commit b78f29ca0516266431688c5eb42d39ce42ec039a upstream.
This patch fix the oops below that catched in my machine
[ 81.560602] uvesafb: NVIDIA Corporation, GT216 Board - 0696a290, Chip Rev , OEM: NVIDIA, VBE v3.0
[ 81.609384] uvesafb: protected mode interface info at c000:d350
[ 81.609388] uvesafb: pmi: set display start = c00cd3b3, set palette = c00cd40e
[ 81.609390] uvesafb: pmi: ports = 3b4 3b5 3ba 3c0 3c1 3c4 3c5 3c6 3c7 3c8 3c9 3cc 3ce 3cf 3d0 3d1 3d2 3d3 3d4 3d5 3da
[ 81.614558] uvesafb: VBIOS/hardware doesn't support DDC transfers
[ 81.614562] uvesafb: no monitor limits have been set, default refresh rate will be used
[ 81.614994] uvesafb: scrolling: ypan using protected mode interface, yres_virtual=4915
[ 81.744147] kernel tried to execute NX-protected page - exploit attempt? (uid: 0)
[ 81.744153] BUG: unable to handle kernel paging request at c00cd3b3
[ 81.744159] IP: [<c00cd3b3>] 0xc00cd3b2
[ 81.744167] *pdpt = 00000000016d6001 *pde = 0000000001c7b067 *pte = 80000000000cd163
[ 81.744171] Oops: 0011 [#1] SMP
[ 81.744174] Modules linked in: uvesafb(+) cfbcopyarea cfbimgblt cfbfillrect
[ 81.744178]
[ 81.744181] Pid: 3497, comm: modprobe Not tainted 3.3.0-rc4NX+ #71 Acer Aspire 4741 /Aspire 4741
[ 81.744185] EIP: 0060:[<c00cd3b3>] EFLAGS: 00010246 CPU: 0
[ 81.744187] EIP is at 0xc00cd3b3
[ 81.744189] EAX: 00004f07 EBX: 00000000 ECX: 00000000 EDX: 00000000
[ 81.744191] ESI: f763f000 EDI: f763f6e8 EBP: f57f3a0c ESP: f57f3a00
[ 81.744192] DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068
[ 81.744195] Process modprobe (pid: 3497, ti=f57f2000 task=f748c600 task.ti=f57f2000)
[ 81.744196] Stack:
[ 81.744197] f82512c5 f759341c 00000000 f57f3a30 c124a9bc 00000001 00000001 000001e0
[ 81.744202] f8251280 f763f000 f7593400 00000000 f57f3a40 c12598dd f5c0c000 00000000
[ 81.744206] f57f3b10 c1255efe c125a21a 00000006 f763f09c 00000000 c1c6cb60 f7593400
[ 81.744210] Call Trace:
[ 81.744215] [<f82512c5>] ? uvesafb_pan_display+0x45/0x60 [uvesafb]
[ 81.744222] [<c124a9bc>] fb_pan_display+0x10c/0x160
[ 81.744226] [<f8251280>] ? uvesafb_vbe_find_mode+0x180/0x180 [uvesafb]
[ 81.744230] [<c12598dd>] bit_update_start+0x1d/0x50
[ 81.744232] [<c1255efe>] fbcon_switch+0x39e/0x550
[ 81.744235] [<c125a21a>] ? bit_cursor+0x4ea/0x560
[ 81.744240] [<c129b6cb>] redraw_screen+0x12b/0x220
[ 81.744245] [<c128843b>] ? tty_do_resize+0x3b/0xc0
[ 81.744247] [<c129ef42>] vc_do_resize+0x3d2/0x3e0
[ 81.744250] [<c129efb4>] vc_resize+0x14/0x20
[ 81.744253] [<c12586bd>] fbcon_init+0x29d/0x500
[ 81.744255] [<c12984c4>] ? set_inverse_trans_unicode+0xe4/0x110
[ 81.744258] [<c129b378>] visual_init+0xb8/0x150
[ 81.744261] [<c129c16c>] bind_con_driver+0x16c/0x360
[ 81.744264] [<c129b47e>] ? register_con_driver+0x6e/0x190
[ 81.744267] [<c129c3a1>] take_over_console+0x41/0x50
[ 81.744269] [<c1257b7a>] fbcon_takeover+0x6a/0xd0
[ 81.744272] [<c12594b8>] fbcon_event_notify+0x758/0x790
[ 81.744277] [<c10929e2>] notifier_call_chain+0x42/0xb0
[ 81.744280] [<c1092d30>] __blocking_notifier_call_chain+0x60/0x90
[ 81.744283] [<c1092d7a>] blocking_notifier_call_chain+0x1a/0x20
[ 81.744285] [<c124a5a1>] fb_notifier_call_chain+0x11/0x20
[ 81.744288] [<c124b759>] register_framebuffer+0x1d9/0x2b0
[ 81.744293] [<c1061c73>] ? ioremap_wc+0x33/0x40
[ 81.744298] [<f82537c6>] uvesafb_probe+0xaba/0xc40 [uvesafb]
[ 81.744302] [<c12bb81f>] platform_drv_probe+0xf/0x20
