2008-05-26Linux 2.6.26-rc4v2.6.26-rc4tip-x86-setup-2008-05-31_10.10_SatLinus Torvalds
2008-05-26posix timers: discard SI_TIMER signals on execOleg Nesterov
Based on Roland's patch. This approach was suggested by Austin Clements from the very beginning, and then by Linus. As Austin pointed out, the execing task can be killed by SI_TIMER signal because exec flushes the signal handlers, but doesn't discard the pending signals generated by posix timers. Perhaps not a bug, but people find this surprising. See http://bugzilla.kernel.org/show_bug.cgi?id=10460 Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Austin Clements <amdragon+kernelbugzilla@mit.edu> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-26posix timers: sigqueue_free: don't free sigqueue if it is queuedOleg Nesterov
Currently sigqueue_free() removes sigqueue from list, but doesn't cancel the pending signal. This is not consistent, the task should either receive the "full" signal along with siginfo_t, or it shouldn't receive the signal at all. Change sigqueue_free() to clear SIGQUEUE_PREALLOC but leave sigqueue on list if it is queued. This is a user-visible change. If the signal is blocked, it stays queued after sys_timer_delete() until unblocked with the "stale" si_code/si_value, and of course it is still counted wrt RLIMIT_SIGPENDING which also limits the number of posix timers. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Austin Clements <amdragon+kernelbugzilla@mit.edu> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-26Merge branch 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6Linus Torvalds
* 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6: i2c: Align i2c_device_id tuner: Do not alter i2c_client.name
2008-05-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6: slub: ksize() abuse checks slob: Fix to return wrong pointer
2008-05-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6.26Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6.26: sh: Drop broken URAM support on SH7723. sh: update Migo-R defconfig sh: use sm501 8250 mfd support on r2d boards sh: add probe support for new sh7723 cut sh: fix VPU interrupt vector for sh7723 sh: fix USBF resource for sh7722
2008-05-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc64: global_reg_snapshot is not for userspace
2008-05-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (52 commits) vlan: Use bitmask of feature flags instead of seperate feature bits fmvj18x_cs: add NextCom NC5310 rev B support xirc2ps_cs: re-initialize the multicast address in do_reset 3C509: rx_bytes should not be increased when alloc_skb failed NETFRONT: Use __skb_queue_purge() VIRTIO: Use __skb_queue_purge() phylib: do EXPORT_SYMBOL on get_phy_id netlink: Fix nla_parse_nested_compat() to call nla_parse() directly WAN: protect HDLC proto list while insmod/rmmod drivers/net/fs_enet: remove null pointer dereference S2io: Version update for napi and MSI-X patches S2io: Added napi support when MSIX is enabled. S2io: Move all the transmit completions to a single msi-x (alarm) vector drivers/net/ehea - remove unnecessary memset after kzalloc au1000_eth: remove useless check Blackfin EMAC Driver: Removed duplicated include <linux/ethtool.h> cpmac bugfixes and enhancements e1000e: use resource_size_t, not unsigned long, for phys addrs net/usb: add support for Apple USB Ethernet Adapter uli526x: add support for netpoll ...
2008-05-26i2c: Align i2c_device_idJiri Slaby
Align i2c_device_id.driver_data to 8 bytes to not fail on crossbuilds. (Added in d2653e92732bd3911feff6bee5e23dbf959381db.) Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-05-26tuner: Do not alter i2c_client.nameMichael Krufky
The tuner driver used to change i2c_client.name for its own needs, but it really shouldn't, as this field is used by i2c-core to do the device/driver matching. So, create and use a separate field for the tuner driver needs. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-05-25sparc64: global_reg_snapshot is not for userspaceAdrian Bunk
global_reg_snapshot shouldn't be visible in our userspace headers. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-26sh: Drop broken URAM support on SH7723.Paul Mundt
This was copied over from the previous MobileR bits, which doesn't apply to R2. The URAM block on R2 is recycled for the L2 instead. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixesLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixes: Kconfig: introduce ARCH_DEFCONFIG to DEFCONFIG_LIST .gitignore: match ncscope.out scripts/ver_linux use 'gcc -dumpversion'
