2010-05-26Linux 2.6.27.47v2.6.27.47Greg Kroah-Hartman
2010-05-26nfsd: fix vm overcommit crash fix #2Junjiro R. Okajima
commit 1b79cd04fab80be61dcd2732e2423aafde9a4c1c upstream. The previous patch from Alan Cox ("nfsd: fix vm overcommit crash", commit 731572d39fcd3498702eda4600db4c43d51e0b26) fixed the problem where knfsd crashes on exported shmemfs objects and strict overcommit is set. But the patch forgot supporting the case when CONFIG_SECURITY is disabled. This patch copies a part of his fix which is mainly for detecting a bug earlier. Acked-by: James Morris <jmorris@namei.org> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Junjiro R. Okajima <hooanon05@yahoo.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-26nfsd: fix vm overcommit crashAlan Cox
commit 731572d39fcd3498702eda4600db4c43d51e0b26 upstream. Junjiro R. Okajima reported a problem where knfsd crashes if you are using it to export shmemfs objects and run strict overcommit. In this situation the current->mm based modifier to the overcommit goes through a NULL pointer. We could simply check for NULL and skip the modifier but we've caught other real bugs in the past from mm being NULL here - cases where we did need a valid mm set up (eg the exec bug about a year ago). To preserve the checks and get the logic we want shuffle the checking around and add a new helper to the vm_ security wrappers Also fix a current->mm reference in nommu that should use the passed mm [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix build] Reported-by: Junjiro R. Okajima <hooanon05@yahoo.co.jp> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-26i2c-tiny-usb: Fix on big-endian systemsJean Delvare
commit 1c010ff8912cbc08d80e865aab9c32b6b00c527d upstream. The functionality bit vector is always returned as a little-endian 32-bit number by the device, so it must be byte-swapped to the host endianness. On the other hand, the delay value is handled by the USB stack, so no byte swapping is needed on our side. This fixes bug #15105: http://bugzilla.kernel.org/show_bug.cgi?id=15105 Reported-by: Jens Richter <jens@richter-stutensee.de> Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Jens Richter <jens@richter-stutensee.de> Cc: Till Harbaum <till@harbaum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-26i2c-i801: Don't use the block buffer for I2C block writesJean Delvare
commit c074c39d62306efa5ba7c69c1a1531bc7333d252 upstream. Experience has shown that the block buffer can only be used for SMBus (not I2C) block transactions, even though the datasheet doesn't mention this limitation. Reported-by: Felix Rubinstein <felixru@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Oleg Ryjkov <oryjkov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-26hwmon: (w83781d) Request I/O ports individually for probingJean Delvare
commit b0bcdd3cd0adb85a7686b396ba50493871b1135c upstream. Different motherboards have different PNP declarations for W83781D/W83782D chips. Some declare the whole range of I/O ports (8 ports), some declare only the useful ports (2 ports at offset 5) and some declare fancy ranges, for example 4 ports at offset 4. To properly handle all cases, request all ports individually for probing. After we have determined that we really have a W83781D or W83782D chip, the useful port range will be requested again, as a single block. I did not see a board which needs this yet, but I know of one for lm78 driver and I'd like to keep the logic of these two drivers in sync. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-26svc: Clean up deferred requests on transport destructionTom Tucker
commit 22945e4a1c7454c97f5d8aee1ef526c83fef3223 upstream. A race between svc_revisit and svc_delete_xprt can result in deferred requests holding references on a transport that can never be recovered because dead transports are not enqueued for subsequent processing. Check for XPT_DEAD in revisit to clean up completing deferrals on a dead transport and sweep a transport's deferred queue to do the same for queued but unprocessed deferrals. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Cc: roma1390 <roma1390@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-26libata: retry FS IOs even if it has failed with AC_ERR_INVALIDTejun Heo
