2014-02-22Linux 3.10.32v3.10.32Greg Kroah-Hartman
2014-02-22EDAC: Correct workqueue setup pathBorislav Petkov
commit cb6ef42e516cb8948f15e4b70dc03af8020050a2 upstream. We're using edac_mc_workq_setup() both on the init path, when we load an edac driver and when we change the polling period (edac_mc_reset_delay_period) through /sys/.../edac_mc_poll_msec. On that second path we don't need to init the workqueue which has been initialized already. Thanks to Tejun for workqueue insights. Signed-off-by: Borislav Petkov <bp@suse.de> Link: http://lkml.kernel.org/r/1391457913-881-1-git-send-email-prarit@redhat.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22EDAC: Poll timeout cannot be zero, p2Borislav Petkov
commit 9da21b1509d8aa7ab4846722817d16c72d656c91 upstream. Sanitize code even more to accept unsigned longs only and to not allow polling intervals below 1 second as this is unnecessary and doesn't make much sense anyway for polling errors. Signed-off-by: Borislav Petkov <bp@suse.de> Link: http://lkml.kernel.org/r/1391457913-881-1-git-send-email-prarit@redhat.com Cc: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22drivers/edac/edac_mc_sysfs.c: poll timeout cannot be zeroPrarit Bhargava
commit 79040cad3f8235937e229f1b9401ba36dd5ad69b upstream. If you do echo 0 > /sys/module/edac_core/parameters/edac_mc_poll_msec the following stack trace is output because the edac module is not designed to poll with a timeout of zero. WARNING: CPU: 12 PID: 0 at lib/list_debug.c:33 __list_add+0xac/0xc0() list_add corruption. prev->next should be next (ffff8808291dd1b8), but was (null). (prev=ffff8808286fe3f8). Modules linked in: sg nfsv3 rpcsec_gss_krb5 nfsv4 dns_resolver nfs fscache cfg80211 rfkill x86_pkg_temp_thermal coretemp kvm_intel kvm ixgbe e1000e crct10dif_pclmul crc32_pclmul crc32c_intel ghash_clmulni_intel aesni_intel lrw gf128mul glue_helper ablk_helper cryptd iTCO_wdt ptp sb_edac iTCO_vendor_support pps_core mdio ipmi_devintf edac_core ioatdma microcode shpchp lpc_ich pcspkr i2c_i801 dca mfd_core ipmi_si wmi ipmi_msghandler nfsd auth_rpcgss nfs_acl lockd sunrpc xfs libcrc32c sd_mod sr_mod cdrom crc_t10dif crct10dif_common mgag200 syscopyarea sysfillrect sysimgblt isci i2c_algo_bit drm_kms_helper ttm drm libsas ahci libahci scsi_transport_sas libata i2c_core dm_mirror dm_region_hash dm_log dm_mod CPU: 12 PID: 0 Comm: swapper/12 Not tainted 3.13.0+ #1 Hardware name: Intel Corporation LH Pass ........../SVRBD-ROW_T, BIOS SE5C600.86B.01.08.0003.022620131521 02/26/2013 Call Trace: <IRQ> __list_add+0xac/0xc0 __internal_add_timer+0xab/0x130 internal_add_timer+0x17/0x40 mod_timer_pinned+0xca/0x170 intel_pstate_timer_func+0x28a/0x380 call_timer_fn+0x36/0x100 run_timer_softirq+0x1ff/0x2f0 __do_softirq+0xf5/0x2e0 irq_exit+0x10d/0x120 smp_apic_timer_interrupt+0x45/0x60 apic_timer_interrupt+0x6d/0x80 <EOI> cpuidle_idle_call+0xb9/0x1f0 arch_cpu_idle+0xe/0x30 cpu_startup_entry+0x9e/0x240 start_secondary+0x1e4/0x290 kernel BUG at kernel/timer.c:1084! invalid opcode: 0000 [#1] SMP Modules linked in: sg nfsv3 rpcsec_gss_krb5 nfsv4 dns_resolver nfs fscache cfg80211 rfkill x86_pkg_temp_thermal coretemp kvm_intel kvm ixgbe e1000e crct10dif_pclmul crc32_pclmul crc32c_intel ghash_clmulni_intel aesni_intel lrw gf128mul glue_helper ablk_helper cryptd iTCO_wdt ptp sb_edac iTCO_vendor_support pps_core mdio ipmi_devintf edac_core ioatdma microcode shpchp lpc_ich pcspkr i2c_i801 dca mfd_core ipmi_si wmi ipmi_msghandler nfsd auth_rpcgss nfs_acl lockd sunrpc xfs libcrc32c sd_mod sr_mod cdrom crc_t10dif crct10dif_common mgag200 syscopyarea sysfillrect sysimgblt isci i2c_algo_bit drm_kms_helper ttm drm libsas ahci libahci scsi_transport_sas libata i2c_core dm_mirror dm_region_hash dm_log dm_mod CPU: 12 PID: 0 Comm: swapper/12 Tainted: G W 3.13.0+ #1 Hardware name: Intel Corporation LH Pass ........../SVRBD-ROW_T, BIOS SE5C600.86B.01.08.0003.022620131521 02/26/2013 Call Trace: <IRQ> run_timer_softirq+0x245/0x2f0 __do_softirq+0xf5/0x2e0 irq_exit+0x10d/0x120 smp_apic_timer_interrupt+0x45/0x60 apic_timer_interrupt+0x6d/0x80 <EOI> cpuidle_idle_call+0xb9/0x1f0 arch_cpu_idle+0xe/0x30 cpu_startup_entry+0x9e/0x240 start_secondary+0x1e4/0x290 RIP cascade+0x93/0xa0 WARNING: CPU: 36 PID: 1154 at kernel/workqueue.c:1461 __queue_delayed_work+0xed/0x1a0() Modules linked in: sg nfsv3 rpcsec_gss_krb5 nfsv4 dns_resolver nfs fscache cfg80211 rfkill x86_pkg_temp_thermal coretemp kvm_intel kvm ixgbe e1000e crct10dif_pclmul crc32_pclmul crc32c_intel ghash_clmulni_intel aesni_intel lrw gf128mul glue_helper ablk_helper cryptd iTCO_wdt ptp sb_edac iTCO_vendor_support pps_core mdio ipmi_devintf edac_core ioatdma microcode shpchp lpc_ich pcspkr i2c_i801 dca mfd_core ipmi_si wmi ipmi_msghandler nfsd auth_rpcgss nfs_acl lockd sunrpc xfs libcrc32c sd_mod sr_mod cdrom crc_t10dif crct10dif_common mgag200 syscopyarea sysfillrect sysimgblt isci i2c_algo_bit drm_kms_helper ttm drm libsas ahci libahci scsi_transport_sas libata i2c_core dm_mirror dm_region_hash dm_log dm_mod CPU: 36 PID: 1154 Comm: kworker/u481:3 Tainted: G W 3.13.0+ #1 Hardware name: Intel Corporation LH Pass ........../SVRBD-ROW_T, BIOS SE5C600.86B.01.08.0003.022620131521 02/26/2013 Workqueue: edac-poller edac_mc_workq_function [edac_core] Call Trace: dump_stack+0x45/0x56 warn_slowpath_common+0x7d/0xa0 warn_slowpath_null+0x1a/0x20 __queue_delayed_work+0xed/0x1a0 queue_delayed_work_on+0x27/0x50 edac_mc_workq_function+0x72/0xa0 [edac_core] process_one_work+0x17b/0x460 worker_thread+0x11b/0x400 kthread+0xd2/0xf0 ret_from_fork+0x7c/0xb0 This patch adds a range check in the edac_mc_poll_msec code to check for 0. Signed-off-by: Prarit Bhargava <prarit@redhat.com> Cc: Doug Thompson <dougthompson@xmission.com> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22EDAC: Replace strict_strtol() with kstrtol()Jingoo Han
