2008-11-10Linux 2.6.25.20v2.6.25.20Greg Kroah-Hartman
2008-11-10netfilter: restore lost ifdef guarding defrag exceptionPatrick McHardy
netfilter: restore lost #ifdef guarding defrag exception Upstream commit 38f7ac3eb: Nir Tzachar <nir.tzachar@gmail.com> reported a warning when sending fragments over loopback with NAT: [ 6658.338121] WARNING: at net/ipv4/netfilter/nf_nat_standalone.c:89 nf_nat_fn+0x33/0x155() The reason is that defragmentation is skipped for already tracked connections. This is wrong in combination with NAT and ip_conntrack actually had some ifdefs to avoid this behaviour when NAT is compiled in. The entire "optimization" may seem a bit silly, for now simply restoring the lost #ifdef is the easiest solution until we can come up with something better. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-10netfilter: snmp nat leaks memory in case of failureIlpo Järvinen
netfilter: snmp nat leaks memory in case of failure Upstream commit 311670f3e: Signed-off-by: Ilpo Jarvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-11-10netfilter: xt_iprange: fix range inversion matchAlexey Dobriyan
netfilter: xt_iprange: fix range inversion match Upstream commit 6def1eb48: Inverted IPv4 v1 and IPv6 v0 matches don't match anything since 2.6.25-rc1! Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-10ACPI: video: fix brightness allocationJulia Jomantaite
Thanks to Arjan for spotting this for .stable: http://www.kerneloops.org/search.php?search=acpi_video_switch_brightness upstream commit 469778c1740fcf3113498b6fdf4559bdec25c58f ACPI: video: fix brightness allocation Fix use of uninitialized device->brightness. Signed-off-by: Julia Jomantaite <julia.jomantaite@gmail.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-10math-emu: Fix signalling of underflow and inexact while packing result.Kumar Gala
[ Upstream commit 930cc144a043ff95e56b6888fa51c618b33f89e7 ] I'm trying to move the powerpc math-emu code to use the include/math-emu bits. In doing so I've been using TestFloat to see how good or bad we are doing. For the most part the current math-emu code that PPC uses has a number of issues that the code in include/math-emu seems to solve (plus bugs we've had for ever that no one every realized). Anyways, I've come across a case that we are flagging underflow and inexact because we think we have a denormalized result from a double precision divide: 000.FFFFFFFFFFFFF / 3FE.FFFFFFFFFFFFE soft: 001.0000000000000 ..... syst: 001.0000000000000 ...ux What it looks like is the results out of FP_DIV_D are: D: sign: 0 mantissa: 01000000 00000000 exp: -1023 (0) The problem seems like we aren't normalizing the result and bumping the exp. Now that I'm digging into this a bit I'm thinking my issue has to do with the fix DaveM put in place from back in Aug 2007 (commit 405849610fd96b4f34cd1875c4c033228fea6c0f): [MATH-EMU]: Fix underflow exception reporting. 2) we ended up rounding back up to normal (this is the case where we set the exponent to 1 and set the fraction to zero), this should set inexact too ... Another example, "0x0.0000000000001p-1022 / 16.0", should signal both inexact and underflow. The cpu implementations and ieee1754 literature is very clear about this. This is case #2 above. Here is the distilled glibc test case from Jakub Jelinek which prompted that commit: -------------------- #include <float.h> #include <fenv.h> #include <stdio.h> volatile double d = DBL_MIN; volatile double e = 0x0.0000000000001p-1022; volatile double f = 16.0; int main (void) { printf ("%x\n", fetestexcept (FE_UNDERFLOW)); d /= f; printf ("%x\n", fetestexcept (FE_UNDERFLOW)); e /= f; printf ("%x\n", fetestexcept (FE_UNDERFLOW)); return 0; } -------------------- It looks like the case I have we are exact before rounding, but think it looks like the rounding case since it appears as if "overflow is set". 000.FFFFFFFFFFFFF / 3FE.FFFFFFFFFFFFE = 001.0000000000000 I think the following adds the check for my case and still works for the issue your commit was trying to resolve. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-10sparc64: Fix race in arch/sparc64/kernel/trampoline.SAndrea Shepard
[ Upstream commit e0037df3852b4b60edbe01f70f4968e4a9fdb272 ] Make arch/sparc64/kernel/trampoline.S in 2.6.27.1 lock prom_entry_lock when calling the PROM. This prevents a race condition that I observed causing a hang on startup on a 12-CPU E4500. I am not subscribed to this list, so please CC me on replies. Signed-off-by: Andrea Shepard <andrea@persephoneslair.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-10net: Fix netdev_run_todo dead-lockHerbert Xu
