2009-10-05Linux 2.6.31.2v2.6.31.2Greg Kroah-Hartman
2009-10-05iwlwifi: fix unloading driver while scanningWey-Yi Guy
This is commit 5bddf54962bf68002816df710348ba197d6391bb in linux-2.6. If NetworkManager is busy scanning when user tries to unload the module, the driver can not be unloaded because HW still scanning. Make sure driver sends abort scan host command to uCode if it is in the middle of scanning during driver unload. Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05iwlwifi: traverse linklist to find the valid OTP blockWey-Yi Guy
commit 415e49936b4b29b34c2fb561eeab867d41fc43a6 upstream. For devices using OTP memory, EEPROM image can start from any one of the OTP blocks. If shadow RAM is disabled, we need to traverse link list to find the last valid block, then start the EEPROM image reading. If OTP is not full, the valid block is the block _before_ the last block on the link list; the last block on the link list is the empty block ready for next OTP refresh/update. If OTP is full, then the last block is the valid block to be used for configure the device. Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05iwlagn: modify digital SVR for 1000Wey-Yi Guy
commit 02c06e4abc0680afd31bf481a803541556757fb6 upstream. On 1000, there are two Switching Voltage Regulators (SVR). The first one apply digital voltage level (1.32V) for PCIe block and core. We need to use this regulator to solve a stability issue related to noisy DC2DC line in the silicon. Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05iwlwifi: update 1000 series API version to match firmwareJay Sternberg
commit cce53aa347c1e023d967b1cb1aa393c725aedba5 upstream. firmware file now contains build number so API needs to be updated. Signed-off-by: Jay Sternberg <jay.e.sternberg@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05iwlwifi: Handle new firmware file with ucode build number in headerJay Sternberg
commit cc0f555d511a5fe9d4519334c8f674a1dbab9e3a upstream. Adding new API version to account for change to ucode file format. New header includes the build number of the ucode. This build number is the SVN revision thus allowing for exact correlation to the code that generated it. The header adds the build number so that older ucode images can also be enhanced to include the build in the future. some cleanup in iwl_read_ucode needed to ensure old header not used and reduce unnecessary references through pointer with the data is already in heap variable. Signed-off-by: Jay Sternberg <jay.e.sternberg@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05NOMMU: Fix MAP_PRIVATE mmap() of objects where the data can be mapped directlyDavid Howells
commit 645d83c5db970a1c57225e155113b4aa2451e920 upstream. Fix MAP_PRIVATE mmap() of files and devices where the data in the backing store might be mapped directly. Use the BDI_CAP_MAP_DIRECT capability flag to govern whether or not we should be trying to map a file directly. This can be used to determine whether or not a region has been filled in at the point where we call do_mmap_shared() or do_mmap_private(). The BDI_CAP_MAP_DIRECT capability flag is cleared by validate_mmap_request() if there's any reason we can't use it. It's also cleared in do_mmap_pgoff() if f_op->get_unmapped_area() fails. Without this fix, attempting to run a program from a RomFS image on a non-mappable MTD partition results in a BUG as the kernel attempts XIP, and this can be caught in gdb: Program received signal SIGABRT, Aborted. 0xc005dce8 in add_nommu_region (region=<value optimized out>) at mm/nommu.c:547 (gdb) bt #0 0xc005dce8 in add_nommu_region (region=<value optimized out>) at mm/nommu.c:547 #1 0xc005f168 in do_mmap_pgoff (file=0xc31a6620, addr=<value optimized out>, len=3808, prot=3, flags=6146, pgoff=0) at mm/nommu.c:1373 #2 0xc00a96b8 in elf_fdpic_map_file (params=0xc33fbbec, file=0xc31a6620, mm=0xc31bef60, what=0xc0213144 "executable") at mm.h:1145 #3 0xc00aa8b4 in load_elf_fdpic_binary (bprm=0xc316cb00, regs=<value optimized out>) at fs/binfmt_elf_fdpic.c:343 #4 0xc006b588 in search_binary_handler (bprm=0x6, regs=0xc33fbce0) at fs/exec.c:1234 #5 0xc006c648 in do_execve (filename=<value optimized out>, argv=0xc3ad14cc, envp=0xc3ad1460, regs=0xc33fbce0) at fs/exec.c:1356 #6 0xc0008cf0 in sys_execve (name=<value optimized out>, argv=0xc3ad14cc, envp=0xc3ad1460) at arch/frv/kernel/process.c:263 #7 0xc00075dc in __syscall_call () at arch/frv/kernel/entry.S:897 Note that this fix does the following commit differently: commit a190887b58c32d19c2eee007c5eb8faa970a69ba Author: David Howells <dhowells@redhat.com> Date: Sat Sep 5 11:17:07 2009 -0700 nommu: fix error handling in do_mmap_pgoff() Reported-by: Graff Yang <graff.yang@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Greg Ungerer <gerg@snapgear.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05mptsas : PAE Kernel more than 4 GB kernel panicKashyap, Desai
