2012-01-12Linux 3.0.17v3.0.17Greg Kroah-Hartman
2012-01-12xfs: fix acl count validation in xfs_acl_from_disk()Xi Wang
commit 093019cf1b18dd31b2c3b77acce4e000e2cbc9ce upstream. Commit fa8b18ed didn't prevent the integer overflow and possible memory corruption. "count" can go negative and bypass the check. Signed-off-by: Xi Wang <xi.wang@gmail.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Ben Myers <bpm@sgi.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12usb: cdc-acm: Fix acm_tty_hangup() vs. acm_tty_close() raceThilo-Alexander Ginkel
[Not upstream as it was fixed differently for 3.3 with a much more "intrusive" rework of the driver - gregkh] There is a race condition involving acm_tty_hangup() and acm_tty_close() where hangup() would attempt to access tty->driver_data without proper locking and NULL checking after close() has potentially already set it to NULL. One possibility to (sporadically) trigger this behavior is to perform a suspend/resume cycle with a running WWAN data connection. This patch addresses the issue by introducing a NULL check for tty->driver_data in acm_tty_hangup() protected by open_mutex and exiting gracefully when hangup() is invoked on a device that has already been closed. Signed-off-by: Thilo-Alexander Ginkel <thilo@ginkel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12SCSI: mpt2sas: Added missing mpt2sas_base_detach call from scsih_remove contextkashyap.desai@lsi.com
commit 9ae89b0296e275d5a556068b40b7c2557a556a85 upstream. mpt2sas_base_detach() call was removed from _scsih_remove() while doing some code shuffling. Mainly when we work on adding code for scsih_shutdown(). I have added back mpt2sas_base_detach() which will get callled from _scsih_remove(). Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-01-12PM / Sleep: Fix race between CPU hotplug and freezerSrivatsa S. Bhat
commit 79cfbdfa87e84992d509e6c1648a18e1d7e68c20 upstream. The CPU hotplug notifications sent out by the _cpu_up() and _cpu_down() functions depend on the value of the 'tasks_frozen' argument passed to them (which indicates whether tasks have been frozen or not). (Examples for such CPU hotplug notifications: CPU_ONLINE, CPU_ONLINE_FROZEN, CPU_DEAD, CPU_DEAD_FROZEN). Thus, it is essential that while the callbacks for those notifications are running, the state of the system with respect to the tasks being frozen or not remains unchanged, *throughout that duration*. Hence there is a need for synchronizing the CPU hotplug code with the freezer subsystem. Since the freezer is involved only in the Suspend/Hibernate call paths, this patch hooks the CPU hotplug code to the suspend/hibernate notifiers PM_[SUSPEND|HIBERNATE]_PREPARE and PM_POST_[SUSPEND|HIBERNATE] to prevent the race between CPU hotplug and freezer, thus ensuring that CPU hotplug notifications will always be run with the state of the system really being what the notifications indicate, _throughout_ their execution time. Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12bonding: fix error handling if slave is busy (v2)stephen hemminger
commit f7d9821a6a9c83450ac35e76d3709e32fd38b76f upstream. If slave device already has a receive handler registered, then the error unwind of bonding device enslave function is broken. The following will leave a pointer to freed memory in the slave device list, causing a later kernel panic. # modprobe dummy # ip li add dummy0-1 link dummy0 type macvlan # modprobe bonding # echo +dummy0 >/sys/class/net/bond0/bonding/slaves The fix is to detach the slave (which removes it from the list) in the unwind path. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Reviewed-by: Nicolas de Pesloüan <nicolas.2p.debian@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12asix: fix infinite loop in rx_fixup()Aurelien Jacobs
commit 6c15d74defd38e7e7f8805392578b7a1d508097e upstream. At this point if skb->len happens to be 2, the subsequant skb_pull(skb, 4) call won't work and the skb->len won't be decreased and won't ever reach 0, resulting in an infinite loop. With an ASIX 88772 under heavy load, without this patch, rx_fixup() reaches an infinite loop in less than a minute. With this patch applied, no infinite loop even after hours of heavy load. Signed-off-by: Aurelien Jacobs <aurel@gnuage.org> Cc: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-12igmp: Avoid zero delay when receiving odd mixture of IGMP queriesBen Hutchings
commit a8c1f65c79cbbb2f7da782d4c9d15639a9b94b27 upstream. Commit 5b7c84066733c5dfb0e4016d939757b38de189e4 ('ipv4: correct IGMP behavior on v3 query during v2-compatibility mode') added yet another case for query parsing, which can result in max_delay = 0. Substitute a value of 1, as in the usual v3 case. Reported-by: Simon McVittie <smcv@debian.org> References: http://bugs.debian.org/654876 Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-12OHCI: final fix for NVIDIA problems (I hope)Alan Stern
