2013-02-17Linux 3.0.65v3.0.65Greg Kroah-Hartman
2013-02-17igb: Remove artificial restriction on RQDPC stat readingAlexander Duyck
commit ae1c07a6b7ced6c0c94c99e3b53f4e7856fa8bff upstream. For some reason the reading of the RQDPC register was being artificially limited to 4K. Instead of limiting the value we should read the value and add the full amount. Otherwise this can lead to a misleading number of dropped packets when the actual value is in fact much higher. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Cc: Vinson Lee <vlee@twitter.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-17PCI/PM: Clean up PME state when removing a deviceRafael J. Wysocki
commit 249bfb83cf8ba658955f0245ac3981d941f746ee upstream. Devices are added to pci_pme_list when drivers use pci_enable_wake() or pci_wake_from_d3(), but they aren't removed from the list unless the driver explicitly disables wakeup. Many drivers never disable wakeup, so their devices remain on the list even after they are removed, e.g., via hotplug. A subsequent PME poll will oops when it tries to touch the device. This patch disables PME# on a device before removing it, which removes the device from pci_pme_list. This is safe even if the device never had PME# enabled. This oops can be triggered by unplugging a Thunderbolt ethernet adapter on a Macbook Pro, as reported by Daniel below. [bhelgaas: changelog] Reference: http://lkml.kernel.org/r/CAMVG2svG21yiM1wkH4_2pen2n+cr2-Zv7TbH3Gj+8MwevZjDbw@mail.gmail.com Reported-and-tested-by: Daniel J Blueman <daniel@quora.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-17x86/xen: don't assume %ds is usable in xen_iret for 32-bit PVOPS.Jan Beulich
commit 13d2b4d11d69a92574a55bfd985cfb0ca77aebdc upstream. This fixes CVE-2013-0228 / XSA-42 Drew Jones while working on CVE-2013-0190 found that that unprivileged guest user in 32bit PV guest can use to crash the > guest with the panic like this: ------------- general protection fault: 0000 [#1] SMP last sysfs file: /sys/devices/vbd-51712/block/xvda/dev Modules linked in: sunrpc ipt_REJECT nf_conntrack_ipv4 nf_defrag_ipv4 iptable_filter ip_tables ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 xt_state nf_conntrack ip6table_filter ip6_tables ipv6 xen_netfront ext4 mbcache jbd2 xen_blkfront dm_mirror dm_region_hash dm_log dm_mod [last unloaded: scsi_wait_scan] Pid: 1250, comm: r Not tainted 2.6.32-356.el6.i686 #1 EIP: 0061:[<c0407462>] EFLAGS: 00010086 CPU: 0 EIP is at xen_iret+0x12/0x2b EAX: eb8d0000 EBX: 00000001 ECX: 08049860 EDX: 00000010 ESI: 00000000 EDI: 003d0f00 EBP: b77f8388 ESP: eb8d1fe0 DS: 0000 ES: 007b FS: 0000 GS: 00e0 SS: 0069 Process r (pid: 1250, ti=eb8d0000 task=c2953550 task.ti=eb8d0000) Stack: 00000000 0027f416 00000073 00000206 b77f8364 0000007b 00000000 00000000 Call Trace: Code: c3 8b 44 24 18 81 4c 24 38 00 02 00 00 8d 64 24 30 e9 03 00 00 00 8d 76 00 f7 44 24 08 00 00 02 80 75 33 50 b8 00 e0 ff ff 21 e0 <8b> 40 10 8b 04 85 a0 f6 ab c0 8b 80 0c b0 b3 c0 f6 44 24 0d 02 EIP: [<c0407462>] xen_iret+0x12/0x2b SS:ESP 0069:eb8d1fe0 general protection fault: 0000 [#2] ---[ end trace ab0d29a492dcd330 ]--- Kernel panic - not syncing: Fatal exception Pid: 1250, comm: r Tainted: G D --------------- 2.6.32-356.el6.i686 #1 Call Trace: [<c08476df>] ? panic+0x6e/0x122 [<c084b63c>] ? oops_end+0xbc/0xd0 [<c084b260>] ? do_general_protection+0x0/0x210 [<c084a9b7>] ? error_code+0x73/ ------------- Petr says: " I've analysed the bug and I think that xen_iret() cannot cope with mangled DS, in this case zeroed out (null selector/descriptor) by either xen_failsafe_callback() or RESTORE_REGS because the corresponding LDT entry was invalidated by the reproducer. " Jan took a look at the preliminary patch and came up a fix that solves this problem: "This code gets called after all registers other than those handled by IRET got already restored, hence a null selector in %ds or a non-null one that got loaded from a code or read-only data descriptor would cause a kernel mode fault (with the potential of crashing the kernel as a whole, if panic_on_oops is set)." The way to fix this is to realize that the we can only relay on the registers that IRET restores. The two that are guaranteed are the %cs and %ss as they are always fixed GDT selectors. Also they are inaccessible from user mode - so they cannot be altered. This is the approach taken in this patch. Another alternative option suggested by Jan would be to relay on the subtle realization that using the %ebp or %esp relative references uses the %ss segment. In which case we could switch from using %eax to %ebp and would not need the %ss over-rides. That would also require one extra instruction to compensate for the one place where the register is used as scaled index. However Andrew pointed out that is too subtle and if further work was to be done in this code-path it could escape folks attention and lead to accidents. Reviewed-by: Petr Matousek <pmatouse@redhat.com> Reported-by: Petr Matousek <pmatouse@redhat.com> Reviewed-by: Andrew Cooper <andrew.cooper3@citrix.com> Signed-off-by: Jan Beulich <jbeulich@suse.