[ Upstream commit 58ec3b4db9eb5a28e3aec5f407a54e28f7039c19 ] Benjamin Thery tracked down a bug that explains many instances of the error unregister_netdevice: waiting for %s to become free. Usage count = %d It turns out that netdev_run_todo can dead-lock with itself if a second instance of it is run in a thread that will then free a reference to the device waited on by the first instance. The problem is really quite silly. We were trying to create parallelism where none was required. As netdev_run_todo always follows a RTNL section, and that todo tasks can only be added with the RTNL held, by definition you should only need to wait for the very ones that you've added and be done with it. There is no need for a second mutex or spinlock. This is exactly what the following patch does. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-10tcpv6: fix option space offsets with md5Ilpo Järvinen
[ Upstream commit 53b125779fb0b29e5b316bf3dc7d199e6dcea567 ] More breakage :-), part of timestamps just were previously overwritten. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-10ACPI: dock: avoid check _STA methodShaohua Li
commit 8b59560a3baf2e7c24e0fb92ea5d09eca92805db upstream. ACPI: dock: avoid check _STA method In some BIOSes, every _STA method call will send a notification again, this cause freeze. And in some BIOSes, it appears _STA should be called after _DCK. This tries to avoid calls _STA, and still keep the device present check. http://bugzilla.kernel.org/show_bug.cgi?id=10431 Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-10ALSA: use correct lock in snd_ctl_dev_disconnect()Takashi Iwai
commit d8009882e9f5e1a76986c741f071edd2ad760c97 upstream The lock used in snd_ctl_dev_disconnect() should be card->ctl_files_rwlock for protection of card->ctl_files entries, instead of card->controls_rwsem. Reported-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz> Cc: Chris Wedgwood <cw@f00f.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-10file caps: always start with clear bprm->caps_*Serge Hallyn
commit 3318a386e4ca68c76e0294363d29bdc46fcad670 upstream While Linux doesn't honor setuid on scripts. However, it mistakenly behaves differently for file capabilities. This patch fixes that behavior by making sure that get_file_caps() begins with empty bprm->caps_*. That way when a script is loaded, its bprm->caps_* may be filled when binfmt_misc calls prepare_binprm(), but they will be cleared again when binfmt_elf calls prepare_binprm() next to read the interpreter's file capabilities. Signed-off-by: Serge Hallyn <serue@us.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Andrew G. Morgan <morgan@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-10libertas: fix buffer overrunJohannes Berg
commit 48735d8d8bd701b1e0cd3d49c21e5e385ddcb077 upstream If somebody sends an invalid beacon/probe response, that can trash the whole BSS descriptor. The descriptor is, luckily, large enough so that it cannot scribble past the end of it; it's well above 400 bytes long. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-10net: Fix recursive descent in __scm_destroy().David Miller
commit f8d570a4745835f2238a33b537218a1bb03fc671 and 3b53fbf4314594fa04544b02b2fc6e607912da18 upstream (because once wasn't good enough...) __scm_destroy() walks the list of file descriptors in the scm_fp_list pointed to by the scm_cookie argument. Those, in turn, can close sockets and invoke __scm_destroy() again. There is nothing which limits how deeply this can occur. The idea for how to fix this is from Linus. Basically, we do all of the fput()s at the top level by collecting all of the scm_fp_list objects hit by an fput(). Inside of the initial __scm_destroy() we keep running the list until it is empty. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-10edac cell: fix incorrect edac_modeBenjamin Herrenschmidt
commit 3b274f44d2ca05f719fe39947b6a5293a2dbd8fd upstream The cell_edac driver is setting the edac_mode field of the csrow's to an incorrect value, causing the sysfs show routine for that field to go out of an array bound and Oopsing the kernel when used. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-10ext[234]: Avoid printk floods in the face of directory corruption ↵Eric Sandeen
