2009-09-24Linux 2.6.27.35v2.6.27.35Greg Kroah-Hartman
2009-09-24nfsd: fix hung up of nfs client while sync write data to nfs serverWei Yongjun
commit a0d24b295aed7a9daf4ca36bd4784e4d40f82303 upstream. nfsd: fix hung up of nfs client while sync write data to nfs server Commit 'Short write in nfsd becomes a full write to the client' (31dec2538e45e9fff2007ea1f4c6bae9f78db724) broken the sync write. With the following commands to reproduce: $ mount -t nfs -o sync 192.168.0.21:/nfsroot /mnt $ cd /mnt $ echo aaaa > temp.txt Then nfs client is hung up. In SYNC mode the server alaways return the write count 0 to the client. This is because the value of host_err in nfsd_vfs_write() will be overwrite in SYNC mode by 'host_err=nfsd_sync(file);', and then we return host_err(which is now 0) as write count. This patch fixed the problem. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Cc: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-24Short write in nfsd becomes a full write to the clientDavid Shaw
commit 31dec2538e45e9fff2007ea1f4c6bae9f78db724 upstream. Short write in nfsd becomes a full write to the client If a filesystem being written to via NFS returns a short write count (as opposed to an error) to nfsd, nfsd treats that as a success for the entire write, rather than the short count that actually succeeded. For example, given a 8192 byte write, if the underlying filesystem only writes 4096 bytes, nfsd will ack back to the nfs client that all 8192 bytes were written. The nfs client does have retry logic for short writes, but this is never called as the client is told the complete write succeeded. There are probably other ways it could happen, but in my case it happened with a fuse (filesystem in userspace) filesystem which can rather easily have a partial write. Here is a patch to properly return the short write count to the client. Signed-off-by: David Shaw <dshaw@jabberwocky.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Cc: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-24sound: oxygen: work around MCE when changing volumeClemens Ladisch
commit f1bc07af9a9edc5c1d4bdd971f7099316ed2e405 upstream. When the volume is changed continuously (e.g., when the user drags a volume slider with the mouse), the driver does lots of I2C writes. Apparently, the sound chip can get confused when we poll the I2C status register too much, and fails to complete a read from it. On the PCI-E models, the PCI-E/PCI bridge gets upset by this and generates a machine check exception. To avoid this, this patch replaces the polling with an unconditional wait that is guaranteed to be long enough. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Tested-by: Johann Messner <johann.messner at jku.at> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-24powerpc/pseries: Fix to handle slb resize across migrationBrian King
commit 46db2f86a3b2a94e0b33e0b4548fb7b7b6bdff66 upstream. The SLB can change sizes across a live migration, which was not being handled, resulting in possible machine crashes during migration if migrating to a machine which has a smaller max SLB size than the source machine. Fix this by first reducing the SLB size to the minimum possible value, which is 32, prior to migration. Then during the device tree update which occurs after migration, we make the call to ensure the SLB gets updated. Also add the slb_size to the lparcfg output so that the migration tools can check to make sure the kernel has this capability before allowing migration in scenarios where the SLB size will change. BenH: Fixed #include <asm/mmu-hash64.h> -> <asm/mmu.h> to avoid breaking ppc32 build Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-24libata: fix off-by-one error in ata_tf_read_block()Tejun Heo
commit ac8672ea922bde59acf50eaa1eaa1640a6395fd2 upstream. ata_tf_read_block() has off-by-one error when converting CHS address to LBA. The bug isn't very visible because ata_tf_read_block() is used only when generating sense data for a failed RW command and CHS addressing isn't used too often these days. This problem was spotted by Atsushi Nemoto. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-24ALSA: cs46xx - Fix minimum period sizeSophie Hamilton
commit 6148b130eb84edc76e4fa88da1877b27be6c2f06 upstream. Fix minimum period size for cs46xx cards. This fixes a problem in the case where neither a period size nor a buffer size is passed to ALSA; this is the case in Audacious, OpenAL, and others. Signed-off-by: Sophie Hamilton <kernel@theblob.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-24udf: Use device size when drive reported bogus number of written blocksJan Kara
commit 24a5d59f3477bcff4c069ff4d0ca9a3e037d0235 upstream. Some drives report 0 as the number of written blocks when there are some blocks recorded. Use device size in such case so that we can automagically mount such media. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-24TPM: Fixup boot probe timeout for tpm_tis driverJason Gunthorpe
