2011-05-18Linux 2.6.39v2.6.39Linus Torvalds
2011-05-18Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2 * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2: configfs: Fix race between configfs_readdir() and configfs_d_iput() configfs: Don't try to d_delete() negative dentries. ocfs2/dlm: Target node death during resource migration leads to thread spin ocfs2: Skip mount recovery for hard-ro mounts ocfs2/cluster: Heartbeat mismatch message improved ocfs2/cluster: Increase the live threshold for global heartbeat ocfs2/dlm: Use negotiated o2dlm protocol version ocfs2: skip existing hole when removing the last extent_rec in punching-hole codes. ocfs2: Initialize data_ac (might be used uninitialized)
2011-05-18Merge branch 'devicetree/merge' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'devicetree/merge' of git://git.secretlab.ca/git/linux-2.6: drivercore: revert addition of of_match to struct device of: fix race when matching drivers
2011-05-18Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linus: MIPS: Kludge IP27 build for 2.6.39. MIPS: AR7: Fix GPIO register size for Titan variant. MIPS: Fix duplicate invocation of notify_die. MIPS: RB532: Fix iomap resource size miscalculation.
2011-05-18drivercore: revert addition of of_match to struct deviceGrant Likely
Commit b826291c, "drivercore/dt: add a match table pointer to struct device" added an of_match pointer to struct device to cache the of_match_table entry discovered at driver match time. This was unsafe because matching is not an atomic operation with probing a driver. If two or more drivers are attempted to be matched to a driver at the same time, then the cached matching entry pointer could get overwritten. This patch reverts the of_match cache pointer and reworks all users to call of_match_device() directly instead. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-18of: fix race when matching driversMilton Miller
If two drivers are probing devices at the same time, both will write their match table result to the dev->of_match cache at the same time. Only write the result if the device matches. In a thread titled "SBus devices sometimes detected, sometimes not", Meelis reported his SBus hme was not detected about 50% of the time. From the debug suggested by Grant it was obvious another driver matched some devices between the call to match the hme and the hme discovery failling. Reported-by: Meelis Roos <mroos@linux.ee> Signed-off-by: Milton Miller <miltonm@bga.com> [grant.likely: modified to only call of_match_device() once] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-18Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blocklatestLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: block: don't delay blk_run_queue_async scsi: remove performance regression due to async queue run blk-throttle: Use task_subsys_state() to determine a task's blkio_cgroup block: rescan partitions on invalidated devices on -ENOMEDIA too cdrom: always check_disk_change() on open block: unexport DISK_EVENT_MEDIA_CHANGE for legacy/fringe drivers
2011-05-18MIPS: Kludge IP27 build for 2.6.39.Ralf Baechle
2011-05-18MIPS: AR7: Fix GPIO register size for Titan variant.Florian Fainelli
The 'size' variable contains the correct register size for both AR7 and Titan, but we never used it to ioremap the correct register size. This problem only shows up on Titan. [ralf@linux-mips.org: Fixed the fix. The original patch as in patchwork recognizes the problem correctly then fails to fix it ...] Reported-by: Alexander Clouter <alex@digriz.org.uk> Signed-off-by: Florian Fainelli <florian@openwrt.org> Patchwork: https://patchwork.linux-mips.org/patch/2380/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-18MIPS: Fix duplicate invocation of notify_die.Ralf Baechle
Initial patch by Yury Polyanskiy <ypolyans@princeton.edu>. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/2373/
2011-05-18MIPS: RB532: Fix iomap resource size miscalculation.Ralf Baechle
This is the MIPS portion of Joe Perches <joe@perches.com>'s https://patchwork.linux-mips.org/patch/2172/ which seems to have been lost in time and space. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-18configfs: Fix race between configfs_readdir() and configfs_d_iput()Joel Becker