commit 534ead709235b967b659947c55d9130873a432c4 upstream. libata currently doesn't retry if a command fails with AC_ERR_INVALID assuming that retrying won't get it any further even if retried. However, a failure may be classified as invalid through hardware glitch (incorrect reading of the error register or firmware bug) and there isn't whole lot to gain by not retrying as actually invalid commands will be failed immediately. Also, commands serving FS IOs are extremely unlikely to be invalid. Retry FS IOs even if it's marked invalid. Transient and incorrect invalid failure was seen while debugging firmware related issue on Samsung n130 on bko#14314. http://bugzilla.kernel.org/show_bug.cgi?id=14314 Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Johannes Stezenbach <js@sig21.net> Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-26libata: ensure NCQ error result taskfile is fully initialized before ↵Jeff Garzik
returning it via qc->result_tf. commit a09bf4cd53b8ab000197ef81f15d50f29ecf973c upstream. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-26i2c: Fix probing of FSC hardware monitoring chipsJean Delvare
commit b1d4b390ea4bb480e65974ce522a04022608a8df upstream. Some FSC hardware monitoring chips (Syleus at least) doesn't like quick writes we typically use to probe for I2C chips. Use a regular byte read instead for the address they live at (0x73). These are the only known chips living at this address on PC systems. For clarity, this fix should not be needed for kernels 2.6.30 and later, as we started instantiating the hwmon devices explicitly based on DMI data. Still, this fix is valuable in the following two cases: * Support for recent FSC chips on older kernels. The DMI-based device instantiation is more difficult to backport than the device support itself. * Case where the DMI-based device instantiation fails, whatever the reason. We fall back to probing in that case, so it should work. This fixes kernel bug #15634: https://bugzilla.kernel.org/show_bug.cgi?id=15634 Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-26NFS: rsize and wsize settings ignored on v4 mountsChuck Lever
commit 356e76b855bdbfd8d1c5e75bcf0c6bf0dfe83496 upstream. NFSv4 mounts ignore the rsize and wsize mount options, and always use the default transfer size for both. This seems to be because all NFSv4 mounts are now cloned, and the cloning logic doesn't copy the rsize and wsize settings from the parent nfs_server. I tested Fedora's 2.6.32.11-99 and it seems to have this problem as well, so I'm guessing that .33, .32, and perhaps older kernels have this issue as well. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-26nfs d_revalidate() is too trigger-happy with d_drop()Al Viro
commit d9e80b7de91db05c1c4d2e5ebbfd70b3b3ba0e0f upstream. If dentry found stale happens to be a root of disconnected tree, we can't d_drop() it; its d_hash is actually part of s_anon and d_drop() would simply hide it from shrink_dcache_for_umount(), leading to all sorts of fun, including busy inodes on umount and oopsen after that. Bug had been there since at least 2006 (commit c636eb already has it), so it's definitely -stable fodder. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-26USB: fix testing the wrong variable in fs_create_by_name()Dan Carpenter
commit fa7fe7af146a7b613e36a311eefbbfb5555325d1 upstream. There is a typo here. We should be testing "*dentry" which was just assigned instead of "dentry". This could result in dereferencing an ERR_PTR inside either usbfs_mkdir() or usbfs_create(). Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-26nfsd4: bug in read_bufNeil Brown
commit 2bc3c1179c781b359d4f2f3439cb3df72afc17fc upstream. When read_buf is called to move over to the next page in the pagelist of an NFSv4 request, it sets argp->end to essentially a random number, certainly not an address within the page which argp->p now points to. So subsequent calls to READ_BUF will think there is much more than a page of spare space (the cast to u32 ensures an unsigned comparison) so we can expect to fall off the end of the second page. We never encountered thsi in testing because typically the only operations which use more than two pages are write-like operations, which have their own decoding logic. Something like a getattr after a write may cross a page boundary, but it would be very unusual for it to cross another boundary after that. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-26clockevent: Prevent dead lock on clockevents_lockSuresh Siddha