commit ec57935837a78f9661125b08a5d08b697568e040 upstream. When probing the device in tpm_tis_init the call request_locality uses timeout_a, which wasn't being initalized until after request_locality. This results in request_locality falsely timing out if the chip is still starting. Move the initialization to before request_locality. This probably only matters for embedded cases (ie mine), a BIOS likely gets the TPM into a state where this code path isn't necessary. Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Acked-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-24powerpc/ps3: Workaround for flash memory I/O errorGeoff Levand
commit bc00351edd5c1b84d48c3fdca740fedfce4ae6ce upstream. A workaround for flash memory I/O errors when the PS3 internal hard disk has not been formatted for OtherOS use. This error condition mainly effects 'Live CD' users who have not formatted the PS3's internal hard disk for OtherOS. Fixes errors similar to these when using the ps3-flash-util or ps3-boot-game-os programs: ps3flash read failed 0x2050000 os_area_header_read: read error: os_area_header: Input/output error main:627: os_area_read_hp error. ERROR: can't change boot flag Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-24binfmt_elf: fix PT_INTERP bss handlingRoland McGrath
commit 9f0ab4a3f0fdb1ff404d150618ace2fa069bb2e1 upstream. In fs/binfmt_elf.c, load_elf_interp() calls padzero() for .bss even if the PT_LOAD has no PROT_WRITE and no .bss. This generates EFAULT. Here is a small test case. (Yes, there are other, useful PT_INTERP which have only .text and no .data/.bss.) ----- ptinterp.S _start: .globl _start nop int3 ----- $ gcc -m32 -nostartfiles -nostdlib -o ptinterp ptinterp.S $ gcc -m32 -Wl,--dynamic-linker=ptinterp -o hello hello.c $ ./hello Segmentation fault # during execve() itself After applying the patch: $ ./hello Trace trap # user-mode execution after execve() finishes If the ELF headers are actually self-inconsistent, then dying is fine. But having no PROT_WRITE segment is perfectly normal and correct if there is no segment with p_memsz > p_filesz (i.e. bss). John Reiser suggested checking for PROT_WRITE in the bss logic. I think it makes most sense to simply apply the bss logic only when there is bss. This patch looks less trivial than it is due to some reindentation. It just moves the "if (last_bss > elf_bss) {" test up to include the partial-page bss logic as well as the more-pages bss logic. Reported-by: John Reiser <jreiser@bitwagon.com> Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-15Linux 2.6.27.34v2.6.27.34Greg Kroah-Hartman
2009-09-15slub: Fix kmem_cache_destroy() with SLAB_DESTROY_BY_RCUEric Dumazet
commit d76b1590e06a63a3d8697168cd0aabf1c4b3cb3a upstream. kmem_cache_destroy() should call rcu_barrier() *after* kmem_cache_close() and *before* sysfs_slab_remove() or risk rcu_free_slab() being called after kmem_cache is deleted (kfreed). rmmod nf_conntrack can crash the machine because it has to kmem_cache_destroy() a SLAB_DESTROY_BY_RCU enabled cache. Reported-by: Zdenek Kabelac <zdenek.kabelac@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-15JFFS2: add missing verify buffer allocation/deallocationMassimo Cirillo
commit bc8cec0dff072f1a45ce7f6b2c5234bb3411ac51 upstream. The function jffs2_nor_wbuf_flash_setup() doesn't allocate the verify buffer if CONFIG_JFFS2_FS_WBUF_VERIFY is defined, so causing a kernel panic when that macro is enabled and the verify function is called. Similarly the jffs2_nor_wbuf_flash_cleanup() must free the buffer if CONFIG_JFFS2_FS_WBUF_VERIFY is enabled. The following patch fixes the problem. The following patch applies to 2.6.30 kernel. Signed-off-by: Massimo Cirillo <maxcir@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-15net: net_assign_generic() fixEric Dumazet
[ Upstream commit 144586301f6af5ae5943a002f030d8c626fa4fdd ] memcpy() should take into account size of pointers, not only number of pointers to copy. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-15E100: fix interaction with swiotlb on X86.Krzysztof Hałasa
[ Upstream commit 6ff9c2e7fa8ca63a575792534b63c5092099c286 ] E100 places it's RX packet descriptors inside skb->data and uses them with bidirectional streaming DMA mapping. Data in descriptors is accessed simultaneously by the chip (writing status and size when a packet is received) and CPU (reading to check if the packet was received). This isn't a valid usage of PCI DMA API, which requires use of the coherent (consistent) memory for such purpose. Unfortunately e100 chips working in "simplified" RX mode have to store received data directly after the descriptor. Fixing the driver to conform to the API would require using unsupported "flexible" RX mode or receiving data into a coherent memory and using CPU to copy it to network buffers. This patch, while not yet making the driver conform to the PCI DMA API, allows it to work correctly on X86 with swiotlb (while not breaking other architectures). Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-09Linux 2.6.27.33v2.6.27.33Greg Kroah-Hartman