commit c55b89fba9872ebcd5ac15cdfdad29ffb89329f0 upstream. This patch is solving problem for PAE kernel DMA operation. On PAE system dma_addr and unsigned long will have different values. Now dma_addr is not type casted using unsigned long. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de> Cc: Jan Beulich <JBeulich@novell.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05HID: completely remove apple mightymouse from blacklistJan Scholz
commit 42960a13001aa6df52ca9952ce996f94a744ea65 upstream. Commit fa047e4f6fa63a6e9d0ae4d7749538830d14a343 "HID: fix inverted wheel for bluetooth version of apple mighty mouse" is incomplete. If we remove Apple MightyMouse (bluetooth version) from the list of apple_devices in drivers/hid/hid-apple.c we have to remove it from hid_blacklist in drivers/hid/hid-core.c as well. Signed-off-by: Jan Scholz <Scholz@fias.uni-frankfurt.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05powerpc: Fix incorrect setting of __HAVE_ARCH_PTE_SPECIALWeirich, Bernhard
[I'm going to fix upstream differently, by having all CPU types actually support _PAGE_SPECIAL, but I prefer the simple and obvious fix for -stable. -- Ben] The test that decides whether to define __HAVE_ARCH_PTE_SPECIAL on powerpc is bogus and will end up always defining it, even when _PAGE_SPECIAL is not supported (in which case it's 0) such as on 8xx or 40x processors. Signed-off-by: Bernhard Weirich <bernhard.weirich@riedel.net> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05powerpc/8xx: Fix regression introduced by cache coherency rewriteRex Feany
commit e0908085fc2391c85b85fb814ae1df377c8e0dcb upstream. After upgrading to the latest kernel on my mpc875 userspace started running incredibly slow (hours to get to a shell, even!). I tracked it down to commit 8d30c14cab30d405a05f2aaceda1e9ad57800f36, that patch removed a work-around for the 8xx. Adding it back makes my problem go away. Signed-off-by: Rex Feany <rfeany@mrv.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05saa7134: ir-kbd-i2c init data needs a persistent objectBrian Rogers
commit 7aedd5ec87686c557d48584d69ad880c11a0984d upstream. Tested on MSI TV@nywhere Plus. Original commit message: ir-kbd-i2c's ir_probe() function can be called much later (i.e. at ir-kbd-i2c module load), than the lifetime of a struct IR_i2c_init_data allocated off of the stack in cx18_i2c_new_ir() at registration time. Make sure we pass a pointer to a persistent IR_i2c_init_data object at i2c registration time. Thanks to Brian Rogers, Dustin Mitchell, Andy Walls and Jean Delvare to rise this question. Before this patch, if ir-kbd-i2c were probed after SAA7134, trash data were used. Compile tested only, but the patch is identical to em28xx one. So, it should work properly. Original-patch-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> [brian@xyzw.org: backported for 2.6.31] Signed-off-by: Brian Rogers <brian@xyzw.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05em28xx: ir-kbd-i2c init data needs a persistent objectBrian Rogers
commit d2ebd0f806fdb6104903365e355675934eec22b2 upstream. Original commit message: ir-kbd-i2c's ir_probe() function can be called much later (i.e. at ir-kbd-i2c module load), than the lifetime of a struct IR_i2c_init_data allocated off of the stack in cx18_i2c_new_ir() at registration time. Make sure we pass a pointer to a persistent IR_i2c_init_data object at i2c registration time. Thanks to Brian Rogers, Dustin Mitchell, Andy Walls and Jean Delvare to rise this question. Before this patch, if ir-kbd-i2c were probed after em28xx, trash data were used. After the patch, no matter what order, it is properly reported as tested by me: input: i2c IR (i2c IR (EM2840 Hauppaug as /class/input/input10 ir-kbd-i2c: i2c IR (i2c IR (EM2840 Hauppaug detected at i2c-4/4-0030/ir0 [em28xx #0] Original-patch-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> [brian@xyzw.org: backported for 2.6.31] Signed-off-by: Brian Rogers <brian@xyzw.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05drm/i915: Handle ERESTARTSYS during page faultChris Wilson
commit c715089f49844260f1eeae8e3b55af9468ba1325 upstream. During a page fault and rebinding the buffer there exists a window for a signal to arrive during the i915_wait_request() and trigger a ERESTARTSYS. This used to be handled by returning SIGBUS and thereby killing the application. Try 'cairo-perf-trace & cairo-test-suite' and watch X go boom! The solution as suggested by H. Peter Anvin is to simply return NOPAGE and leave the higher layers to spot we did not fill the page and resubmit the page fault. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> [anholt: Mostly squash it with another commit] Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05Fix idle time field in /proc/uptimeMichael Abbott
commit 96830a57de1197519b62af6a4c9ceea556c18c3d upstream. Git commit 79741dd changes idle cputime accounting, but unfortunately the /proc/uptime file hasn't caught up. Here the idle time calculation from /proc/stat is copied over. Signed-off-by: Michael Abbott <michael.abbott@diamond.ac.uk> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05mmap: avoid unnecessary anon_vma lock acquisition in vma_adjust()Lee Schermerhorn
