2011-09-12Linux 3.1-rc6v3.1-rc6Linus Torvalds
2011-09-12Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: drm: Remove duplicate "return" statement drm/nv04/crtc: Bail out if FB is not bound to crtc drm/nouveau: fix nv04_sgdma_bind on non-"4kB pages" archs drm/nouveau: properly handle allocation failure in nouveau_sgdma_populate drm/nouveau: fix oops on pre-semaphore hardware drm/nv50/crtc: Bail out if FB is not bound to crtc drm/radeon/kms: fix DP detect and EDID fetch for DP bridges
2011-09-12Merge branch 'fixes' of git://git.linaro.org/people/arnd/arm-socLinus Torvalds
* 'fixes' of git://git.linaro.org/people/arnd/arm-soc: ARM: CSR: add missing sentinels to of_device_id tables ARM: cns3xxx: Fix newly introduced warnings in the PCIe code ARM: cns3xxx: Fix compile error caused by hardware.h removed ARM: davinci: fix cache flush build error ARM: davinci: correct MDSTAT_STATE_MASK ARM: davinci: da850 EVM: read mac address from SPI flash OMAP: omap_device: fix !CONFIG_SUSPEND case in _noirq handlers OMAP2430: hwmod: musb: add missing terminator to omap2430_usbhsotg_addrs[] OMAP3: clock: indicate that gpt12_fck and wdt1_fck are in the WKUP clockdomain OMAP4: clock: fix compile warning OMAP4: clock: re-enable previous clockdomain enable/disable sequence OMAP: clockdomain: Wait for powerdomain to be ON when using clockdomain force wakeup OMAP: powerdomains: Make all powerdomain target states as ON at init
2011-09-12ioctl: register LTTng ioctlMathieu Desnoyers
The LTTng 2.0 kernel tracer (stand-alone module package, available at http://lttng.org) uses the 0xF6 ioctl range for tracer control and transport operations. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-12Merge branch 'for-linus' of git://github.com/chrismason/linuxLinus Torvalds
* 'for-linus' of git://github.com/chrismason/linux: Btrfs: add dummy extent if dst offset excceeds file end in Btrfs: calc file extent num_bytes correctly in file clone btrfs: xattr: fix attribute removal Btrfs: fix wrong nbytes information of the inode Btrfs: fix the file extent gap when doing direct IO Btrfs: fix unclosed transaction handle in btrfs_cont_expand Btrfs: fix misuse of trans block rsv Btrfs: reset to appropriate block rsv after orphan operations Btrfs: skip locking if searching the commit root in csum lookup btrfs: fix warning in iput for bad-inode Btrfs: fix an oops when deleting snapshots
2011-09-12fuse: fix memory leakMiklos Szeredi
kmemleak is reporting that 32 bytes are being leaked by FUSE: unreferenced object 0xe373b270 (size 32): comm "fusermount", pid 1207, jiffies 4294707026 (age 2675.187s) hex dump (first 32 bytes): 01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ backtrace: [<b05517d7>] kmemleak_alloc+0x27/0x50 [<b0196435>] kmem_cache_alloc+0xc5/0x180 [<b02455be>] fuse_alloc_forget+0x1e/0x20 [<b0245670>] fuse_alloc_inode+0xb0/0xd0 [<b01b1a8c>] alloc_inode+0x1c/0x80 [<b01b290f>] iget5_locked+0x8f/0x1a0 [<b0246022>] fuse_iget+0x72/0x1a0 [<b02461da>] fuse_get_root_inode+0x8a/0x90 [<b02465cf>] fuse_fill_super+0x3ef/0x590 [<b019e56f>] mount_nodev+0x3f/0x90 [<b0244e95>] fuse_mount+0x15/0x20 [<b019d1bc>] mount_fs+0x1c/0xc0 [<b01b5811>] vfs_kern_mount+0x41/0x90 [<b01b5af9>] do_kern_mount+0x39/0xd0 [<b01b7585>] do_mount+0x2e5/0x660 [<b01b7966>] sys_mount+0x66/0xa0 This leak report is consistent and happens once per boot on 3.1.0-rc5-dirty. This happens if a FORGET request is queued after the fuse device was released. Reported-by: Sitsofe Wheeler <sitsofe@yahoo.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: Sitsofe Wheeler <sitsofe@yahoo.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-12fuse: fix flock breakageMiklos Szeredi
