2013-03-04Linux 3.0.68v3.0.68Greg Kroah-Hartman
2013-03-04staging: comedi: check s->async for poll(), read() and write()Ian Abbott
commit cc400e185c07c15a42d2635995f422de5b94b696 upstream. Some low-level comedi drivers (incorrectly) point `dev->read_subdev` or `dev->write_subdev` to a subdevice that does not support asynchronous commands. Comedi's poll(), read() and write() file operation handlers assume these subdevices do support asynchronous commands. In particular, they assume `s->async` is valid (where `s` points to the read or write subdevice), which it won't be if it has been set incorrectly. This can lead to a NULL pointer dereference. Check `s->async` is non-NULL in `comedi_poll()`, `comedi_read()` and `comedi_write()` to avoid the bug. Signed-off-by: Ian Abbott <abbotti@mev.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04staging: comedi: ni_labpc: set up command4 register *after* command3Ian Abbott
Commit 22056e2b46246d97ff0f7c6e21a77b8daa07f02c upstream. Tuomas <tvainikk _at_ gmail _dot_ com> reported problems getting meaningful output from a Lab-PC+ in differential mode for AI cmds, but AI insn reads gave correct readings. He tracked it down to two problems, one of which is addressed by this patch. It seems that writing to the command3 register after writing to the command4 register in `labpc_ai_cmd()` messes up the differential reference bit setting in the command4 register. Set up the command4 register after the command3 register (as in `labpc_ai_rinsn()`) to avoid the problem. Thanks to Tuomas for suggesting the fix. Signed-off-by: Ian Abbott <abbotti@mev.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04staging: comedi: ni_labpc: correct differential channel sequence for AI commandsIan Abbott
Commit 4c4bc25d0fa6beaf054c0b4c3b324487f266c820 upstream. Tuomas <tvainikk _at_ gmail _dot_ com> reported problems getting meaningful output from a Lab-PC+ in differential mode for AI cmds, but AI insn reads gave correct readings. He tracked it down to two problems, one of which is addressed by this patch. It seems the setting of the channel bits for particular scanning modes was incorrect for differential mode. (Only half the number of channels are available in differential mode; comedi refers to them as channels 0, 1, 2 and 3, but the hardware documentation refers to them as channels 0, 2, 4 and 6.) In differential mode, the setting of the channel enable bits in the command1 register should depend on whether the scan enable bit is set. Effectively, we need to double the comedi channel number when the scan enable bit is not set in differential mode. The scan enable bit gets set when the AI scan mode is `MODE_MULT_CHAN_UP` or `MODE_MULT_CHAN_DOWN`, and gets cleared when the AI scan mode is `MODE_SINGLE_CHAN` or `MODE_SINGLE_CHAN_INTERVAL`. The existing test for whether the comedi channel number needs to be doubled in differential mode is incorrect in `labpc_ai_cmd()`. This patch corrects the test. Thanks to Tuomas for suggesting the fix. Signed-off-by: Ian Abbott <abbotti@mev.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04s390/kvm: Fix store status for ACRS/FPRS fixJiri Slaby
In 3.0.67, commit 58c9ce6fad8e00d9726447f939fe7e78e2aec891 (s390/kvm: Fix store status for ACRS/FPRS), upstream commit 15bc8d8457875f495c59d933b05770ba88d1eacb, added a call to save_access_regs to save ACRS. But we do not have ARCS in kvm_run in 3.0 yet, so this results in: arch/s390/kvm/kvm-s390.c: In function 'kvm_s390_vcpu_store_status': arch/s390/kvm/kvm-s390.c:593: error: 'struct kvm_run' has no member named 's' Fix it by saving guest_acrs which is where ARCS are in 3.0. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04dca: check against empty dca_domains list before unregister provider fixJiri Slaby
In 3.0.67, commit 7a9a20ea77e7508c795dead9ab2f6c98a617762d (dca: check against empty dca_domains list before unregister provider), upstream commit c419fcfd071cf34ba00f9f65282583772d2655e7, added a fail path to unregister_dca_provider. It added there also a call to raw_spin_unlock_irqrestore. But in 3.0, the lock is not raw, so this results in: drivers/dca/dca-core.c: In function 'unregister_dca_provider': drivers/dca/dca-core.c:413: warning: passing argument 1 of '_raw_spin_unlock_irqrestore' from incompatible pointer type Fix it by calling spin_unlock_irqrestore properly. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04cgroup: fix exit() vs rmdir() raceLi Zefan
commit 71b5707e119653039e6e95213f00479668c79b75 upstream. In cgroup_exit() put_css_set_taskexit() is called without any lock, which might lead to accessing a freed cgroup: thread1 thread2 --------------------------------------------- exit() cgroup_exit() put_css_set_taskexit() atomic_dec(cgrp->count); rmdir(); /* not safe !! */ check_for_release(cgrp); rcu_read_lock() can be used to make sure the cgroup is alive. Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04cpuset: fix cpuset_print_task_mems_allowed() vs rename() raceLi Zefan