[ 81.744306] [<c12ba558>] driver_probe_device+0x68/0x170
[ 81.744309] [<c12ba731>] __device_attach+0x41/0x50
[ 81.744313] [<c12b9088>] bus_for_each_drv+0x48/0x70
[ 81.744316] [<c12ba7f3>] device_attach+0x83/0xa0
[ 81.744319] [<c12ba6f0>] ? __driver_attach+0x90/0x90
[ 81.744321] [<c12b991f>] bus_probe_device+0x6f/0x90
[ 81.744324] [<c12b8a45>] device_add+0x5e5/0x680
[ 81.744329] [<c122a1a3>] ? kvasprintf+0x43/0x60
[ 81.744332] [<c121e6e4>] ? kobject_set_name_vargs+0x64/0x70
[ 81.744335] [<c121e6e4>] ? kobject_set_name_vargs+0x64/0x70
[ 81.744339] [<c12bbe9f>] platform_device_add+0xff/0x1b0
[ 81.744343] [<f8252906>] uvesafb_init+0x50/0x9b [uvesafb]
[ 81.744346] [<c100111f>] do_one_initcall+0x2f/0x170
[ 81.744350] [<f82528b6>] ? uvesafb_is_valid_mode+0x66/0x66 [uvesafb]
[ 81.744355] [<c10c6994>] sys_init_module+0xf4/0x1410
[ 81.744359] [<c1157fc0>] ? vfsmount_lock_local_unlock_cpu+0x30/0x30
[ 81.744363] [<c144cb10>] sysenter_do_call+0x12/0x36
[ 81.744365] Code: f5 00 00 00 32 f6 66 8b da 66 d1 e3 66 ba d4 03 8a e3 b0 1c 66 ef b0 1e 66 ef 8a e7 b0 1d 66 ef b0 1f 66 ef e8 fa 00 00 00 61 c3 <60> e8 c8 00 00 00 66 8b f3 66 8b da 66 ba d4 03 b0 0c 8a e5 66
[ 81.744388] EIP: [<c00cd3b3>] 0xc00cd3b3 SS:ESP 0068:f57f3a00
[ 81.744391] CR2: 00000000c00cd3b3
[ 81.744393] ---[ end trace 18b2c87c925b54d6 ]---
Signed-off-by: Wang YanQing <udknight@gmail.com>
Cc: Michal Januszewski <spock@gentoo.org>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
commit 25c3d30c918207556ae1d6e663150ebdf902186b upstream.
The current code only increments the upper 64 bits of the SHA-512 byte
counter when the number of bytes hashed happens to hit 2^64 exactly.
This patch increments the upper 64 bits whenever the lower 64 bits
overflows.
Signed-off-by: Kent Yoder <key@linux.vnet.ibm.com>
commit cdb1f35dc7de42802527140a3613871c394548e1 upstream.
commit f67fd55fa96f7d7295b43ffbc4a97d8f55e473aa upstream.
Some BIOS implementations leave the Intel GPU interrupts enabled,
even though no one is handling them (f.e. i915 driver is never loaded).
Additionally the interrupt destination is not set up properly
and the interrupt ends up -somewhere-.
These spurious interrupts are "sticky" and the kernel disables
the (shared) interrupt line after 100.000+ generated interrupts.
Fix it by disabling the still enabled interrupts.
This resolves crashes often seen on monitor unplug.
Tested on the following boards:
- Intel DH61CR: Affected
- Intel DH67BL: Affected
- Intel S1200KP server board: Affected
- Asus P8H61-M LE: Affected, but system does not crash.
Probably the IRQ ends up somewhere unnoticed.
According to reports on the net, the Intel DH61WW board is also affected.
Many thanks to Jesse Barnes from Intel for helping
with the register configuration and to Intel in general
for providing public hardware documentation.
Signed-off-by: Thomas Jarosch <thomas.jarosch@intra2net.com>
Tested-by: Charlie Suffin <charlie.suffin@stratus.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Signed-off-by: Willy Tarreau <w@1wt.eu>
commit bcf1b70ac6eb0ed8286c66e6bf37cb747cbaa04c upstream.
A phonet packet is limited to USHRT_MAX bytes, this is never checked during
tx which means that the user can specify any size he wishes, and the kernel
will attempt to allocate that size.
In the good case, it'll lead to the following warning, but it may also cause
the kernel to kick in the OOM and kill a random task on the server.
