2010-11-22Linux 2.6.35.9v2.6.35.9Greg Kroah-Hartman
2010-11-22KVM: x86 emulator: fix regression with cmpxchg8b on i386 hostsAvi Kivity
commit 16518d5ada690643453eb0aef3cc7841d3623c2d upstream. operand::val and operand::orig_val are 32-bit on i386, whereas cmpxchg8b operands are 64-bit. Fix by adding val64 and orig_val64 union members to struct operand, and using them where needed. Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22isdn: avoid calling tty_ldisc_flush() in atomic contextTilman Schmidt
commit bc10f96757bd6ab3721510df8defa8f21c32f974 upstream. Remove the call to tty_ldisc_flush() from the RESULT_NO_CARRIER branch of isdn_tty_modem_result(), as already proposed in commit 00409bb045887ec5e7b9e351bc080c38ab6bfd33. This avoids a "sleeping function called from invalid context" BUG when the hardware driver calls the statcallb() callback with command==ISDN_STAT_DHUP in atomic context, which in turn calls isdn_tty_modem_result(RESULT_NO_CARRIER, ~), and from there, tty_ldisc_flush() which may sleep. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22sgi-xp: incoming XPC channel messages can come in after the channel's ↵Robin Holt
partition structures have been torn down commit 09358972bff5ce99de496bbba97c85d417b3c054 upstream. Under some workloads, some channel messages have been observed being delayed on the sending side past the point where the receiving side has been able to tear down its partition structures. This condition is already detected in xpc_handle_activate_IRQ_uv(), but that information is not given to xpc_handle_activate_mq_msg_uv(). As a result, xpc_handle_activate_mq_msg_uv() assumes the structures still exist and references them, causing a NULL-pointer deref. Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22ARM: cns3xxx: Fixup the missing second parameter to addruart macro to allow ↵Mac Lin
them to build. It can't be merged into Linus' tree because this file has already been changed in incompatible ways. Fixup the missing second parameter to addruart macro to allow them to build, according to to commit 0e17226f7cd289504724466f4298abc9bdfca3fe. Enabling DEBUG in head.S would cause: rch/arm/boot/compressed/head.S: Assembler messages: arch/arm/boot/compressed/head.S:1037: Error: too many positional arguments arch/arm/boot/compressed/head.S:1055: Error: too many positional arguments Signed-off-by: Mac Lin <mkl0301@gmail.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22secmark: do not return early if there was no errorEric Paris
commit 15714f7b58011cf3948cab2988abea560240c74f upstream. Commit 4a5a5c73 attempted to pass decent error messages back to userspace for netfilter errors. In xt_SECMARK.c however the patch screwed up and returned on 0 (aka no error) early and didn't finish setting up secmark. This results in a kernel BUG if you use SECMARK. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22xfrm4: strip ECN bits from tos fieldUlrich Weber
[ Upstream commit 94e2238969e89f5112297ad2a00103089dde7e8f ] otherwise ECT(1) bit will get interpreted as RTO_ONLINK and routing will fail with XfrmOutBundleGenError. Signed-off-by: Ulrich Weber <uweber@astaro.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22net/core: Allow tagged VLAN packets to flow through VETH devices.Ben Greear
[ Upstream commit d2ed817766987fd05e69b7da65d4861b38f1aa2a ] When there are VLANs on a VETH device, the packets being transmitted through the VETH device may be 4 bytes bigger than MTU. A check in dev_forward_skb did not take this into account and so dropped these packets. This patch is needed at least as far back as 2.6.34.7 and should be considered for -stable. Signed-off-by: Ben Greear <greearb@candelatech.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22net: add a recursion limit in xmit pathEric Dumazet
[ Upstream commits 745e20f1b626b1be4b100af5d4bf7b3439392f8f and 11a766ce915fc9f8663714eac6d59239388534ea ] As tunnel devices are going to be lockless, we need to make sure a misconfigured machine wont enter an infinite loop. Add a percpu variable, and limit to three the number of stacked xmits. Reported-by: Jesse Gross <jesse@nicira.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22Revert d88dca79d3852a3623f606f781e013d61486828aNeil Horman