This is a merge of two mainline commits, intended for stable@kernel.org submission for 2.6.27 kernel. commit f833bab87fca5c3ce13778421b1365845843b976 and commit 918aae42aa9b611a3663b16ae849fdedc67c2292 Changelog of both: Currently clockevents_notify() is called with interrupts enabled at some places and interrupts disabled at some other places. This results in a deadlock in this scenario. cpu A holds clockevents_lock in clockevents_notify() with irqs enabled cpu B waits for clockevents_lock in clockevents_notify() with irqs disabled cpu C doing set_mtrr() which will try to rendezvous of all the cpus. This will result in C and A come to the rendezvous point and waiting for B. B is stuck forever waiting for the spinlock and thus not reaching the rendezvous point. Fix the clockevents code so that clockevents_lock is taken with interrupts disabled and thus avoid the above deadlock. Also call lapic_timer_propagate_broadcast() on the destination cpu so that we avoid calling smp_call_function() in the clockevents notifier chain. This issue left us wondering if we need to change the MTRR rendezvous logic to use stop machine logic (instead of smp_call_function) or add a check in spinlock debug code to see if there are other spinlocks which gets taken under both interrupts enabled/disabled conditions. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: "Brown Len" <len.brown@intel.com> Cc: stable@kernel.org LKML-Reference: <1250544899.2709.210.camel@sbs-t61.sc.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> I got following warning on ia64 box: In function 'acpi_processor_power_verify': 642: warning: passing argument 2 of 'smp_call_function_single' from incompatible pointer type This smp_call_function_single() was introduced by a commit f833bab87fca5c3ce13778421b1365845843b976: The problem is that the lapic_timer_propagate_broadcast() has 2 versions: One is real code that modified in the above commit, and the other is NOP code that used when !ARCH_APICTIMER_STOPS_ON_C3: static void lapic_timer_propagate_broadcast(struct acpi_processor *pr) { } So I got warning because of !ARCH_APICTIMER_STOPS_ON_C3. We really want to do nothing here on !ARCH_APICTIMER_STOPS_ON_C3, so modify lapic_timer_propagate_broadcast() of real version to use smp_call_function_single() in it. Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Acked-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-26trace: Fix inappropriate substraction on tracing_pages_allocated in ↵Wang Sheng-Hui
trace_free_page() [No matching upstream git commit id as it was fixed differently due to a rewrite of the tracing code there.] For normal case, the code in trace_free_page() do once more substraction on tracing_pages_allocated, but for CONFIG_TRACER_MAX_TRACE  it doesn't take the freed page into account. That's not consistent with trace_alloc_page(). Well, for there are no message related with this, so we cannot observe its incorrect state when the kernel doesn't define "CONFIG_TRACER_MAX_TRACE". If you add some pr_info() as trace_alloc_page(), you may notice it. Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Wang Sheng-Hui <crosslonelyover@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-26megaraid_sas: fix for 32bit appsTomas Henzl
commit b3dc1a212e5167984616445990c76056034f8eeb upstream. It looks like this patch - commit 7b2519afa1abd1b9f63aa1e90879307842422dae Author: Yang, Bo <Bo.Yang@lsi.com> Date: Tue Oct 6 14:52:20 2009 -0600 [SCSI] megaraid_sas: fix 64 bit sense pointer truncation has caused a problem for 32bit programs with 64bit os - http://bugzilla.kernel.org/show_bug.cgi?id=15001 fix by converting the user space 32bit pointer to a 64 bit one when needed. [jejb: fix up some 64 bit warnings] Signed-off-by: Tomas Henzl <thenzl@redhat.com> Cc: Bo Yang <Bo.Yang@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-26tty: release_one_tty() forgets to put pidsOleg Nesterov
commit 6da8d866d0d39e9509ff826660f6a86a6757c966 upstream. release_one_tty(tty) can be called when tty still has a reference to pgrp/session. In this case we leak the pid. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Reported-by: Catalin Marinas <catalin.marinas@arm.com> Reported-and-tested-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-26vfs: Remove the range_cont writeback mode.Aneesh Kumar K.V
commit 74baaaaec8b4f22e1ae279f5ecca4ff705b28912 upstream. Ext4 was the only user of range_cont writeback mode and ext4 switched to a different method. So remove the range_cont mode which is not used in the kernel. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> CC: linux-fsdevel@vger.kernel.org Signed-off-by: Jayson R. King <dev@jaysonking.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-26ext4: Use tag dirty lookup during mpage_da_submit_ioAneesh Kumar K.V
