2014-06-16Linux 3.10.44v3.10.44Greg Kroah-Hartman
2014-06-16ahci: add PCI ID for Marvell 88SE91A0 SATA ControllerAndreas Schrägle
commit 754a292fe6b08196cb135c03b404444e17de520a upstream. Add support for Marvell Technology Group Ltd. 88SE91A0 SATA 6Gb/s Controller by adding its PCI ID. Signed-off-by: Andreas Schrägle <ajs124.ajs124@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-16ahci: Add Device ID for HighPoint RocketRaid 642LJérôme Carretero
commit d251836508fb26cd1a22b41381739835ee23728d upstream. This device normally comes with a proprietary driver, using a web GUI to configure RAID: http://www.highpoint-tech.com/USA_new/series_rr600-download.htm But thankfully it also works out of the box with the AHCI driver, being just a Marvell 88SE9235. Devices 640L, 644L, 644LS should also be supported but not tested here. Signed-off-by: Jérôme Carretero <cJ-ko@zougloub.eu> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-16mei: me: drop harmful wait optimizationTomas Winkler
commit 07cd7be3d92eeeae1f92a017f2cfe4fdd9256526 upstream. It my take time till ME_RDY will be cleared after the reset, so we cannot check the bit before we got the interrupt Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Alexander Usyskin <alexander.usyskin@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-16SCSI: megaraid: Use resource_size_t for PCI resources, not longBen Collins
commit 11f8a7b31f2140b0dc164bb484281235ffbe51d3 upstream. The assumption that sizeof(long) >= sizeof(resource_size_t) can lead to truncation of the PCI resource address, meaning this driver didn't work on 32-bit systems with 64-bit PCI adressing ranges. Signed-off-by: Ben Collins <ben.c@servergy.com> Acked-by: Sumit Saxena <sumit.saxena@lsi.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-16auditsc: audit_krule mask accesses need bounds checkingAndy Lutomirski
commit a3c54931199565930d6d84f4c3456f6440aefd41 upstream. Fixes an easy DoS and possible information disclosure. This does nothing about the broken state of x32 auditing. eparis: If the admin has enabled auditd and has specifically loaded audit rules. This bug has been around since before git. Wow... Signed-off-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-16mm/compaction: make isolate_freepages start at pageblock boundaryVlastimil Babka
commit 49e068f0b73dd042c186ffa9b420a9943e90389a upstream. The compaction freepage scanner implementation in isolate_freepages() starts by taking the current cc->free_pfn value as the first pfn. In a for loop, it scans from this first pfn to the end of the pageblock, and then subtracts pageblock_nr_pages from the first pfn to obtain the first pfn for the next for loop iteration. This means that when cc->free_pfn starts at offset X rather than being aligned on pageblock boundary, the scanner will start at offset X in all scanned pageblock, ignoring potentially many free pages. Currently this can happen when a) zone's end pfn is not pageblock aligned, or b) through zone->compact_cached_free_pfn with CONFIG_HOLES_IN_ZONE enabled and a hole spanning the beginning of a pageblock This patch fixes the problem by aligning the initial pfn in isolate_freepages() to pageblock boundary. This also permits replacing the end-of-pageblock alignment within the for loop with a simple pageblock_nr_pages increment. Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Reported-by: Heesub Shin <heesub.shin@samsung.com> Acked-by: Minchan Kim <minchan@kernel.org> Cc: Mel Gorman <mgorman@suse.de> Acked-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Cc: Michal Nazarewicz <mina86@mina86.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Christoph Lameter <cl@linux.com> Acked-by: Rik van Riel <riel@redhat.com> Cc: Dongjun Shin <d.j.shin@samsung.com> Cc: Sunghwan Yun <sunghwan.yun@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-16mm: compaction: detect when scanners meet in isolate_freepagesVlastimil Babka
commit 7ed695e069c3cbea5e1fd08f84a04536da91f584 upstream. Compaction of a zone is finished when the migrate scanner (which begins at the zone's lowest pfn) meets the free page scanner (which begins at the zone's highest pfn). This is detected in compact_zone() and in the case of direct compaction, the compact_blockskip_flush flag is set so that kswapd later resets the cached scanner pfn's, and a new compaction may again start at the zone's borders. The meeting of the scanners can happen during either scanner's activity. However, it may currently fail to be detected when it occurs in the free page scanner, due to two problems. First, isolate_freepages() keeps free_pfn at the highest block where it isolated pages from, for the purposes of not missing the pages that are returned back to allocator when migration fails. Second, failing to isolate enough free pages due to scanners meeting results in -ENOMEM being returned by