2009-01-28Linux 2.6.29-rc3v2.6.29-rc3Linus Torvalds
2009-01-28Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc/mm: Fix handling of _PAGE_COHERENT in BAT setup code powerpc/pseries: Correct VIO bus accounting problem in CMO env. powerpc: More printing warning fixes for the l64 to ll64 conversion powerpc: Remove arch/ppc cruft from Kconfig powerpc: Printing fix for l64 to ll64 conversion: phyp_dump.c powerpc/embedded6xx: Update defconfigs powerpc/8xx: Update defconfigs powerpc/86xx: Update defconfigs powerpc/83xx: Update defconfigs powerpc/85xx: Update defconfigs powerpc/mpc8313erdb: fix kernel panic because mdio device is not probed powerpc/4xx: Update multi-board PowerPC 4xx defconfigs powerpc/44x: Update PowerPC 44x defconfigs powerpc/40x: Update PowerPC 40x defconfigs powerpc/85xx: Fix typo in mpc8572ds dts powerpc/44x: Warp patches for the new NDFC driver powerpc/4xx: DTS: Add Add'l SDRAM0 Compatible and Interrupt Info
2009-01-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu: m68knommu: fix 5329 ColdFire periphal addressing uclinux: add process name to allocation error message m68knommu: correct the mii calculations for 532x ColdFire FEC m68knommu: add ColdFire M532x to the FEC configuration options m68knommu: fix syscall restarting m68knommu: remove the obsolete and long unused comempci chip support m68knommu: remove the no longer used PCI support option m68knommu: remove obsolete and unused eLIA board m68knommu: set NO_DMA m68knommu: fix cache flushing for the 527x ColdFire processors m68knommu: fix ColdFire 5272 serial baud rates in mcf.c m68knommu: use one exist from execption
2009-01-28dmi: Fix build breakageKumar Gala
Commit d7b1956fed33d30c4815e848fd7a143722916868 ("DMI: Introduce dmi_first_match to make the interface more flexible") introduced compile errors like the following when !CONFIG_DMI drivers/ata/sata_sil.c: In function 'sil_broken_system_poweroff': drivers/ata/sata_sil.c:713: error: implicit declaration of function 'dmi_first_match' drivers/ata/sata_sil.c:713: warning: initialization makes pointer from integer without a cast We just need a dummy version of dmi_first_match() to fix this all up. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-28drm: Rip out the racy, unused vblank signal code.Eric Anholt
Schedule a vblank signal, kill the process, and we'll go walking over freed memory. Given that no open-source userland exists using this, nor have I ever heard of a consumer, just let this code die. Signed-off-by: Eric Anholt <eric@anholt.net> Requested-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Dave Airlie <airlied@linux.ie> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-28powerpc/mm: Fix handling of _PAGE_COHERENT in BAT setup codeGerhard Pircher
_PAGE_COHERENT is now always set in _PAGE_RAM resp. PAGE_KERNEL. Thus it has to be masked out, if the BAT mapping should be non cacheable or CPU_FTR_NEED_COHERENT is not set. This will work on normal SMP setups because we force-set CPU_FTR_NEED_COHERENT as part of CPU_FTR_COMMON on SMP. Signed-off-by: Gerhard Pircher <gerhard_pircher@gmx.net> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-01-28powerpc/pseries: Correct VIO bus accounting problem in CMO env.Robert Jennings
In the VIO bus code the wrappers for dma alloc_coherent and free_coherent calls are rounding to IOMMU_PAGE_SIZE. Taking a look at the underlying calls, the actual mapping is promoted to PAGE_SIZE. Changing the rounding in these two functions fixes under-reporting the entitlement used by the system. Without this change, the system could run out of entitlement before it believes it has and incur mapping failures at the firmware level. Also in the VIO bus code, the wrapper for dma map_sg is not exiting in an error path where it should. Rather than fall through to code for the success case, this patch adds the return that is needed in the error path. Signed-off-by: Robert Jennings <rcj@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-01-28powerpc: More printing warning fixes for the l64 to ll64 conversionStephen Rothwell
These are all powerpc specific drivers. res.start in fsl_elbc_nand.c needs to be cast since it may be either 32 or 64 bit. Thanks to Scott Wood for noticing. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Arnd Bergmann <arnd@arndb.de> call_edac bits in particular Acked-by: Olof Johansson <olof@lixom.net> pasemi_nand peices Acked-by: Scott Wood <scottwood@freescale.com> fsl_elbc fixes Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-01-28powerpc: Remove arch/ppc cruft from KconfigJosh Boyer