commit af6f029d3836eb7264cd3fbb13a6baf0e5fdb5ea upstream. This enables us to drop the range_cont writeback mode use from ext4_da_writepages. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Jayson R. King <dev@jaysonking.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-26ext4: Retry block allocation if we have free blocks leftAneesh Kumar K.V
commit df22291ff0fde0d350cf15dac3e5cc33ac528875 upstream. When we truncate files, the meta-data blocks released are not reused untill we commit the truncate transaction. That means delayed get_block request will return ENOSPC even if we have free blocks left. Force a journal commit and retry block allocation if we get ENOSPC with free blocks left. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Jayson R. King <dev@jaysonking.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-26ext4: Retry block reservationAneesh Kumar K.V
commit 030ba6bc67b4f2bc5cd174f57785a1745c929abe upstream. During block reservation if we don't have enough blocks left, retry block reservation with smaller block counts. This makes sure we try fallocate and DIO with smaller request size and don't fail early. The delayed allocation reservation cannot try with smaller block count. So retry block reservation to handle temporary disk full conditions. Also print free blocks details if we fail block allocation during writepages. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Jayson R. King <dev@jaysonking.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-26ext4: Add percpu dirty block accounting.Aneesh Kumar K.V
commit 6bc6e63fcd7dac9e633ea29f1fddd9580ab28f3f upstream. This patch adds dirty block accounting using percpu_counters. Delayed allocation block reservation is now done by updating dirty block counter. In a later patch we switch to non delalloc mode if the filesystem free blocks is greater than 150% of total filesystem dirty blocks Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Mingming Cao<cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Jayson R. King <dev@jaysonking.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-26ext4: Make sure all the block allocation paths reserve blocksAneesh Kumar K.V
commit a30d542a0035b886ffaafd0057ced0a2b28c3a4f upstream. With delayed allocation we need to make sure block are reserved before we attempt to allocate them. Otherwise we get block allocation failure (ENOSPC) during writepages which cannot be handled. This would mean silent data loss (We do a printk stating data will be lost). This patch updates the DIO and fallocate code path to do block reservation before block allocation. This is needed to make sure parallel DIO and fallocate request doesn't take block out of delayed reserve space. When free blocks count go below a threshold we switch to a slow patch which looks at other CPU's accumulated percpu counter values. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Jayson R. King <dev@jaysonking.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-26percpu counter: clean up percpu_counter_sum_and_set()Mingming Cao
commit 1f7c14c62ce63805f9574664a6c6de3633d4a354 upstream. percpu_counter_sum_and_set() and percpu_counter_sum() is the same except the former updates the global counter after accounting. Since we are taking the fbc->lock to calculate the precise value of the counter in percpu_counter_sum() anyway, it should simply set fbc->count too, as the percpu_counter_sum_and_set() does. This patch merges these two interfaces into one. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Jayson R. King <dev@jaysonking.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu>
2010-05-26ext4: invalidate pages if delalloc block allocation fails.Aneesh Kumar K.V
commit c4a0c46ec92c194c873232b88debce4e1a448483 upstream. We are a bit agressive in invalidating all the pages. But it is ok because we really don't know why the block allocation failed and it is better to come of the writeback path so that user can look for more info. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Jayson R. King <dev@jaysonking.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-26ALSA: mixart: range checking proc fileDan Carpenter
commit b0cc58a25d04160d39a80e436847eaa2fbc5aa09 upstream. The original code doesn't take into consideration that the value of MIXART_BA0_SIZE - pos can be less than zero which would lead to a large unsigned value for "count". Also I moved the check that read size is a multiple of 4 bytes below the code that adjusts "count". Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01Linux 2.6.27.46v2.6.27.46Greg Kroah-Hartman
