2013-10-18Linux 3.10.17v3.10.17Greg Kroah-Hartman
2013-10-18x86: avoid remapping data in parse_setup_data()Linn Crosetto
commit 30e46b574a1db7d14404e52dca8e1aa5f5155fd2 upstream. Type SETUP_PCI, added by setup_efi_pci(), may advertise a ROM size larger than early_memremap() is able to handle, which is currently limited to 256kB. If this occurs it leads to a NULL dereference in parse_setup_data(). To avoid this, remap the setup_data header and allow parsing functions for individual types to handle their own data remapping. Signed-off-by: Linn Crosetto <linn@hp.com> Link: http://lkml.kernel.org/r/1376430401-67445-1-git-send-email-linn@hp.com Acked-by: Yinghai Lu <yinghai@kernel.org> Reviewed-by: Pekka Enberg <penberg@kernel.org> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc,msg: prevent race with rmid in msgsnd,msgrcvDavidlohr Bueso
commit 4271b05a227dc6175b66c3d9941aeab09048aeb2 upstream. This fixes a race in both msgrcv() and msgsnd() between finding the msg and actually dealing with the queue, as another thread can delete shmid underneath us if we are preempted before acquiring the kern_ipc_perm.lock. Manfred illustrates this nicely: Assume a preemptible kernel that is preempted just after msq = msq_obtain_object_check(ns, msqid) in do_msgrcv(). The only lock that is held is rcu_read_lock(). Now the other thread processes IPC_RMID. When the first task is resumed, then it will happily wait for messages on a deleted queue. Fix this by checking for if the queue has been deleted after taking the lock. Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Reported-by: Manfred Spraul <manfred@colorfullife.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc/sem.c: update sem_otime for all operationsManfred Spraul
commit 0e8c665699e953fa58dc1b0b0d09e5dce7343cc7 upstream. In commit 0a2b9d4c7967 ("ipc/sem.c: move wake_up_process out of the spinlock section"), the update of semaphore's sem_otime(last semop time) was moved to one central position (do_smart_update). But since do_smart_update() is only called for operations that modify the array, this means that wait-for-zero semops do not update sem_otime anymore. The fix is simple: Non-alter operations must update sem_otime. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Reported-by: Jia He <jiakernel@gmail.com> Tested-by: Jia He <jiakernel@gmail.com> Cc: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc/sem.c: synchronize the proc interfaceManfred Spraul
commit d8c633766ad88527f25d9f81a5c2f083d78a2b39 upstream. The proc interface is not aware of sem_lock(), it instead calls ipc_lock_object() directly. This means that simple semop() operations can run in parallel with the proc interface. Right now, this is uncritical, because the implementation doesn't do anything that requires a proper synchronization. But it is dangerous and therefore should be fixed. Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Cc: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc/sem.c: optimize sem_lock()Manfred Spraul
commit 6d07b68ce16ae9535955ba2059dedba5309c3ca1 upstream. Operations that need access to the whole array must guarantee that there are no simple operations ongoing. Right now this is achieved by spin_unlock_wait(sem->lock) on all semaphores. If complex_count is nonzero, then this spin_unlock_wait() is not necessary, because it was already performed in the past by the thread that increased complex_count and even though sem_perm.lock was dropped inbetween, no simple operation could have started, because simple operations cannot start when complex_count is non-zero. Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Cc: Mike Galbraith <bitbucket@online.de> Cc: Rik van Riel <riel@redhat.com> Reviewed-by: Davidlohr Bueso <davidlohr@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc/sem.c: fix race in sem_lock()Manfred Spraul
