commit c055f5b2614b4f758ae6cc86733f31fa4c2c5844 upstream.
The recent commit closing the race window in device teardown:
commit 86cbfb5607d4b81b1a993ff689bbd2addd5d3a9b
Author: James Bottomley <James.Bottomley@suse.de>
Date: Fri Apr 22 10:39:59 2011 -0500
[SCSI] put stricter guards on queue dead checks
is causing a potential NULL deref in scsi_run_queue() because the
q->queuedata may already be NULL by the time this function is called.
Since we shouldn't be running a queue that is being torn down, simply
add a NULL check in scsi_run_queue() to forestall this.
Tested-by: Jim Schutt <jaschut@sandia.gov>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
commit 10022a6c66e199d8f61d9044543f38785713cbbd upstream.
v2: added space after 'if' according code style.
We can get here with a NULL socket argument passed from userspace,
so we need to handle it accordingly.
Thanks to Dave Jones pointing at this issue in net/can/bcm.c
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
Cc: Chuck Ebbert <cebbert@redhat.com>
(backported from commit 28e4639adf0c9f26f6bb56149b7ab547bf33bb95)
If preempted after kvmclock values are updated, but before hardware
virtualization is entered, the last tsc time as read by the guest is
never set. It underflows the next time kvmclock is updated if there
has not yet been a successful entry / exit into hardware virt.
Fix this by simply setting last_tsc to the newly read tsc value so
that any computed nsec advance of kvmclock is nulled.
Signed-off-by: Zachary Amsden <zamsden@redhat.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
BugLink: http://bugs.launchpad.net/bugs/714335
Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com>
Reviewed-by: Stefan Bader <stefan.bader@canonical.com>
(backported from commit 1d5f066e0b63271b67eac6d3752f8aa96adcbddb)
Kernel time, which advances in discrete steps may progress much slower
than TSC. As a result, when kvmclock is adjusted to a new base, the
apparent time to the guest, which runs at a much higher, nsec scaled
rate based on the current TSC, may have already been observed to have
a larger value (kernel_ns + scaled tsc) than the value to which we are
setting it (kernel_ns + 0).
We must instead compute the clock as potentially observed by the guest
for kernel_ns to make sure it does not go backwards.
(cherry-picked from commit 347bb4448c2155eb2310923ccaa4be5677649003)
The scale_delta function for shift / multiply with 31-bit
precision moves to a common header so it can be used by both
kernel and kvm module.
commit b25026981aecde3685dd0e45ad980fff9f528daa upstream.
Since
commit a120e912eb51e347f36c71b60a1d13af74d30e83
Author: Stanislaw Gruszka <sgruszka@redhat.com>
Date: Fri Feb 19 15:47:33 2010 -0800
iwlwifi: sanity check before counting number of tfds can be free
we use skb->data after calling ieee80211_tx_status_irqsafe(), which
could free skb instantly.
On current kernels I do not observe practical problems related with
bug, but on 2.6.35.y it cause random system hangs when stressing
wireless link.
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Acked-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
commit ec95d35a6bd0047f05fe8a21e6c52f8bb418da55 upstream.
MUSB is a non-standard host implementation which
can handle all speeds with the same core. We need
to set has_tt flag after commit
d199c96d41d80a567493e12b8e96ea056a1350c1 (USB: prevent
buggy hubs from crashing the USB stack) in order for
MUSB HCD to continue working.
Signed-off-by: Felipe Balbi <balbi@ti.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Tested-by: Michael Jones <michael.jones@matrix-vision.de>
Tested-by: Alexander Holler <holler@ahsoftware.de>
commit 729a6a300e628a48cf12bac93a964a535e83cd1d upstream.
ata_pio_sectors() expects buffer for each sector to be contained in a
single page; otherwise, it ends up overrunning the first page. This
is achieved by setting queue DMA alignment. If sector_size is smaller
than PAGE_SIZE and all buffers are sector_size aligned, buffer for
each sector is always contained in a single page.
This wasn't applied to ATAPI devices but IDENTIFY_PACKET is executed
as ATA_PROT_PIO and thus uses ata_pio_sectors(). Newer versions of
udev issue IDENTIFY_PACKET with unaligned buffer triggering the
problem and causing oops.
