commit 83589b30f1e1dc9898986293c9336b8ce1705dec upstream.
BugLink: http://bugs.launchpad.net/bugs/1128840
It appears that when this register read fails it never recovers, so
I think there is no need to repeat the same error message ad infinitum.
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
Cc: Ivo van Doorn <IvDoorn@gmail.com>
Cc: Gertjan van Wingerde <gwingerde@gmail.com>
Cc: Helmut Schaa <helmut.schaa@googlemail.com>
Cc: "John W. Linville" <linville@tuxdriver.com>
Cc: linux-wireless@vger.kernel.org
Cc: users@rt2x00.serialmonkey.com
Cc: netdev@vger.kernel.org
Cc: stable@vger.kernel.org
revert commit b9f1f48ce20a1b923429c216669d03b5a900a8cf which is commit
084c7189acb3f969c855536166042e27f5dd703f upstream.
It shouldn't have been applied to the 3.0-stable tree.
Reported-by: Ben Hutchings <ben@decadent.org.uk>
Cc: Marco Cesarano <marco@marvell.com>
Reported-by: Bing Zhao <bzhao@marvell.com>
commit f03574f2d5b2d6229dcdf2d322848065f72953c7 upstream.
This code was an optimization for 32-bit NUMA systems.
It has probably been the cause of a number of subtle bugs over
the years, although the conditions to excite them would have
been hard to trigger. Essentially, we remap part of the kernel
linear mapping area, and then sometimes part of that area gets
freed back in to the bootmem allocator. If those pages get
used by kernel data structures (say mem_map[] or a dentry),
there's no big deal. But, if anyone ever tried to use the
linear mapping for these pages _and_ cared about their physical
address, bad things happen.
For instance, say you passed __GFP_ZERO to the page allocator
and then happened to get handed one of these pages, it zero the
remapped page, but it would make a pte to the _old_ page.
There are probably a hundred other ways that it could screw
with things.
We don't need to hang on to performance optimizations for
these old boxes any more. All my 32-bit NUMA systems are long
dead and buried, and I probably had access to more than most
people.
This code is causing real things to break today:
https://lkml.org/lkml/2013/1/9/376
I looked in to actually fixing this, but it requires surgery
to way too much brittle code, as well as stuff like
per_cpu_ptr_to_phys().
[ hpa: Cc: this for -stable, since it is a memory corruption issue.
However, an alternative is to simply mark NUMA as depends BROKEN
rather than EXPERIMENTAL in the X86_32 subclause... ]
Link: http://lkml.kernel.org/r/20130131005616.1C79F411@kernel.stglabs.ibm.com
Cc: Jiri Slaby <jslaby@suse.cz>
commit b6a9b7f6b1f21735a7456d534dc0e68e61359d2c upstream.
find_vma() can be called by multiple threads with read lock
held on mm->mmap_sem and any of them can update mm->mmap_cache.
Prevent compiler from re-fetching mm->mmap_cache, because other
readers could update it in the meantime:
thread 1 thread 2
find_vma() | find_vma()
struct vm_area_struct *vma = NULL; |
vma = mm->mmap_cache; |
if (!(vma && vma->vm_end > addr |
&& vma->vm_start <= addr)) { |
| mm->mmap_cache = vma;
return vma; |
^^ compiler may optimize this |
local variable out and re-read |
mm->mmap_cache |
This issue can be reproduced with gcc-4.8.0-1 on s390x by running
mallocstress testcase from LTP, which triggers:
kernel BUG at mm/rmap.c:1088!
Call Trace:
([<000003d100c57000>] 0x3d100c57000)
[<000000000023a1c0>] do_wp_page+0x2fc/0xa88
[<000000000023baae>] handle_pte_fault+0x41a/0xac8
[<000000000023d832>] handle_mm_fault+0x17a/0x268
[<000000000060507a>] do_protection_exception+0x1e2/0x394
[<0000000000603a04>] pgm_check_handler+0x138/0x13c
[<000003fffcf1f07a>] 0x3fffcf1f07a
Last Breaking-Event-Address:
[<000000000024755e>] page_add_new_anon_rmap+0xc2/0x168
Thanks to Jakub Jelinek for his insight on gcc and helping to
track this down.
Signed-off-by: Jan Stancek <jstancek@redhat.com>
Acked-by: David Rientjes <rientjes@google.com>
[bwh: Backported to 3.2: adjust context, indentation]
commit da28d966f6aa942ae836d09729f76a1647932309 upstream.
The return code from the registration of the thermal class is used to
unallocate resources, but this failure isn't passed back to the caller of
thermal_init. Return this failure back to the caller.
This bug was introduced in changeset 4cb18728 which overwrote the return code
when the variable was re-used to catch the return code of the registration of
the genetlink thermal socket family.
Signed-off-by: Richard Guy Briggs <rbriggs@redhat.com>
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
Cc: Jonghwan Choi <jhbird.choi@samsung.com>
commit c678ef5286ddb5cf70384ad5af286b0afc9b73e1 upstream.
As found by gcc-4.8, the QUEUE_SYSFS_BIT_FNS macro creates functions
that use a value generated by queue_var_store independent of whether
that value was set or not.
block/blk-sysfs.c: In function 'queue_store_nonrot':
block/blk-sysfs.c:244:385: warning: 'val' may be used uninitialized in this function [-Wmaybe-uninitialized]
Unlike most other such warnings, this one is not a false positive,
writing any non-number string into the sysfs files indeed has
an undefined result, rather than returning an error.
commit d3dde52209ab571e4e2ec26c66f85ad1355f7475 upstream.
rfc4543(gcm(*)) code for GMAC assumes that assoc scatterlist always contains
only one segment and only makes use of this first segment. However ipsec passes
assoc with three segments when using 'extended sequence number' thus in this
case rfc4543(gcm(*)) fails to function correctly. Patch fixes this issue.