[ Upstream commit db5a753bf198ef7a50e17d2ff358adf37efe8648 ] TIPC needs to have its endianess issues fixed. Unfortunately, the format of a subscriber message is passed in directly from user space, so requiring this message to be in network byte order breaks user space ABI. Revert this change until such time as we can determine how to do this in a backwards compatible manner. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22Revert c6537d6742985da1fbf12ae26cde6a096fd35b5cNeil Horman
[ Upstream commit 8c974438085d2c81b006daeaab8801eedbd19758 ] Backout the tipc changes to the flags int he subscription message. These changees, while reasonable on the surface, interefere with user space ABI compatibility which is a no-no. This was part of the changes to fix the endianess issues in the TIPC protocol, which would be really nice to do but we need to do so in a way that is backwards compatible with user space. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22net-2.6: SYN retransmits: Add new parameter to retransmits_timed_out()Damian Lukowski
[ Upstream commit 4d22f7d372f5769c6c0149e427ed6353e2dcfe61 ] Fixes kernel Bugzilla Bug 18952 This patch adds a syn_set parameter to the retransmits_timed_out() routine and updates its callers. If not set, TCP_RTO_MIN is taken as the calculation basis as before. If set, TCP_TIMEOUT_INIT is used instead, so that sysctl_syn_retries represents the actual amount of SYN retransmissions in case no SYNACKs are received when establishing a new connection. Signed-off-by: Damian Lukowski <damian@tvk.rwth-aachen.de> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22tcp: Fix race in tcp_pollTom Marshall
[ Upstream commit a4d258036ed9b2a1811c3670c6099203a0f284a0 ] If a RST comes in immediately after checking sk->sk_err, tcp_poll will return POLLIN but not POLLOUT. Fix this by checking sk->sk_err at the end of tcp_poll. Additionally, ensure the correct order of operations on SMP machines with memory barriers. Signed-off-by: Tom Marshall <tdm.code@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22Limit sysctl_tcp_mem and sysctl_udp_mem initializers to prevent integer ↵holt@sgi.com
overflows. On a 16TB x86_64 machine, sysctl_tcp_mem[2], sysctl_udp_mem[2], and sysctl_sctp_mem[2] can integer overflow. Set limit such that they are maximized without overflowing. Signed-off-by: Robin Holt <holt@sgi.com> To: "David S. Miller" <davem@davemloft.net> Cc: Willy Tarreau <w@1wt.eu> Cc: linux-kernel@vger.kernel.org Cc: netdev@vger.kernel.org Cc: linux-sctp@vger.kernel.org Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Cc: "Pekka Savola (ipv6)" <pekkas@netcore.fi> Cc: James Morris <jmorris@namei.org> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: Patrick McHardy <kaber@trash.net> Cc: Vlad Yasevich <vladislav.yasevich@hp.com> Cc: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22net: Fix the condition passed to sk_wait_event()Nagendra Tomar
[ Upstream commit 482964e56e1320cb7952faa1932d8ecf59c4bf75 ] This patch fixes the condition (3rd arg) passed to sk_wait_event() in sk_stream_wait_memory(). The incorrect check in sk_stream_wait_memory() causes the following soft lockup in tcp_sendmsg() when the global tcp memory pool has exhausted. >>> snip <<< localhost kernel: BUG: soft lockup - CPU#3 stuck for 11s! [sshd:6429] localhost kernel: CPU 3: localhost kernel: RIP: 0010:[sk_stream_wait_memory+0xcd/0x200] [sk_stream_wait_memory+0xcd/0x200] sk_stream_wait_memory+0xcd/0x200 localhost kernel: localhost kernel: Call Trace: localhost kernel: [sk_stream_wait_memory+0x1b1/0x200] sk_stream_wait_memory+0x1b1/0x200 localhost kernel: [<ffffffff802557c0>] autoremove_wake_function+0x0/0x40 localhost kernel: [ipv6:tcp_sendmsg+0x6e6/0xe90] tcp_sendmsg+0x6e6/0xce0 localhost kernel: [sock_aio_write+0x126/0x140] sock_aio_write+0x126/0x140 localhost kernel: [xfs:do_sync_write+0xf1/0x130] do_sync_write+0xf1/0x130 localhost kernel: [<ffffffff802557c0>] autoremove_wake_function+0x0/0x40 localhost kernel: [hrtimer_start+0xe3/0x170] hrtimer_start+0xe3/0x170 localhost kernel: [vfs_write+0x185/0x190] vfs_write+0x185/0x190 localhost kernel: [sys_write+0x50/0x90] sys_write+0x50/0x90 localhost kernel: [system_call+0x7e/0x83] system_call+0x7e/0x83 >>> snip <<< What is happening is, that the sk_wait_event() condition passed from sk_stream_wait_memory() evaluates to true for the case of tcp global memory exhaustion. This is because both sk_stream_memory_free() and vm_wait are true which causes sk_wait_event() to *not* call schedule_timeout(). Hence sk_stream_wait_memory() returns immediately to the caller w/o sleeping. This causes the caller to again try allocation, which again fails and again calls sk_stream_wait_memory(), and so on. [ Bug introduced by commit c1cbe4b7ad0bc4b1d98ea708a3fecb7362aa4088 ("[NET]: Avoid atomic xchg() for non-error case") -DaveM ] Signed-off-by: Nagendra Singh Tomar <tomer_iisc@yahoo.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22rose: Fix signedness issues wrt. digi count.David S. Miller
[ Upstream commit 9828e6e6e3f19efcb476c567b9999891d051f52f ] Just use explicit casts, since we really can't change the types of structures exported to userspace which have been around for 15 years or so. Reported-by: Dan Rosenberg <dan.j.rosenberg@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22r6040: Fix multicast filter some moreBen Hutchings
[ Upstream commit e2269308359d5863b6aa1fcb95a425a2ab255f1f ] This code has been broken forever, but in several different and creative ways. So far as I can work out, the R6040 MAC filter has 4 exact-match entries, the first of which the driver uses for its assigned unicast address, plus a 64-entry hash-based filter for multicast addresses (maybe unicast as well?). The original version of this code would write the first 4 multicast addresses as exact-match entries from offset 1 (bug #1: there is no entry 4 so this could write to some PHY registers). It would fill the remainder of the exact-match entries with the broadcast address (bug #2: this would overwrite the last used entry). If more than 4 multicast addresses were configured, it would set up the hash table, write some random crap to the MAC control register (bug #3) and finally walk off the end of the list when filling the exact-match entries (bug #4). All of this seems to be pointless, since it sets the promiscuous bit when the interface is made promiscuous or if >4 multicast addresses are enabled, and never clears it (bug #5, masking bug #2). The recent(ish) changes to the multicast list fixed bug #4, but completely removed the limit on iteration over the exact-match entries (bug #6). Bug #4 was reported as <https://bugzilla.kernel.org/show_bug.cgi?id=15355> and more recently as <http://bugs.debian.org/600155>. Florian Fainelli attempted to fix these in commit 3bcf8229a8c49769e48d3e0bd1e20d8e003f8106, but that actually dealt with bugs #1-3, bug #4 having been fixed in mainline at that point. That commit fixes the most important current bug #6. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22Phonet: Correct header retrieval after pskb_may_pullKumar Sanghvi
[ Upstream commit a91e7d471e2e384035b9746ea707ccdcd353f5dd ] Retrieve the header after doing pskb_may_pull since, pskb_may_pull could change the buffer structure. This is based on the comment given by Eric Dumazet on Phonet Pipe controller patch for a similar problem. Signed-off-by: Kumar Sanghvi <kumar.sanghvi@stericsson.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22qlcnic: dont set skb->truesizeEric Dumazet
[ Upstream commit 8df8fd27123054b02007361bd5483775db84b4a8 ] skb->truesize is set in core network. Dont change it unless dealing with fragments. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22netxen: dont set skb->truesizeEric Dumazet
[ Upstream commit 7e96dc7045bff8758804b047c0dfb6868f182500 ] skb->truesize is set in core network. Dont change it unless dealing with fragments. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22net: Fix IPv6 PMTU disc. w/ asymmetric routesMaciej Żenczykowski