migrate_pages(), which makes compact_zone() bail out immediately without calling compact_finished() that would detect scanners meeting. This failure to detect scanners meeting might result in repeated attempts at compaction of a zone that keep starting from the cached pfn's close to the meeting point, and quickly failing through the -ENOMEM path, without the cached pfns being reset, over and over. This has been observed (through additional tracepoints) in the third phase of the mmtests stress-highalloc benchmark, where the allocator runs on an otherwise idle system. The problem was observed in the DMA32 zone, which was used as a fallback to the preferred Normal zone, but on the 4GB system it was actually the largest zone. The problem is even amplified for such fallback zone - the deferred compaction logic, which could (after being fixed by a previous patch) reset the cached scanner pfn's, is only applied to the preferred zone and not for the fallbacks. The problem in the third phase of the benchmark was further amplified by commit 81c0a2bb515f ("mm: page_alloc: fair zone allocator policy") which resulted in a non-deterministic regression of the allocation success rate from ~85% to ~65%. This occurs in about half of benchmark runs, making bisection problematic. It is unlikely that the commit itself is buggy, but it should put more pressure on the DMA32 zone during phases 1 and 2, which may leave it more fragmented in phase 3 and expose the bugs that this patch fixes. The fix is to make scanners meeting in isolate_freepage() stay that way, and to check in compact_zone() for scanners meeting when migrate_pages() returns -ENOMEM. The result is that compact_finished() also detects scanners meeting and sets the compact_blockskip_flush flag to make kswapd reset the scanner pfn's. The results in stress-highalloc benchmark show that the "regression" by commit 81c0a2bb515f in phase 3 no longer occurs, and phase 1 and 2 allocation success rates are also significantly improved. Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-16mm: compaction: reset cached scanner pfn's before reading themVlastimil Babka
commit d3132e4b83e6bd383c74d716f7281d7c3136089c upstream. Compaction caches pfn's for its migrate and free scanners to avoid scanning the whole zone each time. In compact_zone(), the cached values are read to set up initial values for the scanners. There are several situations when these cached pfn's are reset to the first and last pfn of the zone, respectively. One of these situations is when a compaction has been deferred for a zone and is now being restarted during a direct compaction, which is also done in compact_zone(). However, compact_zone() currently reads the cached pfn's *before* resetting them. This means the reset doesn't affect the compaction that performs it, and with good chance also subsequent compactions, as update_pageblock_skip() is likely to be called and update the cached pfn's to those being processed. Another chance for a successful reset is when a direct compaction detects that migration and free scanners meet (which has its own problems addressed by another patch) and sets update_pageblock_skip flag which kswapd uses to do the reset because it goes to sleep. This is clearly a bug that results in non-deterministic behavior, so this patch moves the cached pfn reset to be performed *before* the values are read. Signed-off-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Mel Gorman <mgorman@suse.de> Acked-by: Rik van Riel <riel@redhat.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-16target: Fix alua_access_state attribute OOPs for un-configured devicesNicholas Bellinger
commit f1453773514bb8b0bba0716301e8c8f17f8d39c7 upstream. This patch fixes a OOPs where an attempt to write to the per-device alua_access_state configfs attribute at: /sys/kernel/config/target/core/$HBA/$DEV/alua/$TG_PT_GP/alua_access_state results in an NULL pointer dereference when the backend device has not yet been configured. This patch adds an explicit check for DF_CONFIGURED, and fails with -ENODEV to avoid this case. Reported-by: Chris Boot <crb@tiger-computing.co.uk> Reported-by: Philip Gaw <pgaw@darktech.org.uk> Cc: Chris Boot <crb@tiger-computing.co.uk> Cc: Philip Gaw <pgaw@darktech.org.uk> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-16target: Allow READ_CAPACITY opcode in ALUA Standby access stateNicholas Bellinger
commit e7810c2d2c37fa8e58dda74b00790dab60fe6fba upstream. This patch allows READ_CAPACITY + SAI_READ_CAPACITY_16 opcode processing to occur while the associated ALUA group is in Standby access state. This is required to avoid host side LUN probe failures during the initial scan if an ALUA group has already implicitly changed into Standby access state. This addresses a bug reported by Chris + Philip using dm-multipath + ESX hosts configured with ALUA multipath. (Drop v3.15 specific set_ascq usage - nab) Reported-by: Chris Boot <crb@tiger-computing.co.uk> Reported-by: Philip Gaw <pgaw@darktech.org.uk> Cc: Chris Boot <crb@tiger-computing.co.uk> Cc: Philip Gaw <pgaw@darktech.org.uk> Cc: Hannes Reinecke <hare@suse.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-16iscsi-target: Fix wrong buffer / buffer overrun in iscsi_change_param_value()Roland Dreier