2009-09-09OCFS2: fix build errorGreg Kroah-Hartman
Somehow a previous patch did not get committed correctly. This fixes the build. Thanks to Jayson King, Michael Tokarev, Joel Becker, and Chuck Ebbert for pointing out the problem, and the solution. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-08Linux 2.6.27.32v2.6.27.32Greg Kroah-Hartman
2009-09-08ocfs2: ocfs2_write_begin_nolock() should handle len=0Sunil Mushran
commit 8379e7c46cc48f51197dd663fc6676f47f2a1e71 upstream. Bug introduced by mainline commit e7432675f8ca868a4af365759a8d4c3779a3d922 The bug causes ocfs2_write_begin_nolock() to oops when len=0. Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-08SUNRPC: Fix tcp reconnectionTrond Myklebust
This fixes a problem that was reported as Red Hat Bugzilla entry number 485339, in which rpciod starts looping on the TCP connection code, rendering the NFS client unusable for 1/2 minute or so. It is basically a backport of commit f75e6745aa3084124ae1434fd7629853bdaf6798 (SUNRPC: Fix the problem of EADDRNOTAVAIL syslog floods on reconnect) Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-08SCSI: sr: report more accurate drive status after closing the tray.Peter Jones
commit 96bcc722c47d07b6fd05c9d0cb3ab8ea5574c5b1 upstream [SCSI] sr: report more accurate drive status after closing the tray. So, what's happening here is that the drive is reporting a sense of 2/4/1 ("logical unit is becoming ready") from sr_test_unit_ready(), and then we ask for the media event notification before checking that result at all. The check_media_event_descriptor() call isn't getting a check condition, but it's also reporting that the tray is closed and that there's no media. In actuality it doesn't yet know if there's media or not, but there's no way to express that in the media event status field. My current thought is that if it told us the device isn't yet ready, we should return that immediately, since there's nothing that'll tell us any more data than that reliably: Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-08Remove low_latency flag setting from nozomi and mxser driversChuck Ebbert
commit 4d8d4d251df8eaaa3dae71c8cfa7fbf4510d967d upstream [ cebbert@redhat.com: backport to 2.6.27 ] Remove low_latency flag setting from nozomi and mxser drivers The kernel oopses if this flag is set. [and neither driver should set it as they call tty_flip_buffer_push from IRQ paths so have always been buggy] Signed-off-by: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-08USB: removal of tty->low_latency hack dating back to the old serial codeOliver Neukum
commit 2400a2bfbd0e912193fe3b077f492d4980141813 upstream [ cebbert@redhat.com: backport to 2.6.27 ] USB: removal of tty->low_latency hack dating back to the old serial code This removes tty->low_latency from all USB serial drivers that push data into the tty layer at hard interrupt context. It's no longer needed and actually harmful. Signed-off-by: Oliver Neukum <oliver@neukum.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-08parport: quickfix the proc registration bugAlan Cox
commit 05ad709d04799125ed85dd816fdb558258102172 upstream parport: quickfix the proc registration bug Ideally we should have a directory of drivers and a link to the 'active' driver. For now just show the first device which is effectively the existing semantics without a warning. This is an update on the original buggy patch that I then forgot to resubmit. Confusingly it was proposed by Red Hat, written by Etched Pixels fixed and submitted by Intel ... Resolves-Bug: http://bugzilla.kernel.org/show_bug.cgi?id=9749 Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-08ALSA: hda - Add missing vmaster initialization for ALC269Takashi Iwai
commit 100d5eb36ba20dc0b99a17ea2b9800c567bfc3d1 upstream. Without the initialization of vmaster NID, the dB information got confused for ALC269 codec. Reference: Novell bnc#527361 https://bugzilla.novell.com/show_bug.cgi?id=527361 Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-08rose: Fix rose_getname() leakEric Dumazet
commit 17ac2e9c58b69a1e25460a568eae1b0dc0188c25 upstream. rose_getname() can leak kernel memory to user. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-08ocfs2: Initialize the cluster we're writing to in a non-sparse extendSunil Mushran
commit e7432675f8ca868a4af365759a8d4c3779a3d922 upstream. In a non-sparse extend, we correctly allocate (and zero) the clusters between the old_i_size and pos, but we don't zero the portions of the cluster we're writing to outside of pos<->len. It handles clustersize > pagesize and blocksize < pagesize. [Cleaned up by Joel Becker.] Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-08netrom: Fix nr_getname() leakEric Dumazet