[ Upstream commit ae878ae280bea286ff2b1e1cb6e609dd8cb4501d ] Signed-off-by: Maciej Żenczykowski <maze@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22ipv6: fix refcnt problem related to POSTDAD stateUrsula Braun
[ Upstream commit 801715f95be37b865af83b9909ad93da141a9306 ] After running this bonding setup script modprobe bonding miimon=100 mode=0 max_bonds=1 ifconfig bond0 10.1.1.1/16 ifenslave bond0 eth1 ifenslave bond0 eth3 on s390 with qeth-driven slaves, modprobe -r fails with this message unregister_netdevice: waiting for bond0 to become free. Usage count = 1 due to twice detection of duplicate address. Problem is caused by a missing decrease of ifp->refcnt in addrconf_dad_failure. An extra call of in6_ifa_put(ifp) solves it. Problem has been introduced with commit f2344a131bccdbfc5338e17fa71a807dee7944fa. Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Cc: David S. Miller <davem@davemloft.net> Cc: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22ip: fix truesize mismatch in ip fragmentationEric Dumazet
[ Upstream commit 3d13008e7345fa7a79d8f6438150dc15d6ba6e9d ] Special care should be taken when slow path is hit in ip_fragment() : When walking through frags, we transfert truesize ownership from skb to frags. Then if we hit a slow_path condition, we must undo this or risk uncharging frags->truesize twice, and in the end, having negative socket sk_wmem_alloc counter, or even freeing socket sooner than expected. Many thanks to Nick Bowler, who provided a very clean bug report and test program. Thanks to Jarek for reviewing my first patch and providing a V2 While Nick bisection pointed to commit 2b85a34e911 (net: No more expensive sock_hold()/sock_put() on each tx), underlying bug is older (2.6.12-rc5) A side effect is to extend work done in commit b2722b1c3a893e (ip_fragment: also adjust skb->truesize for packets not owned by a socket) to ipv6 as well. Reported-and-bisected-by: Nick Bowler <nbowler@elliptictech.com> Tested-by: Nick Bowler <nbowler@elliptictech.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Jarek Poplawski <jarkao2@gmail.com> CC: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22gianfar: Fix crashes on RX path (Was Re: [Bugme-new] [Bug 19692] New: ↵Jarek Poplawski
linux-2.6.36-rc5 crash with gianfar ethernet at full line rate traffic) [ Upstream commit 0d1fe1111c667e9c713d7efc7ae468a605f236a4 ] The rx_recycle queue is global per device but can be accesed by many napi handlers at the same time, so it needs full skb_queue primitives (with locking). Otherwise, various crashes caused by broken skbs are possible. This patch resolves, at least partly, bugzilla bug 19692. (Because of some doubts that there could be still something around which is hard to reproduce my proposal is to leave this bug opened for a month.) Fixes commit: 0fd56bb5be6455d0d42241e65aed057244665e5e ("gianfar: Add support for skb recycling") Reported-by: emin ak <eminak71@gmail.com> Tested-by: emin ak <eminak71@gmail.com> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> CC: Andy Fleming <afleming@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22gianfar: fix double lock typoDan Carpenter
[ Upstream commit 9756403b16cfeda85efe77e62832a2f6b5752fdf ] This should be a _restore() instead of a _save(). Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22net: clear heap allocations for privileged ethtool actionsKees Cook
[ Upstream commit b00916b189d13a615ff05c9242201135992fcda3 ] Several other ethtool functions leave heap uncleared (potentially) by drivers. Some interfaces appear safe (eeprom, etc), in that the sizes are well controlled. In some situations (e.g. unchecked error conditions), the heap will remain unchanged in areas before copying back to userspace. Note that these are less of an issue since these all require CAP_NET_ADMIN. Cc: stable@kernel.org Signed-off-by: Kees Cook <kees.cook@canonical.com> Acked-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22Fix regressions in scsi_internal_device_blockMike Christie
