2013-08-04Linux 3.10.5v3.10.5Greg Kroah-Hartman
2013-08-04x86: Fix /proc/mtrr with base/size more than 44bitsYinghai Lu
commit d5c78673b1b28467354c2c30c3d4f003666ff385 upstream. On one sytem that mtrr range is more then 44bits, in dmesg we have [ 0.000000] MTRR default type: write-back [ 0.000000] MTRR fixed ranges enabled: [ 0.000000] 00000-9FFFF write-back [ 0.000000] A0000-BFFFF uncachable [ 0.000000] C0000-DFFFF write-through [ 0.000000] E0000-FFFFF write-protect [ 0.000000] MTRR variable ranges enabled: [ 0.000000] 0 [000080000000-0000FFFFFFFF] mask 3FFF80000000 uncachable [ 0.000000] 1 [380000000000-38FFFFFFFFFF] mask 3F0000000000 uncachable [ 0.000000] 2 [000099000000-000099FFFFFF] mask 3FFFFF000000 write-through [ 0.000000] 3 [00009A000000-00009AFFFFFF] mask 3FFFFF000000 write-through [ 0.000000] 4 [381FFA000000-381FFBFFFFFF] mask 3FFFFE000000 write-through [ 0.000000] 5 [381FFC000000-381FFC0FFFFF] mask 3FFFFFF00000 write-through [ 0.000000] 6 [0000AD000000-0000ADFFFFFF] mask 3FFFFF000000 write-through [ 0.000000] 7 [0000BD000000-0000BDFFFFFF] mask 3FFFFF000000 write-through [ 0.000000] 8 disabled [ 0.000000] 9 disabled but /proc/mtrr report wrong: reg00: base=0x080000000 ( 2048MB), size= 2048MB, count=1: uncachable reg01: base=0x80000000000 (8388608MB), size=1048576MB, count=1: uncachable reg02: base=0x099000000 ( 2448MB), size= 16MB, count=1: write-through reg03: base=0x09a000000 ( 2464MB), size= 16MB, count=1: write-through reg04: base=0x81ffa000000 (8519584MB), size= 32MB, count=1: write-through reg05: base=0x81ffc000000 (8519616MB), size= 1MB, count=1: write-through reg06: base=0x0ad000000 ( 2768MB), size= 16MB, count=1: write-through reg07: base=0x0bd000000 ( 3024MB), size= 16MB, count=1: write-through reg08: base=0x09b000000 ( 2480MB), size= 16MB, count=1: write-combining so bit 44 and bit 45 get cut off. We have problems in arch/x86/kernel/cpu/mtrr/generic.c::generic_get_mtrr(). 1. for base, we miss cast base_lo to 64bit before shifting. Fix that by adding u64 casting. 2. for size, it only can handle 44 bits aka 32bits + page_shift Fix that with 64bit mask instead of 32bit mask_lo, then range could be more than 44bits. At the same time, we need to update size_or_mask for old cpus that does support cpuid 0x80000008 to get phys_addr. Need to set high 32bits to all 1s, otherwise will not get correct size for them. Also fix mtrr_add_page: it should check base and (base + size - 1) instead of base and size, as base and size could be small but base + size could bigger enough to be out of boundary. We can use boot_cpu_data.x86_phys_bits directly to avoid size_or_mask. So When are we going to have size more than 44bits? that is 16TiB. after patch we have right ouput: reg00: base=0x080000000 ( 2048MB), size= 2048MB, count=1: uncachable reg01: base=0x380000000000 (58720256MB), size=1048576MB, count=1: uncachable reg02: base=0x099000000 ( 2448MB), size= 16MB, count=1: write-through reg03: base=0x09a000000 ( 2464MB), size= 16MB, count=1: write-through reg04: base=0x381ffa000000 (58851232MB), size= 32MB, count=1: write-through reg05: base=0x381ffc000000 (58851264MB), size= 1MB, count=1: write-through reg06: base=0x0ad000000 ( 2768MB), size= 16MB, count=1: write-through reg07: base=0x0bd000000 ( 3024MB), size= 16MB, count=1: write-through reg08: base=0x09b000000 ( 2480MB), size= 16MB, count=1: write-combining -v2: simply checking in mtrr_add_page according to hpa. [ hpa: This probably wants to go into -stable only after having sat in mainline for a bit. It is not a regression. ] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Link: http://lkml.kernel.org/r/1371162815-29931-1-git-send-email-yinghai@kernel.org Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04drm/i915: Correct obj->mm_list link to dev_priv->dev_priv->mm.inactive_listXiong Zhang
commit 067556084a0e412013af6b0250a3143ae5afde6d upstream. obj->mm_list link to dev_priv->mm.inactive_list/active_list obj->global_list link to dev_priv->mm.unbound_list/bound_list This regression has been introduced in commit 93927ca52a55c23e0a6a305e7e9082e8411ac9fa Author: Daniel Vetter <daniel.vetter@ffwll.ch> Date: Thu Jan 10 18:03:00 2013 +0100 drm/i915: Revert shrinker changes from "Track unbound pages" Cc: stable@vger.kernel.org Signed-off-by: Xiong Zhang <xiong.y.zhang@intel.com> [danvet: Add regression notice.] Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Zhouping Liu <zliu@redhat.com>
2013-08-04perf tools: Revert regression in configuration of Python supportMichael Witten
commit a363a9da65d253fa7354ce5fd630f4f94df934cc upstream. Among other things, the following: commit 31160d7feab786c991780d7f0ce2755a469e0e5e Date: Tue Jan 8 16:22:36 2013 -0500 perf tools: Fix GNU make v3.80 compatibility issue attempts to aid the user by tapping into an existing error message, as described in the commit message: ... Also fix an issue where _get_attempt was called with only one argument. This prevented the error message from printing the name of the variable that can be used to fix the problem. or more precisely: -$(if $($(1)),$(call _ge_attempt,$($(1)),$(1)),$(call _ge_attempt,$(2))) +$(if $($(1)),$(call _ge_attempt,$($(1)),$(1)),$(call _ge_attempt,$(2),$(1))) However, The "missing" argument was in fact missing on purpose; it's absence is a signal that the error message should be skipped, because the failure would be due to the default value, not any user-supplied value. This can be seen in how `_ge_attempt' uses `gea_err' (in the config/utilities.mak file): _ge_attempt = $(if $(get-executable),$(get-executable),$(_gea_warn)$(call _gea_err,$(2))) _gea_warn = $(warning The path '$(1)' is not executable.) _gea_err = $(if $(1),$(error Please set '$(1)' appropriately)) That is, because the argument is no longer missing, the value `$(1)' (associated with `_gea_err') always evaluates to true, thus always triggering the error condition that is meant to be reserved for only the case when a user explicitly supplies an invalid value. Concretely, the result is a regression in the Makefile's configuration of python support; rather than gracefully disable support when the relevant executables cannot be found according to default values, the build process halts in error as though the user explicitly supplied the values. This new commit simply reverts the offending one-line change. Reported-by: Pekka Enberg <penberg@kernel.org> Link: http://lkml.kernel.org/r/CAOJsxLHv17Ys3M7P5q25imkUxQW6LE_vABxh1N3Tt7Mv6Ho4iw@mail.gmail.com Signed-off-by: Michael Witten <mfwitten@gmail.com> Cc: Mark Brown <broonie@sirena.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04iscsi-target: Fix iscsit_sequence_cmd reject handling for iserNicholas Bellinger