commit f6b97b29513950bfbf621a83d85b6f86b39ec8db upstream. nr_getname() can leak kernel memory to user. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-08NET: llc, zero sockaddr_llc structJiri Slaby
commit 28e9fc592cb8c7a43e4d3147b38be6032a0e81bc upstream. sllc_arphrd member of sockaddr_llc might not be changed. Zero sllc before copying to the above layer's structure. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-08kthreads: fix kthread_create() vs kthread_stop() raceOleg Nesterov
The bug should be "accidently" fixed by recent changes in 2.6.31, all kernels <= 2.6.30 need the fix. The problem was never noticed before, it was found because it causes mysterious failures with GFS mount/umount. Credits to Robert Peterson. He blaimed kthread.c from the very beginning. But, despite my promise, I forgot to inspect the old implementation until he did a lot of testing and reminded me. This led to huge delay in fixing this bug. kthread_stop() does put_task_struct(k) before it clears kthread_stop_info.k. This means another kthread_create() can re-use this task_struct, but the new kthread can still see kthread_should_stop() == T and exit even without calling threadfn(). Reported-by: Robert Peterson <rpeterso@redhat.com> Tested-by: Robert Peterson <rpeterso@redhat.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-08irda: Fix irda_getname() leakEric Dumazet
commit 09384dfc76e526c3993c09c42e016372dc9dd22c upstream. irda_getname() can leak kernel memory to user. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-08econet: Fix econet_getname() leakEric Dumazet
commit 80922bbb12a105f858a8f0abb879cb4302d0ecaa upstream. econet_getname() can leak kernel memory to user. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-08do_sigaltstack: avoid copying 'stack_t' as a structure to user spaceLinus Torvalds
commit 0083fc2c50e6c5127c2802ad323adf8143ab7856 upstream. Ulrich Drepper correctly points out that there is generally padding in the structure on 64-bit hosts, and that copying the structure from kernel to user space can leak information from the kernel stack in those padding bytes. Avoid the whole issue by just copying the three members one by one instead, which also means that the function also can avoid the need for a stack frame. This also happens to match how we copy the new structure from user space, so it all even makes sense. [ The obvious solution of adding a memset() generates horrid code, gcc does really stupid things. ] Reported-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-08can: Fix raw_getname() leakEric Dumazet
commit e84b90ae5eb3c112d1f208964df1d8156a538289 upstream. raw_getname() can leak 10 bytes of kernel memory to user (two bytes hole between can_family and can_ifindex, 8 bytes at the end of sockaddr_can structure) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Oliver Hartkopp <oliver@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-08appletalk: fix atalk_getname() leakEric Dumazet
commit 3d392475c873c10c10d6d96b94d092a34ebd4791 upstream. atalk_getname() can leak 8 bytes of kernel memory to user Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-08KVM: MMU: protect kvm_mmu_change_mmu_pages with mmu_lockMarcelo Tosatti
(cherry picked from commit 7c8a83b75a38a807d37f5a4398eca2a42c8cf513) kvm_handle_hva, called by MMU notifiers, manipulates mmu data only with the protection of mmu_lock. Update kvm_mmu_change_mmu_pages callers to take mmu_lock, thus protecting against kvm_handle_hva. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-08KVM: x86: check for cr3 validity in mmu_alloc_rootsMarcelo Tosatti
(cherry picked from commit 8986ecc0ef58c96eec48d8502c048f3ab67fd8e2) Verify the cr3 address stored in vcpu->arch.cr3 points to an existant memslot. If not, inject a triple fault. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-08KVM: Fix dirty bit tracking for slots with large pagesIzik Eidus
(cherry picked from commit e244584fe3a5c20deddeca246548ac86dbc6e1d1) When slot is already allocated and being asked to be tracked we need to break the large pages. This code flush the mmu when someone ask a slot to start dirty bit tracking. Signed-off-by: Izik Eidus <ieidus@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-08KVM: MMU: do not free active mmu pages in free_mmu_pages()Gleb Natapov
(cherry picked from commit f00be0cae4e6ad0a8c7be381c6d9be3586800b3e) free_mmu_pages() should only undo what alloc_mmu_pages() does. Free mmu pages from the generic VM destruction function, kvm_destroy_vm(). Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-08KVM: Fix PDPTR reloading on CR4 writesAvi Kivity