commit c542b53da9ffa4fe9de61149818a06aacae531f8 upstream. The usage of strict_strtol() is not preferred, because strict_strtol() is obsolete. Thus, kstrtol() should be used. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Borislav Petkov <bp@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22genirq: Add missing irq_to_desc export for CONFIG_SPARSE_IRQ=nPaul Gortmaker
commit 2c45aada341121438affc4cb8d5b4cfaa2813d3d upstream. In allmodconfig builds for sparc and any other arch which does not set CONFIG_SPARSE_IRQ, the following will be seen at modpost: CC [M] lib/cpu-notifier-error-inject.o CC [M] lib/pm-notifier-error-inject.o ERROR: "irq_to_desc" [drivers/gpio/gpio-mcp23s08.ko] undefined! make[2]: *** [__modpost] Error 1 This happens because commit 3911ff30f5 ("genirq: export handle_edge_irq() and irq_to_desc()") added one export for it, but there were actually two instances of it, in an if/else clause for CONFIG_SPARSE_IRQ. Add the second one. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Jiri Kosina <jkosina@suse.cz> Link: http://lkml.kernel.org/r/1392057610-11514-1-git-send-email-paul.gortmaker@windriver.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22ring-buffer: Fix first commit on sub-buffer having non-zero deltaSteven Rostedt (Red Hat)
commit d651aa1d68a2f0a7ee65697b04c6a92f8c0a12f2 upstream. Each sub-buffer (buffer page) has a full 64 bit timestamp. The events on that page use a 27 bit delta against that timestamp in order to save on bits written to the ring buffer. If the time between events is larger than what the 27 bits can hold, a "time extend" event is added to hold the entire 64 bit timestamp again and the events after that hold a delta from that timestamp. As a "time extend" is always paired with an event, it is logical to just allocate the event with the time extend, to make things a bit more efficient. Unfortunately, when the pairing code was written, it removed the "delta = 0" from the first commit on a page, causing the events on the page to be slightly skewed. Fixes: 69d1b839f7ee "ring-buffer: Bind time extend and data events together" Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22power: max17040: Fix NULL pointer dereference when there is no platform_dataKrzysztof Kozlowski
commit ac323d8d807060f7c95a685a9fe861e7b6300993 upstream. Fix NULL pointer dereference of "chip->pdata" if platform_data was not supplied to the driver. The driver during probe stored the pointer to the platform_data: chip->pdata = client->dev.platform_data; Later it was dereferenced in max17040_get_online() and max17040_get_status(). If platform_data was not supplied, the NULL pointer exception would happen: [ 6.626094] Unable to handle kernel of a at virtual address 00000000 [ 6.628557] pgd = c0004000 [ 6.632868] [00000000] *pgd=66262564 [ 6.634636] Unable to handle kernel paging request at virtual address e6262000 [ 6.642014] pgd = de468000 [ 6.644700] [e6262000] *pgd=00000000 [ 6.648265] Internal error: Oops: 5 [#1] PREEMPT SMP ARM [ 6.653552] Modules linked in: [ 6.656598] CPU: 0 PID: 31 Comm: kworker/0:1 Not tainted 3.10.14-02717-gc58b4b4 #505 [ 6.664334] Workqueue: events max17040_work [ 6.668488] task: dfa11b80 ti: df9f6000 task.ti: df9f6000 [ 6.673873] PC is at show_pte+0x80/0xb8 [ 6.677687] LR is at show_pte+0x3c/0xb8 [ 6.681503] pc : [<c001b7b8>] lr : [<c001b774>] psr: 600f0113 [ 6.681503] sp : df9f7d58 ip : 600f0113 fp : 00000009 [ 6.692965] r10: 00000000 r9 : 00000000 r8 : dfa11b80 [ 6.698171] r7 : df9f7ea0 r6 : e6262000 r5 : 00000000 r4 : 00000000 [ 6.704680] r3 : 00000000 r2 : e6262000 r1 : 600f0193 r0 : c05b3750 [ 6.711194] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel [ 6.718485] Control: 10c53c7d Table: 5e46806a DAC: 00000015 [ 6.724218] Process kworker/0:1 (pid: 31, stack limit = 0xdf9f6238) [ 6.730465] Stack: (0xdf9f7d58 to 0xdf9f8000) [ 6.914325] [<c001b7b8>] (show_pte+0x80/0xb8) from [<c047107c>] (__do_kernel_fault.part.9+0x44/0x74) [ 6.923425] [<c047107c>] (__do_kernel_fault.part.9+0x44/0x74) from [<c001bb7c>] (do_page_fault+0x2c4/0x360) [ 6.933144] [<c001bb7c>] (do_page_fault+0x2c4/0x360) from [<c0008400>] (do_DataAbort+0x34/0x9c) [ 6.941825] [<c0008400>] (do_DataAbort+0x34/0x9c) from [<c000e5d8>] (__dabt_svc+0x38/0x60) [ 6.950058] Exception stack(0xdf9f7ea0 to 0xdf9f7ee8) [ 6.955099] 7ea0: df0c1790 00000000 00000002 00000000 df0c1794 df0c1790 df0c1790 00000042 [ 6.963271] 7ec0: df0c1794 00000001 00000000 00000009 00000000 df9f7ee8 c0306268 c0306270 [ 6.971419] 7ee0: a00f0113 ffffffff [ 6.974902] [<c000e5d8>] (__dabt_svc+0x38/0x60) from [<c0306270>] (max17040_work+0x8c/0x144) [ 6.983317] [<c0306270>] (max17040_work+0x8c/0x144) from [<c003f364>] (process_one_work+0x138/0x440) [ 6.992429] [<c003f364>] (process_one_work+0x138/0x440) from [<c003fa64>] (worker_thread+0x134/0x3b8) [ 7.001628] [<c003fa64>] (worker_thread+0x134/0x3b8) from [<c00454bc>] (kthread+0xa4/0xb0) [ 7.009875] [<c00454bc>] (kthread+0xa4/0xb0) from [<c000eb28>] (ret_from_fork+0x14/0x2c) [ 7.017943] Code: e1a03005 e2422480 e0826104 e59f002c (e7922104) [ 7.024017] ---[ end trace 73bc7006b9cc5c79 ]--- Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Fixes: c6f4a42de60b981dd210de01cd3e575835e3158e Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22time: Fix overflow when HZ is smaller than 60Mikulas Patocka