(CVE-2008-3528) This is a trivial backport of the following upstream commits: - bd39597cbd42a784105a04010100e27267481c67 (ext2) - cdbf6dba28e8e6268c8420857696309470009fd9 (ext3) - 9d9f177572d9e4eba0f2e18523b44f90dd51fe74 (ext4) This addresses CVE-2008-3528 ext[234]: Avoid printk floods in the face of directory corruption Note: some people thinks this represents a security bug, since it might make the system go away while it is printing a large number of console messages, especially if a serial console is involved. Hence, it has been assigned CVE-2008-3528, but it requires that the attacker either has physical access to your machine to insert a USB disk with a corrupted filesystem image (at which point why not just hit the power button), or is otherwise able to convince the system administrator to mount an arbitrary filesystem image (at which point why not just include a setuid shell or world-writable hard disk device file or some such). Me, I think they're just being silly. --tytso Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: linux-ext4@vger.kernel.org Cc: Eugene Teo <eugeneteo@kernel.sg> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-10gpiolib: fix oops in gpio_get_value_cansleep()David Brownell
commit 978ccaa8ea5d8c7bf6b676209f2fc126eae6355b upstream We can get the following oops from gpio_get_value_cansleep() when a GPIO controller doesn't provide a get() callback: Unable to handle kernel paging request for instruction fetch Faulting instruction address: 0x00000000 Oops: Kernel access of bad area, sig: 11 [#1] [...] NIP [00000000] 0x0 LR [c0182fb0] gpio_get_value_cansleep+0x40/0x50 Call Trace: [c7b79e80] [c0183f28] gpio_value_show+0x5c/0x94 [c7b79ea0] [c01a584c] dev_attr_show+0x30/0x7c [c7b79eb0] [c00d6b48] fill_read_buffer+0x68/0xe0 [c7b79ed0] [c00d6c54] sysfs_read_file+0x94/0xbc [c7b79ef0] [c008f24c] vfs_read+0xb4/0x16c [c7b79f10] [c008f580] sys_read+0x4c/0x90 [c7b79f40] [c0013a14] ret_from_syscall+0x0/0x38 It's OK to request the value of *any* GPIO; most GPIOs are bidirectional, so configuring them as outputs just enables an output driver and doesn't disable the input logic. So the problem is that gpio_get_value_cansleep() isn't making the same sanity check that gpio_get_value() does: making sure this GPIO isn't one of the atypical "no input logic" cases. Reported-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-22Linux 2.6.25.19v2.6.25.19Greg Kroah-Hartman
2008-10-22security: avoid calling a NULL function pointer in drivers/video/tvaudio.cArjan van de Ven
commit 5ba2f67afb02c5302b2898949ed6fc3b3d37dcf1 upstream NULL function pointers are very bad security wise. This one got caught by kerneloops.org quite a few times, so it's happening in the field.... Fix is simple, check the function pointer for NULL, like 6 other places in the same function are already doing. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-22x86: work around MTRR mask setting, v2Ingo Molnar
commit 9754a5b840a209bc1f192d59f63e81b698a55ac8 upstream improve the debug printout: - make it actually display something - print it only once would be nice to have a WARN_ONCE() facility, to feed such things to kerneloops.org. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: S.Çağlar Onur <caglar@pardus.org.tr> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-22drm/i915: fix ioremap of a user address for non-root (CVE-2008-3831)Matthias Hopf
commit 4b40893918203ee1a1f6a114316c2a19c072e9bd upstream Olaf Kirch noticed that the i915_set_status_page() function of the i915 kernel driver calls ioremap with an address offset that is supplied by userspace via ioctl. The function zeroes the mapped memory via memset and tells the hardware about the address. Turns out that access to that ioctl is not restricted to root so users could probably exploit that to do nasty things. We haven't tried to write actual exploit code though. It only affects the Intel G33 series and newer. Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-22V4L: zr36067: Fix RGBR pixel formatJean Delvare
(cherry picked from commit a30ee3c747728f9151664118ffcbdeefd202c332) The zr36067 driver is improperly declaring pixel format RGBP twice, once as "16-bit RGB LE" and once as "16-bit RGB BE". The latter is actually RGBR. Fix the code to properly map both pixel formats. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-22V4L: bttv: Prevent NULL pointer dereference in radio_openJean Delvare