(cherry picked from commit a2edf57f510cce6a389cc14e58c6ad0a4296d6f9) The processor is documented to reload the PDPTRs while in PAE mode if any of the CR4 bits PSE, PGE, or PAE change. Linux relies on this behaviour when zapping the low mappings of PAE kernels during boot. The code already handled changes to CR4.PAE; augment it to also notice changes to PSE and PGE. This triggered while booting an F11 PAE kernel; the futex initialization code runs before any CR3 reloads and writes to a NULL pointer; the futex subsystem ended up uninitialized, killing PI futexes and pulseaudio which uses them. Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-08KVM: Make paravirt tlb flush also reload the PAE PDPTRsAvi Kivity
(cherry picked from commit a8cd0244e9cebcf9b358d24c7e7410062f3665cb) The paravirt tlb flush may be used not only to flush TLBs, but also to reload the four page-directory-pointer-table entries, as it is used as a replacement for reloading CR3. Change the code to do the entire CR3 reloading dance instead of simply flushing the TLB. Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-08KVM: VMX: Handle vmx instruction vmexitsAvi Kivity
(cherry picked from commit e3c7cb6ad7191e92ba89d00a7ae5f5dd1ca0c214) IF a guest tries to use vmx instructions, inject a #UD to let it know the instruction is not implemented, rather than crashing. This prevents guest userspace from crashing the guest kernel. Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-08KVM: Make EFER reads safe when EFER does not existAvi Kivity
(cherry picked from commit e286e86e6d2042d67d09244aa0e05ffef75c9d54) Some processors don't have EFER; don't oops if userspace wants us to read EFER when we check NX. Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-08KVM: SVM: Remove port 80 passthroughAvi Kivity
(cherry picked from commit 99f85a28a78e96d28907fe036e1671a218fee597) KVM optimizes guest port 80 accesses by passthing them through to the host. Some AMD machines die on port 80 writes, allowing the guest to hard-lock the host. Remove the port passthrough to avoid the problem. Reported-by: Piotr Jaroszyński <p.jaroszynski@gmail.com> Tested-by: Piotr Jaroszyński <p.jaroszynski@gmail.com> Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-08KVM: VMX: Don't allow uninhibited access to EFER on i386Avi Kivity
(cherry picked from commit 16175a796d061833aacfbd9672235f2d2725df65) vmx_set_msr() does not allow i386 guests to touch EFER, but they can still do so through the default: label in the switch. If they set EFER_LME, they can oops the host. Fix by having EFER access through the normal channel (which will check for EFER_LME) even on i386. Reported-and-tested-by: Benjamin Gilbert <bgilbert@cs.cmu.edu> Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-08KVM: Don't destroy vcpu in case vcpu_setup failsGlauber Costa
(cherry picked from commit 7d8fece678c1abc2ca3e1ceda2277c3538a9161c) One of vcpu_setup responsibilities is to do mmu initialization. However, in case we fail in kvm_arch_vcpu_reset, before we get the chance to init mmu. OTOH, vcpu_destroy will attempt to destroy mmu, triggering a bug. Keeping track of whether or not mmu is initialized would unnecessarily complicate things. Rather, we just make return, making sure any needed uninitialization is done before we return, in case we fail. Signed-off-by: Glauber Costa <glommer@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-08KVM: VMX: Set IGMT bit in EPT entrySheng Yang
(cherry picked from commit 928d4bf747e9c290b690ff515d8f81e8ee226d97) There is a potential issue that, when guest using pagetable without vmexit when EPT enabled, guest would use PAT/PCD/PWT bits to index PAT msr for it's memory, which would be inconsistent with host side and would cause host MCE due to inconsistent cache attribute. The patch set IGMT bit in EPT entry to ignore guest PAT and use WB as default memory type to protect host (notice that all memory mapped by KVM should be WB). Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-08KVM: MMU: increase per-vcpu rmap cache alloc sizeMarcelo Tosatti
(cherry picked from commit c41ef344de212bd918f7765af21b5008628c03e0) The page fault path can use two rmap_desc structures, if: - walk_addr's dirty pte update allocates one rmap_desc. - mmu_lock is dropped, sptes are zapped resulting in rmap_desc being freed. - fetch->mmu_set_spte allocates another rmap_desc. Increase to 4 for safety. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-08KVM: set debug registers after "schedulable" sectionMarcelo Tosatti
(cherry picked from commit 29415c37f043d1d54dcf356601d738ff6633b72b) The vcpu thread can be preempted after the guest_debug_pre() callback, resulting in invalid debug registers on the new vcpu. Move it inside the non-preemptable section. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@qumranet.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