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-17x86/mm: Check if PUD is large when validating a kernel addressMel Gorman
commit 0ee364eb316348ddf3e0dfcd986f5f13f528f821 upstream. A user reported the following oops when a backup process reads /proc/kcore: BUG: unable to handle kernel paging request at ffffbb00ff33b000 IP: [<ffffffff8103157e>] kern_addr_valid+0xbe/0x110 [...] Call Trace: [<ffffffff811b8aaa>] read_kcore+0x17a/0x370 [<ffffffff811ad847>] proc_reg_read+0x77/0xc0 [<ffffffff81151687>] vfs_read+0xc7/0x130 [<ffffffff811517f3>] sys_read+0x53/0xa0 [<ffffffff81449692>] system_call_fastpath+0x16/0x1b Investigation determined that the bug triggered when reading system RAM at the 4G mark. On this system, that was the first address using 1G pages for the virt->phys direct mapping so the PUD is pointing to a physical address, not a PMD page. The problem is that the page table walker in kern_addr_valid() is not checking pud_large() and treats the physical address as if it was a PMD. If it happens to look like pmd_none then it'll silently fail, probably returning zeros instead of real data. If the data happens to look like a present PMD though, it will be walked resulting in the oops above. This patch adds the necessary pud_large() check. Unfortunately the problem was not readily reproducible and now they are running the backup program without accessing /proc/kcore so the patch has not been validated but I think it makes sense. Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.coM> Reviewed-by: Michal Hocko <mhocko@suse.cz> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: linux-mm@kvack.org Link: http://lkml.kernel.org/r/20130211145236.GX21389@suse.de Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14Linux 3.0.64v3.0.64Greg Kroah-Hartman
2013-02-14netback: correct netbk_tx_err to handle wrap around.Ian Campbell
[ Upstream commit b9149729ebdcfce63f853aa54a404c6a8f6ebbf3 ] Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Acked-by: Jan Beulich <JBeulich@suse.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14xen/netback: free already allocated memory on failure in xen_netbk_get_requestsIan Campbell
[ Upstream commit 4cc7c1cb7b11b6f3515bd9075527576a1eecc4aa ] Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14xen/netback: don't leak pages on failure in xen_netbk_tx_check_gop.Matthew Daley
[ Upstream commit 7d5145d8eb2b9791533ffe4dc003b129b9696c48 ] Signed-off-by: Matthew Daley <mattjd@gmail.com> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Ian Campbell <ian.campbell@citrix.com> Acked-by: Jan Beulich <JBeulich@suse.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14xen/netback: shutdown the ring if it contains garbage.Ian Campbell
[ Upstream commit 48856286b64e4b66ec62b94e504d0b29c1ade664 ] A buggy or malicious frontend should not be able to confuse netback. If we spot anything which is not as it should be then shutdown the device and don't try to continue with the ring in a potentially hostile state. Well behaved and non-hostile frontends will not be penalised. As well as making the existing checks for such errors fatal also add a new check that ensures that there isn't an insane number of requests on the ring (i.e. more than would fit in the ring). If the ring contains garbage then previously is was possible to loop over this insane number, getting an error each time and therefore not generating any more pending requests and therefore not exiting the loop in xen_netbk_tx_build_gops for an externded period. Also turn various netdev_dbg calls which no precipitate a fatal error into netdev_err, they are rate limited because the device is shutdown afterwards. This fixes at least one known DoS/softlockup of the backend domain. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Jan Beulich <JBeulich@suse.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14tg3: Fix crc errors on jumbo frame receiveNithin Nayak Sujir