configfs_readdir() will use the existing inode numbers of inodes in the dcache, but it makes them up for attribute files that aren't currently instantiated. There is a race where a closing attribute file can be tearing down at the same time as configfs_readdir() is trying to get its inode number. We want to get the inode number of open attribute files, because they should match while instantiated. We can't lock down the transition where dentry->d_inode is set to NULL, so we just check for NULL there. We can, however, ensure that an inode we find isn't iput() in configfs_d_iput() until after we've accessed it. Signed-off-by: Joel Becker <jlbec@evilplan.org>
2011-05-18configfs: Don't try to d_delete() negative dentries.Joel Becker
When configfs is faking mkdir() on its subsystem or default group objects, it starts by adding a negative dentry. It then tries to instantiate the group. If that should fail, it must clean up after itself. I was using d_delete() here, but configfs_attach_group() promises to return an empty dentry on error. d_delete() explodes with the entry dentry. Let's try d_drop() instead. The unhashing is what we want for our dentry. Signed-off-by: Joel Becker <jlbec@evilplan.org>
2011-05-18block: don't delay blk_run_queue_asyncShaohua Li
Let's check a scenario: 1. blk_delay_queue(q, SCSI_QUEUE_DELAY); 2. blk_run_queue_async(); the second one will became a noop, because q->delay_work already has WORK_STRUCT_PENDING_BIT set, so the delayed work will still run after SCSI_QUEUE_DELAY. But blk_run_queue_async actually hopes the delayed work runs immediately. Fix this by doing a cancel on potentially pending delayed work before queuing an immediate run of the workqueue. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-18Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: [media] V4L: soc-camera: regression fix: calculate .sizeimage in soc_camera.c [media] v4l2-subdev: fix broken subdev control enumeration [media] Fix cx88 remote control input [media] v4l: Release module if subdev registration fails
2011-05-18Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, AMD: Fix ARAT feature setting again Revert "x86, AMD: Fix APIC timer erratum 400 affecting K8 Rev.A-E processors" x86, apic: Fix spurious error interrupts triggering on all non-boot APs x86, mce, AMD: Fix leaving freed data in a list x86: Fix UV BAU for non-consecutive nasids x86, UV: Fix NMI handler for UV platforms
2011-05-18Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf evlist: Fix per thread mmap setup perf tools: Honour the cpu list parameter when also monitoring a thread list kprobes, x86: Disable irqs during optimized callback
2011-05-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: cifs: fix cifsConvertToUCS() for the mapchars case cifs: add fallback in is_path_accessible for old servers
2011-05-18procfs: add stub for proc_mkdir_mode()Randy Dunlap
Provide a stub for proc_mkdir_mode() when CONFIG_PROC_FS is not enabled, just like the stub for proc_mkdir(). Fixes this linux-next build error: drivers/net/wireless/airo.c:4504: error: implicit declaration of function 'proc_mkdir_mode' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "John W. Linville" <linville@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-18um: fix abortRichard Weinberger
os_dump_core() uses abort() to terminate UML in case of an fatal error. glibc's abort() calls raise(SIGABRT) which makes use of tgkill(). tgkill() has no effect within UML's kernel threads because they are not pthreads. As fallback abort() executes an invalid instruction to terminate the process. Therefore UML gets killed by SIGSEGV and leaves a ugly log entry in the host's kernel ring buffer. To get rid of this we use our own abort routine. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-18memcg: fix zone congestionKAMEZAWA Hiroyuki
ZONE_CONGESTED should be a state of global memory reclaim. If not, a busy memcg sets this and give unnecessary throttoling in wait_iff_congested() against memory recalim in other contexts. This makes system performance bad. I'll think about "memcg is congested!" flag is required or not, later. But this fix is required first. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: Ying Han <yinghan@google.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Johannes Weiner <jweiner@redhat.com> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-18drivers/leds/leds-lm3530.c: add MODULE_DEVICE_TABLEAxel Lin
Adding the necessary MODULE_DEVICE_TABLE() information allows the driver to be automatically loaded by udev. Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Shreshtha Kumar SAHU <shreshthakumar.sahu@stericsson.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-18rapidio: fix default routing initializationAlexandre Bounine