This patch fixes the problem by setting sdev->sector_size to
ATA_SECT_SIZE on ATATPI devices and always setting DMA alignment to
sector_size. While at it, add a warning for the unlikely but still
possible scenario where sector_size is larger than PAGE_SIZE, in which
case the alignment wouldn't be enough.
Reported-by: John Stanley <jpsinthemix@verizon.net>
Tested-by: John Stanley <jpsinthemix@verizon.net>
Signed-off-by: Jonathan Liu <net147@gmail.com>
commit e476a5a41ad67d0e2b4a652820c49a3923eb936b upstream.
Fix unbalanced call to sdio_release_host() on the error path.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
commit 46814e08d80f87449b5adb3d549a3cae6f9f8148 upstream.
My conversion of tehuti to use request_firmware() was confused about
the filename of the firmware blob. Change the driver to match the
blob.
Signed-off-by: Andy Gospodarek <andy@greyhouse.net>
commit a55ab496ea9c820b7192c15ef1fbf3291edfe638 upstream.
When writing a disc on certain lite-on dvd-writers (also rebadged
as optiarc/LG/...) connected to a vt6420, the ATAPI CDB ends
up in the datastream and on the disc, causing silent corruption.
Delaying between sending the CDB and starting DMA seems to
prevent this.
I do not know if there are burners that do not suffer from
this, but the patch should be safe for those as well.
There are many reports of this issue, but AFAICT no solution was
found before. For example:
http://lkml.indiana.edu/hypermail/linux/kernel/0802.3/0561.html
Signed-off-by: Bart Hartgers <bart.hartgers@gmail.com>
[bwh: Remove version bump for 2.6.32]
commit 75f64dd54a185150ebfc45e99351c890d4a2252f upstream.
HW crypto in rt2500usb does not seem to support keys with different ciphers,
which breaks TKIP+AES mode. Fall back to software encryption to fix it.
This should fix long-standing problems with rt2500usb and WPA, such as:
http://rt2x00.serialmonkey.com/phpBB/viewtopic.php?f=4&t=4834
https://bugzilla.redhat.com/show_bug.cgi?id=484888
Also tested that it does not break WEP, TKIP-only and AES-only modes.
Signed-off-by: Ondrej Zary <linux@rainbow-software.org>
Acked-by: Gertjan van Wingerde <gwingerde@gmail.com>
[bwh: Adjust context for 2.6.32]
commit 4d9ef89dee13e964ea8b064d82ff55cf36209237 upstream.
The dts-installed variable is initialised using a wildcard path that
will be expanded relative to the build directory. Use the existing
variable dtstree to generate an absolute wildcard path that will work
when building in a separate directory.
Reported-by: Gerhard Pircher <gerhard_pircher@gmx.net>
Tested-by: Gerhard Pircher <gerhard_pircher@gmx.net> [against 2.6.32]
[bwh: This is only applicable to 2.6.32. Phonet was fixed upstream to
work with multiple net namespaces.]
This should really fix the OOPS when doing:
unshare(CLONE_NEWNET);
exit(0);
while the phonet module is loaded.
Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com>
commit ee9c5cfad29c8a13199962614b9b16f1c4137ac9 upstream.
niu_get_ethtool_tcam_all() assumes that its output buffer is the right
size, and warns before returning if it is not. However, the output
buffer size is under user control and ETHTOOL_GRXCLSRLALL is an
unprivileged ethtool command. Therefore this is at least a local
denial-of-service vulnerability.
Change it to check before writing each entry and to return an error if
the buffer is already full.
Compile-tested only.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
[Adjusted to apply to 2.6.32 by dann frazier <dannf@debian.org>]
commit bb789d01620e5d36081b22edb6fb71cf55ff043c upstream.
scsi_dma_map() returns -1 if an error occurred (zero means that the
command has no data). So the following current code can't catch an
error:
sges_left = scsi_dma_map(scmd);
if (!sges_left) {
sdev_printk(KERN_ERR, scmd->device, "pci_map_sg"
" failed: request for %d bytes!\n", scsi_bufflen(scmd));
return -ENOMEM;
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Acked-by: "Kashyap Desai" <Kashyap.Desai@lsi.com>
commit 3b9c6c11f519718d618f5d7c9508daf78b207f6f upstream.
This only matters for ISA devices with a 24-bit DMA limit or for devices
with a 32-bit DMA limit on systems with ZONE_DMA32 enabled. The latter
currently only affects 32-bit PCI cards on Sibyte-based systems with more
than 1GB RAM installed.
commit c3259c8a7060d480e8eb2166da0a99d6879146b4 upstream.