Reported-by: Chaoxing Lin <Chaoxing.Lin@ultra-3eti.com>
Tested-by: Chaoxing Lin <Chaoxing.Lin@ultra-3eti.com>
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi>
commit 386afc91144b36b42117b0092893f15bc8798a80 upstream.
In UP and non-preempt respectively, the spinlocks and preemption
disable/enable points are stubbed out entirely, because there is no
regular code that can ever hit the kind of concurrency they are meant to
protect against.
However, while there is no regular code that can cause scheduling, we
_do_ end up having some exceptional (literally!) code that can do so,
and that we need to make sure does not ever get moved into the critical
region by the compiler.
In particular, get_user() and put_user() is generally implemented as
inline asm statements (even if the inline asm may then make a call
instruction to call out-of-line), and can obviously cause a page fault
and IO as a result. If that inline asm has been scheduled into the
middle of a preemption-safe (or spinlock-protected) code region, we
obviously lose.
Now, admittedly this is *very* unlikely to actually ever happen, and
we've not seen examples of actual bugs related to this. But partly
exactly because it's so hard to trigger and the resulting bug is so
subtle, we should be extra careful to get this right.
So make sure that even when preemption is disabled, and we don't have to
generate any actual *code* to explicitly tell the system that we are in
a preemption-disabled region, we need to at least tell the compiler not
to move things around the critical region.
This patch grew out of the same discussion that caused commits
79e5f05edcbf ("ARC: Add implicit compiler barrier to raw_local_irq*
functions") and 3e2e0d2c222b ("tile: comment assumption about
__insn_mtspr for <asm/irqflags.h>") to come about.
Note for stable: use discretion when/if applying this. As mentioned,
this bug may never have actually bitten anybody, and gcc may never have
done the required code motion for it to possibly ever trigger in
practice.
Cc: Steven Rostedt <srostedt@redhat.com>
performed before the ANDCOND test
commit 9fb2640159f9d4f5a2a9d60e490482d4cbecafdb upstream.
Some versions of pHyp will perform the adjunct partition test before the
ANDCOND test. The result of this is that H_RESOURCE can be returned and
cause the BUG_ON condition to occur. The HPTE is not removed. So add a
check for H_RESOURCE, it is ok if this HPTE is not removed as
pSeries_lpar_hpte_remove is looking for an HPTE to remove and not a
specific HPTE to remove. So it is ok to just move on to the next slot
and try again.
Signed-off-by: Michael Wolf <mjw@linux.vnet.ibm.com>
commit 5000c418840b309251c5887f0b56503aae30f84c upstream.
If we reenable ftrace via syctl, we currently set ftrace_trace_function
based on the previous simplistic algorithm. This is inconsistent with
what update_ftrace_function does. So better call that helper instead.
Link: http://lkml.kernel.org/r/5151D26F.1070702@siemens.com
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
commit aa8b4be3ac049c8b1df2a87e4d1d902ccfc1f7a9 upstream.
Fixes a NULL pointer dereference at boot on UP1500.
Reviewed-and-Tested-by: Matt Turner <mattst88@gmail.com>
Signed-off-by: Jay Estabrook <jay.estabrook@gmail.com>
Signed-off-by: Matt Turner <mattst88@gmail.com>
Signed-off-by: Michael Cree <mcree@orcon.net.nz>
commit a32450e127fc6e5ca6d958ceb3cfea4d30a00846 upstream.
The Slimtype DVD A DS8A8SH drive locks up when max sector is smaller than
65535, and the blow backtrace is observed on locking up:
INFO: task flush-8:32:1130 blocked for more than 120 seconds.
"echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
flush-8:32 D ffffffff8180cf60 0 1130 2 0x00000000
ffff880273aef618 0000000000000046 0000000000000005 ffff880273aee000
ffff880273aee000 ffff880273aeffd8 ffff880273aee010 ffff880273aee000
ffff880273aeffd8 ffff880273aee000 ffff88026e842ea0 ffff880274a10000
Call Trace:
[<ffffffff8168fc2d>] schedule+0x5d/0x70
[<ffffffff8168fccc>] io_schedule+0x8c/0xd0
[<ffffffff81324461>] get_request+0x731/0x7d0
[<ffffffff8133dc60>] ? cfq_allow_merge+0x50/0x90
[<ffffffff81083aa0>] ? wake_up_bit+0x40/0x40
[<ffffffff81320443>] ? bio_attempt_back_merge+0x33/0x110
[<ffffffff813248ea>] blk_queue_bio+0x23a/0x3f0
[<ffffffff81322176>] generic_make_request+0xc6/0x120
[<ffffffff81322308>] submit_bio+0x138/0x160
[<ffffffff811d7596>] ? bio_alloc_bioset+0x96/0x120
[<ffffffff811d1f61>] submit_bh+0x1f1/0x220
[<ffffffff811d48b8>] __block_write_full_page+0x228/0x340
[<ffffffff811d3650>] ? attach_nobh_buffers+0xc0/0xc0
[<ffffffff811d8960>] ? I_BDEV+0x10/0x10
[<ffffffff811d4ab6>] block_write_full_page_endio+0xe6/0x100
[<ffffffff811d4ae5>] block_write_full_page+0x15/0x20
[<ffffffff811d9268>] blkdev_writepage+0x18/0x20
[<ffffffff81142527>] __writepage+0x17/0x40
[<ffffffff811438ba>] write_cache_pages+0x34a/0x4a0
[<ffffffff81142510>] ? set_page_dirty+0x70/0x70
[<ffffffff81143a61>] generic_writepages+0x51/0x80
[<ffffffff81143ab0>] do_writepages+0x20/0x50
[<ffffffff811c9ed6>] __writeback_single_inode+0xa6/0x2b0
[<ffffffff811ca861>] writeback_sb_inodes+0x311/0x4d0
[<ffffffff811caaa6>] __writeback_inodes_wb+0x86/0xd0
[<ffffffff811cad43>] wb_writeback+0x1a3/0x330
[<ffffffff816916cf>] ? _raw_spin_lock_irqsave+0x3f/0x50
[<ffffffff811b8362>] ? get_nr_inodes+0x52/0x70
[<ffffffff811cb0ac>] wb_do_writeback+0x1dc/0x260
[<ffffffff8168dd34>] ? schedule_timeout+0x204/0x240
[<ffffffff811cb232>] bdi_writeback_thread+0x102/0x2b0
[<ffffffff811cb130>] ? wb_do_writeback+0x260/0x260
[<ffffffff81083550>] kthread+0xc0/0xd0
[<ffffffff81083490>] ? kthread_worker_fn+0x1b0/0x1b0
[<ffffffff8169a3ec>] ret_from_fork+0x7c/0xb0
The above trace was triggered by
"dd if=/dev/zero of=/dev/sr0 bs=2048 count=32768"
It was previously working by accident, since another bug introduced
by 4dce8ba94c7 (libata: Use 'bool' return value for ata_id_XXX) caused
all drives to use maxsect=65535.