Fix switch initialization to ensure that all switches have default routing disabled. This guarantees that no unexpected RapidIO packets arrive to the default port set by reset and there is no default routing destination until it is properly configured by software. This update also unifies handling of unmapped destinations by tsi57x, IDT Gen1 and IDT Gen2 switches. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Thomas Moll <thomas.moll@sysgo.com> Cc: <stable@kernel.org> [2.6.37+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-17cifs: fix cifsConvertToUCS() for the mapchars caseJeff Layton
As Metze pointed out, commit 84cdf74e broke mapchars option: Commit "cifs: fix unaligned accesses in cifsConvertToUCS" (84cdf74e8096a10dd6acbb870dd404b92f07a756) does multiple steps in just one commit (moving the function and changing it without testing). put_unaligned_le16(temp, &target[j]); is never called for any codepoint the goes via the 'default' switch statement. As a result we put just zero (or maybe uninitialized) bytes into the target buffer. His proposed patch looks correct, but doesn't apply to the current head of the tree. This patch should also fix it. Cc: <stable@kernel.org> # .38.x: 581ade4: cifs: clean up various nits in unicode routines (try #2) Reported-by: Stefan Metzmacher <metze@samba.org> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-05-17cifs: add fallback in is_path_accessible for old serversJeff Layton
The is_path_accessible check uses a QPathInfo call, which isn't supported by ancient win9x era servers. Fall back to an older SMBQueryInfo call if it fails with the magic error codes. Cc: stable@kernel.org Reported-and-Tested-by: Sandro Bonazzola <sandro.bonazzola@gmail.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-05-17Merge branch 'timers-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: tick: Clear broadcast active bit when switching to oneshot rtc: mc13xxx: Don't call rtc_device_register while holding lock rtc: rp5c01: Initialize drvdata before registering device rtc: pcap: Initialize drvdata before registering device rtc: msm6242: Initialize drvdata before registering device rtc: max8998: Initialize drvdata before registering device rtc: max8925: Initialize drvdata before registering device rtc: m41t80: Initialize clientdata before registering device rtc: ds1286: Initialize drvdata before registering device rtc: ep93xx: Initialize drvdata before registering device rtc: davinci: Initialize drvdata before registering device rtc: mxc: Initialize drvdata before registering device clocksource: Install completely before selecting
2011-05-17x86, AMD: Fix ARAT feature setting againBorislav Petkov
Trying to enable the local APIC timer on early K8 revisions uncovers a number of other issues with it, in conjunction with the C1E enter path on AMD. Fixing those causes much more churn and troubles than the benefit of using that timer brings so don't enable it on K8 at all, falling back to the original functionality the kernel had wrt to that. Reported-and-bisected-by: Nick Bowler <nbowler@elliptictech.com> Cc: Boris Ostrovsky <Boris.Ostrovsky@amd.com> Cc: Andreas Herrmann <andreas.herrmann3@amd.com> Cc: Greg Kroah-Hartman <greg@kroah.com> Cc: Hans Rosenfeld <hans.rosenfeld@amd.com> Cc: Nick Bowler <nbowler@elliptictech.com> Cc: Joerg-Volker-Peetz <jvpeetz@web.de> Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Link: http://lkml.kernel.org/r/1305636919-31165-3-git-send-email-bp@amd64.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-05-17Revert "x86, AMD: Fix APIC timer erratum 400 affecting K8 Rev.A-E processors"Borislav Petkov
This reverts commit e20a2d205c05cef6b5783df339a7d54adeb50962, as it crashes certain boxes with specific AMD CPU models. Moving the lower endpoint of the Erratum 400 check to accomodate earlier K8 revisions (A-E) opens a can of worms which is simply not worth to fix properly by tweaking the errata checking framework: * missing IntPenging MSR on revisions < CG cause #GP: http://marc.info/?l=linux-kernel&m=130541471818831 * makes earlier revisions use the LAPIC timer instead of the C1E idle routine which switches to HPET, thus not waking up in deeper C-states: http://lkml.org/lkml/2011/4/24/20 Therefore, leave the original boundary starting with K8-revF. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-05-17scsi: remove performance regression due to async queue runJens Axboe