This patch fixes UDP socket refcnt bugs in the pppol2tp driver.
A bug can cause a kernel stack trace when a tunnel socket is closed.
A way to reproduce the issue is to prepare the UDP socket for L2TP (by
opening a tunnel pppol2tp socket) and then close it before any L2TP
sessions are added to it. The sequence is
Create UDP socket
Create tunnel pppol2tp socket to prepare UDP socket for L2TP
pppol2tp_connect: session_id=0, peer_session_id=0
L2TP SCCRP control frame received (tunnel_id==0)
pppol2tp_recv_core: sock_hold()
pppol2tp_recv_core: sock_put
L2TP ZLB control frame received (tunnel_id=nnn)
Close tunnel management socket
pppol2tp_release: session_id=0, peer_session_id=0
Close UDP socket
udp_lib_close: BUG
The addition of sock_hold() in pppol2tp_connect() solves the problem.
For data frames, two sock_put() calls were added to plug a refcnt leak
per received data frame. The ref that is grabbed at the top of
pppol2tp_recv_core() must always be released, but this wasn't done for
accepted data frames or data frames discarded because of bad UDP
checksums. This leak meant that any UDP socket that had passed L2TP
data traffic (i.e. L2TP data frames, not just L2TP control frames)
using pppol2tp would not be released by the kernel.
WARNING: at include/net/sock.h:435 udp_lib_unhash+0x117/0x120()
Pid: 1086, comm: openl2tpd Not tainted 2.6.33-rc1 #8
Call Trace:
[<c119e9b7>] ? udp_lib_unhash+0x117/0x120
[<c101b871>] ? warn_slowpath_common+0x71/0xd0
[<c101b8e3>] ? warn_slowpath_null+0x13/0x20
[<c11598a7>] ? sk_common_release+0x17/0x90
[<c11a5e33>] ? inet_release+0x33/0x60
[<c11577b0>] ? sock_release+0x10/0x60
[<c115780f>] ? sock_close+0xf/0x30
[<c106e542>] ? __fput+0x52/0x150
[<c106b68e>] ? filp_close+0x3e/0x70
[<c101d2e2>] ? put_files_struct+0x62/0xb0
[<c101eaf7>] ? do_exit+0x5e7/0x650
[<c1081623>] ? mntput_no_expire+0x13/0x70
[<c101eb8a>] ? do_group_exit+0x2a/0x70
[<c101ebe1>] ? sys_exit_group+0x11/0x20
[<c10029b0>] ? sysenter_do_call+0x12/0x26
Signed-off-by: James Chapman <jchapman@katalix.com>
commit 2fdc1c8093255f9da877d7b9ce3f46c2098377dc upstream.
When a network namespace is created (via CLONE_NEWNET), the loopback
interface is automatically added to the new namespace, triggering a
printk in ipv6_add_dev() if CONFIG_IPV6_PRIVACY is set.
This is problematic for applications which use CLONE_NEWNET as
part of a sandbox, like Chromium's suid sandbox or recent versions of
vsftpd. On a busy machine, it can lead to thousands of useless
"lo: Disabled Privacy Extensions" messages appearing in dmesg.
It's easy enough to check the status of privacy extensions via the
use_tempaddr sysctl, so just removing the printk seems like the most
sensible solution.
Signed-off-by: Romain Francoise <romain@orebokech.com>
commit 25cca5352712561fba97bd37c495593d641c1d39 upstream.
This patch removes D-Link DGE-550T PCI ID (1186:4000) from the ipg
driver. The ipg driver is for IP2000-based cards and the DGE-550T is
a DL2000-based card. The driver loads and works for a few moments, but
once a real workload is applied it stops operating. The ipg driver
claimed this ID since it was introduced in 2.6.24 and it's forced many
users to blacklist it.
The correct driver for this hardware is the dl2k driver, which has been
claiming this PCI ID since the 2.4 days.
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
commit 2d9e667efdfb4e986074d98e7d9a424003c7c43b upstream.
Certain revisions of this chipset appear to be broken. There is a shadow
GTT which mirrors the real GTT but contains pre-translated physical
addresses, for performance reasons. When a GTT update happens, the
translations are done once and the resulting physical addresses written
back to the shadow GTT.
