Signed-off-by: Willy Tarreau <w@1wt.eu>
Upstream commit e727ca82e0e9 ("proc connector: fix info leaks")
changed many functions that don't exist in 2.6.32.y. When it was
cherry-picked into 2.6.32.61, one extra memset() calls was inserted
into proc_exit_connector(). This results in clearing the cpu
field of exit events.
Acked-by: Mathias Krause <minipli@googlemail.com>
Upstream commit 58f09e00ae09 was applied to the wrong function when
cherry-picked for 2.6.32.61.
commit e81ca6fe85b77109a32489a5db82f575d51dfc98 upstream.
If the queue is dead blk_execute_rq_nowait() doesn't invoke the done()
callback function. That will result in blk_execute_rq() being stuck
in wait_for_completion(). Avoid this by initializing rq->end_io to the
done() callback before we check the queue state. Also, make sure the
queue lock is held around the invocation of the done() callback. Found
this through source code review.
Signed-off-by: Muthukumar Ratty <muthur@gmail.com>
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
Reviewed-by: Tejun Heo <tj@kernel.org>
Acked-by: Jens Axboe <axboe@kernel.dk>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
[bwh: Backported to 2.6.32: adjust context]
commit 8ba61435d73f2274e12d4d823fde06735e8f6a54 upstream.
blk_insert_cloned_request(), blk_execute_rq_nowait() and
blk_flush_plug_list() either didn't check whether the queue was dead
or did it without holding queue_lock. Update them so that dead state
is checked while holding queue_lock.
AFAICS, this plugs all holes (requeue doesn't matter as the request is
transitioning atomically from in_flight to queued).
- Drop inapplicable changes to queue_unplugged() and
- We don't have blk_queue_dead() so open-code it
- Adjust context]
Upstream commit 9c4bdf697c39 ("md/raid6: avoid data corruption during
recovery of double-degraded RAID6") changes handle_stripe(), but we
have separate functions for RAID5 and RAID6 and need to apply the
change to handle_stripe6(). When cherry-picked, the change was
wrongly applied to handle_stripe5().
One deletion was omitted from the backport of upstream commit c485658bae87
("net: sctp: fix skb leakage in COOKIE ECHO path of chunk->auth_chunk").
commit deede2fabe24e00bd7e246eb81cd5767dc6fcfc7 upstream.
When (de)configuring a vlan interface, the IFF_ALLMULTI ans IFF_PROMISC
flags are cleared or set on the underlying interface. So, if these flags
are changed on a vlan interface that is not up, the flags underlying
interface might be set or cleared twice.
Only propagating flag changes when a device is up makes sure this does
not happen. It also makes sure that an underlying device is not set to
promiscuous or allmulti mode for a vlan device that is down.
Signed-off-by: Matthijs Kooijman <matthijs@stdin.nl>
[bwh: This is a dependency of commit d2615bf45069 ("net: core: Always
propagate flag changes to interfaces"), already backported in 2.6.32.62]
commit dc0ab1ddeb0c5f5eb3f37a72eadb394792b3c40d upstream
We need to add a limit check here so we don't overflow the buffer.
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
(backported from commit f2e323ec96077642d397bb1c355def536d489d16)
CVE-2014-8884
BugLink: http://bugs.launchpad.net/bugs/1395187
Signed-off-by: Luis Henriques <luis.henriques@canonical.com>
Acked-by: Andy Whitcroft <apw@canonical.com>
Signed-off-by: Andy Whitcroft <apw@canonical.com>
Acked-by: Stefan Bader <stefan.bader@canonical.com>
commit a722a419815ed203b519151f9556859ff256638b upstream
The "new" fragmentation code (since my rewrite almost 5 years ago)
erroneously sets skb->len rather than using skb_trim() to adjust
the length of the first fragment after copying out all the others.
This leaves the skb tail pointer pointing to after where the data
originally ended, and thus causes the encryption MIC to be written
at that point, rather than where it belongs: immediately after the
data.
The impact of this is that if software encryption is done, then
a) encryption doesn't work for the first fragment, the connection
becomes unusable as the first fragment will never be properly
verified at the receiver, the MIC is practically guaranteed to
be wrong
b) we leak up to 8 bytes of plaintext (!) of the packet out into
the air
This is only mitigated by the fact that many devices are capable
of doing encryption in hardware, in which case this can't happen
as the tail pointer is irrelevant in that case. Additionally,
fragmentation is not used very frequently and would normally have
to be configured manually.
Fix this by using skb_trim() properly.
Cc: stable@vger.kernel.org
Fixes: 2de8e0d999b8 ("mac80211: rewrite fragmentation")
Reported-by: Jouni Malinen <j@w1.fi>
(backported from commit 338f977f4eb441e69bb9a46eaa0ac715c931a67f)
CVE-2014-8709
BugLink: http://bugs.launchpad.net/bugs/1392013
packet
commit a6e1af6f5e9e75095ae1b004f6f00082e5fc4d2d upstream
An SCTP server doing ASCONF will panic on malformed INIT ping-of-death
in the form of:
------------ INIT[PARAM: SET_PRIMARY_IP] ------------>
While the INIT chunk parameter verification dissects through many things
in order to detect malformed input, it misses to actually check parameters
inside of parameters. E.g. RFC5061, section 4.2.4 proposes a 'set primary
IP address' parameter in ASCONF, which has as a subparameter an address
parameter.
So an attacker may send a parameter type other than SCTP_PARAM_IPV4_ADDRESS
or SCTP_PARAM_IPV6_ADDRESS, param_type2af() will subsequently return 0
and thus sctp_get_af_specific() returns NULL, too, which we then happily
dereference unconditionally through af->from_addr_param().
The trace for the log:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000078
IP: [<ffffffffa01e9c62>] sctp_process_init+0x492/0x990 [sctp]
PGD 0
Oops: 0000 [#1] SMP
Pid: 0, comm: swapper Not tainted 2.6.32-504.el6.x86_64 #1 Bochs Bochs
RIP: 0010:[<ffffffffa01e9c62>] [<ffffffffa01e9c62>] sctp_process_init+0x492/0x990 [sctp]
Call Trace:
<IRQ>
[<ffffffffa01f2add>] ? sctp_bind_addr_copy+0x5d/0xe0 [sctp]
[<ffffffffa01e1fcb>] sctp_sf_do_5_1B_init+0x21b/0x340 [sctp]
[<ffffffffa01e3751>] sctp_do_sm+0x71/0x1210 [sctp]
[<ffffffffa01e5c09>] ? sctp_endpoint_lookup_assoc+0xc9/0xf0 [sctp]
[<ffffffffa01e61f6>] sctp_endpoint_bh_rcv+0x116/0x230 [sctp]
[<ffffffffa01ee986>] sctp_inq_push+0x56/0x80 [sctp]
[<ffffffffa01fcc42>] sctp_rcv+0x982/0xa10 [sctp]
[<ffffffffa01d5123>] ? ipt_local_in_hook+0x23/0x28 [iptable_filter]
[<ffffffff8148bdc9>] ? nf_iterate+0x69/0xb0
[<ffffffff81496d10>] ? ip_local_deliver_finish+0x0/0x2d0
[<ffffffff8148bf86>] ? nf_hook_slow+0x76/0x120
A minimal way to address this is to check for NULL as we do on all
other such occasions where we know sctp_get_af_specific() could
possibly return with NULL.