Commit c21e6beb removed our queue request_fn re-enter protection, and defaulted to always running the queues from kblockd to be safe. This was a known potential slow down, but should be safe. Unfortunately this is causing big performance regressions for some, so we need to improve this logic. Looking into the details of the re-enter, the real issue is on requeue of requests. Requeue of requests upon seeing a BUSY condition from the device ends up re-running the queue, causing traces like this: scsi_request_fn() scsi_dispatch_cmd() scsi_queue_insert() __scsi_queue_insert() scsi_run_queue() scsi_request_fn() ... potentially causing the issue we want to avoid. So special case the requeue re-run of the queue, but improve it to offload the entire run of local queue and starved queue from a single workqueue callback. This is a lot better than potentially kicking off a workqueue run for each device seen. This also fixes the issue of the local device going into recursion, since the above mentioned commit never moved that queue run out of line. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: net: Change netdev_fix_features messages loglevel vmxnet3: Fix inconsistent LRO state after initialization sfc: Fix oops in register dump after mapping change IPVS: fix netns if reading ip_vs_* procfs entries bridge: fix forwarding of IPv6
2011-05-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: Revert "mmc: fix a race between card-detect rescan and clock-gate work instances"
2011-05-16mm: fix kernel-doc warning in page_alloc.cRandy Dunlap
Fix new kernel-doc warning in mm/page_alloc.c: Warning(mm/page_alloc.c:2370): No description found for parameter 'nid' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-16PCI: Clear bridge resource flags if requested size is 0Yinghai Lu
During pci remove/rescan testing found: pci 0000:c0:03.0: PCI bridge to [bus c4-c9] pci 0000:c0:03.0: bridge window [io 0x1000-0x0fff] pci 0000:c0:03.0: bridge window [mem 0xf0000000-0xf00fffff] pci 0000:c0:03.0: bridge window [mem 0xfc180000000-0xfc197ffffff 64bit pref] pci 0000:c0:03.0: device not available (can't reserve [io 0x1000-0x0fff]) pci 0000:c0:03.0: Error enabling bridge (-22), continuing pci 0000:c0:03.0: enabling bus mastering pci 0000:c0:03.0: setting latency timer to 64 pcieport 0000:c0:03.0: device not available (can't reserve [io 0x1000-0x0fff]) pcieport: probe of 0000:c0:03.0 failed with error -22 This bug was caused by commit c8adf9a3e873 ("PCI: pre-allocate additional resources to devices only after successful allocation of essential resources.") After that commit, pci_hotplug_io_size is changed to additional_io_size from minium size. So it will not go through resource_size(res) != 0 path, and will not be reset. The root cause is: pci_bridge_check_ranges will set RESOURCE_IO flag for pci bridge, and later if children do not need IO resource. those bridge resources will not need to be allocated. but flags is still there. that will confuse the the pci_enable_bridges later. related code: static void assign_requested_resources_sorted(struct resource_list *head, struct resource_list_x *fail_head) { struct resource *res; struct resource_list *list; int idx; for (list = head->next; list; list = list->next) { res = list->res; idx = res - &list->dev->resource[0]; if (resource_size(res) && pci_assign_resource(list->dev, idx)) { ... reset_resource(res); } } } At last, We have to clear the flags in pbus_size_mem/io when requested size == 0 and !add_head. becasue this case it will not go through adjust_resources_sorted(). Just make size1 = size0 when !add_head. it will make flags get cleared. At the same time when requested size == 0, add_size != 0, will still have in head and add_list. because we do not clear the flags for it. After this, we will get right result: pci 0000:c0:03.0: PCI bridge to [bus c4-c9] pci 0000:c0:03.0: bridge window [io disabled] pci 0000:c0:03.0: bridge window [mem 0xf0000000-0xf00fffff] pci 0000:c0:03.0: bridge window [mem 0xfc180000000-0xfc197ffffff 64bit pref] pci 0000:c0:03.0: enabling bus mastering pci 0000:c0:03.0: setting latency timer to 64 pcieport 0000:c0:03.0: setting latency timer to 64 pcieport 0000:c0:03.0: irq 160 for MSI/MSI-X pcieport 0000:c0:03.0: Signaling PME through PCIe PME interrupt pci 0000:c4:00.0: Signaling PME through PCIe PME interrupt pcie_pme 0000:c0:03.0:pcie01: service driver pcie_pme loaded aer 0000:c0:03.0:pcie02: service driver aer loaded pciehp 0000:c0:03.0:pcie04: Hotplug Controller: v3: more simple fix. also fix one typo in pbus_size_mem Signed-off-by: Yinghai Lu <yinghai@kernel.org> Reviewed-by: Ram Pai <linuxram@us.ibm.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-16tick: Clear broadcast active bit when switching to oneshotThomas Gleixner