[ Upstream commit daf3ec688e057f6060fb9bb0819feac7a8bbf45c ] TG3_PHY_AUXCTL_SMDSP_ENABLE/DISABLE macros do a blind write to the phy auxiliary control register and overwrite the EXT_PKT_LEN (bit 14) resulting in intermittent crc errors on jumbo frames with some link partners. Change the code to do a read/modify/write. Signed-off-by: Nithin Nayak Sujir <nsujir@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14tg3: Avoid null pointer dereference in tg3_interrupt in netconsole modeNithin Nayak Sujir
[ Upstream commit 9c13cb8bb477a83b9a3c9e5a5478a4e21294a760 ] When netconsole is enabled, logging messages generated during tg3_open can result in a null pointer dereference for the uninitialized tg3 status block. Use the irq_sync flag to disable polling in the early stages. irq_sync is cleared when the driver is enabling interrupts after all initialization is completed. Signed-off-by: Nithin Nayak Sujir <nsujir@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14bridge: Pull ip header into skb->data before looking into ip header.Sarveshwar Bandi
[ Upstream commit 6caab7b0544e83e6c160b5e80f5a4a7dd69545c7 ] If lower layer driver leaves the ip header in the skb fragment, it needs to be first pulled into skb->data before inspecting ip header length or ip version number. Signed-off-by: Sarveshwar Bandi <sarveshwar.bandi@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14tcp: fix MSG_SENDPAGE_NOTLAST logicEric Dumazet
[ Upstream commit ae62ca7b03217be5e74759dc6d7698c95df498b3 ] commit 35f9c09fe9c72e (tcp: tcp_sendpages() should call tcp_push() once) added an internal flag : MSG_SENDPAGE_NOTLAST meant to be set on all frags but the last one for a splice() call. The condition used to set the flag in pipe_to_sendpage() relied on splice() user passing the exact number of bytes present in the pipe, or a smaller one. But some programs pass an arbitrary high value, and the test fails. The effect of this bug is a lack of tcp_push() at the end of a splice(pipe -> socket) call, and possibly very slow or erratic TCP sessions. We should both test sd->total_len and fact that another fragment is in the pipe (pipe->nrbufs > 1) Many thanks to Willy for providing very clear bug report, bisection and test programs. Reported-by: Willy Tarreau <w@1wt.eu> Bisected-by: Willy Tarreau <w@1wt.eu> Tested-by: Willy Tarreau <w@1wt.eu> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14tcp: fix for zero packets_in_flight was too broadIlpo Järvinen
[ Upstream commit 6731d2095bd4aef18027c72ef845ab1087c3ba63 ] There are transients during normal FRTO procedure during which the packets_in_flight can go to zero between write_queue state updates and firing the resulting segments out. As FRTO processing occurs during that window the check must be more precise to not match "spuriously" :-). More specificly, e.g., when packets_in_flight is zero but FLAG_DATA_ACKED is true the problematic branch that set cwnd into zero would not be taken and new segments might be sent out later. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Tested-by: Eric Dumazet <edumazet@google.com> Acked-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14tcp: frto should not set snd_cwnd to 0Eric Dumazet
[ Upstream commit 2e5f421211ff76c17130b4597bc06df4eeead24f ] Commit 9dc274151a548 (tcp: fix ABC in tcp_slow_start()) uncovered a bug in FRTO code : tcp_process_frto() is setting snd_cwnd to 0 if the number of in flight packets is 0. As Neal pointed out, if no packet is in flight we lost our chance to disambiguate whether a loss timeout was spurious. We should assume it was a proper loss. Reported-by: Pasi Kärkkäinen <pasik@iki.fi> Signed-off-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Cc: Yuchung Cheng <ycheng@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14net: sctp: sctp_endpoint_free: zero out secret key dataDaniel Borkmann
[ Upstream commit b5c37fe6e24eec194bb29d22fdd55d73bcc709bf ] On sctp_endpoint_destroy, previously used sensitive keying material should be zeroed out before the memory is returned, as we already do with e.g. auth keys when released. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14net: sctp: sctp_setsockopt_auth_key: use kzfree instead of kfreeDaniel Borkmann
[ Upstream commit 6ba542a291a5e558603ac51cda9bded347ce7627 ] In sctp_setsockopt_auth_key, we create a temporary copy of the user passed shared auth key for the endpoint or association and after internal setup, we free it right away. Since it's sensitive data, we should zero out the key before returning the memory back to the allocator. Thus, use kzfree instead of kfree, just as we do in sctp_auth_key_put(). Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14sctp: refactor sctp_outq_teardown to insure proper re-initalizationNeil Horman