Signed-off-by: Shan Hai <shan.hai@windriver.com>
commit d8668fcb0b257d9fdcfbe5c172a99b8d85e1cd82 upstream.
The function returns type of ATAPI drives so it should return integer value.
The commit 4dce8ba94c7 (libata: Use 'bool' return value for ata_id_XXX) since
v2.6.39 changed the type of return value from int to bool, the change would
cause all of the ATAPI class drives to be treated as TYPE_TAPE and the
max_sectors of the drives to be set to 65535 because of the commit
f8d8e5799b7(libata: increase 128 KB / cmd limit for ATAPI tape drives), for the
function would return true for all ATAPI class drives and the TYPE_TAPE is
defined as 0x01.
Replace C division operators with div64_u64 for divides introduced in:
commit 503f4bdcc078e7abee273a85ce322de81b18a224
ext4: use atomic64_t for the per-flexbg free_clusters count
Specific to the 3.0-stable backport of the upstream patch.
Signed-off-by: Todd Poynor <toddpoynor@google.com>
Reviewed-by: "Theodore Ts'o" <tytso@mit.edu>
Cc: Christoph Biedl <linux-kernel.bfrz@manchmal.in-ulm.de>
Cc: Lukas Czerner <lczerner@redhat.com>
commit aeb3a97222832e5457c4b72d72235098ce4bfe8d upstream.
Rename "Digitial In" to "Digital In". This function is only used for
proc output, so should not cause any problems to change.
Signed-off-by: David Henningsson <david.henningsson@canonical.com>
commit 2ef5692efad330b67a234e2c49edad38538751e7 upstream.
In function snd_hdmi_get_eld(), the variable 'ret' should be initialized to 0.
Otherwise it will be returned uninitialized as non-zero after ELD info is got
successfully. Thus hdmi_present_sense() will always assume ELD info is invalid
by mistake, and /proc file system cannot show the proper ELD info.
Signed-off-by: Mengdong Lin <mengdong.lin@intel.com>
Acked-by: David Henningsson <david.henningsson@canonical.com>
commit 35e5cbc0af240778e61113286c019837e06aeec6 upstream.
After commit 21d8a15a (lookup_one_len: don't accept . and ..) reiserfs
started failing to delete xattrs from inode. This was due to a buggy
test for '.' and '..' in fill_with_dentries() which resulted in passing
'.' and '..' entries to lookup_one_len() in some cases. That returned
error and so we failed to iterate over all xattrs of and inode.
Fix the test in fill_with_dentries() along the lines of the one in
lookup_one_len().
Reported-by: Pawel Zawora <pzawora@gmail.com>
commit 67e753ca41782913d805ff4a8a2b0f60b26b7915 upstream.
The UBIFS space fixup is a useful feature which allows to fixup the "broken"
flash space at the time of the first mount. The "broken" space is usually the
result of using a "dumb" industrial flasher which is not able to skip empty
NAND pages and just writes all 0xFFs to the empty space, which has grave
side-effects for UBIFS when UBIFS trise to write useful data to those empty
pages.
The fix-up feature works roughly like this:
1. mkfs.ubifs sets the fixup flag in UBIFS superblock when creating the image
(see -F option)
2. when the file-system is mounted for the first time, UBIFS notices the fixup
flag and re-writes the entire media atomically, which may take really a lot
of time.
3. UBIFS clears the fixup flag in the superblock.
This works fine when the file system is mounted R/W for the very first time.
But it did not really work in the case when we first mount the file-system R/O,
and then re-mount R/W. The reason was that we started the fixup procedure too
late, which we cannot really do because we have to fixup the space before it
starts being used.
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
Reported-by: Mark Jackson <mpfj-list@mimc.co.uk>
commit 417a1178f1bf3cdc606376b3ded3a22489fbb3eb upstream.
The dma-sh7760 currently fails with the following compile error:
sound/soc/sh/dma-sh7760.c:346:2: error: unknown field 'pcm_ops' specified in initializer
sound/soc/sh/dma-sh7760.c:346:2: warning: initialization from incompatible pointer type
sound/soc/sh/dma-sh7760.c:347:2: error: unknown field 'pcm_new' specified in initializer
sound/soc/sh/dma-sh7760.c:347:2: warning: initialization makes integer from pointer without a cast
sound/soc/sh/dma-sh7760.c:348:2: error: unknown field 'pcm_free' specified in initializer
sound/soc/sh/dma-sh7760.c:348:2: warning: initialization from incompatible pointer type
sound/soc/sh/dma-sh7760.c: In function 'sh7760_soc_platform_probe':
sound/soc/sh/dma-sh7760.c:353:2: warning: passing argument 2 of 'snd_soc_register_platform' from incompatible pointer type
include/sound/soc.h:368:5: note: expected 'struct snd_soc_platform_driver *' but argument is of type 'struct snd_soc_platform *'
This is due the misnaming of the snd_soc_platform_driver type name and 'ops'
field. The issue was introduced in commit f0fba2a("ASoC: multi-component - ASoC
Multi-Component Support").