2010-04-01hwmon: (coretemp) Add missing newline to dev_warn() messageDean Nelson
commit 4d7a5644e4adfafe76c2bd8ee168e3f3b5dae3a8 upstream. Add missing newline to dev_warn() message string. This is more of an issue with older kernels that don't automatically add a newline if it was missing from the end of the previous line. Signed-off-by: Dean Nelson <dnelson@redhat.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01USB: fix usbfs regressionAlan Stern
commit 7152b592593b9d48b33f8997b1dfd6df9143f7ec upstream. This patch (as1352) fixes a bug in the way isochronous input data is returned to userspace for usbfs transfers. The entire buffer must be copied, not just the first actual_length bytes, because the individual packets will be discontiguous if any of them are short. Reported-by: Markus Rechberger <mrechberger@gmail.com> Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01tmpfs: cleanup mpol_parse_str()KOSAKI Motohiro
commit 926f2ae04f183098cf9a30521776fb2759c8afeb upstream. mpol_parse_str() made lots 'err' variable related bug. Because it is ugly and reviewing unfriendly. This patch simplifies it. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Ravikiran Thirumalai <kiran@scalex86.org> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Mel Gorman <mel@csn.ul.ie> Acked-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01doc: add the documentation for mpol=localKOSAKI Motohiro
commit 5574169613b40b85d6f4c67208fa4846b897a0a1 upstream. commit 3f226aa1c (mempolicy: support mpol=local tmpfs mount option) added new mpol=local mount option. but it didn't add a documentation. This patch does it. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Ravikiran Thirumalai <kiran@scalex86.org> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Mel Gorman <mel@csn.ul.ie> Acked-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01tmpfs: handle MPOL_LOCAL mount option properlyKOSAKI Motohiro
commit 12821f5fb942e795f8009ece14bde868893bd811 upstream. commit 71fe804b6d5 (mempolicy: use struct mempolicy pointer in shmem_sb_info) added mpol=local mount option. but its feature is broken since it was born. because such code always return 1 (i.e. mount failure). This patch fixes it. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Ravikiran Thirumalai <kiran@scalex86.org> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Mel Gorman <mel@csn.ul.ie> Acked-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01tmpfs: mpol=bind:0 don't cause mount error.KOSAKI Motohiro
commit d69b2e63e9172afb4d07c305601b79a55509ac4c upstream. Currently, following mount operation cause mount error. % mount -t tmpfs -ompol=bind:0 none /tmp Because commit 71fe804b6d5 (mempolicy: use struct mempolicy pointer in shmem_sb_info) corrupted MPOL_BIND parse code. This patch restore the needed one. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Ravikiran Thirumalai <kiran@scalex86.org> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Mel Gorman <mel@csn.ul.ie> Acked-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01tmpfs: fix oops on mounts with mpol=defaultRavikiran G Thirumalai
commit 413b43deab8377819aba1dbad2abf0c15d59b491 upstream. Fix an 'oops' when a tmpfs mount point is mounted with the mpol=default mempolicy. Upon remounting a tmpfs mount point with 'mpol=default' option, the mount code crashed with a null pointer dereference. The initial problem report was on 2.6.27, but the problem exists in mainline 2.6.34-rc as well. On examining the code, we see that mpol_new returns NULL if default mempolicy was requested. This 'NULL' mempolicy is accessed to store the node mask resulting in oops. The following patch fixes it. Signed-off-by: Ravikiran Thirumalai <kiran@scalex86.org> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Mel Gorman <mel@csn.ul.ie> Acked-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01b44 WOL setup: one-bit-off stack corruption kernel panic fixStanislav Brabec
commit e0188829cb724e7d12a2d4e343b368ff1d6e1471 upstream. About 50% of shutdowns of b44 Ethernet adapter ends by kernel panic with kernels compiled with stack-protector. Checking b44_magic_pattern() return values, one call of b44_magic_pattern() returns 127. It means, that set_bit(128, pmask) was called on line 1509. It means that bit 0 of 17th byte of pmask was overwritten. But pmask has only 16 bytes. Stack corruption happens. It seems that set_bit() on line 1509 always writes one bit off. The fix does not only solve the stack corruption, but also makes Wake On LAN working on my onboard B44 on Asus A7V-333X mainboard. It seems that this problem affects all kernel versions since commit 725ad800 ([PATCH] b44: add wol for old nic) on 2006-06-20. Signed-off-by: Stanislav Brabec <sbrabec@suse.cz> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01V4L/DVB (13961): em28xx-dvb: fix memleak in dvb_fini()Francesco Lavra