Remove some leftover cruft from the arch/ppc days Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Acked-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-01-28powerpc: Printing fix for l64 to ll64 conversion: phyp_dump.cStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-01-28Merge commit 'jwb/jwb-merge' into mergeBenjamin Herrenschmidt
Manual merge of: arch/powerpc/configs/44x/warp_defconfig
2009-01-28Merge commit 'kumar/kumar-merge' into mergeBenjamin Herrenschmidt
2009-01-27smackfs load append mode fixCasey Schaufler
Given just how hard it is to find the code that uses MAY_APPEND it's probably not a big surprise that this went unnoticed for so long. The Smack rules loading code is incorrectly setting the MAY_READ bit when MAY_APPEND is requested. Signed-off-by: Casey Schaufler <casey@schaufler-ca.com> Reviewed-by: James Morris <jmorris@namei.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (36 commits) USB: Driver for Freescale QUICC Engine USB Host Controller USB: option: add QUANTA HSDPA Data Card device ids USB: storage: Add another unusual_dev for off-by-one bug USB: unusual_dev: usb-storage needs to ignore a device USB: GADGET: fix !x & y USB: new id for ti_usb_3410_5052 driver USB: cdc-acm: Add another conexant modem to the quirks USB: 'option' driver - onda device MT503HS has wrong id USB: Remove ZTE modem from unusual_devices USB: storage: support of Dane-Elec MediaTouch USB device USB: usbmon: Implement compat_ioctl USB: add kernel-doc for wusb_dev in struct usb_device USB: ftdi_sio driver support of bar code scanner from Diebold USB: ftdi_sio: added Alti-2 VID and Neptune 3 PID USB: cp2101 device USB: usblp.c: add USBLP_QUIRK_BIDIR to Brother HL-1440 USB: remove vernier labpro from ldusb USB: CDC-ACM quirk for MTK GPS USB: cdc-acm: support some gps data loggers USB: composite: Fix bug: low byte of w_index is the usb interface number not the whole 2 bytes of w_index ...
2009-01-27USB: Driver for Freescale QUICC Engine USB Host ControllerAnton Vorontsov
This patch adds support for the FHCI USB controller, as found in the Freescale MPC836x and MPC832x processors. It can support Full or Low speed modes. Quite a lot the hardware is doing by itself (SOF generation, CRC generation and checking), though scheduling and retransmission is on software's shoulders. This controller does not integrate the root hub, so this driver also fakes one-port hub. External hub is required to support more than one device. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: option: add QUANTA HSDPA Data Card device idsAlex.Cheng@quantatw.com
This patch adds the support for the QUANTA Q101 series HSDPA Data Card. With the vendor and product IDs are set properly, the data card can be detected and works fine. Signed-off-by: Alex Cheng <alex.cheng@quantatw.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: storage: Add another unusual_dev for off-by-one bugPhil Dibowitz
Argosy has released another device with the off-by-one sector. This is a harddrive with an internal cardreader which is affected. Based on a patch written by Martijn Hijdra <martijn.hijdra@gmail.com> Signed-off-by: Phil Dibowitz <phil@ipom.com> Cc: Martijn Hijdra <martijn.hijdra@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: unusual_dev: usb-storage needs to ignore a devicePhil Dibowitz
This patch adds an unusual_devs entry for a Sony Ericsson modem. Like many other modems, we have to ignore the storage device in order to access the modem. At this time usb_modeswitch does not work with this device. Reported-by: The Solutor <thesolutor@gmail.com>. Signed-off-by: Phil Dibowitz <phil@ipom.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: GADGET: fix !x & yRoel Kluin
! has a higher precedence than & Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: new id for ti_usb_3410_5052 driverOliver Neukum
This adds a new device id Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: cdc-acm: Add another conexant modem to the quirksAlan Cox
Another Conexant, another device with the same quirk Signed-off-by: Alan Cox <alan@redhat.com> Acked-by: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: 'option' driver - onda device MT503HS has wrong idMarcel Sebek
While trying to make GSM modem Onda MT503HS working, I found a mismatch between device id in the driver code (0x0200) and id in the lsusb output (0x2000). This patch fixed it for me, but I don't know if the original device id was also correct and the new ID should be added instead of replacing the old one. Signed-off-by: Marcel Sebek <sebek64@post.cz> Acked-by: Domenico Riccio <domenico.riccio@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: Remove ZTE modem from unusual_devicesPhil Dibowitz