Fixes: d6de3097592b ("[SCTP]: Add the handling of "Set Primary IP Address" parameter to INIT")
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Cc: Vlad Yasevich <vyasevich@gmail.com>
(cherry picked from commit e40607cbe270a9e8360907cb1e62ddf0736e4864)
CVE-2014-7841
BugLink: http://bugs.launchpad.net/bugs/1392820
commit 541d302ee5c46336cbad333222bc278b76cc1c42 upstream
We did not implement any bound on number of indirect ICBs we follow when
loading inode. Thus corrupted medium could cause kernel to go into an
infinite loop, possibly causing a stack overflow.
Fix the possible stack overflow by removing recursion from
__udf_read_inode() and limit number of indirect ICBs we follow to avoid
infinite loops.
(back ported from commit c03aa9f6e1f938618e6db2e23afef0574efeeb65)
[ luis: adjusted context and replaced udf_err() by printk() ]
CVE-2014-6410
BugLink: http://bugs.launchpad.net/bugs/1370042
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
commit b2d33ef40de7161c23032106284959ae75bdf3cd upstream
This scenario is not limited to ASCONF, just taken as one
example triggering the issue. When receiving ASCONF probes
in the form of ...
-------------- INIT[ASCONF; ASCONF_ACK] ------------->
<----------- INIT-ACK[ASCONF; ASCONF_ACK] ------------
-------------------- COOKIE-ECHO -------------------->
<-------------------- COOKIE-ACK ---------------------
---- ASCONF_a; [ASCONF_b; ...; ASCONF_n;] JUNK ------>
---- ASCONF_m; [ASCONF_o; ...; ASCONF_z;] JUNK ------>
... where ASCONF_a, ASCONF_b, ..., ASCONF_z are good-formed
ASCONFs and have increasing serial numbers, we process such
ASCONF chunk(s) marked with !end_of_packet and !singleton,
since we have not yet reached the SCTP packet end. SCTP does
only do verification on a chunk by chunk basis, as an SCTP
packet is nothing more than just a container of a stream of
chunks which it eats up one by one.
We could run into the case that we receive a packet with a
malformed tail, above marked as trailing JUNK. All previous
chunks are here goodformed, so the stack will eat up all
previous chunks up to this point. In case JUNK does not fit
into a chunk header and there are no more other chunks in
the input queue, or in case JUNK contains a garbage chunk
header, but the encoded chunk length would exceed the skb
tail, or we came here from an entirely different scenario
and the chunk has pdiscard=1 mark (without having had a flush
point), it will happen, that we will excessively queue up
the association's output queue (a correct final chunk may
then turn it into a response flood when flushing the
queue ;)): I ran a simple script with incremental ASCONF
serial numbers and could see the server side consuming
excessive amount of RAM [before/after: up to 2GB and more].
The issue at heart is that the chunk train basically ends
with !end_of_packet and !singleton markers and since commit
2e3216cd54b1 ("sctp: Follow security requirement of responding
with 1 packet") therefore preventing an output queue flush
point in sctp_do_sm() -> sctp_cmd_interpreter() on the input
chunk (chunk = event_arg) even though local_cork is set,
but its precedence has changed since then. In the normal
case, the last chunk with end_of_packet=1 would trigger the
queue flush to accommodate possible outgoing bundling.
In the input queue, sctp_inq_pop() seems to do the right thing
in terms of discarding invalid chunks. So, above JUNK will
not enter the state machine and instead be released and exit
the sctp_assoc_bh_rcv() chunk processing loop. It's simply
the flush point being missing at loop exit. Adding a try-flush
approach on the output queue might not work as the underlying
infrastructure might be long gone at this point due to the
side-effect interpreter run.
One possibility, albeit a bit of a kludge, would be to defer
invalid chunk freeing into the state machine in order to
possibly trigger packet discards and thus indirectly a queue
flush on error. It would surely be better to discard chunks
as in the current, perhaps better controlled environment, but
going back and forth, it's simply architecturally not possible.
I tried various trailing JUNK attack cases and it seems to
look good now.
Joint work with Vlad Yasevich.
Fixes: 2e3216cd54b1 ("sctp: Follow security requirement of responding with 1 packet")
Signed-off-by: Vlad Yasevich <vyasevich@gmail.com>
(cherry picked from commit 26b87c7881006311828bb0ab271a551a62dcceb4)
CVE-2014-3688
BugLink: http://bugs.launchpad.net/bugs/1386393
Acked-by: Andy Whitcroft <andy.whitcroft@canonical.com>
Signed-off-by: Brad Figg <brad.figg@canonical.com>
commit 12b18fdbbda747ad22a7684413a6559b681e503c upstream
When receiving a e.g. semi-good formed connection scan in the
form of ...
---------------- ASCONF_a; ASCONF_b ----------------->
... where ASCONF_a equals ASCONF_b chunk (at least both serials
need to be equal), we panic an SCTP server!
The problem is that good-formed ASCONF chunks that we reply with
ASCONF_ACK chunks are cached per serial. Thus, when we receive a
same ASCONF chunk twice (e.g. through a lost ASCONF_ACK), we do
not need to process them again on the server side (that was the
idea, also proposed in the RFC). Instead, we know it was cached
and we just resend the cached chunk instead. So far, so good.
Where things get nasty is in SCTP's side effect interpreter, that
is, sctp_cmd_interpreter():
While incoming ASCONF_a (chunk = event_arg) is being marked
!end_of_packet and !singleton, and we have an association context,
we do not flush the outqueue the first time after processing the
ASCONF_ACK singleton chunk via SCTP_CMD_REPLY. Instead, we keep it
queued up, although we set local_cork to 1. Commit 2e3216cd54b1
changed the precedence, so that as long as we get bundled, incoming
chunks we try possible bundling on outgoing queue as well. Before
this commit, we would just flush the output queue.