commit 19f48cb105b7fa18d0dcab435919a3a29b7a7c4c upstream. this patch fixes a memory leak which occurs when an em28xx card with DVB extension is unplugged or its DVB extension driver is unloaded. In dvb_fini(), dev->dvb must be freed before being set to NULL, as is done in dvb_init() in case of error. Note that this bug is also present in the latest stable kernel release. Signed-off-by: Francesco Lavra <francescolavra@interfree.it> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01bonding: ignore updelay param when there is no active slaveJiri Pirko
commit 41f8910040639eb106b1a5b5301aab79ecde4940 upstream. Pointed out by Sean E. Millichamp. Quote from Documentation/networking/bonding.txt: "Note that when a bonding interface has no active links, the driver will immediately reuse the first link that goes up, even if the updelay parameter has been specified (the updelay is ignored in this case). If there are slave interfaces waiting for the updelay timeout to expire, the interface that first went into that state will be immediately reused. This reduces down time of the network if the value of updelay has been overestimated, and since this occurs only in cases with no connectivity, there is no additional penalty for ignoring the updelay." This patch actually changes the behaviour in this way. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Jean Delvare <jdelvare@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01coredump: suppress uid comparison test if core output files are pipesNeil Horman
commit 76595f79d76fbe6267a51b3a866a028d150f06d4 upstream. Modify uid check in do_coredump so as to not apply it in the case of pipes. This just got noticed in testing. The end of do_coredump validates the uid of the inode for the created file against the uid of the crashing process to ensure that no one can pre-create a core file with different ownership and grab the information contained in the core when they shouldn' tbe able to. This causes failures when using pipes for a core dumps if the crashing process is not root, which is the uid of the pipe when it is created. The fix is simple. Since the check for matching uid's isn't relevant for pipes (a process can't create a pipe that the uermodehelper code will open anyway), we can just just skip it in the event ispipe is non-zero Reverts a pipe-affecting change which was accidentally made in : commit c46f739dd39db3b07ab5deb4e3ec81e1c04a91af : Author: Ingo Molnar <mingo@elte.hu> : AuthorDate: Wed Nov 28 13:59:18 2007 +0100 : Commit: Linus Torvalds <torvalds@woody.linux-foundation.org> : CommitDate: Wed Nov 28 10:58:01 2007 -0800 : : vfs: coredumping fix Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: maximilian attems <max@stro.at> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01x86, ia32_aout: do not kill argument mappingJiri Slaby
commit 318f6b228ba88a394ef560efc1bfe028ad5ae6b6 upstream. Do not set current->mm->mmap to NULL in 32-bit emulation on 64-bit load_aout_binary after flush_old_exec as it would destroy already set brpm mapping with arguments. Introduced by b6a2fea39318e43fee84fa7b0b90d68bed92d2ba mm: variable length argument support where the argument mapping in bprm was added. [ hpa: this is a regression from 2.6.22... time to kill a.out? ] Signed-off-by: Jiri Slaby <jslaby@suse.cz> LKML-Reference: <1265831716-7668-1-git-send-email-jslaby@suse.cz> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ollie Wild <aaw@google.com> Cc: x86@kernel.org Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01fix LOOKUP_FOLLOW on automount "symlinks"Al Viro
commit ac278a9c505092dd82077a2446af8f9fc0d9c095 upstream. Make sure that automount "symlinks" are followed regardless of LOOKUP_FOLLOW; it should have no effect on them. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01KVM: x86: check for cr3 validity in ioctl_set_sregsMarcelo Tosatti
