with that internal pointer. Fixes: e6f30c7 ("netfilter: x_tables: add xt_bpf match") Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Acked-by: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21netfilter: nf_log: release skbuff on nlmsg put failureHoucheng Lin
commit b51d3fa364885a2c1e1668f88776c67c95291820 upstream. The kernel should reserve enough room in the skb so that the DONE message can always be appended. However, in case of e.g. new attribute erronously not being size-accounted for, __nfulnl_send() will still try to put next nlmsg into this full skbuf, causing the skb to be stuck forever and blocking delivery of further messages. Fix issue by releasing skb immediately after nlmsg_put error and WARN() so we can track down the cause of such size mismatch. [ fw@strlen.de: add tailroom/len info to WARN ] Signed-off-by: Houcheng Lin <houcheng@gmail.com> Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21netfilter: nfnetlink_log: fix maximum packet length logged to userspaceFlorian Westphal
commit c1e7dc91eed0ed1a51c9b814d648db18bf8fc6e9 upstream. don't try to queue payloads > 0xffff - NLA_HDRLEN, it does not work. The nla length includes the size of the nla struct, so anything larger results in u16 integer overflow. This patch is similar to 9cefbbc9c8f9abe (netfilter: nfnetlink_queue: cleanup copy_range usage). Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21netfilter: nf_log: account for size of NLMSG_DONE attributeFlorian Westphal
commit 9dfa1dfe4d5e5e66a991321ab08afe69759d797a upstream. We currently neither account for the nlattr size, nor do we consider the size of the trailing NLMSG_DONE when allocating nlmsg skb. This can result in nflog to stop working, as __nfulnl_send() re-tries sending forever if it failed to append NLMSG_DONE (which will never work if buffer is not large enough). Reported-by: Houcheng Lin <houcheng@gmail.com> Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21ipc: always handle a new value of auto_msgmniAndrey Vagin
commit 1195d94e006b23c6292e78857e154872e33b6d7e upstream. proc_dointvec_minmax() returns zero if a new value has been set. So we don't need to check all charecters have been handled. Below you can find two examples. In the new value has not been handled properly. $ strace ./a.out open("/proc/sys/kernel/auto_msgmni", O_WRONLY) = 3 write(3, "0\n\0", 3) = 2 close(3) = 0 exit_group(0) $ cat /sys/kernel/debug/tracing/trace $strace ./a.out open("/proc/sys/kernel/auto_msgmni", O_WRONLY) = 3 write(3, "0\n", 2) = 2 close(3) = 0 $ cat /sys/kernel/debug/tracing/trace a.out-697 [000] .... 3280.998235: unregister_ipcns_notifier <-proc_ipcauto_dointvec_minmax Fixes: 9eefe520c814 ("ipc: do not use a negative value to re-enable msgmni automatic recomputin") Signed-off-by: Andrey Vagin <avagin@openvz.org> Cc: Mathias Krause <minipli@googlemail.com> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Joe Perches <joe@perches.com> Cc: Davidlohr Bueso <davidlohr@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21clocksource: Remove "weak" from clocksource_default_clock() declarationBjorn Helgaas
commit 96a2adbc6f501996418da9f7afe39bf0e4d006a9 upstream. kernel/time/jiffies.c provides a default clocksource_default_clock() definition explicitly marked "weak". arch/s390 provides its own definition intended to override the default, but the "weak" attribute on the declaration applied to the s390 definition as well, so the linker chose one based on link order (see 10629d711ed7 ("PCI: Remove __weak annotation from pcibios_get_phb_of_node decl")). Remove the "weak" attribute from the clocksource_default_clock() declaration so we always prefer a non-weak definition over the weak one, independent of link order. Fixes: f1b82746c1e9 ("clocksource: Cleanup clocksource selection") Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: John Stultz <john.stultz@linaro.org> Acked-by: Ingo Molnar <mingo@kernel.org> CC: Daniel Lezcano <daniel.lezcano@linaro.org> CC: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21kgdb: Remove "weak" from kgdb_arch_pc() declarationBjorn Helgaas