commit 252c5f94d944487e9f50ece7942b0fbf659c5c31 upstream. We noticed very erratic behavior [throughput] with the AIM7 shared workload running on recent distro [SLES11] and mainline kernels on an 8-socket, 32-core, 256GB x86_64 platform. On the SLES11 kernel [2.6.27.19+] with Barcelona processors, as we increased the load [10s of thousands of tasks], the throughput would vary between two "plateaus"--one at ~65K jobs per minute and one at ~130K jpm. The simple patch below causes the results to smooth out at the ~130k plateau. But wait, there's more: We do not see this behavior on smaller platforms--e.g., 4 socket/8 core. This could be the result of the larger number of cpus on the larger platform--a scalability issue--or it could be the result of the larger number of interconnect "hops" between some nodes in this platform and how the tasks for a given load end up distributed over the nodes' cpus and memories--a stochastic NUMA effect. The variability in the results are less pronounced [on the same platform] with Shanghai processors and with mainline kernels. With 31-rc6 on Shanghai processors and 288 file systems on 288 fibre attached storage volumes, the curves [jpm vs load] are both quite flat with the patched kernel consistently producing ~3.9% better throughput [~80K jpm vs ~77K jpm] than the unpatched kernel. Profiling indicated that the "slow" runs were incurring high[er] contention on an anon_vma lock in vma_adjust(), apparently called from the sbrk() system call. The patch: A comment in mm/mmap.c:vma_adjust() suggests that we don't really need the anon_vma lock when we're only adjusting the end of a vma, as is the case for brk(). The comment questions whether it's worth while to optimize for this case. Apparently, on the newer, larger x86_64 platforms, with interesting NUMA topologies, it is worth while--especially considering that the patch [if correct!] is quite simple. We can detect this condition--no overlap with next vma--by noting a NULL "importer". The anon_vma pointer will also be NULL in this case, so simply avoid loading vma->anon_vma to avoid the lock. However, we DO need to take the anon_vma lock when we're inserting a vma ['insert' non-NULL] even when we have no overlap [NULL "importer"], so we need to check for 'insert', as well. And Hugh points out that we should also take it when adjusting vm_start (so that rmap.c can rely upon vma_address() while it holds the anon_vma lock). akpm: Zhang Yanmin reprts a 150% throughput improvement with aim7, so it might be -stable material even though thiss isn't a regression: "this issue is not clear on dual socket Nehalem machine (2*4*2 cpu), but is severe on large machine (4*8*2 cpu)" [hugh.dickins@tiscali.co.uk: test vma start too] Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: Nick Piggin <npiggin@suse.de> Cc: Eric Whitney <eric.whitney@hp.com> Tested-by: "Zhang, Yanmin" <yanmin_zhang@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05mm: fix anonymous dirtyingHugh Dickins
commit 1ac0cb5d0e22d5e483f56b2bc12172dec1cf7536 upstream. do_anonymous_page() has been wrong to dirty the pte regardless. If it's not going to mark the pte writable, then it won't help to mark it dirty here, and clogs up memory with pages which will need swap instead of being thrown away. Especially wrong if no overcommit is chosen, and this vma is not yet VM_ACCOUNTed - we could exceed the limit and OOM despite no overcommit. Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Acked-by: Rik van Riel <riel@redhat.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Minchan Kim <minchan.kim@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05mm: munlock use follow_pageHugh Dickins
commit 408e82b78bcc9f1b47c76e833c3df97f675947de upstream. Hiroaki Wakabayashi points out that when mlock() has been interrupted by SIGKILL, the subsequent munlock() takes unnecessarily long because its use of __get_user_pages() insists on faulting in all the pages which mlock() never reached. It's worse than slowness if mlock() is terminated by Out Of Memory kill: the munlock_vma_pages_all() in exit_mmap() insists on faulting in all the pages which mlock() could not find memory for; so innocent bystanders are killed too, and perhaps the system hangs. __get_user_pages() does a lot that's silly for munlock(): so remove the munlock option from __mlock_vma_pages_range(), and use a simple loop of follow_page()s in munlock_vma_pages_range() instead; ignoring absent pages, and not marking present pages as accessed or dirty. (Change munlock() to only go so far as mlock() reached? That does not work out, given the convention that mlock() claims complete success even when it has to give up early - in part so that an underlying file can be extended later, and those pages locked which earlier would give SIGBUS.) Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Acked-by: Rik van Riel <riel@redhat.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Hiroaki Wakabayashi <primulaelatior@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05page-allocator: limit the number of MIGRATE_RESERVE pageblocks per zoneMel Gorman
