commit 82e68f7ffec3800425f2391c8c86277606860442 upstream
snd_seq_oss_synth_make_info() incorrectly reports information
to userspace without first checking for the validity of the
device number, leading to possible information leak (CVE-2008-3272).
Reported-By: Tobias Klein <tk@trapkit.de>
Acked-and-tested-by: Takashi Iwai <tiwai@suse.de>
Cc: stable@kernel.org
Signed-off-by: Willy Tarreau <w@1wt.eu>
commit 10488f8ad62be3b860bad74e60b4fe6ab87aece3 upstream
Don't forget to kill tasklets on stop to not panic if they
fire after freeing some structures.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Acked-by: Nick Kossifidis <mickflemm@gmail.com>
Cc: Luis R. Rodriguez <mcgrof@gmail.com>
commit 3a0f2c871849f23c1070965bf94dec3f9c0b479d upstream
When signal is noisy, hardware can use all RX buffers and since the last
entry in the list is self-linked, it overwrites the entry until we link
new buffers.
Ensure that we don't free this last one until we are 100% sure that it
is not used by the hardware anymore to not cause memory curruption as
can be seen below.
This is done by checking next buffer in the list. Even after that we
know that the hardware refetched the new link and proceeded further
(the next buffer is ready) we can finally free the overwritten buffer.
We discard it since the status in its descriptor is overwritten (OR-ed
by new status) too.
BUG kmalloc-4096: Poison overwritten
INFO: 0xffff810067419060-0xffff810067419667. First byte 0x8 instead of 0x6b
INFO: Allocated in dev_alloc_skb+0x18/0x30 age=1118 cpu=1 pid=0
INFO: Freed in skb_release_data+0x85/0xd0 age=1105 cpu=1 pid=3718
INFO: Slab 0xffffe200019d0600 objects=7 used=0 fp=0xffff810067419048 flags=0x40000000000020c3
INFO: Object 0xffff810067419048 @offset=4168 fp=0xffff81006741c120
Bytes b4 0xffff810067419038: 4f 0b 02 00 01 00 00 00 5a 5a 5a 5a 5a 5a 5a 5a O.......ZZZZZZZZ
Object 0xffff810067419048: 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b 6b kkkkkkkkkkkkkkkk
Object 0xffff810067419058: 6b 6b 6b 6b 6b 6b 6b 6b 08 42 30 00 00 0b 6b 80 kkkkkkkk.B0...k.
Object 0xffff810067419068: f0 5d 00 4f 62 08 a3 64 00 0c 42 16 52 e4 f0 5a 360].Ob.243d..B.R344360Z
Object 0xffff810067419078: 68 81 00 00 7b a5 b4 be 7d 3b 8f 53 cd d5 de 12 h...{245264276};.S315325336.
Object 0xffff810067419088: 96 10 0b 89 48 54 23 41 0f 4e 2d b9 37 c3 cb 29 ....HT#A.N-2717303313)
Object 0xffff810067419098: d1 e0 de 14 8a 57 2a cc 3b 44 0d 78 7a 19 12 15 321340336..W*314;D.xz...
Object 0xffff8100674190a8: a9 ec d4 35 a8 10 ec 8c 40 a7 06 0a 51 a7 48 bb 2513543245250.354.@247..Q247H273
Object 0xffff8100674190b8: 3e cf a1 c7 38 60 63 3f 51 15 c7 20 eb ba 65 30 >ϡ3078`c?Q.307.353272e0
Redzone 0xffff81006741a048: bb bb bb bb bb bb bb bb 273273273273273273273273
Padding 0xffff81006741a088: 5a 5a 5a 5a 5a 5a 5a 5a ZZZZZZZZ
Pid: 3297, comm: ath5k_pci Not tainted 2.6.26-rc8-mm1_64 #427
Call Trace:
[<ffffffff802a7306>] print_trailer+0xf6/0x150
[<ffffffff802a7485>] check_bytes_and_report+0x125/0x180
[<ffffffff802a75dc>] check_object+0xac/0x260
[<ffffffff802a9308>] __slab_alloc+0x368/0x6d0
[<ffffffff80544f82>] ? wireless_send_event+0x142/0x310
[<ffffffff804b1bd4>] ? __alloc_skb+0x44/0x150
[<ffffffff802aa853>] __kmalloc_track_caller+0xc3/0xf0
[<ffffffff804b1bfe>] __alloc_skb+0x6e/0x150
[... stack snipped]
FIX kmalloc-4096: Restoring 0xffff810067419060-0xffff810067419667=0x6b
FIX kmalloc-4096: Marking all objects used
commit d70b67c8bc72ee23b55381bd6a884f4796692f77 upstream
Lookup can install a child dentry for a deleted directory. This keeps
the directory dentry alive, and the inode pinned in the cache and on
disk, even after all external references have gone away.