commit 63f43f55c9bbc14f76b582644019b8a07dc8219a upstream. rename() will change dentry->d_name. The result of this race can be worse than seeing partially rewritten name, but we might access a stale pointer because rename() will re-allocate memory to hold a longer name. It's safe in the protection of dentry->d_lock. v2: check NULL dentry before acquiring dentry lock. Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04x86/apic: Work around boot failure on HP ProLiant DL980 G7 Server systemsStoney Wang
commit cb214ede7657db458fd0b2a25ea0b28dbf900ebc upstream. When a HP ProLiant DL980 G7 Server boots a regular kernel, there will be intermittent lost interrupts which could result in a hang or (in extreme cases) data loss. The reason is that this system only supports x2apic physical mode, while the kernel boots with a logical-cluster default setting. This bug can be worked around by specifying the "x2apic_phys" or "nox2apic" boot option, but we want to handle this system without requiring manual workarounds. The BIOS sets ACPI_FADT_APIC_PHYSICAL in FADT table. As all apicids are smaller than 255, BIOS need to pass the control to the OS with xapic mode, according to x2apic-spec, chapter 2.9. Current code handle x2apic when BIOS pass with xapic mode enabled: When user specifies x2apic_phys, or FADT indicates PHYSICAL: 1. During madt oem check, apic driver is set with xapic logical or xapic phys driver at first. 2. enable_IR_x2apic() will enable x2apic_mode. 3. if user specifies x2apic_phys on the boot line, x2apic_phys_probe() will install the correct x2apic phys driver and use x2apic phys mode. Otherwise it will skip the driver will let x2apic_cluster_probe to take over to install x2apic cluster driver (wrong one) even though FADT indicates PHYSICAL, because x2apic_phys_probe does not check FADT PHYSICAL. Add checking x2apic_fadt_phys in x2apic_phys_probe() to fix the problem. Signed-off-by: Stoney Wang <song-bo.wang@hp.com> [ updated the changelog and simplified the code ] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Zhang Lin-Bao <Linbao.zhang@hp.com> [ make a patch specially for 3.0.66] Link: http://lkml.kernel.org/r/1360263182-16226-1-git-send-email-yinghai@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04x86: Do not leak kernel page mapping locationsKees Cook
commit e575a86fdc50d013bf3ad3aa81d9100e8e6cc60d upstream. Without this patch, it is trivial to determine kernel page mappings by examining the error code reported to dmesg[1]. Instead, declare the entire kernel memory space as a violation of a present page. Additionally, since show_unhandled_signals is enabled by default, switch branch hinting to the more realistic expectation, and unobfuscate the setting of the PF_PROT bit to improve readability. [1] http://vulnfactory.org/blog/2013/02/06/a-linux-memory-trick/ Reported-by: Dan Rosenberg <dan.j.rosenberg@gmail.com> Suggested-by: Brad Spengler <spender@grsecurity.net> Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: H. Peter Anvin <hpa@zytor.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20130207174413.GA12485@www.outflux.net Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: CAI Qian <caiqian@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04unbreak automounter support on 64-bit kernel with 32-bit userspace (v2)Helge Deller
commit 4f4ffc3a5398ef9bdbb32db04756d7d34e356fcf upstream. automount-support is broken on the parisc architecture, because the existing #if list does not include a check for defined(__hppa__). The HPPA (parisc) architecture is similiar to other 64bit Linux targets where we have to define autofs_wqt_t (which is passed back and forth to user space) as int type which has a size of 32bit across 32 and 64bit kernels. During the discussion on the mailing list, H. Peter Anvin suggested to invert the #if list since only specific platforms (specifically those who do not have a 32bit userspace, like IA64 and Alpha) should have autofs_wqt_t as unsigned long type. This suggestion is probably the best way to go, since Arm64 (and maybe others?) seems to have a non-working automounter. So in the long run even for other new upcoming architectures this inverted check seem to be the best solution, since it will not require them to change this #if again (unless they are 64bit only). Signed-off-by: Helge Deller <deller@gmx.de> Acked-by: H. Peter Anvin <hpa@zytor.com> Acked-by: Ian Kent <raven@themaw.net> Acked-by: Catalin Marinas <catalin.marinas@arm.com> CC: James Bottomley <James.Bottomley@HansenPartnership.com> CC: Rolf Eike Beer <eike-kernel@sf-tec.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04wake_up_process() should be never used to wakeup a TASK_STOPPED/TRACED taskOleg Nesterov