The first cpu which switches from periodic to oneshot mode switches also the broadcast device into oneshot mode. The broadcast device serves as a backup for per cpu timers which stop in deeper C-states. To avoid starvation of the cpus which might be in idle and depend on broadcast mode it marks the other cpus as broadcast active and sets the brodcast expiry value of those cpus to the next tick. The oneshot mode broadcast bit for the other cpus is sticky and gets only cleared when those cpus exit idle. If a cpu was not idle while the bit got set in consequence the bit prevents that the broadcast device is armed on behalf of that cpu when it enters idle for the first time after it switched to oneshot mode. In most cases that goes unnoticed as one of the other cpus has usually a timer pending which keeps the broadcast device armed with a short timeout. Now if the only cpu which has a short timer active has the bit set then the broadcast device will not be armed on behalf of that cpu and will fire way after the expected timer expiry. In the case of Christians bug report it took ~145 seconds which is about half of the wrap around time of HPET (the limit for that device) due to the fact that all other cpus had no timers armed which expired before the 145 seconds timeframe. The solution is simply to clear the broadcast active bit unconditionally when a cpu switches to oneshot mode after the first cpu switched the broadcast device over. It's not idle at that point otherwise it would not be executing that code. [ I fundamentally hate that broadcast crap. Why the heck thought some folks that when going into deep idle it's a brilliant concept to switch off the last device which brings the cpu back from that state? ] Thanks to Christian for providing all the valuable debug information! Reported-and-tested-by: Christian Hoffmann <email@christianhoffmann.info> Cc: John Stultz <johnstul@us.ibm.com> Link: http://lkml.kernel.org/r/%3Calpine.LFD.2.02.1105161105170.3078%40ionos%3E Cc: stable@kernel.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-05-16net: Change netdev_fix_features messages loglevelMichał Mirosław
Those reduced to DEBUG can possibly be triggered by unprivileged processes and are nothing exceptional. Illegal checksum combinations can only be caused by driver bug, so promote those messages to WARN. Since GSO without SG will now only cause DEBUG message from netdev_fix_features(), remove the workaround from register_netdevice(). Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16vmxnet3: Fix inconsistent LRO state after initializationThomas Jarosch
During initialization of vmxnet3, the state of LRO gets out of sync with netdev->features. This leads to very poor TCP performance in a IP forwarding setup and is hitting many VMware users. Simplified call sequence: 1. vmxnet3_declare_features() initializes "adapter->lro" to true. 2. The kernel automatically disables LRO if IP forwarding is enabled, so vmxnet3_set_flags() gets called. This also updates netdev->features. 3. Now vmxnet3_setup_driver_shared() is called. "adapter->lro" is still set to true and LRO gets enabled again, even though netdev->features shows it's disabled. Fix it by updating "adapter->lro", too. The private vmxnet3 adapter flags are scheduled for removal in net-next, see commit a0d2730c9571aeba793cb5d3009094ee1d8fda35 "net: vmxnet3: convert to hw_features". Patch applies to 2.6.37 / 2.6.38 and 2.6.39-rc6. Please CC: comments. Signed-off-by: Thomas Jarosch <thomas.jarosch@intra2net.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16sfc: Fix oops in register dump after mapping changeBen Hutchings
Commit 747df2258b1b9a2e25929ef496262c339c380009 ('sfc: Always map MCDI shared memory as uncacheable') introduced a separate mapping for the MCDI shared memory (MC_TREG_SMEM). This means we can no longer easily include it in the register dump. Since it is not particularly useful in debugging, substitute a recognisable dummy value. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-16Merge branch 'omap-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: OMAP3: set the core dpll clk rate in its set_rate function omap: iommu: Return IRQ_HANDLED in fault handler when no fault occured