[ 8921.744094] WARNING: at mm/page_alloc.c:2255 __alloc_pages_slowpath+0x65/0x730()
[ 8921.749770] Pid: 5081, comm: trinity Tainted: G W 3.4.0-rc1-next-20120402-sasha #46
[ 8921.756672] Call Trace:
[ 8921.758185] [<ffffffff810b2ba7>] warn_slowpath_common+0x87/0xb0
[ 8921.762868] [<ffffffff810b2be5>] warn_slowpath_null+0x15/0x20
[ 8921.765399] [<ffffffff8117eae5>] __alloc_pages_slowpath+0x65/0x730
[ 8921.769226] [<ffffffff81179c8a>] ? zone_watermark_ok+0x1a/0x20
[ 8921.771686] [<ffffffff8117d045>] ? get_page_from_freelist+0x625/0x660
[ 8921.773919] [<ffffffff8117f3a8>] __alloc_pages_nodemask+0x1f8/0x240
[ 8921.776248] [<ffffffff811c03e0>] kmalloc_large_node+0x70/0xc0
[ 8921.778294] [<ffffffff811c4bd4>] __kmalloc_node_track_caller+0x34/0x1c0
[ 8921.780847] [<ffffffff821b0e3c>] ? sock_alloc_send_pskb+0xbc/0x260
[ 8921.783179] [<ffffffff821b3c65>] __alloc_skb+0x75/0x170
[ 8921.784971] [<ffffffff821b0e3c>] sock_alloc_send_pskb+0xbc/0x260
[ 8921.787111] [<ffffffff821b002e>] ? release_sock+0x7e/0x90
[ 8921.788973] [<ffffffff821b0ff0>] sock_alloc_send_skb+0x10/0x20
[ 8921.791052] [<ffffffff824cfc20>] pep_sendmsg+0x60/0x380
[ 8921.792931] [<ffffffff824cb4a6>] ? pn_socket_bind+0x156/0x180
[ 8921.794917] [<ffffffff824cb50f>] ? pn_socket_autobind+0x3f/0x90
[ 8921.797053] [<ffffffff824cb63f>] pn_socket_sendmsg+0x4f/0x70
[ 8921.798992] [<ffffffff821ab8e7>] sock_aio_write+0x187/0x1b0
[ 8921.801395] [<ffffffff810e325e>] ? sub_preempt_count+0xae/0xf0
[ 8921.803501] [<ffffffff8111842c>] ? __lock_acquire+0x42c/0x4b0
[ 8921.805505] [<ffffffff821ab760>] ? __sock_recv_ts_and_drops+0x140/0x140
[ 8921.807860] [<ffffffff811e07cc>] do_sync_readv_writev+0xbc/0x110
[ 8921.809986] [<ffffffff811958e7>] ? might_fault+0x97/0xa0
[ 8921.811998] [<ffffffff817bd99e>] ? security_file_permission+0x1e/0x90
[ 8921.814595] [<ffffffff811e17e2>] do_readv_writev+0xe2/0x1e0
[ 8921.816702] [<ffffffff810b8dac>] ? do_setitimer+0x1ac/0x200
[ 8921.818819] [<ffffffff810e2ec1>] ? get_parent_ip+0x11/0x50
[ 8921.820863] [<ffffffff810e325e>] ? sub_preempt_count+0xae/0xf0
[ 8921.823318] [<ffffffff811e1926>] vfs_writev+0x46/0x60
[ 8921.825219] [<ffffffff811e1a3f>] sys_writev+0x4f/0xb0
[ 8921.827127] [<ffffffff82658039>] system_call_fastpath+0x16/0x1b
[ 8921.829384] ---[ end trace dffe390f30db9eb7 ]---
Signed-off-by: Sasha Levin <levinsasha928@gmail.com>
Acked-by: RĂ©mi Denis-Courmont <remi.denis-courmont@nokia.com>
commit 45c72cd73c788dd18c8113d4a404d6b4a01decf1 upstream.
Now we store attr->ino at inode->i_ino, return attr->ino at the
first time and then return inode->i_ino if the attribute timeout
isn't expired. That's wrong on 32 bit platforms because attr->ino
is 64 bit and inode->i_ino is 32 bit in this case.
Fix this by saving 64 bit ino in fuse_inode structure and returning
it every time we call getattr. Also squash attr->ino into inode->i_ino
explicitly.
Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
commit 9fe79d7600497ed8a95c3981cbe5b73ab98222f0 upstream.
If the first attempt at opening the lower file read/write fails,
eCryptfs will retry using a privileged kthread. However, the privileged
retry should not happen if the lower file's inode is read-only because a
read/write open will still be unsuccessful.
The check for determining if the open should be retried was intended to
be based on the access mode of the lower file's open flags being
O_RDONLY, but the check was incorrectly performed. This would cause the
open to be retried by the privileged kthread, resulting in a second
failed open of the lower file. This patch corrects the check to
determine if the open request should be handled by the privileged
kthread.
Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Acked-by: Dan Carpenter <dan.carpenter@oracle.com>
commit 57fc2e335fd3c2f898ee73570dc81426c28dc7b4 upstream.
Rapid ata hotplug on a libsas controller results in cases where libsas
is waiting indefinitely on eh to perform an ata probe.