commit 986fe6c7f50974e871b8ab5a800f5310ea25b361 upstream. Deleting a SCSI device on a blocked fc_remote_port (before fast_io_fail_tmo fires) results in a hanging thread: STACK: 0 schedule+1108 [0x5cac48] 1 schedule_timeout+528 [0x5cb7fc] 2 wait_for_common+266 [0x5ca6be] 3 blk_execute_rq+160 [0x354054] 4 scsi_execute+324 [0x3b7ef4] 5 scsi_execute_req+162 [0x3b80ca] 6 sd_sync_cache+138 [0x3cf662] 7 sd_shutdown+138 [0x3cf91a] 8 sd_remove+112 [0x3cfe4c] 9 __device_release_driver+124 [0x3a08b8] 10 device_release_driver+60 [0x3a0a5c] 11 bus_remove_device+266 [0x39fa76] 12 device_del+340 [0x39d818] 13 __scsi_remove_device+204 [0x3bcc48] 14 scsi_remove_device+66 [0x3bcc8e] 15 sysfs_schedule_callback_work+50 [0x260d66] 16 worker_thread+622 [0x162326] 17 kthread+160 [0x1680b0] 18 kernel_thread_starter+6 [0x10aaea] During the delete, the SCSI device is in moved to SDEV_CANCEL. When the FC transport class later calls scsi_target_unblock, this has no effect, since scsi_internal_device_unblock ignores SCSI devics in this state. It looks like all these are regressions caused by: 5c10e63c943b4c67561ddc6bf61e01d4141f881f [SCSI] limit state transitions in scsi_internal_device_unblock Fix by rejecting offline and cancel in the state transition. Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> [jejb: Original patch by Christof Schmitt, modified by Mike Christie] Signed-off-by: James Bottomley <James.Bottomley@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22Fix race when removing SCSI devicesChristof Schmitt
commit 546ae796bfac6399e30da4b5af2cf7a6d0f8a4ec upstream. Removing SCSI devices through echo 1 > /sys/bus/scsi/devices/ ... /delete while the FC transport class removes the SCSI target can lead to an oops: Unable to handle kernel pointer dereference at virtual kernel address 00000000b6815000 Oops: 0011 [#1] PREEMPT SMP DEBUG_PAGEALLOC Modules linked in: sunrpc qeth_l3 binfmt_misc dm_multipath scsi_dh dm_mod ipv6 qeth ccwgroup [last unloaded: scsi_wait_scan] CPU: 1 Not tainted 2.6.35.5-45.x.20100924-s390xdefault #1 Process fc_wq_0 (pid: 861, task: 00000000b7331240, ksp: 00000000b735bac0) Krnl PSW : 0704200180000000 00000000003ff6e4 (__scsi_remove_device+0x24/0xd0) R:0 T:1 IO:1 EX:1 Key:0 M:1 W:0 P:0 AS:0 CC:2 PM:0 EA:3 Krnl GPRS: 0000000000000001 0000000000000000 00000000b6815000 00000000bc24a8c0 00000000003ff7c8 000000000056dbb8 0000000000000002 0000000000835d80 ffffffff00000000 0000000000001000 00000000b6815000 00000000bc24a7f0 00000000b68151a0 00000000b6815000 00000000b735bc20 00000000b735bbf8 Krnl Code: 00000000003ff6d6: a7840001 brc 8,3ff6d8 00000000003ff6da: a7fbffd8 aghi %r15,-40 00000000003ff6de: e3e0f0980024 stg %r14,152(%r15) >00000000003ff6e4: e31021200004 lg %r1,288(%r2) 00000000003ff6ea: a71f0000 cghi %r1,0 00000000003ff6ee: a7a40011 brc 10,3ff710 00000000003ff6f2: a7390003 lghi %r3,3 00000000003ff6f6: c0e5ffffc8b1 brasl %r14,3f8858 Call Trace: ([<0000000000001000>] 0x1000) [<00000000003ff7d2>] scsi_remove_device+0x42/0x54 [<00000000003ff8ba>] __scsi_remove_target+0xca/0xfc [<00000000003ff99a>] __remove_child+0x3a/0x48 [<00000000003e3246>] device_for_each_child+0x72/0xbc [<00000000003ff93a>] scsi_remove_target+0x4e/0x74 [<0000000000406586>] fc_rport_final_delete+0xb2/0x23c [<000000000015d080>] worker_thread+0x200/0x344 [<000000000016330c>] kthread+0xa0/0xa8 [<0000000000106c1a>] kernel_thread_starter+0x6/0xc [<0000000000106c14>] kernel_thread_starter+0x0/0xc INFO: lockdep is turned off. Last Breaking-Event-Address: [<00000000003ff7cc>] scsi_remove_device+0x3c/0x54 The function __scsi_remove_target iterates through the SCSI devices on the host, but it drops the host_lock before calling scsi_remove_device. When the SCSI device is deleted from another thread, the pointer to the SCSI device in scsi_remove_device can become invalid. Fix this by getting a reference to the SCSI device before dropping the host_lock to keep the SCSI device alive for the call to scsi_remove_device. Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22gdth: integer overflow in ioctlDan Carpenter