[ Upstream commit fcd99434fb5c137274d2e15dd2a6a7455f0f29ff ]
Now that netdev_rx_handler_unregister contains synchronize_net(), we need
to call it outside of bond->lock, cause it might sleep. Also, remove the
already unneded synchronize_net().
Signed-off-by: Veaceslav Falico <vfalico@redhat.com>
commit c2a2876e863356b092967ea62bebdb4dd663af80 upstream.
There is a bug introduced with commit 27c2127 that causes
devices which are hot unplugged and then hot-replugged to
not have per-device dma_ops set. This causes these devices
to not function correctly. Fixed with this patch.
Reported-by: Andreas Degert <andreas.degert@googlemail.com>
Signed-off-by: Joerg Roedel <joro@8bytes.org>
[ Upstream commit 4c51e53689569398d656e631c17308d9b8e84650 ]
This patch enables RX of jumbo frames for LAN7500.
Previously the driver would transmit jumbo frames succesfully but
would drop received jumbo frames (incrementing the interface errors
count).
With this patch applied the device can succesfully receive jumbo
frames up to MTU 9000 (9014 bytes on the wire including ethernet
header).
Signed-off-by: Steve Glendinning <steve.glendinning@shawell.net>
[ Upstream commit 76a0e68129d7d24eb995a6871ab47081bbfa0acc ]
skb->ip_summed should be CHECKSUM_UNNECESSARY when the driver reports that
checksums were correct and CHECKSUM_NONE in any other case. They're
currently placed vice versa, which breaks the forwarding scenario. Fix it
by placing them as described above.
[ Upstream commit 00cfec37484761a44a3b6f4675a54caa618210ae ]
commit 35d48903e97819 (bonding: fix rx_handler locking) added a race
in bonding driver, reported by Steven Rostedt who did a very good
diagnosis :
<quoting Steven>
I'm currently debugging a crash in an old 3.0-rt kernel that one of our
customers is seeing. The bug happens with a stress test that loads and
unloads the bonding module in a loop (I don't know all the details as
I'm not the one that is directly interacting with the customer). But the
bug looks to be something that may still be present and possibly present
in mainline too. It will just be much harder to trigger it in mainline.
In -rt, interrupts are threads, and can schedule in and out just like
any other thread. Note, mainline now supports interrupt threads so this
may be easily reproducible in mainline as well. I don't have the ability
to tell the customer to try mainline or other kernels, so my hands are
somewhat tied to what I can do.
But according to a core dump, I tracked down that the eth irq thread
crashed in bond_handle_frame() here:
slave = bond_slave_get_rcu(skb->dev);
bond = slave->bond; <--- BUG
the slave returned was NULL and accessing slave->bond caused a NULL
pointer dereference.
Looking at the code that unregisters the handler:
void netdev_rx_handler_unregister(struct net_device *dev)
ASSERT_RTNL();
RCU_INIT_POINTER(dev->rx_handler, NULL);
RCU_INIT_POINTER(dev->rx_handler_data, NULL);
Which is basically:
dev->rx_handler = NULL;
dev->rx_handler_data = NULL;
And looking at __netif_receive_skb() we have:
rx_handler = rcu_dereference(skb->dev->rx_handler);
if (rx_handler) {
if (pt_prev) {
ret = deliver_skb(skb, pt_prev, orig_dev);
pt_prev = NULL;
switch (rx_handler(&skb)) {
My question to all of you is, what stops this interrupt from happening
while the bonding module is unloading? What happens if the interrupt
triggers and we have this:
CPU0 CPU1
rx_handler = skb->dev->rx_handler
netdev_rx_handler_unregister() {
rx_handler()
bond_handle_frame() {
slave = skb->dev->rx_handler;
bond = slave->bond; <-- NULL pointer dereference!!!
What protection am I missing in the bond release handler that would
prevent the above from happening?
</quoting Steven>
We can fix bug this in two ways. First is adding a test in
bond_handle_frame() and others to check if rx_handler_data is NULL.
A second way is adding a synchronize_net() in
netdev_rx_handler_unregister() to make sure that a rcu protected reader
has the guarantee to see a non NULL rx_handler_data.
The second way is better as it avoids an extra test in fast path.
Reported-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Jiri Pirko <jpirko@redhat.com>
Cc: Paul E. McKenney <paulmck@us.ibm.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
[ Upstream commit 14bc435ea54cb888409efb54fc6b76c13ef530e9 ]
According to the Datasheet (page 52):
15-12 Reserved
11-0 RXBC Receive Byte Count
This field indicates the present received frame byte size.
The code has a bug:
rxh = ks8851_rdreg32(ks, KS_RXFHSR);
rxstat = rxh & 0xffff;
rxlen = rxh >> 16; // BUG!!! 0xFFF mask should be applied
Signed-off-by: Max Nekludov <Max.Nekludov@us.elster.com>
[ Upstream commit a79ca223e029aa4f09abb337accf1812c900a800 ]
Signed-off-by: Hong Zhiguo <honkiko@gmail.com>
[ Upstream commit 188ab1b105c96656f6bcfb49d0d8bb1b1936b632 ]
Usage of pci-msi results in corrupted dma packet transfers to the host.
Reported-by: rebelyouth <rebelyouth.hacklab@gmail.com>
Cc: Huang, Xiong <xiong@qca.qualcomm.com>
Tested-by: Christian Sünkenberg <christian.suenkenberg@student.kit.edu>
restarting tx queue
To restart tx queue use netif_wake_queue() intead of netif_start_queue()
so that net schedule will restart transmission immediately which will
increase network performance while doing huge data transfers.