Commit 37fb3a30b4 ("fuse: fix flock") added in 3.1-rc4 caused flock() to fail with ENOSYS with the kernel ABI version 7.16 or earlier. Fix by falling back to testing FUSE_POSIX_LOCKS for ABI versions 7.16 and earlier. Reported-by: Martin Ziegler <ziegler@email.mathematik.uni-freiburg.de> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: Martin Ziegler <ziegler@email.mathematik.uni-freiburg.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-12Merge branch 'for_3.1/pm-fixes-2' of ↵Arnd Bergmann
git://gitorious.org/khilman/linux-omap-pm into fixes
2011-09-12Merge branch 'sirf/fixes' into fixesArnd Bergmann
2011-09-11Merge branch 'v4l_for_linus' of git://linuxtv.org/mchehab/for_linusLinus Torvalds
* 'v4l_for_linus' of git://linuxtv.org/mchehab/for_linus: [media] vp7045: fix buffer setup [media] nuvoton-cir: simplify raw IR sample handling [media] [Resend] viacam: Don't explode if pci_find_bus() returns NULL [media] v4l2: Fix documentation of the codec device controls [media] gspca - sonixj: Fix the darkness of sensor om6802 in 320x240 [media] gspca - sonixj: Fix wrong register mask for sensor om6802 [media] gspca - ov519: Fix LED inversion of some ov519 webcams [media] pwc: precedence bug in pwc_init_controls()
2011-09-11Merge branch 'for-linus' of git://openrisc.net/~jonas/linuxLinus Torvalds
* 'for-linus' of git://openrisc.net/~jonas/linux: Add missing DMA ops openrisc: don't use pt_regs in struct sigcontext
2011-09-11Btrfs: add dummy extent if dst offset excceeds file end inLi Zefan
You can see there's no file extent with range [0, 4096]. Check this by btrfsck: # btrfsck /dev/sda7 root 5 inode 258 errors 100 ... Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-09-11Btrfs: calc file extent num_bytes correctly in file cloneLi Zefan
num_bytes should be 4096 not 12288. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-09-11btrfs: xattr: fix attribute removalDavid Sterba
An attribute is not removed by 'setfattr -x attr file' and remains visible in attr list. This makes xfstests/062 pass again. Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-09-11Btrfs: fix wrong nbytes information of the inodeMiao Xie
If we write some data into the data hole of the file(no preallocation for this hole), Btrfs will allocate some disk space, and update nbytes of the inode, but the other element--disk_i_size needn't be updated. At this condition, we must update inode metadata though disk_i_size is not changed(btrfs_ordered_update_i_size() return 1). # mkfs.btrfs /dev/sdb1 # mount /dev/sdb1 /mnt # touch /mnt/a # truncate -s 856002 /mnt/a # dd if=/dev/zero of=/mnt/a bs=4K count=1 conv=nocreat,notrunc # umount /mnt # btrfsck /dev/sdb1 root 5 inode 257 errors 400 found 32768 bytes used err is 1 Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-09-11Btrfs: fix the file extent gap when doing direct IOMiao Xie
When we write some data to the place that is beyond the end of the file in direct I/O mode, a data hole will be created. And Btrfs should insert a file extent item that point to this hole into the fs tree. But unfortunately Btrfs forgets doing it. The following is a simple way to reproduce it: # mkfs.btrfs /dev/sdc2 # mount /dev/sdc2 /test4 # touch /test4/a # dd if=/dev/zero of=/test4/a seek=8 count=1 bs=4K oflag=direct conv=nocreat,notrunc # umount /test4 # btrfsck /dev/sdc2 root 5 inode 257 errors 100 Reported-by: Tsutomu Itoh <t-itoh@jp.fujitsu.com> Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Tested-by: Tsutomu Itoh <t-itoh@jp.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-09-11Btrfs: fix unclosed transaction handle in btrfs_cont_expandMiao Xie