commit 78986a678f6ec3759a01976749f4437d8bf2d6c3 upstream. After anti-fragmentation was merged, a bug was reported whereby devices that depended on high-order atomic allocations were failing. The solution was to preserve a property in the buddy allocator which tended to keep the minimum number of free pages in the zone at the lower physical addresses and contiguous. To preserve this property, MIGRATE_RESERVE was introduced and a number of pageblocks at the start of a zone would be marked "reserve", the number of which depended on min_free_kbytes. Anti-fragmentation works by avoiding the mixing of page migratetypes within the same pageblock. One way of helping this is to increase min_free_kbytes because it becomes less like that it will be necessary to place pages of of MIGRATE_RESERVE is unbounded, the free memory is kept there in large contiguous blocks instead of helping anti-fragmentation as much as it should. With the page-allocator tracepoint patches applied, it was found during anti-fragmentation tests that the number of fragmentation-related events were far higher than expected even with min_free_kbytes at higher values. This patch limits the number of MIGRATE_RESERVE blocks that exist per zone to two. For example, with a sufficient min_free_kbytes, 4MB of memory will be kept aside on an x86-64 and remain more or less free and contiguous for the systems uptime. This should be sufficient for devices depending on high-order atomic allocations while helping fragmentation control when min_free_kbytes is tuned appropriately. As side-effect of this patch is that the reserve variable is converted to int as unsigned long was the wrong type to use when ensuring that only the required number of reserve blocks are created. With the patches applied, fragmentation-related events as measured by the page allocator tracepoints were significantly reduced when running some fragmentation stress-tests on systems with min_free_kbytes tuned to a value appropriate for hugepage allocations at runtime. On x86, the events recorded were reduced by 99.8%, on x86-64 by 99.72% and on ppc64 by 99.83%. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05hugetlb: restore interleaving of bootmem huge pages (2.6.31)Lee Schermerhorn
Not upstream as it is fixed differently in .32 I noticed that alloc_bootmem_huge_page() will only advance to the next node on failure to allocate a huge page. I asked about this on linux-mm and linux-numa, cc'ing the usual huge page suspects. Mel Gorman responded: I strongly suspect that the same node being used until allocation failure instead of round-robin is an oversight and not deliberate at all. It appears to be a side-effect of a fix made way back in commit 63b4613c3f0d4b724ba259dc6c201bb68b884e1a ["hugetlb: fix hugepage allocation with memoryless nodes"]. Prior to that patch it looked like allocations would always round-robin even when allocation was successful. Andy Whitcroft countered that the existing behavior looked like Andi Kleen's original implementation and suggested that we ask him. We did and Andy replied that his intention was to interleave the allocations. So, ... This patch moves the advance of the hstate next node from which to allocate up before the test for success of the attempted allocation. This will unconditionally advance the next node from which to alloc, interleaving successful allocations over the nodes with sufficient contiguous memory, and skipping over nodes that fail the huge page allocation attempt. Note that alloc_bootmem_huge_page() will only be called for huge pages of order > MAX_ORDER. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Reviewed-by: Andi Kleen <ak@linux.intel.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: David Rientjes <rientjes@google.com> Cc: Adam Litke <agl@us.ibm.com> Cc: Andy Whitcroft <apw@canonical.com> Cc: Eric Whitney <eric.whitney@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05/proc/kcore: work around a BUG()KAMEZAWA Hiroyuki
Not upstream due to other fixes in .32 Works around a BUG() which is triggered when the kernel accesses holes in vmalloc regions. BUG: unable to handle kernel paging request at fa54c000 IP: [<c04f687a>] read_kcore+0x260/0x31a *pde = 3540b067 *pte = 00000000 Oops: 0000 [#1] SMP last sysfs file: /sys/devices/pci0000:00/0000:00:1c.2/0000:03:00.0/ieee80211/phy0/rfkill0/state Modules linked in: fuse sco bridge stp llc bnep l2cap bluetooth sunrpc nf_conntrack_ftp ip6t_REJECT nf_conntrack_ipv6 ip6table_filter ip6_tables ipv6 cpufreq_ondemand acpi_cpufreq dm_multipath uinput usb_storage arc4 ecb snd_hda_codec_realtek snd_hda_intel ath5k snd_hda_codec snd_hwdep iTCO_wdt snd_pcm iTCO_vendor_support pcspkr i2c_i801 mac80211 joydev snd_timer serio_raw r8169 snd soundcore mii snd_page_alloc ath cfg80211 ata_generic i915 drm