Reported-by: Dan Franke <dan.franke@schneider-electric.com>
Suggested-by: Sriramakrishnan A G <srk@ti.com>
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
[ Upstream commit 91c5746425aed8f7188a351f1224a26aa232e4b3 ]
Some network drivers use a non default hard_header_len
Transmitted skb should take into account dev->hard_header_len, or risk
crashes or expensive reallocations.
In the case of aoe, lets reserve MAX_HEADER bytes.
David reported a crash in defxx driver, solved by this patch.
Reported-by: David Oostdyk <daveo@ll.mit.edu>
Tested-by: David Oostdyk <daveo@ll.mit.edu>
Cc: Ed Cashin <ecashin@coraid.com>
[ Upstream commit ded34e0fe8fe8c2d595bfa30626654e4b87621e0 ]
As reported by Jan, and others over the past few years, there is a
race condition caused by unix_release setting the sock->sk pointer
to NULL before properly marking the socket as dead/orphaned. This
can cause a problem with the LSM hook security_unix_may_send() if
there is another socket attempting to write to this partially
released socket in between when sock->sk is set to NULL and it is
marked as dead/orphaned. This patch fixes this by only setting
sock->sk to NULL after the socket has been marked as dead; I also
take the opportunity to make unix_release_sock() a void function
as it only ever returned 0/success.
Dave, I think this one should go on the -stable pile.
Special thanks to Jan for coming up with a reproducer for this
problem.
Reported-by: Jan Stancek <jan.stancek@gmail.com>
Signed-off-by: Paul Moore <pmoore@redhat.com>
[ Upstream commits 73214f5d9f33b79918b1f7babddd5c8af28dd23d
and f1e79e208076ffe7bad97158275f1c572c04f5c7, the latter
adds an assertion to genetlink to prevent this from happening
again in the future. ]
The original name is too long.
Signed-off-by: Masatake YAMATO <yamato@redhat.com>
[ Upstream commit 4a7df340ed1bac190c124c1601bfc10cde9fb4fb ]
vlan_vid_del() could possibly free ->vlan_info after a RCU grace
period, however, we may still refer to the freed memory area
by 'grp' pointer. Found by code inspection.
This patch moves vlan_vid_del() as behind as possible.
Signed-off-by: Cong Wang <amwang@redhat.com>
Cc: Patrick McHardy <kaber@trash.net>
[ Upstream commit 7ebe183c6d444ef5587d803b64a1f4734b18c564 ]
On SACK reneging the sender immediately retransmits and forces a
timeout but disables Eifel (undo). If the (buggy) receiver does not
drop any packet this can trigger a false slow-start retransmit storm
driven by the ACKs of the original packets. This can be detected with
undo and TCP timestamps.
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
[ Upstream commit f4541d60a449afd40448b06496dcd510f505928e ]
A long standing problem with TSO is the fact that tcp_tso_should_defer()
rearms the deferred timer, while it should not.
Current code leads to following bad bursty behavior :
20:11:24.484333 IP A > B: . 297161:316921(19760) ack 1 win 119
20:11:24.484337 IP B > A: . ack 263721 win 1117
20:11:24.485086 IP B > A: . ack 265241 win 1117
20:11:24.485925 IP B > A: . ack 266761 win 1117
20:11:24.486759 IP B > A: . ack 268281 win 1117
20:11:24.487594 IP B > A: . ack 269801 win 1117
20:11:24.488430 IP B > A: . ack 271321 win 1117
20:11:24.489267 IP B > A: . ack 272841 win 1117
20:11:24.490104 IP B > A: . ack 274361 win 1117
20:11:24.490939 IP B > A: . ack 275881 win 1117
20:11:24.491775 IP B > A: . ack 277401 win 1117
20:11:24.491784 IP A > B: . 316921:332881(15960) ack 1 win 119
20:11:24.492620 IP B > A: . ack 278921 win 1117
20:11:24.493448 IP B > A: . ack 280441 win 1117
20:11:24.494286 IP B > A: . ack 281961 win 1117
20:11:24.495122 IP B > A: . ack 283481 win 1117
20:11:24.495958 IP B > A: . ack 285001 win 1117
20:11:24.496791 IP B > A: . ack 286521 win 1117
20:11:24.497628 IP B > A: . ack 288041 win 1117
20:11:24.498459 IP B > A: . ack 289561 win 1117
20:11:24.499296 IP B > A: . ack 291081 win 1117
20:11:24.500133 IP B > A: . ack 292601 win 1117
20:11:24.500970 IP B > A: . ack 294121 win 1117
20:11:24.501388 IP B > A: . ack 295641 win 1117
20:11:24.501398 IP A > B: . 332881:351881(19000) ack 1 win 119
While the expected behavior is more like :
20:19:49.259620 IP A > B: . 197601:202161(4560) ack 1 win 119
20:19:49.260446 IP B > A: . ack 154281 win 1212
20:19:49.261282 IP B > A: . ack 155801 win 1212
20:19:49.262125 IP B > A: . ack 157321 win 1212
20:19:49.262136 IP A > B: . 202161:206721(4560) ack 1 win 119
20:19:49.262958 IP B > A: . ack 158841 win 1212
20:19:49.263795 IP B > A: . ack 160361 win 1212
20:19:49.264628 IP B > A: . ack 161881 win 1212
20:19:49.264637 IP A > B: . 206721:211281(4560) ack 1 win 119
20:19:49.265465 IP B > A: . ack 163401 win 1212
20:19:49.265886 IP B > A: . ack 164921 win 1212
20:19:49.266722 IP B > A: . ack 166441 win 1212
20:19:49.266732 IP A > B: . 211281:215841(4560) ack 1 win 119
20:19:49.267559 IP B > A: . ack 167961 win 1212
20:19:49.268394 IP B > A: . ack 169481 win 1212
20:19:49.269232 IP B > A: . ack 171001 win 1212
20:19:49.269241 IP A > B: . 215841:221161(5320) ack 1 win 119
Cc: Yuchung Cheng <ycheng@google.com>
Cc: Van Jacobson <vanj@google.com>
Cc: Neal Cardwell <ncardwell@google.com>
Cc: Nandita Dukkipati <nanditad@google.com>
[ Upstream commit 74f9f42c1c1650e74fb464f76644c9041f996851 ]
The sky2 driver sets the Rx Upper Threshold for Pause Packet generation to a
wrong value which leads to only 2kB of RAM remaining space. This can lead to
Rx overflow errors even with activated flow-control.