This isn't a big problem normally, since memory pressure or umount
will clear out the directory dentry and its children, releasing the
inode. But for UBIFS this causes problems because its orphan area can
overflow.
Fix this by returning ENOENT for all lookups on a S_DEAD directory
before creating a child dentry.
Thanks to Zoltan Sogor for noticing this while testing UBIFS, and
Artem for the excellent analysis of the problem and testing.
Reported-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
Tested-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
commit d2cd74b158d7214a556226e3312f9fb1de64d7ae upstream
On Audigy2 Platinum, the Analog/Digital mixer switch is inverted.
https://bugzilla.novell.com/show_bug.cgi?id=396204
The patch adds a simple workaround.
There might be another device requiring a similar fix, too (or fix for
audigy2 generically), but right now I fix only the known broken one.
commit 470eaf6be78424fc499a5039e5d5fe58bace2bc3 upstream
Added the missing SSID of Thinkpad Z60m for model=thinkpad with
AD1981HD.
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
commit 9ad593f6d326e7a4664e3856520f6c042f82a37f upstream
Many HD-audio controllers seem inaccurate about the IRQ timing of
PCM period updates. This has caused problems on audio quality; e.g.
JACK doesn't work with two periods.
This patch fixes the problem by checking the current DMA position
at IRQ handler and delays the period-update via a workq if it's
inaccurate.
commit 43785eaeb1cfb8aed3cf8027f298b242f88fdc45 upstream
Don't create mixer volume elements for Headphone and Speaker if they
use the same DAC as normal line-outs on AD1988. Otherwise the amp
value gets screwed up, e.g.
https://bugzilla.novell.com/show_bug.cgi?id=398255
commit e4cc58944c1e2ce41e3079d4eb60c95e7ce04b2b upstream
Current versions of gdb require a working implementation of
PTRACE_GETSIGINFO for proper watchpoint support. Since struct siginfo
contains pointers it must be converted when passed to a 32-bit debugger.
Signed-off-by: Andreas Schwab <schwab@suse.de>
commit ec8dab36e0738d3059980d144e34f16a26bbda7d upstream
When using the HIDP or BNEP kernel support, the user-space needs to
know if the connection has been terminated for some reasons. Wake up
the application if that happens. Otherwise kernel and user-space are
no longer on the same page and weird behaviors can happen.
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
commit 0376bce7b0659fe1e80d045860087072583ab93f upstream.
Acer Aspire 1360 needs to be added to nomux blacklist, otherwise its
touchpad misbehaves.
Reported-by: Clark Tompsett <clarkt@cnsp.com>
commit 5b5b43d0b32ea586036638288c31179f00de5443 upstream
Gericom Bellagio needs to be added to nomux blacklist, otherwise its
Reported-by: Roland Kletzing <roland.kletzing@materna.de>
commit c3a34f4390396a4bede3f8b7bcc5153f50b974bb upstream
This patch introduces i8042_dmi_nopnp_table to make it possible to perform
DMI matches for systems that need 'i8042.nopnp' to work correctly, and
introduces such an entry for Intel D845PESV -- this system doesn't
detect PS2 mouse reliably without this option, as reported by Robert
Lewis.
[dtor@mail.ru - make it compile if CONFIG_PNP is off - reported
by Randy Dunlap]
commit 3f31fddfa26b7594b44ff2b34f9a04ba409e0f91 upstream
journal_try_to_free_buffers() could race with jbd commit transaction when
the later is holding the buffer reference while waiting for the data
buffer to flush to disk. If the caller of journal_try_to_free_buffers()
request tries hard to release the buffers, it will treat the failure as
error and return back to the caller. We have seen the directo IO failed
due to this race. Some of the caller of releasepage() also expecting the
buffer to be dropped when passed with GFP_KERNEL mask to the
releasepage()->journal_try_to_free_buffers().