commit 80d767d770fd9c697e434fd080c2db7b5c60c6dd upstream. When compiling for the IA-64 ski emulator, HZ is set to 32 because the emulation is slow and we don't want to waste too many cycles processing timers. Alpha also has an option to set HZ to 32. This causes integer underflow in kernel/time/jiffies.c: kernel/time/jiffies.c:66:2: warning: large integer implicitly truncated to unsigned type [-Woverflow] .mult = NSEC_PER_JIFFY << JIFFIES_SHIFT, /* details above */ ^ This patch reduces the JIFFIES_SHIFT value to avoid the overflow. Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Link: http://lkml.kernel.org/r/alpine.LRH.2.02.1401241639100.23871@file01.intranet.prod.int.rdu2.redhat.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22md/raid5: Fix CPU hotplug callback registrationOleg Nesterov
commit 789b5e0315284463617e106baad360cb9e8db3ac upstream. Subsystems that want to register CPU hotplug callbacks, as well as perform initialization for the CPUs that are already online, often do it as shown below: get_online_cpus(); for_each_online_cpu(cpu) init_cpu(cpu); register_cpu_notifier(&foobar_cpu_notifier); put_online_cpus(); This is wrong, since it is prone to ABBA deadlocks involving the cpu_add_remove_lock and the cpu_hotplug.lock (when running concurrently with CPU hotplug operations). Interestingly, the raid5 code can actually prevent double initialization and hence can use the following simplified form of callback registration: register_cpu_notifier(&foobar_cpu_notifier); get_online_cpus(); for_each_online_cpu(cpu) init_cpu(cpu); put_online_cpus(); A hotplug operation that occurs between registering the notifier and calling get_online_cpus(), won't disrupt anything, because the code takes care to perform the memory allocations only once. So reorganize the code in raid5 this way to fix the deadlock with callback registration. Cc: linux-raid@vger.kernel.org Fixes: 36d1c6476be51101778882897b315bd928c8c7b5 Signed-off-by: Oleg Nesterov <oleg@redhat.com> [Srivatsa: Fixed the unregister_cpu_notifier() deadlock, added the free_scratch_buffer() helper to condense code further and wrote the changelog.] Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22md/raid1: restore ability for check and repair to fix read errors.NeilBrown
commit 1877db75589a895bbdc4c4c3f23558e57b521141 upstream. commit 30bc9b53878a9921b02e3b5bc4283ac1c6de102a md/raid1: fix bio handling problems in process_checks() Move the bio_reset() to a point before where BIO_UPTODATE is checked, so that check now always report that the bio is uptodate, even if it is not. This causes process_check() to sometimes treat read-errors as successful matches so the good data isn't written out. This patch preserves the flag until it is needed. Bug was introduced in 3.11, but backported to 3.10-stable (as it fixed an even worse bug). So suitable for any -stable since 3.10. Reported-and-tested-by: Michael Tokarev <mjt@tls.msk.ru> Fixed: 30bc9b53878a9921b02e3b5bc4283ac1c6de102a Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22tick: Clear broadcast pending bit when switching to oneshotThomas Gleixner
commit dd5fd9b91a77b4c9c28b7ef9c181b1a875820d0a upstream. AMD systems which use the C1E workaround in the amd_e400_idle routine trigger the WARN_ON_ONCE in the broadcast code when onlining a CPU. The reason is that the idle routine of those AMD systems switches the cpu into forced broadcast mode early on before the newly brought up CPU can switch over to high resolution / NOHZ mode. The timer related CPU1 bringup looks like this: clockevent_register_device(local_apic); tick_setup(local_apic); ... idle() tick_broadcast_on_off(FORCE); tick_broadcast_oneshot_control(ENTER) cpumask_set(cpu, broadcast_oneshot_mask); halt(); Now the broadcast interrupt on CPU0 sets CPU1 in the broadcast_pending_mask and wakes CPU1. So CPU1 continues: local_apic_timer_interrupt() tick_handle_periodic(); softirq() tick_init_highres(); cpumask_clr(cpu, broadcast_oneshot_mask); tick_broadcast_oneshot_control(ENTER) WARN_ON(cpumask_test(cpu, broadcast_pending_mask); So while we remove CPU1 from the broadcast_oneshot_mask when we switch over to highres mode, we do not clear the pending bit, which then triggers the warning when we go back to idle. The reason why this is only visible on C1E affected AMD systems is that the other machines enter the deep sleep states via acpi_idle/intel_idle and exit the broadcast mode before executing the remote triggered local_apic_timer_interrupt. So the pending bit is already cleared when the switch over to highres mode is clearing the oneshot mask. The solution is simple: Clear the pending bit together with the mask bit when we switch over to highres mode. Stanislaw came up independently with the same patch by enforcing the C1E workaround and debugging the fallout. I picked mine, because mine has a changelog :) Reported-by: poma <pomidorabelisima@gmail.com> Debugged-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Olaf Hering <olaf@aepfle.de> Cc: Dave Jones <davej@redhat.com> Cc: Justin M. Forbes <jforbes@redhat.com> Cc: Josh Boyer <jwboyer@redhat.com> Link: http://lkml.kernel.org/r/alpine.DEB.2.02.1402111434180.21991@ionos.tec.linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22KVM: return an error code in kvm_vm_ioctl_register_coalesced_mmio()Dan Carpenter
commit aac5c4226e7136c331ed384c25d5560204da10a0 upstream. If kvm_io_bus_register_dev() fails then it returns success but it should return an error code. I also did a little cleanup like removing an impossible NULL test. Fixes: 2b3c246a682c ('KVM: Make coalesced mmio use a device per zone') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22IB/qib: Add missing serdes init sequenceMike Marciniszyn
