2011-04-17Linux 2.6.34.9v2.6.34.9Paul Gortmaker
2011-04-17niu: Fix kernel buffer overflow for ETHTOOL_GRXCLSRLALLBen Hutchings
commit ee9c5cfad29c8a13199962614b9b16f1c4137ac9 upstream. niu_get_ethtool_tcam_all() assumes that its output buffer is the right size, and warns before returning if it is not. However, the output buffer size is under user control and ETHTOOL_GRXCLSRLALL is an unprivileged ethtool command. Therefore this is at least a local denial-of-service vulnerability. Change it to check before writing each entry and to return an error if the buffer is already full. Compile-tested only. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17Relax si_code check in rt_sigqueueinfo and rt_tgsigqueueinfoRoland Dreier
commit 243b422af9ea9af4ead07a8ad54c90d4f9b6081a upstream. Commit da48524eb206 ("Prevent rt_sigqueueinfo and rt_tgsigqueueinfo from spoofing the signal code") made the check on si_code too strict. There are several legitimate places where glibc wants to queue a negative si_code different from SI_QUEUE: - This was first noticed with glibc's aio implementation, which wants to queue a signal with si_code SI_ASYNCIO; the current kernel causes glibc's tst-aio4 test to fail because rt_sigqueueinfo() fails with EPERM. - Further examination of the glibc source shows that getaddrinfo_a() wants to use SI_ASYNCNL (which the kernel does not even define). The timer_create() fallback code wants to queue signals with SI_TIMER. As suggested by Oleg Nesterov <oleg@redhat.com>, loosen the check to forbid only the problematic SI_TKILL case. Reported-by: Klaus Dittrich <kladit@arcor.de> Acked-by: Julien Tinnes <jln@google.com> Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17Prevent rt_sigqueueinfo and rt_tgsigqueueinfo from spoofing the signal codeJulien Tinnes
commit da48524eb20662618854bb3df2db01fc65f3070c upstream. Userland should be able to trust the pid and uid of the sender of a signal if the si_code is SI_TKILL. Unfortunately, the kernel has historically allowed sigqueueinfo() to send any si_code at all (as long as it was negative - to distinguish it from kernel-generated signals like SIGILL etc), so it could spoof a SI_TKILL with incorrect siginfo values. Happily, it looks like glibc has always set si_code to the appropriate SI_QUEUE, so there are probably no actual user code that ever uses anything but the appropriate SI_QUEUE flag. So just tighten the check for si_code (we used to allow any negative value), and add a (one-time) warning in case there are binaries out there that might depend on using other si_code values. Signed-off-by: Julien Tinnes <jln@google.com> Acked-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17ALSA: caiaq - Fix possible string-buffer overflowTakashi Iwai
commit eaae55dac6b64c0616046436b294e69fc5311581 upstream Use strlcpy() to assure not to overflow the string array sizes by too long USB device name string. Reported-by: Rafa <rafa@mwrinfosecurity.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17block: check for proper length of iov entries earlier in blk_rq_map_user_iov()Xiaotian Feng
commit 5478755616ae2ef1ce144dded589b62b2a50d575 upstream. commit 9284bcf checks for proper length of iov entries in blk_rq_map_user_iov(). But if the map is unaligned, kernel will break out the loop without checking for the proper length. So we need to check the proper length before the unalign check. Signed-off-by: Xiaotian Feng <dfeng@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17sctp: Fix out-of-bounds reading in sctp_asoc_get_hmac()Dan Rosenberg
commit 51e97a12bef19b7e43199fc153cf9bd5f2140362 upstream The sctp_asoc_get_hmac() function iterates through a peer's hmac_ids array and attempts to ensure that only a supported hmac entry is returned. The current code fails to do this properly - if the last id in the array is out of range (greater than SCTP_AUTH_HMAC_ID_MAX), the id integer remains set after exiting the loop, and the address of an out-of-bounds entry will be returned and subsequently used in the parent function, causing potentially ugly memory corruption. This patch resets the id integer to 0 on encountering an invalid id so that NULL will be returned after finishing the loop if no valid ids are found. Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17sunrpc/cache: fix module refcnt leak in a failure pathLi Zefan
commit a5990ea1254cd186b38744507aeec3136a0c1c95 upstream Don't forget to release the module refcnt if seq_open() returns failure. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: J. Bruce Fields <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17hwmon: (w83627ehf) Fix max_output and step_output readingsGuenter Roeck