commit f63ae56e4e97fb12053590e41a4fa59e7daa74a4 upstream. gdth_ioctl_alloc() takes the size variable as an int. copy_from_user() takes the size variable as an unsigned long. gen.data_len and gen.sense_len are unsigned longs. On x86_64 longs are 64 bit and ints are 32 bit. We could pass in a very large number and the allocation would truncate the size to 32 bits and allocate a small buffer. Then when we do the copy_from_user(), it would result in a memory corruption. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22libsas: fix NCQ mixing with non-NCQDavid Milburn
commit f0ad30d3d2dc924decc0e10b1ff6dc32525a5d99 upstream. Some cards (like mvsas) have issue troubles if non-NCQ commands are mixed with NCQ ones. Fix this by using the libata default NCQ check routine which waits until all NCQ commands are complete before issuing a non-NCQ one. The impact to cards (like aic94xx) which don't need this logic should be minimal Signed-off-by: James Bottomley <James.Bottomley@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22sd name space exhaustion causes system hangMichael Reed
commit 1a03ae0f556a931aa3747b70e44b78308f5b0590 upstream. Following a site power outage which re-enabled all the ports on my FC switches, my system subsequently booted with far too many luns! I had let it run hoping it would make multi-user. It didn't. :( It hung solid after exhausting the last sd device, sdzzz, and attempting to create sdaaaa and beyond. I was unable to get a dump. Discovered using a 2.6.32.13 based system. correct this by detecting when the last index is utilized and failing the sd probe of the device. Patch applies to scsi-misc-2.6. Signed-off-by: Michael Reed <mdr@sgi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22asus-laptop: fix gps rfkillCorentin Chary
commit 23f45c3a76e715217f40ac397c15815c774cad7f upstream. The GPS rfkill crappy code. The ops_data argument wasn't set, and was totally misused. The fix have been tested on an Asus R2H. Signed-off-by: Corentin Chary <corentincj@iksaif.net> Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22USB: accept some invalid ep0-maxpacket valuesAlan Stern
commit 56626a72a47bf3e50875d960d6b5f17b9bee0ab2 upstream. A few devices (such as the RCA VR5220 voice recorder) are so non-compliant with the USB spec that they have invalid maxpacket sizes for endpoint 0. Nevertheless, as long as we can safely use them, we may as well do so. This patch (as1432) softens our acceptance criterion by allowing high-speed devices to have ep0-maxpacket sizes other than 64. A warning is printed in the system log when this happens, and the existing error message is clarified. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Reported-by: James <bjlockie@lockie.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22usb: r8a66597-hcd: Change mistake of the outsw functionNobuhiro Iwamatsu
commit ac9dfe9cdda4eb42ecaa9f13b0fee518e0b6518e upstream. Some functions changed by 1c98347e613bf17ea2f18c9766ce0ab77f65a96d. However, There was a change mistake of the function (outsw). Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> CC: Paul Mundt <lethal@linux-sh.org> Acked-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22USB: opticon: Fix long-standing bugs in opticon driverAlon Ziv
commit 97cd8dc4ca9a1a5efb2cc38758e01492e3b013e2 upstream. The bulk-read callback had two bugs: a) The bulk-in packet's leading two zeros were returned (and the two last bytes truncated) b) The wrong URB was transmitted for the second (and later) read requests, causing further reads to return the entire packet (including leading zeros) Signed-off-by: Alon Ziv <alon-git@nolaviz.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22USB: visor: fix initialisation of UX50/TH55 devicesJohan Hovold
commit cfb8da8f69b81d367b766888e83ec0483a31bf01 upstream. Fix regression introduced by commit 214916f2ec6701e1c9972f26c60b3dc37d3153c6 (USB: visor: reimplement using generic framework) which broke initialisation of UX50/TH55 devices that used re-mapped bulk-out endpoint addresses. Reported-by: Robert Gadsdon <rgadsdon@bayarea.net> Tested-by: Robert Gadsdon <rgadsdon@bayarea.net> Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22USB: disable endpoints after unbinding interfaces, not beforeAlan Stern