2011-05-16Merge branch 'drm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: drm: Take lock around probes for drm_fb_helper_hotplug_event drm/i915: Revert i915.semaphore=1 default from 47ae63e0 vga_switcheroo: don't toggle-switch devices drm/radeon/kms: add some evergreen/ni safe regs drm/radeon/kms: fix extended lvds info parsing drm/radeon/kms: fix tiling reg on fusion
2011-05-16Revert "mmc: fix a race between card-detect rescan and clock-gate work ↵Chris Ball
instances" This reverts commit 26fc8775b51484d8c0a671198639c6d5ae60533e, which has been reported to cause boot/resume-time crashes for some users: https://bbs.archlinux.org/viewtopic.php?id=118751. Signed-off-by: Chris Ball <cjb@laptop.org> Cc: <stable@kernel.org>
2011-05-16blk-throttle: Use task_subsys_state() to determine a task's blkio_cgroupVivek Goyal
Currentlly we first map the task to cgroup and then cgroup to blkio_cgroup. There is a more direct way to get to blkio_cgroup from task using task_subsys_state(). Use that. The real reason for the fix is that it also avoids a race in generic cgroup code. During remount/umount rebind_subsystems() is called and it can do following with and rcu protection. cgrp->subsys[i] = NULL; That means if somebody got hold of cgroup under rcu and then it tried to do cgroup->subsys[] to get to blkio_cgroup, it would get NULL which is wrong. I was running into this race condition with ltp running on a upstream derived kernel and that lead to crash. So ideally we should also fix cgroup generic code to wait for rcu grace period before setting pointer to NULL. Li Zefan is not very keen on introducing synchronize_wait() as he thinks it will slow down moun/remount/umount operations. So for the time being atleast fix the kernel crash by taking a more direct route to blkio_cgroup. One tester had reported a crash while running LTP on a derived kernel and with this fix crash is no more seen while the test has been running for over 6 days. Signed-off-by: Vivek Goyal <vgoyal@redhat.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-05-16x86, apic: Fix spurious error interrupts triggering on all non-boot APsYouquan Song
This patch fixes a bug reported by a customer, who found that many unreasonable error interrupts reported on all non-boot CPUs (APs) during the system boot stage. According to Chapter 10 of Intel Software Developer Manual Volume 3A, Local APIC may signal an illegal vector error when an LVT entry is set as an illegal vector value (0~15) under FIXED delivery mode (bits 8-11 is 0), regardless of whether the mask bit is set or an interrupt actually happen. These errors are seen as error interrupts. The initial value of thermal LVT entries on all APs always reads 0x10000 because APs are woken up by BSP issuing INIT-SIPI-SIPI sequence to them and LVT registers are reset to 0s except for the mask bits which are set to 1s when APs receive INIT IPI. When the BIOS takes over the thermal throttling interrupt, the LVT thermal deliver mode should be SMI and it is required from the kernel to keep AP's LVT thermal monitoring register programmed as such as well. This issue happens when BIOS does not take over thermal throttling interrupt, AP's LVT thermal monitor register will be restored to 0x10000 which means vector 0 and fixed deliver mode, so all APs will signal illegal vector error interrupts. This patch check if interrupt delivery mode is not fixed mode before restoring AP's LVT thermal monitor register. Signed-off-by: Youquan Song <youquan.song@intel.com> Acked-by: Suresh Siddha <suresh.b.siddha@intel.com> Acked-by: Yong Wang <yong.y.wang@intel.com> Cc: hpa@linux.intel.com Cc: joe@perches.com Cc: jbaron@redhat.com Cc: trenn@suse.de Cc: kent.liu@intel.com Cc: chaohong.guo@intel.com Cc: <stable@kernel.org> # As far back as possible Link: http://lkml.kernel.org/r/1303402963-17738-1-git-send-email-youquan.song@intel.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-05-16drm: Take lock around probes for drm_fb_helper_hotplug_eventChris Wilson