Upstream commit 9067ac85d533651b98c2ff903182a20cbb361fcb. wake_up_process() should never wakeup a TASK_STOPPED/TRACED task. Change it to use TASK_NORMAL and add the WARN_ON(). TASK_ALL has no other users, probably can be killed. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04ptrace: ensure arch_ptrace/ptrace_request can never race with SIGKILLOleg Nesterov
Upstream commit 9899d11f654474d2d54ea52ceaa2a1f4db3abd68. putreg() assumes that the tracee is not running and pt_regs_access() can safely play with its stack. However a killed tracee can return from ptrace_stop() to the low-level asm code and do RESTORE_REST, this means that debugger can actually read/modify the kernel stack until the tracee does SAVE_REST again. set_task_blockstep() can race with SIGKILL too and in some sense this race is even worse, the very fact the tracee can be woken up breaks the logic. As Linus suggested we can clear TASK_WAKEKILL around the arch_ptrace() call, this ensures that nobody can ever wakeup the tracee while the debugger looks at it. Not only this fixes the mentioned problems, we can do some cleanups/simplifications in arch_ptrace() paths. Probably ptrace_unfreeze_traced() needs more callers, for example it makes sense to make the tracee killable for oom-killer before access_process_vm(). While at it, add the comment into may_ptrace_stop() to explain why ptrace_stop() still can't rely on SIGKILL and signal_pending_state(). Reported-by: Salman Qazi <sqazi@google.com> Reported-by: Suleiman Souhlal <suleiman@google.com> Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04ptrace: introduce signal_wake_up_state() and ptrace_signal_wake_up()Oleg Nesterov
Upstream commit 910ffdb18a6408e14febbb6e4b6840fd2c928c82. Cleanup and preparation for the next change. signal_wake_up(resume => true) is overused. None of ptrace/jctl callers actually want to wakeup a TASK_WAKEKILL task, but they can't specify the necessary mask. Turn signal_wake_up() into signal_wake_up_state(state), reintroduce signal_wake_up() as a trivial helper, and add ptrace_signal_wake_up() which adds __TASK_TRACED. This way ptrace_signal_wake_up() can work "inside" ptrace_request() even if the tracee doesn't have the TASK_WAKEKILL bit set. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04vhost: fix length for cross region descriptorMichael S. Tsirkin
commit bd97120fc3d1a11f3124c7c9ba1d91f51829eb85 upstream. If a single descriptor crosses a region, the second chunk length should be decremented by size translated so far, instead it includes the full descriptor length. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Acked-by: Jason Wang <jasowang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04svcrpc: make svc_age_temp_xprts enqueue under sv_lockJ. Bruce Fields
commit e75bafbff2270993926abcc31358361db74a9bc2 upstream. svc_age_temp_xprts expires xprts in a two-step process: first it takes the sv_lock and moves the xprts to expire off their server-wide list (sv_tempsocks or sv_permsocks) to a local list. Then it drops the sv_lock and enqueues and puts each one. I see no reason for this: svc_xprt_enqueue() will take sp_lock, but the sv_lock and sp_lock are not otherwise nested anywhere (and documentation at the top of this file claims it's correct to nest these with sp_lock inside.) Tested-by: Jason Tibbitts <tibbs@math.uh.edu> Tested-by: Paweł Sikora <pawel.sikora@agmk.net> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04ext4: fix race in ext4_mb_add_n_trim()Niu Yawei
commit f1167009711032b0d747ec89a632a626c901a1ad upstream. In ext4_mb_add_n_trim(), lg_prealloc_lock should be taken when changing the lg_prealloc_list. Signed-off-by: Niu Yawei <yawei.niu@intel.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04media: rc: unlock on error in show_protocols()Dan Carpenter
commit 30ebc5e44d057a1619ad63fe32c8c1670c37c4b8 upstream. We recently introduced a new return -ENODEV in this function but we need to unlock before returning. [mchehab@redhat.com: found two patches with the same fix. Merged SOB's/acks into one patch] Acked-by: Herton R. Krzesinski <herton.krzesinski@canonical.com> Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Douglas Bagnall <douglas@paradise.net.nz> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04sysctl: fix null checking in bin_dn_node_address()Xi Wang
commit df1778be1a33edffa51d094eeda87c858ded6560 upstream. The null check of `strchr() + 1' is broken, which is always non-null, leading to OOB read. Instead, check the result of strchr(). Signed-off-by: Xi Wang <xi.wang@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04firewire: add minor number range check to fw_device_init()Tejun Heo
