2014-01-09Linux 3.10.26v3.10.26Greg Kroah-Hartman
2014-01-09sh: add EXPORT_SYMBOL(min_low_pfn) and EXPORT_SYMBOL(max_low_pfn) to ↵Nobuhiro Iwamatsu
sh_ksyms_32.c commit ad70b029d2c678386384bd72c7fa2705c449b518 upstream. Min_low_pfn and max_low_pfn were used in pfn_valid macro if defined CONFIG_FLATMEM. When the functions that use the pfn_valid is used in driver module, max_low_pfn and min_low_pfn is to undefined, and fail to build. ERROR: "min_low_pfn" [drivers/block/aoe/aoe.ko] undefined! ERROR: "max_low_pfn" [drivers/block/aoe/aoe.ko] undefined! make[2]: *** [__modpost] Error 1 make[1]: *** [modules] Error 2 This patch fix this problem. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Cc: Kuninori Morimoto <kuninori.morimoto.gx@gmail.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09ext4: fix bigalloc regressionEric Whitney
commit d0abafac8c9162f39c4f6b2f8141b772a09b3770 upstream. Commit f5a44db5d2 introduced a regression on filesystems created with the bigalloc feature (cluster size > blocksize). It causes xfstests generic/006 and /013 to fail with an unexpected JBD2 failure and transaction abort that leaves the test file system in a read only state. Other xfstests run on bigalloc file systems are likely to fail as well. The cause is the accidental use of a cluster mask where a cluster offset was needed in ext4_ext_map_blocks(). Signed-off-by: Eric Whitney <enwlinux@gmail.com> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09arm64: Use Normal NonCacheable memory for writecombineCatalin Marinas
commit 4f00130b70e5eee813cc7bc298e0f3fdf79673cc upstream. This provides better performance compared to Device GRE and also allows unaligned accesses. Such memory is intended to be used with standard RAM (e.g. framebuffers) and not I/O. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09arm64: Do not flush the D-cache for anonymous pagesCatalin Marinas
commit 7249b79f6b4cc3c2aa9138dca52e535a4c789107 upstream. The D-cache on AArch64 is VIPT non-aliasing, so there is no need to flush it for anonymous pages. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Reported-by: Will Deacon <will.deacon@arm.com> Acked-by: Will Deacon <will.deacon@arm.com> Cc: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09arm64: Avoid cache flushing in flush_dcache_page()Catalin Marinas
commit b5b6c9e9149d8a7c3f1d7b9d0c046c6184e1dd17 upstream. The flush_dcache_page() function is called when the kernel modified a page cache page. Since the D-cache on AArch64 does not have aliases this function can simply mark the page as dirty for later flushing via set_pte_at()/__sync_icache_dcache() if the page is executable (to ensure the I-D cache coherency). Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Reported-by: Will Deacon <will.deacon@arm.com> Acked-by: Will Deacon <will.deacon@arm.com> Cc: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09ARM: KVM: arch_timers: zero CNTVOFF upon return to hostMark Rutland
commit f793c23ebbe5afd1cabf4a42a3a297022213756f upstream. To use the virtual counters from the host, we need to ensure that CNTVOFF doesn't change unexpectedly. When we change to a guest, we replace the host's CNTVOFF, but we don't restore it when returning to the host. As the host sets CNTVOFF to zero, and never changes it, we can simply zero CNTVOFF when returning to the host. This patch adds said zeroing to the return to host path. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Christoffer Dall <cdall@cs.columbia.edu> Cc: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09ARM: hyp: initialize CNTVOFF to zeroMarc Zyngier
commit 0af0b189abf73d232af782df2f999235cd2fed7f upstream. In order to be able to use the virtual counter in a safe way, make sure it is initialized to zero before dropping to SVC. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Mark Rutland <mark.rutland@arm.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: Dave Martin <dave.martin@linaro.org> Cc: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09clocksource: arch_timer: use virtual countersMark Rutland