commit 79d59d08082dd0a0a18f8ceb78c99f9f321d72aa upstream. In non-leading connection login, iscsi_login_non_zero_tsih_s1() calls iscsi_change_param_value() with the buffer it uses to hold the login PDU, not a temporary buffer. This leads to the login header getting corrupted and login failing for non-leading connections in MC/S. Fix this by adding a wrapper iscsi_change_param_sprintf() that handles the temporary buffer itself to avoid confusion. Also handle sending a reject in case of failure in the wrapper, which lets the calling code get quite a bit smaller and easier to read. Finally, bump the size of the temporary buffer from 32 to 64 bytes to be safe, since "MaxRecvDataSegmentLength=" by itself is 25 bytes; with a trailing NUL, a value >= 1M will lead to a buffer overrun. (This isn't the default but we don't need to run right at the ragged edge here) (Fix up context changes for v3.10.y - nab) Reported-by: Santosh Kulkarni <santosh.kulkarni@calsoftinc.com> Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-16iser-target: Fix multi network portal shutdown regressionNicholas Bellinger
commit 2363d196686e44c0158929e7cf96c8589a24a81b upstream. This patch fixes a iser-target specific regression introduced in v3.15-rc6 with: commit 14f4b54fe38f3a8f8392a50b951c8aa43b63687a Author: Sagi Grimberg <sagig@mellanox.com> Date: Tue Apr 29 13:13:47 2014 +0300 Target/iscsi,iser: Avoid accepting transport connections during stop stage where the change to set iscsi_np->enabled = false within iscsit_clear_tpg_np_login_thread() meant that a iscsi_np with two iscsi_tpg_np exports would have it's parent iscsi_np set to a disabled state, even if other iscsi_tpg_np exports still existed. This patch changes iscsit_clear_tpg_np_login_thread() to only set iscsi_np->enabled = false when shutdown = true, and also changes iscsit_del_np() to set iscsi_np->enabled = true when iscsi_np->np_exports is non zero. (Fix up context changes for v3.10.y - nab) Cc: Sagi Grimberg <sagig@dev.mellanox.co.il> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-16Target/iscsi,iser: Avoid accepting transport connections during stop stageSagi Grimberg
commit 14f4b54fe38f3a8f8392a50b951c8aa43b63687a upstream. When the target is in stop stage, iSER transport initiates RDMA disconnects. The iSER initiator may wish to establish a new connection over the still existing network portal. In this case iSER transport should not accept and resume new RDMA connections. In order to learn that, iscsi_np is added with enabled flag so the iSER transport can check when deciding weather to accept and resume a new connection request. The iscsi_np is enabled after successful transport setup, and disabled before iscsi_np login threads are cleaned up. (Fix up context changes for v3.10.y - nab) Signed-off-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-16netfilter: ipv4: defrag: set local_df flag on defragmented skbFlorian Westphal
commit 895162b1101b3ea5db08ca6822ae9672717efec0 upstream. else we may fail to forward skb even if original fragments do fit outgoing link mtu: 1. remote sends 2k packets in two 1000 byte frags, DF set 2. we want to forward but only see '2k > mtu and DF set' 3. we then send icmp error saying that outgoing link is 1500 But original sender never sent a packet that would not fit the outgoing link. Setting local_df makes outgoing path test size vs. IPCB(skb)->frag_max_size, so we will still send the correct error in case the largest original size did not fit outgoing link mtu. Reported-by: Maxime Bizon <mbizon@freebox.fr> Suggested-by: Maxime Bizon <mbizon@freebox.fr> Fixes: 5f2d04f1f9 (ipv4: fix path MTU discovery with connection tracking) Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Cc: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-16ARM: mvebu: fix NOR bus-width in Armada XP OpenBlocks AX3 Device TreeThomas Petazzoni