commit 3bec60d511179853138836ae6e1b61fe34d9235f upstream. fw_device_init() didn't check whether the allocated minor number isn't too large. Fail if it goes overflows MINORBITS. Signed-off-by: Tejun Heo <tj@kernel.org> Suggested-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04idr: fix a subtle bug in idr_get_next()Tejun Heo
commit 6cdae7416a1c45c2ce105a78187d9b7e8feb9e24 upstream. The iteration logic of idr_get_next() is borrowed mostly verbatim from idr_for_each(). It walks down the tree looking for the slot matching the current ID. If the matching slot is not found, the ID is incremented by the distance of single slot at the given level and repeats. The implementation assumes that during the whole iteration id is aligned to the layer boundaries of the level closest to the leaf, which is true for all iterations starting from zero or an existing element and thus is fine for idr_for_each(). However, idr_get_next() may be given any point and if the starting id hits in the middle of a non-existent layer, increment to the next layer will end up skipping the same offset into it. For example, an IDR with IDs filled between [64, 127] would look like the following. [ 0 64 ... ] /----/ | | | NULL [ 64 ... 127 ] If idr_get_next() is called with 63 as the starting point, it will try to follow down the pointer from 0. As it is NULL, it will then try to proceed to the next slot in the same level by adding the slot distance at that level which is 64 - making the next try 127. It goes around the loop and finds and returns 127 skipping [64, 126]. Note that this bug also triggers in idr_for_each_entry() loop which deletes during iteration as deletions can make layers go away leaving the iteration with unaligned ID into missing layers. Fix it by ensuring proceeding to the next slot doesn't carry over the unaligned offset - ie. use round_up(id + 1, slot_distance) instead of id += slot_distance. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: David Teigland <teigland@redhat.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04xen-blkback: do not leak mode propertyJan Beulich
commit 9d092603cc306ee6edfe917bf9ab8beb5f32d7bc upstream. "be->mode" is obtained from xenbus_read(), which does a kmalloc() for the message body. The short string is never released, so do it along with freeing "be" itself, and make sure the string isn't kept when backend_changed() doesn't complete successfully (which made it desirable to slightly re-structure that function, so that the error cleanup can be done in one place). Reported-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Jan Beulich <jbeulich@suse.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04ocfs2: ac->ac_allow_chain_relink=0 won't disable group relinkXiaowei.Hu
commit 309a85b6861fedbb48a22d45e0e079d1be993b3a upstream. ocfs2_block_group_alloc_discontig() disables chain relink by setting ac->ac_allow_chain_relink = 0 because it grabs clusters from multiple cluster groups. It doesn't keep the credits for all chain relink,but ocfs2_claim_suballoc_bits overrides this in this call trace: ocfs2_block_group_claim_bits()->ocfs2_claim_clusters()-> __ocfs2_claim_clusters()->ocfs2_claim_suballoc_bits() ocfs2_claim_suballoc_bits set ac->ac_allow_chain_relink = 1; then call ocfs2_search_chain() one time and disable it again, and then we run out of credits. Fix is to allow relink by default and disable it in ocfs2_block_group_alloc_discontig. Without this patch, End-users will run into a crash due to run out of credits, backtrace like this: RIP: 0010:[<ffffffffa0808b14>] [<ffffffffa0808b14>] jbd2_journal_dirty_metadata+0x164/0x170 [jbd2] RSP: 0018:ffff8801b919b5b8 EFLAGS: 00010246 RAX: 0000000000000000 RBX: ffff88022139ddc0 RCX: ffff880159f652d0 RDX: ffff880178aa3000 RSI: ffff880159f652d0 RDI: ffff880087f09bf8 RBP: ffff8801b919b5e8 R08: 0000000000000000 R09: 0000000000000000 R10: 0000000000001e00 R11: 00000000000150b0 R12: ffff880159f652d0 R13: ffff8801a0cae908 R14: ffff880087f09bf8 R15: ffff88018d177800 FS: 00007fc9b0b6b6e0(0000) GS:ffff88022fd40000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 000000000040819c CR3: 0000000184017000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process dd (pid: 9945, threadinfo ffff8801b919a000, task ffff880149a264c0) Call Trace: ocfs2_journal_dirty+0x2f/0x70 [ocfs2] ocfs2_relink_block_group+0x111/0x480 [ocfs2] ocfs2_search_chain+0x455/0x9a0 [ocfs2] ... Signed-off-by: Xiaowei.Hu <xiaowei.hu@oracle.com> Reviewed-by: Srinivas Eeda <srinivas.eeda@oracle.com> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04target: Add missing mapped_lun bounds checking during make_mappedlun setupNicholas Bellinger