Except sometimes, the physical address is actually written back to the
_real_ GTT, not the shadow GTT. Thus we start to see faults when that
physical address is fed through translation again.
commit 99b9f758bbc904f22faffcf4d83205f4a5e7bc0c upstream.
This patch add support for the MacBookAir3,1 and MacBookAir3,2 to the hid
driver.
Signed-off-by: Edgar (gimli) Hucek <gimli@dark-green.com>
commit b30532515f0a62bfe17207ab00883dd262497006 upstream.
Recently reported oops:
kernel BUG at net/core/skbuff.c:813!
invalid opcode: 0000 [#1] SMP
last sysfs file: /sys/devices/virtual/net/bond0/broadcast
CPU 8
Modules linked in: sit tunnel4 cpufreq_ondemand acpi_cpufreq freq_table bonding
ipv6 dm_mirror dm_region_hash dm_log cdc_ether usbnet mii serio_raw i2c_i801
i2c_core iTCO_wdt iTCO_vendor_support shpchp ioatdma i7core_edac edac_core bnx2
ixgbe dca mdio sg ext4 mbcache jbd2 sd_mod crc_t10dif mptsas mptscsih mptbase
scsi_transport_sas dm_mod [last unloaded: microcode]
Pid: 0, comm: swapper Not tainted 2.6.32-71.el6.x86_64 #1 BladeCenter HS22
-[7870AC1]-
RIP: 0010:[<ffffffff81405b16>] [<ffffffff81405b16>]
pskb_expand_head+0x36/0x1e0
RSP: 0018:ffff880028303b70 EFLAGS: 00010202
RAX: 0000000000000002 RBX: ffff880c6458ec80 RCX: 0000000000000020
RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff880c6458ec80
RBP: ffff880028303bc0 R08: ffffffff818a6180 R09: ffff880c6458ed64
R10: ffff880c622b36c0 R11: 0000000000000400 R12: 0000000000000000
R13: 0000000000000180 R14: ffff880c622b3000 R15: 0000000000000000
FS: 0000000000000000(0000) GS:ffff880028300000(0000) knlGS:0000000000000000
CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b
CR2: 00000038653452a4 CR3: 0000000001001000 CR4: 00000000000006e0
Process swapper (pid: 0, threadinfo ffff8806649c2000, task ffff880c64f16ab0)
Stack:
ffff880028303bc0 ffffffff8104fff9 000000000000001c 0000000100000000
<0> ffff880000047d80 ffff880c6458ec80 000000000000001c ffff880c6223da00
<0> ffff880c622b3000 0000000000000000 ffff880028303c10 ffffffff81407f7a
Call Trace:
<IRQ>
[<ffffffff8104fff9>] ? __wake_up_common+0x59/0x90
[<ffffffff81407f7a>] __pskb_pull_tail+0x2aa/0x360
[<ffffffffa0244530>] bond_arp_rcv+0x2c0/0x2e0 [bonding]
[<ffffffff814a0857>] ? packet_rcv+0x377/0x440
[<ffffffff8140f21b>] netif_receive_skb+0x2db/0x670
[<ffffffff8140f788>] napi_skb_finish+0x58/0x70
[<ffffffff8140fc89>] napi_gro_receive+0x39/0x50
[<ffffffffa01286eb>] ixgbe_clean_rx_irq+0x35b/0x900 [ixgbe]
[<ffffffffa01290f6>] ixgbe_clean_rxtx_many+0x136/0x240 [ixgbe]
[<ffffffff8140fe53>] net_rx_action+0x103/0x210
[<ffffffff81073bd7>] __do_softirq+0xb7/0x1e0
[<ffffffff810d8740>] ? handle_IRQ_event+0x60/0x170
[<ffffffff810142cc>] call_softirq+0x1c/0x30
[<ffffffff81015f35>] do_softirq+0x65/0xa0
[<ffffffff810739d5>] irq_exit+0x85/0x90
[<ffffffff814cf915>] do_IRQ+0x75/0xf0
[<ffffffff81013ad3>] ret_from_intr+0x0/0x11
<EOI>
[<ffffffff8101bc01>] ? mwait_idle+0x71/0xd0
[<ffffffff814cd80a>] ? atomic_notifier_call_chain+0x1a/0x20
[<ffffffff81011e96>] cpu_idle+0xb6/0x110
[<ffffffff814c17c8>] start_secondary+0x1fc/0x23f
Resulted from bonding driver registering packet handlers via dev_add_pack and
then trying to call pskb_may_pull. If another packet handler (like for AF_PACKET
sockets) gets called first, the delivered skb will have a user count > 1, which
causes pskb_may_pull to BUG halt when it does its skb_shared check. Fix this by
calling skb_share_check prior to the may_pull call sites in the bonding driver
to clone the skb when needed. Tested by myself and the reported successfully.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
CC: Andy Gospodarek <andy@greyhouse.net>
CC: Jay Vosburgh <fubar@us.ibm.com>
CC: "David S. Miller" <davem@davemloft.net>
Signed-off-by: Jay Vosburgh <fubar@us.ibm.com>
commit bd760e1e5b34351e0705705e5163cb89c1316d71 upstream.