commit 6e20bae8a39c40d4e03698e4160bad2d2629062b upstream. The mvebu-devbus driver had a serious bug, which lead to a 8 bits bus width declared in the Device Tree being considered as a 16 bits bus width when configuring the hardware. This bug in mvebu-devbus driver was compensated by a symetric mistake in the Armada XP OpenBlocks AX3 Device Tree: a 8 bits bus width was declared, even though the hardware actually has a 16 bits bus width connection with the NOR flash. Now that we have fixed the mvebu-devbus driver to behave according to its Device Tree binding, this commit fixes the problematic Device Tree files as well. This bug was introduced in commit a7d4f81821f7eec3175f8e23dd6949c71ab2da43 ('ARM: mvebu: Add support for NOR flash device on Openblocks AX3 board') which was merged in v3.10. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Link: https://lkml.kernel.org/r/1397489361-5833-5-git-send-email-thomas.petazzoni@free-electrons.com Fixes: a7d4f81821f7 ('ARM: mvebu: Add support for NOR flash device on Openblocks AX3 board') Cc: stable@vger.kernel.org # v3.10+ Acked-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-16ARM: mvebu: fix NOR bus-width in Armada XP GP Device TreeThomas Petazzoni
commit 1a88f809ccb5db1509a7514b187c00b3a995fc82 upstream. The mvebu-devbus driver had a serious bug, which lead to a 8 bits bus width declared in the Device Tree being considered as a 16 bits bus width when configuring the hardware. This bug in mvebu-devbus driver was compensated by a symetric mistake in the Armada XP GP Device Tree: a 8 bits bus width was declared, even though the hardware actually has a 16 bits bus width connection with the NOR flash. Now that we have fixed the mvebu-devbus driver to behave according to its Device Tree binding, this commit fixes the problematic Device Tree files as well. This bug was introduced in commit da8d1b38356853c37116f9afa29f15648d7fb159 ('ARM: mvebu: Add support for NOR flash device on Armada XP-GP board') which was merged in v3.10. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Link: https://lkml.kernel.org/r/1397489361-5833-3-git-send-email-thomas.petazzoni@free-electrons.com Fixes: da8d1b383568 ('ARM: mvebu: Add support for NOR flash device on Armada XP-GP board') Cc: stable@vger.kernel.org # v3.10+ Acked-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-16mlx4_en: don't use napi_synchronize inside mlx4_en_netpollChris Mason
commit c98235cb8584a72e95786e17d695a8e5fafcd766 upstream. The mlx4 driver is triggering schedules while atomic inside mlx4_en_netpoll: spin_lock_irqsave(&cq->lock, flags); napi_synchronize(&cq->napi); ^^^^^ msleep here mlx4_en_process_rx_cq(dev, cq, 0); spin_unlock_irqrestore(&cq->lock, flags); This was part of a patch by Alexander Guller from Mellanox in 2011, but it still isn't upstream. Signed-off-by: Chris Mason <clm@fb.com> Acked-By: Amir Vadai <amirv@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Masoud Sharbiani <msharbiani@twitter.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-16fs,userns: Change inode_capable to capable_wrt_inode_uidgidAndy Lutomirski
commit 23adbe12ef7d3d4195e80800ab36b37bee28cd03 upstream. The kernel has no concept of capabilities with respect to inodes; inodes exist independently of namespaces. For example, inode_capable(inode, CAP_LINUX_IMMUTABLE) would be nonsense. This patch changes inode_capable to check for uid and gid mappings and renames it to capable_wrt_inode_uidgid, which should make it more obvious what it does. Fixes CVE-2014-4014. Cc: Theodore Ts'o <tytso@mit.edu> Cc: Serge Hallyn <serge.hallyn@ubuntu.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Dave Chinner <david@fromorbit.com> Signed-off-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11Linux 3.10.43v3.10.43Greg Kroah-Hartman
2014-06-11netfilter: Fix potential use after free in ip6_route_me_harder()Sergey Popovich
commit a8951d5814e1373807a94f79f7ccec7041325470 upstream. Dst is released one line before we access it again with dst->error. Fixes: 58e35d147128 netfilter: ipv6: propagate routing errors from ip6_route_me_harder() Signed-off-by: Sergey Popovich <popovich_sergei@mail.ru> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11ARM: perf: hook up perf_sample_event_took around pmu irq handlingWill Deacon
commit 5f5092e72cc25a6a5785308270e0085b2b2772cc upstream. Since we indirect all of our PMU IRQ handling through a dispatcher, it's trivial to hook up perf_sample_event_took to prevent applications such as oprofile from generating interrupt storms due to an unrealisticly low sample period. Reported-by: Robert Richter <rric@kernel.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Cc: Weng Meiling <wengmeiling.weng@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11perf: Enforce 1 as lower limit for perf_event_max_sample_rateKnut Petersen
commit 723478c8a471403c53cf144999701f6e0c4bbd11 upstream. /proc/sys/kernel/perf_event_max_sample_rate will accept negative values as well as 0. Negative values are unreasonable, and 0 causes a divide by zero exception in perf_proc_update_handler. This patch enforces a lower limit of 1. Signed-off-by: Knut Petersen <Knut_Petersen@t-online.de> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/5242DB0C.4070005@t-online.de Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: Weng Meiling <wengmeiling.weng@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11perf: Fix interrupt handler timing harnessStephane Eranian