commit fbbf8555a986ed31e54f006b6cc637ea4ff1425b upstream. This patch adds missing bounds checking for the configfs provided mapped_lun value during target_fabric_make_mappedlun() setup ahead of se_lun_acl initialization. This addresses a potential OOPs when using a mapped_lun value that exceeds the hardcoded TRANSPORT_MAX_LUNS_PER_TPG-1 value within se_node_acl->device_list[]. Reported-by: Jan Engelhardt <jengelh@inai.de> Cc: Jan Engelhardt <jengelh@inai.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04x86: Make sure we can boot in the case the BDA contains pure garbageH. Peter Anvin
commit 7c10093692ed2e6f318387d96b829320aa0ca64c upstream. On non-BIOS platforms it is possible that the BIOS data area contains garbage instead of being zeroed or something equivalent (firmware people: we are talking of 1.5K here, so please do the sane thing.) We need on the order of 20-30K of low memory in order to boot, which may grow up to < 64K in the future. We probably want to avoid the lowest of the low memory. At the same time, it seems extremely unlikely that a legitimate EBDA would ever reach down to the 128K (which would require it to be over half a megabyte in size.) Thus, pick 128K as the cutoff for "this is insane, ignore." We may still end up reserving a bunch of extra memory on the low megabyte, but that is not really a major issue these days. In the worst case we lose 512K of RAM. This code really should be merged with trim_bios_range() in arch/x86/kernel/setup.c, but that is a bigger patch for a later merge window. Reported-by: Darren Hart <dvhart@linux.intel.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Cc: Matt Fleming <matt.fleming@intel.com> Link: http://lkml.kernel.org/n/tip-oebml055yyfm8yxmria09rja@git.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04doc, kernel-parameters: Document 'console=hvc<n>'Konrad Rzeszutek Wilk
commit a2fd6419174470f5ae6383f5037d0ee21ed9833f upstream. Both the PowerPC hypervisor and Xen hypervisor can utilize the hvc driver. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Link: http://lkml.kernel.org/r/1361825650-14031-3-git-send-email-konrad.wilk@oracle.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04doc, xen: Mention 'earlyprintk=xen' in the documentation.Konrad Rzeszutek Wilk
commit 2482a92e7d17187301d7313cfe5021b13393a0b4 upstream. The earlyprintk for Xen PV guests utilizes a simple hypercall (console_io) to provide output to Xen emergency console. Note that the Xen hypervisor should be booted with 'loglevel=all' to output said information. Reported-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Link: http://lkml.kernel.org/r/1361825650-14031-2-git-send-email-konrad.wilk@oracle.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04ftrace: Call ftrace cleanup module notifier after all other notifiersSteven Rostedt (Red Hat)
commit 8c189ea64eea01ca20d102ddb74d6936dd16c579 upstream. Commit: c1bf08ac "ftrace: Be first to run code modification on modules" changed ftrace module notifier's priority to INT_MAX in order to process the ftrace nops before anything else could touch them (namely kprobes). This was the correct thing to do. Unfortunately, the ftrace module notifier also contains the ftrace clean up code. As opposed to the set up code, this code should be run *after* all the module notifiers have run in case a module is doing correct clean-up and unregisters its ftrace hooks. Basically, ftrace needs to do clean up on module removal, as it needs to know about code being removed so that it doesn't try to modify that code. But after it removes the module from its records, if a ftrace user tries to remove a probe, that removal will fail due as the record of that code segment no longer exists. Nothing really bad happens if the probe removal is called after ftrace did the clean up, but the ftrace removal function will return an error. Correct code (such as kprobes) will produce a WARN_ON() if it fails to remove the probe. As people get annoyed by frivolous warnings, it's best to do the ftrace clean up after everything else. By splitting the ftrace_module_notifier into two notifiers, one that does the module load setup that is run at high priority, and the other that is called for module clean up that is run at low priority, the problem is solved. Reported-by: Frank Ch. Eigler <fche@redhat.com> Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04posix-timer: Don't call idr_find() with out-of-range IDTejun Heo