i2c_algo_bit i2c_core video output [last unloaded: scsi_wait_scan] Sep 4 12:45:16 tuxedu kernel: Pid: 2266, comm: cat Not tainted (2.6.31-rc8 #2) Joybook Lite U101 EIP: 0060:[<c04f687a>] EFLAGS: 00010286 CPU: 0 EIP is at read_kcore+0x260/0x31a EAX: f5e5ea00 EBX: fa54d000 ECX: 00000400 EDX: 00001000 ESI: fa54c000 EDI: f44ad000 EBP: e4533f4c ESP: e4533f24 DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 Process cat (pid: 2266, ti=e4532000 task=f09d19a0 task.ti=e4532000) Stack: 00005000 00000000 f44ad000 09d9c000 00003000 fa54c000 00001000 f6d16f60 e4520b80 fffffffb e4533f70 c04ef8eb e4533f98 00008000 09d97000 c04f661a e4520b80 09d97000 c04ef88c e4533f8c c04ba531 e4533f98 c04c0930 e4520b80 Call Trace: [<c04ef8eb>] ? proc_reg_read+0x5f/0x73 [<c04f661a>] ? read_kcore+0x0/0x31a [<c04ef88c>] ? proc_reg_read+0x0/0x73 [<c04ba531>] ? vfs_read+0x82/0xe1 [<c04c0930>] ? path_put+0x1a/0x1d [<c04ba62e>] ? sys_read+0x40/0x62 [<c0403298>] ? sysenter_do_call+0x12/0x2d Code: 39 f3 89 ca 0f 43 f3 89 fb 29 f2 29 f3 39 cf 0f 46 d3 29 55 dc 8d 1c 32 f6 40 0c 01 75 18 89 d1 89 f7 c1 e9 02 2b 7d ec 03 7d e0 <f3> a5 89 d1 83 e1 03 74 02 f3 a4 8b 00 83 7d dc 00 74 04 85 c0 EIP: [<c04f687a>] read_kcore+0x260/0x31a SS:ESP 0068:e4533f24 CR2: 00000000fa54c000 To access vmalloc area which may have memory holes, copy_from_user is useful. So this: # cat /proc/kcore > /dev/null will not panic. This is a minimal fix, suitable for 2.6.30.x and 2.6.31. More extensive /proc/kcore changes are planned for 2.6.32. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Tested-by: Nick Craig-Wood <nick@craig-wood.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Reported-by: <kbowa@tuxedu.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05USB: Fix SS endpoint companion descriptor parsing.Sarah Sharp
commit 6682bb39e111b34290e25c4d275c5bcf8bbccbe1 upstream. When there's a descriptor after the SuperSpeed endpoint companion descriptor, the previous code would have skipped over twice the length it was supposed to. This code fixes crashes seen with UASP devices (which have a UASP descriptor after the SS endpoint companion descriptor). Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05USB: xhci: Support interrupt transfers.Sarah Sharp
commit 624defa12f304b4d11eda309bc207fa5a1900d0f upstream. Interrupt transfers are submitted to the xHCI hardware using the same TRB type as bulk transfers. Re-use the bulk transfer enqueueing code to enqueue interrupt transfers. Interrupt transfers are a bit different than bulk transfers. When the interrupt endpoint is to be serviced, the xHC will consume (at most) one TD. A TD (comprised of sg list entries) can take several service intervals to transmit. The important thing for device drivers to note is that if they use the scatter gather interface to submit interrupt requests, they will not get data sent from two different scatter gather lists in the same service interval. For now, the xHCI driver will use the service interval from the endpoint's descriptor (bInterval). Drivers will need a hook to poll at a more frequent interval. Set urb->interval to the interval that the xHCI hardware will use. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05USB: xhci: Set -EREMOTEIO when xHC gives bad transfer length.Sarah Sharp
commit 2f697f6cbff155b3ce4053a50cdf00b5be4dda11 upstream. The xHCI hardware reports the number of bytes untransferred for a given transfer buffer. If the hardware reports a bytes untransferred value greater than the submitted buffer size, we want to play it safe and say no data was transferred. If the driver considers a short packet to be an error, remember to set -EREMOTEIO. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05USB: xhci: Check URB_SHORT_NOT_OK before setting short packet status.Sarah Sharp
commit 204970a4bb2f584afc430ae330cd44aee329cea4 upstream. Make sure that the driver that submitted the URB considers a short packet an error before setting -EREMOTEIO during a short control transfer. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05USB: xhci: Check URB's actual transfer buffer size.Sarah Sharp
commit 99eb32db45061443ab7552b8fdceae68b90fde55 upstream. Make sure that the amount of data the xHC says was transmitted is less than or equal to the size of the requested transfer buffer. Before, if the host controller erroneously reported that the number of bytes untransferred was bigger than the buffer in the URB, urb->actual_length could be set to a very large size. Make sure urb->actual_length <= urb->transfer_buffer_length. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05USB: xhci: Don't touch xhci_td after it's freed.Sarah Sharp
commit 9191eee7b8a0e18c07c06d6da502706805cab6d2 upstream. On a successful transfer, urb->td is freed before the URB is ready to be given back to the driver. Don't touch urb->td after it's freed. This bug would have only shown up when xHCI debugging was turned on, and the freed memory was quickly reused for something else. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05USB: xhci: Handle babbling endpoints correctly.Sarah Sharp