[ Upstream commit 2f94aabd9f6c925d77aecb3ff020f1cc12ed8f86 ] Jamie Parsons reported a problem recently, in which the re-initalization of an association (The duplicate init case), resulted in a loss of receive window space. He tracked down the root cause to sctp_outq_teardown, which discarded all the data on an outq during a re-initalization of the corresponding association, but never reset the outq->outstanding_data field to zero. I wrote, and he tested this fix, which does a proper full re-initalization of the outq, fixing this problem, and hopefully future proofing us from simmilar issues down the road. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Reported-by: Jamie Parsons <Jamie.Parsons@metaswitch.com> Tested-by: Jamie Parsons <Jamie.Parsons@metaswitch.com> CC: Jamie Parsons <Jamie.Parsons@metaswitch.com> CC: Vlad Yasevich <vyasevich@gmail.com> CC: "David S. Miller" <davem@davemloft.net> CC: netdev@vger.kernel.org Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14atm/iphase: rename fregt_t -> ffreg_tHeiko Carstens
[ Upstream commit ab54ee80aa7585f9666ff4dd665441d7ce41f1e8 ] We have conflicting type qualifiers for "freg_t" in s390's ptrace.h and the iphase atm device driver, which causes the compile error below. Unfortunately the s390 typedef can't be renamed, since it's a user visible api, nor can I change the include order in s390 code to avoid the conflict. So simply rename the iphase typedef to a new name. Fixes this compile error: In file included from drivers/atm/iphase.c:66:0: drivers/atm/iphase.h:639:25: error: conflicting type qualifiers for 'freg_t' In file included from next/arch/s390/include/asm/ptrace.h:9:0, from next/arch/s390/include/asm/lowcore.h:12, from next/arch/s390/include/asm/thread_info.h:30, from include/linux/thread_info.h:54, from include/linux/preempt.h:9, from include/linux/spinlock.h:50, from include/linux/seqlock.h:29, from include/linux/time.h:5, from include/linux/stat.h:18, from include/linux/module.h:10, from drivers/atm/iphase.c:43: next/arch/s390/include/uapi/asm/ptrace.h:197:3: note: previous declaration of 'freg_t' was here Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Acked-by: chas williams - CONTRACTOR <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14packet: fix leakage of tx_ring memoryPhil Sutter
[ Upstream commit 9665d5d62487e8e7b1f546c00e11107155384b9a ] When releasing a packet socket, the routine packet_set_ring() is reused to free rings instead of allocating them. But when calling it for the first time, it fills req->tp_block_nr with the value of rb->pg_vec_len which in the second invocation makes it bail out since req->tp_block_nr is greater zero but req->tp_block_size is zero. This patch solves the problem by passing a zeroed auto-variable to packet_set_ring() upon each invocation from packet_release(). As far as I can tell, this issue exists even since 69e3c75 (net: TX_RING and packet mmap), i.e. the original inclusion of TX ring support into af_packet, but applies only to sockets with both RX and TX ring allocated, which is probably why this was unnoticed all the time. Signed-off-by: Phil Sutter <phil.sutter@viprinet.com> Cc: Johann Baudy <johann.baudy@gnu-log.net> Cc: Daniel Borkmann <dborkman@redhat.com> Acked-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14ipv6: do not create neighbor entries for local deliveryMarcelo Ricardo Leitner
[ Upstream commit bd30e947207e2ea0ff2c08f5b4a03025ddce48d3 ] They will be created at output, if ever needed. This avoids creating empty neighbor entries when TPROXYing/Forwarding packets for addresses that are not even directly reachable. Note that IPv4 already handles it this way. No neighbor entries are created for local input. Tested by myself and customer. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: Marcelo Ricardo Leitner <mleitner@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14pktgen: correctly handle failures when adding a deviceCong Wang
[ Upstream commit 604dfd6efc9b79bce432f2394791708d8e8f6efc ] The return value of pktgen_add_device() is not checked, so even if we fail to add some device, for example, non-exist one, we still see "OK:...". This patch fixes it. After this patch, I got: # echo "add_device non-exist" > /proc/net/pktgen/kpktgend_0 -bash: echo: write error: No such device # cat /proc/net/pktgen/kpktgend_0 Running: Stopped: Result: ERROR: can not add device non-exist # echo "add_device eth0" > /proc/net/pktgen/kpktgend_0 # cat /proc/net/pktgen/kpktgend_0 Running: Stopped: eth0 Result: OK: add_device=eth0 (Candidate for -stable) Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14net: loopback: fix a dst refcounting issueEric Dumazet