commit e5302920da9ef23f9d19d4e9ac85704cc25bee7a upstream. This patch fixes a serious bug in: 14c63f17b1fd perf: Drop sample rate when sampling is too slow There was an misunderstanding on the API of the do_div() macro. It returns the remainder of the division and this was not what the function expected leading to disabling the interrupt latency watchdog. This patch also remove a duplicate assignment in perf_sample_event_took(). Signed-off-by: Stephane Eranian <eranian@google.com> Cc: peterz@infradead.org Cc: dave.hansen@linux.intel.com Cc: ak@linux.intel.com Cc: jolsa@redhat.com Link: http://lkml.kernel.org/r/20130704223010.GA30625@quad Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: Weng Meiling <wengmeiling.weng@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11perf: Drop sample rate when sampling is too slowDave Hansen
commit 14c63f17b1fde5a575a28e96547a22b451c71fb5 upstream. This patch keeps track of how long perf's NMI handler is taking, and also calculates how many samples perf can take a second. If the sample length times the expected max number of samples exceeds a configurable threshold, it drops the sample rate. This way, we don't have a runaway sampling process eating up the CPU. This patch can tend to drop the sample rate down to level where perf doesn't work very well. *BUT* the alternative is that my system hangs because it spends all of its time handling NMIs. I'll take a busted performance tool over an entire system that's busted and undebuggable any day. BTW, my suspicion is that there's still an underlying bug here. Using the HPET instead of the TSC is definitely a contributing factor, but I suspect there are some other things going on. But, I can't go dig down on a bug like that with my machine hanging all the time. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: paulus@samba.org Cc: acme@ghostprotocols.net Cc: Dave Hansen <dave@sr71.net> [ Prettified it a bit. ] Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: Weng Meiling <wengmeiling.weng@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11iser-target: Add missing target_put_sess_cmd for ImmedateData failureNicholas Bellinger
commit 6cc44a6fb46e1ecc1c28125aa8fa34d317aa9ea7 upstream. This patch addresses a bug where an early exception for SCSI WRITE with ImmediateData=Yes was missing the target_put_sess_cmd() call to drop the extra se_cmd->cmd_kref reference obtained during the normal iscsit_setup_scsi_cmd() codepath execution. This bug was manifesting itself during session shutdown within isert_cq_rx_comp_err() where target_wait_for_sess_cmds() would end up waiting indefinately for the last se_cmd->cmd_kref put to occur for the failed SCSI WRITE + ImmediateData descriptors. This fix follows what traditional iscsi-target code already does for the same failure case within iscsit_get_immediate_data(). Reported-by: Sagi Grimberg <sagig@dev.mellanox.co.il> Cc: Sagi Grimberg <sagig@dev.mellanox.co.il> Cc: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11mm: rmap: fix use-after-free in __put_anon_vmaAndrey Ryabinin
commit 624483f3ea82598ab0f62f1bdb9177f531ab1892 upstream. While working address sanitizer for kernel I've discovered use-after-free bug in __put_anon_vma. For the last anon_vma, anon_vma->root freed before child anon_vma. Later in anon_vma_free(anon_vma) we are referencing to already freed anon_vma->root to check rwsem. This fixes it by freeing the child anon_vma before freeing anon_vma->root. Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11USB: Avoid runtime suspend loops for HCDs that can't handle suspend/resumeAlan Stern
commit 8ef42ddd9a53b73e6fc3934278710c27f80f324f upstream. Not all host controller drivers have bus-suspend and bus-resume methods. When one doesn't, it will cause problems if runtime PM is enabled in the kernel. The PM core will attempt to suspend the controller's root hub, the suspend will fail because there is no bus-suspend routine, and a -EBUSY error code will be returned to the PM core. This will cause the suspend attempt to be repeated shortly thereafter, in a never-ending loop. Part of the problem is that the original error code -ENOENT gets changed to -EBUSY in usb_runtime_suspend(), on the grounds that the PM core will interpret -ENOENT as meaning that the root hub has gotten into a runtime-PM error state. While this change is appropriate for real USB devices, it's not such a good idea for a root hub. In fact, considering the root hub to be in a runtime-PM error state would not be far from the truth. Therefore this patch updates usb_runtime_suspend() so that it adjusts error codes only for non-root-hub devices. Furthermore, the patch attempts to prevent the problem from occurring in the first place by not enabling runtime PM by default for root hubs whose host controller driver doesn't have bus_suspend and bus_resume methods. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Reported-by: Will Deacon <will.deacon@arm.com> Tested-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11USB: io_ti: fix firmware download on big-endian machines (part 2)Johan Hovold