commit 83fbcdcca03013bb5af130d6d91eba11e3d3269e upstream. The 0.95 xHCI spec says that non-control endpoints will be halted if a babble is detected on a transfer. The 0.96 xHCI spec says all types of endpoints will be halted when a babble is detected. Some hardware that claims to be 0.95 compliant halts the control endpoint anyway. When a babble is detected on a control endpoint, check the hardware's output endpoint context to see if the endpoint is marked as halted. If the control endpoint is halted, a reset endpoint command must be issued and the transfer ring dequeue pointer needs to be moved past the stopped transfer. Basically, we treat it as if the control endpoint had stalled. Handle bulk babbling endpoints as if we got a completion event with a stall completion code. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05USB: xhci: Make TRB completion code comparison readable.Sarah Sharp
commit 66d1eebce5cca916e0b08d961690bb01c64751ef upstream. Use trb_comp_code instead of getting the completion code from the transfer event every time. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05USB: xhci: Add quirk for Fresco Logic xHCI hardware.Sarah Sharp
commit ac9d8fe7c6a8041cca5a0738915d2c4e21381421 upstream. This Fresco Logic xHCI host controller chip revision puts bad data into the output endpoint context after a Reset Endpoint command. It needs a Configure Endpoint command (instead of a Set TR Dequeue Pointer command) after the reset endpoint command. Set up the input context before issuing the Reset Endpoint command so we don't copy bad data from the output endpoint context. The HW also can't handle two commands queued at once, so submit the TRB for the Configure Endpoint command in the event handler for the Reset Endpoint command. Devices that stall on control endpoints before a configuration is selected will not work under this Fresco Logic xHCI host controller revision. This patch is for prototype hardware that will be given to other companies for evaluation purposes only, and should not reach consumer hands. Fresco Logic's next chip rev should have this bug fixed. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05USB: xhci: Handle stalled control endpoints.Sarah Sharp
commit 82d1009f537c2a43be0a410abd33521f76ee3a5a upstream. When a control endpoint stalls, the next control transfer will clear the stall. The USB core doesn't call down to the host controller driver's endpoint_reset() method when control endpoints stall, so the xHCI driver has to do all its stall handling for internal state in its interrupt handler. When the host stalls on a control endpoint, it may stop on the data phase or status phase of the control transfer. Like other stalled endpoints, the xHCI driver needs to queue a Reset Endpoint command and move the hardware's control endpoint ring dequeue pointer past the failed control transfer (with a Set TR Dequeue Pointer or a Configure Endpoint command). Since the USB core doesn't call usb_hcd_reset_endpoint() for control endpoints, we need to do this in interrupt context when we get notified of the stalled transfer. URBs may be queued to the hardware before these two commands complete. The endpoint queue will be restarted once both commands complete. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05USB: xhci: Support full speed devices.Sarah Sharp
commit 2d3f1fac7ee8bb4c6fad40f838488edbeabb0c50 upstream. Full speed devices have varying max packet sizes (8, 16, 32, or 64) for endpoint 0. The xHCI hardware needs to know the real max packet size that the USB core discovers after it fetches the first 8 bytes of the device descriptor. In order to fix this without adding a new hook to host controller drivers, the xHCI driver looks for an updated max packet size for control endpoints. If it finds an updated size, it issues an evaluate context command and waits for that command to finish. This should only happen in the initialization and device descriptor fetching steps in the khubd thread, so blocking should be fine. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05USB: xhci: Set correct max packet size for HS/FS control endpoints.Sarah Sharp
commit 47aded8ade9fee6779b121b2b156235f261239d7 upstream. Set the max packet size for the default control endpoint on high speed devices to be 64 bytes. High speed devices always have a max packet size of 64 bytes. There's no use setting it to eight for the initial 8 byte descriptor fetch and then issuing (and waiting for) an evaluate context command to update it to 64 bytes for the subsequent control transfers. The USB core guesses that the max packet size on a full speed control endpoint is 64 bytes, and then updates it after the first 8-byte descriptor fetch. Change the initial setup for the xHCI internal representation of the full speed device to have a 64 byte max packet size. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05USB: xhci: Configure endpoint code refactoring.Sarah Sharp