[ Upstream commit 794ed393b707f01858f5ebe2ae5eabaf89d00022 ] Ben Greear reported crashes in ip_rcv_finish() on a stress test involving many macvlans. We tracked the bug to a dst use after free. ip_rcv_finish() was calling dst->input() and got garbage for dst->input value. It appears the bug is in loopback driver, lacking a skb_dst_force() before calling netif_rx(). As a result, a non refcounted dst, normally protected by a RCU read_lock section, was escaping this section and could be freed before the packet being processed. [<ffffffff813a3c4d>] loopback_xmit+0x64/0x83 [<ffffffff81477364>] dev_hard_start_xmit+0x26c/0x35e [<ffffffff8147771a>] dev_queue_xmit+0x2c4/0x37c [<ffffffff81477456>] ? dev_hard_start_xmit+0x35e/0x35e [<ffffffff8148cfa6>] ? eth_header+0x28/0xb6 [<ffffffff81480f09>] neigh_resolve_output+0x176/0x1a7 [<ffffffff814ad835>] ip_finish_output2+0x297/0x30d [<ffffffff814ad6d5>] ? ip_finish_output2+0x137/0x30d [<ffffffff814ad90e>] ip_finish_output+0x63/0x68 [<ffffffff814ae412>] ip_output+0x61/0x67 [<ffffffff814ab904>] dst_output+0x17/0x1b [<ffffffff814adb6d>] ip_local_out+0x1e/0x23 [<ffffffff814ae1c4>] ip_queue_xmit+0x315/0x353 [<ffffffff814adeaf>] ? ip_send_unicast_reply+0x2cc/0x2cc [<ffffffff814c018f>] tcp_transmit_skb+0x7ca/0x80b [<ffffffff814c3571>] tcp_connect+0x53c/0x587 [<ffffffff810c2f0c>] ? getnstimeofday+0x44/0x7d [<ffffffff810c2f56>] ? ktime_get_real+0x11/0x3e [<ffffffff814c6f9b>] tcp_v4_connect+0x3c2/0x431 [<ffffffff814d6913>] __inet_stream_connect+0x84/0x287 [<ffffffff814d6b38>] ? inet_stream_connect+0x22/0x49 [<ffffffff8108d695>] ? _local_bh_enable_ip+0x84/0x9f [<ffffffff8108d6c8>] ? local_bh_enable+0xd/0x11 [<ffffffff8146763c>] ? lock_sock_nested+0x6e/0x79 [<ffffffff814d6b38>] ? inet_stream_connect+0x22/0x49 [<ffffffff814d6b49>] inet_stream_connect+0x33/0x49 [<ffffffff814632c6>] sys_connect+0x75/0x98 This bug was introduced in linux-2.6.35, in commit 7fee226ad2397b (net: add a noref bit on skb dst) skb_dst_force() is enforced in dev_queue_xmit() for devices having a qdisc. Reported-by: Ben Greear <greearb@candelatech.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Tested-by: Ben Greear <greearb@candelatech.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14r8169: remove the obsolete and incorrect AMD workaroundTimo Teräs
[ Upstream commit 5d0feaff230c0abfe4a112e6f09f096ed99e0b2d ] This was introduced in commit 6dccd16 "r8169: merge with version 6.001.00 of Realtek's r8169 driver". I did not find the version 6.001.00 online, but in 6.002.00 or any later r8169 from Realtek this hunk is no longer present. Also commit 05af214 "r8169: fix Ethernet Hangup for RTL8110SC rev d" claims to have fixed this issue otherwise. The magic compare mask of 0xfffe000 is dubious as it masks parts of the Reserved part, and parts of the VLAN tag. But this does not make much sense as the VLAN tag parts are perfectly valid there. In matter of fact this seems to be triggered with any VLAN tagged packet as RxVlanTag bit is matched. I would suspect 0xfffe0000 was intended to test reserved part only. Finally, this hunk is evil as it can cause more packets to be handled than what was NAPI quota causing net/core/dev.c: net_rx_action(): WARN_ON_ONCE(work > weight) to trigger, and mess up the NAPI state causing device to hang. As result, any system using VLANs and having high receive traffic (so that NAPI poll budget limits rtl_rx) would result in device hang. Signed-off-by: Timo Teräs <timo.teras@iki.fi> Acked-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14isdn/gigaset: fix zero size border case in debug dumpTilman Schmidt
[ Upstream commit d721a1752ba544df8d7d36959038b26bc92bdf80 ] If subtracting 12 from l leaves zero we'd do a zero size allocation, leading to an oops later when we try to set the NUL terminator. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14MAINTAINERS: Stephen Hemminger email changeStephen Hemminger
[ Upstream commit adbbf69d1a54abf424e91875746a610dcc80017d ] I changed my email because the vyatta.com mail server is now redirected to brocade.com; and the Brocade mail system is not friendly to Linux desktop users. Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14net: prevent setting ttl=0 via IP_TTLCong Wang