commit c03890ff5e24a4bf59059f2d179f427559b7330a upstream. A recent patch that purported to fix firmware download on big-endian machines failed to add the corresponding sparse annotation to the i2c-header. This was reported by the kbuild test robot. Adding the appropriate annotation revealed another endianess bug related to the i2c-header Size-field in a code path that is exercised when the firmware is actually being downloaded (and not just verified and left untouched unless older than the firmware at hand). This patch adds the required sparse annotation to the i2c-header and makes sure that the Size-field is sent in little-endian byte order during firmware download also on big-endian machines. Note that this patch is only compile-tested, but that there is no functional change for little-endian systems. Reported-by: kbuild test robot <fengguang.wu@intel.com> Cc: Ludovic Drolez <ldrolez@debian.org> Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11USB: serial: option: add support for Novatel E371 PCIe cardAlexej Starschenko
commit 8a61ba3a47ac39f660702aa66a172185dd605a86 upstream. Adds product ID for the Novatel E371 PCI Express Mini Card. $ lsusb Bus 001 Device 024: ID 1410:9011 Novatel Wireless $ usb-devices T: Bus=01 Lev=01 Prnt=01 Port=03 Cnt=01 Dev#= 24 Spd=480 MxCh= 0 D: Ver= 2.00 Cls=ef(misc ) Sub=02 Prot=01 MxPS=64 #Cfgs= 1 P: Vendor=1410 ProdID=9011 Rev=00.03 S: Manufacturer=Novatel Wireless, Inc. S: Product=Novatel Wireless HSPA S: SerialNumber=012773002115811 C: #Ifs= 6 Cfg#= 1 Atr=e0 MxPwr=500mA I: If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=option I: If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=option I: If#= 2 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=option I: If#= 3 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=option I: If#= 6 Alt= 0 #EPs= 1 Cls=02(commc) Sub=06 Prot=00 Driver=cdc_ether I: If#= 7 Alt= 1 #EPs= 2 Cls=0a(data ) Sub=00 Prot=00 Driver=cdc_ether Tested with kernel 3.2.0. Signed-off-by: Alexej Starschenko <starschenko@gmail.com> Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11USB: cdc-wdm: properly include types.hGreg Kroah-Hartman
commit 7ac3764fcafc06e72e1a79a9d998b9fdd900b2a6 upstream. The file include/uapi/linux/usb/cdc-wdm.h uses a __u16 so it needs to include types.h as well to make the build system happy. Fixes: 3edce1cf813a ("USB: cdc-wdm: implement IOCTL_WDM_MAX_COMMAND") Cc: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11usb: cdc-wdm: export cdc-wdm uapi headerBjørn Mork
commit 7d1896360f4d055d68565ef8ed56a677580f1a39 upstream. The include/uapi/linux/usb/cdc-wdm.h header defines cdc-wdm userspace APIs and should be exported by make headers_install. Fixes: 3edce1cf813a ("USB: cdc-wdm: implement IOCTL_WDM_MAX_COMMAND") Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11USB: ftdi_sio: add NovaTech OrionLXm product IDGeorge McCollister
commit d0839d757e6294921c31b1c4ca4f1dcc5df63bcd upstream. The NovaTech OrionLXm uses an onboard FTDI serial converter for JTAG and console access. Here is the lsusb output: Bus 004 Device 123: ID 0403:7c90 Future Technology Devices International, Ltd Signed-off-by: George McCollister <george.mccollister@gmail.com> Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11ALSA: hda/realtek - Fix COEF widget NID for ALC260 replacer fixupTakashi Iwai
commit 192a98e280e560510a62aca8cfa83b4ae7c095bb upstream. The conversion to a fixup table for Replacer model with ALC260 in commit 20f7d928 took the wrong widget NID for COEF setups. Namely, NID 0x1a should have been used instead of NID 0x20, which is the common node for all Realtek codecs but ALC260. Fixes: 20f7d928fa6e ('ALSA: hda/realtek - Replace ALC260 model=replacer with the auto-parser') Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11ALSA: hda/realtek - Correction of fixup codes for PB V7900 laptopRonan Marquet
commit e30cf2d2bed3aed74a651c64de323ba26e4ff7d0 upstream. Correcion of wrong fixup entries add in commit ca8f0424 to replace static model quirk for PB V7900 laptop (will model). [note: the removal of ALC260_FIXUP_HP_PIN_0F chain is also needed as a part of the fix; otherwise the pin is set up wrongly as a headphone, and user-space (PulseAudio) may be wrongly trying to detect the jack state -- tiwai] Fixes: ca8f04247eaa ('ALSA: hda/realtek - Add the fixup codes for ALC260 model=will') Signed-off-by: Ronan Marquet <ronan.marquet@orange.fr> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11staging: comedi: ni_daq_700: add mux settling delayIan Abbott