commit f2217e8edd95b0428d8123d426e0097a5e955f9f upstream. Refactor out the code issue, wait for, and parse the event completion code for a configure endpoint command. Modify it to support the evaluate context command, which has a very similar submission process. Add functions to copy parts of the output context into the input context (which will be used in the evaluate context command). Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05USB: xhci: Fix slot and endpoint context debugging.Sarah Sharp
commit 018218d1d9eb06116d24a02dd5e7a390f0353d0f upstream. Use the virtual address of the memory hardware uses, not the address for the container of that memory. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05USB: xhci: Work around for chain bit in link TRBs.Sarah Sharp
commit b0567b3f635db72c881a0d561cebb544ec085073 upstream. Different sections of the xHCI 0.95 specification had opposing requirements for the chain bit in a link transaction request buffer (TRB). The chain bit is used to designate that adjacent TRBs are all part of the same scatter gather list that should be sent to the device. Link TRBs can be in the middle, or at the beginning or end of these chained TRBs. Sections 4.11.5.1 and 6.4.4.1 both stated the link TRB "shall have the chain bit set to 1", meaning it is always chained to the next TRB. However, section 4.6.9 on the stop endpoint command has specific cases for what the hardware must do for a link TRB with the chain bit set to 0. The 0.96 specification errata later cleared up this issue by fixing the 4.11.5.1 and 6.4.4.1 sections to state that a link TRB can have the chain bit set to 1 or 0. The problem is that the xHCI cancellation code depends on the chain bit of the link TRB being cleared when it's at the end of a TD, and some 0.95 xHCI hardware simply stops processing the ring when it encounters a link TRB with the chain bit cleared. Allow users who are testing 0.95 xHCI prototypes to set a module parameter (link_quirk) to turn on this link TRB work around. Cancellation may not work if the ring is stopped exactly on a link TRB with chain bit set, but cancellation should be a relatively uncommon case. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05USB serial: update the console driverAlan Stern
commit 7bd032dc2793afcbaf4a350056768da84cdbd89b upstream. This patch (as1292) modifies the USB serial console driver, to make it compatible with the recent changes to the USB serial core. The most important change is that serial->disc_mutex now has to be unlocked following a successful call to usb_serial_get_by_index(). Other less notable changes include: Use the requested port number instead of port 0 always. Prevent the serial device from being autosuspended. Use the ASYNCB_INITIALIZED flag bit to indicate when the port hardware has been initialized. In spite of these changes, there's no question that the USB serial console code is still a big hack. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05usb-serial: straighten out serial_openAlan Stern
commit 320348c8d5c9b591282633ddb8959b42f7fc7a1c upstream. This patch (as1291) removes a bunch of code from serial_open(), things that were rendered unnecessary by earlier patches. A missing spinlock is added to protect port->port.count, which needs to be incremented even if the open fails but not if the tty has gotten a hangup. The test for whether the hardware has been initialized, based on the use count, is replaced by a more transparent test of the ASYNCB_INITIALIZED bit in the port flags. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05usb-serial: add missing tests and debug linesAlan Stern
commit ff8324df1187b7280e507c976777df76c73a1ef1 upstream. This patch (as1290) adds some missing tests. serial_down() isn't supposed to do anything if the hardware hasn't been initialized, and serial_close() isn't supposed to do anything if the tty has gotten a hangup (because serial_hangup() takes care of shutting down the hardware). The patch also updates and adds a few debugging lines. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05usb-serial: rename subroutinesAlan Stern
commit 74556123e034c8337b69a3ebac2f3a5fc0a97032 upstream. This patch (as1289) renames serial_do_down() to serial_down() and serial_do_free() to serial_release(). It also adds a missing call to tty_shutdown() in serial_release(). Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05usb-serial: fix termios initialization logicAlan Stern
commit 7e29bb4b779f4f35385e6f21994758845bf14d23 upstream. This patch (as1288) fixes the initialization logic in serial_install(). A new tty always needs to have a termios initialized no matter what, not just in the case where the lower driver will override the termios settings. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05usb-serial: acquire references when a new tty is installedAlan Stern