cherry picked from commit c37396c19403e249f12626187d51e92c915f2bc9 Fix the following crash in the bttv driver: BUG: unable to handle kernel NULL pointer dereference at 000000000000036c IP: [<ffffffffa037860a>] radio_open+0x3a/0x170 [bttv] This happens because radio_open assumes that all present bttv devices have a radio function. If a bttv device without radio and one with radio are installed on the same system, and the one without radio is registered first, then radio_open checks for the radio device number of a bttv device that has no radio function, and this breaks. All we have to do to fix it is to skip bttv devices without a radio function. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-22Don't allow splice() to files opened with O_APPENDLinus Torvalds
commit efc968d450e013049a662d22727cf132618dcb2f upstream This is debatable, but while we're debating it, let's disallow the combination of splice and an O_APPEND destination. It's not entirely clear what the semantics of O_APPEND should be, and POSIX apparently expects pwrite() to ignore O_APPEND, for example. So we could make up any semantics we want, including the old ones. But Miklos convinced me that we should at least give it some thought, and that accepting writes at arbitrary offsets is wrong at least for IS_APPEND() files (which always have O_APPEND set, even if the reverse isn't true: you can obviously have O_APPEND set on a regular file). So disallow O_APPEND entirely for now. I doubt anybody cares, and this way we have one less gray area to worry about. Reported-and-argued-for-by: Miklos Szeredi <miklos@szeredi.hu> Acked-by: Jens Axboe <ens.axboe@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-22hwmon: (it87) Prevent power-off on Shuttle SN68PTJean Delvare
based on commit 98dd22c3e086d76058083432d4d8fb85f04bab90 upstream On the Shuttle SN68PT, FAN_CTL2 is apparently not connected to a fan, but to something else. One user has reported instant system power-off when changing the PWM2 duty cycle, so we disable it. I use the board name string as the trigger in case the same board is ever used in other systems. This closes lm-sensors ticket #2349: pwmconfig causes a hard poweroff http://www.lm-sensors.org/ticket/2349 Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-22fbcon_set_all_vcs: fix kernel crash when switching the rotated consolesOleg Nesterov
commit 232fb69a53a5ec3f22a8104d447abe4806848a8f upstream echo 3 >> /sys/class/graphics/fbcon/rotate_all, then switch to another console. Result: BUG: unable to handle kernel paging request at ffffc20005d00000 IP: [bitfill_aligned+149/265] bitfill_aligned+0x95/0x109 PGD 7e228067 PUD 7e229067 PMD 7bc1f067 PTE 0 Oops: 0002 [1] SMP CPU 1 Modules linked in: [...a lot...] Pid: 10, comm: events/1 Not tainted 2.6.26.5-45.fc9.x86_64 #1 RIP: 0010:[bitfill_aligned+149/265] [bitfill_aligned+149/265] bitfill_aligned+0x95/0x109 RSP: 0018:ffff81007d811bc8 EFLAGS: 00010216 RAX: ffffc20005d00000 RBX: 0000000000000000 RCX: 0000000000000400 RDX: 0000000000000000 RSI: ffffc20005d00000 RDI: ffffffffffffffff RBP: ffff81007d811be0 R08: 0000000000000400 R09: 0000000000000040 R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000010000 R13: ffffffff811632f0 R14: 0000000000000006 R15: ffff81007cb85400 FS: 0000000000000000(0000) GS:ffff81007e004780(0000) knlGS:0000000000000000 CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b CR2: ffffc20005d00000 CR3: 0000000000201000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process events/1 (pid: 10, threadinfo ffff81007d810000, task ffff81007d808000) Stack: ffff81007c9d75a0 0000000000000000 0000000000000000 ffff81007d811c80 ffffffff81163a61 ffff810000000000 ffffffff8115f9c8 0000001000000000 0000000100aaaaaa 000000007cd0d4a0 fffffd8a00000800 0001000000000000 Call Trace: [cfb_fillrect+523/798] cfb_fillrect+0x20b/0x31e [soft_cursor+416/436] ? soft_cursor+0x1a0/0x1b4 [ccw_clear_margins+205/263] ccw_clear_margins+0xcd/0x107 [fbcon_clear_margins+59/61] fbcon_clear_margins+0x3b/0x3d [fbcon_switch+1291/1466] fbcon_switch+0x50b/0x5ba [redraw_screen+261/481] redraw_screen+0x105/0x1e1 [ccw_cursor+0/1869] ? ccw_cursor+0x0/0x74d [complete_change_console+48/190] complete_change_console+0x30/0xbe [change_console+115/120] change_console+0x73/0x78 [console_callback+0/292] ? console_callback+0x0/0x124 [console_callback+97/292] console_callback+0x61/0x124 [schedule_delayed_work+25/30] ? schedule_delayed_work+0x19/0x1e [run_workqueue+139/282] run_workqueue+0x8b/0x11a [worker_thread+221/238] worker_thread+0xdd/0xee [autoremove_wake_function+0/56] ? autoremove_wake_function+0x0/0x38 [worker_thread+0/238] ? worker_thread+0x0/0xee [kthread+73/118] kthread+0x49/0x76 [child_rip+10/18] child_rip+0xa/0x12 [kthread+0/118] ? kthread+0x0/0x76 [child_rip+0/18] ? child_rip+0x0/0x12 Because fbcon_set_all_vcs()->FBCON_SWAP() uses display->rotate == 0 instead of fbcon_ops->rotate, and vc_resize() has no effect because it is called with new_cols/rows == ->vc_cols/rows. Tested on 2.6.26.5-45.fc9.x86_64, but http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git seems to have the same problem. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-22b43legacy: Fix failure in rate-adjustment mechanismLarry Finger