commit 2f75e12c4457a9b3d042c0a0d748fa198dc2ffaf upstream. Research has shown that commit a77fcf895046 ("IB/qib: Use a single txselect module parameter for serdes tuning") missed a key serdes init sequence. This patch add that sequence. Reviewed-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22compiler/gcc4: Make quirk for asm_volatile_goto() unconditionalSteven Noonan
commit a9f180345f5378ac87d80ed0bea55ba421d83859 upstream. I started noticing problems with KVM guest destruction on Linux 3.12+, where guest memory wasn't being cleaned up. I bisected it down to the commit introducing the new 'asm goto'-based atomics, and found this quirk was later applied to those. Unfortunately, even with GCC 4.8.2 (which ostensibly fixed the known 'asm goto' bug) I am still getting some kind of miscompilation. If I enable the asm_volatile_goto quirk for my compiler, KVM guests are destroyed correctly and the memory is cleaned up. So make the quirk unconditional for now, until bug is found and fixed. Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Steven Noonan <steven@uplinklabs.net> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jakub Jelinek <jakub@redhat.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Link: http://lkml.kernel.org/r/1392274867-15236-1-git-send-email-steven@uplinklabs.net Link: http://gcc.gnu.org/bugzilla/show_bug.cgi?id=58670 Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22block: add cond_resched() to potentially long running ioctl discard loopJens Axboe
commit c8123f8c9cb517403b51aa41c3c46ff5e10b2c17 upstream. When mkfs issues a full device discard and the device only supports discards of a smallish size, we can loop in blkdev_issue_discard() for a long time. If preempt isn't enabled, this can turn into a softlock situation and the kernel will start complaining. Add an explicit cond_resched() at the end of the loop to avoid that. Signed-off-by: Jens Axboe <axboe@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22block: Fix nr_vecs for inline integrity vectorsMartin K. Petersen
commit 087787959ce851d7bbb19f10f6e9241b7f85a3ca upstream. Commit 9f060e2231ca changed the way we handle allocations for the integrity vectors. When the vectors are inline there is no associated slab and consequently bvec_nr_vecs() returns 0. Ensure that we check against BIP_INLINE_VECS in that case. Reported-by: David Milburn <dmilburn@redhat.com> Tested-by: David Milburn <dmilburn@redhat.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <axboe@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22block: __elv_next_request() shouldn't call into the elevator if bypassingTejun Heo
commit 556ee818c06f37b2e583af0363e6b16d0e0270de upstream. request_queue bypassing is used to suppress higher-level function of a request_queue so that they can be switched, reconfigured and shut down. A request_queue does the followings while bypassing. * bypasses elevator and io_cq association and queues requests directly to the FIFO dispatch queue. * bypasses block cgroup request_list lookup and always uses the root request_list. Once confirmed to be bypassing, specific elevator and block cgroup policy implementations can assume that nothing is in flight for them and perform various operations which would be dangerous otherwise. Such confirmation is acheived by short-circuiting all new requests directly to the dispatch queue and waiting for all the requests which were issued before to finish. Unfortunately, while the request allocating and draining sides were properly handled, we forgot to actually plug the request dispatch path. Even after bypassing mode is confirmed, if the attached driver tries to fetch a request and the dispatch queue is empty, __elv_next_request() would invoke the current elevator's elevator_dispatch_fn() callback. As all in-flight requests were drained, the elevator wouldn't contain any request but once bypass is confirmed we don't even know whether the elevator is even there. It might be in the process of being switched and half torn down. Frank Mayhar reports that this actually happened while switching elevators, leading to an oops. Let's fix it by making __elv_next_request() avoid invoking the elevator_dispatch_fn() callback if the queue is bypassing. It already avoids invoking the callback if the queue is dying. As a dying queue is guaranteed to be bypassing, we can simply replace blk_queue_dying() check with blk_queue_bypass(). Reported-by: Frank Mayhar <fmayhar@google.com> References: http://lkml.kernel.org/g/1390319905.20232.38.camel@bobble.lax.corp.google.com Tested-by: Frank Mayhar <fmayhar@google.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22Modpost: fixed USB alias generation for ranges including 0x9 and 0xAJan Moskyto Matejka
commit 03b56329f9bb5a1cb73d7dc659d529a9a9bf3acc upstream. Commit afe2dab4f6 ("USB: add hex/bcd detection to usb modalias generation") changed the routine that generates alias ranges. Before that change, only digits 0-9 were supported; the commit tried to fix the case when the range includes higher values than 0x9. Unfortunately, the commit didn't fix the case when the range includes both 0x9 and 0xA, meaning that the final range must look like [x-9A-y] where x <= 0x9 and y >= 0xA -- instead the [x-9A-x] range was produced. Modprobe doesn't complain as it sees no difference between no-match and bad-pattern results of fnmatch(). Fixing this simple bug to fix the aliases. Also changing the hardcoded beginning of the range to uppercase as all the other letters are also uppercase in the device version numbers. Fortunately, this affects only the dvb-usb-dib0700 module, AFAIK. Signed-off-by: Jan Moskyto Matejka <mq@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22Revert "usbcore: set lpm_capable field for LPM capable root hubs"Sarah Sharp