commit cc56cd0157753c04a987888a2f793803df661a40 upstream. This patch (as1287) makes serial_install() be reponsible for acquiring references to the usb_serial structure and the driver module when a tty is first used. This is more sensible than having serial_open() do it, because a tty can be opened many times whereas it is installed only once, when it is created. (Not to mention that these actions are reversed when the tty is released, not when it is closed.) Finally, it is at install time that the TTY core takes its own reference to the usb_serial module, so it is only fitting that we should act the same way in regard to the lower-level serial driver. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05usb-serial: change logic of serial lookupsAlan Stern
commit 8bc2c1b2daf95029658868cb1427baea2da87139 upstream. This patch (as1286) changes usb_serial_get_by_index(). Now the routine will check whether the serial device has been disconnected; if it has then the return value will be NULL. If the device hasn't been disconnected then the routine will return with serial->disc_mutex held, so that the caller can use the structure without fear of racing against driver unloads. This permits the scope of table_mutex in destroy_serial() to be reduced. Instead of protecting the entire function, it suffices to protect the part that actually uses serial_table[], i.e., the call to return_serial(). There's no longer any danger of the refcount being incremented after it reaches 0 (which was the reason for having the large scope previously), because it can't reach 0 until the serial device has been disconnected. Also, the patch makes serial_install() check that serial is non-NULL before attempting to use it. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05usb-serial: put subroutines in logical orderAlan Stern
commit f5b0953a89fa3407fb293cc54ead7d8feec489e4 upstream. This patch (as1285) rearranges the subroutines in usb-serial.c concerned with tty lifetimes into a more logical order: install, open, hangup, close, release. It also updates the formatting of the kerneldoc comments. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05usb-serial: change referencing of port and serial structuresAlan Stern
commit 41bd34ddd7aa46dbc03b5bb33896e0fa8100fe7b upstream. This patch (as1284) changes the referencing of the usb_serial and usb_serial_port structures in usb-serial.c. It's not feasible to make the port structures keep a reference to the serial structure, because the ports need to remain in existence when serial is released -- quite a few of the drivers expect this. Consequently taking a reference to the port when the device file is open is insufficient; such a reference would not pin serial. To fix this, we now take a reference to serial when the device file is opened. The final put_device() for the ports occurs in destroy_serial(), so that the ports will last as long as they are needed. The patch initializes all the port devices, including those in the unused "fake" ports. This makes the code more uniform because they can all be released in the same way. The error handling code in usb_serial_probe() is much simplified by this approach; instead of freeing everything by hand we can use a single usb_serial_put() call. Also simplified is the port-release mechanism. Instead of being two separate routines, port_release() and port_free() can be combined into one. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05tty: USB serial termios bitsAlan Cox
commit fe1ae7fdd2ee603f2d95f04e09a68f7f79045127 upstream. Various drivers have hacks to mangle termios structures. This stems from the fact there is no nice setup hook for configuring the termios settings when the port is created Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05hwmon: (asus_atk0110) Add maintainer informationLuca Tettamanti
commit 2c2a6172afab7421f6af7e228cd3121f423ea932 upstream. Add myself as asus_atk0110 maintainer. Signed-off-by: Luca Tettamanti <kronos.it@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05tty: USB can now use the shutdown method for kref based freeing of portsAlan Cox
commit 4455e344959a217ffc28de2ab1af87541322b343 upstream. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05tty: USB hangup is racyAlan Cox
commit d2b391822a11302add9e46476f3da4e18e6de84c upstream. The USB layer uses tty_hangup to deal with unplugs of the physical hardware (analogous to loss of carrier) and then frees the resources. However the tty_hangup is asynchronous. As the hangup can sleep we can use tty_vhangup which is the non async version to avoid freeing resources too early. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-05tty: Add a full port_close functionAlan Cox
commit 7ca0ff9ab3218ec443a7a9ad247e4650373ed41e upstream. Now we are extracting out methods for shutdown and the like we can add a proper tty_port_close method that knows all the innards of the tty closing process and hides the lot from the caller. At some point in the future this will be paired with a similar open() helper and the drivers can stick to hardware management. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