commit 0d651e4e65e96989f72236bf83bd4c6e55eb6ce4 upstream. Switching between reading the virtual or physical counters is problematic, as some core code wants a view of time before we're fully set up. Using a function pointer and switching the source after the first read can make time appear to go backwards, and having a check in the read function is an unfortunate block on what we want to be a fast path. Instead, this patch makes us always use the virtual counters. If we're a guest, or don't have hyp mode, we'll use the virtual timers, and as such don't care about CNTVOFF as long as it doesn't change in such a way as to make time appear to travel backwards. As the guest will use the virtual timers, a (potential) KVM host must use the physical timers (which can wake up the host even if they fire while a guest is executing), and hence a host must have CNTVOFF set to zero so as to have a consistent view of time between the physical timers and virtual counters. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09arm64: Remove unused cpu_name ascii in arch/arm64/mm/proc.SCatalin Marinas
commit f3a1d7d53dccf51959aec16b574617cc6bfeca09 upstream. This string has been moved to arch/arm64/kernel/cputable.c. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09arm64: dts: Reserve the memory used for secondary CPU release addressCatalin Marinas
commit df503ba7f653c590b475ab80bde788edf5af70d5 upstream. With the spin-table SMP booting method, secondary CPUs poll a location passed in the DT. The foundation-v8.dts file doesn't have this memory reserved and there is a risk of Linux using it before secondary CPUs are started. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09arm64: check for number of arguments in syscall_get/set_arguments()AKASHI Takahiro
commit 7b22c03536a539142f931815528d55df455ffe2d upstream. In ftrace_syscall_enter(), syscall_get_arguments(..., 0, n, ...) if (i == 0) { <handle orig_x0> ...; n--;} memcpy(..., n * sizeof(args[0])); If 'number of arguments(n)' is zero and 'argument index(i)' is also zero in syscall_get_arguments(), none of arguments should be copied by memcpy(). Otherwise 'n--' can be a big positive number and unexpected amount of data will be copied. Tracing system calls which take no argument, say sync(void), may hit this case and eventually make the system corrupted. This patch fixes the issue both in syscall_get_arguments() and syscall_set_arguments(). Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09arm64: fix possible invalid FPSIMD initialization stateJiang Liu
commit 6db83cea1c975b9a102e17def7d2795814e1ae2b upstream. If context switching happens during executing fpsimd_flush_thread(), stale value in FPSIMD registers will be saved into current thread's fpsimd_state by fpsimd_thread_switch(). That may cause invalid initialization state for the new process, so disable preemption when executing fpsimd_flush_thread(). Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Cc: Jiang Liu <liuj97@gmail.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09arm64: Change kernel stack size to 16KFeng Kan
commit 845ad05ec31e0f3872a321e10dbeaf872022632c upstream. Written by Catalin Marinas, tested by APM on storm platform. This is needed because of the failures encountered when running SpecWeb benchmark test. Signed-off-by: Feng Kan <fkan@apm.com> Acked-by: Kumar Sankaran <ksankaran@apm.com> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09arm64: virt: ensure visibility of __boot_cpu_modeMark Rutland
commit 82b2f495fba338d1e3098dde1df54944a9c19751 upstream. Secondary CPUs write to __boot_cpu_mode with caches disabled, and thus a cached value of __boot_cpu_mode may be incoherent with that in memory. This could lead to a failure to detect mismatched boot modes. This patch adds flushing to ensure that writes by secondaries to __boot_cpu_mode are made visible before we test against it. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Cc: Marc Zyngier <marc.zyngier@arm.com> Cc: Christoffer Dall <cdall@cs.columbia.edu> Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09arm64: Only enable local interrupts after the CPU is marked onlineCatalin Marinas
commit 53ae3acd4390ffeecb3a11dbd5be347b5a3d98f2 upstream. There is a slight chance that (timer) interrupts are triggered before a secondary CPU has been marked online with implications on softirq thread affinity. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Reported-by: Kirill Tkhai <tkhai@yandex.ru> Cc: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09rbd: fix error handling from rbd_snap_name()Josh Durgin