The function - btrfs_cont_expand() forgot to close the transaction handle before it jump out the while loop. Fix it. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-09-11Btrfs: fix misuse of trans block rsvLiu Bo
At the beginning of create_pending_snapshot, trans->block_rsv is set to pending->block_rsv and is used for snapshot things, however, when it is done, we do not recover it as will. Signed-off-by: Liu Bo <liubo2009@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-09-11Btrfs: reset to appropriate block rsv after orphan operationsLiu Bo
While truncating free space cache, we forget to change trans->block_rsv back to the original one, but leave it with the orphan_block_rsv, and then with option inode_cache enable, it leads to countless warnings of btrfs_alloc_free_block and btrfs_orphan_commit_root: WARNING: at fs/btrfs/extent-tree.c:5711 btrfs_alloc_free_block+0x180/0x350 [btrfs]() ... WARNING: at fs/btrfs/inode.c:2193 btrfs_orphan_commit_root+0xb0/0xc0 [btrfs]() Signed-off-by: Liu Bo <liubo2009@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-09-11Btrfs: skip locking if searching the commit root in csum lookupJosef Bacik
It's not enough to just search the commit root, since we could be cow'ing the very block we need to search through, which would mean that its locked and we'll still deadlock. So use path->skip_locking as well. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-09-11btrfs: fix warning in iput for bad-inodeSergei Trofimovich
iput() shouldn't be called for inodes in I_NEW state. We need to mark inode as constructed first. WARNING: at fs/inode.c:1309 iput+0x20b/0x210() Call Trace: [<ffffffff8103e7ba>] warn_slowpath_common+0x7a/0xb0 [<ffffffff8103e805>] warn_slowpath_null+0x15/0x20 [<ffffffff810eaf0b>] iput+0x20b/0x210 [<ffffffff811b96fb>] btrfs_iget+0x1eb/0x4a0 [<ffffffff811c3ad6>] btrfs_run_defrag_inodes+0x136/0x210 [<ffffffff811ad55f>] cleaner_kthread+0x17f/0x1a0 [<ffffffff81035b7d>] ? sub_preempt_count+0x9d/0xd0 [<ffffffff811ad3e0>] ? transaction_kthread+0x280/0x280 [<ffffffff8105af86>] kthread+0x96/0xa0 [<ffffffff814336d4>] kernel_thread_helper+0x4/0x10 [<ffffffff8105aef0>] ? kthread_worker_fn+0x190/0x190 [<ffffffff814336d0>] ? gs_change+0xb/0xb Signed-off-by: Sergei Trofimovich <slyfox@gentoo.org> CC: Konstantin Khlebnikov <khlebnikov@openvz.org> Tested-by: David Sterba <dsterba@suse.cz> CC: Josef Bacik <josef@redhat.com> CC: Chris Mason <chris.mason@oracle.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-09-11Btrfs: fix an oops when deleting snapshotsLiu Bo
We can reproduce this oops via the following steps: $ mkfs.btrfs /dev/sdb7 $ mount /dev/sdb7 /mnt/btrfs $ for ((i=0; i<3; i++)); do btrfs sub snap /mnt/btrfs /mnt/btrfs/s_$i; done $ rm -fr /mnt/btrfs/* $ rm -fr /mnt/btrfs/* then we'll get ------------[ cut here ]------------ kernel BUG at fs/btrfs/inode.c:2264! [...] Call Trace: [<ffffffffa05578c7>] btrfs_rmdir+0xf7/0x1b0 [btrfs] [<ffffffff81150b95>] vfs_rmdir+0xa5/0xf0 [<ffffffff81153cc3>] do_rmdir+0x123/0x140 [<ffffffff81145ac7>] ? fput+0x197/0x260 [<ffffffff810aecff>] ? audit_syscall_entry+0x1bf/0x1f0 [<ffffffff81153d0d>] sys_unlinkat+0x2d/0x40 [<ffffffff8147896b>] system_call_fastpath+0x16/0x1b RIP [<ffffffffa054f7b9>] btrfs_orphan_add+0x179/0x1a0 [btrfs] When it comes to btrfs_lookup_dentry, we may set a snapshot's inode->i_ino to BTRFS_EMPTY_SUBVOL_DIR_OBJECTID instead of BTRFS_FIRST_FREE_OBJECTID, while the snapshot's location.objectid remains unchanged. However, btrfs_ino() does not take this into account, and returns a wrong ino, and causes the oops. Signed-off-by: Liu Bo <liubo2009@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-09-11[media] vp7045: fix buffer setupFlorian Mickler
