(cherry picked from commit fab3a549e204172236779f502eccb4f9bf0dc87d)
Fix the following potential circular locking dependency between
mm->mmap_sem and ei->i_data_sem:
[ INFO: possible circular locking dependency detected ]
2.6.32-04115-gec044c5 #37
ureadahead/1855 is trying to acquire lock:
(&mm->mmap_sem){++++++}, at: [<ffffffff81107224>] might_fault+0x5c/0xac
but task is already holding lock:
(&ei->i_data_sem){++++..}, at: [<ffffffff811be1fd>] ext4_fiemap+0x11b/0x159
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #1 (&ei->i_data_sem){++++..}:
[<ffffffff81099bfa>] __lock_acquire+0xb67/0xd0f
[<ffffffff81099e7e>] lock_acquire+0xdc/0x102
[<ffffffff81516633>] down_read+0x51/0x84
[<ffffffff811a2414>] ext4_get_blocks+0x50/0x2a5
[<ffffffff811a3453>] ext4_get_block+0xab/0xef
[<ffffffff81154f39>] do_mpage_readpage+0x198/0x48d
[<ffffffff81155360>] mpage_readpages+0xd0/0x114
[<ffffffff811a104b>] ext4_readpages+0x1d/0x1f
[<ffffffff810f8644>] __do_page_cache_readahead+0x12f/0x1bc
[<ffffffff810f86f2>] ra_submit+0x21/0x25
[<ffffffff810f0cfd>] filemap_fault+0x19f/0x32c
[<ffffffff81107b97>] __do_fault+0x55/0x3a2
[<ffffffff81109db0>] handle_mm_fault+0x327/0x734
[<ffffffff8151aaa9>] do_page_fault+0x292/0x2aa
[<ffffffff81518205>] page_fault+0x25/0x30
[<ffffffff812a34d8>] clear_user+0x38/0x3c
[<ffffffff81167e16>] padzero+0x20/0x31
[<ffffffff81168b47>] load_elf_binary+0x8bc/0x17ed
[<ffffffff81130e95>] search_binary_handler+0xc2/0x259
[<ffffffff81166d64>] load_script+0x1b8/0x1cc
[<ffffffff8113255f>] do_execve+0x1ce/0x2cf
[<ffffffff81027494>] sys_execve+0x43/0x5a
[<ffffffff8102918a>] stub_execve+0x6a/0xc0
-> #0 (&mm->mmap_sem){++++++}:
[<ffffffff81099aa4>] __lock_acquire+0xa11/0xd0f
[<ffffffff81107251>] might_fault+0x89/0xac
[<ffffffff81139382>] fiemap_fill_next_extent+0x95/0xda
[<ffffffff811bcb43>] ext4_ext_fiemap_cb+0x138/0x157
[<ffffffff811be069>] ext4_ext_walk_space+0x178/0x1f1
[<ffffffff811be21e>] ext4_fiemap+0x13c/0x159
[<ffffffff811390e6>] do_vfs_ioctl+0x348/0x4d6
[<ffffffff811392ca>] sys_ioctl+0x56/0x79
[<ffffffff81028cb2>] system_call_fastpath+0x16/0x1b
1 lock held by ureadahead/1855:
#0: (&ei->i_data_sem){++++..}, at: [<ffffffff811be1fd>] ext4_fiemap+0x11b/0x159
stack backtrace:
Pid: 1855, comm: ureadahead Not tainted 2.6.32-04115-gec044c5 #37
Call Trace:
[<ffffffff81098c70>] print_circular_bug+0xa8/0xb7
[<ffffffff8102f229>] ? sched_clock+0x9/0xd
[<ffffffff81107224>] ? might_fault+0x5c/0xac
[<ffffffff81124b44>] ? __kmalloc+0x13b/0x18c
[<ffffffff811bca0b>] ? ext4_ext_fiemap_cb+0x0/0x157
[<ffffffff8129f6d0>] ? __up_read+0x8d/0x95
[<ffffffff81517fb5>] ? retint_swapgs+0x13/0x1b
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
(cherry picked from commit 4a58579b9e4e2a35d57e6c9c8483e52f6f1b7fd6)
This patch fixes three problems in the handling of the
EXT4_IOC_MOVE_EXT ioctl:
1. In current EXT4_IOC_MOVE_EXT, there are read access mode checks for
original and donor files, but they allow the illegal write access to
donor file, since donor file is overwritten by original file data. To
fix this problem, change access mode checks of original (r->r/w) and
donor (r->w) files.