[extraction from commit da2e025590cf7038440132d4bbc967a579b11112 upstream] The value of max_output and step_output registers isn't read from the respective registers. As a result, zero values are returned to the user through the respective sysfs attributes, instead of the actual fan control settings. The problem is fixed by updating the fan max output and fan step output information from data in registers. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17ip6ip6: autoload ip6 tunnelstephen hemminger
commit 6dfbd87a20a737641ef228230c77f4262434fa24 upstream. Add necessary alias to autoload ip6ip6 tunnel module. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17net: don't allow CAP_NET_ADMIN to load non-netdev kernel modulesVasiliy Kulikov
commit 8909c9ad8ff03611c9c96c9a92656213e4bb495b upstream. Since a8f80e8ff94ecba629542d9b4b5f5a8ee3eb565c any process with CAP_NET_ADMIN may load any module from /lib/modules/. This doesn't mean that CAP_NET_ADMIN is a superset of CAP_SYS_MODULE as modules are limited to /lib/modules/**. However, CAP_NET_ADMIN capability shouldn't allow anybody load any module not related to networking. This patch restricts an ability of autoloading modules to netdev modules with explicit aliases. This fixes CVE-2011-1019. Arnd Bergmann suggested to leave untouched the old pre-v2.6.32 behavior of loading netdev modules by name (without any prefix) for processes with CAP_SYS_MODULE to maintain the compatibility with network scripts that use autoloading netdev modules by aliases like "eth0", "wlan0". Currently there are only three users of the feature in the upstream kernel: ipip, ip_gre and sit. root@albatros:~# capsh --drop=$(seq -s, 0 11),$(seq -s, 13 34) -- root@albatros:~# grep Cap /proc/$$/status CapInh: 0000000000000000 CapPrm: fffffff800001000 CapEff: fffffff800001000 CapBnd: fffffff800001000 root@albatros:~# modprobe xfs FATAL: Error inserting xfs (/lib/modules/2.6.38-rc6-00001-g2bf4ca3/kernel/fs/xfs/xfs.ko): Operation not permitted root@albatros:~# lsmod | grep xfs root@albatros:~# ifconfig xfs xfs: error fetching interface information: Device not found root@albatros:~# lsmod | grep xfs root@albatros:~# lsmod | grep sit root@albatros:~# ifconfig sit sit: error fetching interface information: Device not found root@albatros:~# lsmod | grep sit root@albatros:~# ifconfig sit0 sit0 Link encap:IPv6-in-IPv4 NOARP MTU:1480 Metric:1 root@albatros:~# lsmod | grep sit sit 10457 0 tunnel4 2957 1 sit For CAP_SYS_MODULE module loading is still relaxed: root@albatros:~# grep Cap /proc/$$/status CapInh: 0000000000000000 CapPrm: ffffffffffffffff CapEff: ffffffffffffffff CapBnd: ffffffffffffffff root@albatros:~# ifconfig xfs xfs: error fetching interface information: Device not found root@albatros:~# lsmod | grep xfs xfs 745319 0 Reference: https://lkml.org/lkml/2011/2/24/203 [PG: in 2.6.34, the bare MODULE_ALIAS for ipip/tunl0 and ip_gre/gre0 didn't exist, but this adds the limited scope MODULE_ALIAS_NETDEV ones] Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Signed-off-by: Michael Tokarev <mjt@tls.msk.ru> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Kees Cook <kees.cook@canonical.com> Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17drm: fix unsigned vs signed comparison issue in modeset ctl ioctl.Dave Airlie
commit 1922756124ddd53846877416d92ba4a802bc658f upstream. This fixes CVE-2011-1013. Reported-by: Matthiew Herrb (OpenBSD X.org team) Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17x25: Do not reference freed memory.David S. Miller
commit 96642d42f076101ba98866363d908cab706d156c upstream. In x25_link_free(), we destroy 'nb' before dereferencing 'nb->dev'. Don't do this, because 'nb' might be freed by then. Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Tested-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17av7110: check for negative array offsetDan Carpenter
commit cb26a24ee9706473f31d34cc259f4dcf45cd0644 upstream info->num comes from the user. It's type int. If the user passes in a negative value that would cause memory corruption. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17md: fix regression with re-adding devices to arrays with no metadataNeilBrown
commit bf572541ab44240163eaa2d486b06f306a31d45a upstream. Commit 1a855a0606 (2.6.37-rc4) fixed a problem where devices were re-added when they shouldn't be but caused a regression in a less common case that means sometimes devices cannot be re-added when they should be. In particular, when re-adding a device to an array without metadata we should always access the device, but after the above commit we didn't. This patch sets the In_sync flag in that case so that the re-add succeeds. This patch is suitable for any -stable kernel to which 1a855a0606 was applied. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17posix-cpu-timers: workaround to suppress the problems with mt execOleg Nesterov