commit 59839dfff5eabca01cc4e20b45797a60a80af8cb upstream. Matt T. Yourst notes that kvm_arch_vcpu_ioctl_set_sregs lacks validity checking for the new cr3 value: "Userspace callers of KVM_SET_SREGS can pass a bogus value of cr3 to the kernel. This will trigger a NULL pointer access in gfn_to_rmap() when userspace next tries to call KVM_RUN on the affected VCPU and kvm attempts to activate the new non-existent page table root. This happens since kvm only validates that cr3 points to a valid guest physical memory page when code *inside* the guest sets cr3. However, kvm currently trusts the userspace caller (e.g. QEMU) on the host machine to always supply a valid page table root, rather than properly validating it along with the rest of the reloaded guest state." http://sourceforge.net/tracker/?func=detail&atid=893831&aid=2687641&group_id=180599 Check for a valid cr3 address in kvm_arch_vcpu_ioctl_set_sregs, triple fault in case of failure. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01parisc: isa-eeprom - Fix loff_t usageMichael Buesch
commit 6b4dbcd86a9d464057fcc7abe4d0574093071fcc upstream. loff_t is a signed type. If userspace passes a negative ppos, the "count" range check is weakened. "count"s bigger than HPEE_MAX_LENGTH will pass the check. Also, if ppos is negative, the readb(eisa_eeprom_addr + *ppos) will poke in random memory. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01tc: Fix unitialized kernel memory leakEric Dumazet
commit 16ebb5e0b36ceadc8186f71d68b0c4fa4b6e781b upstream. Three bytes of uninitialized kernel memory are currently leaked to user Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Reviewed-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01drm/r128: Add test for initialisation to all ioctls that require itBen Hutchings
commit 7dc482dfeeeefcfd000d4271c4626937406756d7 upstream. Almost all r128's private ioctls require that the CCE state has already been initialised. However, most do not test that this has been done, and will proceed to dereference a null pointer. This may result in a security vulnerability, since some ioctls are unprivileged. This adds a macro for the common initialisation test and changes all ioctl implementations that require prior initialisation to use that macro. Also, r128_do_init_cce() does not test that the CCE state has not been initialised already. Repeated initialisation may lead to a crash or resource leak. This adds that test. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01KVM: VMX: Check cpl before emulating debug register accessAvi Kivity
commit 0a79b009525b160081d75cef5dbf45817956acf2 upstream. Debug registers may only be accessed from cpl 0. Unfortunately, vmx will code to emulate the instruction even though it was issued from guest userspace, possibly leading to an unexpected trap later. Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01ext4: Avoid null pointer dereference when decoding EROFS w/o a journalTheodore Ts'o
commit 78f1ddbb498283c2445c11b0dfa666424c301803 upstream. We need to check to make sure a journal is present before checking the journal flags in ext4_decode_error(). Signed-off-by: Eric Sesterhenn <eric.sesterhenn@lsexperts.de> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01KVM: x86 emulator: limit instructions to 15 bytesAvi Kivity
commit eb3c79e64a70fb8f7473e30fa07e89c1ecc2c9bb upstream [ <cebbert@redhat.com>: backport to 2.6.27 ] While we are never normally passed an instruction that exceeds 15 bytes, smp games can cause us to attempt to interpret one, which will cause large latencies in non-preempt hosts. Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01USB: EHCI: fix counting of transaction error retriesAlan Stern
commit ef4638f955f2c4a667c8af20769d03f5ed3781ca upstream. This patch (as1274) simplifies the counting of transaction-error retries. Now we will count up from 0 to QH_XACTERR_MAX instead of down from QH_XACTERR_MAX to 0. The patch also fixes a small bug: qh->xacterr was not getting initialized for interrupt endpoints. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Tested-by: Matthijs Kooijman <matthijs@stdin.nl> Cc: Reinoud Koornstra <koornstra@hp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01USB: usbfs: properly clean up the as structure on error pathsLinus Torvalds
commit ddeee0b2eec2a51b0712b04de4b39e7bec892a53 upstream. I notice that the processcompl_compat() function seems to be leaking the 'struct async *as' in the error paths. I think that the calling convention is fundamentally buggered. The caller is the one that did the "reap_as()" to get the as thing, the caller should be the one to free it too. Freeing it in the caller also means that it very clearly always gets freed, and avoids the need for any "free in the error case too". From: Linus Torvalds <torvalds@linux-foundation.org> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Marcus Meissner <meissner@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