2. Disallow the use of donor files that have a setuid or setgid bits.
3. Call mnt_want_write() and mnt_drop_write() before and after
ext4_move_extents() calling to get write access to a mount.
Signed-off-by: Akira Fujita <a-fujita@rs.jp.nec.com>
(cherry picked from commit b436b9bef84de6893e86346d8fbf7104bc520645)
We cannot rely on buffer dirty bits during fsync because pdflush can come
before fsync is called and clear dirty bits without forcing a transaction
commit. What we do is that we track which transaction has last changed
the inode and which transaction last changed allocation and force it to
disk on fsync.
(cherry picked from commit 194074acacebc169ded90a4657193f5180015051)
Inside ->setattr() call both ATTR_UID and ATTR_GID may be valid
This means that we may end-up with transferring all quotas. Add
we have to reserve QUOTA_DEL_BLOCKS for all quotas, as we do in
case of QUOTA_INIT_BLOCKS.
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
Reviewed-by: Mingming Cao <cmm@us.ibm.com>
(cherry picked from commit 5aca07eb7d8f14d90c740834d15ca15277f4820c)
Currently all quota block reservation macros contains hard-coded "2"
aka MAXQUOTAS value. This is no good because in some places it is not
obvious to understand what does this digit represent. Let's introduce
new macro with self descriptive name.
Acked-by: Mingming Cao <cmm@us.ibm.com>
(cherry picked from commit 8aa6790f876e81f5a2211fe1711a5fe3fe2d7b20)
Reviewed-by: Eric Sandeen <sandeen@redhat.com>
(cherry picked from commit b844167edc7fcafda9623955c05e4c1b3c32ebc7)
This fixes a leak of blocks in an inode prealloc list if device failures
cause ext4_mb_mark_diskspace_used() to fail.
Signed-off-by: Curt Wohlgemuth <curtw@google.com>
Acked-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
(cherry picked from commit d4edac314e9ad0b21ba20ba8bc61b61f186f79e1)
There is a potential race when a transaction is committing right when
the file system is being umounting. This could reduce in a race
because EXT4_SB(sb)->s_group_info could be freed in ext4_put_super
before the commit code calls a callback so the mballoc code can
release freed blocks in the transaction, resulting in a panic trying
to access the freed s_group_info.
The fix is to wait for the transaction to finish committing before we
shutdown the multiblock allocator.
Signed-off-by: Josef Bacik <josef@redhat.com>
(cherry picked from commit b9a4207d5e911b938f73079a83cc2ae10524ec7f)
When ext4_write_begin fails after allocating some blocks or
generic_perform_write fails to copy data to write, we truncate blocks
already instantiated beyond i_size. Although these blocks were never
inside i_size, we have to truncate the pagecache of these blocks so
that corresponding buffers get unmapped. Otherwise subsequent
__block_prepare_write (called because we are retrying the write) will
find the buffers mapped, not call ->get_block, and thus the page will
be backed by already freed blocks leading to filesystem and data
corruption.
(cherry picked from commit c09eef305dd43846360944ad072f051f964fa383)
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
(cherry picked from commit e6ec116b67f46e0e7808276476554727b2e6240b)
OOM happens.
(cherry picked from commit ac48b0a1d068887141581bea8285de5fcab182b0)
Integrate duplicate lines (acquire/release semaphore and invalidate
extent cache in move_extent_per_page()) into mext_replace_branches(),
to reduce source and object code size.