2008-05-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdogLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog: [WATCHDOG] Add ICH9DO into the iTCO_wdt.c driver [WATCHDOG] Fix booke_wdt.c on MPC85xx SMP system's [WATCHDOG] Add a watchdog driver based on the CS5535/CS5536 MFGPT timers [WATCHDOG] hpwdt: Fix NMI handling. [WATCHDOG] Blackfin Watchdog Driver: split platform device/driver [WATCHDOG] Add w83697h_wdt early_disable option [WATCHDOG] Make w83697h_wdt timeout option string similar to others [WATCHDOG] Make w83697h_wdt void-like functions void
2008-05-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: [ALSA] hda - Fix capture mute Widget for stac9250/9251 [ALSA] snd-pcsp - fix pcsp_treble_info() to honour an item number [ALSA] hda - Added support for Foxconn P35AX-S mainboard [ALSA] hda - Fix COEF and EAPD in ALC889 auto-configuration mode [ALSA] hda - Fix noise on VT1708 codec [ALSA] hda - Add model for ASUS P5K-E/WIFI-AP
2008-05-25Kconfig: introduce ARCH_DEFCONFIG to DEFCONFIG_LISTSam Ravnborg
init/Kconfig contains a list of configs that are searched for if 'make *config' are used with no .config present. Extend this list to look at the config identified by ARCH_DEFCONFIG. With this change we now try the defconfig targets last. This fixes a regression reported by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com>
2008-05-25.gitignore: match ncscope.outJike Song
Sometimes I got this: $ git-status {snip} # On branch master # Untracked files: # (use "git add <file>..." to include in what will be committed) # # ncscope.out nothing added to commit but untracked files present (use "git add" to track) Fix it. Signed-off-by: Jike Song <albcamus@gmail.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-05-25scripts/ver_linux use 'gcc -dumpversion'Gabriel C
These magic greps and hacks in ver_linux to get the gcc version always break after some gcc releases. Since now gcc >4.3 allows compiling with '--with-pkgversion' ( which can be everything 'My Cool Gcc' or something ) ver_linux will report random junk for these. Simply use 'gcc -dumpversion' to get the gcc version which should always work. Signed-off-by: Gabriel C <nix.or.die@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-05-25[ALSA] hda - Fix capture mute Widget for stac9250/9251Mauro Carvalho Chehab
Fix capture mute widget for STAC9250/9251 codecs. The widget 0x09 has no mute but 0x14 does actually. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-25[ALSA] snd-pcsp - fix pcsp_treble_info() to honour an item numberStas Sergeev
This solves the problem with mixers wrongly displaying the PWM freq. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-05-25[WATCHDOG] Add ICH9DO into the iTCO_wdt.c driverGabriel C
Add the Intel ICH9DO controller ID's for the iTCO_wdt kernel driver and bump the driver version. Tested on an P5E-VM DO ASUS motherboard. Signed-off-by: Gabriel Craciunescu <nix.or.die@googlemail.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2008-05-25[WATCHDOG] Fix booke_wdt.c on MPC85xx SMP system'sChen Gong
On Book-E SMP systems each core has its own private watchdog. If only one watchdog is enabled, when the core that doesn't enable the watchdog is hung, system can't reset because no watchdog is running on it. That's bad. It means we must enable watchdogs on both cores. We can use smp_call_function() to send appropriate messages to all the other cores to enable and update the watchdog. Signed-off-by: Chen Gong <g.chen@freescale.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2008-05-25[WATCHDOG] Add a watchdog driver based on the CS5535/CS5536 MFGPT timersJordan Crouse
Add a watchdog timer based on the MFGPT timers in the CS5535/CS5536 companion chips to the AMD Geode GX and LX processors. Only caveat is that the BIOS must provide at least a one free timer, and most do not. Signed-off-by: Jordan Crouse <jordan.crouse@amd.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-05-25[WATCHDOG] hpwdt: Fix NMI handling.Mingarelli, Thomas
I need to just return in case it's not my NMI so someone else can take a look at it (and reset die_nmi_called to 0 in case I actually do get one that's mine to handle). Signed-off-by: Thomas Mingarelli <thomas.mingarelli@hp.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-05-25[WATCHDOG] Blackfin Watchdog Driver: split platform device/driverMike Frysinger
- split platform device/driver registering from actual watchdog device/driver registering so that we can cleanly load/unload - fixup __initdata with __initconst and __devinitdata with __devinitconst Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-05-25[WATCHDOG] Add w83697h_wdt early_disable optionSamuel Tardieu