The ZTE modem entry causes usb-storage to ignore the device, but for some versions of the device, usb-storage mode is required to get to modem ode. For both kinds the tool: http://www.draisberghof.de/usb_modeswitch/ should work. Note that the various versions of the device have the same ProductId, VendorId, and bcdDevice number, so we cannot have the entry for some and not others. Signed-off-by: Phil Dibowitz <phil@ipom.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: storage: support of Dane-Elec MediaTouch USB deviceJean-Baptiste Onofre
This adds another unusual_devs.h entry for a device that can't handle more than 64k reads/writes in a single command. Signed-off-by: Jean-Baptiste Onofre <jb@nanthrax.net> Signed-off-by: Phil Dibowitz <phil@ipom.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: usbmon: Implement compat_ioctlPete Zaitcev
Running a 32-bit usbmon(8) on 2.6.28-rc9 produces the following: ioctl32(usbmon:28563): Unknown cmd fd(3) cmd(400c9206){t:ffffff92;sz:12} arg(ffd3f458) on /dev/usbmon0 It happens because the compatibility mode was implemented for 2.6.18 and not updated for the fsops.compat_ioctl API. This patch relocates the pieces from under #ifdef CONFIG_COMPAT into compat_ioctl with no other changes except one new whitespace. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: add kernel-doc for wusb_dev in struct usb_deviceInaky Perez-Gonzalez
Reported by Randy Dunlap from a warning on the v2.6.29 merge window. Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com> Cc: David Vrabel <david.vrabel@csr.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: ftdi_sio driver support of bar code scanner from DieboldMhayk Whandson
Added the product id of bcs(bar code scanner) from Diebold Procomp Brazil. Signed-off-by: Mhayk Whandson <eu@mhayk.com.br> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: ftdi_sio: added Alti-2 VID and Neptune 3 PIDRobie Basak
This patch adds the vendor and product ID for the Alti-2 Neptune 3 (http://www.alti-2.com) which uses the FTDI chip. Signed-off-by: Robie Basak <rb-oss-1@justgohome.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: cp2101 deviceTomasz K
My girl use modem GSM (EDGE) Commanader 2 on iPlus Polsih provider, PLEASE add this vendor=0x10C4 and product=0x822B to USB serial driver cp2101.c From: Tomasz K <eros81@o2.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: usblp.c: add USBLP_QUIRK_BIDIR to Brother HL-1440Brandon Philips
My Brother HL-1440 would print one document before CUPS would stop printing with the error "Printer not connected; will retry in 30 seconds...". I traced this down to the CUPS usb backend getting an EIO out of usblp on the IOCNR_GET_DEVICE_ID IOCTL. Adding the USBLP_QUIRK_BIDIR fixes the problem but is it the right solution? output from strace /usr/lib/cups/backend/usb after printing a document (Note: SNDCTL_DSP_SYNC == IOCNR_GET_DEVICE_ID): before patch open("/dev/usb/lp0", O_RDWR|O_EXCL) = 3 ioctl(3, SNDCTL_DSP_SYNC, 0x7fff2478cef0) = -1 EIO (Input/output error) after patch open("/dev/usb/lp0", O_RDWR|O_EXCL) = 3 ioctl(3, SNDCTL_DSP_SYNC, 0x7fffb8d474c0) = 0 Possibly related bug: https://bugs.launchpad.net/ubuntu/+source/cupsys/+bug/35638 Signed-off-by: Brandon Philips <bphilips@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: remove vernier labpro from ldusbsware
Labpro device is in both ldusb and vstusb device tables. Should only be a vstusb device. Signed-off-by: stephen ware <stephen.ware@eqware.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: CDC-ACM quirk for MTK GPSAndrew Lunn
This patch adds a device quirk for a MediaTek Inc GPS chipset. The device implements USB CDC ACM, but is missing the union descriptor, so the ACM class driver fails to probe the device. I've tested this patch with an iBlue A+ GPS which uses this chipset and using kernel 2.6.28-rc9. Signed-off-by: Andrew Lunn, <andrew@lunn.ch> Acked-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: cdc-acm: support some gps data loggersJames A. Treacy
Below is a patch which allows a number of GPS loggers to work under linux. It is known to support the i-Blue 747 (all models), i-Blue 757, Qstarz BT-Q1000, i.Trek Z1, Konet BGL-32, and the Holux M-241. From: James A. Treacy <treacy@debian.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: composite: Fix bug: low byte of w_index is the usb interface number not ↵Bryan Wu