(cherry picked from commit 446aaa6e7e993b38a6f21c6acfa68f3f1af3dbe3)
The move_extent.moved_len is used to pass back the number of exchanged
blocks count to user space. Currently the caller must clear this
field; but we spend more code space checking for this requirement than
simply zeroing the field ourselves, so let's just make life easier for
everyone all around.
Signed-off-by: Kazuya Mio <k-mio@sx.jp.nec.com>
(cherry picked from commit 94d7c16cbbbd0e03841fcf272bcaf0620ad39618)
At the beginning of ext4_move_extent(), we call
ext4_discard_preallocations() to discard inode PAs of orig and donor
inodes. But in the following case, blocks can be double freed, so
move ext4_discard_preallocations() to the end of ext4_move_extents().
1. Discard inode PAs of orig and donor inodes with
ext4_discard_preallocations() in ext4_move_extents().
orig : [ DATA1 ]
donor: [ DATA2 ]
2. While data blocks are exchanging between orig and donor inodes, new
inode PAs is created to orig by other process's block allocation.
(Since there are semaphore gaps in ext4_move_extents().) And new
inode PAs is used partially (2-1).
2-1 Create new inode PAs to orig inode
orig : [ DATA1 | used PA1 | free PA1 ]
donor: [ DATA2 ]
3. Donor inode which has old orig inode's blocks is deleted after
EXT4_IOC_MOVE_EXT finished (3-1, 3-2). So the block bitmap
corresponds to old orig inode's blocks are freed.
3-1 After EXT4_IOC_MOVE_EXT finished
orig : [ DATA2 | free PA1 ]
donor: [ DATA1 | used PA1 ]
3-2 Delete donor inode
donor: [ FREE SPACE(DATA1) | FREE SPACE(used PA1) ]
4. The double-free of blocks is occurred, when close() is called to
orig inode. Because ext4_discard_preallocations() for orig inode
frees used PA1 and free PA1, though used PA1 is already freed in 3.
4-1 Double-free of blocks is occurred
orig : [ DATA2 | FREE SPACE(free PA1) ]
donor: [ FREE SPACE(DATA1) | DOUBLE FREE(used PA1) ]
(cherry picked from commit e3bb52ae2bb9573e84c17b8e3560378d13a5c798)
Users on the linux-ext4 list recently complained about differences
across filesystems w.r.t. how to mount without a journal replay.
In the discussion it was noted that xfs's "norecovery" option is
perhaps more descriptively accurate than "noload," so let's make
that an alias for ext4.
Also show this status in /proc/mounts
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
(cherry picked from commit 5328e635315734d42080de9a5a1ee87bf4cae0a4)
It is anticipated that when sb_issue_discard starts doing
real work on trim-capable devices, we may see issues. Make
this mount-time optional, and default it to off until we know
that things are working out OK.
(cherry picked from commit 2bba702d4f88d7b010ec37e2527b552588404ae7)
When an error happened in ext4_splice_branch we failed to notice that
in ext4_ind_get_blocks and mapped the buffer anyway. Fix the problem
by checking for error properly.
(cherry picked from commit 6b17d902fdd241adfa4ce780df20547b28bf5801)
We don't to issue an I/O barrier on an error or if we force commit
because we are doing data journaling.
Cc: Jan Kara <jack@suse.cz>
(cherry picked from commit 1032988c71f3f85483b2b4319684d1205a704c02)
The block validity checks used by ext4_data_block_valid() wasn't
correctly written to check file systems with the meta_bg feature. Fix
this.
(cherry picked from commit 8dadb198cb70ef811916668fe67eeec82e8858dd)
The number of old-style block group descriptor blocks is
s_meta_first_bg when the meta_bg feature flag is set.