commit 561bf15892375597ee59d473a704a3e634c4f311 upstream This patch moves ISCSI_OP_REJECT failures into iscsit_sequence_cmd() in order to avoid external iscsit_reject_cmd() reject usage for all PDU types. It also updates PDU specific handlers for traditional iscsi-target code to not reset the session after posting a ISCSI_OP_REJECT during setup. (v2: Fix CMDSN_LOWER_THAN_EXP for ISCSI_OP_SCSI to call target_put_sess_cmd() after iscsit_sequence_cmd() failure) Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Cc: Or Gerlitz <ogerlitz@mellanox.com> Cc: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04iscsi-target: Fix iscsit_add_reject* usage for iserNicholas Bellinger
commit ba159914086f06532079fc15141f46ffe7e04a41 upstream This patch changes iscsit_add_reject() + iscsit_add_reject_from_cmd() usage to not sleep on iscsi_cmd->reject_comp to address a free-after-use usage bug in v3.10 with iser-target code. It saves ->reject_reason for use within iscsit_build_reject() so the correct value for both transport cases. It also drops the legacy fail_conn parameter usage throughput iscsi-target code and adds two iscsit_add_reject_cmd() and iscsit_reject_cmd helper functions, along with various small cleanups. (v2: Re-enable target_put_sess_cmd() to be called from iscsit_add_reject_from_cmd() for rejects invoked after target_get_sess_cmd() has been called) Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Cc: Or Gerlitz <ogerlitz@mellanox.com> Cc: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04radeon kms: do not flush uninitialized hotplug workSergey Senozhatsky
commit a01c34f72e7cd2624570818f579b5ab464f93de2 upstream. Fix a warning from lockdep caused by calling flush_work() for uninitialized hotplug work. Initialize hotplug_work, audio_work and reset_work upon successful radeon_irq_kms_init() completion and thus perform hotplug flush_work only when rdev->irq.installed is true. [ 4.790019] [drm] Loading CEDAR Microcode [ 4.790943] r600_cp: Failed to load firmware "radeon/CEDAR_smc.bin" [ 4.791152] [drm:evergreen_startup] *ERROR* Failed to load firmware! [ 4.791330] radeon 0000:01:00.0: disabling GPU acceleration [ 4.792633] INFO: trying to register non-static key. [ 4.792792] the code is fine but needs lockdep annotation. [ 4.792953] turning off the locking correctness validator. [ 4.793114] CPU: 2 PID: 1 Comm: swapper/0 Not tainted 3.11.0-rc0-dbg-10676-gfe56456-dirty #1816 [ 4.793314] Hardware name: Acer Aspire 5741G /Aspire 5741G , BIOS V1.20 02/08/2011 [ 4.793507] ffffffff821fd810 ffff8801530b9a18 ffffffff8160434e 0000000000000002 [ 4.794155] ffff8801530b9ad8 ffffffff810b8404 ffff8801530b0798 ffff8801530b0000 [ 4.794789] ffff8801530b9b00 0000000000000046 00000000000004c0 ffffffff00000000 [ 4.795418] Call Trace: [ 4.795573] [<ffffffff8160434e>] dump_stack+0x4e/0x82 [ 4.795731] [<ffffffff810b8404>] __lock_acquire+0x1a64/0x1d30 [ 4.795893] [<ffffffff814a87f0>] ? dev_vprintk_emit+0x50/0x60 [ 4.796034] [<ffffffff810b8fb4>] lock_acquire+0xa4/0x200 [ 4.796216] [<ffffffff8106cd75>] ? flush_work+0x5/0x280 [ 4.796375] [<ffffffff8106cdad>] flush_work+0x3d/0x280 [ 4.796520] [<ffffffff8106cd75>] ? flush_work+0x5/0x280 [ 4.796682] [<ffffffff810b659d>] ? trace_hardirqs_on_caller+0xfd/0x1c0 [ 4.796862] [<ffffffff8131d775>] ? delay_tsc+0x95/0xf0 [ 4.797024] [<ffffffff8141bb8b>] radeon_irq_kms_fini+0x2b/0x70 [ 4.797186] [<ffffffff814557c9>] evergreen_init+0x2a9/0x2e0 [ 4.797347] [<ffffffff813ebb1f>] radeon_device_init+0x5ef/0x700 [ 4.797511] [<ffffffff81335bc7>] ? pci_find_capability+0x47/0x50 [ 4.797672] [<ffffffff813edaed>] radeon_driver_load_kms+0x8d/0x150 [ 4.797843] [<ffffffff813ce426>] drm_get_pci_dev+0x166/0x280 [ 4.798007] [<ffffffff8116cff5>] ? kfree+0xf5/0x2e0 [ 4.798168] [<ffffffff813ea298>] ? radeon_pci_probe+0x98/0xd0 [ 4.798329] [<ffffffff813ea2aa>] radeon_pci_probe+0xaa/0xd0 [ 4.798489] [<ffffffff81339404>] pci_device_probe+0x84/0xe0 [ 4.798644] [<ffffffff814ac7d6>] driver_probe_device+0x76/0x240 [ 4.798805] [<ffffffff814aca73>] __driver_attach+0x93/0xa0 [ 4.798948] [<ffffffff814ac9e0>] ? __device_attach+0x40/0x40 [ 4.799126] [<ffffffff814aa82b>] bus_for_each_dev+0x6b/0xb0 [ 4.799272] [<ffffffff814ac2be>] driver_attach+0x1e/0x20 [ 4.799434] [<ffffffff814abec0>] bus_add_driver+0x1f0/0x280 [ 4.799596] [<ffffffff814ad0e4>] driver_register+0x74/0x150 [ 4.799758] [<ffffffff8133923d>] __pci_register_driver+0x5d/0x60 [ 4.799936] [<ffffffff81d16efc>] ? ttm_init+0x67/0x67 [ 4.800081] [<ffffffff813ce655>] drm_pci_init+0x115/0x130 [ 4.800243] [<ffffffff81d16efc>] ? ttm_init+0x67/0x67 [ 4.800405] [<ffffffff81d16f98>] radeon_init+0x9c/0xba [ 4.800586] [<ffffffff810002ca>] do_one_initcall+0xfa/0x150 [ 4.800746] [<ffffffff81073f60>] ? parse_args+0x120/0x330 [ 4.800909] [<ffffffff81cdafae>] kernel_init_freeable+0x111/0x191 [ 4.801052] [<ffffffff81cda87a>] ? do_early_param+0x88/0x88 [ 4.801233] [<ffffffff815fb670>] ? rest_init+0x140/0x140 [ 4.801393] [<ffffffff815fb67e>] kernel_init+0xe/0x180 [ 4.801556] [<ffffffff8160dcac>] ret_from_fork+0x7c/0xb0 [ 4.801718] [<ffffffff815fb670>] ? rest_init+0x140/0x140 Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04xen/evtchn: avoid a deadlock when unbinding an event channelDavid Vrabel
commit 179fbd5a45f0d4034cc6fd37b8d367a3b79663c4 upstream. Unbinding an event channel (either with the ioctl or when the evtchn device is closed) may deadlock because disable_irq() is called with port_user_lock held which is also locked by the interrupt handler. Think of the IOCTL_EVTCHN_UNBIND is being serviced, the routine has just taken the lock, and an interrupt happens. The evtchn_interrupt is invoked, tries to take the lock and spins forever. A quick glance at the code shows that the spinlock is a local IRQ variant. Unfortunately that does not help as "disable_irq() waits for the interrupt handler on all CPUs to stop running. If the irq occurs on another VCPU, it tries to take port_user_lock and can't because the unbind ioctl is holding it." (from David). Hence we cannot depend on the said spinlock to protect us. We could make it a system wide IRQ disable spinlock but there is a better way. We can piggyback on the fact that the existence of the spinlock is to make get_port_user() checks be up-to-date. And we can alter those checks to not depend on the spin lock (as it's protected by u->bind_mutex in the ioctl) and can remove the unnecessary locking (this is IOCTL_EVTCHN_UNBIND) path. In the interrupt handler we cannot use the mutex, but we do not need it. "The unbind disables the irq before making the port user stale, so when you clear it you are guaranteed that the interrupt handler that might use that port cannot be running." (from David). Hence this patch removes the spinlock usage on the teardown path and piggybacks on disable_irq happening before we muck with the get_port_user() data. This ensures that the interrupt handler will never run on stale data. Signed-off-by: David Vrabel <david.vrabel@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> [v1: Expanded the commit description a bit] Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04livelock avoidance in sget()Al Viro
