2013-01-11Linux 3.0.58v3.0.58Greg Kroah-Hartman
2013-01-11can: Do not call dev_put if restart timer is running upon closeAlexander Stein
commit ab48b03ec9ae1840a1e427e2375bd0d9d554b4ed upstream. If the restart timer is running due to BUS-OFF and the device is disconnected an dev_put will decrease the usage counter to -1 thus blocking the interface removal, resulting in the following dmesg lines repeating every 10s: can: notifier: receive list not found for dev can0 can: notifier: receive list not found for dev can0 can: notifier: receive list not found for dev can0 unregister_netdevice: waiting for can0 to become free. Usage count = -1 Signed-off-by: Alexander Stein <alexander.stein@systec-electronic.com> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11mm: limit mmu_gather batching to fix soft lockups on !CONFIG_PREEMPTMichal Hocko
commit 53a59fc67f97374758e63a9c785891ec62324c81 upstream. Since commit e303297e6c3a ("mm: extended batches for generic mmu_gather") we are batching pages to be freed until either tlb_next_batch cannot allocate a new batch or we are done. This works just fine most of the time but we can get in troubles with non-preemptible kernel (CONFIG_PREEMPT_NONE or CONFIG_PREEMPT_VOLUNTARY) on large machines where too aggressive batching might lead to soft lockups during process exit path (exit_mmap) because there are no scheduling points down the free_pages_and_swap_cache path and so the freeing can take long enough to trigger the soft lockup. The lockup is harmless except when the system is setup to panic on softlockup which is not that unusual. The simplest way to work around this issue is to limit the maximum number of batches in a single mmu_gather. 10k of collected pages should be safe to prevent from soft lockups (we would have 2ms for one) even if they are all freed without an explicit scheduling point. This patch doesn't add any new explicit scheduling points because it relies on zap_pmd_range during page tables zapping which calls cond_resched per PMD. The following lockup has been reported for 3.0 kernel with a huge process (in order of hundreds gigs but I do know any more details). BUG: soft lockup - CPU#56 stuck for 22s! [kernel:31053] Modules linked in: af_packet nfs lockd fscache auth_rpcgss nfs_acl sunrpc mptctl mptbase autofs4 binfmt_misc dm_round_robin dm_multipath bonding cpufreq_conservative cpufreq_userspace cpufreq_powersave pcc_cpufreq mperf microcode fuse loop osst sg sd_mod crc_t10dif st qla2xxx scsi_transport_fc scsi_tgt netxen_nic i7core_edac iTCO_wdt joydev e1000e serio_raw pcspkr edac_core iTCO_vendor_support acpi_power_meter rtc_cmos hpwdt hpilo button container usbhid hid dm_mirror dm_region_hash dm_log linear uhci_hcd ehci_hcd usbcore usb_common scsi_dh_emc scsi_dh_alua scsi_dh_hp_sw scsi_dh_rdac scsi_dh dm_snapshot pcnet32 mii edd dm_mod raid1 ext3 mbcache jbd fan thermal processor thermal_sys hwmon cciss scsi_mod Supported: Yes CPU 56 Pid: 31053, comm: kernel Not tainted 3.0.31-0.9-default #1 HP ProLiant DL580 G7 RIP: 0010: _raw_spin_unlock_irqrestore+0x8/0x10 RSP: 0018:ffff883ec1037af0 EFLAGS: 00000206 RAX: 0000000000000e00 RBX: ffffea01a0817e28 RCX: ffff88803ffd9e80 RDX: 0000000000000200 RSI: 0000000000000206 RDI: 0000000000000206 RBP: 0000000000000002 R08: 0000000000000001 R09: ffff887ec724a400 R10: 0000000000000000 R11: dead000000200200 R12: ffffffff8144c26e R13: 0000000000000030 R14: 0000000000000297 R15: 000000000000000e FS: 00007ed834282700(0000) GS:ffff88c03f200000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 000000000068b240 CR3: 0000003ec13c5000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process kernel (pid: 31053, threadinfo ffff883ec1036000, task ffff883ebd5d4100) Call Trace: release_pages+0xc5/0x260 free_pages_and_swap_cache+0x9d/0xc0 tlb_flush_mmu+0x5c/0x80 tlb_finish_mmu+0xe/0x50 exit_mmap+0xbd/0x120 mmput+0x49/0x120 exit_mm+0x122/0x160 do_exit+0x17a/0x430 do_group_exit+0x3d/0xb0 get_signal_to_deliver+0x247/0x480 do_signal+0x71/0x1b0 do_notify_resume+0x98/0xb0 int_signal+0x12/0x17 DWARF2 unwinder stuck at int_signal+0x12/0x17 Signed-off-by: Michal Hocko <mhocko@suse.cz> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11drivers/rtc/rtc-vt8500.c: fix handling of data passed in struct rtc_timeTony Prisk
commit 2f90b68309683f2c5765a1b04ca23d71e51f1494 upstream. tm_mon is 0..11, whereas vt8500 expects 1..12 for the month field, causing invalid date errors for January, and causing the day field to roll over incorrectly. The century flag is only handled in vt8500_rtc_read_time, but not set in vt8500_rtc_set_time. This patch corrects the behaviour of the century flag. Signed-off-by: Edgar Toernig <froese@gmx.de> Signed-off-by: Tony Prisk <linux@prisktech.co.nz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11drivers/rtc/rtc-vt8500.c: correct handling of CR_24H bitfieldTony Prisk
commit 532db570e5181abc8f4f7bfa6c77c69ec2240198 upstream. Control register bitfield for 12H/24H mode is handled incorrectly. Setting CR_24H actually enables 12H mode. This patch renames the define and changes the initialization code to correctly set 24H mode. Signed-off-by: Tony Prisk <linux@prisktech.co.nz> Cc: Edgar Toernig <froese@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11CRIS: fix I/O macrosCorey Minyard