commit e0a70217107e6f9844628120412cb27bb4cea194 upstream. posix-cpu-timers.c correctly assumes that the dying process does posix_cpu_timers_exit_group() and removes all !CPUCLOCK_PERTHREAD timers from signal->cpu_timers list. But, it also assumes that timer->it.cpu.task is always the group leader, and thus the dead ->task means the dead thread group. This is obviously not true after de_thread() changes the leader. After that almost every posix_cpu_timer_ method has problems. It is not simple to fix this bug correctly. First of all, I think that timer->it.cpu should use struct pid instead of task_struct. Also, the locking should be reworked completely. In particular, tasklist_lock should not be used at all. This all needs a lot of nontrivial and hard-to-test changes. Change __exit_signal() to do posix_cpu_timers_exit_group() when the old leader dies during exec. This is not the fix, just the temporary hack to hide the problem for 2.6.37 and stable. IOW, this is obviously wrong but this is what we currently have anyway: cpu timers do not work after mt exec. In theory this change adds another race. The exiting leader can detach the timers which were attached to the new leader. However, the window between de_thread() and release_task() is small, we can pretend that sys_timer_create() was called before de_thread(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17block: Deprecate QUEUE_FLAG_CLUSTER and use queue_limits insteadMartin K. Petersen
commit e692cb668fdd5a712c6ed2a2d6f2a36ee83997b4 upstream. When stacking devices, a request_queue is not always available. This forced us to have a no_cluster flag in the queue_limits that could be used as a carrier until the request_queue had been set up for a metadevice. There were several problems with that approach. First of all it was up to the stacking device to remember to set queue flag after stacking had completed. Also, the queue flag and the queue limits had to be kept in sync at all times. We got that wrong, which could lead to us issuing commands that went beyond the max scatterlist limit set by the driver. The proper fix is to avoid having two flags for tracking the same thing. We deprecate QUEUE_FLAG_CLUSTER and use the queue limit directly in the block layer merging functions. The queue_limit 'no_cluster' is turned into 'cluster' to avoid double negatives and to ease stacking. Clustering defaults to being enabled as before. The queue flag logic is removed from the stacking function, and explicitly setting the cluster flag is no longer necessary in DM and MD. Reported-by: Ed Lin <ed.lin@promise.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Acked-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17ALSA: hda: Use LPIB quirk for Dell Inspiron m101z/1120Daniel T Chen
commit e03fa055bc126e536c7f65862e08a9b143138ea9 upstream. Sjoerd Simons reports that, without using position_fix=1, recording experiences overruns. Work around that by applying the LPIB quirk for his hardware. Reported-and-tested-by: Sjoerd Simons <sjoerd@debian.org> Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17ima: fix add LSM rule bugMimi Zohar
commit 867c20265459d30a01b021a9c1e81fb4c5832aa9 upstream. If security_filter_rule_init() doesn't return a rule, then not everything is as fine as the return code implies. This bug only occurs when the LSM (eg. SELinux) is disabled at runtime. Adding an empty LSM rule causes ima_match_rules() to always succeed, ignoring any remaining rules. default IMA TCB policy: # PROC_SUPER_MAGIC dont_measure fsmagic=0x9fa0 # SYSFS_MAGIC dont_measure fsmagic=0x62656572 # DEBUGFS_MAGIC dont_measure fsmagic=0x64626720 # TMPFS_MAGIC dont_measure fsmagic=0x01021994 # SECURITYFS_MAGIC dont_measure fsmagic=0x73636673 < LSM specific rule > dont_measure obj_type=var_log_t measure func=BPRM_CHECK measure func=FILE_MMAP mask=MAY_EXEC measure func=FILE_CHECK mask=MAY_READ uid=0 Thus without the patch, with the boot parameters 'tcb selinux=0', adding the above 'dont_measure obj_type=var_log_t' rule to the default IMA TCB measurement policy, would result in nothing being measured. The patch prevents the default TCB policy from being replaced. Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Cc: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Cc: David Safford <safford@watson.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17mv_xor: fix race in tasklet functionSaeed Bishara