commit acfec9a5a892f98461f52ed5770de99a3e571ae2 upstream. Eric Sandeen has found a nasty livelock in sget() - take a mount(2) about to fail. The superblock is on ->fs_supers, ->s_umount is held exclusive, ->s_active is 1. Along comes two more processes, trying to mount the same thing; sget() in each is picking that superblock, bumping ->s_count and trying to grab ->s_umount. ->s_active is 3 now. Original mount(2) finally gets to deactivate_locked_super() on failure; ->s_active is 2, superblock is still ->fs_supers because shutdown will *not* happen until ->s_active hits 0. ->s_umount is dropped and now we have two processes chasing each other: s_active = 2, A acquired ->s_umount, B blocked A sees that the damn thing is stillborn, does deactivate_locked_super() s_active = 1, A drops ->s_umount, B gets it A restarts the search and finds the same superblock. And bumps it ->s_active. s_active = 2, B holds ->s_umount, A blocked on trying to get it ... and we are in the earlier situation with A and B switched places. The root cause, of course, is that ->s_active should not grow until we'd got MS_BORN. Then failing ->mount() will have deactivate_locked_super() shut the damn thing down. Fortunately, it's easy to do - the key point is that grab_super() is called only for superblocks currently on ->fs_supers, so it can bump ->s_count and grab ->s_umount first, then check MS_BORN and bump ->s_active; we must never increment ->s_count for superblocks past ->kill_sb(), but grab_super() is never called for those. The bug is pretty old; we would've caught it by now, if not for accidental exclusion between sget() for block filesystems; the things like cgroup or e.g. mtd-based filesystems don't have anything of that sort, so they get bitten. The right way to deal with that is obviously to fix sget()... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04tty_port: Fix refcounting leak in tty_port_tty_hangup()Gianluca Anzolin
commit 1d9e689c934bd5ecb0f273c6c65e0655c5cfee5f upstream. The function tty_port_tty_hangup() could leak a reference to the tty_struct: struct tty_struct *tty = tty_port_tty_get(port); if (tty && (!check_clocal || !C_CLOCAL(tty))) { tty_hangup(tty); tty_kref_put(tty); } If tty != NULL and the second condition is false we never call tty_kref_put and the reference is leaked. Fix by always calling tty_kref_put() which accepts a NULL argument. The patch fixes a regression introduced by commit aa27a094. Acked-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Signed-off-by: Gianluca Anzolin <gianluca@sottospazio.it> Acked-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04mm: mempolicy: fix mbind_range() && vma_adjust() interactionOleg Nesterov
commit 3964acd0dbec123aa0a621973a2a0580034b4788 upstream. vma_adjust() does vma_set_policy(vma, vma_policy(next)) and this is doubly wrong: 1. This leaks vma->vm_policy if it is not NULL and not equal to next->vm_policy. This can happen if vma_merge() expands "area", not prev (case 8). 2. This sets the wrong policy if vma_merge() joins prev and area, area is the vma the caller needs to update and it still has the old policy. Revert commit 1444f92c8498 ("mm: merging memory blocks resets mempolicy") which introduced these problems. Change mbind_range() to recheck mpol_equal() after vma_merge() to fix the problem that commit tried to address. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Steven T Hampson <steven.t.hampson@intel.com> Cc: Mel Gorman <mgorman@suse.de> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04usb: gadget: udc-core: fix the typo of udc state attributeRong Wang
commit 1894870eb4240399fabc6f0cb8c6fff4e6edbe83 upstream. The name of udc state attribute file under sysfs is registered as "state", while usb_gadget_set_state take it as "status" when it's going to update. This patch fixes the typo. Signed-off-by: Rong Wang <Rong.Wang@csr.com> Signed-off-by: Barry Song <Baohua.Song@csr.com> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04USB: serial: ftdi_sio: add more RT Systems ftdi devicesRick Farina (Zero_Chaos)
commit fed1f1ed90bce42ea010e2904cbc04e7b8304940 upstream. RT Systems makes many usb serial cables based on the ftdi_sio driver for programming various amateur radios. This patch is a full listing of their current product offerings and should allow these cables to all be recognized. Signed-off-by: Rick Farina (Zero_Chaos) <zerochaos@gentoo.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04rtlwifi: Initialize power-setting callback for USB devicesLarry Finger
commit bcfb879432094c267c35a7ff75d953d3a66c193a upstream. Commit a269913c5 entitled "rtlwifi: Rework rtl_lps_leave() and rtl_lps_enter() to use work queue" has two bugs for USB drivers. Firstly, the work queue in question was not initialized. Secondly, the callback routine used by this queue is contained within the file used for PCI devices. As a result, it is not available for architectures without PCI hardware. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Reported-by: Richard Genoud <richard.genoud@gmail.com> Tested-by: Richard Genoud <richard.genoud@gmail.com> Cc: Richard Genoud <richard.genoud@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04drm/radeon/atom: initialize more atom interpretor elements to 0Alex Deucher
commit 42a21826dc54583cdb79cc8477732e911ac9c376 upstream. The ProcessAuxChannel table on some rv635 boards assumes the divmul members are initialized to 0 otherwise we get an invalid fb offset since it has a bad mask set when setting the fb base. While here initialize all the atom interpretor elements to 0. Fixes: https://bugzilla.kernel.org/show_bug.cgi?id=60639 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04drm/radeon: fix audio dto programming on DCE4+Alex Deucher
commit 7d61d835824f73dc4097b51f800382467c8049c5 upstream. We need to set the dto source before setting the dividers otherwise we may get stability problems with the dto leading to audio playback problems. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Reviewed-by: Christian König <christian.koenig@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04drm/nouveau: fix semaphore dmabuf objMaarten Lankhorst