commit 107bcc6d566cb40184068d888637f9aefe6252dd upstream. kernel/debug/debug_core.c provides a default kgdb_arch_pc() definition explicitly marked "weak". Several architectures provide their own definitions intended to override the default, but the "weak" attribute on the declaration applied to the arch definitions as well, so the linker chose one based on link order (see 10629d711ed7 ("PCI: Remove __weak annotation from pcibios_get_phb_of_node decl")). Remove the "weak" attribute from the declaration so we always prefer a non-weak definition over the weak one, independent of link order. Fixes: 688b744d8bc8 ("kgdb: fix signedness mixmatches, add statics, add declaration to header") Tested-by: Vineet Gupta <vgupta@synopsys.com> # for ARC build Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Reviewed-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21media: ttusb-dec: buffer overflow in ioctlDan Carpenter
commit f2e323ec96077642d397bb1c355def536d489d16 upstream. We need to add a limit check here so we don't overflow the buffer. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21NFSv4: Fix races between nfs_remove_bad_delegation() and delegation returnTrond Myklebust
commit 869f9dfa4d6d57b79e0afc3af14772c2a023eeb1 upstream. Any attempt to call nfs_remove_bad_delegation() while a delegation is being returned is currently a no-op. This means that we can end up looping forever in nfs_end_delegation_return() if something causes the delegation to be revoked. This patch adds a mechanism whereby the state recovery code can communicate to the delegation return code that the delegation is no longer valid and that it should not be used when reclaiming state. It also changes the return value for nfs4_handle_delegation_recall_error() to ensure that nfs_end_delegation_return() does not reattempt the lock reclaim before state recovery is done. http://lkml.kernel.org/r/CAN-5tyHwG=Cn2Q9KsHWadewjpTTy_K26ee+UnSvHvG4192p-Xw@mail.gmail.com Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21nfs: Fix use of uninitialized variable in nfs_getattr()Jan Kara
commit 16caf5b6101d03335b386e77e9e14136f989be87 upstream. Variable 'err' needn't be initialized when nfs_getattr() uses it to check whether it should call generic_fillattr() or not. That can result in spurious error returns. Initialize 'err' properly. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21NFS: Don't try to reclaim delegation open state if recovery failedTrond Myklebust
commit f8ebf7a8ca35dde321f0cd385fee6f1950609367 upstream. If state recovery failed, then we should not attempt to reclaim delegated state. http://lkml.kernel.org/r/CAN-5tyHwG=Cn2Q9KsHWadewjpTTy_K26ee+UnSvHvG4192p-Xw@mail.gmail.com Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21NFSv4: Ensure that we remove NFSv4.0 delegations when state has expiredTrond Myklebust
commit 4dfd4f7af0afd201706ad186352ca423b0f17d4b upstream. NFSv4.0 does not have TEST_STATEID/FREE_STATEID functionality, so unlike NFSv4.1, the recovery procedure when stateids have expired or have been revoked requires us to just forget the delegation. http://lkml.kernel.org/r/CAN-5tyHwG=Cn2Q9KsHWadewjpTTy_K26ee+UnSvHvG4192p-Xw@mail.gmail.com Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21Input: alps - allow up to 2 invalid packets without resetting devicePali Rohár
commit 9d720b34c0a432639252f63012e18b0507f5b432 upstream. On some Dell Latitude laptops ALPS device or Dell EC send one invalid byte in 6 bytes ALPS packet. In this case psmouse driver enter out of sync state. It looks like that all other bytes in packets are valid and also device working properly. So there is no need to do full device reset, just need to wait for byte which match condition for first byte (start of packet). Because ALPS packets are bigger (6 or 8 bytes) default limit is small. This patch increase number of invalid bytes to size of 2 ALPS packets which psmouse driver can drop before do full reset. Resetting ALPS devices take some time and when doing reset on some Dell laptops touchpad, trackstick and also keyboard do not respond. So it is better to do it only if really necessary. Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Tested-by: Pali Rohár <pali.rohar@gmail.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21Input: alps - ignore potential bare packets when device is out of syncPali Rohár