commit e182bb38d7db7494fa5dcd82da17fe0dedf60ecf upstream. When idr_find() was fed a negative ID, it used to look up the ID ignoring the sign bit before recent ("idr: remove MAX_IDR_MASK and move left MAX_IDR_* into idr.c") patch. Now a negative ID triggers a WARN_ON_ONCE(). __lock_timer() feeds timer_id from userland directly to idr_find() without sanitizing it which can trigger the above malfunctions. Add a range check on @timer_id before invoking idr_find() in __lock_timer(). While timer_t is defined as int by all archs at the moment, Andrew worries that it may be defined as a larger type later on. Make the test cover larger integers too so that it at least is guaranteed to not return the wrong timer. Note that WARN_ON_ONCE() in idr_find() on id < 0 is transitional precaution while moving away from ignoring MSB. Once it's gone we can remove the guard as long as timer_t isn't larger than int. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Sasha Levin <sasha.levin@oracle.com> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/20130220232412.GL3570@htj.dyndns.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04iommu/amd: Initialize device table after dma_opsJoerg Roedel
commit f528d980c17b8714aedc918ba86e058af914d66b upstream. When dma_ops are initialized the unity mappings are created. The init_device_table_dma() function makes sure DMA from all devices is blocked by default. This opens a short window in time where DMA to unity mapped regions is blocked by the IOMMU. Make sure this does not happen by initializing the device table after dma_ops. Signed-off-by: Joerg Roedel <joro@8bytes.org> Signed-off-by: Shuah Khan <shuah.khan@hp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04quota: autoload the quota_v2 module for QFMT_VFS_V1 quota formatTheodore Ts'o
commit c3ad83d9efdfe6a86efd44945a781f00c879b7b4 upstream. Otherwise, ext4 file systems with the quota featured enable will get a very confusing "No such process" error message if the quota code is built as a module and the quota_v2 module has not been loaded. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Reviewed-by: Carlos Maiolino <cmaiolino@redhat.com> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28Linux 3.0.67v3.0.67Greg Kroah-Hartman
2013-02-28USB: usb-storage: unusual_devs update for Super TOP SATA bridgeJosh Boyer
commit 18e03310b5caa6d11c1a8c61b982c37047693fba upstream. The current entry in unusual_cypress.h for the Super TOP SATA bridge devices seems to be causing corruption on newer revisions of this device. This has been reported in Arch Linux and Fedora. The original patch was tested on devices with bcdDevice of 1.60, whereas the newer devices report bcdDevice as 2.20. Limit the UNUSUAL_DEV entry to devices less than 2.20. This fixes https://bugzilla.redhat.com/show_bug.cgi?id=909591 The Arch Forum post on this is here: https://bbs.archlinux.org/viewtopic.php?id=152011 Reported-by: Carsten S. <carsteniq@yahoo.com> Tested-by: Carsten S. <carsteniq@yahoo.com> Signed-off-by: Josh Boyer <jwboyer@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28USB: storage: properly handle the endian issues of idProductfangxiaozhi
commit cd060956c5e97931c3909e4a808508469c0bb9f6 upstream. 1. The idProduct is little endian, so make sure its value to be compatible with the current CPU. Make no break on big endian processors. Signed-off-by: fangxiaozhi <huananhu@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28USB: ehci-omap: Fix autoloading of moduleRoger Quadros
commit 04753523266629b1cd0518091da1658755787198 upstream. The module alias should be "ehci-omap" and not "omap-ehci" to match the platform device name. The omap-ehci module should now autoload correctly. Signed-off-by: Roger Quadros <rogerq@ti.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28USB: option: add Huawei "ACM" devices using protocol = vendorBjørn Mork
commit 1f3f687722fd9b29a0c2a85b4844e3b2a3585c63 upstream. The USB device descriptor of one identity presented by a few Huawei morphing devices have serial functions with class codes 02/02/ff, indicating CDC ACM with a vendor specific protocol. This combination is often used for MSFT RNDIS functions, and the CDC ACM class driver will therefore ignore such functions. The CDC ACM class driver cannot support functions with only 2 endpoints. The underlying serial functions of these modems are also believed to be the same as for alternate device identities already supported by the option driver. Letting the same driver handle these functions independently of the current identity ensures consistent handling and user experience. There is no need to blacklist these devices in the rndis_host driver. Huawei serial functions will either have only 2 endpoints or a CDC ACM functional descriptor with bmCapabilities != 0, making them correctly ignored as "non RNDIS" by that driver. Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28USB: option: add Yota / Megafon M100-1 4g modemBjørn Mork