[ Upstream commit c9be4a5c49cf51cc70a993f004c5bb30067a65ce ] A regression is introduced by the following commit: commit 4d52cfbef6266092d535237ba5a4b981458ab171 Author: Eric Dumazet <eric.dumazet@gmail.com> Date: Tue Jun 2 00:42:16 2009 -0700 net: ipv4/ip_sockglue.c cleanups Pure cleanups but it is not a pure cleanup... - if (val != -1 && (val < 1 || val>255)) + if (val != -1 && (val < 0 || val > 255)) Since there is no reason provided to allow ttl=0, change it back. Reported-by: nitin padalia <padalia.nitin@gmail.com> Cc: nitin padalia <padalia.nitin@gmail.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14mac80211: synchronize scan off/on-channel and PS statesStanislaw Gruszka
commit aacde9ee45225f7e0b90960f479aef83c66bfdc0 upstream. Since: commit b23b025fe246f3acc2988eb6d400df34c27cb8ae Author: Ben Greear <greearb@candelatech.com> Date: Fri Feb 4 11:54:17 2011 -0800 mac80211: Optimize scans on current operating channel. we do not disable PS while going back to operational channel (on ieee80211_scan_state_suspend) and deffer that until scan finish. But since we are allowed to send frames, we can send a frame to AP without PM bit set, so disable PS on AP side. Then when we switch to off-channel (in ieee80211_scan_state_resume) we do not enable PS. Hence we are off-channel with PS disabled, frames are not buffered by AP. To fix remove offchannel_ps_disable argument and always enable PS when going off-channel and disable it when going on-channel, like it was before. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Tested-by: Seth Forshee <seth.forshee@canonical.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: CAI Qian <caiqian@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14kernel/resource.c: fix stack overflow in __reserve_region_with_split()T Makphaibulchoke
commit 4965f5667f36a95b41cda6638875bc992bd7d18b upstream. Using a recursive call add a non-conflicting region in __reserve_region_with_split() could result in a stack overflow in the case that the recursive calls are too deep. Convert the recursive calls to an iterative loop to avoid the problem. Tested on a machine containing 135 regions. The kernel no longer panicked with stack overflow. Also tested with code arbitrarily adding regions with no conflict, embedding two consecutive conflicts and embedding two non-consecutive conflicts. Signed-off-by: T Makphaibulchoke <tmac@hp.com> Reviewed-by: Ram Pai <linuxram@us.ibm.com> Cc: Paul Gortmaker <paul.gortmaker@gmail.com> Cc: Wei Yang <weiyang@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14virtio_console: Don't access uninitialized data.Sjur Brændeland
commit aded024a12b32fc1ed9a80639681daae2d07ec25 upstream. Don't access uninitialized work-queue when removing device. The work queue is initialized only if the device multi-queue. So don't call cancel_work unless this is a multi-queue device. This fixes the following panic: Kernel panic - not syncing: BUG! Call Trace: 62031b28: [<6026085d>] panic+0x16b/0x2d3 62031b30: [<6004ef5e>] flush_work+0x0/0x1d7 62031b60: [<602606f2>] panic+0x0/0x2d3 62031b68: [<600333b0>] memcpy+0x0/0x140 62031b80: [<6002d58a>] unblock_signals+0x0/0x84 62031ba0: [<602609c5>] printk+0x0/0xa0 62031bd8: [<60264e51>] __mutex_unlock_slowpath+0x13d/0x148 62031c10: [<6004ef5e>] flush_work+0x0/0x1d7 62031c18: [<60050234>] try_to_grab_pending+0x0/0x17e 62031c38: [<6004e984>] get_work_gcwq+0x71/0x8f 62031c48: [<60050539>] __cancel_work_timer+0x5b/0x115 62031c78: [<628acc85>] unplug_port+0x0/0x191 [virtio_console] 62031c98: [<6005061c>] cancel_work_sync+0x12/0x14 62031ca8: [<628ace96>] virtcons_remove+0x80/0x15c [virtio_console] 62031ce8: [<628191de>] virtio_dev_remove+0x1e/0x7e [virtio] 62031d08: [<601cf242>] __device_release_driver+0x75/0xe4 62031d28: [<601cf2dd>] device_release_driver+0x2c/0x40 62031d48: [<601ce0dd>] driver_unbind+0x7d/0xc6 62031d88: [<601cd5d9>] drv_attr_store+0x27/0x29 62031d98: [<60115f61>] sysfs_write_file+0x100/0x14d 62031df8: [<600b737d>] vfs_write+0xcb/0x184 62031e08: [<600b58b8>] filp_close+0x88/0x94 62031e38: [<600b7686>] sys_write+0x59/0x88 62031e88: [<6001ced1>] handle_syscall+0x5d/0x80 62031ea8: [<60030a74>] userspace+0x405/0x531 62031f08: [<600d32cc>] sys_dup+0x0/0x5e 62031f28: [<601b11d6>] strcpy+0x0/0x18 62031f38: [<600be46c>] do_execve+0x10/0x12 62031f48: [<600184c7>] run_init_process+0x43/0x45 62031fd8: [<60019a91>] new_thread_handler+0xba/0xbc Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-14rtlwifi: Fix the usage of the wrong variable in usb.cLarry Finger