(cherry picked from commit 3f8fb9490efbd300887470a2a880a64e04dcc3f5)
commit a71ce8c6c9bf269b192f352ea555217815cf027e updated ext4_statfs()
to update the on-disk superblock counters, but modified this buffer
directly without any journaling of the change. This is one of the
accesses that was causing the crc errors in journal replay as seen in
kernel.org bugzilla #14354.
(cherry picked from commit 86ebfd08a1930ccedb8eac0aeb1ed4b8b6a41dbc)
ext4_xattr_set_handle() was zeroing out an inode outside
of journaling constraints; this is one of the accesses that
Reviewed-by: Andreas Dilger <adilger@sun.com>
(cherry picked from commit 30c6e07a92ea4cb87160d32ffa9bce172576ae4c)
We need to be testing the i_flags field in the ext4 specific portion
of the inode, instead of the (confusingly aliased) i_flags field in
the generic struct inode.
(cherry picked from commit 50689696867d95b38d9c7be640a311494a04fb86)
When an inode gets unlinked, the functions ext4_clear_blocks() and
ext4_remove_blocks() call ext4_forget() for all the buffer heads
corresponding to the deleted inode's data blocks. If the inode is a
directory or a symlink, the is_metadata parameter must be non-zero so
ext4_forget() will revoke them via jbd2_journal_revoke(). Otherwise,
if these blocks are reused for a data file, and the system crashes
before a journal checkpoint, the journal replay could end up
corrupting these data blocks.
Thanks to Curt Wohlgemuth for pointing out potential problems in this
area.
(cherry picked from commit 567f3e9a70d71e5c9be03701b8578be77857293b)
One of the invalid error paths in ext4_iget() forgot to brelse() the
inode buffer head. Fix it by adding a brelse() in the common error
return path, which also simplifies function.
Thanks to Andi Kleen <ak@linux.intel.com> reporting the problem.
(cherry picked from commit 49bd22bc4d603a2a4fc2a6a60e156cbea52eb494)
If CONFIG_PROVE_LOCKING is enabled, the double_down_write_data_sem()
will trigger a false-positive warning of a recursive lock. Since we
take i_data_sem for the two inodes ordered by their inode numbers,
this isn't a problem. Use of down_write_nested() will notify the lock
dependency checker machinery that there is no problem here.
This problem was reported by Brian Rogers:
http://marc.info/?l=linux-ext4&m=125115356928011&w=1
Reported-by: Brian Rogers <brian@xyzw.org>
(cherry picked from commit fc04cb49a898c372a22b21fffc47f299d8710801)
ext4_move_extents() checks the logical block contiguousness
of original file with ext4_find_extent() and mext_next_extent().
Therefore the extent which ext4_ext_path structure indicates
must not be changed between above functions.
But in current implementation, there is no i_data_sem protection
between ext4_ext_find_extent() and mext_next_extent(). So the extent
which ext4_ext_path structure indicates may be overwritten by
delalloc. As a result, ext4_move_extents() will exchange wrong blocks
between original and donor files. I change the place where
acquire/release i_data_sem to solve this problem.
Moreover, I changed move_extent_per_page() to start transaction first,
and then acquire i_data_sem. Without this change, there is a
possibility of the deadlock between mmap() and ext4_move_extents():
* NOTE: "A", "B" and "C" mean different processes
A-1: ext4_ext_move_extents() acquires i_data_sem of two inodes.
B: do_page_fault() starts the transaction (T),
and then tries to acquire i_data_sem.
But process "A" is already holding it, so it is kept waiting.
C: While "A" and "B" running, kjournald2 tries to commit transaction (T)
but it is under updating, so kjournald2 waits for it.
A-2: Call ext4_journal_start with holding i_data_sem,
but transaction (T) is locked.
(cherry picked from commit f868a48d06f8886cb0367568a12367fa4f21ea0d)
If the EXT4_IOC_MOVE_EXT ioctl fails, the number of blocks that were
exchanged before the failure should be returned to the userspace
caller. Unfortunately, currently if the block size is not the same as
the page size, the returned block count that is returned is the
page-aligned block count instead of the actual block count. This
commit addresses this bug.