commit c24bf9b4cc6a0f330ea355d73bfdf1dae7e63a05 upstream. The inb/outb macros for CRIS are broken from a number of points of view, missing () around parameters and they have an unprotected if statement in them. This was breaking the compile of IPMI on CRIS and thus I was being annoyed by build regressions, so I fixed them. Plus I don't think they would have worked at all, since the data values were missing "&" and the outsl had a "3" instead of a "4" for the size. From what I can tell, this stuff is not used at all, so this can't be any more broken than it was before, anyway. Signed-off-by: Corey Minyard <cminyard@mvista.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Mikael Starvik <starvik@axis.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11Bluetooth: cancel power_on work when unregistering the deviceGustavo Padovan
commit b9b5ef188e5a2222cfc16ef62a4703080750b451 upstream. We need to cancel the hci_power_on work in order to avoid it run when we try to free the hdev. [ 1434.201149] ------------[ cut here ]------------ [ 1434.204998] WARNING: at lib/debugobjects.c:261 debug_print_object+0x8e/0xb0() [ 1434.208324] ODEBUG: free active (active state 0) object type: work_struct hint: hci _power_on+0x0/0x90 [ 1434.210386] Pid: 8564, comm: trinity-child25 Tainted: G W 3.7.0-rc5-next- 20121112-sasha-00018-g2f4ce0e #127 [ 1434.210760] Call Trace: [ 1434.210760] [<ffffffff819f3d6e>] ? debug_print_object+0x8e/0xb0 [ 1434.210760] [<ffffffff8110b887>] warn_slowpath_common+0x87/0xb0 [ 1434.210760] [<ffffffff8110b911>] warn_slowpath_fmt+0x41/0x50 [ 1434.210760] [<ffffffff819f3d6e>] debug_print_object+0x8e/0xb0 [ 1434.210760] [<ffffffff8376b750>] ? hci_dev_open+0x310/0x310 [ 1434.210760] [<ffffffff83bf94e5>] ? _raw_spin_unlock_irqrestore+0x55/0xa0 [ 1434.210760] [<ffffffff819f3ee5>] __debug_check_no_obj_freed+0xa5/0x230 [ 1434.210760] [<ffffffff83785db0>] ? bt_host_release+0x10/0x20 [ 1434.210760] [<ffffffff819f4d15>] debug_check_no_obj_freed+0x15/0x20 [ 1434.210760] [<ffffffff8125eee7>] kfree+0x227/0x330 [ 1434.210760] [<ffffffff83785db0>] bt_host_release+0x10/0x20 [ 1434.210760] [<ffffffff81e539e5>] device_release+0x65/0xc0 [ 1434.210760] [<ffffffff819d3975>] kobject_cleanup+0x145/0x190 [ 1434.210760] [<ffffffff819d39cd>] kobject_release+0xd/0x10 [ 1434.210760] [<ffffffff819d33cc>] kobject_put+0x4c/0x60 [ 1434.210760] [<ffffffff81e548b2>] put_device+0x12/0x20 [ 1434.210760] [<ffffffff8376a334>] hci_free_dev+0x24/0x30 [ 1434.210760] [<ffffffff82fd8fe1>] vhci_release+0x31/0x60 [ 1434.210760] [<ffffffff8127be12>] __fput+0x122/0x250 [ 1434.210760] [<ffffffff811cab0d>] ? rcu_user_exit+0x9d/0xd0 [ 1434.210760] [<ffffffff8127bf49>] ____fput+0x9/0x10 [ 1434.210760] [<ffffffff81133402>] task_work_run+0xb2/0xf0 [ 1434.210760] [<ffffffff8106cfa7>] do_notify_resume+0x77/0xa0 [ 1434.210760] [<ffffffff83bfb0ea>] int_signal+0x12/0x17 [ 1434.210760] ---[ end trace a6d57fefbc8a8cc7 ]--- Reported-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11Bluetooth: ath3k: Add support for VAIO VPCEH [0489:e027]Marcos Chaparro
commit acd9454433e28c1a365d8b069813c35c1c3a8ac3 upstream. Added Atheros AR3011 internal bluetooth device found in Sony VAIO VPCEH to the devices list. Before this, the bluetooth module was identified as an Foxconn / Hai bluetooth device [0489:e027], now it claims to be an AtherosAR3011 Bluetooth [0cf3:3005]. T: Bus=01 Lev=02 Prnt=02 Port=04 Cnt=02 Dev#= 4 Spd=12 MxCh= 0 D: Ver= 1.10 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1 P: Vendor=0489 ProdID=e027 Rev= 0.01 C:* #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=100mA I:* If#= 0 Alt= 0 #EPs= 3 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=81(I) Atr=03(Int.) MxPS= 16 Ivl=1ms E: Ad=82(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms I:* If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=83(I) Atr=01(Isoc) MxPS= 0 Ivl=1ms E: Ad=03(O) Atr=01(Isoc) MxPS= 0 Ivl=1ms I: If#= 1 Alt= 1 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=83(I) Atr=01(Isoc) MxPS= 9 Ivl=1ms E: Ad=03(O) Atr=01(Isoc) MxPS= 9 Ivl=1ms I: If#= 1 Alt= 2 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=83(I) Atr=01(Isoc) MxPS= 17 Ivl=1ms E: Ad=03(O) Atr=01(Isoc) MxPS= 17 Ivl=1ms I: If#= 1 Alt= 3 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=83(I) Atr=01(Isoc) MxPS= 25 Ivl=1ms E: Ad=03(O) Atr=01(Isoc) MxPS= 25 Ivl=1ms I: If#= 1 Alt= 4 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=83(I) Atr=01(Isoc) MxPS= 33 Ivl=1ms E: Ad=03(O) Atr=01(Isoc) MxPS= 33 Ivl=1ms I: If#= 1 Alt= 5 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb E: Ad=83(I) Atr=01(Isoc) MxPS= 49 Ivl=1ms E: Ad=03(O) Atr=01(Isoc) MxPS= 49 Ivl=1ms Signed-off-by: Marcos Chaparro <marcos@mrkindustries.com.ar> Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Cc: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11PCI: Reduce Ricoh 0xe822 SD card reader base clock frequency to 50MHzAndy Lutomirski
