2010-08-15Linux 2.6.36-rc1v2.6.36-rc1Linus Torvalds
2010-08-15Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: gcc-4.6: ACPI: fix unused but set variables in ACPI ACPI thermal: make procfs I/F depend on CONFIG_ACPI_PROCFS ACPI video: make procfs I/F depend on CONFIG_ACPI_PROCFS ACPI processor: remove deprecated ACPI procfs I/F ACPI power_resource: remove unused procfs I/F ACPI: remove deprecated ACPI procfs I/F ACPI: introduce drivers/acpi/sysfs.c ACPI: introduce module parameter acpi.aml_debug_output ACPI: introduce drivers/acpi/debugfs.c ACPI, APEI, ERST debug support ACPI, APEI, Manage GHES as platform devices ACPI, APEI, Rename CPER and GHES severity constants ACPI, APEI, Fix a typo of error path of apei_resources_request ACPI / ACPICA: Fix reference counting problems with GPE handlers ACPI: Add the check of ADR flag in course of finding ACPI handle for PCI device ACPI / Sleep: Drop acpi_suspend_finish() ACPI / Sleep: Consolidate suspend and hibernation routines ACPI / Wakeup: Simplify enabling of wakeup devices ACPI / Sleep: Rework enabling wakeup devices ACPI / Sleep: Free NVS copy if suspending of devices fails Fixed up totally buggered "ACPI: fix unused but set variables in ACPI" patch that doesn't even compile in the merge. Thanks to Sedat Dilek <sedat.dilek@googlemail.com> for noticing the breakage before I even pulled. And a big "Grrr.." at Len for not even bothering to compile the tree before asking me to pull.
2010-08-15Merge git://git.infradead.org/iommu-2.6Linus Torvalds
* git://git.infradead.org/iommu-2.6: intel-iommu: Fix 32-bit build warning with __cmpxchg() intr-remap: allow disabling source id checking
2010-08-15Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: mtd/nand_ids: Fix buswidth mtd/m25p80: fix test for end of loop mtd/m25p80: retlen is never NULL MIPS: Fix gen_nand probe structures contents gen_nand: Test if nr_chips field is valid BFIN: Fix gen_nand probe structures contents nand/denali: move all hardware initialization work to denali_hw_init nand/denali: Add a page check in denali_read_page & denali_read_page_raw nand/denali: use cpu_relax() while waiting for hardware interrupt nand/denali: change read_status function method nand/denali: Fixed check patch warnings ARM: Fix gen_nand probe structures contents mtd/nand_base: fix kernel-doc warnings & typos nand/denali: use dev_xx debug function to replace nand_dbg_print and some printk nand/denali: Fixed handle ECC error bugs nand/denali: use iowrite32() to replace denali_write32() nand/denali: Fixed probe function bugs
2010-08-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: arch/tile: don't validate CROSS_COMPILE needlessly arch/tile: export only COMMAND_LINE_SIZE to userspace. arch/tile: rename ARCH_KMALLOC_MINALIGN to ARCH_DMA_MINALIGN arch/tile: Rename the hweight() implementations to __arch_hweight() arch/tile: extend syscall ABI to set r1 on return as well. arch/tile: Various cleanups. arch/tile: support backtracing on TILE-Gx arch/tile: Fix a couple of issues with the COMPAT code for TILE-Gx. arch/tile: Use separate, better minsec values for clocksource and sched_clock. arch/tile: correct a bug in freeing bootmem by VA for the optional second initrd. arch: tile: mm: pgtable.c: Removed duplicated #include arch: tile: kernel/proc.c Removed duplicated #include Add fanotify syscalls to <asm-generic/unistd.h>. arch/tile: support new kunmap_atomic() naming convention. tile: remove unused ISA_DMA_THRESHOLD define Conflicts in arch/tile/configs/tile_defconfig (pick the mainline version with the reduced defconfig).