commit 4ab8f7f320f91f279c3f06a9795cfea5c972888a upstream. 5th and 6th byte of ALPS trackstick V3 protocol match condition for first byte of PS/2 3 bytes packet. When driver enters out of sync state and ALPS trackstick is sending data then driver match 5th, 6th and next 1st bytes as PS/2. It basically means if user is using trackstick when driver is in out of sync state driver will never resync. Processing these bytes as 3 bytes PS/2 data cause total mess (random cursor movements, random clicks) and make trackstick unusable until psmouse driver decide to do full device reset. Lot of users reported problems with ALPS devices on Dell Latitude E6440, E6540 and E7440 laptops. ALPS device or Dell EC for unknown reason send some invalid ALPS PS/2 bytes which cause driver out of sync. It looks like that i8042 and psmouse/alps driver always receive group of 6 bytes packets so there are no missing bytes and no bytes were inserted between valid ones. This patch does not fix root of problem with ALPS devices found in Dell Latitude laptops but it does not allow to process some (invalid) subsequence of 6 bytes ALPS packets as 3 bytes PS/2 when driver is out of sync. So with this patch trackstick input device does not report bogus data when also driver is out of sync, so trackstick should be usable on those machines. Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Tested-by: Pali Rohár <pali.rohar@gmail.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21dm raid: ensure superblock's size matches device's logical block sizeHeinz Mauelshagen
commit 40d43c4b4cac4c2647bf07110d7b07d35f399a84 upstream. The dm-raid superblock (struct dm_raid_superblock) is padded to 512 bytes and that size is being used to read it in from the metadata device into one preallocated page. Reading or writing this on a 512-byte sector device works fine but on a 4096-byte sector device this fails. Set the dm-raid superblock's size to the logical block size of the metadata device, because IO at that size is guaranteed too work. Also add a size check to avoid silent partial metadata loss in case the superblock should ever grow past the logical block size or PAGE_SIZE. [includes pointer math fix from Dan Carpenter] Reported-by: "Liuhua Wang" <lwang@suse.com> Signed-off-by: Heinz Mauelshagen <heinzm@redhat.com> Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21dm btree: fix a recursion depth bug in btree walking codeJoe Thornber
commit 9b460d3699324d570a4d4161c3741431887f102f upstream. The walk code was using a 'ro_spine' to hold it's locked btree nodes. But this data structure is designed for the rolling lock scheme, and as such automatically unlocks blocks that are two steps up the call chain. This is not suitable for the simple recursive walk algorithm, which retraces its steps. This code is only used by the persistent array code, which in turn is only used by dm-cache. In order to trigger it you need to have a mapping tree that is more than 2 levels deep; which equates to 8-16 million cache blocks. For instance a 4T ssd with a very small block size of 32k only just triggers this bug. The fix just places the locked blocks on the stack, and stops using the ro_spine altogether. Signed-off-by: Joe Thornber <ejt@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21block: Fix computation of merged request priorityJan Kara