commit 8333f65ef094e47020cd01452b4637e7daf5a77f upstream. use mv_xor_slot_cleanup() instead of __mv_xor_slot_cleanup() as the former function aquires the spin lock that needed to protect the drivers data. Signed-off-by: Saeed Bishara <saeed@marvell.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17sound: Prevent buffer overflow in OSS load_mixer_volumesDan Rosenberg
commit d81a12bc29ae4038770e05dce4ab7f26fd5880fb upstream. The load_mixer_volumes() function, which can be triggered by unprivileged users via the SOUND_MIXER_SETLEVELS ioctl, is vulnerable to a buffer overflow. Because the provided "name" argument isn't guaranteed to be NULL terminated at the expected 32 bytes, it's possible to overflow past the end of the last element in the mixer_vols array. Further exploitation can result in an arbitrary kernel write (via subsequent calls to load_mixer_volumes()) leading to privilege escalation, or arbitrary kernel reads via get_mixer_levels(). In addition, the strcmp() may leak bytes beyond the mixer_vols array. Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17p54usb: New USB ID for Gemtek WUBI-100GWEduardo Costa
commit 56e6417b49132d4f56e9f2241d31942b90b46315 upstream. This USB ID is for the WUBI-100GW 802.11g Wireless LAN USB Device that uses p54usb. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: Eduardo Costa <ecosta.tmp@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17p54usb: add 5 more USBIDsChristian Lamparter
commit 16cad7fba037b34ca32cc0adac65bc089d969fb8 upstream. This patch adds five more USBIDs to the table. Source: http://www.linuxant.com/pipermail/driverloader/2005q3/002307.html http://wireless.kernel.org/en/users/Drivers/p54/devices (by M. Davis) Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17USB: usb-storage: unusual_devs entry for the Samsung YP-CP3Vitaly Kuznetsov
commit d73a9b3001f29271c2e9f2a806b05a431c5d9591 upstream. Add an unusual_devs entry for the Samsung YP-CP3 MP4 player. User was getting the following errors in dmesg: usb 2-6: reset high speed USB device using ehci_hcd and address 2 usb 2-6: reset high speed USB device using ehci_hcd and address 2 usb 2-6: reset high speed USB device using ehci_hcd and address 2 usb 2-6: USB disconnect, address 2 sd 3:0:0:0: [sdb] Assuming drive cache: write through sdb:<2>ldm_validate_partition_table(): Disk read failed. Dev sdb: unable to read RDB block 0 unable to read partition table [PG: change USB_ --> US_ to match 2.6.34.x naming conventions] Signed-off-by: Vitaly Kuznetsov <vitty@altlinux.ru> Acked-by: Alan Stern <stern@rowland.harvard.edu> CC: Matthew Dharm <mdharm-usb@one-eyed-alien.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17USB: ftdi_sio: Add D.O.Tec PIDFlorian Faber
commit 5363cdc3c5da9bd431552cf5989ab481596f0c6d upstream. Add FTDI PID to identify D.O.Tec devices correctly. Signed-off-by: Florian Faber <faberman@linuxproaudio.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17USB: misc: uss720.c: add another vendor/product IDThomas Sailer
commit ecc1624a2fff45780959efbcb73ace18fdb3c58d upstream. Fabio Battaglia report that he has another cable that works with this driver, so this patch adds its vendor/product ID. Signed-off-by: Thomas Sailer <t.sailer@alumni.ethz.ch> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17install_special_mapping skips security_file_mmap check.Tavis Ormandy
commit 462e635e5b73ba9a4c03913b77138cd57ce4b050 upstream. The install_special_mapping routine (used, for example, to setup the vdso) skips the security check before insert_vm_struct, allowing a local attacker to bypass the mmap_min_addr security restriction by limiting the available pages for special mappings. bprm_mm_init() also skips the check, and although I don't think this can be used to bypass any restrictions, I don't see any reason not to have the security check. $ uname -m x86_64 $ cat /proc/sys/vm/mmap_min_addr 65536 $ cat install_special_mapping.s section .bss resb BSS_SIZE section .text global _start _start: mov eax, __NR_pause int 0x80 $ nasm -D__NR_pause=29 -DBSS_SIZE=0xfffed000 -f elf -o install_special_mapping.o install_special_mapping.s $ ld -m elf_i386 -Ttext=0x10000 -Tbss=0x11000 -o install_special_mapping install_special_mapping.o $ ./install_special_mapping & [1] 14303 $ cat /proc/14303/maps 0000f000-00010000 r-xp 00000000 00:00 0 [vdso] 00010000-00011000 r-xp 00001000 00:19 2453665 /home/taviso/install_special_mapping 00011000-ffffe000 rwxp 00000000 00:00 0 [stack] It's worth noting that Red Hat are shipping with mmap_min_addr set to 4096. Signed-off-by: Tavis Ormandy <taviso@google.com> Acked-by: Kees Cook <kees@ubuntu.com> Acked-by: Robert Swiecki <swiecki@google.com> [ Changed to not drop the error code - akpm ] Reviewed-by: James Morris <jmorris@namei.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17bfa: fix system crash when reading sysfs fc_host statisticsKrishna Gudipati