Pádraig Brady requested the possibility of not disabling the watchdog at module load time or kernel boot time if it had been previously enabled in the bios. It may help rebooting the machine if it freezes before the userland daemon kicks in. Signed-off-by: Samuel Tardieu <sam@rfc1149.net> Cc: Pádraig Brady <P@draigBrady.com> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-05-25[WATCHDOG] Make w83697h_wdt timeout option string similar to othersSamuel Tardieu
Signed-off-by: Samuel Tardieu <sam@rfc1149.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-05-25[WATCHDOG] Make w83697h_wdt void-like functions voidSamuel Tardieu
Some non-exported functions always returned 0. Mark them void instead. Signed-off-by: Samuel Tardieu <sam@rfc1149.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2008-05-24Merge branch 'x86-fixes-for-linus' of ↵tip-auto-x86-next-base-2008-05-26_08_52_Montip-auto-sched-next-base-2008-05-26_08_52_Montip-auto-latest-base-2008-05-26_08_52_Montip-auto-ftrace-next-base-2008-05-26_08_52_MonLinus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-tip: x86: prevent PGE flush from interruption/preemption x86: use explicit copy in vdso_gettimeofday() namespacecheck: automated fixes x86/xen: fix arbitrary_virt_to_machine() x86: don't read maxlvt before checking if APIC is mapped x86: disable TSC for sched_clock() when calibration failed x86: distangle user disabled TSC from unstable x86: fix setup of cyc2ns in tsc_64.c
2008-05-24Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] integrator: fix build warnings and errors [ARM] fix OMAP include loops Revert "[ARM] pxa: spitz wants PXA27x UDC definitions" [ARM] 5053/1: define before use of processor_id [ARM] 5052/1: export clock functions for the at91x40 [ARM] 5051/1: define pgtable_t for the !CONFIG_MMU case too [ARM] omap: fix omap clk support build errors [ARM] 5039/1: S3C244X: Rename SDI device if running on S3C244X. [ARM] 5043/1: pxafb: remove unused mode variable in pxafb_init_fbinfo [ARM] 5041/1: VR1000: Fix DM9000 IRQ flags initialisation [ARM] 5040/1: BAST: Fix DM9000 IRQ flags initialisation [ARM] 5038/1: ARM: OMAP: Remove tsc2102 references from board-palmte.c [ARM] 5025/2: fix collie cpu initialisation
2008-05-24spi: remove some spidev oops-on-rmmod pathsDavid Brownell
Somehow the spidev code forgot to include a critical mechanism: when the underlying device is removed (e.g. spi_master rmmod), open file descriptors must be prevented from issuing new I/O requests to that device. On penalty of the oopsing reported by Sebastian Siewior <bigeasy@tglx.de> ... This is a partial fix, adding handshaking between the lower level (SPI messaging) and the file operations using the spi_dev. (It also fixes an issue where reads and writes didn't return the number of bytes sent or received.) There's still a refcounting issue to be addressed (separately). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Reported-by: Sebastian Siewior <bigeasy@tglx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24cgroups: remove node_ prefix_from ns subsystemCedric Le Goater
This is a slight change in the namespace cgroup subsystem api. The change is that previously when cgroup_clone() was called (currently only from the unshare path in ns_proxy cgroup, you'd get a new group named "node_$pid" whereas now you'll get a group named after just your pid.) The only users who would notice it are those who are using the ns_proxy cgroup subsystem to auto-create cgroups when namespaces are unshared - something of an experimental feature, which I think really needs more complete container/namespace support in order to be useful. I suspect the only users are Cedric and Serge, or maybe a few others on containers@lists.linux-foundation.org. And in fact it would only be noticed by the users who make the assumption about how the name is generated, rather than getting it from the /proc/<pid>/cgroups file for the process in question. Whether the change is actually needed or not I'm fairly agnostic on, but I guess it is more elegant to just use the pid as the new group name rather than adding a fairly arbitrary "node_" prefix on the front. [menage@google.com: provided changelog] Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: "Paul Menage" <menage@google.com> Cc: "Serge E. Hallyn" <serue@us.ibm.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24for_each_online_pgdat(): kerneldoc fixFernando Luis Vazquez Cao
for_each_pgdat() was renamed to for_each_online_pgdat() and kerneldoc comments should be updated accordingly. Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24frv: export empty_zero_pageAdrian Bunk
Fix the following build error: ERROR: "empty_zero_page" [fs/ext4/ext4dev.ko] undefined! Reported-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24sys_prctl(): fix return of uninitialized valueShi Weihua