commit ece9c72accdc45c3a9484dacb1125ce572647288 upstream. Priority of a merged request is computed by ioprio_best(). If one of the requests has undefined priority (IOPRIO_CLASS_NONE) and another request has priority from IOPRIO_CLASS_BE, the function will return the undefined priority which is wrong. Fix the function to properly return priority of a request with the defined priority. Fixes: d58cdfb89ce0c6bd5f81ae931a984ef298dbda20 Signed-off-by: Jan Kara <jack@suse.cz> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jens Axboe <axboe@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21parisc: Use compat layer for msgctl, shmat, shmctl and semtimedop syscallsHelge Deller
commit 2fe749f50b0bec07650ef135b29b1f55bf543869 upstream. Switch over the msgctl, shmat, shmctl and semtimedop syscalls to use the compat layer. The problem was found with the debian procenv package, which called shmctl(0, SHM_INFO, &info); in which the shmctl syscall then overwrote parts of the surrounding areas on the stack on which the info variable was stored and thus lead to a segfault later on. Additionally fix the definition of struct shminfo64 to use unsigned longs like the other architectures. This has no impact on userspace since we only have a 32bit userspace up to now. Signed-off-by: Helge Deller <deller@gmx.de> Cc: John David Anglin <dave.anglin@bell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21scsi: only re-lock door after EH on devices that were resetChristoph Hellwig
commit 48379270fe6808cf4612ee094adc8da2b7a83baa upstream. Setups that use the blk-mq I/O path can lock up if a host with a single device that has its door locked enters EH. Make sure to only send the command to re-lock the door to devices that actually were reset and thus might have lost their state. Otherwise the EH code might be get blocked on blk_get_request as all requests for non-reset devices might be in use. Signed-off-by: Christoph Hellwig <hch@lst.de> Reported-by: Meelis Roos <meelis.roos@ut.ee> Tested-by: Meelis Roos <meelis.roos@ut.ee> Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21nfs: fix pnfs direct write memory leakPeng Tao
commit 8c393f9a721c30a030049a680e1bf896669bb279 upstream. For pNFS direct writes, layout driver may dynamically allocate ds_cinfo.buckets. So we need to take care to free them when freeing dreq. Ideally this needs to be done inside layout driver where ds_cinfo.buckets are allocated. But buckets are attached to dreq and reused across LD IO iterations. So I feel it's OK to free them in the generic layer. Signed-off-by: Peng Tao <tao.peng@primarydata.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21firewire: cdev: prevent kernel stack leaking into ioctl argumentsStefan Richter
commit eaca2d8e75e90a70a63a6695c9f61932609db212 upstream. Found by the UC-KLEE tool: A user could supply less input to firewire-cdev ioctls than write- or write/read-type ioctl handlers expect. The handlers used data from uninitialized kernel stack then. This could partially leak back to the user if the kernel subsequently generated fw_cdev_event_'s (to be read from the firewire-cdev fd) which notably would contain the _u64 closure field which many of the ioctl argument structures contain. The fact that the handlers would act on random garbage input is a lesser issue since all handlers must check their input anyway. The fix simply always null-initializes the entire ioctl argument buffer regardless of the actual length of expected user input. That is, a runtime overhead of memset(..., 40) is added to each firewirew-cdev ioctl() call. [Comment from Clemens Ladisch: This part of the stack is most likely to be already in the cache.] Remarks: - There was never any leak from kernel stack to the ioctl output buffer itself. IOW, it was not possible to read kernel stack by a read-type or write/read-type ioctl alone; the leak could at most happen in combination with read()ing subsequent event data. - The actual expected minimum user input of each ioctl from include/uapi/linux/firewire-cdev.h is, in bytes: [0x00] = 32, [0x05] = 4, [0x0a] = 16, [0x0f] = 20, [0x14] = 16, [0x01] = 36, [0x06] = 20, [0x0b] = 4, [0x10] = 20, [0x15] = 20, [0x02] = 20, [0x07] = 4, [0x0c] = 0, [0x11] = 0, [0x16] = 8, [0x03] = 4, [0x08] = 24, [0x0d] = 20, [0x12] = 36, [0x17] = 12, [0x04] = 20, [0x09] = 24, [0x0e] = 4, [0x13] = 40, [0x18] = 4. Reported-by: David Ramos <daramos@stanford.edu> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21arm64: __clear_user: handle exceptions on strbKyle McMartin