commit 0a06ad8e3a1cb5311b7dbafde45410aa1bce9d40 upstream. In routine _rtl_rx_pre_process(), skb_dequeue() is called to get an skb; however, the wrong variable name is used in subsequent calls. Reported-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11Linux 3.0.63v3.0.63Greg Kroah-Hartman
2013-02-11USB: XHCI: fix memory leak of URB-private dataAlan Stern
commit 48c3375c5f69b1c2ef3d1051a0009cb9bce0ce24 upstream. This patch (as1640) fixes a memory leak in xhci-hcd. The urb_priv data structure isn't always deallocated in the handle_tx_event() routine for non-control transfers. The patch adds a kfree() call so that all paths end up freeing the memory properly. This patch should be backported to kernels as old as 2.6.36, that contain the commit 8e51adccd4c4b9ffcd509d7f2afce0a906139f75 "USB: xHCI: Introduce urb_priv structure" Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Reported-and-tested-by: Martin Mokrejs <mmokrejs@fold.natur.cuni.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11xhci: Fix isoc TD encoding.Sarah Sharp
commit 760973d2a74b93eb1697981f7448f0e62767cfc4 upstream. An isochronous TD is comprised of one isochronous TRB chained to zero or more normal TRBs. Only the isoc TRB has the TBC and TLBPC fields. The normal TRBs must set those fields to zeroes. The code was setting the TBC and TLBPC fields for both isoc and normal TRBs. Fix this. This should be backported to stable kernels as old as 3.0, that contain the commit b61d378f2da41c748aba6ca19d77e1e1c02bcea5 " xhci 1.0: Set transfer burst last packet count field." Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11USB: storage: optimize to match the Huawei USB storage devices and support ↵fangxiaozhi
new switch command commit 200e0d994d9d1919b28c87f1a5fb99a8e13b8a0f upstream. 1. Optimize the match rules with new macro for Huawei USB storage devices, to avoid to load USB storage driver for the modem interface with Huawei devices. 2. Add to support new switch command for new Huawei USB dongles. Signed-off-by: fangxiaozhi <huananhu@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11USB: storage: Define a new macro for USB storage match rulesfangxiaozhi
commit 07c7be3d87e5cdaf5f94c271c516456364ef286c upstream. 1. Define a new macro for USB storage match rules: matching with Vendor ID and interface descriptors. Signed-off-by: fangxiaozhi <huananhu@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11USB: EHCI: fix bug in scheduling periodic split transfersAlan Stern
commit 3e619d04159be54b3daa0b7036b0ce9e067f4b5d upstream. This patch (as1654) fixes a very old bug in ehci-hcd, connected with scheduling of periodic split transfers. The calculations for full/low-speed bus usage are all carried out after the correction for bit-stuffing has been applied, but the values in the max_tt_usecs array assume it hasn't been. The array should allow for allocation of up to 90% of the bus capacity, which is 900 us, not 780 us. The symptom caused by this bug is that any isochronous transfer to a full-speed device with a maxpacket size larger than about 980 bytes is always rejected with a -ENOSPC error. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11USB: qcserial: add Telit Gobi QDL deviceDaniele Palmas
commit 78796ae17eacedcdcaaeb03ba73d2e532a4c8f83 upstream. Add VID and PID for Telit Gobi QDL device Signed-off-by: Daniele Palmas <dnlplm@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11USB: option: add Changhong CH690Bjørn Mork
commit d4fa681541aa7bf8570d03426dd7ba663a71c467 upstream. New device with 3 serial interfaces: If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend) Sub=ff Prot=ff If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend) Sub=ff Prot=ff If#= 2 Alt= 0 #EPs= 2 Cls=ff(vend) Sub=ff Prot=ff If#= 3 Alt= 0 #EPs= 2 Cls=08(stor) Sub=06 Prot=50 Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11USB: option: add support for Telit LE920Daniele Palmas
commit 03eb466f276ceef9dcf023dc5474db02af68aad9 upstream. Add PID and special handling for Telit LE920 Signed-off-by: Daniele Palmas <dnlplm@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11USB: ftdi_sio: add PID/VID entries for ELV WS 300 PC IISven Killig
commit c249f911406efcc7456cb4af79396726bf7b8c57 upstream. Add PID/VID entries for ELV WS 300 PC II weather station Signed-off-by: Sven Killig <sven@killig.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11USB: ftdi_sio: add Zolix FTDI PIDPetr Kubánek