commit 5e9d527591421ccdb16acb8c23662231135d8686 upstream. The exclusion of complex operations in sem_lock() is insufficient: after acquiring the per-semaphore lock, a simple op must first check that sem_perm.lock is not locked and only after that test check complex_count. The current code does it the other way around - and that creates a race. Details are below. The patch is a complete rewrite of sem_lock(), based in part on the code from Mike Galbraith. It removes all gotos and all loops and thus the risk of livelocks. I have tested the patch (together with the next one) on my i3 laptop and it didn't cause any problems. The bug is probably also present in 3.10 and 3.11, but for these kernels it might be simpler just to move the test of sma->complex_count after the spin_is_locked() test. Details of the bug: Assume: - sma->complex_count = 0. - Thread 1: semtimedop(complex op that must sleep) - Thread 2: semtimedop(simple op). Pseudo-Trace: Thread 1: sem_lock(): acquire sem_perm.lock Thread 1: sem_lock(): check for ongoing simple ops Nothing ongoing, thread 2 is still before sem_lock(). Thread 1: try_atomic_semop() <<< preempted. Thread 2: sem_lock(): static inline int sem_lock(struct sem_array *sma, struct sembuf *sops, int nsops) { int locknum; again: if (nsops == 1 && !sma->complex_count) { struct sem *sem = sma->sem_base + sops->sem_num; /* Lock just the semaphore we are interested in. */ spin_lock(&sem->lock); /* * If sma->complex_count was set while we were spinning, * we may need to look at things we did not lock here. */ if (unlikely(sma->complex_count)) { spin_unlock(&sem->lock); goto lock_array; } <<<<<<<<< <<< complex_count is still 0. <<< <<< Here it is preempted <<<<<<<<< Thread 1: try_atomic_semop() returns, notices that it must sleep. Thread 1: increases sma->complex_count. Thread 1: drops sem_perm.lock Thread 2: /* * Another process is holding the global lock on the * sem_array; we cannot enter our critical section, * but have to wait for the global lock to be released. */ if (unlikely(spin_is_locked(&sma->sem_perm.lock))) { spin_unlock(&sem->lock); spin_unlock_wait(&sma->sem_perm.lock); goto again; } <<< sem_perm.lock already dropped, thus no "goto again;" locknum = sops->sem_num; Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Cc: Mike Galbraith <bitbucket@online.de> Cc: Rik van Riel <riel@redhat.com> Cc: Davidlohr Bueso <davidlohr.bueso@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc: fix race with LSMsDavidlohr Bueso
commit 53dad6d3a8e5ac1af8bacc6ac2134ae1a8b085f1 upstream. Currently, IPC mechanisms do security and auditing related checks under RCU. However, since security modules can free the security structure, for example, through selinux_[sem,msg_queue,shm]_free_security(), we can race if the structure is freed before other tasks are done with it, creating a use-after-free condition. Manfred illustrates this nicely, for instance with shared mem and selinux: -> do_shmat calls rcu_read_lock() -> do_shmat calls shm_object_check(). Checks that the object is still valid - but doesn't acquire any locks. Then it returns. -> do_shmat calls security_shm_shmat (e.g. selinux_shm_shmat) -> selinux_shm_shmat calls ipc_has_perm() -> ipc_has_perm accesses ipc_perms->security shm_close() -> shm_close acquires rw_mutex & shm_lock -> shm_close calls shm_destroy -> shm_destroy calls security_shm_free (e.g. selinux_shm_free_security) -> selinux_shm_free_security calls ipc_free_security(&shp->shm_perm) -> ipc_free_security calls kfree(ipc_perms->security) This patch delays the freeing of the security structures after all RCU readers are done. Furthermore it aligns the security life cycle with that of the rest of IPC - freeing them based on the reference counter. For situations where we need not free security, the current behavior is kept. Linus states: "... the old behavior was suspect for another reason too: having the security blob go away from under a user sounds like it could cause various other problems anyway, so I think the old code was at least _prone_ to bugs even if it didn't have catastrophic behavior." I have tested this patch with IPC testcases from LTP on both my quad-core laptop and on a 64 core NUMA server. In both cases selinux is enabled, and tests pass for both voluntary and forced preemption models. While the mentioned races are theoretical (at least no one as reported them), I wanted to make sure that this new logic doesn't break anything we weren't aware of. Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Acked-by: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc: drop ipc_lock_checkDavidlohr Bueso