Now, while ASCONF_a's ASCONF_ACK sits in the corked outq, we
continue to process the same ASCONF_b chunk from the packet. As
we have cached the previous ASCONF_ACK, we find it, grab it and
do another SCTP_CMD_REPLY command on it. So, effectively, we rip
the chunk->list pointers and requeue the same ASCONF_ACK chunk
another time. Since we process ASCONF_b, it's correctly marked
with end_of_packet and we enforce an uncork, and thus flush, thus
crashing the kernel.
Fix it by testing if the ASCONF_ACK is currently pending and if
that is the case, do not requeue it. When flushing the output
queue we may relink the chunk for preparing an outgoing packet,
but eventually unlink it when it's copied into the skb right
before transmission.
(cherry picked from commit b69040d8e39f20d5215a03502a8e8b4c6ab78395)
CVE-2014-3687
BugLink: http://bugs.launchpad.net/bugs/1386392
commit c5fd4126151855330280ea9382684980afcfdd03 upstream
This patch fixes a potential security issue in the whiteheat USB driver
which might allow a local attacker to cause kernel memory corrpution. This
is due to an unchecked memcpy into a fixed size buffer (of 64 bytes). On
EHCI and XHCI busses it's possible to craft responses greater than 64
bytes leading a buffer overflow.
Signed-off-by: James Forshaw <forshaw@google.com>
Cc: stable <stable@vger.kernel.org>
(backported from commit 6817ae225cd650fb1c3295d769298c38b1eba818)
CVE-2014-3185
BugLink: http://bugs.launchpad.net/bugs/1370036
(commit 82262a46627bebb0febcc26664746c25cef08563 upstream)
There are two issues with the current implementation for replacing user
controls. The first is that the code does not check if the control is actually a
user control and neither does it check if the control is owned by the process
that tries to remove it. That allows userspace applications to remove arbitrary
controls, which can cause a user after free if a for example a driver does not
expect a control to be removed from under its feed.
The second issue is that on one hand when a control is replaced the
user_ctl_count limit is not checked and on the other hand the user_ctl_count is
increased (even though the number of user controls does not change). This allows
userspace, once the user_ctl_count limit as been reached, to repeatedly replace
a control until user_ctl_count overflows. Once that happens new controls can be
added effectively bypassing the user_ctl_count limit.
Both issues can be fixed by instead of open-coding the removal of the control
that is to be replaced to use snd_ctl_remove_user_ctl(). This function does
proper permission checks as well as decrements user_ctl_count after the control
has been removed.
Note that by using snd_ctl_remove_user_ctl() the check which returns -EBUSY at
beginning of the function if the control already exists is removed. This is not
a problem though since the check is quite useless, because the lock that is
protecting the control list is released between the check and before adding the
new control to the list, which means that it is possible that a different
control with the same settings is added to the list after the check. Luckily
there is another check that is done while holding the lock in snd_ctl_add(), so
we'll rely on that to make sure that the same control is not added twice.
Acked-by: Jaroslav Kysela <perex@perex.cz>
Cc: <stable@vger.kernel.org>
[wt: fixes CVE-2014-4654 & CVE-2014-4655]
(commit fd9f26e4eca5d08a27d12c0933fceef76ed9663d upstream)
A control that is visible on the card->controls list can be freed at any time.
This means we must not access any of its memory while not holding the
controls_rw_lock. Otherwise we risk a use after free access.
[wt: fixes CVE-2014-4653]
(commit 3cf521f7dc87c031617fd47e4b7aa2593c2f3daf upstream)
The l2tp [get|set]sockopt() code has fallen back to the UDP functions
for socket option levels != SOL_PPPOL2TP since day one, but that has
never actually worked, since the l2tp socket isn't an inet socket.
As David Miller points out:
"If we wanted this to work, it'd have to look up the tunnel and then
use tunnel->sk, but I wonder how useful that would be"
Since this can never have worked so nobody could possibly have depended
on that functionality, just remove the broken code and return -EINVAL.
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Acked-by: James Chapman <jchapman@katalix.com>
Acked-by: David Miller <davem@davemloft.net>
Cc: Phil Turnbull <phil.turnbull@oracle.com>
Cc: Vegard Nossum <vegard.nossum@oracle.com>
Cc: Willy Tarreau <w@1wt.eu>
[geissert: adjust file paths and context for 2.6.32]
[wt: fixes CVE-2014-4943]
It's possible for iretq to userspace to fail. This can happen because
of a bad CS, SS, or RIP.
Historically, we've handled it by fixing up an exception from iretq to
land at bad_iret, which pretends that the failed iret frame was really
the hardware part of #GP(0) from userspace. To make this work, there's
an extra fixup to fudge the gs base into a usable state.
This is suboptimal because it loses the original exception. It's also
buggy because there's no guarantee that we were on the kernel stack to
begin with. For example, if the failing iret happened on return from an
NMI, then we'll end up executing general_protection on the NMI stack.
This is bad for several reasons, the most immediate of which is that
general_protection, as a non-paranoid idtentry, will try to deliver
signals and/or schedule from the wrong stack.
This patch throws out bad_iret entirely. As a replacement, it augments
the existing swapgs fudge into a full-blown iret fixup, mostly written
in C. It's should be clearer and more correct.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
(cherry picked from commit b645af2d5905c4e32399005b867987919cbfc3ae)
[wt: notes for backport to 2.6.32:
- _ASM_EXTABLE was open-coded.
- removed unneeded CFI_ENDPROC
- removed __visible (introduced in 2.6.37-rc1, not needed here)
/wt]
There's nothing special enough about the espfix64 double fault fixup to
justify writing it in assembly. Move it to C.
This also fixes a bug: if the double fault came from an IST stack, the
old asm code would return to a partially uninitialized stack frame.
Fixes: 3891a04aafd668686239349ea58f3314ea2af86b
(cherry picked from commit af726f21ed8af2cdaa4e93098dc211521218ae65)
[wt: backport notes for 2.6.32 :
- Adaptations to entry_64.S in declaration of do_double_fault.
- no exception_enter() in 2.6.32. Seems to be only for context tracking.
/wt]
On a 32-bit kernel, this has no effect, since there are no IST stacks.
On a 64-bit kernel, #SS can only happen in user code, on a failed iret
to user space, a canonical violation on access via RSP or RBP, or a
genuine stack segment violation in 32-bit kernel code. The first two
cases don't need IST, and the latter two cases are unlikely fatal bugs,
and promoting them to double faults would be fine.
This fixes a bug in which the espfix64 code mishandles a stack segment
violation.