the whole 2 bytes of w_index In some usb gadget driver, for example usb audio class device, the high byte of w_index is the entity id and low byte is the interface number. If we use the 2 bytes of w_index as the array number, we will get a wrong pointer or NULL pointer. This patch fixes this issue. Signed-off-by: Bryan Wu <cooloney@kernel.org> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: composite: Fix bug: should test set_alt function pointer before use itBryan Wu
2009-01-27USB: musb: Kconfig fixDavid Brownell
The Blackfin MUSB Kconfig text didn't properly parenthesise its dependencies. This was visible in non-Blackfin configs by the way the user interfaces lost track of dependencies, when doing a bunch of test builds. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: musb cppi dma fixSwaminathan S
Initializes the actual_len field to 0 before every DMA transaction. Signed-off-by: Swaminathan S <swami.iyer@ti.com> Acked-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: musb cppi bugfixesHugo Villeneuve
These compilation errors are related to incorrect debugging macro and variable names and generated the following errors: drivers/usb/musb/cppi_dma.c:437:5: warning: "MUSB_DEBUG" is not defined drivers/usb/musb/cppi_dma.c: In function 'cppi_next_rx_segment': drivers/usb/musb/cppi_dma.c:884: error: 'debug' undeclared (first use in this function) Signed-off-by: Hugo Villeneuve <hugo@hugovil.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: musb uses endpoint functionsJulia Lawall
This set of patches introduces calls to the following set of functions: usb_endpoint_dir_in(epd) usb_endpoint_dir_out(epd) usb_endpoint_is_bulk_in(epd) usb_endpoint_is_bulk_out(epd) usb_endpoint_is_int_in(epd) usb_endpoint_is_int_out(epd) usb_endpoint_num(epd) usb_endpoint_type(epd) usb_endpoint_xfer_bulk(epd) usb_endpoint_xfer_control(epd) usb_endpoint_xfer_int(epd) usb_endpoint_xfer_isoc(epd) In some cases, introducing one of these functions is not possible, and it just replaces an explicit integer value by one of the following constants: USB_ENDPOINT_XFER_BULK USB_ENDPOINT_XFER_CONTROL USB_ENDPOINT_XFER_INT USB_ENDPOINT_XFER_ISOC An extract of the semantic patch that makes these changes is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @r1@ struct usb_endpoint_descriptor *epd; @@ - ((epd->bmAttributes & \(USB_ENDPOINT_XFERTYPE_MASK\|3\)) == - \(USB_ENDPOINT_XFER_CONTROL\|0\)) + usb_endpoint_xfer_control(epd) @r5@ struct usb_endpoint_descriptor *epd; @@ - ((epd->bEndpointAddress & \(USB_ENDPOINT_DIR_MASK\|0x80\)) == - \(USB_DIR_IN\|0x80\)) + usb_endpoint_dir_in(epd) @inc@ @@ #include <linux/usb.h> @depends on !inc && (r1||r5)@ @@ + #include <linux/usb.h> #include <linux/usb/...> // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: musb: tusb6010 buildfixKalle Valo
drivers/usb/musb/tusb6010_omap.c:18:26: error: asm/arch/dma.h: No such file or directory drivers/usb/musb/tusb6010_omap.c:19:26: error: asm/arch/mux.h: No such file or directory Signed-off-by: Kalle Valo <kalle.valo@nokia.com> Acked-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: musb free_irq bugfixAjay Kumar Gupta
Fixes insert module failure as free_irq() was not done in previous rmmod. Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com> Acked-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: musb_hdrc: another davinci buildfix (otg related)David Brownell
The DaVinci code had an implementation of the OTG transceiver glue too; make it use the new-standard one. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: musb davinci buildfixDavid Brownell
Trying once more to get this merged. The original was submitted for 2.6.27-rc2 or so, and never got correctly merged. Neither were any of the numerous subsequent resends. Sigh. CC drivers/usb/musb/davinci.o drivers/usb/musb/davinci.c:35:32: error: mach/arch/hardware.h: No such file or directory drivers/usb/musb/davinci.c:36:30: error: mach/arch/memory.h: No such file or directory drivers/usb/musb/davinci.c:37:28: error: mach/arch/gpio.h: No such file or directory drivers/usb/musb/davinci.c:373: error: redefinition of 'musb_platform_set_mode' drivers/usb/musb/davinci.c:368: error: previous definition of 'musb_platform_set_mode' was here Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Felipe Balbi <felipe.balbi@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: omap1 ohci buildfix (otg related)David Brownell
> > drivers/built-in.o: In function `ohci_omap_init': > > hid-quirks.c:(.text+0x6c608): undefined reference to `otg_get_transceiver' > > drivers/built-in.o: In function `omap_udc_probe': > > hid-quirks.c:(.init.text+0x34c0): undefined reference to `otg_get_transceiver' > > hid-quirks.c:(.init.text+0x3d40): undefined reference to `otg_put_transceiver' Reported-by: Russell King <linux@arm.linux.org.uk> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: fix char-device disconnect handlingAlan Stern