commit 140e3026a57ab7d830dab2f2c57796c222db0ea9 upstream. Commit 9df89d85b407690afa46ddfbccc80bec6869971d "usbcore: set lpm_capable field for LPM capable root hubs" was created under the assumption that all USB host controllers should have USB 3.0 Link PM enabled for all devices under the hosts. Unfortunately, that's not the case. The xHCI driver relies on knowledge of the host hardware scheduler to calculate the LPM U1/U2 timeout values, and it only sets lpm_capable to one for Intel host controllers (that have the XHCI_LPM_SUPPORT quirk set). When LPM is enabled for some Fresco Logic hosts, it causes failures with a AgeStar 3UBT USB 3.0 hard drive dock: Jan 11 13:59:03 sg-laptop kernel: usb 3-1: new SuperSpeed USB device number 2 using xhci_hcd Jan 11 13:59:03 sg-laptop kernel: usb 3-1: Set SEL for device-initiated U1 failed. Jan 11 13:59:08 sg-laptop kernel: usb 3-1: Set SEL for device-initiated U2 failed. Jan 11 13:59:08 sg-laptop kernel: usb-storage 3-1:1.0: USB Mass Storage device detected Jan 11 13:59:08 sg-laptop mtp-probe[613]: checking bus 3, device 2: "/sys/devices/pci0000:00/0000:00:1c.3/0000:04:00.0/usb3/3-1" Jan 11 13:59:08 sg-laptop mtp-probe[613]: bus: 3, device: 2 was not an MTP device Jan 11 13:59:08 sg-laptop kernel: scsi6 : usb-storage 3-1:1.0 Jan 11 13:59:13 sg-laptop kernel: usb 3-1: Set SEL for device-initiated U1 failed. Jan 11 13:59:18 sg-laptop kernel: usb 3-1: Set SEL for device-initiated U2 failed. Jan 11 13:59:18 sg-laptop kernel: usbcore: registered new interface driver usb-storage Jan 11 13:59:40 sg-laptop kernel: usb 3-1: reset SuperSpeed USB device number 2 using xhci_hcd Jan 11 13:59:41 sg-laptop kernel: usb 3-1: device descriptor read/8, error -71 Jan 11 13:59:41 sg-laptop kernel: usb 3-1: reset SuperSpeed USB device number 2 using xhci_hcd Jan 11 13:59:46 sg-laptop kernel: usb 3-1: device descriptor read/8, error -110 Jan 11 13:59:46 sg-laptop kernel: scsi 6:0:0:0: Device offlined - not ready after error recovery Jan 11 13:59:46 sg-laptop kernel: usb 3-1: USB disconnect, device number 2 lspci for the affected host: 04:00.0 0c03: 1b73:1000 (rev 04) (prog-if 30 [XHCI]) Subsystem: 1043:1039 Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx- Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx- Latency: 0, Cache Line Size: 64 bytes Interrupt: pin A routed to IRQ 19 Region 0: Memory at dd200000 (32-bit, non-prefetchable) [size=64K] Capabilities: [50] Power Management version 3 Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold-) Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME- Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+ Address: 0000000000000000 Data: 0000 Capabilities: [80] Express (v1) Endpoint, MSI 00 DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <2us, L1 <32us ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset- DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported- RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+ MaxPayload 128 bytes, MaxReadReq 512 bytes DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend- LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Latency L0 unlimited, L1 unlimited ClockPM- Surprise- LLActRep- BwNot- LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- Retrain- CommClk+ ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt- LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt- Kernel driver in use: xhci_hcd Kernel modules: xhci_hcd The commit was backported to stable kernels, and will need to be reverted there as well. Signed-off-by: Sarah Sharp <sarah.a.sharp@intel.com> Reported-by: Sergey Galanov <sergey.e.galanov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22usb: option: blacklist ZTE MF667 net interfaceRaymond Wanyoike
commit 3635c7e2d59f7861afa6fa5e87e2a58860ff514d upstream. Interface #5 of 19d2:1270 is a net interface which has been submitted to the qmi_wwan driver so consequently remove it from the option driver. Signed-off-by: Raymond Wanyoike <raymond.wanyoike@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22usb-storage: enable multi-LUN scanning when neededAlan Stern
commit 823d12c95c666fa7ab7dad208d735f6bc6afabdc upstream. People sometimes create their own custom-configured kernels and forget to enable CONFIG_SCSI_MULTI_LUN. This causes problems when they plug in a USB storage device (such as a card reader) with more than one LUN. Fortunately, we can tell fairly easily when a storage device claims to have more than one LUN. When that happens, this patch asks the SCSI layer to probe all the LUNs automatically, regardless of the config setting. The patch also updates the Kconfig help text for usb-storage, explaining that CONFIG_SCSI_MULTI_LUN may be necessary. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Reported-by: Thomas Raschbacher <lordvan@lordvan.com> CC: Matthew Dharm <mdharm-usb@one-eyed-alien.net> CC: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22usb-storage: restrict bcdDevice range for Super Top in Cypress ATACBAlan Stern
commit a9c143c82608bee2a36410caa56d82cd86bdc7fa upstream. The Cypress ATACB unusual-devs entry for the Super Top SATA bridge causes problems. Although it was originally reported only for bcdDevice = 0x160, its range was much larger. This resulted in a bug report for bcdDevice 0x220, so the range was capped at 0x219. Now Milan reports errors with bcdDevice 0x150. Therefore this patch restricts the range to just 0x160. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Reported-and-tested-by: Milan Svoboda <milan.svoboda@centrum.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22usb-storage: add unusual-devs entry for BlackBerry 9000Alan Stern