commit 7a7da592cbb22a1d360638dbecc393470c5effe3 upstream. Fixes some dmabuf object errors on nv50 chipset and below. Signed-off-by: Maarten Lankhorst <maarten.lankhorst@canonical.com> Signed-off-by: Ben Skeggs <bskeggs@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04drm/i915: fix missed hunk after GT access breakageBen Widawsky
commit e1b4d3036c07ff137955fb1c0197ab62534f46ec upstream. Upon some code refactoring, a hunk was missed. This was fixed for next, but missed the current trees, and hasn't yet been merged by Dave Airlie. It is fixed in: commit 907b28c56ea40629aa6595ddfa414ec2fc7da41c Author: Chris Wilson <chris@chris-wilson.co.uk> Date: Fri Jul 19 20:36:52 2013 +0100 drm/i915: Colocate all GT access routines in the same file It is introduced by: commit 181d1b9e31c668259d3798c521672afb8edd355c Author: Daniel Vetter <daniel.vetter@ffwll.ch> Date: Sun Jul 21 13:16:24 2013 +0200 drm/i915: fix up gt init sequence fallout Reported-by: Dave Jones <davej@redhat.com> Signed-off-by: Ben Widawsky <ben@bwidawsk.net> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04drm/i915: fix up gt init sequence falloutDaniel Vetter
commit 181d1b9e31c668259d3798c521672afb8edd355c upstream. The regression fix for gen6+ rps fallout commit 7dcd2677ea912573d9ed4bcd629b0023b2d11505 Author: Konstantin Khlebnikov <khlebnikov@openvz.org> Date: Wed Jul 17 10:22:58 2013 +0400 drm/i915: fix long-standing SNB regression in power consumption after resume unintentionally also changed the init sequence ordering between gt_init and gt_reset - we need to reset BIOS damage like leftover forcewake references before we run our own code. Otherwise we can get nasty dmesg noise like [drm:__gen6_gt_force_wake_mt_get] *ERROR* Timed out waiting for forcewake old ack to clear. again. Since _reset suggests that we first need to have stuff initialized (which isn't the case here) call it sanitze instead. While at it also block out the rps disable introduced by the above commit on ilk: We don't have any knowledge of ilk rps being broken in similar ways. And the disable functions uses the default hw state which is only read out when we're enabling rps. So essentially we've been writing random grabage into that register. Reported-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Chris Wilson <chris@chris-wilson.co.uk> Cc: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Tested-by: Chris Wilson <chris@chris-wilson.co.uk> Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04drm/i915: Serialize almost all register accessChris Wilson
commit a7cd1b8fea2f341b626b255d9898a5ca5fabbf0a upstream. In theory, the different register blocks were meant to be only ever touched when holding either the struct_mutex, mode_config.lock or even a specific localised lock. This does not seem to be the case, and the hardware reacts extremely badly if we attempt to concurrently access two registers within the same cacheline. The HSD suggests that we only need to do this workaround for display range registers. However, upon review we need to serialize the multiple stages in our register write functions - if only for preemption protection. Irrespective of the hardware requirements, the current io functions are a little too loose with respect to the combination of pre- and post-condition testing that we do in conjunction with the actual io. As a result, we may be pre-empted and generate both false-postive and false-negative errors. Note well that this is a "90%" solution, there remains a few direct users of ioread/iowrite which will be fixed up in the next few patches. Since they are more invasive and that this simple change will prevent almost all lockups on Haswell, we kept this patch simple to facilitate backporting to stable. Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=63914 Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04drm/i915: quirk no PCH_PWM_ENABLE for Dell XPS13 backlightKamal Mostafa
commit e85843bec6c2ea7c10ec61238396891cc2b753a9 upstream. BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=47941 BugLink: https://bugs.launchpad.net/bugs/1163720 BugLink: https://bugs.launchpad.net/bugs/1162026 Some machines suffer from non-functional backlight controls if BLM_PCH_PWM_ENABLE is set, so provide a quirk to avoid doing so. Apply this quirk to Dell XPS 13 models. Tested-by: Eric Griffith <EGriffith92@gmail.com> Tested-by: Kent Baxley <kent.baxley@canonical.com> Signed-off-by: Kamal Mostafa <kamal@canonical.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04drm/i915: correctly restore fences with objects attachedDaniel Vetter
commit 94a335dba34ff47cad3d6d0c29b452d43a1be3c8 upstream. To avoid stalls we delay tiling changes and especially hold of committing the new fence state for as long as possible. Synchronization points are in the execbuf code and in our gtt fault handler. Unfortunately we've missed that tricky detail when adding proper fence restore code in commit 19b2dbde5732170a03bd82cc8bd442cf88d856f7 Author: Chris Wilson <chris@chris-wilson.co.uk> Date: Wed Jun 12 10:15:12 2013 +0100 drm/i915: Restore fences after resume and GPU resets The result was that we've restored fences for objects with no tiling, since the object<->fence link still existed after resume. Now that wouldn't have been too bad since any subsequent access would have fixed things up, but if we've changed from tiled to untiled real havoc happened: The tiling stride is stored -1 in the fence register, so a stride of 0 resulted in all 1s in the top 32bits, and so a completely bogus fence spanning everything from the start of the object to the top of the GTT. The tell-tale in the register dumps looks like: FENCE START 2: 0x0214d001 FENCE END 2: 0xfffff3ff Bit 11 isn't set since the hw doesn't store it, even when writing all 1s (at least on my snb here). To prevent such a gaffle in the future add a sanity check for fences with an untiled object attached in i915_gem_write_fence. v2: Fix the WARN, spotted by Chris. v3: Trying to reuse get_fences looked ugly and obfuscated the code. Instead reuse update_fence and to make it really dtrt also move the fence dirty state clearing into update_fence. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=60530 Cc: Chris Wilson <chris@chris-wilson.co.uk> Cc: Stéphane Marchesin <marcheu@chromium.org> Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Tested-by: Matthew Garrett <matthew.garrett@nebula.com> Tested-by: Björn Bidar <theodorstormgrade@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04drm/i915: Fix dereferencing invalid connectors in is_crtc_connector_off()Chris Wilson