commit c61875977458637226ab093a35d200f2d5789787 upstream. Problems with NVIDIA's OHCI host controllers persist. After looking carefully through the spec, I finally realized that when a controller is reset it then automatically goes into a SUSPEND state in which it is completely quiescent (no DMA and no IRQs) and from which it will not awaken until the system puts it into the OPERATIONAL state. Therefore there's no need to worry about controllers being in the RESET state for extended periods, or remaining in the OPERATIONAL state during system shutdown. The proper action for device initialization is to put the controller into the RESET state (if it's not there already) and then to issue a software reset. Similarly, the proper action for device shutdown is simply to do a software reset. This patch (as1499) implements such an approach. It simplifies initialization and shutdown, and allows the NVIDIA shutdown-quirk code to be removed. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Tested-by: Andre "Osku" Schmidt <andre.osku.schmidt@googlemail.com> Tested-by: Arno Augustin <Arno.Augustin@web.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12usb: ch9: fix up MaxStreams helperFelipe Balbi
commit 18b7ede5f7ee2092aedcb578d3ac30bd5d4fc23c upstream. [ removed the dwc3 portion of the patch as it didn't apply to older kernels - gregkh] According to USB 3.0 Specification Table 9-22, if bmAttributes [4:0] are set to zero, it means "no streams supported", but the way this helper was defined on Linux, we will *always* have one stream which might cause several problems. For example on DWC3, we would tell the controller endpoint has streams enabled and yet start transfers with Stream ID set to 0, which would goof up the host side. While doing that, convert the macro to an inline function due to the different checks we now need. Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12usb: option: add ZD Incorporated HSPA modemJanne Snabb
commit 3c8c9316710b83e906e425024153bf0929887b59 upstream. Add support for Chinese Noname HSPA USB modem which is apparently manufactured by a company called ZD Incorporated (based on texts in the Windows drivers). This product is available at least from Dealextreme (SKU 80032) and possibly in India with name Olive V-MW250. It is based on Qualcomm MSM6280 chip. I needed to also add "options usb-storage quirks=0685:7000:i" in modprobe configuration because udevd or the kernel keeps poking the embedded fake-cd-rom which fails and causes the device to reset. There might be a better way to accomplish the same. usb_modeswitch is not needed with this device. Signed-off-by: Janne Snabb <snabb@epipe.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12USB: option: add id for 3G dongle Model VT1000 of ViettelVU Tuan Duc
commit 5b061623355d8f69327a24838b0aa05e435ae5d5 upstream. Add VendorID/ProductID for USB 3G dongle Model VT1000 of Viettel. Signed-off-by: VU Tuan Duc <ducvt@viettel.com.vn> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12xhci: Properly handle COMP_2ND_BW_ERRHans de Goede
commit 71d85724bdd947a3b42a88d08af79f290a1a767b upstream. I encountered a result of COMP_2ND_BW_ERR while improving how the pwc webcam driver handles not having the full usb1 bandwidth available to itself. I created the following test setup, a NEC xhci controller with a single TT USB 2 hub plugged into it, with a usb keyboard and a pwc webcam plugged into the usb2 hub. This caused the following to show up in dmesg when trying to stream from the pwc camera at its highest alt setting: xhci_hcd 0000:01:00.0: ERROR: unexpected command completion code 0x23. usb 6-2.1: Not enough bandwidth for altsetting 9 And usb_set_interface returned -EINVAL, which caused my pwc code to not do the right thing as it expected -ENOSPC. This patch makes the xhci driver properly handle COMP_2ND_BW_ERR and makes usb_set_interface return -ENOSPC as expected. This should be backported to stable kernels as old as 2.6.32. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12usb: fix number of mapped SG DMA entriesClemens Ladisch
commit bc677d5b64644c399cd3db6a905453e611f402ab upstream. Add a new field num_mapped_sgs to struct urb so that we have a place to store the number of mapped entries and can also retain the original value of entries in num_sgs. Previously, usb_hcd_map_urb_for_dma() would overwrite this with the number of mapped entries, which would break dma_unmap_sg() because it requires the original number of entries. This fixes warnings like the following when using USB storage devices: ------------[ cut here ]------------ WARNING: at lib/dma-debug.c:902 check_unmap+0x4e4/0x695() ehci_hcd 0000:00:12.2: DMA-API: device driver frees DMA sg list with different entry count [map count=4] [unmap count=1] Modules linked in: ohci_hcd ehci_hcd Pid: 0, comm: kworker/0:1 Not tainted 3.2.0-rc2+ #319 Call Trace: <IRQ> [<ffffffff81036d3b>] warn_slowpath_common+0x80/0x98 [<ffffffff81036de7>] warn_slowpath_fmt+0x41/0x43 [<ffffffff811fa5ae>] check_unmap+0x4e4/0x695 [<ffffffff8105e92c>] ? trace_hardirqs_off+0xd/0xf [<ffffffff8147208b>] ? _raw_spin_unlock_irqrestore+0x33/0x50 [<ffffffff811fa84a>] debug_dma_unmap_sg+0xeb/0x117 [<ffffffff8137b02f>] usb_hcd_unmap_urb_for_dma+0x71/0x188 [<ffffffff8137b166>] unmap_urb_for_dma+0x20/0x22 [<ffffffff8137b1c5>] usb_hcd_giveback_urb+0x5d/0xc0 [<ffffffffa0000d02>] ehci_urb_done+0xf7/0x10c [ehci_hcd] [<ffffffffa0001140>] qh_completions+0x429/0x4bd [ehci_hcd] [<ffffffffa000340a>] ehci_work+0x95/0x9c0 [ehci_hcd] ... ---[ end trace f29ac88a5a48c580 ]--- Mapped at: [<ffffffff811faac4>] debug_dma_map_sg+0x45/0x139 [<ffffffff8137bc0b>] usb_hcd_map_urb_for_dma+0x22e/0x478 [<ffffffff8137c494>] usb_hcd_submit_urb+0x63f/0x6fa [<ffffffff8137d01c>] usb_submit_urb+0x2c7/0x2de [<ffffffff8137dcd4>] usb_sg_wait+0x55/0x161 Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12USB: Add USB-ID for Multiplex RC serial adapter to cp210x.cMalte Schröder
commit 08e87d0d773dc9ca5faf4c3306e238ed0ea129b0 upstream. Hi, below patch adds the USB-ID of the serial adapters sold by Multiplex RC (www.multiplex-rc.de). Signed-off-by: Malte Schröder <maltesch@gmx.de> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12USB: omninet: fix write_roomJohan Hovold
commit 694c6301e515bad574af74b6552134c4d9dcb334 upstream. Fix regression introduced by commit 507ca9bc047666 ([PATCH] USB: add ability for usb-serial drivers to determine if their write urb is currently being used.) which inverted the logic in write_room so that it returns zero when the write urb is actually free. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12usb: musb: fix pm_runtime mismatchFelipe Contreras
commit 772aed45b604c5ff171f0f12c12392d868333f79 upstream. In musb_init_controller() there's a pm_runtime_put(), but there's no pm_runtime_get(), which creates a mismatch that causes the driver to sleep when it shouldn't. This was introduced in 7acc619[1], but it wasn't triggered in my setup until 18a2689[2] was merged to Linus' branch at point df0914[3]. IOW; when PM is working as it was supposed to. However, it seems most of the time this is used in a way that keeps the counter above 0, so nobody noticed. Also, it seems to depend on the configuration used in versions before 3.1, but not later (or in it). I found the problem by loading isp1704_charger before any usb gadgets: http://article.gmane.org/gmane.linux.kernel/1226122 All versions after 2.6.39 are affected. [1] usb: musb: Idle path retention and offmode support for OMAP3 [2] OMAP2+: musb: hwmod adaptation for musb registration [3] Merge branch 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 Cc: Hema HK <hemahk@ti.com> Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2012-01-12USB: add quirk for another cameraOliver Neukum
commit 35284b3d2f68a8a3703745e629999469f78386b5 upstream. The Guillemot Webcam Hercules Dualpix Exchange camera has been reported with a second ID. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12usb: usb-storage doesn't support dynamic id currently, the patch disables ↵Huajun Li
the feature to fix an oops commit 1a3a026ba1b6bbfe0b7f79ab38cf991d691e7c9a upstream. Echo vendor and product number of a non usb-storage device to usb-storage driver's new_id, then plug in the device to host and you will find following oops msg, the root cause is usb_stor_probe1() refers invalid id entry if giving a dynamic id, so just disable the feature. [ 3105.018012] general protection fault: 0000 [#1] SMP DEBUG_PAGEALLOC [ 3105.018062] CPU 0 [ 3105.018075] Modules linked in: usb_storage usb_libusual bluetooth dm_crypt binfmt_misc snd_hda_codec_analog snd_hda_intel snd_hda_codec snd_hwdep hp_wmi ppdev sparse_keymap snd_pcm snd_seq_midi snd_rawmidi snd_seq_midi_event snd_seq snd_timer snd_seq_device psmouse snd serio_raw tpm_infineon soundcore i915 snd_page_alloc tpm_tis parport_pc tpm tpm_bios drm_kms_helper drm i2c_algo_bit video lp parport usbhid hid sg sr_mod sd_mod ehci_hcd uhci_hcd usbcore e1000e usb_common floppy [ 3105.018408] [ 3105.018419] Pid: 189, comm: khubd Tainted: G I 3.2.0-rc7+ #29 Hewlett-Packard HP Compaq dc7800p Convertible Minitower/0AACh [ 3105.018481] RIP: 0010:[<ffffffffa045830d>] [<ffffffffa045830d>] usb_stor_probe1+0x2fd/0xc20 [usb_storage] [ 3105.018536] RSP: 0018:ffff880056a3d830 EFLAGS: 00010286 [ 3105.018562] RAX: ffff880065f4e648 RBX: ffff88006bb28000 RCX: 0000000000000000 [ 3105.018597] RDX: ffff88006f23c7b0 RSI: 0000000000000001 RDI: 0000000000000206 [ 3105.018632] RBP: ffff880056a3d900 R08: 0000000000000000 R09: ffff880067365000 [ 3105.018665] R10: 00000000000002ac R11: 0000000000000010 R12: ffff6000b41a7340 [ 3105.018698] R13: ffff880065f4ef60 R14: ffff88006bb28b88 R15: ffff88006f23d270 [ 3105.018733] FS: 0000000000000000(0000) GS:ffff88007a200000(0000) knlGS:0000000000000000 [ 3105.018773] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [ 3105.018801] CR2: 00007fc99c8c4650 CR3: 0000000001e05000 CR4: 00000000000006f0 [ 3105.018835] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 