This saves 4k of memory per CPU and a tiny bit of code.
(cherry picked from commit 6f442be2fb22be02cafa606f1769fa1e6f894441)
[wt: no CONFIG_TRACING on 2.6.32, Fixes CVE-2014-9090]
commit 8762e5092828c4dc0f49da5a47a644c670df77f3 upstream.
init_espfix_ap() is currently off by one level when informing hypervisor
that allocated pages will be used for ministacks' page tables.
The most immediate effect of this on a PV guest is that if
'stack_page = __get_free_page()' returns a non-zeroed-out page the hypervisor
will refuse to use it for a page table (which it shouldn't be anyway). This will
result in warnings by both Xen and Linux.
More importantly, a subsequent write to that page (again, by a PV guest) is
likely to result in fatal page fault.
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Link: http://lkml.kernel.org/r/1404926298-5565-1-git-send-email-boris.ostrovsky@oracle.com
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
(cherry picked from 3.2 commit 060e7f67c88ebbcf8745505c7ccf44c53601f7de)
commit 7209a75d2009dbf7745e2fd354abf25c3deb3ca3 upstream.
This moves the espfix64 logic into native_iret. To make this work,
it gets rid of the native patch for INTERRUPT_RETURN:
INTERRUPT_RETURN on native kernels is now 'jmp native_iret'.
This changes the 16-bit SS behavior on Xen from OOPSing to leaking
some bits of the Xen hypervisor's RSP (I think).
[ hpa: this is a nonzero cost on native, but probably not enough to
measure. Xen needs to fix this in their own code, probably doing
something equivalent to espfix64. ]
Link: http://lkml.kernel.org/r/7b8f1d8ef6597cb16ae004a43c56980a7de3cf94.1406129132.git.luto@amacapital.net
(cherry picked from 3.2 commit 8ba19cd8c351e16b6be4caca9338d19b0cb8eaa4)
commit 34273f41d57ee8d854dcd2a1d754cbb546cb548f upstream.
Embedded systems, which may be very memory-size-sensitive, are
extremely unlikely to ever encounter any 16-bit software, so make it
a CONFIG_EXPERT option to turn off support for any 16-bit software
whatsoever.
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Link: http://lkml.kernel.org/r/1398816946-3351-1-git-send-email-hpa@linux.intel.com
(cherry picked from 3.2 commit 70d87cbbd92a3611655b39003176ee1033796bf7)
- Fixed arch/x86/kernel/ldt.c (no IS_ENABLED on 2.6.32).
- No CONFIG_EXPERT condition in 2.6.32.
/wt]
commit 197725de65477bc8509b41388157c1a2283542bb upstream.
Make espfix64 a hidden Kconfig option. This fixes the x86-64 UML
build which had broken due to the non-existence of init_espfix_bsp()
in UML: since UML uses its own Kconfig, this option does not appear in
the UML build.
This also makes it possible to make support for 16-bit segments a
configuration option, for the people who want to minimize the size of
the kernel.
Reported-by: Ingo Molnar <mingo@kernel.org>
Cc: Richard Weinberger <richard@nod.at>
(cherry picked from 3.2 commit da22646d97b7322c757f3a7a21805a3475fed231)
commit 20b68535cd27183ebd3651ff313afb2b97dac941 upstream.
Header guard is #ifndef, not #ifdef...
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
(cherry picked from 3.2 commit 7d4a9eabfe6c7fed70941aceb3b20bf393652bcb)
commit e1fe9ed8d2a4937510d0d60e20705035c2609aea upstream.
Sparse warns that the percpu variables aren't declared before they are
defined. Rather than hacking around it, move espfix definitions into
a proper header file.
(cherry picked from 3.2 commit 62358ee6bb9d3d9dd4761d39ac0e1ede9ba70b0e)
[wt: using DECLARE_PER_CPU instead of DECLARE_PER_CPU_READ_MOSTLY]
commit 3891a04aafd668686239349ea58f3314ea2af86b upstream.
The IRET instruction, when returning to a 16-bit segment, only
restores the bottom 16 bits of the user space stack pointer. This
causes some 16-bit software to break, but it also leaks kernel state
to user space. We have a software workaround for that ("espfix") for
the 32-bit kernel, but it relies on a nonzero stack segment base which
is not available in 64-bit mode.
In checkin:
b3b42ac2cbae x86-64, modify_ldt: Ban 16-bit segments on 64-bit kernels
we "solved" this by forbidding 16-bit segments on 64-bit kernels, with
the logic that 16-bit support is crippled on 64-bit kernels anyway (no
V86 support), but it turns out that people are doing stuff like
running old Win16 binaries under Wine and expect it to work.
This works around this by creating percpu "ministacks", each of which
is mapped 2^16 times 64K apart. When we detect that the return SS is
on the LDT, we copy the IRET frame to the ministack and use the
relevant alias to return to userspace. The ministacks are mapped
readonly, so if IRET faults we promote #GP to #DF which is an IST
vector and thus has its own stack; we then do the fixup in the #DF
handler.
(Making #GP an IST exception would make the msr_safe functions unsafe
in NMI/MC context, and quite possibly have other effects.)
Special thanks to:
- Andy Lutomirski, for the suggestion of using very small stack slots
and copy (as opposed to map) the IRET frame there, and for the
suggestion to mark them readonly and let the fault promote to #DF.
- Konrad Wilk for paravirt fixup and testing.
- Borislav Petkov for testing help and useful comments.
Reported-by: Brian Gerst <brgerst@gmail.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Andrew Lutomriski <amluto@gmail.com>
Cc: Dirk Hohndel <dirk@hohndel.org>
Cc: Arjan van de Ven <arjan.van.de.ven@intel.com>
Cc: comex <comexk@gmail.com>
Cc: Alexander van Heukelum <heukelum@fastmail.fm>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
(cherry picked from 3.2 commit e7836514086d53e0ffaee18d67d85d9477ecdb12)
[wt: backport notes for 2.6.32 differences :
- use DECLARE_PER_CPU instead of DECLARE_PER_CPU_READ_MOSTLY
- replace this_cpu_read(foo) with per_cpu(foo, smp_processor_id())
- replace this_cpu_write(foo,bar) with per_cpu(foo,smp_processor_id())=bar
/wt]
commit 246f2d2ee1d715e1077fc47d61c394569c8ee692 upstream.
It is not safe to use LAR to filter when to go down the espfix path,
because the LDT is per-process (rather than per-thread) and another
thread might change the descriptors behind our back. Fortunately it
is always *safe* (if a bit slow) to go down the espfix path, and a
32-bit LDT stack segment is extremely rare.