commit 97fc15436b36ee3956efad83e22a557991f7d19d upstream. ARM64 currently doesn't fix up faults on the single-byte (strb) case of __clear_user... which means that we can cause a nasty kernel panic as an ordinary user with any multiple PAGE_SIZE+1 read from /dev/zero. i.e.: dd if=/dev/zero of=foo ibs=1 count=1 (or ibs=65537, etc.) This is a pretty obscure bug in the general case since we'll only __do_kernel_fault (since there's no extable entry for pc) if the mmap_sem is contended. However, with CONFIG_DEBUG_VM enabled, we'll always fault. if (!down_read_trylock(&mm->mmap_sem)) { if (!user_mode(regs) && !search_exception_tables(regs->pc)) goto no_context; retry: down_read(&mm->mmap_sem); } else { /* * The above down_read_trylock() might have succeeded in * which * case, we'll have missed the might_sleep() from * down_read(). */ might_sleep(); if (!user_mode(regs) && !search_exception_tables(regs->pc)) goto no_context; } Fix that by adding an extable entry for the strb instruction, since it touches user memory, similar to the other stores in __clear_user. Signed-off-by: Kyle McMartin <kyle@redhat.com> Reported-by: Miloš Prchlík <mprchlik@redhat.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21ARM: 8198/1: make kuser helpers depend on MMUNathan Lynch
commit 08b964ff3c51b10aaf2e6ba639f40054c09f0f7a upstream. The kuser helpers page is not set up on non-MMU systems, so it does not make sense to allow CONFIG_KUSER_HELPERS to be enabled when CONFIG_MMU=n. Allowing it to be set on !MMU results in an oops in set_tls (used in execve and the arm_syscall trap handler): Unhandled exception: IPSR = 00000005 LR = fffffff1 CPU: 0 PID: 1 Comm: swapper Not tainted 3.18.0-rc1-00041-ga30465a #216 task: 8b838000 ti: 8b82a000 task.ti: 8b82a000 PC is at flush_thread+0x32/0x40 LR is at flush_thread+0x21/0x40 pc : [<8f00157a>] lr : [<8f001569>] psr: 4100000b sp : 8b82be20 ip : 00000000 fp : 8b83c000 r10: 00000001 r9 : 88018c84 r8 : 8bb85000 r7 : 8b838000 r6 : 00000000 r5 : 8bb77400 r4 : 8b82a000 r3 : ffff0ff0 r2 : 8b82a000 r1 : 00000000 r0 : 88020354 xPSR: 4100000b CPU: 0 PID: 1 Comm: swapper Not tainted 3.18.0-rc1-00041-ga30465a #216 [<8f002bc1>] (unwind_backtrace) from [<8f002033>] (show_stack+0xb/0xc) [<8f002033>] (show_stack) from [<8f00265b>] (__invalid_entry+0x4b/0x4c) As best I can tell this issue existed for the set_tls ARM syscall before commit fbfb872f5f41 "ARM: 8148/1: flush TLS and thumbee register state during exec" consolidated the TLS manipulation code into the set_tls helper function, but now that we're using it to flush register state during execve, !MMU users encounter the oops at the first exec. Prevent CONFIG_MMU=n configurations from enabling CONFIG_KUSER_HELPERS. Fixes: fbfb872f5f41 (ARM: 8148/1: flush TLS and thumbee register state during exec) Signed-off-by: Nathan Lynch <nathan_lynch@mentor.com> Reported-by: Stefan Agner <stefan@agner.ch> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21drm/radeon: add missing crtc unlock when setting up the MCAlex Deucher
commit f0d7bfb9407fccb6499ec01c33afe43512a439a2 upstream. Need to unlock the crtc after updating the blanking state. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21mac80211: fix use-after-free in defragmentationJohannes Berg
commit b8fff407a180286aa683d543d878d98d9fc57b13 upstream. Upon receiving the last fragment, all but the first fragment are freed, but the multicast check for statistics at the end of the function refers to the current skb (the last fragment) causing a use-after-free bug. Since multicast frames cannot be fragmented and we check for this early in the function, just modify that check to also do the accounting to fix the issue. Reported-by: Yosef Khyal <yosefx.khyal@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