3105.018870] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 3105.018906] Process khubd (pid: 189, threadinfo ffff880056a3c000, task ffff88005677a400) [ 3105.018945] Stack: [ 3105.018959] 0000000000000000 0000000000000000 ffff880056a3d8d0 0000000000000002 [ 3105.019011] 0000000000000000 ffff880056a3d918 ffff880000000000 0000000000000002 [ 3105.019058] ffff880056a3d8d0 0000000000000012 ffff880056a3d8d0 0000000000000006 [ 3105.019105] Call Trace: [ 3105.019128] [<ffffffffa0458cd4>] storage_probe+0xa4/0xe0 [usb_storage] [ 3105.019173] [<ffffffffa0097822>] usb_probe_interface+0x172/0x330 [usbcore] [ 3105.019211] [<ffffffff815fda67>] driver_probe_device+0x257/0x3b0 [ 3105.019243] [<ffffffff815fdd43>] __device_attach+0x73/0x90 [ 3105.019272] [<ffffffff815fdcd0>] ? __driver_attach+0x110/0x110 [ 3105.019303] [<ffffffff815fb93c>] bus_for_each_drv+0x9c/0xf0 [ 3105.019334] [<ffffffff815fd6c7>] device_attach+0xf7/0x120 [ 3105.019364] [<ffffffff815fc905>] bus_probe_device+0x45/0x80 [ 3105.019396] [<ffffffff815f98a6>] device_add+0x876/0x990 [ 3105.019434] [<ffffffffa0094e42>] usb_set_configuration+0x822/0x9e0 [usbcore] [ 3105.019479] [<ffffffffa00a3492>] generic_probe+0x62/0xf0 [usbcore] [ 3105.019518] [<ffffffffa0097a46>] usb_probe_device+0x66/0xb0 [usbcore] [ 3105.019555] [<ffffffff815fda67>] driver_probe_device+0x257/0x3b0 [ 3105.019589] [<ffffffff815fdd43>] __device_attach+0x73/0x90 [ 3105.019617] [<ffffffff815fdcd0>] ? __driver_attach+0x110/0x110 [ 3105.019648] [<ffffffff815fb93c>] bus_for_each_drv+0x9c/0xf0 [ 3105.019680] [<ffffffff815fd6c7>] device_attach+0xf7/0x120 [ 3105.019709] [<ffffffff815fc905>] bus_probe_device+0x45/0x80 [ 3105.021040] usb usb6: usb auto-resume [ 3105.021045] usb usb6: wakeup_rh [ 3105.024849] [<ffffffff815f98a6>] device_add+0x876/0x990 [ 3105.025086] [<ffffffffa0088987>] usb_new_device+0x1e7/0x2b0 [usbcore] [ 3105.025086] [<ffffffffa008a4d7>] hub_thread+0xb27/0x1ec0 [usbcore] [ 3105.025086] [<ffffffff810d5200>] ? wake_up_bit+0x50/0x50 [ 3105.025086] [<ffffffffa00899b0>] ? usb_remote_wakeup+0xa0/0xa0 [usbcore] [ 3105.025086] [<ffffffff810d49b8>] kthread+0xd8/0xf0 [ 3105.025086] [<ffffffff81939884>] kernel_thread_helper+0x4/0x10 [ 3105.025086] [<ffffffff8192a8c0>] ? _raw_spin_unlock_irq+0x50/0x80 [ 3105.025086] [<ffffffff8192b1b4>] ? retint_restore_args+0x13/0x13 [ 3105.025086] [<ffffffff810d48e0>] ? __init_kthread_worker+0x80/0x80 [ 3105.025086] [<ffffffff81939880>] ? gs_change+0x13/0x13 [ 3105.025086] Code: 00 48 83 05 cd ad 00 00 01 48 83 05 cd ad 00 00 01 4c 8b ab 30 0c 00 00 48 8b 50 08 48 83 c0 30 48 89 45 a0 4c 89 a3 40 0c 00 00 <41> 0f b6 44 24 10 48 89 55 a8 3c ff 0f 84 b8 04 00 00 48 83 05 [ 3105.025086] RIP [<ffffffffa045830d>] usb_stor_probe1+0x2fd/0xc20 [usb_storage] [ 3105.025086] RSP <ffff880056a3d830> [ 3105.060037] hub 6-0:1.0: hub_resume [ 3105.062616] usb usb5: usb auto-resume [ 3105.064317] ehci_hcd 0000:00:1d.7: resume root hub [ 3105.094809] ---[ end trace a7919e7f17c0a727 ]--- [ 3105.130069] hub 5-0:1.0: hub_resume [ 3105.132131] usb usb4: usb auto-resume [ 3105.132136] usb usb4: wakeup_rh [ 3105.180059] hub 4-0:1.0: hub_resume [ 3106.290052] usb usb6: suspend_rh (auto-stop) [ 3106.290077] usb usb4: suspend_rh (auto-stop) Signed-off-by: Huajun Li <huajun.li.lee@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12USB: isight: fix kernel bug when loading firmwareGreg Kroah-Hartman
commit 59bf5cf94f0fa3b08fb1258b52649077b7d0914d upstream. We were sending data on the stack when uploading firmware, which causes some machines fits, and is not allowed. Fix this by using the buffer we already had around for this very purpose. Reported-by: Wouter M. Koolen <wmkoolen@cwi.nl> Tested-by: Wouter M. Koolen <wmkoolen@cwi.nl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12drivers/usb/class/cdc-acm.c: clear dangling pointerJulia Lawall
commit e7c8e8605d0bafc705ff27f9da98a1668427cc0f upstream. On some failures, the country_code field of an acm structure is freed without freeing the acm structure itself. Elsewhere, operations including memcpy and kfree are performed on the country_code field. The patch sets the country_code field to NULL when it is freed, and likewise sets the country_code_size field to 0. Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12udf: Fix deadlock when converting file from in-ICB one to normal oneJan Kara
commit d2eb8c359309ec45d6bf5b147303ab8e13be86ea upstream. During BKL removal in 2.6.38, conversion of files from in-ICB format to normal format got broken. We call ->writepage with i_data_sem held but udf_get_block() also acquires i_data_sem thus creating A-A deadlock. We fix the problem by dropping i_data_sem before calling ->writepage() which is safe since i_mutex still protects us against any changes in the file. Also fix pagelock - i_data_sem lock inversion in udf_expand_file_adinicb() by dropping i_data_sem before calling find_or_create_page(). Reported-by: Matthias Matiak <netzpython@mail-on.us> Tested-by: Matthias Matiak <netzpython@mail-on.us> Reviewed-by: Namjae Jeon <linkinjeon@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12cgroup: fix to allow mounting a hierarchy by nameLi Zefan