(cherry picked from 3.2 commit 6806fa8b6795aba9be8742a8f598f60eed26f875)
commit b3b42ac2cbae1f3cecbb6229964a4d48af31d382 upstream.
restores the bottom 16 bits of the user space stack pointer. We have
a software workaround for that ("espfix") for the 32-bit kernel, but
it relies on a nonzero stack segment base which is not available in
32-bit mode.
Since 16-bit support is somewhat crippled anyway on a 64-bit kernel
(no V86 mode), and most (if not quite all) 64-bit processors support
virtualization for the users who really need it, simply reject
attempts at creating a 16-bit segment when running on top of a 64-bit
kernel.
Link: http://lkml.kernel.org/n/tip-kicdm89kzw9lldryb1br9od0@git.kernel.org
(cherry picked from 3.2 commit a862b5c4076b1ba4dd6c87aebac478853dc6db47)
As this isn't an exception or interrupt entry point, it doesn't
have any of the hardware provide frame layouts active.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Acked-by: Alexander van Heukelum <heukelum@fastmail.fm>
LKML-Reference: <4C7FBAA80200007800013F67@vpn.id2.novell.com>
(cherry picked from commit 1f130a783a796f147b080c594488b566c86007d0)
[WT: only merged to minimize changes from mainline in entry_64.S]
Move the handling of truncated %rip from an iret fault to the fault
entry path.
This allows x86-64 to use the standard search_extable() function.
Signed-off-by: Brian Gerst <brgerst@gmail.com>
Cc: Jan Beulich <jbeulich@novell.com>
LKML-Reference: <1255357103-5418-1-git-send-email-brgerst@gmail.com>
(cherry picked from commit ae24ffe5ecec17c956ac25371d7c2e12b4b36e53)
[wt: only merged to fix patch context and ease merging of next patches]
Luis Henriques reported that while backporting commit 40eea80 ("net:
sendmsg: fix NULL pointer dereference") and applying the diff by hand,
I made a typo resulting in the same test being done twice, and msg_name
not being tested.
This fixes cf90357 ("net: sendmsg: fix NULL pointer dereference")
which was merged into 2.6.32.64.
Cc: Andrey Ryabinin <a.ryabinin@samsung.com>
Cc: Luis Henriques <luis.henriques@canonical.com>
2.6.x kernels require a similar logic change as commit 2c0d6ac894a
[sctp: not send SCTP_PEER_ADDR_CHANGE notifications with failed probe]
introduces for newer kernels.
Since the transport has always been in state SCTP_UNCONFIRMED, it
therefore wasn't active before and hasn't been used before, and it
always has been, so it is unnecessary to bug the user with a
notification.
Reported-by: Deepak Khandelwal <khandelwal.deepak.1987@gmail.com>
Suggested-by: Vlad Yasevich <vyasevich@gmail.com>
Suggested-by: Michael Tuexen <tuexen@fh-muenster.de>
Suggested-by: Daniel Borkmann <dborkman@redhat.com>
Signed-off-by: Zhu Yanjun <Yanjun.Zhu@windriver.com>
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
Acked-by: Daniel Borkmann <dborkman@redhat.com>
We did not check relocated directory in any way when processing Rock
Ridge 'CL' tag. Thus a corrupted isofs image can possibly have a CL
entry pointing to another CL entry leading to possibly unbounded
recursion in kernel code and thus stack overflow or deadlocks (if there
is a loop created from CL entries).
Fix the problem by not allowing CL entry to point to a directory entry
with CL entry (such use makes no good sense anyway) and by checking
whether CL entry doesn't point to itself.
CC: stable@vger.kernel.org
Reported-by: Chris Evans <cevans@google.com>
(cherry picked from commit 410dd3cf4c9b36f27ed4542ee18b1af5e68645a4)
futex_wait_requeue_pi() calls futex_wait_setup(). If
futex_wait_setup() succeeds it returns with hb->lock held and
preemption disabled. Now the sanity check after this does:
if (match_futex(&q.key, &key2)) {
ret = -EINVAL;
goto out_put_keys;
which releases the keys but does not release hb->lock.
So we happily return to user space with hb->lock held and therefor
Unlock hb->lock before taking the exit route.
Reported-by: Dave "Trinity" Jones <davej@redhat.com>
Reviewed-by: Darren Hart <dvhart@linux.intel.com>
Reviewed-by: Davidlohr Bueso <dave@stgolabs.net>
Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1409112318500.4178@nanos
(cherry picked from commit 13c42c2f43b19aab3195f2d357db00d1e885eaa8)
[wt: 2.6.32 needs &q as first argument of queue_unlock()]
As ZTE have and will use more pid for new products this year,
so we need to add some new zte 3g-dongle's pid on option.c ,
and delete one pid 0x0154 because it use for mass-storage port.
Signed-off-by: Rui li <li.rui27@zte.com.cn>
(cherry picked from commit 1608ea5f4b5d6262cd6e808839491cfb2a67405a)
This fix ensures that we never meet an integer overflow while adding
255 while parsing a variable length encoding. It works differently from
commit 206a81c ("lzo: properly check for overruns") because instead of
ensuring that we don't overrun the input, which is tricky to guarantee
due to many assumptions in the code, it simply checks that the cumulated
number of 255 read cannot overflow by bounding this number.
The MAX_255_COUNT is the maximum number of times we can add 255 to a base
count without overflowing an integer. The multiply will overflow when
multiplying 255 by more than MAXINT/255. The sum will overflow earlier
depending on the base count. Since the base count is taken from a u8
and a few bits, it is safe to assume that it will always be lower than
or equal to 2*255, thus we can always prevent any overflow by accepting
two less 255 steps.
This patch also reduces the CPU overhead and actually increases performance
by 1.1% compared to the initial code, while the previous fix costs 3.1%
(measured on x86_64).
The fix needs to be backported to all currently supported stable kernels.
Reported-by: Willem Pinckaers <willem@lekkertech.net>
Cc: "Don A. Bailey" <donb@securitymouse.com>
(cherry picked from commit 72cf90124e87d975d0b2114d930808c58b4c05e4)
Add a complete description of the LZO format as processed by the
decompressor. I have not found a public specification of this format
hence this analysis, which will be used to better understand the code.
Cc: Willem Pinckaers <willem@lekkertech.net>
(cherry picked from commit d98a0526434d27e261f622cf9d2e0028b5ff1a00)
This commit updates the kernel LZO code to the current upsteam version
which features a significant speed improvement - benchmarking the Calgary
and Silesia test corpora typically shows a doubled performance in
both compression and decompression on modern i386/x86_64/powerpc machines.