(cherry picked from commit 503358ae01b70ce6909d19dd01287093f6b6271c)
If s_log_groups_per_flex is greater than 31, then groups_per_flex will
will overflow and cause a divide by zero error. This can cause kernel
BUG if such a file system is mounted.
Thanks to Nageswara R Sastry for analyzing the failure and providing
an initial patch.
http://bugzilla.kernel.org/show_bug.cgi?id=14287
(cherry picked from commit 2de770a406b06dfc619faabbf5d85c835ed3f2e1)
Previously add_dirent_to_buf() did not free its passed-in buffer head
in the case of ENOSPC, since in some cases the caller still needed it.
However, this led to potential buffer head leaks since not all callers
dealt with this correctly. Fix this by making simplifying the freeing
convention; now add_dirent_to_buf() *never* frees the passed-in buffer
head, and leaves that to the responsibility of its caller. This makes
things cleaner and easier to prove that the code is neither leaking
buffer heads or calling brelse() one time too many.
Cc: Curt Wohlgemuth <curtw@google.com>
commit 7b2519afa1abd1b9f63aa1e90879307842422dae upstream.
The current sense pointer is cast to a u32 pointer, which can truncate
on 64 bits. Fix by using unsigned long instead.
Signed-off-by Bo Yang<bo.yang@lsi.com>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
commit 0899638688f223fd9e9fee60d662665e11693d12 upstream.
include/scsi/osd_protocol.h uses ALIGN() without an #include
<linux/kernel.h>, leading to:
| include/scsi/osd_protocol.h:362: error: implicit declaration of function 'ALIGN'
Signed-off-by: Martin Michlmayr <tbm@cyrius.com>
Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
commit d139b9bd0e52dda14fd13412e7096e68b56d0076 upstream.
Some of our virtual SCSI hosts don't have a proper bus parent at the
top, which can be a problem for doing DMA on them
This patch makes the host device cache a pointer to the physical bus
device and provides an extra API for setting it (the normal API picks
it up from the parent). This patch also modifies the qla2xxx and lpfc
vport logic to use the new DMA host setting API.
Acked-By: James Smart <james.smart@emulex.com>
commit 2a855dd01bc1539111adb7233f587c5c468732ac upstream.
All architectures in the kernel increment/decrement the stack pointer
before storing values on the stack.
On architectures which have the stack grow down sas_ss_sp == sp is not
on the alternate signal stack while sas_ss_sp + sas_ss_size == sp is
on the alternate signal stack.
On architectures which have the stack grow up sas_ss_sp == sp is on
the alternate signal stack while sas_ss_sp + sas_ss_size == sp is not
The current implementation fails for architectures which have the
stack grow down on the corner case where sas_ss_sp == sp.This was
reported as Debian bug #544905 on AMD64.
Simplified test case: http://download.breakpoint.cc/tc-sig-stack.c
The test case creates the following stack scenario:
0xn0300 stack top
0xn0200 alt stack pointer top (when switching to alt stack)
0xn01ff alt stack end
0xn0100 alt stack start == stack pointer
If the signal is sent the stack pointer is pointing to the base
address of the alt stack and the kernel erroneously decides that it
has already switched to the alternate stack because of the current
check for "sp - sas_ss_sp < sas_ss_size"
On parisc (stack grows up) the scenario would be:
0xn0200 stack pointer
0xn0100 alt stack start = alt stack pointer base
0xn0000 stack base
This is handled correctly by the current implementation.
[ tglx: Modified for archs which have the stack grow up (parisc) which
would fail with the correct implementation for stack grows
down. Added a check for sp >= current->sas_ss_sp which is
strictly not necessary but makes the code symetric for both
variants ]
Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
Cc: Roland McGrath <roland@redhat.com>
Cc: Kyle McMartin <kyle@mcmartin.ca>
LKML-Reference: <20091025143758.GA6653@Chamillionaire.breakpoint.cc>
request_region should be used with release_region, not request_mem_region.