commit da6a6b63978d45f9ae582d1f362f182012da3a22 upstream. rbd_snap_name() calls rbd_dev_v{1,2}_snap_name() depending on the format of the image. The format 1 version returns NULL on error, which is handled by the caller. The format 2 version returns an ERR_PTR, which the caller of rbd_snap_name() does not expect. Fortunately this is unlikely to occur in practice because rbd_snap_id_by_name() is called before rbd_snap_name(). This would hit similar errors to rbd_snap_name() (like the snapshot not existing) and return early, so rbd_snap_name() would not hit an error unless the snapshot was removed between the two calls or memory was exhausted. Use an ERR_PTR in rbd_dev_v1_snap_name() so that the specific error can be propagated, and it is consistent with rbd_dev_v2_snap_name(). Handle the ERR_PTR in the only rbd_snap_name() caller. Suggested-by: Alex Elder <alex.elder@linaro.org> Signed-off-by: Josh Durgin <josh.durgin@inktank.com> Reviewed-by: Alex Elder <elder@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09rbd: ignore unmapped snapshots that no longer existJosh Durgin
commit efadc98aab674153709cc357ba565f04e3164fcd upstream. This prevents erroring out while adding a device when a snapshot unrelated to the current mapping is deleted between reading the snapshot context and reading the snapshot names. If the mapped snapshot name is not found an error still occurs as usual. Signed-off-by: Josh Durgin <josh.durgin@inktank.com> Reviewed-by: Alex Elder <elder@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09rbd: fix use-after free of rbd_dev->diskJosh Durgin
commit 9875201e10496612080e7d164acc8f625c18725c upstream. Removing a device deallocates the disk, unschedules the watch, and finally cleans up the rbd_dev structure. rbd_dev_refresh(), called from the watch callback, updates the disk size and rbd_dev structure. With no locking between them, rbd_dev_refresh() may use the device or rbd_dev after they've been freed. To fix this, check whether RBD_DEV_FLAG_REMOVING is set before updating the disk size in rbd_dev_refresh(). In order to prevent a race where rbd_dev_refresh() is already revalidating the disk when rbd_remove() is called, move the call to rbd_bus_del_dev() after the watch is unregistered and all notifies are complete. It's safe to defer deleting this structure because no new requests can be submitted once the RBD_DEV_FLAG_REMOVING is set, since the device cannot be opened. Fixes: http://tracker.ceph.com/issues/5636 Signed-off-by: Josh Durgin <josh.durgin@inktank.com> Reviewed-by: Alex Elder <elder@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09rbd: make rbd_obj_notify_ack() synchronousJosh Durgin
commit 20e0af67ce88c657d0601977b9941a2256afbdaa upstream. The only user of rbd_obj_notify_ack() is rbd_watch_cb(). It used asynchronously with no tracking of when the notify ack completes, so it may still be in progress when the osd_client is shut down. This results in a BUG() since the osd client assumes no requests are in flight when it stops. Since all notifies are flushed before the osd_client is stopped, waiting for the notify ack to complete before returning from the watch callback ensures there are no notify acks in flight during shutdown. Rename rbd_obj_notify_ack() to rbd_obj_notify_ack_sync() to reflect its new synchronous nature. Signed-off-by: Josh Durgin <josh.durgin@inktank.com> Reviewed-by: Alex Elder <elder@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09rbd: complete notifies before cleaning up osd_client and rbd_devJosh Durgin
commit 9abc59908e0c5f983aaa91150da32d5b62cf60b7 upstream. To ensure rbd_dev is not used after it's released, flush all pending notify callbacks before calling rbd_dev_image_release(). No new notifies can be added to the queue at this point because the watch has already be unregistered with the osd_client. Signed-off-by: Josh Durgin <josh.durgin@inktank.com> Reviewed-by: Alex Elder <elder@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09libceph: add function to ensure notifies are completeJosh Durgin