commit 0ba3b2ccc72b3df5c305d61f59d93ab0f0e87991 upstream. Add support for Zolix Omni 1509 monochromator custom USB-RS232 converter. Signed-off-by: Petr Kubánek <petr@kubanek.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11drivers/rtc/rtc-isl1208.c: call rtc_update_irq() from the alarm irq handlerJan Luebbe
commit 72fca4a4b32dc778b5b885c3498700e42b610d49 upstream. Previously the alarm event was not propagated into the RTC subsystem. By adding a call to rtc_update_irq, this fixes a timeout problem with the hwclock utility. Signed-off-by: Jan Luebbe <jlu@pengutronix.de> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11nilfs2: fix fix very long mount time issueVyacheslav Dubeyko
commit a9bae189542e71f91e61a4428adf6e5a7dfe8063 upstream. There exists a situation when GC can work in background alone without any other filesystem activity during significant time. The nilfs_clean_segments() method calls nilfs_segctor_construct() that updates superblocks in the case of NILFS_SC_SUPER_ROOT and THE_NILFS_DISCONTINUED flags are set. But when GC is working alone the nilfs_clean_segments() is called with unset THE_NILFS_DISCONTINUED flag. As a result, the update of superblocks doesn't occurred all this time and in the case of SPOR superblocks keep very old values of last super root placement. SYMPTOMS: Trying to mount a NILFS2 volume after SPOR in such environment ends with very long mounting time (it can achieve about several hours in some cases). REPRODUCING PATH: 1. It needs to use external USB HDD, disable automount and doesn't make any additional filesystem activity on the NILFS2 volume. 2. Generate temporary file with size about 100 - 500 GB (for example, dd if=/dev/zero of=<file_name> bs=1073741824 count=200). The size of file defines duration of GC working. 3. Then it needs to delete file. 4. Start GC manually by means of command "nilfs-clean -p 0". When you start GC by means of such way then, at the end, superblocks is updated by once. So, for simulation of SPOR, it needs to wait sometime (15 - 40 minutes) and simply switch off USB HDD manually. 5. Switch on USB HDD again and try to mount NILFS2 volume. As a result, NILFS2 volume will mount during very long time. REPRODUCIBILITY: 100% FIX: This patch adds checking that superblocks need to update and set THE_NILFS_DISCONTINUED flag before nilfs_clean_segments() call. Reported-by: Sergey Alexandrov <splavgm@gmail.com> Signed-off-by: Vyacheslav Dubeyko <slava@dubeyko.com> Tested-by: Vyacheslav Dubeyko <slava@dubeyko.com> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11x86-64: Replace left over sti/cli in ia32 audit exit codeJan Beulich
commit 40a1ef95da85843696fc3ebe5fce39b0db32669f upstream. For some reason they didn't get replaced so far by their paravirt equivalents, resulting in code to be run with interrupts disabled that doesn't expect so (causing, in the observed case, a BUG_ON() to trigger) when syscall auditing is enabled. David (Cc-ed) came up with an identical fix, so likely this can be taken to count as an ack from him. Reported-by: Peter Moody <pmoody@google.com> Signed-off-by: Jan Beulich <jbeulich@suse.com> Cc: David Vrabel <david.vrabel@citrix.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Link: http://lkml.kernel.org/r/5108E01902000078000BA9C5@nat28.tlf.novell.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: David Vrabel <david.vrabel@citrix.com> Tested-by: Peter Moody <pmoody@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11drm/radeon: Calling object_unrefer() when creating fb failureliu chuansheng
commit f2d68cf4daa4de97d400d94836b907e35228e54f upstream. When kzalloc() failed in radeon_user_framebuffer_create(), need to call object_unreference() to match the object_reference(). Signed-off-by: liu chuansheng <chuansheng.liu@intel.com> Signed-off-by: xueminsu <xuemin.su@intel.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11drm/radeon: add quirk for RV100 boardAlex Deucher
commit 9200ee4941a6e5d1ec5df88982243686882dff3f upstream. vbios says external TMDS while the board is actually internal TMDS. fixes: https://bugs.freedesktop.org/show_bug.cgi?id=60037 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-11drm/radeon/evergreen+: wait for the MC to settle after MC blackoutAlex Deucher
commit ed39fadd6df01095378e499fac3674883f16b853 upstream. Some chips seem to need a little delay after blacking out the MC before the requests actually stop. May fix: https://bugs.freedesktop.org/show_bug.cgi?id=56139 https://bugs.freedesktop.org/show_bug.cgi?id=57567 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-03Linux 3.0.62v3.0.62Greg Kroah-Hartman