With this patch, if the caller is passing the __GFP_WAIT and __GFP_FS to
indicating this call could wait, in case of try_to_free_buffers() failed,
let's waiting for journal_commit_transaction() to finish commit the
current committing transaction, then try to free those buffers again.
Signed-off-by: Mingming Cao <cmm@us.ibm.com>
Reviewed-by: Badari Pulavarty <pbadari@us.ibm.com>
Acked-by: Jan Kara <jack@suse.cz>
commit f41f741838480aeaa3a189cff6e210503cf9c42d upstream
...and ensure that we obey the NFS_INO_INVALID_ACL flag when retrieving the
acls.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit 3d164fb09bb5cb8a223eddf634fc0d355714fcfe upstream.
The following commit causes ch_remove oops:
commit 24b42566c3fcbb5a9011d1446783d0f5844ccd45
Author: Greg Kroah-Hartman <gregkh@suse.de>
Date: Fri May 16 17:55:12 2008 -0700
SCSI: fix race in device_create
There is a race from when a device is created with device_create() and
then the drvdata is set with a call to dev_set_drvdata() in which a
sysfs file could be open, yet the drvdata will be NULL, causing all
sorts of bad things to happen.
This patch fixes the problem by using the new function,
device_create_drvdata(). It fixes the problem in all of the scsi
drivers that need it.
Cc: Kay Sievers <kay.sievers@vrfy.org>
Cc: Doug Gilbert <dgilbert@interlog.com>
Cc: James E.J. Bottomley <James.Bottomley@HansenPartnership.com>
The problem is ch_probe stores ch's private data at a wrong place.
We need to store it at scsi_device->sdev_gendev but the above patch
stores it at device struct that device_create_drvdata returns. So we
hit an oops when ch_remove accesses
scsi_device->sdev_gendev->driver_data, which is NULL.
Actually, there wasn't a race because ch doesn't create sysfs files
with device struct that device_create returns. This patch puts back
dev_set_drvdata() to set ch's private data properly.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
[ Upstream commit 13864515f7bf6cabd60e63c62e09d311386ae1f1 ]
Correct disk numbering problem check.
Signed-off-by: Nikanth Karthikesan <knikanth@suse.de>
Signed-off-by: Neil Brown <neilb@suse.de>
CC: Oliver Pinter <oliver.pntr@gmail.com>
[ Upstream commit 280763c053fee297d95b474f2c145990670371e6 ]
Fix netfilter xt_time's time_mt()'s use of do_div() on an s64 by using
div_s64() instead.
This was introduced by patch ee4411a1b1e0b679c99686629b5eab5a072ce49f
("[NETFILTER]: x_tables: add xt_time match").
[ Upstream commit d54191b85e294c46f05a2249b1f55ae54930bcc7 ]
On Mon, 2008-04-21 at 18:54 -0400, Masami Hiramatsu wrote:
> Thank you for reporting.
> Actually, kprobes tries to fixup thread's flags in post_kprobe_handler
> (which is called from kprobe_exceptions_notify) by
> trace_hardirqs_fixup_flags(pt_regs->flags). However, even the irq flag
> is set in pt_regs->flags, true hardirq is still off until returning
> from do_debug. Thus, lockdep assumes that hardirq is off without
annotation.
> IMHO, one possible solution is that fixing hardirq flags right after
> notify_die in do_debug instead of in post_kprobe_handler.