commit 20b8875abcf2daa1dda5cf70bd6369df5e85d4c1 upstream. No remaining users, we now use ipc_obtain_object_check(). Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc, shm: drop shm_lock_checkDavidlohr Bueso
commit 7a25dd9e042b2b94202a67e5551112f4ac87285a upstream. This function was replaced by a the lockless shm_obtain_object_check(), and no longer has any users. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc: drop ipc_lock_by_ptrDavidlohr Bueso
commit 32a2750010981216fb788c5190fb0e646abfab30 upstream. After previous cleanups and optimizations, this function is no longer heavily used and we don't have a good reason to keep it. Update the few remaining callers and get rid of it. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc, shm: guard against non-existant vma in shmdt(2)Davidlohr Bueso
commit 530fcd16d87cd2417c472a581ba5a1e501556c86 upstream. When !CONFIG_MMU there's a chance we can derefence a NULL pointer when the VM area isn't found - check the return value of find_vma(). Also, remove the redundant -EINVAL return: retval is set to the proper return code and *only* changed to 0, when we actually unmap the segments. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc: document general ipc locking schemeDavidlohr Bueso
commit 05603c44a7627793219b0bd9a7b236099dc9cd9d upstream. As suggested by Andrew, add a generic initial locking scheme used throughout all sysv ipc mechanisms. Documenting the ids rwsem, how rcu can be enough to do the initial checks and when to actually acquire the kern_ipc_perm.lock spinlock. I found that adding it to util.c was generic enough. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc,msg: drop msg_unlockDavidlohr Bueso
commit 4718787d1f626f45ddb239912bc07266b9880044 upstream. There is only one user left, drop this function and just call ipc_unlock_object() and rcu_read_unlock(). Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc: rename ids->rw_mutexDavidlohr Bueso
commit d9a605e40b1376eb02b067d7690580255a0df68f upstream. Since in some situations the lock can be shared for readers, we shouldn't be calling it a mutex, rename it to rwsem. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc,shm: shorten critical region for shmatDavidlohr Bueso
commit c2c737a0461e61a34676bd0bd1bc1a70a1b4e396 upstream. Similar to other system calls, acquire the kern_ipc_perm lock after doing the initial permission and security checks. [sasha.levin@oracle.com: dont leave do_shmat with rcu lock held] Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc,shm: cleanup do_shmat pastaDavidlohr Bueso
commit f42569b1388b1408b574a5e93a23a663647d4181 upstream. Clean up some of the messy do_shmat() spaghetti code, getting rid of out_free and out_put_dentry labels. This makes shortening the critical region of this function in the next patch a little easier to do and read. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc,shm: shorten critical region for shmctlDavidlohr Bueso
commit 2caacaa82a51b78fc0c800e206473874094287ed upstream. With the *_INFO, *_STAT, IPC_RMID and IPC_SET commands already optimized, deal with the remaining SHM_LOCK and SHM_UNLOCK commands. Take the shm_perm lock after doing the initial auditing and security checks. The rest of the logic remains unchanged. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc,shm: make shmctl_nolock locklessDavidlohr Bueso
commit c97cb9ccab8c85428ec21eff690642ad2ce1fa8a upstream. While the INFO cmd doesn't take the ipc lock, the STAT commands do acquire it unnecessarily. We can do the permissions and security checks only holding the rcu lock. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc,shm: introduce shmctl_nolockDavidlohr Bueso
commit 68eccc1dc345539d589ae78ee43b835c1a06a134 upstream. Similar to semctl and msgctl, when calling msgctl, the *_INFO and *_STAT commands can be performed without acquiring the ipc object. Add a shmctl_nolock() function and move the logic of *_INFO and *_STAT out of msgctl(). Since we are just moving functionality, this change still takes the lock and it will be properly lockless in the next patch. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc: drop ipcctl_pre_downDavidlohr Bueso