commit 7873ca4e4401f0ecd8868bf1543113467e6bae61 upstream. The port data structure related to fc_host statistics collection is not initialized. This causes system crash when reading the fc_host statistics. The fix is to initialize port structure during driver attach. Signed-off-by: Krishna Gudipati <kgudipat@brocade.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17HID: hidraw: fix window in hidraw_releaseJiri Slaby
commit cb174681a9ececa6702f114b85bdf82144b6a5af upstream. There is a window between hidraw_table check and its dereference. In that window, the device may be unplugged and removed form the system and we will then dereference NULL. Lock that place properly so that either we get NULL and jump out or we can work with real pointer. [PG: slightly/trivially reworked for backport to 34] Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17x86, vt-d: Quirk for masking vtd spec errors to platform error handling logicSuresh Siddha
commit 254e42006c893f45bca48f313536fcba12206418 upstream. On platforms with Intel 7500 chipset, there were some reports of system hang/NMI's during kexec/kdump in the presence of interrupt-remapping enabled. During kdump, there is a window where the devices might be still using old kernel's interrupt information, while the kdump kernel is coming up. This can cause vt-d faults as the interrupt configuration from the old kernel map to null IRTE entries in the new kernel etc. (with out interrupt-remapping enabled, we still have the same issue but in this case we will see benign spurious interrupt hit the new kernel). Based on platform config settings, these platforms seem to generate NMI/SMI when a vt-d fault happens and there were reports that the resulting SMI causes the system to hang. Fix it by masking vt-d spec defined errors to platform error reporting logic. VT-d spec related errors are already handled by the VT-d OS code, so need to report the same error through other channels. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> LKML-Reference: <1291667190.2675.8.camel@sbsiddha-MOBL3.sc.intel.com> Reported-by: Max Asbock <masbock@linux.vnet.ibm.com> Reported-and-tested-by: Takao Indoh <indou.takao@jp.fujitsu.com> Acked-by: Chris Wright <chrisw@sous-sol.org> Acked-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17x86, vt-d: Fix the vt-d fault handling irq migration in the x2apic modeKenji Kaneshige
commit 086e8ced65d9bcc4a8e8f1cd39b09640f2883f90 upstream. In x2apic mode, we need to set the upper address register of the fault handling interrupt register of the vt-d hardware. Without this irq migration of the vt-d fault handling interrupt is broken. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> LKML-Reference: <1291225233.2648.39.camel@sbsiddha-MOBL3> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Acked-by: Chris Wright <chrisw@sous-sol.org> Tested-by: Takao Indoh <indou.takao@jp.fujitsu.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17x86, vt-d: Handle previous faults after enabling fault handlingSuresh Siddha
commit 7f99d946e71e71d484b7543b49e990508e70d0c0 upstream. Fault handling is getting enabled after enabling the interrupt-remapping (as the success of interrupt-remapping can affect the apic mode and hence the fault handling mode). Hence there can potentially be some faults between the window of enabling interrupt-remapping in the vt-d and the fault-handling of the vt-d units. Handle any previous faults after enabling the vt-d fault handling. For v2.6.38 cleanup, need to check if we can remove the dmar_fault() in the enable_intr_remapping() and see if we can enable fault handling along with enabling intr-remapping. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> LKML-Reference: <20101201062244.630417138@intel.com> Acked-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17x86: Enable the intr-remap fault handling after local APIC setupKenji Kaneshige
commit 7f7fbf45c6b748074546f7f16b9488ca71de99c1 upstream. Interrupt-remapping gets enabled very early in the boot, as it determines the apic mode that the processor can use. And the current code enables the vt-d fault handling before the setup_local_APIC(). And hence the APIC LDR registers and data structure in the memory may not be initialized. So the vt-d fault handling in logical xapic/x2apic modes were broken. Fix this by enabling the vt-d fault handling in the end_local_APIC_setup() A cleaner fix of enabling fault handling while enabling intr-remapping will be addressed for v2.6.38. [ Enabling intr-remapping determines the usage of x2apic mode and the apic mode determines the fault-handling configuration. ] Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> LKML-Reference: <20101201062244.541996375@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Acked-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17x86, gcc-4.6: Use gcc -m options when building vdsoH. Peter Anvin