A race exists between scsi_schedule_eh() and scsi_restart_operations()
in the case when scsi_restart_operations() issues i/o to other devices
in the sas domain. When this happens the host state transitions from
SHOST_RECOVERY (set by scsi_schedule_eh) back to SHOST_RUNNING and
->host_busy is non-zero so we put the eh thread to sleep even though
->host_eh_scheduled is active.
Before putting the error handler to sleep we need to check if the
host_state needs to return to SHOST_RECOVERY for another trip through
eh. Since i/o that is released by scsi_restart_operations has been
blocked for at least one eh cycle, this implementation allows those
i/o's to run before another eh cycle starts to discourage hung task
timeouts.
Reported-by: Tom Jackson <thomas.p.jackson@intel.com>
Tested-by: Tom Jackson <thomas.p.jackson@intel.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit e69e5d3d25d6b58543f782a515baeda064e2b601 upstream.
commit b17caa174a7e1fd2e17b26e210d4ee91c4c28b37 upstream.
commit 198439e4 [SCSI] libsas: do not set res = 0 in sas_ex_discover_dev()
commit 19252de6 [SCSI] libsas: fix wide port hotplug issues
The above commits seem to have confused the return value of
sas_ex_discover_dev which is non-zero on failure and
sas_ex_join_wide_port which just indicates short circuiting discovery on
already established ports. The result is random discovery failures
depending on configuration.
Calls to sas_ex_join_wide_port are the source of the trouble as its
return value is errantly assigned to 'res'. Convert it to bool and stop
returning its result up the stack.
Tested-by: Dan Melnic <dan.melnic@amd.com>
Reported-by: Dan Melnic <dan.melnic@amd.com>
Reviewed-by: Jack Wang <jack_wang@usish.com>
commit 26f2f199ff150d8876b2641c41e60d1c92d2fb81 upstream.
Continue running revalidation until no more broadcast devices are
discovered. Fixes cases where re-discovery completes too early in a
domain with multiple expanders with pending re-discovery events.
Servicing BCNs can get backed up behind error recovery.
commit 940f5d47e2f2e1fa00443921a0abf4822335b54d upstream.
When we call scsi_unprep_request() the command associated with the request
gets destroyed and therefore drops its reference on the device. If this was
the only reference, the device may get released and we end up with a NULL
pointer deref when we call blk_requeue_request.
Reported-by: Mike Christie <michaelc@cs.wisc.edu>
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
Reviewed-by: Mike Christie <michaelc@cs.wisc.edu>
Reviewed-by: Tejun Heo <tj@kernel.org>
[jejb: enhance commend and add commit log for stable]
commit a9d0acf8d157c30374af76d43e7f05b5b108be0c upstream.
[ Upstream commit 89d7ae34cdda4195809a5a987f697a517a2a3177 ]
As reported by Alan Cox, and verified by Lin Ming, when a user
attempts to add a CIPSO option to a socket using the CIPSO_V4_TAG_LOCAL
tag the kernel dies a terrible death when it attempts to follow a NULL
pointer (the skb argument to cipso_v4_validate() is NULL when called via
the setsockopt() syscall).
This patch fixes this by first checking to ensure that the skb is
non-NULL before using it to find the incoming network interface. In
the unlikely case where the skb is NULL and the user attempts to add
a CIPSO option with the _TAG_LOCAL tag we return an error as this is
not something we want to allow.
A simple reproducer, kindly supplied by Lin Ming, although you must
have the CIPSO DOI #3 configure on the system first or you will be
caught early in cipso_v4_validate():
#include <sys/types.h>
#include <sys/socket.h>
#include <linux/ip.h>
#include <linux/in.h>
#include <string.h>
struct local_tag {
char type;
char length;
char info[4];
struct cipso {
char type;
char length;
char doi[4];
struct local_tag local;
int main(int argc, char **argv)
int sockfd;
struct cipso cipso = {
.type = IPOPT_CIPSO,
.length = sizeof(struct cipso),
.local = {
.type = 128,
.length = sizeof(struct local_tag),
memset(cipso.doi, 0, 4);
cipso.doi[3] = 3;
sockfd = socket(AF_INET, SOCK_DGRAM, 0);
#define SOL_IP 0
setsockopt(sockfd, SOL_IP, IP_OPTIONS,
&cipso, sizeof(struct cipso));
return 0;
CC: Lin Ming <mlin@ss.pku.edu.cn>
Reported-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Signed-off-by: Paul Moore <pmoore@redhat.com>
commit b6070a8d9853eda010a549fa9a09eb8d7269b929 upstream.
If fixup_pi_state_owner() faults, pi_mutex may be NULL. Test
for pi_mutex != NULL before testing the owner against current
and possibly unlocking it.
Signed-off-by: Darren Hart <dvhart@linux.intel.com>
Cc: Dave Jones <davej@redhat.com>
Cc: Dan Carpenter <dan.carpenter@oracle.com>
Link: http://lkml.kernel.org/r/dc59890338fc413606f04e5c5b131530734dae3d.1342809673.git.dvhart@linux.intel.com
commit f27071cb7fe3e1d37a9dbe6c0dfc5395cd40fa43 upstream.