Geert Uytterhoeven pointed out that in the case of drivers/video/gbefb.c,
the problem is actually the other way around; request_mem_region should be
used instead of request_region.
The semantic patch that finds/fixes this problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r1@
expression start;
request_region(start,...)
@b1@
expression r1.start;
request_mem_region(start,...)
@depends on !b1@
expression E;
- release_mem_region
+ release_region
(start,E)
// </smpl>
TXx9 SPI bit rate is calculated by:
fBR = (spi-baseclk) / (n + 1)
Fix calculation of min_speed_hz, max_speed_hz and n.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6:
mfd: Correct WM831X_MAX_ISEL_VALUE
These laptops often leave i8042 in a wierd state resulting in non-
operational touchpad and keyboard.
Signed-off-by: Anisse Astier <anisse@astier.eu>
* 'for-linus' of git://neil.brown.name/md:
md: revert incorrect fix for read error handling in raid1.
Jon confirms that recent modprobe will look in /proc/cmdline, so these
cmdline options can still be used.
See http://bugzilla.kernel.org/show_bug.cgi?id=14164
Reported-by: Adam Williamson <awilliam@redhat.com>
Cc: stable@kernel.org
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus:
MIPS: RB532: Fix devices.c compilation.
MIPS: Fix MIPS I build.
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog:
[PATCH] rc32434_wdt: fix compilation failure
[WATCHDOG] rc32434_wdt.c: use resource_size()
On the parisc architecture we face for each and every loaded kernel module
this kernel "badness warning":
sysfs: cannot create duplicate filename '/module/ac97_bus/sections/.text'
Badness at fs/sysfs/dir.c:487
Reason for that is, that on parisc all kernel modules do have multiple
.text sections due to the usage of the -ffunction-sections compiler flag
which is needed to reach all jump targets on this platform.
An objdump on such a kernel module gives:
Sections:
Idx Name Size VMA LMA File off Algn
0 .note.gnu.build-id 00000024 00000000 00000000 00000034 2**2
CONTENTS, ALLOC, LOAD, READONLY, DATA
1 .text 00000000 00000000 00000000 00000058 2**0
CONTENTS, ALLOC, LOAD, READONLY, CODE
2 .text.ac97_bus_match 0000001c 00000000 00000000 00000058 2**2
3 .text 00000000 00000000 00000000 000000d4 2**0
Since the .text sections are empty (size of 0 bytes) and won't be
loaded by the kernel module loader anyway, I don't see a reason
why such sections need to be listed under
/sys/module/<module_name>/sections/<section_name> either.
The attached patch does solve this issue by not exporting section
names which are empty.
This fixes bugzilla http://bugzilla.kernel.org/show_bug.cgi?id=14703
Signed-off-by: Helge Deller <deller@gmx.de>
CC: rusty@rustcorp.com.au
CC: akpm@linux-foundation.org
CC: James.Bottomley@HansenPartnership.com
CC: roland@redhat.com
CC: dave@hiauly1.hia.nrc.ca
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6:
regulator: Initialise wm831x structure pointor for ISINK driver
The version that made it into mainline missed the initialisation of the
chip handle.
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
We should now use dev_set_drvdata to set the driver driver_data field.
Signed-off-by: Florian Fainelli <florian@openwrt.org>
Patchwork: http://patchwork.linux-mips.org/patch/747/
Broken by d63c63e889bbeeaa461a8addf1245f89f3ce4ece (lmo) rsp.
f1e39a4a616cd9981a9decfd5332fd07a01abb8b (kernel.org).
Patchwork: http://patchwork.linux-mips.org/patch/746/
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6
* 'fix' of git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6:
[ARM] pxamci: call mmc_remove_host() before freeing resources