commit c5637e5119c43452a00e27c274356b072263ecbb upstream. This patch adds an unusual-devs entry for the BlackBerry 9000. This fixes Bugzilla #22442. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Reported-by: Moritz Moeller-Herrmann <moritz-kernel@moeller-herrmann.de> Tested-by: Moritz Moeller-Herrmann <moritz-kernel@moeller-herrmann.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22USB: ftdi_sio: add Tagsys RFID Reader IDsUlrich Hahn
commit 76f24e3f39a1a94bab0d54e98899d64abcd9f69c upstream. Adding two more IDs to the ftdi_sio usb serial driver. It now connects Tagsys RFID readers. There might be more IDs out there for other Tagsys models. Signed-off-by: Ulrich Hahn <uhahn@eanco.de> Cc: Johan Hovold <johan@hovold.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22usb: ftdi_sio: add Mindstorms EV3 console adapterBjørn Mork
commit 67847baee056892dc35efb9c3fd05ae7f075588c upstream. Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22Drivers: hv: vmbus: Don't timeout during the initial connection with hostK. Y. Srinivasan
commit 269f979467cf49f2ea8132316c1f00f8c9678f7c upstream. When the guest attempts to connect with the host when there may already be a connection with the host (as would be the case during the kdump/kexec path), it is difficult to guarantee timely response from the host. Starting with WS2012 R2, the host supports this ability to re-connect with the host (explicitly to support kexec). Prior to responding to the guest, the host needs to ensure that device states based on the previous connection to the host have been properly torn down. This may introduce unbounded delays. To deal with this issue, don't do a timed wait during the initial connect with the host. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22VME: Correct read/write alignment algorithmMartyn Welch
commit f0342e66b397947ed8c3eef8c37b5ca2d5b1bb50 upstream. In order to ensure the correct width cycles on the VME bus, the VME bridge drivers implement an algorithm to utilise the largest possible width reads and writes whilst maintaining natural alignment constraints. The algorithm currently looks at the start address rather than the current read/write address when determining whether a 16-bit width cycle is required to get to 32-bit alignment. This results in incorrect alignment, Reported-by: Jim Strouth <james.strouth@ge.com> Tested-by: Jim Strouth <james.strouth@ge.com> Signed-off-by: Martyn Welch <martyn.welch@ge.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22mei: don't unset read cb ptr on resetAlexander Usyskin
commit 5cb906c7035f03a3a44fecece9d3ff8fcc75d6e0 upstream. Don't set read callback to NULL during reset as this leads to memory leak of both cb and its buffer. The memory is correctly freed during mei_release. The memory leak is detectable by kmemleak if application has open read call while system is going through suspend/resume. unreferenced object 0xecead780 (size 64): comm "AsyncTask #1", pid 1018, jiffies 4294949621 (age 152.440s) hex dump (first 32 bytes): 00 01 10 00 00 02 20 00 00 bf 30 f1 00 00 00 00 ...... ...0..... 00 00 00 00 00 00 00 00 36 01 00 00 00 70 da e2 ........6....p.. backtrace: [<c1a60aec>] kmemleak_alloc+0x3c/0xa0 [<c131ed56>] kmem_cache_alloc_trace+0xc6/0x190 [<c16243c9>] mei_io_cb_init+0x29/0x50 [<c1625722>] mei_cl_read_start+0x102/0x360 [<c16268f3>] mei_read+0x103/0x4e0 [<c1324b09>] vfs_read+0x89/0x160 [<c1324d5f>] SyS_read+0x4f/0x80 [<c1a7b318>] syscall_call+0x7/0xb [<ffffffff>] 0xffffffff unreferenced object 0xe2da7000 (size 512): comm "AsyncTask #1", pid 1018, jiffies 4294949621 (age 152.440s) hex dump (first 32 bytes): 00 6c da e2 7c 00 00 00 00 00 00 00 c0 eb 0c 59 .l..|..........Y 1b 00 00 00 01 00 00 00 02 10 00 00 01 00 00 00 ................ backtrace: [<c1a60aec>] kmemleak_alloc+0x3c/0xa0 [<c131f127>] __kmalloc+0xe7/0x1d0 [<c162447e>] mei_io_cb_alloc_resp_buf+0x2e/0x60 [<c162574c>] mei_cl_read_start+0x12c/0x360 [<c16268f3>] mei_read+0x103/0x4e0 [<c1324b09>] vfs_read+0x89/0x160 [<c1324d5f>] SyS_read+0x4f/0x80 [<c1a7b318>] syscall_call+0x7/0xb [<ffffffff>] 0xffffffff Signed-off-by: Alexander Usyskin <alexander.usyskin@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22mei: clear write cb from waiting list on resetAlexander Usyskin
commit 30c54df7cb9b15b222529a028390b9c9582dd65e upstream. Clear write callbacks sitting in write_waiting list on reset. Otherwise these callbacks are left dangling and cause memory leak. Signed-off-by: Alexander Usyskin <alexander.usyskin@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22ALSA: hda - Fix mic capture on Sony VAIO Pro 11Takashi Iwai
commit f88abaa0d0dc0d1f1a9ae21f8e822918e5aadfdf upstream. The very same fixup is needed to make the mic on Sony VAIO Pro 11 working as well as VAIO Pro 13 model. Reported-and-tested-by: Hendrik-Jan Heins <hjheins@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22ftrace/x86: Use breakpoints for converting function graph callerSteven Rostedt (Red Hat)