Add support for the MacBookAir3,1 and MacBookAir3,2 to the mbp-nvidia-bl
driver.
Acked-by: Richard Purdie <rpurdie@linux.intel.com>
commit b433c3d4549ae74935b585115f076c6fb7bc48fe upstream.
Ilya reported that on a very slow machine he could reliably
reproduce a race between forking init and kthreadd. We first
fork init so that it obtains pid-1, however since the scheduler
is already fully running at this point it can preempt and run
the init thread before we spawn and set kthreadd_task.
The init thread can then attempt spawning kthreads without
kthreadd being present which results in an OOPS.
Reported-by: Ilya Loginov <isloginov@gmail.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
LKML-Reference: <1277736661.3561.110.camel@laptop>
commit 9915672d41273f5b77f1b3c29b391ffb7732b84b upstream.
Vegard Nossum found a unix socket OOM was possible, posting an exploit
program.
My analysis is we can eat all LOWMEM memory before unix_gc() being
called from unix_release_sock(). Moreover, the thread blocked in
unix_gc() can consume huge amount of time to perform cleanup because of
huge working set.
One way to handle this is to have a sensible limit on unix_tot_inflight,
tested from wait_for_unix_gc() and to force a call to unix_gc() if this
limit is hit.
This solves the OOM and also reduce overall latencies, and should not
slowdown normal workloads.
Reported-by: Vegard Nossum <vegard.nossum@gmail.com>
commit 25888e30319f8896fc656fc68643e6a078263060 upstream.
Its easy to eat all kernel memory and trigger NMI watchdog, using an
exploit program that queues unix sockets on top of others.
lkml ref : http://lkml.org/lkml/2010/11/25/8
This mechanism is used in applications, one choice we have is to have a
recursion limit.
Other limits might be needed as well (if we queue other types of files),
since the passfd mechanism is currently limited by socket receive queue
sizes only.
Add a recursion_level to unix socket, allowing up to 4 levels.
Each time we send an unix socket through sendfd mechanism, we copy its
recursion level (plus one) to receiver. This recursion level is cleared
when socket receive queue is emptied.
Reported-by: Марк Коренберг <socketpair@gmail.com>
[bwh: Adjust for 2.6.32]
commit 6f88a4403def422bd8e276ddf6863d6ac71435d2 upstream.
Filesystem rebalancing (BTRFS_IOC_BALANCE) affects the entire
filesystem and may run uninterruptibly for a long time. This does not
seem to be something that an unprivileged user should be able to do.
Reported-by: Aron Xu <happyaron.xu@gmail.com>
Signed-off-by: Chris Mason <chris.mason@oracle.com>
commit e508be174ad36b0cf9b324cd04978c2b13c21502 upstream.
Several users report issues with 32-bit adapters when plugged
into PCI slots in machines with >= 4GB ram. In particular AMD
systems with HyperTransport to PCI bridges seem to trigger the
issue, but it isn't limited to only them.
This issue is not easily reproducible here, yet still continues
to occur in the field. For e1000 on PCI devices, just disable DMA
addresses over the 4GB boundary when in PCI (not PCI-X) mode, to
prevent the issue from continuing to pop up. The performance
impact for this is negligible.
The code was refactored to move the init of the hw struct to its
own function. This allows the init to be called very early in
probe, which then allows using hw-> members for this fix.
A slight refactor to the DMA mask code was done for minor
correctness based on the instructions in DMA-API-HOWTO.
Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com>
commit 627c8a041f7aaaea93c766f69bd61d952a277586 upstream.