dvb_usb_device_init calls the frontend_attach method of this driver which uses vp7045_usb_ob. In order to have a buffer ready in vp7045_usb_op, it has to be allocated before that happens. Luckily we can use the whole private data as the buffer as it gets separately allocated on the heap via kzalloc in dvb_usb_device_init and is thus apt for use via usb_control_msg. This fixes a BUG: unable to handle kernel paging request at 0000000000001e78 reported by Tino Keitel and diagnosed by Dan Carpenter. Cc: stable@kernel.org # For v3.0 and upper Tested-by: Tino Keitel <tino.keitel@tikei.de> Signed-off-by: Florian Mickler <florian@mickler.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-09-11[media] nuvoton-cir: simplify raw IR sample handlingJarod Wilson
The nuvoton-cir driver was storing up consecutive pulse-pulse and space-space samples internally, for no good reason, since ir_raw_event_store_with_filter() already merges back to back like samples types for us. This should also fix a regression introduced late in 3.0 that related to a timeout change, which actually becomes correct when coupled with this change. Tested with RC6 and RC5 on my own nuvoton-cir hardware atop vanilla 3.0.0, after verifying quirky behavior in 3.0 due to the timeout change. Reported-by: Stephan Raue <sraue@openelec.tv> CC: Stephan Raue <sraue@openelec.tv> CC: stable@vger.kernel.org Signed-off-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-09-11[media] [Resend] viacam: Don't explode if pci_find_bus() returns NULLJesper Juhl
In the unlikely case that pci_find_bus() should return NULL viacam_serial_is_enabled() is going to dereference a NULL pointer and blow up. Better safe than sorry, so be defensive and check the pointer. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Acked-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-09-11[media] v4l2: Fix documentation of the codec device controlsKamil Debski
Fixed missing ids of the codec controls description in the controls.xml file. Signed-off-by: Kamil Debski <k.debski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reported-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-09-11[media] gspca - sonixj: Fix the darkness of sensor om6802 in 320x240Jean-François Moine
The images are clearer with a lower bridge clock. Signed-off-by: Jean-François Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-09-11[media] gspca - sonixj: Fix wrong register mask for sensor om6802Luiz Carlos Ramos
The bug was introduced by git commit 0e4d413af1a9d, giving very dark images. Signed-off-by: Luiz Carlos Ramos <lramos.prof@yahoo.com.br> Signed-off-by: Jean-François Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-09-11[media] gspca - ov519: Fix LED inversion of some ov519 webcamsJean-François Moine
The list of the webcams which have LED inversion was rebuild scanning ms-win .inf files. Signed-off-by: Jean-François Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-09-11[media] pwc: precedence bug in pwc_init_controls()Dan Carpenter