commit 80f0cf3947889014d3a3dc0ad60fb87cfda4b12a upstream. This patch (as1430) fixes a bug in usbcore. When a device configuration change occurs or a device is removed, the endpoints for the old config should be completely disabled. However it turns out they aren't; this is because usb_unbind_interface() calls usb_enable_interface() or usb_set_interface() to put interfaces back in altsetting 0, which re-enables the interfaces' endpoints. As a result, when a device goes through a config change or is unconfigured, the ep_in[] and ep_out[] arrays may be left holding old pointers to usb_host_endpoint structures. If the device is deauthorized these structures get freed, and the stale pointers cause errors when the the device is eventually unplugged. The solution is to disable the endpoints after unbinding the interfaces instead of before. This isn't as large a change as it sounds, since usb_unbind_interface() disables all the interface's endpoints anyway before calling the driver's disconnect routine, unless the driver claims to support "soft" unbind. This fixes Bugzilla #19192. Thanks to "Tom" Lei Ming for diagnosing the underlying cause of the problem. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Tested-by: Carsten Sommer <carsten_sommer@ymail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22USB: atmel_usba_udc: force vbus_pin at -EINVAL when gpio_request failledJean-Christophe PLAGNIOL-VILLARD
commit 969affff54702785330de553b790372e261e93f9 upstream. to ensure gpio_is_valid return false Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22USB: cp210x: Add WAGO 750-923 Service Cable device IDAnders Larsen
commit 93ad03d60b5b18897030038234aa2ebae8234748 upstream. The WAGO 750-923 USB Service Cable is used for configuration and firmware updates of several industrial automation products from WAGO Kontakttechnik GmbH. Bus 004 Device 002: ID 1be3:07a6 Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 1.10 bDeviceClass 0 (Defined at Interface level) bDeviceSubClass 0 bDeviceProtocol 0 bMaxPacketSize0 64 idVendor 0x1be3 idProduct 0x07a6 bcdDevice 1.00 iManufacturer 1 Silicon Labs iProduct 2 WAGO USB Service Cable iSerial 3 1277796751 . . . Signed-off-by: Anders Larsen <al@alarsen.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22USB: cp210x: Add Renesas RX-Stick device IDDJ Delorie
commit 2f1136d1d08a63dcdbcd462621373f30d8dfe590 upstream. RX610 development board by Renesas Bus 001 Device 024: ID 045b:0053 Hitachi, Ltd Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 1.10 bDeviceClass 0 (Defined at Interface level) bDeviceSubClass 0 bDeviceProtocol 0 bMaxPacketSize0 64 idVendor 0x045b Hitachi, Ltd idProduct 0x0053 bcdDevice 1.00 iManufacturer 1 Silicon Labs iProduct 2 RX-Stick iSerial 3 0001 . . . http://am.renesas.com/rx610stick Signed-off-by: DJ Delorie <dj@delorie.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22USB: option: Add more ZTE modem USB id'sMauro Carvalho Chehab
commit ecfa153ef616b901e86d9a051b329fcda7a6ce7b upstream. There are lots of ZTE USB id's currently not covered by usb/serial. Adds them, to allow those devices to work properly on Linux. While here, put the USB ID's for 0x2002/0x2003 at the sorted order. This patch is based on zte.c file found on MF645. PS.: The ZTE driver is commenting the USB ID for 0x0053. It also adds, commented, an USB ID for 0x0026. Not sure why, but I think that 0053 is used by their devices in storage mode only. So, I opted to keep the comment on this patch. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22USB: Change acm_iad_descriptor bFunctionProtocol to USB_CDC_ACM_PROTO_AT_V25TERPraveena Nadahally
commit 5c8db070b4480c43394680d9dfd2ddb06b97d2ae upstream. The protocol code is set 00 in IAD and it's set to 01 in ACM control interface descriptor in f_acm.c file. Due to this, windows is unable to install the modem(ACM) driver based on class-subclass-protocol matching. This patch corrects the protocol code in ACM IAD to the same as in acm_control_interface_desc protocol code. Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Praveena Nadahally <praveen.nadahally@stericsson.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22usb: musb: blackfin: call gpio_free() on error path in musb_platform_init()Sergei Shtylyov