Signed-off-by: Markus F.X.J. Oberhumer <markus@oberhumer.com>
(cherry picked from commit 8b975bd3f9089f8ee5d7bbfd798537b992bbc7e7)
[wt: this update was only needed to apply the following security fixes]
Commit 455bd4c430b0 ("ARM: 7668/1: fix memset-related crashes caused by
recent GCC (4.7.2) optimizations") attempted to fix a compliance issue
with the memset return value. However the memset itself became broken
by that patch for misaligned pointers.
This fixes the above by branching over the entry code from the
misaligned fixup code to avoid reloading the original pointer.
Also, because the function entry alignment is wrong in the Thumb mode
compilation, that fixup code is moved to the end.
While at it, the entry instructions are slightly reworked to help dual
issue pipelines.
Signed-off-by: Nicolas Pitre <nico@linaro.org>
Tested-by: Alexander Holler <holler@ahsoftware.de>
(cherry picked from commit 418df63adac56841ef6b0f1fcf435bc64d4ed177)
optimizations
Recent GCC versions (e.g. GCC-4.7.2) perform optimizations based on
assumptions about the implementation of memset and similar functions.
The current ARM optimized memset code does not return the value of
its first argument, as is usually expected from standard implementations.
For instance in the following function:
void debug_mutex_lock_common(struct mutex *lock, struct mutex_waiter *waiter)
memset(waiter, MUTEX_DEBUG_INIT, sizeof(*waiter));
waiter->magic = waiter;
INIT_LIST_HEAD(&waiter->list);
compiled as:
800554d0 <debug_mutex_lock_common>:
800554d0: e92d4008 push {r3, lr}
800554d4: e1a00001 mov r0, r1
800554d8: e3a02010 mov r2, #16 ; 0x10
800554dc: e3a01011 mov r1, #17 ; 0x11
800554e0: eb04426e bl 80165ea0 <memset>
800554e4: e1a03000 mov r3, r0
800554e8: e583000c str r0, [r3, #12]
800554ec: e5830000 str r0, [r3]
800554f0: e5830004 str r0, [r3, #4]
800554f4: e8bd8008 pop {r3, pc}
GCC assumes memset returns the value of pointer 'waiter' in register r0; causing
register/memory corruptions.
This patch fixes the return value of the assembly version of memset.
It adds a 'mov' instruction and merges an additional load+store into
existing load/store instructions.
For ease of review, here is a breakdown of the patch into 4 simple steps:
Step 1
Perform the following substitutions:
ip -> r8, then
r0 -> ip,
and insert 'mov ip, r0' as the first statement of the function.
At this point, we have a memset() implementation returning the proper result,
but corrupting r8 on some paths (the ones that were using ip).
Step 2
Make sure r8 is saved and restored when (! CALGN(1)+0) == 1:
save r8:
- str lr, [sp, #-4]!
+ stmfd sp!, {r8, lr}
and restore r8 on both exit paths:
- ldmeqfd sp!, {pc} @ Now <64 bytes to go.
+ ldmeqfd sp!, {r8, pc} @ Now <64 bytes to go.
tst r2, #16
stmneia ip!, {r1, r3, r8, lr}
- ldr lr, [sp], #4
+ ldmfd sp!, {r8, lr}
Step 3
Make sure r8 is saved and restored when (! CALGN(1)+0) == 0:
save r8:
- stmfd sp!, {r4-r7, lr}
+ stmfd sp!, {r4-r8, lr}
bgt 3b
- ldmeqfd sp!, {r4-r7, pc}
+ ldmeqfd sp!, {r4-r8, pc}
tst r2, #16
stmneia ip!, {r4-r7}
- ldmfd sp!, {r4-r7, lr}
+ ldmfd sp!, {r4-r8, lr}
Step 4
Rewrite register list "r4-r7, r8" as "r4-r8".
Signed-off-by: Ivan Djelic <ivan.djelic@parrot.com>
Reviewed-by: Nicolas Pitre <nico@linaro.org>
Signed-off-by: Dirk Behme <dirk.behme@gmail.com>
(cherry picked from commit 455bd4c430b0c0a361f38e8658a0d6cb469942b5)
The PPP channel MTU is used with Multilink PPP when ppp_mp_explode() (see
ppp_generic module) tries to determine how big a fragment might be. According
to RFC 1661, the MTU excludes the 2-byte PPP protocol field, see the
corresponding comment and code in ppp_mp_explode():
* hdrlen includes the 2-byte PPP protocol field, but the
* MTU counts only the payload excluding the protocol field.
* (RFC1661 Section 2)
mtu = pch->chan->mtu - (hdrlen - 2);
However, the pppoe module *does* include the PPP protocol field in the channel
MTU, which is wrong as it causes the PPP payload to be 1-2 bytes too big under
certain circumstances (one byte if PPP protocol compression is used, two
otherwise), causing the generated Ethernet packets to be dropped. So the pppoe
module has to subtract two bytes from the channel MTU. This error only
manifests itself when using Multilink PPP, as otherwise the channel MTU is not
used anywhere.
In the following, I will describe how to reproduce this bug. We configure two
pppd instances for multilink PPP over two PPPoE links, say eth2 and eth3, with
a MTU of 1492 bytes for each link and a MRRU of 2976 bytes. (This MRRU is
computed by adding the two link MTUs and subtracting the MP header twice, which
is 4 bytes long.) The necessary pppd statements on both sides are "multilink
mtu 1492 mru 1492 mrru 2976". On the client side, we additionally need "plugin
rp-pppoe.so eth2" and "plugin rp-pppoe.so eth3", respectively; on the server
side, we additionally need to start two pppoe-server instances to be able to
establish two PPPoE sessions, one over eth2 and one over eth3. We set the MTU
of the PPP network interface to the MRRU (2976) on both sides of the connection
in order to make use of the higher bandwidth. (If we didn't do that, IP
fragmentation would kick in, which we want to avoid.)
Now we send a ICMPv4 echo request with a payload of 2948 bytes from client to
server over the PPP link. This results in the following network packet:
2948 (echo payload)
+ 8 (ICMPv4 header)
+ 20 (IPv4 header)
2976 (PPP payload)
These 2976 bytes do not exceed the MTU of the PPP network interface, so the
IP packet is not fragmented. Now the multilink PPP code in ppp_mp_explode()
prepends one protocol byte (0x21 for IPv4), making the packet one byte bigger
than the negotiated MRRU. So this packet would have to be divided in three
fragments. But this does not happen as each link MTU is assumed to be two bytes
larger. So this packet is diveded into two fragments only, one of size 1489 and
one of size 1488. Now we have for that bigger fragment:
1489 (PPP payload)
+ 4 (MP header)
+ 2 (PPP protocol field for the MP payload (0x3d))
+ 6 (PPPoE header)
1501 (Ethernet payload)
This packet exceeds the link MTU and is discarded.