commit c6a2afdacccd56cc0be8e9a7977f0ed1509069f6 upstream Date: Sat, 6 Sep 2008 16:51:22 -0500 Subject: b43legacy: Fix failure in rate-adjustment mechanism A coding error present since b43legacy was incorporated into the kernel has prevented the driver from using the rate-setting mechanism of mac80211. The driver has been forced to remain at a 1 Mb/s rate. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-22CIFS: make sure we have the right resume info before calling CIFSFindNextSteve French
commit 0752f1522a9120f731232919f7ad904e9e22b8ce upstream When we do a seekdir() or equivalent, we usually end up doing a FindFirst call and then call FindNext until we get to the offset that we want. The problem is that when we call FindNext, the code usually doesn't have the proper info (mostly, the filename of the entry from the last search) to resume the search. Add a "last_entry" field to the cifs_search_info that points to the last entry in the search. We calculate this pointer by using the LastNameOffset field from the search parms that are returned. We then use that info to do a cifs_save_resume_key before we call CIFSFindNext. This patch allows CIFS to reliably pass the "telldir" connectathon test. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-22sched_rt.c: resch needed in rt_rq_enqueue() for the root rt_rqDario Faggioli
commit f6121f4f8708195e88cbdf8dd8d171b226b3f858 upstream While working on the new version of the code for SCHED_SPORADIC I noticed something strange in the present throttling mechanism. More specifically in the throttling timer handler in sched_rt.c (do_sched_rt_period_timer()) and in rt_rq_enqueue(). The problem is that, when unthrottling a runqueue, rt_rq_enqueue() only asks for rescheduling if the runqueue has a sched_entity associated to it (i.e., rt_rq->rt_se != NULL). Now, if the runqueue is the root rq (which has a rt_se = NULL) rescheduling does not take place, and it is delayed to some undefined instant in the future. This imply some random bandwidth usage by the RT tasks under throttling. For instance, setting rt_runtime_us/rt_period_us = 950ms/1000ms an RT task will get less than 95%. In our tests we got something varying between 70% to 95%. Using smaller time values, e.g., 95ms/100ms, things are even worse, and I can see values also going down to 20-25%!! The tests we performed are simply running 'yes' as a SCHED_FIFO task, and checking the CPU usage with top, but we can investigate thoroughly if you think it is needed. Things go much better, for us, with the attached patch... Don't know if it is the best approach, but it solved the issue for us. Signed-off-by: Dario Faggioli <raistlin@linux.it> Signed-off-by: Michael Trimarchi <trimarchimichael@yahoo.it> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-22tty: Termios locking - sort out real_tty confusions and lock readsAlan Cox
commit 8f520021837d45c47d0ab57e7271f8d88bf7f3a4 upstream (only the tty_io.c portion of this commit) This moves us towards sanity and should mean our termios locking is now complete and comprehensive. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-22x86, early_ioremap: fix fencepost errorAlan Cox
commit c613ec1a7ff3714da11c7c48a13bab03beb5c376 upstream The x86 implementation of early_ioremap has an off by one error. If we get an object which ends on the first byte of a page we undermap by one page and this causes a crash on boot with the ASUS P5QL whose DMI table happens to fit this alignment. The size computation is currently last_addr = phys_addr + size - 1; npages = (PAGE_ALIGN(last_addr) - phys_addr) (Consider a request for 1 byte at alignment 0...) Closes #11693 Debugging work by Ian Campbell/Felix Geyer Signed-off-by: Alan Cox <alan@rehat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-22x86: improve UP kernel when CPU-hotplug and SMP is enabledThomas Gleixner
commit 649c6653fa94ec8f3ea32b19c97b790ec4e8e4ac upstream num_possible_cpus() can be > 1 when disabled CPUs have been accounted. Disabled CPUs are not in the cpu_present_map, so we can use num_present_cpus() as a safe indicator to switch to UP alternatives. Reported-by: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-22x86: Reserve FIRST_DEVICE_VECTOR in used_vectors bitmap.Stefan Bader