Reset the PHY before first accessing it. Doing so, ensure that the PHY is
in a known good state before we read/write PHY registers. This fixes a
driver probe failure.
Signed-off-by: Bruce Allan <bruce.w.allan@intel.com>
[Backported to 2.6.32 by dann frazier <dannf@debian.org>]
commit a7851ce73b9fdef53f251420e6883cf4f3766534 upstream.
cifs_root_iget allocates full_path through
cifs_build_path_to_root, but fails to kfree it upon
cifs_get_inode_info* failure.
Make all failure exit paths traverse clean up
handling at the end of the function.
Signed-off-by: Oskar Schirmer <oskar@scara.com>
Reviewed-by: Jesper Juhl <jj@chaosbits.net>
Signed-off-by: Steve French <sfrench@us.ibm.com>
commit 5738d4449c1baf05e8345684d12371f76296473d upstream.
blk_get_request sets the cmd_flags, so we should not and do not
need to set them. If we did set them to a different value then
it can cause a oops in the elevator code.
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
commit 6c71dcb28ff9b63b814a0b76a256f5dae08d3e0d upstream.
This patch fixes the request setup code for mode selects. I got the fixes from
Hannes Reinecke while trying to hunt down some problems and merged it
into one patch. I am sending it because Hannes is busy with other things.
The patch fixes:
- setting of the length for mode selects.
- setting of the data direction for mode select 10.
Signed-off-by: Hannes Reinecke <hare@suse.de>
commit 410d44c74cf9942e3055d5b7d73953fac8efbacb upstream.
This is to support Precision M4500 and others.
Signed-off-by: Rezwanul Kabir <Rezwanul_Kabir@dell.com>
commit cb6a7937f4328a267e0806680ade500ed2c3c01a upstream.
The Latitude C640 has another variation of dell in its DMI vendor entry.
Add it to the whitelist in order to enjoy the sweet fruits of software
backlight toggling.
Signed-off-by: Erik Andren <erik.andren@gmail.com>
commit a27e13d370415add3487949c60810e36069a23a6 upstream.
Don't declare variable sized array of iovecs on the stack since this
could cause stack overflow if msg->msgiovlen is large. Instead, coalesce
the user-supplied data into a new buffer and use a single iovec for it.
Signed-off-by: Phil Blundell <philb@gnu.org>
commit 9e8342971d44ce86d8567047f5366fc1c06a75ed upstream.
Function argument len was redeclarated within the
function. This patch fix the redeclaration of symbol 'len'.
Signed-off-by: Hagen Paul Pfeifer <hagen@jauu.net>
commit 9f2a0fac625bcef9c579bcf0b0c904ab1a56e7c4 upstream.
On module removal, the sdio version of b43 generates the following warning:
[ 851.560519] ------------[ cut here ]------------
[ 851.560531] WARNING: at drivers/mmc/core/core.c:237 mmc_wait_for_cmd+0x88/0x90()
[ 851.560534] Hardware name: 20552PG
[ 851.560536] Modules linked in: b43(-) ssb mmc_block binfmt_misc rfcomm sco bnep ppdev l2cap ipt_MASQUERADE iptable_nat nf_nat nf_conntrack_ipv4 nf_defrag_ipv4 xt_state nf_conntrack ipt_REJECT xt_tcpudp iptable_filter ip_tables x_tables bridge stp kvm_intel kvm arc4 iwlagn snd_hda_codec_conexant snd_hda_intel snd_hda_codec iwlcore snd_hwdep snd_pcm thinkpad_acpi mac80211 snd_seq_midi snd_rawmidi snd_seq_midi_event snd_seq r852 joydev snd_timer sm_common pcmcia nand snd_seq_device cfg80211 sdhci_pci btusb psmouse tpm_tis yenta_socket nand_ids lp snd pcmcia_rsrc nand_ecc bluetooth sdhci tpm pcmcia_core parport mtd snd_page_alloc serio_raw tpm_bios soundcore nvram led_class sha256_generic aes_i586 aes_generic dm_crypt i915 drm_kms_helper drm ahci intel_agp i2c_algo_bit intel_gtt e1000e libahci video agpgart output
[ 851.560620] Pid: 2504, comm: rmmod Not tainted 2.6.36-titan0+ #1