commit 812089e01b9f65f90fc8fc670d8cce72a0e01fbb upstream. Otherwise it fails like this on cards like the Transcend 16GB SDHC card: mmc0: new SDHC card at address b368 mmcblk0: mmc0:b368 SDC 15.0 GiB mmcblk0: error -110 sending status command, retrying mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb0 Tested on my Lenovo x200 laptop. [bhelgaas: changelog] Signed-off-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Chris Ball <cjb@laptop.org> CC: Manoj Iyer <manoj.iyer@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11solos-pci: fix double-free of TX skb in DMA modeDavid Woodhouse
commit cae49ede00ec3d0cda290b03fee55b72b49efc11 upstream. We weren't clearing card->tx_skb[port] when processing the TX done interrupt. If there wasn't another skb ready to transmit immediately, this led to a double-free because we'd free it *again* next time we did have a packet to send. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11ARM: missing ->mmap_sem around find_vma() in swp_emulate.cAl Viro
commit 7bf9b7bef881aac820bf1f2e9951a17b09bd7e04 upstream. find_vma() is *not* safe when somebody else is removing vmas. Not just the return value might get bogus just as you are getting it (this instance doesn't try to dereference the resulting vma), the search itself can get buggered in rather spectacular ways. IOW, ->mmap_sem really, really is not optional here. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11ARM: mm: use pteval_t to represent page protection valuesWill Deacon
commit 864aa04cd02979c2c755cb28b5f4fe56039171c0 upstream. When updating the page protection map after calculating the user_pgprot value, the base protection map is temporarily stored in an unsigned long type, causing truncation of the protection bits when LPAE is enabled. This effectively means that calls to mprotect() will corrupt the upper page attributes, clearing the XN bit unconditionally. This patch uses pteval_t to store the intermediate protection values, preserving the upper bits for 64-bit descriptors. Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11tcp: RFC 5961 5.2 Blind Data Injection Attack MitigationEric Dumazet
[ Upstream commit 354e4aa391ed50a4d827ff6fc11e0667d0859b25 ] RFC 5961 5.2 [Blind Data Injection Attack].[Mitigation] All TCP stacks MAY implement the following mitigation. TCP stacks that implement this mitigation MUST add an additional input check to any incoming segment. The ACK value is considered acceptable only if it is in the range of ((SND.UNA - MAX.SND.WND) <= SEG.ACK <= SND.NXT). All incoming segments whose ACK value doesn't satisfy the above condition MUST be discarded and an ACK sent back. Move tcp_send_challenge_ack() before tcp_ack() to avoid a forward declaration. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Neal Cardwell <ncardwell@google.com> Cc: Yuchung Cheng <ycheng@google.com> Cc: Jerry Chu <hkchu@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11tcp: tcp_replace_ts_recent() should not be called from tcp_validate_incoming()Eric Dumazet
[ Upstream commit bd090dfc634ddd711a5fbd0cadc6e0ab4977bcaf ] We added support for RFC 5961 in latest kernels but TCP fails to perform exhaustive check of ACK sequence. We can update our view of peer tsval from a frame that is later discarded by tcp_ack() This makes timestamps enabled sessions vulnerable to injection of a high tsval : peers start an ACK storm, since the victim sends a dupack each time it receives an ACK from the other peer. As tcp_validate_incoming() is called before tcp_ack(), we should not peform tcp_replace_ts_recent() from it, and let callers do it at the right time. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Neal Cardwell <ncardwell@google.com> Cc: Yuchung Cheng <ycheng@google.com> Cc: Nandita Dukkipati <nanditad@google.com> Cc: H.K. Jerry Chu <hkchu@google.com> Cc: Romain Francoise <romain@orebokech.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11tcp: refine SYN handling in tcp_validate_incomingEric Dumazet
[ Upstream commit e371589917011efe6ff8c7dfb4e9e81934ac5855 ] Followup of commit 0c24604b68fc (tcp: implement RFC 5961 4.2) As reported by Vijay Subramanian, we should send a challenge ACK instead of a dup ack if a SYN flag is set on a packet received out of window. This permits the ratelimiting to work as intended, and to increase correct SNMP counters. Suggested-by: Vijay Subramanian <subramanian.vijay@gmail.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Acked-by: Vijay Subramanian <subramanian.vijay@gmail.com> Cc: Kiran Kumar Kella <kkiran@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11tcp: implement RFC 5961 4.2Eric Dumazet
[ Upstream commit 0c24604b68fc7810d429d6c3657b6f148270e528 ] Implement the RFC 5691 mitigation against Blind Reset attack using SYN bit. Section 4.2 of RFC 5961 advises to send a Challenge ACK and drop incoming packet, instead of resetting the session. Add a new SNMP counter to count number of challenge acks sent in response to SYN packets. (netstat -s | grep TCPSYNChallenge) Remove obsolete TCPAbortOnSyn, since we no longer abort a TCP session because of a SYN flag. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Kiran Kumar Kella <kkiran@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11tcp: implement RFC 5961 3.2Eric Dumazet