commit 0d19ea866562e46989412a0676412fa0983c9ce7 upstream. If we mount a hierarchy with a specified name, the name is unique, and we can use it to mount the hierarchy without specifying its set of subsystem names. This feature is documented is Documentation/cgroups/cgroups.txt section 2.3 Here's an example: # mount -t cgroup -o cpuset,name=myhier xxx /cgroup1 # mount -t cgroup -o name=myhier xxx /cgroup2 But it was broken by commit 32a8cf235e2f192eb002755076994525cdbaa35a (cgroup: make the mount options parsing more accurate) This fixes the regression. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12atmel_serial: fix spinlock lockup in RS485 codeClaudio Scordino
commit dbf1115d3f8c7052788aa4e6e46abd27f3b3eeba upstream. Patch to fix a spinlock lockup in the driver that sometimes happens when the tasklet starts. Signed-off-by: Claudio Scordino <claudio@evidence.eu.com> Signed-off-by: Dave Bender <codehero@gmail.com> Tested-by: Dave Bender <codehero@gmail.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12USB: update documentation for usbmonAlan Stern
commit d8cae98cddd286e38db1724dda1b0e7b467f9237 upstream. The documentation for usbmon is out of date; the usbfs "devices" file now exists in /sys/kernel/debug/usb rather than /proc/bus/usb. This patch (as1505) updates the documentation accordingly, and also mentions that the necessary information can be found by running lsusb. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12ext3: Don't warn from writepage when readonly inode is spotted after errorJan Kara
commit 33c104d415e92a51aaf638dc3d93920cfa601e5c upstream. WARN_ON_ONCE(IS_RDONLY(inode)) tends to trip when filesystem hits error and is remounted read-only. This unnecessarily scares users (well, they should be scared because of filesystem error, but the stack trace distracts them from the right source of their fear ;-). We could as well just remove the WARN_ON but it's not hard to fix it to not trip on filesystem with errors and not use more cycles in the common case so that's what we do. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12reiserfs: Force inode evictions before umount to avoid crashJeff Mahoney
commit a9e36da655e54545c3289b2a0700b5c443de0edd upstream. This patch fixes a crash in reiserfs_delete_xattrs during umount. When shrink_dcache_for_umount clears the dcache from generic_shutdown_super, delayed evictions are forced to disk. If an evicted inode has extended attributes associated with it, it will need to walk the xattr tree to locate and remove them. But since shrink_dcache_for_umount will BUG if it encounters active dentries, the xattr tree must be released before it's called or it will crash during every umount. This patch forces the evictions to occur before generic_shutdown_super by calling shrink_dcache_sb first. The additional evictions caused by the removal of each associated xattr file and dir will be automatically handled as they're added to the LRU list. CC: reiserfs-devel@vger.kernel.org Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12reiserfs: Fix quota mount option parsingJan Kara
commit a06d789b424190e9f59da391681f908486db2554 upstream. When jqfmt mount option is not specified on remount, we mistakenly clear s_jquota_fmt value stored in superblock. Fix the problem. CC: reiserfs-devel@vger.kernel.org Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12perf: Fix parsing of __print_flags() in TP_printk()Steven Rostedt
commit 49908a1b25d448d68fd26faca260e1850201575f upstream. A update is made to the sched:sched_switch event that adds some logic to the first parameter of the __print_flags() that shows the state of tasks. This change cause perf to fail parsing the flags. A simple fix is needed to have the parser be able to process ops within the argument. Reported-by: Andrew Vagin <avagin@openvz.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12IB/qib: Fix a possible data corruption when receiving packetsRam Vepa
commit eddfb675256f49d14e8c5763098afe3eb2c93701 upstream. Prevent a receive data corruption by ensuring that the write to update the rcvhdrheadn register to generate an interrupt is at the very end of the receive processing. Signed-off-by: Ramkrishna Vepa <ram.vepa@qlogic.com> Signed-off-by: Mike Marciniszyn <mike.marciniszyn@qlogic.com> Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12asix: new device idAurelien Jacobs
commit e8303a3b2196272c3eb994d0fd1a189a958a2bdd upstream. Adds the device id needed for the USB Ethernet Adapter delivered by ASUS with their Zenbook. Signed-off-by: Aurelien Jacobs <aurel@gnuage.org> Acked-by: Grant Grundler <grundler@chromium.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12powerpc: Fix unpaired probe_hcall_entry and probe_hcall_exitLi Zhong