commit cd565279e51bedee1b2988e84f9b3bef485adeb6 upstream. Interface layout: 00 CD-ROM 01 debug COM port 02 AP control port 03 modem 04 usb-ethernet Bus=01 Lev=02 Prnt=02 Port=01 Cnt=02 Dev#= 4 Spd=480 MxCh= 0 D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1 P: Vendor=0408 ProdID=ea42 Rev= 0.00 S: Manufacturer=Qualcomm, Incorporated S: Product=Qualcomm CDMA Technologies MSM S: SerialNumber=353568051xxxxxx C:* #Ifs= 5 Cfg#= 1 Atr=e0 MxPwr=500mA I:* If#= 0 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms I:* If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none) E: Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms I:* If#= 2 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none) E: Ad=83(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms E: Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms I:* If#= 3 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none) E: Ad=84(I) Atr=03(Int.) MxPS= 64 Ivl=2ms E: Ad=85(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms E: Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms I:* If#= 4 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none) E: Ad=86(I) Atr=03(Int.) MxPS= 64 Ivl=2ms E: Ad=87(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms E: Ad=05(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28USB: option: add and update Alcatel modemsBjørn Mork
commit f8f0302bbcbd1b14655bef29f6996a2152be559d upstream. Adding three currently unsupported modems based on information from .inf driver files: Diag VID_1BBB&PID_0052&MI_00 AGPS VID_1BBB&PID_0052&MI_01 VOICE VID_1BBB&PID_0052&MI_02 AT VID_1BBB&PID_0052&MI_03 Modem VID_1BBB&PID_0052&MI_05 wwan VID_1BBB&PID_0052&MI_06 Diag VID_1BBB&PID_00B6&MI_00 AT VID_1BBB&PID_00B6&MI_01 Modem VID_1BBB&PID_00B6&MI_02 wwan VID_1BBB&PID_00B6&MI_03 Diag VID_1BBB&PID_00B7&MI_00 AGPS VID_1BBB&PID_00B7&MI_01 VOICE VID_1BBB&PID_00B7&MI_02 AT VID_1BBB&PID_00B7&MI_03 Modem VID_1BBB&PID_00B7&MI_04 wwan VID_1BBB&PID_00B7&MI_05 Updating the blacklist info for the X060S_X200 and X220_X500D, reserving interfaces for a wwan driver, based on wwan VID_1BBB&PID_0000&MI_04 wwan VID_1BBB&PID_0017&MI_06 Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28dca: check against empty dca_domains list before unregister providerMaciej Sosnowski
commit c419fcfd071cf34ba00f9f65282583772d2655e7 upstream. When providers get blocked unregister_dca_providers() is called ending up with dca_providers and dca_domain lists emptied. Dca should be prevented from trying to unregister any provider if dca_domain list is found empty. Reported-by: Jiang Liu <jiang.liu@huawei.com> Tested-by: Gaohuai Han <hangaohuai@huawei.com> Signed-off-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: Dan Williams <djbw@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28ipv6: use a stronger hash for tcpEric Dumazet
[ Upstream commit 08dcdbf6a7b9d14c2302c5bd0c5390ddf122f664 ] It looks like its possible to open thousands of TCP IPv6 sessions on a server, all landing in a single slot of TCP hash table. Incoming packets have to lookup sockets in a very long list. We should hash all bits from foreign IPv6 addresses, using a salt and hash mix, not a simple XOR. inet6_ehashfn() can also separately use the ports, instead of xoring them. Reported-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Yuchung Cheng <ycheng@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28ipv4: fix a bug in ping_err().Li Wei
[ Upstream commit b531ed61a2a2a77eeb2f7c88b49aa5ec7d9880d8 ] We should get 'type' and 'code' from the outer ICMP header. Signed-off-by: Li Wei <lw@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28xen-netback: cancel the credit timer when taking the vif downDavid Vrabel
[ Upstream commit 3e55f8b306cf305832a4ac78aa82e1b40e818ece ] If the credit timer is left armed after calling xen_netbk_remove_xenvif(), then it may fire and attempt to schedule the vif which will then oops as vif->netbk == NULL. This may happen both in the fatal error path and during normal disconnection from the front end. The sequencing during shutdown is critical to ensure that: a) vif->netbk doesn't become unexpectedly NULL; and b) the net device/vif is not freed. 1. Mark as unschedulable (netif_carrier_off()). 2. Synchronously cancel the timer. 3. Remove the vif from the schedule list. 4. Remove it from it netback thread group. 5. Wait for vif->refcnt to become 0. Signed-off-by: David Vrabel <david.vrabel@citrix.com> Acked-by: Ian Campbell <ian.campbell@citrix.com> Reported-by: Christopher S. Aker <caker@theshore.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28xen-netback: correctly return errors from netbk_count_requests()David Vrabel