[ Upstream commit 282f23c6ee343126156dd41218b22ece96d747e3 ] Implement the RFC 5691 mitigation against Blind Reset attack using RST bit. Idea is to validate incoming RST sequence, to match RCV.NXT value, instead of previouly accepted window : (RCV.NXT <= SEG.SEQ < RCV.NXT+RCV.WND) If sequence is in window but not an exact match, send a "challenge ACK", so that the other part can resend an RST with the appropriate sequence. Add a new sysctl, tcp_challenge_ack_limit, to limit number of challenge ACK sent per second. Add a new SNMP counter to count number of challenge acks sent. (netstat -s | grep TCPChallengeACK) Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Kiran Kumar Kella <kkiran@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11net: sched: integer overflow fixStefan Hasko
[ Upstream commit d2fe85da52e89b8012ffad010ef352a964725d5f ] Fixed integer overflow in function htb_dequeue Signed-off-by: Stefan Hasko <hasko.stevo@gmail.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11sparc: huge_ptep_set_* functions need to call set_huge_pte_at()Dave Kleikamp
[ Upstream commit 6cb9c3697585c47977c42c5cc1b9fc49247ac530 ] Modifying the huge pte's requires that all the underlying pte's be modified. Version 2: added missing flush_tlb_page() Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: sparclinux@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11ftrace: Do not function trace inlined functionsSteven Rostedt
commit 45959ee7aa645815a5ce303a0ea1e48a21e67c6a upstream. When gcc inlines a function, it does not mark it with the mcount prologue, which in turn means that inlined functions are not traced by the function tracer. But if CONFIG_OPTIMIZE_INLINING is set, then gcc is allowed not to inline a function that is marked inline. Depending on the options and the compiler, a function may or may not be traced by the function tracer, depending on whether gcc decides to inline a function or not. This has caused several problems in the pass becaues gcc is not always consistent with what it decides to inline between different gcc versions. Some places should not be traced (like paravirt native_* functions) and these are mostly marked as inline. When gcc decides not to inline the function, and if that function should not be traced, then the ftrace function tracer will suddenly break when it use to work fine. This becomes even harder to debug when different versions of gcc will not inline that function, making the same kernel and config work for some gcc versions and not work for others. By making all functions marked inline to not be traced will remove the ambiguity that gcc adds when it comes to tracing functions marked inline. All gcc versions will be consistent with what functions are traced and having volatile working code will be removed. Note, only the inline macro when CONFIG_OPTIMIZE_INLINING is set needs to have notrace added, as the attribute __always_inline will force the function to be inlined and then not traced. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11x86, amd: Disable way access filter on Piledriver CPUsAndre Przywara
commit 2bbf0a1427c377350f001fbc6260995334739ad7 upstream. The Way Access Filter in recent AMD CPUs may hurt the performance of some workloads, caused by aliasing issues in the L1 cache. This patch disables it on the affected CPUs. The issue is similar to that one of last year: http://lkml.indiana.edu/hypermail/linux/kernel/1107.3/00041.html This new patch does not replace the old one, we just need another quirk for newer CPUs. The performance penalty without the patch depends on the circumstances, but is a bit less than the last year's 3%. The workloads affected would be those that access code from the same physical page under different virtual addresses, so different processes using the same libraries with ASLR or multiple instances of PIE-binaries. The code needs to be accessed simultaneously from both cores of the same compute unit. More details can be found here: http://developer.amd.com/Assets/SharedL1InstructionCacheonAMD15hCPU.pdf CPUs affected are anything with the core known as Piledriver. That includes the new parts of the AMD A-Series (aka Trinity) and the just released new CPUs of the FX-Series (aka Vishera). The model numbering is a bit odd here: FX CPUs have model 2, A-Series has model 10h, with possible extensions to 1Fh. Hence the range of model ids. Signed-off-by: Andre Przywara <osp@andrep.de> Link: http://lkml.kernel.org/r/1351700450-9277-1-git-send-email-osp@andrep.de Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: CAI Qian <caiqian@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11cgroup: remove incorrect dget/dput() pair in cgroup_create_dir()Tejun Heo