The WARN_ON in futex_wait_requeue_pi() for a NULL q.pi_state was testing
the address (&q.pi_state) of the pointer instead of the value
(q.pi_state) of the pointer. Correct it accordingly.
Link: http://lkml.kernel.org/r/1c85d97f6e5f79ec389a4ead3e367363c74bd09a.1342809673.git.dvhart@linux.intel.com
commit 6f7b0a2a5c0fb03be7c25bd1745baa50582348ef upstream.
If uaddr == uaddr2, then we have broken the rule of only requeueing
from a non-pi futex to a pi futex with this call. If we attempt this,
as the trinity test suite manages to do, we miss early wakeups as
q.key is equal to key2 (because they are the same uaddr). We will then
attempt to dereference the pi_mutex (which would exist had the futex_q
been properly requeued to a pi futex) and trigger a NULL pointer
dereference.
Link: http://lkml.kernel.org/r/ad82bfe7f7d130247fbe2b5b4275654807774227.1342809673.git.dvhart@linux.intel.com
commit 6c4088ac3a4d82779903433bcd5f048c58fb1aca upstream.
efi_setup_pcdp_console() is called during boot to parse the HCDP/PCDP
EFI system table and setup an early console for printk output. The
routine uses ioremap/iounmap to setup access to the HCDP/PCDP table
information.
The call to ioremap is happening early in the boot process which leads
to a panic on x86_64 systems:
panic+0x01ca
do_exit+0x043c
oops_end+0x00a7
no_context+0x0119
__bad_area_nosemaphore+0x0138
bad_area_nosemaphore+0x000e
do_page_fault+0x0321
page_fault+0x0020
reserve_memtype+0x02a1
__ioremap_caller+0x0123
ioremap_nocache+0x0012
efi_setup_pcdp_console+0x002b
setup_arch+0x03a9
start_kernel+0x00d4
x86_64_start_reservations+0x012c
x86_64_start_kernel+0x00fe
This replaces the calls to ioremap/iounmap in efi_setup_pcdp_console()
with calls to early_ioremap/early_iounmap which can be called during
early boot.
This patch was tested on an x86_64 prototype system which uses the
HCDP/PCDP table for early console setup.
Signed-off-by: Greg Pearson <greg.pearson@hp.com>
Acked-by: Khalid Aziz <khalid.aziz@hp.com>
commit fb6ccff667712c46b4501b920ea73a326e49626a upstream.
Commit 7572777eef78ebdee1ecb7c258c0ef94d35bad16 attempted to verify that
the total iovec from the client doesn't overflow iov_length() but it
only checked the first element. The iovec could still overflow by
starting with a small element. The obvious fix is to check all the
elements.
The overflow case doesn't look dangerous to the kernel as the copy is
limited by the length after the overflow. This fix restores the
intention of returning an error instead of successfully copying less
than the iovec represented.
I found this by code inspection. I built it but don't have a test case.
I'm cc:ing stable because the initial commit did as well.
Signed-off-by: Zach Brown <zab@redhat.com>
commit 0e665d5d1125f9f4ccff56a75e814f10f88861a2 upstream.
compat_sys_{read,write}v() need the same "pass a copy of file->f_pos" thing
as sys_{read,write}{,v}().
commit d10f27a750312ed5638c876e4bd6aa83664cccd8 upstream.
The rpc server tries to ensure that there will be room to send a reply
before it receives a request.
It does this by tracking, in xpt_reserved, an upper bound on the total
size of the replies that is has already committed to for the socket.
Currently it is adding in the estimate for a new reply *before* it
checks whether there is space available. If it finds that there is not
space, it then subtracts the estimate back out.
This may lead the subsequent svc_xprt_enqueue to decide that there is
space after all.
The results is a svc_recv() that will repeatedly return -EAGAIN, causing
server threads to loop without doing any actual work.
Reported-by: Michael Tokarev <mjt@tls.msk.ru>
Tested-by: Michael Tokarev <mjt@tls.msk.ru>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit f06f00a24d76e168ecb38d352126fd203937b601 upstream.
svc_tcp_sendto sets XPT_CLOSE if we fail to transmit the entire reply.
However, the XPT_CLOSE won't be acted on immediately. Meanwhile other
threads could send further replies before the socket is really shut
down. This can manifest as data corruption: for example, if a truncated
read reply is followed by another rpc reply, that second reply will look
to the client like further read data.
Symptoms were data corruption preceded by svc_tcp_sendto logging
something like
kernel: rpc-srv/tcp: nfsd: sent only 963696 when sending 1048708 bytes - shutting down socket
Reported-by: Malahal Naineni <malahal@us.ibm.com>
Tested-by: Malahal Naineni <malahal@us.ibm.com>
commit 80de7c3138ee9fd86a98696fd2cf7ad89b995d0a upstream.
Trivially triggerable, found by trinity:
kernel BUG at mm/mempolicy.c:2546!