commit 3b1c4ad37741e53804ffe0a30dd01e08b2ab6241 upstream. Now that sem, msgque and shm, through *_down(), all use the lockless variant of ipcctl_pre_down(), go ahead and delete it. [akpm@linux-foundation.org: fix function name in kerneldoc, cleanups] Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc,shm: shorten critical region in shmctl_downDavidlohr Bueso
commit 79ccf0f8c8e04e8b9eda6645ba0f63b0915a3075 upstream. Instead of holding the ipc lock for the entire function, use the ipcctl_pre_down_nolock and only acquire the lock for specific commands: RMID and SET. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc,shm: introduce lockless functions to obtain the ipc objectDavidlohr Bueso
commit 8b8d52ac382b17a19906b930cd69e2edb0aca8ba upstream. This is the third and final patchset that deals with reducing the amount of contention we impose on the ipc lock (kern_ipc_perm.lock). These changes mostly deal with shared memory, previous work has already been done for semaphores and message queues: http://lkml.org/lkml/2013/3/20/546 (sems) http://lkml.org/lkml/2013/5/15/584 (mqueues) With these patches applied, a custom shm microbenchmark stressing shmctl doing IPC_STAT with 4 threads a million times, reduces the execution time by 50%. A similar run, this time with IPC_SET, reduces the execution time from 3 mins and 35 secs to 27 seconds. Patches 1-8: replaces blindly taking the ipc lock for a smarter combination of rcu and ipc_obtain_object, only acquiring the spinlock when updating. Patch 9: renames the ids rw_mutex to rwsem, which is what it already was. Patch 10: is a trivial mqueue leftover cleanup Patch 11: adds a brief lock scheme description, requested by Andrew. This patch: Add shm_obtain_object() and shm_obtain_object_check(), which will allow us to get the ipc object without acquiring the lock. Just as with other forms of ipc, these functions are basically wrappers around ipc_obtain_object*(). Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc/msg.c: Fix lost wakeup in msgsnd().Manfred Spraul
commit bebcb928c820d0ee83aca4b192adc195e43e66a2 upstream. The check if the queue is full and adding current to the wait queue of pending msgsnd() operations (ss_add()) must be atomic. Otherwise: - the thread that performs msgsnd() finds a full queue and decides to sleep. - the thread that performs msgrcv() first reads all messages from the queue and then sleeps, because the queue is empty. - the msgrcv() calls do not perform any wakeups, because the msgsnd() task has not yet called ss_add(). - then the msgsnd()-thread first calls ss_add() and then sleeps. Net result: msgsnd() and msgrcv() both sleep forever. Observed with msgctl08 from ltp with a preemptible kernel. Fix: Call ipc_lock_object() before performing the check. The patch also moves security_msg_queue_msgsnd() under ipc_lock_object: - msgctl(IPC_SET) explicitely mentions that it tries to expunge any pending operations that are not allowed anymore with the new permissions. If security_msg_queue_msgsnd() is called without locks, then there might be races. - it makes the patch much simpler. Reported-and-tested-by: Vineet Gupta <Vineet.Gupta1@synopsys.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc/sem.c: rename try_atomic_semop() to perform_atomic_semop(), docu updateManfred Spraul
commit 758a6ba39ef6df4cdc615e5edd7bd86eab81a5f7 upstream. Cleanup: Some minor points that I noticed while writing the previous patches 1) The name try_atomic_semop() is misleading: The function performs the operation (if it is possible). 2) Some documentation updates. No real code change, a rename and documentation changes. Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Cc: Rik van Riel <riel@redhat.com> Cc: Davidlohr Bueso <davidlohr.bueso@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc/sem.c: replace shared sem_otime with per-semaphore valueManfred Spraul