commit 175431635ec09b1d1bba04979b006b99e8305a83 upstream. cgroup_create_dir() does weird dancing with dentry refcnt. On success, it gets and then puts it achieving nothing. On failure, it puts but there isn't no matching get anywhere leading to the following oops if cgroup_create_file() fails for whatever reason. ------------[ cut here ]------------ kernel BUG at /work/os/work/fs/dcache.c:552! invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC Modules linked in: CPU 2 Pid: 697, comm: mkdir Not tainted 3.7.0-rc4-work+ #3 Bochs Bochs RIP: 0010:[<ffffffff811d9c0c>] [<ffffffff811d9c0c>] dput+0x1dc/0x1e0 RSP: 0018:ffff88001a3ebef8 EFLAGS: 00010246 RAX: 0000000000000000 RBX: ffff88000e5b1ef8 RCX: 0000000000000403 RDX: 0000000000000303 RSI: 2000000000000000 RDI: ffff88000e5b1f58 RBP: ffff88001a3ebf18 R08: ffffffff82c76960 R09: 0000000000000001 R10: ffff880015022080 R11: ffd9bed70f48a041 R12: 00000000ffffffea R13: 0000000000000001 R14: ffff88000e5b1f58 R15: 00007fff57656d60 FS: 00007ff05fcb3800(0000) GS:ffff88001fd00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 00000000004046f0 CR3: 000000001315f000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process mkdir (pid: 697, threadinfo ffff88001a3ea000, task ffff880015022080) Stack: ffff88001a3ebf48 00000000ffffffea 0000000000000001 0000000000000000 ffff88001a3ebf38 ffffffff811cc889 0000000000000001 ffff88000e5b1ef8 ffff88001a3ebf68 ffffffff811d1fc9 ffff8800198d7f18 ffff880019106ef8 Call Trace: [<ffffffff811cc889>] done_path_create+0x19/0x50 [<ffffffff811d1fc9>] sys_mkdirat+0x59/0x80 [<ffffffff811d2009>] sys_mkdir+0x19/0x20 [<ffffffff81be1e02>] system_call_fastpath+0x16/0x1b Code: 00 48 8d 90 18 01 00 00 48 89 93 c0 00 00 00 4c 89 a0 18 01 00 00 48 8b 83 a0 00 00 00 83 80 28 01 00 00 01 e8 e6 6f a0 00 eb 92 <0f> 0b 66 90 0f 1f 44 00 00 55 48 89 e5 41 57 41 56 49 89 fe 41 RIP [<ffffffff811d9c0c>] dput+0x1dc/0x1e0 RSP <ffff88001a3ebef8> ---[ end trace 1277bcfd9561ddb0 ]--- Fix it by dropping the unnecessary dget/dput() pair. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11xhci: Add Lynx Point LP to list of Intel switchable hostsRussell Webb
commit bb1e5dd7113d2fd178d3af9aca8f480ae0468edf upstream. Like Lynx Point, Lynx Point LP is also switchable. See 1c12443ab8eba71a658fae4572147e56d1f84f66 for more details. This patch should be backported to stable kernels as old as 3.0, that contain commit 69e848c2090aebba5698a1620604c7dccb448684 "Intel xhci: Support EHCI/xHCI port switching." Signed-off-by: Russell Webb <russell.webb@linux.intel.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11genirq: Always force thread affinityThomas Gleixner
commit 04aa530ec04f61875b99c12721162e2964e3318c upstream. Sankara reported that the genirq core code fails to adjust the affinity of an interrupt thread in several cases: 1) On request/setup_irq() the call to setup_affinity() happens before the new action is registered, so the new thread is not notified. 2) For secondary shared interrupts nothing notifies the new thread to change its affinity. 3) Interrupts which have the IRQ_NO_BALANCE flag set are not moving the thread either. Fix this by setting the thread affinity flag right on thread creation time. This ensures that under all circumstances the thread moves to the right place. Requires a check in irq_thread_check_affinity for an existing affinity mask (CONFIG_CPU_MASK_OFFSTACK=y) Reported-and-tested-by: Sankara Muthukrishnan <sankara.m@gmail.com> Link: http://lkml.kernel.org/r/alpine.LFD.2.02.1209041738200.2754@ionos Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11Input: walkera0701 - fix crash on startupPeter Popovec
commit a455e2985f57e2a71566bb8850094af38b2c932d upstream. The driver's timer must be set up before enabling IRQ handler, otherwise bad things may happen. Reported-and-tested-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Peter Popovec <popovec@fei.tuke.sk> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11nfs: fix null checking in nfs_get_option_str()Xi Wang
commit e25fbe380c4e3c09afa98bcdcd9d3921443adab8 upstream. The following null pointer check is broken. *option = match_strdup(args); return !option; The pointer `option' must be non-null, and thus `!option' is always false. Use `!*option' instead. The bug was introduced in commit c5cb09b6f8 ("Cleanup: Factor out some cut-and-paste code."). Signed-off-by: Xi Wang <xi.wang@gmail.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11nfsd4: fix oops on unusual readlike compoundJ. Bruce Fields
commit d5f50b0c290431c65377c4afa1c764e2c3fe5305 upstream. If the argument and reply together exceed the maximum payload size, then a reply with a read-like operation can overlow the rq_pages array. Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11NFS: Fix calls to drop_nlink()Trond Myklebust