Process trinity-child2 (pid: 23988, threadinfo ffff88010197e000, task ffff88007821a670)
Call Trace:
show_numa_map+0xd5/0x450
show_pid_numa_map+0x13/0x20
traverse+0xf2/0x230
seq_read+0x34b/0x3e0
vfs_read+0xac/0x180
sys_pread64+0xa2/0xc0
system_call_fastpath+0x1a/0x1f
RIP: mpol_to_str+0x156/0x360
Signed-off-by: Dave Jones <davej@redhat.com>
commit 276bdb82dedb290511467a5a4fdbe9f0b52dce6f upstream.
ccid_hc_rx_getsockopt() and ccid_hc_tx_getsockopt() might be called with
a NULL ccid pointer leading to a NULL pointer dereference. This could
lead to a privilege escalation if the attacker is able to map page 0 and
prepare it with a fake ccid_ops pointer.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: Gerrit Renker <gerrit@erg.abdn.ac.uk>
commit 48f8b641297df49021093763a3271119a84990a2 upstream.
The intent here was clearly to set result to true if the 0x40000000 flag
was set. But instead there was a | vs & typo and we always set result
to true.
Artem: check the spec at
wiki.laptop.org/images/5/5c/88ALP01_Datasheet_July_2007.pdf
and this fix looks correct.
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
commit 27d6379894be4a81984da4d48002196a83939ca9 upstream.
Fix an incorrect error check that returns 1 for error instead of the
expected error code.
commit 68766a2edcd5cd744262a70a2f67a320ac944760 upstream.
In case we detect a problem and bail out, we fail to set "ret" to a
nonzero value, and udf_load_logicalvol will mistakenly report success.
Signed-off-by: Nikola Pajkovsky <npajkovs@redhat.com>
commit 9c2fc0de1a6e638fe58c354a463f544f42a90a09 upstream.
When a file is stored in ICB (inode), we overwrite part of the file, and
the page containing file's data is not in page cache, we end up corrupting
file's data by overwriting them with zeros. The problem is we use
simple_write_begin() which simply zeroes parts of the page which are not
written to. The problem has been introduced by be021ee4 (udf: convert to
new aops).
Fix the problem by providing a ->write_begin function which makes the page
properly uptodate.
Reported-by: Ian Abbott <abbotti@mev.co.uk>
commit 89b1f39eb4189de745fae554b0d614d87c8d5c63 upstream.
For large UDF filesystems with 512-byte blocks the number of necessary
bitmap blocks is larger than 2^16 so s_nr_groups in udf_bitmap overflows
(the number will overflow for filesystems larger than 128 GB with
512-byte blocks). That results in ENOSPC errors despite the filesystem
has plenty of free space.
Fix the problem by changing s_nr_groups' type to 'int'. That is enough
even for filesystems 2^32 blocks (UDF maximum) and 512-byte blocksize.
Reported-and-tested-by: v10lator@myway.de
commit 0143fc5e9f6f5aad4764801015bc8d4b4a278200 upstream.
For type 0x51 the udf.parent_partref member in struct fid gets copied
uninitialized to userland. Fix this by initializing it to 0.
commit 2fb7d99d0de3fd8ae869f35ab682581d8455887a upstream.
Need to brelse the buffer_head stored in cur_epos and next_epos.
Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com>
Signed-off-by: Ashish Sangwan <a.sangwan@samsung.com>
commit e9fbcb42201c862fd6ab45c48ead4f47bb2dea9d upstream.
Each ordered operation has a free callback, and this was called with the
worker spinlock held. Josef made the free callback also call iput,
which we can't do with the spinlock.
This drops the spinlock for the free operation and grabs it again before
moving through the rest of the list. We'll circle back around to this
and find a cleaner way that doesn't bounce the lock around so much.
Signed-off-by: Chris Mason <chris.mason@fusionio.com>
commit bc178622d40d87e75abc131007342429c9b03351 upstream.
Doing this would reliably fail with -EBUSY for me:
# mount /dev/sdb2 /mnt/scratch; umount /mnt/scratch; mkfs.btrfs -f /dev/sdb2
unable to open /dev/sdb2: Device or resource busy
because mkfs.btrfs tries to open the device O_EXCL, and somebody still has it.
Using systemtap to track bdev gets & puts shows a kworker thread doing a
blkdev put after mkfs attempts a get; this is left over from the unmount
path:
btrfs_close_devices
__btrfs_close_devices
call_rcu(&device->rcu, free_device);
free_device
INIT_WORK(&device->rcu_work, __free_device);
schedule_work(&device->rcu_work);
so unmount might complete before __free_device fires & does its blkdev_put.
Adding an rcu_barrier() to btrfs_close_devices() causes unmount to wait
until all blkdev_put()s are done, and the device is truly free once
unmount completes.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Signed-off-by: Josef Bacik <jbacik@fusionio.com>
commit acd6ad83517639e8f09a8c5525b1dccd81cd2a10 upstream.