commit ffed54dced86723f352323f15789d9ad6bee25e1 upstream. I got a patch from the original author, Fred Brooks, to add a small settling delay after setting the AI channel multiplexor. The lack of delay resulted in unstable or scrambled data on faster processors. Signed-off-by: Ian Abbott <abbotti@mev.co.uk> Reported-by: Fred Brooks <nsaspook@nsaspook.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11Staging: speakup: Move pasting into a work itemBen Hutchings
commit d7500135802ca55b3f4e01a16544e8b34082f8c3 upstream. Input is handled in softirq context, but when pasting we may need to sleep. speakup_paste_selection() currently tries to bodge this by busy-waiting if in_atomic(), but that doesn't help because the ldisc may also sleep. For bonus breakage, speakup_paste_selection() changes the state of current, even though it's not running in process context. Move it into a work item and make sure to cancel it on exit. References: https://bugs.debian.org/735202 References: https://bugs.debian.org/744015 Reported-by: Paul Gevers <elbrus@debian.org> Reported-and-tested-by: Jarek Czekalski <jarekczek@poczta.onet.pl> Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11xhci: delete endpoints from bandwidth list before freeing whole deviceMathias Nyman
commit 5dc2808c4729bf080487e61b80ee04e0fdb12a37 upstream. Lists of endpoints are stored for bandwidth calculation for roothub ports. Make sure we remove all endpoints from the list before the whole device, containing its endpoints list_head stuctures, is freed. This used to be done in the wrong order in xhci_mem_cleanup(), and triggered an oops in resume from S4 (hibernate). Tested-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11md: always set MD_RECOVERY_INTR when interrupting a reshape thread.NeilBrown
commit 2ac295a544dcae9299cba13ce250419117ae7fd1 upstream. Commit 8313b8e57f55b15e5b7f7fc5d1630bbf686a9a97 md: fix problem when adding device to read-only array with bitmap. added a called to md_reap_sync_thread() which cause a reshape thread to be interrupted (in particular, it could cause md_thread() to never even call md_do_sync()). However it didn't set MD_RECOVERY_INTR so ->finish_reshape() would not know that the reshape didn't complete. This only happens when mddev->ro is set and normally reshape threads don't run in that situation. But raid5 and raid10 can start a reshape thread during "run" is the array is in the middle of a reshape. They do this even if ->ro is set. So it is best to set MD_RECOVERY_INTR before abortingg the sync thread, just in case. Though it rare for this to trigger a problem it can cause data corruption because the reshape isn't finished properly. So it is suitable for any stable which the offending commit was applied to. (3.2 or later) Fixes: 8313b8e57f55b15e5b7f7fc5d1630bbf686a9a97 Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11md: always set MD_RECOVERY_INTR when aborting a reshape or other "resync".NeilBrown
commit 3991b31ea072b070081ca3bfa860a077eda67de5 upstream. If mddev->ro is set, md_to_sync will (correctly) abort. However in that case MD_RECOVERY_INTR isn't set. If a RESHAPE had been requested, then ->finish_reshape() will be called and it will think the reshape was successful even though nothing happened. Normally a resync will not be requested if ->ro is set, but if an array is stopped while a reshape is on-going, then when the array is started, the reshape will be restarted. If the array is also set read-only at this point, the reshape will instantly appear to success, resulting in data corruption. Consequently, this patch is suitable for any -stable kernel. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11drm/i915: Only copy back the modified fields to userspace from execbufferChris Wilson
commit 9aab8bff7aa3bee567213ad3c1fdfb217bb980a2 upstream. We only want to modifiy a single field in the userspace view of the execbuffer command buffer, so explicitly change that rather than copy everything back again. This serves two purposes: 1. The single fields are much cheaper to copy (constant size so the copy uses special case code) and much smaller than the whole array. 2. We modify the array for internal use that need to be masked from the user. Note: We need this backported since without it the next bugfix will blow up when userspace recycles batchbuffers and relocations. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11sched: Fix hotplug vs. set_cpus_allowed_ptr()Lai Jiangshan
commit 6acbfb96976fc3350e30d964acb1dbbdf876d55e upstream. Lai found that: WARNING: CPU: 1 PID: 13 at arch/x86/kernel/smp.c:124 native_smp_send_reschedule+0x2d/0x4b() ... migration_cpu_stop+0x1d/0x22 was caused by set_cpus_allowed_ptr() assuming that cpu_active_mask is always a sub-set of cpu_online_mask. This isn't true since 5fbd036b552f ("sched: Cleanup cpu_active madness"). So set active and online at the same time to avoid this particular problem. Fixes: 5fbd036b552f ("sched: Cleanup cpu_active madness") Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Gautham R. Shenoy <ego@linux.vnet.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michael wang <wangyun@linux.vnet.ibm.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Toshi Kani <toshi.kani@hp.com> Link: http://lkml.kernel.org/r/53758B12.8060609@cn.fujitsu.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11dm cache: always split discards on cache block boundariesHeinz Mauelshagen