commit d12e1e50e47e0900dbbf52237b7e171f4f15ea1e upstream. sem_otime contains the time of the last semaphore operation that completed successfully. Every operation updates this value, thus access from multiple cpus can cause thrashing. Therefore the patch replaces the variable with a per-semaphore variable. The per-array sem_otime is only calculated when required. No performance improvement on a single-socket i3 - only important for larger systems. Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Cc: Rik van Riel <riel@redhat.com> Cc: Davidlohr Bueso <davidlohr.bueso@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc/sem.c: always use only one queue for alter operationsManfred Spraul
commit f269f40ad5aeee229ed70044926f44318abe41ef upstream. There are two places that can contain alter operations: - the global queue: sma->pending_alter - the per-semaphore queues: sma->sem_base[].pending_alter. Since one of the queues must be processed first, this causes an odd priorization of the wakeups: complex operations have priority over simple ops. The patch restores the behavior of linux <=3.0.9: The longest waiting operation has the highest priority. This is done by using only one queue: - if there are complex ops, then sma->pending_alter is used. - otherwise, the per-semaphore queues are used. As a side effect, do_smart_update_queue() becomes much simpler: no more goto logic. Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Cc: Rik van Riel <riel@redhat.com> Cc: Davidlohr Bueso <davidlohr.bueso@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc/sem: separate wait-for-zero and alter tasks into seperate queuesManfred Spraul
commit 1a82e9e1d0f1b45f47a97c9e2349020536ff8987 upstream. Introduce separate queues for operations that do not modify the semaphore values. Advantages: - Simpler logic in check_restart(). - Faster update_queue(): Right now, all wait-for-zero operations are always tested, even if the semaphore value is not 0. - wait-for-zero gets again priority, as in linux <=3.0.9 Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Cc: Rik van Riel <riel@redhat.com> Cc: Davidlohr Bueso <davidlohr.bueso@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc/sem.c: cacheline align the semaphore structuresManfred Spraul
commit f5c936c0f267ec58641451cf8b8d39b4c207ee4d upstream. As now each semaphore has its own spinlock and parallel operations are possible, give each semaphore its own cacheline. On a i3 laptop, this gives up to 28% better performance: #semscale 10 | grep "interleave 2" - before: Cpus 1, interleave 2 delay 0: 36109234 in 10 secs Cpus 2, interleave 2 delay 0: 55276317 in 10 secs Cpus 3, interleave 2 delay 0: 62411025 in 10 secs Cpus 4, interleave 2 delay 0: 81963928 in 10 secs -after: Cpus 1, interleave 2 delay 0: 35527306 in 10 secs Cpus 2, interleave 2 delay 0: 70922909 in 10 secs <<< + 28% Cpus 3, interleave 2 delay 0: 80518538 in 10 secs Cpus 4, interleave 2 delay 0: 89115148 in 10 secs <<< + 8.7% i3, with 2 cores and with hyperthreading enabled. Interleave 2 in order use first the full cores. HT partially hides the delay from cacheline trashing, thus the improvement is "only" 8.7% if 4 threads are running. Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Cc: Rik van Riel <riel@redhat.com> Cc: Davidlohr Bueso <davidlohr.bueso@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc/util.c, ipc_rcu_alloc: cacheline align allocationManfred Spraul
commit 196aa0132fc7261f34b10ae1bfb44abc1bc69b3c upstream. Enforce that ipc_rcu_alloc returns a cacheline aligned pointer on SMP. Rationale: The SysV sem code tries to move the main spinlock into a seperate cacheline (____cacheline_aligned_in_smp). This works only if ipc_rcu_alloc returns cacheline aligned pointers. vmalloc and kmalloc return cacheline algined pointers, the implementation of ipc_rcu_alloc breaks that. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Cc: Rik van Riel <riel@redhat.com> Cc: Davidlohr Bueso <davidlohr.bueso@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc: remove unused functionsDavidlohr Bueso
commit 9ad66ae65fc8d3e7e3344310fb0aa835910264fe upstream. We can now drop the msg_lock and msg_lock_check functions along with a bogus comment introduced previously in semctl_down. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc,msg: shorten critical region in msgrcvDavidlohr Bueso