If none of the switch cases match, the PR_SET_PDEATHSIG and PR_SET_DUMPABLE cases of the switch statement will never write to local variable `error'. Signed-off-by: Shi Weihua <shiwh@cn.fujitsu.com> Cc: Andrew G. Morgan <morgan@kernel.org> Acked-by: "Serge E. Hallyn" <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24edac: mpc85xx: fix building as a moduleKumar Gala
including of <asm/mpc85xx.h> causes build problems since it doesn't exist. Also removed warning: drivers/edac/mpc85xx_edac.c:45: warning: 'mpc85xx_ctl_name' defined but not used Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Doug Thompson <dougthompson@xmission.com> Acked-by: Dave Jiang <djiang@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24gpio: build fixesDavid Brownell
This fixes various gpio-related build errors (mostly potential) reported in part by Russell King and Uwe Kleine-König. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Uwe Kleine-König <Uwe.Kleine-Koenig@digi.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24S3C2410: fix driver MODULE_ALIAS()Ben Dooks
Add a correct MODULE_ALIAS() entry for this driver to enable udev module loading. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Cc: Arnaud Patard <arnaud.patard@rtp-net.org> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24S3C2410: clean out changelog header and tidyBen Dooks
Remove the old changelog entries which are now out of date and should be extractable from git anyway. Also tidy up the copyright for the driver. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Cc: Arnaud Patard <arnaud.patard@rtp-net.org> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24S3C2410: add error print if we cannot add attributeBen Dooks
Fix the following warning by checking the result of device_create_file and printing an error but not removing the device (loss of debug registers is not fatal). drivers/video/s3c2410fb.c:905: warning: ignoring return value of 'device_create_file', declared with attribute warn_unused_result Signed-off-by: Ben Dooks <ben-linux@fluff.org> Cc: Arnaud Patard <arnaud.patard@rtp-net.org> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24S3C2410: ensure that FB_BLANK_POWERDOWN shuts down the controllerBen Dooks
When a blank level of FB_BLANK_POWERDOWN is used, we should shut down the controller so that it no longer tries to produce any panel signals or data, and shuts down the DMA which is not needed. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Cc: Arnaud Patard <arnaud.patard@rtp-net.org> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24SM501: reverse FPEN/VBIASEN flags behaviourBen Dooks
To keep backwards compatibility, reverse the meanings of these flags so that when they are not set, the driver uses the original behvaiour. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Cc: Arnaud Patard <arnaud.patard@rtp-net.org> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24memory hotplug: fix early allocation handlingHeiko Carstens
Trying to add memory via add_memory() from within an initcall function results in bootmem alloc of 163840 bytes failed! Kernel panic - not syncing: Out of memory This is caused by zone_wait_table_init() which uses system_state to decide if it should use the bootmem allocator or not. When initcalls are handled the system_state is still SYSTEM_BOOTING but the bootmem allocator doesn't work anymore. So the allocation will fail. To fix this use slab_is_available() instead as indicator like we do it everywhere else. [akpm@linux-foundation.org: coding-style fix] Reviewed-by: Andy Whitcroft <apw@shadowen.org> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Yasunori Goto <y-goto@jp.fujitsu.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24zonelists: handle a node zonelist with no applicable entriesAndy Whitcroft
When booting 2.6.26-rc3 on a multi-node x86_32 numa system we are seeing panics when trying node local allocations: BUG: unable to handle kernel NULL pointer dereference at 0000034c IP: [<c1042507>] get_page_from_freelist+0x4a/0x18e *pdpt = 00000000013a7001 *pde = 0000000000000000 Oops: 0000 [#1] SMP Modules linked in: Pid: 0, comm: swapper Not tainted (2.6.26-rc3-00003-g5abc28d #82) EIP: 0060:[<c1042507>] EFLAGS: 00010282 CPU: 0 EIP is at get_page_from_freelist+0x4a/0x18e EAX: c1371ed8 EBX: 00000000 ECX: 00000000 EDX: 00000000 ESI: f7801180 EDI: 00000000 EBP: 00000000 ESP: c1371ec0 DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0068 Process swapper (pid: 0, ti=c1370000 task=c12f5b40 task.ti=c1370000) Stack: 00000000 00000000 00000000 00000000 000612d0 000412d0 00000000 000412d0 f7801180 f7c0101c f7c01018 c10426e4 f7c01018 00000001 00000044 00000000 00000001 c12f5b40 00000001 00000010 00000000 000412d0 00000286 000412d0 Call Trace: [<c10426e4>] __alloc_pages_internal+0x99/0x378 [<c10429ca>] __alloc_pages+0x7/0x9 [<c105e0e8>] kmem_getpages+0x66/0xef [<c105ec55>] cache_grow+0x8f/0x123 [<c105f117>] ____cache_alloc_node+0xb9/0xe4 [<c105f427>] kmem_cache_alloc_node+0x92/0xd2 [<c122118c>] setup_cpu_cache+0xaf/0x177 [<c105e6ca>] kmem_cache_create+0x2c8/0x353 [<c13853af>] kmem_cache_init+0x1ce/0x3ad [<c13755c5>] start_kernel+0x178/0x1ee This occurs when we are scanning the zonelists looking for a ZONE_NORMAL page. In this system there is only ZONE_DMA and ZONE_NORMAL memory on node 0, all other nodes are mapped above 4GB physical. Here is a dump of the zonelists from this system: zonelists pgdat=c1400000 0: c14006c0:2 f7c006c0:2 f7e006c0:2 c1400360:1 c1400000:0 1: c14006c0:2 c1400360:1 c1400000:0 zonelists pgdat=f7c00000 0: f7c006c0:2 f7e006c0:2 c14006c0:2 c1400360:1 c1400000:0 1: f7c006c0:2 zonelists pgdat=f7e00000 0: f7e006c0:2 c14006c0:2 f7c006c0:2 c1400360:1 c1400000:0 1: f7e006c0:2 When performing a node local allocation we call get_page_from_freelist() looking for a page. It in turn calls first_zones_zonelist() which returns a preferred_zone. Where there are no applicable zones this will be NULL. However we use this unconditionally, leading to this panic. Where there are no applicable zones there is no possibility of a successful allocation, so simply fail the allocation. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24serial: fix enable_irq_wake/disable_irq_wake imbalance in serial_core.cArjan van de Ven
enable_irq_wake() and disable_irq_wake() need to be balanced. However, serial_core.c calls these for different conditions during the suspend and resume functions... This is causing a regular WARN_ON() as found at http://www.kerneloops.org/search.php?search=set_irq_wake This patch makes the conditions for triggering the _wake enable/disable sequence identical. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24proc: proc_get_inode() should get module only onceDenis V. Lunev
Any file under /proc/net opened more than once leaked the refcounter on the module it belongs to. The problem is that module_get is called for each file opening while module_put is called only when /proc inode is destroyed. So, lets put module counter if we are dealing with already initialised inode. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=10737 Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: David Miller <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Acked-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Robert Olsson <robert.olsson@its.uu.se> Acked-by: Eric W. Biederman <ebiederm@xmission.com> Reported-by: Roland Kletzing <devzero@web.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24brd: don't show ramdisks in /proc/partitionsMarcin Krol
In 2.6.25, ramdisk devices show up in /proc/partitions, which is a behaviour change from the old rd.c. Add GENHD_FL_SUPPRESS_PARTITION_INFO, which was present in rd.c. All kernels prior to 2.6.25 weren't displaying ramdisks in /proc/partitions. Since there are many userspace tools using information from /proc/partitions some of them may now behave incorrectly (I didn't tested any though). For example before 2.6.25 /proc/partitions was empty if no block devices like hard disks and such were detected by kernel. Now all 16 ramdisks are always visible there. Some software may rely on such information (I mean, on empty /proc/partitions). There was quite similar situation back in 2004, and ramdisks were excluded back from displaying. Thats why I called this a regression (maybe a bit unfortunate). See this patch for info: http://kernel.org/pub/linux/kernel/people/akpm/patches/2.6/2.6.3-rc2/2.6.3-rc2-mm1/broken-out/nbd-proc-partitions-fix.patch I also think that someone somewhere (long time ago) excluded ramdisks from /proc/partitions for good reasons. It is possible that now such new "feature" is harmless, but I think there are more chances that someone will say "hey, /proc/partitions has changed, now my software doesn't work" then "hey where did my new 2.6.25 feature go". nbd devices are also excluded, maybe for very same (unknown to me) reasons. Signed-off-by: Marcin Krol <hawk@pld-linux.org> Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24ip2: fix crashes on load/unloadAlan Cox
This doesn't need to be two modules, and making it one cleans up the problem Signed-off-by: Alan Cox <alan@redhat.com> Cc: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24gpiolib: fix off by one errorsTrent Piepho
The last gpio belonging to a chip is chip->base + chip->ngpios - 1. Some places in the code, but not all, forgot the critical minus one. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24gpio: mcp23s08 debug fixRoel Kluin
The return value of mcp23s08_read_regs() can only be evaluated when signed Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