Fix: We should increase the value to 8192/8
Signed-off-by: Mirko Lindner <mlindner@marvell.com>
Acked-by: Stephen Hemminger <stephen@networkplumber.org>
[ Upstream commit 9cfe8b156c21cf340b3a10ecb3022fbbc1c39185 ]
The sky2 driver doesn't count the Receive Overflows because the MAC
interrupt for this event is not set in the MAC's interrupt mask.
The MAC's interrupt mask is set only for Transmit FIFO Underruns.
Fix: The correct setting should be (GM_IS_TX_FF_UR | GM_IS_RX_FF_OR)
Otherwise the Receive Overflow event will not generate any interrupt.
The Receive Overflow interrupt is handled correctly
commit 613f04a0f51e6e68ac6fe571ab79da3c0a5eb4da upstream.
The latency tracers require the buffers to be in overwrite mode,
otherwise they get screwed up. Force the buffers to stay in overwrite
mode when latency tracers are enabled.
Added a flag_changed() method to the tracer structure to allow
the tracers to see what flags are being changed, and also be able
to prevent the change from happing.
[Backported for 3.4-stable. Re-added current_trace NULL checks; removed
allocated_snapshot field; adapted to tracing_trace_options_write without
trace_set_options.]
Signed-off-by: Lingzhu Xiang <lxiang@redhat.com>
Reviewed-by: CAI Qian <caiqian@redhat.com>
commit 69d34da2984c95b33ea21518227e1f9470f11d95 upstream.
Seems that the tracer flags have never been protected from
synchronous writes. Luckily, admins don't usually modify the
tracing flags via two different tasks. But if scripts were to
be used to modify them, then they could get corrupted.
Move the trace_types_lock that protects against tracers changing
to also protect the flags being set.
[Backported for 3.4, 3.0-stable. Moved return to after unlock.]
commit 90ba983f6889e65a3b506b30dc606aa9d1d46cd2 upstream.
A user who was using a 8TB+ file system and with a very large flexbg
size (> 65536) could cause the atomic_t used in the struct flex_groups
to overflow. This was detected by PaX security patchset:
http://forums.grsecurity.net/viewtopic.php?f=3&t=3289&p=12551#p12551
This bug was introduced in commit 9f24e4208f7e, so it's been around
since 2.6.30. :-(
Fix this by using an atomic64_t for struct orlav_stats's
free_clusters.
[Backported for 3.0-stable. Renamed free_clusters back to free_blocks;
fixed a few more atomic_read's of free_blocks left in 3.0.]
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Reviewed-by: Lukas Czerner <lczerner@redhat.com>
commit e971318bbed610e28bb3fde9d548e6aaf0a6b02e upstream.
Some firmware exhibits a bug where the same VariableName and
VendorGuid values are returned on multiple invocations of
GetNextVariableName(). See,
https://bugzilla.kernel.org/show_bug.cgi?id=47631
As a consequence of such a bug, Andre reports hitting the following
WARN_ON() in the sysfs code after updating the BIOS on his, "Gigabyte
Technology Co., Ltd. To be filled by O.E.M./Z77X-UD3H, BIOS F19e
11/21/2012)" machine,
[ 0.581554] EFI Variables Facility v0.08 2004-May-17
[ 0.584914] ------------[ cut here ]------------
[ 0.585639] WARNING: at /home/andre/linux/fs/sysfs/dir.c:536 sysfs_add_one+0xd4/0x100()
[ 0.586381] Hardware name: To be filled by O.E.M.
[ 0.587123] sysfs: cannot create duplicate filename '/firmware/efi/vars/SbAslBufferPtrVar-01f33c25-764d-43ea-aeea-6b5a41f3f3e8'
[ 0.588694] Modules linked in:
[ 0.589484] Pid: 1, comm: swapper/0 Not tainted 3.8.0+ #7
[ 0.590280] Call Trace:
[ 0.591066] [<ffffffff81208954>] ? sysfs_add_one+0xd4/0x100
[ 0.591861] [<ffffffff810587bf>] warn_slowpath_common+0x7f/0xc0
[ 0.592650] [<ffffffff810588bc>] warn_slowpath_fmt+0x4c/0x50
[ 0.593429] [<ffffffff8134dd85>] ? strlcat+0x65/0x80
[ 0.594203] [<ffffffff81208954>] sysfs_add_one+0xd4/0x100
[ 0.594979] [<ffffffff81208b78>] create_dir+0x78/0xd0
[ 0.595753] [<ffffffff81208ec6>] sysfs_create_dir+0x86/0xe0
[ 0.596532] [<ffffffff81347e4c>] kobject_add_internal+0x9c/0x220
[ 0.597310] [<ffffffff81348307>] kobject_init_and_add+0x67/0x90
[ 0.598083] [<ffffffff81584a71>] ? efivar_create_sysfs_entry+0x61/0x1c0
[ 0.598859] [<ffffffff81584b2b>] efivar_create_sysfs_entry+0x11b/0x1c0
[ 0.599631] [<ffffffff8158517e>] register_efivars+0xde/0x420
[ 0.600395] [<ffffffff81d430a7>] ? edd_init+0x2f5/0x2f5
[ 0.601150] [<ffffffff81d4315f>] efivars_init+0xb8/0x104
[ 0.601903] [<ffffffff8100215a>] do_one_initcall+0x12a/0x180
[ 0.602659] [<ffffffff81d05d80>] kernel_init_freeable+0x13e/0x1c6
[ 0.603418] [<ffffffff81d05586>] ? loglevel+0x31/0x31
[ 0.604183] [<ffffffff816a6530>] ? rest_init+0x80/0x80
[ 0.604936] [<ffffffff816a653e>] kernel_init+0xe/0xf0
[ 0.605681] [<ffffffff816ce7ec>] ret_from_fork+0x7c/0xb0
[ 0.606414] [<ffffffff816a6530>] ? rest_init+0x80/0x80
[ 0.607143] ---[ end trace 1609741ab737eb29 ]---
There's not much we can do to work around and keep traversing the
variable list once we hit this firmware bug. Our only solution is to
terminate the loop because, as Lingzhu reports, some machines get
stuck when they encounter duplicate names,
> I had an IBM System x3100 M4 and x3850 X5 on which kernel would
> get stuck in infinite loop creating duplicate sysfs files because,
> for some reason, there are several duplicate boot entries in nvram
> getting GetNextVariableName into a circle of iteration (with
> period > 2).