commit 87fbb2ac6073a7039303517546a76074feb14c84 upstream. When the conversion was made to remove stop machine and use the breakpoint logic instead, the modification of the function graph caller is still done directly as though it was being done under stop machine. As it is not converted via stop machine anymore, there is a possibility that the code could be layed across cache lines and if another CPU is accessing that function graph call when it is being updated, it could cause a General Protection Fault. Convert the update of the function graph caller to use the breakpoint method as well. Cc: H. Peter Anvin <hpa@zytor.com> Fixes: 08d636b6d4fb "ftrace/x86: Have arch x86_64 use breakpoints instead of stop machine" Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22x86, smap: smap_violation() is bogus if CONFIG_X86_SMAP is offH. Peter Anvin
commit 4640c7ee9b8953237d05a61ea3ea93981d1bc961 upstream. If CONFIG_X86_SMAP is disabled, smap_violation() tests for conditions which are incorrect (as the AC flag doesn't matter), causing spurious faults. The dynamic disabling of SMAP (nosmap on the command line) is fine because it disables X86_FEATURE_SMAP, therefore causing the static_cpu_has() to return false. Found by Fengguang Wu's test system. [ v3: move all predicates into smap_violation() ] [ v2: use IS_ENABLED() instead of #ifdef ] Reported-by: Fengguang Wu <fengguang.wu@intel.com> Link: http://lkml.kernel.org/r/20140213124550.GA30497@localhost Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22x86, smap: Don't enable SMAP if CONFIG_X86_SMAP is disabledH. Peter Anvin
commit 03bbd596ac04fef47ce93a730b8f086d797c3021 upstream. If SMAP support is not compiled into the kernel, don't enable SMAP in CR4 -- in fact, we should clear it, because the kernel doesn't contain the proper STAC/CLAC instructions for SMAP support. Found by Fengguang Wu's test system. Reported-by: Fengguang Wu <fengguang.wu@intel.com> Link: http://lkml.kernel.org/r/20140213124550.GA30497@localhost Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22iio: adis16400: Set timestamp as the last element in chan_specMarcus Folkesson
commit c76782d151dab7ecfdcdf9a01561c2d61d9b490f upstream. This is necessary since timestamp is calculated as the last element in iio_compute_scan_bytes(). Without this fix any userspace code reading the layout of the buffer via sysfs will incorrectly interpret the data leading some nasty corruption. Signed-off-by: Marcus Folkesson <marcus.folkesson@gmail.com> Acked-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22staging:iio:ad799x fix error_free_irq which was freeing an irq that may not ↵Hartmut Knaack
have been requested commit 38408d056188be29a6c4e17f3703c796551bb330 upstream. Only free an IRQ in error_free_irq, if it has been requested previously. Signed-off-by: Hartmut Knaack <knaack.h@gmx.de> Acked-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22staging: comedi: adv_pci1710: fix analog output readback valueH Hartley Sweeten
commit 1e85c1ea1ff2a60659e790ef8ec76c7339445841 upstream. The last value written to a analog output channel is cached in the private data of this driver for readback. Currently, the wrong value is cached in the (*insn_write) functions. The current code stores the data[n] value for readback afer the loop has written all the values. At this time 'n' points past the end of the data array. Fix the functions by using a local variable to hold the data being written to the analog output channel. This variable is then used after the loop is complete to store the readback value. The current value is retrieved before the loop in case no values are actually written.. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Reviewed-by: Ian Abbott <abbotti@mev.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22usb: qcserial: add Netgear Aircard 340UBjørn Mork
commit f948dcf9e9973c05d957bc65b3185682f45feda3 upstream. This device was mentioned in an OpenWRT forum. Seems to have a "standard" Sierra Wireless ifnumber to function layout: 0: qcdm 2: nmea 3: modem 8: qmi 9: storage Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22vt: Fix secure clear screenPetr Písař
commit 0930b0950a8996aa88b0d2ba4bb2bab27cc36bc7 upstream. \E[3J console code (secure clear screen) needs to update_screen(vc) in order to write-through blanks into off-screen video memory. This has been removed accidentally in 3.6 by: commit 81732c3b2fede049a692e58a7ceabb6d18ffb18c Author: Jean-François Moine <moinejf@free.fr> Date: Thu Sep 6 19:24:13 2012 +0200 tty vt: Fix line garbage in virtual console on command line edition Signed-off-by: Petr Písař <petr.pisar@atlas.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22drm/radeon: fix UVD IRQ support on SIChristian König
commit b927e1c20462c1ad9caf4c4fa3a30e838a2d4037 upstream. Otherwise decoding isn't really useable. bug: https://bugs.freedesktop.org/show_bug.cgi?id=71448 Signed-off-by: Christian König <christian.koenig@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22drm/radeon: fix UVD IRQ support on 7xxAlex Deucher
commit 858a41c853cef2cb01de34dae334c19c1c15b237 upstream. Otherwise decoding isn't really useable. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22tty: n_gsm: Fix for modems with brk in modem status controlLars Poeschel
commit 3ac06b905655b3ef2fd2196bab36e4587e1e4e4f upstream. 3GPP TS 07.10 states in section 5.4.6.3.7: "The length byte contains the value 2 or 3 ... depending on the break signal." The break byte is optional and if it is sent, the length is 3. In fact the driver was not able to work with modems that send this break byte in their modem status control message. If the modem just sends the break byte if it is really set, then weird things might happen. The code for deconding the modem status to the internal linux presentation in gsm_process_modem has already a big comment about this 2 or 3 byte length thing and it is already able to decode the brk, but the code calling the gsm_process_modem function in gsm_control_modem does not encode it and hand it over the right way. This patch fixes this. Without this fix if the modem sends the brk byte in it's modem status control message the driver will hang when opening a muxed channel. Signed-off-by: Lars Poeschel <poeschel@lemonage.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22lockd: send correct lock when granting a delayed lock.NeilBrown