commit e4f387d8db3ba3c2dae4d8bdfe7bb5f4fe1bcb0d upstream. Unpaired calling of probe_hcall_entry and probe_hcall_exit might happen as following, which could cause incorrect preempt count. __trace_hcall_entry => trace_hcall_entry -> probe_hcall_entry => get_cpu_var => preempt_disable __trace_hcall_exit => trace_hcall_exit -> probe_hcall_exit => put_cpu_var => preempt_enable where: A => B and A -> B means A calls B, but => means A will call B through function name, and B will definitely be called. -> means A will call B through function pointer, so B might not be called if the function pointer is not set. So error happens when only one of probe_hcall_entry and probe_hcall_exit get called during a hcall. This patch tries to move the preempt count operations from probe_hcall_entry and probe_hcall_exit to its callers. Reported-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Li Zhong <zhong@linux.vnet.ibm.com> Tested-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12powerpc/time: Handle wrapping of decrementerAnton Blanchard
commit 37fb9a0231ee43d42d069863bdfd567fca2b61af upstream. When re-enabling interrupts we have code to handle edge sensitive decrementers by resetting the decrementer to 1 whenever it is negative. If interrupts were disabled long enough that the decrementer wrapped to positive we do nothing. This means interrupts can be delayed for a long time until it finally goes negative again. While we hope interrupts are never be disabled long enough for the decrementer to go positive, we have a very good test team that can drive any kernel into the ground. The softlockup data we get back from these fails could be seconds in the future, completely missing the cause of the lockup. We already keep track of the timebase of the next event so use that to work out if we should trigger a decrementer exception. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12wl12xx: Check buffer bound when processing nvs dataPontus Fuchs
commit f6efe96edd9c41c624c8f4ddbc4930c1a2d8f1e1 upstream. An nvs with malformed contents could cause the processing of the calibration data to read beyond the end of the buffer. Prevent this from happening by adding bound checking. Signed-off-by: Pontus Fuchs <pontus.fuchs@gmail.com> Reviewed-by: Luciano Coelho <coelho@ti.com> Signed-off-by: Luciano Coelho <coelho@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12wl12xx: Validate FEM index from ini file and FWPontus Fuchs
commit 2131d3c2f99b081806fdae7662c92fe6acda52af upstream. Check for out of bound FEM index to prevent reading beyond ini memory end. Signed-off-by: Pontus Fuchs <pontus.fuchs@gmail.com> Reviewed-by: Luciano Coelho <coelho@ti.com> Signed-off-by: Luciano Coelho <coelho@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12offb: Fix bug in calculating requested vram sizeBenjamin Herrenschmidt
commit c055fe0797b7bd8f6f21a13598a55a16d5c13ae7 upstream. We used to try to request 8 times more vram than needed, which would fail if the card has a too small BAR (observed with qemu & kvm). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12offb: Fix setting of the pseudo-palette for >8bppBenjamin Herrenschmidt
commit 1bb0b7d21584b3f878e2bc880db62351ddee5185 upstream. When using a >8bpp framebuffer, offb advertises truecolor, not directcolor, and doesn't touch the color map even if it has a corresponding access method for the real hardware. Thus it needs to set the pseudo-palette with all 3 components of the color, like other truecolor framebuffers, not with copies of the color index like a directcolor framebuffer would do. This went unnoticed for a long time because it's pretty hard to get offb to kick in with anything but 8bpp (old BootX under MacOS will do that and qemu does it). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12rt2800usb: Move ID out of unknownLarry Finger
commit 3f81f8f1524ccca24df1029b0cf825ecef5e5cdc upstream. Testing on the openSUSE wireless forum has shown that a Linksys WUSB54GC v3 with USB ID 1737:0077 works with rt2800usb when the ID is written to /sys/.../new_id. This ID can therefore be moved out of UNKNOWN. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> Acked-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12firmware: Fix an oops on reading fw_priv->fw in sysfs loading fileNeil Horman
commit eea915bb0d1358755f151eaefb8208a2d5f3e10c upstream. This oops was reported recently: firmware_loading_store+0xf9/0x17b dev_attr_store+0x20/0x22 sysfs_write_file+0x101/0x134 vfs_write+0xac/0xf3 sys_write+0x4a/0x6e system_call_fastpath+0x16/0x1b The complete backtrace was unfortunately not captured, but details can be found here: https://bugzilla.redhat.com/show_bug.cgi?id=769920 The cause is fairly clear. Its caused by the fact that firmware_loading_store has a case 0 in its switch statement that reads and writes the fw_priv->fw poniter without the protection of the fw_lock mutex. since there is a window between the time that _request_firmware sets fw_priv->fw to NULL and the time the corresponding sysfs file is unregistered, its possible for a user space application to race in, and write a zero to the loading file, causing a NULL dereference in firmware_loading_store. Fix it by extending the protection of the fw_lock mutex to cover all of the firware_loading_store function. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12Documentation: Update stable addressJoe Perches