[ 851.560622] Call Trace:
[ 851.560631] [<c014a102>] warn_slowpath_common+0x72/0xa0
[ 851.560636] [<c04d94c8>] ? mmc_wait_for_cmd+0x88/0x90
[ 851.560641] [<c04d94c8>] ? mmc_wait_for_cmd+0x88/0x90
[ 851.560645] [<c014a152>] warn_slowpath_null+0x22/0x30
[ 851.560649] [<c04d94c8>] mmc_wait_for_cmd+0x88/0x90
[ 851.560655] [<c0401585>] ? device_release+0x25/0x80
[ 851.560660] [<c04df210>] mmc_io_rw_direct_host+0xa0/0x150
[ 851.560665] [<c04df370>] mmc_io_rw_direct+0x30/0x40
[ 851.560669] [<c04e06e7>] sdio_disable_func+0x37/0xa0
[ 851.560683] [<f8dfcb80>] b43_sdio_remove+0x30/0x50 [b43]
[ 851.560687] [<c04df8cc>] sdio_bus_remove+0x1c/0x60
[ 851.560692] [<c016d39f>] ? blocking_notifier_call_chain+0x1f/0x30
[ 851.560697] [<c0404991>] __device_release_driver+0x51/0xb0
[ 851.560701] [<c0404a7f>] driver_detach+0x8f/0xa0
[ 851.560705] [<c0403c83>] bus_remove_driver+0x63/0xa0
[ 851.560709] [<c0405039>] driver_unregister+0x49/0x80
[ 851.560713] [<c0405039>] ? driver_unregister+0x49/0x80
[ 851.560718] [<c04dfad7>] sdio_unregister_driver+0x17/0x20
[ 851.560727] [<f8dfcb42>] b43_sdio_exit+0x12/0x20 [b43]
[ 851.560734] [<f8dfe76f>] b43_exit+0x17/0x3c [b43]
[ 851.560740] [<c017fb8d>] sys_delete_module+0x13d/0x200
[ 851.560747] [<c01fd7d2>] ? do_munmap+0x212/0x300
[ 851.560752] [<c010311f>] sysenter_do_call+0x12/0x28
[ 851.560757] ---[ end trace 31e14488072d2f7d ]---
[ 851.560759] ------------[ cut here ]------------
The warning is caused by b43 not claiming the device before calling
sdio_disable_func().
Reported-by: Arnd Hannemann <arnd@arndnet.de>
Tested-by: Arnd Hannemann <arnd@arndnet.de>
commit 81ca03a0e2ea0207b2df80e0edcf4c775c07a505 upstream.
This fixes a build breakage introduced by commit 4c2ef25fe0b8 ("mmc: fix
all hangs related to mmc/sd card insert/removal during suspend/resume")
Cc: David Brownell <david-b@pacbell.net>
Cc: linux-mmc@vger.kernel.org
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Acked-by: Maxim Levitsky <maximlevitsky@gmail.com>
commit 4c2ef25fe0b847d2ae818f74758ddb0be1c27d8e upstream.
If you don't use CONFIG_MMC_UNSAFE_RESUME, as soon as you attempt to
suspend, the card will be removed, therefore this patch doesn't change the
behavior of this option.
However the removal will be done by pm notifier, which runs while
userspace is still not frozen and thus can freely use del_gendisk, without
the risk of deadlock which would happen otherwise.
Card detect workqueue is now disabled while userspace is frozen, Therefore
if you do use CONFIG_MMC_UNSAFE_RESUME, and remove the card during
suspend, the removal will be detected as soon as userspace is unfrozen,
again at the moment it is safe to call del_gendisk.
Tested with and without CONFIG_MMC_UNSAFE_RESUME with suspend and hibernate.
[akpm@linux-foundation.org: clean up function prototype]
[akpm@linux-foundation.org: fix CONFIG_PM-n linkage, small cleanups]
Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com>
Cc: <linux-mmc@vger.kernel.org>
commit 84e2f037ce9672d0fb118e3e82cecfe6122ace3f upstream.
This patch introduces support for DVB-T for the following dibcom
based card: Elgato EyeTV Diversity (USB-ID: 0fd9:0011)
Support for the Elgato silver IR remote is added too (set parameter
dvb_usb_dib0700_ir_proto=0)
[w.sang@pengutronix.de: rebased to current linuxtv-master]
Signed-off-by: Michael Müller <mueller_michael@alice-dsl.net>
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Signed-off-by: Patrick Boettcher <pboettcher@kernellabs.com>
[bwh: Adjust context and numbering for 2.6.32]
commit d11c7addfe0fa501cb54c824c0fac3481d527433 upstream.