'!' has higher precedence than '&' so we need parenthesis here. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-09-11Add missing DMA opsJonas Bonn
For the initial architecture submission, not all of the DMA ops were implemented. This patch adds the *map_page and *map_sg variants of the DMA mapping ops. This patch is currently of interest mainly to some drivers that haven't been submitted upstream yet. Signed-off-by: Jonas Bonn <jonas@southpole.se>
2011-09-11ARM: CSR: add missing sentinels to of_device_id tablesJamie Iles
The of_device_id tables used for matching should be terminated with empty sentinel values. Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Barry Song <baohua.song@csr.com>
2011-09-10scsi: qla4xxx driver depends on NETRandy Dunlap
When CONFIG_NET is disabled, SCSI_QLA_ISCSI selects SCSI_ISCSI_ATTRS, which uses network interfaces, so the build fails with multiple errors: warning: (ISCSI_TCP && SCSI_CXGB3_ISCSI && SCSI_CXGB4_ISCSI && SCSI_QLA_ISCSI && INFINIBAND_ISER) selects SCSI_ISCSI_ATTRS which has unmet direct dependencies (SCSI && NET) ERROR: "skb_trim" [drivers/scsi/scsi_transport_iscsi.ko] undefined! ERROR: "netlink_kernel_create" [drivers/scsi/scsi_transport_iscsi.ko] undefined! ERROR: "netlink_kernel_release" [drivers/scsi/scsi_transport_iscsi.ko] undefined! ... so make SCSI_QLA_ISCSI also depend on NET to prevent the build errors. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Cc: Ravi Anand <ravi.anand@qlogic.com> Cc: Vikas Chaudhary <vikas.chaudhary@qlogic.com> Cc: iscsi-driver@qlogic.com Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-10Merge branch 'fixes' of ↵Linus Torvalds
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm * 'fixes' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: ARM: 7088/1: entry: fix wrong parameter name used in do_thumb_abort ARM: 7080/1: l2x0: make sure I&D are not locked down on init ARM: 7081/1: mach-integrator: fix the clocksource NET: am79c961: fix race in link status code ARM: 7067/1: mm: keep significant bits in pfn_valid
2011-09-10ARM: 7088/1: entry: fix wrong parameter name used in do_thumb_abortJanusz Krzysztofik
Commit be020f8618ca, "ARM: entry: abort-macro: specify registers to be used for macros", while replacing register numbers with macro parameter names, mismatched the name used for r1. For me, this resulted in user space built for EABI with -march=armv4t -mtune=arm920t -mthumb-interwork -mthumb broken on my OMAP1510 based Amstrad Delta (old ABI and no thumb still worked for me though). Fix this by using correct parameter name fsr instead of mismatched psr, used by callers for another purpose. Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-09-10Merge branches 'cns3xxx/fixes', 'omap/fixes' and 'davinci/fixes' into fixesArnd Bergmann
2011-09-10backlight: Declare backlight_types[] constBart Van Assche
Since backlight_types[] isn't modified, let's declare it const. That was probably the intention of the author of commit bb7ca747f8d6 ("backlight: add backlight type"), via which the "const char const *" construct was introduced. The duplicate const was detected by sparse. Signed-off-by: Bart Van Assche <bvanassche@acm.org> Cc: Matthew Garrett <mjg@redhat.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-10Merge branch 'for-linus' of git://neil.brown.name/mdLinus Torvalds
* 'for-linus' of git://neil.brown.name/md: md: Fix handling for devices from 2TB to 4TB in 0.90 metadata. md/raid1,10: Remove use-after-free bug in make_request. md/raid10: unify handling of write completion. Avoid dereferencing a 'request_queue' after last close.