2010-08-15arch/tile: don't validate CROSS_COMPILE needlesslyChris Metcalf
With this change, the arch/tile Makefile will only check for a valid combination of CROSS_COMPILE vs "uname -m" for a few common targets that are typically the ones we get wrong (vmlinux, all, and modules). The change handles the case of an empty "make" goal like "make all". Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Reviewed-by: Sam Ravnborg <sam@ravnborg.org>
2010-08-15mm: fix up some user-visible effects of the stack guard pageLinus Torvalds
This commit makes the stack guard page somewhat less visible to user space. It does this by: - not showing the guard page in /proc/<pid>/maps It looks like lvm-tools will actually read /proc/self/maps to figure out where all its mappings are, and effectively do a specialized "mlockall()" in user space. By not showing the guard page as part of the mapping (by just adding PAGE_SIZE to the start for grows-up pages), lvm-tools ends up not being aware of it. - by also teaching the _real_ mlock() functionality not to try to lock the guard page. That would just expand the mapping down to create a new guard page, so there really is no point in trying to lock it in place. It would perhaps be nice to show the guard page specially in /proc/<pid>/maps (or at least mark grow-down segments some way), but let's not open ourselves up to more breakage by user space from programs that depends on the exact deails of the 'maps' file. Special thanks to Henrique de Moraes Holschuh for diving into lvm-tools source code to see what was going on with the whole new warning. Reported-and-tested-by: François Valenduc <francois.valenduc@tvcablenet.be Reported-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: sound/usb/format: silence uninitialized variable warnings MAINTAINERS: Add Ian Lartey as comaintaner for Wolfson devices MAINTAINERS: Make Wolfson entry also cover CODEC drivers ASoC: Only tweak WM8994 chip configuration on devices up to rev D ASoC: Optimise DSP performance for WM8994 ALSA: hda - Fix dynamic ADC change working again ALSA: hda - Restrict PCM parameters per ELD information over HDMI sound: oss: sh_dac_audio.c removed duplicated #include
2010-08-15Merge branch 'idle-release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6 * 'idle-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6: intel_idle: recognize Lincroft Atom Processor intel_idle: no longer EXPERIMENTAL intel_idle: disable module support intel_idle: add support for Westmere-EX intel_idle: delete power_policy modparam, and choose substate functions intel_idle: delete substates DEBUG modparam
2010-08-15arch/tile: export only COMMAND_LINE_SIZE to userspace.Chris Metcalf
This fixes a failure in "make headers_check" for tile. I hadn't realized this file was exported to userspace by default. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-08-15arch/tile: rename ARCH_KMALLOC_MINALIGN to ARCH_DMA_MINALIGNChris Metcalf
See commit a6eb9fe105d5de0053b261148cee56c94b4720ca. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
2010-08-15Merge branch 'fix/asoc' into for-linusTakashi Iwai
2010-08-15Merge branch 'fix/hda' into for-linusTakashi Iwai
2010-08-15ALSA: sound/usb/format: silence uninitialized variable warningsDan Carpenter
Gcc complains that ret might be used uninitialized: sound/usb/format.c: In function ‘snd_usb_parse_audio_format’: sound/usb/format.c:354: warning: ‘ret’ may be used uninitialized in this function sound/usb/format.c:354: note: ‘ret’ was declared here sound/usb/format.c:414: warning: ‘ret’ may be used uninitialized in this function sound/usb/format.c:414: note: ‘ret’ was declared here I suppose it could be uninitialized if there is ever a UAC_VERSION_3 released. Anyway this patch is worthwhile if only to silence the gcc warning. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-15Merge branch 'linus' into releaseLen Brown
Conflicts: drivers/acpi/debug.c Signed-off-by: Len Brown <len.brown@intel.com>
2010-08-15gcc-4.6: ACPI: fix unused but set variables in ACPIAndi Kleen
Some minor improvements in error handling, but overall it was mostly dead code. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2010-08-15ACPI thermal: make procfs I/F depend on CONFIG_ACPI_PROCFSZhang Rui
Mark the ACPI thermal procfs I/F deprecated, because /sys/class/thermal/ is already available and has been working for years w/o any problem. The ACPI thermal procfs I/F will be removed in 2.6.37. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-08-15ACPI video: make procfs I/F depend on CONFIG_ACPI_PROCFSZhang Rui
Mark ACPI video driver procfs I/F deprecated, including: /proc/acpi/video/*/info /proc/acpi/video/*/DOS /proc/acpi/video/*/ROM /proc/acpi/video/*/POST /proc/acpi/video/*/POST_info /proc/acpi/video/*/*/info /proc/acpi/video/*/*/state /proc/acpi/video/*/*/EDID and /proc/acpi/video/*/*/brightness, because 1. we already have the sysfs I/F /sysclass/backlight/ as the replacement of /proc/acpi/video/*/*/brightness. 2. the other procfs I/F is not useful for userspace. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-08-15ACPI processor: remove deprecated ACPI procfs I/FZhang Rui
Remove deprecated ACPI processor procfs I/F, including: /proc/acpi/processor/CPUX/power /proc/acpi/processor/CPUX/limit /proc/acpi/processor/CPUX/info /proc/acpi/processor/CPUX/throttling still exists, as we don't have sysfs I/F available for now. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-08-15ACPI power_resource: remove unused procfs I/FZhang Rui