commit 1f018458b30b0d5c535c94e577aa0acbb92e1395 upstream. It is almost always wrong for NFS to call drop_nlink() after removing a file. What we really want is to mark the inode's attributes for revalidation, and we want to ensure that the VFS drops it if we're reasonably sure that this is the final unlink(). Do the former using the usual cache validity flags, and the latter by testing if inode->i_nlink == 1, and clearing it in that case. This also fixes the following warning reported by Neil Brown and Jeff Layton (among others). [634155.004438] WARNING: at /home/abuild/rpmbuild/BUILD/kernel-desktop-3.5.0/lin [634155.004442] Hardware name: Latitude E6510 [634155.004577] crc_itu_t crc32c_intel snd_hwdep snd_pcm snd_timer snd soundcor [634155.004609] Pid: 13402, comm: bash Tainted: G W 3.5.0-36-desktop # [634155.004611] Call Trace: [634155.004630] [<ffffffff8100444a>] dump_trace+0xaa/0x2b0 [634155.004641] [<ffffffff815a23dc>] dump_stack+0x69/0x6f [634155.004653] [<ffffffff81041a0b>] warn_slowpath_common+0x7b/0xc0 [634155.004662] [<ffffffff811832e4>] drop_nlink+0x34/0x40 [634155.004687] [<ffffffffa05bb6c3>] nfs_dentry_iput+0x33/0x70 [nfs] [634155.004714] [<ffffffff8118049e>] dput+0x12e/0x230 [634155.004726] [<ffffffff8116b230>] __fput+0x170/0x230 [634155.004735] [<ffffffff81167c0f>] filp_close+0x5f/0x90 [634155.004743] [<ffffffff81167cd7>] sys_close+0x97/0x100 [634155.004754] [<ffffffff815c3b39>] system_call_fastpath+0x16/0x1b [634155.004767] [<00007f2a73a0d110>] 0x7f2a73a0d10f Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11NFS: avoid NULL dereference in nfs_destroy_serverNeilBrown
commit f259613a1e4b44a0cf85a5dafd931be96ee7c9e5 upstream. In rare circumstances, nfs_clone_server() of a v2 or v3 server can get an error between setting server->destory (to nfs_destroy_server), and calling nfs_start_lockd (which will set server->nlm_host). If this happens, nfs_clone_server will call nfs_free_server which will call nfs_destroy_server and thence nlmclnt_done(NULL). This causes the NULL to be dereferenced. So add a guard to only call nlmclnt_done() if ->nlm_host is not NULL. The other guards there are irrelevant as nlm_host can only be non-NULL if one of these flags are set - so remove those tests. (Thanks to Trond for this suggestion). This is suitable for any stable kernel since 2.6.25. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11ACPI / scan: Do not use dummy HID for system bus ACPI nodesRafael J. Wysocki
commit 4f5f64cf0cc916220aaa055992e31195470cfe37 upstream. At one point acpi_device_set_id() checks if acpi_device_hid(device) returns NULL, but that never happens, so system bus devices with an empty list of PNP IDs are given the dummy HID ("device") instead of the "system bus HID" ("LNXSYBUS"). Fix the code to use the right check. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11usb: gadget: phonet: free requests in pn_bind()'s error pathSebastian Andrzej Siewior
commit d0eca719dd11ad0619e8dd6a1f3eceb95b0216dd upstream. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11p54usb: add USBIDs for two more p54usb devicesChristian Lamparter
commit 4010fe21a315b4223c25376714c6a2b61b722e5c upstream. This patch adds USBIDs for: - DrayTek Vigor 530 - Zoom 4410a It also adds a note about Gemtek WUBI-100GW and SparkLAN WL-682 USBID conflict [WUBI-100GW is a ISL3886+NET2280 (LM86 firmare) solution, whereas WL-682 is a ISL3887 (LM87 firmware)] device. Source: <http://www.wikidevi.com/wiki/Intersil/p54/usb/windows> Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11p54usb: add USB ID for T-Com Sinus 154 data IITomasz Guszkowski
commit 3194b7fcdf6caea338b5d2c72d76fed80437649c upstream. Added USB ID for T-Com Sinus 154 data II. Signed-off-by: Tomasz Guszkowski <tsg@o2.pl> Acked-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11ALSA: usb-audio: Fix missing autopm for MIDI inputTakashi Iwai
commit f5f165418cabf2218eb466c0e94693b8b1aee88b upstream. The commit [88a8516a: ALSA: usbaudio: implement USB autosuspend] added the support of autopm for USB MIDI output, but it didn't take the MIDI input into account. This patch adds the following for fixing the autopm: - Manage the URB start at the first MIDI input stream open, instead of the time of instance creation - Move autopm code to the common substream_open() - Make snd_usbmidi_input_start/_stop() more robust and add the running state check Reviewd-by: Clemens Ladisch <clemens@ladisch.de> Tested-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11ALSA: usb-audio: Avoid autopm calls after disconnectionTakashi Iwai
commit 59866da9e4ae54819e3c4e0a8f426bdb0c2ef993 upstream. Add a similar protection against the disconnection race and the invalid use of usb instance after disconnection, as well as we've done for the USB audio PCM. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=51201 Reviewd-by: Clemens Ladisch <clemens@ladisch.de> Tested-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11tmpfs mempolicy: fix /proc/mounts corrupting memoryHugh Dickins
commit f2a07f40dbc603c15f8b06e6ec7f768af67b424f upstream. Recently I suggested using "mount -o remount,mpol=local /tmp" in NUMA mempolicy testing. Very nasty. Reading /proc/mounts, /proc/pid/mounts or /proc/pid/mountinfo may then corrupt one bit of kernel memory, often in a page table (causing "Bad swap" or "Bad page map" warning or "Bad pagetable" oops), sometimes in a vm_area_struct or rbnode or somewhere worse. "mpol=prefer" and "mpol=prefer:Node" are equally toxic. Recent NUMA enhancements are not to blame: this dates back to 2.6.35, when commit e17f74af351c "mempolicy: don't call mpol_set_nodemask() when no_context" skipped mpol_parse_str()'s call to mpol_set_nodemask(), which used to initialize v.preferred_node, or set MPOL_F_LOCAL in flags. With slab poisoning, you can then rely on mpol_to_str() to set the bit for node 0x6b6b, probably in the next page above the caller's stack. mpol_parse_str() is