2011-09-10md: Fix handling for devices from 2TB to 4TB in 0.90 metadata.NeilBrown
0.90 metadata uses an unsigned 32bit number to count the number of kilobytes used from each device. This should allow up to 4TB per device. However we multiply this by 2 (to get sectors) before casting to a larger type, so sizes above 2TB get truncated. Also we allow rdev->sectors to be larger than 4TB, so it is possible for the array to be resized larger than the metadata can handle. So make sure rdev->sectors never exceeds 4TB when 0.90 metadata is in used. Also the sanity check at the end of super_90_load should include level 1 as it used ->size too. (RAID0 and Linear don't use ->size at all). Reported-by: Pim Zandbergen <P.Zandbergen@macroscoop.nl> Cc: stable@kernel.org Signed-off-by: NeilBrown <neilb@suse.de>
2011-09-10md/raid1,10: Remove use-after-free bug in make_request.NeilBrown
A single request to RAID1 or RAID10 might result in multiple requests if there are known bad blocks that need to be avoided. To detect if we need to submit another write request we test: if (sectors_handled < (bio->bi_size >> 9)) { However this is after we call **_write_done() so the 'bio' no longer belongs to us - the writes could have completed and the bio freed. So move the **_write_done call until after the test against bio->bi_size. This addresses https://bugzilla.kernel.org/show_bug.cgi?id=41862 Reported-by: Bruno Wolff III <bruno@wolff.to> Tested-by: Bruno Wolff III <bruno@wolff.to> Signed-off-by: NeilBrown <neilb@suse.de>
2011-09-10md/raid10: unify handling of write completion.NeilBrown
A write can complete at two different places: 1/ when the last member-device write completes, through raid10_end_write_request 2/ in make_request() when we remove the initial bias from ->remaining. These two should do exactly the same thing and the comment says they do, but they don't. So factor the correct code out into a function and call it in both places. This makes the code much more similar to RAID1. The difference is only significant if there is an error, and they usually take a while, so it is unlikely that there will be an error already when make_request is completing, so this is unlikely to cause real problems. Signed-off-by: NeilBrown <neilb@suse.de>
2011-09-10Avoid dereferencing a 'request_queue' after last close.NeilBrown
On the last close of an 'md' device which as been stopped, the device is destroyed and in particular the request_queue is freed. The free is done in a separate thread so it might happen a short time later. __blkdev_put calls bdev_inode_switch_bdi *after* ->release has been called. Since commit f758eeabeb96f878c860e8f110f94ec8820822a9 bdev_inode_switch_bdi will dereference the 'old' bdi, which lives inside a request_queue, to get a spin lock. This causes the last close on an md device to sometime take a spin_lock which lives in freed memory - which results in an oops. So move the called to bdev_inode_switch_bdi before the call to ->release. Cc: Christoph Hellwig <hch@lst.de> Cc: Hugh Dickins <hughd@google.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Wu Fengguang <fengguang.wu@intel.com> Acked-by: Wu Fengguang <fengguang.wu@intel.com> Cc: stable@kernel.org Signed-off-by: NeilBrown <neilb@suse.de>
2011-09-09PCI: Remove MRRS modification from MPS setting codeJon Mason
Modifying the Maximum Read Request Size to 0 (value of 128Bytes) has massive negative ramifications on some devices. Without knowing which devices have this issue, do not modify from the default value when walking the PCI-E bus in pcie_bus_safe mode. Also, make pcie_bus_safe the default procedure. Tested-by: Sven Schnelle <svens@stackframe.org> Tested-by: Simon Kirby <sim@hostway.ca> Tested-by: Stephen M. Cameron <scameron@beardog.cce.hp.com> Reported-and-tested-by: Eric Dumazet <eric.dumazet@gmail.com> Reported-and-tested-by: Niels Ole Salscheider <niels_ole@salscheider-online.de> References: https://bugzilla.kernel.org/show_bug.cgi?id=42162 Signed-off-by: Jon Mason <mason@myri.com> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-09Fix pointer dereference before call to pcie_bus_configure_settingsShyam Iyer