This patch (as1198) fixes a conceptual bug: Somewhere along the line we managed to confuse USB class devices with USB char devices. As a result, the code to send a disconnect signal to userspace would not be built if both CONFIG_USB_DEVICE_CLASS and CONFIG_USB_DEVICEFS were disabled. The usb_fs_classdev_common_remove() routine has been renamed to usbdev_remove() and it is now called whenever any USB device is removed, not just when a class device is unregistered. The notifier registration and unregistration calls are no longer conditionally compiled. And since the common removal code will always be called as part of the char device interface, there's no need to call it again as part of the usbfs interface; thus the invocation of usb_fs_classdev_common_remove() has been taken out of usbfs_remove_device(). Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Reported-by: Alon Bar-Lev <alon.barlev@gmail.com> Tested-by: Alon Bar-Lev <alon.barlev@gmail.com> Cc: stable <stable@kernel.org>
2009-01-27USB: Fix suspend-resume of PCI USB controllersRafael J. Wysocki
Commit a0d4922da2e4ccb0973095d8d29f36f6b1b5f703 (USB: fix up suspend and resume for PCI host controllers) attempted to fix the suspend-resume of PCI USB controllers, but unfortunately it did that incorrectly and interrupts are left enabled by the USB controllers' ->suspend_late() callback as a result. This leads to serious problems during suspend which are very difficult to debug. Fix the issue by removing the ->suspend_late() callback of PCI USB controllers and moving the code from there to the ->suspend() callback executed with interrupts enabled. Additionally, make the ->resume() callback of PCI USB controllers execute pci_enable_wake(dev, PCI_D0, false) to disable wake-up from the full power state (PCI_D0). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Tested-by: Andrey Borzenkov <arvidjaar@mail.ru> Tested-by: "Jeff Chua" <jeff.chua.linux@gmail.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: "Zdenek Kabelac" <zdenek.kabelac@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: don't enable wakeup by default for PCI host controllersAlan Stern
This patch (as1199) changes the initial wakeup settings for PCI USB host controllers. The controllers are marked as capable of waking the system, but wakeup is not enabled by default. It turns out that enabling wakeup for USB host controllers has a lot of bad consequences. As the simplest example, if a USB mouse or keyboard is unplugged immediately after the computer is put to sleep, the unplug will cause the system to wake back up again! We are better off marking them as wakeup-capable and leaving wakeup disabled. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Reported-by: Rafael J. Wysocki <rjw@sisk.pl> CC: David Brownell <david-b@pacbell.net> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: storage: add unusual devs entryOliver Neukum
This adds an unusual devs entry for 2116:0320 Signed-off-by: Oliver Neukum <oneukum@suse.de> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: fix toggle mismatch in disable_endpoint pathsAlan Stern
This patch (as1200) finishes some fixes that were left incomplete by an earlier patch. Although nobody has addressed this issue in the past, it turns out that we need to distinguish between two different modes of disabling and enabling endpoints. In one mode only the data structures in usbcore are affected, and in the other mode the host controller and device hardware states are affected as well. The earlier patch added an extra argument to the routines in the enable_endpoint pathways to reflect this difference. This patch adds corresponding arguments to the disable_endpoint pathways. Without this change, the endpoint toggle state can get out of sync between the host and the device. The exact mechanism depends on the details of the host controller (whether or not it stores its own copy of the toggle values). Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Reported-by: Dan Streetman <ddstreet@ieee.org> Tested-by: Dan Streetman <ddstreet@ieee.org> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: cp2101: add fasttrax GPS evaluation kit vendor/product IDWolfgang Glas
This adds the vendor/product ID of the fasttrax GPS evaluation kit from: http://www.fastraxgps.com/products/evaluationtools/evaluationkit/ to the cp2101 module since this device is actually equipped with a CP210x USB to serial bridge. The vendor/product ID is: 0x10c4/0x826b. Signed-off-by: Wolfgang Glas <wolfgang.glas@ev-i.at> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