commit de2a8cf98ecdde25231d6c5e7901e2cffaf32af9 upstream. The vdso Makefile passes linker-style -m options not to the linker but to gcc. This happens to work with earlier gcc, but fails with gcc 4.6. Pass gcc-style -m options, instead. Note: all currently supported versions of gcc supports -m32, so there is no reason to conditionalize it any more. Reported-by: H. J. Lu <hjl.tools@gmail.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com> LKML-Reference: <tip-*@git.kernel.org> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17tracing: Fix panic when lseek() called on "trace" opened for writingSlava Pestov
commit 364829b1263b44aa60383824e4c1289d83d78ca7 upstream. The file_ops struct for the "trace" special file defined llseek as seq_lseek(). However, if the file was opened for writing only, seq_open() was not called, and the seek would dereference a null pointer, file->private_data. This patch introduces a new wrapper for seq_lseek() which checks if the file descriptor is opened for reading first. If not, it does nothing. Signed-off-by: Slava Pestov <slavapestov@google.com> LKML-Reference: <1290640396-24179-1-git-send-email-slavapestov@google.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17md: fix bug with re-adding of partially recovered device.NeilBrown
commit 1a855a0606653d2d82506281e2c686bacb4b2f45 upstream. With v0.90 metadata, a hot-spare does not become a full member of the array until recovery is complete. So if we re-add such a device to the array, we know that all of it is as up-to-date as the event count would suggest, and so it a bitmap-based recovery is possible. However with v1.x metadata, the hot-spare immediately becomes a full member of the array, but it record how much of the device has been recovered. If the array is stopped and re-assembled recovery starts from this point. When such a device is hot-added to an array we currently lose the 'how much is recovered' information and incorrectly included it as a full in-sync member (after bitmap-based fixup). This is wrong and unsafe and could corrupt data. So be more careful about setting saved_raid_disk - which is what guides the re-adding of devices back into an array. The new code matches the code in slot_store which does a similar thing, which is encouraging. This is suitable for any -stable kernel. Reported-by: "Dailey, Nate" <Nate.Dailey@stratus.com> Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17orinoco: clear countermeasure setting on commitDavid Kilroy
commit ba34fcee476d11e7c9df95932787a22a96ff6e68 upstream. ... and interface up. In these situations, you are usually trying to connect to a new AP, so keeping TKIP countermeasures active is confusing. This is already how the driver behaves (inadvertently). However, querying SIOCGIWAUTH may tell userspace that countermeasures are active when they aren't. Clear the setting so that the reporting matches what the driver has done.. Signed-off by: David Kilroy <kilroyd@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17orinoco: fix TKIP countermeasure behaviourDavid Kilroy
commit 0a54917c3fc295cb61f3fb52373c173fd3b69f48 upstream. Enable the port when disabling countermeasures, and disable it on enabling countermeasures. This bug causes the response of the system to certain attacks to be ineffective. It also prevents wpa_supplicant from getting scan results, as wpa_supplicant disables countermeasures on startup - preventing the hardware from scanning. wpa_supplicant works with ap_mode=2 despite this bug because the commit handler re-enables the port. The log tends to look like: State: DISCONNECTED -> SCANNING Starting AP scan for wildcard SSID Scan requested (ret=0) - scan timeout 5 seconds EAPOL: disable timer tick EAPOL: Supplicant port status: Unauthorized Scan timeout - try to get results Failed to get scan results Failed to get scan results - try scanning again Setting scan request: 1 sec 0 usec Starting AP scan for wildcard SSID Scan requested (ret=-1) - scan timeout 5 seconds Failed to initiate AP scan. Reported by: Giacomo Comes <comes@naic.edu> Signed-off by: David Kilroy <kilroyd@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17ACPI: EC: Add another dmi match entry for MSI hardwareAlexey Starikovskiy
commit a5dc4f898c2a0f66e2cefada6c687db82ba2fcbc upstream. http://bugzilla.kernel.org/show_bug.cgi?id=15418 Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17Subject: [PATCH] ACPICA: Fix Scope() op in module level codeBob Moore