Remove unused ACPI power procfs I/F. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-08-15ACPI: remove deprecated ACPI procfs I/FZhang Rui
Rmove deprecated ACPI procfs I/F, including /proc/acpi/debug_layer /proc/acpi/debug_level /proc/acpi/info /proc/acpi/dsdt /proc/acpi/fadt /proc/acpi/sleep because the sysfs I/F is already available and has been working well for years. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-08-15ACPI: introduce drivers/acpi/sysfs.cZhang Rui
Introduce drivers/acpi/sysfs.c. code for ACPI sysfs I/F, including #ifdef ACPI_DEBUG /sys/module/acpi/parameters/debug_layer /sys/module/acpi/parameters/debug_level /sys/module/acpi/parameters/trace_method_name /sys/module/acpi/parameters/trace_debug_layer /sys/module/acpi/parameters/trace_debug_level /sys/module/acpi/parameters/trace_state #endif /sys/module/acpi/parameters/acpica_version /sys/firmware/acpi/tables/ /sys/firmware/acpi/interrupts/ is moved to this file. No function change in this patch. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-08-15Merge branch 'acpica-gpe' into releaseLen Brown
2010-08-14Merge branch 'bugzilla-16422' into releaseLen Brown
2010-08-14Merge branch 'procfs-cleanup' into releaseLen Brown
2010-08-14Merge branch 'apei' into releaseLen Brown
2010-08-14Merge branch 'nvs' into releaseLen Brown
2010-08-14ACPI: introduce module parameter acpi.aml_debug_outputZhang Rui
Introduce module parameter acpi.aml_debug_output. With acpi.aml_debug_output set, we can get AML debug object output (Store (AAA, Debug)), even with CONFIG_ACPI_DEBUG cleared. Together with the runtime custom method mechanism, we can debug AML code problems without rebuilding the kernel. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-08-14ACPI: introduce drivers/acpi/debugfs.cZhang Rui
Introduce drivers/acpi/debugfs.c. Code for ACPI debugfs I/F, i.e. /sys/kernel/debug/acpi/custom_method, is moved to this file. And make ACPI debugfs always built in, even if CONFIG_ACPI_DEBUG is cleared. BTW:this adds about 400bytes code to ACPI, when CONFIG_ACPI_DEBUG is cleared. [uaccess.h build fix from Andrew Morton <akpm@linux-foundation.org>] Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-08-14intel_idle: recognize Lincroft Atom ProcessorArjan van de Ven
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-08-14ACPI, APEI, ERST debug supportHuang Ying
This patch adds debugging/testing support to ERST. A misc device is implemented to export raw ERST read/write/clear etc operations to user space. With this patch, we can add ERST testing support to linuxfirmwarekit ISO (linuxfirmwarekit.org) to verify the kernel support and the firmware implementation. Signed-off-by: Huang Ying <ying.huang@intel.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-08-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/cleanupLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/cleanup: defconfig reduction kbuild: drop unifdef-y support archs: replace unifdef-y with header-y include: replace unifdef-y with header-y
2010-08-14fusion: add function parameter names to kernel-docRandy Dunlap
Fix fusion missing kernel-doc: Warning(drivers/message/fusion/mptbase.c:649): No description found for parameter 'func_name' Warning(drivers/message/fusion/mptbase.c:8010): No description found for parameter 'cb_idx' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-14fs/dcache: fix function param name in kernel-docRandy Dunlap
Fix parameter name in kernel-doc notation (causes a warning). Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-14fusion: fix non-kernel-doc comment blockRandy Dunlap
Fix comment begin notation not to look like kernel-doc since it's not. Removes kernel-doc warnings. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-14mm/page-writeback: fix non-kernel-doc function commentsRandy Dunlap
Remove leading /** from non-kernel-doc function comments to prevent kernel-doc warnings. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-14Documentation: move SCSI parameters to their own text fileRandy Dunlap
Move SCSI parameters from kernel-parameters.txt to their own text file. This continues a trend of moving non-core parameters out of kernel-parameters.txt. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-14Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: (22 commits) hwmon: (via-cputemp) Remove bogus "SHOW" global variable hwmon: jc42 depends on I2C hwmon: (pc87427) Add a maintainer hwmon: (pc87427) Move sysfs file removal to a separate function hwmon: (pc87427) Add temperature monitoring support hwmon: (pc87427) Add support for the second logical device hwmon: (pc87427) Add support for manual fan speed control hwmon: (pc87427) Minor style cleanups hwmon: (pc87427) Handle disabled fan inputs properly hwmon: (w83627ehf) Add support for W83667HG-B hwmon: (w83627ehf) Driver cleanup hwmon: Add driver for SMSC EMC2103 temperature monitor and fan controller hwmon: Remove in[0-*]_fault from sysfs-interface hwmon: Add 4 current alarm/beep attributes to sysfs-interface hwmon: Add 3 critical limit attributes to sysfs-interface hwmon: (asc7621) Clean up and improve detect function hwmon: (it87) Export labels for internal sensors hwmon: (lm75) Add suspend/resume feature hwmon: (emc1403) Add power support hwmon: (ltc4245) Expose all GPIO pins as analog voltages ...