commit 2e57f47d317dd035b18634b0c602272529368fcc upstream. In commit e3de42b68478a8c95dd27520e9adead2af9477a5 Author: Imre Deak <imre.deak@intel.com> Date: Fri May 3 19:44:07 2013 +0200 drm/i915: force full modeset if the connector is in DPMS OFF mode a new function was added that walked over the set of connectors to see if any of the currently associated CRTC was switched off. This function walked an array of connectors, rather than the array of pointers to connectors contained in the drm_mode_set - i.e. it was dereferencing far past the end of the first connector. This only becomes an issue if we attempt to use a clone mode (i.e. more than one connector per CRTC) such that set->num_connectors > 1. Reported-by: Timo Aaltonen <tjaalton@ubuntu.com> Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=65927 Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Imre Deak <imre.deak@intel.com> Cc: Egbert Eich <eich@suse.de> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04drm/i915: fix long-standing SNB regression in power consumption after resume v2Konstantin Khlebnikov
commit 7dcd2677ea912573d9ed4bcd629b0023b2d11505 upstream. This patch fixes regression in power consumtion of sandy bridge gpu, which exists since v3.6 Sometimes after resuming from s2ram gpu starts thinking that it's extremely busy. After that it never reaches rc6 state. Bug exists since kernel v3.6: commit b4ae3f22d238617ca11610b29fde16cf8c0bc6e0 Author: Jesse Barnes <jbarnes@virtuousgeek.org> Date: Thu Jun 14 11:04:48 2012 -0700 drm/i915: load boot context at driver init time For some reason RC6 is already enabled at the beginning of resuming process. Following initliaztion breaks some internal state and confuses RPS engine. This patch disables RC6 at the beginnig of resume and initialization. I've rearranged initialization sequence, because intel_disable_gt_powersave() needs initialized force_wake_get/put and some locks from the dev_priv. Note: The culprit in the initialization sequence seems to be the write to MBCTL added in the above mentioned commit. The first version of this patch just held a forcewake reference across the clock gating init functions, which seems to have been enought to gather quite a few positive test reports. But since that smelled a bit like ad-hoc duct-tape v2 now just disables rps/rc6 across the entire hw setup. [danvet: Add note about v1 vs. v2 of this patch and use standard layout for the commit citation. Also add the tested-bys from v1 and a cc: stable.] References https://bugs.freedesktop.org/show_bug.cgi?id=54089 References https://bugzilla.kernel.org/show_bug.cgi?id=58971 References https://patchwork.kernel.org/patch/2827634/ (patch v1) Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Tested-by: Alexander Kaltsas <alexkaltsas@gmail.com> (v1) Tested-by: rocko <rockorequin@hotmail.com> (v1) Tested-by: JohnMB <johnmbryant@sky.com> (v1) Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04drm/i915: Fix incoherence with fence updates on Sandybridge+Chris Wilson
commit d18b9619034230b6f945e215276425636ca401fe upstream. This hopefully fixes the root cause behind the workaround added in commit 25ff1195f8a0b3724541ae7bbe331b4296de9c06 Author: Chris Wilson <chris@chris-wilson.co.uk> Date: Thu Apr 4 21:31:03 2013 +0100 drm/i915: Workaround incoherence between fences and LLC across multiple CPUs Thanks to further investigation by Jon Bloomfield, he realised that the 64-bit register might be broken up by the hardware into two 32-bit writes (a problem we have encountered elsewhere). This non-atomicity would then cause an issue where a second thread would see an intermediate register state (new high dword, old low dword), and this register would randomly be used in preference to its own thread register. This would cause the second thread to read from and write into a fairly random tiled location. Breaking the operation into 3 explicit 32-bit updates (first disable the fence, poke the upper bits, then poke the lower bits and enable) ensures that, given proper serialisation between the 32-bit register write and the memory transfer, that the fence value is always consistent. Armed with this knowledge, we can explain how the previous workaround work. The key to the corruption is that a second thread sees an erroneous fence register that conflicts and overrides its own. By serialising the fence update across all CPUs, we have a small window where no GTT access is occurring and so hide the potential corruption. This also leads to the conclusion that the earlier workaround was incomplete. v2: Be overly paranoid about the order in which fence updates become visible to the GPU to make really sure that we turn the fence off before doing the update, and then only switch the fence on afterwards. Signed-off-by: Jon Bloomfield <jon.bloomfield@intel.com> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: Carsten Emde <C.Emde@osadl.org> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04Partially revert "drm/i915: unconditionally use mt forcewake on hsw/ivb"Guenter Roeck
commit c11e5f35ab490bd30591563816fbc83526521777 upstream. This patch partially reverts commit 36ec8f877481449bdfa072e6adf2060869e2b970 for IvyBridge CPUs. The original commit results in repeated 'Timed out waiting for forcewake old ack to clear' messages on a Supermicro C7H61 board (BIOS version 2.00 and 2.00b) with i7-3770K CPU. It ultimately results in a hangup if the system is highly loaded. Reverting the commit for IvyBridge CPUs fixes the issue. Issue a warning if the CPU is IvyBridge and mt forcewake is disabled, since this condition can result in secondary issues. v2: Only revert patch for Ivybridge CPUs Issue info message if mt forcewake is disabled on Ivybridge Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=60541 Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: Mika Kuoppala <mika.kuoppala@intel.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=66139 Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04drm/i915: Fix write-read race with multiple ringsChris Wilson
commit 02978ff57a5bdfbf703d2bc5a4d933a53ede3144 upstream. Daniel noticed a problem where is we wrote to an object with ring A in the middle of a very long running batch, then executed a quick batch on ring B before a batch that reads from the same object, its obj->ring would now point to ring B, but its last_write_seqno would be still relative to ring A. This would allow for the user to read from the object before the GPU had completed the write, as set_domain would only check that ring B had passed the last_write_seqno. To fix this simply (and inelegantly), we bump the last_write_seqno when switching rings so that the last_write_seqno is always relative to the current obj->ring. This fixes igt/tests/gem_write_read_ring_switch. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> [danvet: Add note about the newly created igt which exercises this bug.] Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04drm/i915: fix up ring cleanup for the i830/i845 CS tlb w/aDaniel Vetter