commit dd935f44a40f8fb02aff2cc0df2269c92422df1c upstream. Without a way to flush the osd client's notify workqueue, a watch event that is unregistered could continue receiving callbacks indefinitely. Unregistering the event simply means no new notifies are added to the queue, but there may still be events in the queue that will call the watch callback for the event. If the queue is flushed after the event is unregistered, the caller can be sure no more watch callbacks will occur for the canceled watch. Signed-off-by: Josh Durgin <josh.durgin@inktank.com> Reviewed-by: Sage Weil <sage@inktank.com> Reviewed-by: Alex Elder <elder@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09rbd: fix null dereference in doutJosh Durgin
commit c35455791c1131e7ccbf56ea6fbdd562401c2ce2 upstream. The order parameter is sometimes NULL in _rbd_dev_v2_snap_size(), but the dout() always derefences it. Move this to another dout() protected by a check that order is non-NULL. Signed-off-by: Josh Durgin <josh.durgin@inktank.com> Reviewed-by: Sage Weil <sage@inktank.com> Reviewed-by: Alex Elder <alex.elder@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09rbd: fix buffer size for writes to images with snapshotsJosh Durgin
commit 03507db631c94a48e316c7f638ffb2991544d617 upstream. rbd_osd_req_create() needs to know the snapshot context size to create a buffer large enough to send it with the message front. It gets this from the img_request, which was not set for the obj_request yet. This resulted in trying to write past the end of the front payload, hitting this BUG: libceph: BUG_ON(p > msg->front.iov_base + msg->front.iov_len); Fix this by associating the obj_request with its img_request immediately after it's created, before the osd request is created. Fixes: http://tracker.ceph.com/issues/5760 Suggested-by: Alex Elder <alex.elder@linaro.org> Signed-off-by: Josh Durgin <josh.durgin@inktank.com> Reviewed-by: Alex Elder <alex.elder@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09ceph: allow sync_read/write return partial successed size of read/write.majianpeng
commit ee7289bfadda5f4ef60884547ebc9989c8fb314a upstream. For sync_read/write, it may do multi stripe operations.If one of those met erro, we return the former successed size rather than a error value. There is a exception for write-operation met -EOLDSNAPC.If this occur,we retry the whole write again. Signed-off-by: Jianpeng Ma <majianpeng@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09ceph: fix bugs about handling short-read for sync read mode.majianpeng
commit 02ae66d8b229708fd94b764f6c17ead1c7741fcf upstream. cephfs . show_layout >layyout.data_pool: 0 >layout.object_size: 4194304 >layout.stripe_unit: 4194304 >layout.stripe_count: 1 TestA: >dd if=/dev/urandom of=test bs=1M count=2 oflag=direct >dd if=/dev/urandom of=test bs=1M count=2 seek=4 oflag=direct >dd if=test of=/dev/null bs=6M count=1 iflag=direct The messages from func striped_read are: ceph: file.c:350 : striped_read 0~6291456 (read 0) got 2097152 HITSTRIPE SHORT ceph: file.c:350 : striped_read 2097152~4194304 (read 2097152) got 0 HITSTRIPE SHORT ceph: file.c:381 : zero tail 4194304 ceph: file.c:390 : striped_read returns 6291456 The hole of file is from 2M--4M.But actualy it zero the last 4M include the last 2M area which isn't a hole. Using this patch, the messages are: ceph: file.c:350 : striped_read 0~6291456 (read 0) got 2097152 HITSTRIPE SHORT ceph: file.c:358 : zero gap 2097152 to 4194304 ceph: file.c:350 : striped_read 4194304~2097152 (read 4194304) got 2097152 ceph: file.c:384 : striped_read returns 6291456 TestB: >echo majianpeng > test >dd if=test of=/dev/null bs=2M count=1 iflag=direct The messages are: ceph: file.c:350 : striped_read 0~6291456 (read 0) got 11 HITSTRIPE SHORT ceph: file.c:350 : striped_read 11~6291445 (read 11) got 0 HITSTRIPE SHORT ceph: file.c:390 : striped_read returns 11 For this case,it did once more striped_read.It's no meaningless. Using this patch, the message are: ceph: file.c:350 : striped_read 0~6291456 (read 0) got 11 HITSTRIPE SHORT ceph: file.c:384 : striped_read returns 11 Big thanks to Yan Zheng for the patch. Reviewed-by: Yan, Zheng <zheng.z.yan@intel.com> Signed-off-by: Jianpeng Ma <majianpeng@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09libceph: create_singlethread_workqueue() doesn't return ERR_PTRsDan Carpenter