commit 2ec197db1a56c9269d75e965f14c344b58b2a4f6 upstream. If an NFS client attempts to get a lock (using NLM) and the lock is not available, the server will remember the request and when the lock becomes available it will send a GRANT request to the client to provide the lock. If the client already held an adjacent lock, the GRANT callback will report the union of the existing and new locks, which can confuse the client. This happens because __posix_lock_file (called by vfs_lock_file) updates the passed-in file_lock structure when adjacent or over-lapping locks are found. To avoid this problem we take a copy of the two fields that can be changed (fl_start and fl_end) before the call and restore them afterwards. An alternate would be to allocate a 'struct file_lock', initialise it, use locks_copy_lock() to take a copy, then locks_release_private() after the vfs_lock_file() call. But that is a lot more work. Reported-by: Olaf Kirch <okir@suse.com> Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> -- v1 had a couple of issues (large on-stack struct and didn't really work properly). This version is much better tested. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2014-02-22hwmon: (ntc_thermistor) Avoid math overflowDoug Anderson
commit d3d89c468ceebbcf9423d1a3d66c5bf91f569570 upstream. The ntc thermistor code was doing math whose temporary result might have overflowed 32-bits. We need some casts in there to make it safe. In one example I found: - pullup_uV: 1800000 - result of iio_read_channel_raw: 3226 - 1800000 * 3226 => 0x15a1cbc80 Signed-off-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22raw: test against runtime value of max_raw_minorsPaul Bolle
commit 5bbb2ae3d6f896f8d2082d1eceb6131c2420b7cf upstream. bind_get() checks the device number it is called with. It uses MAX_RAW_MINORS for the upper bound. But MAX_RAW_MINORS is set at compile time while the actual number of raw devices can be set at runtime. This means the test can either be too strict or too lenient. And if the test ends up being too lenient bind_get() might try to access memory beyond what was allocated for "raw_devices". So check against the runtime value (max_raw_minors) in this function. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22of: fix PCI bus match for PCIe slotsKleber Sacilotto de Souza
commit 14e2abb732e485ee57d9d5b2cb8884652238e5c1 upstream. On IBM pseries systems the device_type device-tree property of a PCIe bridge contains the string "pciex". The of_bus_pci_match() function was looking only for "pci" on this property, so in such cases the bus matching code was falling back to the default bus, causing problems on functions that should be using "assigned-addresses" for region address translation. This patch fixes the problem by also looking for "pciex" on the PCI bus match function. v2: added comment Signed-off-by: Kleber Sacilotto de Souza <klebers@linux.vnet.ibm.com> Acked-by: Grant Likely <grant.likely@linaro.org> Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22iwlwifi: mvm: BT Coex - disable BT when TXing probe request in scanEmmanuel Grumbach
commit 8e2a866ef214af4e104ec8d593e3269d8fe66d19 upstream. Not doing so will let BT kill our probe requests leading to failures in scan. Reviewed-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22iwlwifi: mvm: print the version of the firmware when it assertsEmmanuel Grumbach
commit b900a87b2eb90c0b9586496c82a323a1b8832d73 upstream. This can be useful to be able to spot the firmware version from the error reports without needing to fetch it from another place. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Reviewed-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22iwlwifi: mvm: don't allow A band if SKU forbids itEmmanuel Grumbach
commit c512865446e6dd5b6e91e81187e75b734ad7cfc7 upstream. The driver wasn't reading the NVM properly. While this didn't lead to any issue until now, it seems that there is an old version of the NVM in the wild. In this version, the A band channels appear to be valid but the SKU capabilities (another field of the NVM) says that A band isn't supported at all. With this specific version of the NVM, the driver would think that A band is supported while the HW / firmware don't. This leads to asserts. Reviewed-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22spi: Fix crash with double message finalisation on error handlingGeert Uytterhoeven
commit 1f802f8249a0da536877842c43c7204064c4de8b upstream. This reverts commit e120cc0dcf2880a4c5c0a6cb27b655600a1cfa1d. It causes a NULL pointer dereference with drivers using the generic spi_transfer_one_message(), which always calls spi_finalize_current_message(), which zeroes master->cur_msg. Drivers implementing transfer_one_message() theirselves must always call spi_finalize_current_message(), even if the transfer failed: * @transfer_one_message: the subsystem calls the driver to transfer a single * message while queuing transfers that arrive in the meantime. When the * driver is finished with this message, it must call * spi_finalize_current_message() so the subsystem can issue the next * transfer Signed-off-by: Geert Uytterhoeven <geert+renesas@linux-m68k.org> Signed-off-by: Mark Brown <broonie@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