Also disable the workqueue, as efivar_update_sysfs_entries() uses
GetNextVariableName() to figure out which variables have been created
since the last iteration. That algorithm isn't going to work if
GetNextVariableName() returns duplicates. Note that we don't disable
EFI variable creation completely on the affected machines, it's just
that any pstore dump-* files won't appear in sysfs until the next
boot.
[Backported for 3.0-stable. Removed code related to pstore
workqueue but pulled in helper function variable_is_present
from a93bc0c; Moved the definition of __efivars to the top
for being referenced in variable_is_present.]
Reported-by: Andre Heider <a.heider@gmail.com>
Reported-by: Lingzhu Xiang <lxiang@redhat.com>
Tested-by: Lingzhu Xiang <lxiang@redhat.com>
Cc: Seiji Aguchi <seiji.aguchi@hds.com>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
commit ec50bd32f1672d38ddce10fb1841cbfda89cfe9a upstream.
It's not wise to assume VariableNameSize represents the length of
VariableName, as not all firmware updates VariableNameSize in the same
way (some don't update it at all if EFI_SUCCESS is returned). There
are even implementations out there that update VariableNameSize with
values that are both larger than the string returned in VariableName
and smaller than the buffer passed to GetNextVariableName(), which
resulted in the following bug report from Michael Schroeder,
> On HP z220 system (firmware version 1.54), some EFI variables are
> incorrectly named :
> ls -d /sys/firmware/efi/vars/*8be4d* | grep -v -- -8be returns
> /sys/firmware/efi/vars/dbxDefault-pport8be4df61-93ca-11d2-aa0d-00e098032b8c
> /sys/firmware/efi/vars/KEKDefault-pport8be4df61-93ca-11d2-aa0d-00e098032b8c
> /sys/firmware/efi/vars/SecureBoot-pport8be4df61-93ca-11d2-aa0d-00e098032b8c
> /sys/firmware/efi/vars/SetupMode-Information8be4df61-93ca-11d2-aa0d-00e098032b8c
The issue here is that because we blindly use VariableNameSize without
verifying its value, we can potentially read garbage values from the
buffer containing VariableName if VariableNameSize is larger than the
length of VariableName.
Since VariableName is a string, we can calculate its size by searching
for the terminating NULL character.
[Backported for 3.8-stable. Removed workqueue code added in
a93bc0c 3.9-rc1.]
Reported-by: Frederic Crozat <fcrozat@suse.com>
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
Cc: Josh Boyer <jwboyer@redhat.com>
Cc: Michael Schroeder <mls@suse.com>
Cc: Lee, Chun-Yi <jlee@suse.com>
Cc: Lingzhu Xiang <lxiang@redhat.com>
commit 4a35f83b2b7c6aae3fc0d1c4554fdc99dc33ad07 upstream.
Restore crtc->fb to the old framebuffer if queue_flip fails.
While at it, kill the pointless intel_fb temp variable.
v2: Update crtc->fb before queue_flip and restore it back
after a failure.
[Backported for 3.0-stable. Adjusted context. Please
cherry-pick commit 7317c75e66fce0c9f82fbe6f72f7e5256b315422
upstream before this patch as it provides necessary context
and fixes a panic.]
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
Reported-and-Tested-by: Mika Kuoppala <mika.kuoppala@intel.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit 7317c75e66fce0c9f82fbe6f72f7e5256b315422 upstream.
This fixes a race where we may try to finish a page flip and decrement
the refcount even if our vblank_get failed and we ended up with a
spurious flip pending interrupt.
Fixes https://bugs.freedesktop.org/show_bug.cgi?id=34211.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Signed-off-by: Keith Packard <keithp@keithp.com>
commit 64a817cfbded8674f345d1117b117f942a351a69 upstream.
Since we only enforce an upper bound, not a lower bound, a "negative"
length can get through here.
The symptom seen was a warning when we attempt to a kmalloc with an
excessive size.
Reported-by: Toralf Förster <toralf.foerster@gmx.de>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit c1681bf8a7b1b98edee8b862a42c19c4e53205fd upstream.
struct block_device lifecycle is defined by its inode (see fs/block_dev.c) -
block_device allocated first time we access /dev/loopXX and deallocated on
bdev_destroy_inode. When we create the device "losetup /dev/loopXX afile"
we want that block_device stay alive until we destroy the loop device
with "losetup -d".