Not in upstream above 2.6.27 due to change in the way this code works (has been fixed differently there.) Someone from the community found out, that after repeatedly unloading and loading a device driver that uses MSI IRQs, the system eventually assigned the vector initially reserved for IRQ0 to the device driver. The reason for this is, that although IRQ0 is tied to the FIRST_DEVICE_VECTOR when declaring the irq_vector table, the corresponding bit in the used_vectors map is not set. So, if vectors are released and assigned often enough, the vector will get assigned to another interrupt. This happens more often with MSI interrupts as those are exclusively using a vector. Fix this by setting the bit for the FIRST_DEVICE_VECTOR in the bitmap. Signed-off-by: Stefan Bader <stefan.bader@canonical.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-08Linux 2.6.25.18v2.6.25.18Greg Kroah-Hartman
2008-10-08udp: Fix rcv socket lockingHerbert Xu
[ Upstream commits d97106ea52aa57e63ff40d04479016836bbb5a4e and 93821778def10ec1e69aa3ac10adee975dad4ff3 ] The previous patch in response to the recursive locking on IPsec reception is broken as it tries to drop the BH socket lock while in user context. This patch fixes it by shrinking the section protected by the socket lock to sock_queue_rcv_skb only. The only reason we added the lock is for the accounting which happens in that function. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-08sctp: Fix oops when INIT-ACK indicates that peer doesn't support AUTHVlad Yasevich
[ Upstream commit add52379dde2e5300e2d574b172e62c6cf43b3d3 ] If INIT-ACK is received with SupportedExtensions parameter which indicates that the peer does not support AUTH, the packet will be silently ignore, and sctp_process_init() do cleanup all of the transports in the association. When T1-Init timer is expires, OOPS happen while we try to choose a different init transport. The solution is to only clean up the non-active transports, i.e the ones that the peer added. However, that introduces a problem with sctp_connectx(), because we don't mark the proper state for the transports provided by the user. So, we'll simply mark user-provided transports as ACTIVE. That will allow INIT retransmissions to work properly in the sctp_connectx() context and prevent the crash. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-08sctp: do not enable peer features if we can't do them.Vlad Yasevich
[ Upstream commit 0ef46e285c062cbe35d60c0adbff96f530d31c86 ] Do not enable peer features like addip and auth, if they are administratively disabled localy. If the peer resports that he supports something that we don't, neither end can use it so enabling it is pointless. This solves a problem when talking to a peer that has auth and addip enabled while we do not. Found by Andrei Pelinescu-Onciul <andrei@iptel.org>. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-08netlink: fix overrun in attribute iterationVegard Nossum
[ Upstream commit 1045b03e07d85f3545118510a587035536030c1c ] kmemcheck reported this: kmemcheck: Caught 16-bit read from uninitialized memory (f6c1ba30) 0500110001508abf050010000500000002017300140000006f72672e66726565 i i i i i i i i i i i i i u u u u u u u u u u u u u u u u u u u ^ Pid: 3462, comm: wpa_supplicant Not tainted (2.6.27-rc3-00054-g6397ab9-dirty #13) EIP: 0060:[<c05de64a>] EFLAGS: 00010296 CPU: 0 EIP is at nla_parse+0x5a/0xf0 EAX: 00000008 EBX: fffffffd ECX: c06f16c0 EDX: 00000005 ESI: 00000010 EDI: f6c1ba30 EBP: f6367c6c ESP: c0a11e88 DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 CR0: 8005003b CR2: f781cc84 CR3: 3632f000 CR4: 000006d0 DR0: c0ead9bc DR1: 00000000 DR2: 00000000 DR3: 00000000 DR6: ffff4ff0 DR7: 00000400 [<c05d4b23>] rtnl_setlink+0x63/0x130 [<c05d5f75>] rtnetlink_rcv_msg+0x165/0x200 [<c05ddf66>] netlink_rcv_skb+0x76/0xa0 [<c05d5dfe>] rtnetlink_rcv+0x1e/0x30 [<c05dda21>] netlink_unicast+0x281/0x290 [<c05ddbe9>] netlink_sendmsg+0x1b9/0x2b0 [<c05beef2>] sock_sendmsg+0xd2/0x100 [<c05bf945>] sys_sendto+0xa5/0xd0 [<c05bf9a6>] sys_send+0x36/0x40 [<c05c03d6>] sys_socketcall+0x1e6/0x2c0 [<c020353b>] sysenter_do_call+0x12/0x3f [<ffffffff>] 0xffffffff This is the line in nla_ok(): /** * nla_ok - check if the netlink attribute fits into the remaining bytes * @nla: netlink attribute * @remaining: number of bytes remaining in attribute stream */ static inline int nla_ok(const struct nlattr *nla, int remaining) { return remaining >= sizeof(*nla) && nla->nla_len >= sizeof(*nla) && nla->nla_len <= remaining; } It turns out that remaining can become negative due to alignment in nla_next(). But GCC promotes "remaining" to unsigned in the test against sizeof(*nla) above. Therefore the test succeeds, and the nla_for_each_attr() may access memory outside the received buffer. A short example illustrating this point is here: #include <stdio.h> main(void) { printf("%d\n", -1 >= sizeof(int)); } ...which prints "1". This patch adds a cast in front of the sizeof so that GCC will make a signed comparison and fix the illegal memory dereference. With the patch applied, there is no kmemcheck report. Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com> Acked-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-08niu: panic on resetSantwona Behera
[ Upstream commit cff502a38394fd33693f6233e03fca363dfa956d ] The reset_task function in the niu driver does not reset the tx and rx buffers properly. This leads to panic on reset. This patch is a modified implementation of the previously posted fix. Signed-off-by: Santwona Behera <santwona.behera@sun.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-08ipv6: Fix OOPS in ip6_dst_lookup_tail().Neil Horman
[ Upstream commit e550dfb0c2c31b6363aa463a035fc9f8dcaa3c9b ] This fixes kernel bugzilla 11469: "TUN with 1024 neighbours: ip6_dst_lookup_tail NULL crash" dst->neighbour is not necessarily hooked up at this point in the processing path, so blindly dereferencing it is the wrong thing to do. This NULL check exists in other similar paths and this case was just an oversight. Also fix the completely wrong and confusing indentation here while we're at it. Based upon a patch by Evgeniy Polyakov. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-08x86: Fix broken LDT access in VMIZachary Amsden
commit de59985e3a623d4d5d6207f1777398ca0606ab1c upstream After investigating a JRE failure, I found this bug was introduced a long time ago, and had already managed to survive another bugfix which occurred on the same line. The result is a total failure of the JRE due to LDT selectors not working properly. This one took a long time to rear up because LDT usage is not very common, but the bug is quite serious. It got introduced along with another bug, already fixed, by 75b8bb3e56ca09a467fbbe5229bc68627f7445be Signed-off-by: Zachary Amsden <zach@vmware.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-08clockevents: remove WARN_ON which was used to gather informationThomas Gleixner
commit 61c22c34c6f80a8e89cff5ff717627c54cc14fd4 upstream The issue of the endless reprogramming loop due to a too small min_delta_ns was fixed with the previous updates of the clock events code, but we had no information about the spread of this problem. I added a WARN_ON to get automated information via kerneloops.org and to get some direct reports, which allowed me to analyse the affected machines. The WARN_ON has served its purpose and would be annoying for a release kernel. Remove it and just keep the information about the increase of the min_delta_ns value. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-08ntp: fix calculation of the next jiffie to trigger RTC syncMaciej W. Rozycki
commit 4ff4b9e19a80b73959ebeb28d1df40176686f0a8 upstream We have a bug in the calculation of the next jiffie to trigger the RTC synchronisation. The aim here is to run sync_cmos_clock() as close as possible to the middle of a second. Which means we want this function to be called less than or equal to half a jiffie away from when now.tv_nsec equals 5e8 (500000000). If this is not the case for a given call to the function, for this purpose instead of updating the RTC we calculate the offset in nanoseconds to the next point in time where now.tv_nsec will be equal 5e8. The calculated offset is then converted to jiffies as these are the unit used by the timer. Hovewer timespec_to_jiffies() used here uses a ceil()-type rounding mode, where the resulting value is rounded up. As a result the range of now.tv_nsec when the timer will trigger is from 5e8 to 5e8 + TICK_NSEC rather than the desired 5e8 - TICK_NSEC / 2 to 5e8 + TICK_NSEC / 2. As a result if for example sync_cmos_clock() happens to be called at the time when now.tv_nsec is between 5e8 + TICK_NSEC / 2 and 5e8 to 5e8 + TICK_NSEC, it will simply be rescheduled HZ jiffies later, falling in the same range of now.tv_nsec again. Similarly for cases offsetted by an integer multiple of TICK_NSEC. This change addresses the problem by subtracting TICK_NSEC / 2 from the nanosecond offset to the next point in time where now.tv_nsec will be equal 5e8, effectively shifting the following rounding in timespec_to_jiffies() so that it produces a rounded-to-nearest result. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-08x86: HPET: read back compare register before reading counterThomas Gleixner