[ Upstream commit 35876b5ffc154c357476b2c3bdab10feaf4bd8f0 ] netbk_count_requests() could detect an error, call netbk_fatal_tx_error() but return 0. The vif may then be used afterwards (e.g., in a call to netbk_tx_error(). Since netbk_fatal_tx_error() could set vif->refcnt to 1, the vif may be freed immediately after the call to netbk_fatal_tx_error() (e.g., if the vif is also removed). Netback thread Xenwatch thread ------------------------------------------- netbk_fatal_tx_err() netback_remove() xenvif_disconnect() ... free_netdev() netbk_tx_err() Oops! Signed-off-by: Wei Liu <wei.liu2@citrix.com> Signed-off-by: Jan Beulich <JBeulich@suse.com> Signed-off-by: David Vrabel <david.vrabel@citrix.com> Reported-by: Christopher S. Aker <caker@theshore.net> Acked-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28bridge: set priority of STP packetsStephen Hemminger
[ Upstream commit 547b4e718115eea74087e28d7fa70aec619200db ] Spanning Tree Protocol packets should have always been marked as control packets, this causes them to get queued in the high prirority FIFO. As Radia Perlman mentioned in her LCA talk, STP dies if bridge gets overloaded and can't communicate. This is a long-standing bug back to the first versions of Linux bridge. Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28fb: Yet another band-aid for fixing lockdep messTakashi Iwai
commit e93a9a868792ad71cdd09d75e5a02d8067473c4e upstream. I've still got lockdep warnings even after Alan's patch, and it seems that yet more band aids are required to paper over similar paths for unbind_con_driver() and unregister_con_driver(). After this hack, lockdep warnings are finally gone. Signed-off-by: Takashi Iwai <tiwai@suse.de> Cc: Alan Cox <alan@linux.intel.com> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Jiri Kosina <jkosina@suse.cz> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28fb: rework locking to fix lock ordering on takeoverAlan Cox
commit 50e244cc793d511b86adea24972f3a7264cae114 upstream. Adjust the console layer to allow a take over call where the caller already holds the locks. Make the fb layer lock in order. This is partly a band aid, the fb layer is terminally confused about the locking rules it uses for its notifiers it seems. [akpm@linux-foundation.org: remove stray non-ascii char, tidy comment] [akpm@linux-foundation.org: export do_take_over_console()] [airlied: cleanup another non-ascii char] Signed-off-by: Alan Cox <alan@linux.intel.com> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Jiri Kosina <jkosina@suse.cz> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28fbcon: don't lose the console font across generic->chip driver switchDave Airlie
commit ae1287865f5361fa138d4d3b1b6277908b54eac9 upstream. If grub2 loads efifb/vesafb, then when systemd starts it can set the console font on that framebuffer device, however when we then load the native KMS driver, the first thing it does is tear down the generic framebuffer driver. The thing is the generic code is doing the right thing, it frees the font because otherwise it would leak memory. However we can assume that if you are removing the generic firmware driver (vesa/efi/offb), that a new driver *should* be loading soon after, so we effectively leak the font. However the old code left a dangling pointer in vc->vc_font.data and we can now reuse that dangling pointer to load the font into the new driver, now that we aren't freeing it. Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=892340 Signed-off-by: Dave Airlie <airlied@redhat.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28pcmcia/vrc4171: Add missing spinlock initJean Delvare
commit 811af9723859884f2f771f3174f3ddedab7c53b5 upstream. It doesn't seem this spinlock was properly initialized. This bug was introduced by commit 7a410e8d4d97457c8c381e2de9cdc7bd3306badc. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28Purge existing TLB entries in set_pte_at and ptep_set_wrprotectJohn David Anglin
commit 7139bc1579901b53db7e898789e916ee2fb52d78 upstream. This patch goes a long way toward fixing the minifail bug, and it  significantly improves the stability of SMP machines such as the rp3440.  When write  protecting a page for COW, we need to purge the existing translation.  Otherwise, the COW break doesn't occur as expected because the TLB may still have a stale entry which allows writes. [jejb: fix up checkpatch errors] Signed-off-by: John David Anglin <dave.anglin@bell.net> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28powerpc/kexec: Disable hard IRQ before kexecPhileas Fogg
commit 8520e443aa56cc157b015205ea53e7b9fc831291 upstream. Disable hard IRQ before kexec a new kernel image. Not doing it can result in corrupted data in the memory segments reserved for the new kernel. Signed-off-by: Phileas Fogg <phileas-fogg@mail.ru> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