We need to hold the dev->mode_config.mutex whilst detecting the output status. But we also need to drop it for the call into drm_fb_helper_single_fb_probe(), which indirectly acquires the lock when attaching the fbcon. Failure to do so exposes a race with normal output probing. Detected by adding some warnings that the mutex is held to the backend detect routines: [ 17.772456] WARNING: at drivers/gpu/drm/i915/intel_crt.c:471 intel_crt_detect+0x3e/0x373 [i915]() [ 17.772458] Hardware name: Latitude E6400 [ 17.772460] Modules linked in: .... [ 17.772582] Pid: 11, comm: kworker/0:1 Tainted: G W 2.6.38.4-custom.2 #8 [ 17.772584] Call Trace: [ 17.772591] [<ffffffff81046af5>] ? warn_slowpath_common+0x78/0x8c [ 17.772603] [<ffffffffa03f3e5c>] ? intel_crt_detect+0x3e/0x373 [i915] [ 17.772612] [<ffffffffa0355d49>] ? drm_helper_probe_single_connector_modes+0xbf/0x2af [drm_kms_helper] [ 17.772619] [<ffffffffa03534d5>] ? drm_fb_helper_probe_connector_modes+0x39/0x4d [drm_kms_helper] [ 17.772625] [<ffffffffa0354760>] ? drm_fb_helper_hotplug_event+0xa5/0xc3 [drm_kms_helper] [ 17.772633] [<ffffffffa035577f>] ? output_poll_execute+0x146/0x17c [drm_kms_helper] [ 17.772638] [<ffffffff81193c01>] ? cfq_init_queue+0x247/0x345 [ 17.772644] [<ffffffffa0355639>] ? output_poll_execute+0x0/0x17c [drm_kms_helper] [ 17.772648] [<ffffffff8105b540>] ? process_one_work+0x193/0x28e [ 17.772652] [<ffffffff8105c6bc>] ? worker_thread+0xef/0x172 [ 17.772655] [<ffffffff8105c5cd>] ? worker_thread+0x0/0x172 [ 17.772658] [<ffffffff8105c5cd>] ? worker_thread+0x0/0x172 [ 17.772663] [<ffffffff8105f767>] ? kthread+0x7a/0x82 [ 17.772668] [<ffffffff8100a724>] ? kernel_thread_helper+0x4/0x10 [ 17.772671] [<ffffffff8105f6ed>] ? kthread+0x0/0x82 [ 17.772674] [<ffffffff8100a720>] ? kernel_thread_helper+0x0/0x10 Reported-by: Frederik Himpe <fhimpe@telenet.be> References: https://bugs.freedesktop.org/show_bug.cgi?id=36394 Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-05-16drm/i915: Revert i915.semaphore=1 default from 47ae63e0Andy Lutomirski
My Q67 / i7-2600 box has rev09 Sandy Bridge graphics. It hangs instantly when GNOME loads and it hangs so hard the reset button doesn't work. Setting i915.semaphore=0 fixes it. Semaphores were disabled in a1656b9090f7008d2941c314f5a64724bea2ae37 in 2.6.38 and were re-enabled by commit 47ae63e0c2e5fdb582d471dc906eb29be94c732f Merge: c59a333 467cffb Author: Chris Wilson <chris@chris-wilson.co.uk> Date: Mon Mar 7 12:32:44 2011 +0000 Merge branch 'drm-intel-fixes' into drm-intel-next Apply the trivial conflicting regression fixes, but keep GPU semaphores enabled. Conflicts: drivers/gpu/drm/i915/i915_drv.h drivers/gpu/drm/i915/i915_gem_execbuffer.c (It's worth noting that the offending change is i915_drv.c, which is not a conflict.) Signed-off-by: Andy Lutomirski <luto@mit.edu> Acked-by: Keith Packard <keithp@keithp.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-05-16vga_switcheroo: don't toggle-switch devicesFlorian Mickler
If the requested device is already active, ignore the request. This restores the original behaviour of the interface. The change was probably an unintended side effect of commit 66b37c6777c4 vga_switcheroo: split switching into two stages which did not take into account to duplicate the !active check in the split-off stage2. Fix this by factoring that check out of stage1 into the debugfs_write routine. References: https://bugzilla.kernel.org/show_bug.cgi?id=34252 Reported-by: Igor Murzov <e-mail@date.by> Tested-by: Igor Murzov <e-mail@date.by> Signed-off-by: Florian Mickler <florian@mickler.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-05-15Merge branch 'pablo/nf-2.6-updates' of git://1984.lsi.us.es/net-2.6David S. Miller
2011-05-15Merge branch 'perf/urgent' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux-2.6 into perf/urgent
2011-05-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstableLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: Btrfs: fix FS_IOC_SETFLAGS ioctl Btrfs: fix FS_IOC_GETFLAGS ioctl fs: remove FS_COW_FL Btrfs: fix easily get into ENOSPC in mixed case Prevent oopsing in posix_acl_valid()
2011-05-15IPVS: fix netns if reading ip_vs_* procfs entriesHans Schillstrom
Without this patch every access to ip_vs in procfs will increase the netns count i.e. an unbalanced get_net()/put_net(). (ipvsadm commands also use procfs.) The result is you can't exit a netns if reading ip_vs_* procfs entries. Signed-off-by: Hans Schillstrom <hans.schillstrom@ericsson.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2011-05-15bridge: fix forwarding of IPv6Stephen Hemminger
The commit 6b1e960fdbd75dcd9bcc3ba5ff8898ff1ad30b6e bridge: Reset IPCB when entering IP stack on NF_FORWARD broke forwarding of IPV6 packets in bridge because it would call bp_parse_ip_options with an IPV6 packet. Reported-by: Noah Meyerhans <noahm@debian.org> Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