commit 8df3fc981dc12d9fdcaef4100a2193b605024d7a upstream. Some Panasonic Toughbooks create nodes in module level code. Module level code is the executable AML code outside of control method, for example, below AML code creates a node \_SB.PCI0.GFX0.DD02.CUBL If (\_OSI ("Windows 2006")) { Scope (\_SB.PCI0.GFX0.DD02) { Name (CUBL, Ones) ... } } Scope() op does not actually create a new object, it refers to an existing object(\_SB.PCI0.GFX0.DD02 in above example). However, for Scope(), we want to indeed open a new scope, so the child nodes(CUBL in above example) can be created correctly under it. https://bugzilla.kernel.org/show_bug.cgi?id=19462 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17PM / Hibernate: Fix PM_POST_* notification with user-space suspendTakashi Iwai
commit 1497dd1d29c6a53fcd3c80f7ac8d0e0239e7389e upstream. The user-space hibernation sends a wrong notification after the image restoration because of thinko for the file flag check. RDONLY corresponds to hibernation and WRONLY to restoration, confusingly. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17IB/uverbs: Handle large number of entries in poll CQDan Carpenter
commit 7182afea8d1afd432a17c18162cc3fd441d0da93 upstream. In ib_uverbs_poll_cq() code there is a potential integer overflow if userspace passes in a large cmd.ne. The calls to kmalloc() would allocate smaller buffers than intended, leading to memory corruption. There iss also an information leak if resp wasn't all used. Unprivileged userspace may call this function, although only if an RDMA device that uses this function is present. Fix this by copying CQ entries one at a time, which avoids the allocation entirely, and also by moving this copying into a function that makes sure to initialize all memory copied to userspace. Special thanks to Jason Gunthorpe <jgunthorpe@obsidianresearch.com> for his help and advice. Signed-off-by: Dan Carpenter <error27@gmail.com> [ Monkey around with things a bit to avoid bad code generation by gcc when designated initializers are used. - Roland ] Signed-off-by: Roland Dreier <rolandd@cisco.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17amd64_edac: Fix interleaving checkBorislav Petkov
commit e726f3c368e7c1919a7166ec09c5705759f1a69d upstream. When matching error address to the range contained by one memory node, we're in valid range when node interleaving 1. is disabled, or 2. enabled and when the address bits we interleave on match the interleave selector on this node (see the "Node Interleaving" section in the BKDG for an enlightening example). Thus, when we early-exit, we need to reverse the compound logic statement properly. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17hwmon: (adm1026) Fix setting fan_divGabriele Gorla
commit 52bc9802ce849d0d287cc5fe76d06b0daa3986ca upstream. Prevent setting fan_div from stomping on other fans that share the same I2C register. Signed-off-by: Gabriele Gorla <gorlik@penguintown.net> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17hwmon: (adm1026) Allow 1 as a valid divider valueGabriele Gorla
commit 8b0f1840a46449e1946fc88860ef3ec8d6b1c2c7 upstream. Allow 1 as a valid div value as specified in the ADM1026 datasheet. Signed-off-by: Gabriele Gorla <gorlik@penguintown.net> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17sunrpc: prevent use-after-free on clearing XPT_BUSYNeilBrown
commit ed2849d3ecfa339435818eeff28f6c3424300cec upstream. When an xprt is created, it has a refcount of 1, and XPT_BUSY is set. The refcount is *not* owned by the thread that created the xprt (as is clear from the fact that creators never put the reference). Rather, it is owned by the absence of XPT_DEAD. Once XPT_DEAD is set, (And XPT_BUSY is clear) that initial reference is dropped and the xprt can be freed. So when a creator clears XPT_BUSY it is dropping its only reference and so must not touch the xprt again. However svc_recv, after calling ->xpo_accept (and so getting an XPT_BUSY reference on a new xprt), calls svc_xprt_recieved. This clears XPT_BUSY and then svc_xprt_enqueue - this last without owning a reference. This is dangerous and has been seen to leave svc_xprt_enqueue working with an xprt containing garbage. So we need to hold an extra counted reference over that call to svc_xprt_received. For safety, any time we clear XPT_BUSY and then use the xprt again, we first get a reference, and the put it again afterwards. Note that svc_close_all does not need this extra protection as there are no threads running, and the final free can only be called asynchronously from such a thread. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17NFS: Fix fcntl F_GETLK not reporting some conflictsSergey Vlasov