commit 41a0d523d0f626e9da0dc01de47f1b89058033cf upstream. do_msgrcv() is the last msg queue function that abuses the ipc lock Take it only when needed when actually updating msq. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Rik van Riel <riel@redhat.com> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc,msg: shorten critical region in msgsndDavidlohr Bueso
commit 3dd1f784ed6603d7ab1043e51e6371235edf2313 upstream. do_msgsnd() is another function that does too many things with the ipc object lock acquired. Take it only when needed when actually updating msq. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc,msg: make msgctl_nolock locklessDavidlohr Bueso
commit ac0ba20ea6f2201a1589d6dc26ad1a4f0f967bb8 upstream. While the INFO cmd doesn't take the ipc lock, the STAT commands do acquire it unnecessarily. We can do the permissions and security checks only holding the rcu lock. This function now mimics semctl_nolock(). Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc,msg: introduce lockless functions to obtain the ipc objectDavidlohr Bueso
commit a5001a0d9768568de5d613c3b3a5b9c7721299da upstream. Add msq_obtain_object() and msq_obtain_object_check(), which will allow us to get the ipc object without acquiring the lock. Just as with semaphores, these functions are basically wrappers around ipc_obtain_object*(). Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc,msg: introduce msgctl_nolockDavidlohr Bueso
commit 2cafed30f150f7314f98717b372df8173516cae0 upstream. Similar to semctl, when calling msgctl, the *_INFO and *_STAT commands can be performed without acquiring the ipc object. Add a msgctl_nolock() function and move the logic of *_INFO and *_STAT out of msgctl(). This change still takes the lock and it will be properly lockless in the next patch Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc,msg: shorten critical region in msgctl_downDavidlohr Bueso
commit 15724ecb7e9bab35fc694c666ad563adba820cc3 upstream. Instead of holding the ipc lock for the entire function, use the ipcctl_pre_down_nolock and only acquire the lock for specific commands: RMID and SET. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc: move locking out of ipcctl_pre_down_nolockDavidlohr Bueso
commit 7b4cc5d8411bd4e9d61d8714f53859740cf830c2 upstream. This function currently acquires both the rw_mutex and the rcu lock on successful lookups, leaving the callers to explicitly unlock them, creating another two level locking situation. Make the callers (including those that still use ipcctl_pre_down()) explicitly lock and unlock the rwsem and rcu lock. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc: close open coded spin lock callsDavidlohr Bueso
commit cf9d5d78d05bca96df7618dfc3a5ee4414dcae58 upstream. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc: introduce ipc object locking helpersDavidlohr Bueso
commit 1ca7003ab41152d673d9e359632283d05294f3d6 upstream. Simple helpers around the (kern_ipc_perm *)->lock spinlock. Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ipc: move rcu lock out of ipc_addidDavidlohr Bueso
commit dbfcd91f06f0e2d5564b2fd184e9c2a43675f9ab upstream. This patchset continues the work that began in the sysv ipc semaphore scaling series, see https://lkml.org/lkml/2013/3/20/546 Just like semaphores used to be, sysv shared memory and msg queues also abuse the ipc lock, unnecessarily holding it for operations such as permission and security checks. This patchset mostly deals with mqueues, and while shared mem can be done in a very similar way, I want to get these patches out in the open first. It also does some pending cleanups, mostly focused on the two level locking we have in ipc code, taking care of ipc_addid() and ipcctl_pre_down_nolock() - yes there are still functions that need to be updated as well. This patch: Make all callers explicitly take and release the RCU read lock. This addresses the two level locking seen in newary(), newseg() and newqueue(). For the last two, explicitly unlock the ipc object and the rcu lock, instead of calling the custom shm_unlock and msg_unlock functions. The next patch will deal with the open coded locking for ->perm.lock Signed-off-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18drm/radeon: fix hw contexts for SUMO2 asicswojciech kapuscinski