commit f1daa838e861ae1a0fb7cd9721a21258430fcc8c upstream. The DM cache target cannot cope with discards that span multiple cache blocks, so each discard bio that spans more than one cache block must get split by the DM core. Signed-off-by: Heinz Mauelshagen <heinzm@redhat.com> Acked-by: Joe Thornber <ejt@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11ARM: 8051/1: put_user: fix possible data corruption in put_userAndrey Ryabinin
commit 537094b64b229bf3ad146042f83e74cf6abe59df upstream. According to arm procedure call standart r2 register is call-cloberred. So after the result of x expression was put into r2 any following function call in p may overwrite r2. To fix this, the result of p expression must be saved to the temporary variable before the assigment x expression to __r2. Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Reviewed-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11ARM: OMAP4: Fix the boot regression with CPU_IDLE enabledSantosh Shilimkar
commit 4b353a706a86598ba47307c47301c3c428b79e09 upstream. On OMAP4 panda board, there have been several bug reports about boot hang and lock-ups with CPU_IDLE enabled. The root cause of the issue is missing interrupts while in idle state. Commit cb7094e8 {cpuidle / omap4 : use CPUIDLE_FLAG_TIMER_STOP flag} moved the broadcast notifiers to common code for right reasons but on OMAP4 which suffers from a nasty ROM code bug with GIC, commit ff999b8a {ARM: OMAP4460: Workaround for ROM bug ..}, we loose interrupts which leads to issues like lock-up, hangs etc. Patch reverts commit cb7094 {cpuidle / omap4 : use CPUIDLE_FLAG_TIMER_STOP flag} and 54769d6 {cpuidle: OMAP4: remove timer broadcast initialization} to avoid the issue. With this change, OMAP4 panda boards, the mentioned issues are getting fixed. We no longer loose interrupts which was the cause of the regression. Fixes: cb7094e8 (cpuidle / omap4 : use CPUIDLE_FLAG_TIMER_STOP flag) Fixes: ff999b8a (cpuidle: OMAP4: remove timer broadcast initialization) Cc: Roger Quadros <rogerq@ti.com> Cc: Kevin Hilman <khilman@linaro.org> Cc: Tony Lindgren <tony@atomide.com> Cc: Daniel Lezcano <daniel.lezcano@linaro.org> Reported-tested-by: Roger Quadros <rogerq@ti.com> Reported-tested-by: Kevin Hilman <khilman@linaro.org> Tested-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11ARM: OMAP3: clock: Back-propagate rate change from cam_mclk to dpll4_m5 on ↵Laurent Pinchart
all OMAP3 platforms commit 98d7e1aee6dd534f468993f8c6a1bc730d4cfa81 upstream. Commit 7b2e1277598e4187c9be3e61fd9b0f0423f97986 ("ARM: OMAP3: clock: Back-propagate rate change from cam_mclk to dpll4_m5") enabled clock rate back-propagation from cam_mclk do dpll4_m5 on OMAP3630 only. Perform back-propagation on other OMAP3 platforms as well. Reported-by: Jean-Philippe François <jp.francois@cynove.com> Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11ARM: imx: fix error handling in ipu device registrationEmil Goode
commit d1d70e5dc2cfa9047bb935c41ba808ebb8135696 upstream. If we fail to allocate struct platform_device pdev we dereference it after the goto label err. This bug was found using coccinelle. Fixes: afa77ef (ARM: mx3: dynamically allocate "ipu-core" devices) Signed-off-by: Emil Goode <emilgoode@gmail.com> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@freescale.com> Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11drm/radeon: handle non-VGA class pci devices with ATRMAlex Deucher
commit d8ade3526b2aa0505132c404c05a38b73ea15490 upstream. Newer PX systems have non-VGA pci class dGPUs. Update the ATRM fetch method to handle those cases. bug: https://bugzilla.kernel.org/show_bug.cgi?id=75401 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Christian König <christian.koenig@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11drm/radeon: also try GART for CPU accessed buffersChristian König
commit 544092596e8ac269f70e70961b5e9381909c9b1e upstream. Placing them exclusively into VRAM might not work all the time. Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=78297 Signed-off-by: Christian König <christian.koenig@amd.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11drm/gf119-/disp: fix nasty bug which can clobber SOR0's clock setupBen Skeggs
commit 0f1d360b2ee3a2a0f510d3f1bcd3f5ebe5d41265 upstream. Fixes a LVDS bleed issue on Lenovo W530 that can occur under a number of circumstances. Signed-off-by: Ben Skeggs <bskeggs@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