commit dbcae088fa660086bde6e10d63bb3c9264832d85 upstream. create_singlethread_workqueue() returns NULL on error, and it doesn't return ERR_PTRs. I tweaked the error handling a little to be consistent with earlier in the function. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Reviewed-by: Sage Weil <sage@inktank.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09libceph: potential NULL dereference in ceph_osdc_handle_map()Dan Carpenter
commit b72e19b9225d4297a18715b0998093d843d170fa upstream. There are two places where we read "nr_maps" if both of them are set to zero then we would hit a NULL dereference here. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Reviewed-by: Sage Weil <sage@inktank.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09libceph: fix error handling in handle_reply()Dan Carpenter
commit 1874119664dafda3ef2ed9b51b4759a9540d4a1a upstream. We've tried to fix the error paths in this function before, but there is still a hidden goto in the ceph_decode_need() macro which goes to the wrong place. We need to release the "req" and unlock a mutex before returning. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Reviewed-by: Sage Weil <sage@inktank.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09ceph: Add check returned value on func ceph_calc_ceph_pg.majianpeng
commit 2fbcbff1d6b9243ef71c64a8ab993bc3c7bb7af1 upstream. Func ceph_calc_ceph_pg maybe failed.So add check for returned value. Signed-off-by: Jianpeng Ma <majianpeng@gmail.com> Reviewed-by: Sage Weil <sage@inktank.com> Signed-off-by: Sage Weil <sage@inktank.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09ceph: cleanup types in striped_read()Dan Carpenter
commit 688bac461ba3e9d221a879ab40b687f5d7b5b19c upstream. We pass in a u64 value for "len" and then immediately truncate away the upper 32 bits. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Reviewed-by: Sage Weil <sage@inktank.com> Reviewed-by: Alex Elder <alex.elder@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09ceph: fix null pointer dereferenceNathaniel Yazdani
commit c338c07c51e3106711fad5eb599e375eadb6855d upstream. When register_session() is given an out-of-range argument for mds, ceph_mdsmap_get_addr() will return a null pointer, which would be given to ceph_con_open() & be dereferenced, causing a kernel oops. This fixes bug #4685 in the Ceph bug tracker <http://tracker.ceph.com/issues/4685>. Signed-off-by: Nathaniel Yazdani <n1ght.4nd.d4y@gmail.com> Reviewed-by: Sage Weil <sage@inktank.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09libceph: call r_unsafe_callback when unsafe reply is receivedYan, Zheng
commit 61c5d6bf7074ee32d014dcdf7698dc8c59eb712d upstream. We can't use !req->r_sent to check if OSD request is sent for the first time, this is because __cancel_request() zeros req->r_sent when OSD map changes. Rather than adding a new variable to struct ceph_osd_request to indicate if it's sent for the first time, We can call the unsafe callback only when unsafe OSD reply is received. If OSD's first reply is safe, just skip calling the unsafe callback. The purpose of unsafe callback is adding unsafe request to a list, so that fsync(2) can wait for the safe reply. fsync(2) doesn't need to wait for a write(2) that hasn't returned yet. So it's OK to add request to the unsafe list when the first OSD reply is received. (ceph_sync_write() returns after receiving the first OSD reply) Signed-off-by: Yan, Zheng <zheng.z.yan@intel.com> Reviewed-by: Sage Weil <sage@inktank.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09ceph: avoid accessing invalid memorySasha Levin