My reply to BZ 10489:
> [ 2.707509] Kprobe smoke test started
> [ 2.709300] ------------[ cut here ]------------
> [ 2.709420] WARNING: at kernel/lockdep.c:2658 check_flags+0x4d/0x12c()
> [ 2.709541] Modules linked in:
> [ 2.709588] Pid: 1, comm: swapper Not tainted 2.6.25.jml.057 #1
> [ 2.709588] [<c0126acc>] warn_on_slowpath+0x41/0x51
> [ 2.709588] [<c010bafc>] ? save_stack_trace+0x1d/0x3b
> [ 2.709588] [<c0140a83>] ? save_trace+0x37/0x89
> [ 2.709588] [<c011987d>] ? kernel_map_pages+0x103/0x11c
> [ 2.709588] [<c0109803>] ? native_sched_clock+0xca/0xea
> [ 2.709588] [<c0142958>] ? mark_held_locks+0x41/0x5c
> [ 2.709588] [<c0382580>] ? kprobe_exceptions_notify+0x322/0x3af
> [ 2.709588] [<c0142aff>] ? trace_hardirqs_on+0xf1/0x119
> [ 2.709588] [<c03825b3>] ? kprobe_exceptions_notify+0x355/0x3af
> [ 2.709588] [<c0140823>] check_flags+0x4d/0x12c
> [ 2.709588] [<c0143c9d>] lock_release+0x58/0x195
> [ 2.709588] [<c038347c>] ? __atomic_notifier_call_chain+0x0/0x80
> [ 2.709588] [<c03834d6>] __atomic_notifier_call_chain+0x5a/0x80
> [ 2.709588] [<c0383508>] atomic_notifier_call_chain+0xc/0xe
> [ 2.709588] [<c013b6d4>] notify_die+0x2d/0x2f
> [ 2.709588] [<c038168a>] do_debug+0x67/0xfe
> [ 2.709588] [<c0381287>] debug_stack_correct+0x27/0x30
> [ 2.709588] [<c01564c0>] ? kprobe_target+0x1/0x34
> [ 2.709588] [<c0156572>] ? init_test_probes+0x50/0x186
> [ 2.709588] [<c04fae48>] init_kprobes+0x85/0x8c
> [ 2.709588] [<c04e947b>] kernel_init+0x13d/0x298
> [ 2.709588] [<c04e933e>] ? kernel_init+0x0/0x298
> [ 2.709588] [<c0105ef7>] kernel_thread_helper+0x7/0x10
> [ 2.709588] =======================
> [ 2.709588] ---[ end trace 778e504de7e3b1e3 ]---
> [ 2.709588] possible reason: unannotated irqs-off.
> [ 2.709588] irq event stamp: 370065
> [ 2.709588] hardirqs last enabled at (370065): [<c0382580>]
> [ 2.709588] hardirqs last disabled at (370064): [<c0381bb7>]
do_int3+0x1d/0x7d
> [ 2.709588] softirqs last enabled at (370050): [<c012b464>]
__do_softirq+0xfa/0x100
> [ 2.709588] softirqs last disabled at (370045): [<c0107438>]
do_softirq+0x74/0xd9
> [ 2.714751] Kprobe smoke test passed successfully
how I love this stuff...
Ok, do_debug() is a trap, this can happen at any time regardless of the
machine's IRQ state. So the first thing we do is fix up the IRQ state.
Then we call this die notifier stuff; and return with messed up IRQ
state... YAY.
So, kprobes fudges it..
notify_die(DIE_DEBUG)
kprobe_exceptions_notify()
post_kprobe_handler()
modify regs->flags
trace_hardirqs_fixup_flags(regs->flags); <--- must be it
So what's the use of modifying flags if they're not meant to take effect
at some point.
/me tries to reproduce issue; enable kprobes test thingy && boot
OK, that reproduces..
So the below makes it work - but I'm not getting this code; at the time
I wrote that stuff I CC'ed each and every kprobe maintainer listed in
the usual places but got no reposonse - can some please explain this
stuff to me?
Are the saved flags only for the TF bit or are they made in full effect
later (and if so, where) ?
Acked-by: Masami Hiramatsu <mhiramat@redhat.com>
[ Upstream commit f48ed538386cb41559282d989354e8f5d442d71c ]
There is a possible race in md_probe. If two threads call md_probe
for the same device, then one could exit (having checked that
->gendisk exists) before the other has called kobject_init_and_add,
thus returning an incomplete kobj which will cause problems when
we try to add children to it.
So extend the range of protection of disks_mutex slightly to
avoid this possibility.