commit 21ac19d484a8ffb66f64487846c8d53afef04d2b upstream. The commit 129a84de2347002f09721cda3155ccfd19fade40 (locks: fix F_GETLK regression (failure to find conflicts)) fixed the posix_test_lock() function by itself, however, its usage in NFS changed by the commit 9d6a8c5c213e34c475e72b245a8eb709258e968c (locks: give posix_test_lock same interface as ->lock) remained broken - subsequent NFS-specific locking code received F_UNLCK instead of the user-specified lock type. To fix the problem, fl->fl_type needs to be saved before the posix_test_lock() call and restored if no local conflicts were reported. Reference: https://bugzilla.kernel.org/show_bug.cgi?id=23892 Tested-by: Alexander Morozov <amorozov@etersoft.ru> Signed-off-by: Sergey Vlasov <vsu@altlinux.ru> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17nfsd: Fix possible BUG_ON firing in set_change_infoNeil Brown
commit c1ac3ffcd0bc7e9617f62be8c7043d53ab84deac upstream. If vfs_getattr in fill_post_wcc returns an error, we don't set fh_post_change. For NFSv4, this can result in set_change_info triggering a BUG_ON. i.e. fh_post_saved being zero isn't really a bug. So: - instead of BUGging when fh_post_saved is zero, just clear ->atomic. - if vfs_getattr fails in fill_post_wcc, take a copy of i_ctime anyway. This will be used i seg_change_info, but not overly trusted. - While we are there, remove the pointless 'if' statements in set_change_info. There is no harm setting all the values. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17NFS: Fix panic after nfs_umount()Chuck Lever
commit 5b362ac3799ff4225c40935500f520cad4d7ed66 upstream. After a few unsuccessful NFS mount attempts in which the client and server cannot agree on an authentication flavor both support, the client panics. nfs_umount() is invoked in the kernel in this case. Turns out nfs_umount()'s UMNT RPC invocation causes the RPC client to write off the end of the rpc_clnt's iostat array. This is because the mount client's nrprocs field is initialized with the count of defined procedures (two: MNT and UMNT), rather than the size of the client's proc array (four). The fix is to use the same initialization technique used by most other upper layer clients in the kernel. Introduced by commit 0b524123, which failed to update nrprocs when support was added for UMNT in the kernel. BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=24302 BugLink: http://bugs.launchpad.net/bugs/683938 Reported-by: Stefan Bader <stefan.bader@canonical.com> Tested-by: Stefan Bader <stefan.bader@canonical.com> Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-04-17nohz: Fix get_next_timer_interrupt() vs cpu hotplugHeiko Carstens
commit dbd87b5af055a0cc9bba17795c9a2b0d17795389 upstream. This fixes a bug as seen on 2.6.32 based kernels where timers got enqueued on offline cpus. If a cpu goes offline it might still have pending timers. These will be migrated during CPU_DEAD handling after the cpu is offline. However while the cpu is going offline it will schedule the idle task which will then call tick_nohz_stop_sched_tick(). That function in turn will call get_next_timer_intterupt() to figure out if the tick of the cpu can be stopped or not. If it turns out that the next tick is just one jiffy off (delta_jiffies == 1) tick_nohz_stop_sched_tick() incorrectly assumes that the tick should not stop and takes an early exit and thus it won't update the load balancer cpu. Just afterwards the cpu will be killed and the load balancer cpu could be the offline cpu. On 2.6.32 based kernel get_nohz_load_balancer() gets called to decide on which cpu a timer should be enqueued (see __mod_timer()). Which leads to the possibility that timers get enqueued on an offline cpu. These will never expire and can cause a system hang. This has been observed 2.6.32 kernels. On current kernels __mod_timer() uses get_nohz_timer_target() which doesn't have that problem. However there might be other problems because of the too early exit tick_nohz_stop_sched_tick() in case a cpu goes offline. The easiest and probably safest fix seems to be to let get_next_timer_interrupt() just lie and let it say there isn't any pending timer if the current cpu is offline. I also thought of moving migrate_[hr]timers() from CPU_DEAD to CPU_DYING, but seeing that there already have been fixes at least in the hrtimer code in this area I'm afraid that this could add new subtle bugs. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20101201091109.GA8984@osiris.boeblingen.de.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