only called from shmem_parse_options(): no_context is always true, so call it unused for now, and remove !no_context code. Set v.nodes or v.preferred_node or MPOL_F_LOCAL as mpol_to_str() might expect. Then mpol_to_str() can ignore its no_context argument also, the mpol being appropriately initialized whether contextualized or not. Rename its no_context unused too, and let subsequent patch remove them (that's not needed for stable backporting, which would involve rejects). I don't understand why MPOL_LOCAL is described as a pseudo-policy: it's a reasonable policy which suffers from a confusing implementation in terms of MPOL_PREFERRED with MPOL_F_LOCAL. I believe this would be much more robust if MPOL_LOCAL were recognized in switch statements throughout, MPOL_F_LOCAL deleted, and MPOL_PREFERRED use the (possibly empty) nodes mask like everyone else, instead of its preferred_node variant (I presume an optimization from the days before MPOL_LOCAL). But that would take me too long to get right and fully tested. Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11mm: Fix PageHead when !CONFIG_PAGEFLAGS_EXTENDEDChristoffer Dall
commit ad4b3fb7ff9940bcdb1e4cd62bd189d10fa636ba upstream. Unfortunately with !CONFIG_PAGEFLAGS_EXTENDED, (!PageHead) is false, and (PageHead) is true, for tail pages. If this is indeed the intended behavior, which I doubt because it breaks cache cleaning on some ARM systems, then the nomenclature is highly problematic. This patch makes sure PageHead is only true for head pages and PageTail is only true for tail pages, and neither is true for non-compound pages. [ This buglet seems ancient - seems to have been introduced back in Apr 2008 in commit 6a1e7f777f61: "pageflags: convert to the use of new macros". And the reason nobody noticed is because the PageHead() tests are almost all about just sanity-checking, and only used on pages that are actual page heads. The fact that the old code returned true for tail pages too was thus not really noticeable. - Linus ] Signed-off-by: Christoffer Dall <cdall@cs.columbia.edu> Acked-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Will Deacon <Will.Deacon@arm.com> Cc: Steve Capper <Steve.Capper@arm.com> Cc: Christoph Lameter <cl@linux.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11virtio: force vring descriptors to be allocated from lowmemWill Deacon
commit b92b1b89a33c172c075edccf6afb0edc41d851fd upstream. Virtio devices may attempt to add descriptors to a virtqueue from atomic context using GFP_ATOMIC allocation. This is problematic because such allocations can fall outside of the lowmem mapping, causing virt_to_phys to report bogus physical addresses which are subsequently passed to userspace via the buffers for the virtual device. This patch masks out __GFP_HIGH and __GFP_HIGHMEM from the requested flags when allocating descriptors for a virtqueue. If an atomic allocation is requested and later fails, we will return -ENOSPC which will be handled by the driver. Signed-off-by: Will Deacon <will.deacon@arm.com> Cc: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11x86, 8042: Enable A20 using KBC to fix S3 resume on some MSI laptopsOndrej Zary
commit ad68652412276f68ad4fe3e1ecf5ee6880876783 upstream. Some MSI laptop BIOSes are broken - INT 15h code uses port 92h to enable A20 line but resume code assumes that KBC was used. The laptop will not resume from S3 otherwise but powers off after a while and then powers on again stuck with a blank screen. Fix it by enabling A20 using KBC in i8042_platform_init for x86. Fixes https://bugzilla.kernel.org/show_bug.cgi?id=12878 Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Rafael J. Wysocki <rjw@sisk.pl> Link: http://lkml.kernel.org/r/201212112218.06551.linux@rainbow-software.org Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11exec: do not leave bprm->interp on stackKees Cook
commit b66c5984017533316fd1951770302649baf1aa33 upstream. If a series of scripts are executed, each triggering module loading via unprintable bytes in the script header, kernel stack contents can leak into the command line. Normally execution of binfmt_script and binfmt_misc happens recursively. However, when modules are enabled, and unprintable bytes exist in the bprm->buf, execution will restart after attempting to load matching binfmt modules. Unfortunately, the logic in binfmt_script and binfmt_misc does not expect to get restarted. They leave bprm->interp pointing to their local stack. This means on restart bprm->interp is left pointing into unused stack memory which can then be copied into the userspace argv areas. After additional study, it seems that both recursion and restart remains the desirable way to handle exec with scripts, misc, and modules. As such, we need to protect the changes to interp. This changes the logic to require allocation for any changes to the bprm->interp. To avoid adding a new kmalloc to every exec, the default value is left as-is. Only when passing through binfmt_script or binfmt_misc does an allocation take place. For a proof of concept, see DoTest.sh from: http://www.halfdog.net/Security/2012/LinuxKernelBinfmtScriptStackDataDisclosure/ Signed-off-by: Kees Cook <keescook@chromium.org> Cc: halfdog <me@halfdog.net> Cc: P J P <ppandit@redhat.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11pnpacpi: fix incorrect TEST_ALPHA() testAlan Cox