[ Upstream commit d6cd7effcc5e0047faf15ab0a54c980f1a616a07 ]
Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com>
Cc: akpm@linux-foundation.org
Cc: andi@firstfloor.org
[ Upstream commit ab6bc3e343fbe3be4a0f67225e849d0db6b4b7ac ]
commit 3f27e3ed11e67c5ee19d560a50eafd93cf8c6682 upstream
[SCSI] bsg: fix bsg_mutex hang with device removal
We don't need to hold bsg_mutex during bsg_complete_all_commands(). It
leads to a problem that we block bsg_unregister_queue during
bsg_complete_all_commands (untill all the outstanding commands
complete).
Thanks to Pete Wyckoff for finding the bug and testing the patch.
The detailed bug report is:
http://marc.info/?l=linux-scsi&m=121182137132145&w=2
Tested-by: Pete Wyckoff <pw@osc.edu>
netfilter: nf_nat_sip: c= is optional for session
Upstream commit c71529e4:
According to RFC2327, the connection information is optional
in the session description since it can be specified in the
media description instead.
My provider does exactly that and does not provide any connection
information in the session description. As a result the new
kernel drops all invite responses.
This patch makes it optional as documented.
commit 0056e65f9e28d83ee1a3fb4f7d0041e838f03c34 upstream
We zero-fill them like we are supposed to, and that's all fine. It's
only an error if the 'romfs_copyfrom()' routine isn't able to fill the
data that is supposed to be there.
Most of the patch is really just re-organizing the code a bit, and using
separate variables for the error value and for how much of the page we
actually filled from the filesystem.
Reported-and-tested-by: Chris Fester <cfester@wms.com>
Cc: Matt Waddel <matt.waddel@freescale.com>
Cc: Greg Ungerer <gerg@snapgear.com>
Signed-of-by: Linus Torvalds <torvalds@linux-foundation.org>
There is no ftrace in the 2.6.26 kernel release, so remove the
documentation as it isn't needed.
commit 94ad374a0751f40d25e22e036c37f7263569d24c upstream
The iov_iter_advance() function would look at the iov->iov_len entry
even though it might have iterated over the whole array, and iov was
pointing past the end. This would cause DEBUG_PAGEALLOC to trigger a
kernel page fault if the allocation was at the end of a page, and the
next page was unallocated.
The quick fix is to just change the order of the tests: check that there
is any iovec data left before we check the iov entry itself.
Thanks to Alexey Dobriyan for finding this case, and testing the fix.
Reported-and-tested-by: Alexey Dobriyan <adobriyan@gmail.com>
Cc: Nick Piggin <npiggin@suse.de>
commit 256b152b005e319f985f50f2a910a75ba0def74f upstream
MSI is a nice thing, but we cannot enable it without changing the
interrupt handler. If we do it, we break MSI capable hardware,
specifically AR5006 chipset.
Signed-off-by: Pavel Roskin <proski@gnu.org>
commit 4104863fb4a724723d1d5f3cba9d3c5084087e45 upstream
The mutex is released on a successful return, so it would seem that it
should be released on an error return as well.
The semantic patch finds this problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
expression l;
mutex_lock(l);
.. when != mutex_unlock(l)
when any
when strict
if (...) { ... when != mutex_unlock(l)
+ mutex_unlock(l);
return ...;
mutex_unlock(l);
// </smpl>
Signed-off-by: Michael Buesch <mb@bu3sch.de>
commit a1531acd43310a7e4571d52e8846640667f4c74b upstream
Ingo Molnar provided a fix to not call _PPC at processor driver
initialization time in "[PATCH] ACPI: fix cpufreq regression" (git
commit e4233dec749a3519069d9390561b5636a75c7579)
But it can still happen that _PPC is called at processor driver
initialization time.
This patch should make sure that this is not possible anymore.
Signed-off-by: Thomas Renninger <trenn@suse.de>
Cc: Len Brown <lenb@kernel.org>
Cc: Dave Jones <davej@codemonkey.org.uk>
Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
commit 3971e1a917548977cff71418a7c3575ffbc9571f upstream
This commit:
commit ba52de123d454b57369f291348266d86f4b35070
Author: Theodore Ts'o <tytso@mit.edu>
Date: Wed Sep 27 01:50:49 2006 -0700
[PATCH] inode-diet: Eliminate i_blksize from the inode structure
caused the block size used by pseudo-filesystems to decrease from
PAGE_SIZE to 1024 leading to a doubling of the number of context switches
during a kernbench run.