commit 50b8f5aec04ebec7dbdf2adb17220b9148c99e63 upstream. They have 4 rather than 8. Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=63599 Signed-off-by: wojciech kapuscinski <wojtask9@wp.pl> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18drm/radeon: fix typo in CP DMA register headersAlex Deucher
commit aa3e146d04b6ae37939daeebaec060562b3db559 upstream. Wrong bit offset for SRC endian swapping. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18drm/radeon: forever loop on error in radeon_do_test_moves()Dan Carpenter
commit 89cd67b326fa95872cc2b4524cd807128db6071d upstream. The error path does this: for (--i; i >= 0; --i) { which is a forever loop because "i" is unsigned. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18drm/i915: Only apply DPMS to the encoder if enabledChris Wilson
commit c9976dcf55c8aaa7037427b239f15e5acfc01a3a upstream. The current test for an attached enabled encoder fails if we have multiple connectors aliased to the same encoder - both connectors believe they own the enabled encoder and so we attempt to both enable and disable DPMS on the encoder, leading to hilarity and an OOPs: [ 354.803064] WARNING: CPU: 0 PID: 482 at /usr/src/linux/dist/3.11.2/drivers/gpu/drm/i915/intel_display.c:3869 intel_modeset_check_state+0x764/0x770 [i915]() [ 354.803064] wrong connector dpms state [ 354.803084] Modules linked in: nfsd auth_rpcgss oid_registry exportfs nfs lockd sunrpc xt_nat iptable_nat nf_nat_ipv4 nf_nat xt_limit xt_LOG xt_tcpudp nf_conntrack_ipv4 nf_defrag_ipv4 ipt_REJECT ipv6 xt_recent xt_conntrack nf_conntrack iptable_filter ip_tables x_tables snd_hda_codec_realtek snd_hda_codec_hdmi x86_pkg_temp_thermal snd_hda_intel coretemp kvm_intel snd_hda_codec i915 kvm snd_hwdep snd_pcm_oss snd_mixer_oss crc32_pclmul snd_pcm crc32c_intel e1000e intel_agp igb ghash_clmulni_intel intel_gtt aesni_intel cfbfillrect aes_x86_64 cfbimgblt lrw cfbcopyarea drm_kms_helper ptp video thermal processor gf128mul snd_page_alloc drm snd_timer glue_helper 8250_pci snd pps_core ablk_helper agpgart cryptd sg soundcore fan i2c_algo_bit sr_mod thermal_sys 8250 i2c_i801 serial_core hwmon cdrom i2c_core evdev button [ 354.803086] CPU: 0 PID: 482 Comm: kworker/0:1 Not tainted 3.11.2 #1 [ 354.803087] Hardware name: Supermicro X10SAE/X10SAE, BIOS 1.00 05/03/2013 [ 354.803091] Workqueue: events console_callback [ 354.803092] 0000000000000009 ffff88023611db48 ffffffff814048ac ffff88023611db90 [ 354.803093] ffff88023611db80 ffffffff8103d4e3 ffff880230d82800 ffff880230f9b800 [ 354.803094] ffff880230f99000 ffff880230f99448 ffff8802351c0e00 ffff88023611dbe0 [ 354.803094] Call Trace: [ 354.803098] [<ffffffff814048ac>] dump_stack+0x54/0x8d [ 354.803101] [<ffffffff8103d4e3>] warn_slowpath_common+0x73/0x90 [ 354.803103] [<ffffffff8103d547>] warn_slowpath_fmt+0x47/0x50 [ 354.803109] [<ffffffffa089f1be>] ? intel_ddi_connector_get_hw_state+0x5e/0x110 [i915] [ 354.803114] [<ffffffffa0896974>] intel_modeset_check_state+0x764/0x770 [i915] [ 354.803117] [<ffffffffa08969bb>] intel_connector_dpms+0x3b/0x60 [i915] [ 354.803120] [<ffffffffa037e1d0>] drm_fb_helper_dpms.isra.11+0x120/0x160 [drm_kms_helper] [ 354.803122] [<ffffffffa037e24e>] drm_fb_helper_blank+0x3e/0x80 [drm_kms_helper] [ 354.803123] [<ffffffff812116c2>] fb_blank+0x52/0xc0 [ 354.803125] [<ffffffff8121e04b>] fbcon_blank+0x21b/0x2d0 [ 354.803127] [<ffffffff81062243>] ? update_rq_clock.part.74+0x13/0x30 [ 354.803129] [<ffffffff81047486>] ? lock_timer_base.isra.30+0x26/0x50 [ 354.803130] [<ffffffff810472b2>] ? internal_add_timer+0x12/0x40 [ 354.803131] [<ffffffff81047f48>] ? mod_timer+0xf8/0x1c0 [ 354.803133] [<ffffffff81266d61>] do_unblank_screen+0xa1/0x1c0 [ 354.803134] [<ffffffff81268087>] poke_blanked_console+0xc7/0xd0 [ 354.803136] [<ffffffff812681cf>] console_callback+0x13f/0x160 [ 354.803137] [<ffffffff81053258>] process_one_work+0x148/0x3d0 [ 354.803138] [<ffffffff81053f19>] worker_thread+0x119/0x3a0 [ 354.803140] [<ffffffff81053e00>] ? manage_workers.isra.30+0x2a0/0x2a0 [ 354.803141] [<ffffffff8105994b>] kthread+0xbb/0xc0 [ 