If one configures the link MTU on the client side to 1501, one can see the
discarded Ethernet frames with tcpdump running on the client. A
ping -s 2948 -c 1 192.168.15.254
leads to the smaller fragment that is correctly received on the server side:
(tcpdump -vvvne -i eth3 pppoes and ppp proto 0x3d)
52:54:00:ad:87:fd > 52:54:00:79:5c:d0, ethertype PPPoE S (0x8864),
length 1514: PPPoE [ses 0x3] MLPPP (0x003d), length 1494: seq 0x000,
Flags [end], length 1492
and to the bigger fragment that is not received on the server side:
(tcpdump -vvvne -i eth2 pppoes and ppp proto 0x3d)
52:54:00:70:9e:89 > 52:54:00:5d:6f:b0, ethertype PPPoE S (0x8864),
length 1515: PPPoE [ses 0x5] MLPPP (0x003d), length 1495: seq 0x000,
Flags [begin], length 1493
With the patch below, we correctly obtain three fragments:
length 1514: PPPoE [ses 0x1] MLPPP (0x003d), length 1494: seq 0x000,
Flags [begin], length 1492
Flags [none], length 1492
length 27: PPPoE [ses 0x1] MLPPP (0x003d), length 7: seq 0x000,
Flags [end], length 5
And the ICMPv4 echo request is successfully received at the server side:
IP (tos 0x0, ttl 64, id 21925, offset 0, flags [DF], proto ICMP (1),
length 2976)
192.168.222.2 > 192.168.15.254: ICMP echo request, id 30530, seq 0,
length 2956
The bug was introduced in commit c9aa6895371b2a257401f59d3393c9f7ac5a8698
("[PPPOE]: Advertise PPPoE MTU") from the very beginning. This patch applies
to 3.10 upwards but the fix can be applied (with minor modifications) to
kernels as old as 2.6.32.
Signed-off-by: Christoph Schulz <develop@kristov.de>
(cherry picked from commit a8a3e41c67d24eb12f9ab9680cbb85e24fcd9711)
During recovery of a double-degraded RAID6 it is possible for
some blocks not to be recovered properly, leading to corruption.
If a write happens to one block in a stripe that would be written to a
missing device, and at the same time that stripe is recovering data
to the other missing device, then that recovered data may not be written.
This patch skips, in the double-degraded case, an optimisation that is
only safe for single-degraded arrays.
Bug was introduced in 2.6.32 and fix is suitable for any kernel since
then. In an older kernel with separate handle_stripe5() and
handle_stripe6() functions the patch must change handle_stripe6().
Cc: stable@vger.kernel.org (2.6.32+)
Fixes: 6c0069c0ae9659e3a91b68eaed06a5c6c37f45c8
Cc: Yuri Tikhonov <yur@emcraft.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Reported-by: "Manibalan P" <pmanibalan@amiindia.co.in>
Tested-by: "Manibalan P" <pmanibalan@amiindia.co.in>
Resolves: https://bugzilla.redhat.com/show_bug.cgi?id=1090423
Signed-off-by: NeilBrown <neilb@suse.de>
Acked-by: Dan Williams <dan.j.williams@intel.com>
(cherry picked from commit 9c4bdf697c39805078392d5ddbbba5ae5680e0dd)
When performing a consuming read, the ring buffer swaps out a
page from the ring buffer with a empty page and this page that
was swapped out becomes the new reader page. The reader page
is owned by the reader and since it was swapped out of the ring
buffer, writers do not have access to it (there's an exception
to that rule, but it's out of scope for this commit).
When reading the "trace" file, it is a non consuming read, which
means that the data in the ring buffer will not be modified.
When the trace file is opened, a ring buffer iterator is allocated
and writes to the ring buffer are disabled, such that the iterator
will not have issues iterating over the data.
Although the ring buffer disabled writes, it does not disable other
reads, or even consuming reads. If a consuming read happens, then
the iterator is reset and starts reading from the beginning again.
My tests would sometimes trigger this bug on my i386 box:
WARNING: CPU: 0 PID: 5175 at kernel/trace/trace.c:1527 __trace_find_cmdline+0x66/0xaa()
Modules linked in:
CPU: 0 PID: 5175 Comm: grep Not tainted 3.16.0-rc3-test+ #8
Hardware name: /DG965MQ, BIOS MQ96510J.86A.0372.2006.0605.1717 06/05/2006
00000000 00000000 f09c9e1c c18796b3 c1b5d74c f09c9e4c c103a0e3 c1b5154b
f09c9e78 00001437 c1b5d74c 000005f7 c10bd85a c10bd85a c1cac57c f09c9eb0
ed0e0000 f09c9e64 c103a185 00000009 f09c9e5c c1b5154b f09c9e78 f09c9e80^M
Call Trace:
[<c18796b3>] dump_stack+0x4b/0x75
[<c103a0e3>] warn_slowpath_common+0x7e/0x95
[<c10bd85a>] ? __trace_find_cmdline+0x66/0xaa
[<c103a185>] warn_slowpath_fmt+0x33/0x35
[<c10bd85a>] __trace_find_cmdline+0x66/0xaa^M
[<c10bed04>] trace_find_cmdline+0x40/0x64
[<c10c3c16>] trace_print_context+0x27/0xec
[<c10c4360>] ? trace_seq_printf+0x37/0x5b
[<c10c0b15>] print_trace_line+0x319/0x39b
[<c10ba3fb>] ? ring_buffer_read+0x47/0x50
[<c10c13b1>] s_show+0x192/0x1ab
[<c10bfd9a>] ? s_next+0x5a/0x7c
[<c112e76e>] seq_read+0x267/0x34c
[<c1115a25>] vfs_read+0x8c/0xef
[<c112e507>] ? seq_lseek+0x154/0x154
[<c1115ba2>] SyS_read+0x54/0x7f
[<c188488e>] syscall_call+0x7/0xb
---[ end trace 3f507febd6b4cc83 ]---
>>>> ##### CPU 1 buffer started ####
Which was the __trace_find_cmdline() function complaining about the pid
in the event record being negative.
After adding more test cases, this would trigger more often. Strangely
enough, it would never trigger on a single test, but instead would trigger
only when running all the tests. I believe that was the case because it
required one of the tests to be shutting down via delayed instances while
a new test started up.