Signed-off-by: Alex Nixon <Alex.Nixon@citrix.com>
Cc: Ian Campbell <Ian.Campbell@eu.citrix.com>
Cc: "Theodore Ts'o" <tytso@mit.edu>
Cc: Hugh Dickins <hugh@veritas.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
commit 5def9a3a22e09c99717f41ab7f07ec9e1a1f3ec8 upstream
Paul pointed out two incorrect read barriers in the marker handler code in
the path where multiple probes are connected. Those are ordering reads of
"ptype" (single or multi probe marker), "multi" array pointer, and "multi"
array data access.
It should be ordered like this :
read ptype
smp_rmb()
read multi array pointer
smp_read_barrier_depends()
access data referenced by multi array pointer
The code with a single probe connected (optimized case, does not have to
allocate an array) has correct memory ordering.
It applies to kernel 2.6.26.x, 2.6.25.x and linux-next.
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
commit 14fcc23fdc78e9d32372553ccf21758a9bd56fa1 upstream
SuSE's insserve initscript ordering program hits kernel BUG at mm/shmem.c:814
on 2.6.26. It's using posix_fadvise on directories, and the shmem_readpage
method added in 2.6.23 is letting POSIX_FADV_WILLNEED allocate useless pages
to a tmpfs directory, incrementing i_blocks count but never decrementing it.
Fix this by assigning shmem_aops (pointing to readpage and writepage and
set_page_dirty) only when it's needed, on a regular file or a long symlink.
Many thanks to Kel for outstanding bugreport and steps to reproduce it.
Reported-by: Kel Modderman <kel@otaku42.de>
Tested-by: Kel Modderman <kel@otaku42.de>
Signed-off-by: Hugh Dickins <hugh@veritas.com>
commit 9a7867e1b34c3575e7e76a05c0c54c6edbdae2a4 upstream
The block transfer routine in the mpc52xx psc spi driver misinterpret
the datasheet. According to the processor datasheet the chipselect is
held as long as the EOF is not written.
Theoretically blocks of any sizes can be transferred in this way. The
old routine however writes an EOF after every word, which has the size
of size_of_word. This makes the transfer slow.
Also fixed some duplicate code.
Signed-off-by: Luotao Fu <l.fu@pengutronix.de>
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
commit bb5d10ac8cc315d53306963001fe650d88a1cbb2 upstream
The ixgbe driver was untested with device ID 8086:10c8 but still advertises
support. Currently if this device is present in the system when the driver
is loaded, the system will panic.
Remove this device ID until full support can be tested with available
hardware. This patch is necessary for 2.6.24, 2.6.25 and 2.6.26
Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com>
commit 7c1fed03b9fa32d4323d5caa6a9c7dcdd7eba767 upstream
My copying of linux/init.h didn't go far enough. The definition of
__used singled out gcc minor version 3, but didn't care what the major
version was. This broke when unit-at-a-time was added and gcc started
throwing out initcalls.
This results in an early boot crash when ptrace tries to initialize a
process with an empty, uninitialized register set.
Signed-off-by: Jeff Dike <jdike@linux.intel.com>
commit 7fcba054373d5dfc43d26e243a5c9b92069972ee upstream
Date: Mon, 28 Jul 2008 15:46:39 -0700
Subject: eCryptfs: use page_alloc not kmalloc to get a page of memory
With SLUB debugging turned on in 2.6.26, I was getting memory corruption
when testing eCryptfs. The root cause turned out to be that eCryptfs was
doing kmalloc(PAGE_CACHE_SIZE); virt_to_page() and treating that as a nice
page-aligned chunk of memory. But at least with SLUB debugging on, this
is not always true, and the page we get from virt_to_page does not
necessarily match the PAGE_CACHE_SIZE worth of memory we got from kmalloc.
My simple testcase was 2 loops doing "rm -f fileX; cp /tmp/fileX ." for 2
different multi-megabyte files. With this change I no longer see the
corruption.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Acked-by: Michael Halcrow <mhalcrow@us.ibm.com>
based on e22146e610bb7aed63282148740ab1d1b91e1d90 upstream
Fix bug in kernel_physical_mapping_init() that causes kernel
page table to be built incorrectly for systems with greater
than 512GB of memory.