When insert_inode_locked() fails in ext4_new_inode() it most likely means inode
bitmap got corrupted and we allocated again inode which is already in use. Also
doing unlock_new_inode() during error recovery is wrong since the inode does
not have I_NEW set. Fix the problem by jumping to fail: (instead of fail_drop:)
which declares filesystem error and does not call unlock_new_inode().
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit 0e9a9a1ad619e7e987815d20262d36a2f95717ca upstream.
When trying to mount a file system which does not contain a journal,
but which does have a orphan list containing an inode which needs to
be truncated, the mount call with hang forever in
ext4_orphan_cleanup() because ext4_orphan_del() will return
immediately without removing the inode from the orphan list, leading
to an uninterruptible loop in kernel code which will busy out one of
the CPU's on the system.
This can be trivially reproduced by trying to mount the file system
found in tests/f_orphan_extents_inode/image.gz from the e2fsprogs
source tree. If a malicious user were to put this on a USB stick, and
mount it on a Linux desktop which has automatic mounts enabled, this
could be considered a potential denial of service attack. (Not a big
deal in practice, but professional paranoids worry about such things,
and have even been known to allocate CVE numbers for such problems.)
Reviewed-by: Zheng Liu <wenqing.lz@taobao.com>
commit c9b92530a723ac5ef8e352885a1862b18f31b2f5 upstream.
Instead of checking whether the handle is valid, we check if journal
is enabled. This avoids taking the s_orphan_lock mutex in all cases
when there is no journal in use, including the error paths where
ext4_orphan_del() is called with a handle set to NULL.
Signed-off-by: Anatol Pomozov <anatol.pomozov@gmail.com>
commit e6155736ad76b2070652745f9e54cdea3f0d8567 upstream.
In the case where we are allocating for a non-extent file,
we must limit the groups we allocate from to those below
2^32 blocks, and ext4_mb_regular_allocator() attempts to
do this initially by putting a cap on ngroups for the
subsequent search loop.
However, the initial target group comes in from the
allocation context (ac), and it may already be beyond
the artificially limited ngroups. In this case,
the limit
if (group == ngroups)
group = 0;
at the top of the loop is never true, and the loop will
run away.
Catch this case inside the loop and reset the search to
start at group 0.
[sandeen@redhat.com: add commit msg & comments]
Signed-off-by: Lachlan McIlroy <lmcilroy@redhat.com>
commit f1167009711032b0d747ec89a632a626c901a1ad upstream.
In ext4_mb_add_n_trim(), lg_prealloc_lock should be taken when
changing the lg_prealloc_list.
Signed-off-by: Niu Yawei <yawei.niu@intel.com>
commit 721e3eba21e43532e438652dd8f1fcdfce3187e7 upstream.
Commit c278531d39 added a warning when ext4_flush_unwritten_io() is
called without i_mutex being taken. It had previously not been taken
during orphan cleanup since races weren't possible at that point in
the mount process, but as a result of this c278531d39, we will now see
a kernel WARN_ON in this case. Take the i_mutex in
ext4_orphan_cleanup() to suppress this warning.
Reported-by: Alexander Beregalov <a.beregalov@gmail.com>
commit b71fc079b5d8f42b2a52743c8d2f1d35d655b1c5 upstream.
Code tracking when transaction needs to be committed on fdatasync(2) forgets
to handle a situation when only inode's i_size is changed. Thus in such
situations fdatasync(2) doesn't force transaction with new i_size to disk
and that can result in wrong i_size after a crash.
Fix the issue by updating inode's i_datasync_tid whenever its size is
updated.
Reported-by: Kristian Nielsen <knielsen@knielsen-hq.org>
commit 6a08f447facb4f9e29fcc30fb68060bb5a0d21c2 upstream.
ext4_special_inode_operations have their own ifdef CONFIG_EXT4_FS_XATTR
to mask those methods. And ext4_iget also always sets it, so there is
an inconsistency.
Signed-off-by: Bernd Schubert <bernd.schubert@itwm.fraunhofer.de>
commit f066055a3449f0e5b0ae4f3ceab4445bead47638 upstream.
Proper block swap for inodes with full journaling enabled is
truly non obvious task. In order to be on a safe side let's
explicitly disable it for now.
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
commit 24ec19b0ae83a385ad9c55520716da671274b96c upstream.
In ext4_xattr_set_acl(), if ext4_journal_start() returns an error,
posix_acl_release() will not be called for 'acl' which may result in a
memory leak.
This patch fixes that.
Reviewed-by: Lukas Czerner <lczerner@redhat.com>
Signed-off-by: Eugene Shatokhin <eugene.shatokhin@rosalab.ru>
commit 6976a6f2acde2b0443cd64f1d08af90630e4ce81 upstream.
Fix for a null pointer bug found while running punch hole tests
Signed-off-by: Allison Henderson <achender@us.ibm.com>
commit 7ad8e4e6ae2a7c95445ee1715b1714106fb95037 upstream.
When make_indexed_dir() fails (e.g. because of ENOSPC) after it has
allocated block for index tree root, we did not properly mark all
changed buffers dirty. This lead to only some of these buffers being
written out and thus effectively corrupting the directory.