commit 72d43d9bc9210d24d09202eaf219eac09e17b339 upstream After fixing the u32 thinko I sill had occasional hickups on ATI chipsets with small deltas. There seems to be a delay between writing the compare register and the transffer to the internal register which triggers the interrupt. Reading back the value makes sure, that it hit the internal match register befor we compare against the counter value. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-08x86: HPET fix moronic 32/64bit thinkoThomas Gleixner
commit f7676254f179eac6b5244a80195ec8ae0e9d4606 upstream We use the HPET only in 32bit mode because: 1) some HPETs are 32bit only 2) on i386 there is no way to read/write the HPET atomic 64bit wide The HPET code unification done by the "moron of the year" did not take into account that unsigned long is different on 32 and 64 bit. This thinko results in a possible endless loop in the clockevents code, when the return comparison fails due to the 64bit/332bit unawareness. unsigned long cnt = (u32) hpet_read() + delta can wrap over 32bit. but the final compare will fail and return -ETIME causing endless loops. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-08clockevents: broadcast fixup possible waitersThomas Gleixner
commit 7300711e8c6824fcfbd42a126980ff50439d8dd0 upstream Until the C1E patches arrived there where no users of periodic broadcast before switching to oneshot mode. Now we need to trigger a possible waiter for a periodic broadcast when switching to oneshot mode. Otherwise we can starve them for ever. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-08HPET: make minimum reprogramming delta usefulThomas Gleixner
commit 7cfb0435330364f90f274a26ecdc5f47f738498c upstream The minimum reprogramming delta was hardcoded in HPET ticks, which is stupid as it does not work with faster running HPETs. The C1E idle patches made this prominent on AMD/RS690 chipsets, where the HPET runs with 25MHz. Set it to 5us which seems to be a reasonable value and fixes the problems on the bug reporters machines. We have a further sanity check now in the clock events, which increases the delta when it is not sufficient. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Luiz Fernando N. Capitulino <lcapitulino@mandriva.com.br> Tested-by: Dmitry Nezhevenko <dion@inhex.net> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-08clockevents: prevent endless loop lockupThomas Gleixner
commit 1fb9b7d29d8e85ba3196eaa7ab871bf76fc98d36 upstream The C1E/HPET bug reports on AMDX2/RS690 systems where tracked down to a too small value of the HPET minumum delta for programming an event. The clockevents code needs to enforce an interrupt event on the clock event device in some cases. The enforcement code was stupid and naive, as it just added the minimum delta to the current time and tried to reprogram the device. When the minimum delta is too small, then this loops forever. Add a sanity check. Allow reprogramming to fail 3 times, then print a warning and double the minimum delta value to make sure, that this does not happen again. Use the same function for both tick-oneshot and tick-broadcast code. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-08clockevents: prevent multiple init/shutdownThomas Gleixner
commit 9c17bcda991000351cb2373f78be7e4b1c44caa3 upstream While chasing the C1E/HPET bugreports I went through the clock events code inch by inch and found that the broadcast device can be initialized and shutdown multiple times. Multiple shutdowns are not critical, but useless waste of time. Multiple initializations are simply broken. Another CPU might have the device in use already after the first initialization and the second init could just render it unusable again. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-08clockevents: enforce reprogram in oneshot setupThomas Gleixner
commit 7205656ab48da29a95d7f55e43a81db755d3cb3a upstream In tick_oneshot_setup we program the device to the given next_event, but we do not check the return value. We need to make sure that the device is programmed enforced so the interrupt handler engine starts working. Split out the reprogramming function from tick_program_event() and call it with the device, which was handed in to tick_setup_oneshot(). Set the force argument, so the devices is firing an interrupt. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