After spending several days debugging this, I found that it was caused by
the iterator becoming corrupted. Debugging further, I found out why
the iterator became corrupted. It happened with the rb_iter_reset().
As consuming reads may not read the full reader page, and only part
of it, there's a "read" field to know where the last read took place.
The iterator, must also start at the read position. In the rb_iter_reset()
code, if the reader page was disconnected from the ring buffer, the iterator
would start at the head page within the ring buffer (where writes still
happen). But the mistake there was that it still used the "read" field
to start the iterator on the head page, where it should always start
at zero because readers never read from within the ring buffer where
writes occur.
I originally wrote a patch to have it set the iter->head to 0 instead
of iter->head_page->read, but then I questioned why it wasn't always
setting the iter to point to the reader page, as the reader page is
still valid. The list_empty(reader_page->list) just means that it was
successful in swapping out. But the reader_page may still have data.
There was a bug report a long time ago that was not reproducible that
had something about trace_pipe (consuming read) not matching trace
(iterator read). This may explain why that happened.
Anyway, the correct answer to this bug is to always use the reader page
an not reset the iterator to inside the writable ring buffer.
Fixes: d769041f8653 "ring_buffer: implement new locking"
(cherry picked from commit 651e22f2701b4113989237c3048d17337dd2185c)
[wt: 2.6.32 has no cache{,_read} member in struct ring_buffer_iter ]
don't try to queue payloads > 0xffff - NLA_HDRLEN, it does not work.
The nla length includes the size of the nla struct, so anything larger
results in u16 integer overflow.
This patch is similar to
9cefbbc9c8f9abe (netfilter: nfnetlink_queue: cleanup copy_range usage).
(cherry picked from commit c1e7dc91eed0ed1a51c9b814d648db18bf8fc6e9)
We currently neither account for the nlattr size, nor do we consider
the size of the trailing NLMSG_DONE when allocating nlmsg skb.
This can result in nflog to stop working, as __nfulnl_send() re-tries
sending forever if it failed to append NLMSG_DONE (which will never
work if buffer is not large enough).
Reported-by: Houcheng Lin <houcheng@gmail.com>
(cherry picked from commit 9dfa1dfe4d5e5e66a991321ab08afe69759d797a)
Kernel oops can cause the tty to be unreleaseable (for example, if
n_tty_read() crashes while on the read_wait queue). This will cause
tty_release() to endlessly loop without sleeping.
Use a killable sleep timeout which grows by 2n+1 jiffies over the interval
[0, 120 secs.) and then jumps to forever (but still killable).
NB: killable just allows for the task to be rewoken manually, not
to be terminated.
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
(cherry picked from commit 37b164578826406a173ca7c20d9ba7430134d23e)
Commit 6f4c618ddb0 ("SCTP : Add paramters validity check for
ASCONF chunk") added basic verification of ASCONF chunks, however,
it is still possible to remotely crash a server by sending a
special crafted ASCONF chunk, even up to pre 2.6.12 kernels:
skb_over_panic: text:ffffffffa01ea1c3 len:31056 put:30768
head:ffff88011bd81800 data:ffff88011bd81800 tail:0x7950
end:0x440 dev:<NULL>
kernel BUG at net/core/skbuff.c:129!
Call Trace:
<IRQ>
[<ffffffff8144fb1c>] skb_put+0x5c/0x70
[<ffffffffa01ea1c3>] sctp_addto_chunk+0x63/0xd0 [sctp]
[<ffffffffa01eadaf>] sctp_process_asconf+0x1af/0x540 [sctp]
[<ffffffff8152d025>] ? _read_unlock_bh+0x15/0x20
[<ffffffffa01e0038>] sctp_sf_do_asconf+0x168/0x240 [sctp]
[<ffffffff8147645d>] ? fib_rules_lookup+0xad/0xf0
[<ffffffffa01e6b22>] ? sctp_cmp_addr_exact+0x32/0x40 [sctp]
[<ffffffffa01e8393>] sctp_assoc_bh_rcv+0xd3/0x180 [sctp]
[<ffffffff81496ded>] ip_local_deliver_finish+0xdd/0x2d0
[<ffffffff81497078>] ip_local_deliver+0x98/0xa0
[<ffffffff8149653d>] ip_rcv_finish+0x12d/0x440
[<ffffffff81496ac5>] ip_rcv+0x275/0x350
[<ffffffff8145c88b>] __netif_receive_skb+0x4ab/0x750
[<ffffffff81460588>] netif_receive_skb+0x58/0x60
This can be triggered e.g., through a simple scripted nmap
connection scan injecting the chunk after the handshake, for
example, ...
------------------ ASCONF; UNKNOWN ------------------>
... where ASCONF chunk of length 280 contains 2 parameters ...
1) Add IP address parameter (param length: 16)
2) Add/del IP address parameter (param length: 255)
... followed by an UNKNOWN chunk of e.g. 4 bytes. Here, the
Address Parameter in the ASCONF chunk is even missing, too.
This is just an example and similarly-crafted ASCONF chunks
could be used just as well.
The ASCONF chunk passes through sctp_verify_asconf() as all
parameters passed sanity checks, and after walking, we ended
up successfully at the chunk end boundary, and thus may invoke
sctp_process_asconf(). Parameter walking is done with
WORD_ROUND() to take padding into account.
In sctp_process_asconf()'s TLV processing, we may fail in
sctp_process_asconf_param() e.g., due to removal of the IP
address that is also the source address of the packet containing
the ASCONF chunk, and thus we need to add all TLVs after the
failure to our ASCONF response to remote via helper function
sctp_add_asconf_response(), which basically invokes a
sctp_addto_chunk() adding the error parameters to the given
skb.
When walking to the next parameter this time, we proceed
with ...
length = ntohs(asconf_param->param_hdr.length);
asconf_param = (void *)asconf_param + length;
... instead of the WORD_ROUND()'ed length, thus resulting here
in an off-by-one that leads to reading the follow-up garbage
parameter length of 12336, and thus throwing an skb_over_panic
for the reply when trying to sctp_addto_chunk() next time,
which implicitly calls the skb_put() with that length.
Fix it by using sctp_walk_params() [ which is also used in
INIT parameter processing ] macro in the verification *and*
in ASCONF processing: it will make sure we don't spill over,
that we walk parameters WORD_ROUND()'ed. Moreover, we're being
more defensive and guard against unknown parameter types and
missized addresses.
Fixes: b896b82be4ae ("[SCTP] ADDIP: Support for processing incoming ASCONF_ACK chunks.")
(cherry picked from commit 9de7922bc709eee2f609cd01d98aaedc4cf5ea74)