Fix the issue by marking all changed data dirty even in the error
failure case.
commit 97795d2a5b8d3c8dc4365d4bd3404191840453ba upstream.
If we hit a condition where we have allocated metadata blocks that
were not appropriately reserved, we risk underflow of
ei->i_reserved_meta_blocks. In turn, this can throw
sbi->s_dirtyclusters_counter significantly out of whack and undermine
the nondelalloc fallback logic in ext4_nonda_switch(). Warn if this
occurs and set i_allocated_meta_blocks to avoid this problem.
This condition is reproduced by xfstests 270 against ext2 with
delalloc enabled:
Mar 28 08:58:02 localhost kernel: [ 171.526344] EXT4-fs (loop1): delayed block allocation failed for inode 14 at logical offset 64486 with max blocks 64 with error -28
Mar 28 08:58:02 localhost kernel: [ 171.526346] EXT4-fs (loop1): This should not happen!! Data will be lost
270 ultimately fails with an inconsistent filesystem and requires an
fsck to repair. The cause of the error is an underflow in
ext4_da_update_reserve_space() due to an unreserved meta block
allocation.
Signed-off-by: Brian Foster <bfoster@redhat.com>
commit 1415dd8705394399d59a3df1ab48d149e1e41e77 upstream.
When insert_inode_locked() fails in ext3_new_inode() it most likely
means inode bitmap got corrupted and we allocated again inode which
is already in use. Also doing unlock_new_inode() during error recovery
is wrong since inode does not have I_NEW set. Fix the problem by jumping
to fail: (instead of fail_drop:) which declares filesystem error and
Reviewed-by: Eric Sandeen <sandeen@redhat.com>
commit 156bddd8e505b295540f3ca0e27dda68cb0d49aa upstream.
updated.
commit 545d680938be1e86a6c5250701ce9abaf360c495 upstream.
After passing through a ->setxattr() call, eCryptfs needs to copy the
inode attributes from the lower inode to the eCryptfs inode, as they
may have changed in the lower filesystem's ->setxattr() path.
One example is if an extended attribute containing a POSIX Access
Control List is being set. The new ACL may cause the lower filesystem to
modify the mode of the lower inode and the eCryptfs inode would need to
be updated to reflect the new mode.
https://launchpad.net/bugs/926292
Reported-by: Sebastien Bacher <seb128@ubuntu.com>
Cc: John Johansen <john.johansen@canonical.com>
commit 48b512e6857139393cdfce26348c362b87537018 upstream.
Ecryptfs is a stackable filesystem which relies on lower filesystems the
ability of setting/getting extended attributes.
If there is a security module enabled on the system it updates the
'security' field of inodes according to the owned extended attribute set
with the function vfs_setxattr(). When this function is performed on a
ecryptfs filesystem the 'security' field is not updated for the lower
filesystem since the call security_inode_post_setxattr() is missing for
the lower inode.
Further, the call security_inode_setxattr() is missing for the lower inode,
leading to policy violations in the security module because specific
checks for this hook are not performed (i. e. filesystem
'associate' permission on SELinux is not checked for the lower filesystem).
This patch replaces the call of the setxattr() method of the lower inode
in the function ecryptfs_setxattr() with vfs_setxattr().
Signed-off-by: Roberto Sassu <roberto.sassu@polito.it>
Cc: Dustin Kirkland <kirkland@canonical.com>
Acked-by: James Morris <jmorris@namei.org>
Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
commit 15291164b22a357cb211b618adfef4fa82fc0de3 upstream.
journal_unmap_buffer()'s zap_buffer: code clears a lot of buffer head
state ala discard_buffer(), but does not touch _Delay or _Unwritten as
discard_buffer() does.
This can be problematic in some areas of the ext4 code which assume
that if they have found a buffer marked unwritten or delay, then it's
a live one. Perhaps those spots should check whether it is mapped
as well, but if jbd2 is going to tear down a buffer, let's really
tear it down completely.
Without this I get some fsx failures on sub-page-block filesystems
up until v3.2, at which point 4e96b2dbbf1d7e81f22047a50f862555a6cb87cb
and 189e868fa8fdca702eb9db9d8afc46b5cb9144c9 make the failures go
away, because buried within that large change is some more flag
clearing. I still think it's worth doing in jbd2, since
->invalidatepage leads here directly, and it's the right place
to clear away these flags.
commit 25389bb207987b5774182f763b9fb65ff08761c8 upstream.
Commit 09e05d48 introduced a wait for transaction commit into
journal_unmap_buffer() in the case we are truncating a buffer undergoing commit
in the page stradding i_size on a filesystem with blocksize < pagesize. Sadly
we forgot to drop buffer lock before waiting for transaction commit and thus
deadlock is possible when kjournald wants to lock the buffer.
Fix the problem by dropping the buffer lock before waiting for transaction
commit. Since we are still holding page lock (and that is OK), buffer cannot
disappear under us.