commit 5446429630257f4723829409337a26c076907d5d upstream. when mounting ceph with a dev name that starts with a slash, ceph would attempt to access the character before that slash. Since we don't actually own that byte of memory, we would trigger an invalid access: [ 43.499934] BUG: unable to handle kernel paging request at ffff880fa3a97fff [ 43.500984] IP: [<ffffffff818f3884>] parse_mount_options+0x1a4/0x300 [ 43.501491] PGD 743b067 PUD 10283c4067 PMD 10282a6067 PTE 8000000fa3a97060 [ 43.502301] Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC [ 43.503006] Dumping ftrace buffer: [ 43.503596] (ftrace buffer empty) [ 43.504046] CPU: 0 PID: 10879 Comm: mount Tainted: G W 3.10.0-sasha #1129 [ 43.504851] task: ffff880fa625b000 ti: ffff880fa3412000 task.ti: ffff880fa3412000 [ 43.505608] RIP: 0010:[<ffffffff818f3884>] [<ffffffff818f3884>] parse_mount_options$ [ 43.506552] RSP: 0018:ffff880fa3413d08 EFLAGS: 00010286 [ 43.507133] RAX: ffff880fa3a98000 RBX: ffff880fa3a98000 RCX: 0000000000000000 [ 43.507893] RDX: ffff880fa3a98001 RSI: 000000000000002f RDI: ffff880fa3a98000 [ 43.508610] RBP: ffff880fa3413d58 R08: 0000000000001f99 R09: ffff880fa3fe64c0 [ 43.509426] R10: ffff880fa3413d98 R11: ffff880fa38710d8 R12: ffff880fa3413da0 [ 43.509792] R13: ffff880fa3a97fff R14: 0000000000000000 R15: ffff880fa3413d90 [ 43.509792] FS: 00007fa9c48757e0(0000) GS:ffff880fd2600000(0000) knlGS:000000000000$ [ 43.509792] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [ 43.509792] CR2: ffff880fa3a97fff CR3: 0000000fa3bb9000 CR4: 00000000000006b0 [ 43.509792] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 43.509792] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 43.509792] Stack: [ 43.509792] 0000e5180000000e ffffffff85ca1900 ffff880fa38710d8 ffff880fa3413d98 [ 43.509792] 0000000000000120 0000000000000000 ffff880fa3a98000 0000000000000000 [ 43.509792] ffffffff85cf32a0 0000000000000000 ffff880fa3413dc8 ffffffff818f3c72 [ 43.509792] Call Trace: [ 43.509792] [<ffffffff818f3c72>] ceph_mount+0xa2/0x390 [ 43.509792] [<ffffffff81226314>] ? pcpu_alloc+0x334/0x3c0 [ 43.509792] [<ffffffff81282f8d>] mount_fs+0x8d/0x1a0 [ 43.509792] [<ffffffff812263d0>] ? __alloc_percpu+0x10/0x20 [ 43.509792] [<ffffffff8129f799>] vfs_kern_mount+0x79/0x100 [ 43.509792] [<ffffffff812a224d>] do_new_mount+0xcd/0x1c0 [ 43.509792] [<ffffffff812a2e8d>] do_mount+0x15d/0x210 [ 43.509792] [<ffffffff81220e55>] ? strndup_user+0x45/0x60 [ 43.509792] [<ffffffff812a2fdd>] SyS_mount+0x9d/0xe0 [ 43.509792] [<ffffffff83fd816c>] tracesys+0xdd/0xe2 [ 43.509792] Code: 4c 8b 5d c0 74 0a 48 8d 50 01 49 89 14 24 eb 17 31 c0 48 83 c9 ff $ [ 43.509792] RIP [<ffffffff818f3884>] parse_mount_options+0x1a4/0x300 [ 43.509792] RSP <ffff880fa3413d08> [ 43.509792] CR2: ffff880fa3a97fff [ 43.509792] ---[ end trace 22469cd81e93af51 ]--- Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Reviewed-by: Sage Weil <sage@inktan.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09ceph: Free mdsc if alloc mdsc->mdsmap failed.majianpeng
commit fb3101b6f0db9ae3f35dc8e6ec908d0af8cdf12e upstream. Signed-off-by: Jianpeng Ma <majianpeng@gmail.com> Reviewed-by: Sage Weil <sage@inktank.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09rbd: fix a couple warningsSage Weil
commit e976cad0f0dbe5440a4ca38e29e1f932d9319125 upstream. gcc isn't quite smart enough and generates these warnings: drivers/block/rbd.c: In function 'rbd_img_request_fill': drivers/block/rbd.c:1266:22: warning: 'bio_list' may be used uninitialized in this function [-Wmaybe-uninitialized] drivers/block/rbd.c:2186:14: note: 'bio_list' was declared here drivers/block/rbd.c:2247:10: warning: 'pages' may be used uninitialized in this function [-Wmaybe-uninitialized] even though they are initialized for their respective code paths. Signed-off-by: Sage Weil <sage@inktank.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09libceph: fix truncate size calculationYan, Zheng
commit ccca4e37b1a912da3db68aee826557ea66145273 upstream. check the "not truncated yet" case Signed-off-by: Yan, Zheng <zheng.z.yan@intel.com> Reviewed-by: Sage Weil <sage@inktank.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09libceph: fix safe completionYan, Zheng
commit eb845ff13a44477f8a411baedbf11d678b9daf0a upstream. handle_reply() calls complete_request() only if the first OSD reply has ONDISK flag. Signed-off-by: Yan, Zheng <zheng.z.yan@intel.com> Reviewed-by: Sage Weil <sage@inktank.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09rbd: protect against concurrent unmapsAlex Elder