But because we do not hold /dev/loopXX inode its counter goes 0, and
inode/bdev can be destroyed at any moment. Usually it happens at memory
pressure or when user drops inode cache (like in the test below). When later in
loop_clr_fd() we want to use bdev we have use-after-free error with following
stack:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000280
bd_set_size+0x10/0xa0
loop_clr_fd+0x1f8/0x420 [loop]
lo_ioctl+0x200/0x7e0 [loop]
lo_compat_ioctl+0x47/0xe0 [loop]
compat_blkdev_ioctl+0x341/0x1290
do_filp_open+0x42/0xa0
compat_sys_ioctl+0xc1/0xf20
do_sys_open+0x16e/0x1d0
sysenter_dispatch+0x7/0x1a
To prevent use-after-free we need to grab the device in loop_set_fd()
and put it later in loop_clr_fd().
The issue is reprodusible on current Linus head and v3.3. Here is the test:
dd if=/dev/zero of=loop.file bs=1M count=1
while [ true ]; do
losetup /dev/loop0 loop.file
echo 2 > /proc/sys/vm/drop_caches
losetup -d /dev/loop0
done
[ Doing bdgrab/bput in loop_set_fd/loop_clr_fd is safe, because every
time we call loop_set_fd() we check that loop_device->lo_state is
Lo_unbound and set it to Lo_bound If somebody will try to set_fd again
it will get EBUSY. And if we try to loop_clr_fd() on unbound loop
device we'll get ENXIO.
loop_set_fd/loop_clr_fd (and any other loop ioctl) is called under
loop_device->lo_ctl_mutex. ]
Signed-off-by: Anatol Pomozov <anatol.pomozov@gmail.com>
commit 6d1068b3a98519247d8ba4ec85cd40ac136dbdf9 upstream.
On hosts without the XSAVE support unprivileged local user can trigger
oops similar to the one below by setting X86_CR4_OSXSAVE bit in guest
cr4 register using KVM_SET_SREGS ioctl and later issuing KVM_RUN
ioctl.
invalid opcode: 0000 [#2] SMP
Modules linked in: tun ip6table_filter ip6_tables ebtable_nat ebtables
Pid: 24935, comm: zoog_kvm_monito Tainted: G D 3.2.0-3-686-pae
EIP: 0060:[<f8b9550c>] EFLAGS: 00210246 CPU: 0
EIP is at kvm_arch_vcpu_ioctl_run+0x92a/0xd13 [kvm]
EAX: 00000001 EBX: 000f387e ECX: 00000000 EDX: 00000000
ESI: 00000000 EDI: 00000000 EBP: ef5a0060 ESP: d7c63e70
DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068
Process zoog_kvm_monito (pid: 24935, ti=d7c62000 task=ed84a0c0
task.ti=d7c62000)
Stack:
00000001 f70a1200 f8b940a9 ef5a0060 00000000 00200202 f8769009 00000000
ef5a0060 000f387e eda5c020 8722f9c8 00015bae 00000000 ed84a0c0 ed84a0c0
c12bf02d 0000ae80 ef7f8740 fffffffb f359b740 ef5a0060 f8b85dc1 0000ae80
Call Trace:
[<f8b940a9>] ? kvm_arch_vcpu_ioctl_set_sregs+0x2fe/0x308 [kvm]
[<c12bfb44>] ? syscall_call+0x7/0xb
Code: 89 e8 e8 14 ee ff ff ba 00 00 04 00 89 e8 e8 98 48 ff ff 85 c0 74
1e 83 7d 48 00 75 18 8b 85 08 07 00 00 31 c9 8b 95 0c 07 00 00 <0f> 01
d1 c7 45 48 01 00 00 00 c7 45 1c 01 00 00 00 0f ae f0 89
EIP: [<f8b9550c>] kvm_arch_vcpu_ioctl_run+0x92a/0xd13 [kvm] SS:ESP
0068:d7c63e70
QEMU first retrieves the supported features via KVM_GET_SUPPORTED_CPUID
and then sets them later. So guest's X86_FEATURE_XSAVE should be masked
out on hosts without X86_FEATURE_XSAVE, making kvm_set_cr4 with
X86_CR4_OSXSAVE fail. Userspaces that allow specifying guest cpuid with
X86_FEATURE_XSAVE even on hosts that do not support it, might be
susceptible to this attack from inside the guest as well.
Allow setting X86_CR4_OSXSAVE bit only if host has XSAVE support.
Signed-off-by: Petr Matousek <pmatouse@redhat.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
commit 08dff7b7d629807dbb1f398c68dd9cd58dd657a1 upstream.
When online_pages() is called to add new memory to an empty zone, it
rebuilds all zone lists by calling build_all_zonelists(). But there's a
bug which prevents the new zone to be added to other nodes' zone lists.
online_pages() {
node_set_state(zone_to_nid(zone), N_HIGH_MEMORY)
Here the node of the zone is put into N_HIGH_MEMORY state after calling
build_all_zonelists(), but build_all_zonelists() only adds zones from
nodes in N_HIGH_MEMORY state to the fallback zone lists.
->__build_all_zonelists()
->build_zonelists()
->find_next_best_node()
->for_each_node_state(n, N_HIGH_MEMORY)
So memory in the new zone will never be used by other nodes, and it may
cause strange behavor when system is under memory pressure. So put node
into N_HIGH_MEMORY state before calling build_all_zonelists().
Signed-off-by: Jianguo Wu <wujianguo@huawei.com>
Signed-off-by: Jiang Liu <liuj97@gmail.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: Keping Chen <chenkeping@huawei.com>
commit f2ebd422f71cda9c791f76f85d2ca102ae34a1ed upstream.
kvm_set_irq() has an internal buffer of three irq routing entries, allowing
connecting a GSI to three IRQ chips or on MSI. However setup_routing_entry()
does not properly enforce this, allowing three irqchip routes followed by
an MSI route to overflow the buffer.
Fix by ensuring that an MSI entry is added to an empty list.
Signed-off-by: Avi Kivity <avi@redhat.com>