commit aaf8a5167291b65e9116cb8736d862965b57c13a upstream. It's not a good idea to also run the pipe_control cleanup. This regression has been introduced whith the original cs tlb w/a in commit b45305fce5bb1abec263fcff9d81ebecd6306ede Author: Daniel Vetter <daniel.vetter@ffwll.ch> Date: Mon Dec 17 16:21:27 2012 +0100 drm/i915: Implement workaround for broken CS tlb on i830/845 Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=64610 Cc: Chris Wilson <chris@chris-wilson.co.uk> Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04drm/radeon: improve dac adjust heuristics for legacy pdacAlex Deucher
commit 03ed8cf9b28d886c64c7e705c7bb1a365fd8fb95 upstream. Hopefully avoid more quirks in the future due to bogus vbios dac data. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04drm/radeon: fix combios tables on older cardsMark Kettenis
commit cef1d00cd56f600121ad121875655ad410a001b8 upstream. Noticed that my old Radeon 7500 hung after printing drm: GPU not posted. posting now... when it wasn't selected as the primary card the BIOS. Some digging revealed that it was hanging in combios_parse_mmio_table() while parsing the ASIC INIT 3 table. Looking at the BIOS ROM for the card, it becomes obvious that there is no ASIC INIT 3 table in the BIOS. The code is just processing random garbage. No surprise it hangs! Why do I say that there is no ASIC INIT 3 table is the BIOS? This table is found through the MISC INFO table. The MISC INFO table can be found at offset 0x5e in the COMBIOS header. But the header is smaller than that. The COMBIOS header starts at offset 0x126. The standard PCI Data Structure (the bit that starts with 'PCIR') lives at offset 0x180. That means that the COMBIOS header can not be larger than 0x5a bytes and therefore cannot contain a MISC INFO table. I looked at a dozen or so BIOS images, some my own, some downloaded from: <http://www.techpowerup.com/vgabios/index.php?manufacturer=ATI&page=1> It is fairly obvious that the size of the COMBIOS header can be found at offset 0x6 of the header. Not sure if it is a 16-bit number or just an 8-bit number, but that doesn't really matter since the tables seems to be always smaller than 256 bytes. So I think combios_get_table_offset() should check if the requested table is present. This can be done by checking the offset against the size of the header. See the diff below. The diff is against the WIP OpenBSD codebase that roughly corresponds to Linux 3.8.13 at this point. But I don't think this bit of the code changed much since then. For what it is worth: Signed-off-by: Mark Kettenis <kettenis@openbsd.org> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04drm/radeon: Another card with wrong primary dac adjOndrej Zary
commit f7929f34fa0e0bb6736a2484fdc07d77a1653081 upstream. Hello, got another card with "too bright" problem: Sapphire Radeon VE 7000 DDR (VGA+S-Video) lspci -vnn: 01:00.0 VGA compatible controller [0300]: Advanced Micro Devices [AMD] nee ATI RV100 QY [Radeon 7000/VE] [1002:5159] (prog-if 00 [VGA controller]) Subsystem: PC Partner Limited Sapphire Radeon VE 7000 DDR [174b:7c28] The patch below fixes the problem for this card. But I don't like the blacklist, couldn't some heuristic be used instead? The interesting thing is that the manufacturer is the same as the other card needing the same quirk. I wonder how many different types are broken this way. The "wrong" ps2_pdac_adj value that comes from BIOS on this card is 0x300. ==================== drm/radeon: Add primary dac adj quirk for Sapphire Radeon VE 7000 DDR Values from BIOS are wrong, causing too bright colors. Use default values instead. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04drm/radeon: fix endian issues with DP handling (v3)Alex Deucher
commit 34be8c9af7b8728465963740fc11136ae90dfc36 upstream. The atom interpreter expects data in LE format, so swap the message buffer as apprioriate. v2: properly handle non-dw aligned byte counts. v3: properly handle remainder Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: Dong He <hedonghust@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04drm/radeon: allow selection of alignment in the sub-allocatorAlex Deucher
commit 6c4f978b357bc779c703fda1f200e9179623d3e9 upstream. There are cases where we need more than 4k alignment. No functional change with this commit. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04drm/radeon: fix UVD fence emitChristian König
commit c9a6ca4abd5f1978ef15b3ece3474f4372ae5fe7 upstream. Currently doesn't matter cause we allocate the fence in the lower 265MB anyway. Reported-by: Frank Huang <FrankR.Huang@amd.com> Signed-off-by: Christian König <christian.koenig@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04drm/radeon/hdmi: make sure we have an afmt block assignedAlex Deucher
commit c2b4cacfe9816c1fe378c785ce8a678cf0635ec6 upstream. Prevents a segfault if an afmt block is not assigned to the encoder such as in the LVDS or eDP case. Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=66714 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04dm verity: fix inability to use a few specific devices sizesMikulas Patocka
commit b1bf2de07271932326af847a3c6a01fdfd29d4be upstream. Fix a boundary condition that caused failure for certain device sizes. The problem is reported at http://code.google.com/p/cryptsetup/issues/detail?id=160 For certain device sizes the number of hashes at a specific level was calculated incorrectly. It happens for example for a device with data and metadata block size 4096 that has 16385 blocks and algorithm sha256. The user can test if he is affected by this bug by running the "veritysetup verify" command and also by activating the dm-verity kernel driver and reading the whole block device. If it passes without an error, then the user is not affected. The condition for the bug is: Split the total number of data blocks (data_block_bits) into bit strings, each string has hash_per_block_bits bits. hash_per_block_bits is rounddown(log2(metadata_block_size/hash_digest_size)). Equivalently, you can say that you convert data_blocks_bits to 2^hash_per_block_bits base. If there some zero bit string below the most significant bit string and at least one bit below this zero bit string is set, then the bug happens. The same bug exists in the userspace veritysetup tool, so you must use fixed veritysetup too if you want to use devices that are affected by this boundary condition. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Cc: Milan Broz <gmazyland@gmail.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04dm ioctl: set noio flag to avoid __vmalloc deadlockMikulas Patocka