For Fedora, I want to force perf to link against libiberty.a for
cplus_demangle, rather than libbfd.a for bfd_demangle due to licensing insanity
on binutils. (libiberty is LGPL2, libbfd is GPL3.)
If we just rely on autodetection, we'll end up with libbfd linked against us,
since they're both in binutils-static in the buildroot.
LKML-Reference: <20100510204335.GA7565@bombadil.infradead.org>
Signed-off-by: Kyle McMartin <kyle@redhat.com>
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
commit 1703f2c321a8a531c393e137a82602e16c6061cb upstream.
At least on Debian PARISC64, using:
acme@parisc:~/git/linux-2.6-tip$ gcc -v
Using built-in specs.
Target: hppa-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Debian
4.3.4-6' --with-bugurl=file:///usr/share/doc/gcc-4.3/README.Bugs
--enable-languages=c,c++,fortran,objc,obj-c++ --prefix=/usr
--enable-shared --enable-multiarch --enable-linker-build-id --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --enable-nls --with-gxx-include-dir=/usr/include/c++/4.3 --program-suffix=-4.3 --enable-clocale=gnu --enable-libstdcxx-debug --enable-objc-gc --enable-mpfr --disable-libssp --enable-checking=release --build=hppa-linux-gnu --host=hppa-linux-gnu --target=hppa-linux-gnu Thread model: posix gcc version 4.3.4 (Debian 4.3.4-6)
there are issues about using 'gcc -o /dev/null':
/usr/bin/ld: final link failed: File truncated
collect2: ld returned 1 exit status
So we test that and use /dev/null in environments where it
works, while using an .INTERMEDIATE file on those where it can't
be used, so that the .perf.dev.null file can be used instead and
then deleted when make exits.
Researched-with: Kyle McMartin <kyle@mcmartin.ca>
Researched-with: Mauro Carvalho Chehab <mchehab@redhat.com>
Cc: Frédéric Weisbecker <fweisbec@gmail.com>
LKML-Reference: <1263293910-8484-2-git-send-email-acme@infradead.org>
[bwh: Backport to 2.6.32]
commit 830395188fae5f4028fa3c38ab1b031aae18a64c upstream.
QUIET_STDERR is used when detecting if -fstack-protector-all can
be used.
Noticed while building the perf tools on a Debian PARISC64
machine.
LKML-Reference: <1263293910-8484-1-git-send-email-acme@infradead.org>
commit 81516c5fc83a13a1d12f466aa7e14f5fd62a63ce upstream.
gcc with no flags typically is a sane default for systems to
use, and looking at the running kernel is probably broken for
cross-builds anyway, so let's not do this. Add EXTRA_CFLAGS so
that users can override default gcc mode if they want to.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Acked-by: Arjan van de Ven <arjan@infradead.org>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
LKML-Reference: <20091122121335.GA24254@redhat.com>
commit b197c7ef7169bd5f11fb9d803b322d0daef7e256 upstream.
On error, suggest installing static libraries
along with shared libraries.
LKML-Reference: <20091122131311.GA24318@redhat.com>
commit 7baed9af4bf0d7850045e36d19a43a2c76872b62 upstream.
Make standard error show up on console when V=2 is set.
LKML-Reference: <20091122112726.GC13644@redhat.com>
commit 751386507701010831d72c522171753d2cd903d2 upstream.
This makes it possible to build perf statically, by
performing:
make LDFLAGS=-static
Since static libraries are only searched in the order they are
specified, move library list from LDFLAGS to EXTLIBS, so that
they are put at the end of linker command line.
LKML-Reference: <20091029152002.GA5406@redhat.com>
[ v2: resolved conflicts ]
commit 5d7bdab75cd56d2bdc0986ae5546be3b09fea70a upstream.
Some architectures (e.g. Alpha) do not support the
-fstack-protector-all compiler option and the use of the option
with -Werror causes the compiler to abort and the build fails.
Test that the compiler supports -fstack-protector-all before
inclusion in CFLAGS.
Signed-off-by: Michael Cree <mcree@orcon.net.nz>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
LKML-Reference: <20091111074302.GA3728@omega>