commit 2eb7f204db51969ea558802a6601d79c2fb273b9 upstream. The Japanese/Korean/Chinese versions still need updating. Also, the stable kernel 2.6.x.y descriptions are out of date and should be updated as well. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12MAINTAINERS: stable: Update addressJoe Perches
commit bc7a2f3abc636d7cab84258a48e77b08fb5fd3d6 upstream. The old address hasn't worked since the great intrusion of August 2011. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-06Linux 3.0.16v3.0.16Greg Kroah-Hartman
2012-01-06ath9k: Fix kernel panic in AR2427 in AP modeMohammed Shafi Shajakhan
commit b25bfda38236f349cde0d1b28952f4eea2148d3f upstream. don't do aggregation related stuff for 'AP mode client power save handling' if aggregation is not enabled in the driver, otherwise it will lead to panic because those data structures won't be never intialized in 'ath_tx_node_init' if aggregation is disabled EIP is at ath_tx_aggr_wakeup+0x37/0x80 [ath9k] EAX: e8c09a20 EBX: f2a304e8 ECX: 00000001 EDX: 00000000 ESI: e8c085e0 EDI: f2a304ac EBP: f40e1ca4 ESP: f40e1c8c DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068 Process swapper/1 (pid: 0, ti=f40e0000 task=f408e860 task.ti=f40dc000) Stack: 0001e966 e8c09a20 00000000 f2a304ac e8c085e0 f2a304ac f40e1cb0 f8186741 f8186700 f40e1d2c f922988d f2a304ac 00000202 00000001 c0b4ba43 00000000 0000000f e8eb75c0 e8c085e0 205b0001 34383220 f2a304ac f2a30000 00010020 Call Trace: [<f8186741>] ath9k_sta_notify+0x41/0x50 [ath9k] [<f8186700>] ? ath9k_get_survey+0x110/0x110 [ath9k] [<f922988d>] ieee80211_sta_ps_deliver_wakeup+0x9d/0x350 [mac80211] [<c018dc75>] ? __module_address+0x95/0xb0 [<f92465b3>] ap_sta_ps_end+0x63/0xa0 [mac80211] [<f9246746>] ieee80211_rx_h_sta_process+0x156/0x2b0 [mac80211] [<f9247d1e>] ieee80211_rx_handlers+0xce/0x510 [mac80211] [<c018440b>] ? trace_hardirqs_on+0xb/0x10 [<c056936e>] ? skb_queue_tail+0x3e/0x50 [<f9248271>] ieee80211_prepare_and_rx_handle+0x111/0x750 [mac80211] [<f9248bf9>] ieee80211_rx+0x349/0xb20 [mac80211] [<f9248949>] ? ieee80211_rx+0x99/0xb20 [mac80211] [<f818b0b8>] ath_rx_tasklet+0x818/0x1d00 [ath9k] [<f8187a75>] ? ath9k_tasklet+0x35/0x1c0 [ath9k] [<f8187a75>] ? ath9k_tasklet+0x35/0x1c0 [ath9k] [<f8187b33>] ath9k_tasklet+0xf3/0x1c0 [ath9k] [<c0151b7e>] tasklet_action+0xbe/0x180 Cc: Senthil Balasubramanian <senthilb@qca.qualcomm.com> Cc: Rajkumar Manoharan <rmanohar@qca.qualcomm.com> Reported-by: Ashwin Mendonca <ashwinloyal@gmail.com> Tested-by: Ashwin Mendonca <ashwinloyal@gmail.com> Signed-off-by: Mohammed Shafi Shajakhan <mohammed@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-06ptrace: partially fix the do_wait(WEXITED) vs EXIT_DEAD->EXIT_ZOMBIE raceOleg Nesterov
commit 50b8d257486a45cba7b65ca978986ed216bbcc10 upstream. Test-case: int main(void) { int pid, status; pid = fork(); if (!pid) { for (;;) { if (!fork()) return 0; if (waitpid(-1, &status, 0) < 0) { printf("ERR!! wait: %m\n"); return 0; } } } assert(ptrace(PTRACE_ATTACH, pid, 0,0) == 0); assert(waitpid(-1, NULL, 0) == pid); assert(ptrace(PTRACE_SETOPTIONS, pid, 0, PTRACE_O_TRACEFORK) == 0); do { ptrace(PTRACE_CONT, pid, 0, 0); pid = waitpid(-1, NULL, 0); } while (pid > 0); return 1; } It fails because ->real_parent sees its child in EXIT_DEAD state while the tracer is going to change the state back to EXIT_ZOMBIE in wait_task_zombie(). The offending commit is 823b018e which moved the EXIT_DEAD check, but in fact we should not blame it. The original code was not correct as well because it didn't take ptrace_reparented() into account and because we can't really trust ->ptrace. This patch adds the additional check to close this particular race but it doesn't solve the whole problem. We simply can't rely on ->ptrace in this case, it can be cleared if the tracer is multithreaded by the exiting ->parent. I think we should kill EXIT_DEAD altogether, we should always remove the soon-to-be-reaped child from ->children or at least we should never do the DEAD->ZOMBIE transition. But this is too complex for 3.2. Reported-and-tested-by: Denys Vlasenko <vda.linux@googlemail.com> Tested-by: Lukasz Michalik <lmi@ift.uni.wroc.pl> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-06Revert "rtc: Disable the alarm in the hardware"Linus Torvalds