commit 00be545e49d83485d49a598d3b7e090088934be8 upstream. Blackfin's musb_platform_init() needs to call gpio_free() for error cleanup iff otg_get_transceiver() call returns NULL. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22usb: musb: blackfin: call usb_nop_xceiv_unregister() in musb_platform_exit()Sergei Shtylyov
commit 3daad24d6c72affdd40e8b6a75c87d3c175880b6 upstream. Blackfin's musb_platform_exit() forgets to call usb_nop_xceiv_unregister(). While fixing this, also remove the unneeded blank line there. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22USB: MUSB: fix kernel WARNING/oops when unloading module in OTG modeSergei Shtylyov
commit f405387435a85a440d1ce16f3ca36e042281643a upstream. Since commit 461972d8a4c94bc44f11a13046041c78a7cf18dd (musb_core: don't call musb_platform_exit() twice), unloading the driver module results in a WARNING "kobject: '(null)' (c73de788): is not initialized, yet kobject_put() is being called." (or even kernel oops) on e.g. DaVincis, though only in the OTG mode. There exists dubious and unbalanced put_device() call in musb_free() which takes place only in the OTG mode. As this commit caused musb_platform_exit() to be called (and so unregister the NOP transceiver) before this put_device() call, this function references already freed memory. On the other hand, all the glue layers miss the otg_put_transceiver() call, complementary to the otg_get_transceiver() call that they do. So, I think the solution is to get rid of the strange put_device() call, and instead call otg_put_transceiver() in the glue layers... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22USB: ftdi_sio: add device ids for ScienceScopeGreg Kroah-Hartman
commit 0f266abd70cd83571eca019f764b5f1992da7361 upstream. This adds the requested device ids to the ftdi_sio driver. Reported-by: Ewan Bingham <ewan@auc.co.uk> Cc: Kuba Ober <kuba@mareimbrium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22USB: ftdi_sio: new VID/PIDs for various Papouch devicesDaniel Suchy
commit 59c6ccd9f9aecfa59c99ceba6d4d34b180547a05 upstream. This patch for FTDI USB serial driver ads new VID/PIDs used on various devices manufactured by Papouch (http://www.papouch.com). These devices have their own VID/PID, although they're using standard FTDI chip. In ftdi_sio.c, I also made small cleanup to have declarations for all Papouch devices together. Signed-off-by: Daniel Suchy <danny@danysek.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22USB: add PID for FTDI based OpenDCC hardwareRainer Keller
commit 99c1e4f89d1033444ce4d0c064bd2826e81c3775 upstream. The OpenDCC project is developing a new hardware. This patch adds its PID to the list of known FTDI devices. The PID can be found at http://www.opendcc.de/elektronik/usb/opendcc_usb.html Signed-off-by: Rainer Keller <mail@rainerkeller.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22USB: ftdi_sio: revert "USB: ftdi_sio: fix DTR/RTS line modes"Johan Hovold
commit 677aeafe19e88c282af74564048243ccabb1c590 upstream. This reverts commit 6a1a82df91fa0eb1cc76069a9efe5714d087eccd. RTS and DTR should not be modified based on CRTSCTS when calling set_termios. Modem control lines are raised at port open by the tty layer and should stay raised regardless of whether hardware flow control is enabled or not. This is in conformance with the way serial ports work today and many applications depend on this behaviour to be able to talk to hardware implementing hardware flow control (without the applications actually using it). Hardware which expects different behaviour on these lines can always use TIOCMSET/TIOCMBI[SC] after port open to change them. Reported-by: Daniel Mack <daniel@caiaq.de> Reported-by: Dave Mielke <dave@mielke.cc> Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-22USB: ftdi_sio: Add PID for accesio productsRich Mattes
commit 3126d8236ca6f68eb8292c6af22c2e59afbeef24 upstream. Adds support for Accesio USB to Serial adapters, which are built around FTDI FT232 UARTs. Tested with the Accesio USB-COM-4SM. Signed-off-by: Rich Mattes <richmattes@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