2010-08-14defconfig reductionSam Ravnborg
Use the defconfig files generated by "make savedefconfig" for remaining defconfig files. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2010-08-14kbuild: drop unifdef-y supportSam Ravnborg
unifdef-y is not used anymore - drop remaining references Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2010-08-14archs: replace unifdef-y with header-ySam Ravnborg
unifdef-y and header-y have same semantic, so drop unifdef-y Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2010-08-14include: replace unifdef-y with header-ySam Ravnborg
unifdef-y and header-y has same semantic. So there is no need to have both. Drop the unifdef-y variant and sort all lines again Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2010-08-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (28 commits) [SCSI] qla4xxx: fix compilation warning [SCSI] make error handling more robust in the face of reservations [SCSI] tgt: fix warning [SCSI] drivers/message/fusion: Adjust confusing if indentation [SCSI] Return NEEDS_RETRY for eh commands with status BUSY [SCSI] ibmvfc: Driver version 1.0.9 [SCSI] ibmvfc: Fix terminate_rport_io [SCSI] ibmvfc: Fix rport add/delete race resulting in oops [SCSI] lpfc 8.3.16: Change LPFC driver version to 8.3.16 [SCSI] lpfc 8.3.16: FCoE Discovery and Failover Fixes [SCSI] lpfc 8.3.16: SLI Additions, updates, and code cleanup [SCSI] pm8001: introduce missing kfree [SCSI] qla4xxx: Update driver version to 5.02.00-k3 [SCSI] qla4xxx: Added AER support for ISP82xx [SCSI] qla4xxx: Handle outstanding mbx cmds on hung f/w scenarios [SCSI] qla4xxx: updated mbx_sys_info struct to sync with FW 4.6.x [SCSI] qla4xxx: clear AF_DPC_SCHEDULED flage when exit from do_dpc [SCSI] qla4xxx: Stop firmware before doing init firmware. [SCSI] qla4xxx: Use the correct request queue. [SCSI] qla4xxx: set correct value in sess->recovery_tmo ...
2010-08-14hwmon: (via-cputemp) Remove bogus "SHOW" global variableH. Peter Anvin
The via-cputemp hwmon driver was probably intending "typedef enum { ... } SHOW;", but the "typedef" was missing creating a global variable named "SHOW". There is absolutely no reason to have this in the global namespace. Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Acked-by: Harald Welte <HaraldWelte@viatech.com> Cc: Juerg Haefliger <juergh@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-08-14hwmon: jc42 depends on I2CRandy Dunlap
jc42 uses i2c interfaces, so it should depend on I2C. drivers/hwmon/jc42.c:426: error: implicit declaration of function 'i2c_check_functionality' drivers/hwmon/jc42.c:521: error: implicit declaration of function 'i2c_smbus_read_word_data' drivers/hwmon/jc42.c:529: error: implicit declaration of function 'i2c_smbus_write_word_data' drivers/hwmon/jc42.c:580: error: implicit declaration of function 'i2c_add_driver' drivers/hwmon/jc42.c:585: error: implicit declaration of function 'i2c_del_driver' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-08-14hwmon: (pc87427) Add a maintainerJean Delvare
As I made significant changes to the pc87427 driver, I'll be maintaining it for the year to come. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-08-14hwmon: (pc87427) Move sysfs file removal to a separate functionJean Delvare
The sysfs file removal code is the same in the probe error path and in the remove function, so move it to a separate function to avoid code duplication. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-08-14hwmon: (pc87427) Add temperature monitoring supportJean Delvare
Add support for the 6 temperature monitoring channels of the PC87427. Note that the sensors resolution can vary, and I couldn't find a way to figure it out, so we might have to compensate in user-space. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-08-14hwmon: (pc87427) Add support for the second logical deviceJean Delvare
The second logical device contains the voltage and temperature registers. We have to extend the driver to support a second logical device before we can add support for these features. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-08-14hwmon: (pc87427) Add support for manual fan speed controlJean Delvare
Add initial support for PWM outputs of the PC87427 Super-I/O chip. Only mode change and manual fan speed control are supported. Automatic mode configuration isn't supported, and won't be until at least one board is known, which makes uses of the PWM outputs. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