commit 1c0e883e86ece31880fac2f84b260545d66a39e0 upstream. Set noio flag while calling __vmalloc() because it doesn't fully respect gfp flags to avoid a possible deadlock (see commit 502624bdad3dba45dfaacaf36b7d83e39e74b2d2). This should be backported to stable kernels 3.8 and newer. The kernel 3.8 doesn't have memalloc_noio_save(), so we should set and restore process flag PF_MEMALLOC instead. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04dm mpath: fix ioctl deadlock when no pathsHannes Reinecke
commit 6c182cd88d179cbbd06f4f8a8a19b6977940753f upstream. When multipath needs to retry an ioctl the reference to the current live table needs to be dropped. Otherwise a deadlock occurs when all paths are down: - dm_blk_ioctl takes a reference to the current table and spins in multipath_ioctl(). - A new table is being loaded, but upon resume the process hangs in dm_table_destroy() waiting for references to drop to zero. With this patch the reference to the old table is dropped prior to retry, thereby avoiding the deadlock. Signed-off-by: Hannes Reinecke <hare@suse.de> Cc: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04ACPI / video: ignore BIOS initial backlight value for Fujitsu E753Lan Tianyu
commit 9657a565a476d517451c10b0bcc106e300785aff upstream. The BIOS of FUjitsu E753 reports an incorrect initial backlight value for WIN8 compatible OS, causing backlight to be dark during startup. This change causes the incorrect initial value from BIOS to be ignored. References: https://bugzilla.kernel.org/show_bug.cgi?id=60161 Reported-and-tested-by: Jan Hinnerk Stosch <janhinnerk.stosch@gmail.com> Signed-off-by: Lan Tianyu <tianyu.lan@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04ACPI / memhotplug: Fix a stale pointer in error pathToshi Kani
commit d19f503e22316a84c39bc19445e0e4fdd49b3532 upstream. device->driver_data needs to be cleared when releasing its data, mem_device, in an error path of acpi_memory_device_add(). The function evaluates the _CRS of memory device objects, and fails when it gets an unexpected resource or cannot allocate memory. A kernel crash or data corruption may occur when the kernel accesses the stale pointer. Signed-off-by: Toshi Kani <toshi.kani@hp.com> Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04ACPI / scan: Do not try to attach scan handlers to devices having themRafael J. Wysocki
commit 3a391a39593b48341f0908511590a6c0e55cc069 upstream. In acpi_bus_device_attach(), if there is an ACPI device object for the given handle and that device object has a scan handler attached to it already, there's nothing more to do for that handle. Moreover, if acpi_scan_attach_handler() is called then, it may execute the .attach() callback of the ACPI scan handler already attached to the device object and that may lead to interesting breakage. For this reason, make acpi_bus_device_attach() return success immediately when the handle's device object has a scan handler attached to it. Reported-by: Toshi Kani <toshi.kani@hp.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Toshi Kani <toshi.kani@hp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04ACPI / scan: Always call acpi_bus_scan() for bus check notificationsRafael J. Wysocki
commit 8832f7e43fa7f0f19bd54e13766a825dd1ed4d6f upstream. An ACPI_NOTIFY_BUS_CHECK notification means that we should scan the entire namespace starting from the given handle even if the device represented by that handle is present (other devices below it may just have appeared). For this reason, modify acpi_scan_bus_device_check() to always run acpi_bus_scan() if the notification being handled is of type ACPI_NOTIFY_BUS_CHECK. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Acked-by: Toshi Kani <toshi.kani@hp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04regmap: cache: bail in regmap_async_complete() for bus-less mapsDaniel Mack
commit f2e055e7c9c6084bfbaa68701e52562acf96419e upstream. Commit f8bd822cb ("regmap: cache: Factor out block sync") made regcache_rbtree_sync() call regmap_async_complete(), which in turn does not check for map->bus before dereferencing it. This causes a NULL pointer dereference on bus-less maps. Signed-off-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04Drivers: hv: balloon: Do not post pressure status if interruptedK. Y. Srinivasan
commit c5e2254f8d63a6654149aa32ac5f2b7dd66a976d upstream. When we are posting pressure status, we may get interrupted and handle the un-balloon operation. In this case just don't post the status as we know the pressure status is stale. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04Drivers: hv: balloon: Fix a bug in the hot-add codeK. Y. Srinivasan
commit ed07ec93e83ec471d365ce084e43ad90fd205903 upstream. As we hot-add 128 MB chunks of memory, we wait to ensure that the memory is onlined before attempting to hot-add the next chunk. If the udev rule for memory hot-add is not executed within the allowed time, we would rollback the state and abort further hot-add. Since the hot-add has succeeded and the only failure is that the memory is not onlined within the allowed time, we should not be rolling back the state. Fix this bug. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Acked-by: Jason Wang <jasowang@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04Tools: hv: KVP: Fix a bug in IPV6 subnet enumerationK. Y. Srinivasan
commit ed4bb9744b41d39ba35080c2390e201575121dc7 upstream. Each subnet string needs to be separated with a semicolon. Fix this bug. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04nfsd: nfsd_open: when dentry_open returns an error do not propagate as ↵Harshula Jayasuriya