commit 157e8bf8b4823bfcdefa6c1548002374b61f61df upstream. This reverts commit c0afabd3d553c521e003779c127143ffde55a16f. It causes failures on Toshiba laptops - instead of disabling the alarm, it actually seems to enable it on the affected laptops, resulting in (for example) the laptop powering on automatically five minutes after shutdown. There's a patch for it that appears to work for at least some people, but it's too late to play around with this, so revert for now and try again in the next merge window. See for example http://bugs.debian.org/652869 Reported-and-bisected-by: Andreas Friedrich <afrie@gmx.net> (Toshiba Tecra) Reported-by: Antonio-M. Corbi Bellot <antonio.corbi@ua.es> (Toshiba Portege R500) Reported-by: Marco Santos <marco.santos@waynext.com> (Toshiba Portege Z830) Reported-by: Christophe Vu-Brugier <cvubrugier@yahoo.fr> (Toshiba Portege R830) Cc: Jonathan Nieder <jrnieder@gmail.com> Requested-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-06hung_task: fix false positive during vforkMandeep Singh Baines
commit f9fab10bbd768b0e5254e53a4a8477a94bfc4b96 upstream. vfork parent uninterruptibly and unkillably waits for its child to exec/exit. This wait is of unbounded length. Ignore such waits in the hung_task detector. Signed-off-by: Mandeep Singh Baines <msb@chromium.org> Reported-by: Sasha Levin <levinsasha928@gmail.com> LKML-Reference: <1325344394.28904.43.camel@lappy> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: John Kacur <jkacur@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-06drm/radeon/kms/atom: fix possible segfault in pm setupAlexander Müller
commit 4376eee92e5a8332b470040e672ea99cd44c826a upstream. If we end up with no power states, don't look up current vddc. fixes: https://bugs.freedesktop.org/show_bug.cgi?id=44130 agd5f: fix patch formatting Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-06xfs: log all dirty inodes in xfs_fs_sync_fsChristoph Hellwig
Commit be4f1ac828776bbc7868a68b465cd8eedb733cfd upstream. Since Linux 2.6.36 the writeback code has introduces various measures for live lock prevention during sync(). Unfortunately some of these are actively harmful for the XFS model, where the inode gets marked dirty for metadata from the data I/O handler. The older_than_this checks that are now more strictly enforced since writeback: avoid livelocking WB_SYNC_ALL writeback by only calling into __writeback_inodes_sb and thus only sampling the current cut off time once. But on a slow enough devices the previous asynchronous sync pass might not have fully completed yet, and thus XFS might mark metadata dirty only after that sampling of the cut off time for the blocking pass already happened. I have not myself reproduced this myself on a real system, but by introducing artificial delay into the XFS I/O completion workqueues it can be reproduced easily. Fix this by iterating over all XFS inodes in ->sync_fs and log all that are dirty. This might log inode that only got redirtied after the previous pass, but given how cheap delayed logging of inodes is it isn't a major concern for performance. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Tested-by: Mark Tinguely <tinguely@sgi.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-06xfs: log the inode in ->write_inode calls for kupdateChristoph Hellwig
Commit 0b8fd3033c308e4088760aa1d38ce77197b4e074 upstream. If the writeback code writes back an inode because it has expired we currently use the non-blockin ->write_inode path. This means any inode that is pinned is skipped. With delayed logging and a workload that has very little log traffic otherwise it is very likely that an inode that gets constantly written to is always pinned, and thus we keep refusing to write it. The VM writeback code at that point redirties it and doesn't try to write it again for another 30 seconds. This means under certain scenarious time based metadata writeback never happens. Fix this by calling into xfs_log_inode for kupdate in addition to data integrity syncs, and thus transfer the inode to the log ASAP. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Tested-by: Mark Tinguely <tinguely@sgi.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-06xen/swiotlb: Use page alignment for early buffer allocation.Konrad Rzeszutek Wilk
commit 63a741757d15320a25ebf5778f8651cce2ed0611 upstream. This fixes an odd bug found on a Dell PowerEdge 1850/0RC130 (BIOS A05 01/09/2006) where all of the modules doing pci_set_dma_mask would fail with: ata_piix 0000:00:1f.1: enabling device (0005 -> 0007) ata_piix 0000:00:1f.1: can't derive routing for PCI INT A ata_piix 0000:00:1f.1: BMDMA: failed to set dma mask, falling back to PIO The issue was the Xen-SWIOTLB was allocated such as that the end of buffer was stradling a page (and also above 4GB). The fix was spotted by Kalev Leonid which was to piggyback on git commit e79f86b2ef9c0a8c47225217c1018b7d3d90101c "swiotlb: Use page alignment for early buffer allocation" which: We could call free_bootmem_late() if swiotlb is not used, and it will shrink to page alignment. So alloc them with page alignment at first, to avoid lose two pages And doing that fixes the outstanding issue. Suggested-by: "Kalev, Leonid" <Leonid.Kalev@ca.com> Reported-and-Tested-by: "Taylor, Neal E" <Neal.Taylor@ca.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