commit 82a442d239695a242c4d584464c9606322cd02aa upstream. Make sure two concurrent unmap operations on the same rbd device won't collide, by only proceeding with the removal and cleanup of a device if is not already underway. Signed-off-by: Alex Elder <elder@inktank.com> Reviewed-by: Josh Durgin <josh.durgin@inktank.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09rbd: set removing flag while holding list lockAlex Elder
commit 751cc0e3cfabdda87c4c21519253c6751e97a8d4 upstream. When unmapping a device, its id is supplied, and that is used to look up which rbd device should be unmapped. Looking up the device involves searching the rbd device list while holding a spinlock that protects access to that list. Currently all of this is done under protection of the control lock, but that protection is going away soon. To ensure the rbd_dev is still valid (still on the list) while setting its REMOVING flag, do so while still holding the list lock. To do so, get rid of __rbd_get_dev(), and open code what it did in the one place it was used. Signed-off-by: Alex Elder <elder@inktank.com> Reviewed-by: Josh Durgin <josh.durgin@inktank.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09rbd: flush dcache after zeroing page dataAlex Elder
commit e215605417b87732c6debf65da6d953016a1e5bc upstream. Neither zero_bio_chain() nor zero_pages() contains a call to flush caches after zeroing a portion of a page. This can cause problems on architectures that have caches that allow virtual address aliasing. This resolves: http://tracker.ceph.com/issues/4777 Signed-off-by: Alex Elder <elder@inktank.com> Reviewed-by: Josh Durgin <josh.durgin@inktank.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09libceph: add lingering request reference when registeredAlex Elder
commit 96e4dac66f69d28af2b736e723364efbbdf9fdee upstream. When an osd request is set to linger, the osd client holds onto the request so it can be re-submitted following certain osd map changes. The osd client holds a reference to the request until it is unregistered. This is used by rbd for watch requests. Currently, the reference is taken when the request is marked with the linger flag. This means that if an error occurs after that time but before the the request completes successfully, that reference is leaked. There's really no reason to take the reference until the request is registered in the the osd client's list of lingering requests, and that only happens when the lingering (watch) request completes successfully. So take that reference only when it gets registered following succesful completion, and drop it (as before) when the request gets unregistered. This avoids the reference problem on error in rbd. Rearrange ceph_osdc_unregister_linger_request() to avoid using the request pointer after it may have been freed. And hold an extra reference in kick_requests() while handling a linger request that has not yet been registered, to ensure it doesn't go away. This resolves: http://tracker.ceph.com/issues/3859 Signed-off-by: Alex Elder <elder@inktank.com> Reviewed-by: Josh Durgin <josh.durgin@inktank.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09ceph: improve error handling in ceph_mdsmap_decodeEmil Goode
commit c213b50b7dcbf06abcfbf1e4eee5b76586718bd9 upstream. This patch makes the following improvements to the error handling in the ceph_mdsmap_decode function: - Add a NULL check for return value from kcalloc - Make use of the variable err Signed-off-by: Emil Goode <emilgoode@gmail.com> Signed-off-by: Sage Weil <sage@inktank.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09clocksource: dw_apb_timer_of: Fix read_sched_clockDinh Nguyen
commit 85dc6ee1237c8a4a7742e6abab96a20389b7d682 upstream. The read_sched_clock should return the ~value because the clock is a countdown implementation. read_sched_clock() should be the same as __apbt_read_clocksource(). Signed-off-by: Dinh Nguyen <dinguyen@altera.com> Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09selinux: process labeled IPsec TCP SYN-ACK packets properly in ↵Paul Moore
selinux_ip_postroute() commit c0828e50485932b7e019df377a6b0a8d1ebd3080 upstream. Due to difficulty in arriving at the proper security label for TCP SYN-ACK packets in selinux_ip_postroute(), we need to check packets while/before they are undergoing XFRM transforms instead of waiting until afterwards so that we can determine the correct security label. Reported-by: Janak Desai <Janak.Desai@gtri.gatech.edu> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09selinux: look for IPsec labels on both inbound and outbound packetsPaul Moore