Signed-off-by: Jack Steiner <steiner@sgi.com>
Cc: linux-mm@kvack.org
Cc: Oliver Pinter <oliver.pntr@gmail.com>
(cherry picked from commit 7e994302ed3fc6d209ce247ad5b6d9c2499bf7c2)
DVB: cx23885: SRAM changes for the 885 and 887 silicon parts
In a previous patch I merged both memory maps into a single struct,
believing that they could be combined. We've since found problems
with streaming multiple channels on the 885. I'm restoring the
multiple memory map structs - in line with the windows driver.
Signed-off-by: Steven Toth <stoth@hauppauge.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
(cherry picked from commit d8d12b4367e2e759f65c5f9dcb94d21ec237bbc5)
DVB: cx23885: Reallocated the sram to avoid concurrent VIDB/C issues
This may be cx23885 chip specific and may not work on the cx23887.
Analog and mpeg encoder streaming are still to be tested.
(cherry picked from commit 52ce27bfc4d302a3e28267a5820a8b031ceccee9)
DVB: cx23885: DVB Transport cards using DVB port VIDB/TS1 did not stream
Certain DVB cards that have demodulators on TS1/VIDB were not
streaming packets.
This ensure the pin directions on PAD_CTRL are set correctly,
solving the issue.
(cherry picked from commit ecda5966c90746a044ff68e78b1062adcddd9664)
DVB: cx23885: Ensure PAD_CTRL is always reset to a sensible default
PAD_CTRL controls TS1 and TS2 input and output states, if the
register became corrupt the driver was never able to recover.
(cherry picked from commit 28901ab621bb56cd2aa9670dc7ce016ba80ec45c)
V4L: cx23885: Bugfix for concurrent use of /dev/video0 and /dev/video1
With the HVR1800, trying to use video0 and video1 simultaneously
caused buffer corruption in the PCIe bridge. This fix reallocates
video1 buffer locations to avoid the issue.
V4L: saa7134: Copy tuner data earlier to avoid overwriting manual tuner type
(cherry picked from commit d53687d1d22c3204394658a31654de2f1efb0e8f)
Copy tuner data earlier in init to avoid overwriting manual tuner type
When saa7134_board_init2 runs, it immediately overwrites the
current value (set earlier from module parameter) of tuner_type
with the static values, and then does autodetection. This patch
moves the tuner_addr copy to earlier in saa7134_initdev and
removes the tuner_type copy from saa7134_board_init2.
Autodetection could still potentially change to the wrong tuner
type, but it is now possible to override the default type for
the card again.
My card's tuner is configured with autodetection from eeprom,
so I don't need to manually set the tuner. I've checked that
the autodetection still works for my card.
Signed-off-by: Simon Arlott <simon@fire.lp0.eu>
Reviewed-by: Hermann Pitton <hermann-pitton@arcor.de>
Cc: Brian Marete <bgmarete@gmail.com>
(cherry picked from commit bdf2fe4a0b9d23e69c77eaec76212216c9a957ef)
V4L: uvcvideo: Add support for Medion Akoya Mini E1210 integrated webcam
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
Signed-off-by: Laurent Pinchart <laurent.pinchart@skynet.be>
(cherry picked from commit 6833c917b4de1757febdbf946d709ece6dc7a86f)
V4L: uvcvideo: Make input device support optional
UVC devices can report button events. The uvcvideo driver depends on
CONFIG_INPUT to report events to the input layer. This patch removes the hard
dependency by introducing a new CONFIG_USB_VIDEO_CLASS_INPUT_EVDEV option.
(cherry picked from commit e01117c81676dc9897f567e32cdc13a26e85280b)
V4L: uvcvideo: Don't free URB buffers on suspend.
All submitted URBs must be killed at suspend time, but URB buffers don't
have to be freed. Avoiding a free on suspend/reallocate on resume lowers
the pressure on system memory.
(cherry picked from commit 291358785cde5536d98a4f3cae77efd8ca626486)
V4L: uvcvideo: Use GFP_NOIO when allocating memory during resume
The swap device might still be asleep, so memory allocated in the resume
handler must use GFP_NOIO. Thanks to Oliver Neukum for catching and reporting
this bug.