354.803142] [<ffffffff81059890>] ? kthread_create_on_node+0x120/0x120 [ 354.803144] [<ffffffff8140b32c>] ret_from_fork+0x7c/0xb0 [ 354.803145] [<ffffffff81059890>] ? kthread_create_on_node+0x120/0x120 This regression goes back to the big modeset rework and the conversion to the new dpms helpers which started with: commit 5ab432ef4997ce32c9406721b37ef6e97e57dae1 Author: Daniel Vetter <daniel.vetter@ffwll.ch> Date: Sat Jun 30 08:59:56 2012 +0200 drm/i915/hdmi: convert to encoder->disable/enable Fixes: igt/kms_flip/dpms-off-confusion Reported-and-tested-by: Wakko Warner <wakko@animx.eu.org> Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=68030 Link: http://lkml.kernel.org/r/20130928185023.GA21672@animx.eu.org Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> [danvet: Add regression citation, mention the igt testcase this fixes and slap a cc: stable on the patch.] Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18cope with potentially long ->d_dname() output for shmem/hugetlbAl Viro
commit 118b23022512eb2f41ce42db70dc0568d00be4ba upstream. dynamic_dname() is both too much and too little for those - the output may be well in excess of 64 bytes dynamic_dname() assumes to be enough (thanks to ashmem feeding really long names to shmem_file_setup()) and vsnprintf() is an overkill for those guys. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Colin Cross <ccross@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ALSA: hda - Fix mono speakers and headset mic on Dell Vostro 5470David Henningsson
This is a backport for stable. The original commit SHA is 338cae565c53755de9f87d6a801517940d2d56f7. On this machine, DAC on node 0x03 seems to give mono output. Also, it needs additional patches for headset mic support. It supports CTIA style headsets only. Alsa-info available at the bug link below. BugLink: https://bugs.launchpad.net/bugs/1236228 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18compiler/gcc4: Add quirk for 'asm goto' miscompilation bugIngo Molnar
commit 3f0116c3238a96bc18ad4b4acefe4e7be32fa861 upstream. Fengguang Wu, Oleg Nesterov and Peter Zijlstra tracked down a kernel crash to a GCC bug: GCC miscompiles certain 'asm goto' constructs, as outlined here: http://gcc.gnu.org/bugzilla/show_bug.cgi?id=58670 Implement a workaround suggested by Jakub Jelinek. Reported-and-tested-by: Fengguang Wu <fengguang.wu@intel.com> Reported-by: Oleg Nesterov <oleg@redhat.com> Reported-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Suggested-by: Jakub Jelinek <jakub@redhat.com> Reviewed-by: Richard Henderson <rth@twiddle.net> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/20131015062351.GA4666@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18watchdog: ts72xx_wdt: locking bug in ioctlDan Carpenter
commit 8612ed0d97abcf1c016d34755b7cf2060de71963 upstream. Calling the WDIOC_GETSTATUS & WDIOC_GETBOOTSTATUS and twice will cause a interruptible deadlock. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Cc: Jonghwan Choi <jhbird.choi@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-18ARC: Ignore ptrace SETREGSET request for synthetic register "stop_pc"Vineet Gupta
commit 5b24282846c064ee90d40fcb3a8f63b8e754fd28 upstream. ARCompact TRAP_S insn used for breakpoints, commits before exception is taken (updating architectural PC). So ptregs->ret contains next-PC and not the breakpoint PC itself. This is different from other restartable exceptions such as TLB Miss where ptregs->ret has exact faulting PC. gdb needs to know exact-PC hence ARC ptrace GETREGSET provides for @stop_pc which returns ptregs->ret vs. EFA depending on the situation. However, writing stop_pc (SETREGSET request), which updates ptregs->ret doesn't makes sense stop_pc doesn't always correspond to that reg as described above. This was not an issue so far since user_regs->ret / user_regs->stop_pc had same value and both writing to ptregs->ret was OK, needless, but NOT broken, hence not observed. With gdb "jump", they diverge, and user_regs->ret updating ptregs is overwritten immediately with stop_pc, which this patch fixes. Reported-by: Anton Kolesov <akolesov@synopsys.com> Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