commit cdc87c5a30f407ed1ce43d8a22261116873d5ef1 upstream. TEST_ALPHA() is broken and always returns 0. [akpm@linux-foundation.org: return false for '@' as well, per Bjorn] Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11usb/ipheth: Add iPhone 5 supportJay Purohit
[ Upstream commit af1b85e49089f945deb46258b0fc4bc9910afb22 ] I noticed that the iPhone ethernet driver did not support iPhone 5. I quickly added support to it in my kernel, here's a patch. Signed-off-by: Jay Purohit <jspurohit@velocitylimitless.com> Acked-by: Valdis Kletnieks <valdis.kletnieks@vt.edu> Signed-off-by: Jan Ceuleers <jan.ceuleers@computer.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11irda: sir_dev: Fix copy/paste typoAlexander Shiyan
[ Upstream commit 2355a62bcbdcc4b567425bab036bfab6ade87eed ] Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11ne2000: add the right platform deviceAlan Cox
[ Upstream commit da9da01d9199b5bb15289d0859053c9aa3a34ac0 ] Without this udev doesn't have a way to key the ne device to the platform device. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11sctp: fix -ENOMEM result with invalid user space pointer in sendto() syscallTommi Rantala
[ Upstream commit 6e51fe7572590d8d86e93b547fab6693d305fd0d ] Consider the following program, that sets the second argument to the sendto() syscall incorrectly: #include <string.h> #include <arpa/inet.h> #include <sys/socket.h> int main(void) { int fd; struct sockaddr_in sa; fd = socket(AF_INET, SOCK_STREAM, 132 /*IPPROTO_SCTP*/); if (fd < 0) return 1; memset(&sa, 0, sizeof(sa)); sa.sin_family = AF_INET; sa.sin_addr.s_addr = inet_addr("127.0.0.1"); sa.sin_port = htons(11111); sendto(fd, NULL, 1, 0, (struct sockaddr *)&sa, sizeof(sa)); return 0; } We get -ENOMEM: $ strace -e sendto ./demo sendto(3, NULL, 1, 0, {sa_family=AF_INET, sin_port=htons(11111), sin_addr=inet_addr("127.0.0.1")}, 16) = -1 ENOMEM (Cannot allocate memory) Propagate the error code from sctp_user_addto_chunk(), so that we will tell user space what actually went wrong: $ strace -e sendto ./demo sendto(3, NULL, 1, 0, {sa_family=AF_INET, sin_port=htons(11111), sin_addr=inet_addr("127.0.0.1")}, 16) = -1 EFAULT (Bad address) Noticed while running Trinity (the syscall fuzzer). Signed-off-by: Tommi Rantala <tt.rantala@gmail.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11sctp: fix memory leak in sctp_datamsg_from_user() when copy from user space ↵Tommi Rantala
fails [ Upstream commit be364c8c0f17a3dd42707b5a090b318028538eb9 ] Trinity (the syscall fuzzer) discovered a memory leak in SCTP, reproducible e.g. with the sendto() syscall by passing invalid user space pointer in the second argument: #include <string.h> #include <arpa/inet.h> #include <sys/socket.h> int main(void) { int fd; struct sockaddr_in sa; fd = socket(AF_INET, SOCK_STREAM, 132 /*IPPROTO_SCTP*/); if (fd < 0) return 1; memset(&sa, 0, sizeof(sa)); sa.sin_family = AF_INET; sa.sin_addr.s_addr = inet_addr("127.0.0.1"); sa.sin_port = htons(11111); sendto(fd, NULL, 1, 0, (struct sockaddr *)&sa, sizeof(sa)); return 0; } As far as I can tell, the leak has been around since ~2003. Signed-off-by: Tommi Rantala <tt.rantala@gmail.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11bonding: fix race condition in bonding_store_slaves_activenikolay@redhat.com
[ Upstream commit e196c0e579902f42cf72414461fb034e5a1ffbf7 ] Race between bonding_store_slaves_active() and slave manipulation functions. The bond_for_each_slave use in bonding_store_slaves_active() is not protected by any synchronization mechanism. NULL pointer dereference is easy to reach. Fixed by acquiring the bond->lock for the slave walk. v2: Make description text < 75 columns Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11bonding: Bonding driver does not consider the gso_max_size/gso_max_segs ↵Sarveshwar Bandi
setting of slave devices. [ Upstream commit 0e376bd0b791ac6ac6bdb051492df0769c840848 ] Patch sets the lowest gso_max_size and gso_max_segs values of the slave devices during enslave and detach. Signed-off-by: Sarveshwar Bandi <sarveshwar.bandi@emulex.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-17Linux 3.0.57v3.0.57Greg Kroah-Hartman
2012-12-17powerpc: Keep thread.dscr and thread.dscr_inherit in syncAnton Blanchard
commit 00ca0de02f80924dfff6b4f630e1dff3db005e35 upstream. When we update the DSCR either via emulation of mtspr(DSCR) or via a change to dscr_default in sysfs we don't update thread.dscr. We will eventually update it at context switch time but there is a period where thread.dscr is incorrect. If we fork at this point we will copy the old value of thread.dscr into the child. To avoid this, always keep thread.dscr in sync with reality. This issue was found with the following testcase: http://ozlabs.org/~anton/junkcode/dscr_inherit_test.c Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Haren Myneni <haren@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