commit 817eff718dca4e54d5721211ddde0914428fbb7c upstream. Previously selinux_skb_peerlbl_sid() would only check for labeled IPsec security labels on inbound packets, this patch enables it to check both inbound and outbound traffic for labeled IPsec security labels. Reported-by: Janak Desai <Janak.Desai@gtri.gatech.edu> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09sh: always link in helper functions extracted from libgccGeert Uytterhoeven
commit 84ed8a99058e61567f495cc43118344261641c5f upstream. E.g. landisk_defconfig, which has CONFIG_NTFS_FS=m: ERROR: "__ashrdi3" [fs/ntfs/ntfs.ko] undefined! For "lib-y", if no symbols in a compilation unit are referenced by other units, the compilation unit will not be included in vmlinux. This breaks modules that do reference those symbols. Use "obj-y" instead to fix this. http://kisskb.ellerman.id.au/kisskb/buildresult/8838077/ This doesn't fix all cases. There are others, e.g. udivsi3. This is also not limited to sh, many architectures handle this in the same way. A simple solution is to unconditionally include all helper functions. A more complex solution is to make the choice of "lib-y" or "obj-y" depend on CONFIG_MODULES: obj-$(CONFIG_MODULES) += ... lib-y($CONFIG_MODULES) += ... Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Paul Mundt <lethal@linux-sh.org> Tested-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Reviewed-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09gpio: msm: Fix irq mask/unmask by writing bits instead of numbersStephen Boyd
commit 4cc629b7a20945ce35628179180329b6bc9e552b upstream. We should be writing bits here but instead we're writing the numbers that correspond to the bits we want to write. Fix it by wrapping the numbers in the BIT() macro. This fixes gpios acting as interrupts. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09gpio: twl4030: Fix regression for twl gpio LED outputRoger Quadros
commit f5837ec11f8cfa6d53ebc5806582771b2c9988c6 upstream. Commit 0b2aa8be introduced a regression that causes failure in setting LED GPO direction to OUT. This causes USB host probe failures for Beagleboard C4. platform usb_phy_gen_xceiv.2: Driver usb_phy_gen_xceiv requests probe deferral hsusb2_vcc: Failed to request enable GPIO510: -22 reg-fixed-voltage reg-fixed-voltage.0.auto: Failed to register regulator: -22 reg-fixed-voltage: probe of reg-fixed-voltage.0.auto failed with error -22 direction_out/direction_in must return 0 if the operation succeeded. Also, don't update direction flag and output data if twl4030_set_gpio_direction() failed inside twl_direction_out(); Signed-off-by: Roger Quadros <rogerq@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09jbd2: don't BUG but return ENOSPC if a handle runs out of spaceTheodore Ts'o
commit f6c07cad081ba222d63623d913aafba5586c1d2c upstream. If a handle runs out of space, we currently stop the kernel with a BUG in jbd2_journal_dirty_metadata(). This makes it hard to figure out what might be going on. So return an error of ENOSPC, so we can let the file system layer figure out what is going on, to make it more likely we can get useful debugging information). This should make it easier to debug problems such as the one which was reported by: https://bugzilla.kernel.org/show_bug.cgi?id=44731 The only two callers of this function are ext4_handle_dirty_metadata() and ocfs2_journal_dirty(). The ocfs2 function will trigger a BUG_ON(), which means there will be no change in behavior. The ext4 function will call ext4_error_inode() which will print the useful debugging information and then handle the situation using ext4's error handling mechanisms (i.e., which might mean halting the kernel or remounting the file system read-only). Also, since both file systems already call WARN_ON(), drop the WARN_ON from jbd2_journal_dirty_metadata() to avoid two stack traces from being displayed. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: ocfs2-devel@oss.oracle.com Acked-by: Joel Becker <jlbec@evilplan.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