Commit b03e7495a862 ("PCI: Set PCI-E Max Payload Size on fabric") introduced a potential NULL pointer dereference in calls to pcie_bus_configure_settings due to attempts to access pci_bus self variables when the self pointer is NULL. To correct this, verify that the self pointer in pci_bus is non-NULL before dereferencing it. Reported-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: Shyam Iyer <shyam_iyer@dell.com> Signed-off-by: Jon Mason <mason@myri.com> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-09Merge branch 'for-linus' of git://dev.laptop.org/users/cjb/mmcLinus Torvalds
* 'for-linus' of git://dev.laptop.org/users/cjb/mmc: mmc: sdhci-s3c: Fix mmc card I/O problem mmc: sd: UHS-I bus speed should be set last in UHS initialization mmc: sdhi: initialise mmc_data->flags before use mmc: core: use non-reentrant workqueue for clock gating mmc: core: prevent aggressive clock gating racing with ios updates mmc: rename mmc_host_clk_{ungate|gate} to mmc_host_clk_{hold|release} mmc: sdhci-esdhc-imx: add missing inclusion of linux/module.h
2011-09-09Merge branch 'for-linus' of git://ceph.newdream.net/git/ceph-clientLinus Torvalds
* 'for-linus' of git://ceph.newdream.net/git/ceph-client: libceph: fix leak of osd structs during shutdown ceph: fix memory leak ceph: fix encoding of ino only (not relative) paths libceph: fix msgpool
2011-09-09vfs: automount should ignore LOOKUP_FOLLOWMiklos Szeredi
Prior to 2.6.38 automount would not trigger on either stat(2) or lstat(2) on the automount point. After 2.6.38, with the introduction of the ->d_automount() infrastructure, stat(2) and others would start triggering automount while lstat(2), etc. still would not. This is a regression and a userspace ABI change. Problem originally reported here: http://thread.gmane.org/gmane.linux.kernel.autofs/6098 It appears that there was an attempt at fixing various userspace tools to not trigger the automount. But since the stat system call is rather common it is impossible to "fix" all userspace. This patch reverts the original behavior, which is to not trigger on stat(2) and other symlink following syscalls. [ It's not really clear what the right behavior is. Apparently Solaris does the "automount on stat, leave alone on lstat". And some programs can get unhappy when "stat+open+fstat" ends up giving a different result from the fstat than from the initial stat. But the change in 2.6.38 resulted in problems for some people, so we're going back to old behavior. Maybe we can re-visit this discussion at some future date - Linus ] Reported-by: Leonardo Chiquitto <leonardo.lists@gmail.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Acked-by: Ian Kent <raven@themaw.net> Cc: David Howells <dhowells@redhat.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-09ARM: cns3xxx: Fix newly introduced warnings in the PCIe codeAnton Vorontsov
commit d5341942d784134f2997b3ff82cd63cf71d1f932 ("PCI: Make the struct pci_dev * argument of pci_fixup_irqs const") did not change argument of pdev_to_cnspci(), and thus introduced the following warnings: CHECK arch/arm/mach-cns3xxx/pcie.c pcie.c:177:60: warning: incorrect type in argument 1 (different modifiers) pcie.c:177:60: expected struct pci_dev *dev pcie.c:177:60: got struct pci_dev const *dev CC arch/arm/mach-cns3xxx/pcie.o pcie.c: In function 'cns3xxx_pcie_map_irq': pcie.c:177: warning: passing argument 1 of 'pdev_to_cnspci' discards qualifiers from pointer target type pcie.c:52: note: expected 'struct pci_dev *' but argument is of type 'const struct pci_dev *' This patch fixes the issue. Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2011-09-09ARM: cns3xxx: Fix compile error caused by hardware.h removedTommy Lin
Commit c9d95fbe59e426eed7f16e7cac812e46ac4772d0 "ARM: convert PCI defines to variables" deleted cns3xxx' hardware.h, but didn't remove references for it, so do it now. This patch removes lines that refer to hardware.h. Signed-off-by: Tommy Lin <tommy.lin.1101@gmail.com> Signed-off-by: Imre Kaloz <kaloz@openwrt.org> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2011-09-09drm: Remove duplicate "return" statementLin Ming
Remove the duplicate "return" statement in drm_fb_helper_panic(). Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