struct file commit e4daf1ffbe6cc3b12aab4d604e627829e93e9914 upstream. The following call chain: ------------------------------------------------------------ nfs4_get_vfs_file - nfsd_open - dentry_open - do_dentry_open - __get_file_write_access - get_write_access - return atomic_inc_unless_negative(&inode->i_writecount) ? 0 : -ETXTBSY; ------------------------------------------------------------ can result in the following state: ------------------------------------------------------------ struct nfs4_file { ... fi_fds = {0xffff880c1fa65c80, 0xffffffffffffffe6, 0x0}, fi_access = {{ counter = 0x1 }, { counter = 0x0 }}, ... ------------------------------------------------------------ 1) First time around, in nfs4_get_vfs_file() fp->fi_fds[O_WRONLY] is NULL, hence nfsd_open() is called where we get status set to an error and fp->fi_fds[O_WRONLY] to -ETXTBSY. Thus we do not reach nfs4_file_get_access() and fi_access[O_WRONLY] is not incremented. 2) Second time around, in nfs4_get_vfs_file() fp->fi_fds[O_WRONLY] is NOT NULL (-ETXTBSY), so nfsd_open() is NOT called, but nfs4_file_get_access() IS called and fi_access[O_WRONLY] is incremented. Thus we leave a landmine in the form of the nfs4_file data structure in an incorrect state. 3) Eventually, when __nfs4_file_put_access() is called it finds fi_access[O_WRONLY] being non-zero, it decrements it and calls nfs4_file_put_fd() which tries to fput -ETXTBSY. ------------------------------------------------------------ ... [exception RIP: fput+0x9] RIP: ffffffff81177fa9 RSP: ffff88062e365c90 RFLAGS: 00010282 RAX: ffff880c2b3d99cc RBX: ffff880c2b3d9978 RCX: 0000000000000002 RDX: dead000000100101 RSI: 0000000000000001 RDI: ffffffffffffffe6 RBP: ffff88062e365c90 R8: ffff88041fe797d8 R9: ffff88062e365d58 R10: 0000000000000008 R11: 0000000000000000 R12: 0000000000000001 R13: 0000000000000007 R14: 0000000000000000 R15: 0000000000000000 ORIG_RAX: ffffffffffffffff CS: 0010 SS: 0018 #9 [ffff88062e365c98] __nfs4_file_put_access at ffffffffa0562334 [nfsd] #10 [ffff88062e365cc8] nfs4_file_put_access at ffffffffa05623ab [nfsd] #11 [ffff88062e365ce8] free_generic_stateid at ffffffffa056634d [nfsd] #12 [ffff88062e365d18] release_open_stateid at ffffffffa0566e4b [nfsd] #13 [ffff88062e365d38] nfsd4_close at ffffffffa0567401 [nfsd] #14 [ffff88062e365d88] nfsd4_proc_compound at ffffffffa0557f28 [nfsd] #15 [ffff88062e365dd8] nfsd_dispatch at ffffffffa054543e [nfsd] #16 [ffff88062e365e18] svc_process_common at ffffffffa04ba5a4 [sunrpc] #17 [ffff88062e365e98] svc_process at ffffffffa04babe0 [sunrpc] #18 [ffff88062e365eb8] nfsd at ffffffffa0545b62 [nfsd] #19 [ffff88062e365ee8] kthread at ffffffff81090886 #20 [ffff88062e365f48] kernel_thread at ffffffff8100c14a ------------------------------------------------------------ Signed-off-by: Harshula Jayasuriya <harshula@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04powerpc/modules: Module CRC relocation fix causes perf issuesAnton Blanchard
commit 0e0ed6406e61434d3f38fb58aa8464ec4722b77e upstream. Module CRCs are implemented as absolute symbols that get resolved by a linker script. We build an intermediate .o that contains an unresolved symbol for each CRC. genksysms parses this .o, calculates the CRCs and writes a linker script that "resolves" the symbols to the calculated CRC. Unfortunately the ppc64 relocatable kernel sees these CRCs as symbols that need relocating and relocates them at boot. Commit d4703aef (module: handle ppc64 relocating kcrctabs when CONFIG_RELOCATABLE=y) added a hook to reverse the bogus relocations. Part of this patch created a symbol at 0x0: # head -2 /proc/kallsyms 0000000000000000 T reloc_start c000000000000000 T .__start This reloc_start symbol is causing lots of confusion to perf. It thinks reloc_start is a massive function that stretches from 0x0 to 0xc000000000000000 and we get various cryptic errors out of perf, including: problem incrementing symbol count, skipping event This patch removes the reloc_start linker script label and instead defines it as PHYSICAL_START. We also need to wrap it with CONFIG_PPC64 because the ppc32 kernel can set a non zero PHYSICAL_START at compile time and we wouldn't want to subtract it from the CRCs in that case. Signed-off-by: Anton Blanchard <anton@samba.org> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04crypto: caam - Fixed the memory out of bound overwrite issueVakul Garg
commit 9c23b7d3d6bda41e2a27375df705485523a96dc8 upstream. When kernel is compiled with CONFIG_SLUB_DEBUG=y and CRYPTO_MANAGER_DISABLE_TESTS=n, during kernel bootup, the kernel reports error given below. The root cause is that in function hash_digest_key(), for allocating descriptor, insufficient memory was being allocated. The required number of descriptor words apart from input and output pointers are 8 (instead of 6). ============================================================================= BUG dma-kmalloc-32 (Not tainted): Redzone overwritten ----------------------------------------------------------------------------- Disabling lock debugging due to kernel taint INFO: 0xdec5dec0-0xdec5dec3. First byte 0x0 instead of 0xcc INFO: Allocated in ahash_setkey+0x60/0x594 age=7 cpu=1 pid=1257 __kmalloc+0x154/0x1b4 ahash_setkey+0x60/0x594 test_hash+0x260/0x5a0 alg_test_hash+0x48/0xb0 alg_test+0x84/0x228 cryptomgr_test+0x4c/0x54 kthread+0x98/0x9c ret_from_kernel_thread+0x64/0x6c INFO: Slab 0xc0bd0ba0 objects=19 used=2 fp=0xdec5d0d0 flags=0x0081 INFO: Object 0xdec5dea0 @offset=3744 fp=0x5c200014 Bytes b4 dec5de90: 00 00 00 00 00 00 00 00 5a 5a 5a 5a 5a 5a 5a 5a ........ZZZZZZZZ Object dec5dea0: b0 80 00 0a 84 41 00 0d f0 40 00 00 00 67 3f c0 .....A...@...g?. Object dec5deb0: 00 00 00 50 2c 14 00 50 f8 40 00 00 1e c5 d0 00 ...P,..P.@...... Redzone dec5dec0: 00 00 00 14 .... Padding dec5df68: 5a 5a 5a 5a 5a 5a 5a 5a ZZZZZZZZ Call Trace: [dec65b60] [c00071b4] show_stack+0x4c/0x168 (unreliable) [dec65ba0] [c00d4ec8] check_bytes_and_report+0xe4/0x11c [dec65bd0] [c00d507c] check_object+0x17c/0x23c [dec65bf0] [c0550a00] free_debug_processing+0xf4/0x294 [dec65c20] [c0550bdc] __slab_free+0x3c/0x294 [dec65c80] [c03f0744] ahash_setkey+0x4e0/0x594 [dec65cd0] [c01ef138] test_hash+0x260/0x5a0 [dec65e50] [c01ef4c0] alg_test_hash+0x48/0xb0 [dec65e70] [c01eecc4] alg_test+0x84/0x228 [dec65ee0] [c01ec640] cryptomgr_test+0x4c/0x54 [dec65ef0] [c005adc0] kthread+0x98/0x9c [dec65f40] [c000e1ac] ret_from_kernel_thread+0x64/0x6c FIX dma-kmalloc-32: Restoring 0xdec5dec0-0xdec5dec3=0xcc Change-Id: I0c7a1048053e811025d1c3b487940f87345c8f5d Signed-off-by: Vakul Garg <vakul@freescale.com> Reviewed-by: Geanta Neag Horia Ioan-B05471 <horia.geanta@freescale.com> Reviewed-by: Fleming Andrew-AFLEMING <AFLEMING@freescale.com> Tested-by: Fleming Andrew-AFLEMING <AFLEMING@freescale.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04svcrdma: underflow issue in decode_write_list()Dan Carpenter
commit b2781e1021525649c0b33fffd005ef219da33926 upstream. My static checker marks everything from ntohl() as untrusted and it complains we could have an underflow problem doing: return (u32 *)&ary->wc_array[nchunks]; Also on 32 bit systems the upper bound check could overflow. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
